Part Number: TMS320C6678
Hi
A function built with C6000 v8.3.2 has lower performance than the same source code built with v7.4.21. Below is the function source code
* test_adap_emph.cpp
* Created on: Feb 28, 2022
* Author: Wai.Kwok.Law
#include "image_process_be_filter_aniso2d.h"
#include "nam_tool.h"
#include "image_process_be.h"
#include "image_process_be_main.h"
#include <c6x.h>
using XtNamApi::RangeClip;
#pragma CODE_SECTION(".sect_DDR2_code")
void adap_emph(ip_int* restrict adap,
const ip_int* restrict lineBufOrig,
const ip_int* restrict lineBufFilter,
const ip_int* restrict range,
const tbl_int* restrict wghtTblS,
const tbl_int* restrict emphTbl,
const Int32 sx,
const Int32 y,
const ImageInfo* info,
const Int32 scale,
const Int32 alphaI,
const Int32 betaI,
const Int32 gammaI)
const Int32 scaleT = (1 << (IMAGECALC_ACCURACY)) - 1;
const Int32 scale2 = (1 << (IMAGECALC_ACCURACY - 1)) - 1;
#pragma MUST_ITERATE(16, MAX_IMAGE_PROCESS_BE_Y_SIZE, 2)
for (Int32 x = 0; x < sx; ++x) {
Int32 idx = GetViewIndex(x, y, info);
Int32 value = lineBufOrig[x];
Int32 edge = range[idx];
edge = RangeClip(edge, 0, scale2);
Int32 w = wghtTblS[edge];
Int32 value2 = lineBufFilter[x];
Int32 wb = (1 << IMAGECALC_ACCURACY) - w;
Int32 tmp2 = (value * alphaI) >> 11;
Int32 tmp3 = (value * betaI + value2 * gammaI) >> 11;
Int32 tmp = (tmp2 * wb + tmp3 * w) >> IMAGECALC_ACCURACY;
tmp = RangeClip(tmp, -scale2 - 1, scale2);//actually image range is +2^15~-2^15, but original algorithm is clip under 2^14. It will help image saturate.
tmp = emphTbl[tmp + scaleT + 1];
adap[idx] = tmp;
#ifndef NAM_TOOL_H
#define NAM_TOOL_H
namespace XtNamApi
* zero or not decision
* @param[in] value evaluated value
* @retval true zero
* @retval false not zero
template <typename T>
static inline bool IsZero(T value)
return ( value == static_cast<T>(0) );
* Is equal decision
* @param[in] a Input1
* @param[in] b Input2
* @retval true a == b
* @retval false b != b
static inline bool IsEqual( float a, float b )
union {
float f32;
int i32;
} va, vb;
va.f32 = a;
vb.f32 = b;
if ( va.i32 == vb.i32 )
return true;
return false;
* Min
* @param[in] a Evaluated value
* @param[in] b Evaluated value
* @return Min value
template< class T > static inline T Min( T a, T b )
T retVal = (a <= b) ? a : b;
return retVal;
* Max
* @return Min value
template< class T > static inline T Max( T a, T b )
T retVal = (a <= b) ? b : a;
return retVal;
* clip
* @param[in] value value
* @param[in] low bottom
* @param[in] high top
* @return clipped value
template< class T > static inline T RangeClip( T value, T low, T high )
T retVal = (value < low) ? low : value;
retVal = (retVal > high) ? high : retVal;
return retVal;
* rounding
* @date 2012/06/12 fix round off(minus)
* @param[in] value evalueted value
* @reurn rounded value
static inline int RoundF2I( float value )
if ( value < 0.0F )
return int( value - 0.5F );
return int( value + 0.5F );
} // End namespace XtNamApi
#endif // NAM_TOOL_H
The generated assembly code using the two compiler versions are
;* TMS320C6x C/C++ Codegen PC v7.4.21 *
;* Date/Time created: Mon Feb 28 22:34:52 2022 *
.compiler_opts --abi=eabi --c64p_l1d_workaround=off --endian=little --hll_source=on --long_precision_bits=32 --mem_model:code=near --mem_model:const=data --mem_model:data=far --object_format=elf --silicon_version=6600 --symdebug:dwarf --symdebug:dwarf_version=3
;* GLOBAL FILE PARAMETERS *
;* Architecture : TMS320C66xx *
;* Optimization : Enabled at level 3 *
;* Optimizing for : Speed *
;* Based on options: -o3, no -ms *
;* Endian : Little *
;* Interrupt Thrshld : Disabled *
;* Data Access Model : Far *
;* Pipelining : Enabled *
;* Speculate Loads : Enabled with threshold = 0 *
;* Memory Aliases : Presume are aliases (pessimistic) *
;* Debug Info : DWARF Debug w/Optimization *
.asg A15, FP
.asg B14, DP
.asg B15, SP
.global $bss
$C$DW$CU .dwtag DW_TAG_compile_unit
.dwattr $C$DW$CU, DW_AT_name("../App/BMode/Integ/src/test_adap_emph.cpp")
.dwattr $C$DW$CU, DW_AT_producer("TI TMS320C6x C/C++ Codegen PC v7.4.21 Copyright (c) 1996-2017 Texas Instruments Incorporated")
.dwattr $C$DW$CU, DW_AT_TI_version(0x01)
.dwattr $C$DW$CU, DW_AT_comp_dir("C:\git\phx_main_1\DevProjects\Apollo_DEBUG")
; C:\ti\c6000_7.4.21\bin\opt6x.exe C:\\Users\\wlaw\\AppData\\Local\\Temp\\447082 C:\\Users\\wlaw\\AppData\\Local\\Temp\\447084
.sect ".sect_DDR2_code"
.clink
.global _Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii
$C$DW$1 .dwtag DW_TAG_subprogram, DW_AT_name("adap_emph")
.dwattr $C$DW$1, DW_AT_low_pc(_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii)
.dwattr $C$DW$1, DW_AT_high_pc(0x00)
.dwattr $C$DW$1, DW_AT_TI_symbol_name("_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii")
.dwattr $C$DW$1, DW_AT_external
.dwattr $C$DW$1, DW_AT_TI_begin_file("../App/BMode/Integ/src/test_adap_emph.cpp")
.dwattr $C$DW$1, DW_AT_TI_begin_line(0x12)
.dwattr $C$DW$1, DW_AT_TI_begin_column(0x06)
.dwattr $C$DW$1, DW_AT_decl_file("../App/BMode/Integ/src/test_adap_emph.cpp")
.dwattr $C$DW$1, DW_AT_decl_line(0x12)
.dwattr $C$DW$1, DW_AT_decl_column(0x06)
.dwattr $C$DW$1, DW_AT_TI_max_frame_size(0x08)
.dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 31,column 1,is_stmt,address _Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii,isa 0
.dwfde $C$DW$CIE, _Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii
$C$DW$208 .dwtag DW_TAG_formal_parameter, DW_AT_name("adap")
.dwattr $C$DW$208, DW_AT_TI_symbol_name("adap")
.dwattr $C$DW$208, DW_AT_type(*$C$DW$T$1714)
.dwattr $C$DW$208, DW_AT_location[DW_OP_reg4]
$C$DW$209 .dwtag DW_TAG_formal_parameter, DW_AT_name("lineBufOrig")
.dwattr $C$DW$209, DW_AT_TI_symbol_name("lineBufOrig")
.dwattr $C$DW$209, DW_AT_type(*$C$DW$T$1717)
.dwattr $C$DW$209, DW_AT_location[DW_OP_reg20]
$C$DW$210 .dwtag DW_TAG_formal_parameter, DW_AT_name("lineBufFilter")
.dwattr $C$DW$210, DW_AT_TI_symbol_name("lineBufFilter")
.dwattr $C$DW$210, DW_AT_type(*$C$DW$T$1717)
.dwattr $C$DW$210, DW_AT_location[DW_OP_reg6]
$C$DW$211 .dwtag DW_TAG_formal_parameter, DW_AT_name("range")
.dwattr $C$DW$211, DW_AT_TI_symbol_name("range")
.dwattr $C$DW$211, DW_AT_type(*$C$DW$T$1717)
.dwattr $C$DW$211, DW_AT_location[DW_OP_reg22]
$C$DW$212 .dwtag DW_TAG_formal_parameter, DW_AT_name("wghtTblS")
.dwattr $C$DW$212, DW_AT_TI_symbol_name("wghtTblS")
.dwattr $C$DW$212, DW_AT_type(*$C$DW$T$1718)
.dwattr $C$DW$212, DW_AT_location[DW_OP_reg8]
$C$DW$213 .dwtag DW_TAG_formal_parameter, DW_AT_name("emphTbl")
.dwattr $C$DW$213, DW_AT_TI_symbol_name("emphTbl")
.dwattr $C$DW$213, DW_AT_type(*$C$DW$T$1718)
.dwattr $C$DW$213, DW_AT_location[DW_OP_reg24]
$C$DW$214 .dwtag DW_TAG_formal_parameter, DW_AT_name("sx")
.dwattr $C$DW$214, DW_AT_TI_symbol_name("sx")
.dwattr $C$DW$214, DW_AT_type(*$C$DW$T$1719)
.dwattr $C$DW$214, DW_AT_location[DW_OP_reg10]
$C$DW$215 .dwtag DW_TAG_formal_parameter, DW_AT_name("y")
.dwattr $C$DW$215, DW_AT_TI_symbol_name("y")
.dwattr $C$DW$215, DW_AT_type(*$C$DW$T$1719)
.dwattr $C$DW$215, DW_AT_location[DW_OP_reg26]
$C$DW$216 .dwtag DW_TAG_formal_parameter, DW_AT_name("info")
.dwattr $C$DW$216, DW_AT_TI_symbol_name("info")
.dwattr $C$DW$216, DW_AT_type(*$C$DW$T$1720)
.dwattr $C$DW$216, DW_AT_location[DW_OP_reg12]
$C$DW$217 .dwtag DW_TAG_formal_parameter, DW_AT_name("scale")
.dwattr $C$DW$217, DW_AT_TI_symbol_name("scale")
.dwattr $C$DW$217, DW_AT_type(*$C$DW$T$1719)
.dwattr $C$DW$217, DW_AT_location[DW_OP_reg28]
$C$DW$218 .dwtag DW_TAG_formal_parameter, DW_AT_name("alphaI")
.dwattr $C$DW$218, DW_AT_TI_symbol_name("alphaI")
.dwattr $C$DW$218, DW_AT_type(*$C$DW$T$1719)
.dwattr $C$DW$218, DW_AT_location[DW_OP_breg31 12]
$C$DW$219 .dwtag DW_TAG_formal_parameter, DW_AT_name("betaI")
.dwattr $C$DW$219, DW_AT_TI_symbol_name("betaI")
.dwattr $C$DW$219, DW_AT_type(*$C$DW$T$1719)
.dwattr $C$DW$219, DW_AT_location[DW_OP_breg31 16]
$C$DW$220 .dwtag DW_TAG_formal_parameter, DW_AT_name("gammaI")
.dwattr $C$DW$220, DW_AT_TI_symbol_name("gammaI")
.dwattr $C$DW$220, DW_AT_type(*$C$DW$T$1719)
.dwattr $C$DW$220, DW_AT_location[DW_OP_breg31 20]
;* FUNCTION NAME: adap_emph(short *, const short *, const short *, const short *, const short *, const short *, int, int, const ImageInfo *, int, int, int, int)*
;* Regs Modified : A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,B0,B4,B5,B6,B7,B8,B9, *
;* SP,FP,A16,A17,A18,A19,A20,A21,A22,A23,A24,A25, *
;* A26,A27,A28,A29,A30,A31,B16,B17,B18,B19,B20,B21, *
;* B22,B23,B24,B25,B26,B27 *
;* Regs Used : A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,A10,A12,B0,B3,B4,B5,B6,*
;* B7,B8,B9,B10,SP,FP,A16,A17,A18,A19,A20,A21,A22, *
;* A23,A24,A25,A26,A27,A28,A29,A30,A31,B16,B17,B18, *
;* B19,B20,B21,B22,B23,B24,B25,B26,B27 *
;* Local Frame Size : 0 Args + 0 Auto + 4 Save = 4 byte *
;* Using -g (debug) with optimization (-o3) may disable key optimizations! *
_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii:
; EXCLUSIVE CPU CYCLES: 8
;** 31 ----------------------- adap = adap;
;** 31 ----------------------- lineBufOrig = lineBufOrig;
;** 31 ----------------------- lineBufFilter = lineBufFilter;
;** 31 ----------------------- range = range;
;** 31 ----------------------- wghtTblS = wghtTblS;
;** 31 ----------------------- emphTbl = emphTbl;
;** 36 ----------------------- if ( sx <= 0 ) goto g4;
.dwcfi cfa_offset, 0
MV .L1X SP,FP ; |31|
|| STW .D2T1 FP,*SP--(8) ; |31|
.dwcfi cfa_offset, 8
.dwcfi save_reg_to_mem, 32, 0
$C$DW$221 .dwtag DW_TAG_variable, DW_AT_name("$O$C3")
.dwattr $C$DW$221, DW_AT_TI_symbol_name("$O$C3")
.dwattr $C$DW$221, DW_AT_type(*$C$DW$T$11)
.dwattr $C$DW$221, DW_AT_location[DW_OP_reg3]
$C$DW$222 .dwtag DW_TAG_variable, DW_AT_name("$O$C4")
.dwattr $C$DW$222, DW_AT_TI_symbol_name("$O$C4")
.dwattr $C$DW$222, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$222, DW_AT_location[DW_OP_reg5]
$C$DW$223 .dwtag DW_TAG_variable, DW_AT_name("$O$C5")
.dwattr $C$DW$223, DW_AT_TI_symbol_name("$O$C5")
.dwattr $C$DW$223, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$223, DW_AT_location[DW_OP_reg2]
$C$DW$224 .dwtag DW_TAG_variable, DW_AT_name("$O$C6")
.dwattr $C$DW$224, DW_AT_TI_symbol_name("$O$C6")
.dwattr $C$DW$224, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$224, DW_AT_location[DW_OP_regx 0x26]
$C$DW$225 .dwtag DW_TAG_variable, DW_AT_name("$O$C7")
.dwattr $C$DW$225, DW_AT_TI_symbol_name("$O$C7")
.dwattr $C$DW$225, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$225, DW_AT_location[DW_OP_reg1]
$C$DW$226 .dwtag DW_TAG_variable, DW_AT_name("$O$C8")
.dwattr $C$DW$226, DW_AT_TI_symbol_name("$O$C8")
.dwattr $C$DW$226, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$226, DW_AT_location[DW_OP_regx 0x26]
$C$DW$227 .dwtag DW_TAG_variable, DW_AT_name("$O$C9")
.dwattr $C$DW$227, DW_AT_TI_symbol_name("$O$C9")
.dwattr $C$DW$227, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$227, DW_AT_location[DW_OP_regx 0x40]
$C$DW$228 .dwtag DW_TAG_variable, DW_AT_name("$O$C10")
.dwattr $C$DW$228, DW_AT_TI_symbol_name("$O$C10")
.dwattr $C$DW$228, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$228, DW_AT_location[DW_OP_reg23]
$C$DW$229 .dwtag DW_TAG_variable, DW_AT_name("$O$C11")
.dwattr $C$DW$229, DW_AT_TI_symbol_name("$O$C11")
.dwattr $C$DW$229, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$229, DW_AT_location[DW_OP_regx 0x3f]
$C$DW$230 .dwtag DW_TAG_variable, DW_AT_name("$O$C12")
.dwattr $C$DW$230, DW_AT_TI_symbol_name("$O$C12")
.dwattr $C$DW$230, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$230, DW_AT_location[DW_OP_reg25]
$C$DW$231 .dwtag DW_TAG_variable, DW_AT_name("$O$C13")
.dwattr $C$DW$231, DW_AT_TI_symbol_name("$O$C13")
.dwattr $C$DW$231, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$231, DW_AT_location[DW_OP_regx 0x37]
$C$DW$232 .dwtag DW_TAG_variable, DW_AT_name("$O$C14")
.dwattr $C$DW$232, DW_AT_TI_symbol_name("$O$C14")
.dwattr $C$DW$232, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$232, DW_AT_location[DW_OP_regx 0x36]
$C$DW$233 .dwtag DW_TAG_variable, DW_AT_name("$O$C15")
.dwattr $C$DW$233, DW_AT_TI_symbol_name("$O$C15")
.dwattr $C$DW$233, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$233, DW_AT_location[DW_OP_regx 0x29]
$C$DW$234 .dwtag DW_TAG_variable, DW_AT_name("$O$s32")
.dwattr $C$DW$234, DW_AT_TI_symbol_name("$O$s32")
.dwattr $C$DW$234, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$234, DW_AT_location[DW_OP_reg24]
$C$DW$235 .dwtag DW_TAG_variable, DW_AT_name("$O$s42")
.dwattr $C$DW$235, DW_AT_TI_symbol_name("$O$s42")
.dwattr $C$DW$235, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$235, DW_AT_location[DW_OP_reg4]
$C$DW$236 .dwtag DW_TAG_variable, DW_AT_name("x")
.dwattr $C$DW$236, DW_AT_TI_symbol_name("x")
.dwattr $C$DW$236, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$236, DW_AT_location[DW_OP_regx 0x35]
$C$DW$237 .dwtag DW_TAG_variable, DW_AT_name("gammaI")
.dwattr $C$DW$237, DW_AT_TI_symbol_name("gammaI")
.dwattr $C$DW$237, DW_AT_type(*$C$DW$T$1719)
.dwattr $C$DW$237, DW_AT_location[DW_OP_regx 0x32]
$C$DW$238 .dwtag DW_TAG_variable, DW_AT_name("betaI")
.dwattr $C$DW$238, DW_AT_TI_symbol_name("betaI")
.dwattr $C$DW$238, DW_AT_type(*$C$DW$T$1719)
.dwattr $C$DW$238, DW_AT_location[DW_OP_regx 0x31]
$C$DW$239 .dwtag DW_TAG_variable, DW_AT_name("alphaI")
.dwattr $C$DW$239, DW_AT_TI_symbol_name("alphaI")
.dwattr $C$DW$239, DW_AT_type(*$C$DW$T$1719)
.dwattr $C$DW$239, DW_AT_location[DW_OP_regx 0x30]
$C$DW$240 .dwtag DW_TAG_variable, DW_AT_name("y")
.dwattr $C$DW$240, DW_AT_TI_symbol_name("y")
.dwattr $C$DW$240, DW_AT_type(*$C$DW$T$1719)
.dwattr $C$DW$240, DW_AT_location[DW_OP_reg26]
$C$DW$241 .dwtag DW_TAG_variable, DW_AT_name("sx")
.dwattr $C$DW$241, DW_AT_TI_symbol_name("sx")
.dwattr $C$DW$241, DW_AT_type(*$C$DW$T$1719)
.dwattr $C$DW$241, DW_AT_location[DW_OP_reg10]
$C$DW$242 .dwtag DW_TAG_variable, DW_AT_name("emphTbl")
.dwattr $C$DW$242, DW_AT_TI_symbol_name("emphTbl")
.dwattr $C$DW$242, DW_AT_type(*$C$DW$T$1718)
.dwattr $C$DW$242, DW_AT_location[DW_OP_reg24]
$C$DW$243 .dwtag DW_TAG_variable, DW_AT_name("wghtTblS")
.dwattr $C$DW$243, DW_AT_TI_symbol_name("wghtTblS")
.dwattr $C$DW$243, DW_AT_type(*$C$DW$T$1718)
.dwattr $C$DW$243, DW_AT_location[DW_OP_reg20]
$C$DW$244 .dwtag DW_TAG_variable, DW_AT_name("range")
.dwattr $C$DW$244, DW_AT_TI_symbol_name("range")
.dwattr $C$DW$244, DW_AT_type(*$C$DW$T$1717)
.dwattr $C$DW$244, DW_AT_location[DW_OP_reg21]
$C$DW$245 .dwtag DW_TAG_variable, DW_AT_name("adap")
.dwattr $C$DW$245, DW_AT_TI_symbol_name("adap")
.dwattr $C$DW$245, DW_AT_type(*$C$DW$T$1714)
.dwattr $C$DW$245, DW_AT_location[DW_OP_reg4]
$C$DW$246 .dwtag DW_TAG_variable, DW_AT_name("info")
.dwattr $C$DW$246, DW_AT_TI_symbol_name("info")
.dwattr $C$DW$246, DW_AT_type(*$C$DW$T$1720)
.dwattr $C$DW$246, DW_AT_location[DW_OP_reg12]
$C$DW$247 .dwtag DW_TAG_variable, DW_AT_name("$O$L1")
.dwattr $C$DW$247, DW_AT_TI_symbol_name("$O$L1")
.dwattr $C$DW$247, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$247, DW_AT_location[DW_OP_reg5]
$C$DW$248 .dwtag DW_TAG_variable, DW_AT_name("$O$U81")
.dwattr $C$DW$248, DW_AT_TI_symbol_name("$O$U81")
.dwattr $C$DW$248, DW_AT_type(*$C$DW$T$1740)
.dwattr $C$DW$248, DW_AT_location[DW_OP_reg22]
$C$DW$249 .dwtag DW_TAG_variable, DW_AT_name("$O$K76")
.dwattr $C$DW$249, DW_AT_TI_symbol_name("$O$K76")
.dwattr $C$DW$249, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$249, DW_AT_location[DW_OP_regx 0x2b]
$C$DW$250 .dwtag DW_TAG_variable, DW_AT_name("$O$K57")
.dwattr $C$DW$250, DW_AT_TI_symbol_name("$O$K57")
.dwattr $C$DW$250, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$250, DW_AT_location[DW_OP_reg23]
$C$DW$251 .dwtag DW_TAG_variable, DW_AT_name("$O$U50")
.dwattr $C$DW$251, DW_AT_TI_symbol_name("$O$U50")
.dwattr $C$DW$251, DW_AT_type(*$C$DW$T$1740)
.dwattr $C$DW$251, DW_AT_location[DW_OP_regx 0x3d]
$C$DW$252 .dwtag DW_TAG_variable, DW_AT_name("$O$U63")
.dwattr $C$DW$252, DW_AT_TI_symbol_name("$O$U63")
.dwattr $C$DW$252, DW_AT_type(*$C$DW$T$1740)
.dwattr $C$DW$252, DW_AT_location[DW_OP_reg3]
$C$DW$253 .dwtag DW_TAG_variable, DW_AT_name("$O$U33")
.dwattr $C$DW$253, DW_AT_TI_symbol_name("$O$U33")
.dwattr $C$DW$253, DW_AT_type(*$C$DW$T$11)
.dwattr $C$DW$253, DW_AT_location[DW_OP_regx 0x28]
$C$DW$254 .dwtag DW_TAG_variable, DW_AT_name("$O$K28")
.dwattr $C$DW$254, DW_AT_TI_symbol_name("$O$K28")
.dwattr $C$DW$254, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$254, DW_AT_location[DW_OP_regx 0x27]
CMPGT .L1 A10,0,A0 ; |36|
|| ZERO .L2 B7
|| MVK .S2 8192,B9
|| MV .D2 B6,B5 ; |31|
|| LDW .D1T1 *+FP(4),A27 ; |31|
|| SHR .S1 A10,1,A5
[ A0] LDW .D1T1 *+A12(12),A20
|| [!A0] B .S1 $C$L4 ; |36|
|| ADDAD .D2 B8,B9,B6
|| SET .S2 B7,0xf,0xf,B7
|| SUB .L1 A6,4,A3
|| ZERO .L2 B16 ; |36|
[ A0] LDW .D1T1 *A12,A19
|| MVK .S1 0x3fff,A18
|| SUB .L2 B4,4,B24
|| MV .S2X A8,B4 ; |31|
MVK .S1 0xffffc000,A22
LDW .D1T1 *+FP(8),A28 ; |31|
LDW .D1T1 *+FP(12),A29 ; |31|
ADD .L2X B10,A20,B8
.dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 36,column 23,is_stmt,isa 0
; BRANCHCC OCCURS {$C$L4} ; |36|
; EXCLUSIVE CPU CYCLES: 5
;** ----------------------- K$28 = 16383;
;** ----------------------- C$15 = (*info).margin;
;** ----------------------- U$33 = ((unsigned)C$15+(unsigned)y)*(*info).xSize+(unsigned)C$15;
;** ----------------------- U$50 = &lineBufOrig[-2];
;** ----------------------- K$57 = 32768;
;** ----------------------- U$63 = &lineBufFilter[-2];
;** ----------------------- K$76 = (-16384);
;** ----------------------- U$81 = &emphTbl[32768];
;** ----------------------- L$1 = sx>>1;
;** 36 ----------------------- x = 0;
;** ----------------------- #pragma MUST_ITERATE(8, 436, 1)
;** ----------------------- // LOOP BELOW UNROLLED BY FACTOR(2)
;** ----------------------- #pragma LOOP_FLAGS(4098u)
;** -----------------------g3:
;** 51 ----------------------- C$11 = *(U$50 += 2);
;** 51 ----------------------- C$9 = (int)U$33+x;
;** 51 ----------------------- C$14 = range[C$9];
;** 51 ----------------------- C$13 = _mpy(C$14 >= 0, C$14);
;** 51 ----------------------- C$12 = wghtTblS[((C$13 < K$28) ? C$13 : K$28)];
;** 51 ----------------------- C$10 = ((int)_lo(_mpyli(C$11, alphaI))>>11)*(K$57-C$12)+(int)_lo(_mpyli(C$12, (int)_lo(_mpyli(C$11, betaI))+(int)_lo(_mpyli(*(U$63 += 2), gammaI))>>11))>>15;
;** 51 ----------------------- (C$10 < K$76) ? (s$32 = K$76) : (s$32 = C$10);
;** 51 ----------------------- adap[C$9] = U$81[((s$32 < K$28) ? s$32 : K$28)];
;** 51 ----------------------- C$5 = U$50[1];
;** 51 ----------------------- C$3 = (unsigned)x+U$33+1u;
;** 51 ----------------------- C$8 = range[C$3];
;** 51 ----------------------- C$7 = _mpy(C$8 >= 0, C$8);
;** 51 ----------------------- C$6 = wghtTblS[((C$7 < K$28) ? C$7 : K$28)];
;** 51 ----------------------- C$4 = ((int)_lo(_mpyli(C$5, alphaI))>>11)*(K$57-C$6)+(int)_lo(_mpyli(C$6, (int)_lo(_mpyli(C$5, betaI))+(int)_lo(_mpyli(U$63[1], gammaI))>>11))>>15;
;** 51 ----------------------- (C$4 < K$76) ? (s$42 = K$76) : (s$42 = C$4);
;** 51 ----------------------- adap[C$3] = U$81[((s$42 < K$28) ? s$42 : K$28)];
;** 36 ----------------------- x += 2;
;** 36 ----------------------- if ( L$1 = L$1-1 ) goto g3;
;** -----------------------g4:
;** ----------------------- return;
SUB .L1 A5,1,A21
MPY32 .M1X A19,B8,A19
NOP 3
;* SOFTWARE PIPELINE INFORMATION
;* Loop found in file : ../App/BMode/Integ/src/test_adap_emph.cpp
;* Loop source line : 36
;* Loop opening brace source line : 36
;* Loop closing brace source line : 55
;* Loop Unroll Multiple : 2x
;* Known Minimum Trip Count : 8
;* Known Maximum Trip Count : 436
;* Known Max Trip Count Factor : 1
;* Loop Carried Dependency Bound(^) : 2
;* Unpartitioned Resource Bound : 9
;* Partitioned Resource Bound(*) : 10
;* Resource Partition:
;* A-side B-side
;* .L units 4 4
;* .S units 3 3
;* .D units 6 6
;* .M units 6 6
;* .X cross paths 2 7
;* .T address paths 6 6
;* Long read paths 0 0
;* Long write paths 0 0
;* Logical ops (.LS) 0 1 (.L or .S unit)
;* Addition ops (.LSD) 15 9 (.L or .S or .D unit)
;* Bound(.L .S .LS) 4 4
;* Bound(.L .S .D .LS .LSD) 10* 8
;* Searching for software pipeline schedule at ...
;* ii = 10 no sploop: Dynlen of 70 > 48
;* ii = 10 Schedule found with 5 iterations in parallel
;* Register Usage Table:
;* |AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA|BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB|
;* |00000000001111111111222222222233|00000000001111111111222222222233|
;* |01234567890123456789012345678901|01234567890123456789012345678901|
;* 0: | ** **** ***************|* ***** ********** |
;* 1: |* **** ** ****************| *** ** ********** |
;* 2: |* ***** ** ****************| *** ** *********** |
;* 3: |* **** *** ****************|* ****** ************ |
;* 4: | ******** ****************|* ** * * * ********** |
;* 5: |********** * **************|* ** * * * ********** |
;* 6: | **** ** * * **************| *** ** * ********* |
;* 7: | * * ** * ****************| **** * ********* |
;* 8: |** ** ** * *************** | *** * ** ******** |
;* 9: | ******* ************** | ***** *** ****** * |
;* Done
;* Loop will be splooped
;* Collapsed epilog stages : 0
;* Collapsed prolog stages : 0
;* Minimum required memory pad : 0 bytes
;* Minimum safe trip count : 1 (after unrolling)
;* Min. prof. trip count (est.) : 3 (after unrolling)
;* Mem bank conflicts/iter(est.) : { min 1.000, est 1.250, max 3.000 }
;* Mem bank perf. penalty (est.) : 11.1%
;* Effective ii : { min 11.00, est 11.25, max 13.00 }
;* Total cycles (est.) : 40 + trip_cnt * 10 = Between 120 and 4400
;* SETUP CODE
;* MV A20,B24
;* ADD 6,B24,B24
;* ADD 4,A20,A20
;* MV B25,B23
;* ADD 6,B23,B23
;* ADD 4,B25,B25
;* MV A30,B16
;* MV A26,B4
;* MV A25,B5
;* MV A24,B22
;* MV A18,B20
;* SINGLE SCHEDULED ITERATION
;* $C$C57:
;* 0 ADD .L1 A19,A30,A0 ; |51|
;* 1 ADD .S1 1,A0,A3 ; |51|
;* 2 ADD .D2X B16,A19,B27 ; |51|
;* || LDH .D1T1 *+A25[A3],A17 ; |51|
;* 3 LDH .D2T2 *+B5[B27],B17 ; |51|
;* 4 NOP 1
;* 5 LDH .D2T1 *B23++(4),A31 ; |51|
;* 6 NOP 1
;* 7 LDH .D1T2 *A20++(4),B26 ; |51|
;* || LDH .D2T1 *B24++(4),A2 ; |51|
;* || ADD .S1 2,A30,A30 ; |36| Define a twin register
;* 8 CMPLT .L2 B17,0,B18 ; |51|
;* || LDH .D2T2 *B25++(4),B7 ; |51|
;* 9 MVD .M2 B27,B9 ; |51| Split a long life
;* || XOR .S2 1,B18,B18 ; |51|
;* || CMPLT .L1 A17,0,A7 ; |51|
;* 10 MVD .M1 A3,A6 ; |51| Split a long life
;* || XOR .D1 1,A7,A16 ; |51|
;* 11 MPY .M2 B18,B17,B18 ; |51|
;* || ADD .D2 2,B16,B16 ; |36|
;* 12 MPYLI .M1 A2,A27,A17:A16 ; |51|
;* 13 MPY .M1 A16,A17,A1 ; |51|
;* 14 CMPLT .L2 B18,B20,B0 ; |51|
;* || MPYLI .M2X B26,A28,B7:B6 ; |51|
;* 15 [ B0] MV .L2 B18,B8 ; |51|
;* || [!B0] MV .S2 B20,B8 ; |51|
;* || MPYLI .M2X B7,A29,B9:B8 ; |51|
;* 16 MVD .M2 B9,B19 ; |51| Split a long life
;* || LDH .D2T2 *+B4[B8],B9 ; |51|
;* || MPYLI .M1 A2,A28,A5:A4 ; |51|
;* 17 CMPLT .L1 A1,A18,A0 ; |51|
;* || MPYLI .M1 A31,A29,A7:A6 ; |51|
;* 18 MPYLI .M2X B26,A27,B7:B6 ; |51|
;* || [ A0] MV .D1 A1,A7 ; |51|
;* || [!A0] MV .L1 A18,A7 ; |51|
;* || SHR .S1 A16,11,A8 ; |51|
;* 19 ADD .D2 B8,B6,B6 ; |51|
;* || MVD .M1 A6,A7 ; |51| Split a long life
;* || LDH .D1T1 *+A26[A7],A17 ; |51|
;* 20 NOP 1
;* 21 SUB .L2X A21,B9,B17 ; |51|
;* || SHR .S2 B6,11,B18 ; |51|
;* 22 SHR .S2 B6,11,B6 ; |51|
;* || MPYLI .M2 B9,B18,B7:B6 ; |51|
;* || ADD .L1 A6,A4,A5 ; |51|
;* 23 MPY32 .M2 B17,B6,B7 ; |51|
;* || SHR .S1 A5,11,A16 ; |51|
;* 24 SUB .S1 A21,A17,A16 ; |51|
;* || MPYLI .M1 A17,A16,A5:A4 ; |51|
;* 25 MPY32 .M1 A16,A8,A5 ; |51|
;* 26 NOP 1
;* 27 MVD .M2 B19,B21 ; |51| Split a long life
;* || ADD .L2 B6,B7,B8 ; |51|
;* 28 SHR .S2 B8,15,B7 ; |51|
;* || MVD .M1 A7,A9 ; |51| Split a long life
;* 29 CMPLT .L2X B7,A22,B0 ; |51|
;* || ADD .S1 A4,A5,A6 ; |51|
;* 30 [ B0] MV .S2X A22,B8 ; |51|
;* || [!B0] MV .L2 B7,B8 ; |51|
;* || SHR .S1 A6,15,A5 ; |51|
;* 31 CMPLT .L1 A5,A22,A0 ; |51|
;* 32 CMPLT .L2 B8,B20,B0 ; |51|
;* || [!A0] MV .S1 A5,A4 ; |51|
;* 33 [ B0] MV .D1X B8,A5 ; |51| Define a twin register
;* || [ A0] MV .L1 A22,A4 ; |51|
;* 34 [!B0] MV .D1X B20,A5 ; |51| Define a twin register
;* || CMPLT .L1 A4,A18,A0 ; |51|
;* 35 LDH .D1T2 *+A23[A5],B8 ; |51|
;* || [!A0] MV .S1 A18,A4 ; |51|
;* 36 LDH .D1T1 *+A23[A4],A3 ; |51|
;* 37 NOP 3
;* 40 STH .D2T2 B8,*+B22[B21] ; |51| ^
;* 41 STH .D1T1 A3,*+A24[A9] ; |51| ^
;* || SPBR $C$C57
;* 42 NOP 8
;* 50 ; BRANCHCC OCCURS {$C$C57} ; |36|
$C$L1: ; PIPED LOOP PROLOG
; EXCLUSIVE CPU CYCLES: 41
SPLOOPD 10 ;50 ; (P)
|| MV .L1X B16,A30
|| MVC .S2X A21,ILC
|| ADD .S1 A20,A19,A19
$C$L2: ; PIPED LOOP KERNEL
.dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 36,column 16,is_stmt,isa 0
$C$DW$L$_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii$4$B:
; EXCLUSIVE CPU CYCLES: 10
SPMASK L2
|| ADD .L2X 4,A3,B25
|| ADD .L1 A19,A30,A0 ; |51| (P) <0,0>
SPMASK L1,L2
|| ADD .L2X 6,A3,B23
|| MV .L1X B5,A25
|| ADD .S1 1,A0,A3 ; |51| (P) <0,1>
ADD .D2X B16,A19,B27 ; |51| (P) <0,2>
|| LDH .D1T1 *+A25[A3],A17 ; |51| (P) <0,2>
.dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 51,column 9,is_stmt,isa 0
LDH .D2T2 *+B5[B27],B17 ; |51| (P) <0,3>
NOP 1
LDH .D2T1 *B23++(4),A31 ; |51| (P) <0,5>
SPMASK L1,L2
|| ADD .L1X 4,B24,A20
|| ADD .L2 6,B24,B24
LDH .D1T2 *A20++(4),B26 ; |51| (P) <0,7>
|| LDH .D2T1 *B24++(4),A2 ; |51| (P) <0,7>
|| ADD .S1 2,A30,A30 ; |36| (P) <0,7> Define a twin register
SPMASK L1
|| MV .L1X B7,A21
|| LDH .D2T2 *B25++(4),B7 ; |51| (P) <0,8>
|| CMPLT .L2 B17,0,B18 ; |51| (P) <0,8>
MVD .M2 B27,B9 ; |51| (P) <0,9> Split a long life
|| XOR .S2 1,B18,B18 ; |51| (P) <0,9>
|| CMPLT .L1 A17,0,A7 ; |51| (P) <0,9>
MVD .M1 A3,A6 ; |51| (P) <0,10> Split a long life
|| XOR .D1 1,A7,A16 ; |51| (P) <0,10>
ADD .D2 2,B16,B16 ; |36| (P) <0,11>
|| MPY .M2 B18,B17,B18 ; |51| (P) <0,11>
MPYLI .M1 A2,A27,A17:A16 ; |51| (P) <0,12>
SPMASK L2
|| MV .L2X A18,B20
|| MPY .M1 A16,A17,A1 ; |51| (P) <0,13>
SPMASK L1
|| MV .L1X B6,A23
|| CMPLT .L2 B18,B20,B0 ; |51| (P) <0,14>
|| MPYLI .M2X B26,A28,B7:B6 ; |51| (P) <0,14>
[ B0] MV .L2 B18,B8 ; |51| (P) <0,15>
|| [!B0] MV .S2 B20,B8 ; |51| (P) <0,15>
|| MPYLI .M2X B7,A29,B9:B8 ; |51| (P) <0,15>
SPMASK L1,S1,L2
|| MV .L1X B4,A26
|| MV .L2X A4,B22
|| MV .S1 A4,A24
|| MVD .M2 B9,B19 ; |51| (P) <0,16> Split a long life
|| LDH .D2T2 *+B4[B8],B9 ; |51| (P) <0,16>
|| MPYLI .M1 A2,A28,A5:A4 ; |51| (P) <0,16>
MPYLI .M1 A31,A29,A7:A6 ; |51| (P) <0,17>
|| CMPLT .L1 A1,A18,A0 ; |51| (P) <0,17>
SHR .S1 A16,11,A8 ; |51| (P) <0,18>
|| [!A0] MV .L1 A18,A7 ; |51| (P) <0,18>
|| [ A0] MV .D1 A1,A7 ; |51| (P) <0,18>
|| MPYLI .M2X B26,A27,B7:B6 ; |51| (P) <0,18>
MVD .M1 A6,A7 ; |51| (P) <0,19> Split a long life
|| LDH .D1T1 *+A26[A7],A17 ; |51| (P) <0,19>
|| ADD .D2 B8,B6,B6 ; |51| (P) <0,19>
NOP 1
SHR .S2 B6,11,B18 ; |51| (P) <0,21>
|| SUB .L2X A21,B9,B17 ; |51| (P) <0,21>
SHR .S2 B6,11,B6 ; |51| (P) <0,22>
|| ADD .L1 A6,A4,A5 ; |51| (P) <0,22>
|| MPYLI .M2 B9,B18,B7:B6 ; |51| (P) <0,22>
SHR .S1 A5,11,A16 ; |51| (P) <0,23>
|| MPY32 .M2 B17,B6,B7 ; |51| (P) <0,23>
MPYLI .M1 A17,A16,A5:A4 ; |51| (P) <0,24>
|| SUB .S1 A21,A17,A16 ; |51| (P) <0,24>
MPY32 .M1 A16,A8,A5 ; |51| (P) <0,25>
NOP 1
MVD .M2 B19,B21 ; |51| (P) <0,27> Split a long life
|| ADD .L2 B6,B7,B8 ; |51| (P) <0,27>
MVD .M1 A7,A9 ; |51| (P) <0,28> Split a long life
|| SHR .S2 B8,15,B7 ; |51| (P) <0,28>
ADD .S1 A4,A5,A6 ; |51| (P) <0,29>
|| CMPLT .L2X B7,A22,B0 ; |51| (P) <0,29>
SHR .S1 A6,15,A5 ; |51| (P) <0,30>
|| [!B0] MV .L2 B7,B8 ; |51| (P) <0,30>
|| [ B0] MV .S2X A22,B8 ; |51| (P) <0,30>
CMPLT .L1 A5,A22,A0 ; |51| (P) <0,31>
CMPLT .L2 B8,B20,B0 ; |51| (P) <0,32>
|| [!A0] MV .S1 A5,A4 ; |51| (P) <0,32>
[ A0] MV .L1 A22,A4 ; |51| (P) <0,33>
|| [ B0] MV .D1X B8,A5 ; |51| (P) <0,33> Define a twin register
[!B0] MV .D1X B20,A5 ; |51| (P) <0,34> Define a twin register
|| CMPLT .L1 A4,A18,A0 ; |51| (P) <0,34>
LDH .D1T2 *+A23[A5],B8 ; |51| (P) <0,35>
|| [!A0] MV .S1 A18,A4 ; |51| (P) <0,35>
LDH .D1T1 *+A23[A4],A3 ; |51| (P) <0,36>
NOP 3
STH .D2T2 B8,*+B22[B21] ; |51| <0,40> ^
SPKERNEL 3,0
|| STH .D1T1 A3,*+A24[A9] ; |51| <0,41> ^
$C$DW$L$_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii$4$E:
$C$L3: ; PIPED LOOP EPILOG
; EXCLUSIVE CPU CYCLES: 32
NOP 2
$C$L4:
; EXCLUSIVE CPU CYCLES: 7
MV .L2X FP,SP ; |56|
|| LDW .D1T1 *FP,FP ; |56|
.dwcfi restore_reg, 32
$C$DW$255 .dwtag DW_TAG_TI_branch
.dwattr $C$DW$255, DW_AT_low_pc(0x00)
.dwattr $C$DW$255, DW_AT_TI_return
RETNOP .S2 B3,5
; BRANCH OCCURS {B3}
$C$DW$256 .dwtag DW_TAG_TI_loop
.dwattr $C$DW$256, DW_AT_name("C:\git\phx_main_1\DevProjects\Apollo_DEBUG\test_adap_emph.asm:$C$L2:1:1646116492")
.dwattr $C$DW$256, DW_AT_TI_begin_file("../App/BMode/Integ/src/test_adap_emph.cpp")
.dwattr $C$DW$256, DW_AT_TI_begin_line(0x24)
.dwattr $C$DW$256, DW_AT_TI_end_line(0x37)
$C$DW$257 .dwtag DW_TAG_TI_loop_range
.dwattr $C$DW$257, DW_AT_low_pc($C$DW$L$_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii$4$B)
.dwattr $C$DW$257, DW_AT_high_pc($C$DW$L$_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii$4$E)
.dwendtag $C$DW$256
.dwattr $C$DW$1, DW_AT_TI_end_file("../App/BMode/Integ/src/test_adap_emph.cpp")
.dwattr $C$DW$1, DW_AT_TI_end_line(0x38)
.dwattr $C$DW$1, DW_AT_TI_end_column(0x01)
.dwendentry
.dwendtag $C$DW$1
;* BUILD ATTRIBUTES *
.battr "TI", Tag_File, 1, Tag_Long_Precision_Bits(2)
.battr "TI", Tag_File, 1, Tag_Bitfield_layout(0)
.battr "TI", Tag_File, 1, Tag_ABI_enum_size(2)
.battr "c6xabi", Tag_File, 1, Tag_ABI_wchar_t(1)
.battr "c6xabi", Tag_File, 1, Tag_ABI_array_object_alignment(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_array_object_align_expected(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_PIC(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_PID(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_DSBT(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_stack_align_needed(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_stack_align_preserved(0)
.battr "TI", Tag_File, 1, Tag_Tramps_Use_SOC(1)
;* TYPE INFORMATION *
$C$DW$T$1590 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1590, DW_AT_byte_size(0x04)
$C$DW$258 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_FORMAT_VER"), DW_AT_const_value(0x0b)
.dwattr $C$DW$258, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$258, DW_AT_decl_line(0x1a6)
.dwattr $C$DW$258, DW_AT_decl_column(0x05)
$C$DW$259 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_NUM_COMMANDS"), DW_AT_const_value(0x05)
.dwattr $C$DW$259, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$259, DW_AT_decl_line(0x1aa)
.dwattr $C$DW$259, DW_AT_decl_column(0x05)
$C$DW$260 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_NUM_FOV"), DW_AT_const_value(0x04)
.dwattr $C$DW$260, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$260, DW_AT_decl_line(0x1ab)
.dwattr $C$DW$260, DW_AT_decl_column(0x05)
$C$DW$261 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_NUM_CORE"), DW_AT_const_value(0x08)
.dwattr $C$DW$261, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$261, DW_AT_decl_line(0x1ac)
.dwattr $C$DW$261, DW_AT_decl_column(0x05)
$C$DW$262 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_NUM_SPDATATYPE"), DW_AT_const_value(0x06)
.dwattr $C$DW$262, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$262, DW_AT_decl_line(0x1ad)
.dwattr $C$DW$262, DW_AT_decl_column(0x05)
$C$DW$263 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_NUM_DSP_CORES"), DW_AT_const_value(0x08)
.dwattr $C$DW$263, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$263, DW_AT_decl_line(0x1ae)
.dwattr $C$DW$263, DW_AT_decl_column(0x05)
$C$DW$264 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_NUM_AXIAL_SEGMENTS"), DW_AT_const_value(0x20)
.dwattr $C$DW$264, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$264, DW_AT_decl_line(0x1af)
.dwattr $C$DW$264, DW_AT_decl_column(0x05)
$C$DW$265 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_RESERVED_SIZE"), DW_AT_const_value(0x10)
.dwattr $C$DW$265, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$265, DW_AT_decl_line(0x1b0)
.dwattr $C$DW$265, DW_AT_decl_column(0x05)
$C$DW$266 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_SPCTL_RFBUF_HASHTABLE_SIZE"), DW_AT_const_value(0x20)
.dwattr $C$DW$266, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$266, DW_AT_decl_line(0x1b1)
.dwattr $C$DW$266, DW_AT_decl_column(0x05)
$C$DW$267 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_CMD_PER_SP"), DW_AT_const_value(0x0a)
.dwattr $C$DW$267, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$267, DW_AT_decl_line(0x1b2)
.dwattr $C$DW$267, DW_AT_decl_column(0x05)
$C$DW$268 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_RTHETA_RAYS"), DW_AT_const_value(0x400)
.dwattr $C$DW$268, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$268, DW_AT_decl_line(0x1b7)
.dwattr $C$DW$268, DW_AT_decl_column(0x05)
$C$DW$269 .dwtag DW_TAG_enumerator, DW_AT_name("IMAGE_BE_FILL_HOLE_PTMASK_MAX"), DW_AT_const_value(0x19)
.dwattr $C$DW$269, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$269, DW_AT_decl_line(0x1bb)
.dwattr $C$DW$269, DW_AT_decl_column(0x05)
$C$DW$270 .dwtag DW_TAG_enumerator, DW_AT_name("IMAGE_BE_MAX_LEV"), DW_AT_const_value(0x04)
.dwattr $C$DW$270, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$270, DW_AT_decl_line(0x1bc)
.dwattr $C$DW$270, DW_AT_decl_column(0x05)
$C$DW$271 .dwtag DW_TAG_enumerator, DW_AT_name("IMAGE_BE_MAX_LEV_P1"), DW_AT_const_value(0x05)
.dwattr $C$DW$271, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$271, DW_AT_decl_line(0x1bd)
.dwattr $C$DW$271, DW_AT_decl_column(0x05)
$C$DW$272 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_NEEDLE_VIS_LOOKS"), DW_AT_const_value(0x03)
.dwattr $C$DW$272, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$272, DW_AT_decl_line(0x1be)
.dwattr $C$DW$272, DW_AT_decl_column(0x05)
$C$DW$273 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_MBEAM_LOOKS"), DW_AT_const_value(0x09)
.dwattr $C$DW$273, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$273, DW_AT_decl_line(0x1bf)
.dwattr $C$DW$273, DW_AT_decl_column(0x05)
$C$DW$274 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_MBEAM_TAPER_LENGTH"), DW_AT_const_value(0x10)
.dwattr $C$DW$274, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$274, DW_AT_decl_line(0x1c0)
.dwattr $C$DW$274, DW_AT_decl_column(0x05)
$C$DW$275 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_NUM_CMPD_CORRECTION_FACTOR"), DW_AT_const_value(0x05)
.dwattr $C$DW$275, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$275, DW_AT_decl_line(0x1c1)
.dwattr $C$DW$275, DW_AT_decl_column(0x05)
$C$DW$276 .dwtag DW_TAG_enumerator, DW_AT_name("REMAP_TABLE_SIZE"), DW_AT_const_value(0x400)
.dwattr $C$DW$276, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$276, DW_AT_decl_line(0x1c2)
.dwattr $C$DW$276, DW_AT_decl_column(0x05)
$C$DW$277 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_KERNEL_LENGTH"), DW_AT_const_value(0x19)
.dwattr $C$DW$277, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$277, DW_AT_decl_line(0x1c3)
.dwattr $C$DW$277, DW_AT_decl_column(0x05)
$C$DW$278 .dwtag DW_TAG_enumerator, DW_AT_name("TWOD_MAX_INP_EST_PER_LINE"), DW_AT_const_value(0x368)
.dwattr $C$DW$278, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$278, DW_AT_decl_line(0x1c4)
.dwattr $C$DW$278, DW_AT_decl_column(0x05)
$C$DW$279 .dwtag DW_TAG_enumerator, DW_AT_name("MMODE_ESTIMATES_PER_LINE_MAX"), DW_AT_const_value(0x380)
.dwattr $C$DW$279, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$279, DW_AT_decl_line(0x1d0)
.dwattr $C$DW$279, DW_AT_decl_column(0x05)
$C$DW$280 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_DOPPLER_DISPLAY_WIDTH"), DW_AT_const_value(0x480)
.dwattr $C$DW$280, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$280, DW_AT_decl_line(0x1d4)
.dwattr $C$DW$280, DW_AT_decl_column(0x05)
$C$DW$281 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_DOPPLER_DISPLAY_HEIGHT"), DW_AT_const_value(0x380)
.dwattr $C$DW$281, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$281, DW_AT_decl_line(0x1d5)
.dwattr $C$DW$281, DW_AT_decl_column(0x05)
$C$DW$282 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_FFT_RATE_IN_HZ"), DW_AT_const_value(0x320)
.dwattr $C$DW$282, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$282, DW_AT_decl_line(0x1d6)
.dwattr $C$DW$282, DW_AT_decl_column(0x05)
$C$DW$283 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_MAX_DBELL_RATE"), DW_AT_const_value(0x7d0)
.dwattr $C$DW$283, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$283, DW_AT_decl_line(0x1d7)
.dwattr $C$DW$283, DW_AT_decl_column(0x05)
$C$DW$284 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_SHIFTS_DEFAULT"), DW_AT_const_value(0x00)
.dwattr $C$DW$284, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$284, DW_AT_decl_line(0x1d8)
.dwattr $C$DW$284, DW_AT_decl_column(0x05)
$C$DW$285 .dwtag DW_TAG_enumerator, DW_AT_name("LINE_INTERLEAVE_MIN_COLOR_ENSEMBLE_SIZE"), DW_AT_const_value(0x08)
.dwattr $C$DW$285, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$285, DW_AT_decl_line(0x1d9)
.dwattr $C$DW$285, DW_AT_decl_column(0x05)
$C$DW$286 .dwtag DW_TAG_enumerator, DW_AT_name("LINE_INTERLEAVE_MAX_TOTAL_COLOR_GROUPS"), DW_AT_const_value(0x32)
.dwattr $C$DW$286, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$286, DW_AT_decl_line(0x1da)
.dwattr $C$DW$286, DW_AT_decl_column(0x05)
$C$DW$287 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MAX_GAP_WINDOWS"), DW_AT_const_value(0x02)
.dwattr $C$DW$287, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$287, DW_AT_decl_line(0x1db)
.dwattr $C$DW$287, DW_AT_decl_column(0x05)
$C$DW$288 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MAX_GAP_SIZE_MSEC"), DW_AT_const_value(0x14)
.dwattr $C$DW$288, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$288, DW_AT_decl_line(0x1dc)
.dwattr $C$DW$288, DW_AT_decl_column(0x05)
$C$DW$289 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MAX_NUM_GAP_SAMPLES"), DW_AT_const_value(0x190)
.dwattr $C$DW$289, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$289, DW_AT_decl_line(0x1df)
.dwattr $C$DW$289, DW_AT_decl_column(0x05)
$C$DW$290 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MIN_NUM_GAP_SAMPLES"), DW_AT_const_value(0x08)
.dwattr $C$DW$290, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$290, DW_AT_decl_line(0x1e2)
.dwattr $C$DW$290, DW_AT_decl_column(0x05)
$C$DW$291 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MAX_NUM_INPUT_SAMPLES"), DW_AT_const_value(0x40)
.dwattr $C$DW$291, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$291, DW_AT_decl_line(0x1e3)
.dwattr $C$DW$291, DW_AT_decl_column(0x05)
$C$DW$292 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MIN_NUM_INPUT_SAMPLES"), DW_AT_const_value(0x09)
.dwattr $C$DW$292, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$292, DW_AT_decl_line(0x1e4)
.dwattr $C$DW$292, DW_AT_decl_column(0x05)
$C$DW$293 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MAX_ORDER"), DW_AT_const_value(0x10)
.dwattr $C$DW$293, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$293, DW_AT_decl_line(0x1e5)
.dwattr $C$DW$293, DW_AT_decl_column(0x05)
$C$DW$294 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MIN_ORDER"), DW_AT_const_value(0x08)
.dwattr $C$DW$294, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$294, DW_AT_decl_line(0x1e6)
.dwattr $C$DW$294, DW_AT_decl_column(0x05)
$C$DW$295 .dwtag DW_TAG_enumerator, DW_AT_name("DOP_ENDOFDATA_DFLT_VALUE"), DW_AT_const_value(-1163015426)
.dwattr $C$DW$295, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$295, DW_AT_decl_line(0x1e8)
.dwattr $C$DW$295, DW_AT_decl_column(0x05)
$C$DW$296 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_COLORFLOW_MULTILINES"), DW_AT_const_value(0x04)
.dwattr $C$DW$296, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$296, DW_AT_decl_line(0x1ec)
.dwattr $C$DW$296, DW_AT_decl_column(0x05)
$C$DW$297 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_COLORFLOW_MPFIR_LENGTH"), DW_AT_const_value(0x08)
.dwattr $C$DW$297, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$297, DW_AT_decl_line(0x1ed)
.dwattr $C$DW$297, DW_AT_decl_column(0x05)
$C$DW$298 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_COLORFLOW_ESTIMATES"), DW_AT_const_value(0x368)
.dwattr $C$DW$298, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$298, DW_AT_decl_line(0x1ee)
.dwattr $C$DW$298, DW_AT_decl_column(0x05)
$C$DW$299 .dwtag DW_TAG_enumerator, DW_AT_name("MIN_NUM_LINES_COLOR_SC"), DW_AT_const_value(0x08)
.dwattr $C$DW$299, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$299, DW_AT_decl_line(0x1ef)
.dwattr $C$DW$299, DW_AT_decl_column(0x05)
$C$DW$300 .dwtag DW_TAG_enumerator, DW_AT_name("ECG_DISPLAY_WIDTH"), DW_AT_const_value(0x480)
.dwattr $C$DW$300, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$300, DW_AT_decl_line(0x1f5)
.dwattr $C$DW$300, DW_AT_decl_column(0x05)
$C$DW$301 .dwtag DW_TAG_enumerator, DW_AT_name("ECG_DISPLAY_HEIGHT"), DW_AT_const_value(0x40)
.dwattr $C$DW$301, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$301, DW_AT_decl_line(0x1f6)
.dwattr $C$DW$301, DW_AT_decl_column(0x05)
$C$DW$302 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_ERROR_FILENAME_SIZE"), DW_AT_const_value(0x40)
.dwattr $C$DW$302, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$302, DW_AT_decl_line(0x1fa)
.dwattr $C$DW$302, DW_AT_decl_column(0x05)
$C$DW$303 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SOFT_ERR_HISTORY_SIZE"), DW_AT_const_value(0x10)
.dwattr $C$DW$303, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$303, DW_AT_decl_line(0x1fb)
.dwattr $C$DW$303, DW_AT_decl_column(0x05)
$C$DW$304 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_DEBUG_PRINT_BUFF"), DW_AT_const_value(0x20)
.dwattr $C$DW$304, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$304, DW_AT_decl_line(0x1fc)
.dwattr $C$DW$304, DW_AT_decl_column(0x05)
$C$DW$305 .dwtag DW_TAG_enumerator, DW_AT_name("NUM_MAIN_CTLR_DEBUG_INFO_ENTRY"), DW_AT_const_value(0x0a)
.dwattr $C$DW$305, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$305, DW_AT_decl_line(0x1fd)
.dwattr $C$DW$305, DW_AT_decl_column(0x05)
$C$DW$306 .dwtag DW_TAG_enumerator, DW_AT_name("NUM_HISTORY_LOG_ENTRIES"), DW_AT_const_value(0x20)
.dwattr $C$DW$306, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$306, DW_AT_decl_line(0x1fe)
.dwattr $C$DW$306, DW_AT_decl_column(0x05)
$C$DW$307 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_CINE_PROCESS_QUEUE_ENTRIES"), DW_AT_const_value(0x08)
.dwattr $C$DW$307, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$307, DW_AT_decl_line(0x202)
.dwattr $C$DW$307, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1590
.dwattr $C$DW$T$1590, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1590, DW_AT_decl_line(0x1a3)
.dwattr $C$DW$T$1590, DW_AT_decl_column(0x01)
$C$DW$T$1591 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1591, DW_AT_byte_size(0x04)
$C$DW$308 .dwtag DW_TAG_enumerator, DW_AT_name("PROCESS_COMMAND_START"), DW_AT_const_value(0x01)
.dwattr $C$DW$308, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$308, DW_AT_decl_line(0x33)
.dwattr $C$DW$308, DW_AT_decl_column(0x05)
$C$DW$309 .dwtag DW_TAG_enumerator, DW_AT_name("PROCESS_COMMAND_END"), DW_AT_const_value(0x1f)
.dwattr $C$DW$309, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$309, DW_AT_decl_line(0x34)
.dwattr $C$DW$309, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1591
.dwattr $C$DW$T$1591, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1591, DW_AT_decl_line(0x32)
.dwattr $C$DW$T$1591, DW_AT_decl_column(0x06)
$C$DW$T$130 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$130, DW_AT_name("AMM_Param")
.dwattr $C$DW$T$130, DW_AT_byte_size(0x20)
$C$DW$310 .dwtag DW_TAG_member
.dwattr $C$DW$310, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$310, DW_AT_name("xStart")
.dwattr $C$DW$310, DW_AT_TI_symbol_name("xStart")
.dwattr $C$DW$310, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$310, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$310, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$310, DW_AT_decl_line(0x4c9)
.dwattr $C$DW$310, DW_AT_decl_column(0x05)
$C$DW$311 .dwtag DW_TAG_member
.dwattr $C$DW$311, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$311, DW_AT_name("yStart")
.dwattr $C$DW$311, DW_AT_TI_symbol_name("yStart")
.dwattr $C$DW$311, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$311, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$311, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$311, DW_AT_decl_line(0x4ca)
.dwattr $C$DW$311, DW_AT_decl_column(0x05)
$C$DW$312 .dwtag DW_TAG_member
.dwattr $C$DW$312, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$312, DW_AT_name("xEnd")
.dwattr $C$DW$312, DW_AT_TI_symbol_name("xEnd")
.dwattr $C$DW$312, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$312, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$312, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$312, DW_AT_decl_line(0x4cc)
.dwattr $C$DW$312, DW_AT_decl_column(0x05)
$C$DW$313 .dwtag DW_TAG_member
.dwattr $C$DW$313, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$313, DW_AT_name("yEnd")
.dwattr $C$DW$313, DW_AT_TI_symbol_name("yEnd")
.dwattr $C$DW$313, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$313, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$313, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$313, DW_AT_decl_line(0x4cd)
.dwattr $C$DW$313, DW_AT_decl_column(0x05)
$C$DW$2 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$2, DW_AT_declaration
.dwattr $C$DW$2, DW_AT_TI_symbol_name("_ZN9AMM_ParamaSERKS_")
.dwattr $C$DW$2, DW_AT_type(*$C$DW$T$126)
.dwattr $C$DW$2, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$314 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$314, DW_AT_type(*$C$DW$T$128)
.dwendtag $C$DW$2
.dwendtag $C$DW$T$130
.dwattr $C$DW$T$130, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$130, DW_AT_decl_line(0x4c8)
.dwattr $C$DW$T$130, DW_AT_decl_column(0x01)
$C$DW$T$127 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$127, DW_AT_type(*$C$DW$T$130)
$C$DW$T$128 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$128, DW_AT_type(*$C$DW$T$127)
.dwattr $C$DW$T$128, DW_AT_address_class(0x20)
$C$DW$T$135 .dwtag DW_TAG_typedef, DW_AT_name("AMM_Param")
.dwattr $C$DW$T$135, DW_AT_type(*$C$DW$T$130)
.dwattr $C$DW$T$135, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$135, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$135, DW_AT_decl_line(0x4d0)
.dwattr $C$DW$T$135, DW_AT_decl_column(0x03)
$C$DW$T$126 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$126, DW_AT_type(*$C$DW$T$130)
.dwattr $C$DW$T$126, DW_AT_address_class(0x20)
$C$DW$T$129 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$129, DW_AT_type(*$C$DW$T$126)
.dwattr $C$DW$T$129, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$315 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$315, DW_AT_type(*$C$DW$T$128)
.dwendtag $C$DW$T$129
$C$DW$T$1566 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1566, DW_AT_name("AutoGain_Param")
.dwattr $C$DW$T$1566, DW_AT_byte_size(0x200)
$C$DW$316 .dwtag DW_TAG_member
.dwattr $C$DW$316, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$316, DW_AT_name("refFrameGainDelta")
.dwattr $C$DW$316, DW_AT_TI_symbol_name("refFrameGainDelta")
.dwattr $C$DW$316, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$316, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$316, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$316, DW_AT_decl_line(0x2e2)
.dwattr $C$DW$316, DW_AT_decl_column(0x05)
$C$DW$317 .dwtag DW_TAG_member
.dwattr $C$DW$317, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$317, DW_AT_name("pixelThresholdOffset")
.dwattr $C$DW$317, DW_AT_TI_symbol_name("pixelThresholdOffset")
.dwattr $C$DW$317, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$317, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$317, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$317, DW_AT_decl_line(0x2e3)
.dwattr $C$DW$317, DW_AT_decl_column(0x05)
$C$DW$318 .dwtag DW_TAG_member
.dwattr $C$DW$318, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$318, DW_AT_name("crdApicalCompDepthMm")
.dwattr $C$DW$318, DW_AT_TI_symbol_name("crdApicalCompDepthMm")
.dwattr $C$DW$318, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$318, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$318, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$318, DW_AT_decl_line(0x2e4)
.dwattr $C$DW$318, DW_AT_decl_column(0x05)
$C$DW$319 .dwtag DW_TAG_member
.dwattr $C$DW$319, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$319, DW_AT_name("pixelThresholdLow")
.dwattr $C$DW$319, DW_AT_TI_symbol_name("pixelThresholdLow")
.dwattr $C$DW$319, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$319, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$319, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$319, DW_AT_decl_line(0x2e5)
.dwattr $C$DW$319, DW_AT_decl_column(0x05)
$C$DW$320 .dwtag DW_TAG_member
.dwattr $C$DW$320, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$320, DW_AT_name("pixelThresholdHigh")
.dwattr $C$DW$320, DW_AT_TI_symbol_name("pixelThresholdHigh")
.dwattr $C$DW$320, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$320, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$320, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$320, DW_AT_decl_line(0x2e6)
.dwattr $C$DW$320, DW_AT_decl_column(0x05)
$C$DW$321 .dwtag DW_TAG_member
.dwattr $C$DW$321, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$321, DW_AT_name("lateralLineSkip")
.dwattr $C$DW$321, DW_AT_TI_symbol_name("lateralLineSkip")
.dwattr $C$DW$321, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$321, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$321, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$321, DW_AT_decl_line(0x2e7)
.dwattr $C$DW$321, DW_AT_decl_column(0x05)
$C$DW$322 .dwtag DW_TAG_member
.dwattr $C$DW$322, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$322, DW_AT_name("roiSectionFraction")
.dwattr $C$DW$322, DW_AT_TI_symbol_name("roiSectionFraction")
.dwattr $C$DW$322, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$322, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$322, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$322, DW_AT_decl_line(0x2e8)
.dwattr $C$DW$322, DW_AT_decl_column(0x05)
$C$DW$323 .dwtag DW_TAG_member
.dwattr $C$DW$323, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$323, DW_AT_name("startSampleSkip")
.dwattr $C$DW$323, DW_AT_TI_symbol_name("startSampleSkip")
.dwattr $C$DW$323, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$323, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$323, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$323, DW_AT_decl_line(0x2e9)
.dwattr $C$DW$323, DW_AT_decl_column(0x05)
$C$DW$324 .dwtag DW_TAG_member
.dwattr $C$DW$324, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$324, DW_AT_name("numAxialSegments")
.dwattr $C$DW$324, DW_AT_TI_symbol_name("numAxialSegments")
.dwattr $C$DW$324, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$324, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$324, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$324, DW_AT_decl_line(0x2ea)
.dwattr $C$DW$324, DW_AT_decl_column(0x05)
$C$DW$325 .dwtag DW_TAG_member
.dwattr $C$DW$325, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$325, DW_AT_name("desiredPixelSlope")
.dwattr $C$DW$325, DW_AT_TI_symbol_name("desiredPixelSlope")
.dwattr $C$DW$325, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$325, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$325, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$325, DW_AT_decl_line(0x2eb)
.dwattr $C$DW$325, DW_AT_decl_column(0x05)
$C$DW$326 .dwtag DW_TAG_member
.dwattr $C$DW$326, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$326, DW_AT_name("maxGainCorrectionDb")
.dwattr $C$DW$326, DW_AT_TI_symbol_name("maxGainCorrectionDb")
.dwattr $C$DW$326, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$326, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$326, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$326, DW_AT_decl_line(0x2ec)
.dwattr $C$DW$326, DW_AT_decl_column(0x05)
$C$DW$327 .dwtag DW_TAG_member
.dwattr $C$DW$327, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$327, DW_AT_name("skinlineRolloffDepthMm")
.dwattr $C$DW$327, DW_AT_TI_symbol_name("skinlineRolloffDepthMm")
.dwattr $C$DW$327, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$327, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$327, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$327, DW_AT_decl_line(0x2ed)
.dwattr $C$DW$327, DW_AT_decl_column(0x05)
$C$DW$328 .dwtag DW_TAG_member
.dwattr $C$DW$328, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$328, DW_AT_name("skinlineRolloffDb")
.dwattr $C$DW$328, DW_AT_TI_symbol_name("skinlineRolloffDb")
.dwattr $C$DW$328, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$328, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$328, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$328, DW_AT_decl_line(0x2ee)
.dwattr $C$DW$328, DW_AT_decl_column(0x05)
$C$DW$329 .dwtag DW_TAG_member
.dwattr $C$DW$329, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$329, DW_AT_name("targetMeanPixel")
.dwattr $C$DW$329, DW_AT_TI_symbol_name("targetMeanPixel")
.dwattr $C$DW$329, DW_AT_data_member_location[DW_OP_plus_uconst 0x68]
.dwattr $C$DW$329, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$329, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$329, DW_AT_decl_line(0x2ef)
.dwattr $C$DW$329, DW_AT_decl_column(0x05)
$C$DW$330 .dwtag DW_TAG_member
.dwattr $C$DW$330, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$330, DW_AT_name("actualSegUsed")
.dwattr $C$DW$330, DW_AT_TI_symbol_name("actualSegUsed")
.dwattr $C$DW$330, DW_AT_data_member_location[DW_OP_plus_uconst 0x70]
.dwattr $C$DW$330, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$330, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$330, DW_AT_decl_line(0x2f2)
.dwattr $C$DW$330, DW_AT_decl_column(0x05)
$C$DW$331 .dwtag DW_TAG_member
.dwattr $C$DW$331, DW_AT_type(*$C$DW$T$1561)
.dwattr $C$DW$331, DW_AT_name("depthArrayMm")
.dwattr $C$DW$331, DW_AT_TI_symbol_name("depthArrayMm")
.dwattr $C$DW$331, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$331, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$331, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$331, DW_AT_decl_line(0x2f3)
.dwattr $C$DW$331, DW_AT_decl_column(0x05)
$C$DW$332 .dwtag DW_TAG_member
.dwattr $C$DW$332, DW_AT_type(*$C$DW$T$1561)
.dwattr $C$DW$332, DW_AT_name("depthCurve")
.dwattr $C$DW$332, DW_AT_TI_symbol_name("depthCurve")
.dwattr $C$DW$332, DW_AT_data_member_location[DW_OP_plus_uconst 0xf8]
.dwattr $C$DW$332, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$332, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$332, DW_AT_decl_line(0x2f4)
.dwattr $C$DW$332, DW_AT_decl_column(0x05)
$C$DW$333 .dwtag DW_TAG_member
.dwattr $C$DW$333, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$333, DW_AT_name("meanCorrection")
.dwattr $C$DW$333, DW_AT_TI_symbol_name("meanCorrection")
.dwattr $C$DW$333, DW_AT_data_member_location[DW_OP_plus_uconst 0x178]
.dwattr $C$DW$333, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$333, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$333, DW_AT_decl_line(0x2f5)
.dwattr $C$DW$333, DW_AT_decl_column(0x05)
$C$DW$334 .dwtag DW_TAG_member
.dwattr $C$DW$334, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$334, DW_AT_name("reserved")
.dwattr $C$DW$334, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$334, DW_AT_data_member_location[DW_OP_plus_uconst 0x180]
.dwattr $C$DW$334, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$334, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$334, DW_AT_decl_line(0x2f8)
.dwattr $C$DW$334, DW_AT_decl_column(0x05)
$C$DW$3 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$3, DW_AT_declaration
.dwattr $C$DW$3, DW_AT_TI_symbol_name("_ZN14AutoGain_ParamaSERKS_")
.dwattr $C$DW$3, DW_AT_type(*$C$DW$T$1562)
.dwattr $C$DW$3, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$335 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$335, DW_AT_type(*$C$DW$T$1564)
.dwendtag $C$DW$3
.dwendtag $C$DW$T$1566
.dwattr $C$DW$T$1566, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1566, DW_AT_decl_line(0x2e0)
.dwattr $C$DW$T$1566, DW_AT_decl_column(0x01)
$C$DW$T$1563 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1563, DW_AT_type(*$C$DW$T$1566)
$C$DW$T$1564 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1564, DW_AT_type(*$C$DW$T$1563)
.dwattr $C$DW$T$1564, DW_AT_address_class(0x20)
$C$DW$T$1584 .dwtag DW_TAG_typedef, DW_AT_name("AutoGain_Param")
.dwattr $C$DW$T$1584, DW_AT_type(*$C$DW$T$1566)
.dwattr $C$DW$T$1584, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1584, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1584, DW_AT_decl_line(0x2f9)
.dwattr $C$DW$T$1584, DW_AT_decl_column(0x03)
$C$DW$T$1562 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1562, DW_AT_type(*$C$DW$T$1566)
.dwattr $C$DW$T$1562, DW_AT_address_class(0x20)
$C$DW$T$1565 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1565, DW_AT_type(*$C$DW$T$1562)
.dwattr $C$DW$T$1565, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$336 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$336, DW_AT_type(*$C$DW$T$1564)
.dwendtag $C$DW$T$1565
$C$DW$T$19 .dwtag DW_TAG_class_type
.dwattr $C$DW$T$19, DW_AT_name("BModeFrameBoundary")
.dwattr $C$DW$T$19, DW_AT_declaration
.dwendtag $C$DW$T$19
.dwattr $C$DW$T$19, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/include/ClearVisualization.h")
.dwattr $C$DW$T$19, DW_AT_decl_line(0x6a)
.dwattr $C$DW$T$19, DW_AT_decl_column(0x07)
$C$DW$T$1041 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1041, DW_AT_name("BlackHoleFill_Param")
.dwattr $C$DW$T$1041, DW_AT_byte_size(0x90)
$C$DW$337 .dwtag DW_TAG_member
.dwattr $C$DW$337, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$337, DW_AT_name("axialThreshold")
.dwattr $C$DW$337, DW_AT_TI_symbol_name("axialThreshold")
.dwattr $C$DW$337, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$337, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$337, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$337, DW_AT_decl_line(0x2fd)
.dwattr $C$DW$337, DW_AT_decl_column(0x05)
$C$DW$338 .dwtag DW_TAG_member
.dwattr $C$DW$338, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$338, DW_AT_name("lateralThreshold")
.dwattr $C$DW$338, DW_AT_TI_symbol_name("lateralThreshold")
.dwattr $C$DW$338, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$338, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$338, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$338, DW_AT_decl_line(0x2fe)
.dwattr $C$DW$338, DW_AT_decl_column(0x05)
$C$DW$339 .dwtag DW_TAG_member
.dwattr $C$DW$339, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$339, DW_AT_name("reserved")
.dwattr $C$DW$339, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$339, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$339, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$339, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$339, DW_AT_decl_line(0x2ff)
.dwattr $C$DW$339, DW_AT_decl_column(0x05)
$C$DW$4 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$4, DW_AT_declaration
.dwattr $C$DW$4, DW_AT_TI_symbol_name("_ZN19BlackHoleFill_ParamaSERKS_")
.dwattr $C$DW$4, DW_AT_type(*$C$DW$T$1037)
.dwattr $C$DW$4, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$340 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$340, DW_AT_type(*$C$DW$T$1039)
.dwendtag $C$DW$4
.dwendtag $C$DW$T$1041
.dwattr $C$DW$T$1041, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1041, DW_AT_decl_line(0x2fc)
.dwattr $C$DW$T$1041, DW_AT_decl_column(0x01)
$C$DW$T$1038 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1038, DW_AT_type(*$C$DW$T$1041)
$C$DW$T$1039 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1039, DW_AT_type(*$C$DW$T$1038)
.dwattr $C$DW$T$1039, DW_AT_address_class(0x20)
$C$DW$T$1582 .dwtag DW_TAG_typedef, DW_AT_name("BlackHoleFill_Param")
.dwattr $C$DW$T$1582, DW_AT_type(*$C$DW$T$1041)
.dwattr $C$DW$T$1582, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1582, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1582, DW_AT_decl_line(0x300)
.dwattr $C$DW$T$1582, DW_AT_decl_column(0x03)
$C$DW$T$1037 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1037, DW_AT_type(*$C$DW$T$1041)
.dwattr $C$DW$T$1037, DW_AT_address_class(0x20)
$C$DW$T$1040 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1040, DW_AT_type(*$C$DW$T$1037)
.dwattr $C$DW$T$1040, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$341 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$341, DW_AT_type(*$C$DW$T$1039)
.dwendtag $C$DW$T$1040
$C$DW$T$1490 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1490, DW_AT_name("BspFilterParam")
.dwattr $C$DW$T$1490, DW_AT_byte_size(0x14)
$C$DW$342 .dwtag DW_TAG_member
.dwattr $C$DW$342, DW_AT_type(*$C$DW$T$1485)
.dwattr $C$DW$342, DW_AT_name("coef")
.dwattr $C$DW$342, DW_AT_TI_symbol_name("coef")
.dwattr $C$DW$342, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$342, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$342, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$342, DW_AT_decl_line(0x73)
.dwattr $C$DW$342, DW_AT_decl_column(0x07)
$C$DW$343 .dwtag DW_TAG_member
.dwattr $C$DW$343, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$343, DW_AT_name("accuracyBits")
.dwattr $C$DW$343, DW_AT_TI_symbol_name("accuracyBits")
.dwattr $C$DW$343, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$343, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$343, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$343, DW_AT_decl_line(0x74)
.dwattr $C$DW$343, DW_AT_decl_column(0x07)
$C$DW$5 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$5, DW_AT_declaration
.dwattr $C$DW$5, DW_AT_TI_symbol_name("_ZN14BspFilterParamaSERKS_")
.dwattr $C$DW$5, DW_AT_type(*$C$DW$T$1486)
.dwattr $C$DW$5, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$344 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$344, DW_AT_type(*$C$DW$T$1488)
.dwendtag $C$DW$5
.dwendtag $C$DW$T$1490
.dwattr $C$DW$T$1490, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$T$1490, DW_AT_decl_line(0x71)
.dwattr $C$DW$T$1490, DW_AT_decl_column(0x08)
$C$DW$T$1487 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1487, DW_AT_type(*$C$DW$T$1490)
$C$DW$T$1488 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1488, DW_AT_type(*$C$DW$T$1487)
.dwattr $C$DW$T$1488, DW_AT_address_class(0x20)
$C$DW$T$1486 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1486, DW_AT_type(*$C$DW$T$1490)
.dwattr $C$DW$T$1486, DW_AT_address_class(0x20)
$C$DW$T$1489 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1489, DW_AT_type(*$C$DW$T$1486)
.dwattr $C$DW$T$1489, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$345 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$345, DW_AT_type(*$C$DW$T$1488)
.dwendtag $C$DW$T$1489
$C$DW$T$124 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$124, DW_AT_name("CBufferMgr_Buffer")
.dwattr $C$DW$T$124, DW_AT_byte_size(0x20)
$C$DW$346 .dwtag DW_TAG_member
.dwattr $C$DW$346, DW_AT_type(*$C$DW$T$105)
.dwattr $C$DW$346, DW_AT_name("storage")
.dwattr $C$DW$346, DW_AT_TI_symbol_name("storage")
.dwattr $C$DW$346, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$346, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$346, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$346, DW_AT_decl_line(0x2d)
.dwattr $C$DW$346, DW_AT_decl_column(0x05)
$C$DW$347 .dwtag DW_TAG_member
.dwattr $C$DW$347, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$347, DW_AT_name("packetSize")
.dwattr $C$DW$347, DW_AT_TI_symbol_name("packetSize")
.dwattr $C$DW$347, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$347, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$347, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$347, DW_AT_decl_line(0x2e)
.dwattr $C$DW$347, DW_AT_decl_column(0x0c)
$C$DW$348 .dwtag DW_TAG_member
.dwattr $C$DW$348, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$348, DW_AT_name("packetStride")
.dwattr $C$DW$348, DW_AT_TI_symbol_name("packetStride")
.dwattr $C$DW$348, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$348, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$348, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$348, DW_AT_decl_line(0x2f)
.dwattr $C$DW$348, DW_AT_decl_column(0x0c)
$C$DW$349 .dwtag DW_TAG_member
.dwattr $C$DW$349, DW_AT_type(*$C$DW$T$113)
.dwattr $C$DW$349, DW_AT_name("numPackets")
.dwattr $C$DW$349, DW_AT_TI_symbol_name("numPackets")
.dwattr $C$DW$349, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$349, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$349, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$349, DW_AT_decl_line(0x31)
.dwattr $C$DW$349, DW_AT_decl_column(0x0c)
$C$DW$350 .dwtag DW_TAG_member
.dwattr $C$DW$350, DW_AT_type(*$C$DW$T$113)
.dwattr $C$DW$350, DW_AT_name("count")
.dwattr $C$DW$350, DW_AT_TI_symbol_name("count")
.dwattr $C$DW$350, DW_AT_data_member_location[DW_OP_plus_uconst 0xe]
.dwattr $C$DW$350, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$350, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$350, DW_AT_decl_line(0x32)
.dwattr $C$DW$350, DW_AT_decl_column(0x0c)
$C$DW$351 .dwtag DW_TAG_member
.dwattr $C$DW$351, DW_AT_type(*$C$DW$T$113)
.dwattr $C$DW$351, DW_AT_name("numCompletedPackets")
.dwattr $C$DW$351, DW_AT_TI_symbol_name("numCompletedPackets")
.dwattr $C$DW$351, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$351, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$351, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$351, DW_AT_decl_line(0x33)
.dwattr $C$DW$351, DW_AT_decl_column(0x0c)
$C$DW$352 .dwtag DW_TAG_member
.dwattr $C$DW$352, DW_AT_type(*$C$DW$T$113)
.dwattr $C$DW$352, DW_AT_name("readIndex")
.dwattr $C$DW$352, DW_AT_TI_symbol_name("readIndex")
.dwattr $C$DW$352, DW_AT_data_member_location[DW_OP_plus_uconst 0x12]
.dwattr $C$DW$352, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$352, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$352, DW_AT_decl_line(0x34)
.dwattr $C$DW$352, DW_AT_decl_column(0x0c)
$C$DW$353 .dwtag DW_TAG_member
.dwattr $C$DW$353, DW_AT_type(*$C$DW$T$113)
.dwattr $C$DW$353, DW_AT_name("writeIndex")
.dwattr $C$DW$353, DW_AT_TI_symbol_name("writeIndex")
.dwattr $C$DW$353, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$353, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$353, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$353, DW_AT_decl_line(0x35)
.dwattr $C$DW$353, DW_AT_decl_column(0x0c)
$C$DW$354 .dwtag DW_TAG_member
.dwattr $C$DW$354, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$354, DW_AT_name("wrapCount")
.dwattr $C$DW$354, DW_AT_TI_symbol_name("wrapCount")
.dwattr $C$DW$354, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$354, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$354, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$354, DW_AT_decl_line(0x37)
.dwattr $C$DW$354, DW_AT_decl_column(0x09)
$C$DW$355 .dwtag DW_TAG_member
.dwattr $C$DW$355, DW_AT_type(*$C$DW$T$119)
.dwattr $C$DW$355, DW_AT_name("storageClass")
.dwattr $C$DW$355, DW_AT_TI_symbol_name("storageClass")
.dwattr $C$DW$355, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c]
.dwattr $C$DW$355, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$355, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$355, DW_AT_decl_line(0x38)
.dwattr $C$DW$355, DW_AT_decl_column(0x17)
$C$DW$6 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$6, DW_AT_declaration
.dwattr $C$DW$6, DW_AT_TI_symbol_name("_ZN17CBufferMgr_BufferaSERKS_")
.dwattr $C$DW$6, DW_AT_type(*$C$DW$T$120)
.dwattr $C$DW$6, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$356 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$356, DW_AT_type(*$C$DW$T$122)
.dwendtag $C$DW$6
.dwendtag $C$DW$T$124
.dwattr $C$DW$T$124, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$T$124, DW_AT_decl_line(0x2b)
.dwattr $C$DW$T$124, DW_AT_decl_column(0x01)
$C$DW$T$121 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$121, DW_AT_type(*$C$DW$T$124)
$C$DW$T$122 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$122, DW_AT_type(*$C$DW$T$121)
.dwattr $C$DW$T$122, DW_AT_address_class(0x20)
$C$DW$T$499 .dwtag DW_TAG_typedef, DW_AT_name("CBufferMgr_Buffer")
.dwattr $C$DW$T$499, DW_AT_type(*$C$DW$T$124)
.dwattr $C$DW$T$499, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$499, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$T$499, DW_AT_decl_line(0x3a)
.dwattr $C$DW$T$499, DW_AT_decl_column(0x03)
$C$DW$T$500 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$500, DW_AT_type(*$C$DW$T$499)
.dwattr $C$DW$T$500, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$500, DW_AT_byte_size(0x40)
$C$DW$357 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$357, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$500
$C$DW$T$521 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$521, DW_AT_type(*$C$DW$T$499)
.dwattr $C$DW$T$521, DW_AT_address_class(0x20)
$C$DW$T$522 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$522, DW_AT_type(*$C$DW$T$521)
.dwattr $C$DW$T$522, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$522, DW_AT_byte_size(0x08)
$C$DW$358 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$358, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$522
$C$DW$T$120 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$120, DW_AT_type(*$C$DW$T$124)
.dwattr $C$DW$T$120, DW_AT_address_class(0x20)
$C$DW$T$123 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$123, DW_AT_type(*$C$DW$T$120)
.dwattr $C$DW$T$123, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$359 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$359, DW_AT_type(*$C$DW$T$122)
.dwendtag $C$DW$T$123
$C$DW$T$1592 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1592, DW_AT_name("CBufferMgr_CacheWbInvEnum")
.dwattr $C$DW$T$1592, DW_AT_byte_size(0x04)
$C$DW$360 .dwtag DW_TAG_enumerator, DW_AT_name("CBUFFERMGR_CACHE_WB_INVALIDATE"), DW_AT_const_value(0x00)
.dwattr $C$DW$360, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$360, DW_AT_decl_line(0xec)
.dwattr $C$DW$360, DW_AT_decl_column(0x05)
$C$DW$361 .dwtag DW_TAG_enumerator, DW_AT_name("CBUFFERMGR_CACHE_INVALIDATE"), DW_AT_const_value(0x01)
.dwattr $C$DW$361, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$361, DW_AT_decl_line(0xed)
.dwattr $C$DW$361, DW_AT_decl_column(0x05)
$C$DW$362 .dwtag DW_TAG_enumerator, DW_AT_name("CBUFFERMGR_CACHE_WB"), DW_AT_const_value(0x02)
.dwattr $C$DW$362, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$362, DW_AT_decl_line(0xee)
.dwattr $C$DW$362, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1592
.dwattr $C$DW$T$1592, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$T$1592, DW_AT_decl_line(0xeb)
.dwattr $C$DW$T$1592, DW_AT_decl_column(0x0e)
$C$DW$T$1593 .dwtag DW_TAG_typedef, DW_AT_name("CBufferMgr_CacheWbInvEnum")
.dwattr $C$DW$T$1593, DW_AT_type(*$C$DW$T$1592)
.dwattr $C$DW$T$1593, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1593, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$T$1593, DW_AT_decl_line(0xef)
.dwattr $C$DW$T$1593, DW_AT_decl_column(0x03)
$C$DW$T$1596 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1596, DW_AT_name("CSL_OpenMode")
.dwattr $C$DW$T$1596, DW_AT_byte_size(0x04)
$C$DW$363 .dwtag DW_TAG_enumerator, DW_AT_name("CSL_EXCLUSIVE"), DW_AT_const_value(0x00)
.dwattr $C$DW$363, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$363, DW_AT_decl_line(0x4a)
.dwattr $C$DW$363, DW_AT_decl_column(0x03)
$C$DW$364 .dwtag DW_TAG_enumerator, DW_AT_name("CSL_SHARED"), DW_AT_const_value(0x01)
.dwattr $C$DW$364, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$364, DW_AT_decl_line(0x4b)
.dwattr $C$DW$364, DW_AT_decl_column(0x03)
.dwendtag $C$DW$T$1596
.dwattr $C$DW$T$1596, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1596, DW_AT_decl_line(0x49)
.dwattr $C$DW$T$1596, DW_AT_decl_column(0x0e)
$C$DW$T$1597 .dwtag DW_TAG_typedef, DW_AT_name("CSL_OpenMode")
.dwattr $C$DW$T$1597, DW_AT_type(*$C$DW$T$1596)
.dwattr $C$DW$T$1597, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1597, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1597, DW_AT_decl_line(0x4c)
.dwattr $C$DW$T$1597, DW_AT_decl_column(0x03)
$C$DW$T$1598 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1598, DW_AT_name("CSL_Test")
.dwattr $C$DW$T$1598, DW_AT_byte_size(0x04)
$C$DW$365 .dwtag DW_TAG_enumerator, DW_AT_name("CSL_FAIL"), DW_AT_const_value(0x00)
.dwattr $C$DW$365, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$365, DW_AT_decl_line(0x4f)
.dwattr $C$DW$365, DW_AT_decl_column(0x03)
$C$DW$366 .dwtag DW_TAG_enumerator, DW_AT_name("CSL_PASS"), DW_AT_const_value(0x01)
.dwattr $C$DW$366, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$366, DW_AT_decl_line(0x50)
.dwattr $C$DW$366, DW_AT_decl_column(0x03)
.dwendtag $C$DW$T$1598
.dwattr $C$DW$T$1598, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1598, DW_AT_decl_line(0x4e)
.dwattr $C$DW$T$1598, DW_AT_decl_column(0x0e)
$C$DW$T$1599 .dwtag DW_TAG_typedef, DW_AT_name("CSL_Test")
.dwattr $C$DW$T$1599, DW_AT_type(*$C$DW$T$1598)
.dwattr $C$DW$T$1599, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1599, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1599, DW_AT_decl_line(0x51)
.dwattr $C$DW$T$1599, DW_AT_decl_column(0x03)
$C$DW$T$212 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$212, DW_AT_name("CVizBase_Param")
.dwattr $C$DW$T$212, DW_AT_byte_size(0xc18)
$C$DW$367 .dwtag DW_TAG_member
.dwattr $C$DW$367, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$367, DW_AT_name("baseId")
.dwattr $C$DW$367, DW_AT_TI_symbol_name("baseId")
.dwattr $C$DW$367, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$367, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$367, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$367, DW_AT_decl_line(0x37f)
.dwattr $C$DW$367, DW_AT_decl_column(0x05)
$C$DW$368 .dwtag DW_TAG_member
.dwattr $C$DW$368, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$368, DW_AT_name("enabled")
.dwattr $C$DW$368, DW_AT_TI_symbol_name("enabled")
.dwattr $C$DW$368, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$368, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$368, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$368, DW_AT_decl_line(0x380)
.dwattr $C$DW$368, DW_AT_decl_column(0x05)
$C$DW$369 .dwtag DW_TAG_member
.dwattr $C$DW$369, DW_AT_type(*$C$DW$T$195)
.dwattr $C$DW$369, DW_AT_name("resolution")
.dwattr $C$DW$369, DW_AT_TI_symbol_name("resolution")
.dwattr $C$DW$369, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$369, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$369, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$369, DW_AT_decl_line(0x381)
.dwattr $C$DW$369, DW_AT_decl_column(0x05)
$C$DW$370 .dwtag DW_TAG_member
.dwattr $C$DW$370, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$370, DW_AT_name("dBRange")
.dwattr $C$DW$370, DW_AT_TI_symbol_name("dBRange")
.dwattr $C$DW$370, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0]
.dwattr $C$DW$370, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$370, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$370, DW_AT_decl_line(0x382)
.dwattr $C$DW$370, DW_AT_decl_column(0x05)
$C$DW$371 .dwtag DW_TAG_member
.dwattr $C$DW$371, DW_AT_type(*$C$DW$T$196)
