TDA4VM: TDA4VM: yocto build failed(8.01)
Part Number: TDA4VM
I am doing a Yocto build. ( with TI Linux SDK v8)
However, the build does not succeed due to an error during onnxruntime and nodejs_12.21.0.bb build below.
WARNING: onnxruntime-1.7.0-r0_psdkla_3 do_fetch: Failed to fetch URL git://github.com/onnx/onnx;protocol=https;branch=master;destsuffix=/home/shlee/ti-processor-sdk-linux-j7-evm-08_01_00_07/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/onnxruntime/1.7.0-r0_psdkla_3/git/cmake/external/onnx;name=cmake-external-onnx, attempting MIRRORS if available
ERROR: onnxruntime-1.7.0-r0_psdkla_3 do_fetch: Fetcher failure: Unable to find revision 237926eab41de21fb9addc4b03b751fd6a3343ec in branch master even from upstream
ERROR: onnxruntime-1.7.0-r0_psdkla_3 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/onnx/onnx;protocol=https;branch=master;destsuffix=/home/shlee/ti-processor-sdk-linux-j7-evm-08_01_00_07/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/onnxruntime/1.7.0-r0_psdkla_3/git/cmake/external/onnx;name=cmake-external-onnx')
ERROR: Logfile of failure stored in: /home/shlee/ti-processor-sdk-linux-j7-evm-08_01_00_07/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/onnxruntime/1.7.0-r0_psdkla_3/temp/log.do_fetch.6783
ERROR: Task (/home/shlee/ti-processor-sdk-linux-j7-evm-08_01_00_07/yocto-build/sources/meta-psdkla/recipes-core/packagegroups/onnxruntime.bb:do_fetch) failed with exit code '1'
ERROR: nodejs-12.21.0-r0 do_compile: oe_runmake failed
ERROR: nodejs-12.21.0-r0 do_compile: Execution of '/home/shlee/ti-processor-sdk-linux-j7-evm-08_01_00_07/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/temp/run.do_compile.7218' failed with exit code 1
ERROR: Logfile of failure stored in: /home/shlee/ti-processor-sdk-linux-j7-evm-08_01_00_07/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/temp/log.do_compile.7218
| collect2: fatal error: ld terminated with signal 9 [Killed]
| compilation terminated.
| node.target.mk:188: recipe for target 'Release/node' failed
| make[1]: *** [Release/node] Error 1
| make[1]: *** Waiting for unfinished jobs....
| cctest.target.mk:205: recipe for target 'Release/cctest' failed
| make[1]: *** [Release/cctest] Error 1
| mkcodecache.target.mk:183: recipe for target 'Release/mkcodecache' failed
| make[1]: *** [Release/mkcodecache] Error 1
| rm 61c97d79d7a0a252db5d18ba732d8e4f5e7ff898.intermediate 5102eae8c2cdcf19e8a657d6a459a57dc43311d7.intermediate c1e70faf92957a28cd81286f33b4c85f27ff8dff.intermediate
| Makefile:104: recipe for target 'node' failed
| make: *** [node] Error 2
| ERROR: oe_runmake failed
| WARNING: /home/shlee/ti-processor-sdk-linux-j7-evm-08_01_00_07/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/temp/run.do_compile.7218:1 exit 1 from 'exit 1'
| ERROR: Execution of '/home/shlee/ti-processor-sdk-linux-j7-evm-08_01_00_07/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/temp/run.do_compile.7218' failed with exit code 1
ERROR: Task (/home/shlee/ti-processor-sdk-linux-j7-evm-08_01_00_07/yocto-build/sources/meta-openembedded/meta-oe/recipes-devtools/nodejs/nodejs_12.21.0.bb:do_compile) failed with exit code '1'
Please tell me how I can fix the error.
