TDA4VM: RTOS 0801 Cant find the rpmsg_ctrl device
Part Number: TDA4VM
Other Parts Discussed in Thread: PCM3168A
Dear ti,
when i use the ti-processor-sdk-rtos-j721e-evm-08_01_00_13-prebuilt.tar.gz, printf the follwing error, i need help
 how should i debug? thanks
root@j7-evm:/opt/vision_apps# ./vx_app_single_cam.out
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
_rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio2.rpmsg_chrdev.-1.13
_rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio3.rpmsg_chrdev.-1.13
_rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio0.rpmsg_chrdev.-1.13
_rpmsg_char_find_rproc: 4d81800000.dsp does not have any virtio devices!
_rpmsg_char_find_rproc: 64800000.dsp is either not probed or not a remoteproc!
IPC: ERROR: Unable to create TX channels for CPU [mcu2_0] !!!
IPC: ERROR: Unable to create TX channels for CPU [mcu2_1] !!!
IPC: ERROR: Unable to create TX channels for CPU [c6x_1] !!!
IPC: ERROR: Unable to create TX channels for CPU [c6x_2] !!!
IPC: ERROR: Unable to create TX channels for CPU [c7x_1] !!!
IPC: Init ... Done !!!
APP: ERROR: IPC init failed !!!
REMOTE_SERVICE: Init ... !!!
_rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio3.rpmsg_chrdev.-1.21
_rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio0.rpmsg_chrdev.-1.21
REMOTE_SERVICE: Init ... Done !!!
303.038640 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
303.042249 s: VX_ZONE_INIT:Enabled
303.042258 s: VX_ZONE_ERROR:Enabled
303.042263 s: VX_ZONE_WARNING:Enabled
303.043867 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
303.045053 s: VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
Single Camera Demo - (c) Texas Instruments 2019
Usage,
./vx_app_single_cam.out --cfg <config file>
Defaulting to interactive mode
IttCtrl_registerHandler: command echo registered at location 0
IttCtrl_registerHandler: command iss_read_2a_params registered at location 1
IttCtrl_registerHandler: command iss_write_2a_params registered at location 2
IttCtrl_registerHandler: command iss_raw_save registered at location 3
IttCtrl_registerHandler: command iss_yuv_save registered at location 4
IttCtrl_registerHandler: command iss_read_sensor_reg registered at location 5
IttCtrl_registerHandler: command iss_write_sensor_reg registered at location 6
IttCtrl_registerHandler: command dev_ctrl registered at location 7
IttCtrl_registerHandler: command iss_send_dcc_file registered at location 8
NETWORK: Opened at IP Addr = 1.4.16.64, socket port=5000!!!
303.048224 s: VX_ZONE_ERROR:[ownContextCreateCmdObj:161] context object descriptor [0] allocation failed
303.048238 s: VX_ZONE_ERROR:[vxCreateContext:946] context objection creation failed
303.048246 s: VX_ZONE_ERROR:[vxGetStatus:713] Reference is NULL
Select camera port index 0-7 :
  • Hi Sun,
    Please check if the rpmsg devices are published from the firmware-side?
    ls -l /sys/bus/rpmsg/devices
    Also, ensure that you are indeed loading and booting the Vision Apps firmwares.
    regards
    Suman
  • U-Boot SPL 2021.01-dirty (Feb 24 2022 - 14:22:36 +0800)
    Model: Texas Instruments K3 J721E SoC
    EEPROM not available at 0x50, trying to read at 0x51
    Reading on-board EEPROM at 0x51 failed 1
    Board: J721EX-PM1-SOM rev E2
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    EEPROM not available at 0x50, trying to read at 0x51 VT102 | 脱机 | ttyUSB0
    Trying to boot from MMC1
    init_env from device 17 not supported!
    Starting ATF on ARM64 core...
    NOTICE: BL31: v2.5(release):08.01.00.006-dirty
    NOTICE: BL31: Built : 16:34:52, Dec 20 2021
    U-Boot SPL 2021.01-00001-g7bb68d48c7-dirty (Feb 24 2022 - 18:31:13 +0800)
    U-Boot 2021.01-00001-g7bb68d48c7-dirty (Feb 24 2022 - 18:31:13 +0800)
    SoC: J721E SR2.0
    DRAM: 4 GiB
    Flash: 0 Bytes
    MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
    Loading Environment from MMC... OK
    In: serial@2800000
    Out: serial@2800000
    Err: serial@2800000
    Net: Could not get PHY for ethernet@46000000: addr 0
    am65_cpsw_nuss_slave ethernet@46000000: phy_connect() failed
    No ethernet found.
    Hit any key to stop autoboot: 0
    switch to partitions #0, OK
    mmc0(part 0) is current device
    SD/MMC found on device 0
    Failed to load 'boot.scr'
    54 bytes read in 7 ms (6.8 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc0 ...
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    626036 bytes read in 11 ms (54.3 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 626036 bytes: Success!
    97676 bytes read in 9 ms (10.3 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 97676 bytes: Success!
    Load Remote Processor 4 with data@addr=0x82000000 97676 bytes: Success!
    Load Remote Processor 5 with data@addr=0x82000000 97676 bytes: Success!
    144332 bytes read in 9 ms (15.3 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 144332 bytes: Success!
    144332 bytes read in 10 ms (13.8 MiB/s)
    Load Remote Processor 7 with data@addr=0x82000000 144332 bytes: Success!
    10489000 bytes read in 65 ms (153.9 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 10489000 bytes: Success!
    19270144 bytes read in 111 ms (165.6 MiB/s)
    100093 bytes read in 8 ms (11.9 MiB/s)
    11211 bytes read in 8 ms (1.3 MiB/s)
    ERROR: reserving fdt memory region failed (addr=fe000000 size=1000000)
    ERROR: reserving fdt memory region failed (addr=fc000000 size=2000000)
    ERROR: reserving fdt memory region failed (addr=ac000000 size=200000)
    ERROR: reserving fdt memory region failed (addr=ac200000 size=1e00000)
    Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
    Starting kernel ...
    [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [ 0.000000] Linux version 5.10.65-gdcc6bedb2c (ruijie.sun@BionicPlatDev) (aarch64-none-linux-gnu-gcc (GNU Toolcha
    in for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Ar
    chitecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Thu Feb 24 13:59:13 CST 2022
    [ 0.000000] Machine model: Texas Instruments K3 J721E SoC
    [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [ 0.000000] printk: bootconsole [ns16550a0] enabled
    [ 0.000000] efi: UEFI not found.
    [ 0.000000] OF: reserved mem: OVERLAP DETECTED!
    [ 0.000000] vision-apps-c71-memory@aa100000 (0x00000000aa100000--0x00000000af000000) overlaps with r5f-virtual-et
    h-queues@ac000000 (0x00000000ac000000--0x00000000ac200000)
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
    [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma
    -pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fc000000, size 32 MiB
    [ 0.000000] OF: reserved mem: initialized node intercore-eth-r5f-memory@fc000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fe000000, size 16 MiB
    [ 0.000000] OF: reserved mem: initialized node eeprom-shadow-r5f-memory@fe000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dm
    a-pool
    [ 0.000000] Zone ranges:
    [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
    [ 0.000000] DMA32 empty
    [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
    [ 0.000000] Movable zone start for each node
    [ 0.000000] Early memory node ranges
    [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
    [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff]
    [ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff]
    [ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff]
    [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000feffffff]
    [ 0.000000] node 0: [mem 0x00000000ff000000-0x00000000ffffffff]
    [ 0.000000] node 0: [mem 0x0000000880000000-0x000000088fffffff]
    [ 0.000000] node 0: [mem 0x0000000890000000-0x00000008ffffffff]
    [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [ 0.000000] cma: Failed to reserve 512 MiB
    [ 0.000000] psci: probing for conduit method from DT.
