TDA4VM: SPI profiling using MCSPI_SLAVE_MODE.C
Part Number: TDA4VM
Hi Team,
I am working with mcspi_slave_mode example provided in
-->/pdk_jacinto_07_03_00_29/packages/ti/drv/spi/example/mcspi_slavemode/src
I am sending 26 bytes of data over loop of 16 times.
for first transfer it is taking  approx 1 sec. and later on it is taking 8 to 10 ms for single transfer.
and to complete data transfer that is 26 bytes *16 times it is taking 1.17 seconds.
test case:- single channel DMA mode
I am using default configuration
as per my understanding those are
from
SPI_Params_init(&spiParams);
const SPI_Params SPI_defaultParams = {
SPI_MODE_BLOCKING, /* transferMode */
0U, /* transferTimeout */
NULL, /* transferCallbackFxn */
SPI_MASTER, /* mode */
1000000, /* bitRate */
8, /* dataSize */
SPI_POL0_PHA0, /* frameFormat */
NULL /* custom */
dataSize=8 bit(tried with 16  bit no significant change in timings)
bitrate = 1Mhz (tried upto 48Mhz no significant change)
for sync
Osal_delay(1000); //master(reduced upto 20ms)
Osal_delay(500);//slave(reduced upto 10ms)
considering this scenario are those time taken for transmission is appropriate?
Please suggest.
Tanvi
  • Hi Tanvi,
    I am checking this internally.
    Meanwhile, can you please share the following details:
    1) Are your observations on a custom board or TI EVM?
    2) If possible, can you share the modification done on <pdkInstallPath>/ti/drv/spi/example/mcspi_slavemode/src
    Parth
  • Hi Parth,
    1. observations are on J721e_evm
    2.changes are attached in text file
    Simultaneously I was debugging default code provided by TI and found same observations.
    while debugging I came Across
    SPI_osalPendLock(cbSem[0], timeout)
    which were taking approximately 1 second duration.
    why is it so?
    CHANGE 1 To execute DMA call back test only
    SPI_Tests Spi_tests_master[] =
    #ifndef SPI_MASTERONLY_TESTS
        /* testFunc               testID         master pollMode cbMode dmaMode timeout               testDesc */
       // #ifdef SPI_DMA_ENABLE
         //   {SPI_test_single_channel, SPI_TEST_ID_DMA, true, false, false, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master in dma mode", },
        //#endif
        //{SPI_test_single_channel, SPI_TEST_ID_INT, true, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master in non-dma interrupt mode", },
        //{SPI_test_single_channel, SPI_TEST_ID_POLL, true, true, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master in polling mode"},
        //{SPI_test_single_channel, SPI_TEST_ID_CB, true, false, true, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master in non-dma callback mode", },
            {SPI_test_single_channel, SPI_TEST_ID_DMA_CB, true, false, true, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master in dma callback mode", },
        #endif
        #endif //end of SPI_MASTERONLY_TESTS added for test
        {NULL, },// added for test
        {SPI_test_xfer_error, SPI_TEST_ID_XFER_ERR, true, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master transfer error test in non-dma interrupt mode", },
        {SPI_test_single_channel, SPI_TEST_ID_PHA_POL, true, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master phase polarity test in non-dma interrupt mode", 1, },
        #ifdef MCSPI_MULT_CHANNEL
                {SPI_test_multi_channel, SPI_TEST_ID_MC_DMA, true, false, false, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master multi channel in dma mode", },
            #endif
            {SPI_test_multi_channel, SPI_TEST_ID_MC_INT, true, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master multi channel in non-dma interrupt mode", },
            {SPI_test_multi_channel, SPI_TEST_ID_MC_POLL, true, true, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master multi channel in polling mode", },
            {SPI_test_multi_channel, SPI_TEST_ID_MC_CB, true, false, true, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master multi channel in non-dma callback mode", },
                {SPI_test_multi_channel, SPI_TEST_ID_MC_DMA_CB, true, false, true, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master multi channel in dma callback mode", },
            #endif
            {SPI_test_multi_channel, SPI_TEST_ID_TX_ONLY, true, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master multi channel TX_ONLY test", 0, },
            #endif
       // #endif //end of SPI_MASTERONLY_TESTS
    #if !defined (SOC_J721E) && !defined (SOC_J7200)
            {SPI_test_single_channel, SPI_TEST_ID_WORD_LEN, true, false, false, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master data size test in loopback dma mode", SPI_TEST_DATA_SIZE, },
        #endif
        {SPI_test_single_channel, SPI_TEST_ID_WORD_LEN, true, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master data size test in loopback mode", SPI_TEST_DATA_SIZE, },
                {SPI_test_multi_channel, SPI_TEST_ID_TRIG_LVL, true, false, false, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master multi channel FIFO trigger level test in loopback dma mode", SPI_TEST_TRIG_LVL, },
            #endif
            {SPI_test_multi_channel, SPI_TEST_ID_TRIG_LVL, true, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master multi channel FIFO trigger level test in loopback mode", SPI_TEST_TRIG_LVL, },
                {SPI_test_multi_channel, SPI_TEST_ID_TCS, true, false, false, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master multi channel TCS test in dma mode", SPI_TEST_TCS, },
            #endif
            {SPI_test_multi_channel, SPI_TEST_ID_TCS, true, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master multi channel TCS test", SPI_TEST_TCS, },
                {SPI_test_multi_channel, SPI_TEST_ID_INIT_DELAY, true, false, false, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master multi channel init delay test in dma mode", SPI_TEST_INIT_DELAY, },
            #endif
            {SPI_test_multi_channel, SPI_TEST_ID_INIT_DELAY, true, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master multi channel init delay test", SPI_TEST_INIT_DELAY, },
       #endif//end of  MCSPI_MULT_CHANNEL
    #endif//end of !defined (SOC_J721E) && !defined (SOC_J7200)  /* Loopback not supported on j721e, j7200 */
         {SPI_test_single_channel, SPI_TEST_ID_DMA_CB_CANCEL, true, false, true, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master transmit cancel in dma callback mode", },
    #endif
         {SPI_test_single_channel, SPI_TEST_ID_CB_CANCEL, true, false, true, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test master transmit cancel in non-dma callback mode", },
        /* NOTE: Timeout Test case should be executed as the final test, as this test requires no transaction on the data lines
         * for the timeout to happen */
        {SPI_test_single_channel, SPI_TEST_ID_TIMEOUT, false, false, false, false, SPI_TIMEOUT_VALUE, "\r\n SPI timeout test in interrupt mode", },
        {SPI_test_single_channel, SPI_TEST_ID_TIMEOUT_POLL, false, true, false, false, SPI_TIMEOUT_VALUE, "\r\n SPI timeout test in polling mode", },
        //{NULL, },
    SPI_Tests Spi_tests_slave[] =
    	    /* testFunc           testID         master pollMode cbMode dmaMode, timeout               testDesc */
        //#ifdef SPI_DMA_ENABLE
          //  {SPI_test_single_channel, SPI_TEST_ID_DMA, false, false, false, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test slave in dma mode", },
        //#endif
        //{SPI_test_single_channel, SPI_TEST_ID_INT, false, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test slave in non-dma interrupt mode", },
        //{SPI_test_single_channel, SPI_TEST_ID_POLL, false, true, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test slave in polling mode", },
        //{SPI_test_single_channel, SPI_TEST_ID_CB, false, false, true, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test slave in non-dma callback mode", },
            {SPI_test_single_channel, SPI_TEST_ID_DMA_CB, false, false, true, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test slave in dma callback mode", },
        #endif
        #endif //end of SPI_MASTERONLY_TESTS for testing
        {NULL, },//end of SPI_MASTERONLY_TESTS for testing
        {SPI_test_xfer_error, SPI_TEST_ID_XFER_ERR, false, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI slave transfer error test in non-dma interrupt mode", },
        {SPI_test_single_channel, SPI_TEST_ID_PHA_POL, false, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI slave phase polarity test in non-dma interrupt mode", 1, },
            {SPI_test_multi_channel, SPI_TEST_ID_MC_DMA, false, false, false, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test slave multi channel in dma mode", },
            #endif
            {SPI_test_multi_channel, SPI_TEST_ID_MC_INT, false, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master  slave test slave multi channel in non-dma interrupt mode", },
            {SPI_test_multi_channel, SPI_TEST_ID_MC_POLL, false, true, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test slave in polling mode", },
            {SPI_test_multi_channel, SPI_TEST_ID_MC_CB, false, false, true, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test slave in non-dma callback mode", },
            {SPI_test_multi_channel, SPI_TEST_ID_MC_DMA_CB, false, false, true, true, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test slave in dma callback mode", },
            #endif
            {SPI_test_multi_channel, SPI_TEST_ID_RX_ONLY, false, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test slave multi channel RX_ONLY test", 0, },
        #endif
    //#endif //end of SPI_MASTERONLY_TESTS
    //    {NULL, },
    Change 2 instead of string passing a structure of 26 bytes
    unsigned char masterTxBuffer[128] = "PASS: Txd from master SPI PASS: Txd from master SPI PASS: Txd from master SPI ";
    unsigned char slaveTxBuffer[128] =  "PASS: Txd from slave SPI  PASS: Txd from slave SPI  PASS: Txd from slave SPI  ";
    Change 3
    num_xfers = 1;
    changed to 16 as I want to send data 16 times
    Tanvi
  • Hi Tanvi,
    I checked, the transfer should not take this much time.