.dwattr $C$DW$371, DW_AT_name("fill")
.dwattr $C$DW$371, DW_AT_TI_symbol_name("fill")
.dwattr $C$DW$371, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8]
.dwattr $C$DW$371, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$371, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$371, DW_AT_decl_line(0x383)
.dwattr $C$DW$371, DW_AT_decl_column(0x05)
$C$DW$372 .dwtag DW_TAG_member
.dwattr $C$DW$372, DW_AT_type(*$C$DW$T$197)
.dwattr $C$DW$372, DW_AT_name("gaussian")
.dwattr $C$DW$372, DW_AT_TI_symbol_name("gaussian")
.dwattr $C$DW$372, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c8]
.dwattr $C$DW$372, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$372, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$372, DW_AT_decl_line(0x384)
.dwattr $C$DW$372, DW_AT_decl_column(0x05)
$C$DW$373 .dwtag DW_TAG_member
.dwattr $C$DW$373, DW_AT_type(*$C$DW$T$198)
.dwattr $C$DW$373, DW_AT_name("edgeDetection")
.dwattr $C$DW$373, DW_AT_TI_symbol_name("edgeDetection")
.dwattr $C$DW$373, DW_AT_data_member_location[DW_OP_plus_uconst 0x258]
.dwattr $C$DW$373, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$373, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$373, DW_AT_decl_line(0x385)
.dwattr $C$DW$373, DW_AT_decl_column(0x05)
$C$DW$374 .dwtag DW_TAG_member
.dwattr $C$DW$374, DW_AT_type(*$C$DW$T$199)
.dwattr $C$DW$374, DW_AT_name("edgeDirection")
.dwattr $C$DW$374, DW_AT_TI_symbol_name("edgeDirection")
.dwattr $C$DW$374, DW_AT_data_member_location[DW_OP_plus_uconst 0x370]
.dwattr $C$DW$374, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$374, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$374, DW_AT_decl_line(0x386)
.dwattr $C$DW$374, DW_AT_decl_column(0x05)
$C$DW$375 .dwtag DW_TAG_member
.dwattr $C$DW$375, DW_AT_type(*$C$DW$T$200)
.dwattr $C$DW$375, DW_AT_name("edgeReliability")
.dwattr $C$DW$375, DW_AT_TI_symbol_name("edgeReliability")
.dwattr $C$DW$375, DW_AT_data_member_location[DW_OP_plus_uconst 0x488]
.dwattr $C$DW$375, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$375, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$375, DW_AT_decl_line(0x387)
.dwattr $C$DW$375, DW_AT_decl_column(0x05)
$C$DW$376 .dwtag DW_TAG_member
.dwattr $C$DW$376, DW_AT_type(*$C$DW$T$201)
.dwattr $C$DW$376, DW_AT_name("emphasis")
.dwattr $C$DW$376, DW_AT_TI_symbol_name("emphasis")
.dwattr $C$DW$376, DW_AT_data_member_location[DW_OP_plus_uconst 0x538]
.dwattr $C$DW$376, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$376, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$376, DW_AT_decl_line(0x388)
.dwattr $C$DW$376, DW_AT_decl_column(0x05)
$C$DW$377 .dwtag DW_TAG_member
.dwattr $C$DW$377, DW_AT_type(*$C$DW$T$202)
.dwattr $C$DW$377, DW_AT_name("directionFilter")
.dwattr $C$DW$377, DW_AT_TI_symbol_name("directionFilter")
.dwattr $C$DW$377, DW_AT_data_member_location[DW_OP_plus_uconst 0x678]
.dwattr $C$DW$377, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$377, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$377, DW_AT_decl_line(0x389)
.dwattr $C$DW$377, DW_AT_decl_column(0x05)
$C$DW$378 .dwtag DW_TAG_member
.dwattr $C$DW$378, DW_AT_type(*$C$DW$T$203)
.dwattr $C$DW$378, DW_AT_name("nepS")
.dwattr $C$DW$378, DW_AT_TI_symbol_name("nepS")
.dwattr $C$DW$378, DW_AT_data_member_location[DW_OP_plus_uconst 0x770]
.dwattr $C$DW$378, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$378, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$378, DW_AT_decl_line(0x38a)
.dwattr $C$DW$378, DW_AT_decl_column(0x05)
$C$DW$379 .dwtag DW_TAG_member
.dwattr $C$DW$379, DW_AT_type(*$C$DW$T$201)
.dwattr $C$DW$379, DW_AT_name("emphasis2")
.dwattr $C$DW$379, DW_AT_TI_symbol_name("emphasis2")
.dwattr $C$DW$379, DW_AT_data_member_location[DW_OP_plus_uconst 0x898]
.dwattr $C$DW$379, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$379, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$379, DW_AT_decl_line(0x38b)
.dwattr $C$DW$379, DW_AT_decl_column(0x05)
$C$DW$380 .dwtag DW_TAG_member
.dwattr $C$DW$380, DW_AT_type(*$C$DW$T$204)
.dwattr $C$DW$380, DW_AT_name("path")
.dwattr $C$DW$380, DW_AT_TI_symbol_name("path")
.dwattr $C$DW$380, DW_AT_data_member_location[DW_OP_plus_uconst 0x9d8]
.dwattr $C$DW$380, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$380, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$380, DW_AT_decl_line(0x38c)
.dwattr $C$DW$380, DW_AT_decl_column(0x05)
$C$DW$381 .dwtag DW_TAG_member
.dwattr $C$DW$381, DW_AT_type(*$C$DW$T$205)
.dwattr $C$DW$381, DW_AT_name("ftc")
.dwattr $C$DW$381, DW_AT_TI_symbol_name("ftc")
.dwattr $C$DW$381, DW_AT_data_member_location[DW_OP_plus_uconst 0xa68]
.dwattr $C$DW$381, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$381, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$381, DW_AT_decl_line(0x38d)
.dwattr $C$DW$381, DW_AT_decl_column(0x05)
$C$DW$382 .dwtag DW_TAG_member
.dwattr $C$DW$382, DW_AT_type(*$C$DW$T$206)
.dwattr $C$DW$382, DW_AT_name("lineThin")
.dwattr $C$DW$382, DW_AT_TI_symbol_name("lineThin")
.dwattr $C$DW$382, DW_AT_data_member_location[DW_OP_plus_uconst 0xb18]
.dwattr $C$DW$382, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$382, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$382, DW_AT_decl_line(0x38e)
.dwattr $C$DW$382, DW_AT_decl_column(0x05)
$C$DW$383 .dwtag DW_TAG_member
.dwattr $C$DW$383, DW_AT_type(*$C$DW$T$207)
.dwattr $C$DW$383, DW_AT_name("dummy")
.dwattr $C$DW$383, DW_AT_TI_symbol_name("dummy")
.dwattr $C$DW$383, DW_AT_data_member_location[DW_OP_plus_uconst 0xbb8]
.dwattr $C$DW$383, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$383, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$383, DW_AT_decl_line(0x38f)
.dwattr $C$DW$383, DW_AT_decl_column(0x05)
$C$DW$7 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$7, DW_AT_declaration
.dwattr $C$DW$7, DW_AT_TI_symbol_name("_ZN14CVizBase_ParamaSERKS_")
.dwattr $C$DW$7, DW_AT_type(*$C$DW$T$208)
.dwattr $C$DW$7, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$384 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$384, DW_AT_type(*$C$DW$T$210)
.dwendtag $C$DW$7
.dwendtag $C$DW$T$212
.dwattr $C$DW$T$212, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$212, DW_AT_decl_line(0x37e)
.dwattr $C$DW$T$212, DW_AT_decl_column(0x10)
$C$DW$T$209 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$209, DW_AT_type(*$C$DW$T$212)
$C$DW$T$210 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$210, DW_AT_type(*$C$DW$T$209)
.dwattr $C$DW$T$210, DW_AT_address_class(0x20)
$C$DW$T$1202 .dwtag DW_TAG_typedef, DW_AT_name("CVizBase_Param")
.dwattr $C$DW$T$1202, DW_AT_type(*$C$DW$T$212)
.dwattr $C$DW$T$1202, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1202, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1202, DW_AT_decl_line(0x390)
.dwattr $C$DW$T$1202, DW_AT_decl_column(0x03)
$C$DW$T$208 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$208, DW_AT_type(*$C$DW$T$212)
.dwattr $C$DW$T$208, DW_AT_address_class(0x20)
$C$DW$T$211 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$211, DW_AT_type(*$C$DW$T$208)
.dwattr $C$DW$T$211, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$385 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$385, DW_AT_type(*$C$DW$T$210)
.dwendtag $C$DW$T$211
$C$DW$T$225 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$225, DW_AT_name("CVizUser_Param")
.dwattr $C$DW$T$225, DW_AT_byte_size(0x440)
$C$DW$386 .dwtag DW_TAG_member
.dwattr $C$DW$386, DW_AT_type(*$C$DW$T$213)
.dwattr $C$DW$386, DW_AT_name("speckleReduction")
.dwattr $C$DW$386, DW_AT_TI_symbol_name("speckleReduction")
.dwattr $C$DW$386, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$386, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$386, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$386, DW_AT_decl_line(0x3c5)
.dwattr $C$DW$386, DW_AT_decl_column(0x05)
$C$DW$387 .dwtag DW_TAG_member
.dwattr $C$DW$387, DW_AT_type(*$C$DW$T$214)
.dwattr $C$DW$387, DW_AT_name("edgeEnhance")
.dwattr $C$DW$387, DW_AT_TI_symbol_name("edgeEnhance")
.dwattr $C$DW$387, DW_AT_data_member_location[DW_OP_plus_uconst 0x88]
.dwattr $C$DW$387, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$387, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$387, DW_AT_decl_line(0x3c6)
.dwattr $C$DW$387, DW_AT_decl_column(0x05)
$C$DW$388 .dwtag DW_TAG_member
.dwattr $C$DW$388, DW_AT_type(*$C$DW$T$215)
.dwattr $C$DW$388, DW_AT_name("sharpness")
.dwattr $C$DW$388, DW_AT_TI_symbol_name("sharpness")
.dwattr $C$DW$388, DW_AT_data_member_location[DW_OP_plus_uconst 0x118]
.dwattr $C$DW$388, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$388, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$388, DW_AT_decl_line(0x3c7)
.dwattr $C$DW$388, DW_AT_decl_column(0x05)
$C$DW$389 .dwtag DW_TAG_member
.dwattr $C$DW$389, DW_AT_type(*$C$DW$T$216)
.dwattr $C$DW$389, DW_AT_name("blackSpotFill")
.dwattr $C$DW$389, DW_AT_TI_symbol_name("blackSpotFill")
.dwattr $C$DW$389, DW_AT_data_member_location[DW_OP_plus_uconst 0x1b0]
.dwattr $C$DW$389, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$389, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$389, DW_AT_decl_line(0x3c8)
.dwattr $C$DW$389, DW_AT_decl_column(0x05)
$C$DW$390 .dwtag DW_TAG_member
.dwattr $C$DW$390, DW_AT_type(*$C$DW$T$217)
.dwattr $C$DW$390, DW_AT_name("lineThinning")
.dwattr $C$DW$390, DW_AT_TI_symbol_name("lineThinning")
.dwattr $C$DW$390, DW_AT_data_member_location[DW_OP_plus_uconst 0x240]
.dwattr $C$DW$390, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$390, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$390, DW_AT_decl_line(0x3c9)
.dwattr $C$DW$390, DW_AT_decl_column(0x05)
$C$DW$391 .dwtag DW_TAG_member
.dwattr $C$DW$391, DW_AT_type(*$C$DW$T$218)
.dwattr $C$DW$391, DW_AT_name("edgeThreshold")
.dwattr $C$DW$391, DW_AT_TI_symbol_name("edgeThreshold")
.dwattr $C$DW$391, DW_AT_data_member_location[DW_OP_plus_uconst 0x2d0]
.dwattr $C$DW$391, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$391, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$391, DW_AT_decl_line(0x3ca)
.dwattr $C$DW$391, DW_AT_decl_column(0x05)
$C$DW$392 .dwtag DW_TAG_member
.dwattr $C$DW$392, DW_AT_type(*$C$DW$T$219)
.dwattr $C$DW$392, DW_AT_name("hContrast")
.dwattr $C$DW$392, DW_AT_TI_symbol_name("hContrast")
.dwattr $C$DW$392, DW_AT_data_member_location[DW_OP_plus_uconst 0x370]
.dwattr $C$DW$392, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$392, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$392, DW_AT_decl_line(0x3cb)
.dwattr $C$DW$392, DW_AT_decl_column(0x05)
$C$DW$393 .dwtag DW_TAG_member
.dwattr $C$DW$393, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$393, DW_AT_name("adaptiveFilterRatio")
.dwattr $C$DW$393, DW_AT_TI_symbol_name("adaptiveFilterRatio")
.dwattr $C$DW$393, DW_AT_data_member_location[DW_OP_plus_uconst 0x410]
.dwattr $C$DW$393, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$393, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$393, DW_AT_decl_line(0x3cc)
.dwattr $C$DW$393, DW_AT_decl_column(0x05)
$C$DW$394 .dwtag DW_TAG_member
.dwattr $C$DW$394, DW_AT_type(*$C$DW$T$220)
.dwattr $C$DW$394, DW_AT_name("reserve")
.dwattr $C$DW$394, DW_AT_TI_symbol_name("reserve")
.dwattr $C$DW$394, DW_AT_data_member_location[DW_OP_plus_uconst 0x418]
.dwattr $C$DW$394, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$394, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$394, DW_AT_decl_line(0x3cd)
.dwattr $C$DW$394, DW_AT_decl_column(0x05)
$C$DW$8 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$8, DW_AT_declaration
.dwattr $C$DW$8, DW_AT_TI_symbol_name("_ZN14CVizUser_ParamaSERKS_")
.dwattr $C$DW$8, DW_AT_type(*$C$DW$T$221)
.dwattr $C$DW$8, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$395 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$395, DW_AT_type(*$C$DW$T$223)
.dwendtag $C$DW$8
.dwendtag $C$DW$T$225
.dwattr $C$DW$T$225, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$225, DW_AT_decl_line(0x3c4)
.dwattr $C$DW$T$225, DW_AT_decl_column(0x01)
$C$DW$T$222 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$222, DW_AT_type(*$C$DW$T$225)
$C$DW$T$223 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$223, DW_AT_type(*$C$DW$T$222)
.dwattr $C$DW$T$223, DW_AT_address_class(0x20)
$C$DW$T$1583 .dwtag DW_TAG_typedef, DW_AT_name("CVizUser_Param")
.dwattr $C$DW$T$1583, DW_AT_type(*$C$DW$T$225)
.dwattr $C$DW$T$1583, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1583, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1583, DW_AT_decl_line(0x3ce)
.dwattr $C$DW$T$1583, DW_AT_decl_column(0x03)
$C$DW$T$221 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$221, DW_AT_type(*$C$DW$T$225)
.dwattr $C$DW$T$221, DW_AT_address_class(0x20)
$C$DW$T$224 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$224, DW_AT_type(*$C$DW$T$221)
.dwattr $C$DW$T$224, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$396 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$396, DW_AT_type(*$C$DW$T$223)
.dwendtag $C$DW$T$224
$C$DW$T$1922 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1922, DW_AT_name("CbufErrorSourceType")
.dwattr $C$DW$T$1922, DW_AT_byte_size(0x04)
$C$DW$397 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ALLOCATE"), DW_AT_const_value(0x10)
.dwattr $C$DW$397, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$397, DW_AT_decl_line(0x5a)
.dwattr $C$DW$397, DW_AT_decl_column(0x05)
$C$DW$398 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_RECYCLE"), DW_AT_const_value(0x11)
.dwattr $C$DW$398, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$398, DW_AT_decl_line(0x5b)
.dwattr $C$DW$398, DW_AT_decl_column(0x05)
$C$DW$399 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_0"), DW_AT_const_value(0x100)
.dwattr $C$DW$399, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$399, DW_AT_decl_line(0x5e)
.dwattr $C$DW$399, DW_AT_decl_column(0x05)
$C$DW$400 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_1"), DW_AT_const_value(0x101)
.dwattr $C$DW$400, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$400, DW_AT_decl_line(0x5f)
.dwattr $C$DW$400, DW_AT_decl_column(0x05)
$C$DW$401 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_2"), DW_AT_const_value(0x102)
.dwattr $C$DW$401, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$401, DW_AT_decl_line(0x60)
.dwattr $C$DW$401, DW_AT_decl_column(0x05)
$C$DW$402 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_3"), DW_AT_const_value(0x103)
.dwattr $C$DW$402, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$402, DW_AT_decl_line(0x61)
.dwattr $C$DW$402, DW_AT_decl_column(0x05)
$C$DW$403 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_4"), DW_AT_const_value(0x104)
.dwattr $C$DW$403, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$403, DW_AT_decl_line(0x62)
.dwattr $C$DW$403, DW_AT_decl_column(0x05)
$C$DW$404 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_5"), DW_AT_const_value(0x105)
.dwattr $C$DW$404, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$404, DW_AT_decl_line(0x63)
.dwattr $C$DW$404, DW_AT_decl_column(0x05)
$C$DW$405 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_6"), DW_AT_const_value(0x106)
.dwattr $C$DW$405, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$405, DW_AT_decl_line(0x64)
.dwattr $C$DW$405, DW_AT_decl_column(0x05)
$C$DW$406 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_7"), DW_AT_const_value(0x107)
.dwattr $C$DW$406, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$406, DW_AT_decl_line(0x65)
.dwattr $C$DW$406, DW_AT_decl_column(0x05)
$C$DW$407 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_8"), DW_AT_const_value(0x108)
.dwattr $C$DW$407, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$407, DW_AT_decl_line(0x66)
.dwattr $C$DW$407, DW_AT_decl_column(0x05)
$C$DW$408 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_9"), DW_AT_const_value(0x109)
.dwattr $C$DW$408, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$408, DW_AT_decl_line(0x67)
.dwattr $C$DW$408, DW_AT_decl_column(0x05)
$C$DW$409 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_10"), DW_AT_const_value(0x10a)
.dwattr $C$DW$409, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$409, DW_AT_decl_line(0x68)
.dwattr $C$DW$409, DW_AT_decl_column(0x05)
$C$DW$410 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_11"), DW_AT_const_value(0x10b)
.dwattr $C$DW$410, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$410, DW_AT_decl_line(0x69)
.dwattr $C$DW$410, DW_AT_decl_column(0x05)
$C$DW$411 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_12"), DW_AT_const_value(0x10c)
.dwattr $C$DW$411, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$411, DW_AT_decl_line(0x6a)
.dwattr $C$DW$411, DW_AT_decl_column(0x05)
$C$DW$412 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_13"), DW_AT_const_value(0x10d)
.dwattr $C$DW$412, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$412, DW_AT_decl_line(0x6b)
.dwattr $C$DW$412, DW_AT_decl_column(0x05)
$C$DW$413 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_14"), DW_AT_const_value(0x10e)
.dwattr $C$DW$413, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$413, DW_AT_decl_line(0x6c)
.dwattr $C$DW$413, DW_AT_decl_column(0x05)
$C$DW$414 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_15"), DW_AT_const_value(0x10f)
.dwattr $C$DW$414, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$414, DW_AT_decl_line(0x6d)
.dwattr $C$DW$414, DW_AT_decl_column(0x05)
$C$DW$415 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_HEAP_MEM_MGR_0"), DW_AT_const_value(0x200)
.dwattr $C$DW$415, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$415, DW_AT_decl_line(0x6f)
.dwattr $C$DW$415, DW_AT_decl_column(0x05)
$C$DW$416 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_HOST_MGR_0"), DW_AT_const_value(0x300)
.dwattr $C$DW$416, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$416, DW_AT_decl_line(0x71)
.dwattr $C$DW$416, DW_AT_decl_column(0x05)
$C$DW$417 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_IN_MGR_0"), DW_AT_const_value(0x400)
.dwattr $C$DW$417, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$417, DW_AT_decl_line(0x73)
.dwattr $C$DW$417, DW_AT_decl_column(0x05)
$C$DW$418 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_0"), DW_AT_const_value(0x500)
.dwattr $C$DW$418, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$418, DW_AT_decl_line(0x75)
.dwattr $C$DW$418, DW_AT_decl_column(0x05)
$C$DW$419 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_1"), DW_AT_const_value(0x501)
.dwattr $C$DW$419, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$419, DW_AT_decl_line(0x76)
.dwattr $C$DW$419, DW_AT_decl_column(0x05)
$C$DW$420 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_2"), DW_AT_const_value(0x502)
.dwattr $C$DW$420, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$420, DW_AT_decl_line(0x77)
.dwattr $C$DW$420, DW_AT_decl_column(0x05)
$C$DW$421 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_3"), DW_AT_const_value(0x503)
.dwattr $C$DW$421, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$421, DW_AT_decl_line(0x78)
.dwattr $C$DW$421, DW_AT_decl_column(0x05)
$C$DW$422 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_4"), DW_AT_const_value(0x504)
.dwattr $C$DW$422, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$422, DW_AT_decl_line(0x79)
.dwattr $C$DW$422, DW_AT_decl_column(0x05)
$C$DW$423 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_5"), DW_AT_const_value(0x505)
.dwattr $C$DW$423, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$423, DW_AT_decl_line(0x7a)
.dwattr $C$DW$423, DW_AT_decl_column(0x05)
$C$DW$424 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_6"), DW_AT_const_value(0x506)
.dwattr $C$DW$424, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$424, DW_AT_decl_line(0x7b)
.dwattr $C$DW$424, DW_AT_decl_column(0x05)
$C$DW$425 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_7"), DW_AT_const_value(0x507)
.dwattr $C$DW$425, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$425, DW_AT_decl_line(0x7c)
.dwattr $C$DW$425, DW_AT_decl_column(0x05)
$C$DW$426 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_ECG_CINE"), DW_AT_const_value(0x508)
.dwattr $C$DW$426, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$426, DW_AT_decl_line(0x7d)
.dwattr $C$DW$426, DW_AT_decl_column(0x05)
$C$DW$427 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_0"), DW_AT_const_value(0x600)
.dwattr $C$DW$427, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$427, DW_AT_decl_line(0x7f)
.dwattr $C$DW$427, DW_AT_decl_column(0x05)
$C$DW$428 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_1"), DW_AT_const_value(0x601)
.dwattr $C$DW$428, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$428, DW_AT_decl_line(0x80)
.dwattr $C$DW$428, DW_AT_decl_column(0x05)
$C$DW$429 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_2"), DW_AT_const_value(0x602)
.dwattr $C$DW$429, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$429, DW_AT_decl_line(0x81)
.dwattr $C$DW$429, DW_AT_decl_column(0x05)
$C$DW$430 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_3"), DW_AT_const_value(0x603)
.dwattr $C$DW$430, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$430, DW_AT_decl_line(0x82)
.dwattr $C$DW$430, DW_AT_decl_column(0x05)
$C$DW$431 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_4"), DW_AT_const_value(0x604)
.dwattr $C$DW$431, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$431, DW_AT_decl_line(0x83)
.dwattr $C$DW$431, DW_AT_decl_column(0x05)
$C$DW$432 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_ECG_READ"), DW_AT_const_value(0x605)
.dwattr $C$DW$432, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$432, DW_AT_decl_line(0x84)
.dwattr $C$DW$432, DW_AT_decl_column(0x05)
$C$DW$433 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_PLAYLIST_0"), DW_AT_const_value(0x700)
.dwattr $C$DW$433, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$433, DW_AT_decl_line(0x86)
.dwattr $C$DW$433, DW_AT_decl_column(0x05)
$C$DW$434 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_PLAYLIST_1"), DW_AT_const_value(0x701)
.dwattr $C$DW$434, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$434, DW_AT_decl_line(0x87)
.dwattr $C$DW$434, DW_AT_decl_column(0x05)
$C$DW$435 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_PLAYLIST_2"), DW_AT_const_value(0x702)
.dwattr $C$DW$435, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$435, DW_AT_decl_line(0x88)
.dwattr $C$DW$435, DW_AT_decl_column(0x05)
$C$DW$436 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_0"), DW_AT_const_value(0x800)
.dwattr $C$DW$436, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$436, DW_AT_decl_line(0x89)
.dwattr $C$DW$436, DW_AT_decl_column(0x05)
$C$DW$437 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_1"), DW_AT_const_value(0x801)
.dwattr $C$DW$437, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$437, DW_AT_decl_line(0x8a)
.dwattr $C$DW$437, DW_AT_decl_column(0x05)
$C$DW$438 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_2"), DW_AT_const_value(0x802)
.dwattr $C$DW$438, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$438, DW_AT_decl_line(0x8b)
.dwattr $C$DW$438, DW_AT_decl_column(0x05)
$C$DW$439 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_3"), DW_AT_const_value(0x803)
.dwattr $C$DW$439, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$439, DW_AT_decl_line(0x8c)
.dwattr $C$DW$439, DW_AT_decl_column(0x05)
$C$DW$440 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_ASYNC_LIST_TWOD"), DW_AT_const_value(0x810)
.dwattr $C$DW$440, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$440, DW_AT_decl_line(0x8e)
.dwattr $C$DW$440, DW_AT_decl_column(0x05)
$C$DW$441 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_ASYNC_LIST_COLOR"), DW_AT_const_value(0x811)
.dwattr $C$DW$441, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$441, DW_AT_decl_line(0x8f)
.dwattr $C$DW$441, DW_AT_decl_column(0x05)
$C$DW$442 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_ASYNC_LIST_COLOR_VAR"), DW_AT_const_value(0x812)
.dwattr $C$DW$442, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$442, DW_AT_decl_line(0x90)
.dwattr $C$DW$442, DW_AT_decl_column(0x05)
$C$DW$443 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_AUDIO"), DW_AT_const_value(0x830)
.dwattr $C$DW$443, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$443, DW_AT_decl_line(0x92)
.dwattr $C$DW$443, DW_AT_decl_column(0x05)
$C$DW$444 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_DOPPLER"), DW_AT_const_value(0x831)
.dwattr $C$DW$444, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$444, DW_AT_decl_line(0x93)
.dwattr $C$DW$444, DW_AT_decl_column(0x05)
$C$DW$445 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_PK_MN0"), DW_AT_const_value(0x832)
.dwattr $C$DW$445, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$445, DW_AT_decl_line(0x94)
.dwattr $C$DW$445, DW_AT_decl_column(0x05)
$C$DW$446 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_RAW_PK_MN1"), DW_AT_const_value(0x833)
.dwattr $C$DW$446, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$446, DW_AT_decl_line(0x95)
.dwattr $C$DW$446, DW_AT_decl_column(0x05)
$C$DW$447 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_MMODE"), DW_AT_const_value(0x834)
.dwattr $C$DW$447, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$447, DW_AT_decl_line(0x96)
.dwattr $C$DW$447, DW_AT_decl_column(0x05)
$C$DW$448 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_ECG"), DW_AT_const_value(0x835)
.dwattr $C$DW$448, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$448, DW_AT_decl_line(0x97)
.dwattr $C$DW$448, DW_AT_decl_column(0x05)
$C$DW$449 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_PLAYLIST"), DW_AT_const_value(0x836)
.dwattr $C$DW$449, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$449, DW_AT_decl_line(0x98)
.dwattr $C$DW$449, DW_AT_decl_column(0x05)
$C$DW$450 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_ECGTEST_SPCTL"), DW_AT_const_value(0x840)
.dwattr $C$DW$450, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$450, DW_AT_decl_line(0x99)
.dwattr $C$DW$450, DW_AT_decl_column(0x05)
$C$DW$451 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_WORKER_0"), DW_AT_const_value(0x900)
.dwattr $C$DW$451, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$451, DW_AT_decl_line(0x9b)
.dwattr $C$DW$451, DW_AT_decl_column(0x05)
$C$DW$452 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_COLOR_0"), DW_AT_const_value(0x1000)
.dwattr $C$DW$452, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$452, DW_AT_decl_line(0x9e)
.dwattr $C$DW$452, DW_AT_decl_column(0x05)
$C$DW$453 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_0"), DW_AT_const_value(0x1200)
.dwattr $C$DW$453, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$453, DW_AT_decl_line(0xa0)
.dwattr $C$DW$453, DW_AT_decl_column(0x05)
$C$DW$454 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_1"), DW_AT_const_value(0x1201)
.dwattr $C$DW$454, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$454, DW_AT_decl_line(0xa1)
.dwattr $C$DW$454, DW_AT_decl_column(0x05)
$C$DW$455 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_2"), DW_AT_const_value(0x1202)
.dwattr $C$DW$455, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$455, DW_AT_decl_line(0xa2)
.dwattr $C$DW$455, DW_AT_decl_column(0x05)
$C$DW$456 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_3"), DW_AT_const_value(0x1203)
.dwattr $C$DW$456, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$456, DW_AT_decl_line(0xa3)
.dwattr $C$DW$456, DW_AT_decl_column(0x05)
$C$DW$457 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_4"), DW_AT_const_value(0x1204)
.dwattr $C$DW$457, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$457, DW_AT_decl_line(0xa4)
.dwattr $C$DW$457, DW_AT_decl_column(0x05)
$C$DW$458 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_5"), DW_AT_const_value(0x1205)
.dwattr $C$DW$458, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$458, DW_AT_decl_line(0xa5)
.dwattr $C$DW$458, DW_AT_decl_column(0x05)
$C$DW$459 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_6"), DW_AT_const_value(0x1206)
.dwattr $C$DW$459, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$459, DW_AT_decl_line(0xa6)
.dwattr $C$DW$459, DW_AT_decl_column(0x05)
$C$DW$460 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_7"), DW_AT_const_value(0x1207)
.dwattr $C$DW$460, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$460, DW_AT_decl_line(0xa7)
.dwattr $C$DW$460, DW_AT_decl_column(0x05)
$C$DW$461 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_8"), DW_AT_const_value(0x1208)
.dwattr $C$DW$461, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$461, DW_AT_decl_line(0xa8)
.dwattr $C$DW$461, DW_AT_decl_column(0x05)
$C$DW$462 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_9"), DW_AT_const_value(0x1209)
.dwattr $C$DW$462, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$462, DW_AT_decl_line(0xa9)
.dwattr $C$DW$462, DW_AT_decl_column(0x05)
$C$DW$463 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_10"), DW_AT_const_value(0x120a)
.dwattr $C$DW$463, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$463, DW_AT_decl_line(0xaa)
.dwattr $C$DW$463, DW_AT_decl_column(0x05)
$C$DW$464 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_11"), DW_AT_const_value(0x120b)
.dwattr $C$DW$464, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$464, DW_AT_decl_line(0xab)
.dwattr $C$DW$464, DW_AT_decl_column(0x05)
$C$DW$465 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_12"), DW_AT_const_value(0x120c)
.dwattr $C$DW$465, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$465, DW_AT_decl_line(0xac)
.dwattr $C$DW$465, DW_AT_decl_column(0x05)
$C$DW$466 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_13"), DW_AT_const_value(0x120d)
.dwattr $C$DW$466, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$466, DW_AT_decl_line(0xad)
.dwattr $C$DW$466, DW_AT_decl_column(0x05)
$C$DW$467 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_14"), DW_AT_const_value(0x120e)
.dwattr $C$DW$467, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$467, DW_AT_decl_line(0xae)
.dwattr $C$DW$467, DW_AT_decl_column(0x05)
$C$DW$468 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_16"), DW_AT_const_value(0x1210)
.dwattr $C$DW$468, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$468, DW_AT_decl_line(0xaf)
.dwattr $C$DW$468, DW_AT_decl_column(0x05)
$C$DW$469 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_17"), DW_AT_const_value(0x1211)
.dwattr $C$DW$469, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$469, DW_AT_decl_line(0xb0)
.dwattr $C$DW$469, DW_AT_decl_column(0x05)
$C$DW$470 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_18"), DW_AT_const_value(0x1212)
.dwattr $C$DW$470, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$470, DW_AT_decl_line(0xb1)
.dwattr $C$DW$470, DW_AT_decl_column(0x05)
$C$DW$471 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_19"), DW_AT_const_value(0x1213)
.dwattr $C$DW$471, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$471, DW_AT_decl_line(0xb2)
.dwattr $C$DW$471, DW_AT_decl_column(0x05)
$C$DW$472 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_20"), DW_AT_const_value(0x1214)
.dwattr $C$DW$472, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$472, DW_AT_decl_line(0xb3)
.dwattr $C$DW$472, DW_AT_decl_column(0x05)
$C$DW$473 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_21"), DW_AT_const_value(0x1215)
.dwattr $C$DW$473, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$473, DW_AT_decl_line(0xb4)
.dwattr $C$DW$473, DW_AT_decl_column(0x05)
$C$DW$474 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_22"), DW_AT_const_value(0x1216)
.dwattr $C$DW$474, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$474, DW_AT_decl_line(0xb5)
.dwattr $C$DW$474, DW_AT_decl_column(0x05)
$C$DW$475 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_0"), DW_AT_const_value(0x1300)
.dwattr $C$DW$475, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$475, DW_AT_decl_line(0xb8)
.dwattr $C$DW$475, DW_AT_decl_column(0x05)
$C$DW$476 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_1"), DW_AT_const_value(0x1301)
.dwattr $C$DW$476, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$476, DW_AT_decl_line(0xb9)
.dwattr $C$DW$476, DW_AT_decl_column(0x05)
$C$DW$477 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_2"), DW_AT_const_value(0x1302)
.dwattr $C$DW$477, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$477, DW_AT_decl_line(0xba)
.dwattr $C$DW$477, DW_AT_decl_column(0x05)
$C$DW$478 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_3"), DW_AT_const_value(0x1303)
.dwattr $C$DW$478, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$478, DW_AT_decl_line(0xbb)
.dwattr $C$DW$478, DW_AT_decl_column(0x05)
$C$DW$479 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_4"), DW_AT_const_value(0x1304)
.dwattr $C$DW$479, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$479, DW_AT_decl_line(0xbc)
.dwattr $C$DW$479, DW_AT_decl_column(0x05)
$C$DW$480 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_5"), DW_AT_const_value(0x1305)
.dwattr $C$DW$480, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$480, DW_AT_decl_line(0xbd)
.dwattr $C$DW$480, DW_AT_decl_column(0x05)
$C$DW$481 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_6"), DW_AT_const_value(0x1306)
.dwattr $C$DW$481, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$481, DW_AT_decl_line(0xbe)
.dwattr $C$DW$481, DW_AT_decl_column(0x05)
$C$DW$482 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_7"), DW_AT_const_value(0x1307)
.dwattr $C$DW$482, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$482, DW_AT_decl_line(0xbf)
.dwattr $C$DW$482, DW_AT_decl_column(0x05)
$C$DW$483 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_8"), DW_AT_const_value(0x1308)
.dwattr $C$DW$483, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$483, DW_AT_decl_line(0xc0)
.dwattr $C$DW$483, DW_AT_decl_column(0x05)
$C$DW$484 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_9"), DW_AT_const_value(0x1309)
.dwattr $C$DW$484, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$484, DW_AT_decl_line(0xc1)
.dwattr $C$DW$484, DW_AT_decl_column(0x05)
$C$DW$485 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_0"), DW_AT_const_value(0x1320)
.dwattr $C$DW$485, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$485, DW_AT_decl_line(0xc3)
.dwattr $C$DW$485, DW_AT_decl_column(0x05)
$C$DW$486 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_1"), DW_AT_const_value(0x1321)
.dwattr $C$DW$486, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$486, DW_AT_decl_line(0xc4)
.dwattr $C$DW$486, DW_AT_decl_column(0x05)
$C$DW$487 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_2"), DW_AT_const_value(0x1322)
.dwattr $C$DW$487, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$487, DW_AT_decl_line(0xc5)
.dwattr $C$DW$487, DW_AT_decl_column(0x05)
$C$DW$488 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_3"), DW_AT_const_value(0x1323)
.dwattr $C$DW$488, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$488, DW_AT_decl_line(0xc6)
.dwattr $C$DW$488, DW_AT_decl_column(0x05)
$C$DW$489 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_4"), DW_AT_const_value(0x1324)
.dwattr $C$DW$489, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$489, DW_AT_decl_line(0xc7)
.dwattr $C$DW$489, DW_AT_decl_column(0x05)
$C$DW$490 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_5"), DW_AT_const_value(0x1325)
.dwattr $C$DW$490, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$490, DW_AT_decl_line(0xc8)
.dwattr $C$DW$490, DW_AT_decl_column(0x05)
$C$DW$491 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_6"), DW_AT_const_value(0x1326)
.dwattr $C$DW$491, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$491, DW_AT_decl_line(0xc9)
.dwattr $C$DW$491, DW_AT_decl_column(0x05)
$C$DW$492 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_7"), DW_AT_const_value(0x1327)
.dwattr $C$DW$492, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$492, DW_AT_decl_line(0xca)
.dwattr $C$DW$492, DW_AT_decl_column(0x05)
$C$DW$493 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_8"), DW_AT_const_value(0x1328)
.dwattr $C$DW$493, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$493, DW_AT_decl_line(0xcb)
.dwattr $C$DW$493, DW_AT_decl_column(0x05)
$C$DW$494 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_9"), DW_AT_const_value(0x1329)
.dwattr $C$DW$494, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$494, DW_AT_decl_line(0xcc)
.dwattr $C$DW$494, DW_AT_decl_column(0x05)
$C$DW$495 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_10"), DW_AT_const_value(0x132a)
.dwattr $C$DW$495, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$495, DW_AT_decl_line(0xcd)
.dwattr $C$DW$495, DW_AT_decl_column(0x05)
$C$DW$496 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_11"), DW_AT_const_value(0x132b)
.dwattr $C$DW$496, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$496, DW_AT_decl_line(0xce)
.dwattr $C$DW$496, DW_AT_decl_column(0x05)
$C$DW$497 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_12"), DW_AT_const_value(0x132c)
.dwattr $C$DW$497, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$497, DW_AT_decl_line(0xcf)
.dwattr $C$DW$497, DW_AT_decl_column(0x05)
$C$DW$498 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_13"), DW_AT_const_value(0x132d)
.dwattr $C$DW$498, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$498, DW_AT_decl_line(0xd0)
.dwattr $C$DW$498, DW_AT_decl_column(0x05)
$C$DW$499 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_14"), DW_AT_const_value(0x132e)
.dwattr $C$DW$499, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$499, DW_AT_decl_line(0xd1)
.dwattr $C$DW$499, DW_AT_decl_column(0x05)
$C$DW$500 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_15"), DW_AT_const_value(0x132f)
.dwattr $C$DW$500, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$500, DW_AT_decl_line(0xd2)
.dwattr $C$DW$500, DW_AT_decl_column(0x05)
$C$DW$501 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_16"), DW_AT_const_value(0x1330)
.dwattr $C$DW$501, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$501, DW_AT_decl_line(0xd3)
.dwattr $C$DW$501, DW_AT_decl_column(0x05)
$C$DW$502 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_17"), DW_AT_const_value(0x1331)
.dwattr $C$DW$502, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$502, DW_AT_decl_line(0xd4)
.dwattr $C$DW$502, DW_AT_decl_column(0x05)
$C$DW$503 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MMODE_0"), DW_AT_const_value(0x1400)
.dwattr $C$DW$503, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$503, DW_AT_decl_line(0xd6)
.dwattr $C$DW$503, DW_AT_decl_column(0x05)
$C$DW$504 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MMODE_1"), DW_AT_const_value(0x1401)
.dwattr $C$DW$504, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$504, DW_AT_decl_line(0xd7)
.dwattr $C$DW$504, DW_AT_decl_column(0x05)
$C$DW$505 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MMODE_2"), DW_AT_const_value(0x1402)
.dwattr $C$DW$505, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$505, DW_AT_decl_line(0xd8)
.dwattr $C$DW$505, DW_AT_decl_column(0x05)
$C$DW$506 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MMODE_3"), DW_AT_const_value(0x1403)
.dwattr $C$DW$506, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$506, DW_AT_decl_line(0xd9)
.dwattr $C$DW$506, DW_AT_decl_column(0x02)
$C$DW$507 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MMODE_4"), DW_AT_const_value(0x1404)
.dwattr $C$DW$507, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$507, DW_AT_decl_line(0xda)
.dwattr $C$DW$507, DW_AT_decl_column(0x02)
$C$DW$508 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ECG_ENQUEUE_WRITE"), DW_AT_const_value(0x1500)
.dwattr $C$DW$508, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$508, DW_AT_decl_line(0xdc)
.dwattr $C$DW$508, DW_AT_decl_column(0x02)
$C$DW$509 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ECG_PROCESS_INPUT"), DW_AT_const_value(0x1501)
.dwattr $C$DW$509, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$509, DW_AT_decl_line(0xdd)
.dwattr $C$DW$509, DW_AT_decl_column(0x02)
$C$DW$510 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ECG_PROCESS_READ"), DW_AT_const_value(0x1502)
.dwattr $C$DW$510, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$510, DW_AT_decl_line(0xde)
.dwattr $C$DW$510, DW_AT_decl_column(0x02)
$C$DW$511 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ECG_3"), DW_AT_const_value(0x1503)
.dwattr $C$DW$511, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$511, DW_AT_decl_line(0xdf)
.dwattr $C$DW$511, DW_AT_decl_column(0x05)
$C$DW$512 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ECG_4"), DW_AT_const_value(0x1504)
.dwattr $C$DW$512, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$512, DW_AT_decl_line(0xe0)
.dwattr $C$DW$512, DW_AT_decl_column(0x05)
$C$DW$513 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_TWOD_0"), DW_AT_const_value(0x1600)
.dwattr $C$DW$513, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$513, DW_AT_decl_line(0xe2)
.dwattr $C$DW$513, DW_AT_decl_column(0x05)
$C$DW$514 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_TWOD_1"), DW_AT_const_value(0x1601)
.dwattr $C$DW$514, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$514, DW_AT_decl_line(0xe3)
.dwattr $C$DW$514, DW_AT_decl_column(0x05)
$C$DW$515 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MAX_VALUE"), DW_AT_const_value(0xffff)
.dwattr $C$DW$515, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$515, DW_AT_decl_line(0xe5)
.dwattr $C$DW$515, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1922
.dwattr $C$DW$T$1922, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$T$1922, DW_AT_decl_line(0x59)
.dwattr $C$DW$T$1922, DW_AT_decl_column(0x01)
$C$DW$T$1923 .dwtag DW_TAG_typedef, DW_AT_name("CbufErrorSourceType")
.dwattr $C$DW$T$1923, DW_AT_type(*$C$DW$T$1922)
.dwattr $C$DW$T$1923, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1923, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h")
.dwattr $C$DW$T$1923, DW_AT_decl_line(0xe6)
.dwattr $C$DW$T$1923, DW_AT_decl_column(0x03)
$C$DW$T$118 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$118, DW_AT_name("CbufStorageClassType")
.dwattr $C$DW$T$118, DW_AT_byte_size(0x04)
$C$DW$516 .dwtag DW_TAG_enumerator, DW_AT_name("CBUFF_STORAGE_CLASS_NOT_FREEABLE"), DW_AT_const_value(0x00)
.dwattr $C$DW$516, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$516, DW_AT_decl_line(0x1f)
.dwattr $C$DW$516, DW_AT_decl_column(0x05)
$C$DW$517 .dwtag DW_TAG_enumerator, DW_AT_name("CBUFF_STORAGE_CLASS_FREEABLE"), DW_AT_const_value(0x01)
.dwattr $C$DW$517, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$517, DW_AT_decl_line(0x23)
.dwattr $C$DW$517, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$118
.dwattr $C$DW$T$118, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$T$118, DW_AT_decl_line(0x1b)
.dwattr $C$DW$T$118, DW_AT_decl_column(0x01)
$C$DW$T$119 .dwtag DW_TAG_typedef, DW_AT_name("CbufStorageClassType")
.dwattr $C$DW$T$119, DW_AT_type(*$C$DW$T$118)
.dwattr $C$DW$T$119, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$119, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h")
.dwattr $C$DW$T$119, DW_AT_decl_line(0x24)
.dwattr $C$DW$T$119, DW_AT_decl_column(0x04)
$C$DW$T$994 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$994, DW_AT_name("CineIqInfo")
.dwattr $C$DW$T$994, DW_AT_byte_size(0x20)
$C$DW$518 .dwtag DW_TAG_member
.dwattr $C$DW$518, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$518, DW_AT_name("lineSize")
.dwattr $C$DW$518, DW_AT_TI_symbol_name("lineSize")
.dwattr $C$DW$518, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$518, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$518, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$518, DW_AT_decl_line(0xbf)
.dwattr $C$DW$518, DW_AT_decl_column(0x09)
$C$DW$519 .dwtag DW_TAG_member
.dwattr $C$DW$519, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$519, DW_AT_name("sampleSize")
.dwattr $C$DW$519, DW_AT_TI_symbol_name("sampleSize")
.dwattr $C$DW$519, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$519, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$519, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$519, DW_AT_decl_line(0xc0)
.dwattr $C$DW$519, DW_AT_decl_column(0x09)
$C$DW$520 .dwtag DW_TAG_member
.dwattr $C$DW$520, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$520, DW_AT_name("lineStart")
.dwattr $C$DW$520, DW_AT_TI_symbol_name("lineStart")
.dwattr $C$DW$520, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$520, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$520, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$520, DW_AT_decl_line(0xc2)
.dwattr $C$DW$520, DW_AT_decl_column(0x09)
$C$DW$521 .dwtag DW_TAG_member
.dwattr $C$DW$521, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$521, DW_AT_name("sampleStart")
.dwattr $C$DW$521, DW_AT_TI_symbol_name("sampleStart")
.dwattr $C$DW$521, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$521, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$521, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$521, DW_AT_decl_line(0xc3)
.dwattr $C$DW$521, DW_AT_decl_column(0x09)
$C$DW$522 .dwtag DW_TAG_member
.dwattr $C$DW$522, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$522, DW_AT_name("lineScale")
.dwattr $C$DW$522, DW_AT_TI_symbol_name("lineScale")
.dwattr $C$DW$522, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$522, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$522, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$522, DW_AT_decl_line(0xc5)
.dwattr $C$DW$522, DW_AT_decl_column(0x0b)
$C$DW$523 .dwtag DW_TAG_member
.dwattr $C$DW$523, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$523, DW_AT_name("sampleScale")
.dwattr $C$DW$523, DW_AT_TI_symbol_name("sampleScale")
.dwattr $C$DW$523, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$523, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$523, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$523, DW_AT_decl_line(0xc6)
.dwattr $C$DW$523, DW_AT_decl_column(0x0b)
$C$DW$524 .dwtag DW_TAG_member
.dwattr $C$DW$524, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$524, DW_AT_name("samplePerMm")
.dwattr $C$DW$524, DW_AT_TI_symbol_name("samplePerMm")
.dwattr $C$DW$524, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$524, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$524, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$524, DW_AT_decl_line(0xc8)
.dwattr $C$DW$524, DW_AT_decl_column(0x0b)
$C$DW$525 .dwtag DW_TAG_member
.dwattr $C$DW$525, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$525, DW_AT_name("adClock")
.dwattr $C$DW$525, DW_AT_TI_symbol_name("adClock")
.dwattr $C$DW$525, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c]
.dwattr $C$DW$525, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$525, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$525, DW_AT_decl_line(0xc9)
.dwattr $C$DW$525, DW_AT_decl_column(0x0b)
$C$DW$9 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$9, DW_AT_declaration
.dwattr $C$DW$9, DW_AT_TI_symbol_name("_ZN10CineIqInfoaSERKS_")
.dwattr $C$DW$9, DW_AT_type(*$C$DW$T$990)
.dwattr $C$DW$9, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$526 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$526, DW_AT_type(*$C$DW$T$992)
.dwendtag $C$DW$9
.dwendtag $C$DW$T$994
.dwattr $C$DW$T$994, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$T$994, DW_AT_decl_line(0xbd)
.dwattr $C$DW$T$994, DW_AT_decl_column(0x08)
$C$DW$T$991 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$991, DW_AT_type(*$C$DW$T$994)
$C$DW$T$992 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$992, DW_AT_type(*$C$DW$T$991)
.dwattr $C$DW$T$992, DW_AT_address_class(0x20)
$C$DW$T$990 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$990, DW_AT_type(*$C$DW$T$994)
.dwattr $C$DW$T$990, DW_AT_address_class(0x20)
$C$DW$T$993 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$993, DW_AT_type(*$C$DW$T$990)
.dwattr $C$DW$T$993, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$527 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$527, DW_AT_type(*$C$DW$T$992)
.dwendtag $C$DW$T$993
$C$DW$T$1018 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1018, DW_AT_name("CinePlayback_Speed")
.dwattr $C$DW$T$1018, DW_AT_byte_size(0x04)
$C$DW$528 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PLAYBACK_SPEED_FULL"), DW_AT_const_value(0x00)
.dwattr $C$DW$528, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$528, DW_AT_decl_line(0x160)
.dwattr $C$DW$528, DW_AT_decl_column(0x05)
$C$DW$529 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PLAYBACK_SPEED_HALF"), DW_AT_const_value(0x01)
.dwattr $C$DW$529, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$529, DW_AT_decl_line(0x161)
.dwattr $C$DW$529, DW_AT_decl_column(0x05)
$C$DW$530 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PLAYBACK_SPEED_QTR"), DW_AT_const_value(0x02)
.dwattr $C$DW$530, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$530, DW_AT_decl_line(0x162)
.dwattr $C$DW$530, DW_AT_decl_column(0x05)
$C$DW$531 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PLAYBACK_SPEED_EOL"), DW_AT_const_value(0x03)
.dwattr $C$DW$531, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$531, DW_AT_decl_line(0x163)
.dwattr $C$DW$531, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1018
.dwattr $C$DW$T$1018, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1018, DW_AT_decl_line(0x15f)
.dwattr $C$DW$T$1018, DW_AT_decl_column(0x01)
$C$DW$T$1019 .dwtag DW_TAG_typedef, DW_AT_name("CinePlayback_Speed")
.dwattr $C$DW$T$1019, DW_AT_type(*$C$DW$T$1018)
.dwattr $C$DW$T$1019, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1019, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1019, DW_AT_decl_line(0x164)
.dwattr $C$DW$T$1019, DW_AT_decl_column(0x03)
$C$DW$T$1016 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1016, DW_AT_name("CineProcessType")
.dwattr $C$DW$T$1016, DW_AT_byte_size(0x04)
$C$DW$532 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESSTYPE_FRAME"), DW_AT_const_value(0x00)
.dwattr $C$DW$532, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$532, DW_AT_decl_line(0x168)
.dwattr $C$DW$532, DW_AT_decl_column(0x05)
$C$DW$533 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESSTYPE_COL"), DW_AT_const_value(0x02)
.dwattr $C$DW$533, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$533, DW_AT_decl_line(0x169)
.dwattr $C$DW$533, DW_AT_decl_column(0x05)
$C$DW$534 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESSTYPE_SIMULT"), DW_AT_const_value(0x03)
.dwattr $C$DW$534, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$534, DW_AT_decl_line(0x16a)
.dwattr $C$DW$534, DW_AT_decl_column(0x05)
$C$DW$535 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESSTYPE_EOL"), DW_AT_const_value(0x04)
.dwattr $C$DW$535, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$535, DW_AT_decl_line(0x16b)
.dwattr $C$DW$535, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1016
.dwattr $C$DW$T$1016, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1016, DW_AT_decl_line(0x167)
.dwattr $C$DW$T$1016, DW_AT_decl_column(0x01)
$C$DW$T$1017 .dwtag DW_TAG_typedef, DW_AT_name("CineProcessType")
.dwattr $C$DW$T$1017, DW_AT_type(*$C$DW$T$1016)
.dwattr $C$DW$T$1017, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1017, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1017, DW_AT_decl_line(0x16c)
.dwattr $C$DW$T$1017, DW_AT_decl_column(0x03)
$C$DW$T$1000 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1000, DW_AT_name("CineProcess_Commands")
.dwattr $C$DW$T$1000, DW_AT_byte_size(0x660)
$C$DW$536 .dwtag DW_TAG_member
.dwattr $C$DW$536, DW_AT_type(*$C$DW$T$995)
.dwattr $C$DW$536, DW_AT_name("cineProcessQueue")
.dwattr $C$DW$536, DW_AT_TI_symbol_name("cineProcessQueue")
.dwattr $C$DW$536, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$536, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$536, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$536, DW_AT_decl_line(0x543)
.dwattr $C$DW$536, DW_AT_decl_column(0x05)
$C$DW$537 .dwtag DW_TAG_member
.dwattr $C$DW$537, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$537, DW_AT_name("reserved")
.dwattr $C$DW$537, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$537, DW_AT_data_member_location[DW_OP_plus_uconst 0x5e0]
.dwattr $C$DW$537, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$537, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$537, DW_AT_decl_line(0x544)
.dwattr $C$DW$537, DW_AT_decl_column(0x05)
$C$DW$10 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$10, DW_AT_declaration
.dwattr $C$DW$10, DW_AT_TI_symbol_name("_ZN20CineProcess_CommandsaSERKS_")
.dwattr $C$DW$10, DW_AT_type(*$C$DW$T$996)
.dwattr $C$DW$10, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$538 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$538, DW_AT_type(*$C$DW$T$998)
.dwendtag $C$DW$10
.dwendtag $C$DW$T$1000
.dwattr $C$DW$T$1000, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1000, DW_AT_decl_line(0x542)
.dwattr $C$DW$T$1000, DW_AT_decl_column(0x01)
$C$DW$T$997 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$997, DW_AT_type(*$C$DW$T$1000)
$C$DW$T$998 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$998, DW_AT_type(*$C$DW$T$997)
.dwattr $C$DW$T$998, DW_AT_address_class(0x20)
$C$DW$T$1367 .dwtag DW_TAG_typedef, DW_AT_name("CineProcess_Commands")
.dwattr $C$DW$T$1367, DW_AT_type(*$C$DW$T$1000)
.dwattr $C$DW$T$1367, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1367, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1367, DW_AT_decl_line(0x545)
.dwattr $C$DW$T$1367, DW_AT_decl_column(0x03)
$C$DW$T$996 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$996, DW_AT_type(*$C$DW$T$1000)
.dwattr $C$DW$T$996, DW_AT_address_class(0x20)
$C$DW$T$999 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$999, DW_AT_type(*$C$DW$T$996)
.dwattr $C$DW$T$999, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$539 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$539, DW_AT_type(*$C$DW$T$998)
.dwendtag $C$DW$T$999
$C$DW$T$1008 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1008, DW_AT_name("CineProcess_Entry")
.dwattr $C$DW$T$1008, DW_AT_byte_size(0xa8)
$C$DW$540 .dwtag DW_TAG_member
.dwattr $C$DW$540, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$540, DW_AT_name("frameColIdx")
.dwattr $C$DW$540, DW_AT_TI_symbol_name("frameColIdx")
.dwattr $C$DW$540, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$540, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$540, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$540, DW_AT_decl_line(0x52f)
.dwattr $C$DW$540, DW_AT_decl_column(0x05)
$C$DW$541 .dwtag DW_TAG_member
.dwattr $C$DW$541, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$541, DW_AT_name("simultCursor")
.dwattr $C$DW$541, DW_AT_TI_symbol_name("simultCursor")
.dwattr $C$DW$541, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$541, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$541, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$541, DW_AT_decl_line(0x530)
.dwattr $C$DW$541, DW_AT_decl_column(0x05)
$C$DW$542 .dwtag DW_TAG_member
.dwattr $C$DW$542, DW_AT_type(*$C$DW$T$1002)
.dwattr $C$DW$542, DW_AT_name("status")
.dwattr $C$DW$542, DW_AT_TI_symbol_name("status")
.dwattr $C$DW$542, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$542, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$542, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$542, DW_AT_decl_line(0x531)
.dwattr $C$DW$542, DW_AT_decl_column(0x05)
$C$DW$543 .dwtag DW_TAG_member
.dwattr $C$DW$543, DW_AT_type(*$C$DW$T$1003)
.dwattr $C$DW$543, DW_AT_name("modeIssued")
.dwattr $C$DW$543, DW_AT_TI_symbol_name("modeIssued")
.dwattr $C$DW$543, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$543, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$543, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$543, DW_AT_decl_line(0x532)
.dwattr $C$DW$543, DW_AT_decl_column(0x05)
$C$DW$544 .dwtag DW_TAG_member
.dwattr $C$DW$544, DW_AT_type(*$C$DW$T$1003)
.dwattr $C$DW$544, DW_AT_name("modeCompleted")
.dwattr $C$DW$544, DW_AT_TI_symbol_name("modeCompleted")
.dwattr $C$DW$544, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$544, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$544, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$544, DW_AT_decl_line(0x533)
.dwattr $C$DW$544, DW_AT_decl_column(0x05)
$C$DW$545 .dwtag DW_TAG_member
.dwattr $C$DW$545, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$545, DW_AT_name("reserved")
.dwattr $C$DW$545, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$545, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$545, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$545, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$545, DW_AT_decl_line(0x534)
.dwattr $C$DW$545, DW_AT_decl_column(0x05)
$C$DW$11 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$11, DW_AT_declaration
.dwattr $C$DW$11, DW_AT_TI_symbol_name("_ZN17CineProcess_EntryaSERKS_")
.dwattr $C$DW$11, DW_AT_type(*$C$DW$T$1004)
.dwattr $C$DW$11, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$546 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$546, DW_AT_type(*$C$DW$T$1006)
.dwendtag $C$DW$11
.dwendtag $C$DW$T$1008
.dwattr $C$DW$T$1008, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1008, DW_AT_decl_line(0x52d)
.dwattr $C$DW$T$1008, DW_AT_decl_column(0x01)
$C$DW$T$1005 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1005, DW_AT_type(*$C$DW$T$1008)
$C$DW$T$1006 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1006, DW_AT_type(*$C$DW$T$1005)
.dwattr $C$DW$T$1006, DW_AT_address_class(0x20)
$C$DW$T$1009 .dwtag DW_TAG_typedef, DW_AT_name("CineProcess_Entry")
.dwattr $C$DW$T$1009, DW_AT_type(*$C$DW$T$1008)
.dwattr $C$DW$T$1009, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1009, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1009, DW_AT_decl_line(0x535)
.dwattr $C$DW$T$1009, DW_AT_decl_column(0x03)
$C$DW$T$1010 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1010, DW_AT_type(*$C$DW$T$1009)
.dwattr $C$DW$T$1010, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1010, DW_AT_byte_size(0x540)
$C$DW$547 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$547, DW_AT_upper_bound(0x07)
.dwendtag $C$DW$T$1010
$C$DW$T$1004 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1004, DW_AT_type(*$C$DW$T$1008)
.dwattr $C$DW$T$1004, DW_AT_address_class(0x20)
$C$DW$T$1007 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1007, DW_AT_type(*$C$DW$T$1004)
.dwattr $C$DW$T$1007, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$548 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$548, DW_AT_type(*$C$DW$T$1006)
.dwendtag $C$DW$T$1007
$C$DW$T$1015 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1015, DW_AT_name("CineProcess_Queue")
.dwattr $C$DW$T$1015, DW_AT_byte_size(0x5e0)
$C$DW$549 .dwtag DW_TAG_member
.dwattr $C$DW$549, DW_AT_type(*$C$DW$T$1010)
.dwattr $C$DW$549, DW_AT_name("entry")
.dwattr $C$DW$549, DW_AT_TI_symbol_name("entry")
.dwattr $C$DW$549, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$549, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$549, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$549, DW_AT_decl_line(0x539)
.dwattr $C$DW$549, DW_AT_decl_column(0x05)
$C$DW$550 .dwtag DW_TAG_member
.dwattr $C$DW$550, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$550, DW_AT_name("curIdx")
.dwattr $C$DW$550, DW_AT_TI_symbol_name("curIdx")
.dwattr $C$DW$550, DW_AT_data_member_location[DW_OP_plus_uconst 0x540]
.dwattr $C$DW$550, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$550, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$550, DW_AT_decl_line(0x53a)
.dwattr $C$DW$550, DW_AT_decl_column(0x05)
$C$DW$551 .dwtag DW_TAG_member
.dwattr $C$DW$551, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$551, DW_AT_name("writeIdx")
.dwattr $C$DW$551, DW_AT_TI_symbol_name("writeIdx")
.dwattr $C$DW$551, DW_AT_data_member_location[DW_OP_plus_uconst 0x548]
.dwattr $C$DW$551, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$551, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$551, DW_AT_decl_line(0x53b)
.dwattr $C$DW$551, DW_AT_decl_column(0x05)
$C$DW$552 .dwtag DW_TAG_member
.dwattr $C$DW$552, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$552, DW_AT_name("readIdx")
.dwattr $C$DW$552, DW_AT_TI_symbol_name("readIdx")
.dwattr $C$DW$552, DW_AT_data_member_location[DW_OP_plus_uconst 0x550]
.dwattr $C$DW$552, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$552, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$552, DW_AT_decl_line(0x53c)
.dwattr $C$DW$552, DW_AT_decl_column(0x05)
$C$DW$553 .dwtag DW_TAG_member
.dwattr $C$DW$553, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$553, DW_AT_name("count")
.dwattr $C$DW$553, DW_AT_TI_symbol_name("count")
.dwattr $C$DW$553, DW_AT_data_member_location[DW_OP_plus_uconst 0x558]
.dwattr $C$DW$553, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$553, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$553, DW_AT_decl_line(0x53d)
.dwattr $C$DW$553, DW_AT_decl_column(0x05)
$C$DW$554 .dwtag DW_TAG_member
.dwattr $C$DW$554, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$554, DW_AT_name("reserved")
.dwattr $C$DW$554, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$554, DW_AT_data_member_location[DW_OP_plus_uconst 0x560]
.dwattr $C$DW$554, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$554, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$554, DW_AT_decl_line(0x53e)
.dwattr $C$DW$554, DW_AT_decl_column(0x05)
$C$DW$12 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$12, DW_AT_declaration
.dwattr $C$DW$12, DW_AT_TI_symbol_name("_ZN17CineProcess_QueueaSERKS_")
.dwattr $C$DW$12, DW_AT_type(*$C$DW$T$1011)
.dwattr $C$DW$12, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$555 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$555, DW_AT_type(*$C$DW$T$1013)
.dwendtag $C$DW$12
.dwendtag $C$DW$T$1015
.dwattr $C$DW$T$1015, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1015, DW_AT_decl_line(0x538)
.dwattr $C$DW$T$1015, DW_AT_decl_column(0x01)
$C$DW$T$995 .dwtag DW_TAG_typedef, DW_AT_name("CineProcess_Queue")
.dwattr $C$DW$T$995, DW_AT_type(*$C$DW$T$1015)
.dwattr $C$DW$T$995, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$995, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$995, DW_AT_decl_line(0x53f)
.dwattr $C$DW$T$995, DW_AT_decl_column(0x03)
$C$DW$T$1012 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1012, DW_AT_type(*$C$DW$T$1015)
$C$DW$T$1013 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1013, DW_AT_type(*$C$DW$T$1012)
.dwattr $C$DW$T$1013, DW_AT_address_class(0x20)
$C$DW$T$1011 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1011, DW_AT_type(*$C$DW$T$1015)
.dwattr $C$DW$T$1011, DW_AT_address_class(0x20)
$C$DW$T$1014 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1014, DW_AT_type(*$C$DW$T$1011)
.dwattr $C$DW$T$1014, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$556 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$556, DW_AT_type(*$C$DW$T$1013)
.dwendtag $C$DW$T$1014
$C$DW$T$1001 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1001, DW_AT_name("CineProcess_Status")
.dwattr $C$DW$T$1001, DW_AT_byte_size(0x04)
$C$DW$557 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESS_INVALID"), DW_AT_const_value(0x00)
.dwattr $C$DW$557, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$557, DW_AT_decl_line(0x157)
.dwattr $C$DW$557, DW_AT_decl_column(0x05)
$C$DW$558 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESS_REQUESTED"), DW_AT_const_value(0x01)
.dwattr $C$DW$558, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$558, DW_AT_decl_line(0x158)
.dwattr $C$DW$558, DW_AT_decl_column(0x05)
$C$DW$559 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESS_IN_PROGRESS"), DW_AT_const_value(0x02)
.dwattr $C$DW$559, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$559, DW_AT_decl_line(0x159)
.dwattr $C$DW$559, DW_AT_decl_column(0x05)
$C$DW$560 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESS_COMPLETE"), DW_AT_const_value(0x03)
.dwattr $C$DW$560, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$560, DW_AT_decl_line(0x15a)
.dwattr $C$DW$560, DW_AT_decl_column(0x05)
$C$DW$561 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESS_EOL"), DW_AT_const_value(0x04)
.dwattr $C$DW$561, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$561, DW_AT_decl_line(0x15b)
.dwattr $C$DW$561, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1001
.dwattr $C$DW$T$1001, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1001, DW_AT_decl_line(0x156)
.dwattr $C$DW$T$1001, DW_AT_decl_column(0x01)
$C$DW$T$1002 .dwtag DW_TAG_typedef, DW_AT_name("CineProcess_Status")
.dwattr $C$DW$T$1002, DW_AT_type(*$C$DW$T$1001)
.dwattr $C$DW$T$1002, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1002, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1002, DW_AT_decl_line(0x15c)
.dwattr $C$DW$T$1002, DW_AT_decl_column(0x03)
$C$DW$T$1024 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1024, DW_AT_name("Cine_Param")
.dwattr $C$DW$T$1024, DW_AT_byte_size(0xe8)
$C$DW$562 .dwtag DW_TAG_member
.dwattr $C$DW$562, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$562, DW_AT_name("numCineFrame")
.dwattr $C$DW$562, DW_AT_TI_symbol_name("numCineFrame")
.dwattr $C$DW$562, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$562, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$562, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$562, DW_AT_decl_line(0x516)
.dwattr $C$DW$562, DW_AT_decl_column(0x05)
$C$DW$563 .dwtag DW_TAG_member
.dwattr $C$DW$563, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$563, DW_AT_name("currentCineFrame")
.dwattr $C$DW$563, DW_AT_TI_symbol_name("currentCineFrame")
.dwattr $C$DW$563, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$563, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$563, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$563, DW_AT_decl_line(0x517)
.dwattr $C$DW$563, DW_AT_decl_column(0x05)
$C$DW$564 .dwtag DW_TAG_member
.dwattr $C$DW$564, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$564, DW_AT_name("startCineFrame")
.dwattr $C$DW$564, DW_AT_TI_symbol_name("startCineFrame")
.dwattr $C$DW$564, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$564, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$564, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$564, DW_AT_decl_line(0x518)
.dwattr $C$DW$564, DW_AT_decl_column(0x05)
$C$DW$565 .dwtag DW_TAG_member
.dwattr $C$DW$565, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$565, DW_AT_name("stopCineFrame")
.dwattr $C$DW$565, DW_AT_TI_symbol_name("stopCineFrame")
.dwattr $C$DW$565, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$565, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$565, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$565, DW_AT_decl_line(0x519)
.dwattr $C$DW$565, DW_AT_decl_column(0x05)
$C$DW$566 .dwtag DW_TAG_member
.dwattr $C$DW$566, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$566, DW_AT_name("currentCineCol")
.dwattr $C$DW$566, DW_AT_TI_symbol_name("currentCineCol")
.dwattr $C$DW$566, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$566, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$566, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$566, DW_AT_decl_line(0x51a)
.dwattr $C$DW$566, DW_AT_decl_column(0x05)
$C$DW$567 .dwtag DW_TAG_member
.dwattr $C$DW$567, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$567, DW_AT_name("isCineReady")
.dwattr $C$DW$567, DW_AT_TI_symbol_name("isCineReady")
.dwattr $C$DW$567, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$567, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$567, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$567, DW_AT_decl_line(0x51c)
.dwattr $C$DW$567, DW_AT_decl_column(0x05)
$C$DW$568 .dwtag DW_TAG_member
.dwattr $C$DW$568, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$568, DW_AT_name("firstCineColumn")
.dwattr $C$DW$568, DW_AT_TI_symbol_name("firstCineColumn")
.dwattr $C$DW$568, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$568, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$568, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$568, DW_AT_decl_line(0x51f)
.dwattr $C$DW$568, DW_AT_decl_column(0x05)
$C$DW$569 .dwtag DW_TAG_member
.dwattr $C$DW$569, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$569, DW_AT_name("lastCineColumn")
.dwattr $C$DW$569, DW_AT_TI_symbol_name("lastCineColumn")
.dwattr $C$DW$569, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$569, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$569, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$569, DW_AT_decl_line(0x520)
.dwattr $C$DW$569, DW_AT_decl_column(0x05)
$C$DW$570 .dwtag DW_TAG_member
.dwattr $C$DW$570, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$570, DW_AT_name("last2DFrameColumnOffset")
.dwattr $C$DW$570, DW_AT_TI_symbol_name("last2DFrameColumnOffset")
.dwattr $C$DW$570, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$570, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$570, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$570, DW_AT_decl_line(0x521)
.dwattr $C$DW$570, DW_AT_decl_column(0x05)
$C$DW$571 .dwtag DW_TAG_member
.dwattr $C$DW$571, DW_AT_type(*$C$DW$T$1017)
.dwattr $C$DW$571, DW_AT_name("cineProcessType")
.dwattr $C$DW$571, DW_AT_TI_symbol_name("cineProcessType")
.dwattr $C$DW$571, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$571, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$571, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$571, DW_AT_decl_line(0x524)
.dwattr $C$DW$571, DW_AT_decl_column(0x05)
$C$DW$572 .dwtag DW_TAG_member
.dwattr $C$DW$572, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$572, DW_AT_name("layoutChgLeftMostCol")
.dwattr $C$DW$572, DW_AT_TI_symbol_name("layoutChgLeftMostCol")
.dwattr $C$DW$572, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$572, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$572, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$572, DW_AT_decl_line(0x525)
.dwattr $C$DW$572, DW_AT_decl_column(0x05)
$C$DW$573 .dwtag DW_TAG_member
.dwattr $C$DW$573, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$573, DW_AT_name("layoutChgColMarker")
.dwattr $C$DW$573, DW_AT_TI_symbol_name("layoutChgColMarker")
.dwattr $C$DW$573, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$573, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$573, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$573, DW_AT_decl_line(0x526)
.dwattr $C$DW$573, DW_AT_decl_column(0x05)
$C$DW$574 .dwtag DW_TAG_member
.dwattr $C$DW$574, DW_AT_type(*$C$DW$T$1019)
.dwattr $C$DW$574, DW_AT_name("playbackSpeed")
.dwattr $C$DW$574, DW_AT_TI_symbol_name("playbackSpeed")
.dwattr $C$DW$574, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$574, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$574, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$574, DW_AT_decl_line(0x527)
.dwattr $C$DW$574, DW_AT_decl_column(0x05)
$C$DW$575 .dwtag DW_TAG_member
.dwattr $C$DW$575, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$575, DW_AT_name("reserved")
.dwattr $C$DW$575, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$575, DW_AT_data_member_location[DW_OP_plus_uconst 0x68]
.dwattr $C$DW$575, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$575, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$575, DW_AT_decl_line(0x529)
.dwattr $C$DW$575, DW_AT_decl_column(0x05)
$C$DW$13 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$13, DW_AT_declaration
.dwattr $C$DW$13, DW_AT_TI_symbol_name("_ZN10Cine_ParamaSERKS_")
.dwattr $C$DW$13, DW_AT_type(*$C$DW$T$1020)
.dwattr $C$DW$13, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$576 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$576, DW_AT_type(*$C$DW$T$1022)
.dwendtag $C$DW$13
.dwendtag $C$DW$T$1024
.dwattr $C$DW$T$1024, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1024, DW_AT_decl_line(0x514)
.dwattr $C$DW$T$1024, DW_AT_decl_column(0x01)
$C$DW$T$1021 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1021, DW_AT_type(*$C$DW$T$1024)
$C$DW$T$1022 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1022, DW_AT_type(*$C$DW$T$1021)
.dwattr $C$DW$T$1022, DW_AT_address_class(0x20)
$C$DW$T$2191 .dwtag DW_TAG_typedef, DW_AT_name("Cine_Param")
.dwattr $C$DW$T$2191, DW_AT_type(*$C$DW$T$1024)
.dwattr $C$DW$T$2191, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2191, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$2191, DW_AT_decl_line(0x52a)
.dwattr $C$DW$T$2191, DW_AT_decl_column(0x03)
$C$DW$T$1020 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1020, DW_AT_type(*$C$DW$T$1024)
.dwattr $C$DW$T$1020, DW_AT_address_class(0x20)
$C$DW$T$1023 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1023, DW_AT_type(*$C$DW$T$1020)
.dwattr $C$DW$T$1023, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$577 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$577, DW_AT_type(*$C$DW$T$1022)
.dwendtag $C$DW$T$1023
$C$DW$T$1179 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1179, DW_AT_name("ColorFlow_MP_FIR_Coeff")
.dwattr $C$DW$T$1179, DW_AT_byte_size(0xd0)
$C$DW$578 .dwtag DW_TAG_member
.dwattr $C$DW$578, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$578, DW_AT_name("useMP_FIR_Coefficients")
.dwattr $C$DW$578, DW_AT_TI_symbol_name("useMP_FIR_Coefficients")
.dwattr $C$DW$578, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$578, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$578, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$578, DW_AT_decl_line(0x41f)
.dwattr $C$DW$578, DW_AT_decl_column(0x05)
$C$DW$579 .dwtag DW_TAG_member
.dwattr $C$DW$579, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$579, DW_AT_name("length")
.dwattr $C$DW$579, DW_AT_TI_symbol_name("length")
.dwattr $C$DW$579, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$579, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$579, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$579, DW_AT_decl_line(0x420)
.dwattr $C$DW$579, DW_AT_decl_column(0x05)
$C$DW$580 .dwtag DW_TAG_member
.dwattr $C$DW$580, DW_AT_type(*$C$DW$T$1174)
.dwattr $C$DW$580, DW_AT_name("coeffs")
.dwattr $C$DW$580, DW_AT_TI_symbol_name("coeffs")
.dwattr $C$DW$580, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$580, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$580, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$580, DW_AT_decl_line(0x421)
.dwattr $C$DW$580, DW_AT_decl_column(0x05)
$C$DW$581 .dwtag DW_TAG_member
.dwattr $C$DW$581, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$581, DW_AT_name("reserved")
.dwattr $C$DW$581, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$581, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$581, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$581, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$581, DW_AT_decl_line(0x422)
.dwattr $C$DW$581, DW_AT_decl_column(0x05)
$C$DW$14 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$14, DW_AT_declaration
