TDA4VM: when use yuv sensor and capture csirx output picture, then find resolution is wrong
Part Number: TDA4VM
HI TI:
     now i find a problem,when use yuv sensor,  capture csirx output,i find the resolution is wrong. the res is 640*1280. but mosaic output is right,the right resolution is 1280*1285. please have a look, thanks very much!
4-1.zip
    Can you please provide correct resolution in the capture node?
    CSIRX module in itself cannot change the resolution, so it capture only configured size.. So please use correct size in the capture node..
    Brijesh
  • HI TI:
        capture node size has correct configured.but from capture image,the image is wrong.attached the uart log
    J7EVM@QNX:/ti_fs/vision_apps# ./run_app_multi_cam.sh
    APP: Init QNX ... !!!
    Sciclient_qnxVirtToPhyFxn:Error from mem_offset
    [xxx] disable ENABLE_IPC_MCU1_0 in qnx app
    appIpcInit: IPC: Init QNX ... !!!
    appIpcInit: IPC: Init ... Done !!!
    22.711994 s: REMOTE_SERVICE: Init ... !!!
    22.712116 s: REMOTE_SERVICE: Init ... Done !!!
    22.712144 s: GTC Frequency = 200 MHz
    APP: Init ... Done !!!
    22.712167 s: VX_ZONE_INIT:Enabled
    22.712179 s: VX_ZONE_ERROR:Enabled
    22.712191 s: VX_ZONE_WARNING:Enabled
    22.712380 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
    22.712412 s: VX_ZONE_INIT:[tivxHostInit:48] Initialization Done for HOST !!!
    22.713209 s: ISS: Enumerating sensors ... !!!
    22.713370 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
    22.713392 s: ISS: Enumerating sensors ... found 1 : UB9xxx_RAW12_TESTPATTERN
    22.713409 s: ISS: Enumerating sensors ... found 2 : UB96x_UYVY_TESTPATTERN
    22.713424 s: ISS: Enumerating sensors ... found 3 : GW_AR0233_UYVY
    4 sensor(s) found
    Supported sensor list:
    a : IMX390-UB953_D3
    b : UB9xxx_RAW12_TESTPATTERN
    c : UB96x_UYVY_TESTPATTERN
    d : GW_AR0233_UYVY
    Select a sensor above or press '0' to autodetect the sensor
    b
    Sensor selected : UB9xxx_RAW12_TESTPATTERN
    Querying UB9xxx_RAW12_TESTPATTERN
    23.777320 s: ISS: Querying sensor [UB9xxx_RAW12_TESTPATTERN] ... !!!
    23.777465 s: ISS: Querying sensor [UB9xxx_RAW12_TESTPATTERN] ... Done !!!
    ---sensorObj->sensor_out_format = 1---
    LDC Selection Yes(1)/No(0)
    Invalid selection
    . Try again
    1
    Max number of cameras supported by sensor UB9xxx_RAW12_TESTPATTERN = 4
    Please enter number of cameras to be enabled
    Invalid selection
    . Try again
    4
    WDR mode is not supported. Defaulting to linear
    Sensor DCC is enabled
    Sensor width = 1280
    Sensor height = 1285
    Sensor DCC ID = 9702
    Sensor Supported Features = 0x00000120
    Sensor Enabled Features = 0x00000120
    [xxx] app_multi_cam_main test
    sensor_out_format=1
    YUV Input selected. VISS, AEWB and Mosaic nodes will be bypassed.