    [ 0.000000] psci: PSCIv1.1 detected in firmware.
    [ 0.000000] psci: Using standard PSCI v0.2 function IDs
    [ 0.000000] psci: Trusted OS migration not required
    [ 0.000000] psci: SMC Calling Convention v1.2
    [ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
    [ 0.000000] Detected PIPT I-cache on CPU0
    [ 0.000000] CPU features: detected: GIC system register CPU interface
    [ 0.000000] CPU features: detected: EL2 vector hardening
    [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472
    [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi
    .0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(o
    spi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env)
    ,1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=be91c085-02 rw rootfstype=ext4 rootwait
    [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [ 0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
    [ 0.000000] Memory: 2270080K/4194304K available (10880K kernel code, 1346K rwdata, 4288K rodata, 1856K init, 757K
    bss, 1924224K reserved, 0K cma-reserved)
    [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
    [ 0.000000] rcu: RCU event tracing is enabled.
    [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [ 0.000000] Trampoline variant of Tasks RCU enabled.
    [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [ 0.000000] GICv3: 960 SPIs implemented
    [ 0.000000] GICv3: 0 Extended SPIs implemented
    [ 0.000000] GICv3: Distributor has no Range Selector support
    [ 0.000000] GICv3: 16 PPIs implemented
    [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [ 0.000000] ITS [mem 0x01820000-0x0182ffff]
    [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0)
    [ 0.000000] ITS: using cache flushing for cmd queue
    [ 0.000000] GICv3: using LPI property table @0x00000008a00b0000
    [ 0.000000] GIC: using cache flushing for LPI property table
    [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a00c0000
    [ 0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
    [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 44079521
    0634 ns
    [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [ 0.008365] Console: colour dummy device 80x25
    [ 0.012926] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=80000
    0)
    [ 0.023596] pid_max: default: 32768 minimum: 301
    [ 0.028345] LSM: Security Framework initializing
    [ 0.033088] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [ 0.040654] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [ 0.049601] rcu: Hierarchical SRCU implementation.
    [ 0.054650] Platform MSI: msi-controller@1820000 domain created
    [ 0.060893] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [ 0.070192] EFI services will not be available.
    [ 0.074939] smp: Bringing up secondary CPUs ...
    [ 0.080193] Detected PIPT I-cache on CPU1
    [ 0.080218] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [ 0.080229] GICv3: CPU1: using allocated LPI pending table @0x00000008a00d0000
    [ 0.080260] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [ 0.080311] smp: Brought up 1 node, 2 CPUs
    [ 0.109658] SMP: Total of 2 processors activated.
    [ 0.114463] CPU features: detected: 32-bit EL0 Support
    [ 0.119716] CPU features: detected: CRC32 instructions
    [ 0.133578] CPU: All CPU(s) started at EL2
    [ 0.137776] alternatives: patching kernel code
    [ 0.142771] devtmpfs: initialized
    [ 0.151252] KASLR disabled due to lack of seed
    [ 0.155906] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [ 0.165869] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [ 0.173023] pinctrl core: initialized pinctrl subsystem
    [ 0.178576] DMI not present or invalid.
    [ 0.182780] NET: Registered protocol family 16
    [ 0.187537] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [ 0.194860] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [ 0.202822] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [ 0.211096] thermal_sys: Registered thermal governor 'step_wise'
    [ 0.211098] thermal_sys: Registered thermal governor 'power_allocator'
    [ 0.217489] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [ 0.231117] ASID allocator initialised with 65536 entries
    [ 0.252365] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [ 0.259220] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [ 0.265977] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [ 0.273580] cryptd: max_cpu_qlen set to 1000
    [ 0.279492] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [ 0.288286] vsys_3v3: supplied by evm_12v0
    [ 0.292664] vsys_5v0: supplied by evm_12v0
    [ 0.297339] iommu: Default domain type: Translated
    [ 0.302518] SCSI subsystem initialized
    [ 0.306614] mc: Linux media interface: v0.10
    [ 0.310988] videodev: Linux video capture interface: v2.00
    [ 0.316616] pps_core: LinuxPPS API ver. 1 registered
    [ 0.321686] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.331023] PTP clock support registered
    [ 0.335042] EDAC MC: Ver: 3.0.0
    [ 0.338774] FPGA manager framework
    [ 0.342286] Advanced Linux Sound Architecture Driver Initialized.
    [ 0.348901] clocksource: Switched to clocksource arch_sys_counter
    [ 0.355306] VFS: Disk quotas dquot_6.6.0
    [ 0.359349] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [ 0.369001] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [ 0.375294] NET: Registered protocol family 2
    [ 0.379866] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [ 0.388455] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [ 0.397222] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [ 0.405419] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [ 0.413214] TCP: Hash tables configured (established 32768 bind 32768)
    [ 0.419953] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [ 0.426842] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [ 0.434235] NET: Registered protocol family 1
    [ 0.438933] RPC: Registered named UNIX socket transport module.
    [ 0.444988] RPC: Registered udp transport module.
    [ 0.449801] RPC: Registered tcp transport module.
    [ 0.454605] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.461189] PCI: CLS 0 bytes, default 64
    [ 0.465536] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [ 0.475722] Initialise system trusted keyrings
    [ 0.480336] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [ 0.488616] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.494806] NFS: Registering the id_resolver key type
    [ 0.500022] Key type id_resolver registered
    [ 0.504294] Key type id_legacy registered
    [ 0.508413] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [ 0.515262] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [ 0.522901] 9p: Installing v9fs 9p2000 file system support
    [ 0.548781] Key type asymmetric registered
    [ 0.552967] Asymmetric key parser 'x509' registered
    [ 0.557963] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [ 0.565522] io scheduler mq-deadline registered
    [ 0.570147] io scheduler kyber registered
    [ 0.575387] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [ 0.581550] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [ 0.589980] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [ 0.596242] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [ 0.603994] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [ 0.612030] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [ 0.621013] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [ 0.629840] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [ 0.637525] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [ 0.650262] brd: module loaded
    [ 0.656096] loop: module loaded
    [ 0.659653] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
    [ 0.667575] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.65-gdcc6bedb2c #1
    [ 0.674775] Hardware name: Texas Instruments K3 J721E SoC (DT)
    [ 0.680730] Call trace:
    [ 0.683234] dump_backtrace+0x0/0x1a0
    [ 0.686969] show_stack+0x18/0x68
    [ 0.690352] dump_stack+0xd0/0x12c
    [ 0.693822] sysfs_warn_dup+0x60/0x80
    [ 0.697556] sysfs_create_dir_ns+0xe0/0xf8
    [ 0.701737] kobject_add_internal+0x98/0x288
    [ 0.706093] kobject_add+0x94/0x100
    [ 0.709654] device_add+0xe0/0x740
    [ 0.713124] platform_device_add+0x100/0x238
    [ 0.717482] platform_device_register_full+0xcc/0x150
    [ 0.722640] dma_buf_phys_init+0x6c/0x9c
    [ 0.726641] do_one_initcall+0x54/0x1b8
    [ 0.730554] kernel_init_freeable+0x220/0x2a0
    [ 0.735000] kernel_init+0x14/0x114
    [ 0.738557] ret_from_fork+0x10/0x34
    [ 0.742213] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same
    name in the same directory.
