AM6548: dmsc: Mbox timedout in resp
Part Number: AM6548
Other Parts Discussed in Thread: TMDSLCD1EVM
we have a problem with Linux booting:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.41-g4c2eade9f7 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the1
[    0.000000] Machine model: Texas Instruments AM654 Base Board
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a20fffff]
[    0.000000]   node   0: [mem 0x00000000a2100000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[    0.000000] Kernel command line: earlycon=ns16550a,mmio32,0x02800000 console=serial2,115200n8 root=PARTUUID=30dc3d02-5517-48f1-8952-b0fae62afcfc rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3514240K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 155776K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008800d0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800e0000
[    0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000005] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008659] Console: colour dummy device 80x25
[    0.013280] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.024005] pid_max: default: 32768 minimum: 301
[    0.028848] LSM: Security Framework initializing
[    0.033665] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.041276] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.051848] rcu: Hierarchical SRCU implementation.
[    0.057220] Platform MSI: msi-controller@1820000 domain created
[    0.063622] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.073023] EFI services will not be available.
[    0.078142] smp: Bringing up secondary CPUs ...
[    0.084018] Detected VIPT I-cache on CPU1
[    0.084064] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.084080] GICv3: CPU1: using allocated LPI pending table @0x00000008800f0000
[    0.084150] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.085559] Detected VIPT I-cache on CPU2
[    0.085603] GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000
[    0.085620] GICv3: CPU2: using allocated LPI pending table @0x0000000880100000
[    0.085693] CPU2: Booted secondary processor 0x0000000100 [0x410fd034]
[    0.087035] Detected VIPT I-cache on CPU3
[    0.087068] GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000
[    0.087083] GICv3: CPU3: using allocated LPI pending table @0x0000000880110000
[    0.087138] CPU3: Booted secondary processor 0x0000000101 [0x410fd034]
[    0.087306] smp: Brought up 1 node, 4 CPUs
[    0.167709] SMP: Total of 4 processors activated.
[    0.172549] CPU features: detected: 32-bit EL0 Support
[    0.177844] CPU features: detected: CRC32 instructions
[    0.198597] CPU: All CPU(s) started at EL2
[    0.202843] alternatives: patching kernel code
[    0.209125] devtmpfs: initialized
[    0.223388] KASLR disabled due to lack of seed
[    0.228428] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.238452] futex hash table entries: 1024 (order: 0, 65536 bytes, linear)
[    0.247230] pinctrl core: initialized pinctrl subsystem
[    0.253264] DMI not present or invalid.
[    0.258048] NET: Registered protocol family 16
[    0.270662] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.278153] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.286318] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.295123] thermal_sys: Registered thermal governor 'step_wise'
[    0.295130] thermal_sys: Registered thermal governor 'power_allocator'
[    0.301988] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.315836] ASID allocator initialised with 65536 entries
[    0.363451] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.370379] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.377203] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.387550] cryptd: max_cpu_qlen set to 1000
[    0.397487] k3-chipinfo 43000014.chipid: Family:AM65X rev:SR2.0 JTAGID[0x1bb5a02f] Detected
[    0.406917] vcc3v3_io: supplied by evm_12v0
[    0.412345] iommu: Default domain type: Translated
[    0.418003] SCSI subsystem initialized
[    0.422545] mc: Linux media interface: v0.10
[    0.427001] videodev: Linux video capture interface: v2.00
[    0.432732] pps_core: LinuxPPS API ver. 1 registered
[    0.437838] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.447235] PTP clock support registered
[    0.451300] EDAC MC: Ver: 3.0.0
[    0.455898] FPGA manager framework
[    0.459515] Advanced Linux Sound Architecture Driver Initialized.
[    0.466974] clocksource: Switched to clocksource arch_sys_counter
[    0.473788] VFS: Disk quotas dquot_6.6.0
[    0.477937] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.492955] NET: Registered protocol family 2
[    0.497786] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[    0.508000] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.516984] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.525450] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.533611] TCP: Hash tables configured (established 32768 bind 32768)
[    0.540553] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.547560] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.555219] NET: Registered protocol family 1
[    0.560534] RPC: Registered named UNIX socket transport module.
[    0.566646] RPC: Registered udp transport module.