    obj->sensorObj.image_width=1280
    obj->sensorObj.image_height=1285
    now set obj->sensorObj.image_width=1280
    now set obj->sensorObj.image_height=1280
    resized_width=1280,resized_height=1280,
    num_cameras_enabled=4
    numCh=4,grid_size is 2
    ----imgMosaicObj->params.windows[0].startX=0---
    ----imgMosaicObj->params.windows[0].startY=0---
    ----imgMosaicObj->params.windows[0].width=640
    ----imgMosaicObj->params.windows[0].height=640
    ----imgMosaicObj->params.windows[1].startX=640---
    ----imgMosaicObj->params.windows[1].startY=0---
    ----imgMosaicObj->params.windows[1].width=640
    ----imgMosaicObj->params.windows[1].height=640
    ----imgMosaicObj->params.windows[2].startX=0---
    ----imgMosaicObj->params.windows[2].startY=640---
    ----imgMosaicObj->params.windows[2].width=640
    ----imgMosaicObj->params.windows[2].height=640
    ----imgMosaicObj->params.windows[3].startX=640---
    ----imgMosaicObj->params.windows[3].startY=640---
    ----imgMosaicObj->params.windows[3].width=640
    ----imgMosaicObj->params.windows[3].height=640
    Creating context done!
    Kernel loading done!
    ---app_init_sensor----
    ---sensorObj->num_cameras_enabled=4---
    ---sensorObj->image_width=1280---
    ---sensorObj->image_height=1280---
    24.763159 s: ISS: Initializing sensor [UB9xxx_RAW12_TESTPATTERN], doing IM_SENSOR_CMD_PWRON ... !!!
    24.763393 s: ISS: ERROR: Initializing sensor [UB9xxx_RAW12_TESTPATTERN] failed !!!
    24.763415 s: ISS: Initializing sensor [UB9xxx_RAW12_TESTPATTERN] ... Done !!!
    Error initializing sensor UB9xxx_RAW12_TESTPATTERN
    Sensor init done!
    captureObj->params.numDataLanes = 4
    captureObj->params.dataLanesMap[0] = 1
    captureObj->params.dataLanesMap[1] = 2
    captureObj->params.dataLanesMap[2] = 3
    captureObj->params.dataLanesMap[3] = 4
    24.763696 s: VX_ZONE_ERROR:[vxCopyUserDataObject:429] wdp offset is 0,size is 208
    captureObj->capture_format is 1
    vx vxCreateImage UYVY width=1280,height=1285
    wdp bufq_depth is 4,num_cameras_enabled is 4
    24.900578 s: VX_ZONE_ERROR:[vxCopyUserDataObject:429] wdp offset is 0,size is 12
    24.900645 s: VX_ZONE_ERROR:[vxCopyUserDataObject:429] wdp offset is 0,size is 16
    24.900702 s: VX_ZONE_ERROR:[vxCopyUserDataObject:429] wdp offset is 0,size is 24
    ldcObj->table_width=1280----ldcObj->table_height=1280---
    LDC init done!
    24.900844 s: VX_ZONE_ERROR:[vxCopyUserDataObject:429] wdp offset is 0,size is 1428
    vxCreateImage NV12 imgMosaicObj->out_width=1280,height is 1280
    Img Mosaic init done!
    Display init done!
    App Init Done!
    Graph create done!
    Capture graph done!
    enable_ldc is 1
    LDC graph done!
    enable_mosaic is 1
    Img Mosaic graph done!
    Display graph done!
    App Create Graph Done!
    24.901391 s: VX_ZONE_ERROR:[vxCopyUserDataObject:429] wdp offset is 0,size is 24
    Graph verify done!
    App Verify Graph Done!
    App Send Error Frame Done!
    app_run_graph_interactive
    app_pipeline_params_defaults returned
    obj->test_mode is 0
    25.056968 s: ISS: Starting sensor [UB9xxx_RAW12_TESTPATTERN] ... !!!