    Can you please share how you are calculating the time of transfer?
    Parth
  • Hi Parth,
    please note:
    This observation is under DMA call back mode
    "while debugging I came Across
    which were taking approximately 1 second duration."
  • I am using "TimerP_getTimeInUsecs();" as per provided in Ti's other profiling applications.
    following is my code snippet
    uint64_t PreTime,PostTime,objAcc;
    if(transferOK)
         PreTime=TimerP_getTimeInUsecs();//l0
         if (cbMode)
               if (SPI_osalPendLock(cbSem[0], timeout) != SemaphoreP_OK)
                      goto Err;
       PostTime=TimerP_getTimeInUsecs();//l0
                     Keeping everything as it is
    else
         ret = true;
         objAcc=(PostTime-PreTime);//cbMode
         SPI_log("cbMode %d\n",objAcc);
          Err:
                return (ret);
    Output is as below
    Starting SPI Slave test.
    SPI UT 4
    SPI master slave test slave in dma callbace
    SPI initialized
    Slave: PASS: Txd from master SPI PASS:
    cbMode 998618
    SPI master slave test slave in dma callbacd
    All tests have passed.
    Done
    Tanvi
  • Hi Tanvi,
    I'll reproduce this on my end to figure out the issue. Will keep you posted on this.
    Parth
  • Hi Tanvi,
    Apologies for long delay.
    Here is the update so far:
    I have been able to reproduce this issue on my end and as you mentioned previously SPI_osalPendLock(cbSem[0], timeout) is taking approximately 1s. I am investigating this further, will provide updates by end of day.
    Parth
  • Hi Tanvi,
    SPI_osalPendLock(cbSem[0], timeout) is taking 1s due to sync requirement between master and slave. Basically, SPI slave needs to be ready, by the time master initiates the transfer. In order to achieve this condition Task_sleep is used in masterTaskFxn, due to which SPI_osalPendLock(cbSem[0], timeout) is taking 1s to release.
    I have tried reducing this to Task_sleep(10) and it works fine and reduces the time taken to release the lock. You can reduce this further based on your use case.
    Parth
  • Hi Parth,
    I tried what you specified.
    With the build default application I used SPI in DMA callback mode.
    I used the following command to build -->
    make -s -j MCSPI_Master_TestApp BOARD=j721e_evm SOC=j721e CORE=mcu1_0 BUILD_OS_TYPE=tirtos BUILD_PROFILE=release DMA=enable
    make -s -j MCSPI_Slave_TestApp BOARD=j721e_evm SOC=j721e CORE=mpu1_0 BUILD_OS_TYPE=tirtos BUILD_PROFILE=release DMA=enable
    After which is used this command to make a combined image -->
    ./MulticoreImageGen LE 55 app 0 MCSPI_Slave_Dma_j721e_evm_mpu1_0TestApp_release.rprc 4 MCSPI_Master_Dma_j721e_evm_mcu1_0TestApp_release.rprc
    I changed the Task_sleep(1000) to Task_sleep(10) in masterTaskFxn() in main_mcspi_slave_mode.c.
    When i ran the code i got that the default application took 50 msecs with Task_sleep(10) and when I changed it back to Task_sleep(1000) it took 1040 msecs.
    50 msecs with Task_sleep(10)  for default application where it is only sending -->
    Can you please give your readings as to what you got when you tried to switch Task_sleep(1000) to Task_sleep(10) ?
    I still think that this 50 msecs is too much time for default application running with SPI DMA mode.
    I am also sharing the file so that you get to know the changes made for your clarity.
     *  \file   main_mcspi_slave_mode.c
     *  \brief  The application Demonstrate the MCSPI slave mode functionality.
     *          This application transmits data from master to slave and at the
     *          same instance data from slave will be transferred to master.
     *  \details
     *          For K2x and AM3/AM4/AM5 devices, to demonstrate the example two
     *          boards are needed one board acts as master and another as slave.
     *          Following is the Pin connection information:
     *          MasterSPI_SCLK----SlaveSPI_SCLK
     *          MasterSPI_D0------SlaveSPI_D1
     *          MasterSPI_D1------SlaveSPI_D0
     *          MasterSPI_CS------SlaveSPI_CS
     *          To run the example:
     *          1) Connect the master and slave boards as per above pin connections.
     *          2) Two consoles. One for master and another for slave.
     *          3) Run slave application binary and then master application binary.
     *          For AM65xx and J721e/J7200 devices, to demonstrate the example two cores
     *          on the same SoC are needed, mcu1_0 uses McSPI instance 2 on the MCU
     *          domain as the master and mpu1_0 uses  McSPI instance 4 on the Main
     *          doman as slave. These two instances are internally connected in the SoC:
     *          Following is the internal pin signal connection information:
     *          1) Run the MasterSlave mpu1_0 test binary (slave) on MPU1_0 core
     *          2) Run the MasterSlave mcu1_0 test binary (master) on MCU1_0 core
     *          3) Be sure to run slave application and then master application
     *  \Output
     *          At slave end console:
     *              SPI initialized
     *              Slave: PASS: Txd from master SPI
     *          At master end console:
     *              SPI initialized
     *              Master: PASS: Txd from slave SPI
     *              Done
     * Copyright (C) 2016 - 2020 Texas Instruments Incorporated - http://www.ti.com/
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * Redistributions of source code must retain the above copyright
     * notice, this list of conditions and the following disclaimer.
     * Redistributions in binary form must reproduce the above copyright
     * notice, this list of conditions and the following disclaimer in the
     * documentation and/or other materials provided with the
     * distribution.