.dwattr $C$DW$14, DW_AT_TI_symbol_name("_ZN22ColorFlow_MP_FIR_CoeffaSERKS_")
.dwattr $C$DW$14, DW_AT_type(*$C$DW$T$1175)
.dwattr $C$DW$14, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$582 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$582, DW_AT_type(*$C$DW$T$1177)
.dwendtag $C$DW$14
.dwendtag $C$DW$T$1179
.dwattr $C$DW$T$1179, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1179, DW_AT_decl_line(0x41e)
.dwattr $C$DW$T$1179, DW_AT_decl_column(0x01)
$C$DW$T$1176 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1176, DW_AT_type(*$C$DW$T$1179)
$C$DW$T$1177 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1177, DW_AT_type(*$C$DW$T$1176)
.dwattr $C$DW$T$1177, DW_AT_address_class(0x20)
$C$DW$T$1184 .dwtag DW_TAG_typedef, DW_AT_name("ColorFlow_MP_FIR_Coeff")
.dwattr $C$DW$T$1184, DW_AT_type(*$C$DW$T$1179)
.dwattr $C$DW$T$1184, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1184, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1184, DW_AT_decl_line(0x423)
.dwattr $C$DW$T$1184, DW_AT_decl_column(0x03)
$C$DW$T$1175 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1175, DW_AT_type(*$C$DW$T$1179)
.dwattr $C$DW$T$1175, DW_AT_address_class(0x20)
$C$DW$T$1178 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1178, DW_AT_type(*$C$DW$T$1175)
.dwattr $C$DW$T$1178, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$583 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$583, DW_AT_type(*$C$DW$T$1177)
.dwendtag $C$DW$T$1178
$C$DW$T$1185 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1185, DW_AT_name("ColorFlow_MP_FIR_Source")
.dwattr $C$DW$T$1185, DW_AT_byte_size(0x04)
$C$DW$584 .dwtag DW_TAG_enumerator, DW_AT_name("COLORFLOW_MP_FIR_SOURCE_CTURN"), DW_AT_const_value(0x00)
.dwattr $C$DW$584, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$584, DW_AT_decl_line(0x109)
.dwattr $C$DW$584, DW_AT_decl_column(0x05)
$C$DW$585 .dwtag DW_TAG_enumerator, DW_AT_name("COLORFLOW_MP_FIR_SOURCE_WF"), DW_AT_const_value(0x01)
.dwattr $C$DW$585, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$585, DW_AT_decl_line(0x10a)
.dwattr $C$DW$585, DW_AT_decl_column(0x05)
$C$DW$586 .dwtag DW_TAG_enumerator, DW_AT_name("COLORFLOW_MP_FIR_SOURCE_WF_TIS"), DW_AT_const_value(0x02)
.dwattr $C$DW$586, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$586, DW_AT_decl_line(0x10b)
.dwattr $C$DW$586, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1185
.dwattr $C$DW$T$1185, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1185, DW_AT_decl_line(0x108)
.dwattr $C$DW$T$1185, DW_AT_decl_column(0x0e)
$C$DW$T$1186 .dwtag DW_TAG_typedef, DW_AT_name("ColorFlow_MP_FIR_Source")
.dwattr $C$DW$T$1186, DW_AT_type(*$C$DW$T$1185)
.dwattr $C$DW$T$1186, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1186, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1186, DW_AT_decl_line(0x10c)
.dwattr $C$DW$T$1186, DW_AT_decl_column(0x03)
$C$DW$T$1191 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1191, DW_AT_name("ColorFlow_Param")
.dwattr $C$DW$T$1191, DW_AT_byte_size(0x338)
$C$DW$587 .dwtag DW_TAG_member
.dwattr $C$DW$587, DW_AT_type(*$C$DW$T$1181)
.dwattr $C$DW$587, DW_AT_name("subMode")
.dwattr $C$DW$587, DW_AT_TI_symbol_name("subMode")
.dwattr $C$DW$587, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$587, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$587, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$587, DW_AT_decl_line(0x427)
.dwattr $C$DW$587, DW_AT_decl_column(0x05)
$C$DW$588 .dwtag DW_TAG_member
.dwattr $C$DW$588, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$588, DW_AT_name("varianceFlag")
.dwattr $C$DW$588, DW_AT_TI_symbol_name("varianceFlag")
.dwattr $C$DW$588, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$588, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$588, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$588, DW_AT_decl_line(0x429)
.dwattr $C$DW$588, DW_AT_decl_column(0x05)
$C$DW$589 .dwtag DW_TAG_member
.dwattr $C$DW$589, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$589, DW_AT_name("persistence")
.dwattr $C$DW$589, DW_AT_TI_symbol_name("persistence")
.dwattr $C$DW$589, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$589, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$589, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$589, DW_AT_decl_line(0x42a)
.dwattr $C$DW$589, DW_AT_decl_column(0x05)
$C$DW$590 .dwtag DW_TAG_member
.dwattr $C$DW$590, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$590, DW_AT_name("logPwrThreshLower")
.dwattr $C$DW$590, DW_AT_TI_symbol_name("logPwrThreshLower")
.dwattr $C$DW$590, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$590, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$590, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$590, DW_AT_decl_line(0x42b)
.dwattr $C$DW$590, DW_AT_decl_column(0x05)
$C$DW$591 .dwtag DW_TAG_member
.dwattr $C$DW$591, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$591, DW_AT_name("invLogPwrTaperRngM")
.dwattr $C$DW$591, DW_AT_TI_symbol_name("invLogPwrTaperRngM")
.dwattr $C$DW$591, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$591, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$591, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$591, DW_AT_decl_line(0x42c)
.dwattr $C$DW$591, DW_AT_decl_column(0x05)
$C$DW$592 .dwtag DW_TAG_member
.dwattr $C$DW$592, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$592, DW_AT_name("invLogPwrTaperRngE")
.dwattr $C$DW$592, DW_AT_TI_symbol_name("invLogPwrTaperRngE")
.dwattr $C$DW$592, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$592, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$592, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$592, DW_AT_decl_line(0x42d)
.dwattr $C$DW$592, DW_AT_decl_column(0x05)
$C$DW$593 .dwtag DW_TAG_member
.dwattr $C$DW$593, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$593, DW_AT_name("logRatioThreshLower")
.dwattr $C$DW$593, DW_AT_TI_symbol_name("logRatioThreshLower")
.dwattr $C$DW$593, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$593, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$593, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$593, DW_AT_decl_line(0x42e)
.dwattr $C$DW$593, DW_AT_decl_column(0x05)
$C$DW$594 .dwtag DW_TAG_member
.dwattr $C$DW$594, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$594, DW_AT_name("invLogRatioTaperRngM")
.dwattr $C$DW$594, DW_AT_TI_symbol_name("invLogRatioTaperRngM")
.dwattr $C$DW$594, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$594, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$594, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$594, DW_AT_decl_line(0x42f)
.dwattr $C$DW$594, DW_AT_decl_column(0x05)
$C$DW$595 .dwtag DW_TAG_member
.dwattr $C$DW$595, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$595, DW_AT_name("invLogRatioTaperRngE")
.dwattr $C$DW$595, DW_AT_TI_symbol_name("invLogRatioTaperRngE")
.dwattr $C$DW$595, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$595, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$595, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$595, DW_AT_decl_line(0x430)
.dwattr $C$DW$595, DW_AT_decl_column(0x05)
$C$DW$596 .dwtag DW_TAG_member
.dwattr $C$DW$596, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$596, DW_AT_name("numPingPackets")
.dwattr $C$DW$596, DW_AT_TI_symbol_name("numPingPackets")
.dwattr $C$DW$596, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$596, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$596, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$596, DW_AT_decl_line(0x432)
.dwattr $C$DW$596, DW_AT_decl_column(0x05)
$C$DW$597 .dwtag DW_TAG_member
.dwattr $C$DW$597, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$597, DW_AT_name("nEstimates")
.dwattr $C$DW$597, DW_AT_TI_symbol_name("nEstimates")
.dwattr $C$DW$597, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$597, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$597, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$597, DW_AT_decl_line(0x434)
.dwattr $C$DW$597, DW_AT_decl_column(0x05)
$C$DW$598 .dwtag DW_TAG_member
.dwattr $C$DW$598, DW_AT_type(*$C$DW$T$1182)
.dwattr $C$DW$598, DW_AT_name("multiline")
.dwattr $C$DW$598, DW_AT_TI_symbol_name("multiline")
.dwattr $C$DW$598, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$598, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$598, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$598, DW_AT_decl_line(0x437)
.dwattr $C$DW$598, DW_AT_decl_column(0x05)
$C$DW$599 .dwtag DW_TAG_member
.dwattr $C$DW$599, DW_AT_type(*$C$DW$T$1183)
.dwattr $C$DW$599, DW_AT_name("colorKernel")
.dwattr $C$DW$599, DW_AT_TI_symbol_name("colorKernel")
.dwattr $C$DW$599, DW_AT_data_member_location[DW_OP_plus_uconst 0xf8]
.dwattr $C$DW$599, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$599, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$599, DW_AT_decl_line(0x439)
.dwattr $C$DW$599, DW_AT_decl_column(0x05)
$C$DW$600 .dwtag DW_TAG_member
.dwattr $C$DW$600, DW_AT_type(*$C$DW$T$1184)
.dwattr $C$DW$600, DW_AT_name("MP_Fir")
.dwattr $C$DW$600, DW_AT_TI_symbol_name("MP_Fir")
.dwattr $C$DW$600, DW_AT_data_member_location[DW_OP_plus_uconst 0x1b8]
.dwattr $C$DW$600, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$600, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$600, DW_AT_decl_line(0x43d)
.dwattr $C$DW$600, DW_AT_decl_column(0x05)
$C$DW$601 .dwtag DW_TAG_member
.dwattr $C$DW$601, DW_AT_type(*$C$DW$T$1186)
.dwattr $C$DW$601, DW_AT_name("mpFirSource")
.dwattr $C$DW$601, DW_AT_TI_symbol_name("mpFirSource")
.dwattr $C$DW$601, DW_AT_data_member_location[DW_OP_plus_uconst 0x288]
.dwattr $C$DW$601, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$601, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$601, DW_AT_decl_line(0x43e)
.dwattr $C$DW$601, DW_AT_decl_column(0x05)
$C$DW$602 .dwtag DW_TAG_member
.dwattr $C$DW$602, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$602, DW_AT_name("logFlashSupThreshLower")
.dwattr $C$DW$602, DW_AT_TI_symbol_name("logFlashSupThreshLower")
.dwattr $C$DW$602, DW_AT_data_member_location[DW_OP_plus_uconst 0x290]
.dwattr $C$DW$602, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$602, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$602, DW_AT_decl_line(0x442)
.dwattr $C$DW$602, DW_AT_decl_column(0x05)
$C$DW$603 .dwtag DW_TAG_member
.dwattr $C$DW$603, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$603, DW_AT_name("invLogFlashSupTaperRngM")
.dwattr $C$DW$603, DW_AT_TI_symbol_name("invLogFlashSupTaperRngM")
.dwattr $C$DW$603, DW_AT_data_member_location[DW_OP_plus_uconst 0x298]
.dwattr $C$DW$603, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$603, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$603, DW_AT_decl_line(0x443)
.dwattr $C$DW$603, DW_AT_decl_column(0x05)
$C$DW$604 .dwtag DW_TAG_member
.dwattr $C$DW$604, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$604, DW_AT_name("invLogFlashSupTaperRngE")
.dwattr $C$DW$604, DW_AT_TI_symbol_name("invLogFlashSupTaperRngE")
.dwattr $C$DW$604, DW_AT_data_member_location[DW_OP_plus_uconst 0x2a0]
.dwattr $C$DW$604, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$604, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$604, DW_AT_decl_line(0x444)
.dwattr $C$DW$604, DW_AT_decl_column(0x05)
$C$DW$605 .dwtag DW_TAG_member
.dwattr $C$DW$605, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$605, DW_AT_name("scalingFactor")
.dwattr $C$DW$605, DW_AT_TI_symbol_name("scalingFactor")
.dwattr $C$DW$605, DW_AT_data_member_location[DW_OP_plus_uconst 0x2a8]
.dwattr $C$DW$605, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$605, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$605, DW_AT_decl_line(0x44f)
.dwattr $C$DW$605, DW_AT_decl_column(0x05)
$C$DW$606 .dwtag DW_TAG_member
.dwattr $C$DW$606, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$606, DW_AT_name("colorOutLen")
.dwattr $C$DW$606, DW_AT_TI_symbol_name("colorOutLen")
.dwattr $C$DW$606, DW_AT_data_member_location[DW_OP_plus_uconst 0x2b0]
.dwattr $C$DW$606, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$606, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$606, DW_AT_decl_line(0x451)
.dwattr $C$DW$606, DW_AT_decl_column(0x05)
$C$DW$607 .dwtag DW_TAG_member
.dwattr $C$DW$607, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$607, DW_AT_name("reserved")
.dwattr $C$DW$607, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$607, DW_AT_data_member_location[DW_OP_plus_uconst 0x2b8]
.dwattr $C$DW$607, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$607, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$607, DW_AT_decl_line(0x453)
.dwattr $C$DW$607, DW_AT_decl_column(0x05)
$C$DW$15 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$15, DW_AT_declaration
.dwattr $C$DW$15, DW_AT_TI_symbol_name("_ZN15ColorFlow_ParamaSERKS_")
.dwattr $C$DW$15, DW_AT_type(*$C$DW$T$1187)
.dwattr $C$DW$15, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$608 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$608, DW_AT_type(*$C$DW$T$1189)
.dwendtag $C$DW$15
.dwendtag $C$DW$T$1191
.dwattr $C$DW$T$1191, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1191, DW_AT_decl_line(0x426)
.dwattr $C$DW$T$1191, DW_AT_decl_column(0x01)
$C$DW$T$1188 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1188, DW_AT_type(*$C$DW$T$1191)
$C$DW$T$1189 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1189, DW_AT_type(*$C$DW$T$1188)
.dwattr $C$DW$T$1189, DW_AT_address_class(0x20)
$C$DW$T$2195 .dwtag DW_TAG_typedef, DW_AT_name("ColorFlow_Param")
.dwattr $C$DW$T$2195, DW_AT_type(*$C$DW$T$1191)
.dwattr $C$DW$T$2195, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2195, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$2195, DW_AT_decl_line(0x454)
.dwattr $C$DW$T$2195, DW_AT_decl_column(0x03)
$C$DW$T$1187 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1187, DW_AT_type(*$C$DW$T$1191)
.dwattr $C$DW$T$1187, DW_AT_address_class(0x20)
$C$DW$T$1190 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1190, DW_AT_type(*$C$DW$T$1187)
.dwattr $C$DW$T$1190, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$609 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$609, DW_AT_type(*$C$DW$T$1189)
.dwendtag $C$DW$T$1190
$C$DW$T$1215 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1215, DW_AT_name("ContextBe")
.dwattr $C$DW$T$1215, DW_AT_byte_size(0x3eb570)
$C$DW$610 .dwtag DW_TAG_member
.dwattr $C$DW$610, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$610, DW_AT_name("sSize")
.dwattr $C$DW$610, DW_AT_TI_symbol_name("sSize")
.dwattr $C$DW$610, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$610, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$610, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$610, DW_AT_decl_line(0xd3)
.dwattr $C$DW$610, DW_AT_decl_column(0x0b)
$C$DW$611 .dwtag DW_TAG_member
.dwattr $C$DW$611, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$611, DW_AT_name("lSize")
.dwattr $C$DW$611, DW_AT_TI_symbol_name("lSize")
.dwattr $C$DW$611, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$611, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$611, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$611, DW_AT_decl_line(0xd4)
.dwattr $C$DW$611, DW_AT_decl_column(0x0b)
$C$DW$612 .dwtag DW_TAG_member
.dwattr $C$DW$612, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$612, DW_AT_name("startLine")
.dwattr $C$DW$612, DW_AT_TI_symbol_name("startLine")
.dwattr $C$DW$612, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$612, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$612, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$612, DW_AT_decl_line(0xd6)
.dwattr $C$DW$612, DW_AT_decl_column(0x0b)
$C$DW$613 .dwtag DW_TAG_member
.dwattr $C$DW$613, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$613, DW_AT_name("startSample")
.dwattr $C$DW$613, DW_AT_TI_symbol_name("startSample")
.dwattr $C$DW$613, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$613, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$613, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$613, DW_AT_decl_line(0xd7)
.dwattr $C$DW$613, DW_AT_decl_column(0x0b)
$C$DW$614 .dwtag DW_TAG_member
.dwattr $C$DW$614, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$614, DW_AT_name("level")
.dwattr $C$DW$614, DW_AT_TI_symbol_name("level")
.dwattr $C$DW$614, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$614, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$614, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$614, DW_AT_decl_line(0xd9)
.dwattr $C$DW$614, DW_AT_decl_column(0x0b)
$C$DW$615 .dwtag DW_TAG_member
.dwattr $C$DW$615, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$615, DW_AT_name("samplePerMm")
.dwattr $C$DW$615, DW_AT_TI_symbol_name("samplePerMm")
.dwattr $C$DW$615, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$615, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$615, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$615, DW_AT_decl_line(0xdb)
.dwattr $C$DW$615, DW_AT_decl_column(0x0c)
$C$DW$616 .dwtag DW_TAG_member
.dwattr $C$DW$616, DW_AT_type(*$C$DW$T$1109)
.dwattr $C$DW$616, DW_AT_name("inInfo")
.dwattr $C$DW$616, DW_AT_TI_symbol_name("inInfo")
.dwattr $C$DW$616, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$616, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$616, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$616, DW_AT_decl_line(0xdd)
.dwattr $C$DW$616, DW_AT_decl_column(0x10)
$C$DW$617 .dwtag DW_TAG_member
.dwattr $C$DW$617, DW_AT_type(*$C$DW$T$1192)
.dwattr $C$DW$617, DW_AT_name("inInfoSub")
.dwattr $C$DW$617, DW_AT_TI_symbol_name("inInfoSub")
.dwattr $C$DW$617, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$617, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$617, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$617, DW_AT_decl_line(0xde)
.dwattr $C$DW$617, DW_AT_decl_column(0x10)
$C$DW$618 .dwtag DW_TAG_member
.dwattr $C$DW$618, DW_AT_type(*$C$DW$T$1193)
.dwattr $C$DW$618, DW_AT_name("info")
.dwattr $C$DW$618, DW_AT_TI_symbol_name("info")
.dwattr $C$DW$618, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$618, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$618, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$618, DW_AT_decl_line(0xdf)
.dwattr $C$DW$618, DW_AT_decl_column(0x10)
$C$DW$619 .dwtag DW_TAG_member
.dwattr $C$DW$619, DW_AT_type(*$C$DW$T$1109)
.dwattr $C$DW$619, DW_AT_name("outInfo")
.dwattr $C$DW$619, DW_AT_TI_symbol_name("outInfo")
.dwattr $C$DW$619, DW_AT_data_member_location[DW_OP_plus_uconst 0xd8]
.dwattr $C$DW$619, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$619, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$619, DW_AT_decl_line(0xe0)
.dwattr $C$DW$619, DW_AT_decl_column(0x10)
$C$DW$620 .dwtag DW_TAG_member
.dwattr $C$DW$620, DW_AT_type(*$C$DW$T$1194)
.dwattr $C$DW$620, DW_AT_name("infoSub")
.dwattr $C$DW$620, DW_AT_TI_symbol_name("infoSub")
.dwattr $C$DW$620, DW_AT_data_member_location[DW_OP_plus_uconst 0xf0]
.dwattr $C$DW$620, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$620, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$620, DW_AT_decl_line(0xe1)
.dwattr $C$DW$620, DW_AT_decl_column(0x10)
$C$DW$621 .dwtag DW_TAG_member
.dwattr $C$DW$621, DW_AT_type(*$C$DW$T$1195)
.dwattr $C$DW$621, DW_AT_name("inLineOffset")
.dwattr $C$DW$621, DW_AT_TI_symbol_name("inLineOffset")
.dwattr $C$DW$621, DW_AT_data_member_location[DW_OP_plus_uconst 0x1e0]
.dwattr $C$DW$621, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$621, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$621, DW_AT_decl_line(0xe3)
.dwattr $C$DW$621, DW_AT_decl_column(0x0b)
$C$DW$622 .dwtag DW_TAG_member
.dwattr $C$DW$622, DW_AT_type(*$C$DW$T$1195)
.dwattr $C$DW$622, DW_AT_name("outLineOffset")
.dwattr $C$DW$622, DW_AT_TI_symbol_name("outLineOffset")
.dwattr $C$DW$622, DW_AT_data_member_location[DW_OP_plus_uconst 0x1e8]
.dwattr $C$DW$622, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$622, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$622, DW_AT_decl_line(0xe4)
.dwattr $C$DW$622, DW_AT_decl_column(0x0b)
$C$DW$623 .dwtag DW_TAG_member
.dwattr $C$DW$623, DW_AT_type(*$C$DW$T$994)
.dwattr $C$DW$623, DW_AT_name("iqInfo")
.dwattr $C$DW$623, DW_AT_TI_symbol_name("iqInfo")
.dwattr $C$DW$623, DW_AT_data_member_location[DW_OP_plus_uconst 0x1f0]
.dwattr $C$DW$623, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$623, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$623, DW_AT_decl_line(0xe6)
.dwattr $C$DW$623, DW_AT_decl_column(0x10)
$C$DW$624 .dwtag DW_TAG_member
.dwattr $C$DW$624, DW_AT_type(*$C$DW$T$253)
.dwattr $C$DW$624, DW_AT_name("imageB")
.dwattr $C$DW$624, DW_AT_TI_symbol_name("imageB")
.dwattr $C$DW$624, DW_AT_data_member_location[DW_OP_plus_uconst 0x210]
.dwattr $C$DW$624, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$624, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$624, DW_AT_decl_line(0xe9)
.dwattr $C$DW$624, DW_AT_decl_column(0x22)
$C$DW$625 .dwtag DW_TAG_member
.dwattr $C$DW$625, DW_AT_type(*$C$DW$T$1549)
.dwattr $C$DW$625, DW_AT_name("fill")
.dwattr $C$DW$625, DW_AT_TI_symbol_name("fill")
.dwattr $C$DW$625, DW_AT_data_member_location[DW_OP_plus_uconst 0x854]
.dwattr $C$DW$625, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$625, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$625, DW_AT_decl_line(0xeb)
.dwattr $C$DW$625, DW_AT_decl_column(0x0f)
$C$DW$626 .dwtag DW_TAG_member
.dwattr $C$DW$626, DW_AT_type(*$C$DW$T$1196)
.dwattr $C$DW$626, DW_AT_name("emphasis1")
.dwattr $C$DW$626, DW_AT_TI_symbol_name("emphasis1")
.dwattr $C$DW$626, DW_AT_data_member_location[DW_OP_plus_uconst 0x860]
.dwattr $C$DW$626, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$626, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$626, DW_AT_decl_line(0xed)
.dwattr $C$DW$626, DW_AT_decl_column(0x0f)
$C$DW$627 .dwtag DW_TAG_member
.dwattr $C$DW$627, DW_AT_type(*$C$DW$T$1196)
.dwattr $C$DW$627, DW_AT_name("emphasis2")
.dwattr $C$DW$627, DW_AT_TI_symbol_name("emphasis2")
.dwattr $C$DW$627, DW_AT_data_member_location[DW_OP_plus_uconst 0x89c]
.dwattr $C$DW$627, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$627, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$627, DW_AT_decl_line(0xee)
.dwattr $C$DW$627, DW_AT_decl_column(0x0f)
$C$DW$628 .dwtag DW_TAG_member
.dwattr $C$DW$628, DW_AT_type(*$C$DW$T$989)
.dwattr $C$DW$628, DW_AT_name("gauss")
.dwattr $C$DW$628, DW_AT_TI_symbol_name("gauss")
.dwattr $C$DW$628, DW_AT_data_member_location[DW_OP_plus_uconst 0x8d8]
.dwattr $C$DW$628, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$628, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$628, DW_AT_decl_line(0xf1)
.dwattr $C$DW$628, DW_AT_decl_column(0x12)
$C$DW$629 .dwtag DW_TAG_member
.dwattr $C$DW$629, DW_AT_type(*$C$DW$T$989)
.dwattr $C$DW$629, DW_AT_name("gaussPyramid")
.dwattr $C$DW$629, DW_AT_TI_symbol_name("gaussPyramid")
.dwattr $C$DW$629, DW_AT_data_member_location[DW_OP_plus_uconst 0x960]
.dwattr $C$DW$629, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$629, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$629, DW_AT_decl_line(0xf2)
.dwattr $C$DW$629, DW_AT_decl_column(0x12)
$C$DW$630 .dwtag DW_TAG_member
.dwattr $C$DW$630, DW_AT_type(*$C$DW$T$1233)
.dwattr $C$DW$630, DW_AT_name("edgeRange")
.dwattr $C$DW$630, DW_AT_TI_symbol_name("edgeRange")
.dwattr $C$DW$630, DW_AT_data_member_location[DW_OP_plus_uconst 0x9e8]
.dwattr $C$DW$630, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$630, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$630, DW_AT_decl_line(0xf4)
.dwattr $C$DW$630, DW_AT_decl_column(0x16)
$C$DW$631 .dwtag DW_TAG_member
.dwattr $C$DW$631, DW_AT_type(*$C$DW$T$1227)
.dwattr $C$DW$631, DW_AT_name("edgeDir")
.dwattr $C$DW$631, DW_AT_TI_symbol_name("edgeDir")
.dwattr $C$DW$631, DW_AT_data_member_location[DW_OP_plus_uconst 0x140ccc]
.dwattr $C$DW$631, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$631, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$631, DW_AT_decl_line(0xf5)
.dwattr $C$DW$631, DW_AT_decl_column(0x16)
$C$DW$632 .dwtag DW_TAG_member
.dwattr $C$DW$632, DW_AT_type(*$C$DW$T$1490)
.dwattr $C$DW$632, DW_AT_name("bspFilter")
.dwattr $C$DW$632, DW_AT_TI_symbol_name("bspFilter")
.dwattr $C$DW$632, DW_AT_data_member_location[DW_OP_plus_uconst 0x142fdc]
.dwattr $C$DW$632, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$632, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$632, DW_AT_decl_line(0xf7)
.dwattr $C$DW$632, DW_AT_decl_column(0x14)
$C$DW$633 .dwtag DW_TAG_member
.dwattr $C$DW$633, DW_AT_type(*$C$DW$T$1197)
.dwattr $C$DW$633, DW_AT_name("lapDir0")
.dwattr $C$DW$633, DW_AT_TI_symbol_name("lapDir0")
.dwattr $C$DW$633, DW_AT_data_member_location[DW_OP_plus_uconst 0x142ff0]
.dwattr $C$DW$633, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$633, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$633, DW_AT_decl_line(0xf9)
.dwattr $C$DW$633, DW_AT_decl_column(0x12)
$C$DW$634 .dwtag DW_TAG_member
.dwattr $C$DW$634, DW_AT_type(*$C$DW$T$1198)
.dwattr $C$DW$634, DW_AT_name("drange")
.dwattr $C$DW$634, DW_AT_TI_symbol_name("drange")
.dwattr $C$DW$634, DW_AT_data_member_location[DW_OP_plus_uconst 0x143298]
.dwattr $C$DW$634, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$634, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$634, DW_AT_decl_line(0xfb)
.dwattr $C$DW$634, DW_AT_decl_column(0x14)
$C$DW$635 .dwtag DW_TAG_member
.dwattr $C$DW$635, DW_AT_type(*$C$DW$T$1199)
.dwattr $C$DW$635, DW_AT_name("pCvizRemapTable")
.dwattr $C$DW$635, DW_AT_TI_symbol_name("pCvizRemapTable")
.dwattr $C$DW$635, DW_AT_data_member_location[DW_OP_plus_uconst 0x14329c]
.dwattr $C$DW$635, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$635, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$635, DW_AT_decl_line(0xfe)
.dwattr $C$DW$635, DW_AT_decl_column(0x14)
$C$DW$636 .dwtag DW_TAG_member
.dwattr $C$DW$636, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$636, DW_AT_name("activeRemapTableIndex")
.dwattr $C$DW$636, DW_AT_TI_symbol_name("activeRemapTableIndex")
.dwattr $C$DW$636, DW_AT_data_member_location[DW_OP_plus_uconst 0x1432a4]
.dwattr $C$DW$636, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$636, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$636, DW_AT_decl_line(0xff)
.dwattr $C$DW$636, DW_AT_decl_column(0x14)
$C$DW$637 .dwtag DW_TAG_member
.dwattr $C$DW$637, DW_AT_type(*$C$DW$T$1200)
.dwattr $C$DW$637, DW_AT_name("nep")
.dwattr $C$DW$637, DW_AT_TI_symbol_name("nep")
.dwattr $C$DW$637, DW_AT_data_member_location[DW_OP_plus_uconst 0x1432a8]
.dwattr $C$DW$637, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$637, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$637, DW_AT_decl_line(0x102)
.dwattr $C$DW$637, DW_AT_decl_column(0x12)
$C$DW$638 .dwtag DW_TAG_member
.dwattr $C$DW$638, DW_AT_type(*$C$DW$T$1200)
.dwattr $C$DW$638, DW_AT_name("nepS")
.dwattr $C$DW$638, DW_AT_TI_symbol_name("nepS")
.dwattr $C$DW$638, DW_AT_data_member_location[DW_OP_plus_uconst 0x2832f8]
.dwattr $C$DW$638, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$638, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$638, DW_AT_decl_line(0x103)
.dwattr $C$DW$638, DW_AT_decl_column(0x12)
$C$DW$639 .dwtag DW_TAG_member
.dwattr $C$DW$639, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$639, DW_AT_name("resample")
.dwattr $C$DW$639, DW_AT_TI_symbol_name("resample")
.dwattr $C$DW$639, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c3348]
.dwattr $C$DW$639, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$639, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$639, DW_AT_decl_line(0x104)
.dwattr $C$DW$639, DW_AT_decl_column(0x15)
$C$DW$640 .dwtag DW_TAG_member
.dwattr $C$DW$640, DW_AT_type(*$C$DW$T$1201)
.dwattr $C$DW$640, DW_AT_name("calcNepWeightTblWorkBuf")
.dwattr $C$DW$640, DW_AT_TI_symbol_name("calcNepWeightTblWorkBuf")
.dwattr $C$DW$640, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c334c]
.dwattr $C$DW$640, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$640, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$640, DW_AT_decl_line(0x106)
.dwattr $C$DW$640, DW_AT_decl_column(0x0e)
$C$DW$641 .dwtag DW_TAG_member
.dwattr $C$DW$641, DW_AT_type(*$C$DW$T$1221)
.dwattr $C$DW$641, DW_AT_name("image")
.dwattr $C$DW$641, DW_AT_TI_symbol_name("image")
.dwattr $C$DW$641, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e334c]
.dwattr $C$DW$641, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$641, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$641, DW_AT_decl_line(0x109)
.dwattr $C$DW$641, DW_AT_decl_column(0x14)
$C$DW$642 .dwtag DW_TAG_member
.dwattr $C$DW$642, DW_AT_type(*$C$DW$T$1202)
.dwattr $C$DW$642, DW_AT_name("actualParam")
.dwattr $C$DW$642, DW_AT_TI_symbol_name("actualParam")
.dwattr $C$DW$642, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e3450]
.dwattr $C$DW$642, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$642, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$642, DW_AT_decl_line(0x10c)
.dwattr $C$DW$642, DW_AT_decl_column(0x14)
$C$DW$643 .dwtag DW_TAG_member
.dwattr $C$DW$643, DW_AT_type(*$C$DW$T$1202)
.dwattr $C$DW$643, DW_AT_name("tempParam")
.dwattr $C$DW$643, DW_AT_TI_symbol_name("tempParam")
.dwattr $C$DW$643, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e4068]
.dwattr $C$DW$643, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$643, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$643, DW_AT_decl_line(0x10f)
.dwattr $C$DW$643, DW_AT_decl_column(0x14)
$C$DW$644 .dwtag DW_TAG_member
.dwattr $C$DW$644, DW_AT_type(*$C$DW$T$1203)
.dwattr $C$DW$644, DW_AT_name("anisoTmpFloat")
.dwattr $C$DW$644, DW_AT_TI_symbol_name("anisoTmpFloat")
.dwattr $C$DW$644, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e4c80]
.dwattr $C$DW$644, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$644, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$644, DW_AT_decl_line(0x112)
.dwattr $C$DW$644, DW_AT_decl_column(0x0b)
$C$DW$645 .dwtag DW_TAG_member
.dwattr $C$DW$645, DW_AT_type(*$C$DW$T$1204)
.dwattr $C$DW$645, DW_AT_name("anisoTmpIpInt")
.dwattr $C$DW$645, DW_AT_TI_symbol_name("anisoTmpIpInt")
.dwattr $C$DW$645, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e4fa0]
.dwattr $C$DW$645, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$645, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$645, DW_AT_decl_line(0x115)
.dwattr $C$DW$645, DW_AT_decl_column(0x0c)
$C$DW$646 .dwtag DW_TAG_member
.dwattr $C$DW$646, DW_AT_type(*$C$DW$T$248)
.dwattr $C$DW$646, DW_AT_name("multiProcEnabled")
.dwattr $C$DW$646, DW_AT_TI_symbol_name("multiProcEnabled")
.dwattr $C$DW$646, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e5130]
.dwattr $C$DW$646, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$646, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$646, DW_AT_decl_line(0x117)
.dwattr $C$DW$646, DW_AT_decl_column(0x0a)
$C$DW$647 .dwtag DW_TAG_member
.dwattr $C$DW$647, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$647, DW_AT_name("expandSizeX")
.dwattr $C$DW$647, DW_AT_TI_symbol_name("expandSizeX")
.dwattr $C$DW$647, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e5134]
.dwattr $C$DW$647, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$647, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$647, DW_AT_decl_line(0x119)
.dwattr $C$DW$647, DW_AT_decl_column(0x0b)
$C$DW$648 .dwtag DW_TAG_member
.dwattr $C$DW$648, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$648, DW_AT_name("expandSizeY")
.dwattr $C$DW$648, DW_AT_TI_symbol_name("expandSizeY")
.dwattr $C$DW$648, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e5138]
.dwattr $C$DW$648, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$648, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$648, DW_AT_decl_line(0x11a)
.dwattr $C$DW$648, DW_AT_decl_column(0x0b)
$C$DW$649 .dwtag DW_TAG_member
.dwattr $C$DW$649, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$649, DW_AT_name("procType")
.dwattr $C$DW$649, DW_AT_TI_symbol_name("procType")
.dwattr $C$DW$649, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e513c]
.dwattr $C$DW$649, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$649, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$649, DW_AT_decl_line(0x11c)
.dwattr $C$DW$649, DW_AT_decl_column(0x0b)
$C$DW$650 .dwtag DW_TAG_member
.dwattr $C$DW$650, DW_AT_type(*$C$DW$T$1205)
.dwattr $C$DW$650, DW_AT_name("lineOffset")
.dwattr $C$DW$650, DW_AT_TI_symbol_name("lineOffset")
.dwattr $C$DW$650, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e5140]
.dwattr $C$DW$650, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$650, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$650, DW_AT_decl_line(0x11f)
.dwattr $C$DW$650, DW_AT_decl_column(0x0b)
$C$DW$651 .dwtag DW_TAG_member
.dwattr $C$DW$651, DW_AT_type(*$C$DW$T$1205)
.dwattr $C$DW$651, DW_AT_name("numLateralEst")
.dwattr $C$DW$651, DW_AT_TI_symbol_name("numLateralEst")
.dwattr $C$DW$651, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e5ee0]
.dwattr $C$DW$651, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$651, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$651, DW_AT_decl_line(0x120)
.dwattr $C$DW$651, DW_AT_decl_column(0x0b)
$C$DW$652 .dwtag DW_TAG_member
.dwattr $C$DW$652, DW_AT_type(*$C$DW$T$1206)
.dwattr $C$DW$652, DW_AT_name("estOffset")
.dwattr $C$DW$652, DW_AT_TI_symbol_name("estOffset")
.dwattr $C$DW$652, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e6c80]
.dwattr $C$DW$652, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$652, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$652, DW_AT_decl_line(0x121)
.dwattr $C$DW$652, DW_AT_decl_column(0x0b)
$C$DW$653 .dwtag DW_TAG_member
.dwattr $C$DW$653, DW_AT_type(*$C$DW$T$1206)
.dwattr $C$DW$653, DW_AT_name("numAxialEst")
.dwattr $C$DW$653, DW_AT_TI_symbol_name("numAxialEst")
.dwattr $C$DW$653, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e7c80]
.dwattr $C$DW$653, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$653, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$653, DW_AT_decl_line(0x122)
.dwattr $C$DW$653, DW_AT_decl_column(0x0b)
$C$DW$654 .dwtag DW_TAG_member
.dwattr $C$DW$654, DW_AT_type(*$C$DW$T$1207)
.dwattr $C$DW$654, DW_AT_name("numAxialOffsetSub")
.dwattr $C$DW$654, DW_AT_TI_symbol_name("numAxialOffsetSub")
.dwattr $C$DW$654, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e8c80]
.dwattr $C$DW$654, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$654, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$654, DW_AT_decl_line(0x123)
.dwattr $C$DW$654, DW_AT_decl_column(0x0b)
$C$DW$655 .dwtag DW_TAG_member
.dwattr $C$DW$655, DW_AT_type(*$C$DW$T$1208)
.dwattr $C$DW$655, DW_AT_name("numAxialOffset")
.dwattr $C$DW$655, DW_AT_TI_symbol_name("numAxialOffset")
.dwattr $C$DW$655, DW_AT_data_member_location[DW_OP_plus_uconst 0x3ea7c0]
.dwattr $C$DW$655, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$655, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$655, DW_AT_decl_line(0x124)
.dwattr $C$DW$655, DW_AT_decl_column(0x0c)
$C$DW$656 .dwtag DW_TAG_member
.dwattr $C$DW$656, DW_AT_type(*$C$DW$T$1210)
.dwattr $C$DW$656, DW_AT_name("numAxialOffsetSub2")
.dwattr $C$DW$656, DW_AT_TI_symbol_name("numAxialOffsetSub2")
.dwattr $C$DW$656, DW_AT_data_member_location[DW_OP_plus_uconst 0x3ea7c4]
.dwattr $C$DW$656, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$656, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$656, DW_AT_decl_line(0x125)
.dwattr $C$DW$656, DW_AT_decl_column(0x0b)
$C$DW$657 .dwtag DW_TAG_member
.dwattr $C$DW$657, DW_AT_type(*$C$DW$T$1208)
.dwattr $C$DW$657, DW_AT_name("numAxialOffset2")
.dwattr $C$DW$657, DW_AT_TI_symbol_name("numAxialOffset2")
.dwattr $C$DW$657, DW_AT_data_member_location[DW_OP_plus_uconst 0x3eb564]
.dwattr $C$DW$657, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$657, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$657, DW_AT_decl_line(0x126)
.dwattr $C$DW$657, DW_AT_decl_column(0x0c)
$C$DW$658 .dwtag DW_TAG_member
.dwattr $C$DW$658, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$658, DW_AT_name("frameBoundaryMode")
.dwattr $C$DW$658, DW_AT_TI_symbol_name("frameBoundaryMode")
.dwattr $C$DW$658, DW_AT_data_member_location[DW_OP_plus_uconst 0x3eb568]
.dwattr $C$DW$658, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$658, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$658, DW_AT_decl_line(0x127)
.dwattr $C$DW$658, DW_AT_decl_column(0x0b)
$C$DW$16 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$16, DW_AT_declaration
.dwattr $C$DW$16, DW_AT_TI_symbol_name("_ZN9ContextBeaSERKS_")
.dwattr $C$DW$16, DW_AT_type(*$C$DW$T$1211)
.dwattr $C$DW$16, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$659 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$659, DW_AT_type(*$C$DW$T$1213)
.dwendtag $C$DW$16
.dwendtag $C$DW$T$1215
.dwattr $C$DW$T$1215, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$T$1215, DW_AT_decl_line(0xd1)
.dwattr $C$DW$T$1215, DW_AT_decl_column(0x08)
$C$DW$T$1212 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1212, DW_AT_type(*$C$DW$T$1215)
$C$DW$T$1213 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1213, DW_AT_type(*$C$DW$T$1212)
.dwattr $C$DW$T$1213, DW_AT_address_class(0x20)
$C$DW$T$387 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$387, DW_AT_type(*$C$DW$T$1215)
.dwattr $C$DW$T$387, DW_AT_address_class(0x20)
$C$DW$T$2196 .dwtag DW_TAG_typedef, DW_AT_name("CVIZ_Context")
.dwattr $C$DW$T$2196, DW_AT_type(*$C$DW$T$387)
.dwattr $C$DW$T$2196, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2196, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/include/ClearVisualization.h")
.dwattr $C$DW$T$2196, DW_AT_decl_line(0x67)
.dwattr $C$DW$T$2196, DW_AT_decl_column(0x1b)
$C$DW$T$1211 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1211, DW_AT_type(*$C$DW$T$1215)
.dwattr $C$DW$T$1211, DW_AT_address_class(0x20)
$C$DW$T$1214 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1214, DW_AT_type(*$C$DW$T$1211)
.dwattr $C$DW$T$1214, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$660 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$660, DW_AT_type(*$C$DW$T$1213)
.dwendtag $C$DW$T$1214
$C$DW$T$1221 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1221, DW_AT_name("ContextBeImage")
.dwattr $C$DW$T$1221, DW_AT_byte_size(0x104)
$C$DW$661 .dwtag DW_TAG_member
.dwattr $C$DW$661, DW_AT_type(*$C$DW$T$416)
.dwattr $C$DW$661, DW_AT_name("outTrape")
.dwattr $C$DW$661, DW_AT_TI_symbol_name("outTrape")
.dwattr $C$DW$661, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$661, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$661, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$661, DW_AT_decl_line(0x95)
.dwattr $C$DW$661, DW_AT_decl_column(0x0f)
$C$DW$662 .dwtag DW_TAG_member
.dwattr $C$DW$662, DW_AT_type(*$C$DW$T$416)
.dwattr $C$DW$662, DW_AT_name("pre")
.dwattr $C$DW$662, DW_AT_TI_symbol_name("pre")
.dwattr $C$DW$662, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$662, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$662, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$662, DW_AT_decl_line(0x96)
.dwattr $C$DW$662, DW_AT_decl_column(0x12)
$C$DW$663 .dwtag DW_TAG_member
.dwattr $C$DW$663, DW_AT_type(*$C$DW$T$1065)
.dwattr $C$DW$663, DW_AT_name("gaussian")
.dwattr $C$DW$663, DW_AT_TI_symbol_name("gaussian")
.dwattr $C$DW$663, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$663, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$663, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$663, DW_AT_decl_line(0x97)
.dwattr $C$DW$663, DW_AT_decl_column(0x12)
$C$DW$664 .dwtag DW_TAG_member
.dwattr $C$DW$664, DW_AT_type(*$C$DW$T$1065)
.dwattr $C$DW$664, DW_AT_name("edgeRange")
.dwattr $C$DW$664, DW_AT_TI_symbol_name("edgeRange")
.dwattr $C$DW$664, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c]
.dwattr $C$DW$664, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$664, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$664, DW_AT_decl_line(0x98)
.dwattr $C$DW$664, DW_AT_decl_column(0x12)
$C$DW$665 .dwtag DW_TAG_member
.dwattr $C$DW$665, DW_AT_type(*$C$DW$T$1065)
.dwattr $C$DW$665, DW_AT_name("edgeDir")
.dwattr $C$DW$665, DW_AT_TI_symbol_name("edgeDir")
.dwattr $C$DW$665, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$665, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$665, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$665, DW_AT_decl_line(0x99)
.dwattr $C$DW$665, DW_AT_decl_column(0x12)
$C$DW$666 .dwtag DW_TAG_member
.dwattr $C$DW$666, DW_AT_type(*$C$DW$T$1065)
.dwattr $C$DW$666, DW_AT_name("lapPyramid")
.dwattr $C$DW$666, DW_AT_TI_symbol_name("lapPyramid")
.dwattr $C$DW$666, DW_AT_data_member_location[DW_OP_plus_uconst 0x44]
.dwattr $C$DW$666, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$666, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$666, DW_AT_decl_line(0x9a)
.dwattr $C$DW$666, DW_AT_decl_column(0x12)
$C$DW$667 .dwtag DW_TAG_member
.dwattr $C$DW$667, DW_AT_type(*$C$DW$T$1216)
.dwattr $C$DW$667, DW_AT_name("lapDir")
.dwattr $C$DW$667, DW_AT_TI_symbol_name("lapDir")
.dwattr $C$DW$667, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$667, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$667, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$667, DW_AT_decl_line(0x9b)
.dwattr $C$DW$667, DW_AT_decl_column(0x12)
$C$DW$668 .dwtag DW_TAG_member
.dwattr $C$DW$668, DW_AT_type(*$C$DW$T$1071)
.dwattr $C$DW$668, DW_AT_name("edgeDirWork")
.dwattr $C$DW$668, DW_AT_TI_symbol_name("edgeDirWork")
.dwattr $C$DW$668, DW_AT_data_member_location[DW_OP_plus_uconst 0x80]
.dwattr $C$DW$668, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$668, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$668, DW_AT_decl_line(0x9c)
.dwattr $C$DW$668, DW_AT_decl_column(0x12)
$C$DW$669 .dwtag DW_TAG_member
.dwattr $C$DW$669, DW_AT_type(*$C$DW$T$1065)
.dwattr $C$DW$669, DW_AT_name("adapt")
.dwattr $C$DW$669, DW_AT_TI_symbol_name("adapt")
.dwattr $C$DW$669, DW_AT_data_member_location[DW_OP_plus_uconst 0xe4]
.dwattr $C$DW$669, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$669, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$669, DW_AT_decl_line(0x9d)
.dwattr $C$DW$669, DW_AT_decl_column(0x12)
$C$DW$670 .dwtag DW_TAG_member
.dwattr $C$DW$670, DW_AT_type(*$C$DW$T$416)
.dwattr $C$DW$670, DW_AT_name("lapDirCoef")
.dwattr $C$DW$670, DW_AT_TI_symbol_name("lapDirCoef")
.dwattr $C$DW$670, DW_AT_data_member_location[DW_OP_plus_uconst 0xf8]
.dwattr $C$DW$670, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$670, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$670, DW_AT_decl_line(0x9e)
.dwattr $C$DW$670, DW_AT_decl_column(0x12)
$C$DW$671 .dwtag DW_TAG_member
.dwattr $C$DW$671, DW_AT_type(*$C$DW$T$416)
.dwattr $C$DW$671, DW_AT_name("lineBuf")
.dwattr $C$DW$671, DW_AT_TI_symbol_name("lineBuf")
.dwattr $C$DW$671, DW_AT_data_member_location[DW_OP_plus_uconst 0xfc]
.dwattr $C$DW$671, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$671, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$671, DW_AT_decl_line(0x9f)
.dwattr $C$DW$671, DW_AT_decl_column(0x12)
$C$DW$672 .dwtag DW_TAG_member
.dwattr $C$DW$672, DW_AT_type(*$C$DW$T$416)
.dwattr $C$DW$672, DW_AT_name("stitch")
.dwattr $C$DW$672, DW_AT_TI_symbol_name("stitch")
.dwattr $C$DW$672, DW_AT_data_member_location[DW_OP_plus_uconst 0x100]
.dwattr $C$DW$672, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$672, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$672, DW_AT_decl_line(0xa0)
.dwattr $C$DW$672, DW_AT_decl_column(0x12)
$C$DW$17 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$17, DW_AT_declaration
.dwattr $C$DW$17, DW_AT_TI_symbol_name("_ZN14ContextBeImageaSERKS_")
.dwattr $C$DW$17, DW_AT_type(*$C$DW$T$1217)
.dwattr $C$DW$17, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$673 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$673, DW_AT_type(*$C$DW$T$1219)
.dwendtag $C$DW$17
.dwendtag $C$DW$T$1221
.dwattr $C$DW$T$1221, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$T$1221, DW_AT_decl_line(0x93)
.dwattr $C$DW$T$1221, DW_AT_decl_column(0x08)
$C$DW$T$1218 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1218, DW_AT_type(*$C$DW$T$1221)
$C$DW$T$1219 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1219, DW_AT_type(*$C$DW$T$1218)
.dwattr $C$DW$T$1219, DW_AT_address_class(0x20)
$C$DW$T$1217 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1217, DW_AT_type(*$C$DW$T$1221)
.dwattr $C$DW$T$1217, DW_AT_address_class(0x20)
$C$DW$T$1220 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1220, DW_AT_type(*$C$DW$T$1217)
.dwattr $C$DW$T$1220, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$674 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$674, DW_AT_type(*$C$DW$T$1219)
.dwendtag $C$DW$T$1220
$C$DW$T$1227 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1227, DW_AT_name("ContextEdgeDir")
.dwattr $C$DW$T$1227, DW_AT_byte_size(0x2310)
$C$DW$675 .dwtag DW_TAG_member
.dwattr $C$DW$675, DW_AT_type(*$C$DW$T$1197)
.dwattr $C$DW$675, DW_AT_name("filter")
.dwattr $C$DW$675, DW_AT_TI_symbol_name("filter")
.dwattr $C$DW$675, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$675, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$675, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$675, DW_AT_decl_line(0xae)
.dwattr $C$DW$675, DW_AT_decl_column(0x19)
$C$DW$676 .dwtag DW_TAG_member
.dwattr $C$DW$676, DW_AT_type(*$C$DW$T$1222)
.dwattr $C$DW$676, DW_AT_name("dirFilter")
.dwattr $C$DW$676, DW_AT_TI_symbol_name("dirFilter")
.dwattr $C$DW$676, DW_AT_data_member_location[DW_OP_plus_uconst 0x2a8]
.dwattr $C$DW$676, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$676, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$676, DW_AT_decl_line(0xb0)
.dwattr $C$DW$676, DW_AT_decl_column(0x15)
$C$DW$677 .dwtag DW_TAG_member
.dwattr $C$DW$677, DW_AT_type(*$C$DW$T$1036)
.dwattr $C$DW$677, DW_AT_name("dirParam")
.dwattr $C$DW$677, DW_AT_TI_symbol_name("dirParam")
.dwattr $C$DW$677, DW_AT_data_member_location[DW_OP_plus_uconst 0x378]
.dwattr $C$DW$677, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$677, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$677, DW_AT_decl_line(0xb1)
.dwattr $C$DW$677, DW_AT_decl_column(0x13)
$C$DW$678 .dwtag DW_TAG_member
.dwattr $C$DW$678, DW_AT_type(*$C$DW$T$1490)
.dwattr $C$DW$678, DW_AT_name("bspFilter")
.dwattr $C$DW$678, DW_AT_TI_symbol_name("bspFilter")
.dwattr $C$DW$678, DW_AT_data_member_location[DW_OP_plus_uconst 0x22c0]
.dwattr $C$DW$678, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$678, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$678, DW_AT_decl_line(0xb2)
.dwattr $C$DW$678, DW_AT_decl_column(0x15)
$C$DW$679 .dwtag DW_TAG_member
.dwattr $C$DW$679, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$679, DW_AT_name("calc")
.dwattr $C$DW$679, DW_AT_TI_symbol_name("calc")
.dwattr $C$DW$679, DW_AT_data_member_location[DW_OP_plus_uconst 0x22d4]
.dwattr $C$DW$679, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$679, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$679, DW_AT_decl_line(0xb4)
.dwattr $C$DW$679, DW_AT_decl_column(0x09)
$C$DW$680 .dwtag DW_TAG_member
.dwattr $C$DW$680, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$680, DW_AT_name("calcDir")
.dwattr $C$DW$680, DW_AT_TI_symbol_name("calcDir")
.dwattr $C$DW$680, DW_AT_data_member_location[DW_OP_plus_uconst 0x22e8]
.dwattr $C$DW$680, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$680, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$680, DW_AT_decl_line(0xb5)
.dwattr $C$DW$680, DW_AT_decl_column(0x09)
$C$DW$681 .dwtag DW_TAG_member
.dwattr $C$DW$681, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$681, DW_AT_name("calcDet")
.dwattr $C$DW$681, DW_AT_TI_symbol_name("calcDet")
.dwattr $C$DW$681, DW_AT_data_member_location[DW_OP_plus_uconst 0x22fc]
.dwattr $C$DW$681, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$681, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$681, DW_AT_decl_line(0xb6)
.dwattr $C$DW$681, DW_AT_decl_column(0x09)
$C$DW$18 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$18, DW_AT_declaration
.dwattr $C$DW$18, DW_AT_TI_symbol_name("_ZN14ContextEdgeDiraSERKS_")
.dwattr $C$DW$18, DW_AT_type(*$C$DW$T$1223)
.dwattr $C$DW$18, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$682 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$682, DW_AT_type(*$C$DW$T$1225)
.dwendtag $C$DW$18
.dwendtag $C$DW$T$1227
.dwattr $C$DW$T$1227, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$T$1227, DW_AT_decl_line(0xac)
.dwattr $C$DW$T$1227, DW_AT_decl_column(0x08)
$C$DW$T$1224 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1224, DW_AT_type(*$C$DW$T$1227)
$C$DW$T$1225 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1225, DW_AT_type(*$C$DW$T$1224)
.dwattr $C$DW$T$1225, DW_AT_address_class(0x20)
$C$DW$T$386 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$386, DW_AT_type(*$C$DW$T$1227)
.dwattr $C$DW$T$386, DW_AT_address_class(0x20)
$C$DW$T$1223 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1223, DW_AT_type(*$C$DW$T$1227)
.dwattr $C$DW$T$1223, DW_AT_address_class(0x20)
$C$DW$T$1226 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1226, DW_AT_type(*$C$DW$T$1223)
.dwattr $C$DW$T$1226, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$683 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$683, DW_AT_type(*$C$DW$T$1225)
.dwendtag $C$DW$T$1226
$C$DW$T$1233 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1233, DW_AT_name("ContextEdgeRange")
.dwattr $C$DW$T$1233, DW_AT_byte_size(0x1402e4)
$C$DW$684 .dwtag DW_TAG_member
.dwattr $C$DW$684, DW_AT_type(*$C$DW$T$1228)
.dwattr $C$DW$684, DW_AT_name("edgeNorm")
.dwattr $C$DW$684, DW_AT_TI_symbol_name("edgeNorm")
.dwattr $C$DW$684, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$684, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$684, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$684, DW_AT_decl_line(0xa6)
.dwattr $C$DW$684, DW_AT_decl_column(0x14)
$C$DW$685 .dwtag DW_TAG_member
.dwattr $C$DW$685, DW_AT_type(*$C$DW$T$1197)
.dwattr $C$DW$685, DW_AT_name("filter")
.dwattr $C$DW$685, DW_AT_TI_symbol_name("filter")
.dwattr $C$DW$685, DW_AT_data_member_location[DW_OP_plus_uconst 0x140028]
.dwattr $C$DW$685, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$685, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$685, DW_AT_decl_line(0xa7)
.dwattr $C$DW$685, DW_AT_decl_column(0x19)
$C$DW$686 .dwtag DW_TAG_member
.dwattr $C$DW$686, DW_AT_type(*$C$DW$T$1490)
.dwattr $C$DW$686, DW_AT_name("bspFilter")
.dwattr $C$DW$686, DW_AT_TI_symbol_name("bspFilter")
.dwattr $C$DW$686, DW_AT_data_member_location[DW_OP_plus_uconst 0x1402d0]
.dwattr $C$DW$686, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$686, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$686, DW_AT_decl_line(0xa8)
.dwattr $C$DW$686, DW_AT_decl_column(0x15)
$C$DW$19 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$19, DW_AT_declaration
.dwattr $C$DW$19, DW_AT_TI_symbol_name("_ZN16ContextEdgeRangeaSERKS_")
.dwattr $C$DW$19, DW_AT_type(*$C$DW$T$1229)
.dwattr $C$DW$19, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$687 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$687, DW_AT_type(*$C$DW$T$1231)
.dwendtag $C$DW$19
.dwendtag $C$DW$T$1233
.dwattr $C$DW$T$1233, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$T$1233, DW_AT_decl_line(0xa4)
.dwattr $C$DW$T$1233, DW_AT_decl_column(0x08)
$C$DW$T$1230 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1230, DW_AT_type(*$C$DW$T$1233)
$C$DW$T$1231 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1231, DW_AT_type(*$C$DW$T$1230)
.dwattr $C$DW$T$1231, DW_AT_address_class(0x20)
$C$DW$T$1229 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1229, DW_AT_type(*$C$DW$T$1233)
.dwattr $C$DW$T$1229, DW_AT_address_class(0x20)
$C$DW$T$1232 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1232, DW_AT_type(*$C$DW$T$1229)
.dwattr $C$DW$T$1232, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$688 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$688, DW_AT_type(*$C$DW$T$1231)
.dwendtag $C$DW$T$1232
$C$DW$T$498 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$498, DW_AT_name("DbellMsg")
.dwattr $C$DW$T$498, DW_AT_byte_size(0x30)
$C$DW$689 .dwtag DW_TAG_member
.dwattr $C$DW$689, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$689, DW_AT_name("info")
.dwattr $C$DW$689, DW_AT_TI_symbol_name("info")
.dwattr $C$DW$689, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$689, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$689, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$689, DW_AT_decl_line(0xa8)
.dwattr $C$DW$689, DW_AT_decl_column(0x19)
$C$DW$690 .dwtag DW_TAG_member
.dwattr $C$DW$690, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$690, DW_AT_name("timeStamp")
.dwattr $C$DW$690, DW_AT_TI_symbol_name("timeStamp")
.dwattr $C$DW$690, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$690, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$690, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$690, DW_AT_decl_line(0xab)
.dwattr $C$DW$690, DW_AT_decl_column(0x19)
$C$DW$691 .dwtag DW_TAG_member
.dwattr $C$DW$691, DW_AT_type(*$C$DW$T$493)
.dwattr $C$DW$691, DW_AT_name("data")
.dwattr $C$DW$691, DW_AT_TI_symbol_name("data")
.dwattr $C$DW$691, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$691, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$691, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$691, DW_AT_decl_line(0xac)
.dwattr $C$DW$691, DW_AT_decl_column(0x19)
$C$DW$20 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$20, DW_AT_declaration
.dwattr $C$DW$20, DW_AT_TI_symbol_name("_ZN8DbellMsgaSERKS_")
.dwattr $C$DW$20, DW_AT_type(*$C$DW$T$494)
.dwattr $C$DW$20, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$692 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$692, DW_AT_type(*$C$DW$T$496)
.dwendtag $C$DW$20
.dwendtag $C$DW$T$498
.dwattr $C$DW$T$498, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$498, DW_AT_decl_line(0xa7)
.dwattr $C$DW$T$498, DW_AT_decl_column(0x01)
$C$DW$T$495 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$495, DW_AT_type(*$C$DW$T$498)
$C$DW$T$496 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$496, DW_AT_type(*$C$DW$T$495)
.dwattr $C$DW$T$496, DW_AT_address_class(0x20)
$C$DW$T$1478 .dwtag DW_TAG_typedef, DW_AT_name("DbellMsg")
.dwattr $C$DW$T$1478, DW_AT_type(*$C$DW$T$498)
.dwattr $C$DW$T$1478, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1478, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1478, DW_AT_decl_line(0xad)
.dwattr $C$DW$T$1478, DW_AT_decl_column(0x03)
$C$DW$T$494 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$494, DW_AT_type(*$C$DW$T$498)
.dwattr $C$DW$T$494, DW_AT_address_class(0x20)
$C$DW$T$497 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$497, DW_AT_type(*$C$DW$T$494)
.dwattr $C$DW$T$497, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$693 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$693, DW_AT_type(*$C$DW$T$496)
.dwendtag $C$DW$T$497
$C$DW$T$1030 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1030, DW_AT_name("DirFilterParam")
.dwattr $C$DW$T$1030, DW_AT_byte_size(0x34)
$C$DW$694 .dwtag DW_TAG_member
.dwattr $C$DW$694, DW_AT_type(*$C$DW$T$1025)
.dwattr $C$DW$694, DW_AT_name("coef")
.dwattr $C$DW$694, DW_AT_TI_symbol_name("coef")
.dwattr $C$DW$694, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$694, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$694, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$694, DW_AT_decl_line(0x7e)
.dwattr $C$DW$694, DW_AT_decl_column(0x07)
$C$DW$695 .dwtag DW_TAG_member
.dwattr $C$DW$695, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$695, DW_AT_name("accuracyBits")
.dwattr $C$DW$695, DW_AT_TI_symbol_name("accuracyBits")
.dwattr $C$DW$695, DW_AT_data_member_location[DW_OP_plus_uconst 0x24]
.dwattr $C$DW$695, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$695, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$695, DW_AT_decl_line(0x7f)
.dwattr $C$DW$695, DW_AT_decl_column(0x07)
$C$DW$696 .dwtag DW_TAG_member
.dwattr $C$DW$696, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$696, DW_AT_name("maskh")
.dwattr $C$DW$696, DW_AT_TI_symbol_name("maskh")
.dwattr $C$DW$696, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$696, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$696, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$696, DW_AT_decl_line(0x80)
.dwattr $C$DW$696, DW_AT_decl_column(0x07)
$C$DW$697 .dwtag DW_TAG_member
.dwattr $C$DW$697, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$697, DW_AT_name("alpha")
.dwattr $C$DW$697, DW_AT_TI_symbol_name("alpha")
.dwattr $C$DW$697, DW_AT_data_member_location[DW_OP_plus_uconst 0x2c]
.dwattr $C$DW$697, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$697, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$697, DW_AT_decl_line(0x81)
.dwattr $C$DW$697, DW_AT_decl_column(0x0a)
$C$DW$698 .dwtag DW_TAG_member
.dwattr $C$DW$698, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$698, DW_AT_name("filterType")
.dwattr $C$DW$698, DW_AT_TI_symbol_name("filterType")
.dwattr $C$DW$698, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$698, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$698, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$698, DW_AT_decl_line(0x82)
.dwattr $C$DW$698, DW_AT_decl_column(0x0a)
$C$DW$21 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$21, DW_AT_declaration
.dwattr $C$DW$21, DW_AT_TI_symbol_name("_ZN14DirFilterParamaSERKS_")
.dwattr $C$DW$21, DW_AT_type(*$C$DW$T$1026)
.dwattr $C$DW$21, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$699 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$699, DW_AT_type(*$C$DW$T$1028)
.dwendtag $C$DW$21
.dwendtag $C$DW$T$1030
.dwattr $C$DW$T$1030, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$T$1030, DW_AT_decl_line(0x7c)
.dwattr $C$DW$T$1030, DW_AT_decl_column(0x08)
$C$DW$T$1027 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1027, DW_AT_type(*$C$DW$T$1030)
$C$DW$T$1028 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1028, DW_AT_type(*$C$DW$T$1027)
.dwattr $C$DW$T$1028, DW_AT_address_class(0x20)
$C$DW$T$1026 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1026, DW_AT_type(*$C$DW$T$1030)
.dwattr $C$DW$T$1026, DW_AT_address_class(0x20)
$C$DW$T$1029 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1029, DW_AT_type(*$C$DW$T$1026)
.dwattr $C$DW$T$1029, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$700 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$700, DW_AT_type(*$C$DW$T$1028)
.dwendtag $C$DW$T$1029
$C$DW$T$1222 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1222, DW_AT_type(*$C$DW$T$1030)
.dwattr $C$DW$T$1222, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1222, DW_AT_byte_size(0xd0)
$C$DW$701 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$701, DW_AT_upper_bound(0x03)
.dwendtag $C$DW$T$1222
$C$DW$T$1036 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1036, DW_AT_name("DirLutParam")
.dwattr $C$DW$T$1036, DW_AT_byte_size(0x1f48)
$C$DW$702 .dwtag DW_TAG_member
.dwattr $C$DW$702, DW_AT_type(*$C$DW$T$1031)
.dwattr $C$DW$702, DW_AT_name("lut")
.dwattr $C$DW$702, DW_AT_TI_symbol_name("lut")
.dwattr $C$DW$702, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$702, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$702, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$702, DW_AT_decl_line(0x41)
.dwattr $C$DW$702, DW_AT_decl_column(0x07)
$C$DW$703 .dwtag DW_TAG_member
.dwattr $C$DW$703, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$703, DW_AT_name("dirNum")
.dwattr $C$DW$703, DW_AT_TI_symbol_name("dirNum")
.dwattr $C$DW$703, DW_AT_data_member_location[DW_OP_plus_uconst 0x1f44]
.dwattr $C$DW$703, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$703, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$703, DW_AT_decl_line(0x42)
.dwattr $C$DW$703, DW_AT_decl_column(0x07)
$C$DW$22 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$22, DW_AT_declaration
.dwattr $C$DW$22, DW_AT_TI_symbol_name("_ZN11DirLutParamaSERKS_")
.dwattr $C$DW$22, DW_AT_type(*$C$DW$T$1032)
.dwattr $C$DW$22, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$704 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$704, DW_AT_type(*$C$DW$T$1034)
.dwendtag $C$DW$22
.dwendtag $C$DW$T$1036
.dwattr $C$DW$T$1036, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$T$1036, DW_AT_decl_line(0x3f)
.dwattr $C$DW$T$1036, DW_AT_decl_column(0x08)
$C$DW$T$1033 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1033, DW_AT_type(*$C$DW$T$1036)
$C$DW$T$1034 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1034, DW_AT_type(*$C$DW$T$1033)
.dwattr $C$DW$T$1034, DW_AT_address_class(0x20)
$C$DW$T$1032 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1032, DW_AT_type(*$C$DW$T$1036)
.dwattr $C$DW$T$1032, DW_AT_address_class(0x20)
$C$DW$T$1035 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1035, DW_AT_type(*$C$DW$T$1032)
.dwattr $C$DW$T$1035, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$705 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$705, DW_AT_type(*$C$DW$T$1034)
.dwendtag $C$DW$T$1035
$C$DW$T$2197 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$2197, DW_AT_name("DopplerGapBlankAction")
.dwattr $C$DW$T$2197, DW_AT_byte_size(0x04)
$C$DW$706 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_BLANK_COUNT_RESET"), DW_AT_const_value(0x00)
.dwattr $C$DW$706, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$706, DW_AT_decl_line(0x1c)
.dwattr $C$DW$706, DW_AT_decl_column(0x05)
$C$DW$707 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_BLANK_COUNTDOWN"), DW_AT_const_value(0x01)
.dwattr $C$DW$707, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$707, DW_AT_decl_line(0x1d)
.dwattr $C$DW$707, DW_AT_decl_column(0x05)
$C$DW$708 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_BLANK_DEACTIVATE_COUNTDOWN"), DW_AT_const_value(0x02)
.dwattr $C$DW$708, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$708, DW_AT_decl_line(0x1e)
.dwattr $C$DW$708, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$2197
.dwattr $C$DW$T$2197, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$T$2197, DW_AT_decl_line(0x1b)
.dwattr $C$DW$T$2197, DW_AT_decl_column(0x01)
$C$DW$T$2198 .dwtag DW_TAG_typedef, DW_AT_name("DopplerGapBlankAction")
.dwattr $C$DW$T$2198, DW_AT_type(*$C$DW$T$2197)
.dwattr $C$DW$T$2198, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2198, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$T$2198, DW_AT_decl_line(0x1f)
.dwattr $C$DW$T$2198, DW_AT_decl_column(0x03)
$C$DW$T$1243 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1243, DW_AT_name("DopplerInputData")
.dwattr $C$DW$T$1243, DW_AT_byte_size(0x18)
$C$DW$709 .dwtag DW_TAG_member
.dwattr $C$DW$709, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$709, DW_AT_name("timeStamp")
.dwattr $C$DW$709, DW_AT_TI_symbol_name("timeStamp")
.dwattr $C$DW$709, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$709, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$709, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$709, DW_AT_decl_line(0x2b)
.dwattr $C$DW$709, DW_AT_decl_column(0x19)
$C$DW$710 .dwtag DW_TAG_member
.dwattr $C$DW$710, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$710, DW_AT_name("rfBufIdx")
.dwattr $C$DW$710, DW_AT_TI_symbol_name("rfBufIdx")
.dwattr $C$DW$710, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$710, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$710, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$710, DW_AT_decl_line(0x2c)
.dwattr $C$DW$710, DW_AT_decl_column(0x19)
$C$DW$711 .dwtag DW_TAG_member
.dwattr $C$DW$711, DW_AT_type(*$C$DW$T$520)
.dwattr $C$DW$711, DW_AT_name("data")
.dwattr $C$DW$711, DW_AT_TI_symbol_name("data")
.dwattr $C$DW$711, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$711, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$711, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$711, DW_AT_decl_line(0x2d)
.dwattr $C$DW$711, DW_AT_decl_column(0x19)
$C$DW$23 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$23, DW_AT_declaration
.dwattr $C$DW$23, DW_AT_TI_symbol_name("_ZN16DopplerInputDataaSERKS_")
.dwattr $C$DW$23, DW_AT_type(*$C$DW$T$1239)
.dwattr $C$DW$23, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$712 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$712, DW_AT_type(*$C$DW$T$1241)
.dwendtag $C$DW$23
.dwendtag $C$DW$T$1243
.dwattr $C$DW$T$1243, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1243, DW_AT_decl_line(0x29)
.dwattr $C$DW$T$1243, DW_AT_decl_column(0x01)
$C$DW$T$1164 .dwtag DW_TAG_typedef, DW_AT_name("DopplerInputData")
.dwattr $C$DW$T$1164, DW_AT_type(*$C$DW$T$1243)
.dwattr $C$DW$T$1164, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1164, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1164, DW_AT_decl_line(0x2e)
.dwattr $C$DW$T$1164, DW_AT_decl_column(0x03)
$C$DW$T$1240 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1240, DW_AT_type(*$C$DW$T$1243)
$C$DW$T$1241 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1241, DW_AT_type(*$C$DW$T$1240)
.dwattr $C$DW$T$1241, DW_AT_address_class(0x20)
$C$DW$T$1239 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1239, DW_AT_type(*$C$DW$T$1243)
.dwattr $C$DW$T$1239, DW_AT_address_class(0x20)
$C$DW$T$1242 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1242, DW_AT_type(*$C$DW$T$1239)
.dwattr $C$DW$T$1242, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$713 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$713, DW_AT_type(*$C$DW$T$1241)
.dwendtag $C$DW$T$1242
$C$DW$T$1248 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1248, DW_AT_name("Doppler_GapConfig")
.dwattr $C$DW$T$1248, DW_AT_byte_size(0xa8)
$C$DW$714 .dwtag DW_TAG_member
.dwattr $C$DW$714, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$714, DW_AT_name("burgOrder")
.dwattr $C$DW$714, DW_AT_TI_symbol_name("burgOrder")
.dwattr $C$DW$714, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$714, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$714, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$714, DW_AT_decl_line(0x46a)
.dwattr $C$DW$714, DW_AT_decl_column(0x05)
$C$DW$715 .dwtag DW_TAG_member
.dwattr $C$DW$715, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$715, DW_AT_name("size")
.dwattr $C$DW$715, DW_AT_TI_symbol_name("size")
.dwattr $C$DW$715, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$715, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$715, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$715, DW_AT_decl_line(0x46b)
.dwattr $C$DW$715, DW_AT_decl_column(0x05)
$C$DW$716 .dwtag DW_TAG_member
.dwattr $C$DW$716, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$716, DW_AT_name("numModelSamples")
.dwattr $C$DW$716, DW_AT_TI_symbol_name("numModelSamples")
.dwattr $C$DW$716, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$716, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$716, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$716, DW_AT_decl_line(0x46e)
.dwattr $C$DW$716, DW_AT_decl_column(0x05)
$C$DW$717 .dwtag DW_TAG_member
.dwattr $C$DW$717, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$717, DW_AT_name("numTotalSamples")
.dwattr $C$DW$717, DW_AT_TI_symbol_name("numTotalSamples")
.dwattr $C$DW$717, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$717, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$717, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$717, DW_AT_decl_line(0x470)
.dwattr $C$DW$717, DW_AT_decl_column(0x05)
$C$DW$718 .dwtag DW_TAG_member
.dwattr $C$DW$718, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$718, DW_AT_name("alpha")
.dwattr $C$DW$718, DW_AT_TI_symbol_name("alpha")
.dwattr $C$DW$718, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$718, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$718, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$718, DW_AT_decl_line(0x471)
.dwattr $C$DW$718, DW_AT_decl_column(0x05)
$C$DW$719 .dwtag DW_TAG_member
.dwattr $C$DW$719, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$719, DW_AT_name("reserved")
.dwattr $C$DW$719, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$719, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$719, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$719, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$719, DW_AT_decl_line(0x472)
.dwattr $C$DW$719, DW_AT_decl_column(0x05)
$C$DW$24 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$24, DW_AT_declaration
.dwattr $C$DW$24, DW_AT_TI_symbol_name("_ZN17Doppler_GapConfigaSERKS_")
.dwattr $C$DW$24, DW_AT_type(*$C$DW$T$1244)
.dwattr $C$DW$24, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$720 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$720, DW_AT_type(*$C$DW$T$1246)
.dwendtag $C$DW$24
.dwendtag $C$DW$T$1248
.dwattr $C$DW$T$1248, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1248, DW_AT_decl_line(0x469)
.dwattr $C$DW$T$1248, DW_AT_decl_column(0x01)
$C$DW$T$1245 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1245, DW_AT_type(*$C$DW$T$1248)
$C$DW$T$1246 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1246, DW_AT_type(*$C$DW$T$1245)
.dwattr $C$DW$T$1246, DW_AT_address_class(0x20)
$C$DW$T$1264 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_GapConfig")
.dwattr $C$DW$T$1264, DW_AT_type(*$C$DW$T$1248)
.dwattr $C$DW$T$1264, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1264, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1264, DW_AT_decl_line(0x473)
.dwattr $C$DW$T$1264, DW_AT_decl_column(0x03)
$C$DW$T$1265 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1265, DW_AT_type(*$C$DW$T$1264)
.dwattr $C$DW$T$1265, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1265, DW_AT_byte_size(0x150)
$C$DW$721 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$721, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$1265
$C$DW$T$1244 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1244, DW_AT_type(*$C$DW$T$1248)
.dwattr $C$DW$T$1244, DW_AT_address_class(0x20)
$C$DW$T$1247 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1247, DW_AT_type(*$C$DW$T$1244)
.dwattr $C$DW$T$1247, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$722 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$722, DW_AT_type(*$C$DW$T$1246)
.dwendtag $C$DW$T$1247
$C$DW$T$1254 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1254, DW_AT_name("Doppler_ImagingState")
.dwattr $C$DW$T$1254, DW_AT_byte_size(0x0c)
$C$DW$723 .dwtag DW_TAG_member
.dwattr $C$DW$723, DW_AT_type(*$C$DW$T$456)
.dwattr $C$DW$723, DW_AT_name("blankOn")
.dwattr $C$DW$723, DW_AT_TI_symbol_name("blankOn")
.dwattr $C$DW$723, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$723, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$723, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$723, DW_AT_decl_line(0x29)
.dwattr $C$DW$723, DW_AT_decl_column(0x0a)
$C$DW$724 .dwtag DW_TAG_member
.dwattr $C$DW$724, DW_AT_type(*$C$DW$T$456)
.dwattr $C$DW$724, DW_AT_name("wfUpdatePending")
.dwattr $C$DW$724, DW_AT_TI_symbol_name("wfUpdatePending")
.dwattr $C$DW$724, DW_AT_data_member_location[DW_OP_plus_uconst 0x2]
.dwattr $C$DW$724, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$724, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$724, DW_AT_decl_line(0x2a)
.dwattr $C$DW$724, DW_AT_decl_column(0x0a)
$C$DW$725 .dwtag DW_TAG_member
.dwattr $C$DW$725, DW_AT_type(*$C$DW$T$113)
.dwattr $C$DW$725, DW_AT_name("wfPingPongRdIdx")
.dwattr $C$DW$725, DW_AT_TI_symbol_name("wfPingPongRdIdx")
.dwattr $C$DW$725, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$725, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$725, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$725, DW_AT_decl_line(0x2b)
.dwattr $C$DW$725, DW_AT_decl_column(0x0c)
$C$DW$726 .dwtag DW_TAG_member
.dwattr $C$DW$726, DW_AT_type(*$C$DW$T$113)
.dwattr $C$DW$726, DW_AT_name("wallFilterLength")
.dwattr $C$DW$726, DW_AT_TI_symbol_name("wallFilterLength")
.dwattr $C$DW$726, DW_AT_data_member_location[DW_OP_plus_uconst 0x6]
.dwattr $C$DW$726, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$726, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$726, DW_AT_decl_line(0x2c)
.dwattr $C$DW$726, DW_AT_decl_column(0x0c)
$C$DW$727 .dwtag DW_TAG_member
.dwattr $C$DW$727, DW_AT_type(*$C$DW$T$1249)
.dwattr $C$DW$727, DW_AT_name("wallFilterCoefAddr")
.dwattr $C$DW$727, DW_AT_TI_symbol_name("wallFilterCoefAddr")
.dwattr $C$DW$727, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$727, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$727, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$727, DW_AT_decl_line(0x2d)
.dwattr $C$DW$727, DW_AT_decl_column(0x0c)
$C$DW$25 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$25, DW_AT_declaration
.dwattr $C$DW$25, DW_AT_TI_symbol_name("_ZN20Doppler_ImagingStateaSERKS_")
.dwattr $C$DW$25, DW_AT_type(*$C$DW$T$1250)
.dwattr $C$DW$25, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$728 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$728, DW_AT_type(*$C$DW$T$1252)
.dwendtag $C$DW$25
.dwendtag $C$DW$T$1254
.dwattr $C$DW$T$1254, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$T$1254, DW_AT_decl_line(0x28)
.dwattr $C$DW$T$1254, DW_AT_decl_column(0x01)
$C$DW$T$548 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_ImagingState")
.dwattr $C$DW$T$548, DW_AT_type(*$C$DW$T$1254)
.dwattr $C$DW$T$548, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$548, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h")
.dwattr $C$DW$T$548, DW_AT_decl_line(0x2e)
.dwattr $C$DW$T$548, DW_AT_decl_column(0x03)
$C$DW$T$1251 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1251, DW_AT_type(*$C$DW$T$1254)
$C$DW$T$1252 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1252, DW_AT_type(*$C$DW$T$1251)
.dwattr $C$DW$T$1252, DW_AT_address_class(0x20)
$C$DW$T$1250 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1250, DW_AT_type(*$C$DW$T$1254)
.dwattr $C$DW$T$1250, DW_AT_address_class(0x20)
$C$DW$T$1253 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1253, DW_AT_type(*$C$DW$T$1250)
.dwattr $C$DW$T$1253, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$729 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$729, DW_AT_type(*$C$DW$T$1252)
.dwendtag $C$DW$T$1253
$C$DW$T$1259 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1259, DW_AT_name("Doppler_LineInterleave")
.dwattr $C$DW$T$1259, DW_AT_byte_size(0x48)
$C$DW$730 .dwtag DW_TAG_member
.dwattr $C$DW$730, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$730, DW_AT_name("pwsPerColorGroup")
.dwattr $C$DW$730, DW_AT_TI_symbol_name("pwsPerColorGroup")
.dwattr $C$DW$730, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$730, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$730, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$730, DW_AT_decl_line(0x45a)
.dwattr $C$DW$730, DW_AT_decl_column(0x05)
$C$DW$731 .dwtag DW_TAG_member
.dwattr $C$DW$731, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$731, DW_AT_name("colorGroupCrossingDline")
.dwattr $C$DW$731, DW_AT_TI_symbol_name("colorGroupCrossingDline")