    [ 0.755380] megasas: 07.714.04.00-rc1
    [ 0.760391] libphy: Fixed MDIO Bus: probed
    [ 0.765019] tun: Universal TUN/TAP device driver, 1.6
    [ 0.770426] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [ 0.776831] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [ 0.782902] sky2: driver version 1.30
    [ 0.787162] VFIO - User Level meta-driver version: 0.3
    [ 0.792811] i2c /dev entries driver
    [ 0.796984] sdhci: Secure Digital Host Controller Interface driver
    [ 0.803299] sdhci: Copyright(c) Pierre Ossman
    [ 0.807984] sdhci-pltfm: SDHCI platform and OF driver helper
    [ 0.814301] ledtrig-cpu: registered to indicate activity on CPUs
    [ 0.820594] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [ 0.827703] optee: probing for conduit method.
    [ 0.832263] optee: revision 3.12 (3d47a131)
    [ 0.832517] optee: initialized driver
    [ 0.841781] NET: Registered protocol family 17
    [ 0.846391] 9pnet: Installing 9P2000 support
    [ 0.850777] Key type dns_resolver registered
    [ 0.855219] Loading compiled-in X.509 certificates
    [ 0.864107] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [ 0.870445] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [ 0.878432] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    [ 0.908145] random: fast init done
    [ 0.937756] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [ 0.945330] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [ 0.951396] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [ 0.957467] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [ 0.963830] pca953x 3-0020: supply vcc not found, using dummy regulator
    [ 0.970648] pca953x 3-0020: using no AI
    [ 0.996945] pca953x 3-0020: failed writing register
    [ 1.001981] pca953x: probe of 3-0020 failed with error -121
    [ 1.008011] pca953x 3-0022: supply vcc not found, using dummy regulator
    [ 1.014806] pca953x 3-0022: using AI
    [ 1.018507] pca953x 3-0022: failed writing register
    [ 1.023528] pca953x: probe of 3-0022 failed with error -121
    [ 1.029262] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [ 1.038807] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
    [ 1.045085] pca953x 5-0020: supply vcc not found, using dummy regulator
    [ 1.051889] pca953x 5-0020: using no AI
    [ 1.076946] pca953x 5-0020: failed writing register
    [ 1.081974] pca953x: probe of 5-0020 failed with error -121
    [ 1.088033] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
    [ 1.094091] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
    [ 1.100045] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
    [ 1.106428] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [ 1.116406] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [ 1.125213] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [ 1.135057] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [ 1.153194] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 1.160864] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 1.169140] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 1.177415] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 1.186213] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 1.193892] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 1.202169] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 1.210445] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 1.219228] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 1.226902] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 1.235177] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 1.243452] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 1.252593] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [ 1.262473] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [ 1.269232] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [ 1.278244] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [ 1.288408] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [ 1.295168] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [ 1.303118] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [ 1.312494] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [ 1.321240] printk: console [ttyS2] enabled
    [ 1.329678] printk: bootconsole [ns16550a0] disabled
    [ 1.340117] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [ 1.349070] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [ 1.358644] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enab
    led
    [ 1.369154] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [ 1.379309] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [ 1.389550] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enable
    d
    [ 1.400363] scsi host0: ufshcd
    [ 1.444919] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [ 1.452567] libphy: 46000f00.mdio: probed
    [ 1.456781] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
    [ 1.463504] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA8
    0100 Ports: 2 quirks:00000000
    [ 1.477266] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [ 1.486108] mmc0: CQHCI version 5.10
    [ 1.486367] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [ 1.502144] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [ 1.509013] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [ 1.515852] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [ 1.522674] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [ 1.527521] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [ 1.529481] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [ 1.546237] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 1.553807] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 1.561940] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 1.570073] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 1.578796] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 1.586342] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 1.594475] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 1.602606] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 1.611224] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 1.618730] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 1.626811] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 1.634898] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 1.643991] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [ 1.654534] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [ 1.668347] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
    [ 1.673589] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [ 1.680195] Creating 8 MTD partitions on "47040000.spi.0":
    [ 1.685673] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [ 1.691676] 0x000000080000-0x000000280000 : "ospi.tispl"
    [ 1.697372] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [ 1.703110] 0x000000680000-0x0000006c0000 : "ospi.env"
    [ 1.708660] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [ 1.714346] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [ 1.720510] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [ 1.726293] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [ 1.733424] mmc0: Command Queue Engine enabled
    [ 1.735090] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [ 1.737871] mmc0: new DDR MMC card at address 0001
    [ 1.748016] mmcblk0: mmc0:0001 064G32 58.2 GiB
    [ 1.752669] mmcblk0boot0: mmc0:0001 064G32 partition 1 8.00 MiB
    [ 1.758677] mmcblk0boot1: mmc0:0001 064G32 partition 2 8.00 MiB
    [ 1.764664] mmcblk0rpmb: mmc0:0001 064G32 partition 3 4.00 MiB, chardev (237:0)
    [ 1.773947] mmcblk0: p1 p2 p3 p4
    [ 1.784918] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [ 1.792567] libphy: 46000f00.mdio: probed
    [ 1.796786] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
    [ 1.803551] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA8
    [ 1.817185] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [ 1.824223] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [ 1.831434] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [ 1.837781] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [ 1.838465] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [ 1.848039] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [ 1.852341] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [ 1.863201] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [ 1.869466] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [ 1.869953] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 1.875893] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [ 1.875895] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [ 1.875898] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [ 1.875901] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [ 1.883384] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 1.890219] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [ 1.890221] cdns-ufshcd 4e84000.ufs: last intr at 1736445 us, last intr status=0x404
    [ 1.890223] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [ 1.890226] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [ 1.896832] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 1.903160] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [ 1.907684] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 1.915742] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [ 1.915744] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [ 1.924247] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 1.931635] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [ 1.939117] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 1.948122] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, I
    NVALID MODE], rate = 0
    [ 1.948142] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [ 1.956218] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 1.962186] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [ 1.962189] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [ 1.970440] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 1.976678] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [ 1.983067] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 1.990214] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [ 1.990217] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [ 1.990219] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [ 1.990222] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [ 1.990225] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [ 1.996319] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 2.004374] host_regs: 00000090: 00000000 00000000 00000000 00000000
    [ 2.016524] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 2.022848] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [ 2.022850] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [ 2.030928] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 2.037256] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [ 2.037258] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [ 2.045360] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 2.051837] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [ 2.051840] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [ 2.058191] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 2.065651] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [ 2.071993] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 2.078320] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1737567 us
    [ 2.084656] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 2.090993] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [ 2.097627] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 2.105394] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [ 2.105396] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [ 2.105398] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [ 2.105406] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [ 2.111765] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 2.249222] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 2.257300] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 2.265852] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 2.273362] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 2.281454] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 2.289544] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 2.298182] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [ 2.305507] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [ 2.313768] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [ 2.321089] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [ 2.328394] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [ 2.335697] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [ 2.343740] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [ 2.351171] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 2.358671] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 2.366757] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 2.374843] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 2.383516] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 2.391013] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 2.399103] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 2.407188] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 2.415773] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 2.423265] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 2.431349] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 2.439434] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 2.458993] ALSA device list:
    [ 2.461961] No soundcards found.
    [ 2.564292] EXT4-fs (mmcblk0p2): recovery complete
    [ 2.570043] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [ 2.578150] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [ 2.585012] devtmpfs: mounted
    [ 2.588264] Freeing unused kernel memory: 1856K
    [ 2.592817] Run /sbin/init as init process
    [ 2.684147] systemd[1]: System time before build time, advancing clock.
    [ 2.720043] NET: Registered protocol family 10
    [ 2.724937] Segment Routing with IPv6
    [ 2.737722] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVI
    NIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hie
    rarchy=hybrid)
    [ 2.759481] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [ 2.793845] systemd[1]: Set hostname to <j7-evm>.
    [ 2.934310] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directo
    ry /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [ 2.991298] random: systemd: uninitialized urandom read (16 bytes read)
    [ 2.998031] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support
    BPF/cgroup firewalling.
