Hi sir,
I am Ramachandra ,
I am using Beagleboard-x15 with ti-processor-sdk-linux-am57xx-evm-06.01.00.08 and u-boot 2019.1 and Linux 4.19.59 using,
Actually Beagle board x-15 of p16 connector is connected our custom fpga board from fpga to rugged camera(1080p30) connected.(Beagle-->custom fpga(I2C3)-->camera)
From beagle board x15 we are able to communicating FPGA device through i2c3 and getting Device ID of FPGA.
Actually FPGA device i am taken like OV5640 device.
In DTS:
&vin3a { vin3a_ep: endpoint { remote-endpoint = <&cam>; slave-mode; }; }; &vip2 { status = "okay"; }; &i2c3 { status = "okay"; clock-frequency = <400000>; ov5640@3C { compatible = "ovti,ov5640"; reg = <0x3C>; clock-names = "xclk"; clock-frequency = <24000000>; port { cam: endpoint { bus-width = <16>; hsync-active = <1>; vsync-active = <1>; pclk-sample = <1>; remote-endpoint = <&vin3a_ep>; }; }; }; };
OV5640 code some changes i have done:
/* * Copyright (C) 2011-2013 Freescale Semiconductor, Inc. All Rights Reserved. * Copyright (C) 2014-2017 Mentor Graphics Inc. * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. */ #include <linux/clk.h> #include <linux/clk-provider.h> #include <linux/clkdev.h> #include <linux/ctype.h> #include <linux/delay.h> #include <linux/device.h> #include <linux/gpio/consumer.h> #include <linux/i2c.h> #include <linux/init.h> #include <linux/module.h> #include <linux/of_device.h> #include <linux/regulator/consumer.h> #include <linux/slab.h> #include <linux/types.h> #include <media/v4l2-async.h> #include <media/v4l2-ctrls.h> #include <media/v4l2-device.h> #include <media/v4l2-event.h> #include <media/v4l2-fwnode.h> #include <media/v4l2-subdev.h> /* min/typical/max system clock (xclk) frequencies */ #define OV5640_XCLK_MIN 6000000 #define OV5640_XCLK_MAX 74250000 #define OV5640_DEFAULT_SLAVE_ID 0x3c #define OV5640_REG_SYS_CARAVEL 0x3000 #define OV5640_REG_SYS_RESET02 0x3002 #define OV5640_REG_SYS_CLOCK_ENABLE02 0x3006 #define OV5640_REG_SYS_CTRL0 0x3008 #define OV5640_REG_CHIP_ID 0x300a #define OV5640_REG_IO_MIPI_CTRL00 0x300e #define OV5640_REG_PAD_OUTPUT_ENABLE01 0x3017 #define OV5640_REG_PAD_OUTPUT_ENABLE02 0x3018 #define OV5640_REG_PAD_OUTPUT00 0x3019 #define OV5640_REG_SYSTEM_CONTROL1 0x302e #define OV5640_REG_SC_PLL_CTRL0 0x3034 #define OV5640_REG_SC_PLL_CTRL1 0x3035 #define OV5640_REG_SC_PLL_CTRL2 0x3036 #define OV5640_REG_SC_PLL_CTRL3 0x3037 #define OV5640_REG_SLAVE_ID 0x3100 #define OV5640_REG_SCCB_SYS_CTRL1 0x3103 #define OV5640_REG_SYS_ROOT_DIVIDER 0x3108 #define OV5640_REG_AWB_R_GAIN 0x3400 #define OV5640_REG_AWB_G_GAIN 0x3402 #define OV5640_REG_AWB_B_GAIN 0x3404 #define OV5640_REG_AWB_MANUAL_CTRL 0x3406 #define OV5640_REG_AEC_PK_EXPOSURE_HI 0x3500 #define OV5640_REG_AEC_PK_EXPOSURE_MED 0x3501 #define OV5640_REG_AEC_PK_EXPOSURE_LO 0x3502 #define OV5640_REG_AEC_PK_MANUAL 0x3503 #define OV5640_REG_AEC_PK_REAL_GAIN 0x350a #define OV5640_REG_AEC_PK_VTS 0x350c #define OV5640_REG_TIMING_DVPHO 0x3808 #define OV5640_REG_TIMING_DVPVO 0x380a #define OV5640_REG_TIMING_HTS 0x380c #define OV5640_REG_TIMING_VTS 0x380e #define OV5640_REG_TIMING_TC_REG20 0x3820 #define OV5640_REG_TIMING_TC_REG21 0x3821 #define OV5640_REG_AEC_CTRL00 0x3a00 #define OV5640_REG_AEC_B50_STEP 0x3a08 #define OV5640_REG_AEC_B60_STEP 0x3a0a #define OV5640_REG_AEC_CTRL0D 0x3a0d #define OV5640_REG_AEC_CTRL0E 0x3a0e #define OV5640_REG_AEC_CTRL0F 0x3a0f #define OV5640_REG_AEC_CTRL10 0x3a10 #define OV5640_REG_AEC_CTRL11 0x3a11 #define OV5640_REG_AEC_CTRL1B 0x3a1b #define OV5640_REG_AEC_CTRL1E 0x3a1e #define OV5640_REG_AEC_CTRL1F 0x3a1f #define OV5640_REG_HZ5060_CTRL00 0x3c00 #define OV5640_REG_HZ5060_CTRL01 0x3c01 #define OV5640_REG_SIGMADELTA_CTRL0C 0x3c0c #define OV5640_REG_FRAME_CTRL01 0x4202 #define OV5640_REG_FORMAT_CONTROL00 0x4300 #define OV5640_REG_POLARITY_CTRL00 0x4740 #define OV5640_REG_MIPI_CTRL00 0x4800 #define OV5640_REG_DEBUG_MODE 0x4814 #define OV5640_REG_ISP_FORMAT_MUX_CTRL 0x501f #define OV5640_REG_PRE_ISP_TEST_SET1 0x503d #define OV5640_REG_SDE_CTRL0 0x5580 #define OV5640_REG_SDE_CTRL1 0x5581 #define OV5640_REG_SDE_CTRL3 0x5583 #define OV5640_REG_SDE_CTRL4 0x5584 #define OV5640_REG_SDE_CTRL5 0x5585 #define OV5640_REG_AVG_READOUT 0x56a1 enum ov5640_mode_id { OV5640_MODE_QCIF_176_144 = 0, OV5640_MODE_QVGA_320_240, OV5640_MODE_VGA_640_480, OV5640_MODE_NTSC_720_480, OV5640_MODE_PAL_720_576, OV5640_MODE_XGA_1024_768, OV5640_MODE_720P_1280_720, OV5640_MODE_1080P_1920_1080, OV5640_MODE_QSXGA_2592_1944, OV5640_NUM_MODES, }; enum ov5640_frame_rate { OV5640_15_FPS = 0, OV5640_30_FPS, OV5640_60_FPS, OV5640_NUM_FRAMERATES, }; struct ov5640_pixfmt { u32 code; u32 colorspace; }; static const struct ov5640_pixfmt ov5640_formats[] = { { MEDIA_BUS_FMT_JPEG_1X8, V4L2_COLORSPACE_JPEG, }, { MEDIA_BUS_FMT_UYVY8_2X8, V4L2_COLORSPACE_SRGB, }, { MEDIA_BUS_FMT_YUYV8_2X8, V4L2_COLORSPACE_SRGB, }, { MEDIA_BUS_FMT_RGB565_2X8_LE, V4L2_COLORSPACE_SRGB, }, { MEDIA_BUS_FMT_RGB565_2X8_BE, V4L2_COLORSPACE_SRGB, }, }; /* * FIXME: remove this when a subdev API becomes available * to set the MIPI CSI-2 virtual channel. */ static unsigned int virtual_channel; module_param(virtual_channel, uint, 0444); MODULE_PARM_DESC(virtual_channel, "MIPI CSI-2 virtual channel (0..3), default 0"); static const int ov5640_framerates[] = { [OV5640_15_FPS] = 15, [OV5640_30_FPS] = 30, [OV5640_60_FPS] = 60, }; /* regulator supplies */ static const char * const ov5640_supply_name[] = { "DOVDD", /* Digital I/O (1.8V) supply */ "DVDD", /* Digital Core (1.5V) supply */ "AVDD", /* Analog (2.8V) supply */ }; #define OV5640_NUM_SUPPLIES ARRAY_SIZE(ov5640_supply_name) /* * Image size under 1280 * 960 are SUBSAMPLING * Image size upper 1280 * 960 are SCALING */ enum ov5640_downsize_mode { SUBSAMPLING, SCALING, }; struct reg_value { u16 reg_addr; u8 val; u8 mask; u32 delay_ms; }; struct ov5640_mode_info { enum ov5640_mode_id id; enum ov5640_downsize_mode dn_mode; u32 hact; u32 htot; u32 vact; u32 vtot; const struct reg_value *reg_data; u32 reg_data_size; }; struct ov5640_ctrls { struct v4l2_ctrl_handler handler; struct { struct v4l2_ctrl *pixel_rate; }; struct { struct v4l2_ctrl *auto_exp; struct v4l2_ctrl *exposure; }; struct { struct v4l2_ctrl *auto_wb; struct v4l2_ctrl *blue_balance; struct v4l2_ctrl *red_balance; }; struct { struct v4l2_ctrl *auto_gain; struct v4l2_ctrl *gain; }; struct v4l2_ctrl *brightness; struct v4l2_ctrl *light_freq; struct v4l2_ctrl *saturation; struct v4l2_ctrl *contrast; struct v4l2_ctrl *hue; struct v4l2_ctrl *test_pattern; struct v4l2_ctrl *hflip; struct v4l2_ctrl *vflip; }; struct ov5640_dev { struct i2c_client *i2c_client; struct v4l2_subdev sd; struct media_pad pad; struct v4l2_fwnode_endpoint ep; /* the parsed DT endpoint info */ struct clk *xclk; /* system clock to OV5640 */ u32 xclk_freq; struct regulator_bulk_data supplies[OV5640_NUM_SUPPLIES]; struct gpio_desc *reset_gpio; struct gpio_desc *pwdn_gpio; bool upside_down; /* lock to protect all members below */ struct mutex lock; int power_count; struct v4l2_mbus_framefmt fmt; bool pending_fmt_change; const struct ov5640_mode_info *current_mode; const struct ov5640_mode_info *last_mode; enum ov5640_frame_rate current_fr; struct v4l2_fract frame_interval; u64 pixel_rate; struct ov5640_ctrls ctrls; u32 prev_sysclk, prev_hts; u32 ae_low, ae_high, ae_target; bool pending_mode_change; bool streaming; }; static inline struct ov5640_dev *to_ov5640_dev(struct v4l2_subdev *sd) { return container_of(sd, struct ov5640_dev, sd); } static inline struct v4l2_subdev *ctrl_to_sd(struct v4l2_ctrl *ctrl) { return &container_of(ctrl->handler, struct ov5640_dev, ctrls.handler)->sd; } /* * FIXME: all of these register tables are likely filled with * entries that set the register to their power-on default values, * and which are otherwise not touched by this driver. Those entries * should be identified and removed to speed register load time * over i2c. */ /* YUV422 UYVY VGA@30fps */ static const struct reg_value ov5640_init_setting_30fps_VGA[] = { {0x3103, 0x11, 0, 0}, {0x3008, 0x82, 0, 5}, {0x3008, 0x42, 0, 0}, {0x3103, 0x03, 0, 0}, {0x3017, 0x00, 0, 0}, {0x3018, 0x00, 0, 0}, {0x3630, 0x36, 0, 0}, {0x3631, 0x0e, 0, 0}, {0x3632, 0xe2, 0, 0}, {0x3633, 0x12, 0, 0}, {0x3621, 0xe0, 0, 0}, {0x3704, 0xa0, 0, 0}, {0x3703, 0x5a, 0, 0}, {0x3715, 0x78, 0, 0}, {0x3717, 0x01, 0, 0}, {0x370b, 0x60, 0, 0}, {0x3705, 0x1a, 0, 0}, {0x3905, 0x02, 0, 0}, {0x3906, 0x10, 0, 0}, {0x3901, 0x0a, 0, 0}, {0x3731, 0x12, 0, 0}, {0x3600, 0x08, 0, 0}, {0x3601, 0x33, 0, 0}, {0x302d, 0x60, 0, 0}, {0x3620, 0x52, 0, 0}, {0x371b, 0x20, 0, 0}, {0x471c, 0x50, 0, 0}, {0x3a13, 0x43, 0, 0}, {0x3a18, 0x00, 0, 0}, {0x3a19, 0xf8, 0, 0}, {0x3635, 0x13, 0, 0}, {0x3636, 0x03, 0, 0}, {0x3634, 0x40, 0, 0}, {0x3622, 0x01, 0, 0}, {0x3c01, 0xa4, 0, 0}, {0x3c04, 0x28, 0, 0}, {0x3c05, 0x98, 0, 0}, {0x3c06, 0x00, 0, 0}, {0x3c07, 0x08, 0, 0}, {0x3c08, 0x00, 0, 0}, {0x3c09, 0x1c, 0, 0}, {0x3c0a, 0x9c, 0, 0}, {0x3c0b, 0x40, 0, 0}, {0x3820, 0x41, 0, 0}, {0x3821, 0x07, 0, 0}, {0x3814, 0x31, 0, 0}, {0x3815, 0x31, 0, 0}, {0x3800, 0x00, 0, 0}, {0x3801, 0x00, 0, 0}, {0x3802, 0x00, 0, 0}, {0x3803, 0x04, 0, 0}, {0x3804, 0x0a, 0, 0}, {0x3805, 0x3f, 0, 0}, {0x3806, 0x07, 0, 0}, {0x3807, 0x9b, 0, 0}, {0x3810, 0x00, 0, 0}, {0x3811, 0x10, 0, 0}, {0x3812, 0x00, 0, 0}, {0x3813, 0x06, 0, 0}, {0x3618, 0x00, 0, 0}, {0x3612, 0x29, 0, 0}, {0x3708, 0x64, 0, 0}, {0x3709, 0x52, 0, 0}, {0x370c, 0x03, 0, 0}, {0x3a02, 0x03, 0, 0}, {0x3a03, 0xd8, 0, 0}, {0x3a08, 0x01, 0, 0}, {0x3a09, 0x27, 0, 0}, {0x3a0a, 0x00, 0, 0}, {0x3a0b, 0xf6, 0, 0}, {0x3a0e, 0x03, 0, 0}, {0x3a0d, 0x04, 0, 0}, {0x3a14, 0x03, 0, 0}, {0x3a15, 0xd8, 0, 0}, {0x4001, 0x02, 0, 0}, {0x4004, 0x02, 0, 0}, {0x3000, 0x00, 0, 0}, {0x3002, 0x1c, 0, 0}, {0x3004, 0xff, 0, 0}, {0x3006, 0xc3, 0, 0}, {0x302e, 0x08, 0, 0}, {0x4300, 0x3f, 0, 0}, {0x501f, 0x00, 0, 0}, {0x4713, 0x03, 0, 0}, {0x4407, 0x04, 0, 0}, {0x440e, 0x00, 0, 0}, {0x460b, 0x35, 0, 0}, {0x460c, 0x22, 0, 0}, {0x4837, 0x0a, 0, 0}, {0x3824, 0x02, 0, 0}, {0x5000, 0xa7, 0, 0}, {0x5001, 0xa3, 0, 0}, {0x5180, 0xff, 0, 0}, {0x5181, 0xf2, 0, 0}, {0x5182, 0x00, 0, 0}, {0x5183, 0x14, 0, 0}, {0x5184, 0x25, 0, 0}, {0x5185, 0x24, 0, 0}, {0x5186, 0x09, 0, 0}, {0x5187, 0x09, 0, 0}, {0x5188, 0x09, 0, 0}, {0x5189, 0x88, 0, 0}, {0x518a, 0x54, 0, 0}, {0x518b, 0xee, 0, 0}, {0x518c, 0xb2, 0, 0}, {0x518d, 0x50, 0, 0}, {0x518e, 0x34, 0, 0}, {0x518f, 0x6b, 0, 0}, {0x5190, 0x46, 0, 0}, {0x5191, 0xf8, 0, 0}, {0x5192, 0x04, 0, 0}, {0x5193, 0x70, 0, 0}, {0x5194, 0xf0, 0, 0}, {0x5195, 0xf0, 0, 0}, {0x5196, 0x03, 0, 0}, {0x5197, 0x01, 0, 0}, {0x5198, 0x04, 0, 0}, {0x5199, 0x6c, 0, 0}, {0x519a, 0x04, 0, 0}, {0x519b, 0x00, 0, 0}, {0x519c, 0x09, 0, 0}, {0x519d, 0x2b, 0, 0}, {0x519e, 0x38, 0, 0}, {0x5381, 0x1e, 0, 0}, {0x5382, 0x5b, 0, 0}, {0x5383, 0x08, 0, 0}, {0x5384, 0x0a, 0, 0}, {0x5385, 0x7e, 0, 0}, {0x5386, 0x88, 0, 0}, {0x5387, 0x7c, 0, 0}, {0x5388, 0x6c, 0, 0}, {0x5389, 0x10, 0, 0}, {0x538a, 0x01, 0, 0}, {0x538b, 0x98, 0, 0}, {0x5300, 0x08, 0, 0}, {0x5301, 0x30, 0, 0}, {0x5302, 0x10, 0, 0}, {0x5303, 0x00, 0, 0}, {0x5304, 0x08, 0, 0}, {0x5305, 0x30, 0, 0}, {0x5306, 0x08, 0, 0}, {0x5307, 0x16, 0, 0}, {0x5309, 0x08, 0, 0}, {0x530a, 0x30, 0, 0}, {0x530b, 0x04, 0, 0}, {0x530c, 0x06, 0, 0}, {0x5480, 0x01, 0, 0}, {0x5481, 0x08, 0, 0}, {0x5482, 0x14, 0, 0}, {0x5483, 0x28, 0, 0}, {0x5484, 0x51, 0, 0}, {0x5485, 0x65, 0, 0}, {0x5486, 0x71, 0, 0}, {0x5487, 0x7d, 0, 0}, {0x5488, 0x87, 0, 0}, {0x5489, 0x91, 0, 0}, {0x548a, 0x9a, 0, 0}, {0x548b, 0xaa, 0, 0}, {0x548c, 0xb8, 0, 0}, {0x548d, 0xcd, 0, 0}, {0x548e, 0xdd, 0, 0}, {0x548f, 0xea, 0, 0}, {0x5490, 0x1d, 0, 0}, {0x5580, 0x02, 0, 0}, {0x5583, 0x40, 0, 0}, {0x5584, 0x10, 0, 0}, {0x5589, 0x10, 0, 0}, {0x558a, 0x00, 0, 0}, {0x558b, 0xf8, 0, 0}, {0x5800, 0x23, 0, 0}, {0x5801, 0x14, 0, 0}, {0x5802, 0x0f, 0, 0}, {0x5803, 0x0f, 0, 0}, {0x5804, 0x12, 0, 0}, {0x5805, 0x26, 0, 0}, {0x5806, 0x0c, 0, 0}, {0x5807, 0x08, 0, 0}, {0x5808, 0x05, 0, 0}, {0x5809, 0x05, 0, 0}, {0x580a, 0x08, 0, 0}, {0x580b, 0x0d, 0, 0}, {0x580c, 0x08, 0, 0}, {0x580d, 0x03, 0, 0}, {0x580e, 0x00, 0, 0}, {0x580f, 0x00, 0, 0}, {0x5810, 0x03, 0, 0}, {0x5811, 0x09, 0, 0}, {0x5812, 0x07, 0, 0}, {0x5813, 0x03, 0, 0}, {0x5814, 0x00, 0, 0}, {0x5815, 0x01, 0, 0}, {0x5816, 0x03, 0, 0}, {0x5817, 0x08, 0, 0}, {0x5818, 0x0d, 0, 0}, {0x5819, 0x08, 0, 0}, {0x581a, 0x05, 0, 0}, {0x581b, 0x06, 0, 0}, {0x581c, 0x08, 0, 0}, {0x581d, 0x0e, 0, 0}, {0x581e, 0x29, 0, 0}, {0x581f, 0x17, 0, 0}, {0x5820, 0x11, 0, 0}, {0x5821, 0x11, 0, 0}, {0x5822, 0x15, 0, 0}, {0x5823, 0x28, 0, 0}, {0x5824, 0x46, 0, 0}, {0x5825, 0x26, 0, 0}, {0x5826, 0x08, 0, 0}, {0x5827, 0x26, 0, 0}, {0x5828, 0x64, 0, 0}, {0x5829, 0x26, 0, 0}, {0x582a, 0x24, 0, 0}, {0x582b, 0x22, 0, 0}, {0x582c, 0x24, 0, 0}, {0x582d, 0x24, 0, 0}, {0x582e, 0x06, 0, 0}, {0x582f, 0x22, 0, 0}, {0x5830, 0x40, 0, 0}, {0x5831, 0x42, 0, 0}, {0x5832, 0x24, 0, 0}, {0x5833, 0x26, 0, 0}, {0x5834, 0x24, 0, 0}, {0x5835, 0x22, 0, 0}, {0x5836, 0x22, 0, 0}, {0x5837, 0x26, 0, 0}, {0x5838, 0x44, 0, 0}, {0x5839, 0x24, 0, 0}, {0x583a, 0x26, 0, 0}, {0x583b, 0x28, 0, 0}, {0x583c, 0x42, 0, 0}, {0x583d, 0xce, 0, 0}, {0x5025, 0x00, 0, 0}, {0x3a0f, 0x30, 0, 0}, {0x3a10, 0x28, 0, 0}, {0x3a1b, 0x30, 0, 0}, {0x3a1e, 0x26, 0, 0}, {0x3a11, 0x60, 0, 0}, {0x3a1f, 0x14, 0, 0}, {0x3008, 0x02, 0, 0}, {0x3c00, 0x04, 0, 300}, }; static const struct reg_value ov5640_setting_VGA_640_480[] = { {0x3c07, 0x08, 0, 0}, {0x3c09, 0x1c, 0, 0}, {0x3c0a, 0x9c, 0, 0}, {0x3c0b, 0x40, 0, 0}, {0x3814, 0x31, 0, 0}, {0x3815, 0x31, 0, 0}, {0x3800, 0x00, 0, 0}, {0x3801, 0x00, 0, 0}, {0x3802, 0x00, 0, 0}, {0x3803, 0x04, 0, 0}, {0x3804, 0x0a, 0, 0}, {0x3805, 0x3f, 0, 0}, {0x3806, 0x07, 0, 0}, {0x3807, 0x9b, 0, 0}, {0x3810, 0x00, 0, 0}, {0x3811, 0x10, 0, 0}, {0x3812, 0x00, 0, 0}, {0x3813, 0x06, 0, 0}, {0x3618, 0x00, 0, 0}, {0x3612, 0x29, 0, 0}, {0x3708, 0x64, 0, 0}, {0x3709, 0x52, 0, 0}, {0x370c, 0x03, 0, 0}, {0x3a02, 0x03, 0, 0}, {0x3a03, 0xd8, 0, 0}, {0x3a08, 0x01, 0, 0}, {0x3a09, 0x27, 0, 0}, {0x3a0a, 0x00, 0, 0}, {0x3a0b, 0xf6, 0, 0}, {0x3a0e, 0x03, 0, 0}, {0x3a0d, 0x04, 0, 0}, {0x3a14, 0x03, 0, 0}, {0x3a15, 0xd8, 0, 0}, {0x4001, 0x02, 0, 0}, {0x4004, 0x02, 0, 0}, {0x4713, 0x03, 0, 0}, {0x4407, 0x04, 0, 0}, {0x460b, 0x35, 0, 0}, {0x460c, 0x22, 0, 0}, {0x3824, 0x02, 0, 0}, {0x5001, 0xa3, 0, 0}, }; static const struct reg_value ov5640_setting_XGA_1024_768[] = { {0x3c07, 0x08, 0, 0}, {0x3c09, 0x1c, 0, 0}, {0x3c0a, 0x9c, 0, 0}, {0x3c0b, 0x40, 0, 0}, {0x3814, 0x31, 0, 0}, {0x3815, 0x31, 0, 0}, {0x3800, 0x00, 0, 0}, {0x3801, 0x00, 0, 0}, {0x3802, 0x00, 0, 0}, {0x3803, 0x04, 0, 0}, {0x3804, 0x0a, 0, 0}, {0x3805, 0x3f, 0, 0}, {0x3806, 0x07, 0, 0}, {0x3807, 0x9b, 0, 0}, {0x3810, 0x00, 0, 0}, {0x3811, 0x10, 0, 0}, {0x3812, 0x00, 0, 0}, {0x3813, 0x06, 0, 0}, {0x3618, 0x00, 0, 0}, {0x3612, 0x29, 0, 0}, {0x3708, 0x64, 0, 0}, {0x3709, 0x52, 0, 0}, {0x370c, 0x03, 0, 0}, {0x3a02, 0x03, 0, 0}, {0x3a03, 0xd8, 0, 0}, {0x3a08, 0x01, 0, 0}, {0x3a09, 0x27, 0, 0}, {0x3a0a, 0x00, 0, 0}, {0x3a0b, 0xf6, 0, 0}, {0x3a0e, 0x03, 0, 0}, {0x3a0d, 0x04, 0, 0}, {0x3a14, 0x03, 0, 0}, {0x3a15, 0xd8, 0, 0}, {0x4001, 0x02, 0, 0}, {0x4004, 0x02, 0, 0}, {0x4713, 0x03, 0, 0}, {0x4407, 0x04, 0, 0}, {0x460b, 0x35, 0, 0}, {0x460c, 0x22, 0, 0}, {0x3824, 0x02, 0, 0}, {0x5001, 0xa3, 0, 0}, }; static const struct reg_value ov5640_setting_QVGA_320_240[] = { {0x3c07, 0x08, 0, 0}, {0x3c09, 0x1c, 0, 0}, {0x3c0a, 0x9c, 0, 0}, {0x3c0b, 0x40, 0, 0}, {0x3814, 0x31, 0, 0}, {0x3815, 0x31, 0, 0}, {0x3800, 0x00, 0, 0}, {0x3801, 0x00, 0, 0}, {0x3802, 0x00, 0, 0}, {0x3803, 0x04, 0, 0}, {0x3804, 0x0a, 0, 0}, {0x3805, 0x3f, 0, 0}, {0x3806, 0x07, 0, 0}, {0x3807, 0x9b, 0, 0}, {0x3810, 0x00, 0, 0}, {0x3811, 0x10, 0, 0}, {0x3812, 0x00, 0, 0}, {0x3813, 0x06, 0, 0}, {0x3618, 0x00, 0, 0}, {0x3612, 0x29, 0, 0}, {0x3708, 0x64, 0, 0}, {0x3709, 0x52, 0, 0}, {0x370c, 0x03, 0, 0}, {0x3a02, 0x03, 0, 0}, {0x3a03, 0xd8, 