.dwattr $C$DW$731, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$731, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$731, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$731, DW_AT_decl_line(0x45b)
.dwattr $C$DW$731, DW_AT_decl_column(0x05)
$C$DW$732 .dwtag DW_TAG_member
.dwattr $C$DW$732, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$732, DW_AT_name("colorGroupNextClosestToDline")
.dwattr $C$DW$732, DW_AT_TI_symbol_name("colorGroupNextClosestToDline")
.dwattr $C$DW$732, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$732, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$732, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$732, DW_AT_decl_line(0x45c)
.dwattr $C$DW$732, DW_AT_decl_column(0x05)
$C$DW$733 .dwtag DW_TAG_member
.dwattr $C$DW$733, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$733, DW_AT_name("numClrGrpsToCorrect")
.dwattr $C$DW$733, DW_AT_TI_symbol_name("numClrGrpsToCorrect")
.dwattr $C$DW$733, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$733, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$733, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$733, DW_AT_decl_line(0x45d)
.dwattr $C$DW$733, DW_AT_decl_column(0x05)
$C$DW$734 .dwtag DW_TAG_member
.dwattr $C$DW$734, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$734, DW_AT_name("totalColorGroups")
.dwattr $C$DW$734, DW_AT_TI_symbol_name("totalColorGroups")
.dwattr $C$DW$734, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$734, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$734, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$734, DW_AT_decl_line(0x45f)
.dwattr $C$DW$734, DW_AT_decl_column(0x05)
$C$DW$735 .dwtag DW_TAG_member
.dwattr $C$DW$735, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$735, DW_AT_name("bmodeCrossingDline")
.dwattr $C$DW$735, DW_AT_TI_symbol_name("bmodeCrossingDline")
.dwattr $C$DW$735, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$735, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$735, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$735, DW_AT_decl_line(0x460)
.dwattr $C$DW$735, DW_AT_decl_column(0x05)
$C$DW$736 .dwtag DW_TAG_member
.dwattr $C$DW$736, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$736, DW_AT_name("numPwSamplesPerBModeFrame")
.dwattr $C$DW$736, DW_AT_TI_symbol_name("numPwSamplesPerBModeFrame")
.dwattr $C$DW$736, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$736, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$736, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$736, DW_AT_decl_line(0x461)
.dwattr $C$DW$736, DW_AT_decl_column(0x05)
$C$DW$737 .dwtag DW_TAG_member
.dwattr $C$DW$737, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$737, DW_AT_name("numPwSamplesAffectedByBmode")
.dwattr $C$DW$737, DW_AT_TI_symbol_name("numPwSamplesAffectedByBmode")
.dwattr $C$DW$737, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$737, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$737, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$737, DW_AT_decl_line(0x462)
.dwattr $C$DW$737, DW_AT_decl_column(0x05)
$C$DW$738 .dwtag DW_TAG_member
.dwattr $C$DW$738, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$738, DW_AT_name("stdDerivativeThreshold")
.dwattr $C$DW$738, DW_AT_TI_symbol_name("stdDerivativeThreshold")
.dwattr $C$DW$738, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$738, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$738, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$738, DW_AT_decl_line(0x464)
.dwattr $C$DW$738, DW_AT_decl_column(0x05)
$C$DW$26 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$26, DW_AT_declaration
.dwattr $C$DW$26, DW_AT_TI_symbol_name("_ZN22Doppler_LineInterleaveaSERKS_")
.dwattr $C$DW$26, DW_AT_type(*$C$DW$T$1255)
.dwattr $C$DW$26, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$739 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$739, DW_AT_type(*$C$DW$T$1257)
.dwendtag $C$DW$26
.dwendtag $C$DW$T$1259
.dwattr $C$DW$T$1259, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1259, DW_AT_decl_line(0x459)
.dwattr $C$DW$T$1259, DW_AT_decl_column(0x01)
$C$DW$T$1256 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1256, DW_AT_type(*$C$DW$T$1259)
$C$DW$T$1257 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1257, DW_AT_type(*$C$DW$T$1256)
.dwattr $C$DW$T$1257, DW_AT_address_class(0x20)
$C$DW$T$1266 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_LineInterleave")
.dwattr $C$DW$T$1266, DW_AT_type(*$C$DW$T$1259)
.dwattr $C$DW$T$1266, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1266, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1266, DW_AT_decl_line(0x465)
.dwattr $C$DW$T$1266, DW_AT_decl_column(0x03)
$C$DW$T$1255 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1255, DW_AT_type(*$C$DW$T$1259)
.dwattr $C$DW$T$1255, DW_AT_address_class(0x20)
$C$DW$T$1258 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1258, DW_AT_type(*$C$DW$T$1255)
.dwattr $C$DW$T$1258, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$740 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$740, DW_AT_type(*$C$DW$T$1257)
.dwendtag $C$DW$T$1258
$C$DW$T$1273 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1273, DW_AT_name("Doppler_Param")
.dwattr $C$DW$T$1273, DW_AT_byte_size(0x360)
$C$DW$741 .dwtag DW_TAG_member
.dwattr $C$DW$741, DW_AT_type(*$C$DW$T$1261)
.dwattr $C$DW$741, DW_AT_name("subMode")
.dwattr $C$DW$741, DW_AT_TI_symbol_name("subMode")
.dwattr $C$DW$741, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$741, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$741, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$741, DW_AT_decl_line(0x479)
.dwattr $C$DW$741, DW_AT_decl_column(0x05)
$C$DW$742 .dwtag DW_TAG_member
.dwattr $C$DW$742, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$742, DW_AT_name("pResamplingFilterCoeffsBuf")
.dwattr $C$DW$742, DW_AT_TI_symbol_name("pResamplingFilterCoeffsBuf")
.dwattr $C$DW$742, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$742, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$742, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$742, DW_AT_decl_line(0x47b)
.dwattr $C$DW$742, DW_AT_decl_column(0x05)
$C$DW$743 .dwtag DW_TAG_member
.dwattr $C$DW$743, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$743, DW_AT_name("pQbpCoeffsBuf")
.dwattr $C$DW$743, DW_AT_TI_symbol_name("pQbpCoeffsBuf")
.dwattr $C$DW$743, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$743, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$743, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$743, DW_AT_decl_line(0x47c)
.dwattr $C$DW$743, DW_AT_decl_column(0x05)
$C$DW$744 .dwtag DW_TAG_member
.dwattr $C$DW$744, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$744, DW_AT_name("pWallFilterCoeffsBuf")
.dwattr $C$DW$744, DW_AT_TI_symbol_name("pWallFilterCoeffsBuf")
.dwattr $C$DW$744, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$744, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$744, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$744, DW_AT_decl_line(0x47e)
.dwattr $C$DW$744, DW_AT_decl_column(0x05)
$C$DW$745 .dwtag DW_TAG_member
.dwattr $C$DW$745, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$745, DW_AT_name("pCompressionLUT")
.dwattr $C$DW$745, DW_AT_TI_symbol_name("pCompressionLUT")
.dwattr $C$DW$745, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$745, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$745, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$745, DW_AT_decl_line(0x47f)
.dwattr $C$DW$745, DW_AT_decl_column(0x05)
$C$DW$746 .dwtag DW_TAG_member
.dwattr $C$DW$746, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$746, DW_AT_name("resamplingCoeffsBufSize")
.dwattr $C$DW$746, DW_AT_TI_symbol_name("resamplingCoeffsBufSize")
.dwattr $C$DW$746, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$746, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$746, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$746, DW_AT_decl_line(0x481)
.dwattr $C$DW$746, DW_AT_decl_column(0x05)
$C$DW$747 .dwtag DW_TAG_member
.dwattr $C$DW$747, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$747, DW_AT_name("qbpCoeffsBufSize")
.dwattr $C$DW$747, DW_AT_TI_symbol_name("qbpCoeffsBufSize")
.dwattr $C$DW$747, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$747, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$747, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$747, DW_AT_decl_line(0x483)
.dwattr $C$DW$747, DW_AT_decl_column(0x05)
$C$DW$748 .dwtag DW_TAG_member
.dwattr $C$DW$748, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$748, DW_AT_name("qbpFilterLen")
.dwattr $C$DW$748, DW_AT_TI_symbol_name("qbpFilterLen")
.dwattr $C$DW$748, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$748, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$748, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$748, DW_AT_decl_line(0x484)
.dwattr $C$DW$748, DW_AT_decl_column(0x05)
$C$DW$749 .dwtag DW_TAG_member
.dwattr $C$DW$749, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$749, DW_AT_name("wallFitlerCoeffsBufSize")
.dwattr $C$DW$749, DW_AT_TI_symbol_name("wallFitlerCoeffsBufSize")
.dwattr $C$DW$749, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$749, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$749, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$749, DW_AT_decl_line(0x486)
.dwattr $C$DW$749, DW_AT_decl_column(0x05)
$C$DW$750 .dwtag DW_TAG_member
.dwattr $C$DW$750, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$750, DW_AT_name("wallFilterLen")
.dwattr $C$DW$750, DW_AT_TI_symbol_name("wallFilterLen")
.dwattr $C$DW$750, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$750, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$750, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$750, DW_AT_decl_line(0x487)
.dwattr $C$DW$750, DW_AT_decl_column(0x05)
$C$DW$751 .dwtag DW_TAG_member
.dwattr $C$DW$751, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$751, DW_AT_name("wallFilterGainExp")
.dwattr $C$DW$751, DW_AT_TI_symbol_name("wallFilterGainExp")
.dwattr $C$DW$751, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$751, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$751, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$751, DW_AT_decl_line(0x489)
.dwattr $C$DW$751, DW_AT_decl_column(0x05)
$C$DW$752 .dwtag DW_TAG_member
.dwattr $C$DW$752, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$752, DW_AT_name("wallFilterGainMant")
.dwattr $C$DW$752, DW_AT_TI_symbol_name("wallFilterGainMant")
.dwattr $C$DW$752, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$752, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$752, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$752, DW_AT_decl_line(0x48a)
.dwattr $C$DW$752, DW_AT_decl_column(0x05)
$C$DW$753 .dwtag DW_TAG_member
.dwattr $C$DW$753, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$753, DW_AT_name("usecsPerPri")
.dwattr $C$DW$753, DW_AT_TI_symbol_name("usecsPerPri")
.dwattr $C$DW$753, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$753, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$753, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$753, DW_AT_decl_line(0x48c)
.dwattr $C$DW$753, DW_AT_decl_column(0x05)
$C$DW$754 .dwtag DW_TAG_member
.dwattr $C$DW$754, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$754, DW_AT_name("usecsPerFft")
.dwattr $C$DW$754, DW_AT_TI_symbol_name("usecsPerFft")
.dwattr $C$DW$754, DW_AT_data_member_location[DW_OP_plus_uconst 0x68]
.dwattr $C$DW$754, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$754, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$754, DW_AT_decl_line(0x48d)
.dwattr $C$DW$754, DW_AT_decl_column(0x05)
$C$DW$755 .dwtag DW_TAG_member
.dwattr $C$DW$755, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$755, DW_AT_name("fftsPerColumn")
.dwattr $C$DW$755, DW_AT_TI_symbol_name("fftsPerColumn")
.dwattr $C$DW$755, DW_AT_data_member_location[DW_OP_plus_uconst 0x70]
.dwattr $C$DW$755, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$755, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$755, DW_AT_decl_line(0x48e)
.dwattr $C$DW$755, DW_AT_decl_column(0x05)
$C$DW$756 .dwtag DW_TAG_member
.dwattr $C$DW$756, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$756, DW_AT_name("compressionLUTSize")
.dwattr $C$DW$756, DW_AT_TI_symbol_name("compressionLUTSize")
.dwattr $C$DW$756, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$756, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$756, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$756, DW_AT_decl_line(0x490)
.dwattr $C$DW$756, DW_AT_decl_column(0x05)
$C$DW$757 .dwtag DW_TAG_member
.dwattr $C$DW$757, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$757, DW_AT_name("audioGain")
.dwattr $C$DW$757, DW_AT_TI_symbol_name("audioGain")
.dwattr $C$DW$757, DW_AT_data_member_location[DW_OP_plus_uconst 0x80]
.dwattr $C$DW$757, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$757, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$757, DW_AT_decl_line(0x492)
.dwattr $C$DW$757, DW_AT_decl_column(0x05)
$C$DW$758 .dwtag DW_TAG_member
.dwattr $C$DW$758, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$758, DW_AT_name("audioRampLen")
.dwattr $C$DW$758, DW_AT_TI_symbol_name("audioRampLen")
.dwattr $C$DW$758, DW_AT_data_member_location[DW_OP_plus_uconst 0x88]
.dwattr $C$DW$758, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$758, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$758, DW_AT_decl_line(0x493)
.dwattr $C$DW$758, DW_AT_decl_column(0x05)
$C$DW$759 .dwtag DW_TAG_member
.dwattr $C$DW$759, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$759, DW_AT_name("baselineIndex")
.dwattr $C$DW$759, DW_AT_TI_symbol_name("baselineIndex")
.dwattr $C$DW$759, DW_AT_data_member_location[DW_OP_plus_uconst 0x90]
.dwattr $C$DW$759, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$759, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$759, DW_AT_decl_line(0x495)
.dwattr $C$DW$759, DW_AT_decl_column(0x05)
$C$DW$760 .dwtag DW_TAG_member
.dwattr $C$DW$760, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$760, DW_AT_name("graphicsInvert")
.dwattr $C$DW$760, DW_AT_TI_symbol_name("graphicsInvert")
.dwattr $C$DW$760, DW_AT_data_member_location[DW_OP_plus_uconst 0x98]
.dwattr $C$DW$760, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$760, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$760, DW_AT_decl_line(0x496)
.dwattr $C$DW$760, DW_AT_decl_column(0x05)
$C$DW$761 .dwtag DW_TAG_member
.dwattr $C$DW$761, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$761, DW_AT_name("graphicsHeight")
.dwattr $C$DW$761, DW_AT_TI_symbol_name("graphicsHeight")
.dwattr $C$DW$761, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0]
.dwattr $C$DW$761, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$761, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$761, DW_AT_decl_line(0x497)
.dwattr $C$DW$761, DW_AT_decl_column(0x05)
$C$DW$762 .dwtag DW_TAG_member
.dwattr $C$DW$762, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$762, DW_AT_name("graphicsWidth")
.dwattr $C$DW$762, DW_AT_TI_symbol_name("graphicsWidth")
.dwattr $C$DW$762, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8]
.dwattr $C$DW$762, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$762, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$762, DW_AT_decl_line(0x498)
.dwattr $C$DW$762, DW_AT_decl_column(0x05)
$C$DW$763 .dwtag DW_TAG_member
.dwattr $C$DW$763, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$763, DW_AT_name("graphicsAlignDelay")
.dwattr $C$DW$763, DW_AT_TI_symbol_name("graphicsAlignDelay")
.dwattr $C$DW$763, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0]
.dwattr $C$DW$763, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$763, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$763, DW_AT_decl_line(0x499)
.dwattr $C$DW$763, DW_AT_decl_column(0x05)
$C$DW$764 .dwtag DW_TAG_member
.dwattr $C$DW$764, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$764, DW_AT_name("unused0")
.dwattr $C$DW$764, DW_AT_TI_symbol_name("unused0")
.dwattr $C$DW$764, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8]
.dwattr $C$DW$764, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$764, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$764, DW_AT_decl_line(0x49b)
.dwattr $C$DW$764, DW_AT_decl_column(0x05)
$C$DW$765 .dwtag DW_TAG_member
.dwattr $C$DW$765, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$765, DW_AT_name("unused1")
.dwattr $C$DW$765, DW_AT_TI_symbol_name("unused1")
.dwattr $C$DW$765, DW_AT_data_member_location[DW_OP_plus_uconst 0xc0]
.dwattr $C$DW$765, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$765, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$765, DW_AT_decl_line(0x49c)
.dwattr $C$DW$765, DW_AT_decl_column(0x05)
$C$DW$766 .dwtag DW_TAG_member
.dwattr $C$DW$766, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$766, DW_AT_name("unused2")
.dwattr $C$DW$766, DW_AT_TI_symbol_name("unused2")
.dwattr $C$DW$766, DW_AT_data_member_location[DW_OP_plus_uconst 0xc8]
.dwattr $C$DW$766, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$766, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$766, DW_AT_decl_line(0x49d)
.dwattr $C$DW$766, DW_AT_decl_column(0x05)
$C$DW$767 .dwtag DW_TAG_member
.dwattr $C$DW$767, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$767, DW_AT_name("unused3")
.dwattr $C$DW$767, DW_AT_TI_symbol_name("unused3")
.dwattr $C$DW$767, DW_AT_data_member_location[DW_OP_plus_uconst 0xd0]
.dwattr $C$DW$767, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$767, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$767, DW_AT_decl_line(0x49e)
.dwattr $C$DW$767, DW_AT_decl_column(0x05)
$C$DW$768 .dwtag DW_TAG_member
.dwattr $C$DW$768, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$768, DW_AT_name("valveClickEnable")
.dwattr $C$DW$768, DW_AT_TI_symbol_name("valveClickEnable")
.dwattr $C$DW$768, DW_AT_data_member_location[DW_OP_plus_uconst 0xd8]
.dwattr $C$DW$768, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$768, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$768, DW_AT_decl_line(0x4a0)
.dwattr $C$DW$768, DW_AT_decl_column(0x05)
$C$DW$769 .dwtag DW_TAG_member
.dwattr $C$DW$769, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$769, DW_AT_name("peakMeanDirFlag")
.dwattr $C$DW$769, DW_AT_TI_symbol_name("peakMeanDirFlag")
.dwattr $C$DW$769, DW_AT_data_member_location[DW_OP_plus_uconst 0xe0]
.dwattr $C$DW$769, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$769, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$769, DW_AT_decl_line(0x4a1)
.dwattr $C$DW$769, DW_AT_decl_column(0x05)
$C$DW$770 .dwtag DW_TAG_member
.dwattr $C$DW$770, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$770, DW_AT_name("pHilbertCoeffsBuf")
.dwattr $C$DW$770, DW_AT_TI_symbol_name("pHilbertCoeffsBuf")
.dwattr $C$DW$770, DW_AT_data_member_location[DW_OP_plus_uconst 0xe8]
.dwattr $C$DW$770, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$770, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$770, DW_AT_decl_line(0x4a3)
.dwattr $C$DW$770, DW_AT_decl_column(0x05)
$C$DW$771 .dwtag DW_TAG_member
.dwattr $C$DW$771, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$771, DW_AT_name("fftWindowShift")
.dwattr $C$DW$771, DW_AT_TI_symbol_name("fftWindowShift")
.dwattr $C$DW$771, DW_AT_data_member_location[DW_OP_plus_uconst 0xf0]
.dwattr $C$DW$771, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$771, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$771, DW_AT_decl_line(0x4a6)
.dwattr $C$DW$771, DW_AT_decl_column(0x05)
$C$DW$772 .dwtag DW_TAG_member
.dwattr $C$DW$772, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$772, DW_AT_name("audioChanPolarity")
.dwattr $C$DW$772, DW_AT_TI_symbol_name("audioChanPolarity")
.dwattr $C$DW$772, DW_AT_data_member_location[DW_OP_plus_uconst 0xf8]
.dwattr $C$DW$772, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$772, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$772, DW_AT_decl_line(0x4a8)
.dwattr $C$DW$772, DW_AT_decl_column(0x05)
$C$DW$773 .dwtag DW_TAG_member
.dwattr $C$DW$773, DW_AT_type(*$C$DW$T$1263)
.dwattr $C$DW$773, DW_AT_name("pkMnSelect")
.dwattr $C$DW$773, DW_AT_TI_symbol_name("pkMnSelect")
.dwattr $C$DW$773, DW_AT_data_member_location[DW_OP_plus_uconst 0x100]
.dwattr $C$DW$773, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$773, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$773, DW_AT_decl_line(0x4a9)
.dwattr $C$DW$773, DW_AT_decl_column(0x05)
$C$DW$774 .dwtag DW_TAG_member
.dwattr $C$DW$774, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$774, DW_AT_name("fftWindowLen")
.dwattr $C$DW$774, DW_AT_TI_symbol_name("fftWindowLen")
.dwattr $C$DW$774, DW_AT_data_member_location[DW_OP_plus_uconst 0x108]
.dwattr $C$DW$774, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$774, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$774, DW_AT_decl_line(0x4aa)
.dwattr $C$DW$774, DW_AT_decl_column(0x05)
$C$DW$775 .dwtag DW_TAG_member
.dwattr $C$DW$775, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$775, DW_AT_name("fftWindowLenMultQ16p16")
.dwattr $C$DW$775, DW_AT_TI_symbol_name("fftWindowLenMultQ16p16")
.dwattr $C$DW$775, DW_AT_data_member_location[DW_OP_plus_uconst 0x110]
.dwattr $C$DW$775, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$775, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$775, DW_AT_decl_line(0x4ac)
.dwattr $C$DW$775, DW_AT_decl_column(0x05)
$C$DW$776 .dwtag DW_TAG_member
.dwattr $C$DW$776, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$776, DW_AT_name("audioGainFloat")
.dwattr $C$DW$776, DW_AT_TI_symbol_name("audioGainFloat")
.dwattr $C$DW$776, DW_AT_data_member_location[DW_OP_plus_uconst 0x118]
.dwattr $C$DW$776, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$776, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$776, DW_AT_decl_line(0x4ad)
.dwattr $C$DW$776, DW_AT_decl_column(0x05)
$C$DW$777 .dwtag DW_TAG_member
.dwattr $C$DW$777, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$777, DW_AT_name("shifts")
.dwattr $C$DW$777, DW_AT_TI_symbol_name("shifts")
.dwattr $C$DW$777, DW_AT_data_member_location[DW_OP_plus_uconst 0x120]
.dwattr $C$DW$777, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$777, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$777, DW_AT_decl_line(0x4ae)
.dwattr $C$DW$777, DW_AT_decl_column(0x05)
$C$DW$778 .dwtag DW_TAG_member
.dwattr $C$DW$778, DW_AT_type(*$C$DW$T$1265)
.dwattr $C$DW$778, DW_AT_name("gap")
.dwattr $C$DW$778, DW_AT_TI_symbol_name("gap")
.dwattr $C$DW$778, DW_AT_data_member_location[DW_OP_plus_uconst 0x128]
.dwattr $C$DW$778, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$778, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$778, DW_AT_decl_line(0x4b5)
.dwattr $C$DW$778, DW_AT_decl_column(0x05)
$C$DW$779 .dwtag DW_TAG_member
.dwattr $C$DW$779, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$779, DW_AT_name("gapNumSubBlockSamples")
.dwattr $C$DW$779, DW_AT_TI_symbol_name("gapNumSubBlockSamples")
.dwattr $C$DW$779, DW_AT_data_member_location[DW_OP_plus_uconst 0x278]
.dwattr $C$DW$779, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$779, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$779, DW_AT_decl_line(0x4b6)
.dwattr $C$DW$779, DW_AT_decl_column(0x05)
$C$DW$780 .dwtag DW_TAG_member
.dwattr $C$DW$780, DW_AT_type(*$C$DW$T$1266)
.dwattr $C$DW$780, DW_AT_name("lineInterleave")
.dwattr $C$DW$780, DW_AT_TI_symbol_name("lineInterleave")
.dwattr $C$DW$780, DW_AT_data_member_location[DW_OP_plus_uconst 0x280]
.dwattr $C$DW$780, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$780, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$780, DW_AT_decl_line(0x4bb)
.dwattr $C$DW$780, DW_AT_decl_column(0x05)
$C$DW$781 .dwtag DW_TAG_member
.dwattr $C$DW$781, DW_AT_type(*$C$DW$T$1268)
.dwattr $C$DW$781, DW_AT_name("simulMode")
.dwattr $C$DW$781, DW_AT_TI_symbol_name("simulMode")
.dwattr $C$DW$781, DW_AT_data_member_location[DW_OP_plus_uconst 0x2c8]
.dwattr $C$DW$781, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$781, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$781, DW_AT_decl_line(0x4bc)
.dwattr $C$DW$781, DW_AT_decl_column(0x05)
$C$DW$782 .dwtag DW_TAG_member
.dwattr $C$DW$782, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$782, DW_AT_name("disableBudsAndBbp")
.dwattr $C$DW$782, DW_AT_TI_symbol_name("disableBudsAndBbp")
.dwattr $C$DW$782, DW_AT_data_member_location[DW_OP_plus_uconst 0x2d0]
.dwattr $C$DW$782, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$782, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$782, DW_AT_decl_line(0x4be)
.dwattr $C$DW$782, DW_AT_decl_column(0x05)
$C$DW$783 .dwtag DW_TAG_member
.dwattr $C$DW$783, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$783, DW_AT_name("endOfData")
.dwattr $C$DW$783, DW_AT_TI_symbol_name("endOfData")
.dwattr $C$DW$783, DW_AT_data_member_location[DW_OP_plus_uconst 0x2d8]
.dwattr $C$DW$783, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$783, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$783, DW_AT_decl_line(0x4c0)
.dwattr $C$DW$783, DW_AT_decl_column(0x05)
$C$DW$784 .dwtag DW_TAG_member
.dwattr $C$DW$784, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$784, DW_AT_name("reserved")
.dwattr $C$DW$784, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$784, DW_AT_data_member_location[DW_OP_plus_uconst 0x2e0]
.dwattr $C$DW$784, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$784, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$784, DW_AT_decl_line(0x4c2)
.dwattr $C$DW$784, DW_AT_decl_column(0x05)
$C$DW$27 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$27, DW_AT_declaration
.dwattr $C$DW$27, DW_AT_TI_symbol_name("_ZN13Doppler_ParamaSERKS_")
.dwattr $C$DW$27, DW_AT_type(*$C$DW$T$1269)
.dwattr $C$DW$27, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$785 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$785, DW_AT_type(*$C$DW$T$1271)
.dwendtag $C$DW$27
.dwendtag $C$DW$T$1273
.dwattr $C$DW$T$1273, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1273, DW_AT_decl_line(0x478)
.dwattr $C$DW$T$1273, DW_AT_decl_column(0x01)
$C$DW$T$1270 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1270, DW_AT_type(*$C$DW$T$1273)
$C$DW$T$1271 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1271, DW_AT_type(*$C$DW$T$1270)
.dwattr $C$DW$T$1271, DW_AT_address_class(0x20)
$C$DW$T$2199 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_Param")
.dwattr $C$DW$T$2199, DW_AT_type(*$C$DW$T$1273)
.dwattr $C$DW$T$2199, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2199, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$2199, DW_AT_decl_line(0x4c3)
.dwattr $C$DW$T$2199, DW_AT_decl_column(0x03)
$C$DW$T$1269 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1269, DW_AT_type(*$C$DW$T$1273)
.dwattr $C$DW$T$1269, DW_AT_address_class(0x20)
$C$DW$T$1272 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1272, DW_AT_type(*$C$DW$T$1269)
.dwattr $C$DW$T$1272, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$786 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$786, DW_AT_type(*$C$DW$T$1271)
.dwendtag $C$DW$T$1272
$C$DW$T$1262 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1262, DW_AT_name("Doppler_PeakMeanType")
.dwattr $C$DW$T$1262, DW_AT_byte_size(0x04)
$C$DW$787 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_DRAW_MEAN"), DW_AT_const_value(0x00)
.dwattr $C$DW$787, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$787, DW_AT_decl_line(0x177)
.dwattr $C$DW$787, DW_AT_decl_column(0x05)
$C$DW$788 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_DRAW_PEAK"), DW_AT_const_value(0x01)
.dwattr $C$DW$788, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$788, DW_AT_decl_line(0x178)
.dwattr $C$DW$788, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1262
.dwattr $C$DW$T$1262, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1262, DW_AT_decl_line(0x176)
.dwattr $C$DW$T$1262, DW_AT_decl_column(0x01)
$C$DW$T$1263 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_PeakMeanType")
.dwattr $C$DW$T$1263, DW_AT_type(*$C$DW$T$1262)
.dwattr $C$DW$T$1263, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1263, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1263, DW_AT_decl_line(0x179)
.dwattr $C$DW$T$1263, DW_AT_decl_column(0x03)
$C$DW$T$1267 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1267, DW_AT_name("Doppler_SimulMode")
.dwattr $C$DW$T$1267, DW_AT_byte_size(0x04)
$C$DW$789 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_NORMAL"), DW_AT_const_value(0x00)
.dwattr $C$DW$789, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$789, DW_AT_decl_line(0x17d)
.dwattr $C$DW$789, DW_AT_decl_column(0x05)
$C$DW$790 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_LINE_INTERLEAVE"), DW_AT_const_value(0x01)
.dwattr $C$DW$790, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$790, DW_AT_decl_line(0x17e)
.dwattr $C$DW$790, DW_AT_decl_column(0x05)
$C$DW$791 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_BLOCK_INTERLEAVE"), DW_AT_const_value(0x02)
.dwattr $C$DW$791, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$791, DW_AT_decl_line(0x17f)
.dwattr $C$DW$791, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1267
.dwattr $C$DW$T$1267, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1267, DW_AT_decl_line(0x17c)
.dwattr $C$DW$T$1267, DW_AT_decl_column(0x01)
$C$DW$T$1268 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_SimulMode")
.dwattr $C$DW$T$1268, DW_AT_type(*$C$DW$T$1267)
.dwattr $C$DW$T$1268, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1268, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1268, DW_AT_decl_line(0x180)
.dwattr $C$DW$T$1268, DW_AT_decl_column(0x03)
$C$DW$T$1495 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1495, DW_AT_name("DspLoadInfo")
.dwattr $C$DW$T$1495, DW_AT_byte_size(0xa0)
$C$DW$792 .dwtag DW_TAG_member
.dwattr $C$DW$792, DW_AT_type(*$C$DW$T$189)
.dwattr $C$DW$792, DW_AT_name("coreLd")
.dwattr $C$DW$792, DW_AT_TI_symbol_name("coreLd")
.dwattr $C$DW$792, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$792, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$792, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$792, DW_AT_decl_line(0x5f4)
.dwattr $C$DW$792, DW_AT_decl_column(0x05)
$C$DW$793 .dwtag DW_TAG_member
.dwattr $C$DW$793, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$793, DW_AT_name("reserved")
.dwattr $C$DW$793, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$793, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$793, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$793, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$793, DW_AT_decl_line(0x5f5)
.dwattr $C$DW$793, DW_AT_decl_column(0x05)
$C$DW$28 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$28, DW_AT_declaration
.dwattr $C$DW$28, DW_AT_TI_symbol_name("_ZN11DspLoadInfoaSERKS_")
.dwattr $C$DW$28, DW_AT_type(*$C$DW$T$1491)
.dwattr $C$DW$28, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$794 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$794, DW_AT_type(*$C$DW$T$1493)
.dwendtag $C$DW$28
.dwendtag $C$DW$T$1495
.dwattr $C$DW$T$1495, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1495, DW_AT_decl_line(0x5f3)
.dwattr $C$DW$T$1495, DW_AT_decl_column(0x01)
$C$DW$T$1492 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1492, DW_AT_type(*$C$DW$T$1495)
$C$DW$T$1493 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1493, DW_AT_type(*$C$DW$T$1492)
.dwattr $C$DW$T$1493, DW_AT_address_class(0x20)
$C$DW$T$2205 .dwtag DW_TAG_typedef, DW_AT_name("DspLoadInfo")
.dwattr $C$DW$T$2205, DW_AT_type(*$C$DW$T$1495)
.dwattr $C$DW$T$2205, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2205, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$2205, DW_AT_decl_line(0x5f6)
.dwattr $C$DW$T$2205, DW_AT_decl_column(0x03)
$C$DW$T$1491 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1491, DW_AT_type(*$C$DW$T$1495)
.dwattr $C$DW$T$1491, DW_AT_address_class(0x20)
$C$DW$T$1494 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1494, DW_AT_type(*$C$DW$T$1491)
.dwattr $C$DW$T$1494, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$795 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$795, DW_AT_type(*$C$DW$T$1493)
.dwendtag $C$DW$T$1494
$C$DW$T$586 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$586, DW_AT_name("Ecg_Param")
.dwattr $C$DW$T$586, DW_AT_byte_size(0x138)
$C$DW$796 .dwtag DW_TAG_member
.dwattr $C$DW$796, DW_AT_type(*$C$DW$T$580)
.dwattr $C$DW$796, DW_AT_name("subMode")
.dwattr $C$DW$796, DW_AT_TI_symbol_name("subMode")
.dwattr $C$DW$796, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$796, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$796, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$796, DW_AT_decl_line(0x503)
.dwattr $C$DW$796, DW_AT_decl_column(0x05)
$C$DW$797 .dwtag DW_TAG_member
.dwattr $C$DW$797, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$797, DW_AT_name("graphicsHeight")
.dwattr $C$DW$797, DW_AT_TI_symbol_name("graphicsHeight")
.dwattr $C$DW$797, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$797, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$797, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$797, DW_AT_decl_line(0x506)
.dwattr $C$DW$797, DW_AT_decl_column(0x05)
$C$DW$798 .dwtag DW_TAG_member
.dwattr $C$DW$798, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$798, DW_AT_name("graphicsWidth")
.dwattr $C$DW$798, DW_AT_TI_symbol_name("graphicsWidth")
.dwattr $C$DW$798, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$798, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$798, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$798, DW_AT_decl_line(0x508)
.dwattr $C$DW$798, DW_AT_decl_column(0x05)
$C$DW$799 .dwtag DW_TAG_member
.dwattr $C$DW$799, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$799, DW_AT_name("decimationFactor")
.dwattr $C$DW$799, DW_AT_TI_symbol_name("decimationFactor")
.dwattr $C$DW$799, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$799, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$799, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$799, DW_AT_decl_line(0x509)
.dwattr $C$DW$799, DW_AT_decl_column(0x05)
$C$DW$800 .dwtag DW_TAG_member
.dwattr $C$DW$800, DW_AT_type(*$C$DW$T$581)
.dwattr $C$DW$800, DW_AT_name("ecgDelayParam")
.dwattr $C$DW$800, DW_AT_TI_symbol_name("ecgDelayParam")
.dwattr $C$DW$800, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$800, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$800, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$800, DW_AT_decl_line(0x50a)
.dwattr $C$DW$800, DW_AT_decl_column(0x05)
$C$DW$801 .dwtag DW_TAG_member
.dwattr $C$DW$801, DW_AT_type(*$C$DW$T$167)
.dwattr $C$DW$801, DW_AT_name("heartBeatsPerHREst")
.dwattr $C$DW$801, DW_AT_TI_symbol_name("heartBeatsPerHREst")
.dwattr $C$DW$801, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0]
.dwattr $C$DW$801, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$801, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$801, DW_AT_decl_line(0x50b)
.dwattr $C$DW$801, DW_AT_decl_column(0x05)
$C$DW$802 .dwtag DW_TAG_member
.dwattr $C$DW$802, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$802, DW_AT_name("reserved")
.dwattr $C$DW$802, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$802, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8]
.dwattr $C$DW$802, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$802, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$802, DW_AT_decl_line(0x50e)
.dwattr $C$DW$802, DW_AT_decl_column(0x05)
$C$DW$29 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$29, DW_AT_declaration
.dwattr $C$DW$29, DW_AT_TI_symbol_name("_ZN9Ecg_ParamaSERKS_")
.dwattr $C$DW$29, DW_AT_type(*$C$DW$T$582)
.dwattr $C$DW$29, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$803 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$803, DW_AT_type(*$C$DW$T$584)
.dwendtag $C$DW$29
.dwendtag $C$DW$T$586
.dwattr $C$DW$T$586, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$586, DW_AT_decl_line(0x501)
.dwattr $C$DW$T$586, DW_AT_decl_column(0x01)
$C$DW$T$583 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$583, DW_AT_type(*$C$DW$T$586)
$C$DW$T$584 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$584, DW_AT_type(*$C$DW$T$583)
.dwattr $C$DW$T$584, DW_AT_address_class(0x20)
$C$DW$T$1932 .dwtag DW_TAG_typedef, DW_AT_name("Ecg_Param")
.dwattr $C$DW$T$1932, DW_AT_type(*$C$DW$T$586)
.dwattr $C$DW$T$1932, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1932, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1932, DW_AT_decl_line(0x50f)
.dwattr $C$DW$T$1932, DW_AT_decl_column(0x03)
$C$DW$T$582 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$582, DW_AT_type(*$C$DW$T$586)
.dwattr $C$DW$T$582, DW_AT_address_class(0x20)
$C$DW$T$585 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$585, DW_AT_type(*$C$DW$T$582)
.dwattr $C$DW$T$585, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$804 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$804, DW_AT_type(*$C$DW$T$584)
.dwendtag $C$DW$T$585
$C$DW$T$1463 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1463, DW_AT_name("ErrorMgr_AbortInfo")
.dwattr $C$DW$T$1463, DW_AT_byte_size(0x220)
$C$DW$805 .dwtag DW_TAG_member
.dwattr $C$DW$805, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$805, DW_AT_name("code")
.dwattr $C$DW$805, DW_AT_TI_symbol_name("code")
.dwattr $C$DW$805, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$805, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$805, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$805, DW_AT_decl_line(0x20a)
.dwattr $C$DW$805, DW_AT_decl_column(0x05)
$C$DW$806 .dwtag DW_TAG_member
.dwattr $C$DW$806, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$806, DW_AT_name("lineNum")
.dwattr $C$DW$806, DW_AT_TI_symbol_name("lineNum")
.dwattr $C$DW$806, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$806, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$806, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$806, DW_AT_decl_line(0x20b)
.dwattr $C$DW$806, DW_AT_decl_column(0x05)
$C$DW$807 .dwtag DW_TAG_member
.dwattr $C$DW$807, DW_AT_type(*$C$DW$T$1458)
.dwattr $C$DW$807, DW_AT_name("filename")
.dwattr $C$DW$807, DW_AT_TI_symbol_name("filename")
.dwattr $C$DW$807, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$807, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$807, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$807, DW_AT_decl_line(0x20c)
.dwattr $C$DW$807, DW_AT_decl_column(0x05)
$C$DW$808 .dwtag DW_TAG_member
.dwattr $C$DW$808, DW_AT_type(*$C$DW$T$1458)
.dwattr $C$DW$808, DW_AT_name("msg")
.dwattr $C$DW$808, DW_AT_TI_symbol_name("msg")
.dwattr $C$DW$808, DW_AT_data_member_location[DW_OP_plus_uconst 0xd8]
.dwattr $C$DW$808, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$808, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$808, DW_AT_decl_line(0x20d)
.dwattr $C$DW$808, DW_AT_decl_column(0x05)
$C$DW$809 .dwtag DW_TAG_member
.dwattr $C$DW$809, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$809, DW_AT_name("reserved")
.dwattr $C$DW$809, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$809, DW_AT_data_member_location[DW_OP_plus_uconst 0x1a0]
.dwattr $C$DW$809, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$809, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$809, DW_AT_decl_line(0x20e)
.dwattr $C$DW$809, DW_AT_decl_column(0x05)
$C$DW$30 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$30, DW_AT_declaration
.dwattr $C$DW$30, DW_AT_TI_symbol_name("_ZN18ErrorMgr_AbortInfoaSERKS_")
.dwattr $C$DW$30, DW_AT_type(*$C$DW$T$1459)
.dwattr $C$DW$30, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$810 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$810, DW_AT_type(*$C$DW$T$1461)
.dwendtag $C$DW$30
.dwendtag $C$DW$T$1463
.dwattr $C$DW$T$1463, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1463, DW_AT_decl_line(0x209)
.dwattr $C$DW$T$1463, DW_AT_decl_column(0x10)
$C$DW$T$1460 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1460, DW_AT_type(*$C$DW$T$1463)
$C$DW$T$1461 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1461, DW_AT_type(*$C$DW$T$1460)
.dwattr $C$DW$T$1461, DW_AT_address_class(0x20)
$C$DW$T$2202 .dwtag DW_TAG_typedef, DW_AT_name("ErrorMgr_AbortInfo")
.dwattr $C$DW$T$2202, DW_AT_type(*$C$DW$T$1463)
.dwattr $C$DW$T$2202, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2202, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$2202, DW_AT_decl_line(0x20f)
.dwattr $C$DW$T$2202, DW_AT_decl_column(0x03)
$C$DW$T$1459 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1459, DW_AT_type(*$C$DW$T$1463)
.dwattr $C$DW$T$1459, DW_AT_address_class(0x20)
$C$DW$T$1462 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1462, DW_AT_type(*$C$DW$T$1459)
.dwattr $C$DW$T$1462, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$811 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$811, DW_AT_type(*$C$DW$T$1461)
.dwendtag $C$DW$T$1462
$C$DW$T$1468 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1468, DW_AT_name("ErrorMsg")
.dwattr $C$DW$T$1468, DW_AT_byte_size(0x02)
$C$DW$812 .dwtag DW_TAG_member
.dwattr $C$DW$812, DW_AT_type(*$C$DW$T$456)
.dwattr $C$DW$812, DW_AT_name("isFatalErr")
.dwattr $C$DW$812, DW_AT_TI_symbol_name("isFatalErr")
.dwattr $C$DW$812, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$812, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$812, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$812, DW_AT_decl_line(0xa0)
.dwattr $C$DW$812, DW_AT_decl_column(0x19)
$C$DW$31 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$31, DW_AT_declaration
.dwattr $C$DW$31, DW_AT_TI_symbol_name("_ZN8ErrorMsgaSERKS_")
.dwattr $C$DW$31, DW_AT_type(*$C$DW$T$1464)
.dwattr $C$DW$31, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$813 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$813, DW_AT_type(*$C$DW$T$1466)
.dwendtag $C$DW$31
.dwendtag $C$DW$T$1468
.dwattr $C$DW$T$1468, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1468, DW_AT_decl_line(0x9f)
.dwattr $C$DW$T$1468, DW_AT_decl_column(0x01)
$C$DW$T$1465 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1465, DW_AT_type(*$C$DW$T$1468)
$C$DW$T$1466 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1466, DW_AT_type(*$C$DW$T$1465)
.dwattr $C$DW$T$1466, DW_AT_address_class(0x20)
$C$DW$T$1477 .dwtag DW_TAG_typedef, DW_AT_name("ErrorMsg")
.dwattr $C$DW$T$1477, DW_AT_type(*$C$DW$T$1468)
.dwattr $C$DW$T$1477, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1477, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1477, DW_AT_decl_line(0xa1)
.dwattr $C$DW$T$1477, DW_AT_decl_column(0x03)
$C$DW$T$1464 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1464, DW_AT_type(*$C$DW$T$1468)
.dwattr $C$DW$T$1464, DW_AT_address_class(0x20)
$C$DW$T$1467 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1467, DW_AT_type(*$C$DW$T$1464)
.dwattr $C$DW$T$1467, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$814 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$814, DW_AT_type(*$C$DW$T$1466)
.dwendtag $C$DW$T$1467
$C$DW$T$2203 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$2203, DW_AT_name("ErrorType")
.dwattr $C$DW$T$2203, DW_AT_byte_size(0x04)
$C$DW$815 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON"), DW_AT_const_value(0x100)
.dwattr $C$DW$815, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$815, DW_AT_decl_line(0x24)
.dwattr $C$DW$815, DW_AT_decl_column(0x05)
$C$DW$816 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_NULLPTR"), DW_AT_const_value(0x101)
.dwattr $C$DW$816, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$816, DW_AT_decl_line(0x25)
.dwattr $C$DW$816, DW_AT_decl_column(0x05)
$C$DW$817 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_CBUF_BAD_INIT"), DW_AT_const_value(0x102)
.dwattr $C$DW$817, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$817, DW_AT_decl_line(0x26)
.dwattr $C$DW$817, DW_AT_decl_column(0x05)
$C$DW$818 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_CBUF_OVERFLOW"), DW_AT_const_value(0x103)
.dwattr $C$DW$818, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$818, DW_AT_decl_line(0x27)
.dwattr $C$DW$818, DW_AT_decl_column(0x05)
$C$DW$819 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_CBUF_UNDERFLOW"), DW_AT_const_value(0x104)
.dwattr $C$DW$819, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$819, DW_AT_decl_line(0x28)
.dwattr $C$DW$819, DW_AT_decl_column(0x05)
$C$DW$820 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_CBUF_UNKNOWN_CACHE_CMD"), DW_AT_const_value(0x105)
.dwattr $C$DW$820, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$820, DW_AT_decl_line(0x29)
.dwattr $C$DW$820, DW_AT_decl_column(0x05)
$C$DW$821 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_ABORT"), DW_AT_const_value(0x106)
.dwattr $C$DW$821, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$821, DW_AT_decl_line(0x2a)
.dwattr $C$DW$821, DW_AT_decl_column(0x05)
$C$DW$822 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_NUM_CORES"), DW_AT_const_value(0x107)
.dwattr $C$DW$822, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$822, DW_AT_decl_line(0x2b)
.dwattr $C$DW$822, DW_AT_decl_column(0x05)
$C$DW$823 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FUNCTION_NOT_CORE_COMPATIBLE"), DW_AT_const_value(0x108)
.dwattr $C$DW$823, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$823, DW_AT_decl_line(0x2c)
.dwattr $C$DW$823, DW_AT_decl_column(0x05)
$C$DW$824 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_CBUF_INVALID_OFFSET"), DW_AT_const_value(0x109)
.dwattr $C$DW$824, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$824, DW_AT_decl_line(0x2d)
.dwattr $C$DW$824, DW_AT_decl_column(0x05)
$C$DW$825 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_INVALID_FIR_PARAM"), DW_AT_const_value(0x10a)
.dwattr $C$DW$825, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$825, DW_AT_decl_line(0x2e)
.dwattr $C$DW$825, DW_AT_decl_column(0x05)
$C$DW$826 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_RTOS_ERR_RAISE_HOOK"), DW_AT_const_value(0x10b)
.dwattr $C$DW$826, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$826, DW_AT_decl_line(0x2f)
.dwattr $C$DW$826, DW_AT_decl_column(0x05)
$C$DW$827 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP"), DW_AT_const_value(0x200)
.dwattr $C$DW$827, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$827, DW_AT_decl_line(0x31)
.dwattr $C$DW$827, DW_AT_decl_column(0x05)
$C$DW$828 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_CREATE_ERR"), DW_AT_const_value(0x201)
.dwattr $C$DW$828, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$828, DW_AT_decl_line(0x32)
.dwattr $C$DW$828, DW_AT_decl_column(0x05)
$C$DW$829 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_DDR_ERR"), DW_AT_const_value(0x202)
.dwattr $C$DW$829, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$829, DW_AT_decl_line(0x33)
.dwattr $C$DW$829, DW_AT_decl_column(0x05)
$C$DW$830 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_LL2_ERR"), DW_AT_const_value(0x203)
.dwattr $C$DW$830, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$830, DW_AT_decl_line(0x34)
.dwattr $C$DW$830, DW_AT_decl_column(0x05)
$C$DW$831 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_SL2_ERR"), DW_AT_const_value(0x204)
.dwattr $C$DW$831, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$831, DW_AT_decl_line(0x35)
.dwattr $C$DW$831, DW_AT_decl_column(0x05)
$C$DW$832 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_DDR_NONCACHED_ERR"), DW_AT_const_value(0x205)
.dwattr $C$DW$832, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$832, DW_AT_decl_line(0x36)
.dwattr $C$DW$832, DW_AT_decl_column(0x05)
$C$DW$833 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBDDR_ERR"), DW_AT_const_value(0x206)
.dwattr $C$DW$833, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$833, DW_AT_decl_line(0x37)
.dwattr $C$DW$833, DW_AT_decl_column(0x05)
$C$DW$834 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBDDR_1_ERR"), DW_AT_const_value(0x207)
.dwattr $C$DW$834, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$834, DW_AT_decl_line(0x38)
.dwattr $C$DW$834, DW_AT_decl_column(0x05)
$C$DW$835 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBDDR_2_ERR"), DW_AT_const_value(0x208)
.dwattr $C$DW$835, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$835, DW_AT_decl_line(0x39)
.dwattr $C$DW$835, DW_AT_decl_column(0x05)
$C$DW$836 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBLL2_ERR"), DW_AT_const_value(0x209)
.dwattr $C$DW$836, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$836, DW_AT_decl_line(0x3a)
.dwattr $C$DW$836, DW_AT_decl_column(0x05)
$C$DW$837 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBSL2_ERR"), DW_AT_const_value(0x20a)
.dwattr $C$DW$837, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$837, DW_AT_decl_line(0x3b)
.dwattr $C$DW$837, DW_AT_decl_column(0x05)
$C$DW$838 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBSL2_1_ERR"), DW_AT_const_value(0x20b)
.dwattr $C$DW$838, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$838, DW_AT_decl_line(0x3c)
.dwattr $C$DW$838, DW_AT_decl_column(0x05)
$C$DW$839 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBSL2_2_ERR"), DW_AT_const_value(0x20c)
.dwattr $C$DW$839, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$839, DW_AT_decl_line(0x3d)
.dwattr $C$DW$839, DW_AT_decl_column(0x05)
$C$DW$840 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBFOV1_ERR"), DW_AT_const_value(0x20d)
.dwattr $C$DW$840, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$840, DW_AT_decl_line(0x3e)
.dwattr $C$DW$840, DW_AT_decl_column(0x05)
$C$DW$841 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBFOV2_ERR"), DW_AT_const_value(0x20e)
.dwattr $C$DW$841, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$841, DW_AT_decl_line(0x3f)
.dwattr $C$DW$841, DW_AT_decl_column(0x05)
$C$DW$842 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_MEM_SEL_ERR"), DW_AT_const_value(0x20f)
.dwattr $C$DW$842, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$842, DW_AT_decl_line(0x40)
.dwattr $C$DW$842, DW_AT_decl_column(0x05)
$C$DW$843 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_DDR_HEAP_BASE_TOO_LOW"), DW_AT_const_value(0x210)
.dwattr $C$DW$843, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$843, DW_AT_decl_line(0x41)
.dwattr $C$DW$843, DW_AT_decl_column(0x05)
$C$DW$844 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_DDR_LEAK_ERR"), DW_AT_const_value(0x211)
.dwattr $C$DW$844, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$844, DW_AT_decl_line(0x42)
.dwattr $C$DW$844, DW_AT_decl_column(0x05)
$C$DW$845 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_CINE_FOV1_LEAK_ERR"), DW_AT_const_value(0x212)
.dwattr $C$DW$845, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$845, DW_AT_decl_line(0x43)
.dwattr $C$DW$845, DW_AT_decl_column(0x05)
$C$DW$846 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_CINE_FOV2_LEAK_ERR"), DW_AT_const_value(0x213)
.dwattr $C$DW$846, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$846, DW_AT_decl_line(0x44)
.dwattr $C$DW$846, DW_AT_decl_column(0x05)
$C$DW$847 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_SL2_LEAK_ERR"), DW_AT_const_value(0x214)
.dwattr $C$DW$847, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$847, DW_AT_decl_line(0x45)
.dwattr $C$DW$847, DW_AT_decl_column(0x05)
$C$DW$848 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_CORE0_LL2_LEAK_ERR"), DW_AT_const_value(0x215)
.dwattr $C$DW$848, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$848, DW_AT_decl_line(0x46)
.dwattr $C$DW$848, DW_AT_decl_column(0x05)
$C$DW$849 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_EDMA"), DW_AT_const_value(0x300)
.dwattr $C$DW$849, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$849, DW_AT_decl_line(0x48)
.dwattr $C$DW$849, DW_AT_decl_column(0x05)
$C$DW$850 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_EDMA_BCNT_TOO_LARGE"), DW_AT_const_value(0x301)
.dwattr $C$DW$850, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$850, DW_AT_decl_line(0x49)
.dwattr $C$DW$850, DW_AT_decl_column(0x05)
$C$DW$851 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_EDMA_INVALID_IDX"), DW_AT_const_value(0x302)
.dwattr $C$DW$851, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$851, DW_AT_decl_line(0x4a)
.dwattr $C$DW$851, DW_AT_decl_column(0x05)
$C$DW$852 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO"), DW_AT_const_value(0x400)
.dwattr $C$DW$852, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$852, DW_AT_decl_line(0x4c)
.dwattr $C$DW$852, DW_AT_decl_column(0x05)
$C$DW$853 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO_SIZE"), DW_AT_const_value(0x401)
.dwattr $C$DW$853, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$853, DW_AT_decl_line(0x4d)
.dwattr $C$DW$853, DW_AT_decl_column(0x05)
$C$DW$854 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO_CREATE"), DW_AT_const_value(0x402)
.dwattr $C$DW$854, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$854, DW_AT_decl_line(0x4e)
.dwattr $C$DW$854, DW_AT_decl_column(0x05)
$C$DW$855 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO_DEQ_ERR"), DW_AT_const_value(0x403)
.dwattr $C$DW$855, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$855, DW_AT_decl_line(0x4f)
.dwattr $C$DW$855, DW_AT_decl_column(0x05)
$C$DW$856 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO_ENQ_ERR"), DW_AT_const_value(0x404)
.dwattr $C$DW$856, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$856, DW_AT_decl_line(0x50)
.dwattr $C$DW$856, DW_AT_decl_column(0x05)
$C$DW$857 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO_ITEM_CNT_ERR"), DW_AT_const_value(0x405)
.dwattr $C$DW$857, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$857, DW_AT_decl_line(0x51)
.dwattr $C$DW$857, DW_AT_decl_column(0x05)
$C$DW$858 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_DB"), DW_AT_const_value(0x500)
.dwattr $C$DW$858, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$858, DW_AT_decl_line(0x53)
.dwattr $C$DW$858, DW_AT_decl_column(0x05)
$C$DW$859 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_DB_SEMAPHORE_CREATE_ERR"), DW_AT_const_value(0x501)
.dwattr $C$DW$859, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$859, DW_AT_decl_line(0x54)
.dwattr $C$DW$859, DW_AT_decl_column(0x05)
$C$DW$860 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_DB_SEMAPHORE_PEND_ERR"), DW_AT_const_value(0x502)
.dwattr $C$DW$860, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$860, DW_AT_decl_line(0x55)
.dwattr $C$DW$860, DW_AT_decl_column(0x05)
$C$DW$861 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_REGULATOR"), DW_AT_const_value(0x600)
.dwattr $C$DW$861, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$861, DW_AT_decl_line(0x57)
.dwattr $C$DW$861, DW_AT_decl_column(0x05)
$C$DW$862 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_REGULATOR_OVERFLOW"), DW_AT_const_value(0x601)
.dwattr $C$DW$862, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$862, DW_AT_decl_line(0x58)
.dwattr $C$DW$862, DW_AT_decl_column(0x05)
$C$DW$863 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_REGULATOR_UNDERFLOW"), DW_AT_const_value(0x602)
.dwattr $C$DW$863, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$863, DW_AT_decl_line(0x59)
.dwattr $C$DW$863, DW_AT_decl_column(0x05)
$C$DW$864 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY"), DW_AT_const_value(0x700)
.dwattr $C$DW$864, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$864, DW_AT_decl_line(0x5b)
.dwattr $C$DW$864, DW_AT_decl_column(0x05)
$C$DW$865 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY_CAN_HAVE_ONLY_ONE_WRITER"), DW_AT_const_value(0x701)
.dwattr $C$DW$865, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$865, DW_AT_decl_line(0x5c)
.dwattr $C$DW$865, DW_AT_decl_column(0x05)
$C$DW$866 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY_TABLE_SIZE_NOT_POWER_OF_TWO"), DW_AT_const_value(0x702)
.dwattr $C$DW$866, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$866, DW_AT_decl_line(0x5d)
.dwattr $C$DW$866, DW_AT_decl_column(0x05)
$C$DW$867 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY_TABLE_ALREADY_ALLOCATED"), DW_AT_const_value(0x703)
.dwattr $C$DW$867, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$867, DW_AT_decl_line(0x5e)
.dwattr $C$DW$867, DW_AT_decl_column(0x05)
$C$DW$868 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY_NOT_INITIALIZED"), DW_AT_const_value(0x704)
.dwattr $C$DW$868, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$868, DW_AT_decl_line(0x5f)
.dwattr $C$DW$868, DW_AT_decl_column(0x05)
$C$DW$869 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY_MUST_INSTANTIATE_FROM_TASK"), DW_AT_const_value(0x705)
.dwattr $C$DW$869, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$869, DW_AT_decl_line(0x60)
.dwattr $C$DW$869, DW_AT_decl_column(0x05)
$C$DW$870 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR"), DW_AT_const_value(0x1000)
.dwattr $C$DW$870, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$870, DW_AT_decl_line(0x62)
.dwattr $C$DW$870, DW_AT_decl_column(0x05)
$C$DW$871 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PERIPH_INIT_ERR"), DW_AT_const_value(0x1001)
.dwattr $C$DW$871, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$871, DW_AT_decl_line(0x63)
.dwattr $C$DW$871, DW_AT_decl_column(0x05)
$C$DW$872 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_INIT_ERR"), DW_AT_const_value(0x1002)
.dwattr $C$DW$872, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$872, DW_AT_decl_line(0x64)
.dwattr $C$DW$872, DW_AT_decl_column(0x05)
$C$DW$873 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_DOORBELL_ERR"), DW_AT_const_value(0x1003)
.dwattr $C$DW$873, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$873, DW_AT_decl_line(0x65)
.dwattr $C$DW$873, DW_AT_decl_column(0x05)
$C$DW$874 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_UNREGISTERED_DOORBELL_ERR"), DW_AT_const_value(0x1004)
.dwattr $C$DW$874, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$874, DW_AT_decl_line(0x66)
.dwattr $C$DW$874, DW_AT_decl_column(0x05)
$C$DW$875 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_GPIO_ERR"), DW_AT_const_value(0x1005)
.dwattr $C$DW$875, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$875, DW_AT_decl_line(0x67)
.dwattr $C$DW$875, DW_AT_decl_column(0x05)
$C$DW$876 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_ERROR_DOORBELL_SWI_NOT_CREATED"), DW_AT_const_value(0x1006)
.dwattr $C$DW$876, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$876, DW_AT_decl_line(0x68)
.dwattr $C$DW$876, DW_AT_decl_column(0x05)
$C$DW$877 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_NULL_NOTIFY_FXN"), DW_AT_const_value(0x1007)
.dwattr $C$DW$877, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$877, DW_AT_decl_line(0x69)
.dwattr $C$DW$877, DW_AT_decl_column(0x05)
$C$DW$878 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLC"), DW_AT_const_value(0x2000)
.dwattr $C$DW$878, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$878, DW_AT_decl_line(0x6b)
.dwattr $C$DW$878, DW_AT_decl_column(0x05)
$C$DW$879 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLC_INIT"), DW_AT_const_value(0x2001)
.dwattr $C$DW$879, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$879, DW_AT_decl_line(0x6c)
.dwattr $C$DW$879, DW_AT_decl_column(0x05)
$C$DW$880 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLC_OPEN"), DW_AT_const_value(0x2002)
.dwattr $C$DW$880, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$880, DW_AT_decl_line(0x6d)
.dwattr $C$DW$880, DW_AT_decl_column(0x05)
$C$DW$881 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLCHWSETUP"), DW_AT_const_value(0x2003)
.dwattr $C$DW$881, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$881, DW_AT_decl_line(0x6e)
.dwattr $C$DW$881, DW_AT_decl_column(0x05)
$C$DW$882 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLCHWCONTROL"), DW_AT_const_value(0x2004)
.dwattr $C$DW$882, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$882, DW_AT_decl_line(0x6f)
.dwattr $C$DW$882, DW_AT_decl_column(0x05)
$C$DW$883 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLCGETHWSTATUS"), DW_AT_const_value(0x2005)
.dwattr $C$DW$883, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$883, DW_AT_decl_line(0x70)
.dwattr $C$DW$883, DW_AT_decl_column(0x05)
$C$DW$884 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_HPI"), DW_AT_const_value(0x3000)
.dwattr $C$DW$884, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$884, DW_AT_decl_line(0x72)
.dwattr $C$DW$884, DW_AT_decl_column(0x05)
$C$DW$885 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_HPIINIT"), DW_AT_const_value(0x3001)
.dwattr $C$DW$885, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$885, DW_AT_decl_line(0x73)
.dwattr $C$DW$885, DW_AT_decl_column(0x05)
$C$DW$886 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_HPIOPEN"), DW_AT_const_value(0x3002)
.dwattr $C$DW$886, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$886, DW_AT_decl_line(0x74)
.dwattr $C$DW$886, DW_AT_decl_column(0x05)
$C$DW$887 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_DDR2"), DW_AT_const_value(0x4000)
.dwattr $C$DW$887, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$887, DW_AT_decl_line(0x76)
.dwattr $C$DW$887, DW_AT_decl_column(0x05)
$C$DW$888 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_DDR2_INIT"), DW_AT_const_value(0x4001)
.dwattr $C$DW$888, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$888, DW_AT_decl_line(0x77)
.dwattr $C$DW$888, DW_AT_decl_column(0x05)
$C$DW$889 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_DDR2_OPEN"), DW_AT_const_value(0x4002)
.dwattr $C$DW$889, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$889, DW_AT_decl_line(0x78)
.dwattr $C$DW$889, DW_AT_decl_column(0x05)
$C$DW$890 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_DDR2_HWSETUP"), DW_AT_const_value(0x4003)
.dwattr $C$DW$890, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$890, DW_AT_decl_line(0x79)
.dwattr $C$DW$890, DW_AT_decl_column(0x05)
$C$DW$891 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_MCBSP"), DW_AT_const_value(0x4100)
.dwattr $C$DW$891, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$891, DW_AT_decl_line(0x7b)
.dwattr $C$DW$891, DW_AT_decl_column(0x05)
$C$DW$892 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_MCBSP_INIT"), DW_AT_const_value(0x4101)
.dwattr $C$DW$892, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$892, DW_AT_decl_line(0x7c)
.dwattr $C$DW$892, DW_AT_decl_column(0x05)
$C$DW$893 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_MCBSP_OPEN"), DW_AT_const_value(0x4102)
.dwattr $C$DW$893, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$893, DW_AT_decl_line(0x7d)
.dwattr $C$DW$893, DW_AT_decl_column(0x05)
$C$DW$894 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_MCBSP0_ENB"), DW_AT_const_value(0x4103)
.dwattr $C$DW$894, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$894, DW_AT_decl_line(0x7e)
.dwattr $C$DW$894, DW_AT_decl_column(0x05)
$C$DW$895 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_MCBSP0_DIS"), DW_AT_const_value(0x4104)
.dwattr $C$DW$895, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$895, DW_AT_decl_line(0x7f)
.dwattr $C$DW$895, DW_AT_decl_column(0x05)
$C$DW$896 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3"), DW_AT_const_value(0x4200)
.dwattr $C$DW$896, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$896, DW_AT_decl_line(0x81)
.dwattr $C$DW$896, DW_AT_decl_column(0x05)
$C$DW$897 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_INIT"), DW_AT_const_value(0x4201)
.dwattr $C$DW$897, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$897, DW_AT_decl_line(0x82)
.dwattr $C$DW$897, DW_AT_decl_column(0x05)
$C$DW$898 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_OPEN"), DW_AT_const_value(0x4202)
.dwattr $C$DW$898, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$898, DW_AT_decl_line(0x83)
.dwattr $C$DW$898, DW_AT_decl_column(0x05)
$C$DW$899 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_HWSETUP"), DW_AT_const_value(0x4203)
.dwattr $C$DW$899, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$899, DW_AT_decl_line(0x84)
.dwattr $C$DW$899, DW_AT_decl_column(0x05)
$C$DW$900 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_CW_OPEN"), DW_AT_const_value(0x4204)
.dwattr $C$DW$900, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$900, DW_AT_decl_line(0x85)
.dwattr $C$DW$900, DW_AT_decl_column(0x05)
$C$DW$901 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_AUDIO_OPEN"), DW_AT_const_value(0x4205)
.dwattr $C$DW$901, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$901, DW_AT_decl_line(0x86)
.dwattr $C$DW$901, DW_AT_decl_column(0x05)
$C$DW$902 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_INSTANCE_INIT"), DW_AT_const_value(0x4206)
.dwattr $C$DW$902, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$902, DW_AT_decl_line(0x87)
.dwattr $C$DW$902, DW_AT_decl_column(0x05)
$C$DW$903 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_INTERRUPT_ENABLE"), DW_AT_const_value(0x4207)
.dwattr $C$DW$903, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$903, DW_AT_decl_line(0x88)
.dwattr $C$DW$903, DW_AT_decl_column(0x05)
$C$DW$904 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_CREATE_SHADOW_REGION"), DW_AT_const_value(0x4208)
.dwattr $C$DW$904, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$904, DW_AT_decl_line(0x89)
.dwattr $C$DW$904, DW_AT_decl_column(0x05)
$C$DW$905 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_UNOPENED_CHANNEL"), DW_AT_const_value(0x4209)
.dwattr $C$DW$905, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$905, DW_AT_decl_line(0x8a)
.dwattr $C$DW$905, DW_AT_decl_column(0x05)
$C$DW$906 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_CHAN_IN_USE"), DW_AT_const_value(0x420a)
.dwattr $C$DW$906, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$906, DW_AT_decl_line(0x8b)
.dwattr $C$DW$906, DW_AT_decl_column(0x05)
$C$DW$907 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_OUT_OF_PHY_CHAN"), DW_AT_const_value(0x420b)
.dwattr $C$DW$907, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$907, DW_AT_decl_line(0x8c)
.dwattr $C$DW$907, DW_AT_decl_column(0x05)
$C$DW$908 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_EXCEEDED_MAX_PHY_CHAN"), DW_AT_const_value(0x420c)
.dwattr $C$DW$908, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$908, DW_AT_decl_line(0x8d)
.dwattr $C$DW$908, DW_AT_decl_column(0x05)
$C$DW$909 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_OUT_OF_LINK_PARAMS"), DW_AT_const_value(0x420d)
.dwattr $C$DW$909, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$909, DW_AT_decl_line(0x8e)
.dwattr $C$DW$909, DW_AT_decl_column(0x05)
$C$DW$910 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_SETUP_FAILURE"), DW_AT_const_value(0x420e)
.dwattr $C$DW$910, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$910, DW_AT_decl_line(0x8f)
.dwattr $C$DW$910, DW_AT_decl_column(0x05)
$C$DW$911 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_TIMER"), DW_AT_const_value(0x4300)
.dwattr $C$DW$911, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$911, DW_AT_decl_line(0x91)
.dwattr $C$DW$911, DW_AT_decl_column(0x05)
$C$DW$912 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_TIMER_ERR"), DW_AT_const_value(0x4301)
.dwattr $C$DW$912, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$912, DW_AT_decl_line(0x92)
.dwattr $C$DW$912, DW_AT_decl_column(0x05)
$C$DW$913 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO"), DW_AT_const_value(0x4400)
.dwattr $C$DW$913, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$913, DW_AT_decl_line(0x94)
.dwattr $C$DW$913, DW_AT_decl_column(0x05)
$C$DW$914 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_PORT_ERR"), DW_AT_const_value(0x4401)
.dwattr $C$DW$914, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$914, DW_AT_decl_line(0x95)
.dwattr $C$DW$914, DW_AT_decl_column(0x05)
$C$DW$915 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_LSU_ERR"), DW_AT_const_value(0x4402)
.dwattr $C$DW$915, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$915, DW_AT_decl_line(0x96)
.dwattr $C$DW$915, DW_AT_decl_column(0x05)
$C$DW$916 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_SETUP_ERR"), DW_AT_const_value(0x4403)
.dwattr $C$DW$916, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$916, DW_AT_decl_line(0x97)
.dwattr $C$DW$916, DW_AT_decl_column(0x05)
$C$DW$917 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_INV_CONF_ERR"), DW_AT_const_value(0x4404)
.dwattr $C$DW$917, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$917, DW_AT_decl_line(0x98)
.dwattr $C$DW$917, DW_AT_decl_column(0x05)
$C$DW$918 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_PSC_ERR"), DW_AT_const_value(0x4405)
.dwattr $C$DW$918, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$918, DW_AT_decl_line(0x99)
.dwattr $C$DW$918, DW_AT_decl_column(0x05)
$C$DW$919 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_TIMEOUT_ERR"), DW_AT_const_value(0x4406)
.dwattr $C$DW$919, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$919, DW_AT_decl_line(0x9a)
.dwattr $C$DW$919, DW_AT_decl_column(0x05)
$C$DW$920 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_INV_SIZE_ERR"), DW_AT_const_value(0x4407)
.dwattr $C$DW$920, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$920, DW_AT_decl_line(0x9b)
.dwattr $C$DW$920, DW_AT_decl_column(0x05)
$C$DW$921 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_LSU_BSY_ERR"), DW_AT_const_value(0x4408)
.dwattr $C$DW$921, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$921, DW_AT_decl_line(0x9c)
.dwattr $C$DW$921, DW_AT_decl_column(0x05)
$C$DW$922 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_RST_TIMEOUT"), DW_AT_const_value(0x4409)
.dwattr $C$DW$922, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$922, DW_AT_decl_line(0x9d)
.dwattr $C$DW$922, DW_AT_decl_column(0x05)
$C$DW$923 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_ASYNC_SIZE_ERR"), DW_AT_const_value(0x440a)
.dwattr $C$DW$923, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$923, DW_AT_decl_line(0x9e)
.dwattr $C$DW$923, DW_AT_decl_column(0x05)
$C$DW$924 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_CLOSE_ERR"), DW_AT_const_value(0x440b)
.dwattr $C$DW$924, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$924, DW_AT_decl_line(0x9f)
.dwattr $C$DW$924, DW_AT_decl_column(0x05)
$C$DW$925 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_OPEN_ERR"), DW_AT_const_value(0x440c)
.dwattr $C$DW$925, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$925, DW_AT_decl_line(0xa0)
.dwattr $C$DW$925, DW_AT_decl_column(0x05)
$C$DW$926 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_MULTIPLE_DOORBELL_INTERRUPT"), DW_AT_const_value(0x440d)
.dwattr $C$DW$926, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$926, DW_AT_decl_line(0xa1)
.dwattr $C$DW$926, DW_AT_decl_column(0x05)
$C$DW$927 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_COM_UNKNOWN"), DW_AT_const_value(0x4500)
.dwattr $C$DW$927, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$927, DW_AT_decl_line(0xa3)
.dwattr $C$DW$927, DW_AT_decl_column(0x05)
$C$DW$928 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_COM_NONFATAL"), DW_AT_const_value(0x4501)
.dwattr $C$DW$928, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$928, DW_AT_decl_line(0xa4)
.dwattr $C$DW$928, DW_AT_decl_column(0x05)
$C$DW$929 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_COM_FATAL"), DW_AT_const_value(0x4502)
.dwattr $C$DW$929, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$929, DW_AT_decl_line(0xa5)
.dwattr $C$DW$929, DW_AT_decl_column(0x05)
$C$DW$930 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_COM_DATA"), DW_AT_const_value(0x4503)
.dwattr $C$DW$930, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$930, DW_AT_decl_line(0xa6)
.dwattr $C$DW$930, DW_AT_decl_column(0x05)
$C$DW$931 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_COM_RE_INIT"), DW_AT_const_value(0x4504)
.dwattr $C$DW$931, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$931, DW_AT_decl_line(0xa7)
.dwattr $C$DW$931, DW_AT_decl_column(0x05)
$C$DW$932 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL"), DW_AT_const_value(0x4600)
.dwattr $C$DW$932, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$932, DW_AT_decl_line(0xa9)
.dwattr $C$DW$932, DW_AT_decl_column(0x05)
$C$DW$933 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_BUFADDR_NOT_ALIGNED"), DW_AT_const_value(0x4601)
.dwattr $C$DW$933, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$933, DW_AT_decl_line(0xaa)
.dwattr $C$DW$933, DW_AT_decl_column(0x05)
$C$DW$934 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_BUFSIZE_NOT_ALIGNED"), DW_AT_const_value(0x4602)
.dwattr $C$DW$934, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$934, DW_AT_decl_line(0xab)
.dwattr $C$DW$934, DW_AT_decl_column(0x05)
$C$DW$935 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_BUFBLKSIZE_NOT_ALIGNED"), DW_AT_const_value(0x4603)
.dwattr $C$DW$935, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$935, DW_AT_decl_line(0xac)
.dwattr $C$DW$935, DW_AT_decl_column(0x05)
$C$DW$936 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_DBELLINTVL_NOT_ALIGNED"), DW_AT_const_value(0x4604)
.dwattr $C$DW$936, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$936, DW_AT_decl_line(0xad)
.dwattr $C$DW$936, DW_AT_decl_column(0x05)
$C$DW$937 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_TOO_MANY_BLOCKS"), DW_AT_const_value(0x4605)
.dwattr $C$DW$937, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$937, DW_AT_decl_line(0xae)
.dwattr $C$DW$937, DW_AT_decl_column(0x05)
$C$DW$938 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_INVALID_SPB_SPECIFIER"), DW_AT_const_value(0x4606)
.dwattr $C$DW$938, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$938, DW_AT_decl_line(0xaf)
.dwattr $C$DW$938, DW_AT_decl_column(0x05)
$C$DW$939 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_UNSUPPORTED_DATA_TYPE"), DW_AT_const_value(0x4607)
.dwattr $C$DW$939, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$939, DW_AT_decl_line(0xb0)
.dwattr $C$DW$939, DW_AT_decl_column(0x05)
$C$DW$940 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_DBELL_INTERVAL_OVERFLOW"), DW_AT_const_value(0x4608)
.dwattr $C$DW$940, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$940, DW_AT_decl_line(0xb1)
.dwattr $C$DW$940, DW_AT_decl_column(0x05)
$C$DW$941 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_BEC"), DW_AT_const_value(0x4700)
.dwattr $C$DW$941, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$941, DW_AT_decl_line(0xb3)
.dwattr $C$DW$941, DW_AT_decl_column(0x05)
$C$DW$942 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_BEC_INVALID_DATATYPE1"), DW_AT_const_value(0x4701)
.dwattr $C$DW$942, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$942, DW_AT_decl_line(0xb4)
.dwattr $C$DW$942, DW_AT_decl_column(0x05)
$C$DW$943 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_BEC_INVALID_DATATYPE2"), DW_AT_const_value(0x4702)
.dwattr $C$DW$943, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$943, DW_AT_decl_line(0xb5)
