TDA4VM: TDA4VM
Part Number: TDA4VM
hi:
On the board designed by ourselves, the startup mode of tda4 MCU is :MCU_BOOTMODE[9:0] =0b1100001000. In most cases, it can be started normally, but there is a certain probability that it will fail to start. In case of startup failure, use the emulator to confirm through JTAG that the R-core PC pointer of MCU stops at address 0x41800410 .Please help to analyze the cause of the problem, thank you!