[    0.571479] RPC: Registered tcp transport module.
[    0.576309] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.582928] PCI: CLS 0 bytes, default 64
[    0.588167] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.602815] Initialise system trusted keyrings
[    0.607629] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.620209] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.626937] NFS: Registering the id_resolver key type
[    0.632168] Key type id_resolver registered
[    0.636467] Key type id_legacy registered
[    0.640669] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.647553] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.655345] 9p: Installing v9fs 9p2000 file system support
[    0.713451] Key type asymmetric registered
[    0.717672] Asymmetric key parser 'x509' registered
[    0.722727] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.730329] io scheduler mq-deadline registered
[    0.734981] io scheduler kyber registered
[    0.741890] pinctrl-single 4301c000.pinctrl: 70 pins, size 280
[    0.748508] pinctrl-single 11c000.pinctrl: 185 pins, size 740
[    0.754576] pinctrl-single 11c2e8.pinctrl: 9 pins, size 36
[    0.767035] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.773410] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.784185] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.810091] brd: module loaded
[    0.822256] loop: module loaded
[    0.826443] megasas: 07.714.04.00-rc1
[    0.833782] libphy: Fixed MDIO Bus: probed
[    0.839557] tun: Universal TUN/TAP device driver, 1.6
[    0.845571] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.852015] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.858150] sky2: driver version 1.30
[    0.863237] VFIO - User Level meta-driver version: 0.3
[    0.869628] i2c /dev entries driver
[    0.874822] sdhci: Secure Digital Host Controller Interface driver
[    0.881176] sdhci: Copyright(c) Pierre Ossman
[    0.886128] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.893514] ledtrig-cpu: registered to indicate activity on CPUs
[    0.899803] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource
[    0.907536] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.915690] optee: probing for conduit method.
[    0.920295] optee: revision 3.12 (3d47a131)
[    0.920912] optee: initialized driver
[    0.931674] NET: Registered protocol family 17
[    0.936415] 9pnet: Installing 9P2000 support
[    0.940877] Key type dns_resolver registered
[    0.945497] Loading compiled-in X.509 certificates
[    0.960915] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.967484] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.980360] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource
[   11.051051] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: Mbox timedout in resp(caller: platform_drv_probe+0x54/0xa8)
[   11.062380] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: Mbox send fail -110
[   11.070074] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: Unable to communicate with TISCI(-110)
[   11.079497] ti-sci: probe of bus@100000:bus@28380000:bus@42040000:dmsc failed with error -110
[   11.089940] omap_i2c 42120000.i2c: deferred probe timeout, ignoring dependency
[   11.097426] omap_i2c: probe of 42120000.i2c failed with error -110
[   11.104139] omap_i2c 40b00000.i2c: deferred probe timeout, ignoring dependency
[   11.111592] omap_i2c: probe of 40b00000.i2c failed with error -110
[   11.118301] omap_i2c 2000000.i2c: deferred probe timeout, ignoring dependency
[   11.125670] omap_i2c: probe of 2000000.i2c failed with error -110
[   11.132278] omap_i2c 2010000.i2c: deferred probe timeout, ignoring dependency
[   11.139641] omap_i2c: probe of 2010000.i2c failed with error -110
[   11.146264] omap_i2c 2020000.i2c: deferred probe timeout, ignoring dependency
[   11.153632] omap_i2c: probe of 2020000.i2c failed with error -110
[   11.160225] omap_i2c 2030000.i2c: deferred probe timeout, ignoring dependency
[   11.167583] omap_i2c: probe of 2030000.i2c failed with error -110
[   11.175904] ecap 3100000.pwm: deferred probe timeout, ignoring dependency
