Part Number: TDA4VM
Other Parts Discussed in Thread: DRA821
hi expert,
the linux cant start, it stop blow,could you help check why,thanks
40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 0
2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 820
printk: console [ttyS2] enabled
printk: bootconsole [ns16550a0] disabled
2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 820
2840000.serial: ttyS0 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 820
cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply red
cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulad
cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply reguld
cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regud
scsi host0: ufshcd
davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
libphy: 46000f00.mdio: probed
mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00100
mmc0: CQHCI version 5.10
davinci-mcasp 2ba0000.mcasp: IRQ common not found
omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: )
ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: )
spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
mtd: 47040000.spi.0: partitioning exceeds flash size, truncating
mtd: 47040000.spi.0: skipping zero sized partition
7 cmdlinepart partitions found on MTD device 47040000.spi.0
Creating 7 MTD partitions on "47040000.spi.0":
0x000000000000-0x000000080000 : "ospi.tiboot3"
0x000000080000-0x000000280000 : "ospi.tispl"
0x000000280000-0x000000680000 : "ospi.u-boot"
0x000000680000-0x0000006c0000 : "ospi.env"
0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
0x0000007c0000-0x000000800000 : "ospi.env.backup"
0x000000800000-0x000004000000 : "ospi.rootfs"
spi-nor spi1.0: mt25qu512a (65536 Kbytes)
am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
random: crng init done
mmc0: mmc_select_hs200 failed, error -110
mmc0: error -110 whilst initialising MMC card
cdns-ufshcd 4e84000.ufs: link startup failed 1
cdns-ufshcd 4e84000.ufs: UFS Host state=0
cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
cdns-ufshcd 4e84000.ufs: Clk gate=1
cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
cdns-ufshcd 4e84000.ufs: last intr at 2836047 us, last intr status=0x404
cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, 0
cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 00
host_regs: 00000000: 1587031f 00000000 00000210 00000000
host_regs: 00000010: 00000000 00000000 00000000 00000000
host_regs: 00000020: 00000000 00000470 00000000 00000000
host_regs: 00000030: 00000008 00000001 00000000 00000000
debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
host_regs: 00000040: 00000000 00000000 00000000 00000000
host_regs: 00000050: 00000000 00000000 00000000 00000000
host_regs: 00000060: 00000000 00000000 00000000 00000000
host_regs: 00000070: 00000000 00000000 00000000 00000000
host_regs: 00000080: 00000000 00000000 00000000 00000000
debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
host_regs: 00000090: 00000000 00000000 00000000 00000000
debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
cdns-ufshcd 4e84000.ufs: No record of pa_err
debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
cdns-ufshcd 4e84000.ufs: No record of dl_err
cdns-ufshcd 4e84000.ufs: No record of nl_err
printk: console [netcon0] enabled
cdns-ufshcd 4e84000.ufs: No record of tl_err
netconsole: network logging started
cdns-ufshcd 4e84000.ufs: No record of dme_err
input: gpio-keys as /devices/platform/gpio-keys/input/input0
cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
cdns-ufshcd 4e84000.ufs: No record of fatal_err
cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 2837182 us
cdns-ufshcd 4e84000.ufs: No record of resume_fail
cdns-ufshcd 4e84000.ufs: No record of suspend_fail
cdns-ufshcd 4e84000.ufs: No record of dev_reset
cdns-ufshcd 4e84000.ufs: No record of host_reset
cdns-ufshcd 4e84000.ufs: No record of task_abort
ALSA device list:
No soundcards found.
md: Waiting for all devices to be available before autodetect
md: If you don't use raid, use raid=noautodetect
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
Waiting for root device PARTUUID=28764f8d-02...
tlv71033: disabling