    [ 3.010357] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [ 3.020207] systemd[1]: Created slice system-getty.slice.
    [ OK ] Created slice system-getty.slice.
    [ 3.040977] random: systemd: uninitialized urandom read (16 bytes read)
    [ 3.048205] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [ OK ] Created slice system-serial\x2dgetty.slice.
    [ 3.068971] random: systemd: uninitialized urandom read (16 bytes read)
    [ 3.076110] systemd[1]: Created slice User and Session Slice.
    [ OK ] Created slice User and Session Slice.
    [ 3.097080] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [ OK ] Started Dispatch Password …ts to Console Directory Watch.
    [ 3.121007] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [ OK ] Started Forward Password R…uests to Wall Directory Watch.
    [ 3.144993] systemd[1]: Reached target Paths.
    [ OK ] Reached target Paths.
    [ 3.164955] systemd[1]: Reached target Remote File Systems.
    [ OK ] Reached target Remote File Systems.
    [ 3.184946] systemd[1]: Reached target Slices.
    [ OK ] Reached target Slices.
    [ 3.204955] systemd[1]: Reached target Swap.
    [ OK ] Reached target Swap.
    [ 3.229919] systemd[1]: Listening on RPCbind Server Activation Socket.
    [ OK ] Listening on RPCbind Server Activation Socket.
    [ 3.252975] systemd[1]: Reached target RPC Port Mapper.
    [ OK ] Reached target RPC Port Mapper.
    [ 3.275388] systemd[1]: Listening on Process Core Dump Socket.
    [ OK ] Listening on Process Core Dump Socket.
    [ 3.297079] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [ OK ] Listening on initctl Compatibility Named Pipe.
    [ 3.327147] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [ 3.335455] systemd[1]: Listening on Journal Socket (/dev/log).
    [ OK ] Listening on Journal Socket (/dev/log).
    [ 3.357157] systemd[1]: Listening on Journal Socket.
    [ OK ] Listening on Journal Socket.
    [ 3.377213] systemd[1]: Listening on Network Service Netlink Socket.
    [ OK ] Listening on Network Service Netlink Socket.
    [ 3.401126] systemd[1]: Listening on udev Control Socket.
    [ OK ] Listening on udev Control Socket.
    [ 3.421063] systemd[1]: Listening on udev Kernel Socket.
    [ OK ] Listening on udev Kernel Socket.
    [ 3.443757] systemd[1]: Mounting Huge Pages File System...
    [ 3.467832] systemd[1]: Mounting POSIX Message Queue File System...
    [ 3.491551] systemd[1]: Mounting Kernel Debug File System...
    [ 3.516067] systemd[1]: Mounting Temporary Directory (/tmp)...
    [ 3.539825] systemd[1]: Starting Create list of static device nodes for the current kernel...
    Starting Create list of st…odes for the current kernel...
    [ 3.567198] systemd[1]: Starting Start psplash boot splash screen...
    [ 3.597168] systemd[1]: Starting RPC Bind...
    [ 3.613052] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [ 3.624779] systemd[1]: Starting Journal Service...
    [ 3.647300] systemd[1]: Starting Load Kernel Modules...
    [ 3.662266] cryptodev: loading out-of-tree module taints kernel.
    [ 3.670656] systemd[1]: Starting Remount Root and Kernel File Systems...
    Starting Remount Root and Kernel File Systems 3.679973] cryptodev: driver 1.10 loaded.
    [0m...
    [ 3.693960] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [ 3.703894] systemd[1]: Starting udev Coldplug all Devices...
    [ 3.727486] systemd[1]: Started RPC Bind.
    [ OK ] Started RPC Bind.
    [ 3.745306] systemd[1]: Started Journal Service.
    [ OK ] Started Journal Service.
    [ OK ] Mounted Huge Pages File System.
    [ OK ] Mounted POSIX Message Queue File System.
    [ OK ] Mounted Kernel Debug File System.
    [ OK ] Mounted Temporary Directory (/tmp).
    [ OK ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [ OK ] Started Load Kernel Modules.
    [ OK ] Started Remount Root and Kernel File Systems.
    Mounting Kernel Configuration File System...
    Starting Flush Journal to Persistent Storage...
    Starting Apply Kernel Variables...[ 3.960713] systemd-journald[162]: Received client request to flush ru
    ntime journal.
    Starting Create Static Device Nodes in /dev...
    [ OK ] Mounted Kernel Configuration File System.
    [ OK ] Started Flush Journal to Persistent Storage.
    [ OK ] Started Apply Kernel Variables.
    [ OK ] Started Create Static Device Nodes in /dev.
    [ OK ] Reached target Local File Systems (Pre).
    Mounting /media/ram...
    Mounting /var/volatile...
    Starting udev Kernel Device Manager...
    [ OK ] Started udev Coldplug all Devices.
    [ OK ] Mounted /media/ram.
    [ OK ] Mounted /var/volatile.
    Starting udev Wait for Complete Device Initialization...
    Starting Load/Save Random Seed...
    [ OK ] Reached target Local File Systems.
    Starting Create Volatile Files and Directories...
    [ OK ] Started udev Kernel Device Manager.
    [ OK ] Started Create Volatile Files and Directories.
    Starting Network Time Synchronization...
    Starting Update UTMP about System Boot/Shutdown...
    [ OK ] Started Update UTMP about System Boot/Shutdown.
    [ OK ] Started Network Time Synchronization.
    [ OK ] Reached target System Time Set.
    [ 4.371674] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 4.381179] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 4.390077] CAN device driver interface
    [ OK ] Reached target System Time Synchron[ 4.393969] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017fff
    fff -> 0x0010011000
    ized.