    [MCU2_0] 25.450275 s: IssSensor_Start camera 0
    [MCU2_0] 25.450331 s: no need IssSensor_Start
    [MCU2_0] 25.451369 s: Error : sensor handle at channel Id 0 = NULL
    [MCU2_0] 25.451415 s: IssSensor_Start camera 1
    [MCU2_0] 25.451444 s: no need IssSensor_Start
    [MCU2_0] 25.452460 s: Error : sensor handle at channel Id 1 = NULL
    [MCU2_0] 25.452498 s: IssSensor_Start camera 2
    [MCU2_0] 25.452524 s: no need IssSensor_Start
    [MCU2_0] 25.453540 s: Error : sensor handle at channel Id 2 = NULL
    [MCU2_0] 25.453580 s: IssSensor_Start camera 3
    [MCU2_0] 25.453607 s: no need IssSensor_Start
    [MCU2_0] 25.454628 s: Error : sensor handle at channel Id 3 = NULL
    [MCU2_0] 25.493740 s: wdp now set all four port
    25.501608 s: ISS: Starting sensor [UB9xxx_RAW12_TESTPATTERN] ... !!!
    appStartImageSensor returned with status: 0
    wdp start frame is 0,num_frames is 1
    25.501676 s: VX_ZONE_ERROR:[vxCopyUserDataObject:429] wdp offset is 0,size is 12
    Capture node send command success!
    app_run_graph_for_one_pipeline: frame 0 beginning
    app_run_graph_for_one_pipeline: frame 1 beginning
    app_run_graph_for_one_pipeline: frame 2 beginning
    Demo : Camera Demo
    s: Save CSIx, VISS and LDC outputs
    p: Print performance statistics
    x: Exit
    Enter Choice:
    Demo : Camera Demo
    x: Exit
    Enter Choice: Writing /tmp/csix_raw_output_1280x1285_ch_0_00000000.bin ..
    Done!
    Writing /tmp/csix_raw_output_1280x1285_ch_1_00000000.bin ..
    Done!
    Writing /tmp/csix_raw_output_1280x1285_ch_2_00000000.bin ..
    Done!
    Writing /tmp/csix_raw_output_1280x1285_ch_3_00000000.bin ..
    Done!
    app_run_graph_for_one_pipeline: frame 3 beginning
    app_run_graph_for_one_pipeline: frame 4 beginning
    app_run_graph_for_one_pipeline: frame 5 beginning
    app_run_graph_for_one_pipeline: frame 6 beginning
    app_run_graph_for_one_pipeline: frame 7 beginning
    app_run_graph_for_one_pipeline: frame 8 beginning
    app_run_graph_for_one_pipeline: frame 9 beginning
    app_run_graph_for_one_pipeline: frame 10 beginning
    app_run_graph_for_one_pipeline: frame 11 beginning
    app_run_graph_for_one_pipeline: frame 12 beginning
    app_run_graph_for_one_pipeline: frame 13 beginning
    app_run_graph_for_one_pipeline: frame 14 beginning
    app_run_graph_for_one_pipeline: frame 15 beginning
    app_run_graph_for_one_pipeline: frame 16 beginning
    app_run_graph_for_one_pipeline: frame 17 beginning
    sapp_run_graph_for_one_pipeline: frame 18 beginning
    app_run_graph_for_one_pipeline: frame 19 beginning
    app_run_graph_for_one_pipeline: frame 20 beginning
    app_run_graph_for_one_pipeline: frame 21 beginning
    app_run_graph_for_one_pipeline: frame 22 beginning
    Demo : Camera Demo
    x: Exit
    Enter Choice:
    Demo : Camera Demo
    x: Exit
    Enter Choice: wdp start frame is 23,num_frames is 1
    26.835264 s: VX_ZONE_ERROR:[vxCopyUserDataObject:429] wdp offset is 0,size is 12
    app_run_graph_for_one_pipeline: frame 23 beginning
    app_run_graph_for_one_pipeline: frame 24 beginning
    app_run_graph_for_one_pipeline: frame 25 beginning
    Writing /tmp/csix_raw_output_1280x1285_ch_0_00000023.bin ..
    Done!
    Writing /tmp/csix_raw_output_1280x1285_ch_1_00000023.bin ..
    Done!
