Other Parts Discussed in Thread: AM1808
I'm using DDR2 sdram in my AM1808 board, but DDR2 is not support in TI's SDK, so, any tips how to modify the kernel to support DDR2 ?
Power Pan
Hi, Jeff,
thanks for replying.
where could I get the UBL of hawkboard? I downloaded the spread sheet to calculate the DDR2 register, but, don't know how to fill the form to get correct value, is there any explain how to use the spreadsheet?
Power Pan
Instructions on using the spreadsheet are on the wiki: http://processors.wiki.ti.com/index.php/Programming_mDDR/DDR2_EMIF_on_OMAP-L1x/C674x
Just get the datasheet for the memory device you are using and plug in the timing parameters required.
Hawkboard does not use a UBL. It converts U-boot to AIS format and boots it directly. You can use a hex editor to look at the U-boot AIS file and see what the DDR registers were configured to that way.
Jeff
Hi, Jeff,
still some green clock blank don't know what to fill, like IBANK_POS, DDR2EN TIMING_UNLOCK .... is it matter?
and saw the DDR2 SPEC, there are 2 mode registers in DDR2, so AM1808 will output default setting to those register without our setting the value, right?
anyway, we'll try first, cause we change the DDR2 memory, and making it work is kinder embarrassing, both software engineer and hardware engineer will have a headache how to deal with the case, do you have any reference how to debug this using CCS? our ccs for linux always crashes and CCS4 could not compile the UBL the first after import the free license file, it makes things even tough.
like import project-> build -> target->launch TI debugger(or debug active project? -> load gel file, then ?
regards,
Power Pan
IBANK_POS should be 0. TIMING_UNLOCK should be 0 also.
After you are connected to the target, open up the memory window to 0xC0000000 and try to write values there. If your DDR is configured correctly you should be able to read and write to that memory window.
Jeff