    [ 4.412985] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 4.425149] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 4.436948] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 4.445083] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 4.456964] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 4.465822] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 4.473362] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 4.484954] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 4.493083] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 4.509020] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 4.516547] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 4.524701] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 4.536945] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 4.594358] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 4.601967] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 4.617680] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 4.628546] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 4.641228] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 4.648776] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 4.658720] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 4.668014] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 4.677487] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [ 4.678674] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 4.695748] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 4.703908] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 4.712968] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [ 4.719958] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 4.729200] ina2xx 4-0040: error configuring the device: -121
    [ 4.730491] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 4.743174] ina2xx 4-0041: error configuring the device: -121
    [ 4.744954] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 4.757003] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 4.757071] remoteproc remoteproc0: 4d80800000.dsp is available
    [ 4.765087] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 4.779288] ina2xx 4-0042: error configuring the device: -121
    [ 4.779321] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [ 4.785423] ina2xx 4-0043: error configuring the device: -121
    [ 4.799073] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [ 4.805051] remoteproc remoteproc0: unsupported resource 65538
    [ 4.809250] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [ 4.811106] ina2xx 4-0044: error configuring the device: -121
    [ 4.823899] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [ 4.830734] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [ 4.830838] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 4.840305] ina2xx 4-0045: error configuring the device: -121
    [ 4.854221] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [ 4.861400] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 4.861835] virtio_rpmsg_bus virtio0: rpmsg host is online
    [ 4.869511] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 4.875179] ina2xx 4-0046: error configuring the device: -121
    [ 4.888879] remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [ 4.892931] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 4.903281] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [ 4.911092] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 4.911412] ina2xx 4-0047: error configuring the device: -121
    [ 4.924948] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 4.925070] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [ 4.933059] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 4.948926] ina2xx 4-0048: error configuring the device: -121
    [ 4.952086] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 4.961095] ina2xx 4-0049: error configuring the device: -121
    [ 4.970704] ina2xx 4-004a: error configuring the device: -121
    [ 4.977037] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [ 4.984052] ina2xx 4-004b: error configuring the device: -121
    [ 4.990694] remoteproc remoteproc1: 4d81800000.dsp is available
    [ 4.996746] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 4.997505] ina2xx 4-004c: error configuring the device: -121
    [ 5.004257] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 5.010558] remoteproc remoteproc1: attaching to 4d81800000.dsp
    [ 5.018052] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 5.018063] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 5.024104] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 5.033267] Unable to handle kernel paging request at virtual address ffff7fffd8d28e3b
    [ 5.040357] ina2xx 4-004d: error configuring the device: -121
    [ 5.048098] Mem abort info:
    [ 5.055725] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 5.061784] ESR = 0x96000005
    [ 5.064233] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 5.072584] EC = 0x25: DABT (current EL), IL = 32 bits
    [ 5.075356] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 5.083698] SET = 0, FnV = 0
    [ 5.100180] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 5.100735] EA = 0, S1PTW = 0
    [ 5.110890] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 5.111834] Data abort info:
    [ 5.118995] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 5.122157] ISV = 0, ISS = 0x00000005
    [ 5.129939] ina2xx 4-004e: error configuring the device: -121
    [ 5.134056] CM = 0, WnR = 0
    [ 5.139514] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 5.142756] swapper pgtable: 64k pages, 48-bit VAs, pgdp=0000000082f30000
    [ 5.157729] [ffff7fffd8d28e3b] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000
    [ 5.164932] ina2xx 4-004f: error configuring the device: -121
    [ 5.166856] Internal error: Oops: 96000005 [#1] PREEMPT SMP
    [ 5.177696] Modules linked in: vxd_dec vxe_enc ti_k3_dsp_remoteproc(+) videobuf2_dma_contig videobuf2_dma_sg ina2
    xx v4l2_mem2mem videobuf2_memops virtio_rpmsg_bus videobuf2_v4l2 cdns_dphy videobuf2_common snd_soc_pcm3168a_i2c snd
    _soc_pcm3168a cdns3_ti m_can_platform m_can can_dev rti_wdt sch_fq_codel rpmsg_kdrv_switch cryptodev(O) ipv6
    [ 5.207393] CPU: 0 PID: 198 Comm: systemd-udevd Tainted: G O 5.10.65-gdcc6bedb2c #1
    [ 5.216329] Hardware name: Texas Instruments K3 J721E SoC (DT)
    [ 5.222147] pstate: 00000005 (nzcv daif -PAN -UAO -TCO BTYPE=--)
    [ 5.228147] pc : rproc_handle_resources.constprop.0+0x94/0x168
    [ 5.233966] lr : rproc_boot+0x334/0x670
    [ 5.237788] sp : ffff8000131af7d0
    [ 5.241088] x29: ffff8000131af7d0 x28: ffff8000113069e8
    [ 5.246384] x27: ffff00087ff29a08 x26: ffffffffbfd28e3b
    [ 5.251680] x25: ffff800019000000 x24: ffff800010e1c6f8
    [ 5.256977] x23: ffff000825239838 x22: 0000000000000000
    [ 5.262273] x21: ffff80001123c690 x20: ffff000825239800
    [ 5.267568] x19: 0000000000000000 x18: 0000000000000000
    [ 5.272863] x17: 0000000000000000 x16: 0000000000000000
    [ 5.278159] x15: 0000a6c813df5086 x14: 3f7fee71ac4d5e12
    [ 5.283455] x13: 2176bfca81e9ac20 x12: c5a5b2a1fcafb631
    [ 5.288751] x11: fb6dbe58dbbf2d21 x10: e7d8bd5a0f4cf58c
    [ 5.294046] x9 : f9bd6fd600a9b7fb x8 : 49d80ef579cdee48
    [ 5.299343] x7 : cb5e4fd7ebca0b01 x6 : ffff000824626600
    [ 5.304639] x5 : 0000000000000000 x4 : 0000000000000000
    [ 5.309937] x3 : 00000000402d72c1 x2 : 00000000bfd28e3b
    [ 5.315237] x1 : ffff7fffd8d28e3f x0 : ffff800019000000
    [ 5.320536] Call trace:
    [ 5.322981] rproc_handle_resources.constprop.0+0x94/0x168
    [ 5.328453] rproc_boot+0x334/0x670
    [ 5.331928] rproc_add+0x88/0x158
    [ 5.335237] k3_dsp_rproc_probe+0x710/0x850 [ti_k3_dsp_remoteproc]
    [ 5.341401] platform_drv_probe+0x54/0xa8
    [ 5.345396] really_probe+0xec/0x3e0
    [ 5.348958] driver_probe_device+0x58/0xb8
    [ 5.353040] device_driver_attach+0x74/0x80
    [ 5.357208] __driver_attach+0x58/0xe0
    [ 5.360945] bus_for_each_dev+0x70/0xc0
    [ 5.364766] driver_attach+0x24/0x30
    [ 5.368327] bus_add_driver+0x14c/0x1f0
    [ 5.372152] driver_register+0x64/0x120
    [ 5.375976] __platform_driver_register+0x48/0x58
    [ 5.380669] k3_dsp_rproc_driver_init+0x20/0x10000 [ti_k3_dsp_remoteproc]
    [ 5.387442] do_one_initcall+0x54/0x1b8
    [ 5.391265] do_init_module+0x54/0x208
    [ 5.395000] load_module+0x1f28/0x24c8
    [ 5.398735] __do_sys_finit_module+0xb8/0xf8
    [ 5.402990] __arm64_sys_finit_module+0x20/0x30
    [ 5.407507] el0_svc_common.constprop.0+0x78/0x1c8
    [ 5.412285] do_el0_svc+0x24/0x90
    [ 5.415587] el0_svc+0x14/0x20
    [ 5.418627] el0_sync_handler+0xb0/0xb8
    [ 5.422448] el0_sync+0x180/0x1c0
    [ 5.425755] Code: 128002b3 911b0021 97ffeb98 1400002e (b87a6b20)
    [ 5.431833] ---[ end trace eeca3adcc9a10ad3 ]---
    [ 5.469345] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 5.480952] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 5.492206] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 5.500319] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 5.513591] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 5.524958] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 5.533089] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 5.541205] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 5.552398] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 5.564497] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 5.572615] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 5.580720] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 5.598041] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 5.608287] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 5.610914] PVR_K: 181: Read BVNC 22.104.208.318 from HW device registers
    [ 5.620189] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 5.623247] PVR_K: 181: RGX Device registered with BVNC 22.104.208.318
    [ 5.638342] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
    [ 5.641432] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 5.668964] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 5.681762] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 5.697608] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 5.713564] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 5.731752] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 5.746712] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 5.762931] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 5.781256] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 5.800281] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 5.816927] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 5.831881] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 5.848957] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 5.863089] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 5.876957] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 5.889597] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 5.902563] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 6.074987] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) !=
    actual state (1)
    [ 6.197801] platform 41000000.r5f: configured R5F for IPC-only mode
    [ 6.229088] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [ 6.332527] remoteproc remoteproc2: 41000000.r5f is available
    [ 6.397037] remoteproc remoteproc2: attaching to 41000000.r5f
    [ 6.429465] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [ 6.457980] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [ 6.491796] virtio_rpmsg_bus virtio1: rpmsg host is online
    [ 6.505387] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 6.514332] remoteproc2#vdev0buffer: registered virtio1 (type 7)
    [ 6.520562] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 6.528778] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 6.536960] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 6.545724] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [ 6.553809] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [ 6.563486] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 6.572109] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 6.580309] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 6.588470] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 6.591470] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
    [ 6.598283] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 6.612491] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 6.621508] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 6.632969] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 6.698942] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 6.708600] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 6.720595] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 6.733402] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 6.750603] platform 5c00000.r5f: configured R5F for IPC-only mode
    [ 6.758786] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 6.768951] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 6.784976] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 6.799165] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 6.813688] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 6.821882] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [ 6.830958] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 6.839071] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 6.848785] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 6.914445] remoteproc remoteproc3: 5c00000.r5f is available
    [ 6.920171] random: crng init done
    [ 6.920176] random: 7 urandom warning(s) missed due to ratelimiting
    [ OK ] Started Load/Save Random Seed.