     * Neither the name of Texas Instruments Incorporated nor the names of
     * its contributors may be used to endorse or promote products derived
     * from this software without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include <stdio.h>
    #include <string.h>
    #ifdef USE_BIOS
    /* XDCtools Header files */
    #include <xdc/std.h>
    #include <xdc/runtime/System.h>
    #include <stdio.h>
    #include <ti/sysbios/knl/Task.h>
    #include <ti/sysbios/hal/Hwi.h>
    /* BIOS Header files */
    #include <ti/sysbios/BIOS.h>
    #include <xdc/runtime/Error.h>
    #endif /* #ifdef USE_BIOS */
    /* CSL Header files */
    #ifdef _TMS320C6X
    #include <ti/csl/csl_chip.h>
    #endif
    /* OSAL Header files */
    #include <ti/osal/osal.h>
    /* TI-RTOS Header files */
    #include <ti/drv/spi/soc/SPI_soc.h>
    #include <ti/drv/spi/src/SPI_osal.h>
    #include <ti/drv/spi/SPI.h>
    #include "SPI_log.h"
    #if defined(iceAMIC110)
    #include <ti/drv/gpio/GPIO.h>
    #include <ti/drv/gpio/soc/GPIO_soc.h>
    #endif
    #include <ti/board/board.h>
    #ifdef SOC_AM65XX
    #include <ti/csl/soc/am65xx/src/cslr_soc_baseaddress.h>
    #include <ti/csl/soc/am65xx/src/cslr_wkup_ctrl_mmr.h>
    #elif defined(SOC_J721E)
    #include <ti/csl/soc/j721e/src/cslr_soc_baseaddress.h>
    #include <ti/csl/soc/j721e/src/cslr_wkup_ctrl_mmr.h>
    #elif defined(SOC_J7200)
    #include <ti/csl/soc/j7200/src/cslr_soc_baseaddress.h>
    #include <ti/csl/soc/j7200/src/cslr_wkup_ctrl_mmr.h>
    #endif
    #include <ti/osal/CacheP.h>
    #if defined (SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200) || defined (SOC_AM64X)
    #include <ti/drv/udma/udma.h>
    #else
    /* EDMA3 Header files */
    #include <ti/sdo/edma3/drv/edma3_drv.h>
    #include <ti/sdo/edma3/rm/edma3_rm.h>
    #include <ti/sdo/edma3/rm/sample/bios6_edma3_rm_sample.h>
    #if defined(evmK2G)
    #include <ti/csl/soc.h>
    #endif
    static EDMA3_RM_Handle MCSPIApp_edmaInit(void);
    #if defined(SOC_K2H) || defined(SOC_K2K) || defined(SOC_K2L) || defined(SOC_K2E) || defined(SOC_K2G) || \
        defined(SOC_C6678) || defined(SOC_C6657)
    extern EDMA3_RM_InstanceInitConfig sampleInstInitConfig[][EDMA3_MAX_REGIONS];
    extern EDMA3_RM_GblConfigParams sampleEdma3GblCfgParams[];
    #endif
    #endif
    #endif
    #if (defined (SOC_J721E) || defined (SOC_J7200))
    #include <ti/drv/sciclient/sciclient.h>
    #if defined (BUILD_MCU1_0)
    #include <ti/drv/sciclient/sciserver_tirtos.h>
    /* Aligned address at which the X509 header is placed */
    #define SCISERVER_COMMON_X509_HEADER_ADDR (0x41cffb00)
    #endif
    #endif
    /* Define the SPI test interface */
    typedef struct SPI_Tests_s
        bool     (*testFunc)(void *);
        int32_t  testId;
        bool     master;
        bool     pollMode;
        bool     cbMode;
        bool     dmaMode;
        uint32_t timeout;
        char     testDesc[80];
        uint32_t param;
        uint32_t trigLvl;
    } SPI_Tests;
     ************************** Macros ************************************
    #define SPI_TIMEOUT_VALUE 5000
    /* SPI transfer message definitions */
    #define SPI_MSG_LENGTH    26
    #define SPI_MSG_LENGTH2   78
    #define SPI_NUM_XFERS     2
    uint32_t spi_test_xfer_len[SPI_NUM_XFERS] =
        SPI_MSG_LENGTH,
        SPI_MSG_LENGTH2
    /* Maximum # of channels per SPI instance */
    #define MCSPI_MAX_NUM_CHN       4
    /* Test channel # */
    #define MCSPI_TEST_CHN          0
    /* SPI Test definitions */
    /* Unit test IDs */
    #define SPI_TEST_ID_DMA         0   /* Single-channel DMA mode test */
    #define SPI_TEST_ID_INT         1   /* Single-channel interrupt mode test */
    #define SPI_TEST_ID_POLL        2   /* Single-channel polling mode test */
    #define SPI_TEST_ID_CB          3   /* Single-channel non-DMA callback mode test */
    #define SPI_TEST_ID_DMA_CB      4   /* Single-channel DMA callback mode test */
    #define SPI_TEST_ID_MC_DMA      5   /* Multi-channel DMA mode test */
    #define SPI_TEST_ID_MC_INT      6   /* Multi-channel interrupt mode test */
    #define SPI_TEST_ID_MC_POLL     7   /* Multie-channel polling mode test */
    #define SPI_TEST_ID_MC_CB       8   /* Multi-channel non-DMA callback mode test */
    #define SPI_TEST_ID_MC_DMA_CB   9   /* Multi-channel DMA callback mode test */
    #define SPI_TEST_ID_TX_ONLY     10  /* Multi-channel TX only test */
    #define SPI_TEST_ID_RX_ONLY     11  /* Multi-channel RX only test */
    #define SPI_TEST_ID_XFER_ERR    12  /* Single-channel transfer error test */
    #define SPI_TEST_ID_PHA_POL     13  /* Single-channel phase/polarity test */
    #define SPI_TEST_ID_TIMEOUT     14  /* Single-channel Timeout test with interrupt enabled */
    #define SPI_TEST_ID_TIMEOUT_POLL 15 /* Single-channel Timeout test with polling enabled */
    #define SPI_TEST_ID_DMA_CB_CANCEL   16
    #define SPI_TEST_ID_CB_CANCEL      17
    /* Loopback tests */
    #define SPI_TEST_ID_LOOPBACK    20
    #define SPI_TEST_ID_WORD_LEN    (SPI_TEST_ID_LOOPBACK)      /* transfer data size test */
    #define SPI_TEST_ID_TRIG_LVL    (SPI_TEST_ID_LOOPBACK + 1)  /* FIFO trigger level test */
    #define SPI_TEST_ID_TCS         (SPI_TEST_ID_LOOPBACK + 2)  /* Multi-channel chip select time control test */
    #define SPI_TEST_ID_INIT_DELAY  (SPI_TEST_ID_LOOPBACK + 3)  /* Multi-channel 1st transfer init delay test */
    /* Transfer data size test parameter, in # of bits per SPI word */
    #define SPI_TEST_DATA_SIZE_16   16
    #define SPI_TEST_DATA_SIZE_32   32
    #if defined(SOC_DRA78x) || defined(SOC_TDA3XX) || defined(SOC_TDA2XX) || defined(SOC_TDA2EX) || defined (SOC_DRA72x) || defined (SOC_DRA75x) || defined(SOC_AM574x) || defined (SOC_AM572x) || defined (SOC_AM571x) || defined (SOC_AM437x) || defined (SOC_AM335x) || defined (SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200) || defined (SOC_AM64X)
    #define SPI_TEST_DATA_SIZE      SPI_TEST_DATA_SIZE_32
    #else
    #define SPI_TEST_DATA_SIZE      SPI_TEST_DATA_SIZE_16
    #endif
    /* Chip select time control test parameter */
    #define SPI_TEST_TCS            MCSPI_CH0CONF_TCS0_ONECYCLEDLY
    /* 1st transfer init delay test parameter */
    #define SPI_TEST_INIT_DELAY     MCSPI_INITDLY_4
    /* FIFO trigger level test parameter, in # of bytes */
    #define SPI_TEST_TRIG_LVL       16
    #endif
    #if defined(SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200)
    /* WKUP CTRL base address + offset to beginning of PAD CONFIG section */
    #define WKUP_PINMUX_REG_BASE            (CSL_WKUP_CTRL_MMR0_CFG0_BASE + \
                                             CSL_WKUP_CTRL_MMR_CFG0_PADCONFIG0)
    #define MCU_SPI0_CLK_PADCFG_OFFSET      (0x90U)
    #define MCU_SPI0_D1_PADCFG_OFFSET       (0x98U)
    #define PIN_MODE(mode)                  (mode)
    /** \brief Active mode configurations */
    /** \brief Resistor disable */
    #define PIN_PULL_DISABLE                (0x1U << 16U)