.dwattr $C$DW$943, DW_AT_decl_column(0x05)
$C$DW$944 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_INTC_CONTEXT_INIT"), DW_AT_const_value(0x4800)
.dwattr $C$DW$944, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$944, DW_AT_decl_line(0xb7)
.dwattr $C$DW$944, DW_AT_decl_column(0x05)
$C$DW$945 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_EXCEEDED_MAX_SEC_EVENTS"), DW_AT_const_value(0x4801)
.dwattr $C$DW$945, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$945, DW_AT_decl_line(0xb8)
.dwattr $C$DW$945, DW_AT_decl_column(0x05)
$C$DW$946 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_INVALID_SEC_EVENTS"), DW_AT_const_value(0x4802)
.dwattr $C$DW$946, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$946, DW_AT_decl_line(0xb9)
.dwattr $C$DW$946, DW_AT_decl_column(0x02)
$C$DW$947 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_EXCEEDED_MAX_BROAD_EVENTS"), DW_AT_const_value(0x4803)
.dwattr $C$DW$947, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$947, DW_AT_decl_line(0xba)
.dwattr $C$DW$947, DW_AT_decl_column(0x05)
$C$DW$948 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_BROADCAST_INVALID_EVENTS"), DW_AT_const_value(0x4804)
.dwattr $C$DW$948, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$948, DW_AT_decl_line(0xbb)
.dwattr $C$DW$948, DW_AT_decl_column(0x02)
$C$DW$949 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_BROADCAST_EVENT_ALREADY_IN_USE"), DW_AT_const_value(0x4805)
.dwattr $C$DW$949, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$949, DW_AT_decl_line(0xbc)
.dwattr $C$DW$949, DW_AT_decl_column(0x05)
$C$DW$950 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_SERVICED_ON_WRONG_CORE"), DW_AT_const_value(0x4806)
.dwattr $C$DW$950, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$950, DW_AT_decl_line(0xbd)
.dwattr $C$DW$950, DW_AT_decl_column(0x05)
$C$DW$951 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_CREATE"), DW_AT_const_value(0x4807)
.dwattr $C$DW$951, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$951, DW_AT_decl_line(0xbe)
.dwattr $C$DW$951, DW_AT_decl_column(0x05)
$C$DW$952 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_CORE_INTERRUPT_VECTOR_IN_USE"), DW_AT_const_value(0x4808)
.dwattr $C$DW$952, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$952, DW_AT_decl_line(0xbf)
.dwattr $C$DW$952, DW_AT_decl_column(0x05)
$C$DW$953 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_CORE_ISR_VECTOR_SETUP_FAILURE"), DW_AT_const_value(0x4809)
.dwattr $C$DW$953, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$953, DW_AT_decl_line(0xc0)
.dwattr $C$DW$953, DW_AT_decl_column(0x05)
$C$DW$954 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_OPEN_CIC_INSTANCE"), DW_AT_const_value(0x480a)
.dwattr $C$DW$954, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$954, DW_AT_decl_line(0xc1)
.dwattr $C$DW$954, DW_AT_decl_column(0x05)
$C$DW$955 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_CORE_INTERRUPT_VECTOR_OUT_OF_RANGE"), DW_AT_const_value(0x480b)
.dwattr $C$DW$955, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$955, DW_AT_decl_line(0xc2)
.dwattr $C$DW$955, DW_AT_decl_column(0x05)
$C$DW$956 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_SETUP_ERR"), DW_AT_const_value(0x4900)
.dwattr $C$DW$956, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$956, DW_AT_decl_line(0xc4)
.dwattr $C$DW$956, DW_AT_decl_column(0x05)
$C$DW$957 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_SEND_LIST_OVERFLOW"), DW_AT_const_value(0x4901)
.dwattr $C$DW$957, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$957, DW_AT_decl_line(0xc5)
.dwattr $C$DW$957, DW_AT_decl_column(0x05)
$C$DW$958 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_SEND_LIST_UNDERFLOW"), DW_AT_const_value(0x4902)
.dwattr $C$DW$958, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$958, DW_AT_decl_line(0xc6)
.dwattr $C$DW$958, DW_AT_decl_column(0x05)
$C$DW$959 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_SEND_START_ADDR_INVALID"), DW_AT_const_value(0x4903)
.dwattr $C$DW$959, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$959, DW_AT_decl_line(0xc7)
.dwattr $C$DW$959, DW_AT_decl_column(0x05)
$C$DW$960 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_SEND_END_ADDR_INVALID"), DW_AT_const_value(0x4904)
.dwattr $C$DW$960, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$960, DW_AT_decl_line(0xc8)
.dwattr $C$DW$960, DW_AT_decl_column(0x05)
$C$DW$961 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_TIMEOUT"), DW_AT_const_value(0x4905)
.dwattr $C$DW$961, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$961, DW_AT_decl_line(0xc9)
.dwattr $C$DW$961, DW_AT_decl_column(0x05)
$C$DW$962 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_FPGA_TIME_OVERFLOW"), DW_AT_const_value(0x4906)
.dwattr $C$DW$962, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$962, DW_AT_decl_line(0xca)
.dwattr $C$DW$962, DW_AT_decl_column(0x05)
$C$DW$963 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR"), DW_AT_const_value(0x5000)
.dwattr $C$DW$963, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$963, DW_AT_decl_line(0xcc)
.dwattr $C$DW$963, DW_AT_decl_column(0x05)
$C$DW$964 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_COMMAND"), DW_AT_const_value(0x5001)
.dwattr $C$DW$964, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$964, DW_AT_decl_line(0xcd)
.dwattr $C$DW$964, DW_AT_decl_column(0x05)
$C$DW$965 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_SUB_COMMAND"), DW_AT_const_value(0x5002)
.dwattr $C$DW$965, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$965, DW_AT_decl_line(0xce)
.dwattr $C$DW$965, DW_AT_decl_column(0x05)
$C$DW$966 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_STATE_TRANSITION"), DW_AT_const_value(0x5003)
.dwattr $C$DW$966, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$966, DW_AT_decl_line(0xcf)
.dwattr $C$DW$966, DW_AT_decl_column(0x05)
$C$DW$967 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_SEM_STATE"), DW_AT_const_value(0x5004)
.dwattr $C$DW$967, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$967, DW_AT_decl_line(0xd0)
.dwattr $C$DW$967, DW_AT_decl_column(0x05)
$C$DW$968 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_SEM_BORROWER_STATE"), DW_AT_const_value(0x5005)
.dwattr $C$DW$968, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$968, DW_AT_decl_line(0xd1)
.dwattr $C$DW$968, DW_AT_decl_column(0x05)
$C$DW$969 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_MODE_FOR_STOP"), DW_AT_const_value(0x5006)
.dwattr $C$DW$969, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$969, DW_AT_decl_line(0xd2)
.dwattr $C$DW$969, DW_AT_decl_column(0x05)
$C$DW$970 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_RASTERZOOM_DATATYPE"), DW_AT_const_value(0x5007)
.dwattr $C$DW$970, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$970, DW_AT_decl_line(0xd3)
.dwattr $C$DW$970, DW_AT_decl_column(0x05)
$C$DW$971 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_CLEAR_CINE_ON_ACTIVE_DATATYPE"), DW_AT_const_value(0x5008)
.dwattr $C$DW$971, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$971, DW_AT_decl_line(0xd4)
.dwattr $C$DW$971, DW_AT_decl_column(0x05)
$C$DW$972 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_SPDATATYPE"), DW_AT_const_value(0x5009)
.dwattr $C$DW$972, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$972, DW_AT_decl_line(0xd5)
.dwattr $C$DW$972, DW_AT_decl_column(0x05)
$C$DW$973 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_STOP_CALLED_WHEN_CINE_NOT_READY"), DW_AT_const_value(0x500a)
.dwattr $C$DW$973, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$973, DW_AT_decl_line(0xd6)
.dwattr $C$DW$973, DW_AT_decl_column(0x05)
$C$DW$974 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_CINE_OUT_OF_RANGE"), DW_AT_const_value(0x500b)
.dwattr $C$DW$974, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$974, DW_AT_decl_line(0xd7)
.dwattr $C$DW$974, DW_AT_decl_column(0x05)
$C$DW$975 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_CINE_PROCESSTYPE_OUT_OF_BOUNDS"), DW_AT_const_value(0x500c)
.dwattr $C$DW$975, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$975, DW_AT_decl_line(0xd8)
.dwattr $C$DW$975, DW_AT_decl_column(0x05)
$C$DW$976 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MAINCTLR"), DW_AT_const_value(0x5500)
.dwattr $C$DW$976, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$976, DW_AT_decl_line(0xda)
.dwattr $C$DW$976, DW_AT_decl_column(0x05)
$C$DW$977 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MAINCTLR_INVALID_EVENT"), DW_AT_const_value(0x5501)
.dwattr $C$DW$977, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$977, DW_AT_decl_line(0xdb)
.dwattr $C$DW$977, DW_AT_decl_column(0x05)
$C$DW$978 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MAINCTLR_INVALID_CMD"), DW_AT_const_value(0x5502)
.dwattr $C$DW$978, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$978, DW_AT_decl_line(0xdc)
.dwattr $C$DW$978, DW_AT_decl_column(0x05)
$C$DW$979 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MAINCTLR_INVALID_MODE_COMBINATION"), DW_AT_const_value(0x5503)
.dwattr $C$DW$979, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$979, DW_AT_decl_line(0xdd)
.dwattr $C$DW$979, DW_AT_decl_column(0x02)
$C$DW$980 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MAINCTLR_INVALID_MSG_TYPE"), DW_AT_const_value(0x5504)
.dwattr $C$DW$980, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$980, DW_AT_decl_line(0xde)
.dwattr $C$DW$980, DW_AT_decl_column(0x05)
$C$DW$981 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR"), DW_AT_const_value(0x6000)
.dwattr $C$DW$981, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$981, DW_AT_decl_line(0xe0)
.dwattr $C$DW$981, DW_AT_decl_column(0x05)
$C$DW$982 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_CMD_TABLE_OVERFLOW"), DW_AT_const_value(0x6001)
.dwattr $C$DW$982, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$982, DW_AT_decl_line(0xe1)
.dwattr $C$DW$982, DW_AT_decl_column(0x05)
$C$DW$983 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_DATATYPE0"), DW_AT_const_value(0x6002)
.dwattr $C$DW$983, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$983, DW_AT_decl_line(0xe2)
.dwattr $C$DW$983, DW_AT_decl_column(0x05)
$C$DW$984 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_DATATYPE1"), DW_AT_const_value(0x6003)
.dwattr $C$DW$984, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$984, DW_AT_decl_line(0xe3)
.dwattr $C$DW$984, DW_AT_decl_column(0x05)
$C$DW$985 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_SP_SUBMODE"), DW_AT_const_value(0x6004)
.dwattr $C$DW$985, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$985, DW_AT_decl_line(0xe4)
.dwattr $C$DW$985, DW_AT_decl_column(0x05)
$C$DW$986 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_START_TIMEOUT"), DW_AT_const_value(0x6005)
.dwattr $C$DW$986, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$986, DW_AT_decl_line(0xe5)
.dwattr $C$DW$986, DW_AT_decl_column(0x05)
$C$DW$987 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INIT_TIMEOUT"), DW_AT_const_value(0x6006)
.dwattr $C$DW$987, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$987, DW_AT_decl_line(0xe6)
.dwattr $C$DW$987, DW_AT_decl_column(0x05)
$C$DW$988 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_STOP_TIMEOUT"), DW_AT_const_value(0x6007)
.dwattr $C$DW$988, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$988, DW_AT_decl_line(0xe7)
.dwattr $C$DW$988, DW_AT_decl_column(0x05)
$C$DW$989 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_PROCESS_CMD"), DW_AT_const_value(0x6008)
.dwattr $C$DW$989, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$989, DW_AT_decl_line(0xe8)
.dwattr $C$DW$989, DW_AT_decl_column(0x05)
$C$DW$990 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_MODE_COMBINATION"), DW_AT_const_value(0x6009)
.dwattr $C$DW$990, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$990, DW_AT_decl_line(0xe9)
.dwattr $C$DW$990, DW_AT_decl_column(0x05)
$C$DW$991 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_CINE_MEM_SEL"), DW_AT_const_value(0x600a)
.dwattr $C$DW$991, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$991, DW_AT_decl_line(0xea)
.dwattr $C$DW$991, DW_AT_decl_column(0x05)
$C$DW$992 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_SPDATATYPE_INVALID0"), DW_AT_const_value(0x600b)
.dwattr $C$DW$992, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$992, DW_AT_decl_line(0xeb)
.dwattr $C$DW$992, DW_AT_decl_column(0x05)
$C$DW$993 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_SPDATATYPE_INVALID1"), DW_AT_const_value(0x600c)
.dwattr $C$DW$993, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$993, DW_AT_decl_line(0xec)
.dwattr $C$DW$993, DW_AT_decl_column(0x05)
$C$DW$994 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_SPDATATYPE_INVALID2"), DW_AT_const_value(0x600d)
.dwattr $C$DW$994, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$994, DW_AT_decl_line(0xed)
.dwattr $C$DW$994, DW_AT_decl_column(0x05)
$C$DW$995 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_SUB_COMMAND"), DW_AT_const_value(0x600e)
.dwattr $C$DW$995, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$995, DW_AT_decl_line(0xee)
.dwattr $C$DW$995, DW_AT_decl_column(0x05)
$C$DW$996 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_UPDATE_COMMAND"), DW_AT_const_value(0x600f)
.dwattr $C$DW$996, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$996, DW_AT_decl_line(0xef)
.dwattr $C$DW$996, DW_AT_decl_column(0x02)
$C$DW$997 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_PLMGR"), DW_AT_const_value(0x7000)
.dwattr $C$DW$997, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$997, DW_AT_decl_line(0xf1)
.dwattr $C$DW$997, DW_AT_decl_column(0x05)
$C$DW$998 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_PLMGR_INVALID_SP_MODE"), DW_AT_const_value(0x7001)
.dwattr $C$DW$998, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$998, DW_AT_decl_line(0xf2)
.dwattr $C$DW$998, DW_AT_decl_column(0x05)
$C$DW$999 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_PLMGR_INVALID_SP_SUBMODE"), DW_AT_const_value(0x7002)
.dwattr $C$DW$999, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$999, DW_AT_decl_line(0xf3)
.dwattr $C$DW$999, DW_AT_decl_column(0x05)
$C$DW$1000 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR"), DW_AT_const_value(0x8000)
.dwattr $C$DW$1000, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1000, DW_AT_decl_line(0xf5)
.dwattr $C$DW$1000, DW_AT_decl_column(0x05)
$C$DW$1001 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_OVERFLOW"), DW_AT_const_value(0x8001)
.dwattr $C$DW$1001, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1001, DW_AT_decl_line(0xf6)
.dwattr $C$DW$1001, DW_AT_decl_column(0x05)
$C$DW$1002 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_NULL_ENQUEUE_FXN"), DW_AT_const_value(0x8002)
.dwattr $C$DW$1002, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1002, DW_AT_decl_line(0xf7)
.dwattr $C$DW$1002, DW_AT_decl_column(0x05)
$C$DW$1003 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_UNSUPP_MODE"), DW_AT_const_value(0x8003)
.dwattr $C$DW$1003, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1003, DW_AT_decl_line(0xf8)
.dwattr $C$DW$1003, DW_AT_decl_column(0x05)
$C$DW$1004 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_INVALID_DOORBELL_INFO"), DW_AT_const_value(0x8004)
.dwattr $C$DW$1004, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1004, DW_AT_decl_line(0xf9)
.dwattr $C$DW$1004, DW_AT_decl_column(0x05)
$C$DW$1005 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_SYSTEM_NOT_READY"), DW_AT_const_value(0x8005)
.dwattr $C$DW$1005, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1005, DW_AT_decl_line(0xfa)
.dwattr $C$DW$1005, DW_AT_decl_column(0x05)
$C$DW$1006 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_MODE_MISMATCH"), DW_AT_const_value(0x8006)
.dwattr $C$DW$1006, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1006, DW_AT_decl_line(0xfb)
.dwattr $C$DW$1006, DW_AT_decl_column(0x05)
$C$DW$1007 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGE_INVALID_MSG_TYPE"), DW_AT_const_value(0x8007)
.dwattr $C$DW$1007, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1007, DW_AT_decl_line(0xfc)
.dwattr $C$DW$1007, DW_AT_decl_column(0x05)
$C$DW$1008 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_FRAME_HISTORY_BAD_SIZE"), DW_AT_const_value(0x8008)
.dwattr $C$DW$1008, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1008, DW_AT_decl_line(0xfd)
.dwattr $C$DW$1008, DW_AT_decl_column(0x05)
$C$DW$1009 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_MAX_PRF_OVERFLOW"), DW_AT_const_value(0x8009)
.dwattr $C$DW$1009, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1009, DW_AT_decl_line(0xfe)
.dwattr $C$DW$1009, DW_AT_decl_column(0x05)
$C$DW$1010 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR"), DW_AT_const_value(0x9000)
.dwattr $C$DW$1010, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1010, DW_AT_decl_line(0x100)
.dwattr $C$DW$1010, DW_AT_decl_column(0x05)
$C$DW$1011 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_UNSUPP_MODE"), DW_AT_const_value(0x9001)
.dwattr $C$DW$1011, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1011, DW_AT_decl_line(0x101)
.dwattr $C$DW$1011, DW_AT_decl_column(0x05)
$C$DW$1012 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_UNKNOWN_BUFFER_XFER"), DW_AT_const_value(0x9002)
.dwattr $C$DW$1012, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1012, DW_AT_decl_line(0x102)
.dwattr $C$DW$1012, DW_AT_decl_column(0x05)
$C$DW$1013 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_STRANGE_SWI_WAKEUP"), DW_AT_const_value(0x9003)
.dwattr $C$DW$1013, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1013, DW_AT_decl_line(0x103)
.dwattr $C$DW$1013, DW_AT_decl_column(0x05)
$C$DW$1014 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_AUDIO_OVERFLOW"), DW_AT_const_value(0x9004)
.dwattr $C$DW$1014, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1014, DW_AT_decl_line(0x104)
.dwattr $C$DW$1014, DW_AT_decl_column(0x05)
$C$DW$1015 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_AUDIO_UNDERFLOW"), DW_AT_const_value(0x9005)
.dwattr $C$DW$1015, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1015, DW_AT_decl_line(0x105)
.dwattr $C$DW$1015, DW_AT_decl_column(0x05)
$C$DW$1016 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_AUDIO_SETUP_ERR"), DW_AT_const_value(0x9006)
.dwattr $C$DW$1016, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1016, DW_AT_decl_line(0x106)
.dwattr $C$DW$1016, DW_AT_decl_column(0x05)
$C$DW$1017 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_AUDIO_SHUTDN_ERR"), DW_AT_const_value(0x9007)
.dwattr $C$DW$1017, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1017, DW_AT_decl_line(0x107)
.dwattr $C$DW$1017, DW_AT_decl_column(0x05)
$C$DW$1018 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_SIZE_ERR"), DW_AT_const_value(0x9008)
.dwattr $C$DW$1018, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1018, DW_AT_decl_line(0x108)
.dwattr $C$DW$1018, DW_AT_decl_column(0x05)
$C$DW$1019 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_EXCEED_CPU_MEMORY_CAPACITY"), DW_AT_const_value(0x9009)
.dwattr $C$DW$1019, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1019, DW_AT_decl_line(0x109)
.dwattr $C$DW$1019, DW_AT_decl_column(0x05)
$C$DW$1020 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_DATATYPE"), DW_AT_const_value(0x900a)
.dwattr $C$DW$1020, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1020, DW_AT_decl_line(0x10a)
.dwattr $C$DW$1020, DW_AT_decl_column(0x05)
$C$DW$1021 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_FRAME_SYNC_HOLDOFF_OVERFLOW"), DW_AT_const_value(0x900b)
.dwattr $C$DW$1021, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1021, DW_AT_decl_line(0x10b)
.dwattr $C$DW$1021, DW_AT_decl_column(0x05)
$C$DW$1022 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_FRAME_SYNC_UNEXPECTED_FRAME_ID"), DW_AT_const_value(0x900c)
.dwattr $C$DW$1022, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1022, DW_AT_decl_line(0x10c)
.dwattr $C$DW$1022, DW_AT_decl_column(0x05)
$C$DW$1023 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_MSG_TYPE"), DW_AT_const_value(0x900d)
.dwattr $C$DW$1023, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1023, DW_AT_decl_line(0x10d)
.dwattr $C$DW$1023, DW_AT_decl_column(0x05)
$C$DW$1024 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_DATATYPE_FOR_CLEAR"), DW_AT_const_value(0x900e)
.dwattr $C$DW$1024, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1024, DW_AT_decl_line(0x10e)
.dwattr $C$DW$1024, DW_AT_decl_column(0x05)
$C$DW$1025 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_PLAYLIST_RW_IDX"), DW_AT_const_value(0x900f)
.dwattr $C$DW$1025, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1025, DW_AT_decl_line(0x10f)
.dwattr $C$DW$1025, DW_AT_decl_column(0x05)
$C$DW$1026 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_PLAYLIST_BUF_FULL"), DW_AT_const_value(0x9010)
.dwattr $C$DW$1026, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1026, DW_AT_decl_line(0x110)
.dwattr $C$DW$1026, DW_AT_decl_column(0x05)
$C$DW$1027 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_CORE"), DW_AT_const_value(0x9011)
.dwattr $C$DW$1027, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1027, DW_AT_decl_line(0x111)
.dwattr $C$DW$1027, DW_AT_decl_column(0x05)
$C$DW$1028 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_FRAMEWORK"), DW_AT_const_value(0xa000)
.dwattr $C$DW$1028, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1028, DW_AT_decl_line(0x113)
.dwattr $C$DW$1028, DW_AT_decl_column(0x05)
$C$DW$1029 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_FRAMEWORK_BADMODE"), DW_AT_const_value(0xa001)
.dwattr $C$DW$1029, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1029, DW_AT_decl_line(0x114)
.dwattr $C$DW$1029, DW_AT_decl_column(0x05)
$C$DW$1030 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_FRAMEWORK_BADCLUSTER"), DW_AT_const_value(0xa002)
.dwattr $C$DW$1030, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1030, DW_AT_decl_line(0x115)
.dwattr $C$DW$1030, DW_AT_decl_column(0x05)
$C$DW$1031 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_FRAMEWORK_BADPHYSPKT"), DW_AT_const_value(0xa003)
.dwattr $C$DW$1031, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1031, DW_AT_decl_line(0x116)
.dwattr $C$DW$1031, DW_AT_decl_column(0x05)
$C$DW$1032 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_FRAMEWORK_ACTIVECLUSTER_OVERFLOW"), DW_AT_const_value(0xa004)
.dwattr $C$DW$1032, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1032, DW_AT_decl_line(0x117)
.dwattr $C$DW$1032, DW_AT_decl_column(0x05)
$C$DW$1033 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC"), DW_AT_const_value(0xb000)
.dwattr $C$DW$1033, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1033, DW_AT_decl_line(0x119)
.dwattr $C$DW$1033, DW_AT_decl_column(0x05)
$C$DW$1034 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_ATTACH_ERR"), DW_AT_const_value(0xb001)
.dwattr $C$DW$1034, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1034, DW_AT_decl_line(0x11a)
.dwattr $C$DW$1034, DW_AT_decl_column(0x05)
$C$DW$1035 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_CREATE_ERR"), DW_AT_const_value(0xb002)
.dwattr $C$DW$1035, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1035, DW_AT_decl_line(0x11b)
.dwattr $C$DW$1035, DW_AT_decl_column(0x05)
$C$DW$1036 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_ALLOC_ERR"), DW_AT_const_value(0xb003)
.dwattr $C$DW$1036, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1036, DW_AT_decl_line(0x11c)
.dwattr $C$DW$1036, DW_AT_decl_column(0x05)
$C$DW$1037 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_PUT_ERR"), DW_AT_const_value(0xb004)
.dwattr $C$DW$1037, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1037, DW_AT_decl_line(0x11d)
.dwattr $C$DW$1037, DW_AT_decl_column(0x05)
$C$DW$1038 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_GET_ERR"), DW_AT_const_value(0xb005)
.dwattr $C$DW$1038, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1038, DW_AT_decl_line(0x11e)
.dwattr $C$DW$1038, DW_AT_decl_column(0x05)
$C$DW$1039 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_FREE_ERR"), DW_AT_const_value(0xb006)
.dwattr $C$DW$1039, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1039, DW_AT_decl_line(0x11f)
.dwattr $C$DW$1039, DW_AT_decl_column(0x05)
$C$DW$1040 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_CREATE_ERR"), DW_AT_const_value(0xb007)
.dwattr $C$DW$1040, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1040, DW_AT_decl_line(0x120)
.dwattr $C$DW$1040, DW_AT_decl_column(0x05)
$C$DW$1041 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_INVALID_ID_ERR"), DW_AT_const_value(0xb008)
.dwattr $C$DW$1041, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1041, DW_AT_decl_line(0x121)
.dwattr $C$DW$1041, DW_AT_decl_column(0x05)
$C$DW$1042 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_SYNC_EVENT_CREATE_ERR"), DW_AT_const_value(0xb009)
.dwattr $C$DW$1042, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1042, DW_AT_decl_line(0x122)
.dwattr $C$DW$1042, DW_AT_decl_column(0x05)
$C$DW$1043 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK"), DW_AT_const_value(0xc000)
.dwattr $C$DW$1043, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1043, DW_AT_decl_line(0x124)
.dwattr $C$DW$1043, DW_AT_decl_column(0x05)
$C$DW$1044 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK_PROCESS_BUF_OVERFLOW"), DW_AT_const_value(0xc001)
.dwattr $C$DW$1044, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1044, DW_AT_decl_line(0x125)
.dwattr $C$DW$1044, DW_AT_decl_column(0x05)
$C$DW$1045 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK_INVALID_SP_MODE"), DW_AT_const_value(0xc002)
.dwattr $C$DW$1045, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1045, DW_AT_decl_line(0x126)
.dwattr $C$DW$1045, DW_AT_decl_column(0x05)
$C$DW$1046 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK_INVALID_MSG_TYPE"), DW_AT_const_value(0xc003)
.dwattr $C$DW$1046, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1046, DW_AT_decl_line(0x127)
.dwattr $C$DW$1046, DW_AT_decl_column(0x05)
$C$DW$1047 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK_INVALID_PROCESSCMD_TYPE"), DW_AT_const_value(0xc004)
.dwattr $C$DW$1047, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1047, DW_AT_decl_line(0x128)
.dwattr $C$DW$1047, DW_AT_decl_column(0x02)
$C$DW$1048 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK_INVALID_UPDATE_COMMAND"), DW_AT_const_value(0xc005)
.dwattr $C$DW$1048, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1048, DW_AT_decl_line(0x129)
.dwattr $C$DW$1048, DW_AT_decl_column(0x02)
$C$DW$1049 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE"), DW_AT_const_value(0xd000)
.dwattr $C$DW$1049, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1049, DW_AT_decl_line(0x12b)
.dwattr $C$DW$1049, DW_AT_decl_column(0x05)
$C$DW$1050 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_PINGPKT_MISSING_EOB"), DW_AT_const_value(0xd001)
.dwattr $C$DW$1050, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1050, DW_AT_decl_line(0x12c)
.dwattr $C$DW$1050, DW_AT_decl_column(0x05)
$C$DW$1051 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_PINGPKT_DSIZE_ERR"), DW_AT_const_value(0xd002)
.dwattr $C$DW$1051, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1051, DW_AT_decl_line(0x12d)
.dwattr $C$DW$1051, DW_AT_decl_column(0x05)
$C$DW$1052 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_PINGPKT_UNEXPECTED_EOB"), DW_AT_const_value(0xd003)
.dwattr $C$DW$1052, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1052, DW_AT_decl_line(0x12e)
.dwattr $C$DW$1052, DW_AT_decl_column(0x05)
$C$DW$1053 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_INVALID_RFBUFIDX"), DW_AT_const_value(0xd004)
.dwattr $C$DW$1053, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1053, DW_AT_decl_line(0x12f)
.dwattr $C$DW$1053, DW_AT_decl_column(0x05)
$C$DW$1054 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_LINE_LENGTH_ERR"), DW_AT_const_value(0xd005)
.dwattr $C$DW$1054, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1054, DW_AT_decl_line(0x130)
.dwattr $C$DW$1054, DW_AT_decl_column(0x05)
$C$DW$1055 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_PINGPKT_UNEXPECTED_SEQUENCE_NUMBER"), DW_AT_const_value(0xd006)
.dwattr $C$DW$1055, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1055, DW_AT_decl_line(0x131)
.dwattr $C$DW$1055, DW_AT_decl_column(0x05)
$C$DW$1056 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_PINGPKT_MAGIC_ERR"), DW_AT_const_value(0xd007)
.dwattr $C$DW$1056, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1056, DW_AT_decl_line(0x132)
.dwattr $C$DW$1056, DW_AT_decl_column(0x05)
$C$DW$1057 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR"), DW_AT_const_value(0xe000)
.dwattr $C$DW$1057, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1057, DW_AT_decl_line(0x134)
.dwattr $C$DW$1057, DW_AT_decl_column(0x05)
$C$DW$1058 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_FRAME_RANGE"), DW_AT_const_value(0xe001)
.dwattr $C$DW$1058, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1058, DW_AT_decl_line(0x135)
.dwattr $C$DW$1058, DW_AT_decl_column(0x05)
$C$DW$1059 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_COL_RANGE"), DW_AT_const_value(0xe002)
.dwattr $C$DW$1059, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1059, DW_AT_decl_line(0x136)
.dwattr $C$DW$1059, DW_AT_decl_column(0x05)
$C$DW$1060 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_ECG_INVALID_COL_RANGE"), DW_AT_const_value(0xe003)
.dwattr $C$DW$1060, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1060, DW_AT_decl_line(0x137)
.dwattr $C$DW$1060, DW_AT_decl_column(0x05)
$C$DW$1061 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_QUEUE_RANGE"), DW_AT_const_value(0xe004)
.dwattr $C$DW$1061, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1061, DW_AT_decl_line(0x138)
.dwattr $C$DW$1061, DW_AT_decl_column(0x05)
$C$DW$1062 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_PLAYBACK_RANGE"), DW_AT_const_value(0xe005)
.dwattr $C$DW$1062, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1062, DW_AT_decl_line(0x139)
.dwattr $C$DW$1062, DW_AT_decl_column(0x05)
$C$DW$1063 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_PLAYBACK_SPEED"), DW_AT_const_value(0xe006)
.dwattr $C$DW$1063, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1063, DW_AT_decl_line(0x13a)
.dwattr $C$DW$1063, DW_AT_decl_column(0x05)
$C$DW$1064 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_PLAYBACK_TIMEOUT"), DW_AT_const_value(0xe007)
.dwattr $C$DW$1064, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1064, DW_AT_decl_line(0x13b)
.dwattr $C$DW$1064, DW_AT_decl_column(0x05)
$C$DW$1065 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_INCBUF_ADDR0"), DW_AT_const_value(0xe008)
.dwattr $C$DW$1065, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1065, DW_AT_decl_line(0x13c)
.dwattr $C$DW$1065, DW_AT_decl_column(0x05)
$C$DW$1066 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_INCBUF_ADDR1"), DW_AT_const_value(0xe009)
.dwattr $C$DW$1066, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1066, DW_AT_decl_line(0x13d)
.dwattr $C$DW$1066, DW_AT_decl_column(0x05)
$C$DW$1067 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_OUTCBUF_ADDR0"), DW_AT_const_value(0xe00a)
.dwattr $C$DW$1067, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1067, DW_AT_decl_line(0x13e)
.dwattr $C$DW$1067, DW_AT_decl_column(0x05)
$C$DW$1068 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_OUTCBUF_ADDR1"), DW_AT_const_value(0xe00b)
.dwattr $C$DW$1068, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1068, DW_AT_decl_line(0x13f)
.dwattr $C$DW$1068, DW_AT_decl_column(0x05)
$C$DW$1069 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_DATATYPE0"), DW_AT_const_value(0xe00c)
.dwattr $C$DW$1069, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1069, DW_AT_decl_line(0x140)
.dwattr $C$DW$1069, DW_AT_decl_column(0x05)
$C$DW$1070 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_DATATYPE1"), DW_AT_const_value(0xe00d)
.dwattr $C$DW$1070, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1070, DW_AT_decl_line(0x141)
.dwattr $C$DW$1070, DW_AT_decl_column(0x05)
$C$DW$1071 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_SUBCMD"), DW_AT_const_value(0xe00e)
.dwattr $C$DW$1071, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1071, DW_AT_decl_line(0x142)
.dwattr $C$DW$1071, DW_AT_decl_column(0x05)
$C$DW$1072 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_CINECOL_MMODE"), DW_AT_const_value(0xe00f)
.dwattr $C$DW$1072, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1072, DW_AT_decl_line(0x143)
.dwattr $C$DW$1072, DW_AT_decl_column(0x05)
$C$DW$1073 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_CINECOL_DOP"), DW_AT_const_value(0xe010)
.dwattr $C$DW$1073, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1073, DW_AT_decl_line(0x144)
.dwattr $C$DW$1073, DW_AT_decl_column(0x05)
$C$DW$1074 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_CINECOL_ECG"), DW_AT_const_value(0xe011)
.dwattr $C$DW$1074, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1074, DW_AT_decl_line(0x145)
.dwattr $C$DW$1074, DW_AT_decl_column(0x05)
$C$DW$1075 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_CORE"), DW_AT_const_value(0xe012)
.dwattr $C$DW$1075, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1075, DW_AT_decl_line(0x146)
.dwattr $C$DW$1075, DW_AT_decl_column(0x05)
$C$DW$1076 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_CINE_NOT_READY"), DW_AT_const_value(0xe013)
.dwattr $C$DW$1076, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1076, DW_AT_decl_line(0x147)
.dwattr $C$DW$1076, DW_AT_decl_column(0x05)
$C$DW$1077 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_BOSSTASK"), DW_AT_const_value(0xf000)
.dwattr $C$DW$1077, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1077, DW_AT_decl_line(0x149)
.dwattr $C$DW$1077, DW_AT_decl_column(0x05)
$C$DW$1078 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_BOSSTASK_INVALID_MSG_TYPE"), DW_AT_const_value(0xf001)
.dwattr $C$DW$1078, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1078, DW_AT_decl_line(0x14a)
.dwattr $C$DW$1078, DW_AT_decl_column(0x05)
$C$DW$1079 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER"), DW_AT_const_value(0x10000)
.dwattr $C$DW$1079, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1079, DW_AT_decl_line(0x14d)
.dwattr $C$DW$1079, DW_AT_decl_column(0x05)
$C$DW$1080 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_BADSTATE"), DW_AT_const_value(0x10001)
.dwattr $C$DW$1080, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1080, DW_AT_decl_line(0x14e)
.dwattr $C$DW$1080, DW_AT_decl_column(0x05)
$C$DW$1081 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INPUT_OVERFLOW"), DW_AT_const_value(0x10002)
.dwattr $C$DW$1081, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1081, DW_AT_decl_line(0x14f)
.dwattr $C$DW$1081, DW_AT_decl_column(0x05)
$C$DW$1082 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_EMPTY_INPUT"), DW_AT_const_value(0x10003)
.dwattr $C$DW$1082, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1082, DW_AT_decl_line(0x150)
.dwattr $C$DW$1082, DW_AT_decl_column(0x05)
$C$DW$1083 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_USECS_PER_PRI"), DW_AT_const_value(0x10004)
.dwattr $C$DW$1083, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1083, DW_AT_decl_line(0x151)
.dwattr $C$DW$1083, DW_AT_decl_column(0x05)
$C$DW$1084 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_USECS_PER_FFT"), DW_AT_const_value(0x10005)
.dwattr $C$DW$1084, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1084, DW_AT_decl_line(0x152)
.dwattr $C$DW$1084, DW_AT_decl_column(0x05)
$C$DW$1085 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_FFTS_PER_COLUMN"), DW_AT_const_value(0x10006)
.dwattr $C$DW$1085, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1085, DW_AT_decl_line(0x153)
.dwattr $C$DW$1085, DW_AT_decl_column(0x05)
$C$DW$1086 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_CWQBP_FILTERLEN"), DW_AT_const_value(0x10007)
.dwattr $C$DW$1086, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1086, DW_AT_decl_line(0x154)
.dwattr $C$DW$1086, DW_AT_decl_column(0x05)
$C$DW$1087 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_CWQBP_INVALID_DECIMATION"), DW_AT_const_value(0x10008)
.dwattr $C$DW$1087, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1087, DW_AT_decl_line(0x155)
.dwattr $C$DW$1087, DW_AT_decl_column(0x05)
$C$DW$1088 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_BUFFER_EXCEEDS_SRIO_ATW"), DW_AT_const_value(0x10009)
.dwattr $C$DW$1088, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1088, DW_AT_decl_line(0x156)
.dwattr $C$DW$1088, DW_AT_decl_column(0x05)
$C$DW$1089 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INVALID_PROCESS_CMD"), DW_AT_const_value(0x1000a)
.dwattr $C$DW$1089, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1089, DW_AT_decl_line(0x157)
.dwattr $C$DW$1089, DW_AT_decl_column(0x05)
$C$DW$1090 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_DEVELOPMENT"), DW_AT_const_value(0x1000b)
.dwattr $C$DW$1090, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1090, DW_AT_decl_line(0x158)
.dwattr $C$DW$1090, DW_AT_decl_column(0x05)
$C$DW$1091 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_AUDIO"), DW_AT_const_value(0x1000c)
.dwattr $C$DW$1091, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1091, DW_AT_decl_line(0x159)
.dwattr $C$DW$1091, DW_AT_decl_column(0x05)
$C$DW$1092 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_AUDIO_BUF_OVERFLOW"), DW_AT_const_value(0x1000d)
.dwattr $C$DW$1092, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1092, DW_AT_decl_line(0x15a)
.dwattr $C$DW$1092, DW_AT_decl_column(0x05)
$C$DW$1093 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_FILL_TIMER_INIT"), DW_AT_const_value(0x1000e)
.dwattr $C$DW$1093, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1093, DW_AT_decl_line(0x15b)
.dwattr $C$DW$1093, DW_AT_decl_column(0x05)
$C$DW$1094 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INVALID_PRI"), DW_AT_const_value(0x1000f)
.dwattr $C$DW$1094, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1094, DW_AT_decl_line(0x15c)
.dwattr $C$DW$1094, DW_AT_decl_column(0x05)
$C$DW$1095 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_SAMP_PER_BLOCK_0"), DW_AT_const_value(0x10010)
.dwattr $C$DW$1095, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1095, DW_AT_decl_line(0x15d)
.dwattr $C$DW$1095, DW_AT_decl_column(0x05)
$C$DW$1096 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INVALID_SAMP_PER_BLOCK"), DW_AT_const_value(0x10011)
.dwattr $C$DW$1096, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1096, DW_AT_decl_line(0x15e)
.dwattr $C$DW$1096, DW_AT_decl_column(0x05)
$C$DW$1097 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_TOO_MANY_OUTPUTS"), DW_AT_const_value(0x10012)
.dwattr $C$DW$1097, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1097, DW_AT_decl_line(0x15f)
.dwattr $C$DW$1097, DW_AT_decl_column(0x05)
$C$DW$1098 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_USEC_PER_PRI_ZERO"), DW_AT_const_value(0x10013)
.dwattr $C$DW$1098, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1098, DW_AT_decl_line(0x160)
.dwattr $C$DW$1098, DW_AT_decl_column(0x05)
$C$DW$1099 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INCBUF_NOT_BIG_ENOUGH"), DW_AT_const_value(0x10014)
.dwattr $C$DW$1099, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1099, DW_AT_decl_line(0x161)
.dwattr $C$DW$1099, DW_AT_decl_column(0x05)
$C$DW$1100 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_MKR_IN_BWD_ALG_STATE"), DW_AT_const_value(0x10015)
.dwattr $C$DW$1100, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1100, DW_AT_decl_line(0x162)
.dwattr $C$DW$1100, DW_AT_decl_column(0x05)
$C$DW$1101 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_SIZE_0"), DW_AT_const_value(0x10016)
.dwattr $C$DW$1101, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1101, DW_AT_decl_line(0x163)
.dwattr $C$DW$1101, DW_AT_decl_column(0x05)
$C$DW$1102 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_SZ_UNKNOWN"), DW_AT_const_value(0x10017)
.dwattr $C$DW$1102, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1102, DW_AT_decl_line(0x164)
.dwattr $C$DW$1102, DW_AT_decl_column(0x05)
$C$DW$1103 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_MRK_WHEN_ZERO"), DW_AT_const_value(0x10018)
.dwattr $C$DW$1103, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1103, DW_AT_decl_line(0x165)
.dwattr $C$DW$1103, DW_AT_decl_column(0x05)
$C$DW$1104 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_UNKNOWN_STATE"), DW_AT_const_value(0x10019)
.dwattr $C$DW$1104, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1104, DW_AT_decl_line(0x166)
.dwattr $C$DW$1104, DW_AT_decl_column(0x05)
$C$DW$1105 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_REMAINDER_NOT_ZERO"), DW_AT_const_value(0x1001a)
.dwattr $C$DW$1105, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1105, DW_AT_decl_line(0x167)
.dwattr $C$DW$1105, DW_AT_decl_column(0x05)
$C$DW$1106 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_SAMPLES_AFTER_MKR_BIT"), DW_AT_const_value(0x1001b)
.dwattr $C$DW$1106, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1106, DW_AT_decl_line(0x168)
.dwattr $C$DW$1106, DW_AT_decl_column(0x05)
$C$DW$1107 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_SAMPLES_AFTER_MKR_BIT1"), DW_AT_const_value(0x1001c)
.dwattr $C$DW$1107, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1107, DW_AT_decl_line(0x169)
.dwattr $C$DW$1107, DW_AT_decl_column(0x05)
$C$DW$1108 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_SPCTL_BUF_SIZE"), DW_AT_const_value(0x1001d)
.dwattr $C$DW$1108, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1108, DW_AT_decl_line(0x16a)
.dwattr $C$DW$1108, DW_AT_decl_column(0x05)
$C$DW$1109 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_FFT_AND_FFTBYN_DIFF_CORE"), DW_AT_const_value(0x1001e)
.dwattr $C$DW$1109, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1109, DW_AT_decl_line(0x16b)
.dwattr $C$DW$1109, DW_AT_decl_column(0x05)
$C$DW$1110 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_UNKNOWN_INIT_CMD"), DW_AT_const_value(0x1001f)
.dwattr $C$DW$1110, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1110, DW_AT_decl_line(0x16c)
.dwattr $C$DW$1110, DW_AT_decl_column(0x05)
$C$DW$1111 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_LINE_INTERLEAVE_ERROR"), DW_AT_const_value(0x10020)
.dwattr $C$DW$1111, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1111, DW_AT_decl_line(0x16d)
.dwattr $C$DW$1111, DW_AT_decl_column(0x05)
$C$DW$1112 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INVALID_PARAM"), DW_AT_const_value(0x10021)
.dwattr $C$DW$1112, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1112, DW_AT_decl_line(0x16e)
.dwattr $C$DW$1112, DW_AT_decl_column(0x05)
$C$DW$1113 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INVALID_IDX"), DW_AT_const_value(0x10022)
.dwattr $C$DW$1113, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1113, DW_AT_decl_line(0x16f)
.dwattr $C$DW$1113, DW_AT_decl_column(0x05)
$C$DW$1114 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_GAP_SZ_TOO_LARGE"), DW_AT_const_value(0x11000)
.dwattr $C$DW$1114, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1114, DW_AT_decl_line(0x170)
.dwattr $C$DW$1114, DW_AT_decl_column(0x05)
$C$DW$1115 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_GAP_SZ_TOO_SMALL"), DW_AT_const_value(0x11001)
.dwattr $C$DW$1115, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1115, DW_AT_decl_line(0x171)
.dwattr $C$DW$1115, DW_AT_decl_column(0x05)
$C$DW$1116 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_IN_SZ_TOO_LARGE"), DW_AT_const_value(0x11002)
.dwattr $C$DW$1116, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1116, DW_AT_decl_line(0x172)
.dwattr $C$DW$1116, DW_AT_decl_column(0x05)
$C$DW$1117 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_IN_SZ_TOO_SMALL"), DW_AT_const_value(0x11003)
.dwattr $C$DW$1117, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1117, DW_AT_decl_line(0x173)
.dwattr $C$DW$1117, DW_AT_decl_column(0x05)
$C$DW$1118 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_BURG_ORDER_TOO_LARGE"), DW_AT_const_value(0x11004)
.dwattr $C$DW$1118, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1118, DW_AT_decl_line(0x174)
.dwattr $C$DW$1118, DW_AT_decl_column(0x05)
$C$DW$1119 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_BURG_ORDER_TOO_SMALL"), DW_AT_const_value(0x11005)
.dwattr $C$DW$1119, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1119, DW_AT_decl_line(0x175)
.dwattr $C$DW$1119, DW_AT_decl_column(0x05)
$C$DW$1120 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_VAR_EXP_G_THAN_31"), DW_AT_const_value(0x11006)
.dwattr $C$DW$1120, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1120, DW_AT_decl_line(0x176)
.dwattr $C$DW$1120, DW_AT_decl_column(0x05)
$C$DW$1121 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_NOT_ENOUGH_SAMPLES"), DW_AT_const_value(0x11007)
.dwattr $C$DW$1121, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1121, DW_AT_decl_line(0x177)
.dwattr $C$DW$1121, DW_AT_decl_column(0x05)
$C$DW$1122 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_PW_DATATYPE_INCOMPATIBLE"), DW_AT_const_value(0x11008)
.dwattr $C$DW$1122, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1122, DW_AT_decl_line(0x178)
.dwattr $C$DW$1122, DW_AT_decl_column(0x05)
$C$DW$1123 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_CW_DATATYPE_INCOMPATIBLE"), DW_AT_const_value(0x11009)
.dwattr $C$DW$1123, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1123, DW_AT_decl_line(0x179)
.dwattr $C$DW$1123, DW_AT_decl_column(0x05)
$C$DW$1124 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_BASELINE_IDX_OUT_OF_BOUND"), DW_AT_const_value(0x1100a)
.dwattr $C$DW$1124, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1124, DW_AT_decl_line(0x17a)
.dwattr $C$DW$1124, DW_AT_decl_column(0x05)
$C$DW$1125 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_DBELL_SIZE_VIOLATE_SPCTL_SPEC"), DW_AT_const_value(0x1100b)
.dwattr $C$DW$1125, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1125, DW_AT_decl_line(0x17b)
.dwattr $C$DW$1125, DW_AT_decl_column(0x05)
$C$DW$1126 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_IRREGULAR_NUM_OUTPUT_COLS"), DW_AT_const_value(0x1100c)
.dwattr $C$DW$1126, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1126, DW_AT_decl_line(0x17c)
.dwattr $C$DW$1126, DW_AT_decl_column(0x05)
$C$DW$1127 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_PROCESS_LL2_MEMORY_INVALID"), DW_AT_const_value(0x1100d)
.dwattr $C$DW$1127, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1127, DW_AT_decl_line(0x17d)
.dwattr $C$DW$1127, DW_AT_decl_column(0x05)
$C$DW$1128 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_PW_UNKNOWN_SUB_MODE"), DW_AT_const_value(0x1100e)
.dwattr $C$DW$1128, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1128, DW_AT_decl_line(0x17e)
.dwattr $C$DW$1128, DW_AT_decl_column(0x05)
$C$DW$1129 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW"), DW_AT_const_value(0x20000)
.dwattr $C$DW$1129, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1129, DW_AT_decl_line(0x180)
.dwattr $C$DW$1129, DW_AT_decl_column(0x05)
$C$DW$1130 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_INPUT_BUFFER_ALLOCATION_FAILURE"), DW_AT_const_value(0x20001)
.dwattr $C$DW$1130, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1130, DW_AT_decl_line(0x181)
.dwattr $C$DW$1130, DW_AT_decl_column(0x05)
$C$DW$1131 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_BUFF_OVF"), DW_AT_const_value(0x20002)
.dwattr $C$DW$1131, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1131, DW_AT_decl_line(0x182)
.dwattr $C$DW$1131, DW_AT_decl_column(0x05)
$C$DW$1132 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_BUFF_UF"), DW_AT_const_value(0x20003)
.dwattr $C$DW$1132, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1132, DW_AT_decl_line(0x183)
.dwattr $C$DW$1132, DW_AT_decl_column(0x05)
$C$DW$1133 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_GRPSZE_INVALID"), DW_AT_const_value(0x20004)
.dwattr $C$DW$1133, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1133, DW_AT_decl_line(0x184)
.dwattr $C$DW$1133, DW_AT_decl_column(0x05)
$C$DW$1134 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_VARSZE_INVALID"), DW_AT_const_value(0x20005)
.dwattr $C$DW$1134, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1134, DW_AT_decl_line(0x185)
.dwattr $C$DW$1134, DW_AT_decl_column(0x05)
$C$DW$1135 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_BADSTATE"), DW_AT_const_value(0x20006)
.dwattr $C$DW$1135, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1135, DW_AT_decl_line(0x186)
.dwattr $C$DW$1135, DW_AT_decl_column(0x05)
$C$DW$1136 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_INBUFF_SIZE_INVALID"), DW_AT_const_value(0x20007)
.dwattr $C$DW$1136, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1136, DW_AT_decl_line(0x187)
.dwattr $C$DW$1136, DW_AT_decl_column(0x05)
$C$DW$1137 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_PARAMETER_OUT_OF_BOUNDS"), DW_AT_const_value(0x20008)
.dwattr $C$DW$1137, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1137, DW_AT_decl_line(0x188)
.dwattr $C$DW$1137, DW_AT_decl_column(0x05)
$C$DW$1138 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_INVALID_PROCESS_CMD0"), DW_AT_const_value(0x20009)
.dwattr $C$DW$1138, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1138, DW_AT_decl_line(0x189)
.dwattr $C$DW$1138, DW_AT_decl_column(0x05)
$C$DW$1139 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_INVALID_PROCESS_CMD1"), DW_AT_const_value(0x2000a)
.dwattr $C$DW$1139, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1139, DW_AT_decl_line(0x18a)
.dwattr $C$DW$1139, DW_AT_decl_column(0x05)
$C$DW$1140 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_INVALID_PROCESS_CMD2"), DW_AT_const_value(0x2000b)
.dwattr $C$DW$1140, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1140, DW_AT_decl_line(0x18b)
.dwattr $C$DW$1140, DW_AT_decl_column(0x05)
$C$DW$1141 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_PING_PKT_HEADER_CORRUPT"), DW_AT_const_value(0x2000c)
.dwattr $C$DW$1141, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1141, DW_AT_decl_line(0x18c)
.dwattr $C$DW$1141, DW_AT_decl_column(0x05)
$C$DW$1142 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_UNSUPPORTED_MPFIR_SOURCE"), DW_AT_const_value(0x2000d)
.dwattr $C$DW$1142, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1142, DW_AT_decl_line(0x18d)
.dwattr $C$DW$1142, DW_AT_decl_column(0x05)
$C$DW$1143 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_UNSUPPORTED_MPFIR_MODE"), DW_AT_const_value(0x2000e)
.dwattr $C$DW$1143, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1143, DW_AT_decl_line(0x18e)
.dwattr $C$DW$1143, DW_AT_decl_column(0x05)
$C$DW$1144 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_ALREADY_INITIALIZED"), DW_AT_const_value(0x2000f)
.dwattr $C$DW$1144, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1144, DW_AT_decl_line(0x18f)
.dwattr $C$DW$1144, DW_AT_decl_column(0x05)
$C$DW$1145 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_COMPUTED_FRAMERATE_BAD"), DW_AT_const_value(0x20010)
.dwattr $C$DW$1145, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1145, DW_AT_decl_line(0x190)
.dwattr $C$DW$1145, DW_AT_decl_column(0x05)
$C$DW$1146 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_COLOROUTLEN_LESS_THAN_NESTIMATES"), DW_AT_const_value(0x20011)
.dwattr $C$DW$1146, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1146, DW_AT_decl_line(0x191)
.dwattr $C$DW$1146, DW_AT_decl_column(0x05)
$C$DW$1147 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_LOCAL_MEMORY_NOT_ALLOCATED"), DW_AT_const_value(0x20012)
.dwattr $C$DW$1147, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1147, DW_AT_decl_line(0x192)
.dwattr $C$DW$1147, DW_AT_decl_column(0x05)
$C$DW$1148 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_OUTPUT_READY_LATENCY"), DW_AT_const_value(0x20013)
.dwattr $C$DW$1148, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1148, DW_AT_decl_line(0x193)
.dwattr $C$DW$1148, DW_AT_decl_column(0x05)
$C$DW$1149 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD"), DW_AT_const_value(0x30000)
.dwattr $C$DW$1149, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1149, DW_AT_decl_line(0x195)
.dwattr $C$DW$1149, DW_AT_decl_column(0x05)
$C$DW$1150 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_BADSTATE"), DW_AT_const_value(0x30001)
.dwattr $C$DW$1150, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1150, DW_AT_decl_line(0x196)
.dwattr $C$DW$1150, DW_AT_decl_column(0x05)
$C$DW$1151 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_DMAOPEN"), DW_AT_const_value(0x30002)
.dwattr $C$DW$1151, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1151, DW_AT_decl_line(0x197)
.dwattr $C$DW$1151, DW_AT_decl_column(0x05)
$C$DW$1152 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_INVALID_SUBMODE"), DW_AT_const_value(0x30003)
.dwattr $C$DW$1152, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1152, DW_AT_decl_line(0x198)
.dwattr $C$DW$1152, DW_AT_decl_column(0x05)
$C$DW$1153 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_INVALID_PROCESS_CMD"), DW_AT_const_value(0x30004)
.dwattr $C$DW$1153, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1153, DW_AT_decl_line(0x199)
.dwattr $C$DW$1153, DW_AT_decl_column(0x05)
$C$DW$1154 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_INVALID_PARAMS"), DW_AT_const_value(0x30005)
.dwattr $C$DW$1154, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1154, DW_AT_decl_line(0x19a)
.dwattr $C$DW$1154, DW_AT_decl_column(0x05)
$C$DW$1155 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_MB_OUTPUT_EST_GT_INPUT_EST"), DW_AT_const_value(0x30006)
.dwattr $C$DW$1155, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1155, DW_AT_decl_line(0x19b)
.dwattr $C$DW$1155, DW_AT_decl_column(0x05)
$C$DW$1156 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_UNEXPECTED_PADDING"), DW_AT_const_value(0x30007)
.dwattr $C$DW$1156, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1156, DW_AT_decl_line(0x19c)
.dwattr $C$DW$1156, DW_AT_decl_column(0x05)
$C$DW$1157 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_MB_PREFETCH_BUF_UNDERFLOW"), DW_AT_const_value(0x30008)
.dwattr $C$DW$1157, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1157, DW_AT_decl_line(0x19d)
.dwattr $C$DW$1157, DW_AT_decl_column(0x05)
$C$DW$1158 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_POST_PROCESS_INVALID_FORK"), DW_AT_const_value(0x30009)
.dwattr $C$DW$1158, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1158, DW_AT_decl_line(0x19e)
.dwattr $C$DW$1158, DW_AT_decl_column(0x05)
$C$DW$1159 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_RF_BUFFER_INDEX_OUT_OF_BOUNDS"), DW_AT_const_value(0x3000a)
.dwattr $C$DW$1159, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1159, DW_AT_decl_line(0x19f)
.dwattr $C$DW$1159, DW_AT_decl_column(0x05)
$C$DW$1160 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_LL2_BUFFER_POINTER_NULL"), DW_AT_const_value(0x3000b)
.dwattr $C$DW$1160, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1160, DW_AT_decl_line(0x1a0)
.dwattr $C$DW$1160, DW_AT_decl_column(0x05)
$C$DW$1161 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_SL2_BUFFER_POINTER_NULL"), DW_AT_const_value(0x3000c)
.dwattr $C$DW$1161, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1161, DW_AT_decl_line(0x1a1)
.dwattr $C$DW$1161, DW_AT_decl_column(0x05)
$C$DW$1162 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_DDR_BUFFER_POINTER_NULL"), DW_AT_const_value(0x3000d)
.dwattr $C$DW$1162, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1162, DW_AT_decl_line(0x1a2)
.dwattr $C$DW$1162, DW_AT_decl_column(0x05)
$C$DW$1163 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_INVALID_DRAW_NUMBER_PARAM"), DW_AT_const_value(0x3000e)
.dwattr $C$DW$1163, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1163, DW_AT_decl_line(0x1a3)
.dwattr $C$DW$1163, DW_AT_decl_column(0x05)
$C$DW$1164 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IMAGING"), DW_AT_const_value(0x40000)
.dwattr $C$DW$1164, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1164, DW_AT_decl_line(0x1a5)
.dwattr $C$DW$1164, DW_AT_decl_column(0x05)
$C$DW$1165 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IMAGING_BADSTATE"), DW_AT_const_value(0x40001)
.dwattr $C$DW$1165, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1165, DW_AT_decl_line(0x1a6)
.dwattr $C$DW$1165, DW_AT_decl_column(0x05)
$C$DW$1166 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ"), DW_AT_const_value(0x50000)
.dwattr $C$DW$1166, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1166, DW_AT_decl_line(0x1a8)
.dwattr $C$DW$1166, DW_AT_decl_column(0x05)
$C$DW$1167 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_PARAMS"), DW_AT_const_value(0x50001)
.dwattr $C$DW$1167, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1167, DW_AT_decl_line(0x1a9)
.dwattr $C$DW$1167, DW_AT_decl_column(0x05)
$C$DW$1168 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_DDR_PROCESS_BUF_OVERFLOW"), DW_AT_const_value(0x50002)
.dwattr $C$DW$1168, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1168, DW_AT_decl_line(0x1aa)
.dwattr $C$DW$1168, DW_AT_decl_column(0x05)
$C$DW$1169 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_OPERATION"), DW_AT_const_value(0x50003)
.dwattr $C$DW$1169, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1169, DW_AT_decl_line(0x1ab)
.dwattr $C$DW$1169, DW_AT_decl_column(0x05)
$C$DW$1170 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_IMAGE_Y_SIZE"), DW_AT_const_value(0x50004)
.dwattr $C$DW$1170, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1170, DW_AT_decl_line(0x1ac)
.dwattr $C$DW$1170, DW_AT_decl_column(0x05)
$C$DW$1171 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_IMAGE_X_SIZE"), DW_AT_const_value(0x50005)
.dwattr $C$DW$1171, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1171, DW_AT_decl_line(0x1ad)
.dwattr $C$DW$1171, DW_AT_decl_column(0x05)
$C$DW$1172 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_IMAGE_MARGIN"), DW_AT_const_value(0x50006)
.dwattr $C$DW$1172, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1172, DW_AT_decl_line(0x1ae)
.dwattr $C$DW$1172, DW_AT_decl_column(0x05)
$C$DW$1173 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_COPYOFFSET"), DW_AT_const_value(0x50007)
.dwattr $C$DW$1173, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1173, DW_AT_decl_line(0x1af)
.dwattr $C$DW$1173, DW_AT_decl_column(0x05)
$C$DW$1174 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_LUT_SCALE"), DW_AT_const_value(0x50008)
.dwattr $C$DW$1174, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1174, DW_AT_decl_line(0x1b0)
.dwattr $C$DW$1174, DW_AT_decl_column(0x05)
$C$DW$1175 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_MAX_LEV"), DW_AT_const_value(0x50009)
.dwattr $C$DW$1175, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1175, DW_AT_decl_line(0x1b1)
.dwattr $C$DW$1175, DW_AT_decl_column(0x05)
$C$DW$1176 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_FRAME_BOUNDARY_INPUT_PARAM"), DW_AT_const_value(0x5000a)
.dwattr $C$DW$1176, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1176, DW_AT_decl_line(0x1b2)
.dwattr $C$DW$1176, DW_AT_decl_column(0x02)
$C$DW$1177 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC"), DW_AT_const_value(0x60000)
.dwattr $C$DW$1177, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1177, DW_AT_decl_line(0x1b4)
.dwattr $C$DW$1177, DW_AT_decl_column(0x05)
$C$DW$1178 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_INVALID_DATATYPE"), DW_AT_const_value(0x60001)
.dwattr $C$DW$1178, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1178, DW_AT_decl_line(0x1b5)
.dwattr $C$DW$1178, DW_AT_decl_column(0x05)
$C$DW$1179 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_TBLINIT"), DW_AT_const_value(0x60002)
.dwattr $C$DW$1179, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1179, DW_AT_decl_line(0x1b6)
.dwattr $C$DW$1179, DW_AT_decl_column(0x05)
$C$DW$1180 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_SUBSECTORSIZE"), DW_AT_const_value(0x60003)
.dwattr $C$DW$1180, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1180, DW_AT_decl_line(0x1b7)
.dwattr $C$DW$1180, DW_AT_decl_column(0x05)
$C$DW$1181 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_NUMSUBSECTORS"), DW_AT_const_value(0x60004)
.dwattr $C$DW$1181, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1181, DW_AT_decl_line(0x1b8)
.dwattr $C$DW$1181, DW_AT_decl_column(0x05)
$C$DW$1182 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RASTER_SIZEX"), DW_AT_const_value(0x60005)
.dwattr $C$DW$1182, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1182, DW_AT_decl_line(0x1b9)
.dwattr $C$DW$1182, DW_AT_decl_column(0x05)
$C$DW$1183 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RASTER_SIZEY"), DW_AT_const_value(0x60006)
.dwattr $C$DW$1183, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1183, DW_AT_decl_line(0x1ba)
.dwattr $C$DW$1183, DW_AT_decl_column(0x05)
$C$DW$1184 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_ESTDELTA"), DW_AT_const_value(0x60007)
.dwattr $C$DW$1184, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1184, DW_AT_decl_line(0x1bb)
.dwattr $C$DW$1184, DW_AT_decl_column(0x05)
$C$DW$1185 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_COLDELTA"), DW_AT_const_value(0x60008)
.dwattr $C$DW$1185, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1185, DW_AT_decl_line(0x1bc)
.dwattr $C$DW$1185, DW_AT_decl_column(0x05)
$C$DW$1186 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_ROWDELTA"), DW_AT_const_value(0x60009)
.dwattr $C$DW$1186, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1186, DW_AT_decl_line(0x1bd)
.dwattr $C$DW$1186, DW_AT_decl_column(0x05)
$C$DW$1187 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_OUTINDEX"), DW_AT_const_value(0x6000a)
.dwattr $C$DW$1187, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1187, DW_AT_decl_line(0x1be)
.dwattr $C$DW$1187, DW_AT_decl_column(0x05)
$C$DW$1188 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE"), DW_AT_const_value(0x70000)
.dwattr $C$DW$1188, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1188, DW_AT_decl_line(0x1c0)
.dwattr $C$DW$1188, DW_AT_decl_column(0x05)
$C$DW$1189 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_INVALID_PARAMS"), DW_AT_const_value(0x70001)
.dwattr $C$DW$1189, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1189, DW_AT_decl_line(0x1c1)
.dwattr $C$DW$1189, DW_AT_decl_column(0x05)
$C$DW$1190 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_INVALID_PROCESS_CMD"), DW_AT_const_value(0x70002)
.dwattr $C$DW$1190, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1190, DW_AT_decl_line(0x1c2)
.dwattr $C$DW$1190, DW_AT_decl_column(0x05)
$C$DW$1191 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_LL2_PROCESS_BUF_OVERFLOW"), DW_AT_const_value(0x70003)
.dwattr $C$DW$1191, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1191, DW_AT_decl_line(0x1c3)
.dwattr $C$DW$1191, DW_AT_decl_column(0x05)
$C$DW$1192 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_SAMPLE_PERIOD"), DW_AT_const_value(0x70004)
.dwattr $C$DW$1192, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1192, DW_AT_decl_line(0x1c4)
.dwattr $C$DW$1192, DW_AT_decl_column(0x05)
$C$DW$1193 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_INVALID_SUBMODE"), DW_AT_const_value(0x70005)
.dwattr $C$DW$1193, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1193, DW_AT_decl_line(0x1c5)
.dwattr $C$DW$1193, DW_AT_decl_column(0x05)
$C$DW$1194 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_LL2_BUFFER_ALLOCATION_FAILURE"), DW_AT_const_value(0x70006)
.dwattr $C$DW$1194, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1194, DW_AT_decl_line(0x1c6)
.dwattr $C$DW$1194, DW_AT_decl_column(0x05)
$C$DW$1195 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_ENQUEUE_INFO_ALLOCATION_FAILURE"), DW_AT_const_value(0x70007)
.dwattr $C$DW$1195, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1195, DW_AT_decl_line(0x1c7)
.dwattr $C$DW$1195, DW_AT_decl_column(0x05)
$C$DW$1196 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_SPCTL_BUFFER_ALLOCATION_FAILURE"), DW_AT_const_value(0x70008)
.dwattr $C$DW$1196, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1196, DW_AT_decl_line(0x1c8)
.dwattr $C$DW$1196, DW_AT_decl_column(0x05)
$C$DW$1197 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_RFBUF_OUT_OF_BOUNDS"), DW_AT_const_value(0x70009)
.dwattr $C$DW$1197, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1197, DW_AT_decl_line(0x1c9)
.dwattr $C$DW$1197, DW_AT_decl_column(0x05)
$C$DW$1198 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_PARAMETER"), DW_AT_const_value(0x7000a)
.dwattr $C$DW$1198, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1198, DW_AT_decl_line(0x1ca)
.dwattr $C$DW$1198, DW_AT_decl_column(0x02)
$C$DW$1199 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_BUFFER_PTR"), DW_AT_const_value(0x7000b)
.dwattr $C$DW$1199, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1199, DW_AT_decl_line(0x1cb)
.dwattr $C$DW$1199, DW_AT_decl_column(0x02)
$C$DW$1200 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_BUFFER_SIZE"), DW_AT_const_value(0x7000c)
.dwattr $C$DW$1200, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1200, DW_AT_decl_line(0x1cc)
.dwattr $C$DW$1200, DW_AT_decl_column(0x02)
$C$DW$1201 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_LINE_START_COORD"), DW_AT_const_value(0x7000d)
.dwattr $C$DW$1201, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1201, DW_AT_decl_line(0x1cd)
.dwattr $C$DW$1201, DW_AT_decl_column(0x02)
$C$DW$1202 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_LINE_END_COORD"), DW_AT_const_value(0x7000e)
.dwattr $C$DW$1202, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1202, DW_AT_decl_line(0x1ce)
.dwattr $C$DW$1202, DW_AT_decl_column(0x02)
$C$DW$1203 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_START_END_PT_NOT_INIT"), DW_AT_const_value(0x7000f)
.dwattr $C$DW$1203, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1203, DW_AT_decl_line(0x1cf)
.dwattr $C$DW$1203, DW_AT_decl_column(0x02)
$C$DW$1204 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_COL_TIME_COUNT"), DW_AT_const_value(0x70010)
.dwattr $C$DW$1204, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1204, DW_AT_decl_line(0x1d0)
.dwattr $C$DW$1204, DW_AT_decl_column(0x02)
$C$DW$1205 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB"), DW_AT_const_value(0x80000)
.dwattr $C$DW$1205, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1205, DW_AT_decl_line(0x1d2)
.dwattr $C$DW$1205, DW_AT_decl_column(0x05)
$C$DW$1206 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_NUM_LOOKS"), DW_AT_const_value(0x80001)
.dwattr $C$DW$1206, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1206, DW_AT_decl_line(0x1d3)
.dwattr $C$DW$1206, DW_AT_decl_column(0x05)
$C$DW$1207 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_NUM_EST"), DW_AT_const_value(0x80002)
.dwattr $C$DW$1207, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1207, DW_AT_decl_line(0x1d4)
.dwattr $C$DW$1207, DW_AT_decl_column(0x05)
$C$DW$1208 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_SH_PARAM"), DW_AT_const_value(0x80003)
.dwattr $C$DW$1208, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1208, DW_AT_decl_line(0x1d5)
.dwattr $C$DW$1208, DW_AT_decl_column(0x05)
$C$DW$1209 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_IMG_PARAM"), DW_AT_const_value(0x80004)
.dwattr $C$DW$1209, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1209, DW_AT_decl_line(0x1d6)
.dwattr $C$DW$1209, DW_AT_decl_column(0x05)
$C$DW$1210 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_NULL_PTR"), DW_AT_const_value(0x80005)
.dwattr $C$DW$1210, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1210, DW_AT_decl_line(0x1d7)
.dwattr $C$DW$1210, DW_AT_decl_column(0x05)
$C$DW$1211 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_NUM_LINE"), DW_AT_const_value(0x80006)
.dwattr $C$DW$1211, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1211, DW_AT_decl_line(0x1d8)
.dwattr $C$DW$1211, DW_AT_decl_column(0x05)
$C$DW$1212 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_LINE_IDX"), DW_AT_const_value(0x80007)
.dwattr $C$DW$1212, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1212, DW_AT_decl_line(0x1d9)
.dwattr $C$DW$1212, DW_AT_decl_column(0x05)
$C$DW$1213 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_EST_IDX"), DW_AT_const_value(0x80008)
.dwattr $C$DW$1213, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1213, DW_AT_decl_line(0x1da)
.dwattr $C$DW$1213, DW_AT_decl_column(0x05)
$C$DW$1214 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_SHORT_ARRAY_LEN"), DW_AT_const_value(0x80009)
.dwattr $C$DW$1214, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1214, DW_AT_decl_line(0x1db)
.dwattr $C$DW$1214, DW_AT_decl_column(0x05)
$C$DW$1215 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_FRAME_BOUNDARY_INPUT_PARAM"), DW_AT_const_value(0x8000a)
.dwattr $C$DW$1215, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1215, DW_AT_decl_line(0x1dc)
.dwattr $C$DW$1215, DW_AT_decl_column(0x05)
$C$DW$1216 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_NUM_TAPER_COEFF"), DW_AT_const_value(0x8000b)
.dwattr $C$DW$1216, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1216, DW_AT_decl_line(0x1dd)
.dwattr $C$DW$1216, DW_AT_decl_column(0x05)
$C$DW$1217 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_TAPER_COEFF"), DW_AT_const_value(0x8000c)
.dwattr $C$DW$1217, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1217, DW_AT_decl_line(0x1de)
.dwattr $C$DW$1217, DW_AT_decl_column(0x05)
$C$DW$1218 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_ANGLE_IDX"), DW_AT_const_value(0x8000d)
.dwattr $C$DW$1218, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1218, DW_AT_decl_line(0x1df)
.dwattr $C$DW$1218, DW_AT_decl_column(0x05)
$C$DW$1219 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_ANGLE"), DW_AT_const_value(0x8000e)
.dwattr $C$DW$1219, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1219, DW_AT_decl_line(0x1e0)
.dwattr $C$DW$1219, DW_AT_decl_column(0x05)
$C$DW$1220 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_STRIDE"), DW_AT_const_value(0x8000f)
.dwattr $C$DW$1220, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1220, DW_AT_decl_line(0x1e1)
.dwattr $C$DW$1220, DW_AT_decl_column(0x05)
$C$DW$1221 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_FRAME_DATA_SIZE"), DW_AT_const_value(0x80010)
.dwattr $C$DW$1221, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1221, DW_AT_decl_line(0x1e2)
.dwattr $C$DW$1221, DW_AT_decl_column(0x05)
$C$DW$1222 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_QFMT_VAL_OUT_OF_RANGE"), DW_AT_const_value(0x80011)
.dwattr $C$DW$1222, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1222, DW_AT_decl_line(0x1e3)
.dwattr $C$DW$1222, DW_AT_decl_column(0x05)
$C$DW$1223 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_FRAME_DATA_ORDER"), DW_AT_const_value(0x80012)
.dwattr $C$DW$1223, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1223, DW_AT_decl_line(0x1e4)
.dwattr $C$DW$1223, DW_AT_decl_column(0x05)
$C$DW$1224 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_AUTOGAIN"), DW_AT_const_value(0x90000)
.dwattr $C$DW$1224, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1224, DW_AT_decl_line(0x1e6)
.dwattr $C$DW$1224, DW_AT_decl_column(0x05)
$C$DW$1225 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_AUTOGAIN_INVALID_PARAMETER"), DW_AT_const_value(0x90001)
.dwattr $C$DW$1225, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1225, DW_AT_decl_line(0x1e7)
.dwattr $C$DW$1225, DW_AT_decl_column(0x05)
$C$DW$1226 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_AUTOGAIN_NO_QUALIFIED_EST"), DW_AT_const_value(0x90002)
.dwattr $C$DW$1226, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1226, DW_AT_decl_line(0x1e8)
.dwattr $C$DW$1226, DW_AT_decl_column(0x05)
$C$DW$1227 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG"), DW_AT_const_value(0xa0000)
.dwattr $C$DW$1227, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1227, DW_AT_decl_line(0x1ea)
.dwattr $C$DW$1227, DW_AT_decl_column(0x05)
$C$DW$1228 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_PARAMS"), DW_AT_const_value(0xa0001)
.dwattr $C$DW$1228, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1228, DW_AT_decl_line(0x1eb)
.dwattr $C$DW$1228, DW_AT_decl_column(0x05)
$C$DW$1229 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_PROCESS_CMD"), DW_AT_const_value(0xa0002)
.dwattr $C$DW$1229, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1229, DW_AT_decl_line(0x1ec)
.dwattr $C$DW$1229, DW_AT_decl_column(0x05)
$C$DW$1230 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_LL2_PROCESS_BUF_OVERFLOW"), DW_AT_const_value(0xa0003)
.dwattr $C$DW$1230, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1230, DW_AT_decl_line(0x1ed)
.dwattr $C$DW$1230, DW_AT_decl_column(0x05)
$C$DW$1231 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_ARRAY_BOUNDS"), DW_AT_const_value(0xa0004)
.dwattr $C$DW$1231, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1231, DW_AT_decl_line(0x1ee)
.dwattr $C$DW$1231, DW_AT_decl_column(0x05)
$C$DW$1232 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_SYNC_MAX_BOUNDS"), DW_AT_const_value(0xa0005)
.dwattr $C$DW$1232, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1232, DW_AT_decl_line(0x1ef)
.dwattr $C$DW$1232, DW_AT_decl_column(0x05)
$C$DW$1233 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_LOOP_COUNT_NEGATIVE"), DW_AT_const_value(0xa0006)
.dwattr $C$DW$1233, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1233, DW_AT_decl_line(0x1f0)
.dwattr $C$DW$1233, DW_AT_decl_column(0x05)
$C$DW$1234 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_DELAY_SAMP_WRONG"), DW_AT_const_value(0xa0007)
.dwattr $C$DW$1234, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1234, DW_AT_decl_line(0x1f1)
.dwattr $C$DW$1234, DW_AT_decl_column(0x05)
$C$DW$1235 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_IMAGE_START_ON_FIRST_SAMPLE"), DW_AT_const_value(0xa0008)
.dwattr $C$DW$1235, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1235, DW_AT_decl_line(0x1f2)
.dwattr $C$DW$1235, DW_AT_decl_column(0x05)
$C$DW$1236 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_TWO_IMAGE_STARTS"), DW_AT_const_value(0xa0009)
.dwattr $C$DW$1236, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1236, DW_AT_decl_line(0x1f3)
.dwattr $C$DW$1236, DW_AT_decl_column(0x05)
$C$DW$1237 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_LL2_BUFFER_ALLOCATION_FAILURE"), DW_AT_const_value(0xa000a)
.dwattr $C$DW$1237, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1237, DW_AT_decl_line(0x1f4)