    [ 6.961755] remoteproc remoteproc3: attaching to 5c00000.r5f
    [ 6.986374] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [ 7.033817] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [ 7.074770] virtio_rpmsg_bus virtio2: rpmsg host is online
    [ 7.084494] virtio_rpmsg_bus virtio2: creating channel rpmsg-kdrv addr 0x1a
    [ 7.093458] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uar
    t_id: 2
    [ 7.103547] remoteproc3#vdev0buffer: registered virtio2 (type 7)
    [ 7.104473] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 7.124980] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 4/Nov/2021 SHA:9fe
    47caa
    [ 7.137945] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 7.140845] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
    [ 7.146280] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_i
    d: 2
    [ 7.168972] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 7.181154] platform 5d00000.r5f: configured R5F for IPC-only mode
    [ 7.187416] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.196954] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 4/Nov/2021 SHA:9fe47c
    aa
    [ 7.216026] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 7.225322] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [ 7.236379] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 7.248766] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 7.259951] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [ 7.269143] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.278888] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 7.292307] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 7.293711] remoteproc remoteproc4: 5d00000.r5f is available
    [ 7.304456] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 7.317178] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.327878] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 7.328594] remoteproc remoteproc4: attaching to 5d00000.r5f
    [ 7.337639] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 7.351005] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 7.362087] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.371976] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [ 7.381181] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 7.391103] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 7.401420] remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [ 7.410862] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 7.419108] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.428734] virtio_rpmsg_bus virtio3: rpmsg host is online
    [ 7.461193] remoteproc4#vdev0buffer: registered virtio3 (type 7)
    [ 7.467447] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 7.474988] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 7.484964] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 7.493101] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.510724] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 7.524967] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 7.533085] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 7.544951] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.563242] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 7.572058] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached
    [ 7.579681] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 7.587893] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 7.596041] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.605859] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 7.614817] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 7.619041] platform 5e00000.r5f: configured R5F for IPC-only mode
    [ 7.622950] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 7.640983] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.654497] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 7.662075] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 7.670205] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 7.681588] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.695378] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [ 7.703903] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [ 7.713204] remoteproc remoteproc5: 5e00000.r5f is available
    [ 7.718949] remoteproc remoteproc5: attaching to 5e00000.r5f
    [ 7.725371] platform 5e00000.r5f: R5F core initialized in IPC-only mode
    [ 7.733686] remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [ 7.743587] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [ 7.757051] m_can_platform 2721000.can: m_can device registered (irq=50, version=32)
    [ 7.761738] virtio_rpmsg_bus virtio4: rpmsg host is online
    [ 7.771619] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 7.775517] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [ 7.779142] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 7.791930] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [ 7.800939] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 7.809893] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.819074] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 7.829068] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 7.837198] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 7.848673] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.861083] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 7.869958] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 7.878125] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 7.892956] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.895655] remoteproc5#vdev0buffer: registered virtio4 (type 7)
    [ 7.908226] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 7.917233] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ OK ] Created slice system-systemd\x2dfsc[ 7.928201] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001ffff
    fff -> 0x0018011000
    k.slice.
    [ 7.941211] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [ 7.948134] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.957484] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 7.967451] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 7.980946] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 7.989083] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 7.990988] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_
    mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
    [ 8.015383] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 8.019478] remoteproc remoteproc5: remote processor 5e00000.r5f is now attached
    [ 8.024984] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 8.033205] platform 5f00000.r5f: configured R5F for IPC-only mode
    [ 8.047579] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 8.057398] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
    [ 8.059895] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 8.093662] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_
    psil_dst_id:4A00 mac_only:0
    [ 8.145466] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [ 8.229567] remoteproc remoteproc6: 5f00000.r5f is available
    [ 8.265227] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff
    :76:1d:92:c1
    [ 8.299298] remoteproc remoteproc6: attaching to 5f00000.r5f
    [ 8.354129] platform 5f00000.r5f: R5F core initialized in IPC-only mode
    [ 8.374489] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 8.385107] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 8.396982] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 8.405154] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 8.416706] remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [ 8.427225] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 8.436488] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 8.444651] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 8.456152] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 8.465583] virtio_rpmsg_bus virtio5: rpmsg host is online
    [ 8.472592] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [ 8.480331] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 8.487934] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 8.496122] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 8.505106] remoteproc6#vdev0buffer: registered virtio5 (type 7)
    [ 8.511262] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ OK ] Found device /dev/mmcblk0p1.
    [ 8.520141] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_
    mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
    [ 8.543342] remoteproc remoteproc6: remote processor 5f00000.r5f is now attached
    [ 8.551480] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    Starting File System Check on /dev/mmcblk0p1 8.560618] j721e-pcie 2910000.pcie: IO 0x0018001000..0
    0m...
    [ 8.580956] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 8.592557] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 8.603956] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
    [ 8.613080] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 8.622578] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 8.637891] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 8.652993] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 8.670975] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [ 8.684950] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ OK ] Found device /dev/mmcblk0p4.[ 8.706450] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff ->
    0x0010001000
    Starting File System Check on /dev/mmcblk0p4...
    [ 8.730899] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 8.736868] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_
    psil_dst_id:4A01 mac_only:1
    [ 8.742102] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 8.751700] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff
    :76:1d:92:c2
    [ 8.781787] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 8.795704] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 8.808987] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 8.820945] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 8.836091] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 8.843704] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 8.852145] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 8.860339] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 8.870127] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [ 8.882819] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 8.893393] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 8.901782] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 8.912774] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ OK ] Found device /dev/mmcblk0p3.
    Starting File System Check on /dev/mmcblk0p3...
    [ OK ] Started File System Check on /dev/mmcblk0p1.
    Mounting /run/media/mmcblk0p1...
    [ OK ] Mounted /run/media/mmcblk0p1.
    [ OK ] Started File System Check on /dev/mmcblk0p4.
    Mounting /run/media/mmcblk0p4...
    [ OK ] Started File System Check on /dev/m[ 9.077082] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data
    mode. Opts: (null)
    mcblk0p3.
    [ OK ] Mounted /run/media/mmcblk0p4.
    Mounting /run/media/mmcblk0p3...
    [ 9.141882] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
    [ OK ] Mounted /run/media/mmcblk0p3.
    [ 9.212028] usbcore: registered new interface driver usbfs
    [ 9.217539] usbcore: registered new interface driver hub
    [ 9.224070] usbcore: registered new device driver usb
    [ 9.240346] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 9.251284] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 9.265180] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 9.281079] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.297049] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 9.307310] remoteproc remoteproc7: b034000.pru is available
    [ 9.311221] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 9.325295] remoteproc remoteproc8: b004000.rtu is available
    [ 9.329113] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 9.331349] remoteproc remoteproc9: b00a000.txpru is available
    [ 9.349086] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.361138] remoteproc remoteproc10: b038000.pru is available
    [ 9.365753] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [ 9.367103] remoteproc remoteproc11: b006000.rtu is available
    [ 9.380021] remoteproc remoteproc12: b00c000.txpru is available
    [ 9.386105] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 9.397046] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 9.397233] remoteproc remoteproc13: b134000.pru is available
    [ 9.411371] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 9.424970] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.436682] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 9.445388] remoteproc remoteproc14: b104000.rtu is available
    [ 9.447910] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 9.464950] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 9.469452] remoteproc remoteproc15: b10a000.txpru is available
    [ 9.473060] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.480555] remoteproc remoteproc16: b138000.pru is available
    [ 9.495796] remoteproc remoteproc17: b106000.rtu is available
    [ 9.497163] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 9.502871] remoteproc remoteproc18: b10c000.txpru is available
    [ 9.512937] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 9.523097] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 9.534777] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.544031] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [ 9.556961] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 9.568966] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 9.577091] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 9.585256] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.597805] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 9.608938] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 9.617043] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 9.625148] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.634760] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 9.642343] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 9.650457] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 9.658582] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ OK ] Created slice system-weston.slice.
