Part Number: TDA4VM
We have configured the UDMA DRU by referring the DRU examples that came with pdk. Our use case has 16 scattered blocks of data that needs to be transferred at once. I have configured 8 + 8 16 TRs so when triggerted all of this are transferred and then I wait for the response.
For me the configuring 16 TR's and pushing to the ring queue and again waiting for completion de-queque and checking response of each of 16 transfers is taking away significant number of cycles.
Is there a better way of implementing such UDMA of scattered blocks of data.
I'm attaching the code used to configure and de-configuring of the UDMA dru for 16 blocks.
Please Guide.
void DMATransfer()
CSL_UdmapCppi5TRPD *pTrpd = (CSL_UdmapCppi5TRPD *)pTrpdMem;
CSL_UdmapTR15 *pTr = (CSL_UdmapTR15 *)(pTrpdMem);
uint32_t *pTrResp = (uint32_t *)(pTrpdMem + (sizeof(CSL_UdmapTR15) * (numOfPatches + 1U)));
uint32_t cqRingNum = Udma_chGetCqRingNum(chHandle);
uint32_t i;
uint32_t hNumOfPatches = numOfPatches / 2;
CSL_UdmapTR15 Tr;
int32_t searchoffset;
/* Make TRPD */
UdmaUtils_makeTrpd(pTrpd, UDMA_TR_TYPE_9, numOfPatches, cqRingNum);
Tr.flags = CSL_FMK(UDMAP_TR_FLAGS_TYPE, CSL_UDMAP_TR_FLAGS_TYPE_4D_BLOCK_MOVE) |
CSL_FMK(UDMAP_TR_FLAGS_STATIC, 0U) |
CSL_FMK(UDMAP_TR_FLAGS_EOL, 0U) | /* NA */
CSL_FMK(UDMAP_TR_FLAGS_EVENT_SIZE, CSL_UDMAP_TR_FLAGS_EVENT_SIZE_COMPLETION) |
CSL_FMK(UDMAP_TR_FLAGS_TRIGGER0, CSL_UDMAP_TR_FLAGS_TRIGGER_NONE) |
CSL_FMK(UDMAP_TR_FLAGS_TRIGGER0_TYPE, CSL_UDMAP_TR_FLAGS_TRIGGER_TYPE_ALL) |
CSL_FMK(UDMAP_TR_FLAGS_TRIGGER1, CSL_UDMAP_TR_FLAGS_TRIGGER_NONE) |
CSL_FMK(UDMAP_TR_FLAGS_TRIGGER1_TYPE, CSL_UDMAP_TR_FLAGS_TRIGGER_TYPE_ALL) |
CSL_FMK(UDMAP_TR_FLAGS_CMD_ID, 0x25U) | /* This will come back in TR response */
CSL_FMK(UDMAP_TR_FLAGS_SA_INDIRECT, 0U) |
CSL_FMK(UDMAP_TR_FLAGS_DA_INDIRECT, 0U) |
CSL_FMK(UDMAP_TR_FLAGS_EOP, 1U);
Tr.icnt0 = searchPatchWidth * sizeof(uint16_t);
Tr.icnt1 = searchPatchHeight;
Tr.icnt2 = 1U;
Tr.icnt3 = 1U;
Tr.dim1 = imgWidth * sizeof(uint16_t);
Tr.dim2 = (Tr.icnt0 * Tr.icnt1);
Tr.dim3 = (Tr.icnt0 * Tr.icnt1 * Tr.icnt2);
Tr.fmtflags = 0x00000000U; /* Linear addressing, 1 byte per elem.