0, 0}, {0x3a08, 0x01, 0, 0}, {0x3a09, 0x27, 0, 0}, {0x3a0a, 0x00, 0, 0}, {0x3a0b, 0xf6, 0, 0}, {0x3a0e, 0x03, 0, 0}, {0x3a0d, 0x04, 0, 0}, {0x3a14, 0x03, 0, 0}, {0x3a15, 0xd8, 0, 0}, {0x4001, 0x02, 0, 0}, {0x4004, 0x02, 0, 0}, {0x4713, 0x03, 0, 0}, {0x4407, 0x04, 0, 0}, {0x460b, 0x35, 0, 0}, {0x460c, 0x22, 0, 0}, {0x3824, 0x02, 0, 0}, {0x5001, 0xa3, 0, 0}, }; static const struct reg_value ov5640_setting_QCIF_176_144[] = { {0x3c07, 0x08, 0, 0}, {0x3c09, 0x1c, 0, 0}, {0x3c0a, 0x9c, 0, 0}, {0x3c0b, 0x40, 0, 0}, {0x3814, 0x31, 0, 0}, {0x3815, 0x31, 0, 0}, {0x3800, 0x00, 0, 0}, {0x3801, 0x00, 0, 0}, {0x3802, 0x00, 0, 0}, {0x3803, 0x04, 0, 0}, {0x3804, 0x0a, 0, 0}, {0x3805, 0x3f, 0, 0}, {0x3806, 0x07, 0, 0}, {0x3807, 0x9b, 0, 0}, {0x3810, 0x00, 0, 0}, {0x3811, 0x10, 0, 0}, {0x3812, 0x00, 0, 0}, {0x3813, 0x06, 0, 0}, {0x3618, 0x00, 0, 0}, {0x3612, 0x29, 0, 0}, {0x3708, 0x64, 0, 0}, {0x3709, 0x52, 0, 0}, {0x370c, 0x03, 0, 0}, {0x3a02, 0x03, 0, 0}, {0x3a03, 0xd8, 0, 0}, {0x3a08, 0x01, 0, 0}, {0x3a09, 0x27, 0, 0}, {0x3a0a, 0x00, 0, 0}, {0x3a0b, 0xf6, 0, 0}, {0x3a0e, 0x03, 0, 0}, {0x3a0d, 0x04, 0, 0}, {0x3a14, 0x03, 0, 0}, {0x3a15, 0xd8, 0, 0}, {0x4001, 0x02, 0, 0}, {0x4004, 0x02, 0, 0}, {0x4713, 0x03, 0, 0}, {0x4407, 0x04, 0, 0}, {0x460b, 0x35, 0, 0}, {0x460c, 0x22, 0, 0}, {0x3824, 0x02, 0, 0}, {0x5001, 0xa3, 0, 0}, }; static const struct reg_value ov5640_setting_NTSC_720_480[] = { {0x3c07, 0x08, 0, 0}, {0x3c09, 0x1c, 0, 0}, {0x3c0a, 0x9c, 0, 0}, {0x3c0b, 0x40, 0, 0}, {0x3814, 0x31, 0, 0}, {0x3815, 0x31, 0, 0}, {0x3800, 0x00, 0, 0}, {0x3801, 0x00, 0, 0}, {0x3802, 0x00, 0, 0}, {0x3803, 0x04, 0, 0}, {0x3804, 0x0a, 0, 0}, {0x3805, 0x3f, 0, 0}, {0x3806, 0x07, 0, 0}, {0x3807, 0x9b, 0, 0}, {0x3810, 0x00, 0, 0}, {0x3811, 0x10, 0, 0}, {0x3812, 0x00, 0, 0}, {0x3813, 0x3c, 0, 0}, {0x3618, 0x00, 0, 0}, {0x3612, 0x29, 0, 0}, {0x3708, 0x64, 0, 0}, {0x3709, 0x52, 0, 0}, {0x370c, 0x03, 0, 0}, {0x3a02, 0x03, 0, 0}, {0x3a03, 0xd8, 0, 0}, {0x3a08, 0x01, 0, 0}, {0x3a09, 0x27, 0, 0}, {0x3a0a, 0x00, 0, 0}, {0x3a0b, 0xf6, 0, 0}, {0x3a0e, 0x03, 0, 0}, {0x3a0d, 0x04, 0, 0}, {0x3a14, 0x03, 0, 0}, {0x3a15, 0xd8, 0, 0}, {0x4001, 0x02, 0, 0}, {0x4004, 0x02, 0, 0}, {0x4713, 0x03, 0, 0}, {0x4407, 0x04, 0, 0}, {0x460b, 0x35, 0, 0}, {0x460c, 0x22, 0, 0}, {0x3824, 0x02, 0, 0}, {0x5001, 0xa3, 0, 0}, }; static const struct reg_value ov5640_setting_PAL_720_576[] = { {0x3c07, 0x08, 0, 0}, {0x3c09, 0x1c, 0, 0}, {0x3c0a, 0x9c, 0, 0}, {0x3c0b, 0x40, 0, 0}, {0x3814, 0x31, 0, 0}, {0x3815, 0x31, 0, 0}, {0x3800, 0x00, 0, 0}, {0x3801, 0x00, 0, 0}, {0x3802, 0x00, 0, 0}, {0x3803, 0x04, 0, 0}, {0x3804, 0x0a, 0, 0}, {0x3805, 0x3f, 0, 0}, {0x3806, 0x07, 0, 0}, {0x3807, 0x9b, 0, 0}, {0x3810, 0x00, 0, 0}, {0x3811, 0x38, 0, 0}, {0x3812, 0x00, 0, 0}, {0x3813, 0x06, 0, 0}, {0x3618, 0x00, 0, 0}, {0x3612, 0x29, 0, 0}, {0x3708, 0x64, 0, 0}, {0x3709, 0x52, 0, 0}, {0x370c, 0x03, 0, 0}, {0x3a02, 0x03, 0, 0}, {0x3a03, 0xd8, 0, 0}, {0x3a08, 0x01, 0, 0}, {0x3a09, 0x27, 0, 0}, {0x3a0a, 0x00, 0, 0}, {0x3a0b, 0xf6, 0, 0}, {0x3a0e, 0x03, 0, 0}, {0x3a0d, 0x04, 0, 0}, {0x3a14, 0x03, 0, 0}, {0x3a15, 0xd8, 0, 0}, {0x4001, 0x02, 0, 0}, {0x4004, 0x02, 0, 0}, {0x4713, 0x03, 0, 0}, {0x4407, 0x04, 0, 0}, {0x460b, 0x35, 0, 0}, {0x460c, 0x22, 0, 0}, {0x3824, 0x02, 0, 0}, {0x5001, 0xa3, 0, 0}, }; static const struct reg_value ov5640_setting_720P_1280_720[] = { {0x3c07, 0x07, 0, 0}, {0x3c09, 0x1c, 0, 0}, {0x3c0a, 0x9c, 0, 0}, {0x3c0b, 0x40, 0, 0}, {0x3814, 0x31, 0, 0}, {0x3815, 0x31, 0, 0}, {0x3800, 0x00, 0, 0}, {0x3801, 0x00, 0, 0}, {0x3802, 0x00, 0, 0}, {0x3803, 0xfa, 0, 0}, {0x3804, 0x0a, 0, 0}, {0x3805, 0x3f, 0, 0}, {0x3806, 0x06, 0, 0}, {0x3807, 0xa9, 0, 0}, {0x3810, 0x00, 0, 0}, {0x3811, 0x10, 0, 0}, {0x3812, 0x00, 0, 0}, {0x3813, 0x04, 0, 0}, {0x3618, 0x00, 0, 0}, {0x3612, 0x29, 0, 0}, {0x3708, 0x64, 0, 0}, {0x3709, 0x52, 0, 0}, {0x370c, 0x03, 0, 0}, {0x3a02, 0x02, 0, 0}, {0x3a03, 0xe4, 0, 0}, {0x3a08, 0x01, 0, 0}, {0x3a09, 0xbc, 0, 0}, {0x3a0a, 0x01, 0, 0}, {0x3a0b, 0x72, 0, 0}, {0x3a0e, 0x01, 0, 0}, {0x3a0d, 0x02, 0, 0}, {0x3a14, 0x02, 0, 0}, {0x3a15, 0xe4, 0, 0}, {0x4001, 0x02, 0, 0}, {0x4004, 0x02, 0, 0}, {0x4713, 0x03, 0, 0}, {0x4407, 0x04, 0, 0}, {0x460b, 0x37, 0, 0}, {0x460c, 0x20, 0, 0}, {0x3824, 0x04, 0, 0}, {0x5001, 0x83, 0, 0}, }; static const struct reg_value ov5640_setting_1080P_1920_1080[] = { {0x3c07, 0x08, 0, 0}, {0x3c09, 0x1c, 0, 0}, {0x3c0a, 0x9c, 0, 0}, {0x3c0b, 0x40, 0, 0}, {0x3814, 0x11, 0, 0}, {0x3815, 0x11, 0, 0}, {0x3800, 0x00, 0, 0}, {0x3801, 0x00, 0, 0}, {0x3802, 0x00, 0, 0}, {0x3803, 0x00, 0, 0}, {0x3804, 0x0a, 0, 0}, {0x3805, 0x3f, 0, 0}, {0x3806, 0x07, 0, 0}, {0x3807, 0x9f, 0, 0}, {0x3810, 0x00, 0, 0}, {0x3811, 0x10, 0, 0}, {0x3812, 0x00, 0, 0}, {0x3813, 0x04, 0, 0}, {0x3618, 0x04, 0, 0}, {0x3612, 0x29, 0, 0}, {0x3708, 0x21, 0, 0}, {0x3709, 0x12, 0, 0}, {0x370c, 0x00, 0, 0}, {0x3a02, 0x03, 0, 0}, {0x3a03, 0xd8, 0, 0}, {0x3a08, 0x01, 0, 0}, {0x3a09, 0x27, 0, 0}, {0x3a0a, 0x00, 0, 0}, {0x3a0b, 0xf6, 0, 0}, {0x3a0e, 0x03, 0, 0}, {0x3a0d, 0x04, 0, 0}, {0x3a14, 0x03, 0, 0}, {0x3a15, 0xd8, 0, 0}, {0x4001, 0x02, 0, 0}, {0x4004, 0x06, 0, 0}, {0x4713, 0x03, 0, 0}, {0x4407, 0x04, 0, 0}, {0x460b, 0x35, 0, 0}, {0x460c, 0x22, 0, 0}, {0x3824, 0x02, 0, 0}, {0x5001, 0x83, 0, 0}, {0x3c07, 0x07, 0, 0}, {0x3c08, 0x00, 0, 0}, {0x3c09, 0x1c, 0, 0}, {0x3c0a, 0x9c, 0, 0}, {0x3c0b, 0x40, 0, 0}, {0x3800, 0x01, 0, 0}, {0x3801, 0x50, 0, 0}, {0x3802, 0x01, 0, 0}, {0x3803, 0xb2, 0, 0}, {0x3804, 0x08, 0, 0}, {0x3805, 0xef, 0, 0}, {0x3806, 0x05, 0, 0}, {0x3807, 0xf1, 0, 0}, {0x3612, 0x2b, 0, 0}, {0x3708, 0x64, 0, 0}, {0x3a02, 0x04, 0, 0}, {0x3a03, 0x60, 0, 0}, {0x3a08, 0x01, 0, 0}, {0x3a09, 0x50, 0, 0}, {0x3a0a, 0x01, 0, 0}, {0x3a0b, 0x18, 0, 0}, {0x3a0e, 0x03, 0, 0}, {0x3a0d, 0x04, 0, 0}, {0x3a14, 0x04, 0, 0}, {0x3a15, 0x60, 0, 0}, {0x4713, 0x02, 0, 0}, {0x4407, 0x04, 0, 0}, {0x460b, 0x37, 0, 0}, {0x460c, 0x20, 0, 0}, {0x3824, 0x04, 0, 0}, {0x4005, 0x1a, 0, 0}, }; static const struct reg_value ov5640_setting_QSXGA_2592_1944[] = { {0x3c07, 0x08, 0, 0}, {0x3c09, 0x1c, 0, 0}, {0x3c0a, 0x9c, 0, 0}, {0x3c0b, 0x40, 0, 0}, {0x3814, 0x11, 0, 0}, {0x3815, 0x11, 0, 0}, {0x3800, 0x00, 0, 0}, {0x3801, 0x00, 0, 0}, {0x3802, 0x00, 0, 0}, {0x3803, 0x00, 0, 0}, {0x3804, 0x0a, 0, 0}, {0x3805, 0x3f, 0, 0}, {0x3806, 0x07, 0, 0}, {0x3807, 0x9f, 0, 0}, {0x3810, 0x00, 0, 0}, {0x3811, 0x10, 0, 0}, {0x3812, 0x00, 0, 0}, {0x3813, 0x04, 0, 0}, {0x3618, 0x04, 0, 0}, {0x3612, 0x29, 0, 0}, {0x3708, 0x21, 0, 0}, {0x3709, 0x12, 0, 0}, {0x370c, 0x00, 0, 0}, {0x3a02, 0x03, 0, 0}, {0x3a03, 0xd8, 0, 0}, {0x3a08, 0x01, 0, 0}, {0x3a09, 0x27, 0, 0}, {0x3a0a, 0x00, 0, 0}, {0x3a0b, 0xf6, 0, 0}, {0x3a0e, 0x03, 0, 0}, {0x3a0d, 0x04, 0, 0}, {0x3a14, 0x03, 0, 0}, {0x3a15, 0xd8, 0, 0}, {0x4001, 0x02, 0, 0}, {0x4004, 0x06, 0, 0}, {0x4713, 0x03, 0, 0}, {0x4407, 0x04, 0, 0}, {0x460b, 0x35, 0, 0}, {0x460c, 0x22, 0, 0}, {0x3824, 0x02, 0, 0}, {0x5001, 0x83, 0, 70}, }; /* power-on sensor init reg table */ static const struct ov5640_mode_info ov5640_mode_init_data = { 0, SUBSAMPLING, 640, 1896, 480, 984, ov5640_init_setting_30fps_VGA, ARRAY_SIZE(ov5640_init_setting_30fps_VGA), }; static const struct ov5640_mode_info ov5640_mode_data[OV5640_NUM_MODES] = { {OV5640_MODE_QCIF_176_144, SUBSAMPLING, 176, 1896, 144, 984, ov5640_setting_QCIF_176_144, ARRAY_SIZE(ov5640_setting_QCIF_176_144)}, {OV5640_MODE_QVGA_320_240, SUBSAMPLING, 320, 1896, 240, 984, ov5640_setting_QVGA_320_240, ARRAY_SIZE(ov5640_setting_QVGA_320_240)}, {OV5640_MODE_VGA_640_480, SUBSAMPLING, 640, 1896, 480, 1080, ov5640_setting_VGA_640_480, ARRAY_SIZE(ov5640_setting_VGA_640_480)}, {OV5640_MODE_NTSC_720_480, SUBSAMPLING, 720, 1896, 480, 984, ov5640_setting_NTSC_720_480, ARRAY_SIZE(ov5640_setting_NTSC_720_480)}, {OV5640_MODE_PAL_720_576, SUBSAMPLING, 720, 1896, 576, 984, ov5640_setting_PAL_720_576, ARRAY_SIZE(ov5640_setting_PAL_720_576)}, {OV5640_MODE_XGA_1024_768, SUBSAMPLING, 1024, 1896, 768, 1080, ov5640_setting_XGA_1024_768, ARRAY_SIZE(ov5640_setting_XGA_1024_768)}, {OV5640_MODE_720P_1280_720, SUBSAMPLING, 1280, 1892, 720, 740, ov5640_setting_720P_1280_720, ARRAY_SIZE(ov5640_setting_720P_1280_720)}, {OV5640_MODE_1080P_1920_1080, SCALING, 1920, 2500, 1080, 1120, ov5640_setting_1080P_1920_1080, ARRAY_SIZE(ov5640_setting_1080P_1920_1080)}, {OV5640_MODE_QSXGA_2592_1944, SCALING, 2592, 2844, 1944, 1968, ov5640_setting_QSXGA_2592_1944, ARRAY_SIZE(ov5640_setting_QSXGA_2592_1944)}, }; static int ov5640_init_slave_id(struct ov5640_dev *sensor) { struct i2c_client *client = sensor->i2c_client; struct i2c_msg msg; u8 buf[3]; int ret; dev_err(&client->dev, "%s: client->addr= %x\n", __func__,client->addr ); if (client->addr == OV5640_DEFAULT_SLAVE_ID) return 0; buf[0] = OV5640_REG_SLAVE_ID >> 8; buf[1] = OV5640_REG_SLAVE_ID & 0xff; buf[2] = client->addr << 1; msg.addr = OV5640_DEFAULT_SLAVE_ID; msg.flags = 0; msg.buf = buf; msg.len = sizeof(buf); ret = i2c_transfer(client->adapter, &msg, 1); if (ret < 0) { dev_err(&client->dev, "%s: failed with %d\n", __func__, ret); return ret; } return 0; } static int ov5640_write_reg(struct ov5640_dev *sensor, u16 reg, u8 val) { struct i2c_client *client = sensor->i2c_client; struct i2c_msg msg; u8 buf[3]; int ret; buf[0] = reg >> 8; buf[1] = reg & 0xff; buf[2] = val; msg.addr = client->addr; msg.flags = client->flags; msg.buf = buf; msg.len = sizeof(buf); ret = i2c_transfer(client->adapter, &msg, 1); if (ret < 0) { dev_err(&client->dev, "%s: error: reg=%x, val=%x\n", __func__, reg, val); return ret; } return 0; } static int ov5640_cispl_read_reg(struct ov5640_dev *sensor, u16 reg, u16 *val) { struct i2c_client *client = sensor->i2c_client; struct i2c_msg msg[1]; u8 buf[2]; int ret; buf[0] = reg & 0xff; msg[0].addr = client->addr; msg[0].flags = client->flags | I2C_M_RD; msg[0].buf = buf; msg[0].len = 2; ret = i2c_transfer(client->adapter, msg, 1); if (ret < 0) { dev_err(&client->dev, "%s: error: reg=%x\n", __func__, reg); return ret; } *val = buf[0]<<8 | buf[1];; // *val = buf[0]; return 0; } static int ov5640_read_reg(struct ov5640_dev *sensor, u16 reg, u8 *val) { struct i2c_client *client = sensor->i2c_client; struct i2c_msg msg[2]; u8 buf[2]; int ret; buf[0] = reg >> 8; buf[1] = reg & 0xff; msg[0].addr = client->addr; msg[0].flags = client->flags; msg[0].buf = buf; msg[0].len = sizeof(buf); msg[1].addr = client->addr; msg[1].flags = client->flags | I2C_M_RD; msg[1].buf = buf; msg[1].len = 1; ret = i2c_transfer(client->adapter, msg, 2); if (ret < 0) { dev_err(&client->dev, "%s: error: reg=%x\n", __func__, reg); return ret; } *val = buf[0]; return 0; } static int ov5640_read_reg16(struct ov5640_dev *sensor, u16 reg, u16 *val) { u8 hi, lo; int ret; ret = ov5640_read_reg(sensor, reg, &hi); if (ret) return ret; ret = ov5640_read_reg(sensor, reg + 1, &lo); if (ret) return ret; *val = ((u16)hi << 8) | (u16)lo; return 0; } static int ov5640_write_reg16(struct ov5640_dev *sensor, u16 reg, u16 val) { int ret; ret = ov5640_write_reg(sensor, reg, val >> 8); if (ret) return ret; return ov5640_write_reg(sensor, reg + 1, val & 0xff); } static int ov5640_mod_reg(struct ov5640_dev *sensor, u16 reg, u8 mask, u8 val) { u8 readval; int ret; ret = ov5640_read_reg(sensor, reg, &readval); if (ret) return ret; readval &= ~mask; val &= mask; val |= readval; return ov5640_write_reg(sensor, reg, val); } /* * After trying the various combinations, reading various * documentations spreaded around the net, and from the various * feedback, the clock tree is probably as follows: * * +--------------+ * | Ext. Clock | * +-+------------+ * | +----------+ * +->| PLL1 | - reg 0x3036, for the multiplier * +-+--------+ - reg 0x3037, bits 0-3 for the pre-divider * | +--------------+ * +->| System Clock | - reg 0x3035, bits 4-7 * +-+------------+ * | +--------------+ * +->| MIPI Divider | - reg 0x3035, bits 0-3 * | +-+------------+ * | +----------------> MIPI SCLK * | + +-----+ * | +->| / 2 |-------> MIPI BIT CLK * | +-----+ * | +--------------+ * +->| PLL Root Div | - reg 0x3037, bit 4 * +-+------------+ * | +---------+ * +->| Bit Div | - reg 0x3035, bits 0-3 * +-+-------+ * | +-------------+ * +->| SCLK Div | - reg 0x3108, bits 0-1 * | +-+-----------+ * | +---------------> SCLK * | +-------------+ * +->| SCLK 2X Div | - reg 0x3108, bits 2-3 * | +-+-----------+ * | +---------------> SCLK 2X * | +-------------+ * +->| PCLK Div | - reg 0x3108, bits 4-5 * ++------------+ * + +-----------+ * +->| P_DIV | - reg 0x3035, bits 0-3 * +-----+-----+ * +------------> PCLK * * This is deviating from the datasheet at least for the register * 0x3108, since it's said here that the PCLK would be clocked from * the PLL. * * There seems to be also (unverified) constraints: * - the PLL pre-divider output rate should be in the 4-27MHz range * - the PLL multiplier output rate should be in the 500-1000MHz range * - PCLK >= SCLK * 2 in YUV, >= SCLK in Raw or JPEG * * In the two latter cases, these constraints are met since our * factors are hardcoded. If we were to change that, we would need to * take this into account. The only varying parts are the PLL * multiplier and the system clock divider, which are shared between * all these clocks so won't cause any issue. */ /* * This is supposed to be ranging from 1 to 8, but the value is always * set to 3 in the vendor kernels. */ #define OV5640_PLL_PREDIV 3 #define OV5640_PLL_MULT_MIN 4 #define OV5640_PLL_MULT_MAX 252 /* * This is supposed to be ranging from 1 to 16, but the value is * always set to either 1 or 2 in the vendor kernels. */ #define OV5640_SYSDIV_MIN 1 #define OV5640_SYSDIV_MAX 16 /* * Hardcode these values for scaler and non-scaler modes. * FIXME: to be re-calcualted for 1 data lanes setups */ #define OV5640_MIPI_DIV_PCLK 2 #define OV5640_MIPI_DIV_SCLK 1 /* * This is supposed to be ranging from 1 to 2, but the value is always * set to 2 in the vendor kernels. */ #define OV5640_PLL_ROOT_DIV 2 #define OV5640_PLL_CTRL3_PLL_ROOT_DIV_2 BIT(4) /* * We only supports 8-bit formats at the moment */ #define OV5640_BIT_DIV 2 #define OV5640_PLL_CTRL0_MIPI_MODE_8BIT 0x08 /* * This is supposed to be ranging from 1 to 8, but the value is always * set to 2 in the vendor kernels. */ #define OV5640_SCLK_ROOT_DIV 2 /* * This is hardcoded so that the consistency is maintained between SCLK and * SCLK 2x. */ #define OV5640_SCLK2X_ROOT_DIV (OV5640_SCLK_ROOT_DIV / 2) /* * This is supposed to be ranging from 1 to 8, but the value is always * set to 1 in the vendor kernels. */ #define OV5640_PCLK_ROOT_DIV 1 #define OV5640_PLL_SYS_ROOT_DIVIDER_BYPASS 0x00 static unsigned long ov5640_compute_sys_clk(struct ov5640_dev *sensor, u8 pll_prediv, u8 pll_mult, u8 sysdiv) { unsigned long sysclk = sensor->xclk_freq / pll_prediv * pll_mult; /* PLL1 output cannot exceed 1GHz. */ if (sysclk / 1000000 > 1000) return 0; return sysclk / sysdiv; } static unsigned long ov5640_calc_sys_clk(struct ov5640_dev *sensor, unsigned long rate, u8 *pll_prediv, u8 *pll_mult, u8 *sysdiv) { unsigned long best = ~0; u8 best_sysdiv = 1, best_mult = 1; u8 _sysdiv, _pll_mult; for (_sysdiv = OV5640_SYSDIV_MIN; _sysdiv <= OV5640_SYSDIV_MAX; _sysdiv++) { for (_pll_mult = OV5640_PLL_MULT_MIN; _pll_mult <= OV5640_PLL_MULT_MAX; _pll_mult++) { unsigned long _rate; /* * The PLL multiplier cannot be odd if above * 127. */ if (_pll_mult > 127 && (_pll_mult % 2)) continue; _rate = ov5640_compute_sys_clk(sensor, OV5640_PLL_PREDIV, _pll_mult, _sysdiv); /* * We have reached the maximum allowed PLL1 output, * increase sysdiv. */ if (!rate) break; /* * Prefer rates above the expected clock rate than * below, even if that means being less precise. */ if (_rate < rate) continue; if (abs(rate - _rate) < abs(rate - best)) { best = _rate; best_sysdiv = _sysdiv; best_mult = _pll_mult; } if (_rate == rate) goto out; } } out: *sysdiv = best_sysdiv; *pll_prediv = OV5640_PLL_PREDIV; *pll_mult = best_mult; return best; } /* * ov5640_set_mipi_pclk() - Calculate the clock tree configuration values * for the MIPI CSI-2 output. * * @rate: The requested bandwidth per lane in bytes per second. * 'Bandwidth Per Lane' is calculated as: * bpl = HTOT * VTOT * FPS * bpp / num_lanes; * * This function use the requested bandwidth to calculate: * - sample_rate = bpl / (bpp / num_lanes); * = bpl / (PLL_RDIV * BIT_DIV * PCLK_DIV * MIPI_DIV / num_lanes); * * - mipi_sclk = bpl / MIPI_DIV / 2; ( / 2 is for CSI-2 DDR) * * with these fixed parameters: * PLL_RDIV = 2; * BIT_DIVIDER = 2; (MIPI_BIT_MODE == 8 ? 