[   11.182919] ecap: probe of 3100000.pwm failed with error -110
[   11.189165] ehrpwm 3000000.pwm: deferred probe timeout, ignoring dependency
[   11.196346] ehrpwm: probe of 3000000.pwm failed with error -110
[   11.202738] ehrpwm 3010000.pwm: deferred probe timeout, ignoring dependency
[   11.209919] ehrpwm: probe of 3010000.pwm failed with error -110
[   11.216312] ehrpwm 3020000.pwm: deferred probe timeout, ignoring dependency
[   11.223490] ehrpwm: probe of 3020000.pwm failed with error -110
[   11.229883] ehrpwm 3030000.pwm: deferred probe timeout, ignoring dependency
[   11.237063] ehrpwm: probe of 3030000.pwm failed with error -110
[   11.243455] ehrpwm 3040000.pwm: deferred probe timeout, ignoring dependency
[   11.250615] ehrpwm: probe of 3040000.pwm failed with error -110
[   11.257008] ehrpwm 3050000.pwm: deferred probe timeout, ignoring dependency
[   11.264191] ehrpwm: probe of 3050000.pwm failed with error -110
[   11.271288] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[   11.277851] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[   11.284419] omap8250 40a00000.serial: deferred probe timeout, ignoring dependency
[   11.292135] omap8250: probe of 40a00000.serial failed with error -110
[   11.299075] omap8250 2800000.serial: deferred probe timeout, ignoring dependency
[   11.306692] omap8250: probe of 2800000.serial failed with error -110
[   11.313511] omap8250 2810000.serial: deferred probe timeout, ignoring dependency
[   11.321135] omap8250: probe of 2810000.serial failed with error -110
[   11.327929] omap8250 2820000.serial: deferred probe timeout, ignoring dependency
[   11.335553] omap8250: probe of 2820000.serial failed with error -110
[   11.342819] cadence-qspi 47050000.spi: deferred probe timeout, ignoring dependency
[   11.350627] cadence-qspi: probe of 47050000.spi failed with error -110
[   11.357668] omap2_mcspi 40300000.spi: deferred probe timeout, ignoring dependency
[   11.365382] omap2_mcspi: probe of 40300000.spi failed with error -110
[   11.372330] omap2_mcspi 40310000.spi: deferred probe timeout, ignoring dependency
[   11.380043] omap2_mcspi: probe of 40310000.spi failed with error -110
[   11.386999] omap2_mcspi 40320000.spi: deferred probe timeout, ignoring dependency
[   11.394707] omap2_mcspi: probe of 40320000.spi failed with error -110
[   11.401671] omap2_mcspi 2100000.spi: deferred probe timeout, ignoring dependency
[   11.409302] omap2_mcspi: probe of 2100000.spi failed with error -110
[   11.416457] omap2_mcspi 2120000.spi: deferred probe timeout, ignoring dependency
[   11.424085] omap2_mcspi: probe of 2120000.spi failed with error -110
[   11.430922] omap2_mcspi 2130000.spi: deferred probe timeout, ignoring dependency
[   11.438555] omap2_mcspi: probe of 2130000.spi failed with error -110
[   11.445414] omap2_mcspi 2140000.spi: deferred probe timeout, ignoring dependency
[   11.453040] omap2_mcspi: probe of 2140000.spi failed with error -110
[   11.459929] am65-cpsw-nuss 46000000.ethernet: deferred probe timeout, ignoring dependency
[   11.468368] am65-cpsw-nuss: probe of 46000000.ethernet failed with error -110
[   11.476268] k3-soc-thermal 42050000.temperature-sensor: deferred probe timeout, ignoring dependency
[   11.485589] k3-soc-thermal: probe of 42050000.temperature-sensor failed with error -110
[   11.494409] sdhci-am654 4f80000.mmc: deferred probe timeout, ignoring dependency
[   11.502043] sdhci-am654: probe of 4f80000.mmc failed with error -110
[   11.509497] sdhci-am654 4fa0000.mmc: deferred probe timeout, ignoring dependency
[   11.510016] ALSA device list:
[   11.517172] sdhci-am654: probe of 4fa0000.mmc failed with error -110
[   11.520194]   No soundcards found.
[   11.530280] Warning: unable to open an initial console.
[   11.535845] Waiting for root device PARTUUID=30dc3d02-5517-48f1-8952-b0fae62afcfc...
We use a custom board based on the EVM reference design.
We try to boot from prebuilt Image and dtb from these SDKs: psdk linux am65xx evm 08.00.00.04, psdk linux-rt am65xx evm 08.00.00.02, psdk linux-rt am65xx evm 07.03.00.08. Same things.
We use tiboot3, tispl and u-boot compiled with usbdfu config. sysfw.itb is taken from prebuilt.