    Writing /tmp/csix_raw_output_1280x1285_ch_2_00000023.bin ..
    Done!
    Writing /tmp/csix_raw_output_1280x1285_ch_3_00000023.bin ..
    Done!
    app_run_graph_for_one_pipeline: frame 26 beginning
    app_run_graph_for_one_pipeline: frame 27 beginning
    app_run_graph_for_one_pipeline: frame 28 beginning
    app_run_graph_for_one_pipeline: frame 29 beginning
    app_run_graph_for_one_pipeline: frame 30 beginning
    app_run_graph_for_one_pipeline: frame 31 beginning
    app_run_graph_for_one_pipeline: frame 32 beginning
    xapp_run_graph_for_one_pipeline: frame 33 beginning
    app_run_graph_for_one_pipeline: frame 34 beginning
    app_run_graph_for_one_pipeline: frame 35 beginning
    app_run_graph_for_one_pipeline: frame 36 beginning
    27.511028 s: ISS: Stopping sensor [UB9xxx_RAW12_TESTPATTERN] ... !!!
    27.591153 s: ISS: Stopping sensor [UB9xxx_RAW12_TESTPATTERN] ... Done !!!
    App Run Graph Done!
    Capture delete done!
    VISS delete done!
    AEWB delete done!
    LDC delete done!
    Img Mosaic delete done!
    Display delete done!
    [MCU2_0] 27.629536 s: ==========================================================
    [MCU2_0] 27.629619 s: Capture Status: Instance|0
    [MCU2_0] 27.629662 s: ==========================================================
    [MCU2_0] 27.629699 s: overflowCount: 0
    [MCU2_0] 27.629746 s: spuriousUdmaIntrCount: 0
    [MCU2_0] 27.629776 s: frontFIFOOvflCount: 0
    [MCU2_0] 27.629800 s: crcCount: 1
    [MCU2_0] 27.629821 s: eccCount: 0
    [MCU2_0] 27.629843 s: correctedEccCount: 0
    [MCU2_0] 27.629868 s: dataIdErrorCount: 0
    [MCU2_0] 27.629893 s: invalidAccessCount: 0
    [MCU2_0] 27.629917 s: invalidSpCount: 0
    [MCU2_0] 27.629942 s: strmFIFOOvflCount[0]: 0
    [MCU2_0] 27.629969 s: strmFIFOOvflCount[1]: 0
    [MCU2_0] 27.629995 s: strmFIFOOvflCount[2]: 83
    [MCU2_0] 27.630021 s: strmFIFOOvflCount[3]: 18
    [MCU2_0] 27.630064 s: Channel Num | Frame Queue Count | Frame De-queue Count | Frame Drop Count | Error Frame Count |
    [MCU2_0] 27.630119 s: 0 | 39 | 39 | 2 | 0 |
    [MCU2_0] 27.630197 s: 1 | 39 | 39 | 2 | 0 |
    [MCU2_0] 27.630257 s: 2 | 39 | 39 | 2 | 0 |
    [MCU2_0] 27.630311 s: 3 | 39 | 39 | 2 | 0 |
    Graph delete done!
    App Delete Graph Done!
    27.632881 s: ISS: De-initializing sensor [UB9xxx_RAW12_TESTPATTERN] ... !!!
    27.633024 s: ISS: De-initializing sensor [UB9xxx_RAW12_TESTPATTERN] ... Done !!!
    Sensor deinit done!
    Capture deinit done!
    LDC deinit done!
    Img Mosaic deinit done!
    Display deinit done!
    Kernels unload done!
    Release context done!
    App De-init Done!
    27.638061 s: VX_ZONE_INIT:[tivxHostDeInit:56] De-Initialization Done for HOST !!!
    27.645842 s: VX_ZONE_INIT:[tivxDeInit:111] De-Initialization Done !!!
    APP: Deinit ... !!!
