Part Number: TDA4VM
Hi Sir :
I used SBL to boot up and mount the file system with NFS, but the SD Card crashed.
Is there any way to solve this problem?
PSDK vserion : 8.1
Rootfs : tisdk-default-image-j7-evm.tar.xz
NOTICE: BL31: v2.5(release):08.01.00.006-dirty
NOTICE: BL31: Built : 19:52:11, Dec 20 2021
ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.65-rt53 (pierrehsieh@jetson-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT_RT Tue Feb 15 15:20:00 CST 2022
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[ 0.000000] OF: reserved mem: OVERLAP DETECTED!
[ 0.000000] vision-apps-c71-memory@aa100000 (0x00000000aa100000--0x00000000af000000) overlaps with r5f-virtual-eth-queues@ac000000 (0x00000000ac000000--0x00000000ac200000)
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] Carveout Heap: regions without no-map are not yet supported
[ 0.000000] OF: reserved mem: node vision_apps_shared-memories compatible matching fail
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1024 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff]
[ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x00000000fc000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008bfffffff]
[ 0.000000] node 0: [mem 0x00000008c0000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] On node 0 totalpages: 1048576
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 8192 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:63
[ 0.000000] cma: Reserved 24 MiB at 0x00000000fe800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 18 pages/cpu s34752 r8192 d30784 u73728
[ 0.000000] pcpu-alloc: s34752 r8192 d30784 u73728 alloc=18*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/nfs rw rootfstype=nfs root=/dev/nfs rw nfsroot=192.168.100.100:/home/user/net_nfsshare/PSDKv81_targetNFS,nolock,v3,tcp,rsize=4096,wsize=4096 ip=dhcp
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000d4000000-0x00000000d8000000] (64MB)
[ 0.000000] Memory: 1969216K/4194304K available (10624K kernel code, 1156K rwdata, 4108K rodata, 1728K init, 438K bss, 2200512K reserved, 24576K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008c0030000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c0040000
[ 0.000000] random: get_random_bytes called from start_kernel+0x320/0x4c8 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008345] Console: colour dummy device 80x25
[ 0.012910] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023579] pid_max: default: 32768 minimum: 301
[ 0.028333] LSM: Security Framework initializing
[ 0.033084] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.040659] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.049459] rcu: Hierarchical SRCU implementation.
[ 0.054586] Platform MSI: msi-controller@1820000 domain created
[ 0.060809] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070115] EFI services will not be available.
[ 0.074841] smp: Bringing up secondary CPUs ...
[ 0.085785] Detected PIPT I-cache on CPU1
[ 0.089939] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.096970] GICv3: CPU1: using allocated LPI pending table @0x00000008c0050000
[ 0.104377] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.111097] smp: Brought up 1 node, 2 CPUs
[ 0.115291] SMP: Total of 2 processors activated.
[ 0.120100] CPU features: detected: 32-bit EL0 Support
[ 0.125354] CPU features: detected: CRC32 instructions
[ 0.138877] CPU: All CPU(s) started at EL2
[ 0.143072] alternatives: patching kernel code
[ 0.148109] devtmpfs: initialized
[ 0.157215] KASLR disabled due to lack of seed
[ 0.161844] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.171808] futex hash table entries: 512 (order: 4, 65536 bytes, linear)
[ 0.179277] pinctrl core: initialized pinctrl subsystem
[ 0.184851] DMI not present or invalid.
[ 0.189013] NET: Registered protocol family 16
[ 0.194226] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.201498] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.209488] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.217807] thermal_sys: Registered thermal governor 'step_wise'
[ 0.218082] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.231180] ASID allocator initialised with 32768 entries
[ 0.248616] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.255496] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.262353] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.269210] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.276601] cryptd: max_cpu_qlen set to 1000
[ 0.282536] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
[ 0.291338] vsys_3v3: supplied by evm_12v0
[ 0.295708] vsys_5v0: supplied by evm_12v0
[ 0.300073] vdd_mmc1: supplied by vsys_3v3
[ 0.304549] vdd_sd_dv_alt: supplied by vsys_3v3
[ 0.309673] iommu: Default domain type: Translated
[ 0.314814] SCSI subsystem initialized
[ 0.318923] mc: Linux media interface: v0.10
[ 0.323298] videodev: Linux video capture interface: v2.00
[ 0.328927] pps_core: LinuxPPS API ver. 1 registered
[ 0.333997] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.343333] PTP clock support registered
[ 0.347350] EDAC MC: Ver: 3.0.0
[ 0.351063] FPGA manager framework
[ 0.354581] Advanced Linux Sound Architecture Driver Initialized.
[ 0.361184] clocksource: Switched to clocksource arch_sys_counter
[ 0.367512] VFS: Disk quotas dquot_6.6.0
[ 0.371543] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.381382] NET: Registered protocol family 2
[ 0.386082] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.394689] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.403596] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.411826] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear)
[ 0.420475] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.427379] UDP hash table entries: 2048 (order: 6, 262144 bytes, linear)
[ 0.434553] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear)
[ 0.442260] NET: Registered protocol family 1
[ 0.447063] RPC: Registered named UNIX socket transport module.
[ 0.453125] RPC: Registered udp transport module.
[ 0.457929] RPC: Registered tcp transport module.
