Flashing Android Root File System to NAND - am3517evm
I am flashing the root file system to nand with am3517evm board, I start from mmc first, then in the shell command, do following.
[prompt]$ flash_eraseall –j /dev/mtd/mtd4
[prompt]$ mount t jffs2 /dev/block/mtdblock4 /media/nand
[prompt]$ cd /media/nand
[prompt]$ busybox tar xzf /home/root/rootfs_am35x.tar.gz
in the u-boot commands, I changed the nandargs by typing:
setenv nandargs 'setenv bootargs console=${console} root=/dev/mtdblock4 rw rootfstype=jffs2 init=/init'
saveenv
after reboot, the system stops at the android robot screen, and can't enter the android system.
on the serial console, it logs
input: Feeling-tech-USB product Feeling-tech-USB product as /devices/platform/ehci-omap.0/usb1/1-1/1-1.3/1-1.3:1.0/input/input1
generic-usb 0003:1D57:FA01.0001: input: USB HID v1.10 Keyboard [Feeling-tech-USB product Feeling-tech-USB product] on usb-ehci-omap.0-1.3/input0
Empty flash at 0x1c3759f8 ends at 0x1c376000
VFS: Mounted root (jffs2 filesystem) on device 31:4.
Freeing init memory: 172K
Warning: unable to open an initial console.
init: cannot find '/system/bin/playmp3', disabling 'bootsound'
sh: can't access tty; job control turned off
# enabling adb
adb_open
android_usb gadget: high speed config #1: android
JFFS2 notice: (838) check_node_data: wrong data CRC in data node at 0x02d70088: read 0xdf3cbc18, calculated 0xddaa66c4.
request_suspend_state: wakeup (3->0) at 123791046145 (2000-01-01 04:59:40.127746582 UTC)
init: untracked pid 839 exited
request_suspend_state: wakeup (0->0) at 134390258791 (2000-01-01 04:59:50.726959228 UTC)
init: untracked pid 912 exited
then the message such as "request_suspend_state: wakeup (3->0) at xxx init: untracked pid xxx exited"  shows up repeatedly.
on the Dalvik Debug Monitor, it logs
01-01 05:10:38.210: DEBUG/dalvikvm(2375): Stale deps in cache file; removing and retrying
01-01 05:10:38.414: INFO/(2374): ServiceManager: 0xad08
01-01 05:10:38.414: WARN/AudioHardwareInterface(2374): Using stubbed audio hardware. No sound will be produced.
01-01 05:10:38.414: DEBUG/AudioHardwareInterface(2374): setMode(NORMAL)
01-01 05:10:38.414: INFO/CameraService(2374): CameraService started: pid=2374
01-01 05:10:38.421: INFO/AudioFlinger(2374): AudioFlinger's thread 0xb370 ready to run
01-01 05:10:41.140: DEBUG/dalvikvm(2375): DexOpt: --- BEGIN 'core.jar' (bootstrap=1) ---
01-01 05:10:41.187: DEBUG/dalvikvm(2385): creating instr width table
01-01 05:10:41.187: ERROR/dalvikvm(2385): unable to mmap DEX cache: Invalid argument
01-01 05:10:41.187: ERROR/dalvikvm(2385): Optimization failed
01-01 05:10:41.187: WARN/dalvikvm(2375): DexOpt: --- END 'core.jar' --- status=0xff00, process failed
01-01 05:10:41.187: ERROR/dalvikvm(2375): Unable to extract+optimize DEX from '/system/framework/core.jar'
01-01 05:10:41.187: DEBUG/dalvikvm(2375): Unable to process classpath element '/system/framework/core.jar'
01-01 05:10:41.187: DEBUG/dalvikvm(2375): DexOpt: incorrect opt magic number (0xff ff ff ff)
01-01 05:10:41.187: DEBUG/dalvikvm(2375): Stale deps in cache file; removing and retrying
01-01 05:10:42.226: DEBUG/dalvikvm(2375): DexOpt: --- BEGIN 'ext.jar' (bootstrap=1) ---
01-01 05:10:42.265: DEBUG/dalvikvm(2386): creating instr width table
01-01 05:10:42.265: ERROR/dalvikvm(2386): unable to mmap DEX cache: Invalid argument
01-01 05:10:42.265: ERROR/dalvikvm(2386): Optimization failed
01-01 05:10:42.273: WARN/dalvikvm(2375): DexOpt: --- END 'ext.jar' --- status=0xff00, process failed
01-01 05:10:42.273: ERROR/dalvikvm(2375): Unable to extract+optimize DEX from '/system/framework/ext.jar'
01-01 05:10:42.273: DEBUG/dalvikvm(2375): Unable to process classpath element '/system/framework/ext.jar'
01-01 05:10:42.273: DEBUG/dalvikvm(2375): DexOpt: incorrect opt magic number (0xff ff ff ff)