    /** \brief Pull direction */
    #define PIN_PULL_DIRECTION              (0x1U << 17U)
    /** \brief Receiver enable */
    #define PIN_INPUT_ENABLE                (0x1U << 18U)
    /** \brief Driver disable */
    #define PIN_OUTPUT_DISABLE              (0x1U << 21U)
    /** \brief Wakeup enable */
    #define PIN_WAKEUP_ENABLE               (0x1U << 29U)
    #endif
    #if defined(SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200) || defined(SOC_AM64X)
     * Ring parameters
    /** \brief Number of ring entries - we can prime this much memcpy operations */
    #define UDMA_TEST_APP_RING_ENTRIES      (1U)
    /** \brief Size (in bytes) of each ring entry (Size of pointer - 64-bit) */
    #define UDMA_TEST_APP_RING_ENTRY_SIZE   (sizeof(uint64_t))
    /** \brief Total ring memory */
    #define UDMA_TEST_APP_RING_MEM_SIZE     (UDMA_TEST_APP_RING_ENTRIES * \
                                             UDMA_TEST_APP_RING_ENTRY_SIZE)
    /** \brief This ensures every channel memory is aligned */
    #define UDMA_TEST_APP_RING_MEM_SIZE_ALIGN ((UDMA_TEST_APP_RING_MEM_SIZE + UDMA_CACHELINE_ALIGNMENT) & ~(UDMA_CACHELINE_ALIGNMENT - 1U))
    /** \brief UDMA host mode buffer descriptor memory size. */
    #define UDMA_TEST_APP_DESC_SIZE         (sizeof(CSL_UdmapCppi5HMPD))
    #define UDMA_TEST_APP_DESC_SIZE_ALIGN   ((UDMA_TEST_APP_DESC_SIZE + UDMA_CACHELINE_ALIGNMENT) & ~(UDMA_CACHELINE_ALIGNMENT - 1U))
     * UDMA driver objects
    struct Udma_DrvObj      gUdmaDrvObj;
    struct Udma_ChObj       gUdmaTxChObj;
    struct Udma_ChObj       gUdmaRxChObj;
    struct Udma_EventObj    gUdmaTxCqEventObj;
    struct Udma_EventObj    gUdmaRxCqEventObj;
    Udma_DrvHandle          gDrvHandle = NULL;
     * UDMA Memories
    static uint8_t gTxRingMem[UDMA_TEST_APP_RING_MEM_SIZE_ALIGN] __attribute__((aligned(UDMA_CACHELINE_ALIGNMENT)));
    static uint8_t gTxCompRingMem[UDMA_TEST_APP_RING_MEM_SIZE_ALIGN] __attribute__((aligned(UDMA_CACHELINE_ALIGNMENT)));
    static uint8_t gUdmaTxHpdMem[UDMA_TEST_APP_DESC_SIZE_ALIGN] __attribute__((aligned(UDMA_CACHELINE_ALIGNMENT)));
    static uint8_t gRxRingMem[UDMA_TEST_APP_RING_MEM_SIZE_ALIGN] __attribute__((aligned(UDMA_CACHELINE_ALIGNMENT)));
    static uint8_t gRxCompRingMem[UDMA_TEST_APP_RING_MEM_SIZE_ALIGN] __attribute__((aligned(UDMA_CACHELINE_ALIGNMENT)));
    static uint8_t gUdmaRxHpdMem[UDMA_TEST_APP_DESC_SIZE_ALIGN] __attribute__((aligned(UDMA_CACHELINE_ALIGNMENT)));
    static SPI_dmaInfo gUdmaInfo;
    Udma_DrvHandle MCSPIApp_udmaInit(SPI_v1_HWAttrs *cfg)
        int32_t         retVal = UDMA_SOK;
        Udma_InitPrms   initPrms;
        uint32_t        instId;
        if (gDrvHandle == NULL)
            /* UDMA driver init */
    #if defined(SOC_AM64X)
            instId = UDMA_INST_ID_PKTDMA_0;
    #else
    #if defined (__aarch64__)
            instId = UDMA_INST_ID_MAIN_0;
    #else
            instId = UDMA_INST_ID_MCU_0;
    #endif
    #endif
            UdmaInitPrms_init(instId, &initPrms);
            retVal = Udma_init(&gUdmaDrvObj, &initPrms);
            if(UDMA_SOK == retVal)
                gDrvHandle = &gUdmaDrvObj;
        if(gDrvHandle != NULL)
            gUdmaInfo.txChHandle     = (void *)&gUdmaTxChObj;
            gUdmaInfo.rxChHandle     = (void *)&gUdmaRxChObj;
            gUdmaInfo.txRingMem      = (void *)&gTxRingMem[0];
            gUdmaInfo.cqTxRingMem    = (void *)&gTxCompRingMem[0];
            gUdmaInfo.rxRingMem      = (void *)&gRxRingMem[0];
            gUdmaInfo.cqRxRingMem    = (void *)&gRxCompRingMem[0];
            gUdmaInfo.txHpdMem       = (void *)&gUdmaTxHpdMem[0];
            gUdmaInfo.rxHpdMem       = (void *)&gUdmaRxHpdMem[0];
            gUdmaInfo.txEventHandle  = (void *)&gUdmaTxCqEventObj;
            gUdmaInfo.rxEventHandle  = (void *)&gUdmaRxCqEventObj;
            cfg->dmaInfo             = &gUdmaInfo;
        else
            UART_printf("MCSPIApp_udmaInit:  Udma_init failed with error code: %d\n", retVal);
        return (gDrvHandle);
    int32_t MCSPI_udma_deinit(void)
        if (gDrvHandle != NULL)
            retVal = Udma_deinit(gDrvHandle);
                gDrvHandle = NULL;
        return (retVal);
    #endif
    #endif /* #if defined(SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200) */
     ************************** Global Variables **************************
    #if (defined(_TMS320C6X) || defined (__TI_ARM_V7M4__))
    #pragma DATA_ALIGN (masterRxBuffer, 128)
    unsigned char masterRxBuffer[128];
    #pragma DATA_ALIGN (slaveRxBuffer, 128)
    unsigned char slaveRxBuffer[128];
    #else
    unsigned char masterRxBuffer[128] __attribute__ ((aligned (128)));
    unsigned char slaveRxBuffer[128] __attribute__ ((aligned (128)));
    #endif
    #define CANCEL_TX_LEN   (1024)
    unsigned char cancelTxBuff[CANCEL_TX_LEN];
    unsigned char cancelRxBuff[CANCEL_TX_LEN];
    #define GPIO_BUS_SWITCH_ENABLE_OFFSET     (0)
    #define GPIO_PIN_VAL_LOW     (0U)
    #define GPIO_PIN_VAL_HIGH    (1U)
    #define GPIO_BUS_SWITCH_ENABLE_PIN_NUM    (0x15)
    #define GPIO_BUS_SWITCH_ENABLE_PORT_NUM   (0x2)
    /* GPIO Driver board specific pin configuration structure */
    GPIO_PinConfig gpioPinConfigs[] = {
        /* Boot switch enable pin to control the buffer for routing McSPI
         * lines to Launchpad header on iceAMIC110 board */
        GPIO_DEVICE_CONFIG((GPIO_BUS_SWITCH_ENABLE_PORT_NUM + 1), GPIO_BUS_SWITCH_ENABLE_PIN_NUM) |
        GPIO_CFG_IN_INT_NONE | GPIO_CFG_OUTPUT,
    /* GPIO Driver call back functions */
    GPIO_CallbackFxn gpioCallbackFunctions[] = {
        NULL
    /* GPIO Driver configuration structure */
    GPIO_v1_Config GPIO_v1_config = {
        gpioPinConfigs,
        gpioCallbackFunctions,
        sizeof(gpioPinConfigs) / sizeof(GPIO_PinConfig),
        sizeof(gpioCallbackFunctions) / sizeof(GPIO_CallbackFxn),
        0x1U,
    #endif  /* #if defined(iceAMIC110) */
    /* Transaction data */
    SPI_Transaction   transaction;
    /* Callback mode variables */
    SemaphoreP_Params cbSemParams;
    SemaphoreP_Handle cbSem[MCSPI_MAX_NUM_CHN] = {NULL, NULL, NULL, NULL};
    static bool loopBackTest = false;
    #if !(defined (SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200) || defined (SOC_AM64X))
    EDMA3_RM_Handle gEdmaHandle = NULL;
     * \brief      Function to initialize the edma driver and get the handle to the
     *             edma driver;
        EDMA3_DRV_Result edmaResult = EDMA3_DRV_E_INVALID_PARAM;
        uint32_t         edma3Id;
        if (gEdmaHandle != NULL)
            return (gEdmaHandle);
        uint32_t edmaEvent[2], i, chnMapping, chnMappingIdx;
        /* For Keystone devices, edm3Id is SPI instance and SoC specific */
        SPI_getEdmaInfo(BOARD_MCSPI_MASTER_INSTANCE - 1, &edma3Id, edmaEvent);
        /* Set the RX/TX ownDmaChannels and dmaChannelHwEvtMap */
        for (i = 0; i < 2; i++)
            chnMapping = edmaEvent[i];
            if (chnMapping < 32)
                chnMappingIdx = 0;
            else
                chnMapping -= 32;