[ 0.462731] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.469315] PCI: CLS 0 bytes, default 64
[ 0.473707] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.484000] Initialise system trusted keyrings
[ 0.488641] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.497151] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.503398] NFS: Registering the id_resolver key type
[ 0.508692] Key type id_resolver registered
[ 0.512975] Key type id_legacy registered
[ 0.517103] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.523963] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.531652] 9p: Installing v9fs 9p2000 file system support
[ 0.556731] Key type asymmetric registered
[ 0.560926] Asymmetric key parser 'x509' registered
[ 0.565936] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.573508] io scheduler mq-deadline registered
[ 0.578135] io scheduler kyber registered
[ 0.583205] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.589406] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.597351] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.603620] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.611440] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.619387] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.627513] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.634657] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.643205] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.656146] brd: module loaded
[ 0.663103] loop: module loaded
[ 0.666725] megasas: 07.714.04.00-rc1
[ 0.671648] libphy: Fixed MDIO Bus: probed
[ 0.676314] tun: Universal TUN/TAP device driver, 1.6
[ 0.681713] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.688128] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.694215] sky2: driver version 1.30
[ 0.698425] VFIO - User Level meta-driver version: 0.3
[ 0.704063] i2c /dev entries driver
[ 0.708094] sdhci: Secure Digital Host Controller Interface driver
[ 0.714417] sdhci: Copyright(c) Pierre Ossman
[ 0.719088] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.725435] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.732579] optee: probing for conduit method.
[ 0.737149] optee: revision 3.12 (3d47a131)
[ 0.737407] optee: initialized driver
[ 0.746308] NET: Registered protocol family 17
[ 0.750947] 9pnet: Installing 9P2000 support
[ 0.755343] Key type dns_resolver registered
[ 0.759867] printk: bootconsole [ns16550a0]: printing thread started
[ 0.759891] Loading compiled-in X.509 certificates
[ 0.763956] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.764053] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.765669] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
[ 0.781793] random: fast init done
[ 0.803723] printk: console [ttyS2]: printing thread started
[ 0.803728] printk: console [ttyS2] enabled
[ 0.803730] printk: bootconsole [ns16550a0] disabled
[ 0.803740] printk: bootconsole [ns16550a0]: printing thread stopped
[ 0.809588] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 26, base_baud = 3000000) is a 8250
[ 0.817239] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 27, base_baud = 3000000) is a 8250
[ 0.825242] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 0.825248] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 0.825251] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 0.825253] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 0.873783] scsi host0: ufshcd
[ 0.925193] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 0.925203] libphy: 46000f00.mdio: probed
[ 0.926400] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 0.926448] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 0.927464] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 0.928133] mmc0: CQHCI version 5.10
[ 0.928447] mmc1: CQHCI version 5.10
[ 0.941292] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 0.945236] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 0.953240] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 0.953743] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 0.957212] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 0.969443] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 0.978272] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 0.978740] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 1.010057] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[ 1.012339] mmc1: new high speed SDHC card at address aaaa
[ 1.012760] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
[ 1.015128] mmcblk1: p1 p2
[ 1.056209] mmc0: Command Queue Engine enabled
[ 1.056218] mmc0: new HS200 MMC card at address 0001
[ 1.056513] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
[ 1.056630] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
[ 1.056741] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
[ 1.056844] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (237:0)
[ 1.057576] mmcblk0: p1 p2
[ 1.085200] spi-nor spi0.0: mt35xu02g (262144 Kbytes)
[ 1.133198] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.133207] libphy: 46000f00.mdio: probed
[ 1.134412] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.134456] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 1.135324] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 1.135768] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 1.135772] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 1.136104] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 1.137072] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 1.137097] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 1.138484] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 1.138510] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 1.138537] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 1.138567] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 1.291022] cdns-ufshcd 4e84000.ufs: link startup failed 1
[ 1.291029] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[ 1.291032] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[ 1.291034] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[ 1.291037] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[ 1.291039] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[ 1.291042] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[ 1.291044] cdns-ufshcd 4e84000.ufs: Clk gate=1
[ 1.291046] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[ 1.291048] cdns-ufshcd 4e84000.ufs: last intr at 1180725 us, last intr status=0x404
[ 1.291051] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[ 1.291054] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[ 1.291056] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[ 1.291059] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[ 1.291062] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[ 1.291064] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[ 1.291067] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[ 1.291086] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[ 1.291089] host_regs: 00000010: 00000000 00000000 00000000 00000000
[ 1.291092] host_regs: 00000020: 00000000 00000470 00000000 00000000
[ 1.291095] host_regs: 00000030: 00000008 00000001 00000000 00000000
[ 1.291097] host_regs: 00000040: 00000000 00000000 00000000 00000000
[ 1.291099] host_regs: 00000050: 00000000 00000000 00000000 00000000
[ 1.291101] host_regs: 00000060: 00000000 00000000 00000000 00000000
[ 1.291103] host_regs: 00000070: 00000000 00000000 00000000 00000000
[ 1.291105] host_regs: 00000080: 00000000 00000000 00000000 00000000
[ 1.291107] host_regs: 00000090: 00000000 00000000 00000000 00000000
[ 1.291110] cdns-ufshcd 4e84000.ufs: No record of pa_err
[ 1.291112] cdns-ufshcd 4e84000.ufs: No record of dl_err
[ 1.291114] cdns-ufshcd 4e84000.ufs: No record of nl_err
[ 1.291116] cdns-ufshcd 4e84000.ufs: No record of tl_err
[ 1.291118] cdns-ufshcd 4e84000.ufs: No record of dme_err
[ 1.291120] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[ 1.291122] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[ 1.291124] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1181841 us
[ 1.291127] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[ 1.291129] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[ 1.291131] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[ 1.291133] cdns-ufshcd 4e84000.ufs: No record of host_reset
[ 1.291135] cdns-ufshcd 4e84000.ufs: No record of task_abort
[ 1.300696] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[ 1.303210] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[ 5.390657] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 5.413199] Sending DHCP requests ., OK
[ 6.425215] IP-Config: Got DHCP answer from 192.168.5.1, my address is 192.168.5.16
[ 6.425220] IP-Config: Complete:
[ 6.425222] device=eth0, hwaddr=50:51:a9:8e:61:50, ipaddr=192.168.5.16, mask=255.255.255.0, gw=192.168.5.1
[ 6.425226] host=192.168.5.16, domain=, nis-domain=(none)
[ 6.425228] bootserver=0.0.0.0, rootserver=192.168.5.231, rootpath=
[ 6.425230] nameserver0=192.168.5.20, nameserver1=192.168.1.1, nameserver2=168.95.1.1
[ 6.430644] ALSA device list:
[ 6.430648] No soundcards found.