01-01 05:10:42.273: DEBUG/dalvikvm(2375): Stale deps in cache file; removing and retrying
01-01 05:10:47.140: DEBUG/dalvikvm(2375): DexOpt: --- BEGIN 'framework.jar' (bootstrap=1) ---
01-01 05:10:47.187: DEBUG/dalvikvm(2393): creating instr width table
01-01 05:10:47.187: ERROR/dalvikvm(2393): unable to mmap DEX cache: Invalid argument
01-01 05:10:47.187: ERROR/dalvikvm(2393): Optimization failed
01-01 05:10:47.187: WARN/dalvikvm(2375): DexOpt: --- END 'framework.jar' --- status=0xff00, process failed
01-01 05:10:47.187: ERROR/dalvikvm(2375): Unable to extract+optimize DEX from '/system/framework/framework.jar'
01-01 05:10:47.187: DEBUG/dalvikvm(2375): Unable to process classpath element '/system/framework/framework.jar'
01-01 05:10:47.187: DEBUG/dalvikvm(2375): DexOpt: incorrect opt magic number (0xff ff ff ff)
01-01 05:10:47.187: DEBUG/dalvikvm(2375): Stale deps in cache file; removing and retrying
01-01 05:10:47.367: DEBUG/dalvikvm(2375): DexOpt: --- BEGIN 'android.policy.jar' (bootstrap=1) ---
01-01 05:10:47.414: DEBUG/dalvikvm(2394): creating instr width table
01-01 05:10:47.414: ERROR/dalvikvm(2394): unable to mmap DEX cache: Invalid argument
01-01 05:10:47.414: ERROR/dalvikvm(2394): Optimization failed
01-01 05:10:47.414: WARN/dalvikvm(2375): DexOpt: --- END 'android.policy.jar' --- status=0xff00, process failed
01-01 05:10:47.414: ERROR/dalvikvm(2375): Unable to extract+optimize DEX from '/system/framework/android.policy.jar'
01-01 05:10:47.414: DEBUG/dalvikvm(2375): Unable to process classpath element '/system/framework/android.policy.jar'
01-01 05:10:47.414: DEBUG/dalvikvm(2375): DexOpt: incorrect opt magic number (0xff ff ff ff)
01-01 05:10:47.414: DEBUG/dalvikvm(2375): Stale deps in cache file; removing and retrying
01-01 05:10:48.750: DEBUG/dalvikvm(2375): DexOpt: --- BEGIN 'services.jar' (bootstrap=1) ---
01-01 05:10:48.796: DEBUG/dalvikvm(2399): creating instr width table
01-01 05:10:48.796: ERROR/dalvikvm(2399): unable to mmap DEX cache: Invalid argument
01-01 05:10:48.796: ERROR/dalvikvm(2399): Optimization failed
01-01 05:10:48.796: WARN/dalvikvm(2375): DexOpt: --- END 'services.jar' --- status=0xff00, process failed
01-01 05:10:48.796: ERROR/dalvikvm(2375): Unable to extract+optimize DEX from '/system/framework/services.jar'
01-01 05:10:48.796: DEBUG/dalvikvm(2375): Unable to process classpath element '/system/framework/services.jar'
01-01 05:10:48.796: ERROR/dalvikvm(2375): ERROR: no valid entries found in bootclasspath '/system/framework/core.jar:/system/framework/ext.jar:/system/framework/framework.jar:/system/framework/android.policy.jar:/system/framework/services.jar'
01-01 05:10:48.796: DEBUG/dalvikvm(2375): VM cleaning up
01-01 05:10:48.796: DEBUG/dalvikvm(2375): LinearAlloc 0x0 used 4100 of 5242880 (0%)
01-01 05:10:48.796: WARN/dalvikvm(2375): JNI_CreateJavaVM failed
01-01 05:10:48.796: ERROR/AndroidRuntime(2375): JNI_CreateJavaVM failed
01-01 05:10:48.828: INFO/ServiceManager(833): service 'media.audio_flinger' died
01-01 05:10:48.828: INFO/ServiceManager(833): service 'media.player' died
01-01 05:10:48.828: INFO/ServiceManager(833): service 'media.camera' died
01-01 05:10:48.828: INFO/ServiceManager(833): service 'media.audio_policy' died
01-01 05:10:49.195: DEBUG/AndroidRuntime(2401): >>>>>>>>>>>>>> AndroidRuntime START <<<<<<<<<<<<<<
01-01 05:10:49.195: DEBUG/AndroidRuntime(2401): CheckJNI is ON
01-01 05:10:49.195: DEBUG/dalvikvm(2401): creating instr width table
01-01 05:10:49.195: DEBUG/dalvikvm(2401): DexOpt: incorrect opt magic number (0xff ff ff ff)
01-01 05:10:49.195: DEBUG/dalvikvm(2401): Stale deps in cache file; removing and retrying
01-01 05:10:49.460: INFO/(2400): ServiceManager: 0xad08
01-01 05:10:49.460: WARN/AudioHardwareInterface(2400): Using stubbed audio hardware. No sound will be produced.