  • Hi Roman,
    Can you share the complete boot logs starting from the first print of SPL. DMSC seems to be failing:
    What is the difference between the TI Evaluation board & your custom board?
    What is the boot mode used?
    - Keerthy
  • Thank you for your quick response!
    We took wrong sysfw (for sr1). Linux is now booting with correct one, but we got another problem (on custom board):
    [    0.888735] sdhci: Secure Digital Host Controller Interface driver
    [    0.895160] sdhci: Copyright(c) Pierre Ossman
    [    0.900361] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.907868] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource
    [    0.915586] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.923918] optee: probing for conduit method.
    [    0.928528] optee: revision 3.12 (3d47a131)
    [    0.929176] optee: initialized driver
    [    0.940114] NET: Registered protocol family 17
    [    0.944983] 9pnet: Installing 9P2000 support
    [    0.949552] Key type dns_resolver registered
    [    0.954314] printk: bootconsole [ns16550a0]: printing thread started
    [    0.954372] Loading compiled-in X.509 certificates
    [    0.966403] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.966728] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.974049] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource
    [    0.974541] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
    [    1.044476] random: fast init done
    [    1.052029] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.053408] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.055086] pca953x 2-0021: supply vcc not found, using dummy regulator
    [    1.055260] pca953x 2-0021: using no AI
    [    2.101041] omap_i2c 2000000.i2c: controller timed out
    [    2.101058] pca953x 2-0021: failed writing register
    [    2.101248] pca953x: probe of 2-0021 failed with error -110
    [    2.101402] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz
    [    2.125576] printk: console [ttyS2]: printing thread started
    [    2.102654] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
    [    2.125603] printk: console [ttyS2] enabled
    [    2.125610] printk: bootconsole [ns16550a0] disabled
    [    2.142632] printk: bootconsole [ns16550a0]: printing thread stopped
    [    2.143947] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 30, base_baud = 3000000) is a 8250
    [    2.144995] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 31, base_baud = 3000000) is a 8250
    [    2.201059] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.201087] libphy: 46000f00.mdio: probed
    [    2.201629] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
    [    2.201793] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00102, cpsw version 0x6BA80102 Ports: 2 quirks:00000000
    [    2.204623] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [    2.207133] mmc0: CQHCI version 5.10
    [    2.223577] pca953x 0-0039: supply vcc not found, using dummy regulator
    [    2.223778] pca953x 0-0039: using no AI
    [    2.246881] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    2.247472] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    2.248904] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    2.251177] ti-udma 285c0000.dma-controller: Channels: 28 (tchan: 14, rchan: 14, gp-rflow: 16)
    [    2.259138] ti-udma 31150000.dma-controller: Channels: 119 (tchan: 53, rchan: 66, gp-rflow: 64)
    [    2.273262] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
    [    2.285334] spi-nor spi9.0: n25q128a13 (16384 Kbytes)
    [    2.329046] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.329076] libphy: 46000f00.mdio: probed
    [    2.329552] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
    [    2.329695] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00102, cpsw version 0x6BA80102 Ports: 2 quirks:00000000
    [    2.331430] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.332376] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.332387] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.333696] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [    2.338136] mmc0: mmc_select_hs200 failed, error -110
    [    2.338159] mmc0: error -110 whilst initialising MMC card
    [    2.353906] vdd_mmc1_sd: supplied by vcc3v3_io
    [    2.355549] debugfs: Directory 'pd:121' with parent 'pm_genpd' already present!
    [    2.355616] debugfs: Directory 'pd:120' with parent 'pm_genpd' already present!
    [    2.355705] mmc1: CQHCI version 5.10
    [    2.361954] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    2.380050] ALSA device list:
    [    2.380060]   No soundcards found.
    [    2.478698] mmc0: mmc_select_hs200 failed, error -110
    [    2.478712] mmc0: error -110 whilst initialising MMC card
    [    2.603984] mmc0: mmc_select_hs200 failed, error -110
    [    2.603994] mmc0: error -110 whilst initialising MMC card
    [    2.771181] mmc0: mmc_select_hs200 failed, error -110
    [    2.771191] mmc0: error -110 whilst initialising MMC card
    [    3.274646] mmc1: SDHCI controller on 4fa0000.mmc [4fa0000.mmc] using ADMA 64-bit
    [    3.275266] Waiting for root device PARTUUID=30dc3d02-5517-48f1-8952-b0fae62afcfc...