                chnMappingIdx = 1;
            sampleInstInitConfig[edma3Id][0].ownDmaChannels[chnMappingIdx] |= (1 << chnMapping);
            sampleInstInitConfig[edma3Id][0].ownTccs[chnMappingIdx] |= (1 << chnMapping);
            sampleInstInitConfig[edma3Id][0].ownPaRAMSets[chnMappingIdx] |= (1 << chnMapping);
            sampleEdma3GblCfgParams[edma3Id].dmaChannelHwEvtMap[chnMappingIdx] |= (1 << chnMapping);
    #endif
    #if defined(SOC_AM574x) || defined(SOC_AM572x)|| defined(SOC_AM571x) || defined (SOC_DRA72x)  || defined (SOC_DRA75x) || defined (SOC_DRA78x) || defined (SOC_AM335x) || defined (SOC_AM437x)
        edma3Id = 0;
    #endif
        gEdmaHandle = (EDMA3_RM_Handle)edma3init(edma3Id, &edmaResult);
    #ifdef USE_BIOS
        if (edmaResult != EDMA3_DRV_SOK)
            /* Report EDMA Error */
            System_printf("\nEDMA driver initialization FAIL\n");
        else
            System_printf("\nEDMA driver initialization PASS.\n");
    #endif
        return(gEdmaHandle);
    #endif
    #endif
    /* Callback mode functions */
    void SPI_callback(SPI_Handle handle, SPI_Transaction *transaction)
        SPI_osalPostLock(cbSem[0]);
    void MCSPI_callback0(MCSPI_Handle handle, SPI_Transaction *transaction)
    void MCSPI_callback1(MCSPI_Handle handle, SPI_Transaction *transaction)
        SPI_osalPostLock(cbSem[1]);
    void MCSPI_callback2(MCSPI_Handle handle, SPI_Transaction *transaction)
        SPI_osalPostLock(cbSem[2]);
    void MCSPI_callback3(MCSPI_Handle handle, SPI_Transaction *transaction)
        SPI_osalPostLock(cbSem[3]);
    #endif
     *  ======== SPI init config ========
    static void SPI_initConfigDefault(SPI_HWAttrs *cfg, uint32_t chn)
        cfg->chNum                        = chn;
        cfg->chnCfg[chn].tcs              = MCSPI_CS_TCS_0PNT5_CLK;
    #if defined (SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200) || defined(SOC_AM64X)
        /* SPIDAT[1] for TX and SPIDAT[0] for RX */
        cfg->chnCfg[chn].dataLineCommMode = MCSPI_DATA_LINE_COMM_MODE_1;
    #else
        /* SPIDAT[1] for RX and SPIDAT[0] for TX */
        cfg->chnCfg[chn].dataLineCommMode = MCSPI_DATA_LINE_COMM_MODE_6;
    #endif
        cfg->chnCfg[chn].trMode           = MCSPI_TX_RX_MODE;
        cfg->initDelay                    = MCSPI_INITDLY_0;
    #if defined (SOC_AM335x)
        cfg->rxTrigLvl                    = MCSPI_RX_TX_FIFO_SIZE / 2;
        cfg->txTrigLvl                    = MCSPI_RX_TX_FIFO_SIZE / 2;
    #else
        cfg->rxTrigLvl                    = MCSPI_RX_TX_FIFO_SIZE;
        cfg->txTrigLvl                    = MCSPI_RX_TX_FIFO_SIZE;
    #endif
    #endif
    static void SPI_initConfig(uint32_t instance, SPI_Tests *test, uint32_t chn, bool multiChn)
        SPI_HWAttrs spi_cfg;
        int32_t     testId = test->testId;
        bool        pollMode = test->pollMode;
        bool        dmaMode = test->dmaMode;
    #endif
        /* Get the default SPI init configurations */
        SPI_socGetInitCfg(instance, &spi_cfg);
        SPI_initConfigDefault(&spi_cfg, chn);
    #endif
         * Set blocking mode (dma mode or non-dma interrupt mode)
         * or callback mode
        if (pollMode == true)
            /* polling mode */
            spi_cfg.enableIntr = false;
            /* SPI DMA mode is not supported in polling mode */
            spi_cfg.edmaHandle = NULL;
            spi_cfg.dmaMode    = FALSE;
        else
            /* interrupt enabled */
            spi_cfg.enableIntr = true;
    #if defined(SOC_DRA78x) || defined(SOC_TDA3XX) || defined(SOC_TDA2XX) || defined(SOC_TDA2PX) || defined(SOC_TDA2EX) || defined (SOC_DRA75x) || \
        defined(SOC_AM574x) || defined (SOC_AM572x) || defined (SOC_AM571x) || defined (SOC_AM437x) || defined (SOC_AM335x) || \
        defined(SOC_C6678) || defined(SOC_C6657) || defined (SOC_AM65XX)  || defined(SOC_J721E) || defined(SOC_J7200) || defined (SOC_AM64X)
            if (dmaMode == true)
                /* Set the DMA related init config */
                spi_cfg.edmaHandle = (void *)MCSPIApp_udmaInit(&spi_cfg);
    #else
                spi_cfg.edmaHandle = MCSPIApp_edmaInit();
    #endif
                spi_cfg.dmaMode    = TRUE;
                spi_cfg.enableIntr = FALSE;
            else
    #endif
    #endif
        switch(testId)
        case (SPI_TEST_ID_TX_ONLY):
            spi_cfg.chnCfg[chn].trMode = MCSPI_TX_ONLY_MODE;
            /* Data line 1 TX enabled, data line 0 RX enabled TX disabled */
            spi_cfg.chnCfg[chn].dataLineCommMode = MCSPI_DATA_LINE_COMM_MODE_1;
    #else
            /* Data line 0 TX enabled, data line 1 RX enabled TX disabled */
            spi_cfg.chnCfg[chn].dataLineCommMode = MCSPI_DATA_LINE_COMM_MODE_6;
    #endif
            break;
        case (SPI_TEST_ID_RX_ONLY):
            spi_cfg.chnCfg[chn].trMode = MCSPI_RX_ONLY_MODE;
        /* Data line 1 TX disabled, data line 0 RX enabled TX disabled */
            spi_cfg.chnCfg[chn].dataLineCommMode = MCSPI_DATA_LINE_COMM_MODE_3;
    #else
            /* Data line 0 TX disabled, data line 1 RX enabled TX disabled */
            spi_cfg.chnCfg[chn].dataLineCommMode = MCSPI_DATA_LINE_COMM_MODE_7;
    #endif
            break;
        case (SPI_TEST_ID_TRIG_LVL):
            spi_cfg.rxTrigLvl = test->param;
            spi_cfg.txTrigLvl = test->param;
            /* enalbe loopback mode */
            spi_cfg.chnCfg[chn].dataLineCommMode = MCSPI_DATA_LINE_COMM_MODE_4;
            break;
        case (SPI_TEST_ID_TCS):
            spi_cfg.chnCfg[chn].tcs = test->param;
            break;
        case (SPI_TEST_ID_INIT_DELAY):
            spi_cfg.initDelay = test->param;
            break;
        default:
            break;
        if (spi_cfg.txTrigLvl != 0)
            test->trigLvl = spi_cfg.txTrigLvl;
        else
            test->trigLvl = 0;
        if (spi_cfg.txTrigLvl < spi_cfg.rxTrigLvl)
            test->trigLvl = spi_cfg.rxTrigLvl;
    #endif
    #endif
        if ((testId == SPI_TEST_ID_WORD_LEN) || (testId == SPI_TEST_ID_CB_CANCEL) || (testId == SPI_TEST_ID_DMA_CB_CANCEL))
    #if defined(SOC_DRA78x) || defined(SOC_TDA3XX) || defined(SOC_TDA2XX) || defined(SOC_TDA2EX) || defined (SOC_DRA72x) || defined (SOC_DRA75x) || defined (SOC_AM572x) || defined (SOC_AM571x) || defined (SOC_AM574x) || defined (SOC_AM437x) || defined (SOC_AM335x) || defined (SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200) || defined (SOC_AM64X)
            /* enable loopback mode */
    #else
            spi_cfg.loopback = 1;
    #endif
        /* Set the SPI init configurations */
        SPI_socSetInitCfg(instance, &spi_cfg);
    bool SPI_verify_data(unsigned char *data1, unsigned char *data2, uint32_t length)
    	uint32_t i;
    	bool     ret = true;
        for (i = 0; i < length; i++)
            if (data1[i] != data2[i])
                ret = false;
                break;
    	return (ret);
     * Utility function which converts a local GEM L2 memory address
     * to global memory address.