[ 6.439621] VFS: Mounted root (nfs filesystem) on device 0:20.
[ 6.439754] devtmpfs: mounted
[ 6.440525] Freeing unused kernel memory: 1728K
[ 6.453281] Run /sbin/init as init process
[ 6.643143] systemd[1]: System time before build time, advancing clock.
[ 6.664450] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 6.664651] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[ 6.710664] systemd[1]: Set hostname to <j7-evm>.
[ 7.098091] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[ 7.098121] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[ 7.129888] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ OK ] Created slice system-getty.slice 7.227793] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.227904] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
m.
[ 7.227910] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 7.229615] systemd[1]: Created slice system-getty.slice.
[ 7.268697] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.269628] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice User and Session Slice.
[ 7.297267] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.297958] systemd[1]: Created slice User and Session Slice.
[ 7.313418] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 7.349343] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.365315] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ OK ] Reached target Remote File Systems.
[ 7.393260] systemd[1]: Reached target Remote File Systems.
[ 7.409254] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ OK ] Reached target Swap.[ 7.433269] systemd[1]: Reached target Swap.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 7.455391] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 7.469295] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ OK ] Listening on Process Core Dump Socket.
[ 7.502754] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on initctl Compatibility [ 7.523237] systemd[1]: Listening on initctl Compatibility Named Pipe.
Named Pipe.
[ OK ] Listening on Journal Socket (/dev/log).
[ 7.554659] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 7.555455] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.569583] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 7.607202] systemd[1]: Listening on Network Service Netlink Socket.
[ 7.623328] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on udev Kernel Socket.
[ 7.649464] systemd[1]: Listening on udev Kernel Socket.
[ 7.667666] systemd[1]: Mounting Huge Pages File System...
Mounting POSIX Message Queue File System..[ 7.691636] systemd[1]: Mounting POSIX Message Queue File System...
Mounting Kernel Debug File System...
[ 7.715656] systemd[1]: Mounting Kernel Debug File System...
Mounting Temporary Directory (/tmp)...
[ 7.739634] systemd[1]: Mounting Temporary Directory (/tmp)...
Starting Start psplash boot splash screen.[ 7.751357] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[ 7.754111] systemd[1]: Starting Start psplash boot splash screen...
Starting RPC Bind...
[ 7.784669] systemd[1]: Starting RPC Bind...
Starting Journal Service...
[ 7.793711] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Starting Load Kernel Modules...
[ 7.796969] systemd[1]: Starting Journal Service...
Starting Remount Root and Kernel File Systems systemd[1]: Starting Load Kernel Modules...
[0m...
[ 7.836046] systemd[1]: Starting Remount Root and Kernel File Systems...
Starting udev Coldplug all Devices...
[ 7.864538] systemd[1]: Starting udev Coldplug all Devices...
[ OK ] Mounted Huge Pages File System.[ 7.883278] systemd[1]: Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File Sy[ 7.905865] systemd[1]: Mounted POSIX Message Queue File System.
stem.
[ OK ] Started Journal Service.[ 7.931666] systemd[1]: Started Journal Service.
[ 7.937576] random: crng init done
[ 7.937582] random: 7 urandom warning(s) missed due to ratelimiting
[ OK ] Started RPC Bind.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
Starting Apply Kernel Variables...
Starting Create System Users...
[ 8.183519] systemd-journald[191]: Received client request to flush runtime journal.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Wait for Complete Device Initialization...
Starting udev Kernel Device Manager...
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Rebuild Dynamic Linker Cache...
Starting Create Volatile Files and Directories...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Create Volatile Files and Directories.
Starting Rebuild Journal Catalog...
[FAILED] Failed to start Network Time Synchronization.
See 'systemctl status systemd-timesyncd.service' for details.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Stopped Network Time Synchronization.
[ OK ] Started Rebuild Journal Catalog.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Found device /dev/mmcblk0p1.
Starting File System Check on /dev/mmcblk0p1...
[ OK ] Started File System Check on /dev/mmcblk0p1.
Mounting /run/media/mmcblk0p1...
[ OK ] Mounted /run/media/mmcblk0p1.
[ OK ] Found device /dev/mmcblk1p2.
[ OK ] Found device /dev/mmcblk1p1.
[ OK ] Started udev Wait for Complete Device Initialization.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
Starting File System Check on /dev/mmcblk1p1...
