TDA4VM: TDA4VM
Part Number: TDA4VM
    For newest version of RTOS SDK for TDA4VM, I have followed the build instructions from file:///home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/tidl_j7_08_01_00_05/ti_dl/docs/user_guide_html/md_tidl_build_instruction.html but found the below build errors on tidl build. The previous version of SDK is OK. I think this maybe the fault of SDK because tvm branch is the same one should be as previous version of SDK using.
======== MAKING IMPORT LIBS =================
make -C ./ti_dl/utils/tidlModelImport -f makefile_shared
make[1]: Entering directory '/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/tidl_j7_08_01_00_05/ti_dl/utils/tidlModelImport'
make[1]: Leaving directory '/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/tidl_j7_08_01_00_05/ti_dl/utils/tidlModelImport'
make -C ./ti_dl/utils/tidlModelImport -f makefile_shared tvm_relay
compiling tidl_relayImport.cpp
tidl_relayImport.cpp: In function ‘int32_t TIDL_relayMapPadParams(tvm::relay::Call&, sTIDL_LayerPC_t&)’:
tidl_relayImport.cpp:1243:27: error: ‘const struct tvm::relay::PadAttrs’ has no member named ‘pad_value’
auto pad_value = attrs->pad_value;
make[1]: *** [/home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/tidl_j7_08_01_00_05/makerules/rules.mk:508: /home/janssen/ti/j721e/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/tidl_j7_08_01_00_05/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/tidl_relayImport.obj] Error 1
make: *** [makefile:285: it_lib] Error 2