    static uintptr_t l2_global_address (uintptr_t addr)
    #if defined(SOC_K2H) || defined(SOC_K2K) || defined(SOC_K2L) || defined(SOC_K2E) || defined(SOC_K2G) || defined(SOC_C6678) || defined(SOC_C6657)
    #ifdef _TMS320C6X
        uint32_t corenum;
        /* Get the core number. */
        corenum = CSL_chipReadReg (CSL_CHIP_DNUM);
        /* Compute the global address. */
        return (addr + (0x10000000 + (corenum * 0x1000000)));
    #else
        return addr;
    #endif
    #else
        return addr;
    #endif
    static void SPI_test_xfer_ctrl(SPI_Handle spi, uint32_t xferEnable)
    #if defined(SOC_K2H) || defined(SOC_K2K) || defined(SOC_K2E) || defined(SOC_K2L) || defined(SOC_K2G) || defined(SOC_C6678) || defined(SOC_C6657)
        uint32_t xferActivate = xferEnable;
        SPI_control(spi, SPI_V0_CMD_XFER_ACTIVATE, (void *)&xferActivate);
    #endif
    static bool SPI_test_mst_slv_xfer(void *spi, SPI_Tests *test, uint32_t xferLen, bool multChn)
        bool            transferOK;
        uintptr_t        addrMasterRxBuf, addrMasterTxBuf, addrSlaveRxBuf, addrSlaveTxBuf, addrCancelTxBuff, addrCancelRxBuff;
        bool            ret = false;
        uint32_t        terminateXfer = 1;
        bool            master = test->master;
        bool            cbMode = test->cbMode;
        uint32_t        timeout = test->timeout;
        uint32_t        transCount, xferBytes, testLen;
        unsigned char  *srcPtr;
        if (dmaMode)
            addrMasterRxBuf = l2_global_address((uintptr_t)masterRxBuffer);
            addrMasterTxBuf = l2_global_address((uintptr_t)masterTxBuffer);
            addrSlaveRxBuf = l2_global_address((uintptr_t)slaveRxBuffer);
            addrSlaveTxBuf = l2_global_address((uintptr_t)slaveTxBuffer);
            addrCancelTxBuff = l2_global_address((uintptr_t)cancelTxBuff);
            addrCancelRxBuff = l2_global_address((uintptr_t)cancelRxBuff);
        else
            addrMasterRxBuf = (uintptr_t)masterRxBuffer;
            addrMasterTxBuf = (uintptr_t)masterTxBuffer;
            addrSlaveRxBuf = (uintptr_t)slaveRxBuffer;
            addrSlaveTxBuf = (uintptr_t)slaveTxBuffer;
            addrCancelTxBuff = (uintptr_t)cancelTxBuff;
            addrCancelRxBuff = (uintptr_t)cancelRxBuff;
        memset(cancelTxBuff, 0, sizeof(cancelTxBuff));
        memset(cancelRxBuff, 0, sizeof(cancelRxBuff));
        memset(masterRxBuffer, 0, sizeof(masterRxBuffer));
        memset(slaveRxBuffer, 0, sizeof(slaveRxBuffer));
    #if !defined (__aarch64__) || defined (SOC_AM64X)
        if (dmaMode)
            CacheP_wbInv((void *)addrMasterRxBuf, (int32_t)sizeof(masterRxBuffer));
            CacheP_wbInv((void *)addrSlaveRxBuf, (int32_t)sizeof(slaveRxBuffer));
            CacheP_wbInv((void *)addrCancelTxBuff, (int32_t)sizeof(cancelTxBuff));
            CacheP_wbInv((void *)addrCancelRxBuff, (int32_t)sizeof(cancelRxBuff));
    #endif
    #endif
        testLen = xferLen;
    #if defined(SOC_AM574x) || defined(SOC_AM572x)|| defined(SOC_AM571x) || defined (SOC_DRA72x)  || defined (SOC_DRA75x) || defined (SOC_DRA78x) || defined (SOC_AM335x) || defined (SOC_AM437x) || defined (SOC_AM65XX)  || defined(SOC_J721E) || defined(SOC_J7200) || defined (SOC_AM64X)
            if (testLen > test->trigLvl)
                /* always transfer data bytes of multiple trigger level */
                testLen = (xferLen / test->trigLvl) * test->trigLvl;
            else
                /* transfer data bytes of 1 trigger level */
                testLen = test->trigLvl;
    #endif
    #endif
        if (testId == SPI_TEST_ID_WORD_LEN)
             * Word length can be 8/16/32 bits,
             * calculate the SPI word count
            transCount = testLen / (test->param / 8);
            xferBytes = transCount * (test->param / 8);
        else
            /* Default word length is 8-bit */
            transCount = testLen;
            xferBytes = testLen;
        /* Initialize slave SPI transaction structure */
        transaction.count = transCount;
        transaction.arg = (void *)&terminateXfer;
        if (master == true)
            if ((testId == SPI_TEST_ID_CB_CANCEL) || (testId == SPI_TEST_ID_DMA_CB_CANCEL))
                transaction.txBuf = (void *)addrCancelTxBuff;
                transaction.rxBuf = (void *)addrCancelRxBuff;
            else
                transaction.txBuf = (void *)addrMasterTxBuf;
                transaction.rxBuf = (void *)addrMasterRxBuf;
        else
            transaction.txBuf = (void *)addrSlaveTxBuf;
            transaction.rxBuf = (void *)addrSlaveRxBuf;
        /* Initiate SPI transfer */
        SPI_test_xfer_ctrl(spi, 1);
        if (multChn == true)
            transferOK = MCSPI_transfer((MCSPI_Handle)spi, &transaction);
        else
    #endif
            transferOK = SPI_transfer((SPI_Handle)spi, &transaction);
                SPI_transferCancel(spi);
        if(transferOK)
            if (cbMode)
                    goto Err;
            SPI_test_xfer_ctrl(spi, 0);
            /* Get the actual transfer bytes */
                xferBytes = transaction.count * (test->param / 8);
            else
                xferBytes = transaction.count;
                if (transaction.status == SPI_TRANSFER_CANCELED)
                    SPI_log("\n SPI Transfer Canceled!\n");
                else
                    SPI_log("\n SPI Transfer Cancel failed!\n");
                    goto Err;
            else if (testId != SPI_TEST_ID_TX_ONLY)
                if (master == true)
                    if (testId >= SPI_TEST_ID_LOOPBACK)
                        srcPtr = masterTxBuffer;
                    else
                        srcPtr = slaveTxBuffer;
                    /* master mode, verify master recieved data match with slave sent data */
                    if (SPI_verify_data(masterRxBuffer, srcPtr, xferBytes) == false)
                        goto Err;
                    /* Print contents of master receive buffer */
                    SPI_log("Master: %s\n", masterRxBuffer);
                else
                    /* slave mode, verify slave recieved data match with master sent data */
                    if (SPI_verify_data(slaveRxBuffer, masterTxBuffer, xferBytes) == false)
                        goto Err;
                    /* Print contents of slave receive buffer */
                    SPI_log("Slave: %s\n", slaveRxBuffer);
        else
            if ((testId == SPI_TEST_ID_TIMEOUT) || (testId == SPI_TEST_ID_TIMEOUT_POLL))
                if (transaction.status == SPI_TRANSFER_TIMEOUT)
                    SPI_log("SPI Slave transfer Timed out for transfer length %d\n", xferLen);
                else
                    SPI_log("Unsuccessful slave SPI transfer");
                    goto Err;
            else
                goto Err;
        ret = true;
    Err:
        return (ret);
    static uint32_t SPI_test_get_instance (uint32_t testId, bool master)
        uint32_t instance;
        /* Soc configuration structures indexing starts from 0. If the IP
         * instances start with 1, to address proper Configuration
         * structure index, McSPI Instance should be substracted with 1
        if (master == (bool)true)
            instance = (uint32_t)BOARD_MCSPI_MASTER_INSTANCE - 1;
        else
            instance = (uint32_t)BOARD_MCSPI_SLAVE_INSTANCE - 1;
         * For AM65XX/J721E/J7200 SoC, master/slave test is set up to use
         * McSPI 2 on the MCU domain for master and McSPI 4 on the
         * Main domain for slave, for loopback test it uses default
         * board McSPI instance
        if (testId < SPI_TEST_ID_LOOPBACK)
            if (master == true)
                instance = 2U;
            else
                instance = 4U;
                 * Timeout test is done in slave mode,
                 * on the McSPI 2 on MCU domain
                instance = 2U;
    #endif
        return (instance);
    static bool SPI_test_single_channel(void *arg)
        uint64_t S_preTime,S_postTime;//for profile testing
        uint64_t read;//for profile testing
        SPI_Handle        spi;
        SPI_Params        spiParams;
        uint32_t          instance, i, modeIndex, SPI_modeIndex, xferLen, num_xfers;
        bool              ret = false;
        SPI_Tests        *test = (SPI_Tests *)arg;
        S_preTime=S_postTime=0;//for profile testing
        read=0;
    	SPI_FrameFormat   frameFormat[]=
    		SPI_POL0_PHA0, /*!< SPI mode Polarity 0 Phase 0 */
    		SPI_POL0_PHA1, /*!< SPI mode Polarity 0 Phase 1 */
    		SPI_POL1_PHA0, /*!< SPI mode Polarity 1 Phase 0 */
    		SPI_POL1_PHA1,  /*!< SPI mode Polarity 1 Phase 1 */
        if (cbMode == true)
            /* Create call back semaphore */
            SPI_osalSemParamsInit(&cbSemParams);
            cbSemParams.mode = SemaphoreP_Mode_BINARY;
            cbSem[0] = SPI_osalCreateBlockingLock(0, &cbSemParams);
    	if ((testId == SPI_TEST_ID_WORD_LEN) && (test->dmaMode == false))
            SPI_modeIndex = 4;
        else
            SPI_modeIndex = 1;
    	/* In case of SPI_TEST_ID_PHA_POL all SPI modes need to be tested */