Starting File System Check on /dev/mmcblk1p2...
[ 13.854099] Unable to handle kernel paging request at virtual address ffff80086ebe5000
[ 13.857187] Unable to handle kernel paging request at virtual address ffff80086ebd3000
[ 13.862010] Mem abort info:
[ 13.869900] Mem abort info:
[ 13.872678] ESR = 0x96000005
[ 13.875457] ESR = 0x96000005
[ 13.878497] EC = 0x25: DABT (current EL), IL = 32 bits
[ 13.881535] EC = 0x25: DABT (current EL), IL = 32 bits
[ 13.886826] SET = 0, FnV = 0
[ 13.892117] SET = 0, FnV = 0
[ 13.895155] EA = 0, S1PTW = 0
[ 13.898193] EA = 0, S1PTW = 0
[ 13.901317] Data abort info:
[ 13.904443] Data abort info:
[ 13.907307] ISV = 0, ISS = 0x00000005
[ 13.910171] ISV = 0, ISS = 0x00000005
[ 13.913990] CM = 0, WnR = 0
[ 13.917808] CM = 0, WnR = 0
[ 13.920761] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000080ef8000
[ 13.923713] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000080ef8000
[ 13.930391] [ffff80086ebe5000] pgd=00000008fffff003, p4d=00000008fffff003, pud=0000000000000000
[ 13.937070] [ffff80086ebd3000] pgd=00000008fffff003, p4d=00000008fffff003, pud=0000000000000000
[ 13.945744] Internal error: Oops: 96000005 [#1] PREEMPT_RT SMP
[ 13.960227] Modules linked in:
[ 13.963269] CPU: 1 PID: 753 Comm: rngd Not tainted 5.10.65-rt53 #2
[ 13.969431] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 13.975245] pstate: 40000085 (nZcv daIf -PAN -UAO -TCO BTYPE=--)
[ 13.981233] pc : cpuacct_charge+0x64/0xa8
[ 13.985238] lr : cpuacct_charge+0x40/0xa8
[ 13.989233] sp : ffff800013753c90
[ 13.992532] x29: ffff800013753c90 x28: ffff0008425b1d80
[ 13.997828] x27: 0000000000000000 x26: ffff00087fb6b540
[ 14.003122] x25: ffff800010e48600 x24: ffff000840c55880
[ 14.008417] x23: ffff00087fb6b4c0 x22: 0000000000000000
[ 14.013712] x21: ffff0008425b1d80 x20: 0000000000017719
[ 14.019006] x19: 0000000000000000 x18: 0000000000000000
[ 14.024300] x17: 0000000000000000 x16: 0000000000000000
[ 14.029594] x15: 0000000000000000 x14: 0000000000000000
[ 14.034889] x13: 0000000000000000 x12: 0000000000000c2f
[ 14.040182] x11: 000000000000012b x10: 000000000030fad7
[ 14.045476] x9 : 000000000030fad7 x8 : 0000000000000000
[ 14.050770] x7 : ffff00087fb6bfc0 x6 : ffff00087fb6b4c0
[ 14.056064] x5 : 0000000000000000 x4 : ffff80086ebe5000
[ 14.061358] x3 : ffff80086ebe5000 x2 : ffff000845e18400
[ 14.066652] x1 : ffff0008425b1d80 x0 : 0000000000000000
[ 14.071947] Call trace:
[ 14.074381] cpuacct_charge+0x64/0xa8
[ 14.078029] update_curr+0xfc/0x1a8
[ 14.081504] put_prev_entity+0x74/0x108
[ 14.085325] pick_next_task_fair+0x218/0x388
[ 14.089580] __schedule+0x120/0x7b8
[ 14.093057] schedule+0x88/0x108
[ 14.096271] do_notify_resume+0x204/0x718
[ 14.100268] work_pending+0xc/0x43c
[ 14.103746] Code: d503201f f9406440 d538d084 8b050000 (f8646803)
[ 14.109821] ---[ end trace 0000000000000002 ]---
[ 14.114491] Internal error: Oops: 96000005 [#2] PREEMPT_RT SMP
[ 14.114492] note: rngd[753] exited with preempt_count 2
[ 14.120305] Modules linked in:
[ 14.125517] Unable to handle kernel paging request at virtual address ffff80086ebe5010
[ 14.128549] CPU: 0 PID: 752 Comm: rngd Tainted: G D 5.10.65-rt53 #2
[ 14.136441] Mem abort info:
[ 14.143985] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 14.146763] ESR = 0x96000005
[ 14.152575] pstate: 80000085 (Nzcv daIf -PAN -UAO -TCO BTYPE=--)
[ 14.155612] EC = 0x25: DABT (current EL), IL = 32 bits
[ 14.161597] pc : cpuacct_account_field+0x4c/0x88
[ 14.166890] SET = 0, FnV = 0
[ 14.171488] lr : cpuacct_account_field+0x24/0x88
[ 14.174528] EA = 0, S1PTW = 0
[ 14.179126] sp : ffff800010003d70
[ 14.182251] Data abort info:
[ 14.185549] x29: ffff800010003d70 x28: ffff00087fb56440
[ 14.188413] ISV = 0, ISS = 0x00000005
[ 14.193704] x27: ffff00087fb56c18 x26: ffff800010162308
[ 14.197522] CM = 0, WnR = 0
[ 14.202813] x25: 0000000000000001 x24: 0000000000000080
[ 14.205766] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000080ef8000
[ 14.211057] x23: 000000000000000f x22: ffff00087fb564e8
[ 14.217735] [ffff80086ebe5010] pgd=00000008fffff003, p4d=00000008fffff003, pud=0000000000000000
[ 14.223026] x21: ffff0008425b0ec0 x20: 00000000003b1c3f
[ 14.236990] x19: 0000000000000000 x18: 0000000000000000
[ 14.242286] x17: 0000000000000000 x16: 0000000000000000
[ 14.247579] x15: 0000000000000000 x14: 0000000000000000