    27.645867 s: REMOTE_SERVICE: Deinit ... !!!
    27.645919 s: REMOTE_SERVICE: Deinit ... Done !!!
    IPC: Deinit ... !!!
    IPC: Deinit ... Done !!!
    APP: Deinit ... Done !!!
  • HI TI:
       from uart log it show
      so i think i have configured correct capture resolution.but from attach 4-1.zip,you can see csix_raw_output_1280x1285_ch_0_00000038.bin can't show the full picture.it is about quarter size.but mosaic_output_0000000075_1280x1288.yuv can see full size.
    It looks like half of the frame is getting cut, during dumping the frame. This is because only saved frame is incorrect, but the frame which goes to next component, most likely LDC and then mosaic, seems to be of correct size.. Can you please check your logic of saving frames?
    Brijesh
  • HI TI:
       yes,the first dump frame is csirx frame,and then ldc,the last mosaic. i dump csirx frame and mosaic frame in 4-1.zip.and i found mosaic dump is ok,but csirx frame is wrong. i doubt it is SDK7.3 problem. i can't find the reason, buffer malloc?buffer queue or storage format
    Which function prints "Writing /tmp/csix_raw_output_1280x1285_ch_3_00000023.bin ." statement? Can you please share this function? Essentially, i want to check the code which is writing the CSIRX output to a file..
    Brijesh
  • HI TI:
        i found the function is tivxKernelWriteImageProcess,attached the file. and the format is VX_DF_IMAGE_UYVY.
    * Copyright (c) 2020 Texas Instruments Incorporated
    * All rights reserved not granted herein.
    * Limited License.
    * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
    * license under copyrights and patents it now or hereafter owns or controls to make,
    * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
    * terms herein.  With respect to the foregoing patent license, such license is granted
    * solely to the extent that any such patent is necessary to Utilize the software alone.
    * The patent license shall not apply to any combinations which include this software,
    * other than combinations with devices manufactured by or for TI ("TI Devices").
    * No hardware patent is licensed hereunder.
    * Redistributions must preserve existing copyright notices and reproduce this license
    * (including the above copyright notice and the disclaimer and (if applicable) source
    * code license limitations below) in the documentation and/or other materials provided
    * with the distribution
    * Redistribution and use in binary form, without modification, are permitted provided
    * that the following conditions are met:
    * *       No reverse engineering, decompilation, or disassembly of this software is
    * permitted with respect to any software provided in binary form.
    * *       any redistribution and use are licensed by TI for use only with TI Devices.
    * *       Nothing shall obligate TI to provide you with source code for the software
    * licensed and provided to you in object code.
    * If software source code is provided to you, modification and redistribution of the
    * source code are permitted provided that the following conditions are met:
    * *       any redistribution and use of the source code, including any resulting derivative
    * works, are licensed by TI for use only with TI Devices.
    * *       any redistribution and use of any object code compiled from the source code
    * and any resulting derivative works, are licensed by TI for use only with TI Devices.
    * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
    * may be used to endorse or promote products derived from this software without
    * specific prior written permission.
    * DISCLAIMER.
    * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
    * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
    * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
    * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
    * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
    * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
    * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
    * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
    * OF THE POSSIBILITY OF SUCH DAMAGE.
