Hi TI,
When I use SBL + enet_loopback_test app in SDK07.03, I found that there are no other prints of app.
This is the log from SBL:
SBL Revision: 01.00.10.00 (Feb 24 2022 - 11:41:09)
TIFS ver: 21.1.1--v2021.01a (Terrific Lla
Sciserver Built On: Mar 12 2021 10:54:54
Starting Sciserver..... PASSED
GTC freq: 200000000
This is my compilation log:
hluo@CSCD-csp1:~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build$ make enet_loopback_test CORE=mcu2_0 BUILD_PROFILE=release -s -j12
# Invoking configuro...
making package.mak (because of package.bld) ...
generating interfaces for package configuro (because package/package.xdc.inc is older than package.xdc) ...
configuring sysbios_r5f.xer5ft from package/cfg/sysbios_r5f_per5ft.cfg ...
# !!! Apply Timer clock freq. change for J721E
# MPU setup for 11 entries !!!
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
making /cscd/hluo/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/binary/enet_loopback_test/obj/j721e_evm/mcu2_0/release/configuro/package/cfg/sysbios_r5f_per5ft.src/sysbios/sysbios.aer5ft ...
cler5ft /cscd/hluo/tda4/730/ra/bios_6_83_02_07/packages/ti/sysbios/BIOS.c ...
asmer5ft /cscd/hluo/tda4/730/ra/bios_6_83_02_07/packages/ti/sysbios/family/arm/IntrinsicsSupport_asm.asm ...
asmer5ft /cscd/hluo/tda4/730/ra/bios_6_83_02_07/packages/ti/sysbios/family/arm/MPU_asm.sv7R ...
asmer5ft /cscd/hluo/tda4/730/ra/bios_6_83_02_07/packages/ti/sysbios/family/arm/TaskSupport_asm.asm ...
asmer5ft /cscd/hluo/tda4/730/ra/bios_6_83_02_07/packages/ti/sysbios/family/arm/v7r/keystone3/Core_asm.sv7R ...
asmer5ft /cscd/hluo/tda4/730/ra/bios_6_83_02_07/packages/ti/sysbios/family/arm/v7r/keystone3/Hwi_asm.sv7R ...
asmer5ft /cscd/hluo/tda4/730/ra/bios_6_83_02_07/packages/ti/sysbios/family/arm/v7r/keystone3/Hwi_asm_switch.sv7R ...
asmer5ft /cscd/hluo/tda4/730/ra/bios_6_83_02_07/packages/ti/sysbios/family/arm/exc/Exception_asm.asm ...
asmer5ft /cscd/hluo/tda4/730/ra/bios_6_83_02_07/packages/ti/sysbios/family/arm/v7r/Cache_asm.sv7R ...
asmer5ft /cscd/hluo/tda4/730/ra/bios_6_83_02_07/packages/ti/sysbios/timers/dmtimer/Timer_asm.s470 ...
asmer5ft /cscd/hluo/tda4/730/ra/bios_6_83_02_07/packages/ti/sysbios/family/arm/a15/TimestampProvider_asm.asm ...
arer5ft BIOS.obj arm_IntrinsicsSupport_asm.obj arm_MPU_asm.obj arm_TaskSupport_asm.obj keystone3_Core_asm.obj keystone3_Hwi_asm.obj keystone3_Hwi_asm_switch.obj exc_Exception_asm.obj v7r_Cache_asm.obj dmtimer_Timer_asm.obj a15_TimestampProvider_asm.obj ...
Build of libraries done.
# Configuro done!
# Compiling j721e_evm:j721e:mcu2_0:release:enet_loopback_test: enet_loopback.c
# Compiling generated sysbios_r5f_per5ft.oer5ft
# Linking into /cscd/hluo/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/binary/enet_loopback_test/bin/j721e_evm/enet_loopback_test_mcu2_0_release.xer5f...
<Linking>
# /cscd/hluo/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/binary/enet_loopback_test/bin/j721e_evm/enet_loopback_test_mcu2_0_release.xer5f created.
# Generating stripped image into /cscd/hluo/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/binary/enet_loopback_test/bin/j721e_evm/enet_loopback_test_mcu2_0_release_strip.xer5f...
~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/drv/enet/examples/enet_loopback_test ~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/drv/enet/examples/enet_loopback_test
R5 Certificate being generated :
X509_CFG = ./x509-temp.cfg
KEY = /cscd/hluo/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build/makerules/k3_dev_mpk.pem
BIN = /cscd/hluo/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/binary/enet_loopback_test/bin/j721e_evm/enet_loopback_test_mcu2_0_release.appimage
CERT TYPE = R5, 1
CORE ID = 16
LOADADDR = 0x41c00100
IMAGE_SIZE = 487240
BOOT_OPTIONS = 0
SUCCESS: Image /cscd/hluo/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/binary/enet_loopback_test/bin/j721e_evm/enet_loopback_test_mcu2_0_release.appimage.signed generated. Good to boot
# SBL App image /cscd/hluo/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/binary/enet_loopback_test/bin/j721e_evm/enet_loopback_test_mcu2_0_release.appimage and /cscd/hluo/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/binary/enet_loopback_test/bin/j721e_evm/enet_loopback_test_mcu2_0_release_BE.appimage created.