        for (modeIndex = 0; modeIndex < SPI_modeIndex; modeIndex++)
            ret = false;
            instance = SPI_test_get_instance(testId, master);
            SPI_initConfig(instance, test, MCSPI_TEST_CHN, false);
            /* Initialize SPI handle */
            if (master == false)
                spiParams.mode = SPI_SLAVE;
            if (cbMode == true)
                spiParams.transferMode = SPI_MODE_CALLBACK;
                spiParams.transferCallbackFxn = SPI_callback;
            spiParams.transferTimeout = timeout;
            if (testId == SPI_TEST_ID_PHA_POL)
                spiParams.frameFormat = (SPI_FrameFormat)(test->param);
                if(test->dmaMode == false)
                    spiParams.frameFormat = frameFormat[modeIndex];
                    SPI_log("\n%s with SPI Mode %d\n", test->testDesc, spiParams.frameFormat);
                spiParams.dataSize = test->param;
            spi = SPI_open(instance, &spiParams);
            if (spi == NULL)
                SPI_log("Error initializing SPI\n");
                goto Err;
            else
                SPI_log("SPI initialized\n");
                num_xfers = 1;
            else
                num_xfers = 1;
    #else
                num_xfers = SPI_NUM_XFERS;
    #endif
            for (i = 0; i < num_xfers; i++)
                    xferLen = CANCEL_TX_LEN;
                else
                    xferLen = spi_test_xfer_len[i];
                S_preTime=TimerP_getTimeInUsecs();//debug
                if (SPI_test_mst_slv_xfer((void *)spi, test, xferLen, false) == false)
                    goto Err;
                S_postTime=TimerP_getTimeInUsecs();//debug
                read+= S_postTime-S_preTime;//debug
                    SPI_log("SPI Master Transfer Cancelled!!\n");
                if ((master == true) && (testId < SPI_TEST_ID_LOOPBACK))
                     * master sleep for 1 second after each transfer
                     * to sync with slave transfer
                    Osal_delay(1000);
                else
                     * slave sleep for half second after each transfer
                     * to sync with master transfer
                    Osal_delay(500);
            ret = true;
            if (testId == SPI_TEST_ID_WORD_LEN){
                    if (spi)
                        SPI_close(spi);
    	} /* End of for loop */
        SPI_log("\ndummy Profiling!!\n");//debug
        SPI_log(" %d \n",read/1000);//debug in msec
    Err:
    	if (testId != SPI_TEST_ID_WORD_LEN){
    	    if (spi)
    	        SPI_close(spi);
        if (cbSem[0])
            SPI_osalDeleteBlockingLock(cbSem[0]);
            cbSem[0] = NULL;
        return (ret);
    static bool SPI_test_xfer_error(void *arg)
        bool              ret;
    #if defined(SOC_K2G)
        SPI_Handle        spi;
        bool              transferOK;
        uint32_t          instance;
        uint32_t          xferErr;
        if (master == true)
            ret = false;
            instance = 2;
            if (spi == NULL)
                goto Err;
            else
            transaction.count = 10;
            transaction.txBuf = (void *)masterTxBuffer;
            transaction.rxBuf = (void *)masterRxBuffer;
            if(transferOK)
                SPI_control(spi, SPI_V0_CMD_GET_XFER_ERR, (void *)&xferErr);
                if (xferErr == SPI_XFER_ERR_RXOR)
                    SPI_log("Receive overrun error detected\n");
                else if (xferErr == SPI_XFER_ERR_BE)
                    SPI_log("Bit error detected\n");
                else
                    SPI_log("No error detected\n");
                ret = true;
    #ifdef USE_BIOS
            Task_sleep(1000);
    #else
    #endif
        Err:
            if (spi)
                SPI_close(spi);
        else
            /* slave do nothing for xfer error test */
            ret = true;
    #else
        ret = true;
    #endif
        return (ret);
    static bool SPI_test_multi_channel(void *arg)
        MCSPI_Handle      spi[MCSPI_MAX_NUM_CHN];
        MCSPI_Params      spiParams;
        uint32_t          instance, i;
        bool              ret = false;
        uint32_t          chn, maxNumChn, testChn;
        MCSPI_CallbackFxn cbFxn[MCSPI_MAX_NUM_CHN] = {MCSPI_callback0, MCSPI_callback1, MCSPI_callback2, MCSPI_callback3};
        if (cbMode == true)
        testChn = MCSPI_TEST_CHN;
        SPI_initConfig(instance, test, testChn, false);
        MCSPI_Params_init(&spiParams);
        if (cbMode == true)
        if (master == true)
            maxNumChn = MCSPI_MAX_NUM_CHN;
        else
            /* Only 1 channel supported in slave mode */
            maxNumChn = 1;
        for (i = 0; i < maxNumChn; i++)
            if (master == true)
                chn = i;
            else
                chn = testChn;
            if (cbMode == true)
                cbSem[chn] = SPI_osalCreateBlockingLock(0, &cbSemParams);
                spiParams.transferCallbackFxn = cbFxn[chn];;
            spi[chn] = MCSPI_open(instance, chn, &spiParams);
            if (spi[chn] == NULL)
                SPI_log("Error initializing SPI instance %d channel %d\n",
                        instance, chn);
                goto Err;
            else
                SPI_log("SPI instance %d channel %d\n",
                        instance, chn);
        for (i = 0; i < 1; i++)
    #else
        for (i = 0; i < SPI_NUM_XFERS; i++)
    #endif
            if (SPI_test_mst_slv_xfer((void *)(spi[testChn]), test, spi_test_xfer_len[i], true) == false)
                goto Err;
                Osal_delay(1000);
            else
                Osal_delay(500);
        ret = true;
    Err:
            if (master == true)
                chn = i;
            else
                chn = testChn;
            if (spi[chn])
                MCSPI_close(spi[chn]);
            if (cbSem[chn])
                SPI_osalDeleteBlockingLock(cbSem[chn]);
                cbSem[chn] = NULL;
        return (ret);
    #endif
    void SPI_test_print_test_desc(SPI_Tests *test)
        char        testId[16] = {0, };
        /* Print unit test ID */
        sprintf(testId, "%d", test->testId);
    	SPI_log("\r\n SPI UT %s\r\n", testId);
    	/* Print test description */
    	SPI_log("\r\n %s\r\n", test->testDesc);
        #endif
       #endif
            #endif
            #endif
            #endif
        #endif
            #endif
            #endif
            #endif
    #endif
        //{NULL, },
        #endif
    //    {SPI_test_single_channel, SPI_TEST_ID_INT, false, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n SPI master slave test slave in non-dma interrupt mode", },
        #endif
            #endif
            #endif
        #endif
    //    {NULL, },
    #if defined (SOC_J721E) || defined (SOC_J7200)
    #define MCSPI_SYNC_ADDR         (0x90000000U)
    #endif
     *  ======== slaveTaskFxn ========
     *  The task is part of separate slave example project.
     *  To test slave mode example, slave task has to be
     *  ready for master. Slave SPI sends a message to master
     *  while receiving message from master.
    #ifdef USE_BIOS
    Void slaveTaskFxn (UArg arg0, UArg arg1)
    #else
    void slaveTaskFxn()
    #endif
        uint32_t  i;
        bool      testFail = false;
        SPI_Tests *test;
        SPI_log("Starting SPI Slave test. \n");
        SPI_init();
        *((volatile uint32_t *)(MCSPI_SYNC_ADDR)) = 0x12341234U;
        CacheP_wb((void *)MCSPI_SYNC_ADDR, 4);
    #endif
        for (i = 0; ; i++)
            if (loopBackTest == true)
                /* Slave mode test not supported for loopback test */
                break;
            test = &Spi_tests_slave[i];
            if (test->testFunc == NULL)
                break;
            if (test->testId >= SPI_TEST_ID_LOOPBACK)
                /* bypass the loopback test for slave task */
                break;
            SPI_test_print_test_desc(test);
            if (test->testFunc((void *)test) == true)
                SPI_log("\r\n %s have passed\r\n", test->testDesc);
            else
                SPI_log("\r\n %s have failed\r\n", test->testDesc);
                testFail = true;
                break;
        if(testFail == true)
            SPI_log("\n Some tests have failed. \n");
        else
            SPI_log("\n All tests have passed. \n");
        SPI_log("Done\n");
        while (true)
     *  ======== masterTaskFxn ========
     *  This task is part of master example project.
     *  Slave task has to ensure transaction ready.
     *  Master SPI sends a message to slave and
     *  receives message from slave.
    #ifdef USE_BIOS
    Void masterTaskFxn (UArg arg0, UArg arg1)
    #else
    void masterTaskFxn()
    #endif
        uint32_t  i;
        SPI_Tests *test;
        SPI_log("Starting SPI Master test. \n");
        while ( *((volatile uint32_t *)(MCSPI_SYNC_ADDR)) != 0x12341234U)
    #ifdef USE_BIOS
            Task_yield();
    #endif
            /* wait for slave to start. */
            CacheP_Inv((void *)MCSPI_SYNC_ADDR, 4);
    #ifdef USE_BIOS
        /* Add small delay after the sync.