Replace with CSL-FL API */
Tr.dicnt0 = searchPatchWidth * sizeof(uint16_t);
Tr.dicnt1 = searchPatchHeight;
Tr.dicnt2 = 1U;
Tr.dicnt3 = 1U;
Tr.ddim1 = Tr.dicnt0;
Tr.ddim2 = (Tr.dicnt0 * Tr.dicnt1);
Tr.ddim3 = (Tr.dicnt0 * Tr.dicnt1 * Tr.dicnt2);
/* Setup TR */
for (i = 0; i < hNumOfPatches; i++)
pTr++;
*pTr = Tr;
searchoffset = ((patchList[i].lower_left_y - searchMarginHeight + yPosSearch[i]) * imgWidth) + (patchList[i].lower_left_x - searchMarginwidth + xPosSearch[i]);
// printf("patch:%d - searchOffset = %d\n", i, searchoffset);
pTr->addr = (uint64_t)(searchImage + searchoffset);
pTr->daddr = (uint64_t)(searchPatches + (i * searchPatchWidth * searchPatchHeight));
/* Clear TR response memory */
*pTrResp = 0xFFFFFFFFU;
pTrResp++;
Tr.icnt0 = refPatchWidth * sizeof(uint16_t);
Tr.icnt1 = refPatchHeight;
Tr.dicnt0 = refPatchWidth * sizeof(uint16_t);
Tr.dicnt1 = refPatchHeight;
pTr++;
*pTr = Tr;
pTr->addr = (uint64_t)(refImage + ((patchList[i].lower_left_y - 1) * imgWidth) + (patchList[i].lower_left_x - 1));
pTr->daddr = (uint64_t)(refPatches + (i * refPatchWidth * refPatchHeight));
pTrResp++;
/* Writeback cache */
Udma_appUtilsCacheWb(pTrpdMem, UDMA_TEST_APP_TRPD_SIZE);
tempRetVal = Udma_ringQueueRaw(Udma_chGetFqRingHandle(chHandle0), (uint64_t)trpdMemCh0);
if (UDMA_SOK != tempRetVal)
App_print("[Error] Channel 0 queue failed!!\n");
if (UDMA_SOK == tempRetVal)
/* Wait for return descriptor in completion ring - this marks the
* transfer completion */
SemaphoreP_pend(gUdmaAppDoneSemCh0, SemaphoreP_WAIT_FOREVER);
SemaphoreP_pend(gUdmaAppDoneSemCh1, SemaphoreP_WAIT_FOREVER);
// cycTransferA = __TSC;
/* Response received in completion queue */
tempRetVal = Udma_ringDequeueRaw(Udma_chGetCqRingHandle(chHandle0), &pDescCh0);
App_print("[Error] No descriptor after callback Ch 0!!\n");
tempRetVal = UDMA_EFAIL;
#ifdef DEBUG_PRINTS
App_print("[Debug] ringdequeue Ch 0 passed!!\n");
#endif
* Sanity check
/* Check returned descriptor pointer */
if (pDescCh0 != ((uint64_t)trpdMemCh0))
App_print("[Error] TR descriptor pointer returned doesn't "
"match the submitted address for Ch 0!!\n");
tempRetVal = Udma_ringDequeueRaw(Udma_chGetCqRingHandle(chHandle1), &pDescCh1);
App_print("[Error] No descriptor after callback Ch 1!!\n");
#ifdef DEBUG_PRINTS
App_print("[Debug] ringdequeue Ch 1 passed!!\n");
#endif
* Sanity check
if (pDescCh1 != ((uint64_t)trpdMemCh1))
"match the submitted address for Ch 1!!\n");
/* Invalidate cache */
Udma_appUtilsCacheInv(gUdmaTrpdMem, UDMA_TEST_APP_TRPD_SIZE);
/* check TR response status */
pTrResp = (uint32_t *)(trpdMemCh0 + (sizeof(CSL_UdmapTR15) * (numOfPatches + 1U)));
for (i = 0; i < numOfPatches; i++)
trRespStatus = CSL_FEXT(*pTrResp, UDMAP_TR_RESPONSE_STATUS_TYPE);
if (trRespStatus != CSL_UDMAP_TR_RESPONSE_STATUS_COMPLETE)
App_print("[Error] TR Response not completed for Ch 0!!\n");
pTrResp++;
#ifdef DEBUG_PRINTS
App_print("[Debug] TR Response completed for Ch 0 passed!!\n");
#endif
Udma_appUtilsCacheInv(gUdmaTrpdMem + UDMA_TEST_APP_TRPD_SIZE_ALIGN, UDMA_TEST_APP_TRPD_SIZE);
pTrResp = (uint32_t *)(trpdMemCh1 + (sizeof(CSL_UdmapTR15) * (numOfPatches + 1U)));
App_print("[Error] TR Response not completed for Ch 1!!\n");
pTrResp++;
#ifdef DEBUG_PRINTS
App_print("[Debug] TR Response completed for Ch 1 passed!!\n");
#endif
if (tempRetVal != UDMA_SOK)
retVal = _CALL_LK_RETURN_DMA_ERROR_;