2 : 2,5); * PCLK_DIV = 1; * * The MIPI clock generation differs for modes that use the scaler and modes * that do not. In case the scaler is in use, the MIPI_SCLK generates the MIPI * BIT CLk, and thus: * * - mipi_sclk = bpl / MIPI_DIV / 2; * MIPI_DIV = 1; * * For modes that do not go through the scaler, the MIPI BIT CLOCK is generated * from the pixel clock, and thus: * * - sample_rate = bpl / (bpp / num_lanes); * = bpl / (2 * 2 * 1 * MIPI_DIV / num_lanes); * = bpl / (4 * MIPI_DIV / num_lanes); * - MIPI_DIV = bpp / (4 * num_lanes); * * FIXME: this have been tested with 16bpp and 2 lanes setup only. * MIPI_DIV is fixed to value 2, but it -might- be changed according to the * above formula for setups with 1 lane or image formats with different bpp. * * FIXME: this deviates from the sensor manual documentation which is quite * thin on the MIPI clock tree generation part. */ static int ov5640_set_mipi_pclk(struct ov5640_dev *sensor, unsigned long rate) { const struct ov5640_mode_info *mode = sensor->current_mode; u8 prediv, mult, sysdiv; u8 mipi_div; int ret; /* * 1280x720 is reported to use 'SUBSAMPLING' only, * but according to the sensor manual it goes through the * scaler before subsampling. */ if (mode->dn_mode == SCALING || (mode->id == OV5640_MODE_720P_1280_720)) mipi_div = OV5640_MIPI_DIV_SCLK; else mipi_div = OV5640_MIPI_DIV_PCLK; ov5640_calc_sys_clk(sensor, rate, &prediv, &mult, &sysdiv); ret = ov5640_mod_reg(sensor, OV5640_REG_SC_PLL_CTRL0, 0x0f, OV5640_PLL_CTRL0_MIPI_MODE_8BIT); ret = ov5640_mod_reg(sensor, OV5640_REG_SC_PLL_CTRL1, 0xff, sysdiv << 4 | mipi_div); if (ret) return ret; ret = ov5640_mod_reg(sensor, OV5640_REG_SC_PLL_CTRL2, 0xff, mult); if (ret) return ret; ret = ov5640_mod_reg(sensor, OV5640_REG_SC_PLL_CTRL3, 0x1f, OV5640_PLL_CTRL3_PLL_ROOT_DIV_2 | prediv); if (ret) return ret; return ov5640_mod_reg(sensor, OV5640_REG_SYS_ROOT_DIVIDER, 0x30, OV5640_PLL_SYS_ROOT_DIVIDER_BYPASS); } static unsigned long ov5640_calc_pclk(struct ov5640_dev *sensor, unsigned long rate, u8 *pll_prediv, u8 *pll_mult, u8 *sysdiv, u8 *pll_rdiv, u8 *bit_div, u8 *pclk_div) { unsigned long _rate = rate * OV5640_PLL_ROOT_DIV * OV5640_BIT_DIV * OV5640_PCLK_ROOT_DIV; _rate = ov5640_calc_sys_clk(sensor, _rate, pll_prediv, pll_mult, sysdiv); *pll_rdiv = OV5640_PLL_ROOT_DIV; *bit_div = OV5640_BIT_DIV; *pclk_div = OV5640_PCLK_ROOT_DIV; return _rate / *pll_rdiv / *bit_div / *pclk_div; } static int ov5640_set_dvp_pclk(struct ov5640_dev *sensor, unsigned long rate) { u8 prediv, mult, sysdiv, pll_rdiv, bit_div, pclk_div; int ret; ov5640_calc_pclk(sensor, rate, &prediv, &mult, &sysdiv, &pll_rdiv, &bit_div, &pclk_div); if (bit_div == 2) bit_div = 8; ret = ov5640_mod_reg(sensor, OV5640_REG_SC_PLL_CTRL0, 0x0f, bit_div); if (ret) return ret; /* * We need to set sysdiv according to the clock, and to clear * the MIPI divider. */ ret = ov5640_mod_reg(sensor, OV5640_REG_SC_PLL_CTRL1, 0xff, sysdiv << 4); if (ret) return ret; ret = ov5640_mod_reg(sensor, OV5640_REG_SC_PLL_CTRL2, 0xff, mult); if (ret) return ret; ret = ov5640_mod_reg(sensor, OV5640_REG_SC_PLL_CTRL3, 0x1f, prediv | ((pll_rdiv - 1) << 4)); if (ret) return ret; return ov5640_mod_reg(sensor, OV5640_REG_SYS_ROOT_DIVIDER, 0x30, (ilog2(pclk_div) << 4)); } /* download ov5640 settings to sensor through i2c */ static int ov5640_set_timings(struct ov5640_dev *sensor, const struct ov5640_mode_info *mode) { int ret; ret = ov5640_write_reg16(sensor, OV5640_REG_TIMING_DVPHO, mode->hact); if (ret < 0) return ret; ret = ov5640_write_reg16(sensor, OV5640_REG_TIMING_DVPVO, mode->vact); if (ret < 0) return ret; ret = ov5640_write_reg16(sensor, OV5640_REG_TIMING_HTS, mode->htot); if (ret < 0) return ret; return ov5640_write_reg16(sensor, OV5640_REG_TIMING_VTS, mode->vtot); } static int ov5640_load_regs(struct ov5640_dev *sensor, const struct ov5640_mode_info *mode) { const struct reg_value *regs = mode->reg_data; unsigned int i; u32 delay_ms; u16 reg_addr; u8 mask, val; int ret = 0; for (i = 0; i < mode->reg_data_size; ++i, ++regs) { delay_ms = regs->delay_ms; reg_addr = regs->reg_addr; val = regs->val; mask = regs->mask; if (mask) ret = ov5640_mod_reg(sensor, reg_addr, mask, val); else ret = ov5640_write_reg(sensor, reg_addr, val); if (ret) break; if (delay_ms) usleep_range(1000 * delay_ms, 1000 * delay_ms + 100); } return ov5640_set_timings(sensor, mode); } static int ov5640_set_autoexposure(struct ov5640_dev *sensor, bool on) { return ov5640_mod_reg(sensor, OV5640_REG_AEC_PK_MANUAL, BIT(0), on ? 0 : BIT(0)); } /* read exposure, in number of line periods */ static int ov5640_get_exposure(struct ov5640_dev *sensor) { int exp, ret; u8 temp; ret = ov5640_read_reg(sensor, OV5640_REG_AEC_PK_EXPOSURE_HI, &temp); if (ret) return ret; exp = ((int)temp & 0x0f) << 16; ret = ov5640_read_reg(sensor, OV5640_REG_AEC_PK_EXPOSURE_MED, &temp); if (ret) return ret; exp |= ((int)temp << 8); ret = ov5640_read_reg(sensor, OV5640_REG_AEC_PK_EXPOSURE_LO, &temp); if (ret) return ret; exp |= (int)temp; return exp >> 4; } /* write exposure, given number of line periods */ static int ov5640_set_exposure(struct ov5640_dev *sensor, u32 exposure) { int ret; exposure <<= 4; ret = ov5640_write_reg(sensor, OV5640_REG_AEC_PK_EXPOSURE_LO, exposure & 0xff); if (ret) return ret; ret = ov5640_write_reg(sensor, OV5640_REG_AEC_PK_EXPOSURE_MED, (exposure >> 8) & 0xff); if (ret) return ret; return ov5640_write_reg(sensor, OV5640_REG_AEC_PK_EXPOSURE_HI, (exposure >> 16) & 0x0f); } static int ov5640_get_gain(struct ov5640_dev *sensor) { u16 gain; int ret; ret = ov5640_read_reg16(sensor, OV5640_REG_AEC_PK_REAL_GAIN, &gain); if (ret) return ret; return gain & 0x3ff; } static int ov5640_set_gain(struct ov5640_dev *sensor, int gain) { return ov5640_write_reg16(sensor, OV5640_REG_AEC_PK_REAL_GAIN, (u16)gain & 0x3ff); } static int ov5640_set_autogain(struct ov5640_dev *sensor, bool on) { return ov5640_mod_reg(sensor, OV5640_REG_AEC_PK_MANUAL, BIT(1), on ? 0 : BIT(1)); } static int ov5640_set_stream_dvp(struct ov5640_dev *sensor, bool on) { int ret; unsigned int flags = sensor->ep.bus.parallel.flags; u8 pclk_pol = 0; u8 hsync_pol = 0; u8 vsync_pol = 0; /* * Note about parallel port configuration. * * When configured in parallel mode, the OV5640 will * output 10 bits data on DVP data lines [9:0]. * If only 8 bits data are wanted, the 8 bits data lines * of the camera interface must be physically connected * on the DVP data lines [9:2]. * * Control lines polarity can be configured through * devicetree endpoint control lines properties. * If no endpoint control lines properties are set, * polarity will be as below: * - VSYNC: active high * - HREF: active low * - PCLK: active low */ if (on) { /* * configure parallel port control lines polarity * * POLARITY CTRL0 * - [5]: PCLK polarity (0: active low, 1: active high) * - [1]: HREF polarity (0: active low, 1: active high) * - [0]: VSYNC polarity (mismatch here between * datasheet and hardware, 0 is active high * and 1 is active low...) */ if (flags & V4L2_MBUS_PCLK_SAMPLE_RISING) pclk_pol = 1; if (flags & V4L2_MBUS_HSYNC_ACTIVE_HIGH) hsync_pol = 1; if (flags & V4L2_MBUS_VSYNC_ACTIVE_LOW) vsync_pol = 1; ret = ov5640_write_reg(sensor, OV5640_REG_POLARITY_CTRL00, (pclk_pol << 5) | (hsync_pol << 1) | vsync_pol); if (ret) return ret; } /* * powerdown MIPI TX/RX PHY & disable MIPI * * MIPI CONTROL 00 * 4: PWDN PHY TX * 3: PWDN PHY RX * 2: MIPI enable */ ret = ov5640_write_reg(sensor, OV5640_REG_IO_MIPI_CTRL00, on ? 0x18 : 0); if (ret) return ret; /* * enable VSYNC/HREF/PCLK DVP control lines * & D[9:6] DVP data lines * * PAD OUTPUT ENABLE 01 * - 6: VSYNC output enable * - 5: HREF output enable * - 4: PCLK output enable * - [3:0]: D[9:6] output enable */ ret = ov5640_write_reg(sensor, OV5640_REG_PAD_OUTPUT_ENABLE01, on ? 0x7f : 0); if (ret) return ret; /* * enable D[5:0] DVP data lines * * PAD OUTPUT ENABLE 02 * - [7:2]: D[5:0] output enable */ return ov5640_write_reg(sensor, OV5640_REG_PAD_OUTPUT_ENABLE02, on ? 0xfc : 0); } static int ov5640_set_stream_mipi(struct ov5640_dev *sensor, bool on) { int ret; /* * Enable/disable the MIPI interface * * 0x300e = on ? 0x45 : 0x40 * * FIXME: the sensor manual (version 2.03) reports * [7:5] = 000 : 1 data lane mode * [7:5] = 001 : 2 data lanes mode * But this settings do not work, while the following ones * have been validated for 2 data lanes mode. * * [7:5] = 010 : 2 data lanes mode * [4] = 0 : Power up MIPI HS Tx * [3] = 0 : Power up MIPI LS Rx * [2] = 1/0 : MIPI interface enable/disable * [1:0] = 01/00: FIXME: 'debug' */ ret = ov5640_write_reg(sensor, OV5640_REG_IO_MIPI_CTRL00, on ? 0x45 : 0x40); if (ret) return ret; return ov5640_write_reg(sensor, OV5640_REG_FRAME_CTRL01, on ? 0x00 : 0x0f); } static int ov5640_get_sysclk(struct ov5640_dev *sensor) { /* calculate sysclk */ u32 xvclk = sensor->xclk_freq / 10000; u32 multiplier, prediv, VCO, sysdiv, pll_rdiv; u32 sclk_rdiv_map[] = {1, 2, 4, 8}; u32 bit_div2x = 1, sclk_rdiv, sysclk; u8 temp1, temp2; int ret; ret = ov5640_read_reg(sensor, OV5640_REG_SC_PLL_CTRL0, &temp1); if (ret) return ret; temp2 = temp1 & 0x0f; if (temp2 == 8 || temp2 == 10) bit_div2x = temp2 / 2; ret = ov5640_read_reg(sensor, OV5640_REG_SC_PLL_CTRL1, &temp1); if (ret) return ret; sysdiv = temp1 >> 4; if (sysdiv == 0) sysdiv = 16; ret = ov5640_read_reg(sensor, OV5640_REG_SC_PLL_CTRL2, &temp1); if (ret) return ret; multiplier = temp1; ret = ov5640_read_reg(sensor, OV5640_REG_SC_PLL_CTRL3, &temp1); if (ret) return ret; prediv = temp1 & 0x0f; pll_rdiv = ((temp1 >> 4) & 0x01) + 1; ret = ov5640_read_reg(sensor, OV5640_REG_SYS_ROOT_DIVIDER, &temp1); if (ret) return ret; temp2 = temp1 & 0x03; sclk_rdiv = sclk_rdiv_map[temp2]; if (!prediv || !sysdiv || !pll_rdiv || !bit_div2x) return -EINVAL; VCO = xvclk * multiplier / prediv; sysclk = VCO / sysdiv / pll_rdiv * 2 / bit_div2x / sclk_rdiv; return sysclk; } static int ov5640_set_night_mode(struct ov5640_dev *sensor) { /* read HTS from register settings */ u8 mode; int ret; ret = ov5640_read_reg(sensor, OV5640_REG_AEC_CTRL00, &mode); if (ret) return ret; mode &= 0xfb; return ov5640_write_reg(sensor, OV5640_REG_AEC_CTRL00, mode); } static int ov5640_get_hts(struct ov5640_dev *sensor) { /* read HTS from register settings */ u16 hts; int ret; ret = ov5640_read_reg16(sensor, OV5640_REG_TIMING_HTS, &hts); if (ret) return ret; return hts; } static int ov5640_get_vts(struct ov5640_dev *sensor) { u16 vts; int ret; ret = ov5640_read_reg16(sensor, OV5640_REG_TIMING_VTS, &vts); if (ret) return ret; return vts; } static int ov5640_set_vts(struct ov5640_dev *sensor, int vts) { return ov5640_write_reg16(sensor, OV5640_REG_TIMING_VTS, vts); } static int ov5640_get_light_freq(struct ov5640_dev *sensor) { /* get banding filter value */ int ret, light_freq = 0; u8 temp, temp1; ret = ov5640_read_reg(sensor, OV5640_REG_HZ5060_CTRL01, &temp); if (ret) return ret; if (temp & 0x80) { /* manual */ ret = ov5640_read_reg(sensor, OV5640_REG_HZ5060_CTRL00, &temp1); if (ret) return ret; if (temp1 & 0x04) { /* 50Hz */ light_freq = 50; } else { /* 60Hz */ light_freq = 60; } } else { /* auto */ ret = ov5640_read_reg(sensor, OV5640_REG_SIGMADELTA_CTRL0C, &temp1); if (ret) return ret; if (temp1 & 0x01) { /* 50Hz */ light_freq = 50; } else { /* 60Hz */ } } return light_freq; } static int ov5640_set_bandingfilter(struct ov5640_dev *sensor) { u32 band_step60, max_band60, band_step50, max_band50, prev_vts; int ret; /* read preview PCLK */ ret = ov5640_get_sysclk(sensor); if (ret < 0) return ret; if (ret == 0) return -EINVAL; sensor->prev_sysclk = ret; /* read preview HTS */ ret = ov5640_get_hts(sensor); if (ret < 0) return ret; if (ret == 0) return -EINVAL; sensor->prev_hts = ret; /* read preview VTS */ ret = ov5640_get_vts(sensor); if (ret < 0) return ret; prev_vts = ret; /* calculate banding filter */ /* 60Hz */ band_step60 = sensor->prev_sysclk * 100 / sensor->prev_hts * 100 / 120; ret = ov5640_write_reg16(sensor, OV5640_REG_AEC_B60_STEP, band_step60); if (ret) return ret; if (!band_step60) return -EINVAL; max_band60 = (int)((prev_vts - 4) / band_step60); ret = ov5640_write_reg(sensor, OV5640_REG_AEC_CTRL0D, max_band60); if (ret) return ret; /* 50Hz */ band_step50 = sensor->prev_sysclk * 100 / sensor->prev_hts; ret = ov5640_write_reg16(sensor, OV5640_REG_AEC_B50_STEP, band_step50); if (ret) return ret; if (!band_step50) return -EINVAL; max_band50 = (int)((prev_vts - 4) / band_step50); return ov5640_write_reg(sensor, OV5640_REG_AEC_CTRL0E, max_band50); } static int ov5640_set_ae_target(struct ov5640_dev *sensor, int target) { /* stable in high */ u32 fast_high, fast_low; int ret; sensor->ae_low = target * 23 / 25; /* 0.92 */ sensor->ae_high = target * 27 / 25; /* 1.08 */ fast_high = sensor->ae_high << 1; if (fast_high > 255) fast_high = 255; fast_low = sensor->ae_low >> 1; ret = ov5640_write_reg(sensor, OV5640_REG_AEC_CTRL0F, sensor->ae_high); if (ret) return ret; ret = ov5640_write_reg(sensor, OV5640_REG_AEC_CTRL10, sensor->ae_low); if (ret) return ret; ret = ov5640_write_reg(sensor, OV5640_REG_AEC_CTRL1B, sensor->ae_high); if (ret) return ret; ret = ov5640_write_reg(sensor, OV5640_REG_AEC_CTRL1E, sensor->ae_low); if (ret) return ret; ret = ov5640_write_reg(sensor, OV5640_REG_AEC_CTRL11, fast_high); if (ret) return ret; return ov5640_write_reg(sensor, OV5640_REG_AEC_CTRL1F, fast_low); } static int ov5640_get_binning(struct ov5640_dev *sensor) { u8 temp; int ret; ret = ov5640_read_reg(sensor, OV5640_REG_TIMING_TC_REG21, &temp); if (ret) return ret; return temp & BIT(0); } static int ov5640_set_binning(struct ov5640_dev *sensor, bool enable) { int ret; /* * TIMING TC REG21: * - [0]: Horizontal binning enable */ ret = ov5640_mod_reg(sensor, OV5640_REG_TIMING_TC_REG21, BIT(0), enable ? BIT(0) : 0); if (ret) return ret; /* * TIMING TC REG20: * - [0]: Undocumented, but hardcoded init sequences * are always setting REG21/REG20 bit 0 to same value... */ return ov5640_mod_reg(sensor, OV5640_REG_TIMING_TC_REG20, BIT(0), enable ? BIT(0) : 0); } static int ov5640_set_virtual_channel(struct ov5640_dev *sensor) { struct i2c_client *client = sensor->i2c_client; u8 temp, channel = virtual_channel; int ret; if (channel > 3) { dev_err(&client->dev, "%s: wrong virtual_channel parameter, expected (0..3), got %d\n", __func__, channel); return -EINVAL; } ret = ov5640_read_reg(sensor, OV5640_REG_DEBUG_MODE, &temp); if (ret) return ret; temp &= ~(3 << 6); temp |= (channel << 6); return ov5640_write_reg(sensor, OV5640_REG_DEBUG_MODE, temp); } static const struct ov5640_mode_info * ov5640_find_mode(struct ov5640_dev *sensor, enum ov5640_frame_rate fr, int width, int height, bool nearest) { const struct ov5640_mode_info *mode; mode = v4l2_find_nearest_size(ov5640_mode_data, ARRAY_SIZE(ov5640_mode_data), hact, vact, width, height); if (!mode || (!nearest && (mode->hact != width || mode->vact != height))) return NULL; /* Only 640x480 can operate at 60fps (for now) */ if (fr == OV5640_60_FPS && !(mode->hact == 640 && mode->vact == 480)) return NULL; if (fr == OV5640_30_FPS && !