    #include <stdio.h>
    #include <TI/tivx.h>
    #include <TI/j7.h>
    #include <TI/tivx_fileio.h>
    #include <TI/tivx_target_kernel.h>
    #include "tivx_kernels_target_utils.h"
    #include <tivx_fileio_write_image_host.h>
    #define WRITE_FILE_OUTPUT
    typedef struct {
        tivxFileIOWriteCmd cmd;
        vx_uint32 frame_counter;
        vx_uint32 skip_counter;
        vx_uint32 ch_num;
    } tivxWriteImageParams;
    static tivx_target_kernel vx_write_image_target_kernel = NULL;
    static vx_int32 inst_id = 0;
    static vx_status tivxKernelWriteImageCmd
        tivxWriteImageParams *prms,
        const tivx_obj_desc_user_data_object_t *usr_data_obj
        vx_status status = (vx_status)VX_SUCCESS;
        if (NULL != usr_data_obj)
            void  *target_ptr = tivxMemShared2TargetPtr(&usr_data_obj->mem_ptr);
            tivxMemBufferMap(target_ptr, usr_data_obj->mem_size,
                (vx_enum)VX_MEMORY_TYPE_HOST, (vx_enum)VX_READ_ONLY);
            if (sizeof(tivxFileIOWriteCmd) ==  usr_data_obj->mem_size)
                memcpy(&prms->cmd, target_ptr, sizeof(tivxFileIOWriteCmd));
            prms->skip_counter = 0;
            tivxMemBufferUnmap(target_ptr, usr_data_obj->mem_size,
        else
            VX_PRINT(VX_ZONE_ERROR,
                "tivxKernelWriteImageCmd: Data Object is NULL\n");
            status = (vx_status)VX_ERROR_INVALID_PARAMETERS;
        return (status);
    static vx_status VX_CALLBACK tivxKernelWriteImageControl
        tivx_target_kernel_instance kernel,
        uint32_t node_cmd_id,
        tivx_obj_desc_t *obj_desc[],
        uint16_t num_params,
        void *priv_arg
        vx_status status = VX_SUCCESS;
        tivxWriteImageParams *prms = NULL;
        if (NULL == obj_desc[TIVX_KERNEL_WRITE_IMAGE_INPUT_IDX])
            printf("Input Image handle is NULL!\n");
            status = VX_FAILURE;
        if(status==VX_SUCCESS)
            uint32_t size;
            status = tivxGetTargetKernelInstanceContext(kernel,
                (void **)&prms, &size);
            if ((VX_SUCCESS != status) || (NULL == prms) ||
                (sizeof(tivxWriteImageParams) != size))
        switch (node_cmd_id)
            case TIVX_FILEIO_CMD_SET_FILE_WRITE:
                tivxKernelWriteImageCmd(prms,
                    (tivx_obj_desc_user_data_object_t *)obj_desc[0U]);
                break;
            default:
                    "tivxKernelWriteImageControl: Invalid Command Id\n");
                status = (vx_status)VX_FAILURE;
                break;
        return (status);
    static vx_status VX_CALLBACK tivxKernelWriteImageCreate
      vx_uint16 num_params,
      void *priv_arg
      tivxWriteImageParams * prms = NULL;
      prms = tivxMemAlloc(sizeof(tivxWriteImageParams), TIVX_MEM_EXTERNAL);
      if(prms == NULL)
          printf("Unable to allcate memory for tivxWriteImageParams\n");
          return VX_FAILURE;
      prms->ch_num = inst_id;
      prms->frame_counter   = 0;
      prms->cmd.start_frame = -1;
      prms->cmd.num_frames  = 0;
      prms->cmd.num_skip    = 0;
      inst_id++;
      tivxSetTargetKernelInstanceContext(kernel, prms,  sizeof(tivxWriteImageParams));
      return(VX_SUCCESS);
    static vx_status VX_CALLBACK tivxKernelWriteImageDelete(
        tivx_target_kernel_instance kernel, tivx_obj_desc_t *obj_desc[],
        vx_uint16 num_params, void *priv_arg)
        if (VX_SUCCESS == status)
            uint32_t size;
            tivxMemFree(prms, sizeof(tivxWriteImageParams), TIVX_MEM_EXTERNAL);
        return (status);
    static vx_status VX_CALLBACK tivxKernelWriteImageProcess