hluo@CSCD-csp1:~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 956K 1 loop /snap/gnome-logs/100
loop1 7:1 0 2.2M 1 loop /snap/gnome-system-monitor/148
loop2 7:2 0 247.9M 1 loop /snap/gnome-3-38-2004/87
loop3 7:3 0 248.8M 1 loop /snap/gnome-3-38-2004/99
loop4 7:4 0 704K 1 loop /snap/gnome-characters/761
loop5 7:5 0 548K 1 loop /snap/gnome-logs/106
loop6 7:6 0 43.6M 1 loop /snap/snapd/14978
loop7 7:7 0 219M 1 loop /snap/gnome-3-34-1804/77
loop8 7:8 0 65.2M 1 loop /snap/gtk-common-themes/1519
loop9 7:9 0 61.9M 1 loop /snap/core20/1328
loop10 7:10 0 61.9M 1 loop /snap/core20/1270
loop11 7:11 0 55.5M 1 loop /snap/core18/2253
loop12 7:12 0 255.6M 1 loop /snap/gnome-3-34-1804/36
loop13 7:13 0 62.1M 1 loop /snap/gtk-common-themes/1506
loop14 7:14 0 4K 1 loop /snap/bare/5
loop15 7:15 0 55.5M 1 loop /snap/core18/2284
loop16 7:16 0 2.5M 1 loop /snap/gnome-calculator/884
loop17 7:17 0 704K 1 loop /snap/gnome-characters/741
loop18 7:18 0 2.6M 1 loop /snap/gnome-calculator/920
loop19 7:19 0 2.5M 1 loop /snap/gnome-system-monitor/174
sda 8:0 0 1.8T 0 disk
├─sda1 8:1 0 300M 0 part
├─sda2 8:2 0 128M 0 part
└─sda3 8:3 0 1.8T 0 part /cscd
sdb 8:16 1 29.7G 0 disk
├─sdb1 8:17 1 4G 0 part /media/csp/BOOT1
├─sdb2 8:18 1 4G 0 part /media/csp/rootfsA1
├─sdb3 8:19 1 4G 0 part /media/csp/rootfsB1
└─sdb4 8:20 1 17.7G 0 part /media/csp/data1
sr0 11:0 1 1024M 0 rom
nvme0n1 259:0 0 477G 0 disk
├─nvme0n1p1 259:1 0 300M 0 part /boot/efi
├─nvme0n1p2 259:2 0 120.1G 0 part /
├─nvme0n1p3 259:3 0 77.1G 0 part
└─nvme0n1p5 259:4 0 279.4G 0 part
hluo@CSCD-csp1:~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build$ sudo cp /cscd/hluo/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/binary/enet_loopback_test/bin/j721e_evm/enet_loopback_test_mcu2_0_release.appimage /media/csp/BOOT1/app
hluo@CSCD-csp1:~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build$ sudo cp /cscd/hluo/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/boot/sbl/binary/j721e_evm/mmcsd/bin/sbl_mmcsd_img_hlos_mcu1_0_release.tiimage /media/csp/BOOT1/tiboot3.bin
hluo@CSCD-csp1:~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build$ sudo cp ~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/drv/sciclient/soc/V1/tifs.bin /media/csp/BOOT1/
hluo@CSCD-csp1:~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build$ ll /media/csp/BOOT1
ls: cannot access '/media/csp/BOOT1': Permission denied
hluo@CSCD-csp1:~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build$ sudo ll /media/csp/BOOT1
sudo: ll: command not found
hluo@CSCD-csp1:~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build$ m b
-- Main device is: /dev/nvme0n1p2
/dev/sdb1 on /media/csp/BOOT1 type vfat (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
/dev/sdb3 on /media/csp/rootfsB1 type ext4 (rw,nosuid,nodev,relatime,uhelper=udisks2)
/dev/sdb4 on /media/csp/data1 type ext4 (rw,nosuid,nodev,relatime,uhelper=udisks2)
/dev/sdb2 on /media/csp/rootfsA1 type ext4 (rw,nosuid,nodev,relatime,uhelper=udisks2)
++ /dev/sdb has benn mounted ++
umount: /dev/sdb: not mounted.
The drive /dev/sdb will be mounted at /media/hluo/
|-sda1 8:1 0 300M 0 part
|-sda2 8:2 0 128M 0 part
`-sda3 8:3 0 1.8T 0 part /cscd
|-sdb1 8:17 1 4G 0 part /media/hluo/boot
|-sdb2 8:18 1 4G 0 part /media/hluo/rootfsA
|-sdb3 8:19 1 4G 0 part /media/hluo/rootfsB
`-sdb4 8:20 1 17.7G 0 part /media/hluo/data
|-nvme0n1p1 259:1 0 300M 0 part /boot/efi
|-nvme0n1p2 259:2 0 120.1G 0 part /
|-nvme0n1p3 259:3 0 77.1G 0 part
`-nvme0n1p5 259:4 0 279.4G 0 part
hluo@CSCD-csp1:~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build$ sudo ^C
hluo@CSCD-csp1:~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build$ ls /media/hluo/boot -lh
total 1.1M
-rw-r--r-- 1 csp csp 476K 2月 24 21:02 app
drwxr-xr-x 12 csp csp 4.0K 2月 24 20:33 qnx
drwxr-xr-x 2 csp csp 4.0K 2月 24 20:41 sbl
-rw-r--r-- 1 csp csp 284K 2月 24 21:02 tiboot3.bin
-rw-r--r-- 1 csp csp 257K 2月 24 21:03 tifs.bin
hluo@CSCD-csp1:~/tda4/730/ra/pdk_jacinto_07_03_00_29/packages/ti/build$ sync
Could you give me some suggestion?
Thank you!