(mode->hact == 1920 && mode->vact == 1080)) return NULL; /* 2592x1944 only works at 15fps */ if (fr != OV5640_15_FPS && (mode->hact == 2592 && mode->vact == 1944)) return NULL; return mode; } /* * sensor changes between scaling and subsampling, go through * exposure calculation */ static int ov5640_set_mode_exposure_calc(struct ov5640_dev *sensor, const struct ov5640_mode_info *mode) { u32 prev_shutter, prev_gain16; u32 cap_shutter, cap_gain16; u32 cap_sysclk, cap_hts, cap_vts; u32 light_freq, cap_bandfilt, cap_maxband; u32 cap_gain16_shutter; u8 average; int ret; if (!mode->reg_data) return -EINVAL; /* read preview shutter */ ret = ov5640_get_exposure(sensor); if (ret < 0) return ret; prev_shutter = ret; ret = ov5640_get_binning(sensor); if (ret < 0) return ret; if (ret && mode->id != OV5640_MODE_720P_1280_720 && mode->id != OV5640_MODE_1080P_1920_1080) prev_shutter *= 2; /* read preview gain */ ret = ov5640_get_gain(sensor); if (ret < 0) return ret; prev_gain16 = ret; /* get average */ ret = ov5640_read_reg(sensor, OV5640_REG_AVG_READOUT, &average); if (ret) return ret; /* turn off night mode for capture */ ret = ov5640_set_night_mode(sensor); if (ret < 0) return ret; /* Write capture setting */ ret = ov5640_load_regs(sensor, mode); if (ret < 0) return ret; /* read capture VTS */ ret = ov5640_get_vts(sensor); if (ret < 0) return ret; cap_vts = ret; ret = ov5640_get_hts(sensor); if (ret < 0) return ret; if (ret == 0) return -EINVAL; cap_hts = ret; ret = ov5640_get_sysclk(sensor); if (ret < 0) return ret; if (ret == 0) return -EINVAL; cap_sysclk = ret; /* calculate capture banding filter */ ret = ov5640_get_light_freq(sensor); if (ret < 0) return ret; light_freq = ret; if (light_freq == 60) { /* 60Hz */ cap_bandfilt = cap_sysclk * 100 / cap_hts * 100 / 120; } else { /* 50Hz */ cap_bandfilt = cap_sysclk * 100 / cap_hts; } if (!sensor->prev_sysclk) { ret = ov5640_get_sysclk(sensor); if (ret < 0) return ret; if (ret == 0) return -EINVAL; sensor->prev_sysclk = ret; } if (!cap_bandfilt) return -EINVAL; cap_maxband = (int)((cap_vts - 4) / cap_bandfilt); /* calculate capture shutter/gain16 */ if (average > sensor->ae_low && average < sensor->ae_high) { /* in stable range */ cap_gain16_shutter = prev_gain16 * prev_shutter * cap_sysclk / sensor->prev_sysclk * sensor->prev_hts / cap_hts * sensor->ae_target / average; } else { cap_gain16_shutter = prev_gain16 * prev_shutter * cap_sysclk / sensor->prev_sysclk * sensor->prev_hts / cap_hts; } /* gain to shutter */ if (cap_gain16_shutter < (cap_bandfilt * 16)) { /* shutter < 1/100 */ cap_shutter = cap_gain16_shutter / 16; if (cap_shutter < 1) cap_shutter = 1; cap_gain16 = cap_gain16_shutter / cap_shutter; if (cap_gain16 < 16) cap_gain16 = 16; } else { if (cap_gain16_shutter > (cap_bandfilt * cap_maxband * 16)) { /* exposure reach max */ cap_shutter = cap_bandfilt * cap_maxband; if (!cap_shutter) return -EINVAL; cap_gain16 = cap_gain16_shutter / cap_shutter; } else { /* 1/100 < (cap_shutter = n/100) =< max */ cap_shutter = ((int)(cap_gain16_shutter / 16 / cap_bandfilt)) * cap_bandfilt; if (!cap_shutter) return -EINVAL; cap_gain16 = cap_gain16_shutter / cap_shutter; } } /* set capture gain */ ret = ov5640_set_gain(sensor, cap_gain16); if (ret) return ret; /* write capture shutter */ if (cap_shutter > (cap_vts - 4)) { cap_vts = cap_shutter + 4; ret = ov5640_set_vts(sensor, cap_vts); if (ret < 0) return ret; } /* set exposure */ return ov5640_set_exposure(sensor, cap_shutter); } /* * if sensor changes inside scaling or subsampling * change mode directly */ static int ov5640_set_mode_direct(struct ov5640_dev *sensor, const struct ov5640_mode_info *mode) { if (!mode->reg_data) return -EINVAL; /* Write capture setting */ return ov5640_load_regs(sensor, mode); } static int ov5640_set_mode(struct ov5640_dev *sensor) { const struct ov5640_mode_info *mode = sensor->current_mode; const struct ov5640_mode_info *orig_mode = sensor->last_mode; enum ov5640_downsize_mode dn_mode, orig_dn_mode; bool auto_gain = sensor->ctrls.auto_gain->val == 1; bool auto_exp = sensor->ctrls.auto_exp->val == V4L2_EXPOSURE_AUTO; unsigned long rate; int ret; dn_mode = mode->dn_mode; orig_dn_mode = orig_mode->dn_mode; /* auto gain and exposure must be turned off when changing modes */ if (auto_gain) { ret = ov5640_set_autogain(sensor, false); if (ret) return ret; } if (auto_exp) { ret = ov5640_set_autoexposure(sensor, false); if (ret) goto restore_auto_gain; } /* * All the formats we support have 16 bits per pixel, seems to require * the same rate than YUV, so we can just use 16 bpp all the time. */ rate = mode->vtot * mode->htot * 16; rate *= ov5640_framerates[sensor->current_fr]; if (sensor->ep.bus_type == V4L2_MBUS_CSI2) { rate = rate / sensor->ep.bus.mipi_csi2.num_data_lanes; ret = ov5640_set_mipi_pclk(sensor, rate); } else { rate = rate / sensor->ep.bus.parallel.bus_width; ret = ov5640_set_dvp_pclk(sensor, rate); } if (ret < 0) return 0; if ((dn_mode == SUBSAMPLING && orig_dn_mode == SCALING) || (dn_mode == SCALING && orig_dn_mode == SUBSAMPLING)) { /* * change between subsampling and scaling * go through exposure calculation */ ret = ov5640_set_mode_exposure_calc(sensor, mode); } else { /* * change inside subsampling or scaling * download firmware directly */ ret = ov5640_set_mode_direct(sensor, mode); } if (ret < 0) goto restore_auto_exp_gain; /* restore auto gain and exposure */ if (auto_gain) ov5640_set_autogain(sensor, true); if (auto_exp) ov5640_set_autoexposure(sensor, true); ret = ov5640_set_binning(sensor, dn_mode != SCALING); if (ret < 0) return ret; ret = ov5640_set_ae_target(sensor, sensor->ae_target); if (ret < 0) return ret; ret = ov5640_get_light_freq(sensor); if (ret < 0) return ret; ret = ov5640_set_bandingfilter(sensor); if (ret < 0) return ret; ret = ov5640_set_virtual_channel(sensor); if (ret < 0) return ret; sensor->pending_mode_change = false; sensor->last_mode = mode; return 0; restore_auto_exp_gain: if (auto_exp) ov5640_set_autoexposure(sensor, true); restore_auto_gain: if (auto_gain) ov5640_set_autogain(sensor, true); return ret; } static int ov5640_set_framefmt(struct ov5640_dev *sensor, struct v4l2_mbus_framefmt *format); /* restore the last set video mode after chip power-on */ static int ov5640_restore_mode(struct ov5640_dev *sensor) { int ret; /* first load the initial register values */ ret = ov5640_load_regs(sensor, &ov5640_mode_init_data); if (ret < 0) return ret; sensor->last_mode = &ov5640_mode_init_data; ret = ov5640_mod_reg(sensor, OV5640_REG_SYS_ROOT_DIVIDER, 0x3f, (ilog2(OV5640_SCLK2X_ROOT_DIV) << 2) | ilog2(OV5640_SCLK_ROOT_DIV)); if (ret) return ret; /* now restore the last capture mode */ ret = ov5640_set_mode(sensor); if (ret < 0) return ret; return ov5640_set_framefmt(sensor, &sensor->fmt); } static void ov5640_power(struct ov5640_dev *sensor, bool enable) { gpiod_set_value_cansleep(sensor->pwdn_gpio, enable ? 0 : 1); } static void ov5640_reset(struct ov5640_dev *sensor) { if (!sensor->reset_gpio) return; gpiod_set_value_cansleep(sensor->reset_gpio, 0); /* camera power cycle */ ov5640_power(sensor, false); usleep_range(5000, 10000); ov5640_power(sensor, true); usleep_range(5000, 10000); gpiod_set_value_cansleep(sensor->reset_gpio, 1); usleep_range(1000, 2000); gpiod_set_value_cansleep(sensor->reset_gpio, 0); usleep_range(20000, 25000); } static int ov5640_set_power_on(struct ov5640_dev *sensor) { struct i2c_client *client = sensor->i2c_client; int ret; ret = clk_prepare_enable(sensor->xclk); if (ret) { dev_err(&client->dev, "%s: failed to enable clock\n", __func__); return ret; } ret = regulator_bulk_enable(OV5640_NUM_SUPPLIES, sensor->supplies); if (ret) { dev_err(&client->dev, "%s: failed to enable regulators\n", __func__); goto xclk_off; } ov5640_reset(sensor); ov5640_power(sensor, true); ret = ov5640_init_slave_id(sensor); if (ret) goto power_off; return 0; power_off: ov5640_power(sensor, false); regulator_bulk_disable(OV5640_NUM_SUPPLIES, sensor->supplies); xclk_off: clk_disable_unprepare(sensor->xclk); return ret; } static void ov5640_set_power_off(struct ov5640_dev *sensor) { ov5640_power(sensor, false); regulator_bulk_disable(OV5640_NUM_SUPPLIES, sensor->supplies); clk_disable_unprepare(sensor->xclk); } static int ov5640_set_power(struct ov5640_dev *sensor, bool on) { int ret = 0; if (on) { ret = ov5640_set_power_on(sensor); if (ret) return ret; ret = ov5640_restore_mode(sensor); if (ret) goto power_off; /* We're done here for DVP bus, while CSI-2 needs setup. */ if (sensor->ep.bus_type != V4L2_MBUS_CSI2) return 0; /* * Power up MIPI HS Tx and LS Rx; 2 data lanes mode * * 0x300e = 0x40 * [7:5] = 010 : 2 data lanes mode (see FIXME note in * "ov5640_set_stream_mipi()") * [4] = 0 : Power up MIPI HS Tx * [3] = 0 : Power up MIPI LS Rx * [2] = 0 : MIPI interface disabled */ ret = ov5640_write_reg(sensor, OV5640_REG_IO_MIPI_CTRL00, 0x40); if (ret) goto power_off; /* * Gate clock and set LP11 in 'no packets mode' (idle) * * 0x4800 = 0x24 * [5] = 1 : Gate clock when 'no packets' * [2] = 1 : MIPI bus in LP11 when 'no packets' */ ret = ov5640_write_reg(sensor, OV5640_REG_MIPI_CTRL00, 0x24); if (ret) goto power_off; /* * Set data lanes and clock in LP11 when 'sleeping' * * 0x3019 = 0x70 * [6] = 1 : MIPI data lane 2 in LP11 when 'sleeping' * [5] = 1 : MIPI data lane 1 in LP11 when 'sleeping' * [4] = 1 : MIPI clock lane in LP11 when 'sleeping' */ ret = ov5640_write_reg(sensor, OV5640_REG_PAD_OUTPUT00, 0x70); if (ret) goto power_off; /* Give lanes some time to coax into LP11 state. */ usleep_range(500, 1000); } else { if (sensor->ep.bus_type == V4L2_MBUS_CSI2) { /* Reset MIPI bus settings to their default values. */ ov5640_write_reg(sensor, OV5640_REG_IO_MIPI_CTRL00, 0x58); ov5640_write_reg(sensor, OV5640_REG_MIPI_CTRL00, 0x04); ov5640_write_reg(sensor, OV5640_REG_PAD_OUTPUT00, 0x00); } ov5640_set_power_off(sensor); } return 0; power_off: ov5640_set_power_off(sensor); return ret; } /* --------------- Subdev Operations --------------- */ static int ov5640_s_power(struct v4l2_subdev *sd, int on) { struct ov5640_dev *sensor = to_ov5640_dev(sd); int ret = 0; mutex_lock(&sensor->lock); /* * If the power count is modified from 0 to != 0 or from != 0 to 0, * update the power state. */ if (sensor->power_count == !on) { ret = ov5640_set_power(sensor, !!on); if (ret) goto out; } /* Update the power count. */ sensor->power_count += on ? 1 : -1; WARN_ON(sensor->power_count < 0); out: mutex_unlock(&sensor->lock); if (on && !ret && sensor->power_count == 1) { /* restore controls */ ret = v4l2_ctrl_handler_setup(&sensor->ctrls.handler); } return ret; } static int ov5640_try_frame_interval(struct ov5640_dev *sensor, struct v4l2_fract *fi, u32 width, u32 height) { const struct ov5640_mode_info *mode; enum ov5640_frame_rate rate = OV5640_30_FPS; int minfps, maxfps, best_fps, fps; int i; minfps = ov5640_framerates[OV5640_15_FPS]; maxfps = ov5640_framerates[OV5640_60_FPS]; if (fi->numerator == 0) { fi->denominator = maxfps; fi->numerator = 1; rate = OV5640_60_FPS; goto find_mode; } fps = clamp_val(DIV_ROUND_CLOSEST(fi->denominator, fi->numerator), minfps, maxfps); best_fps = minfps; for (i = 0; i < ARRAY_SIZE(ov5640_framerates); i++) { int curr_fps = ov5640_framerates[i]; if (abs(curr_fps - fps) < abs(best_fps - fps)) { best_fps = curr_fps; rate = i; } } fi->numerator = 1; fi->denominator = best_fps; find_mode: mode = ov5640_find_mode(sensor, rate, width, height, false); return mode ? rate : -EINVAL; } static int ov5640_get_fmt(struct v4l2_subdev *sd, struct v4l2_subdev_pad_config *cfg, struct v4l2_subdev_format *format) { struct ov5640_dev *sensor = to_ov5640_dev(sd); struct v4l2_mbus_framefmt *fmt; if (format->pad != 0) return -EINVAL; mutex_lock(&sensor->lock); if (format->which == V4L2_SUBDEV_FORMAT_TRY) fmt = v4l2_subdev_get_try_format(&sensor->sd, cfg, format->pad); else fmt = &sensor->fmt; format->format = *fmt; mutex_unlock(&sensor->lock); return 0; } static int ov5640_try_fmt_internal(struct v4l2_subdev *sd, struct v4l2_mbus_framefmt *fmt, enum ov5640_frame_rate fr, const struct ov5640_mode_info **new_mode) { struct ov5640_dev *sensor = to_ov5640_dev(sd); const struct ov5640_mode_info *mode; int i; mode = ov5640_find_mode(sensor, fr, fmt->width, fmt->height, true); if (!mode) return -EINVAL; fmt->width = mode->hact; fmt->height = mode->vact; if (new_mode) *new_mode = mode; for (i = 0; i < ARRAY_SIZE(ov5640_formats); i++) if (ov5640_formats[i].code == fmt->code) break; if (i >= ARRAY_SIZE(ov5640_formats)) i = 0; fmt->code = ov5640_formats[i].code; fmt->colorspace = ov5640_formats[i].colorspace; fmt->ycbcr_enc = V4L2_MAP_YCBCR_ENC_DEFAULT(fmt->colorspace); fmt->quantization = V4L2_QUANTIZATION_FULL_RANGE; fmt->xfer_func = V4L2_MAP_XFER_FUNC_DEFAULT(fmt->colorspace); return 0; } static int ov5640_set_fmt(struct v4l2_subdev *sd, struct v4l2_subdev_pad_config *cfg, struct v4l2_subdev_format *format) { struct ov5640_dev *sensor = to_ov5640_dev(sd); const struct ov5640_mode_info *new_mode; struct v4l2_mbus_framefmt *mbus_fmt = &format->format; struct v4l2_mbus_framefmt *fmt; u64 rate; int ret; if (format->pad != 0) return -EINVAL; mutex_lock(&sensor->lock); if (sensor->streaming) { ret = -EBUSY; goto out; } ret = ov5640_try_fmt_internal(sd, mbus_fmt, sensor->current_fr, &new_mode); if (ret) goto out; if (format->which == V4L2_SUBDEV_FORMAT_TRY) fmt = v4l2_subdev_get_try_format(sd, cfg, 0); else fmt = &sensor->fmt; *fmt = *mbus_fmt; if (new_mode != sensor->current_mode) { sensor->current_mode = new_mode; sensor->pending_mode_change = true; } if (mbus_fmt->code != sensor->fmt.code) sensor->pending_fmt_change = true; rate = sensor->current_mode->vtot * sensor->current_mode->htot; rate *= ov5640_framerates[sensor->current_fr]; sensor->pixel_rate = rate; __v4l2_ctrl_s_ctrl_int64(sensor->ctrls.pixel_rate,sensor->pixel_rate); out: mutex_unlock(&sensor->lock); return ret; } static int ov5640_set_framefmt(struct ov5640_dev *sensor, struct v4l2_mbus_framefmt *format) { int ret = 0; bool is_rgb = false; bool is_jpeg = false; u8 val; switch (format->code) { case MEDIA_BUS_FMT_UYVY8_2X8: /* YUV422, UYVY */ val = 0x3f; break; case MEDIA_BUS_FMT_YUYV8_2X8: /* YUV422, YUYV */ val = 0x30; break; case MEDIA_BUS_FMT_RGB565_2X8_LE: /* RGB565 {g[2:0],b[4:0]},{r[4:0],g[5:3]} */ val = 0x6F; is_rgb = true; break; case MEDIA_BUS_FMT_RGB565_2X8_BE: /* RGB565 {r[4:0],g[5:3]},{g[2:0],b[4:0]} */ val = 0x61; is_rgb = true; break; case MEDIA_BUS_FMT_JPEG_1X8: /* YUV422, YUYV */ val = 0x30; is_jpeg = true; break; default: return -EINVAL; } /* FORMAT CONTROL00: YUV and RGB formatting */ ret = ov5640_write_reg(sensor, OV5640_REG_FORMAT_CONTROL00, val); if (ret) return ret; /* FORMAT MUX CONTROL: ISP YUV or RGB */ ret = ov5640_write_reg(sensor, OV5640_REG_ISP_FORMAT_MUX_CTRL, is_rgb ? 0x01 : 0x00); if (ret) return ret; /* * TIMING TC REG21: * - [5]: JPEG enable */ ret = ov5640_mod_reg(sensor, OV5640_REG_TIMING_TC_REG21, BIT(5), is_jpeg ? BIT(5) : 0); if (ret) return ret; /* * SYSTEM RESET02: * - [4]: Reset JFIFO * - [3]: Reset SFIFO * - [2]: Reset JPEG */ ret = ov5640_mod_reg(sensor, OV5640_REG_SYS_RESET02, BIT(4) | BIT(3) | BIT(2), is_jpeg ? 0 : (BIT(4) | BIT(3) | BIT(2))); if (ret) return ret; /* * CLOCK ENABLE02: * - [5]: Enable JPEG 2x clock * - [3]: Enable JPEG clock */ return ov5640_mod_reg(sensor, OV5640_REG_SYS_CLOCK_ENABLE02, BIT(5) | BIT(3), is_jpeg ? (BIT(5) | BIT(3)) : 0); } /* * Sensor Controls. */ static int ov5640_set_ctrl_hue(struct ov5640_dev *sensor, int value) { int ret; if (value) { ret = ov5640_mod_reg(sensor, OV5640_REG_SDE_CTRL0, BIT(0), BIT(0)); if (ret) return ret; ret = ov5640_write_reg16(sensor, OV5640_REG_SDE_CTRL1, value); } else { ret = ov5640_mod_reg(sensor, OV5640_REG_SDE_CTRL0, BIT(0), 0); } return ret; } static int ov5640_set_ctrl_contrast(struct ov5640_dev *sensor, int value) { int ret; if (value) { ret = ov5640_mod_reg(sensor, OV5640_REG_SDE_CTRL0, BIT(2), BIT(2)); if (ret) return ret; ret = ov5640_write_reg(sensor, OV5640_REG_SDE_CTRL5, value & 0xff); } else { ret = ov5640_mod_reg(sensor, OV5640_REG_SDE_CTRL0, BIT(2), 0); } return ret; } static int ov5640_set_ctrl_saturation(struct ov5640_dev *sensor, int value) { int ret; if (value) { ret = ov5640_mod_reg(sensor, OV5640_REG_SDE_CTRL0, BIT(1), BIT(1)); if (ret) return ret; ret = ov5640_write_reg(sensor, OV5640_REG_SDE_CTRL3, value & 0xff); if (ret) return ret; ret = ov5640_write_reg(sensor, OV5640_REG_SDE_CTRL4, value & 0xff); } else { ret = ov5640_mod_reg(sensor, OV5640_REG_SDE_CTRL0, BIT(1), 0); } return ret; } static int ov5640_set_ctrl_white_balance(struct ov5640_dev *sensor, int awb) { int ret; ret = ov5640_mod_reg(sensor, OV5640_REG_AWB_MANUAL_CTRL, BIT(0), awb ? 