    [ 9.717096] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [ 9.733700] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [DEPEND] Dependency failed for Star�[ 9.744549] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran
    ges:
    ��progress communication helper.
    [ 9.761208] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 9.775691] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 9.789126] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.802888] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 9.812939] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 9.824961] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 9.833110] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.845246] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 9.856617] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 9.864763] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 9.878913] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.888254] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [ 9.897201] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 9.905494] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 9.913695] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 9.925473] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.938749] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 9.947906] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 9.957063] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 9.965415] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 9.977820] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 9.987793] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 10.000142] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 10.012456] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 10.790059] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [ 10.801077] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 10.812976] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 10.821573] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 10.829743] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ OK ] Reached target Hardware activated U[ 10.839553] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@291
    0000 ranges:
    SB gadget.
    [ 10.853679] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 10.863012] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [ 10.868563] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 10.876663] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [ 10.884336] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 10.884716] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [ 10.894035] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 10.902868] xhci-hcd xhci-hcd.2.auto: irq 650, io mem 0x06410000
    [ 10.910119] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 10.915786] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [ 10.924050] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 10.931875] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 10.940299] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 10.947172] usb usb1: Product: xHCI Host Controller
    [ 10.957201] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [ 10.961306] usb usb1: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd
    [ 10.973666] usb usb1: SerialNumber: xhci-hcd.2.auto
    [ 10.978814] hub 1-0:1.0: USB hub found
    [ 10.982595] hub 1-0:1.0: 1 port detected
    [ 10.986843] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [ 10.992455] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 10.993049] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [ 10.999945] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 11.008069] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [ 11.015642] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 11.015652] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 11.022903] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [ 11.046670] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [ 11.054932] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 11.062216] usb usb2: Product: xHCI Host Controller
    [ 11.067092] usb usb2: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd
    [ 11.067380] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 11.073611] usb usb2: SerialNumber: xhci-hcd.2.auto
    [ 11.074791] hub 2-0:1.0: USB hub found
    [ 11.081106] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 11.081116] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 11.086847] hub 2-0:1.0: 1 port detected
    [ 11.089751] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 11.120804] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 11.129290] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
    [ 11.137995] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [ 11.148791] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 11.158081] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [ 11.168123] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 11.175672] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
    [ 11.183778] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [ 11.191876] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [ 11.201321] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 11.208868] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
    [ 11.216958] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [ 11.225050] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [** ] A start job is running for udev Wai…ce Initialization (23s / 2min 54s)
    [FAILED] Failed to start udev Wait …omplete Device Initialization.
    See 'systemctl status systemd-udev-settle.service' for details.
    [ OK ] Started Hardware RNG Entropy Gatherer Daemon.
    [ OK ] Reached target System Initialization.
    [ OK ] Started Daily rotation of log files.
    [ OK ] Started Daily Cleanup of Temporary Directories.
    [ OK ] Reached target Timers.
    [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [ OK ] Listening on D-Bus System Message Bus Socket.
    Starting Docker Socket for the API.
    [ OK ] Listening on dropbear.socket.
    Starting Reboot and dump vmcore via kexec...
    [ OK ] Listening on Docker Socket for the API.
    [ OK ] Started Reboot and dump vmcore via kexec.
    [ OK ] Reached target Sockets.
    [ OK ] Reached target Basic System.
    [ OK ] Started Job spooling tools.
    [ OK ] Started Periodic Command Scheduler.
    [ OK ] Started D-Bus System Message Bus.
    Starting Print notice about GPLv3 packages...
    Starting IPv6 Packet Filtering Framework...
    Starting IPv4 Packet Filtering Framework...
    [ OK ] Started irqbalance daemon.
    Starting Telephony service...
    Starting rc.pvr.service...
    Starting startwlan...
    Starting Login Service...
    Starting Update weston ini… based on the platform name...
    [ 124.683844] Bluetooth: Core ver 2.22
    [ 124.687530] NET: Registered protocol family 31
    [ OK ] Started IPv6 Packet Filtering Frame[ 124.700939] Bluetooth: HCI device and connection manager initialized
    work.
    [ 124.708542] Bluetooth: HCI socket layer initialized
    [ 124.716952] Bluetooth: L2CAP socket layer initialized
    [ OK ] Started IPv4 Packet Filtering Frame[ 124.724467] Bluetooth: SCO socket layer initialized
    work.
    [ OK ] Started rc.pvr.service.
    [ OK ] Started Update weston ini …ge based on the platform name.
    [ OK ] Reached target Network (Pre).
    [ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    Starting Network Service...
    Starting[ 124.766634] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    weston.service...
    [ OK ] Started Telephony service.
    [ OK ] Started weston.service.
    Starting DEMO...
    Starting telnetd.service...
    [ OK ] Started DEMO.
    [ OK ] Started telnetd.service.
    [ 124.880747] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [ OK ] Started Network Service.
    Starting Wait for Network to be Configured...
    Starting Network Name Resolution...
    [ 125.058173] PVR_K: 1005: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [ OK ] Started Login Service.
    [ 125.194828] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
    [ OK ] Started Network Name Resolution[ 125.216712] Intel(R) Wireless WiFi driver for Linux
    [ OK ] Reached target Network.
    [ OK ] Reached target Host and Network Name Lookups.
    Starting Avahi mDNS/DNS-SD Stack...
    Starting Enable and configure wl18xx bluetooth stack...
    [ OK ] Started NFS status monitor for NFSv2/3 locking..
    Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
    Starting Permit User Sessions...
    [ OK ] Started Permit User Sessions.
    [ OK ] Started Getty on tty1.
    [ OK ] Started Serial Getty on ttyS2.
    [ OK ] Started Serial Getty on ttyS3.
    [ OK ] Reached target Login Prompts.
    Starting Synchronize System and HW clocks...
    Starting Weston Wayland Compositor...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [ OK ] Started Avahi mDNS/DNS-SD Stack.
    [ OK ] Started Enable and configure wl18xx bluetooth stack.
    [ OK ] Created slice User Slice of UID 0.
    Starting User Runtime Directory /run/user/0...
    [ OK ] Started User Runtime Directory /run/user/0.
    Starting User Manager for UID 0...
    [ 125.692382] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
    [ OK ] Started User Manager for UID 0.
    [ OK ] Started Session c1 of user root.
    [ 125.762766] am65-cpsw-nuss 46000000.ethernet: phy /bus@100000/bus@28380000/ethernet@46000000/mdio@f00/ethernet-ph
    y@0 not found on slave 1
    [FAILED] Failed to start Weston Wayland Compositor.
    See 'systemctl status weston@root.service' for details.