    Our boot configuration is eMMC as primary and DFU as secondary boot sources. It works fine in U-boot.
    On our custom board: we removed FT4232 and overvoltage protection. We have empty serdes, csi interfaces and have some changes in the current-monitoring part. Also we use KSZ9031 PHYs instead DP83867.
    We just got EVM board and we got the second problem :)
    Linux boots fine on EVM but the display (on the TMDSLCD1EVM board) is too dim. We tried to change brightness in the /sys/class/backlight. Doesn't work. Prebuilt images from SDK 07 and 08 behave the same way.
    Also we have some errors during linux booting:
    [   12.399774] panel-simple display0: supply power not found, using dummy regulator
    [   12.400719] ------------[ cut here ]------------
    [   12.400726] WARNING: CPU: 2 PID: 80 at drivers/gpu/drm/panel/panel-simple.c:583 panel_simple_probe+0x254/0x3d0
    [   12.400752] Modules linked in:
    [   12.400763] CPU: 2 PID: 80 Comm: kworker/2:1 Not tainted 5.10.41-rt39-g0701a5b58c #1
    [   12.400774] Hardware name: Texas Instruments AM654 Base Board (DT)
    [   12.400784] Workqueue: events deferred_probe_work_func
    [   12.400799] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO BTYPE=--)
    [   12.400808] pc : panel_simple_probe+0x254/0x3d0
    [   12.400816] lr : panel_simple_probe+0x11c/0x3d0
    [   12.400824] sp : ffff80001161bac0
    [   12.400827] x29: ffff80001161bac0 x28: ffff800011029000
    [   12.400838] x27: ffff8000112fbcc8 x26: ffff00080036ff48
    [   12.400847] x25: ffff8000110f6fb8 x24: 0000000000000023
    [   12.400857] x23: ffff800010b16530 x22: ffff0008001de740
    [   12.400867] x21: ffff000800c2dc10 x20: ffff0008019d5480
    [   12.400876] x19: 0000000000000000 x18: 0000000000000000
    [   12.400885] x17: 0000000000000000 x16: 0000000000000001
    [   12.400894] x15: 00007097d70f68c6 x14: 0000000000000347
    [   12.400903] x13: 0000000000000342 x12: 0000000000000020
    [   12.400912] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
    [   12.400921] x9 : 6e6d1f39454e6f24 x8 : 7f7f7f7f7f7f7f7f
    [   12.400931] x7 : fefefeff666d686c x6 : 0000000080808080
    [   12.400940] x5 : ffff00087f7d3e90 x4 : 0000000000000000
    [   12.400948] x3 : 0000000000000007 x2 : 00000000ffffeff0
    [   12.400957] x1 : 00000000ffffefef x0 : 0000000000000000
    [   12.400967] Call trace:
    [   12.400971]  panel_simple_probe+0x254/0x3d0
    [   12.400979]  panel_simple_platform_probe+0x34/0x50
    [   12.400988]  platform_drv_probe+0x54/0xa8
    [   12.401001]  really_probe+0xe4/0x3b0
    [   12.401011]  driver_probe_device+0x58/0xb8
    [   12.401021]  __device_attach_driver+0x84/0xc8
    [   12.401031]  bus_for_each_drv+0x78/0xc8
    [   12.401041]  __device_attach+0xf0/0x150
    [   12.401050]  device_initial_probe+0x14/0x20
    [   12.401060]  bus_probe_device+0x9c/0xa8
    [   12.401069]  deferred_probe_work_func+0x88/0xc0
    [   12.401079]  process_one_work+0x1a0/0x328
    [   12.401094]  worker_thread+0x1f8/0x420
    [   12.401105]  kthread+0x174/0x198
    [   12.401114]  ret_from_fork+0x10/0x34
    [   12.401127] ---[ end trace 0000000000000002 ]---
    [   12.705751] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
    Thanks for the information. The original issue is resolved so please open a separate thread with the latest logs so that the module expert will
    be able to give inputs.
    Please click on verify answer.
    Keerthy