0 : 1); if (ret) return ret; if (!awb) { u16 red = (u16)sensor->ctrls.red_balance->val; u16 blue = (u16)sensor->ctrls.blue_balance->val; ret = ov5640_write_reg16(sensor, OV5640_REG_AWB_R_GAIN, red); if (ret) return ret; ret = ov5640_write_reg16(sensor, OV5640_REG_AWB_B_GAIN, blue); } return ret; } static int ov5640_set_ctrl_exposure(struct ov5640_dev *sensor, enum v4l2_exposure_auto_type auto_exposure) { struct ov5640_ctrls *ctrls = &sensor->ctrls; bool auto_exp = (auto_exposure == V4L2_EXPOSURE_AUTO); int ret = 0; if (ctrls->auto_exp->is_new) { ret = ov5640_set_autoexposure(sensor, auto_exp); if (ret) return ret; } if (!auto_exp && ctrls->exposure->is_new) { u16 max_exp; ret = ov5640_read_reg16(sensor, OV5640_REG_AEC_PK_VTS, &max_exp); if (ret) return ret; ret = ov5640_get_vts(sensor); if (ret < 0) return ret; max_exp += ret; ret = 0; if (ctrls->exposure->val < max_exp) ret = ov5640_set_exposure(sensor, ctrls->exposure->val); } return ret; } static int ov5640_set_ctrl_gain(struct ov5640_dev *sensor, bool auto_gain) { struct ov5640_ctrls *ctrls = &sensor->ctrls; int ret = 0; if (ctrls->auto_gain->is_new) { ret = ov5640_set_autogain(sensor, auto_gain); if (ret) return ret; } if (!auto_gain && ctrls->gain->is_new) ret = ov5640_set_gain(sensor, ctrls->gain->val); return ret; } static int ov5640_set_ctrl_test_pattern(struct ov5640_dev *sensor, int value) { return ov5640_mod_reg(sensor, OV5640_REG_PRE_ISP_TEST_SET1, 0xa4, value ? 0xa4 : 0); } static int ov5640_set_ctrl_light_freq(struct ov5640_dev *sensor, int value) { int ret; ret = ov5640_mod_reg(sensor, OV5640_REG_HZ5060_CTRL01, BIT(7), (value == V4L2_CID_POWER_LINE_FREQUENCY_AUTO) ? 0 : BIT(7)); if (ret) return ret; return ov5640_mod_reg(sensor, OV5640_REG_HZ5060_CTRL00, BIT(2), (value == V4L2_CID_POWER_LINE_FREQUENCY_50HZ) ? BIT(2) : 0); } static int ov5640_set_ctrl_hflip(struct ov5640_dev *sensor, int value) { /* * If sensor is mounted upside down, mirror logic is inversed. * * Sensor is a BSI (Back Side Illuminated) one, * so image captured is physically mirrored. * This is why mirror logic is inversed in * order to cancel this mirror effect. */ /* * TIMING TC REG21: * - [2]: ISP mirror * - [1]: Sensor mirror */ return ov5640_mod_reg(sensor, OV5640_REG_TIMING_TC_REG21, BIT(2) | BIT(1), (!(value ^ sensor->upside_down)) ? (BIT(2) | BIT(1)) : 0); } static int ov5640_set_ctrl_vflip(struct ov5640_dev *sensor, int value) { /* If sensor is mounted upside down, flip logic is inversed */ /* * TIMING TC REG20: * - [2]: ISP vflip * - [1]: Sensor vflip */ return ov5640_mod_reg(sensor, OV5640_REG_TIMING_TC_REG20, BIT(2) | BIT(1), (value ^ sensor->upside_down) ? (BIT(2) | BIT(1)) : 0); } static int ov5640_g_volatile_ctrl(struct v4l2_ctrl *ctrl) { struct v4l2_subdev *sd = ctrl_to_sd(ctrl); struct ov5640_dev *sensor = to_ov5640_dev(sd); int val; /* v4l2_ctrl_lock() locks our own mutex */ switch (ctrl->id) { case V4L2_CID_AUTOGAIN: val = ov5640_get_gain(sensor); if (val < 0) return val; sensor->ctrls.gain->val = val; break; case V4L2_CID_EXPOSURE_AUTO: val = ov5640_get_exposure(sensor); if (val < 0) return val; sensor->ctrls.exposure->val = val; break; } return 0; } static int ov5640_s_ctrl(struct v4l2_ctrl *ctrl) { struct v4l2_subdev *sd = ctrl_to_sd(ctrl); struct ov5640_dev *sensor = to_ov5640_dev(sd); int ret; /* v4l2_ctrl_lock() locks our own mutex */ /* * If the device is not powered up by the host driver do * not apply any controls to H/W at this time. Instead * the controls will be restored right after power-up. */ if (sensor->power_count == 0) return 0; switch (ctrl->id) { case V4L2_CID_AUTOGAIN: ret = ov5640_set_ctrl_gain(sensor, ctrl->val); break; case V4L2_CID_EXPOSURE_AUTO: ret = ov5640_set_ctrl_exposure(sensor, ctrl->val); break; case V4L2_CID_AUTO_WHITE_BALANCE: ret = ov5640_set_ctrl_white_balance(sensor, ctrl->val); break; case V4L2_CID_HUE: ret = ov5640_set_ctrl_hue(sensor, ctrl->val); break; case V4L2_CID_CONTRAST: ret = ov5640_set_ctrl_contrast(sensor, ctrl->val); break; case V4L2_CID_SATURATION: ret = ov5640_set_ctrl_saturation(sensor, ctrl->val); break; case V4L2_CID_TEST_PATTERN: ret = ov5640_set_ctrl_test_pattern(sensor, ctrl->val); break; case V4L2_CID_POWER_LINE_FREQUENCY: ret = ov5640_set_ctrl_light_freq(sensor, ctrl->val); break; case V4L2_CID_HFLIP: ret = ov5640_set_ctrl_hflip(sensor, ctrl->val); break; case V4L2_CID_VFLIP: ret = ov5640_set_ctrl_vflip(sensor, ctrl->val); break; default: ret = -EINVAL; break; } return ret; } static const struct v4l2_ctrl_ops ov5640_ctrl_ops = { .g_volatile_ctrl = ov5640_g_volatile_ctrl, .s_ctrl = ov5640_s_ctrl, }; static const char * const test_pattern_menu[] = { "Disabled", "Color bars", }; static int ov5640_init_controls(struct ov5640_dev *sensor) { const struct v4l2_ctrl_ops *ops = &ov5640_ctrl_ops; struct ov5640_ctrls *ctrls = &sensor->ctrls; struct v4l2_ctrl_handler *hdl = &ctrls->handler; int ret; v4l2_ctrl_handler_init(hdl, 32); /* we can use our own mutex for the ctrl lock */ hdl->lock = &sensor->lock; /* Clock related controls */ ctrls->pixel_rate = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_PIXEL_RATE, 0, INT_MAX, 1, 55969920); ctrls->pixel_rate->flags |= V4L2_CTRL_FLAG_READ_ONLY; /* Auto/manual white balance */ ctrls->auto_wb = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_AUTO_WHITE_BALANCE, 0, 1, 1, 1); ctrls->blue_balance = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_BLUE_BALANCE, 0, 4095, 1, 0); ctrls->red_balance = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_RED_BALANCE, 0, 4095, 1, 0); /* Auto/manual exposure */ ctrls->auto_exp = v4l2_ctrl_new_std_menu(hdl, ops, V4L2_CID_EXPOSURE_AUTO, V4L2_EXPOSURE_MANUAL, 0, V4L2_EXPOSURE_AUTO); ctrls->exposure = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_EXPOSURE, 0, 65535, 1, 0); /* Auto/manual gain */ ctrls->auto_gain = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_AUTOGAIN, 0, 1, 1, 1); ctrls->gain = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_GAIN, 0, 1023, 1, 0); ctrls->saturation = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_SATURATION, 0, 255, 1, 64); ctrls->hue = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_HUE, 0, 359, 1, 0); ctrls->contrast = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_CONTRAST, 0, 255, 1, 0); ctrls->test_pattern = v4l2_ctrl_new_std_menu_items(hdl, ops, V4L2_CID_TEST_PATTERN, ARRAY_SIZE(test_pattern_menu) - 1, 0, 0, test_pattern_menu); ctrls->hflip = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_HFLIP, 0, 1, 1, 0); ctrls->vflip = v4l2_ctrl_new_std(hdl, ops, V4L2_CID_VFLIP, 0, 1, 1, 0); ctrls->light_freq = v4l2_ctrl_new_std_menu(hdl, ops, V4L2_CID_POWER_LINE_FREQUENCY, V4L2_CID_POWER_LINE_FREQUENCY_AUTO, 0, V4L2_CID_POWER_LINE_FREQUENCY_50HZ); if (hdl->error) { ret = hdl->error; goto free_ctrls; } ctrls->gain->flags |= V4L2_CTRL_FLAG_VOLATILE; ctrls->exposure->flags |= V4L2_CTRL_FLAG_VOLATILE; v4l2_ctrl_auto_cluster(3, &ctrls->auto_wb, 0, false); v4l2_ctrl_auto_cluster(2, &ctrls->auto_gain, 0, true); v4l2_ctrl_auto_cluster(2, &ctrls->auto_exp, 1, true); sensor->sd.ctrl_handler = hdl; return 0; free_ctrls: v4l2_ctrl_handler_free(hdl); return ret; } static int ov5640_enum_frame_size(struct v4l2_subdev *sd, struct v4l2_subdev_pad_config *cfg, struct v4l2_subdev_frame_size_enum *fse) { if (fse->pad != 0) return -EINVAL; if (fse->index >= OV5640_NUM_MODES) return -EINVAL; fse->min_width = ov5640_mode_data[fse->index].hact; fse->max_width = fse->min_width; fse->min_height = ov5640_mode_data[fse->index].vact; fse->max_height = fse->min_height; return 0; } static int ov5640_enum_frame_interval( struct v4l2_subdev *sd, struct v4l2_subdev_pad_config *cfg, struct v4l2_subdev_frame_interval_enum *fie) { struct ov5640_dev *sensor = to_ov5640_dev(sd); struct v4l2_fract tpf; int ret; if (fie->pad != 0) return -EINVAL; if (fie->index >= OV5640_NUM_FRAMERATES) return -EINVAL; tpf.numerator = 1; tpf.denominator = ov5640_framerates[fie->index]; ret = ov5640_try_frame_interval(sensor, &tpf, fie->width, fie->height); if (ret < 0) return -EINVAL; fie->interval = tpf; return 0; } static int ov5640_g_frame_interval(struct v4l2_subdev *sd, struct v4l2_subdev_frame_interval *fi) { struct ov5640_dev *sensor = to_ov5640_dev(sd); mutex_lock(&sensor->lock); fi->interval = sensor->frame_interval; mutex_unlock(&sensor->lock); return 0; } static int ov5640_s_frame_interval(struct v4l2_subdev *sd, struct v4l2_subdev_frame_interval *fi) { struct ov5640_dev *sensor = to_ov5640_dev(sd); const struct ov5640_mode_info *mode; int frame_rate, ret = 0; u64 rate; if (fi->pad != 0) return -EINVAL; mutex_lock(&sensor->lock); if (sensor->streaming) { ret = -EBUSY; goto out; } mode = sensor->current_mode; frame_rate = ov5640_try_frame_interval(sensor, &fi->interval, mode->hact, mode->vact); if (frame_rate < 0) { /* Always return a valid frame interval value */ fi->interval = sensor->frame_interval; goto out; } mode = ov5640_find_mode(sensor, frame_rate, mode->hact, mode->vact, true); if (!mode) { ret = -EINVAL; goto out; } if (mode != sensor->current_mode || frame_rate != sensor->current_fr) { sensor->current_fr = frame_rate; sensor->frame_interval = fi->interval; sensor->current_mode = mode; sensor->pending_mode_change = true; rate = sensor->current_mode->vtot * sensor->current_mode->htot; rate *= ov5640_framerates[sensor->current_fr]; sensor->pixel_rate = rate; __v4l2_ctrl_s_ctrl_int64(sensor->ctrls.pixel_rate, sensor->pixel_rate); } out: mutex_unlock(&sensor->lock); return ret; } static int ov5640_enum_mbus_code(struct v4l2_subdev *sd, struct v4l2_subdev_pad_config *cfg, struct v4l2_subdev_mbus_code_enum *code) { if (code->pad != 0) return -EINVAL; if (code->index >= ARRAY_SIZE(ov5640_formats)) return -EINVAL; code->code = ov5640_formats[code->index].code; return 0; } static int ov5640_s_stream(struct v4l2_subdev *sd, int enable) { struct ov5640_dev *sensor = to_ov5640_dev(sd); int ret = 0; mutex_lock(&sensor->lock); if (sensor->streaming == !enable) { if (enable && sensor->pending_mode_change) { ret = ov5640_set_mode(sensor); if (ret) goto out; } if (enable && sensor->pending_fmt_change) { ret = ov5640_set_framefmt(sensor, &sensor->fmt); if (ret) goto out; sensor->pending_fmt_change = false; } if (sensor->ep.bus_type == V4L2_MBUS_CSI2) ret = ov5640_set_stream_mipi(sensor, enable); else ret = ov5640_set_stream_dvp(sensor, enable); if (!ret) sensor->streaming = enable; } out: mutex_unlock(&sensor->lock); return ret; } static const struct v4l2_subdev_core_ops ov5640_core_ops = { .s_power = ov5640_s_power, .log_status = v4l2_ctrl_subdev_log_status, .subscribe_event = v4l2_ctrl_subdev_subscribe_event, .unsubscribe_event = v4l2_event_subdev_unsubscribe, }; static const struct v4l2_subdev_video_ops ov5640_video_ops = { .g_frame_interval = ov5640_g_frame_interval, .s_frame_interval = ov5640_s_frame_interval, .s_stream = ov5640_s_stream, }; static const struct v4l2_subdev_pad_ops ov5640_pad_ops = { .enum_mbus_code = ov5640_enum_mbus_code, .get_fmt = ov5640_get_fmt, .set_fmt = ov5640_set_fmt, .enum_frame_size = ov5640_enum_frame_size, .enum_frame_interval = ov5640_enum_frame_interval, }; static const struct v4l2_subdev_ops ov5640_subdev_ops = { .core = &ov5640_core_ops, .video = &ov5640_video_ops, .pad = &ov5640_pad_ops, }; static int ov5640_get_regulators(struct ov5640_dev *sensor) { int i; for (i = 0; i < OV5640_NUM_SUPPLIES; i++) sensor->supplies[i].supply = ov5640_supply_name[i]; return devm_regulator_bulk_get(&sensor->i2c_client->dev, OV5640_NUM_SUPPLIES, sensor->supplies); } static int ov5640_check_chip_id(struct ov5640_dev *sensor) { struct i2c_client *client = sensor->i2c_client; int ret = 0; u16 chip_id; ov5640_init_slave_id(sensor); /*ret = ov5640_set_power_on(sensor); //cispl if (ret) return ret;*/ ret = ov5640_cispl_read_reg(sensor, OV5640_REG_SYS_CARAVEL, &chip_id); //ret = ov5640_read_reg16(sensor, OV5640_REG_CHIP_ID, &chip_id); if (ret) { dev_err(&client->dev, "%s: failed to read chip identifier\n", __func__); // goto power_off; } if (chip_id != 0x5640) { dev_err(&client->dev, "%s: wrong chip identifier, expected 0x5640, got 0x%x\n", __func__, chip_id); ret = -ENXIO; } //power_off: // ov5640_set_power_off(sensor); // return ret; } static int ov5640_probe(struct i2c_client *client, const struct i2c_device_id *id) { struct device *dev = &client->dev; struct fwnode_handle *endpoint; struct ov5640_dev *sensor; struct v4l2_mbus_framefmt *fmt; u32 rotation; int ret; sensor = devm_kzalloc(dev, sizeof(*sensor), GFP_KERNEL); if (!sensor) return -ENOMEM; sensor->i2c_client = client; /* * default init sequence initialize sensor to * YUV422 UYVY VGA@30fps */ fmt = &sensor->fmt; fmt->code = MEDIA_BUS_FMT_YUYV8_2X8; fmt->colorspace = V4L2_COLORSPACE_JPEG; fmt->ycbcr_enc = V4L2_MAP_YCBCR_ENC_DEFAULT(fmt->colorspace); fmt->quantization = V4L2_QUANTIZATION_FULL_RANGE; fmt->xfer_func = V4L2_MAP_XFER_FUNC_DEFAULT(fmt->colorspace); fmt->width = 1920; fmt->height = 1080; fmt->field = V4L2_FIELD_NONE; sensor->frame_interval.numerator = 1; sensor->frame_interval.denominator = ov5640_framerates[OV5640_30_FPS]; sensor->current_fr = OV5640_30_FPS; sensor->current_mode = &ov5640_mode_data[OV5640_MODE_1080P_1920_1080]; sensor->last_mode = sensor->current_mode; sensor->ae_target = 52; /* optional indication of physical rotation of sensor */ ret = fwnode_property_read_u32(dev_fwnode(&client->dev), "rotation", &rotation); if (!ret) { switch (rotation) { case 180: sensor->upside_down = true; /* fall through */ case 0: break; default: dev_warn(dev, "%u degrees rotation is not supported, ignoring...\n", rotation); } } endpoint = fwnode_graph_get_next_endpoint(dev_fwnode(&client->dev), NULL); if (!endpoint) { dev_err(dev, "endpoint node not found\n"); return -EINVAL; } ret = v4l2_fwnode_endpoint_parse(endpoint, &sensor->ep); fwnode_handle_put(endpoint); if (ret) { dev_err(dev, "Could not parse endpoint\n"); return ret; } /* get system clock (xclk) */ /*sensor->xclk = devm_clk_get(dev, "xclk"); if (IS_ERR(sensor->xclk)) { dev_err(dev, "failed to get xclk\n"); return PTR_ERR(sensor->xclk); } sensor->xclk_freq = clk_get_rate(sensor->xclk); if (sensor->xclk_freq < OV5640_XCLK_MIN || sensor->xclk_freq > OV5640_XCLK_MAX) { dev_err(dev, "xclk frequency out of range: %d Hz\n", sensor->xclk_freq); return -EINVAL; }*/ sensor->xclk_freq = OV5640_XCLK_MAX; /* request optional power down pin */ sensor->pwdn_gpio = devm_gpiod_get_optional(dev, "powerdown", GPIOD_OUT_HIGH); /* request optional reset pin */ sensor->reset_gpio = devm_gpiod_get_optional(dev, "reset", GPIOD_OUT_HIGH); v4l2_i2c_subdev_init(&sensor->sd, client, &ov5640_subdev_ops); sensor->sd.flags |= V4L2_SUBDEV_FL_HAS_DEVNODE | V4L2_SUBDEV_FL_HAS_EVENTS; sensor->pad.flags = MEDIA_PAD_FL_SOURCE; sensor->sd.entity.function = MEDIA_ENT_F_CAM_SENSOR; ret = media_entity_pads_init(&sensor->sd.entity, 1, &sensor->pad); if (ret) return ret; ret = ov5640_get_regulators(sensor); if (ret) return ret; mutex_init(&sensor->lock); ret = ov5640_check_chip_id(sensor); // if (ret) // goto entity_cleanup; // ret = ov5640_init_controls(sensor); // if (ret) // goto entity_cleanup; ret = v4l2_async_register_subdev(&sensor->sd); if (ret) goto free_ctrls; return 0; free_ctrls: v4l2_ctrl_handler_free(&sensor->ctrls.handler); entity_cleanup: mutex_destroy(&sensor->lock); media_entity_cleanup(&sensor->sd.entity); return ret; } static int ov5640_remove(struct i2c_client *client) { struct v4l2_subdev *sd = i2c_get_clientdata(client); struct ov5640_dev *sensor = to_ov5640_dev(sd); v4l2_async_unregister_subdev(&sensor->sd); mutex_destroy(&sensor->lock); media_entity_cleanup(&sensor->sd.entity); v4l2_ctrl_handler_free(&sensor->ctrls.handler); return 0; } static const struct i2c_device_id ov5640_id[] = { {"ov5640", 0}, {}, }; MODULE_DEVICE_TABLE(i2c, ov5640_id); static const struct of_device_id ov5640_dt_ids[] = { { .compatible = "ovti,ov5640" }, { /* sentinel */ } }; MODULE_DEVICE_TABLE(of, ov5640_dt_ids); static struct i2c_driver ov5640_i2c_driver = { .driver = { .name = "ov5640", .of_match_table = ov5640_dt_ids, }, .id_table = ov5640_id, .probe = ov5640_probe, .remove = ov5640_remove, }; module_i2c_driver(ov5640_i2c_driver); MODULE_DESCRIPTION("OV5640 MIPI Camera Subdev Driver"); MODULE_LICENSE("GPL");