[ 14.252874] x13: 003d090000000000 x12: 00003d0900000000
[ 14.258168] x11: 0000000000000000 x10: 00003d0900000000
[ 14.263462] x9 : 00000000000c3500 x8 : 0000000000000000
[ 14.268756] x7 : 0000000000000008 x6 : ffff8000110d1120
[ 14.274049] x5 : 0000000000000000 x4 : ffff80086ebd3000
[ 14.279343] x3 : ffff000845e18400 x2 : 00000000003b1c3f
[ 14.284637] x1 : ffff0008425b0ec0 x0 : 0000000000000000
[ 14.289932] Call trace:
[ 14.292365] cpuacct_account_field+0x4c/0x88
[ 14.296621] account_user_time+0x9c/0xe0
[ 14.300531] irqtime_account_process_tick+0x104/0x148
[ 14.305568] account_process_tick+0xb8/0xc8
[ 14.309736] update_process_times+0x54/0xa0
[ 14.313907] tick_sched_handle.isra.0+0x34/0x50
[ 14.318423] tick_sched_timer+0x4c/0xa8
[ 14.322244] __hrtimer_run_queues+0x128/0x210
[ 14.326586] hrtimer_interrupt+0xe8/0x248
[ 14.330581] arch_timer_handler_phys+0x34/0x48
[ 14.335012] handle_percpu_devid_irq+0x84/0x148
[ 14.339529] generic_handle_irq+0x30/0x48
[ 14.343523] __handle_domain_irq+0x64/0xc0
[ 14.347605] gic_handle_irq+0x58/0x128
[ 14.351340] el0_irq_naked+0x4c/0x54
[ 14.354903] Code: 937d7e65 f9406860 d538d084 8b050000 (f8646801)
[ 14.360984] ------------[ cut here ]------------
[ 14.365584] WARNING: CPU: 0 PID: 752 at kernel/locking/rtmutex.c:2040 __rt_mutex_trylock+0x20/0xe0
[ 14.374523] Modules linked in:
[ 14.377562] CPU: 0 PID: 752 Comm: rngd Tainted: G D 5.10.65-rt53 #2
[ 14.385111] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 14.390923] pstate: 00000085 (nzcv daIf -PAN -UAO -TCO BTYPE=--)
[ 14.396911] pc : __rt_mutex_trylock+0x20/0xe0
[ 14.401253] lr : _mutex_trylock+0x10/0x20
[ 14.405248] sp : ffff800010003870
[ 14.408547] x29: ffff800010003870 x28: ffff0008425b0ec0
[ 14.413841] x27: ffff00087fb56c18 x26: ffff800010162308
[ 14.419135] x25: 0000000000000001 x24: 0000000000000080
[ 14.424428] x23: ffff0008425b0ec0 x22: ffff8000111fee40
[ 14.429722] x21: ffff8000111fe000 x20: ffff800010003c20
[ 14.435016] x19: ffff0008425b0ec0 x18: 0000000000000010
[ 14.440309] x17: 0000000000000000 x16: 0000000000000000
[ 14.445603] x15: ffff0008425b1400 x14: ffffffffffffffff
[ 14.450897] x13: ffff8000900036d7 x12: ffff8000100036df
[ 14.456192] x11: ffff80001112cf80 x10: ffff8000110dd600
[ 14.461486] x9 : ffff800011129d10 x8 : 6620353665376437
[ 14.466780] x7 : 3339203a65646f43 x6 : ffff80001117d73f
[ 14.472073] x5 : ffff00087fb53b30 x4 : ffff8000110ca6b8
[ 14.477367] x3 : ffff800010003c20 x2 : ffff0008425b0ec0
[ 14.482660] x1 : 0000000000010001 x0 : ffff8000111fee50
[ 14.487954] Call trace:
[ 14.490387] __rt_mutex_trylock+0x20/0xe0
[ 14.494382] _mutex_trylock+0x10/0x20
[ 14.498031] __crash_kexec+0x38/0x120
[ 14.501679] crash_kexec+0x58/0x98
[ 14.505066] die+0x1e0/0x268
[ 14.507935] die_kernel_fault+0x64/0x78
[ 14.511758] __do_kernel_fault+0x74/0x148
[ 14.515753] do_bad_area+0x5c/0x68
[ 14.519140] do_translation_fault+0x38/0x68
[ 14.523308] do_mem_abort+0x40/0xa0
[ 14.526782] el1_abort+0x48/0x70
[ 14.529996] el1_sync_handler+0xac/0xc8
[ 14.533816] el1_sync+0x88/0x140
[ 14.537030] cpuacct_account_field+0x4c/0x88
[ 14.541285] account_user_time+0x9c/0xe0
[ 14.545193] irqtime_account_process_tick+0x104/0x148
[ 14.550228] account_process_tick+0xb8/0xc8
[ 14.554397] update_process_times+0x54/0xa0
[ 14.558566] tick_sched_handle.isra.0+0x34/0x50
[ 14.563081] tick_sched_timer+0x4c/0xa8
[ 14.566902] __hrtimer_run_queues+0x128/0x210
[ 14.571244] hrtimer_interrupt+0xe8/0x248
[ 14.575239] arch_timer_handler_phys+0x34/0x48
[ 14.579667] handle_percpu_devid_irq+0x84/0x148
[ 14.584183] generic_handle_irq+0x30/0x48
[ 14.588177] __handle_domain_irq+0x64/0xc0
[ 14.592258] gic_handle_irq+0x58/0x128
[ 14.595992] el0_irq_naked+0x4c/0x54
[ 14.599553] ---[ end trace 0000000000000003 ]---
[ 14.604187] ---[ end trace 0000000000000004 ]---
[ 14.608816] Kernel panic - not syncing:
[ 14.612636] Oops: Fatal exception in interrupt
[ 14.612668] SMP: stopping secondary CPUs
[ 15.675000] SMP: failed to stop secondary CPUs 0-1
[ 15.679776] Kernel Offset: 0x80000 from 0xffff800010000000
[ 15.685242] PHYS_OFFSET: 0x80000000
[ 15.688715] CPU features: 0x0040022,20806008
[ 15.692969] Memory Limit: none
[ 15.696011] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
I switch to an SD Card file system, I will have the same problem.