        void *priv_arg
            uint32_t size;
            tivx_obj_desc_image_t *in_img_desc;
            void* in_img_target_ptr[2];
            tivx_obj_desc_array_t* file_path_desc;
            void * file_path_target_ptr = NULL;
            tivx_obj_desc_array_t* file_prefix_desc;
            void * file_prefix_target_ptr = NULL;
            in_img_desc  = (tivx_obj_desc_image_t *)obj_desc[TIVX_KERNEL_WRITE_IMAGE_INPUT_IDX];
            in_img_target_ptr[0]  = tivxMemShared2TargetPtr(&in_img_desc->mem_ptr[0]);
            tivxMemBufferMap(in_img_target_ptr[0], in_img_desc->mem_size[0], VX_MEMORY_TYPE_HOST, VX_READ_ONLY);
            in_img_target_ptr[1]  = NULL;
            if(in_img_desc->mem_ptr[1].shared_ptr != 0)
                in_img_target_ptr[1]  = tivxMemShared2TargetPtr(&in_img_desc->mem_ptr[1]);
                tivxMemBufferMap(in_img_target_ptr[1], in_img_desc->mem_size[1], VX_MEMORY_TYPE_HOST, VX_READ_ONLY);
            file_path_desc = (tivx_obj_desc_array_t *)obj_desc[TIVX_KERNEL_WRITE_IMAGE_FILE_PATH_IDX];
            if(file_path_desc != NULL)
                file_path_target_ptr = tivxMemShared2TargetPtr(&file_path_desc->mem_ptr);
                tivxMemBufferMap(file_path_target_ptr, file_path_desc->mem_size, VX_MEMORY_TYPE_HOST,VX_READ_ONLY);
            file_prefix_desc = (tivx_obj_desc_array_t *)obj_desc[TIVX_KERNEL_WRITE_IMAGE_FILE_PREFIX_IDX];
            if(file_prefix_desc != NULL)
                file_prefix_target_ptr = tivxMemShared2TargetPtr(&file_prefix_desc->mem_ptr);
                tivxMemBufferMap(file_prefix_target_ptr, file_prefix_desc->mem_size, VX_MEMORY_TYPE_HOST,VX_READ_ONLY);
            /* This helps in synchonizing frames across nodes */
            if(prms->frame_counter == prms->cmd.start_frame)
            if((prms->frame_counter >= prms->cmd.start_frame) &&
               (prms->frame_counter < (prms->cmd.start_frame + (prms->cmd.num_frames * (prms->cmd.num_skip + 1)))) &&
               (prms->skip_counter == 0))
                char file_path[TIVX_FILEIO_FILE_PATH_LENGTH];
                char file_prefix[TIVX_FILEIO_FILE_PREFIX_LENGTH];
                char file_name[TIVX_FILEIO_FILE_PATH_LENGTH * 2];
                strcpy(file_path, file_path_target_ptr);
                strcpy(file_prefix, file_prefix_target_ptr);
                sprintf(file_name, "%s/%s_%dx%d_ch_%d_%08d", file_path, file_prefix, in_img_desc->width, in_img_desc->height, prms->ch_num, prms->frame_counter);
                if(in_img_desc->format == VX_DF_IMAGE_NV12)
                    strcat(file_name, ".yuv");
                else if (in_img_desc->format == VX_DF_IMAGE_RGB)
                    strcat(file_name, ".rgb");
                else
                    strcat(file_name, ".bin");
                printf("Writing %s ..\n", file_name);
    	    printf("wdp it is image target\n");
    #ifdef WRITE_FILE_OUTPUT
                FILE *fp = fopen(file_name, "wb");
                if(fp == NULL)
                    printf("Unable to write file %s\n", file_name);
                else
                    uint32_t width  = in_img_desc->imagepatch_addr[0].dim_x;
                    uint32_t height = in_img_desc->imagepatch_addr[0].dim_y;
                    uint32_t stride = in_img_desc->imagepatch_addr[0].stride_y;
                    uint8_t *pData  = in_img_target_ptr[0];
                    int32_t i;
                    for(i = 0; i < height; i++)
                        fwrite(pData, 1, width, fp);
                        pData += stride;
                    if(in_img_target_ptr[1] != NULL)