01-01 05:10:49.460: DEBUG/AudioHardwareInterface(2400): setMode(NORMAL)
01-01 05:10:49.460: INFO/CameraService(2400): CameraService started: pid=2400
01-01 05:10:49.468: INFO/AudioFlinger(2400): AudioFlinger's thread 0xb370 ready to run
Process list:
USER     PID   PPID  VSIZE  RSS     WCHAN    PC         NAME
root      1     0     300    212   c00bc454 0000cc6c S /init
root      2     0     0      0     c006dec8 00000000 S kthreadd
root      3     2     0      0     c0060984 00000000 S ksoftirqd/0
root      4     2     0      0     c0084b14 00000000 S watchdog/0
root      5     2     0      0     c006aea8 00000000 S events/0
root      6     2     0      0     c006aea8 00000000 S khelper
root      10    2     0      0     c00734a0 00000000 S async/mgr
root      13    2     0      0     c006aea8 00000000 S suspend
root      213   2     0      0     c0099850 00000000 S sync_supers
root      215   2     0      0     c009a080 00000000 S bdi-default
root      217   2     0      0     c006aea8 00000000 S kblockd/0
root      229   2     0      0     c006aea8 00000000 S ksuspend_usbd
root      233   2     0      0     c02291d8 00000000 S khubd
root      236   2     0      0     c025b6bc 00000000 S kseriod
root      258   2     0      0     c006aea8 00000000 S kmmcd
root      275   2     0      0     c006aea8 00000000 S musb_hdrc
root      277   2     0      0     c006aea8 00000000 S rpciod/0
root      284   2     0      0     c0084d0c 00000000 S khungtaskd
root      285   2     0      0     c0094ef8 00000000 S kswapd0
root      287   2     0      0     c006aea8 00000000 S aio/0
root      288   2     0      0     c006aea8 00000000 S nfsiod
root      289   2     0      0     c006aea8 00000000 S crypto/0
root      437   2     0      0     c006aea8 00000000 S scsi_tgtd/0
root      444   2     0      0     c01f67ac 00000000 S mtdblockd
root      519   2     0      0     c006aea8 00000000 S kondemand/0
root      520   2     0      0     c006aea8 00000000 S kconservative/0
root      527   2     0      0     c006aea8 00000000 S usbhid_resumer
root      570   2     0      0     c01605c8 00000000 S jffs2_gcd_mtd4
root      831   1     700    324   c005e684 afe0d60c S /system/bin/sh
system    833   1     764    284   c02ab660 afe0c9dc S /system/bin/servicemanager
root      835   1     800    364   c00bc454 afe0cb04 S /system/bin/vold
root      836   1     628    256   c0303114 afe0d36c S /system/bin/debuggerd
root      837   1     1272   592   c007173c afe0d04c S /system/bin/rild
bluetooth 840   1     1068   516   c00bc454 afe0d7dc S /system/bin/dbus-daemon
root      841   1     756    272   c0303114 afe0d36c S /system/bin/installd
keystore  843   1     1600   408   c0303114 afe0d36c S /system/bin/keystore
root      845   1     4396   184   ffffffff 0000f444 S /sbin/adbd
root      1075  845   700    324   c01bc344 afe0c73c S /system/bin/sh
root      2706  845   700    324   c005e684 afe0d60c S /system/bin/sh
root      2709  2706  636    328   c02aef54 afe0c73c S logcat
root      3958  1     18044  3984  ffffffff afe0c9dc S /system/bin/mediaserver
root      3959  1     31500  2904  00000000 afe0c75c R zygote
root      3971  831   848    332   00000000 afe0c73c R ps
I am confused, I don't know what to do, it seems some processes start ok, but other processes generated by zygote is not working.
Does anyone know what is the problem, or can anybody give me any suggestions?