NOTICE: BL31: v2.5(release):08.01.00.006-dirty NOTICE: BL31: Built : 19:52:11, Dec 20 2021 ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.65-rt53 (pierrehsieh@jetson-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT_RT Tue Feb 15 15:20:00 CST 2022 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! [ 0.000000] OF: reserved mem: OVERLAP DETECTED! [ 0.000000] vision-apps-c71-memory@aa100000 (0x00000000aa100000--0x00000000af000000) overlaps with r5f-virtual-eth-queues@ac000000 (0x00000000ac000000--0x00000000ac200000) [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB [ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB [ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool [ 0.000000] Carveout Heap: regions without no-map are not yet supported [ 0.000000] OF: reserved mem: node vision_apps_shared-memories compatible matching fail [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1024 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff] [ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff] [ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff] [ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000fbffffff] [ 0.000000] node 0: [mem 0x00000000fc000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008bfffffff] [ 0.000000] node 0: [mem 0x00000008c0000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] On node 0 totalpages: 1048576 [ 0.000000] DMA zone: 8192 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 524288 pages, LIFO batch:63 [ 0.000000] Normal zone: 8192 pages used for memmap [ 0.000000] Normal zone: 524288 pages, LIFO batch:63 [ 0.000000] cma: Reserved 24 MiB at 0x00000000fe800000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 18 pages/cpu s34752 r8192 d30784 u73728 [ 0.000000] pcpu-alloc: s34752 r8192 d30784 u73728 alloc=18*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait loglevel=0 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000d4000000-0x00000000d8000000] (64MB) [ 0.000000] Memory: 1969216K/4194304K available (10624K kernel code, 1156K rwdata, 4108K rodata, 1728K init, 438K bss, 2200512K reserved, 24576K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms. [ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads. [ 0.000000] No expedited grace period (rcu_normal_after_boot). [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008c0030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c0040000 [ 0.000000] random: get_random_bytes called from start_kernel+0x320/0x4c8 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008347] Console: colour dummy device 80x25 [ 0.012912] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023581] pid_max: default: 32768 minimum: 301 [ 0.028336] LSM: Security Framework initializing [ 0.033086] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.040661] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.049461] rcu: Hierarchical SRCU implementation. [ 0.054585] Platform MSI: msi-controller@1820000 domain created [ 0.060808] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070113] EFI services will not be available. [ 0.074836] smp: Bringing up secondary CPUs ... ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader [ 0.085781] Detected PIPT I-cache on CPU1 [ 0.089936] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.096966] GICv3: CPU1: using allocated LPI pending table @0x00000008c0050000 [ 0.104373] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.111094] smp: Brought up 1 node, 2 CPUs [ 0.115288] SMP: Total of 2 processors activated. [ 0.120096] CPU features: detected: 32-bit EL0 Support [ 0.125349] CPU features: detected: CRC32 instructions [ 0.138784] CPU: All CPU(s) started at EL2 [ 0.142977] alternatives: patching kernel code [ 0.148024] devtmpfs: initialized [ 0.157136] KASLR disabled due to lack of seed [ 0.161777] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.171741] futex hash table entries: 512 (order: 4, 65536 bytes, linear) [ 0.179215] pinctrl core: initialized pinctrl subsystem [ 0.184789] DMI not present or invalid. [ 0.188941] NET: Registered protocol family 16 [ 0.194153] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 0.201422] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.209413] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.217734] thermal_sys: Registered thermal governor 'step_wise' [ 0.217993] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.231093] ASID allocator initialised with 32768 entries [ 0.248270] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.255150] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.262007] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.268864] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.276256] cryptd: max_cpu_qlen set to 1000 [ 0.282185] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected [ 0.290985] vsys_3v3: supplied by evm_12v0 [ 0.295356] vsys_5v0: supplied by evm_12v0 [ 0.299721] vdd_mmc1: supplied by vsys_3v3 [ 0.304191] vdd_sd_dv_alt: supplied by vsys_3v3 [ 0.309304] iommu: Default domain type: Translated [ 0.314443] SCSI subsystem initialized [ 0.318554] mc: Linux media interface: v0.10 [ 0.322927] videodev: Linux video capture interface: v2.00 [ 0.328558] pps_core: LinuxPPS API ver. 1 registered [ 0.333627] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.342964] PTP clock support registered [ 0.346981] EDAC MC: Ver: 3.0.0 [ 0.350703] FPGA manager framework [ 0.354224] Advanced Linux Sound Architecture Driver Initialized. [ 0.360830] clocksource: Switched to clocksource arch_sys_counter [ 0.367159] VFS: Disk quotas dquot_6.6.0 [ 