                        pData = in_img_target_ptr[1];
                        height = height / 2;
                            pData += stride;
                    fflush(fp);
                    fclose(fp);
    #endif
                printf("Done!\n");
            prms->skip_counter++;
            prms->skip_counter = prms->skip_counter % (prms->cmd.num_skip + 1);
            prms->frame_counter++;
            tivxMemBufferUnmap(in_img_target_ptr[0], in_img_desc->mem_size[0], VX_MEMORY_TYPE_HOST, VX_READ_ONLY);
            if (in_img_target_ptr[1] != NULL){
              tivxMemBufferUnmap(in_img_target_ptr[1], in_img_desc->mem_size[1], VX_MEMORY_TYPE_HOST, VX_READ_ONLY);
            if(file_path_target_ptr != NULL)
                tivxMemBufferUnmap(file_path_target_ptr, file_path_desc->mem_size, VX_MEMORY_TYPE_HOST, VX_READ_ONLY);
            if(file_prefix_target_ptr != NULL)
                tivxMemBufferUnmap(file_prefix_target_ptr, file_prefix_desc->mem_size, VX_MEMORY_TYPE_HOST, VX_READ_ONLY);
        return (status);
    void tivxAddTargetKernelWriteImage()
        char target_name[TIVX_TARGET_MAX_NAME];
        vx_enum self_cpu;
        self_cpu = tivxGetSelfCpuId();
        if ((self_cpu == TIVX_CPU_ID_A72_0))
            strncpy(target_name, TIVX_TARGET_A72_0, TIVX_TARGET_MAX_NAME);
            vx_write_image_target_kernel = tivxAddTargetKernelByName
                                             TIVX_KERNEL_WRITE_IMAGE_NAME,
                                             target_name,
                                             tivxKernelWriteImageCreate,
                                             tivxKernelWriteImageDelete,
                                             tivxKernelWriteImageControl,
                                             NULL
    void tivxRemoveTargetKernelWriteImage()
        status = tivxRemoveTargetKernel(vx_write_image_target_kernel);
        if (status == VX_SUCCESS)
  • Hi wu dunpeng,
    I think i know what is the issue here.
    In the below code snippet, it is writing one line at a time, but the size used here is width. For YUV422 image, it must be width*2, otherwise, it would just write half of the captured image.
        pData += stride;
    Can you please make a small change in this function, as shown below, and try it out?
    uint32_t width = in_img_desc->imagepatch_addr[0].dim_x * in_img_desc->imagepatch_addr[0].stride_x;
    int32_t i;
        width = width * 3;
    else if ((in_img_desc->format == VX_DF_IMAGE_UYVY) || (in_img_desc->format == VX_DF_IMAGE_YUYV))
       width = width * 2;
    Brijesh
  • HI TI:
      it still has problem. the size is too large6012.zip
  • HI TI:
       now i only modify
      and  //height = height / 2;
    capture image ok. so i want to ask why need height = height / 2?
    No, i dont think by making height to half of what is actual will save the correct image.
    In your case,
    in_img_desc->imagepatch_addr[0].dim_x = 1280
    in_img_desc->imagepatch_addr[0].stride_x = 1
    height = 1285
    So you need to multiply width by 2, for yuv422 data..
    Brijesh
  • HI TI:
      i see in_img_desc->imagepatch_addr[0].stride_x = 2 from uart log.
      i doubt is
    pData += stride;
    height = height / 2; is not applicable for yuv sensor. so yuv sensor need't this.
    ok this is for the NV12 image. For NV12 images, there are two planes, one for luma and other for chroam and chroma height is half of luma height..
     As we can see, the condition is "if(in_img_target_ptr[1] != NULL)", which mean it is trying to save chroma plane..
    Brijesh
  • ok,question resolved.thanks very much