         * for the slave to be ready before master initiates transfer. */
        Task_sleep(1000);
    //    Task_sleep(10);//debug
    #endif
    #endif
        SPI_init();
        for (i = 0; ; i++)
            test = &Spi_tests_master[i];
                break;
                /* Only loopback test supported */
                if ((test->testId < SPI_TEST_ID_LOOPBACK)       &&
                    (test->testId != SPI_TEST_ID_TIMEOUT)       &&
                    (test->testId != SPI_TEST_ID_TIMEOUT_POLL))
                    continue;
            else
                testFail = true;
                break;
        else
        SPI_log("Done\n");
        while (true)
    #if (defined (USE_BIOS)  && (defined (SOC_J721E) || defined (SOC_J7200)))
    void MCSPI_setupSciServer(void)
        Sciserver_TirtosCfgPrms_t appPrms;
        int32_t ret = CSL_PASS;
        ret = Sciserver_tirtosInitPrms_Init(&appPrms);
        appPrms.taskPriority[SCISERVER_TASK_USER_LO] =
                                                4;
        appPrms.taskPriority[SCISERVER_TASK_USER_HI] =
                                                5;
        if (ret == CSL_PASS)
            ret = Sciserver_tirtosInit(&appPrms);
            System_printf("Starting Sciserver..... PASSED\n");
        else
            System_printf("Starting Sciserver..... FAILED\n");
        return;
    #endif
    void MCSPI_initSciclient()
        Sciclient_ConfigPrms_t        config;
        /* Now reinitialize it as default parameter */
        ret = Sciclient_configPrmsInit(&config);
        if (ret != CSL_PASS)
            System_printf("Sciclient_configPrmsInit Failed\n");
            ret = Sciclient_boardCfgParseHeader(
                (uint8_t *)SCISERVER_COMMON_X509_HEADER_ADDR,
                &config.inPmPrms, &config.inRmPrms);
                System_printf("Sciclient_boardCfgParseHeader Failed\n");
    #endif
            ret = Sciclient_init(&config);
                System_printf("Sciclient_init Failed\n");
    #endif
     *  ======== main ========
    int main(void)
        /* Call board init functions */
        Board_initCfg boardCfg;
        Board_STATUS  boardStatus;
    #if defined (evmK2G)
        SPI_v0_HWAttrs spi_cfg;
        uint8_t instance;
        Board_SoCInfo socInfo;
    #endif
    #if defined (idkAM571x)
        Board_IDInfo  id;
    #endif
    #ifdef USE_BIOS
    #if defined(SOC_AM335x) || defined (SOC_AM437x) || defined (SOC_AM65XX) || defined(SOC_J721E) || defined(SOC_J7200) || defined (SOC_AM64X)
        Task_Handle task;
        Error_Block eb;
        Task_Params taskParams;
        Error_init(&eb);
        /* Initialize the task params */
        Task_Params_init(&taskParams);
        /* Set the task priority higher than the default priority (1) */
        taskParams.priority = 2;
        taskParams.stackSize = 0x4000;
    #if defined (MCSPI_SLAVE_TASK)
        task = Task_create(slaveTaskFxn, &taskParams, &eb);
    #elif defined (MCSPI_MASTER_TASK)
        task = Task_create(masterTaskFxn, &taskParams, &eb);
    #endif /* Task type */
        if (task == NULL)
            System_printf("Task_create() failed!\n");
            BIOS_exit(0);
    #endif /* Soc type */
        MCSPI_setupSciServer();
    #endif
        /* It must be called before board init */
        MCSPI_initSciclient();
    #endif
     * For AM65XX/J721E/J7200, master and slave apps are
     * running on the same SoC, master is running on
     * MCU core and slave is running on MPU core,
     * pinmux only need to be initialized once in board
    #if defined(BUILD_MPU)
        boardCfg = BOARD_INIT_PINMUX_CONFIG |
                   BOARD_INIT_MODULE_CLOCK |
                   BOARD_INIT_UART_STDIO;
    #else
    #endif
    #else
    #endif
        boardStatus = Board_init(boardCfg);
        if (boardStatus != BOARD_SOK)
            return (0);
            return (0);
        loopBackTest = true;
    #endif
    #if defined (__TI_ARM_V7R4__)
        /* Configure the MCU SPI0_D1 pinmux, since it is not set by default in board */
        HW_WR_REG32((WKUP_PINMUX_REG_BASE + MCU_SPI0_D1_PADCFG_OFFSET), PIN_MODE(0) | \
                    ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)));
        /* Configure the MCU SPI0_CLK pinmux to support loopback */
        HW_WR_REG32((WKUP_PINMUX_REG_BASE + MCU_SPI0_CLK_PADCFG_OFFSET), PIN_MODE(0) | \
    #endif
    #endif
        boardStatus = Board_getIDInfo(&id);
            return (0);
        /* Check if is DRA (AM570x) SoC */
        if ((id.boardName[0] == 'D') &&
            (id.boardName[1] == 'R') &&
            (id.boardName[2] == 'A'))
    #endif
        /* GPIO initialization */
        GPIO_init();
        /* Set BUS_Switch_ENABLE pin to low for enabling the switch */
        GPIO_write((GPIO_BUS_SWITCH_ENABLE_OFFSET), GPIO_PIN_VAL_LOW);
    #endif
        /* Read the SoC info to get the System clock value */
        Board_getSoCInfo(&socInfo);
        if(socInfo.sysClock != BOARD_SYS_CLK_DEFAULT)
            /* Since this is a generic SPI test,
             * configure the input clock for all the available instances */
            for (instance = 0; instance < CSL_SPI_CNT; instance++)
                /* Update the I2C functional clock based on CPU clock - 1G or 600MHz */
                spi_cfg.inputClkFreq = socInfo.sysClock/SPI_MODULE_CLOCK_DIVIDER;
    #endif
    #ifdef USE_BIOS
        /* Start BIOS */
        BIOS_start();
    #else
    #ifdef MCSPI_MASTER_TASK
        masterTaskFxn();
    #else
        slaveTaskFxn();
    #endif
    #endif
        return (0);
    #if defined(BUILD_MPU) || defined (__C7100__)
    extern void Osal_initMmuDefault(void);
    void InitMmu(void)
        Osal_initMmuDefault();
    #endif
    Please look into it.
    Thanks & Regards,
    Tanvi
  • Hi Tanvi,
    Have you tried reducing the value further? If not may be try 5?
    Is this 50 msecs are for complete transaction or it's just for SPI_osalPendLock(cbSem[0], timeout) != SemaphoreP_OK?
    Also, how much time you are expecting to achieve?
    Parth
  • Hi Parth,
    Yes, I tried with Task_sleep(5) but my application gets stuck Task_sleep(5) won't help.
    Yes, this time is for the complete transaction and not just for SPI_osalPendLock(cbSem[0], timeout) != SemaphoreP_OK.
  • Hi Tanvi,
    There is a Task_sleep API in  SPI_test_xfer_error used for sync, can you try reducing that as well as see if that helps?
    Parth
  • Hi Parth,
    Tried what you specified, but it didn't help me.
    Please suggest something else for this.
    I want to send 2KB in approximately 30 msecs.
    Thanks & Regards,
    Tanvi
  • Tanvi,
    Is the 50msecs time with reduced value or actual value?
    Parth
  • Hi Parth,
    As per the file main_mcspi_slave_mode.c file I shared with you in the function SPI_test_single_channel() Osal_delay have 10 & 20 passed into it.
    You can also check it in the file I shared with you.
    Thanks & Regards,
    Tanvi
  • Hi Tanvi,
    I checked the code you shared. The 50ms of time calculated is for the complete execution of SPI_test_mst_slv_xfer API which in addition to the transfer of data includes some data verification and log prints. I have verified that the log prints are taking much more time than the actual transfer. After commenting out all the SPI_log calls from the  SPI_test_mst_slv_xfer I got the reading of around 9 ms for the default case, majority of which is due to OSAL_pendlock which is a one time sync requirement, which may not be required in your actual use case.
    Can you also comment out all the SPI_log calls on your end as well and see if you get the desired results?
    Parth
  • Hi Parth,
    After commenting all the logs the transfer rate for above mentioned data is same i.e. 10ms approx.
    I will check with commenting OSAL_pendlock, and update you the readings.
    Thanks & Regards,
    Tanvi
  • Hi Tanvi,
    This reading lies in the desired range right?
    Sure, please check and let us know
    Parth
  • Hi Parth,
    I checked by commenting the
    but it took now 3 msecs more than when it wasn't commented out.
    Please suggest some other method.
    Tanvi
  • Hi Tanvi,
    What is your final use case here? What kind of communication your application is finally gonna have? The application provided in the SDK is just for validation purposes and not meant for profiling. Your use case most probably is not going to be the same as example, you might not need this syncing at all and anyway you are gonna have to port this according your requirement.
    Now by commenting out all the SPI_log calls you can see that the SPI transfer itself does not take much time, out of 10ms more than 9ms are taken for syncing purpose by OSAL_Pendlock which means the transfer itself took less than 1ms. The rest of time is just application specific which will vary based how we are writing the application.
    For profiling purpose you should check just the time taken to execute SPI_test_xfer_ctrl and MCSPI_transfer rest all is application dependent.