Output of :
U-Boot 2019.01 (Dec 23 2021 - 18:29:37 +0530) CPU : DRA752-GP ES2.0 Model: TI AM5728 BeagleBoard-X15 rev C Board: BeagleBoard X15 REV C.00 DRAM: 2 GiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 Loading Environment from FAT... OK Net: Warning: ethernet@48484000 using MAC address from ROM eth0: ethernet@48484000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 ** Unable to read file boot.scr ** 1490 bytes read in 1 ms (1.4 MiB/s) Loaded env from uEnv.txt Importing environment from mmc0 ... Running uenvcmd ... 1 bytes read in 1 ms (1000 Bytes/s) Already setup. switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 4403712 bytes read in 196 ms (21.4 MiB/s) 131858 bytes read in 8 ms (15.7 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8ffdc000, end 8ffff311 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.59-g5f8c1c6121 (root@ubuntu-OptiPlex-3040) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #11 SMP PREEMPT Fri Dec 31 14:58:49 IST 2021 [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: TI AM5728 BeagleBoard-X15 rev C [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB [ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000 [ 0.000000] OMAP4: Map 0x00000000ffd00000 to (ptrval) for dram barrier [ 0.000000] DRA752 ES2.0 [ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0 [ 0.000000] percpu: Embedded 16 pages/cpu s36492 r8192 d20852 u65536 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 472640 [ 0.000000] Kernel command line: console=ttyS2,115200n8 root=PARTUUID=0f3f03ba-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 1673648K/1897472K available (10240K kernel code, 333K rwdata, 2772K rodata, 2048K init, 269K bss, 35408K reserved, 188416K cma-reserved, 1283072K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (12256 kB) [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB) [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 334 kB) [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 270 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] OMAP clockevent source: timer1 at 32786 Hz [ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns [ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns [ 0.000018] Switching to timer-based delay loop, resolution 162ns [ 0.000300] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000309] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000817] Console: colour dummy device 80x30 [ 0.000860] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475) [ 0.000877] pid_max: default: 32768 minimum: 301 [ 0.000998] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001014] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001567] CPU: Testing write buffer coherency: ok [ 0.001606] CPU0: Spectre v2: using ICIALLU workaround [ 0.001816] /cpus/cpu@0 missing clock-frequency property [ 0.001836] /cpus/cpu@1 missing clock-frequency property [ 0.001849] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.059905] Setting up static identity map for 0x80200000 - 0x80200060 [ 0.079916] rcu: Hierarchical SRCU implementation. [ 0.100105] EFI services will not be available. [ 0.119979] smp: Bringing up secondary CPUs ... [ 0.200375] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.200380] CPU1: Spectre v2: using ICIALLU workaround [ 0.200503] smp: Brought up 1 node, 2 CPUs [ 0.200515] SMP: Total of 2 processors activated (24.59 BogoMIPS). [ 0.200524] CPU: All CPU(s) started in HYP mode. [ 0.200532] CPU: Virtualization extensions available. [ 0.201085] devtmpfs: initialized [ 0.220091] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.220377] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.220422] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.223526] pinctrl core: initialized pinctrl subsystem [ 0.224026] DMI not present or invalid. [ 0.224299] NET: Registered protocol family 16 [ 0.225436] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.226376] omap_hwmod: l3_main_2 using broken dt data from ocp [ 0.328731] wkupaon_cm:clk:0068:0: failed to disable [ 0.428463] cpuidle: using governor ladder [ 0.428498] cpuidle: using governor menu [ 0.438700] OMAP GPIO hardware version 0.1 [ 0.462841] No ATAGs? [ 0.462918] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.462932] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.463461] omap4_sram_init:Unable to allocate sram needed to handle errata I688 [ 0.463474] omap4_sram_init:Unable to get sram pool needed to handle errata I688 [ 0.464104] OMAP DMA hardware revision 0.0 [ 0.475134] edma 43300000.edma: memcpy is disabled [ 0.478391] edma 43300000.edma: TI EDMA DMA engine driver [ 0.485284] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported) [ 0.486072] evm_5v0: supplied by main_12v0 [ 0.489402] omap-iommu 40d01000.mmu: 40d01000.mmu registered [ 0.489581] omap-iommu 40d02000.mmu: 40d02000.mmu registered [ 0.489816] omap-iommu 58882000.mmu: 58882000.mmu registered [ 0.490067] omap-iommu 55082000.mmu: 55082000.mmu registered [ 0.490429] omap-iommu 41501000.mmu: 41501000.mmu registered [ 0.490602] omap-iommu 41502000.mmu: 41502000.mmu registered [ 0.490875] iommu: Adding device 58820000.ipu to group 1 [ 0.490954] iommu: Adding device 55020000.ipu to group 2 [ 0.491078] iommu: Adding device 40800000.dsp to group 0 [ 0.491304] iommu: Adding device 41000000.dsp to group 3 [ 0.492530] SCSI subsystem initialized [ 0.493571] palmas 0-0058: Irq flag is 0x00000008 [ 0.521299] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0 [ 0.522891] SMPS12: supplied by regulator-dummy [ 0.524568] SMPS3: supplied by regulator-dummy [ 0.526218] SMPS45: supplied by regulator-dummy [ 0.528014] SMPS6: supplied by regulator-dummy [ 0.529450] SMPS7: supplied by regulator-dummy [ 0.530822] SMPS8: supplied by regulator-dummy [ 0.532078] SMPS9: supplied by regulator-dummy [ 0.532749] LDO1: supplied by regulator-dummy [ 0.539812] LDO2: supplied by regulator-dummy [ 0.540309] random: fast init done [ 0.549682] LDO3: supplied by regulator-dummy [ 0.559688] LDO4: supplied by regulator-dummy [ 0.569715] LDO5: supplied by regulator-dummy [ 0.570388] LDO6: supplied by regulator-dummy [ 0.571077] LDO7: supplied by regulator-dummy [ 0.571760] LDO8: supplied by regulator-dummy [ 0.572457] LDO9: supplied by regulator-dummy [ 0.579736] LDOLN: supplied by regulator-dummy [ 0.589760] LDOUSB: supplied by regulator-dummy [ 0.602133] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz [ 0.602717] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz [ 0.602928] media: Linux media interface: v0.10 [ 0.602968] videodev: Linux video capture interface: v2.00 [ 0.603040] pps_core: LinuxPPS API ver. 1 registered [ 0.603050] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.603071] PTP clock support registered [ 0.603106] EDAC MC: Ver: 3.0.0 [ 0.603892] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [ 0.604137] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [ 0.604620] Advanced Linux Sound Architecture Driver Initialized. [ 0.605390] clocksource: Switched to clocksource arch_sys_counter [ 0.613605] NET: Registered protocol family 2 [ 0.614191] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes) [ 0.614221] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.614284] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.614410] TCP: Hash tables configured (established 8192 bind 8192) [ 0.614481] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.614516] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.614644] NET: Registered protocol family 1 [ 0.615052] RPC: Registered named UNIX socket transport module. [ 0.615063] RPC: Registered udp transport module. [ 0.615072] RPC: Registered tcp transport module. [ 0.615080] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.616116] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.616303] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.617276] Initialise system trusted keyrings [ 0.617415] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 0.622237] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.622702] NFS: Registering the id_resolver key type [ 0.622725] Key type id_resolver registered [ 0.622735] Key type id_legacy registered [ 0.622777] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.624328] Key type asymmetric registered [ 0.624340] Asymmetric key parser 'x509' registered [ 0.624390] bounce: pool size: 64 pages [ 0.624424] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.624435] io scheduler noop registered [ 0.624444] io scheduler deadline registered [ 0.624538] io scheduler cfq registered (default) [ 0.624550] io scheduler mq-deadline registered [ 0.624559] io scheduler kyber registered [ 0.630264] pinctrl-single 4a003400.pinmux: 282 pins, size 1128 [ 0.633797] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1 [ 0.634057] dra7-pcie 51000000.pcie: WA for Errata i870 not applied [ 0.634146] dra7-pcie 51000000.pcie: host bridge /ocp/axi@0/pcie@51000000 ranges: [ 0.634187] dra7-pcie 51000000.pcie: IO 0x20003000..0x20012fff -> 0x00000000 [ 0.634216] dra7-pcie 51000000.pcie: MEM 0x20013000..0x2fffffff -> 0x20013000 [ 1.634502] dra7-pcie 51000000.pcie: Phy link never came up [ 1.634640] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00 [ 1.634655] pci_bus 0000:00: root bus resource [bus 00-ff] [ 1.634667] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 1.634679] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff] [ 1.641083] PCI: bus0: Fast back to back transfers disabled [ 1.646946] PCI: bus1: Fast back to back transfers enabled [ 1.646990] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit] [ 1.647010] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [ 1.647327] pcieport 0000:00:00.0: Signaling PME with IRQ 172 [ 1.647457] pcieport 0000:00:00.0: AER enabled with IRQ 172 [ 1.651119] vdd_3v3: supplied by regen1 [ 1.651348] aic_dvdd_fixed: supplied by vdd_3v3 [ 1.651412] vtt_fixed: supplied by smps3 [ 1.695299] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 1.698822] console [ttyS2] disabled [ 1.698878] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 45, base_baud = 3000000) is a 8250 [ 2.804396] console [ttyS2] enabled [ 2.810237] omap_rng 48090000.rng: Random Number Generator ver. 20 [ 2.810589] random: crng init done [ 2.817362] omapdss_dss 58000000.dss: Linked as a consumer to regulator.22 [ 2.826959] DSS: OMAP DSS rev 6.1 [ 2.833170] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.16 [ 2.840732] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.16 [ 2.861020] brd: module loaded [ 2.870184] loop: module loaded [ 2.877300] libphy: Fixed MDIO Bus: probed [ 2.935417] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 2.943113] libphy: 48485000.mdio: probed [ 2.951851] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY [ 2.961574] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver Micrel KSZ9031 Gigabit PHY [ 2.971825] cpsw 48484000.ethernet: Detected MACID = d4:36:39:26:8c:68 [ 2.978443] cpsw 48484000.ethernet: initialized cpsw ale version 1.4 [ 2.984827] cpsw 48484000.ethernet: ALE Table size 1024 [ 2.990134] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies) [ 2.998113] cpsw 48484000.ethernet: cpsw: Detected MACID = d4:36:39:26:8c:69 [ 3.006393] i2c /dev entries driver [ 3.013031] gpio-fan gpio_fan: GPIO fan initialized [ 3.019094] tmp102 0-0048: initialized [ 3.025888] cpu cpu0: Linked as a consumer to regulator.6 [ 3.031383] cpu cpu0: Linked as a consumer to regulator.29 [ 3.038524] sdhci: Secure Digital Host Controller Interface driver [ 3.044734] sdhci: Copyright(c) Pierre Ossman [ 3.050359] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.056697] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22) [ 3.065557] sdhci-omap 4809c000.mmc: Got CD GPIO [ 3.070352] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.28 [ 3.077389] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.13 [ 3.084257] sdhci-omap 4809c000.mmc: Dropping the link to regulator.13 [ 3.090899] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.3 [ 3.097825] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.13 [ 3.104763] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode [ 3.135908] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA [ 3.144042] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.3 [ 3.150879] sdhci-omap 480b4000.mmc: Dropping the link to regulator.3 [ 3.157664] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.3 [ 3.188176] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA [ 3.196671] ledtrig-cpu: registered to indicate activity on CPUs [ 3.209023] NET: Registered protocol family 10 [ 3.214246] Segment Routing with IPv6 [ 3.218024] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 3.224368] NET: Registered protocol family 17 [ 3.229057] Key type dns_resolver registered [ 3.233474] Registering SWP/SWPB emulation handler [ 3.238338] omap_voltage_late_init: Voltage driver support not added [ 3.244739] Power Management for TI OMAP4+ devices. [ 3.250243] Loading compiled-in X.509 certificates [ 3.260069] mmc0: host does not support reading read-only switch, assuming write-enable [ 3.271059] mmc0: new high speed SDHC card at address aaaa [ 3.277806] mmc1: new DDR MMC card at address 0001 [ 3.282883] dmm 4e000000.dmm: workaround for errata i878 in use [ 3.287314] mmcblk0: mmc0:aaaa SD32G 29.7 GiB [ 3.293764] mmcblk1: mmc1:0001 M62704 3.53 GiB [ 3.298373] dmm 4e000000.dmm: initialized all PAT entries [ 3.298748] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB [ 3.310136] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.16 [ 3.310650] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB [ 3.317667] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.16 [ 3.330915] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB, chardev (244:0) [ 3.338254] mmcblk0: p1 p2 [ 3.341853] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.16 [ 3.342447] mmcblk1: p1 [ 3.353345] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops) [ 3.361350] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops) [ 3.370063] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.376725] [drm] No driver support for vblank timestamp query. [ 3.382685] [drm] Cannot find any crtc or sizes [ 3.387923] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0 [ 3.395522] hctosys: unable to open rtc device (rtc0) [ 3.401184] aic_dvdd_fixed: disabling [ 3.405023] ldousb: disabling [ 3.408306] ALSA device list: [ 3.411285] No soundcards found. [ 3.434404] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 3.442580] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 3.456524] devtmpfs: mounted [ 3.460379] Freeing unused kernel memory: 2048K [ 3.465026] Run /sbin/init as init process [ 3.823309] systemd[1]: System time before build time, advancing clock. [ 3.857551] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 3.879437] systemd[1]: Detected architecture arm. Welcome to Arago 2019.07! [ 3.916489] systemd[1]: Set hostname to <am57xx-evm>. [ 4.095030] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 4.112214] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 4.322359] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 4.355755] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 4.385842] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 4.415450] [drm] Cannot find any crtc or sizes [ 4.415537] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 4.445685] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Listening on Journal Socket. [ OK ] Started Hardware RNG Entropy Gatherer Daemon. Starting Load Kernel Modules... Mounting Kernel Debug File System... [ 4.618329] cmemk: loading out-of-tree module taints kernel. [ 4.625117] CMEMK module: reference Linux version 4.19.59 Mounting POSIX Message Queue File System... [ 4.631211] allocated heap buffer 0x40500000 of size 0x100000 [ 4.640423] cmemk initialized [ 4.650865] cryptodev: driver 1.9 loaded. Starting Create list of required st…ce nodes for the current kernel... Starting Remount Root and Kernel File Systems... [ 4.704568] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 4.717326] usbcore: registered new interface driver usbfs [ 4.722868] usbcore: registered new interface driver hub [ 4.728785] usbcore: registered new device driver usb Mounting Temporary Directory (/tmp)... [ 4.749212] usbcore: registered new interface driver ftdi_sio [ 4.755020] usbserial: USB Serial support registered for FTDI USB Serial Device [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Reached target Paths. [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Created slice system-getty.slice. [ OK ] Listening on udev Kernel Socket. Starting udev Coldplug all Devices... [ OK ] Created slice User and Session Slice. [ OK ] Listening on Process Core Dump Socket. Starting Journal Service... [ OK ] Reached target Slices. [ OK ] Listening on Network Service Netlink Socket. [ OK ] Created slice system-serial\x2dgetty.slice. [ OK ] Started Journal Service. [ OK ] Started Load Kernel Modules. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Started Create list of required sta…vice nodes for the current kernel. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Mounted Temporary Directory (/tmp). Starting Create Static Device Nodes in /dev... Mounting Kernel Configuration File System... Starting Apply Kernel Variables... Starting Flush Journal to Persistent Storage... [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Apply Kernel Variables. [ 5.583375] systemd-journald[106]: Received request to flush runtime journal from PID 1 Starting udev Kernel Device Manager... [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... [ OK ] Reached target Containers. Mounting /var/volatile... [ OK ] Started udev Kernel Device Manager. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started Load/Save Random Seed. [ 5.941047] omap-rproc 58820000.ipu: ignoring dependency for device, assuming no driver [ 5.992893] omap-rproc 58820000.ipu: ignoring dependency for device, assuming no driver [ 6.042606] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000 [ OK ] Found device /dev/ttyS2. [ 6.105337] remoteproc remoteproc0: 58820000.ipu is available [ OK ] Started Create Volatile Files and Directories. Starting Update UTMP about System Boot/Shutdown... [ 6.157033] omap-rproc 55020000.ipu: ignoring dependency for device, assuming no driver Starting Network Service... [ 6.201717] omap-rproc 55020000.ipu: ignoring dependency for device, assuming no driver Starting Network Time Synchronization... [ 6.226820] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000 [ OK ] Started udev Coldplug all Devices. [ 6.239299] remoteproc remoteproc1: 55020000.ipu is available [ 6.281360] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver [ OK ] Started Update UTMP about System Boot/Shutdow[ 6.304501] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver n. [ 6.352470] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000 [ 6.361522] remoteproc remoteproc2: 40800000.dsp is available [ 6.384840] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver [ 6.400556] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver [ 6.416789] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000 [ 6.425308] remoteproc remoteproc3: 41000000.dsp is available [ 6.511841] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659038@58:tps659038_rtc as rtc1 [ 6.891461] omap_rtc 48838000.rtc: registered as rtc2 [ 6.899609] Driver for 1-wire Dallas network protocol. [ 6.912203] remoteproc remoteproc1: powering up 55020000.ipu [ 6.917943] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3747220 [ 6.926271] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1 [ 6.977675] remoteproc remoteproc0: powering up 58820000.ipu [ 6.983371] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 6726740 [ 7.010839] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1 [ 7.017845] virtio_rpmsg_bus virtio0: rpmsg host is online [ 7.024273] remoteproc remoteproc1: registered virtio0 (type 7) [ 7.030574] remoteproc remoteproc1: remote processor 55020000.ipu is now up [ 7.038084] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65 [ 7.045642] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x66 [ 7.064089] virtio_rpmsg_bus virtio1: rpmsg host is online [ 7.076344] remoteproc remoteproc0: registered virtio1 (type 7) [ 7.082296] remoteproc remoteproc0: remote processor 58820000.ipu is now up [ 7.158409] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write [ 7.185447] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.:. Driver in Interrupt mode [ 7.226539] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x3d [ 7.243788] virtio_rpmsg_bus virtio1: msg received with no recipient [ 7.253200] tlv320aic3x-codec 0-0018: Linked as a consumer to regulator.3 [ 7.261156] tlv320aic3x-codec 0-0018: Linked as a consumer to regulator.4 [ 7.372207] ov5640 2-003c: 2-003c supply DOVDD not found, using dummy regulator [ 7.386084] ov5640 2-003c: Linked as a consumer to regulator.0 [ 7.391975] ov5640 2-003c: 2-003c supply DVDD not found, using dummy regulator [ 7.400288] ov5640 2-003c: 2-003c supply AVDD not found, using dummy regulator [ 7.408385] ov5640 2-003c: ov5640_init_slave_id: client->addr= 3c [ 7.416019] w1_master_driver w1_bus_master1: Attaching one wire slave 01.000000000000 crc 3d [ 7.431775] w1_master_driver w1_bus_master1: Family 1 for 01.000000000000.3d is not registered. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Initialization. [ OK ] Listening on RPCbind Server Activation Socket. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ 7.582720] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2 [ 7.590476] net eth1: initializing cpsw version 1.15 (0) Starting Reboot and dump vmcore via kexec... [ 7.605431] omap-des 480a5000.des: will run requests pump with realtime priority [ 7.739887] Micrel KSZ9031 Gigabit PHY 48485000.mdio:02: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:02, irq=POLL) [ 7.758390] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 7.767323] net eth0: initializing cpsw version 1.15 (0) [ 7.827684] phy phy-4a084000.phy.3: Linked as a consumer to regulator.23 [ 7.838220] phy phy-4a085000.phy.4: Linked as a consumer to regulator.23 [ OK ] Listening on dropbear.socket. [ 7.847124] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3 [ 7.857185] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin [ OK ] Started Daily Cleanup of Temporary Directorie[ 7.866261] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec s. [ 7.922433] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:01, irq=POLL) [ 7.943552] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 7.985577] vpe 489d0000.vpe: Device registered as /dev/video0 [ 8.077066] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3 [ 8.087269] omap-aes 4b500000.aes: will run requests pump with realtime priority [ 8.101428] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3 [ 8.107421] omap-aes 4b700000.aes: will run requests pump with realtime priority [ OK ] Listening on D-Bus System Message Bus Socket.[ 8.166757] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok [ OK ] Reached target Sockets. [ 8.182219] omap-hdmi-audio omap-hdmi-audio.0.auto: ASoC: no DMI vendor name! [ OK ] Reached target Basic System. [ 8.243859] virtio_rpmsg_bus virtio1: msg received with no recipient [ 8.322923] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.gpu on minor 1 [ OK ] Started Periodic Command Scheduler. Starting TI MultiCore Tools Daemon... Starting TI IPC Daemon... [ OK ] Started Job spooling tools. [ 8.608802] ahci 4a140000.sata: controller can't do 64bit DMA, forcing 32bit [ 8.616232] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1 [ 8.623582] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 8.632301] ahci 4a140000.sata: flags: ncq sntf pm led clo only pmp pio slum part ccc apst [ 8.643142] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok Starting RPC Bind Service... [ 8.652433] asoc-simple-card sound0: ASoC: no DMI vendor name! Starting Print notice about GPLv3 packages... [ 8.683802] scsi host0: ahci [ 8.687059] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 80 [ OK ] Started D-Bus System Message Bus. Starting Login Service... Starting uim-sysfs.service... [ OK ] Reached target System Time Synchronized. [ OK ] Started Daily rotation of log files. [ OK ] Reached target Timers. [ OK ] Started Network Service. [ 8.883613] vip 48990000.vip: loading firmware vpdma-1b8.bin Starting Network Name Resolution... Starting Wait for Network to be Configured... [ 9.015406] vip 48990000.vip: VPDMA firmware loaded [ 9.021100] vin3a: Port A: Using subdev ov5640 2-003c for capture [ 9.027849] vin3a-0: device registered as video1 [ 9.031957] ata1: SATA link down (SStatus 0 SControl 300) [ 9.068123] remoteproc remoteproc3: powering up 41000000.dsp [ 9.073817] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 20481364 [ 9.093599] remoteproc remoteproc2: powering up 40800000.dsp [ 9.113728] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 20481364 [ 9.135622] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0 [ 9.141511] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0 [ 9.147935] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0 [ 9.153834] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0 [ 9.257165] virtio_rpmsg_bus virtio1: msg received with no recipient [ 9.265591] virtio_rpmsg_bus virtio2: rpmsg host is online [ 9.271737] remoteproc remoteproc3: registered virtio2 (type 7) [ 9.351720] remoteproc remoteproc3: remote processor 41000000.dsp is now up [ 9.458050] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d [ 9.523601] virtio_rpmsg_bus virtio3: rpmsg host is online [ 9.534728] remoteproc remoteproc2: registered virtio3 (type 7) [ OK ] Started Login Service. [ OK ] Started Network Name Resolution. [ OK ] Started Reboot and dump vmcore via kexec. [ OK ] Started TI MultiCore Tools Daemon. [ OK ] Started TI IPC Daemon. [ OK ] Started RPC Bind Se[ 9.578866] remoteproc remoteproc2: remote processor 40800000.dsp is now up rvice. [ 9.719176] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d [ 10.248858] virtio_rpmsg_bus virtio1: msg received with no recipient [ 11.070048] dwc3 48890000.usb: Failed to get clk 'ref': -2 [ 11.088584] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: probing service dce-callback with src 1024 dst 101 [ 11.097917] NET: Registered protocol family 45 [ 11.098835] dwc3 488d0000.usb: Failed to get clk 'ref': -2 [ OK ] Started uim-sysfs.service. [ 11.117845] rpmsg_rpc virtio0.rpmsg-rpc.-1.102: probing service rpmsg-dce with src 1025 dst 102 [ 11.118181] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: published functions = 4 [ 11.197896] rpmsg_rpc virtio0.rpmsg-rpc.-1.102: published functions = 9 [ 11.268470] Unable to handle kernel NULL pointer dereference at virtual address 0000001c [ 11.290303] remoteproc remoteproc4: 4b234000.pru is available [ 11.299818] pgd = a5537d37 [ 11.302804] [0000001c] *pgd=acffd003, *pmd=00000000 [ 11.322149] Internal error: Oops: 206 [#1] PREEMPT SMP ARM [ 11.327667] Modules linked in: pru_rproc(+) irq_pruss_intc pruss rpmsg_proto rpmsg_rpc dwc3 udc_core ti_vip snd_soc_simple_card ahci_platform snd_soc_simple_card_utils libahci_platform libahci pvrsrvkm(O) snd_soc_omap_hdmi omap_aes_driver libata pruss_soc_bus ti_vpe omap_wdt omap_sham phy_omap_usb2 ti_sc omap_des ti_csc ov5640 des_generic ti_vpdma snd_soc_tlv320aic3x at24 omap_hdq v4l2_fwnode crypto_engine omap_crypto dwc3_omap wire extcon_palmas rtc_omap rtc_palmas omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 11.327947] pru-rproc 4b234000.pru: PRU rproc node pru@4b234000 probed successfully [ 11.384102] CPU: 0 PID: 718 Comm: v4l_id Tainted: G O 4.19.59-g5f8c1c6121 #11 [ 11.384106] Hardware name: Generic DRA74X (Flattened Device Tree) [ 11.384118] PC is at __v4l2_ctrl_s_ctrl_int64+0x10/0x5c [ 11.384130] LR is at ov5640_set_fmt+0x1a0/0x288 [ov5640] [ 11.384137] pc : [<c07c34c0>] lr : [<bf1abfa4>] psr: 600f0013 [ 11.423254] sp : ec5fdb70 ip : ec5fdb90 fp : ec5fdb8c [ 11.428503] r10: 00000004 r9 : 00000000 r8 : 0000001e [ 11.433749] r7 : 00000000 r6 : ed693c44 r5 : 00000000 r4 : 00000000 [ 11.440300] r3 : 00000000 r2 : 0501bd00 r1 : 00000000 r0 : 00000000 [ 11.441493] remoteproc remoteproc5: 4b238000.pru is available [ 11.446852] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 11.446857] Control: 30c5387d Table: ad6b0880 DAC: fffffffd [ 11.446863] Process v4l_id (pid: 718, stack limit = 0x4f6a3e88) [ 11.446867] Stack: (0xec5fdb70 to 0xec5fe000) [ 11.446872] db60: 00000000 00000000 ed693c44 ed693d8c [ 11.446878] db80: ec5fdbb4 ec5fdb90 bf1abfa4 c07c34bc ec426040 bf339000 c1204c48 bf339400 [ 11.454604] pru-rproc 4b238000.pru: PRU rproc node pru@4b238000 probed successfully [ 11.459801] dba0: 00000000 00000000 ec5fdc4c ec5fdbb8 bf3354d8 bf1abe10 ec5fdbdc ec5fdbc8 [ 11.459806] dbc0: c030226c c0300f30 ffefe8e8 00000001 00000000 00000780 00000438 00002006 [ 11.459811] dbe0: 00000001 00000008 00010001 00000002 00000000 00000000 00000000 00000000 [ 11.459819] dc00: 00000000 ec5fdc10 c0215168 c0215028 c1066e2c 00000014 c0321f48 00000000 [ 11.466911] remoteproc remoteproc6: 4b2b4000.pru is available [ 11.471522] dc20: 00000001 a9166ef0 ec426040 c1204c48 00000000 ecd3f000 ed6a43c0 00000000 [ 11.476695] pru-rproc 4b2b4000.pru: PRU rproc node pru@4b2b4000 probed successfully [ 11.484096] dc40: ec5fdd54 ec5fdc50 bf33579c bf335320 00000081 ec5fdd04 00000002 a9166ef0 [ 11.493271] remoteproc remoteproc7: 4b2b8000.pru is available [ 11.499987] dc60: ec5fdd3c ecd3f000 00000081 006200ca ec52a750 b6e4e000 ecdee400 00000000 [ 11.499992] dc80: ec5fdd6c ec5fdc90 c02f915c c02f7a74 000000a0 c1204c48 ec5fdcb4 a9166ef0 [ 11.499996] dca0: c02ba800 a00f0013 ffffffff ec5fdcfc ec5fdd98 ec5fc000 ec5fdd34 ec5fdcc8 [ 11.500001] dcc0: c0201970 c021512c bf339200 00000001 ec5fc000 bf339200 ed9c77c0 bf339200 [ 11.500008] dce0: ee80dc00 ed9c77c0 ec5fdd98 00000000 ed9c77c0 bf339200 ec5fdd14 ec5fdd08 [ 11.509436] pru-rproc 4b2b8000.pru: PRU rproc node pru@4b2b8000 probed successfully [ 11.516422] dd00: ec5fdd1c ec5fdd10 c07b2a38 c07b29a8 ec5fdd34 ec5fdd20 c07bb128 c0a13090 [ 11.516426] dd20: edbe0780 ed6a43c0 ec5fdd54 ec5fdd38 ec5fdd54 a9166ef0 ecedaca4 ed6a43c0 [ 11.516431] dd40: 00000000 ecd3f000 ec5fdd74 ec5fdd58 bf3359a0 bf335778 ecf94000 bf335924 [ 11.516438] dd60: ed6a43c0 ecf940f0 ec5fdd94 ec5fdd78 c07b2fe0 bf335930 c0c80048 c1204c48 [ 11.649976] dd80: ed9c77c0 ece75470 