.dwattr $C$DW$1237, DW_AT_decl_column(0x05)
$C$DW$1238 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_SCROLL_RATE"), DW_AT_const_value(0xa000b)
.dwattr $C$DW$1238, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1238, DW_AT_decl_line(0x1f5)
.dwattr $C$DW$1238, DW_AT_decl_column(0x05)
$C$DW$1239 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_HEART_RATE_WINDOW_SIZE"), DW_AT_const_value(0xa000c)
.dwattr $C$DW$1239, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1239, DW_AT_decl_line(0x1f6)
.dwattr $C$DW$1239, DW_AT_decl_column(0x05)
$C$DW$1240 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_ENQUEUE_INFO_ALLOCATION_FAILURE"), DW_AT_const_value(0xa000d)
.dwattr $C$DW$1240, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1240, DW_AT_decl_line(0x1f7)
.dwattr $C$DW$1240, DW_AT_decl_column(0x05)
$C$DW$1241 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_CORE"), DW_AT_const_value(0xa000e)
.dwattr $C$DW$1241, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1241, DW_AT_decl_line(0x1f8)
.dwattr $C$DW$1241, DW_AT_decl_column(0x05)
$C$DW$1242 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_SCREEN_WIDTH"), DW_AT_const_value(0xa000f)
.dwattr $C$DW$1242, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1242, DW_AT_decl_line(0x1f9)
.dwattr $C$DW$1242, DW_AT_decl_column(0x05)
$C$DW$1243 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_NV"), DW_AT_const_value(0xb0000)
.dwattr $C$DW$1243, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1243, DW_AT_decl_line(0x1fb)
.dwattr $C$DW$1243, DW_AT_decl_column(0x05)
$C$DW$1244 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_NV_INVALID_PROBE_TYPE"), DW_AT_const_value(0xb0001)
.dwattr $C$DW$1244, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1244, DW_AT_decl_line(0x1fc)
.dwattr $C$DW$1244, DW_AT_decl_column(0x05)
$C$DW$1245 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_NV_SC_INIT_BUF_SIZE_ERR"), DW_AT_const_value(0xb0002)
.dwattr $C$DW$1245, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1245, DW_AT_decl_line(0x1fd)
.dwattr $C$DW$1245, DW_AT_decl_column(0x05)
$C$DW$1246 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_NV_INVALID_IDX_VAL"), DW_AT_const_value(0xb0003)
.dwattr $C$DW$1246, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1246, DW_AT_decl_line(0x1fe)
.dwattr $C$DW$1246, DW_AT_decl_column(0x05)
$C$DW$1247 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_NV_INVALID_DEC_FACTOR"), DW_AT_const_value(0xb0004)
.dwattr $C$DW$1247, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1247, DW_AT_decl_line(0x1ff)
.dwattr $C$DW$1247, DW_AT_decl_column(0x05)
$C$DW$1248 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DIAG"), DW_AT_const_value(0xf0000)
.dwattr $C$DW$1248, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1248, DW_AT_decl_line(0x201)
.dwattr $C$DW$1248, DW_AT_decl_column(0x05)
$C$DW$1249 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DIAG_INVALID_ADDR"), DW_AT_const_value(0xf0001)
.dwattr $C$DW$1249, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1249, DW_AT_decl_line(0x202)
.dwattr $C$DW$1249, DW_AT_decl_column(0x05)
$C$DW$1250 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DIAG_BADSTATE"), DW_AT_const_value(0xf0002)
.dwattr $C$DW$1250, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1250, DW_AT_decl_line(0x203)
.dwattr $C$DW$1250, DW_AT_decl_column(0x05)
$C$DW$1251 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DIAG_ALREADY_RUNNING"), DW_AT_const_value(0xf0003)
.dwattr $C$DW$1251, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1251, DW_AT_decl_line(0x205)
.dwattr $C$DW$1251, DW_AT_decl_column(0x05)
$C$DW$1252 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DIAG_UNKNOWN_COMMAND"), DW_AT_const_value(0xf0004)
.dwattr $C$DW$1252, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1252, DW_AT_decl_line(0x206)
.dwattr $C$DW$1252, DW_AT_decl_column(0x05)
$C$DW$1253 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTI_CHAPTER_NAME_OVERLAP"), DW_AT_const_value(0x100000)
.dwattr $C$DW$1253, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1253, DW_AT_decl_line(0x208)
.dwattr $C$DW$1253, DW_AT_decl_column(0x05)
$C$DW$1254 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTI_INVALID_ARG_NUMBER"), DW_AT_const_value(0x100001)
.dwattr $C$DW$1254, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1254, DW_AT_decl_line(0x209)
.dwattr $C$DW$1254, DW_AT_decl_column(0x05)
$C$DW$1255 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTI_TABLE_OF_CONTENTS_OVERFLOW"), DW_AT_const_value(0x100002)
.dwattr $C$DW$1255, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1255, DW_AT_decl_line(0x20a)
.dwattr $C$DW$1255, DW_AT_decl_column(0x05)
$C$DW$1256 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTI_CORE_NOT_ZERO"), DW_AT_const_value(0x100003)
.dwattr $C$DW$1256, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1256, DW_AT_decl_line(0x20b)
.dwattr $C$DW$1256, DW_AT_decl_column(0x05)
$C$DW$1257 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTI_INVALID_PARAMS"), DW_AT_const_value(0x100004)
.dwattr $C$DW$1257, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1257, DW_AT_decl_line(0x20c)
.dwattr $C$DW$1257, DW_AT_decl_column(0x02)
$C$DW$1258 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTILS_EXCEEDED_MAX_TASK_JOIN"), DW_AT_const_value(0x110000)
.dwattr $C$DW$1258, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1258, DW_AT_decl_line(0x20e)
.dwattr $C$DW$1258, DW_AT_decl_column(0x05)
$C$DW$1259 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTILS_INVALID_CORE0_ADDRESS"), DW_AT_const_value(0x110001)
.dwattr $C$DW$1259, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1259, DW_AT_decl_line(0x20f)
.dwattr $C$DW$1259, DW_AT_decl_column(0x05)
$C$DW$1260 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_INVALID_ARGC_ARGV"), DW_AT_const_value(0x120000)
.dwattr $C$DW$1260, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1260, DW_AT_decl_line(0x214)
.dwattr $C$DW$1260, DW_AT_decl_column(0x05)
$C$DW$1261 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_INIT_SUPPORT_MODULE_FAIL"), DW_AT_const_value(0x120001)
.dwattr $C$DW$1261, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1261, DW_AT_decl_line(0x215)
.dwattr $C$DW$1261, DW_AT_decl_column(0x05)
$C$DW$1262 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_INVALID_PARAM"), DW_AT_const_value(0x120002)
.dwattr $C$DW$1262, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1262, DW_AT_decl_line(0x216)
.dwattr $C$DW$1262, DW_AT_decl_column(0x02)
$C$DW$1263 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_AUTO_GAIN_FAIL"), DW_AT_const_value(0x120003)
.dwattr $C$DW$1263, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1263, DW_AT_decl_line(0x217)
.dwattr $C$DW$1263, DW_AT_decl_column(0x05)
$C$DW$1264 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_AMM_FAIL"), DW_AT_const_value(0x120004)
.dwattr $C$DW$1264, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1264, DW_AT_decl_line(0x218)
.dwattr $C$DW$1264, DW_AT_decl_column(0x05)
$C$DW$1265 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_ASSERT_EQUAL"), DW_AT_const_value(0x120005)
.dwattr $C$DW$1265, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1265, DW_AT_decl_line(0x219)
.dwattr $C$DW$1265, DW_AT_decl_column(0x02)
$C$DW$1266 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_ASSERT_TRUE"), DW_AT_const_value(0x120006)
.dwattr $C$DW$1266, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1266, DW_AT_decl_line(0x21a)
.dwattr $C$DW$1266, DW_AT_decl_column(0x02)
$C$DW$1267 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_INVALI_CYCLE_COUNT_PARM"), DW_AT_const_value(0x120007)
.dwattr $C$DW$1267, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1267, DW_AT_decl_line(0x21b)
.dwattr $C$DW$1267, DW_AT_decl_column(0x02)
$C$DW$1268 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COUNTER_EXTENDER"), DW_AT_const_value(0x130000)
.dwattr $C$DW$1268, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1268, DW_AT_decl_line(0x21d)
.dwattr $C$DW$1268, DW_AT_decl_column(0x02)
$C$DW$1269 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COUNTER_EXTENDER_INVALID_BW"), DW_AT_const_value(0x130001)
.dwattr $C$DW$1269, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1269, DW_AT_decl_line(0x21e)
.dwattr $C$DW$1269, DW_AT_decl_column(0x02)
$C$DW$1270 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COUNTER_EXTENDER_INVALID_COUNTER_VAL"), DW_AT_const_value(0x130002)
.dwattr $C$DW$1270, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1270, DW_AT_decl_line(0x21f)
.dwattr $C$DW$1270, DW_AT_decl_column(0x02)
$C$DW$1271 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_URATIONAL"), DW_AT_const_value(0x140000)
.dwattr $C$DW$1271, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1271, DW_AT_decl_line(0x221)
.dwattr $C$DW$1271, DW_AT_decl_column(0x05)
$C$DW$1272 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_URATIONAL_TRIGGER_OVERFLOW"), DW_AT_const_value(0x140001)
.dwattr $C$DW$1272, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$1272, DW_AT_decl_line(0x222)
.dwattr $C$DW$1272, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$2203
.dwattr $C$DW$T$2203, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$T$2203, DW_AT_decl_line(0x23)
.dwattr $C$DW$T$2203, DW_AT_decl_column(0x01)
$C$DW$T$2204 .dwtag DW_TAG_typedef, DW_AT_name("ErrorType")
.dwattr $C$DW$T$2204, DW_AT_type(*$C$DW$T$2203)
.dwattr $C$DW$T$2204, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2204, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h")
.dwattr $C$DW$T$2204, DW_AT_decl_line(0x224)
.dwattr $C$DW$T$2204, DW_AT_decl_column(0x03)
$C$DW$T$149 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$149, DW_AT_name("FOVBase_Param")
.dwattr $C$DW$T$149, DW_AT_byte_size(0x88)
$C$DW$1273 .dwtag DW_TAG_member
.dwattr $C$DW$1273, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1273, DW_AT_name("frameIntervalNumClocks48MHz")
.dwattr $C$DW$1273, DW_AT_TI_symbol_name("frameIntervalNumClocks48MHz")
.dwattr $C$DW$1273, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1273, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1273, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1273, DW_AT_decl_line(0x571)
.dwattr $C$DW$1273, DW_AT_decl_column(0x05)
$C$DW$1274 .dwtag DW_TAG_member
.dwattr $C$DW$1274, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1274, DW_AT_name("reserved")
.dwattr $C$DW$1274, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1274, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1274, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1274, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1274, DW_AT_decl_line(0x572)
.dwattr $C$DW$1274, DW_AT_decl_column(0x05)
$C$DW$32 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$32, DW_AT_declaration
.dwattr $C$DW$32, DW_AT_TI_symbol_name("_ZN13FOVBase_ParamaSERKS_")
.dwattr $C$DW$32, DW_AT_type(*$C$DW$T$145)
.dwattr $C$DW$32, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1275 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1275, DW_AT_type(*$C$DW$T$147)
.dwendtag $C$DW$32
.dwendtag $C$DW$T$149
.dwattr $C$DW$T$149, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$149, DW_AT_decl_line(0x570)
.dwattr $C$DW$T$149, DW_AT_decl_column(0x01)
$C$DW$T$146 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$146, DW_AT_type(*$C$DW$T$149)
$C$DW$T$147 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$147, DW_AT_type(*$C$DW$T$146)
.dwattr $C$DW$T$147, DW_AT_address_class(0x20)
$C$DW$T$1595 .dwtag DW_TAG_typedef, DW_AT_name("FOVBase_Param")
.dwattr $C$DW$T$1595, DW_AT_type(*$C$DW$T$149)
.dwattr $C$DW$T$1595, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1595, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1595, DW_AT_decl_line(0x573)
.dwattr $C$DW$T$1595, DW_AT_decl_column(0x03)
$C$DW$T$145 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$145, DW_AT_type(*$C$DW$T$149)
.dwattr $C$DW$T$145, DW_AT_address_class(0x20)
$C$DW$T$148 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$148, DW_AT_type(*$C$DW$T$145)
.dwattr $C$DW$T$148, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1276 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1276, DW_AT_type(*$C$DW$T$147)
.dwendtag $C$DW$T$148
$C$DW$T$989 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$989, DW_AT_name("FilterParam")
.dwattr $C$DW$T$989, DW_AT_byte_size(0x88)
$C$DW$1277 .dwtag DW_TAG_member
.dwattr $C$DW$1277, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1277, DW_AT_name("maskh")
.dwattr $C$DW$1277, DW_AT_TI_symbol_name("maskh")
.dwattr $C$DW$1277, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1277, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1277, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1277, DW_AT_decl_line(0x66)
.dwattr $C$DW$1277, DW_AT_decl_column(0x08)
$C$DW$1278 .dwtag DW_TAG_member
.dwattr $C$DW$1278, DW_AT_type(*$C$DW$T$984)
.dwattr $C$DW$1278, DW_AT_name("coef")
.dwattr $C$DW$1278, DW_AT_TI_symbol_name("coef")
.dwattr $C$DW$1278, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1278, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1278, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1278, DW_AT_decl_line(0x67)
.dwattr $C$DW$1278, DW_AT_decl_column(0x08)
$C$DW$1279 .dwtag DW_TAG_member
.dwattr $C$DW$1279, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1279, DW_AT_name("accuracyBits")
.dwattr $C$DW$1279, DW_AT_TI_symbol_name("accuracyBits")
.dwattr $C$DW$1279, DW_AT_data_member_location[DW_OP_plus_uconst 0x84]
.dwattr $C$DW$1279, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1279, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1279, DW_AT_decl_line(0x68)
.dwattr $C$DW$1279, DW_AT_decl_column(0x08)
$C$DW$33 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$33, DW_AT_declaration
.dwattr $C$DW$33, DW_AT_TI_symbol_name("_ZN11FilterParamaSERKS_")
.dwattr $C$DW$33, DW_AT_type(*$C$DW$T$985)
.dwattr $C$DW$33, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1280 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1280, DW_AT_type(*$C$DW$T$987)
.dwendtag $C$DW$33
.dwendtag $C$DW$T$989
.dwattr $C$DW$T$989, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$T$989, DW_AT_decl_line(0x64)
.dwattr $C$DW$T$989, DW_AT_decl_column(0x08)
$C$DW$T$986 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$986, DW_AT_type(*$C$DW$T$989)
$C$DW$T$987 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$987, DW_AT_type(*$C$DW$T$986)
.dwattr $C$DW$T$987, DW_AT_address_class(0x20)
$C$DW$T$418 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$418, DW_AT_type(*$C$DW$T$989)
.dwattr $C$DW$T$418, DW_AT_address_class(0x20)
$C$DW$T$985 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$985, DW_AT_type(*$C$DW$T$989)
.dwattr $C$DW$T$985, DW_AT_address_class(0x20)
$C$DW$T$988 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$988, DW_AT_type(*$C$DW$T$985)
.dwattr $C$DW$T$988, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1281 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1281, DW_AT_type(*$C$DW$T$987)
.dwendtag $C$DW$T$988
$C$DW$T$1197 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1197, DW_AT_type(*$C$DW$T$989)
.dwattr $C$DW$T$1197, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1197, DW_AT_byte_size(0x2a8)
$C$DW$1282 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$1282, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1197
$C$DW$T$274 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$274, DW_AT_name("ImageDirectionFilter")
.dwattr $C$DW$T$274, DW_AT_byte_size(0x78)
$C$DW$1283 .dwtag DW_TAG_member
.dwattr $C$DW$1283, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1283, DW_AT_name("radius")
.dwattr $C$DW$1283, DW_AT_TI_symbol_name("radius")
.dwattr $C$DW$1283, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1283, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1283, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1283, DW_AT_decl_line(0x7f)
.dwattr $C$DW$1283, DW_AT_decl_column(0x07)
$C$DW$1284 .dwtag DW_TAG_member
.dwattr $C$DW$1284, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1284, DW_AT_name("sigma")
.dwattr $C$DW$1284, DW_AT_TI_symbol_name("sigma")
.dwattr $C$DW$1284, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1284, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1284, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1284, DW_AT_decl_line(0x80)
.dwattr $C$DW$1284, DW_AT_decl_column(0x08)
$C$DW$1285 .dwtag DW_TAG_member
.dwattr $C$DW$1285, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1285, DW_AT_name("amp")
.dwattr $C$DW$1285, DW_AT_TI_symbol_name("amp")
.dwattr $C$DW$1285, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1285, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1285, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1285, DW_AT_decl_line(0x81)
.dwattr $C$DW$1285, DW_AT_decl_column(0x08)
$C$DW$1286 .dwtag DW_TAG_member
.dwattr $C$DW$1286, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1286, DW_AT_name("base")
.dwattr $C$DW$1286, DW_AT_TI_symbol_name("base")
.dwattr $C$DW$1286, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c]
.dwattr $C$DW$1286, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1286, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1286, DW_AT_decl_line(0x82)
.dwattr $C$DW$1286, DW_AT_decl_column(0x08)
$C$DW$1287 .dwtag DW_TAG_member
.dwattr $C$DW$1287, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1287, DW_AT_name("val")
.dwattr $C$DW$1287, DW_AT_TI_symbol_name("val")
.dwattr $C$DW$1287, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$1287, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1287, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1287, DW_AT_decl_line(0x83)
.dwattr $C$DW$1287, DW_AT_decl_column(0x08)
$C$DW$1288 .dwtag DW_TAG_member
.dwattr $C$DW$1288, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1288, DW_AT_name("anisoMaskH")
.dwattr $C$DW$1288, DW_AT_TI_symbol_name("anisoMaskH")
.dwattr $C$DW$1288, DW_AT_data_member_location[DW_OP_plus_uconst 0x64]
.dwattr $C$DW$1288, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1288, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1288, DW_AT_decl_line(0x84)
.dwattr $C$DW$1288, DW_AT_decl_column(0x07)
$C$DW$34 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$34, DW_AT_declaration
.dwattr $C$DW$34, DW_AT_TI_symbol_name("_ZN13XtNamApiParam20ImageDirectionFilteraSERKS0_")
.dwattr $C$DW$34, DW_AT_type(*$C$DW$T$270)
.dwattr $C$DW$34, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1289 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1289, DW_AT_type(*$C$DW$T$272)
.dwendtag $C$DW$34
.dwendtag $C$DW$T$274
.dwattr $C$DW$T$274, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$T$274, DW_AT_decl_line(0x7d)
.dwattr $C$DW$T$274, DW_AT_decl_column(0x08)
$C$DW$T$271 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$271, DW_AT_type(*$C$DW$T$274)
$C$DW$T$272 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$272, DW_AT_type(*$C$DW$T$271)
.dwattr $C$DW$T$272, DW_AT_address_class(0x20)
$C$DW$T$270 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$270, DW_AT_type(*$C$DW$T$274)
.dwattr $C$DW$T$270, DW_AT_address_class(0x20)
$C$DW$T$273 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$273, DW_AT_type(*$C$DW$T$270)
.dwattr $C$DW$T$273, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1290 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1290, DW_AT_type(*$C$DW$T$272)
.dwendtag $C$DW$T$273
$C$DW$T$1053 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1053, DW_AT_name("ImageDirectionFilter")
.dwattr $C$DW$T$1053, DW_AT_byte_size(0xf8)
$C$DW$1291 .dwtag DW_TAG_member
.dwattr $C$DW$1291, DW_AT_type(*$C$DW$T$1047)
.dwattr $C$DW$1291, DW_AT_name("radius")
.dwattr $C$DW$1291, DW_AT_TI_symbol_name("radius")
.dwattr $C$DW$1291, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1291, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1291, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1291, DW_AT_decl_line(0x347)
.dwattr $C$DW$1291, DW_AT_decl_column(0x05)
$C$DW$1292 .dwtag DW_TAG_member
.dwattr $C$DW$1292, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1292, DW_AT_name("sigma")
.dwattr $C$DW$1292, DW_AT_TI_symbol_name("sigma")
.dwattr $C$DW$1292, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1292, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1292, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1292, DW_AT_decl_line(0x348)
.dwattr $C$DW$1292, DW_AT_decl_column(0x05)
$C$DW$1293 .dwtag DW_TAG_member
.dwattr $C$DW$1293, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1293, DW_AT_name("amp")
.dwattr $C$DW$1293, DW_AT_TI_symbol_name("amp")
.dwattr $C$DW$1293, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1293, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1293, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1293, DW_AT_decl_line(0x349)
.dwattr $C$DW$1293, DW_AT_decl_column(0x05)
$C$DW$1294 .dwtag DW_TAG_member
.dwattr $C$DW$1294, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1294, DW_AT_name("base")
.dwattr $C$DW$1294, DW_AT_TI_symbol_name("base")
.dwattr $C$DW$1294, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$1294, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1294, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1294, DW_AT_decl_line(0x34a)
.dwattr $C$DW$1294, DW_AT_decl_column(0x05)
$C$DW$1295 .dwtag DW_TAG_member
.dwattr $C$DW$1295, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1295, DW_AT_name("val")
.dwattr $C$DW$1295, DW_AT_TI_symbol_name("val")
.dwattr $C$DW$1295, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$1295, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1295, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1295, DW_AT_decl_line(0x34b)
.dwattr $C$DW$1295, DW_AT_decl_column(0x05)
$C$DW$1296 .dwtag DW_TAG_member
.dwattr $C$DW$1296, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1296, DW_AT_name("reserved")
.dwattr $C$DW$1296, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1296, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$1296, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1296, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1296, DW_AT_decl_line(0x34c)
.dwattr $C$DW$1296, DW_AT_decl_column(0x05)
$C$DW$35 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$35, DW_AT_declaration
.dwattr $C$DW$35, DW_AT_TI_symbol_name("_ZN20ImageDirectionFilteraSERKS_")
.dwattr $C$DW$35, DW_AT_type(*$C$DW$T$1049)
.dwattr $C$DW$35, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1297 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1297, DW_AT_type(*$C$DW$T$1051)
.dwendtag $C$DW$35
.dwendtag $C$DW$T$1053
.dwattr $C$DW$T$1053, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1053, DW_AT_decl_line(0x346)
.dwattr $C$DW$T$1053, DW_AT_decl_column(0x10)
$C$DW$T$202 .dwtag DW_TAG_typedef, DW_AT_name("ImageDirectionFilter")
.dwattr $C$DW$T$202, DW_AT_type(*$C$DW$T$1053)
.dwattr $C$DW$T$202, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$202, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$202, DW_AT_decl_line(0x34d)
.dwattr $C$DW$T$202, DW_AT_decl_column(0x03)
$C$DW$T$1050 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1050, DW_AT_type(*$C$DW$T$1053)
$C$DW$T$1051 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1051, DW_AT_type(*$C$DW$T$1050)
.dwattr $C$DW$T$1051, DW_AT_address_class(0x20)
$C$DW$T$1049 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1049, DW_AT_type(*$C$DW$T$1053)
.dwattr $C$DW$T$1049, DW_AT_address_class(0x20)
$C$DW$T$1052 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1052, DW_AT_type(*$C$DW$T$1049)
.dwattr $C$DW$T$1052, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1298 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1298, DW_AT_type(*$C$DW$T$1051)
.dwendtag $C$DW$T$1052
$C$DW$T$237 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$237, DW_AT_name("ImageDummy")
.dwattr $C$DW$T$237, DW_AT_byte_size(0x78)
$C$DW$1299 .dwtag DW_TAG_member
.dwattr $C$DW$1299, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1299, DW_AT_name("edgeRelFilH")
.dwattr $C$DW$1299, DW_AT_TI_symbol_name("edgeRelFilH")
.dwattr $C$DW$1299, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1299, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1299, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1299, DW_AT_decl_line(0xa4)
.dwattr $C$DW$1299, DW_AT_decl_column(0x07)
$C$DW$1300 .dwtag DW_TAG_member
.dwattr $C$DW$1300, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1300, DW_AT_name("edgeRelFilS")
.dwattr $C$DW$1300, DW_AT_TI_symbol_name("edgeRelFilS")
.dwattr $C$DW$1300, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1300, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1300, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1300, DW_AT_decl_line(0xa5)
.dwattr $C$DW$1300, DW_AT_decl_column(0x08)
$C$DW$1301 .dwtag DW_TAG_member
.dwattr $C$DW$1301, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1301, DW_AT_name("nepWghtM")
.dwattr $C$DW$1301, DW_AT_TI_symbol_name("nepWghtM")
.dwattr $C$DW$1301, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1301, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1301, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1301, DW_AT_decl_line(0xa6)
.dwattr $C$DW$1301, DW_AT_decl_column(0x07)
$C$DW$1302 .dwtag DW_TAG_member
.dwattr $C$DW$1302, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1302, DW_AT_name("nepWghtS")
.dwattr $C$DW$1302, DW_AT_TI_symbol_name("nepWghtS")
.dwattr $C$DW$1302, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c]
.dwattr $C$DW$1302, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1302, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1302, DW_AT_decl_line(0xa7)
.dwattr $C$DW$1302, DW_AT_decl_column(0x07)
$C$DW$1303 .dwtag DW_TAG_member
.dwattr $C$DW$1303, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1303, DW_AT_name("reserveInt")
.dwattr $C$DW$1303, DW_AT_TI_symbol_name("reserveInt")
.dwattr $C$DW$1303, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$1303, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1303, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1303, DW_AT_decl_line(0xa8)
.dwattr $C$DW$1303, DW_AT_decl_column(0x0a)
$C$DW$1304 .dwtag DW_TAG_member
.dwattr $C$DW$1304, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1304, DW_AT_name("reserveFloat")
.dwattr $C$DW$1304, DW_AT_TI_symbol_name("reserveFloat")
.dwattr $C$DW$1304, DW_AT_data_member_location[DW_OP_plus_uconst 0x64]
.dwattr $C$DW$1304, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1304, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1304, DW_AT_decl_line(0xa9)
.dwattr $C$DW$1304, DW_AT_decl_column(0x0a)
$C$DW$36 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$36, DW_AT_declaration
.dwattr $C$DW$36, DW_AT_TI_symbol_name("_ZN13XtNamApiParam10ImageDummyaSERKS0_")
.dwattr $C$DW$36, DW_AT_type(*$C$DW$T$233)
.dwattr $C$DW$36, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1305 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1305, DW_AT_type(*$C$DW$T$235)
.dwendtag $C$DW$36
.dwendtag $C$DW$T$237
.dwattr $C$DW$T$237, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$T$237, DW_AT_decl_line(0xa2)
.dwattr $C$DW$T$237, DW_AT_decl_column(0x08)
$C$DW$T$234 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$234, DW_AT_type(*$C$DW$T$237)
$C$DW$T$235 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$235, DW_AT_type(*$C$DW$T$234)
.dwattr $C$DW$T$235, DW_AT_address_class(0x20)
$C$DW$T$233 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$233, DW_AT_type(*$C$DW$T$237)
.dwattr $C$DW$T$233, DW_AT_address_class(0x20)
$C$DW$T$236 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$236, DW_AT_type(*$C$DW$T$233)
.dwattr $C$DW$T$236, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1306 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1306, DW_AT_type(*$C$DW$T$235)
.dwendtag $C$DW$T$236
$C$DW$T$1058 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1058, DW_AT_name("ImageDummy")
.dwattr $C$DW$T$1058, DW_AT_byte_size(0x60)
$C$DW$1307 .dwtag DW_TAG_member
.dwattr $C$DW$1307, DW_AT_type(*$C$DW$T$1047)
.dwattr $C$DW$1307, DW_AT_name("debug1")
.dwattr $C$DW$1307, DW_AT_TI_symbol_name("debug1")
.dwattr $C$DW$1307, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1307, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1307, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1307, DW_AT_decl_line(0x377)
.dwattr $C$DW$1307, DW_AT_decl_column(0x05)
$C$DW$1308 .dwtag DW_TAG_member
.dwattr $C$DW$1308, DW_AT_type(*$C$DW$T$1047)
.dwattr $C$DW$1308, DW_AT_name("debug2")
.dwattr $C$DW$1308, DW_AT_TI_symbol_name("debug2")
.dwattr $C$DW$1308, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1308, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1308, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1308, DW_AT_decl_line(0x378)
.dwattr $C$DW$1308, DW_AT_decl_column(0x05)
$C$DW$1309 .dwtag DW_TAG_member
.dwattr $C$DW$1309, DW_AT_type(*$C$DW$T$1047)
.dwattr $C$DW$1309, DW_AT_name("reserveInt")
.dwattr $C$DW$1309, DW_AT_TI_symbol_name("reserveInt")
.dwattr $C$DW$1309, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1309, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1309, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1309, DW_AT_decl_line(0x379)
.dwattr $C$DW$1309, DW_AT_decl_column(0x05)
$C$DW$1310 .dwtag DW_TAG_member
.dwattr $C$DW$1310, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1310, DW_AT_name("reserveFloat")
.dwattr $C$DW$1310, DW_AT_TI_symbol_name("reserveFloat")
.dwattr $C$DW$1310, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$1310, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1310, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1310, DW_AT_decl_line(0x37a)
.dwattr $C$DW$1310, DW_AT_decl_column(0x05)
$C$DW$37 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$37, DW_AT_declaration
.dwattr $C$DW$37, DW_AT_TI_symbol_name("_ZN10ImageDummyaSERKS_")
.dwattr $C$DW$37, DW_AT_type(*$C$DW$T$1054)
.dwattr $C$DW$37, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1311 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1311, DW_AT_type(*$C$DW$T$1056)
.dwendtag $C$DW$37
.dwendtag $C$DW$T$1058
.dwattr $C$DW$T$1058, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1058, DW_AT_decl_line(0x376)
.dwattr $C$DW$T$1058, DW_AT_decl_column(0x10)
$C$DW$T$207 .dwtag DW_TAG_typedef, DW_AT_name("ImageDummy")
.dwattr $C$DW$T$207, DW_AT_type(*$C$DW$T$1058)
.dwattr $C$DW$T$207, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$207, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$207, DW_AT_decl_line(0x37b)
.dwattr $C$DW$T$207, DW_AT_decl_column(0x03)
$C$DW$T$1055 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1055, DW_AT_type(*$C$DW$T$1058)
$C$DW$T$1056 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1056, DW_AT_type(*$C$DW$T$1055)
.dwattr $C$DW$T$1056, DW_AT_address_class(0x20)
$C$DW$T$1054 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1054, DW_AT_type(*$C$DW$T$1058)
.dwattr $C$DW$T$1054, DW_AT_address_class(0x20)
$C$DW$T$1057 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1057, DW_AT_type(*$C$DW$T$1054)
.dwattr $C$DW$T$1057, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1312 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1312, DW_AT_type(*$C$DW$T$1056)
.dwendtag $C$DW$T$1057
$C$DW$T$1064 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1064, DW_AT_name("ImageEdgeDetection")
.dwattr $C$DW$T$1064, DW_AT_byte_size(0x118)
$C$DW$1313 .dwtag DW_TAG_member
.dwattr $C$DW$1313, DW_AT_type(*$C$DW$T$1059)
.dwattr $C$DW$1313, DW_AT_name("rankCoef")
.dwattr $C$DW$1313, DW_AT_TI_symbol_name("rankCoef")
.dwattr $C$DW$1313, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1313, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1313, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1313, DW_AT_decl_line(0x323)
.dwattr $C$DW$1313, DW_AT_decl_column(0x05)
$C$DW$1314 .dwtag DW_TAG_member
.dwattr $C$DW$1314, DW_AT_type(*$C$DW$T$1047)
.dwattr $C$DW$1314, DW_AT_name("engTblNum")
.dwattr $C$DW$1314, DW_AT_TI_symbol_name("engTblNum")
.dwattr $C$DW$1314, DW_AT_data_member_location[DW_OP_plus_uconst 0x68]
.dwattr $C$DW$1314, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1314, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1314, DW_AT_decl_line(0x324)
.dwattr $C$DW$1314, DW_AT_decl_column(0x05)
$C$DW$1315 .dwtag DW_TAG_member
.dwattr $C$DW$1315, DW_AT_type(*$C$DW$T$1047)
.dwattr $C$DW$1315, DW_AT_name("engTblAccuracy")
.dwattr $C$DW$1315, DW_AT_TI_symbol_name("engTblAccuracy")
.dwattr $C$DW$1315, DW_AT_data_member_location[DW_OP_plus_uconst 0x80]
.dwattr $C$DW$1315, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1315, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1315, DW_AT_decl_line(0x325)
.dwattr $C$DW$1315, DW_AT_decl_column(0x05)
$C$DW$1316 .dwtag DW_TAG_member
.dwattr $C$DW$1316, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1316, DW_AT_name("reserved")
.dwattr $C$DW$1316, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1316, DW_AT_data_member_location[DW_OP_plus_uconst 0x98]
.dwattr $C$DW$1316, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1316, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1316, DW_AT_decl_line(0x326)
.dwattr $C$DW$1316, DW_AT_decl_column(0x05)
$C$DW$38 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$38, DW_AT_declaration
.dwattr $C$DW$38, DW_AT_TI_symbol_name("_ZN18ImageEdgeDetectionaSERKS_")
.dwattr $C$DW$38, DW_AT_type(*$C$DW$T$1060)
.dwattr $C$DW$38, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1317 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1317, DW_AT_type(*$C$DW$T$1062)
.dwendtag $C$DW$38
.dwendtag $C$DW$T$1064
.dwattr $C$DW$T$1064, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1064, DW_AT_decl_line(0x322)
.dwattr $C$DW$T$1064, DW_AT_decl_column(0x10)
$C$DW$T$198 .dwtag DW_TAG_typedef, DW_AT_name("ImageEdgeDetection")
.dwattr $C$DW$T$198, DW_AT_type(*$C$DW$T$1064)
.dwattr $C$DW$T$198, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$198, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$198, DW_AT_decl_line(0x327)
.dwattr $C$DW$T$198, DW_AT_decl_column(0x03)
$C$DW$T$1061 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1061, DW_AT_type(*$C$DW$T$1064)
$C$DW$T$1062 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1062, DW_AT_type(*$C$DW$T$1061)
.dwattr $C$DW$T$1062, DW_AT_address_class(0x20)
$C$DW$T$1060 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1060, DW_AT_type(*$C$DW$T$1064)
.dwattr $C$DW$T$1060, DW_AT_address_class(0x20)
$C$DW$T$1063 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1063, DW_AT_type(*$C$DW$T$1060)
.dwattr $C$DW$T$1063, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1318 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1318, DW_AT_type(*$C$DW$T$1062)
.dwendtag $C$DW$T$1063
$C$DW$T$1071 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1071, DW_AT_name("ImageEdgeDir")
.dwattr $C$DW$T$1071, DW_AT_byte_size(0x64)
$C$DW$1319 .dwtag DW_TAG_member
.dwattr $C$DW$1319, DW_AT_type(*$C$DW$T$1066)
.dwattr $C$DW$1319, DW_AT_name("ups")
.dwattr $C$DW$1319, DW_AT_TI_symbol_name("ups")
.dwattr $C$DW$1319, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1319, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1319, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1319, DW_AT_decl_line(0x8b)
.dwattr $C$DW$1319, DW_AT_decl_column(0x0d)
$C$DW$39 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$39, DW_AT_declaration
.dwattr $C$DW$39, DW_AT_TI_symbol_name("_ZN12ImageEdgeDiraSERKS_")
.dwattr $C$DW$39, DW_AT_type(*$C$DW$T$1067)
.dwattr $C$DW$39, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1320 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1320, DW_AT_type(*$C$DW$T$1069)
.dwendtag $C$DW$39
.dwendtag $C$DW$T$1071
.dwattr $C$DW$T$1071, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$T$1071, DW_AT_decl_line(0x89)
.dwattr $C$DW$T$1071, DW_AT_decl_column(0x08)
$C$DW$T$1068 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1068, DW_AT_type(*$C$DW$T$1071)
$C$DW$T$1069 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1069, DW_AT_type(*$C$DW$T$1068)
.dwattr $C$DW$T$1069, DW_AT_address_class(0x20)
$C$DW$T$1067 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1067, DW_AT_type(*$C$DW$T$1071)
.dwattr $C$DW$T$1067, DW_AT_address_class(0x20)
$C$DW$T$1070 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1070, DW_AT_type(*$C$DW$T$1067)
.dwattr $C$DW$T$1070, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1321 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1321, DW_AT_type(*$C$DW$T$1069)
.dwendtag $C$DW$T$1070
$C$DW$T$279 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$279, DW_AT_name("ImageEdgeReliability")
.dwattr $C$DW$T$279, DW_AT_byte_size(0x14)
$C$DW$1322 .dwtag DW_TAG_member
.dwattr $C$DW$1322, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1322, DW_AT_name("filRadius")
.dwattr $C$DW$1322, DW_AT_TI_symbol_name("filRadius")
.dwattr $C$DW$1322, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1322, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1322, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1322, DW_AT_decl_line(0x66)
.dwattr $C$DW$1322, DW_AT_decl_column(0x07)
$C$DW$40 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$40, DW_AT_declaration
.dwattr $C$DW$40, DW_AT_TI_symbol_name("_ZN13XtNamApiParam20ImageEdgeReliabilityaSERKS0_")
.dwattr $C$DW$40, DW_AT_type(*$C$DW$T$275)
.dwattr $C$DW$40, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1323 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1323, DW_AT_type(*$C$DW$T$277)
.dwendtag $C$DW$40
.dwendtag $C$DW$T$279
.dwattr $C$DW$T$279, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$T$279, DW_AT_decl_line(0x64)
.dwattr $C$DW$T$279, DW_AT_decl_column(0x08)
$C$DW$T$276 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$276, DW_AT_type(*$C$DW$T$279)
$C$DW$T$277 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$277, DW_AT_type(*$C$DW$T$276)
.dwattr $C$DW$T$277, DW_AT_address_class(0x20)
$C$DW$T$275 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$275, DW_AT_type(*$C$DW$T$279)
.dwattr $C$DW$T$275, DW_AT_address_class(0x20)
$C$DW$T$278 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$278, DW_AT_type(*$C$DW$T$275)
.dwattr $C$DW$T$278, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1324 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1324, DW_AT_type(*$C$DW$T$277)
.dwendtag $C$DW$T$278
$C$DW$T$1076 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1076, DW_AT_name("ImageEdgeReliability")
.dwattr $C$DW$T$1076, DW_AT_byte_size(0xb0)
$C$DW$1325 .dwtag DW_TAG_member
.dwattr $C$DW$1325, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1325, DW_AT_name("relDrBottom")
.dwattr $C$DW$1325, DW_AT_TI_symbol_name("relDrBottom")
.dwattr $C$DW$1325, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1325, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1325, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1325, DW_AT_decl_line(0x333)
.dwattr $C$DW$1325, DW_AT_decl_column(0x05)
$C$DW$1326 .dwtag DW_TAG_member
.dwattr $C$DW$1326, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1326, DW_AT_name("relDrTop")
.dwattr $C$DW$1326, DW_AT_TI_symbol_name("relDrTop")
.dwattr $C$DW$1326, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1326, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1326, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1326, DW_AT_decl_line(0x334)
.dwattr $C$DW$1326, DW_AT_decl_column(0x05)
$C$DW$1327 .dwtag DW_TAG_member
.dwattr $C$DW$1327, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1327, DW_AT_name("reserved")
.dwattr $C$DW$1327, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1327, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1327, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1327, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1327, DW_AT_decl_line(0x335)
.dwattr $C$DW$1327, DW_AT_decl_column(0x05)
$C$DW$41 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$41, DW_AT_declaration
.dwattr $C$DW$41, DW_AT_TI_symbol_name("_ZN20ImageEdgeReliabilityaSERKS_")
.dwattr $C$DW$41, DW_AT_type(*$C$DW$T$1072)
.dwattr $C$DW$41, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1328 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1328, DW_AT_type(*$C$DW$T$1074)
.dwendtag $C$DW$41
.dwendtag $C$DW$T$1076
.dwattr $C$DW$T$1076, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1076, DW_AT_decl_line(0x332)
.dwattr $C$DW$T$1076, DW_AT_decl_column(0x10)
$C$DW$T$200 .dwtag DW_TAG_typedef, DW_AT_name("ImageEdgeReliability")
.dwattr $C$DW$T$200, DW_AT_type(*$C$DW$T$1076)
.dwattr $C$DW$T$200, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$200, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$200, DW_AT_decl_line(0x336)
.dwattr $C$DW$T$200, DW_AT_decl_column(0x03)
$C$DW$T$1073 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1073, DW_AT_type(*$C$DW$T$1076)
$C$DW$T$1074 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1074, DW_AT_type(*$C$DW$T$1073)
.dwattr $C$DW$T$1074, DW_AT_address_class(0x20)
$C$DW$T$1072 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1072, DW_AT_type(*$C$DW$T$1076)
.dwattr $C$DW$T$1072, DW_AT_address_class(0x20)
$C$DW$T$1075 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1075, DW_AT_type(*$C$DW$T$1072)
.dwattr $C$DW$T$1075, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1329 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1329, DW_AT_type(*$C$DW$T$1074)
.dwendtag $C$DW$T$1075
$C$DW$T$264 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$264, DW_AT_name("ImageEgdeDetection")
.dwattr $C$DW$T$264, DW_AT_byte_size(0xe4)
$C$DW$1330 .dwtag DW_TAG_member
.dwattr $C$DW$1330, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1330, DW_AT_name("dilationRadius")
.dwattr $C$DW$1330, DW_AT_TI_symbol_name("dilationRadius")
.dwattr $C$DW$1330, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1330, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1330, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1330, DW_AT_decl_line(0x46)
.dwattr $C$DW$1330, DW_AT_decl_column(0x09)
$C$DW$1331 .dwtag DW_TAG_member
.dwattr $C$DW$1331, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1331, DW_AT_name("erosionRadius")
.dwattr $C$DW$1331, DW_AT_TI_symbol_name("erosionRadius")
.dwattr $C$DW$1331, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1331, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1331, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1331, DW_AT_decl_line(0x47)
.dwattr $C$DW$1331, DW_AT_decl_column(0x09)
$C$DW$1332 .dwtag DW_TAG_member
.dwattr $C$DW$1332, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1332, DW_AT_name("crrgbBase")
.dwattr $C$DW$1332, DW_AT_TI_symbol_name("crrgbBase")
.dwattr $C$DW$1332, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1332, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1332, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1332, DW_AT_decl_line(0x48)
.dwattr $C$DW$1332, DW_AT_decl_column(0x08)
$C$DW$1333 .dwtag DW_TAG_member
.dwattr $C$DW$1333, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1333, DW_AT_name("crrgbM")
.dwattr $C$DW$1333, DW_AT_TI_symbol_name("crrgbM")
.dwattr $C$DW$1333, DW_AT_data_member_location[DW_OP_plus_uconst 0x2c]
.dwattr $C$DW$1333, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1333, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1333, DW_AT_decl_line(0x49)
.dwattr $C$DW$1333, DW_AT_decl_column(0x09)
$C$DW$1334 .dwtag DW_TAG_member
.dwattr $C$DW$1334, DW_AT_type(*$C$DW$T$259)
.dwattr $C$DW$1334, DW_AT_name("rankCoef")
.dwattr $C$DW$1334, DW_AT_TI_symbol_name("rankCoef")
.dwattr $C$DW$1334, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1334, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1334, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1334, DW_AT_decl_line(0x4a)
.dwattr $C$DW$1334, DW_AT_decl_column(0x09)
$C$DW$1335 .dwtag DW_TAG_member
.dwattr $C$DW$1335, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1335, DW_AT_name("smoothRadius")
.dwattr $C$DW$1335, DW_AT_TI_symbol_name("smoothRadius")
.dwattr $C$DW$1335, DW_AT_data_member_location[DW_OP_plus_uconst 0x94]
.dwattr $C$DW$1335, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1335, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1335, DW_AT_decl_line(0x4c)
.dwattr $C$DW$1335, DW_AT_decl_column(0x08)
$C$DW$1336 .dwtag DW_TAG_member
.dwattr $C$DW$1336, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1336, DW_AT_name("smoothSigma")
.dwattr $C$DW$1336, DW_AT_TI_symbol_name("smoothSigma")
.dwattr $C$DW$1336, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8]
.dwattr $C$DW$1336, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1336, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1336, DW_AT_decl_line(0x4d)
.dwattr $C$DW$1336, DW_AT_decl_column(0x09)
$C$DW$1337 .dwtag DW_TAG_member
.dwattr $C$DW$1337, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1337, DW_AT_name("engTblNum")
.dwattr $C$DW$1337, DW_AT_TI_symbol_name("engTblNum")
.dwattr $C$DW$1337, DW_AT_data_member_location[DW_OP_plus_uconst 0xbc]
.dwattr $C$DW$1337, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1337, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1337, DW_AT_decl_line(0x4f)
.dwattr $C$DW$1337, DW_AT_decl_column(0x08)
$C$DW$1338 .dwtag DW_TAG_member
.dwattr $C$DW$1338, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1338, DW_AT_name("engTblAccuracy")
.dwattr $C$DW$1338, DW_AT_TI_symbol_name("engTblAccuracy")
.dwattr $C$DW$1338, DW_AT_data_member_location[DW_OP_plus_uconst 0xd0]
.dwattr $C$DW$1338, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1338, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1338, DW_AT_decl_line(0x50)
.dwattr $C$DW$1338, DW_AT_decl_column(0x08)
$C$DW$42 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$42, DW_AT_declaration
.dwattr $C$DW$42, DW_AT_TI_symbol_name("_ZN13XtNamApiParam18ImageEgdeDetectionaSERKS0_")
.dwattr $C$DW$42, DW_AT_type(*$C$DW$T$260)
.dwattr $C$DW$42, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1339 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1339, DW_AT_type(*$C$DW$T$262)
.dwendtag $C$DW$42
.dwendtag $C$DW$T$264
.dwattr $C$DW$T$264, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$T$264, DW_AT_decl_line(0x44)
.dwattr $C$DW$T$264, DW_AT_decl_column(0x08)
$C$DW$T$261 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$261, DW_AT_type(*$C$DW$T$264)
$C$DW$T$262 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$262, DW_AT_type(*$C$DW$T$261)
.dwattr $C$DW$T$262, DW_AT_address_class(0x20)
$C$DW$T$385 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$385, DW_AT_type(*$C$DW$T$261)
.dwattr $C$DW$T$385, DW_AT_address_class(0x20)
$C$DW$T$260 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$260, DW_AT_type(*$C$DW$T$264)
.dwattr $C$DW$T$260, DW_AT_address_class(0x20)
$C$DW$T$263 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$263, DW_AT_type(*$C$DW$T$260)
.dwattr $C$DW$T$263, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1340 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1340, DW_AT_type(*$C$DW$T$262)
.dwendtag $C$DW$T$263
$C$DW$T$269 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$269, DW_AT_name("ImageEgdeDirection")
.dwattr $C$DW$T$269, DW_AT_byte_size(0xa0)
$C$DW$1341 .dwtag DW_TAG_member
.dwattr $C$DW$1341, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1341, DW_AT_name("aveFilRadius")
.dwattr $C$DW$1341, DW_AT_TI_symbol_name("aveFilRadius")
.dwattr $C$DW$1341, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1341, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1341, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1341, DW_AT_decl_line(0x59)
.dwattr $C$DW$1341, DW_AT_decl_column(0x07)
$C$DW$1342 .dwtag DW_TAG_member
.dwattr $C$DW$1342, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1342, DW_AT_name("aveFilSigma")
.dwattr $C$DW$1342, DW_AT_TI_symbol_name("aveFilSigma")
.dwattr $C$DW$1342, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1342, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1342, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1342, DW_AT_decl_line(0x5a)
.dwattr $C$DW$1342, DW_AT_decl_column(0x08)
$C$DW$1343 .dwtag DW_TAG_member
.dwattr $C$DW$1343, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1343, DW_AT_name("aveW")
.dwattr $C$DW$1343, DW_AT_TI_symbol_name("aveW")
.dwattr $C$DW$1343, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1343, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1343, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1343, DW_AT_decl_line(0x5b)
.dwattr $C$DW$1343, DW_AT_decl_column(0x09)
$C$DW$1344 .dwtag DW_TAG_member
.dwattr $C$DW$1344, DW_AT_type(*$C$DW$T$259)
.dwattr $C$DW$1344, DW_AT_name("rankCoef")
.dwattr $C$DW$1344, DW_AT_TI_symbol_name("rankCoef")
.dwattr $C$DW$1344, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c]
.dwattr $C$DW$1344, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1344, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1344, DW_AT_decl_line(0x5c)
.dwattr $C$DW$1344, DW_AT_decl_column(0x08)
$C$DW$43 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$43, DW_AT_declaration
.dwattr $C$DW$43, DW_AT_TI_symbol_name("_ZN13XtNamApiParam18ImageEgdeDirectionaSERKS0_")
.dwattr $C$DW$43, DW_AT_type(*$C$DW$T$265)
.dwattr $C$DW$43, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1345 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1345, DW_AT_type(*$C$DW$T$267)
.dwendtag $C$DW$43
.dwendtag $C$DW$T$269
.dwattr $C$DW$T$269, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$T$269, DW_AT_decl_line(0x57)
.dwattr $C$DW$T$269, DW_AT_decl_column(0x08)
$C$DW$T$266 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$266, DW_AT_type(*$C$DW$T$269)
$C$DW$T$267 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$267, DW_AT_type(*$C$DW$T$266)
.dwattr $C$DW$T$267, DW_AT_address_class(0x20)
$C$DW$T$384 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$384, DW_AT_type(*$C$DW$T$266)
.dwattr $C$DW$T$384, DW_AT_address_class(0x20)
$C$DW$T$265 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$265, DW_AT_type(*$C$DW$T$269)
.dwattr $C$DW$T$265, DW_AT_address_class(0x20)
$C$DW$T$268 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$268, DW_AT_type(*$C$DW$T$265)
.dwattr $C$DW$T$268, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1346 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1346, DW_AT_type(*$C$DW$T$267)
.dwendtag $C$DW$T$268
$C$DW$T$1081 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1081, DW_AT_name("ImageEgdeDirection")
.dwattr $C$DW$T$1081, DW_AT_byte_size(0x118)
$C$DW$1347 .dwtag DW_TAG_member
.dwattr $C$DW$1347, DW_AT_type(*$C$DW$T$1047)
.dwattr $C$DW$1347, DW_AT_name("aveFilRadius")
.dwattr $C$DW$1347, DW_AT_TI_symbol_name("aveFilRadius")
.dwattr $C$DW$1347, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1347, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1347, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1347, DW_AT_decl_line(0x32b)
.dwattr $C$DW$1347, DW_AT_decl_column(0x05)
$C$DW$1348 .dwtag DW_TAG_member
.dwattr $C$DW$1348, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1348, DW_AT_name("aveFilSigma")
.dwattr $C$DW$1348, DW_AT_TI_symbol_name("aveFilSigma")
.dwattr $C$DW$1348, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1348, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1348, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1348, DW_AT_decl_line(0x32c)
.dwattr $C$DW$1348, DW_AT_decl_column(0x05)
$C$DW$1349 .dwtag DW_TAG_member
.dwattr $C$DW$1349, DW_AT_type(*$C$DW$T$1059)
.dwattr $C$DW$1349, DW_AT_name("rankCoef")
.dwattr $C$DW$1349, DW_AT_TI_symbol_name("rankCoef")
.dwattr $C$DW$1349, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1349, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1349, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1349, DW_AT_decl_line(0x32d)
.dwattr $C$DW$1349, DW_AT_decl_column(0x05)
$C$DW$1350 .dwtag DW_TAG_member
.dwattr $C$DW$1350, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1350, DW_AT_name("reserved")
.dwattr $C$DW$1350, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1350, DW_AT_data_member_location[DW_OP_plus_uconst 0x98]
.dwattr $C$DW$1350, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1350, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1350, DW_AT_decl_line(0x32e)
.dwattr $C$DW$1350, DW_AT_decl_column(0x05)
$C$DW$44 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$44, DW_AT_declaration
.dwattr $C$DW$44, DW_AT_TI_symbol_name("_ZN18ImageEgdeDirectionaSERKS_")
.dwattr $C$DW$44, DW_AT_type(*$C$DW$T$1077)
.dwattr $C$DW$44, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1351 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1351, DW_AT_type(*$C$DW$T$1079)
.dwendtag $C$DW$44
.dwendtag $C$DW$T$1081
.dwattr $C$DW$T$1081, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1081, DW_AT_decl_line(0x32a)
.dwattr $C$DW$T$1081, DW_AT_decl_column(0x10)
$C$DW$T$199 .dwtag DW_TAG_typedef, DW_AT_name("ImageEgdeDirection")
.dwattr $C$DW$T$199, DW_AT_type(*$C$DW$T$1081)
.dwattr $C$DW$T$199, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$199, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$199, DW_AT_decl_line(0x32f)
.dwattr $C$DW$T$199, DW_AT_decl_column(0x03)
$C$DW$T$1078 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1078, DW_AT_type(*$C$DW$T$1081)
$C$DW$T$1079 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1079, DW_AT_type(*$C$DW$T$1078)
.dwattr $C$DW$T$1079, DW_AT_address_class(0x20)
$C$DW$T$1077 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1077, DW_AT_type(*$C$DW$T$1081)
.dwattr $C$DW$T$1077, DW_AT_address_class(0x20)
$C$DW$T$1080 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1080, DW_AT_type(*$C$DW$T$1077)
.dwattr $C$DW$T$1080, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1352 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1352, DW_AT_type(*$C$DW$T$1079)
.dwendtag $C$DW$T$1080
$C$DW$T$242 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$242, DW_AT_name("ImageEmphasis")
.dwattr $C$DW$T$242, DW_AT_byte_size(0xa0)
$C$DW$1353 .dwtag DW_TAG_member
.dwattr $C$DW$1353, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1353, DW_AT_name("mulW")
.dwattr $C$DW$1353, DW_AT_TI_symbol_name("mulW")
.dwattr $C$DW$1353, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1353, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1353, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1353, DW_AT_decl_line(0x6f)
.dwattr $C$DW$1353, DW_AT_decl_column(0x08)
$C$DW$1354 .dwtag DW_TAG_member
.dwattr $C$DW$1354, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1354, DW_AT_name("thW")
.dwattr $C$DW$1354, DW_AT_TI_symbol_name("thW")
.dwattr $C$DW$1354, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1354, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1354, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1354, DW_AT_decl_line(0x70)
.dwattr $C$DW$1354, DW_AT_decl_column(0x07)
$C$DW$1355 .dwtag DW_TAG_member
.dwattr $C$DW$1355, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1355, DW_AT_name("cW")
.dwattr $C$DW$1355, DW_AT_TI_symbol_name("cW")
.dwattr $C$DW$1355, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1355, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1355, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1355, DW_AT_decl_line(0x71)
.dwattr $C$DW$1355, DW_AT_decl_column(0x08)
$C$DW$1356 .dwtag DW_TAG_member
.dwattr $C$DW$1356, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1356, DW_AT_name("bW")
.dwattr $C$DW$1356, DW_AT_TI_symbol_name("bW")
.dwattr $C$DW$1356, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c]
.dwattr $C$DW$1356, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1356, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1356, DW_AT_decl_line(0x72)
.dwattr $C$DW$1356, DW_AT_decl_column(0x08)
$C$DW$1357 .dwtag DW_TAG_member
.dwattr $C$DW$1357, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1357, DW_AT_name("mulB")
.dwattr $C$DW$1357, DW_AT_TI_symbol_name("mulB")
.dwattr $C$DW$1357, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$1357, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1357, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1357, DW_AT_decl_line(0x73)
.dwattr $C$DW$1357, DW_AT_decl_column(0x08)
$C$DW$1358 .dwtag DW_TAG_member
.dwattr $C$DW$1358, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1358, DW_AT_name("thB")
.dwattr $C$DW$1358, DW_AT_TI_symbol_name("thB")
.dwattr $C$DW$1358, DW_AT_data_member_location[DW_OP_plus_uconst 0x64]
.dwattr $C$DW$1358, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1358, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1358, DW_AT_decl_line(0x74)
.dwattr $C$DW$1358, DW_AT_decl_column(0x07)
$C$DW$1359 .dwtag DW_TAG_member
.dwattr $C$DW$1359, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1359, DW_AT_name("cB")
.dwattr $C$DW$1359, DW_AT_TI_symbol_name("cB")
.dwattr $C$DW$1359, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$1359, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1359, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1359, DW_AT_decl_line(0x75)
.dwattr $C$DW$1359, DW_AT_decl_column(0x08)
$C$DW$1360 .dwtag DW_TAG_member
.dwattr $C$DW$1360, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1360, DW_AT_name("bB")
.dwattr $C$DW$1360, DW_AT_TI_symbol_name("bB")
.dwattr $C$DW$1360, DW_AT_data_member_location[DW_OP_plus_uconst 0x8c]
.dwattr $C$DW$1360, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1360, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1360, DW_AT_decl_line(0x76)
.dwattr $C$DW$1360, DW_AT_decl_column(0x08)
$C$DW$45 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$45, DW_AT_declaration
.dwattr $C$DW$45, DW_AT_TI_symbol_name("_ZN13XtNamApiParam13ImageEmphasisaSERKS0_")
.dwattr $C$DW$45, DW_AT_type(*$C$DW$T$238)
.dwattr $C$DW$45, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1361 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1361, DW_AT_type(*$C$DW$T$240)
.dwendtag $C$DW$45
.dwendtag $C$DW$T$242
.dwattr $C$DW$T$242, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$T$242, DW_AT_decl_line(0x6d)
.dwattr $C$DW$T$242, DW_AT_decl_column(0x08)
$C$DW$T$239 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$239, DW_AT_type(*$C$DW$T$242)
$C$DW$T$240 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$240, DW_AT_type(*$C$DW$T$239)
.dwattr $C$DW$T$240, DW_AT_address_class(0x20)
$C$DW$T$238 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$238, DW_AT_type(*$C$DW$T$242)
.dwattr $C$DW$T$238, DW_AT_address_class(0x20)
$C$DW$T$241 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$241, DW_AT_type(*$C$DW$T$238)
.dwattr $C$DW$T$241, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1362 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1362, DW_AT_type(*$C$DW$T$240)
.dwendtag $C$DW$T$241
$C$DW$T$1086 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1086, DW_AT_name("ImageEmphasis")
.dwattr $C$DW$T$1086, DW_AT_byte_size(0x140)
$C$DW$1363 .dwtag DW_TAG_member
.dwattr $C$DW$1363, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1363, DW_AT_name("mulW")
.dwattr $C$DW$1363, DW_AT_TI_symbol_name("mulW")
.dwattr $C$DW$1363, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1363, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1363, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1363, DW_AT_decl_line(0x33a)
.dwattr $C$DW$1363, DW_AT_decl_column(0x05)
$C$DW$1364 .dwtag DW_TAG_member
.dwattr $C$DW$1364, DW_AT_type(*$C$DW$T$1047)
.dwattr $C$DW$1364, DW_AT_name("thW")
.dwattr $C$DW$1364, DW_AT_TI_symbol_name("thW")
.dwattr $C$DW$1364, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1364, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1364, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1364, DW_AT_decl_line(0x33b)
.dwattr $C$DW$1364, DW_AT_decl_column(0x05)
$C$DW$1365 .dwtag DW_TAG_member
.dwattr $C$DW$1365, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1365, DW_AT_name("cW")
.dwattr $C$DW$1365, DW_AT_TI_symbol_name("cW")
.dwattr $C$DW$1365, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1365, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1365, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1365, DW_AT_decl_line(0x33c)
.dwattr $C$DW$1365, DW_AT_decl_column(0x05)
$C$DW$1366 .dwtag DW_TAG_member
.dwattr $C$DW$1366, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1366, DW_AT_name("bW")
.dwattr $C$DW$1366, DW_AT_TI_symbol_name("bW")
.dwattr $C$DW$1366, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$1366, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1366, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1366, DW_AT_decl_line(0x33d)
.dwattr $C$DW$1366, DW_AT_decl_column(0x05)
$C$DW$1367 .dwtag DW_TAG_member
.dwattr $C$DW$1367, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1367, DW_AT_name("mulB")
.dwattr $C$DW$1367, DW_AT_TI_symbol_name("mulB")
.dwattr $C$DW$1367, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$1367, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1367, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1367, DW_AT_decl_line(0x33e)
.dwattr $C$DW$1367, DW_AT_decl_column(0x05)
$C$DW$1368 .dwtag DW_TAG_member
.dwattr $C$DW$1368, DW_AT_type(*$C$DW$T$1047)
.dwattr $C$DW$1368, DW_AT_name("thB")
.dwattr $C$DW$1368, DW_AT_TI_symbol_name("thB")
.dwattr $C$DW$1368, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$1368, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1368, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1368, DW_AT_decl_line(0x33f)
.dwattr $C$DW$1368, DW_AT_decl_column(0x05)
$C$DW$1369 .dwtag DW_TAG_member
.dwattr $C$DW$1369, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1369, DW_AT_name("cB")
.dwattr $C$DW$1369, DW_AT_TI_symbol_name("cB")
.dwattr $C$DW$1369, DW_AT_data_member_location[DW_OP_plus_uconst 0x90]
.dwattr $C$DW$1369, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1369, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1369, DW_AT_decl_line(0x340)
.dwattr $C$DW$1369, DW_AT_decl_column(0x05)
$C$DW$1370 .dwtag DW_TAG_member
.dwattr $C$DW$1370, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1370, DW_AT_name("bB")
.dwattr $C$DW$1370, DW_AT_TI_symbol_name("bB")
.dwattr $C$DW$1370, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8]
.dwattr $C$DW$1370, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1370, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1370, DW_AT_decl_line(0x341)
.dwattr $C$DW$1370, DW_AT_decl_column(0x05)
$C$DW$1371 .dwtag DW_TAG_member
.dwattr $C$DW$1371, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1371, DW_AT_name("reserved")
.dwattr $C$DW$1371, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1371, DW_AT_data_member_location[DW_OP_plus_uconst 0xc0]
.dwattr $C$DW$1371, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1371, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1371, DW_AT_decl_line(0x342)
.dwattr $C$DW$1371, DW_AT_decl_column(0x05)
$C$DW$46 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$46, DW_AT_declaration
.dwattr $C$DW$46, DW_AT_TI_symbol_name("_ZN13ImageEmphasisaSERKS_")
.dwattr $C$DW$46, DW_AT_type(*$C$DW$T$1082)
.dwattr $C$DW$46, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1372 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1372, DW_AT_type(*$C$DW$T$1084)
.dwendtag $C$DW$46
.dwendtag $C$DW$T$1086
.dwattr $C$DW$T$1086, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1086, DW_AT_decl_line(0x339)
.dwattr $C$DW$T$1086, DW_AT_decl_column(0x10)
$C$DW$T$201 .dwtag DW_TAG_typedef, DW_AT_name("ImageEmphasis")
.dwattr $C$DW$T$201, DW_AT_type(*$C$DW$T$1086)
.dwattr $C$DW$T$201, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$201, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$201, DW_AT_decl_line(0x343)
.dwattr $C$DW$T$201, DW_AT_decl_column(0x03)
$C$DW$T$1083 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1083, DW_AT_type(*$C$DW$T$1086)
$C$DW$T$1084 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1084, DW_AT_type(*$C$DW$T$1083)
.dwattr $C$DW$T$1084, DW_AT_address_class(0x20)
$C$DW$T$1082 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1082, DW_AT_type(*$C$DW$T$1086)
.dwattr $C$DW$T$1082, DW_AT_address_class(0x20)
$C$DW$T$1085 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1085, DW_AT_type(*$C$DW$T$1082)
.dwattr $C$DW$T$1085, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1373 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1373, DW_AT_type(*$C$DW$T$1084)
.dwendtag $C$DW$T$1085
$C$DW$T$1093 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1093, DW_AT_name("ImageFTC")
.dwattr $C$DW$T$1093, DW_AT_byte_size(0xb0)
$C$DW$1374 .dwtag DW_TAG_member
.dwattr $C$DW$1374, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1374, DW_AT_name("mode")
.dwattr $C$DW$1374, DW_AT_TI_symbol_name("mode")
.dwattr $C$DW$1374, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1374, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1374, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1374, DW_AT_decl_line(0x363)
.dwattr $C$DW$1374, DW_AT_decl_column(0x05)
$C$DW$1375 .dwtag DW_TAG_member
.dwattr $C$DW$1375, DW_AT_type(*$C$DW$T$1087)
.dwattr $C$DW$1375, DW_AT_name("radius")
.dwattr $C$DW$1375, DW_AT_TI_symbol_name("radius")
.dwattr $C$DW$1375, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1375, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1375, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1375, DW_AT_decl_line(0x364)
.dwattr $C$DW$1375, DW_AT_decl_column(0x05)
$C$DW$1376 .dwtag DW_TAG_member
.dwattr $C$DW$1376, DW_AT_type(*$C$DW$T$1087)
.dwattr $C$DW$1376, DW_AT_name("intBottom")
.dwattr $C$DW$1376, DW_AT_TI_symbol_name("intBottom")
.dwattr $C$DW$1376, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1376, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1376, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1376, DW_AT_decl_line(0x365)
.dwattr $C$DW$1376, DW_AT_decl_column(0x05)
$C$DW$1377 .dwtag DW_TAG_member
.dwattr $C$DW$1377, DW_AT_type(*$C$DW$T$1087)
.dwattr $C$DW$1377, DW_AT_name("intTop")
.dwattr $C$DW$1377, DW_AT_TI_symbol_name("intTop")
.dwattr $C$DW$1377, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1377, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1377, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1377, DW_AT_decl_line(0x366)
.dwattr $C$DW$1377, DW_AT_decl_column(0x05)
$C$DW$1378 .dwtag DW_TAG_member
.dwattr $C$DW$1378, DW_AT_type(*$C$DW$T$1088)
.dwattr $C$DW$1378, DW_AT_name("coefBottom")
.dwattr $C$DW$1378, DW_AT_TI_symbol_name("coefBottom")
.dwattr $C$DW$1378, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1378, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1378, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1378, DW_AT_decl_line(0x367)
.dwattr $C$DW$1378, DW_AT_decl_column(0x05)
$C$DW$1379 .dwtag DW_TAG_member
.dwattr $C$DW$1379, DW_AT_type(*$C$DW$T$1088)
.dwattr $C$DW$1379, DW_AT_name("coefTop")
.dwattr $C$DW$1379, DW_AT_TI_symbol_name("coefTop")
.dwattr $C$DW$1379, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1379, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1379, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1379, DW_AT_decl_line(0x368)
.dwattr $C$DW$1379, DW_AT_decl_column(0x05)
$C$DW$1380 .dwtag DW_TAG_member
.dwattr $C$DW$1380, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1380, DW_AT_name("reserved")
.dwattr $C$DW$1380, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1380, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1380, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1380, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1380, DW_AT_decl_line(0x369)
.dwattr $C$DW$1380, DW_AT_decl_column(0x05)
$C$DW$47 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$47, DW_AT_declaration
.dwattr $C$DW$47, DW_AT_TI_symbol_name("_ZN8ImageFTCaSERKS_")
.dwattr $C$DW$47, DW_AT_type(*$C$DW$T$1089)
.dwattr $C$DW$47, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1381 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1381, DW_AT_type(*$C$DW$T$1091)
.dwendtag $C$DW$47
.dwendtag $C$DW$T$1093
.dwattr $C$DW$T$1093, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1093, DW_AT_decl_line(0x362)
.dwattr $C$DW$T$1093, DW_AT_decl_column(0x10)
$C$DW$T$205 .dwtag DW_TAG_typedef, DW_AT_name("ImageFTC")
.dwattr $C$DW$T$205, DW_AT_type(*$C$DW$T$1093)
.dwattr $C$DW$T$205, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$205, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$205, DW_AT_decl_line(0x36a)
.dwattr $C$DW$T$205, DW_AT_decl_column(0x03)
$C$DW$T$1090 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1090, DW_AT_type(*$C$DW$T$1093)
$C$DW$T$1091 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1091, DW_AT_type(*$C$DW$T$1090)
.dwattr $C$DW$T$1091, DW_AT_address_class(0x20)
$C$DW$T$1089 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1089, DW_AT_type(*$C$DW$T$1093)
.dwattr $C$DW$T$1089, DW_AT_address_class(0x20)
$C$DW$T$1092 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1092, DW_AT_type(*$C$DW$T$1089)
.dwattr $C$DW$T$1092, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1382 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1382, DW_AT_type(*$C$DW$T$1091)
.dwendtag $C$DW$T$1092
$C$DW$T$290 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$290, DW_AT_name("ImageFill")
.dwattr $C$DW$T$290, DW_AT_byte_size(0x80)
$C$DW$1383 .dwtag DW_TAG_member
.dwattr $C$DW$1383, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1383, DW_AT_name("patternNwM")
.dwattr $C$DW$1383, DW_AT_TI_symbol_name("patternNwM")
.dwattr $C$DW$1383, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1383, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1383, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1383, DW_AT_decl_line(0x29)
.dwattr $C$DW$1383, DW_AT_decl_column(0x08)
$C$DW$1384 .dwtag DW_TAG_member
.dwattr $C$DW$1384, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1384, DW_AT_name("patternNwS")
.dwattr $C$DW$1384, DW_AT_TI_symbol_name("patternNwS")
.dwattr $C$DW$1384, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1384, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1384, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1384, DW_AT_decl_line(0x2a)
.dwattr $C$DW$1384, DW_AT_decl_column(0x08)
$C$DW$1385 .dwtag DW_TAG_member
.dwattr $C$DW$1385, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1385, DW_AT_name("ptMaskH")
.dwattr $C$DW$1385, DW_AT_TI_symbol_name("ptMaskH")
.dwattr $C$DW$1385, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1385, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1385, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1385, DW_AT_decl_line(0x2b)
.dwattr $C$DW$1385, DW_AT_decl_column(0x08)
$C$DW$1386 .dwtag DW_TAG_member
.dwattr $C$DW$1386, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1386, DW_AT_name("ptMaskW")
.dwattr $C$DW$1386, DW_AT_TI_symbol_name("ptMaskW")
.dwattr $C$DW$1386, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1386, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1386, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1386, DW_AT_decl_line(0x2c)
.dwattr $C$DW$1386, DW_AT_decl_column(0x08)
$C$DW$1387 .dwtag DW_TAG_member
.dwattr $C$DW$1387, DW_AT_type(*$C$DW$T$285)
.dwattr $C$DW$1387, DW_AT_name("ptMask")
.dwattr $C$DW$1387, DW_AT_TI_symbol_name("ptMask")
.dwattr $C$DW$1387, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1387, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1387, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1387, DW_AT_decl_line(0x2d)
.dwattr $C$DW$1387, DW_AT_decl_column(0x09)
$C$DW$1388 .dwtag DW_TAG_member
.dwattr $C$DW$1388, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1388, DW_AT_name("patternWeight")
.dwattr $C$DW$1388, DW_AT_TI_symbol_name("patternWeight")
.dwattr $C$DW$1388, DW_AT_data_member_location[DW_OP_plus_uconst 0x74]
.dwattr $C$DW$1388, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1388, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1388, DW_AT_decl_line(0x2f)
.dwattr $C$DW$1388, DW_AT_decl_column(0x09)
$C$DW$1389 .dwtag DW_TAG_member
.dwattr $C$DW$1389, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1389, DW_AT_name("ptBackBase")
.dwattr $C$DW$1389, DW_AT_TI_symbol_name("ptBackBase")
.dwattr $C$DW$1389, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$1389, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1389, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1389, DW_AT_decl_line(0x30)
.dwattr $C$DW$1389, DW_AT_decl_column(0x08)
$C$DW$1390 .dwtag DW_TAG_member
.dwattr $C$DW$1390, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1390, DW_AT_name("ptBackM")
.dwattr $C$DW$1390, DW_AT_TI_symbol_name("ptBackM")
.dwattr $C$DW$1390, DW_AT_data_member_location[DW_OP_plus_uconst 0x7c]
.dwattr $C$DW$1390, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1390, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1390, DW_AT_decl_line(0x31)
.dwattr $C$DW$1390, DW_AT_decl_column(0x09)
$C$DW$48 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$48, DW_AT_declaration
.dwattr $C$DW$48, DW_AT_TI_symbol_name("_ZN13XtNamApiParam9ImageFillaSERKS0_")
.dwattr $C$DW$48, DW_AT_type(*$C$DW$T$286)
.dwattr $C$DW$48, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1391 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1391, DW_AT_type(*$C$DW$T$288)
.dwendtag $C$DW$48
.dwendtag $C$DW$T$290
.dwattr $C$DW$T$290, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$T$290, DW_AT_decl_line(0x27)
.dwattr $C$DW$T$290, DW_AT_decl_column(0x08)
$C$DW$T$287 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$287, DW_AT_type(*$C$DW$T$290)
$C$DW$T$288 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$288, DW_AT_type(*$C$DW$T$287)
.dwattr $C$DW$T$288, DW_AT_address_class(0x20)
$C$DW$T$286 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$286, DW_AT_type(*$C$DW$T$290)
.dwattr $C$DW$T$286, DW_AT_address_class(0x20)
$C$DW$T$289 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$289, DW_AT_type(*$C$DW$T$286)
.dwattr $C$DW$T$289, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1392 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1392, DW_AT_type(*$C$DW$T$288)
.dwendtag $C$DW$T$289
$C$DW$T$1099 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1099, DW_AT_name("ImageFill")
.dwattr $C$DW$T$1099, DW_AT_byte_size(0x120)
$C$DW$1393 .dwtag DW_TAG_member
.dwattr $C$DW$1393, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1393, DW_AT_name("patternNwM")
.dwattr $C$DW$1393, DW_AT_TI_symbol_name("patternNwM")
.dwattr $C$DW$1393, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1393, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1393, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1393, DW_AT_decl_line(0x30f)
.dwattr $C$DW$1393, DW_AT_decl_column(0x05)
$C$DW$1394 .dwtag DW_TAG_member
.dwattr $C$DW$1394, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1394, DW_AT_name("patternNwS")
.dwattr $C$DW$1394, DW_AT_TI_symbol_name("patternNwS")