0.371190] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.381019] NET: Registered protocol family 2 [ 0.385729] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.394331] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.403246] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.411478] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear) [ 0.420918] TCP: Hash tables configured (established 32768 bind 32768) [ 0.427777] UDP hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 0.434997] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 0.442757] NET: Registered protocol family 1 [ 0.447540] RPC: Registered named UNIX socket transport module. [ 0.453603] RPC: Registered udp transport module. [ 0.458407] RPC: Registered tcp transport module. [ 0.463210] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.469794] PCI: CLS 0 bytes, default 64 [ 0.474154] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.484419] Initialise system trusted keyrings [ 0.489088] workingset: timestamp_bits=46 max_order=19 bucket_order=0 [ 0.497615] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.503943] NFS: Registering the id_resolver key type [ 0.509129] Key type id_resolver registered [ 0.513400] Key type id_legacy registered [ 0.517532] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.524388] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.532082] 9p: Installing v9fs 9p2000 file system support [ 0.557906] Key type asymmetric registered [ 0.562105] Asymmetric key parser 'x509' registered [ 0.567111] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.574680] io scheduler mq-deadline registered [ 0.579306] io scheduler kyber registered [ 0.584361] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.590548] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.598446] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.604745] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.612565] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.620501] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.628638] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq [ 0.635777] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq [ 0.644338] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.657315] brd: module loaded [ 0.664247] loop: module loaded [ 0.667861] megasas: 07.714.04.00-rc1 [ 0.672752] libphy: Fixed MDIO Bus: probed [ 0.677442] tun: Universal TUN/TAP device driver, 1.6 [ 0.682840] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.689259] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.695340] sky2: driver version 1.30 [ 0.699547] VFIO - User Level meta-driver version: 0.3 [ 0.705204] i2c /dev entries driver [ 0.709230] sdhci: Secure Digital Host Controller Interface driver [ 0.715555] sdhci: Copyright(c) Pierre Ossman [ 0.720195] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.726529] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.733681] optee: probing for conduit method. [ 0.738249] optee: revision 3.12 (3d47a131) [ 0.738480] optee: initialized driver [ 0.747389] NET: Registered protocol family 17 [ 0.752041] 9pnet: Installing 9P2000 support [ 0.756428] Key type dns_resolver registered [ 0.798794] printk: console [ttyS2]: printing thread started [ 0.798799] printk: console [ttyS2] enabled [ 0.798802] printk: bootconsole [ns16550a0] disabled [ 0.798812] printk: bootconsole [ns16550a0]: printing thread stopped [ 0.799214] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 26, base_baud = 3000000) is a 8250 [ 0.799565] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 27, base_baud = 3000000) is a 8250 [ 0.800242] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 0.800248] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 0.800251] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 0.800254] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 0.800648] scsi host0: ufshcd [ 0.840841] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 0.840851] libphy: 46000f00.mdio: probed [ 0.842054] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 0.842101] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 0.843118] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 0.844023] mmc0: CQHCI version 5.10 [ 0.844334] mmc1: CQHCI version 5.10 [ 0.849478] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 0.849764] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 0.850047] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 0.850327] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 0.850585] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 0.851162] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 0.852972] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16) [ 0.857000] spi-nor spi0.0: mt35xu02g (262144 Kbytes) [ 0.885010] mmc0: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 0.885012] mmc1: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 0.896854] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 0.896863] libphy: 46000f00.mdio: probed [ 0.898066] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 0.898117] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 0.899044] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 0.899483] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 0.899487] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 0.899818] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 0.900771] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present! [ 0.900796] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present! [ 0.902227] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 