TDA4VM: PTPS65941212RWERQ1sometimes has no output
Part Number: TDA4VM
Dear Expert,
      We tested the TDA4 by "power on--power off--power on--power of" cycles and found that sometimes the pmic(PTPS65941212RWERQ1) has no voltage output, failing to supply powers for TDA4. How could i do?
  • Hi Menghai,
    Can you please share some details? Is the board not powering up at all?
    Also, can you share what operations led to this failure?
    Parth
    The board is powered up but the PMIC lost the voltage output for TDA4. Even I added a dead-loop at the start point of main() function, this phenomenon still hanpped. So how to checked what happened in the PMIC?
  • Note the PMICs have safety features which will detect if residual voltage is present on the power rails, and if so - will detect as an error not not power up.  If power cycling quickly - this could be the issue.