.dwattr $C$DW$1394, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1394, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1394, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1394, DW_AT_decl_line(0x310)
.dwattr $C$DW$1394, DW_AT_decl_column(0x05)
$C$DW$1395 .dwtag DW_TAG_member
.dwattr $C$DW$1395, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1395, DW_AT_name("ptMaskH")
.dwattr $C$DW$1395, DW_AT_TI_symbol_name("ptMaskH")
.dwattr $C$DW$1395, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1395, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1395, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1395, DW_AT_decl_line(0x311)
.dwattr $C$DW$1395, DW_AT_decl_column(0x05)
$C$DW$1396 .dwtag DW_TAG_member
.dwattr $C$DW$1396, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1396, DW_AT_name("ptMaskW")
.dwattr $C$DW$1396, DW_AT_TI_symbol_name("ptMaskW")
.dwattr $C$DW$1396, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1396, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1396, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1396, DW_AT_decl_line(0x312)
.dwattr $C$DW$1396, DW_AT_decl_column(0x05)
$C$DW$1397 .dwtag DW_TAG_member
.dwattr $C$DW$1397, DW_AT_type(*$C$DW$T$1094)
.dwattr $C$DW$1397, DW_AT_name("ptMask")
.dwattr $C$DW$1397, DW_AT_TI_symbol_name("ptMask")
.dwattr $C$DW$1397, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1397, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1397, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1397, DW_AT_decl_line(0x313)
.dwattr $C$DW$1397, DW_AT_decl_column(0x05)
$C$DW$1398 .dwtag DW_TAG_member
.dwattr $C$DW$1398, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1398, DW_AT_name("patternWeight")
.dwattr $C$DW$1398, DW_AT_TI_symbol_name("patternWeight")
.dwattr $C$DW$1398, DW_AT_data_member_location[DW_OP_plus_uconst 0x88]
.dwattr $C$DW$1398, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1398, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1398, DW_AT_decl_line(0x314)
.dwattr $C$DW$1398, DW_AT_decl_column(0x05)
$C$DW$1399 .dwtag DW_TAG_member
.dwattr $C$DW$1399, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1399, DW_AT_name("ptBackBase")
.dwattr $C$DW$1399, DW_AT_TI_symbol_name("ptBackBase")
.dwattr $C$DW$1399, DW_AT_data_member_location[DW_OP_plus_uconst 0x90]
.dwattr $C$DW$1399, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1399, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1399, DW_AT_decl_line(0x315)
.dwattr $C$DW$1399, DW_AT_decl_column(0x05)
$C$DW$1400 .dwtag DW_TAG_member
.dwattr $C$DW$1400, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1400, DW_AT_name("ptBackM")
.dwattr $C$DW$1400, DW_AT_TI_symbol_name("ptBackM")
.dwattr $C$DW$1400, DW_AT_data_member_location[DW_OP_plus_uconst 0x98]
.dwattr $C$DW$1400, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1400, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1400, DW_AT_decl_line(0x316)
.dwattr $C$DW$1400, DW_AT_decl_column(0x05)
$C$DW$1401 .dwtag DW_TAG_member
.dwattr $C$DW$1401, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1401, DW_AT_name("reserved")
.dwattr $C$DW$1401, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1401, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0]
.dwattr $C$DW$1401, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1401, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1401, DW_AT_decl_line(0x317)
.dwattr $C$DW$1401, DW_AT_decl_column(0x05)
$C$DW$49 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$49, DW_AT_declaration
.dwattr $C$DW$49, DW_AT_TI_symbol_name("_ZN9ImageFillaSERKS_")
.dwattr $C$DW$49, DW_AT_type(*$C$DW$T$1095)
.dwattr $C$DW$49, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1402 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1402, DW_AT_type(*$C$DW$T$1097)
.dwendtag $C$DW$49
.dwendtag $C$DW$T$1099
.dwattr $C$DW$T$1099, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1099, DW_AT_decl_line(0x30e)
.dwattr $C$DW$T$1099, DW_AT_decl_column(0x10)
$C$DW$T$196 .dwtag DW_TAG_typedef, DW_AT_name("ImageFill")
.dwattr $C$DW$T$196, DW_AT_type(*$C$DW$T$1099)
.dwattr $C$DW$T$196, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$196, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$196, DW_AT_decl_line(0x318)
.dwattr $C$DW$T$196, DW_AT_decl_column(0x03)
$C$DW$T$1096 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1096, DW_AT_type(*$C$DW$T$1099)
$C$DW$T$1097 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1097, DW_AT_type(*$C$DW$T$1096)
.dwattr $C$DW$T$1097, DW_AT_address_class(0x20)
$C$DW$T$1095 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1095, DW_AT_type(*$C$DW$T$1099)
.dwattr $C$DW$T$1095, DW_AT_address_class(0x20)
$C$DW$T$1098 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1098, DW_AT_type(*$C$DW$T$1095)
.dwattr $C$DW$T$1098, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1403 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1403, DW_AT_type(*$C$DW$T$1097)
.dwendtag $C$DW$T$1098
$C$DW$T$247 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$247, DW_AT_name("ImageGaussian")
.dwattr $C$DW$T$247, DW_AT_byte_size(0x08)
$C$DW$1404 .dwtag DW_TAG_member
.dwattr $C$DW$1404, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1404, DW_AT_name("sigma")
.dwattr $C$DW$1404, DW_AT_TI_symbol_name("sigma")
.dwattr $C$DW$1404, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1404, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1404, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1404, DW_AT_decl_line(0x3b)
.dwattr $C$DW$1404, DW_AT_decl_column(0x08)
$C$DW$1405 .dwtag DW_TAG_member
.dwattr $C$DW$1405, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1405, DW_AT_name("radius")
.dwattr $C$DW$1405, DW_AT_TI_symbol_name("radius")
.dwattr $C$DW$1405, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1405, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1405, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1405, DW_AT_decl_line(0x3c)
.dwattr $C$DW$1405, DW_AT_decl_column(0x07)
$C$DW$50 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$50, DW_AT_declaration
.dwattr $C$DW$50, DW_AT_TI_symbol_name("_ZN13XtNamApiParam13ImageGaussianaSERKS0_")
.dwattr $C$DW$50, DW_AT_type(*$C$DW$T$243)
.dwattr $C$DW$50, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1406 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1406, DW_AT_type(*$C$DW$T$245)
.dwendtag $C$DW$50
.dwendtag $C$DW$T$247
.dwattr $C$DW$T$247, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$T$247, DW_AT_decl_line(0x39)
.dwattr $C$DW$T$247, DW_AT_decl_column(0x08)
$C$DW$T$244 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$244, DW_AT_type(*$C$DW$T$247)
$C$DW$T$245 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$245, DW_AT_type(*$C$DW$T$244)
.dwattr $C$DW$T$245, DW_AT_address_class(0x20)
$C$DW$T$243 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$243, DW_AT_type(*$C$DW$T$247)
.dwattr $C$DW$T$243, DW_AT_address_class(0x20)
$C$DW$T$246 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$246, DW_AT_type(*$C$DW$T$243)
.dwattr $C$DW$T$246, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1407 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1407, DW_AT_type(*$C$DW$T$245)
.dwendtag $C$DW$T$246
$C$DW$T$1104 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1104, DW_AT_name("ImageGaussian")
.dwattr $C$DW$T$1104, DW_AT_byte_size(0x90)
$C$DW$1408 .dwtag DW_TAG_member
.dwattr $C$DW$1408, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1408, DW_AT_name("sigma")
.dwattr $C$DW$1408, DW_AT_TI_symbol_name("sigma")
.dwattr $C$DW$1408, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1408, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1408, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1408, DW_AT_decl_line(0x31c)
.dwattr $C$DW$1408, DW_AT_decl_column(0x05)
$C$DW$1409 .dwtag DW_TAG_member
.dwattr $C$DW$1409, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1409, DW_AT_name("radius")
.dwattr $C$DW$1409, DW_AT_TI_symbol_name("radius")
.dwattr $C$DW$1409, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1409, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1409, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1409, DW_AT_decl_line(0x31d)
.dwattr $C$DW$1409, DW_AT_decl_column(0x05)
$C$DW$1410 .dwtag DW_TAG_member
.dwattr $C$DW$1410, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1410, DW_AT_name("reserved")
.dwattr $C$DW$1410, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1410, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1410, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1410, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1410, DW_AT_decl_line(0x31e)
.dwattr $C$DW$1410, DW_AT_decl_column(0x05)
$C$DW$51 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$51, DW_AT_declaration
.dwattr $C$DW$51, DW_AT_TI_symbol_name("_ZN13ImageGaussianaSERKS_")
.dwattr $C$DW$51, DW_AT_type(*$C$DW$T$1100)
.dwattr $C$DW$51, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1411 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1411, DW_AT_type(*$C$DW$T$1102)
.dwendtag $C$DW$51
.dwendtag $C$DW$T$1104
.dwattr $C$DW$T$1104, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1104, DW_AT_decl_line(0x31b)
.dwattr $C$DW$T$1104, DW_AT_decl_column(0x10)
$C$DW$T$197 .dwtag DW_TAG_typedef, DW_AT_name("ImageGaussian")
.dwattr $C$DW$T$197, DW_AT_type(*$C$DW$T$1104)
.dwattr $C$DW$T$197, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$197, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$197, DW_AT_decl_line(0x31f)
.dwattr $C$DW$T$197, DW_AT_decl_column(0x03)
$C$DW$T$1101 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1101, DW_AT_type(*$C$DW$T$1104)
$C$DW$T$1102 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1102, DW_AT_type(*$C$DW$T$1101)
.dwattr $C$DW$T$1102, DW_AT_address_class(0x20)
$C$DW$T$1100 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1100, DW_AT_type(*$C$DW$T$1104)
.dwattr $C$DW$T$1100, DW_AT_address_class(0x20)
$C$DW$T$1103 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1103, DW_AT_type(*$C$DW$T$1100)
.dwattr $C$DW$T$1103, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1412 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1412, DW_AT_type(*$C$DW$T$1102)
.dwendtag $C$DW$T$1103
$C$DW$T$1109 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1109, DW_AT_name("ImageInfo")
.dwattr $C$DW$T$1109, DW_AT_byte_size(0x18)
$C$DW$1413 .dwtag DW_TAG_member
.dwattr $C$DW$1413, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1413, DW_AT_name("xSize")
.dwattr $C$DW$1413, DW_AT_TI_symbol_name("xSize")
.dwattr $C$DW$1413, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1413, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1413, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1413, DW_AT_decl_line(0x26)
.dwattr $C$DW$1413, DW_AT_decl_column(0x07)
$C$DW$1414 .dwtag DW_TAG_member
.dwattr $C$DW$1414, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1414, DW_AT_name("ySize")
.dwattr $C$DW$1414, DW_AT_TI_symbol_name("ySize")
.dwattr $C$DW$1414, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1414, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1414, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1414, DW_AT_decl_line(0x27)
.dwattr $C$DW$1414, DW_AT_decl_column(0x07)
$C$DW$1415 .dwtag DW_TAG_member
.dwattr $C$DW$1415, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1415, DW_AT_name("scaleBits")
.dwattr $C$DW$1415, DW_AT_TI_symbol_name("scaleBits")
.dwattr $C$DW$1415, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1415, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1415, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1415, DW_AT_decl_line(0x28)
.dwattr $C$DW$1415, DW_AT_decl_column(0x07)
$C$DW$1416 .dwtag DW_TAG_member
.dwattr $C$DW$1416, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1416, DW_AT_name("margin")
.dwattr $C$DW$1416, DW_AT_TI_symbol_name("margin")
.dwattr $C$DW$1416, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1416, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1416, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1416, DW_AT_decl_line(0x29)
.dwattr $C$DW$1416, DW_AT_decl_column(0x07)
$C$DW$1417 .dwtag DW_TAG_member
.dwattr $C$DW$1417, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1417, DW_AT_name("xRotation")
.dwattr $C$DW$1417, DW_AT_TI_symbol_name("xRotation")
.dwattr $C$DW$1417, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1417, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1417, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1417, DW_AT_decl_line(0x2a)
.dwattr $C$DW$1417, DW_AT_decl_column(0x07)
$C$DW$1418 .dwtag DW_TAG_member
.dwattr $C$DW$1418, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1418, DW_AT_name("yRotation")
.dwattr $C$DW$1418, DW_AT_TI_symbol_name("yRotation")
.dwattr $C$DW$1418, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1418, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1418, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1418, DW_AT_decl_line(0x2b)
.dwattr $C$DW$1418, DW_AT_decl_column(0x07)
$C$DW$52 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$52, DW_AT_declaration
.dwattr $C$DW$52, DW_AT_TI_symbol_name("_ZN9ImageInfoaSERKS_")
.dwattr $C$DW$52, DW_AT_type(*$C$DW$T$1105)
.dwattr $C$DW$52, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1419 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1419, DW_AT_type(*$C$DW$T$1107)
.dwendtag $C$DW$52
.dwendtag $C$DW$T$1109
.dwattr $C$DW$T$1109, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$T$1109, DW_AT_decl_line(0x24)
.dwattr $C$DW$T$1109, DW_AT_decl_column(0x08)
$C$DW$T$1106 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1106, DW_AT_type(*$C$DW$T$1109)
$C$DW$T$1107 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1107, DW_AT_type(*$C$DW$T$1106)
.dwattr $C$DW$T$1107, DW_AT_address_class(0x20)
$C$DW$T$1720 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1720, DW_AT_type(*$C$DW$T$1106)
.dwattr $C$DW$T$1720, DW_AT_address_class(0x20)
$C$DW$T$417 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$417, DW_AT_type(*$C$DW$T$1109)
.dwattr $C$DW$T$417, DW_AT_address_class(0x20)
$C$DW$T$1105 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1105, DW_AT_type(*$C$DW$T$1109)
.dwattr $C$DW$T$1105, DW_AT_address_class(0x20)
$C$DW$T$1108 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1108, DW_AT_type(*$C$DW$T$1105)
.dwattr $C$DW$T$1108, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1420 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1420, DW_AT_type(*$C$DW$T$1107)
.dwendtag $C$DW$T$1108
$C$DW$T$1192 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1192, DW_AT_type(*$C$DW$T$1109)
.dwattr $C$DW$T$1192, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1192, DW_AT_byte_size(0x30)
$C$DW$1421 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$1421, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$1192
$C$DW$T$1193 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1193, DW_AT_type(*$C$DW$T$1109)
.dwattr $C$DW$T$1193, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1193, DW_AT_byte_size(0x78)
$C$DW$1422 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$1422, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1193
$C$DW$T$1194 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1194, DW_AT_type(*$C$DW$T$1109)
.dwattr $C$DW$T$1194, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1194, DW_AT_byte_size(0xf0)
$C$DW$1423 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$1423, DW_AT_upper_bound(0x01)
$C$DW$1424 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$1424, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1194
$C$DW$T$1115 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1115, DW_AT_name("ImageLineThin")
.dwattr $C$DW$T$1115, DW_AT_byte_size(0xa0)
$C$DW$1425 .dwtag DW_TAG_member
.dwattr $C$DW$1425, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1425, DW_AT_name("mode")
.dwattr $C$DW$1425, DW_AT_TI_symbol_name("mode")
.dwattr $C$DW$1425, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1425, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1425, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1425, DW_AT_decl_line(0x36e)
.dwattr $C$DW$1425, DW_AT_decl_column(0x05)
$C$DW$1426 .dwtag DW_TAG_member
.dwattr $C$DW$1426, DW_AT_type(*$C$DW$T$1087)
.dwattr $C$DW$1426, DW_AT_name("radius")
.dwattr $C$DW$1426, DW_AT_TI_symbol_name("radius")
.dwattr $C$DW$1426, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1426, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1426, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1426, DW_AT_decl_line(0x36f)
.dwattr $C$DW$1426, DW_AT_decl_column(0x05)
$C$DW$1427 .dwtag DW_TAG_member
.dwattr $C$DW$1427, DW_AT_type(*$C$DW$T$1088)
.dwattr $C$DW$1427, DW_AT_name("coef")
.dwattr $C$DW$1427, DW_AT_TI_symbol_name("coef")
.dwattr $C$DW$1427, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1427, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1427, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1427, DW_AT_decl_line(0x370)
.dwattr $C$DW$1427, DW_AT_decl_column(0x05)
$C$DW$1428 .dwtag DW_TAG_member
.dwattr $C$DW$1428, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1428, DW_AT_name("offset")
.dwattr $C$DW$1428, DW_AT_TI_symbol_name("offset")
.dwattr $C$DW$1428, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1428, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1428, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1428, DW_AT_decl_line(0x371)
.dwattr $C$DW$1428, DW_AT_decl_column(0x05)
$C$DW$1429 .dwtag DW_TAG_member
.dwattr $C$DW$1429, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1429, DW_AT_name("reserved")
.dwattr $C$DW$1429, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1429, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1429, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1429, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1429, DW_AT_decl_line(0x372)
.dwattr $C$DW$1429, DW_AT_decl_column(0x05)
$C$DW$53 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$53, DW_AT_declaration
.dwattr $C$DW$53, DW_AT_TI_symbol_name("_ZN13ImageLineThinaSERKS_")
.dwattr $C$DW$53, DW_AT_type(*$C$DW$T$1111)
.dwattr $C$DW$53, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1430 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1430, DW_AT_type(*$C$DW$T$1113)
.dwendtag $C$DW$53
.dwendtag $C$DW$T$1115
.dwattr $C$DW$T$1115, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1115, DW_AT_decl_line(0x36d)
.dwattr $C$DW$T$1115, DW_AT_decl_column(0x10)
$C$DW$T$206 .dwtag DW_TAG_typedef, DW_AT_name("ImageLineThin")
.dwattr $C$DW$T$206, DW_AT_type(*$C$DW$T$1115)
.dwattr $C$DW$T$206, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$206, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$206, DW_AT_decl_line(0x373)
.dwattr $C$DW$T$206, DW_AT_decl_column(0x03)
$C$DW$T$1112 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1112, DW_AT_type(*$C$DW$T$1115)
$C$DW$T$1113 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1113, DW_AT_type(*$C$DW$T$1112)
.dwattr $C$DW$T$1113, DW_AT_address_class(0x20)
$C$DW$T$1111 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1111, DW_AT_type(*$C$DW$T$1115)
.dwattr $C$DW$T$1111, DW_AT_address_class(0x20)
$C$DW$T$1114 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1114, DW_AT_type(*$C$DW$T$1111)
.dwattr $C$DW$T$1114, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1431 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1431, DW_AT_type(*$C$DW$T$1113)
.dwendtag $C$DW$T$1114
$C$DW$T$284 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$284, DW_AT_name("ImageNEP")
.dwattr $C$DW$T$284, DW_AT_byte_size(0xf0)
$C$DW$1432 .dwtag DW_TAG_member
.dwattr $C$DW$1432, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1432, DW_AT_name("weightM")
.dwattr $C$DW$1432, DW_AT_TI_symbol_name("weightM")
.dwattr $C$DW$1432, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1432, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1432, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1432, DW_AT_decl_line(0x8e)
.dwattr $C$DW$1432, DW_AT_decl_column(0x07)
$C$DW$1433 .dwtag DW_TAG_member
.dwattr $C$DW$1433, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1433, DW_AT_name("weightS")
.dwattr $C$DW$1433, DW_AT_TI_symbol_name("weightS")
.dwattr $C$DW$1433, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1433, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1433, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1433, DW_AT_decl_line(0x8f)
.dwattr $C$DW$1433, DW_AT_decl_column(0x07)
$C$DW$1434 .dwtag DW_TAG_member
.dwattr $C$DW$1434, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1434, DW_AT_name("weightA")
.dwattr $C$DW$1434, DW_AT_TI_symbol_name("weightA")
.dwattr $C$DW$1434, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1434, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1434, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1434, DW_AT_decl_line(0x90)
.dwattr $C$DW$1434, DW_AT_decl_column(0x08)
$C$DW$1435 .dwtag DW_TAG_member
.dwattr $C$DW$1435, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1435, DW_AT_name("weightB")
.dwattr $C$DW$1435, DW_AT_TI_symbol_name("weightB")
.dwattr $C$DW$1435, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c]
.dwattr $C$DW$1435, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1435, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1435, DW_AT_decl_line(0x91)
.dwattr $C$DW$1435, DW_AT_decl_column(0x08)
$C$DW$1436 .dwtag DW_TAG_member
.dwattr $C$DW$1436, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1436, DW_AT_name("alpha")
.dwattr $C$DW$1436, DW_AT_TI_symbol_name("alpha")
.dwattr $C$DW$1436, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$1436, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1436, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1436, DW_AT_decl_line(0x92)
.dwattr $C$DW$1436, DW_AT_decl_column(0x08)
$C$DW$1437 .dwtag DW_TAG_member
.dwattr $C$DW$1437, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1437, DW_AT_name("beta")
.dwattr $C$DW$1437, DW_AT_TI_symbol_name("beta")
.dwattr $C$DW$1437, DW_AT_data_member_location[DW_OP_plus_uconst 0x64]
.dwattr $C$DW$1437, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1437, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1437, DW_AT_decl_line(0x93)
.dwattr $C$DW$1437, DW_AT_decl_column(0x08)
$C$DW$1438 .dwtag DW_TAG_member
.dwattr $C$DW$1438, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1438, DW_AT_name("gamma")
.dwattr $C$DW$1438, DW_AT_TI_symbol_name("gamma")
.dwattr $C$DW$1438, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$1438, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1438, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1438, DW_AT_decl_line(0x94)
.dwattr $C$DW$1438, DW_AT_decl_column(0x08)
$C$DW$1439 .dwtag DW_TAG_member
.dwattr $C$DW$1439, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1439, DW_AT_name("backWM")
.dwattr $C$DW$1439, DW_AT_TI_symbol_name("backWM")
.dwattr $C$DW$1439, DW_AT_data_member_location[DW_OP_plus_uconst 0x8c]
.dwattr $C$DW$1439, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1439, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1439, DW_AT_decl_line(0x96)
.dwattr $C$DW$1439, DW_AT_decl_column(0x07)
$C$DW$1440 .dwtag DW_TAG_member
.dwattr $C$DW$1440, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1440, DW_AT_name("backWS")
.dwattr $C$DW$1440, DW_AT_TI_symbol_name("backWS")
.dwattr $C$DW$1440, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0]
.dwattr $C$DW$1440, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1440, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1440, DW_AT_decl_line(0x97)
.dwattr $C$DW$1440, DW_AT_decl_column(0x07)
$C$DW$1441 .dwtag DW_TAG_member
.dwattr $C$DW$1441, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1441, DW_AT_name("backWA")
.dwattr $C$DW$1441, DW_AT_TI_symbol_name("backWA")
.dwattr $C$DW$1441, DW_AT_data_member_location[DW_OP_plus_uconst 0xb4]
.dwattr $C$DW$1441, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1441, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1441, DW_AT_decl_line(0x98)
.dwattr $C$DW$1441, DW_AT_decl_column(0x08)
$C$DW$1442 .dwtag DW_TAG_member
.dwattr $C$DW$1442, DW_AT_type(*$C$DW$T$232)
.dwattr $C$DW$1442, DW_AT_name("backWB")
.dwattr $C$DW$1442, DW_AT_TI_symbol_name("backWB")
.dwattr $C$DW$1442, DW_AT_data_member_location[DW_OP_plus_uconst 0xc8]
.dwattr $C$DW$1442, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1442, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1442, DW_AT_decl_line(0x99)
.dwattr $C$DW$1442, DW_AT_decl_column(0x08)
$C$DW$1443 .dwtag DW_TAG_member
.dwattr $C$DW$1443, DW_AT_type(*$C$DW$T$231)
.dwattr $C$DW$1443, DW_AT_name("backWT")
.dwattr $C$DW$1443, DW_AT_TI_symbol_name("backWT")
.dwattr $C$DW$1443, DW_AT_data_member_location[DW_OP_plus_uconst 0xdc]
.dwattr $C$DW$1443, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1443, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1443, DW_AT_decl_line(0x9a)
.dwattr $C$DW$1443, DW_AT_decl_column(0x07)
$C$DW$54 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$54, DW_AT_declaration
.dwattr $C$DW$54, DW_AT_TI_symbol_name("_ZN13XtNamApiParam8ImageNEPaSERKS0_")
.dwattr $C$DW$54, DW_AT_type(*$C$DW$T$280)
.dwattr $C$DW$54, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1444 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1444, DW_AT_type(*$C$DW$T$282)
.dwendtag $C$DW$54
.dwendtag $C$DW$T$284
.dwattr $C$DW$T$284, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$T$284, DW_AT_decl_line(0x8c)
.dwattr $C$DW$T$284, DW_AT_decl_column(0x08)
$C$DW$T$281 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$281, DW_AT_type(*$C$DW$T$284)
$C$DW$T$282 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$282, DW_AT_type(*$C$DW$T$281)
.dwattr $C$DW$T$282, DW_AT_address_class(0x20)
$C$DW$T$280 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$280, DW_AT_type(*$C$DW$T$284)
.dwattr $C$DW$T$280, DW_AT_address_class(0x20)
$C$DW$T$283 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$283, DW_AT_type(*$C$DW$T$280)
.dwattr $C$DW$T$283, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1445 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1445, DW_AT_type(*$C$DW$T$282)
.dwendtag $C$DW$T$283
$C$DW$T$1120 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1120, DW_AT_name("ImageNEP")
.dwattr $C$DW$T$1120, DW_AT_byte_size(0x128)
$C$DW$1446 .dwtag DW_TAG_member
.dwattr $C$DW$1446, DW_AT_type(*$C$DW$T$1047)
.dwattr $C$DW$1446, DW_AT_name("weightM")
.dwattr $C$DW$1446, DW_AT_TI_symbol_name("weightM")
.dwattr $C$DW$1446, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1446, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1446, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1446, DW_AT_decl_line(0x351)
.dwattr $C$DW$1446, DW_AT_decl_column(0x05)
$C$DW$1447 .dwtag DW_TAG_member
.dwattr $C$DW$1447, DW_AT_type(*$C$DW$T$1047)
.dwattr $C$DW$1447, DW_AT_name("weightS")
.dwattr $C$DW$1447, DW_AT_TI_symbol_name("weightS")
.dwattr $C$DW$1447, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1447, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1447, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1447, DW_AT_decl_line(0x352)
.dwattr $C$DW$1447, DW_AT_decl_column(0x05)
$C$DW$1448 .dwtag DW_TAG_member
.dwattr $C$DW$1448, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1448, DW_AT_name("weightA")
.dwattr $C$DW$1448, DW_AT_TI_symbol_name("weightA")
.dwattr $C$DW$1448, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1448, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1448, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1448, DW_AT_decl_line(0x353)
.dwattr $C$DW$1448, DW_AT_decl_column(0x05)
$C$DW$1449 .dwtag DW_TAG_member
.dwattr $C$DW$1449, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1449, DW_AT_name("weightB")
.dwattr $C$DW$1449, DW_AT_TI_symbol_name("weightB")
.dwattr $C$DW$1449, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$1449, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1449, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1449, DW_AT_decl_line(0x354)
.dwattr $C$DW$1449, DW_AT_decl_column(0x05)
$C$DW$1450 .dwtag DW_TAG_member
.dwattr $C$DW$1450, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1450, DW_AT_name("alpha")
.dwattr $C$DW$1450, DW_AT_TI_symbol_name("alpha")
.dwattr $C$DW$1450, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$1450, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1450, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1450, DW_AT_decl_line(0x355)
.dwattr $C$DW$1450, DW_AT_decl_column(0x05)
$C$DW$1451 .dwtag DW_TAG_member
.dwattr $C$DW$1451, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1451, DW_AT_name("beta")
.dwattr $C$DW$1451, DW_AT_TI_symbol_name("beta")
.dwattr $C$DW$1451, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$1451, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1451, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1451, DW_AT_decl_line(0x356)
.dwattr $C$DW$1451, DW_AT_decl_column(0x05)
$C$DW$1452 .dwtag DW_TAG_member
.dwattr $C$DW$1452, DW_AT_type(*$C$DW$T$1048)
.dwattr $C$DW$1452, DW_AT_name("gamma")
.dwattr $C$DW$1452, DW_AT_TI_symbol_name("gamma")
.dwattr $C$DW$1452, DW_AT_data_member_location[DW_OP_plus_uconst 0x90]
.dwattr $C$DW$1452, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1452, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1452, DW_AT_decl_line(0x357)
.dwattr $C$DW$1452, DW_AT_decl_column(0x05)
$C$DW$1453 .dwtag DW_TAG_member
.dwattr $C$DW$1453, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1453, DW_AT_name("reserved")
.dwattr $C$DW$1453, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1453, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8]
.dwattr $C$DW$1453, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1453, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1453, DW_AT_decl_line(0x358)
.dwattr $C$DW$1453, DW_AT_decl_column(0x05)
$C$DW$55 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$55, DW_AT_declaration
.dwattr $C$DW$55, DW_AT_TI_symbol_name("_ZN8ImageNEPaSERKS_")
.dwattr $C$DW$55, DW_AT_type(*$C$DW$T$1116)
.dwattr $C$DW$55, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1454 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1454, DW_AT_type(*$C$DW$T$1118)
.dwendtag $C$DW$55
.dwendtag $C$DW$T$1120
.dwattr $C$DW$T$1120, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1120, DW_AT_decl_line(0x350)
.dwattr $C$DW$T$1120, DW_AT_decl_column(0x10)
$C$DW$T$203 .dwtag DW_TAG_typedef, DW_AT_name("ImageNEP")
.dwattr $C$DW$T$203, DW_AT_type(*$C$DW$T$1120)
.dwattr $C$DW$T$203, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$203, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$203, DW_AT_decl_line(0x359)
.dwattr $C$DW$T$203, DW_AT_decl_column(0x03)
$C$DW$T$1117 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1117, DW_AT_type(*$C$DW$T$1120)
$C$DW$T$1118 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1118, DW_AT_type(*$C$DW$T$1117)
.dwattr $C$DW$T$1118, DW_AT_address_class(0x20)
$C$DW$T$1116 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1116, DW_AT_type(*$C$DW$T$1120)
.dwattr $C$DW$T$1116, DW_AT_address_class(0x20)
$C$DW$T$1119 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1119, DW_AT_type(*$C$DW$T$1116)
.dwattr $C$DW$T$1119, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1455 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1455, DW_AT_type(*$C$DW$T$1118)
.dwendtag $C$DW$T$1119
$C$DW$T$253 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$253, DW_AT_name("ImageProcessB")
.dwattr $C$DW$T$253, DW_AT_byte_size(0x644)
$C$DW$1456 .dwtag DW_TAG_member
.dwattr $C$DW$1456, DW_AT_type(*$C$DW$T$248)
.dwattr $C$DW$1456, DW_AT_name("enabled")
.dwattr $C$DW$1456, DW_AT_TI_symbol_name("enabled")
.dwattr $C$DW$1456, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1456, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1456, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1456, DW_AT_decl_line(0x22)
.dwattr $C$DW$1456, DW_AT_decl_column(0x0a)
$C$DW$1457 .dwtag DW_TAG_member
.dwattr $C$DW$1457, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1457, DW_AT_name("gain")
.dwattr $C$DW$1457, DW_AT_TI_symbol_name("gain")
.dwattr $C$DW$1457, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1457, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1457, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1457, DW_AT_decl_line(0x24)
.dwattr $C$DW$1457, DW_AT_decl_column(0x0d)
$C$DW$1458 .dwtag DW_TAG_member
.dwattr $C$DW$1458, DW_AT_type(*$C$DW$T$258)
.dwattr $C$DW$1458, DW_AT_name("resolution")
.dwattr $C$DW$1458, DW_AT_TI_symbol_name("resolution")
.dwattr $C$DW$1458, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1458, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1458, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1458, DW_AT_decl_line(0x26)
.dwattr $C$DW$1458, DW_AT_decl_column(0x1d)
$C$DW$1459 .dwtag DW_TAG_member
.dwattr $C$DW$1459, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1459, DW_AT_name("dBRange")
.dwattr $C$DW$1459, DW_AT_TI_symbol_name("dBRange")
.dwattr $C$DW$1459, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1459, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1459, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1459, DW_AT_decl_line(0x27)
.dwattr $C$DW$1459, DW_AT_decl_column(0x1d)
$C$DW$1460 .dwtag DW_TAG_member
.dwattr $C$DW$1460, DW_AT_type(*$C$DW$T$290)
.dwattr $C$DW$1460, DW_AT_name("fill")
.dwattr $C$DW$1460, DW_AT_TI_symbol_name("fill")
.dwattr $C$DW$1460, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1460, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1460, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1460, DW_AT_decl_line(0x28)
.dwattr $C$DW$1460, DW_AT_decl_column(0x1d)
$C$DW$1461 .dwtag DW_TAG_member
.dwattr $C$DW$1461, DW_AT_type(*$C$DW$T$247)
.dwattr $C$DW$1461, DW_AT_name("gaussian")
.dwattr $C$DW$1461, DW_AT_TI_symbol_name("gaussian")
.dwattr $C$DW$1461, DW_AT_data_member_location[DW_OP_plus_uconst 0x94]
.dwattr $C$DW$1461, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1461, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1461, DW_AT_decl_line(0x29)
.dwattr $C$DW$1461, DW_AT_decl_column(0x1d)
$C$DW$1462 .dwtag DW_TAG_member
.dwattr $C$DW$1462, DW_AT_type(*$C$DW$T$264)
.dwattr $C$DW$1462, DW_AT_name("edgeDetection")
.dwattr $C$DW$1462, DW_AT_TI_symbol_name("edgeDetection")
.dwattr $C$DW$1462, DW_AT_data_member_location[DW_OP_plus_uconst 0x9c]
.dwattr $C$DW$1462, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1462, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1462, DW_AT_decl_line(0x2a)
.dwattr $C$DW$1462, DW_AT_decl_column(0x1d)
$C$DW$1463 .dwtag DW_TAG_member
.dwattr $C$DW$1463, DW_AT_type(*$C$DW$T$269)
.dwattr $C$DW$1463, DW_AT_name("edgeDirection")
.dwattr $C$DW$1463, DW_AT_TI_symbol_name("edgeDirection")
.dwattr $C$DW$1463, DW_AT_data_member_location[DW_OP_plus_uconst 0x180]
.dwattr $C$DW$1463, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1463, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1463, DW_AT_decl_line(0x2b)
.dwattr $C$DW$1463, DW_AT_decl_column(0x1d)
$C$DW$1464 .dwtag DW_TAG_member
.dwattr $C$DW$1464, DW_AT_type(*$C$DW$T$279)
.dwattr $C$DW$1464, DW_AT_name("edgeReliability")
.dwattr $C$DW$1464, DW_AT_TI_symbol_name("edgeReliability")
.dwattr $C$DW$1464, DW_AT_data_member_location[DW_OP_plus_uconst 0x220]
.dwattr $C$DW$1464, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1464, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1464, DW_AT_decl_line(0x2c)
.dwattr $C$DW$1464, DW_AT_decl_column(0x1d)
$C$DW$1465 .dwtag DW_TAG_member
.dwattr $C$DW$1465, DW_AT_type(*$C$DW$T$242)
.dwattr $C$DW$1465, DW_AT_name("emphasis")
.dwattr $C$DW$1465, DW_AT_TI_symbol_name("emphasis")
.dwattr $C$DW$1465, DW_AT_data_member_location[DW_OP_plus_uconst 0x234]
.dwattr $C$DW$1465, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1465, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1465, DW_AT_decl_line(0x2d)
.dwattr $C$DW$1465, DW_AT_decl_column(0x1d)
$C$DW$1466 .dwtag DW_TAG_member
.dwattr $C$DW$1466, DW_AT_type(*$C$DW$T$274)
.dwattr $C$DW$1466, DW_AT_name("directionFilter")
.dwattr $C$DW$1466, DW_AT_TI_symbol_name("directionFilter")
.dwattr $C$DW$1466, DW_AT_data_member_location[DW_OP_plus_uconst 0x2d4]
.dwattr $C$DW$1466, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1466, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1466, DW_AT_decl_line(0x2e)
.dwattr $C$DW$1466, DW_AT_decl_column(0x1d)
$C$DW$1467 .dwtag DW_TAG_member
.dwattr $C$DW$1467, DW_AT_type(*$C$DW$T$284)
.dwattr $C$DW$1467, DW_AT_name("nep")
.dwattr $C$DW$1467, DW_AT_TI_symbol_name("nep")
.dwattr $C$DW$1467, DW_AT_data_member_location[DW_OP_plus_uconst 0x34c]
.dwattr $C$DW$1467, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1467, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1467, DW_AT_decl_line(0x2f)
.dwattr $C$DW$1467, DW_AT_decl_column(0x1d)
$C$DW$1468 .dwtag DW_TAG_member
.dwattr $C$DW$1468, DW_AT_type(*$C$DW$T$284)
.dwattr $C$DW$1468, DW_AT_name("nepS")
.dwattr $C$DW$1468, DW_AT_TI_symbol_name("nepS")
.dwattr $C$DW$1468, DW_AT_data_member_location[DW_OP_plus_uconst 0x43c]
.dwattr $C$DW$1468, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1468, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1468, DW_AT_decl_line(0x30)
.dwattr $C$DW$1468, DW_AT_decl_column(0x1d)
$C$DW$1469 .dwtag DW_TAG_member
.dwattr $C$DW$1469, DW_AT_type(*$C$DW$T$242)
.dwattr $C$DW$1469, DW_AT_name("emphasis2")
.dwattr $C$DW$1469, DW_AT_TI_symbol_name("emphasis2")
.dwattr $C$DW$1469, DW_AT_data_member_location[DW_OP_plus_uconst 0x52c]
.dwattr $C$DW$1469, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1469, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1469, DW_AT_decl_line(0x31)
.dwattr $C$DW$1469, DW_AT_decl_column(0x1d)
$C$DW$1470 .dwtag DW_TAG_member
.dwattr $C$DW$1470, DW_AT_type(*$C$DW$T$237)
.dwattr $C$DW$1470, DW_AT_name("dummy")
.dwattr $C$DW$1470, DW_AT_TI_symbol_name("dummy")
.dwattr $C$DW$1470, DW_AT_data_member_location[DW_OP_plus_uconst 0x5cc]
.dwattr $C$DW$1470, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1470, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$1470, DW_AT_decl_line(0x32)
.dwattr $C$DW$1470, DW_AT_decl_column(0x1d)
$C$DW$56 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$56, DW_AT_declaration
.dwattr $C$DW$56, DW_AT_TI_symbol_name("_ZN13XtNamApiParam13ImageProcessBaSERKS0_")
.dwattr $C$DW$56, DW_AT_type(*$C$DW$T$249)
.dwattr $C$DW$56, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1471 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1471, DW_AT_type(*$C$DW$T$251)
.dwendtag $C$DW$56
.dwendtag $C$DW$T$253
.dwattr $C$DW$T$253, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h")
.dwattr $C$DW$T$253, DW_AT_decl_line(0x20)
.dwattr $C$DW$T$253, DW_AT_decl_column(0x09)
$C$DW$T$250 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$250, DW_AT_type(*$C$DW$T$253)
$C$DW$T$251 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$251, DW_AT_type(*$C$DW$T$250)
.dwattr $C$DW$T$251, DW_AT_address_class(0x20)
$C$DW$T$249 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$249, DW_AT_type(*$C$DW$T$253)
.dwattr $C$DW$T$249, DW_AT_address_class(0x20)
$C$DW$T$252 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$252, DW_AT_type(*$C$DW$T$249)
.dwattr $C$DW$T$252, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1472 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1472, DW_AT_type(*$C$DW$T$251)
.dwendtag $C$DW$T$252
$C$DW$T$1126 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1126, DW_AT_name("ImageProcessPath")
.dwattr $C$DW$T$1126, DW_AT_byte_size(0x90)
$C$DW$1473 .dwtag DW_TAG_member
.dwattr $C$DW$1473, DW_AT_type(*$C$DW$T$1121)
.dwattr $C$DW$1473, DW_AT_name("flg")
.dwattr $C$DW$1473, DW_AT_TI_symbol_name("flg")
.dwattr $C$DW$1473, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1473, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1473, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1473, DW_AT_decl_line(0x35d)
.dwattr $C$DW$1473, DW_AT_decl_column(0x05)
$C$DW$1474 .dwtag DW_TAG_member
.dwattr $C$DW$1474, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1474, DW_AT_name("reserved")
.dwattr $C$DW$1474, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1474, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1474, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1474, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1474, DW_AT_decl_line(0x35e)
.dwattr $C$DW$1474, DW_AT_decl_column(0x05)
$C$DW$57 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$57, DW_AT_declaration
.dwattr $C$DW$57, DW_AT_TI_symbol_name("_ZN16ImageProcessPathaSERKS_")
.dwattr $C$DW$57, DW_AT_type(*$C$DW$T$1122)
.dwattr $C$DW$57, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1475 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1475, DW_AT_type(*$C$DW$T$1124)
.dwendtag $C$DW$57
.dwendtag $C$DW$T$1126
.dwattr $C$DW$T$1126, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1126, DW_AT_decl_line(0x35c)
.dwattr $C$DW$T$1126, DW_AT_decl_column(0x10)
$C$DW$T$204 .dwtag DW_TAG_typedef, DW_AT_name("ImageProcessPath")
.dwattr $C$DW$T$204, DW_AT_type(*$C$DW$T$1126)
.dwattr $C$DW$T$204, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$204, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$204, DW_AT_decl_line(0x35f)
.dwattr $C$DW$T$204, DW_AT_decl_column(0x03)
$C$DW$T$1123 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1123, DW_AT_type(*$C$DW$T$1126)
$C$DW$T$1124 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1124, DW_AT_type(*$C$DW$T$1123)
.dwattr $C$DW$T$1124, DW_AT_address_class(0x20)
$C$DW$T$1122 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1122, DW_AT_type(*$C$DW$T$1126)
.dwattr $C$DW$T$1122, DW_AT_address_class(0x20)
$C$DW$T$1125 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1125, DW_AT_type(*$C$DW$T$1122)
.dwattr $C$DW$T$1125, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1476 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1476, DW_AT_type(*$C$DW$T$1124)
.dwendtag $C$DW$T$1125
$C$DW$T$258 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$258, DW_AT_name("ImageResolution")
.dwattr $C$DW$T$258, DW_AT_byte_size(0x08)
$C$DW$1477 .dwtag DW_TAG_member
.dwattr $C$DW$1477, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1477, DW_AT_name("scaleLine")
.dwattr $C$DW$1477, DW_AT_TI_symbol_name("scaleLine")
.dwattr $C$DW$1477, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1477, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1477, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1477, DW_AT_decl_line(0x19)
.dwattr $C$DW$1477, DW_AT_decl_column(0x09)
$C$DW$1478 .dwtag DW_TAG_member
.dwattr $C$DW$1478, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1478, DW_AT_name("frequencySample")
.dwattr $C$DW$1478, DW_AT_TI_symbol_name("frequencySample")
.dwattr $C$DW$1478, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1478, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1478, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$1478, DW_AT_decl_line(0x1a)
.dwattr $C$DW$1478, DW_AT_decl_column(0x09)
$C$DW$58 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$58, DW_AT_declaration
.dwattr $C$DW$58, DW_AT_TI_symbol_name("_ZN13XtNamApiParam15ImageResolutionaSERKS0_")
.dwattr $C$DW$58, DW_AT_type(*$C$DW$T$254)
.dwattr $C$DW$58, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1479 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1479, DW_AT_type(*$C$DW$T$256)
.dwendtag $C$DW$58
.dwendtag $C$DW$T$258
.dwattr $C$DW$T$258, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h")
.dwattr $C$DW$T$258, DW_AT_decl_line(0x17)
.dwattr $C$DW$T$258, DW_AT_decl_column(0x08)
$C$DW$T$255 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$255, DW_AT_type(*$C$DW$T$258)
$C$DW$T$256 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$256, DW_AT_type(*$C$DW$T$255)
.dwattr $C$DW$T$256, DW_AT_address_class(0x20)
$C$DW$T$254 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$254, DW_AT_type(*$C$DW$T$258)
.dwattr $C$DW$T$254, DW_AT_address_class(0x20)
$C$DW$T$257 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$257, DW_AT_type(*$C$DW$T$254)
.dwattr $C$DW$T$257, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1480 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1480, DW_AT_type(*$C$DW$T$256)
.dwendtag $C$DW$T$257
$C$DW$T$1131 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1131, DW_AT_name("ImageResolution")
.dwattr $C$DW$T$1131, DW_AT_byte_size(0x90)
$C$DW$1481 .dwtag DW_TAG_member
.dwattr $C$DW$1481, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1481, DW_AT_name("scaleLine")
.dwattr $C$DW$1481, DW_AT_TI_symbol_name("scaleLine")
.dwattr $C$DW$1481, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1481, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1481, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1481, DW_AT_decl_line(0x308)
.dwattr $C$DW$1481, DW_AT_decl_column(0x05)
$C$DW$1482 .dwtag DW_TAG_member
.dwattr $C$DW$1482, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1482, DW_AT_name("frequencySample")
.dwattr $C$DW$1482, DW_AT_TI_symbol_name("frequencySample")
.dwattr $C$DW$1482, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1482, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1482, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1482, DW_AT_decl_line(0x309)
.dwattr $C$DW$1482, DW_AT_decl_column(0x05)
$C$DW$1483 .dwtag DW_TAG_member
.dwattr $C$DW$1483, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1483, DW_AT_name("reserved")
.dwattr $C$DW$1483, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1483, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1483, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1483, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1483, DW_AT_decl_line(0x30a)
.dwattr $C$DW$1483, DW_AT_decl_column(0x05)
$C$DW$59 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$59, DW_AT_declaration
.dwattr $C$DW$59, DW_AT_TI_symbol_name("_ZN15ImageResolutionaSERKS_")
.dwattr $C$DW$59, DW_AT_type(*$C$DW$T$1127)
.dwattr $C$DW$59, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1484 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1484, DW_AT_type(*$C$DW$T$1129)
.dwendtag $C$DW$59
.dwendtag $C$DW$T$1131
.dwattr $C$DW$T$1131, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1131, DW_AT_decl_line(0x307)
.dwattr $C$DW$T$1131, DW_AT_decl_column(0x01)
$C$DW$T$195 .dwtag DW_TAG_typedef, DW_AT_name("ImageResolution")
.dwattr $C$DW$T$195, DW_AT_type(*$C$DW$T$1131)
.dwattr $C$DW$T$195, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$195, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$195, DW_AT_decl_line(0x30b)
.dwattr $C$DW$T$195, DW_AT_decl_column(0x03)
$C$DW$T$1128 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1128, DW_AT_type(*$C$DW$T$1131)
$C$DW$T$1129 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1129, DW_AT_type(*$C$DW$T$1128)
.dwattr $C$DW$T$1129, DW_AT_address_class(0x20)
$C$DW$T$1127 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1127, DW_AT_type(*$C$DW$T$1131)
.dwattr $C$DW$T$1127, DW_AT_address_class(0x20)
$C$DW$T$1130 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1130, DW_AT_type(*$C$DW$T$1127)
.dwattr $C$DW$T$1130, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1485 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1485, DW_AT_type(*$C$DW$T$1129)
.dwendtag $C$DW$T$1130
$C$DW$T$1136 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1136, DW_AT_name("ImagingDelay_Param")
.dwattr $C$DW$T$1136, DW_AT_byte_size(0x90)
$C$DW$1486 .dwtag DW_TAG_member
.dwattr $C$DW$1486, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1486, DW_AT_name("ecgAnalogDelayInUsecs")
.dwattr $C$DW$1486, DW_AT_TI_symbol_name("ecgAnalogDelayInUsecs")
.dwattr $C$DW$1486, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1486, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1486, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1486, DW_AT_decl_line(0x4f9)
.dwattr $C$DW$1486, DW_AT_decl_column(0x05)
$C$DW$1487 .dwtag DW_TAG_member
.dwattr $C$DW$1487, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1487, DW_AT_name("ecgDigitalDelayInUsecs")
.dwattr $C$DW$1487, DW_AT_TI_symbol_name("ecgDigitalDelayInUsecs")
.dwattr $C$DW$1487, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1487, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1487, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1487, DW_AT_decl_line(0x4fa)
.dwattr $C$DW$1487, DW_AT_decl_column(0x05)
$C$DW$1488 .dwtag DW_TAG_member
.dwattr $C$DW$1488, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1488, DW_AT_name("reserved")
.dwattr $C$DW$1488, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1488, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1488, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1488, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1488, DW_AT_decl_line(0x4fb)
.dwattr $C$DW$1488, DW_AT_decl_column(0x05)
$C$DW$60 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$60, DW_AT_declaration
.dwattr $C$DW$60, DW_AT_TI_symbol_name("_ZN18ImagingDelay_ParamaSERKS_")
.dwattr $C$DW$60, DW_AT_type(*$C$DW$T$1132)
.dwattr $C$DW$60, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1489 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1489, DW_AT_type(*$C$DW$T$1134)
.dwendtag $C$DW$60
.dwendtag $C$DW$T$1136
.dwattr $C$DW$T$1136, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1136, DW_AT_decl_line(0x4f8)
.dwattr $C$DW$T$1136, DW_AT_decl_column(0x01)
$C$DW$T$581 .dwtag DW_TAG_typedef, DW_AT_name("ImagingDelay_Param")
.dwattr $C$DW$T$581, DW_AT_type(*$C$DW$T$1136)
.dwattr $C$DW$T$581, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$581, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$581, DW_AT_decl_line(0x4fc)
.dwattr $C$DW$T$581, DW_AT_decl_column(0x03)
$C$DW$T$1133 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1133, DW_AT_type(*$C$DW$T$1136)
$C$DW$T$1134 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1134, DW_AT_type(*$C$DW$T$1133)
.dwattr $C$DW$T$1134, DW_AT_address_class(0x20)
$C$DW$T$1132 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1132, DW_AT_type(*$C$DW$T$1136)
.dwattr $C$DW$T$1132, DW_AT_address_class(0x20)
$C$DW$T$1135 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1135, DW_AT_type(*$C$DW$T$1132)
.dwattr $C$DW$T$1135, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1490 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1490, DW_AT_type(*$C$DW$T$1134)
.dwendtag $C$DW$T$1135
$C$DW$T$1141 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1141, DW_AT_name("ImgFilterAnIso2DParam")
.dwattr $C$DW$T$1141, DW_AT_byte_size(0x0c)
$C$DW$1491 .dwtag DW_TAG_member
.dwattr $C$DW$1491, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1491, DW_AT_name("maskw")
.dwattr $C$DW$1491, DW_AT_TI_symbol_name("maskw")
.dwattr $C$DW$1491, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1491, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1491, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1491, DW_AT_decl_line(0x3f0)
.dwattr $C$DW$1491, DW_AT_decl_column(0x09)
$C$DW$1492 .dwtag DW_TAG_member
.dwattr $C$DW$1492, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1492, DW_AT_name("maskh")
.dwattr $C$DW$1492, DW_AT_TI_symbol_name("maskh")
.dwattr $C$DW$1492, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1492, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1492, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1492, DW_AT_decl_line(0x3f1)
.dwattr $C$DW$1492, DW_AT_decl_column(0x09)
$C$DW$1493 .dwtag DW_TAG_member
.dwattr $C$DW$1493, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1493, DW_AT_name("accuracyBits")
.dwattr $C$DW$1493, DW_AT_TI_symbol_name("accuracyBits")
.dwattr $C$DW$1493, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1493, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1493, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1493, DW_AT_decl_line(0x3f2)
.dwattr $C$DW$1493, DW_AT_decl_column(0x09)
$C$DW$61 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$61, DW_AT_declaration
.dwattr $C$DW$61, DW_AT_TI_symbol_name("_ZN21ImgFilterAnIso2DParamaSERKS_")
.dwattr $C$DW$61, DW_AT_type(*$C$DW$T$1137)
.dwattr $C$DW$61, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1494 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1494, DW_AT_type(*$C$DW$T$1139)
.dwendtag $C$DW$61
.dwendtag $C$DW$T$1141
.dwattr $C$DW$T$1141, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$T$1141, DW_AT_decl_line(0x3ee)
.dwattr $C$DW$T$1141, DW_AT_decl_column(0x08)
$C$DW$T$1138 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1138, DW_AT_type(*$C$DW$T$1141)
$C$DW$T$1139 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1139, DW_AT_type(*$C$DW$T$1138)
.dwattr $C$DW$T$1139, DW_AT_address_class(0x20)
$C$DW$T$1137 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1137, DW_AT_type(*$C$DW$T$1141)
.dwattr $C$DW$T$1137, DW_AT_address_class(0x20)
$C$DW$T$1140 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1140, DW_AT_type(*$C$DW$T$1137)
.dwattr $C$DW$T$1140, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1495 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1495, DW_AT_type(*$C$DW$T$1139)
.dwendtag $C$DW$T$1140
$C$DW$T$1161 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1161, DW_AT_name("InitMsg")
.dwattr $C$DW$T$1161, DW_AT_byte_size(0x38)
$C$DW$1496 .dwtag DW_TAG_member
.dwattr $C$DW$1496, DW_AT_type(*$C$DW$T$510)
.dwattr $C$DW$1496, DW_AT_name("spDataType")
.dwattr $C$DW$1496, DW_AT_TI_symbol_name("spDataType")
.dwattr $C$DW$1496, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1496, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1496, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1496, DW_AT_decl_line(0x77)
.dwattr $C$DW$1496, DW_AT_decl_column(0x19)
$C$DW$1497 .dwtag DW_TAG_member
.dwattr $C$DW$1497, DW_AT_type(*$C$DW$T$454)
.dwattr $C$DW$1497, DW_AT_name("command")
.dwattr $C$DW$1497, DW_AT_TI_symbol_name("command")
.dwattr $C$DW$1497, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1497, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1497, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1497, DW_AT_decl_line(0x78)
.dwattr $C$DW$1497, DW_AT_decl_column(0x19)
$C$DW$1498 .dwtag DW_TAG_member
.dwattr $C$DW$1498, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$1498, DW_AT_name("timeStarted")
.dwattr $C$DW$1498, DW_AT_TI_symbol_name("timeStarted")
.dwattr $C$DW$1498, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1498, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1498, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1498, DW_AT_decl_line(0x79)
.dwattr $C$DW$1498, DW_AT_decl_column(0x19)
$C$DW$1499 .dwtag DW_TAG_member
.dwattr $C$DW$1499, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$1499, DW_AT_name("timeEnded")
.dwattr $C$DW$1499, DW_AT_TI_symbol_name("timeEnded")
.dwattr $C$DW$1499, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1499, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1499, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1499, DW_AT_decl_line(0x7a)
.dwattr $C$DW$1499, DW_AT_decl_column(0x19)
$C$DW$1500 .dwtag DW_TAG_member
.dwattr $C$DW$1500, DW_AT_type(*$C$DW$T$508)
.dwattr $C$DW$1500, DW_AT_name("coreId")
.dwattr $C$DW$1500, DW_AT_TI_symbol_name("coreId")
.dwattr $C$DW$1500, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1500, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1500, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1500, DW_AT_decl_line(0x7b)
.dwattr $C$DW$1500, DW_AT_decl_column(0x19)
$C$DW$1501 .dwtag DW_TAG_member
.dwattr $C$DW$1501, DW_AT_type(*$C$DW$T$456)
.dwattr $C$DW$1501, DW_AT_name("enableDryRun")
.dwattr $C$DW$1501, DW_AT_TI_symbol_name("enableDryRun")
.dwattr $C$DW$1501, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c]
.dwattr $C$DW$1501, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1501, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1501, DW_AT_decl_line(0x7c)
.dwattr $C$DW$1501, DW_AT_decl_column(0x19)
$C$DW$1502 .dwtag DW_TAG_member
.dwattr $C$DW$1502, DW_AT_type(*$C$DW$T$522)
.dwattr $C$DW$1502, DW_AT_name("pDryRunInCBuf")
.dwattr $C$DW$1502, DW_AT_TI_symbol_name("pDryRunInCBuf")
.dwattr $C$DW$1502, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1502, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1502, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1502, DW_AT_decl_line(0x7d)
.dwattr $C$DW$1502, DW_AT_decl_column(0x19)
$C$DW$1503 .dwtag DW_TAG_member
.dwattr $C$DW$1503, DW_AT_type(*$C$DW$T$522)
.dwattr $C$DW$1503, DW_AT_name("pDryRunOutCBuf")
.dwattr $C$DW$1503, DW_AT_TI_symbol_name("pDryRunOutCBuf")
.dwattr $C$DW$1503, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1503, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1503, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1503, DW_AT_decl_line(0x7e)
.dwattr $C$DW$1503, DW_AT_decl_column(0x19)
$C$DW$1504 .dwtag DW_TAG_member
.dwattr $C$DW$1504, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1504, DW_AT_name("numInCmd")
.dwattr $C$DW$1504, DW_AT_TI_symbol_name("numInCmd")
.dwattr $C$DW$1504, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1504, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1504, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1504, DW_AT_decl_line(0x7f)
.dwattr $C$DW$1504, DW_AT_decl_column(0x19)
$C$DW$1505 .dwtag DW_TAG_member
.dwattr $C$DW$1505, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1505, DW_AT_name("numOutCmd")
.dwattr $C$DW$1505, DW_AT_TI_symbol_name("numOutCmd")
.dwattr $C$DW$1505, DW_AT_data_member_location[DW_OP_plus_uconst 0x34]
.dwattr $C$DW$1505, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1505, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1505, DW_AT_decl_line(0x80)
.dwattr $C$DW$1505, DW_AT_decl_column(0x19)
$C$DW$62 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$62, DW_AT_declaration
.dwattr $C$DW$62, DW_AT_TI_symbol_name("_ZN7InitMsgaSERKS_")
.dwattr $C$DW$62, DW_AT_type(*$C$DW$T$1157)
.dwattr $C$DW$62, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1506 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1506, DW_AT_type(*$C$DW$T$1159)
.dwendtag $C$DW$62
.dwendtag $C$DW$T$1161
.dwattr $C$DW$T$1161, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1161, DW_AT_decl_line(0x76)
.dwattr $C$DW$T$1161, DW_AT_decl_column(0x01)
$C$DW$T$1158 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1158, DW_AT_type(*$C$DW$T$1161)
$C$DW$T$1159 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1159, DW_AT_type(*$C$DW$T$1158)
.dwattr $C$DW$T$1159, DW_AT_address_class(0x20)
$C$DW$T$1473 .dwtag DW_TAG_typedef, DW_AT_name("InitMsg")
.dwattr $C$DW$T$1473, DW_AT_type(*$C$DW$T$1161)
.dwattr $C$DW$T$1473, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1473, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1473, DW_AT_decl_line(0x81)
.dwattr $C$DW$T$1473, DW_AT_decl_column(0x03)
$C$DW$T$1157 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1157, DW_AT_type(*$C$DW$T$1161)
.dwattr $C$DW$T$1157, DW_AT_address_class(0x20)
$C$DW$T$1160 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1160, DW_AT_type(*$C$DW$T$1157)
.dwattr $C$DW$T$1160, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1507 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1507, DW_AT_type(*$C$DW$T$1159)
.dwendtag $C$DW$T$1160
$C$DW$T$1172 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$1172, DW_AT_name("InputMgrData")
.dwattr $C$DW$T$1172, DW_AT_byte_size(0x18)
$C$DW$1508 .dwtag DW_TAG_member
.dwattr $C$DW$1508, DW_AT_type(*$C$DW$T$1162)
.dwattr $C$DW$1508, DW_AT_name("MBInputData")
.dwattr $C$DW$1508, DW_AT_TI_symbol_name("MBInputData")
.dwattr $C$DW$1508, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1508, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1508, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1508, DW_AT_decl_line(0x38)
.dwattr $C$DW$1508, DW_AT_decl_column(0x1b)
$C$DW$1509 .dwtag DW_TAG_member
.dwattr $C$DW$1509, DW_AT_type(*$C$DW$T$1163)
.dwattr $C$DW$1509, DW_AT_name("nMBInputData")
.dwattr $C$DW$1509, DW_AT_TI_symbol_name("nMBInputData")
.dwattr $C$DW$1509, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1509, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1509, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1509, DW_AT_decl_line(0x39)
.dwattr $C$DW$1509, DW_AT_decl_column(0x1b)
$C$DW$1510 .dwtag DW_TAG_member
.dwattr $C$DW$1510, DW_AT_type(*$C$DW$T$1164)
.dwattr $C$DW$1510, DW_AT_name("dopplerData")
.dwattr $C$DW$1510, DW_AT_TI_symbol_name("dopplerData")
.dwattr $C$DW$1510, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1510, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1510, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1510, DW_AT_decl_line(0x3a)
.dwattr $C$DW$1510, DW_AT_decl_column(0x1b)
$C$DW$1511 .dwtag DW_TAG_member
.dwattr $C$DW$1511, DW_AT_type(*$C$DW$T$1165)
.dwattr $C$DW$1511, DW_AT_name("colorData")
.dwattr $C$DW$1511, DW_AT_TI_symbol_name("colorData")
.dwattr $C$DW$1511, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1511, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1511, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1511, DW_AT_decl_line(0x3b)
.dwattr $C$DW$1511, DW_AT_decl_column(0x1b)
$C$DW$1512 .dwtag DW_TAG_member
.dwattr $C$DW$1512, DW_AT_type(*$C$DW$T$1166)
.dwattr $C$DW$1512, DW_AT_name("mModeData")
.dwattr $C$DW$1512, DW_AT_TI_symbol_name("mModeData")
.dwattr $C$DW$1512, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1512, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1512, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1512, DW_AT_decl_line(0x3c)
.dwattr $C$DW$1512, DW_AT_decl_column(0x1b)
$C$DW$1513 .dwtag DW_TAG_member
.dwattr $C$DW$1513, DW_AT_type(*$C$DW$T$1167)
.dwattr $C$DW$1513, DW_AT_name("ecgData")
.dwattr $C$DW$1513, DW_AT_TI_symbol_name("ecgData")
.dwattr $C$DW$1513, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1513, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1513, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1513, DW_AT_decl_line(0x3d)
.dwattr $C$DW$1513, DW_AT_decl_column(0x1b)
$C$DW$63 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$63, DW_AT_declaration
.dwattr $C$DW$63, DW_AT_TI_symbol_name("_ZN12InputMgrDataaSERKS_")
.dwattr $C$DW$63, DW_AT_type(*$C$DW$T$1168)
.dwattr $C$DW$63, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1514 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1514, DW_AT_type(*$C$DW$T$1170)
.dwendtag $C$DW$63
.dwendtag $C$DW$T$1172
.dwattr $C$DW$T$1172, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1172, DW_AT_decl_line(0x37)
.dwattr $C$DW$T$1172, DW_AT_decl_column(0x01)
$C$DW$T$1169 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1169, DW_AT_type(*$C$DW$T$1172)
$C$DW$T$1170 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1170, DW_AT_type(*$C$DW$T$1169)
.dwattr $C$DW$T$1170, DW_AT_address_class(0x20)
$C$DW$T$1469 .dwtag DW_TAG_typedef, DW_AT_name("InputMgrData")
.dwattr $C$DW$T$1469, DW_AT_type(*$C$DW$T$1172)
.dwattr $C$DW$T$1469, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1469, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1469, DW_AT_decl_line(0x3f)
.dwattr $C$DW$T$1469, DW_AT_decl_column(0x03)
$C$DW$T$1168 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1168, DW_AT_type(*$C$DW$T$1172)
.dwattr $C$DW$T$1168, DW_AT_address_class(0x20)
$C$DW$T$1171 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1171, DW_AT_type(*$C$DW$T$1168)
.dwattr $C$DW$T$1171, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1515 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1515, DW_AT_type(*$C$DW$T$1170)
.dwendtag $C$DW$T$1171
$C$DW$T$877 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$877, DW_AT_name("KernelFilter_Coeff")
.dwattr $C$DW$T$877, DW_AT_byte_size(0xc0)
$C$DW$1516 .dwtag DW_TAG_member
.dwattr $C$DW$1516, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$1516, DW_AT_name("length")
.dwattr $C$DW$1516, DW_AT_TI_symbol_name("length")
.dwattr $C$DW$1516, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1516, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1516, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1516, DW_AT_decl_line(0x40f)
.dwattr $C$DW$1516, DW_AT_decl_column(0x05)
$C$DW$1517 .dwtag DW_TAG_member
.dwattr $C$DW$1517, DW_AT_type(*$C$DW$T$872)
.dwattr $C$DW$1517, DW_AT_name("coeffs")
.dwattr $C$DW$1517, DW_AT_TI_symbol_name("coeffs")
.dwattr $C$DW$1517, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1517, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1517, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1517, DW_AT_decl_line(0x410)
.dwattr $C$DW$1517, DW_AT_decl_column(0x05)
$C$DW$1518 .dwtag DW_TAG_member
.dwattr $C$DW$1518, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1518, DW_AT_name("reserved")
.dwattr $C$DW$1518, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1518, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$1518, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1518, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1518, DW_AT_decl_line(0x411)
.dwattr $C$DW$1518, DW_AT_decl_column(0x05)
$C$DW$64 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$64, DW_AT_declaration
.dwattr $C$DW$64, DW_AT_TI_symbol_name("_ZN18KernelFilter_CoeffaSERKS_")
.dwattr $C$DW$64, DW_AT_type(*$C$DW$T$873)
.dwattr $C$DW$64, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1519 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1519, DW_AT_type(*$C$DW$T$875)
.dwendtag $C$DW$64
.dwendtag $C$DW$T$877
.dwattr $C$DW$T$877, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$877, DW_AT_decl_line(0x40e)
.dwattr $C$DW$T$877, DW_AT_decl_column(0x01)
$C$DW$T$874 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$874, DW_AT_type(*$C$DW$T$877)
$C$DW$T$875 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$875, DW_AT_type(*$C$DW$T$874)
.dwattr $C$DW$T$875, DW_AT_address_class(0x20)
$C$DW$T$1183 .dwtag DW_TAG_typedef, DW_AT_name("KernelFilter_Coeff")
.dwattr $C$DW$T$1183, DW_AT_type(*$C$DW$T$877)
.dwattr $C$DW$T$1183, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1183, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1183, DW_AT_decl_line(0x412)
.dwattr $C$DW$T$1183, DW_AT_decl_column(0x03)
$C$DW$T$873 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$873, DW_AT_type(*$C$DW$T$877)
.dwattr $C$DW$T$873, DW_AT_address_class(0x20)
$C$DW$T$876 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$876, DW_AT_type(*$C$DW$T$873)
.dwattr $C$DW$T$876, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1520 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1520, DW_AT_type(*$C$DW$T$875)
.dwendtag $C$DW$T$876
$C$DW$T$882 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$882, DW_AT_name("KernelFilter_Param")
.dwattr $C$DW$T$882, DW_AT_byte_size(0xb8)
$C$DW$1521 .dwtag DW_TAG_member
.dwattr $C$DW$1521, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$1521, DW_AT_name("pKernelFiltCoeffs")
.dwattr $C$DW$1521, DW_AT_TI_symbol_name("pKernelFiltCoeffs")
.dwattr $C$DW$1521, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1521, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1521, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1521, DW_AT_decl_line(0x402)
.dwattr $C$DW$1521, DW_AT_decl_column(0x05)
$C$DW$1522 .dwtag DW_TAG_member
.dwattr $C$DW$1522, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$1522, DW_AT_name("KrnCoeffsSize")
.dwattr $C$DW$1522, DW_AT_TI_symbol_name("KrnCoeffsSize")
.dwattr $C$DW$1522, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1522, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1522, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1522, DW_AT_decl_line(0x403)
.dwattr $C$DW$1522, DW_AT_decl_column(0x05)
$C$DW$1523 .dwtag DW_TAG_member
.dwattr $C$DW$1523, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$1523, DW_AT_name("KrnFilterLen")
.dwattr $C$DW$1523, DW_AT_TI_symbol_name("KrnFilterLen")
.dwattr $C$DW$1523, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1523, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1523, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1523, DW_AT_decl_line(0x404)
.dwattr $C$DW$1523, DW_AT_decl_column(0x05)
$C$DW$1524 .dwtag DW_TAG_member
.dwattr $C$DW$1524, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$1524, DW_AT_name("KrnGain")
.dwattr $C$DW$1524, DW_AT_TI_symbol_name("KrnGain")
.dwattr $C$DW$1524, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1524, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1524, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1524, DW_AT_decl_line(0x405)
.dwattr $C$DW$1524, DW_AT_decl_column(0x05)
$C$DW$1525 .dwtag DW_TAG_member
.dwattr $C$DW$1525, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1525, DW_AT_name("KrnMm5Reg")
.dwattr $C$DW$1525, DW_AT_TI_symbol_name("KrnMm5Reg")
.dwattr $C$DW$1525, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1525, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1525, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1525, DW_AT_decl_line(0x406)
.dwattr $C$DW$1525, DW_AT_decl_column(0x05)
$C$DW$1526 .dwtag DW_TAG_member
.dwattr $C$DW$1526, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1526, DW_AT_name("KrnMm6Reg")
.dwattr $C$DW$1526, DW_AT_TI_symbol_name("KrnMm6Reg")
.dwattr $C$DW$1526, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1526, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1526, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1526, DW_AT_decl_line(0x407)
.dwattr $C$DW$1526, DW_AT_decl_column(0x05)
$C$DW$1527 .dwtag DW_TAG_member
.dwattr $C$DW$1527, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1527, DW_AT_name("KrnMm7Reg")
.dwattr $C$DW$1527, DW_AT_TI_symbol_name("KrnMm7Reg")
.dwattr $C$DW$1527, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1527, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1527, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1527, DW_AT_decl_line(0x408)
.dwattr $C$DW$1527, DW_AT_decl_column(0x05)
$C$DW$1528 .dwtag DW_TAG_member
.dwattr $C$DW$1528, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1528, DW_AT_name("reserved")
.dwattr $C$DW$1528, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1528, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$1528, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1528, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1528, DW_AT_decl_line(0x409)
.dwattr $C$DW$1528, DW_AT_decl_column(0x05)
$C$DW$65 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$65, DW_AT_declaration
.dwattr $C$DW$65, DW_AT_TI_symbol_name("_ZN18KernelFilter_ParamaSERKS_")
.dwattr $C$DW$65, DW_AT_type(*$C$DW$T$878)
.dwattr $C$DW$65, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1529 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1529, DW_AT_type(*$C$DW$T$880)
.dwendtag $C$DW$65
.dwendtag $C$DW$T$882
.dwattr $C$DW$T$882, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$882, DW_AT_decl_line(0x401)
.dwattr $C$DW$T$882, DW_AT_decl_column(0x10)
$C$DW$T$879 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$879, DW_AT_type(*$C$DW$T$882)
$C$DW$T$880 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$880, DW_AT_type(*$C$DW$T$879)
.dwattr $C$DW$T$880, DW_AT_address_class(0x20)
$C$DW$T$2146 .dwtag DW_TAG_typedef, DW_AT_name("KernelFilter_Param")
.dwattr $C$DW$T$2146, DW_AT_type(*$C$DW$T$882)
.dwattr $C$DW$T$2146, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2146, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$2146, DW_AT_decl_line(0x40a)
.dwattr $C$DW$T$2146, DW_AT_decl_column(0x03)
$C$DW$T$878 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$878, DW_AT_type(*$C$DW$T$882)
.dwattr $C$DW$T$878, DW_AT_address_class(0x20)
$C$DW$T$881 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$881, DW_AT_type(*$C$DW$T$878)
.dwattr $C$DW$T$881, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1530 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1530, DW_AT_type(*$C$DW$T$880)
.dwendtag $C$DW$T$881
$C$DW$T$1549 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1549, DW_AT_name("LutParam")
.dwattr $C$DW$T$1549, DW_AT_byte_size(0x0c)
$C$DW$1531 .dwtag DW_TAG_member
.dwattr $C$DW$1531, DW_AT_type(*$C$DW$T$1544)
.dwattr $C$DW$1531, DW_AT_name("lut")
.dwattr $C$DW$1531, DW_AT_TI_symbol_name("lut")
.dwattr $C$DW$1531, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1531, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1531, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1531, DW_AT_decl_line(0x35)
.dwattr $C$DW$1531, DW_AT_decl_column(0x0b)
$C$DW$1532 .dwtag DW_TAG_member
.dwattr $C$DW$1532, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1532, DW_AT_name("accuracyBits")
.dwattr $C$DW$1532, DW_AT_TI_symbol_name("accuracyBits")
.dwattr $C$DW$1532, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1532, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1532, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1532, DW_AT_decl_line(0x36)
.dwattr $C$DW$1532, DW_AT_decl_column(0x06)
$C$DW$1533 .dwtag DW_TAG_member
.dwattr $C$DW$1533, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1533, DW_AT_name("num")
.dwattr $C$DW$1533, DW_AT_TI_symbol_name("num")
.dwattr $C$DW$1533, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1533, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1533, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1533, DW_AT_decl_line(0x37)
.dwattr $C$DW$1533, DW_AT_decl_column(0x06)
$C$DW$66 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$66, DW_AT_declaration
.dwattr $C$DW$66, DW_AT_TI_symbol_name("_ZN8LutParamaSERKS_")
.dwattr $C$DW$66, DW_AT_type(*$C$DW$T$1545)
.dwattr $C$DW$66, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1534 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1534, DW_AT_type(*$C$DW$T$1547)
.dwendtag $C$DW$66
.dwendtag $C$DW$T$1549
.dwattr $C$DW$T$1549, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$T$1549, DW_AT_decl_line(0x33)
.dwattr $C$DW$T$1549, DW_AT_decl_column(0x08)
$C$DW$T$1546 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1546, DW_AT_type(*$C$DW$T$1549)
$C$DW$T$1547 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1547, DW_AT_type(*$C$DW$T$1546)
.dwattr $C$DW$T$1547, DW_AT_address_class(0x20)
$C$DW$T$444 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$444, DW_AT_type(*$C$DW$T$1549)
.dwattr $C$DW$T$444, DW_AT_address_class(0x20)
$C$DW$T$1196 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1196, DW_AT_type(*$C$DW$T$1549)
.dwattr $C$DW$T$1196, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1196, DW_AT_byte_size(0x3c)
$C$DW$1535 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$1535, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1196
$C$DW$T$1545 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1545, DW_AT_type(*$C$DW$T$1549)
.dwattr $C$DW$T$1545, DW_AT_address_class(0x20)
$C$DW$T$1548 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1548, DW_AT_type(*$C$DW$T$1545)