ec5fddc4 ec5fdd98 c0359060 c07b2f68 00000000 a9166ef0 [ 11.658185] dda0: ed6a43c0 ece75470 00000000 00020000 ed6a43c8 c0358fac ec5fddec ec5fddc8 [ 11.666397] ddc0: c03509c4 c0358fb8 ec5fde90 00000000 00000000 00020000 ee4023b8 ed6a43c0 [ 11.674607] dde0: ec5fddfc ec5fddf0 c0351ed0 c03508b4 ec5fde8c ec5fde00 c036369c c0351ea8 [ 11.682816] de00: c0324130 c0219ba0 00000000 200f0013 c0ddac38 00080000 ffffe000 04600000 [ 11.691026] de20: 0000075f ffefe000 00000041 c1204c48 00000002 00000000 ed6a43c0 00000000 [ 11.699238] de40: 00000002 ece75470 edb05510 ec898c38 00000000 00000000 00000000 a9166ef0 [ 11.707447] de60: 00000000 c1204c48 c1204c48 ec5fde90 ec5fdf50 00000001 ec5fc000 00000142 [ 11.715656] de80: ec5fdf44 ec5fde90 c0365580 c03633f0 edb05510 ec898c38 ebcda8fb 00000006 [ 11.723866] dea0: ecdd2015 c027eab0 00000000 ee6d8000 ece75470 00000101 00000002 00000658 [ 11.732076] dec0: 00000000 00000000 00000000 ec5fded0 ec5fdf04 00000003 ed66c500 ed66c518 [ 11.740288] dee0: 00000000 00000400 ed66c540 00000020 ec5fdf34 ec5fdf00 c0373e5c c0a13038 [ 11.748499] df00: ecdd2000 00000000 00000001 00000002 ffffff9c ffffff9c ecdd2000 a9166ef0 [ 11.756708] df20: ec5fc000 00000003 c1204c48 ffffff9c ecdd2000 fffff000 ec5fdf94 ec5fdf48 [ 11.764917] df40: c03521cc c0365510 c02411fc c0a1319c 00020000 ec5f0000 00000004 00000100 [ 11.773127] df60: 00000001 a9166ef0 00000008 b6f1c968 00417f38 00000000 00000142 c0201204 [ 11.781336] df80: ec5fc000 00000142 ec5fdfa4 ec5fdf98 c0352288 c0352068 00000000 ec5fdfa8 [ 11.789548] dfa0: c0201000 c0352280 b6f1c968 00417f38 ffffff9c bed52f2c 00020000 00000000 [ 11.797757] dfc0: b6f1c968 00417f38 00000000 00000142 bed52e34 00000000 00417f38 00000000 [ 11.805966] dfe0: b6e7922c bed52c30 00405b59 b6e62680 600f0010 ffffff9c 00000000 00000000 [ 11.814173] Backtrace: [ 11.816640] [<c07c34b0>] (__v4l2_ctrl_s_ctrl_int64) from [<bf1abfa4>] (ov5640_set_fmt+0x1a0/0x288 [ov5640]) [ 11.826423] r7:ed693d8c r6:ed693c44 r5:00000000 r4:00000000 [ 11.832121] [<bf1abe04>] (ov5640_set_fmt [ov5640]) from [<bf3354d8>] (vip_init_port+0x1c4/0x458 [ti_vip]) [ 11.841727] r9:00000000 r8:00000000 r7:bf339400 r6:c1204c48 r5:bf339000 r4:ec426040 [ 11.849514] [<bf335314>] (vip_init_port [ti_vip]) from [<bf33579c>] (vip_init_stream+0x30/0x1b8 [ti_vip]) [ 11.859119] r9:00000000 r8:ed6a43c0 r7:ecd3f000 r6:00000000 r5:c1204c48 r4:ec426040 [ 11.866902] [<bf33576c>] (vip_init_stream [ti_vip]) from [<bf3359a0>] (vip_open+0x7c/0xac [ti_vip]) [ 11.875984] r7:ecd3f000 r6:00000000 r5:ed6a43c0 r4:ecedaca4 [ 11.881673] [<bf335924>] (vip_open [ti_vip]) from [<c07b2fe0>] (v4l2_open+0x84/0x110) [ 11.889535] r7:ecf940f0 r6:ed6a43c0 r5:bf335924 r4:ecf94000 [ 11.895220] [<c07b2f5c>] (v4l2_open) from [<c0359060>] (chrdev_open+0xb4/0x19c) [ 11.902557] r7:ece75470 r6:ed9c77c0 r5:c1204c48 r4:c0c80048 [ 11.908241] [<c0358fac>] (chrdev_open) from [<c03509c4>] (do_dentry_open+0x11c/0x3c0) [ 11.916103] r9:c0358fac r8:ed6a43c8 r7:00020000 r6:00000000 r5:ece75470 r4:ed6a43c0 [ 11.923877] [<c03508a8>] (do_dentry_open) from [<c0351ed0>] (vfs_open+0x34/0x38) [ 11.931301] r9:ed6a43c0 r8:ee4023b8 r7:00020000 r6:00000000 r5:00000000 r4:ec5fde90 [ 11.939077] [<c0351e9c>] (vfs_open) from [<c036369c>] (path_openat+0x2b8/0x1114) [ 11.946507] [<c03633e4>] (path_openat) from [<c0365580>] (do_filp_open+0x7c/0xe4) [ 11.954020] r10:00000142 r9:ec5fc000 r8:00000001 r7:ec5fdf50 r6:ec5fde90 r5:c1204c48 [ 11.961878] r4:c1204c48 [ 11.964422] [<c0365504>] (do_filp_open) from [<c03521cc>] (do_sys_open+0x170/0x1f4) [ 11.972108] r8:fffff000 r7:ecdd2000 r6:ffffff9c r5:c1204c48 r4:00000003 [ 11.978836] [<c035205c>] (do_sys_open) from [<c0352288>] (sys_openat+0x14/0x18) [ 11.986174] r10:00000142 r9:ec5fc000 r8:c0201204 r7:00000142 r6:00000000 r5:00417f38 [ 11.994033] r4:b6f1c968 [ 11.996578] [<c0352274>] (sys_openat) from [<c0201000>] (ret_fast_syscall+0x0/0x4c) [ 12.004263] Exception stack(0xec5fdfa8 to 0xec5fdff0) [ 12.009335] dfa0: b6f1c968 00417f38 ffffff9c bed52f2c 00020000 00000000 [ 12.017545] dfc0: b6f1c968 00417f38 00000000 00000142 bed52e34 00000000 00417f38 00000000 [ 12.025752] dfe0: b6e7922c bed52c30 00405b59 b6e62680 [ 12.030823] Code: e1a0c00d e92dd8f0 e24cb004 e1a07003 (e1d031dc) [ 12.072625] ---[ end trace ae3e54dd5ff30d07 ]--- [ 12.119390] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 12.131380] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 12.153294] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010 [ 12.175837] xhci-hcd xhci-hcd.1.auto: irq 179, io mem 0x48890000 [ 12.186668] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 12.197576] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 12.207876] usb usb1: Product: xHCI Host Controller [ 12.214453] usb usb1: Manufacturer: Linux 4.19.59-g5f8c1c6121 xhci-hcd [ 12.222420] usb usb1: SerialNumber: xhci-hcd.1.auto [ 12.229793] hub 1-0:1.0: USB hub found [ 12.234421] hub 1-0:1.0: 1 port detected [ 12.239838] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 12.246043] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 12.254061] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 12.264782] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 12.273962] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 12.282558] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 12.290597] usb usb2: Product: xHCI Host Controller [ 12.295911] usb usb2: Manufacturer: Linux 4.19.59-g5f8c1c6121 xhci-hcd [ 12.302713] usb usb2: SerialNumber: xhci-hcd.1.auto [ 12.312160] hub 2-0:1.0: USB hub found [ 12.317390] hub 2-0:1.0: 1 port detected [ 12.605463] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 12.785975] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00 [ 12.798274] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1 [ 12.806611] usb 1-1: SerialNumber: E3000079FEB7 [ 12.872898] hub 1-1:1.0: USB hub found [ 12.877215] hub 1-1:1.0: 4 ports detected [ 12.936810] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd [ 12.976023] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00 [ 12.984612] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 13.032932] hub 2-1:1.0: USB hub found [ 13.037967] hub 2-1:1.0: 4 ports detected [ 13.255434] usb 1-1.3: new low-speed USB device number 3 using xhci-hcd [ 13.401115] usb 1-1.3: New USB device found, idVendor=413c, idProduct=2003, bcdDevice= 3.01 [ 13.409752] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 13.418582] usb 1-1.3: Product: Dell USB Keyboard [ 13.423482] usb 1-1.3: Manufacturer: Dell [ 13.500565] input: Dell Dell USB Keyboard as /devices/platform/44000000.ocp/48880000.omap_dwc3_1/48890000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:2003.0001/input/input0 [ 13.588023] hid-generic 0003:413C:2003.0001: input: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-xhci-hcd.1.auto-1.3/input0 [ 13.601544] usbcore: registered new interface driver usbhid [ 13.609241] usbhid: USB HID core driver *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash bc binutils-dev binutils bison-dev bison cifs-utils cpio cpp-symlinks cpp dosfstools elfutils-dev elfutils findutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbc6x gdbserver gettext glmark2 gstreamer1.0-libav gzip hidapi libasm1 libbfd libcairo-perf-utils libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp10 libidn2-0 libmavconn libmpc3 libmpfr6 libreadline-dev libreadline7 libunistring2 m4-dev m4 make mavlink mavros-extras mavros-msgs mavros nettle parted pdm-anomaly-detection socketcan-interface swig-dev swig which If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** Starting Save/Restore Sound Card State... [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. Starting rc.pvr.service... [ OK ] Created slice system-systemd\x2dfsck.slice. [ 15.365810] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ] Starting File System Check on /dev/mmcblk0p1... Starting File System Check on /dev/mmcblk1p1... [ OK ] Reached target Network. Starting Enable and configure wl18xx bluetooth stack... Starting Lightning Fast Webserver With Light System Requirements... [ OK ] Started Redis In-Memory Data Store. Starting Permit User Sessions... Starting Simple Network Management Protocol (SNMP) Daemon.... [ OK ] Reached target Host and Network Name Lookups. [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Avahi mDNS/DNS-SD Stack... [ OK ] Started Print notice about GPLv3 packages. [ OK ] Started Save/Restore Sound Card State. [ OK ] Started rc.pvr.service. [ OK ] Started Enable and configure wl18xx bluetooth stack. [ OK ] Started Permit User Sessions. [ OK ] Started Serial Getty on ttyS2. [ OK ] Started Getty on tty1. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Starting weston.service... [ OK ] Reached target Sound Card. [ OK ] Started File System Check on /dev/mmcblk0p1. Mounting /run/media/mmcblk0p1... [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ OK ] Started File System Check on /dev/mmcblk1p1. [ OK ] Started weston.service. [ OK ] Started Lightning Fast Webserver With Light System Requirements. Starting Matrix GUI... Starting telnetd.service... Mounting /run/media/mmcblk1p1... [ OK ] Started telnetd.service. [ 15.941483] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null) [ OK ] Started Matrix GUI. [ OK ] Mounted /run/media/mmcblk0p1. [ OK ] Mounted /run/media/mmcblk1p1. [ OK ] Started Avahi mDNS/DNS-SD Stack. Starting thttpd.service... [ OK ] Started thttpd.service. [ 17.159025] l4per_cm:clk:00d0:0: failed to disable [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am57xx-evm ttyS2 Arago 2019.07 am57xx-evm ttyS2 am57xx-evm login: root root@am57xx-evm:~# cd .. root@am57xx-evm:/home# cd .. root@am57xx-evm:/# sudo dmesg | grep ov5640 [ 7.372084] ov5640 2-003c: GPIO lookup for consumer powerdown [ 7.372091] ov5640 2-003c: using device tree for GPIO lookup [ 7.372105] of_get_named_gpiod_flags: can't parse 'powerdown-gpios' property of node '/ocp/i2c@48060000/ov5640@3C[0]' [ 7.372116] of_get_named_gpiod_flags: can't parse 'powerdown-gpio' property of node '/ocp/i2c@48060000/ov5640@3C[0]' [ 7.372122] ov5640 2-003c: using lookup tables for GPIO lookup [ 7.372127] ov5640 2-003c: No GPIO consumer powerdown found [ 7.372133] ov5640 2-003c: GPIO lookup for consumer reset [ 7.372137] ov5640 2-003c: using device tree for GPIO lookup [ 7.372147] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/i2c@48060000/ov5640@3C[0]' [ 7.372156] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/i2c@48060000/ov5640@3C[0]' [ 7.372162] ov5640 2-003c: using lookup tables for GPIO lookup [ 7.372167] ov5640 2-003c: No GPIO consumer reset found [ 7.372207] ov5640 2-003c: 2-003c supply DOVDD not found, using dummy regulator [ 7.386084] ov5640 2-003c: Linked as a consumer to regulator.0 [ 7.391975] ov5640 2-003c: 2-003c supply DVDD not found, using dummy regulator [ 7.400288] ov5640 2-003c: 2-003c supply AVDD not found, using dummy regulator [ 7.408385] ov5640 2-003c: ov5640_init_slave_id: client->addr= 3c [ 9.021100] vin3a: Port A: Using subdev ov5640 2-003c for capture [ 11.327667] Modules linked in: pru_rproc(+) irq_pruss_intc pruss rpmsg_proto rpmsg_rpc dwc3 udc_core ti_vip snd_soc_simple_card ahci_platform snd_soc_simple_card_utils libahci_platform libahci pvrsrvkm(O) snd_soc_omap_hdmi omap_aes_driver libata pruss_soc_bus ti_vpe omap_wdt omap_sham phy_omap_usb2 ti_sc omap_des ti_csc ov5640 des_generic ti_vpdma snd_soc_tlv320aic3x at24 omap_hdq v4l2_fwnode crypto_engine omap_crypto dwc3_omap wire extcon_palmas rtc_omap rtc_palmas omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 11.384130] LR is at ov5640_set_fmt+0x1a0/0x288 [ov5640] [ 11.816640] [<c07c34b0>] (__v4l2_ctrl_s_ctrl_int64) from [<bf1abfa4>] (ov5640_set_fmt+0x1a0/0x288 [ov5640]) [ 11.832121] [<bf1abe04>] (ov5640_set_fmt [ov5640]) from [<bf3354d8>] (vip_init_port+0x1c4/0x458 [ti_vip]) root@am57xx-evm:/# sudo dmesg | grep vip [ 8.883613] vip 48990000.vip: loading firmware vpdma-1b8.bin [ 9.015406] vip 48990000.vip: VPDMA firmware loaded [ 11.327667] Modules linked in: pru_rproc(+) irq_pruss_intc pruss rpmsg_proto rpmsg_rpc dwc3 udc_core ti_vip snd_soc_simple_card ahci_platform snd_soc_simple_card_utils libahci_platform libahci pvrsrvkm(O) snd_soc_omap_hdmi omap_aes_driver libata pruss_soc_bus ti_vpe omap_wdt omap_sham phy_omap_usb2 ti_sc omap_des ti_csc ov5640 des_generic ti_vpdma snd_soc_tlv320aic3x at24 omap_hdq v4l2_fwnode crypto_engine omap_crypto dwc3_omap wire extcon_palmas rtc_omap rtc_palmas omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 11.832121] [<bf1abe04>] (ov5640_set_fmt [ov5640]) from [<bf3354d8>] (vip_init_port+0x1c4/0x458 [ti_vip]) [ 11.849514] [<bf335314>] (vip_init_port [ti_vip]) from [<bf33579c>] (vip_init_stream+0x30/0x1b8 [ti_vip]) [ 11.866902] [<bf33576c>] (vip_init_stream [ti_vip]) from [<bf3359a0>] (vip_open+0x7c/0xac [ti_vip]) [ 11.881673] [<bf335924>] (vip_open [ti_vip]) from [<c07b2fe0>] (v4l2_open+0x84/0x110) root@am57xx-evm:/# sudo dmesg | grep vpe [ 7.857185] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin [ 7.985577] vpe 489d0000.vpe: Device registered as /dev/video0 [ 11.327667] Modules linked in: pru_rproc(+) irq_pruss_intc pruss rpmsg_proto rpmsg_rpc dwc3 udc_core ti_vip snd_soc_simple_card ahci_platform snd_soc_simple_card_utils libahci_platform libahci pvrsrvkm(O) snd_soc_omap_hdmi omap_aes_driver libata pruss_soc_bus ti_vpe omap_wdt omap_sham phy_omap_usb2 ti_sc omap_des ti_csc ov5640 des_generic ti_vpdma snd_soc_tlv320aic3x at24 omap_hdq v4l2_fwnode crypto_engine omap_crypto dwc3_omap wire extcon_palmas rtc_omap rtc_palmas omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) root@am57xx-evm:/# sudo dmesg | grep video [ 0.602968] videodev: Linux video capture interface: v2.00 [ 7.985577] vpe 489d0000.vpe: Device registered as /dev/video0 [ 9.027849] vin3a-0: device registered as video1 root@am57xx-evm:/# lsmod 0v5640 Usage: lsmod root@am57xx-evm:/# lsmod Module Size Used by usbhid 24576 0 xhci_plat_hcd 16384 0 xhci_hcd 143360 1 xhci_plat_hcd pru_rproc 20480 0 irq_pruss_intc 16384 1 pru_rproc pruss 16384 1 pru_rproc rpmsg_proto 16384 0 rpmsg_rpc 32768 0 dwc3 73728 0 udc_core 28672 1 dwc3 ti_vip 49152 1 snd_soc_simple_card 16384 0 ahci_platform 16384 0 snd_soc_simple_card_utils 16384 1 snd_soc_simple_card libahci_platform 20480 1 ahci_platform libahci 36864 2 ahci_platform,libahci_platform pvrsrvkm 401408 2 snd_soc_omap_hdmi 16384 0 omap_aes_driver 24576 0 libata 208896 3 ahci_platform,libahci_platform,libahci pruss_soc_bus 16384 0 ti_vpe 28672 0 omap_wdt 16384 0 omap_sham 28672 0 phy_omap_usb2 16384 3 ti_sc 36864 2 ti_vpe,ti_vip omap_des 20480 0 ti_csc 16384 2 ti_vpe,ti_vip ov5640 28672 1 des_generic 28672 1 omap_des ti_vpdma 24576 2 ti_vpe,ti_vip snd_soc_tlv320aic3x 57344 1 at24 20480 0 omap_hdq 16384 0 v4l2_fwnode 20480 2 ov5640,ti_vip crypto_engine 16384 2 omap_des,omap_aes_driver omap_crypto 16384 2 omap_des,omap_aes_driver dwc3_omap 16384 0 wire 32768 1 omap_hdq extcon_palmas 16384 0 rtc_omap 20480 0 rtc_palmas 16384 1 omap_remoteproc 20480 0 virtio_rpmsg_bus 20480 0 remoteproc 49152 4 pru_rproc,rpmsg_rpc,omap_remoteproc,rpmsg_proto sch_fq_codel 20480 3 uio_module_drv 16384 0 uio 20480 1 uio_module_drv ftdi_sio 40960 0 usbserial 36864 1 ftdi_sio usbcore 217088 5 usbhid,ftdi_sio,usbserial,xhci_plat_hcd,xhci_hcd usb_common 16384 3 udc_core,usbcore,dwc3 jailhouse 32768 0 gdbserverproxy 16384 0 cryptodev 49152 0 cmemk 45056 2
I am getting video1 in /dev/video* but i want to change the frame formats and colour space things.
Could you give me suggestions.
Is this right driver inplace of FPGA taken OV5640 or else any other driver i want to take because so many registers are there in ov5640?
In v4l2 capture frame rate, color space, and 16-bit data and 1080p30fps how to read video data where to change the formats?
Thanking you sir,
Ramachandra