    [ OK ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
    autoconf
    bash-dev
    bash
    bc
    binutils
    cifs-utils
    coreutils-stdbuf
    coreutils
    cpio
    cpp-symlinks
    cpp
    dosfstools
    elfutils
    g++-symlinks
    g++
    gawk
    gcc-symlinks
    gcc
    gdb
    gdbserver
    gettext
    glmark2
    gstreamer1.0-libav-dev
    gstreamer1.0-libav
    gzip
    less
    libasm1
    libbfd
    libdw1
    libelf1
    libgdbm-compat4
    libgdbm-dev
    libgdbm6
    libgettextlib
    libgettextsrc
    libgmp-dev
    libgmp10
    libgmpxx4
    libidn2-0
    libidn2-dev
    libmpc3
    libmpfr6
    libreadline-dev
    libreadline8
    libunistring-dev
    libunistring2
    m4-dev
    m4
    make
    nettle-dev
    nettle
    parted
    python3-rfc3987
    python3-strict-rfc3339
    tar
    which
    zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution. This can be done using
    the opkg remove command. i.e.:
    opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
    will be notified of the dependent packages. You should
    use the --force-removal-of-dependent-packages option to
    also remove the dependent packages as well
    [ OK ] Started Print notice about GPLv3 packages.
    [ 126.279876] startwlan.sh[967]: Starting WLAN AP setup
    [ 126.336553] startwlan.sh[1241]: Starting WLAN AP se
    [ 126.348523] startwlan.sh[1242]: Starting WLAN AP se
    [ 126.360818] startwlan.sh[1242]: ddin
    [ 126.372330] startwlan.sh[1244]: ddin
    [ 126.384678] startwlan.sh[1244]: ommand failed: No such file or directory (
    [ 126.400227] startwlan.sh[1245]: ommand failed: No such file or directory (
    [ 126.416097] startwlan.sh[1245]: onfiguration file: /usr/share/intel9260/hostapd.conf
    [ 126.432068] startwlan.sh[1245]: Could not read interface wlp1s0 flags: No such device
    [ 126.448077] startwlan.sh[1245]: nl80211: Driver does not support authentication/association or connect commands
    [ 126.464119] startwlan.sh[1245]: nl80211: deinit ifname=wlp1s0 disabled_11b_rates=0
    [ 126.480070] startwlan.sh[1245]: Could not read interface wlp1s0 flags: No such device
    [ 126.496069] startwlan.sh[1245]: nl80211 driver initialization failed.
    [ 126.512069] startwlan.sh[1245]: wlp1s0: interface state UNINITIALIZED->DISABLED
    [ 126.528066] startwlan.sh[1245]: wlp1s0: AP-DISABLED
    [ 126.540064] startwlan.sh[1245]: wlp1s0: CTRL-EVENT-TERMINATING
    [ 127.312245] startwlan.sh[1245]: hostapd_free_h
    [ 127.324550] startwlan.sh[1253]: hostapd_free_h
    [ 127.336250] startwlan.sh[1253]: IOCSIFADDR: Nwlp1s0: ERROR while getting interface flags: No such device
    [ 127.352262] startwlan.sh[1253]: SIOCSIFNETMASK: No such device
    [ 127.368298] startwlan.sh[1253]: wlp1s0: ERROR while getting interface flags: No such device
    [ OK ] Started startwlan.
    [ 128.464863] startwlan.sh[1274]: iperf3: error - unable to start listener for connections: Cannot assign requested
    address
    [ 128.484172] startwlan.sh[1274]: iperf3: exiting
    _____ _____ _ _
    | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
    | | _| .'| . | . | | __| _| . | | | -_| _| _|
    |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
    |___| |___|
    Arago Project http://arago-project.org j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login: root
    Last login: Mon Dec 20 16:29:13 UTC 2021
    root@j7-evm:~# ls -l /sys/bus/rpmsg/devices
    total 0
    lrwxrwxrwx 1 root root 0 Dec 20 16:29 virtio0.rpmsg_chrdev.-1.14 -> ../../../devices/platform/bus@100000/4d80800000.
    dsp/remoteproc/remoteproc0/remoteproc0#vdev0buffer/virtio0/virtio0.rpmsg_chrdev.-1.14
    lrwxrwxrwx 1 root root 0 Dec 20 16:29 virtio0.ti.ipc4.ping-pong.-1.13 -> ../../../devices/platform/bus@100000/4d8080
    0000.dsp/remoteproc/remoteproc0/remoteproc0#vdev0buffer/virtio0/virtio0.ti.ipc4.ping-pong.-1.13
    lrwxrwxrwx 1 root root 0 Dec 20 16:29 virtio1.rpmsg_chrdev.-1.14 -> ../../../devices/platform/bus@100000/bus@100000:
    bus@28380000/bus@100000:bus@28380000:r5fss@41000000/41000000.r5f/remoteproc/remoteproc2/remoteproc2#vdev0buffer/virt
    io1/virtio1.rpmsg_chrdev.-1.14
    lrwxrwxrwx 1 root root 0 Dec 20 16:29 virtio1.ti.ipc4.ping-pong.-1.13 -> ../../../devices/platform/bus@100000/bus@10
    0000:bus@28380000/bus@100000:bus@28380000:r5fss@41000000/41000000.r5f/remoteproc/remoteproc2/remoteproc2#vdev0buffer
    /virtio1/virtio1.ti.ipc4.ping-pong.-1.13
    lrwxrwxrwx 1 root root 0 Dec 20 16:29 virtio2.rpmsg-kdrv.-1.26 -> ../../../devices/platform/bus@100000/bus@100000:r5
    fss@5c00000/5c00000.r5f/remoteproc/remoteproc3/remoteproc3#vdev0buffer/virtio2/virtio2.rpmsg-kdrv.-1.26
    lrwxrwxrwx 1 root root 0 Dec 20 16:29 virtio2.rpmsg_chrdev.-1.21 -> ../../../devices/platform/bus@100000/bus@100000:
    r5fss@5c00000/5c00000.r5f/remoteproc/remoteproc3/remoteproc3#vdev0buffer/virtio2/virtio2.rpmsg_chrdev.-1.21
    root@j7-evm:~#
  • hi susan,
    the ls -l /sys/bus/rpmsg/devices show the log:
    total 0
    and the uboot logs show haved download the fw successfully:
    Hit any key to stop autoboot: 0
    switch to partitions #0, OK
    mmc0(part 0) is current device
    SD/MMC found on device 0
    Failed to load 'boot.scr'
    54 bytes read in 7 ms (6.8 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc0 ...
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    626036 bytes read in 11 ms (54.3 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 626036 bytes: Success!
    97676 bytes read in 9 ms (10.3 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 97676 bytes: Success!
    Load Remote Processor 4 with data@addr=0x82000000 97676 bytes: Success!
    Load Remote Processor 5 with data@addr=0x82000000 97676 bytes: Success!
    144332 bytes read in 9 ms (15.3 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 144332 bytes: Success!
    144332 bytes read in 10 ms (13.8 MiB/s)
    Load Remote Processor 7 with data@addr=0x82000000 144332 bytes: Success!
    10489000 bytes read in 65 ms (153.9 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 10489000 bytes: Success!
  • hi suan,
    we found the linux kernel print the following error log:
    the error log reason is the rproc->rsc_table parse failed
     the the rproc->rsc_table if from the fw header, is right?
    so is the sdk 0801 rtos fw rproc->rsc table have something wrong?
    thanks,
    Ruijie Sun
  • Hi Ruijie,
    You don't seem to be running the Vision Apps firmwares, based on the file sizes I can see.
    Can you provide the output of ls -l /lib/firmware?
    Also, the SDK uses only a limited set of cores for Vision Apps (MCU2_0, MCU2_1, C66x_1, C66x_2 and C71_0).
    Make sure you don't mix and match VisionApps firmwares and ipc_echo_test firmwares.
    Please cross-reference against the Sample Logs provided with the Vision Apps documentation.
    regards
    Suman
  • hi suman,
    thanks for your reply,  i did mix and match VisionApps firmwares and ipc_echo_test firmwares
    Ruijie Sun