0.902253] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 0.902271] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 0.902302] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 0.908516] ALSA device list: [ 0.908521] No soundcards found. [ 0.924023] mmc0: new high speed SDHC card at address aaaa [ 0.924380] mmcblk0: mmc0:aaaa SL16G 14.8 GiB [ 0.926808] mmcblk0: p1 p2 [ 0.967721] mmc1: Command Queue Engine enabled [ 0.967729] mmc1: new HS200 MMC card at address 0001 [ 0.968031] mmcblk1: mmc1:0001 S0J57X 29.6 GiB [ 0.968146] mmcblk1boot0: mmc1:0001 S0J57X partition 1 31.5 MiB [ 0.968260] mmcblk1boot1: mmc1:0001 S0J57X partition 2 31.5 MiB [ 0.968351] mmcblk1rpmb: mmc1:0001 S0J57X partition 3 4.00 MiB, chardev (237:0) [ 0.969075] mmcblk1: p1 p2 [ 1.209174] cdns-ufshcd 4e84000.ufs: link startup failed 1 [ 1.209182] cdns-ufshcd 4e84000.ufs: UFS Host state=0 [ 1.209184] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0 [ 1.209187] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0 [ 1.209190] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0 [ 1.209192] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0 [ 1.209195] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0 [ 1.209197] cdns-ufshcd 4e84000.ufs: Clk gate=1 [ 1.209200] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0 [ 1.209202] cdns-ufshcd 4e84000.ufs: last intr at 1099231 us, last intr status=0x404 [ 1.209205] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0 [ 1.209208] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0 [ 1.209211] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0 [ 1.209213] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000 [ 1.209216] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000 [ 1.209218] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000 [ 1.209220] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0 [ 1.209240] host_regs: 00000000: 1587031f 00000000 00000210 00000000 [ 1.209243] host_regs: 00000010: 00000000 00000000 00000000 00000000 [ 1.209246] host_regs: 00000020: 00000000 00000470 00000000 00000000 [ 1.209248] host_regs: 00000030: 00000008 00000001 00000000 00000000 [ 1.209251] host_regs: 00000040: 00000000 00000000 00000000 00000000 [ 1.209253] host_regs: 00000050: 00000000 00000000 00000000 00000000 [ 1.209255] host_regs: 00000060: 00000000 00000000 00000000 00000000 [ 1.209257] host_regs: 00000070: 00000000 00000000 00000000 00000000 [ 1.209259] host_regs: 00000080: 00000000 00000000 00000000 00000000 [ 1.209262] host_regs: 00000090: 00000000 00000000 00000000 00000000 [ 1.209264] cdns-ufshcd 4e84000.ufs: No record of pa_err [ 1.209267] cdns-ufshcd 4e84000.ufs: No record of dl_err [ 1.209269] cdns-ufshcd 4e84000.ufs: No record of nl_err [ 1.209271] cdns-ufshcd 4e84000.ufs: No record of tl_err [ 1.209273] cdns-ufshcd 4e84000.ufs: No record of dme_err [ 1.209275] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err [ 1.209277] cdns-ufshcd 4e84000.ufs: No record of fatal_err [ 1.209279] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1100348 us [ 1.209282] cdns-ufshcd 4e84000.ufs: No record of resume_fail [ 1.209284] cdns-ufshcd 4e84000.ufs: No record of suspend_fail [ 1.209286] cdns-ufshcd 4e84000.ufs: No record of dev_reset [ 1.209288] cdns-ufshcd 4e84000.ufs: No record of host_reset [ 1.209290] cdns-ufshcd 4e84000.ufs: No record of task_abort [ 1.212182] List of all partitions: [ 1.212187] 0100 4096 ram0 [ 1.212189] (driver?) [ 1.212192] 0101 4096 ram1 [ 1.212194] (driver?) [ 1.212196] 0102 4096 ram2 [ 1.212198] (driver?) [ 1.212200] 0103 4096 ram3 [ 1.212202] (driver?) [ 1.212203] 0104 4096 ram4 [ 1.212205] (driver?) [ 1.212207] 0105 4096 ram5 [ 1.212209] (driver?) [ 1.212211] 0106 4096 ram6 [ 1.212213] (driver?) [ 1.212215] 0107 4096 ram7 [ 1.212217] (driver?) [ 1.212219] 0108 4096 ram8 [ 1.212220] (driver?) [ 1.212222] 0109 4096 ram9 [ 1.212223] (driver?) [ 1.212225] 010a 4096 ram10 [ 1.212227] (driver?) [ 1.212229] 010b 4096 ram11 [ 1.212231] (driver?) [ 1.212233] 010c 4096 ram12 [ 1.212234] (driver?) [ 1.212237] 010d 4096 ram13 [ 1.212238] (driver?) [ 1.212240] 010e 4096 ram14 [ 1.212242] (driver?) [ 1.212244] 010f 4096 ram15 [ 1.212245] (driver?) [ 1.212250] 1f00 262144 mtdblock0 [ 1.212251] (driver?) [ 1.212254] b300 15558144 mmcblk0 [ 1.212256] driver: mmcblk [ 1.212259] b301 131072 mmcblk0p1 18f0c324-01 [ 1.212261] [ 1.212263] b302 15426048 mmcblk0p2 18f0c324-02 [ 1.212265] [ 1.212267] b320 31080448 mmcblk1 [ 1.212269] driver: mmcblk [ 1.212271] b321 131072 mmcblk1p1 01ac63cf-01 [ 1.212273] [ 1.212275] b322 30948352 mmcblk1p2 01ac63cf-02 [ 1.212277] [ 1.212279] No filesystem could mount root, tried: [ 1.212280] ext4 [ 1.212281] [ 1.212282] Kernel panic - not syncing: [ 1.212283] VFS: Unable to mount root fs on unknown-block(179,34) [ 1.212286] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.65-rt53 #2 [ 1.212290] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 1.212293] Call trace: [ 1.212294] dump_backtrace+0x0/0x1a0 [ 1.212308] show_stack+0x18/0x68 [ 1.212312] dump_stack+0xd0/0x12c [ 1.212318] panic+0xcc/0x360 [ 1.212321] mount_block_root+0x238/0x254 [ 1.212327] mount_root+0x10c/0x140 [ 1.212330] prepare_namespace+0x130/0x170 [ 1.212333] kernel_init_freeable+0x25c/0x2a0 [ 1.212336] kernel_init+0x14/0x114 [ 1.212340] ret_from_fork+0x10/0x34 [ 2.212465] SMP: stopping secondary CPUs [ 3.046109] Kernel Offset: 0x80000 from 0xffff800010000000 [ 3.051576] PHYS_OFFSET: 0x80000000 [ 3.055050] CPU features: 0x0040022,20806008 [ 3.059305] Memory Limit: none [ 3.062348] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,34) ]---