.dwattr $C$DW$T$1548, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1536 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1536, DW_AT_type(*$C$DW$T$1547)
.dwendtag $C$DW$T$1548
$C$DW$T$1555 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1555, DW_AT_name("LutParamFloat")
.dwattr $C$DW$T$1555, DW_AT_byte_size(0x40008)
$C$DW$1537 .dwtag DW_TAG_member
.dwattr $C$DW$1537, DW_AT_type(*$C$DW$T$1550)
.dwattr $C$DW$1537, DW_AT_name("lut")
.dwattr $C$DW$1537, DW_AT_TI_symbol_name("lut")
.dwattr $C$DW$1537, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1537, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1537, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1537, DW_AT_decl_line(0x4c)
.dwattr $C$DW$1537, DW_AT_decl_column(0x08)
$C$DW$1538 .dwtag DW_TAG_member
.dwattr $C$DW$1538, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1538, DW_AT_name("num")
.dwattr $C$DW$1538, DW_AT_TI_symbol_name("num")
.dwattr $C$DW$1538, DW_AT_data_member_location[DW_OP_plus_uconst 0x40000]
.dwattr $C$DW$1538, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1538, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1538, DW_AT_decl_line(0x4d)
.dwattr $C$DW$1538, DW_AT_decl_column(0x07)
$C$DW$1539 .dwtag DW_TAG_member
.dwattr $C$DW$1539, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1539, DW_AT_name("accuracy")
.dwattr $C$DW$1539, DW_AT_TI_symbol_name("accuracy")
.dwattr $C$DW$1539, DW_AT_data_member_location[DW_OP_plus_uconst 0x40004]
.dwattr $C$DW$1539, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1539, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1539, DW_AT_decl_line(0x4e)
.dwattr $C$DW$1539, DW_AT_decl_column(0x07)
$C$DW$67 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$67, DW_AT_declaration
.dwattr $C$DW$67, DW_AT_TI_symbol_name("_ZN13LutParamFloataSERKS_")
.dwattr $C$DW$67, DW_AT_type(*$C$DW$T$1551)
.dwattr $C$DW$67, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1540 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1540, DW_AT_type(*$C$DW$T$1553)
.dwendtag $C$DW$67
.dwendtag $C$DW$T$1555
.dwattr $C$DW$T$1555, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$T$1555, DW_AT_decl_line(0x4a)
.dwattr $C$DW$T$1555, DW_AT_decl_column(0x08)
$C$DW$T$1552 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1552, DW_AT_type(*$C$DW$T$1555)
$C$DW$T$1553 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1553, DW_AT_type(*$C$DW$T$1552)
.dwattr $C$DW$T$1553, DW_AT_address_class(0x20)
$C$DW$T$1228 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1228, DW_AT_type(*$C$DW$T$1555)
.dwattr $C$DW$T$1228, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1228, DW_AT_byte_size(0x140028)
$C$DW$1541 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$1541, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1228
$C$DW$T$1551 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1551, DW_AT_type(*$C$DW$T$1555)
.dwattr $C$DW$T$1551, DW_AT_address_class(0x20)
$C$DW$T$1554 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1554, DW_AT_type(*$C$DW$T$1551)
.dwattr $C$DW$T$1554, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1542 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1542, DW_AT_type(*$C$DW$T$1553)
.dwendtag $C$DW$T$1554
$C$DW$T$1560 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1560, DW_AT_name("LutParamNEP")
.dwattr $C$DW$T$1560, DW_AT_byte_size(0x40010)
$C$DW$1543 .dwtag DW_TAG_member
.dwattr $C$DW$1543, DW_AT_type(*$C$DW$T$1550)
.dwattr $C$DW$1543, DW_AT_name("lut")
.dwattr $C$DW$1543, DW_AT_TI_symbol_name("lut")
.dwattr $C$DW$1543, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1543, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1543, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1543, DW_AT_decl_line(0x58)
.dwattr $C$DW$1543, DW_AT_decl_column(0x0e)
$C$DW$1544 .dwtag DW_TAG_member
.dwattr $C$DW$1544, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1544, DW_AT_name("alpha")
.dwattr $C$DW$1544, DW_AT_TI_symbol_name("alpha")
.dwattr $C$DW$1544, DW_AT_data_member_location[DW_OP_plus_uconst 0x40000]
.dwattr $C$DW$1544, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1544, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1544, DW_AT_decl_line(0x59)
.dwattr $C$DW$1544, DW_AT_decl_column(0x0e)
$C$DW$1545 .dwtag DW_TAG_member
.dwattr $C$DW$1545, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1545, DW_AT_name("beta")
.dwattr $C$DW$1545, DW_AT_TI_symbol_name("beta")
.dwattr $C$DW$1545, DW_AT_data_member_location[DW_OP_plus_uconst 0x40004]
.dwattr $C$DW$1545, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1545, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1545, DW_AT_decl_line(0x5a)
.dwattr $C$DW$1545, DW_AT_decl_column(0x0e)
$C$DW$1546 .dwtag DW_TAG_member
.dwattr $C$DW$1546, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1546, DW_AT_name("gamma")
.dwattr $C$DW$1546, DW_AT_TI_symbol_name("gamma")
.dwattr $C$DW$1546, DW_AT_data_member_location[DW_OP_plus_uconst 0x40008]
.dwattr $C$DW$1546, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1546, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1546, DW_AT_decl_line(0x5b)
.dwattr $C$DW$1546, DW_AT_decl_column(0x0e)
$C$DW$1547 .dwtag DW_TAG_member
.dwattr $C$DW$1547, DW_AT_type(*$C$DW$T$1544)
.dwattr $C$DW$1547, DW_AT_name("lutS")
.dwattr $C$DW$1547, DW_AT_TI_symbol_name("lutS")
.dwattr $C$DW$1547, DW_AT_data_member_location[DW_OP_plus_uconst 0x4000c]
.dwattr $C$DW$1547, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1547, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$1547, DW_AT_decl_line(0x5c)
.dwattr $C$DW$1547, DW_AT_decl_column(0x0e)
$C$DW$68 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$68, DW_AT_declaration
.dwattr $C$DW$68, DW_AT_TI_symbol_name("_ZN11LutParamNEPaSERKS_")
.dwattr $C$DW$68, DW_AT_type(*$C$DW$T$1556)
.dwattr $C$DW$68, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1548 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1548, DW_AT_type(*$C$DW$T$1558)
.dwendtag $C$DW$68
.dwendtag $C$DW$T$1560
.dwattr $C$DW$T$1560, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$T$1560, DW_AT_decl_line(0x56)
.dwattr $C$DW$T$1560, DW_AT_decl_column(0x08)
$C$DW$T$1557 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1557, DW_AT_type(*$C$DW$T$1560)
$C$DW$T$1558 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1558, DW_AT_type(*$C$DW$T$1557)
.dwattr $C$DW$T$1558, DW_AT_address_class(0x20)
$C$DW$T$1200 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1200, DW_AT_type(*$C$DW$T$1560)
.dwattr $C$DW$T$1200, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1200, DW_AT_byte_size(0x140050)
$C$DW$1549 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$1549, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1200
$C$DW$T$1556 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1556, DW_AT_type(*$C$DW$T$1560)
.dwattr $C$DW$T$1556, DW_AT_address_class(0x20)
$C$DW$T$1559 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1559, DW_AT_type(*$C$DW$T$1556)
.dwattr $C$DW$T$1559, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1550 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1550, DW_AT_type(*$C$DW$T$1558)
.dwendtag $C$DW$T$1559
$C$DW$T$142 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$142, DW_AT_name("MMode_Param")
.dwattr $C$DW$T$142, DW_AT_byte_size(0x150)
$C$DW$1551 .dwtag DW_TAG_member
.dwattr $C$DW$1551, DW_AT_type(*$C$DW$T$132)
.dwattr $C$DW$1551, DW_AT_name("subMode")
.dwattr $C$DW$1551, DW_AT_TI_symbol_name("subMode")
.dwattr $C$DW$1551, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1551, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1551, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1551, DW_AT_decl_line(0x4d6)
.dwattr $C$DW$1551, DW_AT_decl_column(0x05)
$C$DW$1552 .dwtag DW_TAG_member
.dwattr $C$DW$1552, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1552, DW_AT_name("InpEchoEstimates")
.dwattr $C$DW$1552, DW_AT_TI_symbol_name("InpEchoEstimates")
.dwattr $C$DW$1552, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1552, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1552, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1552, DW_AT_decl_line(0x4d7)
.dwattr $C$DW$1552, DW_AT_decl_column(0x05)
$C$DW$1553 .dwtag DW_TAG_member
.dwattr $C$DW$1553, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1553, DW_AT_name("InpColorEstimates")
.dwattr $C$DW$1553, DW_AT_TI_symbol_name("InpColorEstimates")
.dwattr $C$DW$1553, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1553, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1553, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1553, DW_AT_decl_line(0x4d8)
.dwattr $C$DW$1553, DW_AT_decl_column(0x05)
$C$DW$1554 .dwtag DW_TAG_member
.dwattr $C$DW$1554, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1554, DW_AT_name("InputValidEsts")
.dwattr $C$DW$1554, DW_AT_TI_symbol_name("InputValidEsts")
.dwattr $C$DW$1554, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1554, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1554, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1554, DW_AT_decl_line(0x4d9)
.dwattr $C$DW$1554, DW_AT_decl_column(0x05)
$C$DW$1555 .dwtag DW_TAG_member
.dwattr $C$DW$1555, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1555, DW_AT_name("StartEstimates")
.dwattr $C$DW$1555, DW_AT_TI_symbol_name("StartEstimates")
.dwattr $C$DW$1555, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1555, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1555, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1555, DW_AT_decl_line(0x4da)
.dwattr $C$DW$1555, DW_AT_decl_column(0x05)
$C$DW$1556 .dwtag DW_TAG_member
.dwattr $C$DW$1556, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1556, DW_AT_name("VerticalScaleFactor")
.dwattr $C$DW$1556, DW_AT_TI_symbol_name("VerticalScaleFactor")
.dwattr $C$DW$1556, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1556, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1556, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1556, DW_AT_decl_line(0x4db)
.dwattr $C$DW$1556, DW_AT_decl_column(0x05)
$C$DW$1557 .dwtag DW_TAG_member
.dwattr $C$DW$1557, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1557, DW_AT_name("NumScaledPixels")
.dwattr $C$DW$1557, DW_AT_TI_symbol_name("NumScaledPixels")
.dwattr $C$DW$1557, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1557, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1557, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1557, DW_AT_decl_line(0x4dc)
.dwattr $C$DW$1557, DW_AT_decl_column(0x05)
$C$DW$1558 .dwtag DW_TAG_member
.dwattr $C$DW$1558, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1558, DW_AT_name("MultiLineON")
.dwattr $C$DW$1558, DW_AT_TI_symbol_name("MultiLineON")
.dwattr $C$DW$1558, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$1558, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1558, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1558, DW_AT_decl_line(0x4dd)
.dwattr $C$DW$1558, DW_AT_decl_column(0x05)
$C$DW$1559 .dwtag DW_TAG_member
.dwattr $C$DW$1559, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1559, DW_AT_name("EchoThreshold")
.dwattr $C$DW$1559, DW_AT_TI_symbol_name("EchoThreshold")
.dwattr $C$DW$1559, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$1559, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1559, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1559, DW_AT_decl_line(0x4de)
.dwattr $C$DW$1559, DW_AT_decl_column(0x05)
$C$DW$1560 .dwtag DW_TAG_member
.dwattr $C$DW$1560, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1560, DW_AT_name("ColorThreshold")
.dwattr $C$DW$1560, DW_AT_TI_symbol_name("ColorThreshold")
.dwattr $C$DW$1560, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$1560, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1560, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1560, DW_AT_decl_line(0x4df)
.dwattr $C$DW$1560, DW_AT_decl_column(0x05)
$C$DW$1561 .dwtag DW_TAG_member
.dwattr $C$DW$1561, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1561, DW_AT_name("InputRate")
.dwattr $C$DW$1561, DW_AT_TI_symbol_name("InputRate")
.dwattr $C$DW$1561, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$1561, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1561, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1561, DW_AT_decl_line(0x4e0)
.dwattr $C$DW$1561, DW_AT_decl_column(0x05)
$C$DW$1562 .dwtag DW_TAG_member
.dwattr $C$DW$1562, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1562, DW_AT_name("OutputRate")
.dwattr $C$DW$1562, DW_AT_TI_symbol_name("OutputRate")
.dwattr $C$DW$1562, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$1562, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1562, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1562, DW_AT_decl_line(0x4e1)
.dwattr $C$DW$1562, DW_AT_decl_column(0x05)
$C$DW$1563 .dwtag DW_TAG_member
.dwattr $C$DW$1563, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1563, DW_AT_name("persistence")
.dwattr $C$DW$1563, DW_AT_TI_symbol_name("persistence")
.dwattr $C$DW$1563, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$1563, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1563, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1563, DW_AT_decl_line(0x4e2)
.dwattr $C$DW$1563, DW_AT_decl_column(0x05)
$C$DW$1564 .dwtag DW_TAG_member
.dwattr $C$DW$1564, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1564, DW_AT_name("ColorEstimateDoubling")
.dwattr $C$DW$1564, DW_AT_TI_symbol_name("ColorEstimateDoubling")
.dwattr $C$DW$1564, DW_AT_data_member_location[DW_OP_plus_uconst 0x68]
.dwattr $C$DW$1564, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1564, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1564, DW_AT_decl_line(0x4e3)
.dwattr $C$DW$1564, DW_AT_decl_column(0x05)
$C$DW$1565 .dwtag DW_TAG_member
.dwattr $C$DW$1565, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1565, DW_AT_name("ColorEstimateStart")
.dwattr $C$DW$1565, DW_AT_TI_symbol_name("ColorEstimateStart")
.dwattr $C$DW$1565, DW_AT_data_member_location[DW_OP_plus_uconst 0x70]
.dwattr $C$DW$1565, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1565, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1565, DW_AT_decl_line(0x4e4)
.dwattr $C$DW$1565, DW_AT_decl_column(0x05)
$C$DW$1566 .dwtag DW_TAG_member
.dwattr $C$DW$1566, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1566, DW_AT_name("logPwrThreshLower")
.dwattr $C$DW$1566, DW_AT_TI_symbol_name("logPwrThreshLower")
.dwattr $C$DW$1566, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$1566, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1566, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1566, DW_AT_decl_line(0x4e5)
.dwattr $C$DW$1566, DW_AT_decl_column(0x05)
$C$DW$1567 .dwtag DW_TAG_member
.dwattr $C$DW$1567, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1567, DW_AT_name("invLogPwrTaperRngM")
.dwattr $C$DW$1567, DW_AT_TI_symbol_name("invLogPwrTaperRngM")
.dwattr $C$DW$1567, DW_AT_data_member_location[DW_OP_plus_uconst 0x80]
.dwattr $C$DW$1567, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1567, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1567, DW_AT_decl_line(0x4e6)
.dwattr $C$DW$1567, DW_AT_decl_column(0x05)
$C$DW$1568 .dwtag DW_TAG_member
.dwattr $C$DW$1568, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1568, DW_AT_name("invLogPwrTaperRngE")
.dwattr $C$DW$1568, DW_AT_TI_symbol_name("invLogPwrTaperRngE")
.dwattr $C$DW$1568, DW_AT_data_member_location[DW_OP_plus_uconst 0x88]
.dwattr $C$DW$1568, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1568, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1568, DW_AT_decl_line(0x4e7)
.dwattr $C$DW$1568, DW_AT_decl_column(0x05)
$C$DW$1569 .dwtag DW_TAG_member
.dwattr $C$DW$1569, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1569, DW_AT_name("logRatioThreshLower")
.dwattr $C$DW$1569, DW_AT_TI_symbol_name("logRatioThreshLower")
.dwattr $C$DW$1569, DW_AT_data_member_location[DW_OP_plus_uconst 0x90]
.dwattr $C$DW$1569, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1569, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1569, DW_AT_decl_line(0x4e8)
.dwattr $C$DW$1569, DW_AT_decl_column(0x05)
$C$DW$1570 .dwtag DW_TAG_member
.dwattr $C$DW$1570, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1570, DW_AT_name("invLogRatioTaperRngM")
.dwattr $C$DW$1570, DW_AT_TI_symbol_name("invLogRatioTaperRngM")
.dwattr $C$DW$1570, DW_AT_data_member_location[DW_OP_plus_uconst 0x98]
.dwattr $C$DW$1570, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1570, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1570, DW_AT_decl_line(0x4e9)
.dwattr $C$DW$1570, DW_AT_decl_column(0x05)
$C$DW$1571 .dwtag DW_TAG_member
.dwattr $C$DW$1571, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1571, DW_AT_name("invLogRatioTaperRngE")
.dwattr $C$DW$1571, DW_AT_TI_symbol_name("invLogRatioTaperRngE")
.dwattr $C$DW$1571, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0]
.dwattr $C$DW$1571, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1571, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1571, DW_AT_decl_line(0x4ea)
.dwattr $C$DW$1571, DW_AT_decl_column(0x05)
$C$DW$1572 .dwtag DW_TAG_member
.dwattr $C$DW$1572, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1572, DW_AT_name("graphicsHeight")
.dwattr $C$DW$1572, DW_AT_TI_symbol_name("graphicsHeight")
.dwattr $C$DW$1572, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8]
.dwattr $C$DW$1572, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1572, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1572, DW_AT_decl_line(0x4eb)
.dwattr $C$DW$1572, DW_AT_decl_column(0x05)
$C$DW$1573 .dwtag DW_TAG_member
.dwattr $C$DW$1573, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1573, DW_AT_name("graphicsWidth")
.dwattr $C$DW$1573, DW_AT_TI_symbol_name("graphicsWidth")
.dwattr $C$DW$1573, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0]
.dwattr $C$DW$1573, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1573, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1573, DW_AT_decl_line(0x4ec)
.dwattr $C$DW$1573, DW_AT_decl_column(0x05)
$C$DW$1574 .dwtag DW_TAG_member
.dwattr $C$DW$1574, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1574, DW_AT_name("VarianceOn")
.dwattr $C$DW$1574, DW_AT_TI_symbol_name("VarianceOn")
.dwattr $C$DW$1574, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8]
.dwattr $C$DW$1574, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1574, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1574, DW_AT_decl_line(0x4ed)
.dwattr $C$DW$1574, DW_AT_decl_column(0x05)
$C$DW$1575 .dwtag DW_TAG_member
.dwattr $C$DW$1575, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$1575, DW_AT_name("pCMModeKernel")
.dwattr $C$DW$1575, DW_AT_TI_symbol_name("pCMModeKernel")
.dwattr $C$DW$1575, DW_AT_data_member_location[DW_OP_plus_uconst 0xc0]
.dwattr $C$DW$1575, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1575, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1575, DW_AT_decl_line(0x4ee)
.dwattr $C$DW$1575, DW_AT_decl_column(0x05)
$C$DW$1576 .dwtag DW_TAG_member
.dwattr $C$DW$1576, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1576, DW_AT_name("numLinesForAvg")
.dwattr $C$DW$1576, DW_AT_TI_symbol_name("numLinesForAvg")
.dwattr $C$DW$1576, DW_AT_data_member_location[DW_OP_plus_uconst 0xc8]
.dwattr $C$DW$1576, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1576, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1576, DW_AT_decl_line(0x4ef)
.dwattr $C$DW$1576, DW_AT_decl_column(0x05)
$C$DW$1577 .dwtag DW_TAG_member
.dwattr $C$DW$1577, DW_AT_type(*$C$DW$T$135)
.dwattr $C$DW$1577, DW_AT_name("amm")
.dwattr $C$DW$1577, DW_AT_TI_symbol_name("amm")
.dwattr $C$DW$1577, DW_AT_data_member_location[DW_OP_plus_uconst 0xd0]
.dwattr $C$DW$1577, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1577, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1577, DW_AT_decl_line(0x4f1)
.dwattr $C$DW$1577, DW_AT_decl_column(0x05)
$C$DW$1578 .dwtag DW_TAG_member
.dwattr $C$DW$1578, DW_AT_type(*$C$DW$T$137)
.dwattr $C$DW$1578, DW_AT_name("reserved")
.dwattr $C$DW$1578, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1578, DW_AT_data_member_location[DW_OP_plus_uconst 0xf0]
.dwattr $C$DW$1578, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1578, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1578, DW_AT_decl_line(0x4f2)
.dwattr $C$DW$1578, DW_AT_decl_column(0x05)
$C$DW$69 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$69, DW_AT_declaration
.dwattr $C$DW$69, DW_AT_TI_symbol_name("_ZN11MMode_ParamaSERKS_")
.dwattr $C$DW$69, DW_AT_type(*$C$DW$T$138)
.dwattr $C$DW$69, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1579 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1579, DW_AT_type(*$C$DW$T$140)
.dwendtag $C$DW$69
.dwendtag $C$DW$T$142
.dwattr $C$DW$T$142, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$142, DW_AT_decl_line(0x4d5)
.dwattr $C$DW$T$142, DW_AT_decl_column(0x01)
$C$DW$T$139 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$139, DW_AT_type(*$C$DW$T$142)
$C$DW$T$140 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$140, DW_AT_type(*$C$DW$T$139)
.dwattr $C$DW$T$140, DW_AT_address_class(0x20)
$C$DW$T$1594 .dwtag DW_TAG_typedef, DW_AT_name("MMode_Param")
.dwattr $C$DW$T$1594, DW_AT_type(*$C$DW$T$142)
.dwattr $C$DW$T$1594, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1594, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1594, DW_AT_decl_line(0x4f3)
.dwattr $C$DW$T$1594, DW_AT_decl_column(0x03)
$C$DW$T$138 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$138, DW_AT_type(*$C$DW$T$142)
.dwattr $C$DW$T$138, DW_AT_address_class(0x20)
$C$DW$T$141 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$141, DW_AT_type(*$C$DW$T$138)
.dwattr $C$DW$T$141, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1580 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1580, DW_AT_type(*$C$DW$T$140)
.dwendtag $C$DW$T$141
$C$DW$T$332 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$332, DW_AT_name("M_Test")
.dwattr $C$DW$T$332, DW_AT_byte_size(0x0c)
$C$DW$1581 .dwtag DW_TAG_member
.dwattr $C$DW$1581, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1581, DW_AT_name("inputClockPeriodMSec")
.dwattr $C$DW$1581, DW_AT_TI_symbol_name("inputClockPeriodMSec")
.dwattr $C$DW$1581, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1581, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1581, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$1581, DW_AT_decl_line(0x17f)
.dwattr $C$DW$1581, DW_AT_decl_column(0x0c)
$C$DW$1582 .dwtag DW_TAG_member
.dwattr $C$DW$1582, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1582, DW_AT_name("outputClockPeriodMSec")
.dwattr $C$DW$1582, DW_AT_TI_symbol_name("outputClockPeriodMSec")
.dwattr $C$DW$1582, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1582, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1582, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$1582, DW_AT_decl_line(0x180)
.dwattr $C$DW$1582, DW_AT_decl_column(0x0c)
$C$DW$1583 .dwtag DW_TAG_member
.dwattr $C$DW$1583, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1583, DW_AT_name("numInputMessages")
.dwattr $C$DW$1583, DW_AT_TI_symbol_name("numInputMessages")
.dwattr $C$DW$1583, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1583, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1583, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$1583, DW_AT_decl_line(0x181)
.dwattr $C$DW$1583, DW_AT_decl_column(0x0c)
$C$DW$70 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$70, DW_AT_declaration
.dwattr $C$DW$70, DW_AT_TI_symbol_name("_ZN6M_TestaSERKS_")
.dwattr $C$DW$70, DW_AT_type(*$C$DW$T$328)
.dwattr $C$DW$70, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1584 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1584, DW_AT_type(*$C$DW$T$330)
.dwendtag $C$DW$70
.dwendtag $C$DW$T$332
.dwattr $C$DW$T$332, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$T$332, DW_AT_decl_line(0x17e)
.dwattr $C$DW$T$332, DW_AT_decl_column(0x10)
$C$DW$T$329 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$329, DW_AT_type(*$C$DW$T$332)
$C$DW$T$330 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$330, DW_AT_type(*$C$DW$T$329)
.dwattr $C$DW$T$330, DW_AT_address_class(0x20)
$C$DW$T$1605 .dwtag DW_TAG_typedef, DW_AT_name("M_Test")
.dwattr $C$DW$T$1605, DW_AT_type(*$C$DW$T$332)
.dwattr $C$DW$T$1605, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1605, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$T$1605, DW_AT_decl_line(0x182)
.dwattr $C$DW$T$1605, DW_AT_decl_column(0x03)
$C$DW$T$328 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$328, DW_AT_type(*$C$DW$T$332)
.dwattr $C$DW$T$328, DW_AT_address_class(0x20)
$C$DW$T$331 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$331, DW_AT_type(*$C$DW$T$328)
.dwattr $C$DW$T$331, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1585 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1585, DW_AT_type(*$C$DW$T$330)
.dwendtag $C$DW$T$331
$C$DW$T$370 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$370, DW_AT_name("MainCtlrData")
.dwattr $C$DW$T$370, DW_AT_byte_size(0x08)
$C$DW$1586 .dwtag DW_TAG_member
.dwattr $C$DW$1586, DW_AT_type(*$C$DW$T$363)
.dwattr $C$DW$1586, DW_AT_name("senderId")
.dwattr $C$DW$1586, DW_AT_TI_symbol_name("senderId")
.dwattr $C$DW$1586, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1586, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1586, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1586, DW_AT_decl_line(0x5c)
.dwattr $C$DW$1586, DW_AT_decl_column(0x10)
$C$DW$1587 .dwtag DW_TAG_member
.dwattr $C$DW$1587, DW_AT_type(*$C$DW$T$365)
.dwattr $C$DW$1587, DW_AT_name("borrowerId")
.dwattr $C$DW$1587, DW_AT_TI_symbol_name("borrowerId")
.dwattr $C$DW$1587, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1587, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1587, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1587, DW_AT_decl_line(0x5d)
.dwattr $C$DW$1587, DW_AT_decl_column(0x1c)
$C$DW$71 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$71, DW_AT_declaration
.dwattr $C$DW$71, DW_AT_TI_symbol_name("_ZN12MainCtlrDataaSERKS_")
.dwattr $C$DW$71, DW_AT_type(*$C$DW$T$366)
.dwattr $C$DW$71, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1588 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1588, DW_AT_type(*$C$DW$T$368)
.dwendtag $C$DW$71
.dwendtag $C$DW$T$370
.dwattr $C$DW$T$370, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$370, DW_AT_decl_line(0x5b)
.dwattr $C$DW$T$370, DW_AT_decl_column(0x01)
$C$DW$T$367 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$367, DW_AT_type(*$C$DW$T$370)
$C$DW$T$368 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$368, DW_AT_type(*$C$DW$T$367)
.dwattr $C$DW$T$368, DW_AT_address_class(0x20)
$C$DW$T$1471 .dwtag DW_TAG_typedef, DW_AT_name("MainCtlrData")
.dwattr $C$DW$T$1471, DW_AT_type(*$C$DW$T$370)
.dwattr $C$DW$T$1471, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1471, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1471, DW_AT_decl_line(0x5e)
.dwattr $C$DW$T$1471, DW_AT_decl_column(0x03)
$C$DW$T$366 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$366, DW_AT_type(*$C$DW$T$370)
.dwattr $C$DW$T$366, DW_AT_address_class(0x20)
$C$DW$T$369 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$369, DW_AT_type(*$C$DW$T$366)
.dwattr $C$DW$T$369, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1589 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1589, DW_AT_type(*$C$DW$T$368)
.dwendtag $C$DW$T$369
$C$DW$T$505 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$505, DW_AT_name("McMgr_CbufBundle")
.dwattr $C$DW$T$505, DW_AT_byte_size(0x88)
$C$DW$1590 .dwtag DW_TAG_member
.dwattr $C$DW$1590, DW_AT_type(*$C$DW$T$500)
.dwattr $C$DW$1590, DW_AT_name("inCBuf")
.dwattr $C$DW$1590, DW_AT_TI_symbol_name("inCBuf")
.dwattr $C$DW$1590, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1590, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1590, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1590, DW_AT_decl_line(0x147)
.dwattr $C$DW$1590, DW_AT_decl_column(0x19)
$C$DW$1591 .dwtag DW_TAG_member
.dwattr $C$DW$1591, DW_AT_type(*$C$DW$T$500)
.dwattr $C$DW$1591, DW_AT_name("outCBuf")
.dwattr $C$DW$1591, DW_AT_TI_symbol_name("outCBuf")
.dwattr $C$DW$1591, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$1591, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1591, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1591, DW_AT_decl_line(0x148)
.dwattr $C$DW$1591, DW_AT_decl_column(0x19)
$C$DW$1592 .dwtag DW_TAG_member
.dwattr $C$DW$1592, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1592, DW_AT_name("numInCBuf")
.dwattr $C$DW$1592, DW_AT_TI_symbol_name("numInCBuf")
.dwattr $C$DW$1592, DW_AT_data_member_location[DW_OP_plus_uconst 0x80]
.dwattr $C$DW$1592, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1592, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1592, DW_AT_decl_line(0x149)
.dwattr $C$DW$1592, DW_AT_decl_column(0x13)
$C$DW$1593 .dwtag DW_TAG_member
.dwattr $C$DW$1593, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1593, DW_AT_name("numOutCBuf")
.dwattr $C$DW$1593, DW_AT_TI_symbol_name("numOutCBuf")
.dwattr $C$DW$1593, DW_AT_data_member_location[DW_OP_plus_uconst 0x84]
.dwattr $C$DW$1593, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1593, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1593, DW_AT_decl_line(0x14a)
.dwattr $C$DW$1593, DW_AT_decl_column(0x13)
$C$DW$72 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$72, DW_AT_declaration
.dwattr $C$DW$72, DW_AT_TI_symbol_name("_ZN16McMgr_CbufBundleaSERKS_")
.dwattr $C$DW$72, DW_AT_type(*$C$DW$T$501)
.dwattr $C$DW$72, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1594 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1594, DW_AT_type(*$C$DW$T$503)
.dwendtag $C$DW$72
.dwendtag $C$DW$T$505
.dwattr $C$DW$T$505, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$505, DW_AT_decl_line(0x146)
.dwattr $C$DW$T$505, DW_AT_decl_column(0x01)
$C$DW$T$502 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$502, DW_AT_type(*$C$DW$T$505)
$C$DW$T$503 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$503, DW_AT_type(*$C$DW$T$502)
.dwattr $C$DW$T$503, DW_AT_address_class(0x20)
$C$DW$T$506 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CbufBundle")
.dwattr $C$DW$T$506, DW_AT_type(*$C$DW$T$505)
.dwattr $C$DW$T$506, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$506, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$506, DW_AT_decl_line(0x14b)
.dwattr $C$DW$T$506, DW_AT_decl_column(0x03)
$C$DW$T$501 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$501, DW_AT_type(*$C$DW$T$505)
.dwattr $C$DW$T$501, DW_AT_address_class(0x20)
$C$DW$T$504 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$504, DW_AT_type(*$C$DW$T$501)
.dwattr $C$DW$T$504, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1595 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1595, DW_AT_type(*$C$DW$T$503)
.dwendtag $C$DW$T$504
$C$DW$T$517 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$517, DW_AT_name("McMgr_CmdEntries")
.dwattr $C$DW$T$517, DW_AT_byte_size(0xc0)
$C$DW$1596 .dwtag DW_TAG_member
.dwattr $C$DW$1596, DW_AT_type(*$C$DW$T$454)
.dwattr $C$DW$1596, DW_AT_name("command")
.dwattr $C$DW$1596, DW_AT_TI_symbol_name("command")
.dwattr $C$DW$1596, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1596, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1596, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1596, DW_AT_decl_line(0x14f)
.dwattr $C$DW$1596, DW_AT_decl_column(0x19)
$C$DW$1597 .dwtag DW_TAG_member
.dwattr $C$DW$1597, DW_AT_type(*$C$DW$T$506)
.dwattr $C$DW$1597, DW_AT_name("cbufBundle")
.dwattr $C$DW$1597, DW_AT_TI_symbol_name("cbufBundle")
.dwattr $C$DW$1597, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1597, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1597, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1597, DW_AT_decl_line(0x150)
.dwattr $C$DW$1597, DW_AT_decl_column(0x19)
$C$DW$1598 .dwtag DW_TAG_member
.dwattr $C$DW$1598, DW_AT_type(*$C$DW$T$508)
.dwattr $C$DW$1598, DW_AT_name("coreAssign")
.dwattr $C$DW$1598, DW_AT_TI_symbol_name("coreAssign")
.dwattr $C$DW$1598, DW_AT_data_member_location[DW_OP_plus_uconst 0x90]
.dwattr $C$DW$1598, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1598, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1598, DW_AT_decl_line(0x158)
.dwattr $C$DW$1598, DW_AT_decl_column(0x19)
$C$DW$1599 .dwtag DW_TAG_member
.dwattr $C$DW$1599, DW_AT_type(*$C$DW$T$456)
.dwattr $C$DW$1599, DW_AT_name("isCineData")
.dwattr $C$DW$1599, DW_AT_TI_symbol_name("isCineData")
.dwattr $C$DW$1599, DW_AT_data_member_location[DW_OP_plus_uconst 0x94]
.dwattr $C$DW$1599, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1599, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1599, DW_AT_decl_line(0x159)
.dwattr $C$DW$1599, DW_AT_decl_column(0x19)
$C$DW$1600 .dwtag DW_TAG_member
.dwattr $C$DW$1600, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1600, DW_AT_name("cineOutDelay")
.dwattr $C$DW$1600, DW_AT_TI_symbol_name("cineOutDelay")
.dwattr $C$DW$1600, DW_AT_data_member_location[DW_OP_plus_uconst 0x98]
.dwattr $C$DW$1600, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1600, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1600, DW_AT_decl_line(0x15e)
.dwattr $C$DW$1600, DW_AT_decl_column(0x19)
$C$DW$1601 .dwtag DW_TAG_member
.dwattr $C$DW$1601, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$1601, DW_AT_name("timeStarted")
.dwattr $C$DW$1601, DW_AT_TI_symbol_name("timeStarted")
.dwattr $C$DW$1601, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0]
.dwattr $C$DW$1601, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1601, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1601, DW_AT_decl_line(0x15f)
.dwattr $C$DW$1601, DW_AT_decl_column(0x19)
$C$DW$1602 .dwtag DW_TAG_member
.dwattr $C$DW$1602, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1602, DW_AT_name("timeDuration")
.dwattr $C$DW$1602, DW_AT_TI_symbol_name("timeDuration")
.dwattr $C$DW$1602, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8]
.dwattr $C$DW$1602, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1602, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1602, DW_AT_decl_line(0x160)
.dwattr $C$DW$1602, DW_AT_decl_column(0x19)
$C$DW$1603 .dwtag DW_TAG_member
.dwattr $C$DW$1603, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1603, DW_AT_name("timeProcessed")
.dwattr $C$DW$1603, DW_AT_TI_symbol_name("timeProcessed")
.dwattr $C$DW$1603, DW_AT_data_member_location[DW_OP_plus_uconst 0xac]
.dwattr $C$DW$1603, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1603, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1603, DW_AT_decl_line(0x161)
.dwattr $C$DW$1603, DW_AT_decl_column(0x19)
$C$DW$1604 .dwtag DW_TAG_member
.dwattr $C$DW$1604, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1604, DW_AT_name("inputSeqId")
.dwattr $C$DW$1604, DW_AT_TI_symbol_name("inputSeqId")
.dwattr $C$DW$1604, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0]
.dwattr $C$DW$1604, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1604, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1604, DW_AT_decl_line(0x162)
.dwattr $C$DW$1604, DW_AT_decl_column(0x19)
$C$DW$1605 .dwtag DW_TAG_member
.dwattr $C$DW$1605, DW_AT_type(*$C$DW$T$510)
.dwattr $C$DW$1605, DW_AT_name("spDataType")
.dwattr $C$DW$1605, DW_AT_TI_symbol_name("spDataType")
.dwattr $C$DW$1605, DW_AT_data_member_location[DW_OP_plus_uconst 0xb4]
.dwattr $C$DW$1605, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1605, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1605, DW_AT_decl_line(0x163)
.dwattr $C$DW$1605, DW_AT_decl_column(0x19)
$C$DW$1606 .dwtag DW_TAG_member
.dwattr $C$DW$1606, DW_AT_type(*$C$DW$T$512)
.dwattr $C$DW$1606, DW_AT_name("entryStatus")
.dwattr $C$DW$1606, DW_AT_TI_symbol_name("entryStatus")
.dwattr $C$DW$1606, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8]
.dwattr $C$DW$1606, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1606, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1606, DW_AT_decl_line(0x164)
.dwattr $C$DW$1606, DW_AT_decl_column(0x19)
$C$DW$1607 .dwtag DW_TAG_member
.dwattr $C$DW$1607, DW_AT_type(*$C$DW$T$456)
.dwattr $C$DW$1607, DW_AT_name("updateParam")
.dwattr $C$DW$1607, DW_AT_TI_symbol_name("updateParam")
.dwattr $C$DW$1607, DW_AT_data_member_location[DW_OP_plus_uconst 0xbc]
.dwattr $C$DW$1607, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1607, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1607, DW_AT_decl_line(0x165)
.dwattr $C$DW$1607, DW_AT_decl_column(0x19)
$C$DW$73 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$73, DW_AT_declaration
.dwattr $C$DW$73, DW_AT_TI_symbol_name("_ZN16McMgr_CmdEntriesaSERKS_")
.dwattr $C$DW$73, DW_AT_type(*$C$DW$T$513)
.dwattr $C$DW$73, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1608 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1608, DW_AT_type(*$C$DW$T$515)
.dwendtag $C$DW$73
.dwendtag $C$DW$T$517
.dwattr $C$DW$T$517, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$517, DW_AT_decl_line(0x14e)
.dwattr $C$DW$T$517, DW_AT_decl_column(0x01)
$C$DW$T$514 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$514, DW_AT_type(*$C$DW$T$517)
$C$DW$T$515 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$515, DW_AT_type(*$C$DW$T$514)
.dwattr $C$DW$T$515, DW_AT_address_class(0x20)
$C$DW$T$1924 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CmdEntries")
.dwattr $C$DW$T$1924, DW_AT_type(*$C$DW$T$517)
.dwattr $C$DW$T$1924, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1924, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1924, DW_AT_decl_line(0x167)
.dwattr $C$DW$T$1924, DW_AT_decl_column(0x03)
$C$DW$T$513 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$513, DW_AT_type(*$C$DW$T$517)
.dwattr $C$DW$T$513, DW_AT_address_class(0x20)
$C$DW$T$516 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$516, DW_AT_type(*$C$DW$T$513)
.dwattr $C$DW$T$516, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1609 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1609, DW_AT_type(*$C$DW$T$515)
.dwendtag $C$DW$T$516
$C$DW$T$527 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$527, DW_AT_name("McMgr_CmdProperties")
.dwattr $C$DW$T$527, DW_AT_byte_size(0x4c)
$C$DW$1610 .dwtag DW_TAG_member
.dwattr $C$DW$1610, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1610, DW_AT_name("coreCompatible")
.dwattr $C$DW$1610, DW_AT_TI_symbol_name("coreCompatible")
.dwattr $C$DW$1610, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1610, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1610, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1610, DW_AT_decl_line(0x16b)
.dwattr $C$DW$1610, DW_AT_decl_column(0x19)
$C$DW$1611 .dwtag DW_TAG_member
.dwattr $C$DW$1611, DW_AT_type(*$C$DW$T$518)
.dwattr $C$DW$1611, DW_AT_name("inputCmd")
.dwattr $C$DW$1611, DW_AT_TI_symbol_name("inputCmd")
.dwattr $C$DW$1611, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1611, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1611, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1611, DW_AT_decl_line(0x16c)
.dwattr $C$DW$1611, DW_AT_decl_column(0x19)
$C$DW$1612 .dwtag DW_TAG_member
.dwattr $C$DW$1612, DW_AT_type(*$C$DW$T$518)
.dwattr $C$DW$1612, DW_AT_name("outputCmd")
.dwattr $C$DW$1612, DW_AT_TI_symbol_name("outputCmd")
.dwattr $C$DW$1612, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1612, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1612, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1612, DW_AT_decl_line(0x16d)
.dwattr $C$DW$1612, DW_AT_decl_column(0x19)
$C$DW$1613 .dwtag DW_TAG_member
.dwattr $C$DW$1613, DW_AT_type(*$C$DW$T$519)
.dwattr $C$DW$1613, DW_AT_name("triggerCmdAccumulatedCntQ15")
.dwattr $C$DW$1613, DW_AT_TI_symbol_name("triggerCmdAccumulatedCntQ15")
.dwattr $C$DW$1613, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1613, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1613, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1613, DW_AT_decl_line(0x16e)
.dwattr $C$DW$1613, DW_AT_decl_column(0x19)
$C$DW$1614 .dwtag DW_TAG_member
.dwattr $C$DW$1614, DW_AT_type(*$C$DW$T$520)
.dwattr $C$DW$1614, DW_AT_name("triggerCmdIncrCntQ15")
.dwattr $C$DW$1614, DW_AT_TI_symbol_name("triggerCmdIncrCntQ15")
.dwattr $C$DW$1614, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c]
.dwattr $C$DW$1614, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1614, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1614, DW_AT_decl_line(0x16f)
.dwattr $C$DW$1614, DW_AT_decl_column(0x19)
$C$DW$1615 .dwtag DW_TAG_member
.dwattr $C$DW$1615, DW_AT_type(*$C$DW$T$520)
.dwattr $C$DW$1615, DW_AT_name("triggerCmdMaxCntQ15")
.dwattr $C$DW$1615, DW_AT_TI_symbol_name("triggerCmdMaxCntQ15")
.dwattr $C$DW$1615, DW_AT_data_member_location[DW_OP_plus_uconst 0x24]
.dwattr $C$DW$1615, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1615, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1615, DW_AT_decl_line(0x170)
.dwattr $C$DW$1615, DW_AT_decl_column(0x19)
$C$DW$1616 .dwtag DW_TAG_member
.dwattr $C$DW$1616, DW_AT_type(*$C$DW$T$522)
.dwattr $C$DW$1616, DW_AT_name("inCBuf")
.dwattr $C$DW$1616, DW_AT_TI_symbol_name("inCBuf")
.dwattr $C$DW$1616, DW_AT_data_member_location[DW_OP_plus_uconst 0x2c]
.dwattr $C$DW$1616, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1616, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1616, DW_AT_decl_line(0x172)
.dwattr $C$DW$1616, DW_AT_decl_column(0x19)
$C$DW$1617 .dwtag DW_TAG_member
.dwattr $C$DW$1617, DW_AT_type(*$C$DW$T$522)
.dwattr $C$DW$1617, DW_AT_name("outCBuf")
.dwattr $C$DW$1617, DW_AT_TI_symbol_name("outCBuf")
.dwattr $C$DW$1617, DW_AT_data_member_location[DW_OP_plus_uconst 0x34]
.dwattr $C$DW$1617, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1617, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1617, DW_AT_decl_line(0x173)
.dwattr $C$DW$1617, DW_AT_decl_column(0x19)
$C$DW$1618 .dwtag DW_TAG_member
.dwattr $C$DW$1618, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1618, DW_AT_name("numInCmd")
.dwattr $C$DW$1618, DW_AT_TI_symbol_name("numInCmd")
.dwattr $C$DW$1618, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c]
.dwattr $C$DW$1618, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1618, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1618, DW_AT_decl_line(0x175)
.dwattr $C$DW$1618, DW_AT_decl_column(0x13)
$C$DW$1619 .dwtag DW_TAG_member
.dwattr $C$DW$1619, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1619, DW_AT_name("numOutCmd")
.dwattr $C$DW$1619, DW_AT_TI_symbol_name("numOutCmd")
.dwattr $C$DW$1619, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$1619, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1619, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1619, DW_AT_decl_line(0x176)
.dwattr $C$DW$1619, DW_AT_decl_column(0x13)
$C$DW$1620 .dwtag DW_TAG_member
.dwattr $C$DW$1620, DW_AT_type(*$C$DW$T$521)
.dwattr $C$DW$1620, DW_AT_name("inCBufAtStop")
.dwattr $C$DW$1620, DW_AT_TI_symbol_name("inCBufAtStop")
.dwattr $C$DW$1620, DW_AT_data_member_location[DW_OP_plus_uconst 0x44]
.dwattr $C$DW$1620, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1620, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1620, DW_AT_decl_line(0x178)
.dwattr $C$DW$1620, DW_AT_decl_column(0x1a)
$C$DW$1621 .dwtag DW_TAG_member
.dwattr $C$DW$1621, DW_AT_type(*$C$DW$T$521)
.dwattr $C$DW$1621, DW_AT_name("outCBufAtStop")
.dwattr $C$DW$1621, DW_AT_TI_symbol_name("outCBufAtStop")
.dwattr $C$DW$1621, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$1621, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1621, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1621, DW_AT_decl_line(0x179)
.dwattr $C$DW$1621, DW_AT_decl_column(0x1a)
$C$DW$74 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$74, DW_AT_declaration
.dwattr $C$DW$74, DW_AT_TI_symbol_name("_ZN19McMgr_CmdPropertiesaSERKS_")
.dwattr $C$DW$74, DW_AT_type(*$C$DW$T$523)
.dwattr $C$DW$74, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1622 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1622, DW_AT_type(*$C$DW$T$525)
.dwendtag $C$DW$74
.dwendtag $C$DW$T$527
.dwattr $C$DW$T$527, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$527, DW_AT_decl_line(0x16a)
.dwattr $C$DW$T$527, DW_AT_decl_column(0x01)
$C$DW$T$524 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$524, DW_AT_type(*$C$DW$T$527)
$C$DW$T$525 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$525, DW_AT_type(*$C$DW$T$524)
.dwattr $C$DW$T$525, DW_AT_address_class(0x20)
$C$DW$T$1925 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CmdProperties")
.dwattr $C$DW$T$1925, DW_AT_type(*$C$DW$T$527)
.dwattr $C$DW$T$1925, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1925, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1925, DW_AT_decl_line(0x17a)
.dwattr $C$DW$T$1925, DW_AT_decl_column(0x02)
$C$DW$T$523 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$523, DW_AT_type(*$C$DW$T$527)
.dwattr $C$DW$T$523, DW_AT_address_class(0x20)
$C$DW$T$526 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$526, DW_AT_type(*$C$DW$T$523)
.dwattr $C$DW$T$526, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1623 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1623, DW_AT_type(*$C$DW$T$525)
.dwendtag $C$DW$T$526
$C$DW$T$532 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$532, DW_AT_name("McMgr_CmdSetup")
.dwattr $C$DW$T$532, DW_AT_byte_size(0x20)
$C$DW$1624 .dwtag DW_TAG_member
.dwattr $C$DW$1624, DW_AT_type(*$C$DW$T$454)
.dwattr $C$DW$1624, DW_AT_name("command")
.dwattr $C$DW$1624, DW_AT_TI_symbol_name("command")
.dwattr $C$DW$1624, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1624, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1624, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1624, DW_AT_decl_line(0x17f)
.dwattr $C$DW$1624, DW_AT_decl_column(0x19)
$C$DW$1625 .dwtag DW_TAG_member
.dwattr $C$DW$1625, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1625, DW_AT_name("numInCmd")
.dwattr $C$DW$1625, DW_AT_TI_symbol_name("numInCmd")
.dwattr $C$DW$1625, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1625, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1625, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1625, DW_AT_decl_line(0x182)
.dwattr $C$DW$1625, DW_AT_decl_column(0x0c)
$C$DW$1626 .dwtag DW_TAG_member
.dwattr $C$DW$1626, DW_AT_type(*$C$DW$T$520)
.dwattr $C$DW$1626, DW_AT_name("inDataPacketSze")
.dwattr $C$DW$1626, DW_AT_TI_symbol_name("inDataPacketSze")
.dwattr $C$DW$1626, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1626, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1626, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1626, DW_AT_decl_line(0x185)
.dwattr $C$DW$1626, DW_AT_decl_column(0x0e)
$C$DW$1627 .dwtag DW_TAG_member
.dwattr $C$DW$1627, DW_AT_type(*$C$DW$T$520)
.dwattr $C$DW$1627, DW_AT_name("numInDataPacket")
.dwattr $C$DW$1627, DW_AT_TI_symbol_name("numInDataPacket")
.dwattr $C$DW$1627, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1627, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1627, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1627, DW_AT_decl_line(0x186)
.dwattr $C$DW$1627, DW_AT_decl_column(0x0e)
$C$DW$1628 .dwtag DW_TAG_member
.dwattr $C$DW$1628, DW_AT_type(*$C$DW$T$518)
.dwattr $C$DW$1628, DW_AT_name("inputCmd")
.dwattr $C$DW$1628, DW_AT_TI_symbol_name("inputCmd")
.dwattr $C$DW$1628, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1628, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1628, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1628, DW_AT_decl_line(0x189)
.dwattr $C$DW$1628, DW_AT_decl_column(0x19)
$C$DW$75 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$75, DW_AT_declaration
.dwattr $C$DW$75, DW_AT_TI_symbol_name("_ZN14McMgr_CmdSetupaSERKS_")
.dwattr $C$DW$75, DW_AT_type(*$C$DW$T$528)
.dwattr $C$DW$75, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1629 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1629, DW_AT_type(*$C$DW$T$530)
.dwendtag $C$DW$75
.dwendtag $C$DW$T$532
.dwattr $C$DW$T$532, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$532, DW_AT_decl_line(0x17e)
.dwattr $C$DW$T$532, DW_AT_decl_column(0x01)
$C$DW$T$529 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$529, DW_AT_type(*$C$DW$T$532)
$C$DW$T$530 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$530, DW_AT_type(*$C$DW$T$529)
.dwattr $C$DW$T$530, DW_AT_address_class(0x20)
$C$DW$T$533 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CmdSetup")
.dwattr $C$DW$T$533, DW_AT_type(*$C$DW$T$532)
.dwattr $C$DW$T$533, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$533, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$533, DW_AT_decl_line(0x18a)
.dwattr $C$DW$T$533, DW_AT_decl_column(0x02)
$C$DW$T$534 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$534, DW_AT_type(*$C$DW$T$533)
.dwattr $C$DW$T$534, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$534, DW_AT_byte_size(0x200)
$C$DW$1630 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$1630, DW_AT_upper_bound(0x0f)
.dwendtag $C$DW$T$534
$C$DW$T$528 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$528, DW_AT_type(*$C$DW$T$532)
.dwattr $C$DW$T$528, DW_AT_address_class(0x20)
$C$DW$T$531 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$531, DW_AT_type(*$C$DW$T$528)
.dwattr $C$DW$T$531, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1631 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1631, DW_AT_type(*$C$DW$T$530)
.dwendtag $C$DW$T$531
$C$DW$T$539 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$539, DW_AT_name("McMgr_CmdSetupTbl")
.dwattr $C$DW$T$539, DW_AT_byte_size(0x204)
$C$DW$1632 .dwtag DW_TAG_member
.dwattr $C$DW$1632, DW_AT_type(*$C$DW$T$534)
.dwattr $C$DW$1632, DW_AT_name("cmdProperties")
.dwattr $C$DW$1632, DW_AT_TI_symbol_name("cmdProperties")
.dwattr $C$DW$1632, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1632, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1632, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1632, DW_AT_decl_line(0x18f)
.dwattr $C$DW$1632, DW_AT_decl_column(0x14)
$C$DW$1633 .dwtag DW_TAG_member
.dwattr $C$DW$1633, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1633, DW_AT_name("numCmd")
.dwattr $C$DW$1633, DW_AT_TI_symbol_name("numCmd")
.dwattr $C$DW$1633, DW_AT_data_member_location[DW_OP_plus_uconst 0x200]
.dwattr $C$DW$1633, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1633, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1633, DW_AT_decl_line(0x190)
.dwattr $C$DW$1633, DW_AT_decl_column(0x0c)
$C$DW$76 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$76, DW_AT_declaration
.dwattr $C$DW$76, DW_AT_TI_symbol_name("_ZN17McMgr_CmdSetupTblaSERKS_")
.dwattr $C$DW$76, DW_AT_type(*$C$DW$T$535)
.dwattr $C$DW$76, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1634 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1634, DW_AT_type(*$C$DW$T$537)
.dwendtag $C$DW$76
.dwendtag $C$DW$T$539
.dwattr $C$DW$T$539, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$539, DW_AT_decl_line(0x18e)
.dwattr $C$DW$T$539, DW_AT_decl_column(0x01)
$C$DW$T$536 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$536, DW_AT_type(*$C$DW$T$539)
$C$DW$T$537 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$537, DW_AT_type(*$C$DW$T$536)
.dwattr $C$DW$T$537, DW_AT_address_class(0x20)
$C$DW$T$1926 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CmdSetupTbl")
.dwattr $C$DW$T$1926, DW_AT_type(*$C$DW$T$539)
.dwattr $C$DW$T$1926, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1926, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1926, DW_AT_decl_line(0x191)
.dwattr $C$DW$T$1926, DW_AT_decl_column(0x03)
$C$DW$T$535 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$535, DW_AT_type(*$C$DW$T$539)
.dwattr $C$DW$T$535, DW_AT_address_class(0x20)
$C$DW$T$538 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$538, DW_AT_type(*$C$DW$T$535)
.dwattr $C$DW$T$538, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1635 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1635, DW_AT_type(*$C$DW$T$537)
.dwendtag $C$DW$T$538
$C$DW$T$507 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$507, DW_AT_name("McMgr_CoreIdType")
.dwattr $C$DW$T$507, DW_AT_byte_size(0x04)
$C$DW$1636 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_NONE"), DW_AT_const_value(0x00)
.dwattr $C$DW$1636, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1636, DW_AT_decl_line(0x9c)
.dwattr $C$DW$1636, DW_AT_decl_column(0x05)
$C$DW$1637 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_0"), DW_AT_const_value(0x01)
.dwattr $C$DW$1637, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1637, DW_AT_decl_line(0x9d)
.dwattr $C$DW$1637, DW_AT_decl_column(0x05)
$C$DW$1638 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_1"), DW_AT_const_value(0x02)
.dwattr $C$DW$1638, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1638, DW_AT_decl_line(0x9e)
.dwattr $C$DW$1638, DW_AT_decl_column(0x05)
$C$DW$1639 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_2"), DW_AT_const_value(0x04)
.dwattr $C$DW$1639, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1639, DW_AT_decl_line(0x9f)
.dwattr $C$DW$1639, DW_AT_decl_column(0x05)
$C$DW$1640 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_3"), DW_AT_const_value(0x08)
.dwattr $C$DW$1640, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1640, DW_AT_decl_line(0xa0)
.dwattr $C$DW$1640, DW_AT_decl_column(0x05)
$C$DW$1641 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_4"), DW_AT_const_value(0x10)
.dwattr $C$DW$1641, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1641, DW_AT_decl_line(0xa1)
.dwattr $C$DW$1641, DW_AT_decl_column(0x05)
$C$DW$1642 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_5"), DW_AT_const_value(0x20)
.dwattr $C$DW$1642, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1642, DW_AT_decl_line(0xa2)
.dwattr $C$DW$1642, DW_AT_decl_column(0x05)
$C$DW$1643 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_6"), DW_AT_const_value(0x40)
.dwattr $C$DW$1643, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1643, DW_AT_decl_line(0xa3)
.dwattr $C$DW$1643, DW_AT_decl_column(0x05)
$C$DW$1644 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_7"), DW_AT_const_value(0x80)
.dwattr $C$DW$1644, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1644, DW_AT_decl_line(0xa4)
.dwattr $C$DW$1644, DW_AT_decl_column(0x05)
$C$DW$1645 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_EOL"), DW_AT_const_value(0x81)
.dwattr $C$DW$1645, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1645, DW_AT_decl_line(0xa5)
.dwattr $C$DW$1645, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$507
.dwattr $C$DW$T$507, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$507, DW_AT_decl_line(0x9b)
.dwattr $C$DW$T$507, DW_AT_decl_column(0x01)
$C$DW$T$508 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CoreIdType")
.dwattr $C$DW$T$508, DW_AT_type(*$C$DW$T$507)
.dwattr $C$DW$T$508, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$508, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$508, DW_AT_decl_line(0xa6)
.dwattr $C$DW$T$508, DW_AT_decl_column(0x03)
$C$DW$T$540 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$540, DW_AT_name("McMgr_CoreState")
.dwattr $C$DW$T$540, DW_AT_byte_size(0x04)
$C$DW$1646 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_RESET"), DW_AT_const_value(0x00)
.dwattr $C$DW$1646, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1646, DW_AT_decl_line(0x114)
.dwattr $C$DW$1646, DW_AT_decl_column(0x05)
$C$DW$1647 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_STARTING"), DW_AT_const_value(0x01)
.dwattr $C$DW$1647, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1647, DW_AT_decl_line(0x115)
.dwattr $C$DW$1647, DW_AT_decl_column(0x05)
$C$DW$1648 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_STARTED"), DW_AT_const_value(0x02)
.dwattr $C$DW$1648, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1648, DW_AT_decl_line(0x116)
.dwattr $C$DW$1648, DW_AT_decl_column(0x05)
$C$DW$1649 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_IDLE"), DW_AT_const_value(0x03)
.dwattr $C$DW$1649, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1649, DW_AT_decl_line(0x117)
.dwattr $C$DW$1649, DW_AT_decl_column(0x05)
$C$DW$1650 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_RUN"), DW_AT_const_value(0x04)
.dwattr $C$DW$1650, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1650, DW_AT_decl_line(0x118)
.dwattr $C$DW$1650, DW_AT_decl_column(0x05)
$C$DW$1651 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_PARAM_UPDATING"), DW_AT_const_value(0x05)
.dwattr $C$DW$1651, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1651, DW_AT_decl_line(0x11b)
.dwattr $C$DW$1651, DW_AT_decl_column(0x05)
$C$DW$1652 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_STOPPING"), DW_AT_const_value(0x06)
.dwattr $C$DW$1652, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1652, DW_AT_decl_line(0x11c)
.dwattr $C$DW$1652, DW_AT_decl_column(0x05)
$C$DW$1653 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_STOPPED"), DW_AT_const_value(0x07)
.dwattr $C$DW$1653, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1653, DW_AT_decl_line(0x11d)
.dwattr $C$DW$1653, DW_AT_decl_column(0x05)
$C$DW$1654 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_TERMINATED"), DW_AT_const_value(0x08)
.dwattr $C$DW$1654, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1654, DW_AT_decl_line(0x11f)
.dwattr $C$DW$1654, DW_AT_decl_column(0x05)
$C$DW$1655 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_EOL"), DW_AT_const_value(0x09)
.dwattr $C$DW$1655, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1655, DW_AT_decl_line(0x120)
.dwattr $C$DW$1655, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$540
.dwattr $C$DW$T$540, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$540, DW_AT_decl_line(0x113)
.dwattr $C$DW$T$540, DW_AT_decl_column(0x01)
$C$DW$T$541 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CoreState")
.dwattr $C$DW$T$541, DW_AT_type(*$C$DW$T$540)
.dwattr $C$DW$T$541, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$541, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$541, DW_AT_decl_line(0x121)
.dwattr $C$DW$T$541, DW_AT_decl_column(0x03)
$C$DW$T$547 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$547, DW_AT_name("McMgr_CoreStatus")
.dwattr $C$DW$T$547, DW_AT_byte_size(0x54)
$C$DW$1656 .dwtag DW_TAG_member
.dwattr $C$DW$1656, DW_AT_type(*$C$DW$T$541)
.dwattr $C$DW$1656, DW_AT_name("state")
.dwattr $C$DW$1656, DW_AT_TI_symbol_name("state")
.dwattr $C$DW$1656, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1656, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1656, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1656, DW_AT_decl_line(0x13d)
.dwattr $C$DW$1656, DW_AT_decl_column(0x19)
$C$DW$1657 .dwtag DW_TAG_member
.dwattr $C$DW$1657, DW_AT_type(*$C$DW$T$454)
.dwattr $C$DW$1657, DW_AT_name("command")
.dwattr $C$DW$1657, DW_AT_TI_symbol_name("command")
.dwattr $C$DW$1657, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1657, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1657, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1657, DW_AT_decl_line(0x13e)
.dwattr $C$DW$1657, DW_AT_decl_column(0x19)
$C$DW$1658 .dwtag DW_TAG_member
.dwattr $C$DW$1658, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1658, DW_AT_name("entryIdx")
.dwattr $C$DW$1658, DW_AT_TI_symbol_name("entryIdx")
.dwattr $C$DW$1658, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1658, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1658, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1658, DW_AT_decl_line(0x13f)
.dwattr $C$DW$1658, DW_AT_decl_column(0x19)
$C$DW$1659 .dwtag DW_TAG_member
.dwattr $C$DW$1659, DW_AT_type(*$C$DW$T$542)
.dwattr $C$DW$1659, DW_AT_name("cmdCompatible")
.dwattr $C$DW$1659, DW_AT_TI_symbol_name("cmdCompatible")
.dwattr $C$DW$1659, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1659, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1659, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1659, DW_AT_decl_line(0x140)
.dwattr $C$DW$1659, DW_AT_decl_column(0x19)
$C$DW$1660 .dwtag DW_TAG_member
.dwattr $C$DW$1660, DW_AT_type(*$C$DW$T$542)
.dwattr $C$DW$1660, DW_AT_name("cmdInit")
.dwattr $C$DW$1660, DW_AT_TI_symbol_name("cmdInit")
.dwattr $C$DW$1660, DW_AT_data_member_location[DW_OP_plus_uconst 0x24]
.dwattr $C$DW$1660, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1660, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1660, DW_AT_decl_line(0x141)
.dwattr $C$DW$1660, DW_AT_decl_column(0x19)
$C$DW$1661 .dwtag DW_TAG_member
.dwattr $C$DW$1661, DW_AT_type(*$C$DW$T$542)
.dwattr $C$DW$1661, DW_AT_name("paramUpdated")
.dwattr $C$DW$1661, DW_AT_TI_symbol_name("paramUpdated")
.dwattr $C$DW$1661, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c]
.dwattr $C$DW$1661, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1661, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1661, DW_AT_decl_line(0x142)
.dwattr $C$DW$1661, DW_AT_decl_column(0x19)
$C$DW$77 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$77, DW_AT_declaration
.dwattr $C$DW$77, DW_AT_TI_symbol_name("_ZN16McMgr_CoreStatusaSERKS_")
.dwattr $C$DW$77, DW_AT_type(*$C$DW$T$543)
.dwattr $C$DW$77, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1662 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1662, DW_AT_type(*$C$DW$T$545)
.dwendtag $C$DW$77
.dwendtag $C$DW$T$547
.dwattr $C$DW$T$547, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$547, DW_AT_decl_line(0x13c)
.dwattr $C$DW$T$547, DW_AT_decl_column(0x01)
$C$DW$T$544 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$544, DW_AT_type(*$C$DW$T$547)
$C$DW$T$545 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$545, DW_AT_type(*$C$DW$T$544)
.dwattr $C$DW$T$545, DW_AT_address_class(0x20)
$C$DW$T$1927 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CoreStatus")
.dwattr $C$DW$T$1927, DW_AT_type(*$C$DW$T$547)
.dwattr $C$DW$T$1927, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1927, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1927, DW_AT_decl_line(0x143)
.dwattr $C$DW$T$1927, DW_AT_decl_column(0x03)
$C$DW$T$543 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$543, DW_AT_type(*$C$DW$T$547)
.dwattr $C$DW$T$543, DW_AT_address_class(0x20)
$C$DW$T$546 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$546, DW_AT_type(*$C$DW$T$543)
.dwattr $C$DW$T$546, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1663 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1663, DW_AT_type(*$C$DW$T$545)
.dwendtag $C$DW$T$546
$C$DW$T$511 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$511, DW_AT_name("McMgr_EntryStatus")
.dwattr $C$DW$T$511, DW_AT_byte_size(0x04)
$C$DW$1664 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_ENTRY_NONE"), DW_AT_const_value(0x00)
.dwattr $C$DW$1664, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1664, DW_AT_decl_line(0x10a)
.dwattr $C$DW$1664, DW_AT_decl_column(0x05)
$C$DW$1665 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_ENTRY_UNSERVICED"), DW_AT_const_value(0x01)
.dwattr $C$DW$1665, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1665, DW_AT_decl_line(0x10b)
.dwattr $C$DW$1665, DW_AT_decl_column(0x05)
$C$DW$1666 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_ENTRY_INPROGRESS"), DW_AT_const_value(0x02)
.dwattr $C$DW$1666, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1666, DW_AT_decl_line(0x10c)
.dwattr $C$DW$1666, DW_AT_decl_column(0x05)
$C$DW$1667 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_ENTRY_SERVICED"), DW_AT_const_value(0x03)
.dwattr $C$DW$1667, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1667, DW_AT_decl_line(0x10d)
.dwattr $C$DW$1667, DW_AT_decl_column(0x05)
$C$DW$1668 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_ENTRY_EOL"), DW_AT_const_value(0x04)
.dwattr $C$DW$1668, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1668, DW_AT_decl_line(0x10e)
.dwattr $C$DW$1668, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$511
.dwattr $C$DW$T$511, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$511, DW_AT_decl_line(0x109)
.dwattr $C$DW$T$511, DW_AT_decl_column(0x01)
$C$DW$T$512 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_EntryStatus")
.dwattr $C$DW$T$512, DW_AT_type(*$C$DW$T$511)
.dwattr $C$DW$T$512, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$512, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$512, DW_AT_decl_line(0x10f)
.dwattr $C$DW$T$512, DW_AT_decl_column(0x03)
$C$DW$T$1530 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1530, DW_AT_name("McMgr_IpcMsg")
.dwattr $C$DW$T$1530, DW_AT_byte_size(0x04)
$C$DW$1669 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_NONE"), DW_AT_const_value(0x00)
.dwattr $C$DW$1669, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1669, DW_AT_decl_line(0xdc)
.dwattr $C$DW$1669, DW_AT_decl_column(0x05)
$C$DW$1670 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_ERROR_CMD"), DW_AT_const_value(0x01)
.dwattr $C$DW$1670, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1670, DW_AT_decl_line(0xdf)
.dwattr $C$DW$1670, DW_AT_decl_column(0x05)
$C$DW$1671 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_ADD_CMD"), DW_AT_const_value(0x02)
.dwattr $C$DW$1671, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1671, DW_AT_decl_line(0xe0)
.dwattr $C$DW$1671, DW_AT_decl_column(0x05)
$C$DW$1672 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_INIT_CMD"), DW_AT_const_value(0x03)
.dwattr $C$DW$1672, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1672, DW_AT_decl_line(0xe1)
.dwattr $C$DW$1672, DW_AT_decl_column(0x05)
$C$DW$1673 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_INIT_RSP"), DW_AT_const_value(0x04)
.dwattr $C$DW$1673, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1673, DW_AT_decl_line(0xe2)
.dwattr $C$DW$1673, DW_AT_decl_column(0x05)
$C$DW$1674 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_START_CMD"), DW_AT_const_value(0x05)
.dwattr $C$DW$1674, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1674, DW_AT_decl_line(0xe3)
.dwattr $C$DW$1674, DW_AT_decl_column(0x05)
$C$DW$1675 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_START_RSP"), DW_AT_const_value(0x06)
.dwattr $C$DW$1675, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1675, DW_AT_decl_line(0xe4)
.dwattr $C$DW$1675, DW_AT_decl_column(0x05)
$C$DW$1676 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_STOP_CMD"), DW_AT_const_value(0x07)
.dwattr $C$DW$1676, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1676, DW_AT_decl_line(0xe5)
.dwattr $C$DW$1676, DW_AT_decl_column(0x05)
$C$DW$1677 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_STOP_RSP"), DW_AT_const_value(0x08)
.dwattr $C$DW$1677, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1677, DW_AT_decl_line(0xe6)
.dwattr $C$DW$1677, DW_AT_decl_column(0x05)
$C$DW$1678 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_RT_PARAM_UPDATE_RSP"), DW_AT_const_value(0x09)
.dwattr $C$DW$1678, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1678, DW_AT_decl_line(0xe7)
.dwattr $C$DW$1678, DW_AT_decl_column(0x05)
$C$DW$1679 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_VSYNC_DISABLED"), DW_AT_const_value(0x0a)
.dwattr $C$DW$1679, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1679, DW_AT_decl_line(0xea)
.dwattr $C$DW$1679, DW_AT_decl_column(0x05)
$C$DW$1680 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_FOV_UPDATE_CMD"), DW_AT_const_value(0x0b)
.dwattr $C$DW$1680, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1680, DW_AT_decl_line(0xeb)
.dwattr $C$DW$1680, DW_AT_decl_column(0x05)
$C$DW$1681 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_FOV_UPDATE_RSP"), DW_AT_const_value(0x0c)
.dwattr $C$DW$1681, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1681, DW_AT_decl_line(0xec)
.dwattr $C$DW$1681, DW_AT_decl_column(0x05)
$C$DW$1682 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_NRT_PARAM_UPDATE_CMD"), DW_AT_const_value(0x0d)
.dwattr $C$DW$1682, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1682, DW_AT_decl_line(0xed)
.dwattr $C$DW$1682, DW_AT_decl_column(0x05)
$C$DW$1683 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_RT_PARAM_UPDATE_CMD"), DW_AT_const_value(0x0e)
.dwattr $C$DW$1683, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1683, DW_AT_decl_line(0xee)
.dwattr $C$DW$1683, DW_AT_decl_column(0x05)
$C$DW$1684 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PLAYLIST_UPDATE_CMD"), DW_AT_const_value(0x0f)
.dwattr $C$DW$1684, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1684, DW_AT_decl_line(0xef)
.dwattr $C$DW$1684, DW_AT_decl_column(0x05)
$C$DW$1685 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PLAYLIST_UPDATE_RT_RSP"), DW_AT_const_value(0x10)
.dwattr $C$DW$1685, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1685, DW_AT_decl_line(0xf0)
.dwattr $C$DW$1685, DW_AT_decl_column(0x05)
$C$DW$1686 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PLAYLIST_UPDATE_NRT_RSP"), DW_AT_const_value(0x11)
.dwattr $C$DW$1686, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1686, DW_AT_decl_line(0xf1)
.dwattr $C$DW$1686, DW_AT_decl_column(0x05)
$C$DW$1687 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PROCESS_CMD"), DW_AT_const_value(0x12)
.dwattr $C$DW$1687, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1687, DW_AT_decl_line(0xf4)
.dwattr $C$DW$1687, DW_AT_decl_column(0x05)
$C$DW$1688 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PROCESS_RSP"), DW_AT_const_value(0x13)
.dwattr $C$DW$1688, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1688, DW_AT_decl_line(0xf5)
.dwattr $C$DW$1688, DW_AT_decl_column(0x05)
$C$DW$1689 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PARAM_UPDATE_CMD"), DW_AT_const_value(0x14)
.dwattr $C$DW$1689, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1689, DW_AT_decl_line(0xf6)
.dwattr $C$DW$1689, DW_AT_decl_column(0x05)
$C$DW$1690 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PARAM_UPDATE_RSP"), DW_AT_const_value(0x15)
.dwattr $C$DW$1690, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1690, DW_AT_decl_line(0xf7)
.dwattr $C$DW$1690, DW_AT_decl_column(0x05)
$C$DW$1691 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_CINE_PROCESS_DONE"), DW_AT_const_value(0x16)
.dwattr $C$DW$1691, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1691, DW_AT_decl_line(0xf8)
.dwattr $C$DW$1691, DW_AT_decl_column(0x05)
$C$DW$1692 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_SRIO_DBELL"), DW_AT_const_value(0x17)
.dwattr $C$DW$1692, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1692, DW_AT_decl_line(0xfc)
.dwattr $C$DW$1692, DW_AT_decl_column(0x05)
$C$DW$1693 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_VSYNC"), DW_AT_const_value(0x18)
.dwattr $C$DW$1693, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1693, DW_AT_decl_line(0xff)
.dwattr $C$DW$1693, DW_AT_decl_column(0x05)
$C$DW$1694 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_POST_TO_UTI"), DW_AT_const_value(0x19)
.dwattr $C$DW$1694, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1694, DW_AT_decl_line(0x102)
.dwattr $C$DW$1694, DW_AT_decl_column(0x05)
$C$DW$1695 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_EOL"), DW_AT_const_value(0x1a)
.dwattr $C$DW$1695, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1695, DW_AT_decl_line(0x105)
.dwattr $C$DW$1695, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1530
.dwattr $C$DW$T$1530, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1530, DW_AT_decl_line(0xdb)
.dwattr $C$DW$T$1530, DW_AT_decl_column(0x01)
$C$DW$T$1531 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_IpcMsg")
.dwattr $C$DW$T$1531, DW_AT_type(*$C$DW$T$1530)
.dwattr $C$DW$T$1531, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1531, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1531, DW_AT_decl_line(0x106)
.dwattr $C$DW$T$1531, DW_AT_decl_column(0x03)
$C$DW$T$553 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$553, DW_AT_name("McMgr_ModuleImagingState")
.dwattr $C$DW$T$553, DW_AT_byte_size(0x0c)
$C$DW$1696 .dwtag DW_TAG_member
.dwattr $C$DW$1696, DW_AT_type(*$C$DW$T$548)
.dwattr $C$DW$1696, DW_AT_name("doppler")
.dwattr $C$DW$1696, DW_AT_TI_symbol_name("doppler")
.dwattr $C$DW$1696, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1696, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1696, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1696, DW_AT_decl_line(0x199)
.dwattr $C$DW$1696, DW_AT_decl_column(0x1a)
$C$DW$78 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$78, DW_AT_declaration
.dwattr $C$DW$78, DW_AT_TI_symbol_name("_ZN24McMgr_ModuleImagingStateaSERKS_")
.dwattr $C$DW$78, DW_AT_type(*$C$DW$T$549)
.dwattr $C$DW$78, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1697 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1697, DW_AT_type(*$C$DW$T$551)
.dwendtag $C$DW$78
.dwendtag $C$DW$T$553
.dwattr $C$DW$T$553, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$553, DW_AT_decl_line(0x195)
.dwattr $C$DW$T$553, DW_AT_decl_column(0x01)
$C$DW$T$550 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$550, DW_AT_type(*$C$DW$T$553)
$C$DW$T$551 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$551, DW_AT_type(*$C$DW$T$550)
.dwattr $C$DW$T$551, DW_AT_address_class(0x20)
$C$DW$T$567 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ModuleImagingState")
.dwattr $C$DW$T$567, DW_AT_type(*$C$DW$T$553)
.dwattr $C$DW$T$567, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$567, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$567, DW_AT_decl_line(0x19c)
.dwattr $C$DW$T$567, DW_AT_decl_column(0x03)
$C$DW$T$549 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$549, DW_AT_type(*$C$DW$T$553)
.dwattr $C$DW$T$549, DW_AT_address_class(0x20)
$C$DW$T$552 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$552, DW_AT_type(*$C$DW$T$549)
.dwattr $C$DW$T$552, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1698 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1698, DW_AT_type(*$C$DW$T$551)
.dwendtag $C$DW$T$552
$C$DW$T$452 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$452, DW_AT_name("McMgr_ParamUpdateCmd")
.dwattr $C$DW$T$452, DW_AT_byte_size(0x04)
$C$DW$1699 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_UPDATE_COMMAND_NONE"), DW_AT_const_value(0x00)
.dwattr $C$DW$1699, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1699, DW_AT_decl_line(0xd3)
.dwattr $C$DW$1699, DW_AT_decl_column(0x05)
$C$DW$1700 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_UPDATE_COMMAND_DYN_RANGE_CHG_INIT"), DW_AT_const_value(0x01)
.dwattr $C$DW$1700, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1700, DW_AT_decl_line(0xd4)
.dwattr $C$DW$1700, DW_AT_decl_column(0x05)
$C$DW$1701 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_UPDATE_COMMAND_AMMLINE"), DW_AT_const_value(0x02)
.dwattr $C$DW$1701, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1701, DW_AT_decl_line(0xd5)
.dwattr $C$DW$1701, DW_AT_decl_column(0x05)
$C$DW$1702 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_UPDATE_COMMAND_EOL"), DW_AT_const_value(0x03)
.dwattr $C$DW$1702, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1702, DW_AT_decl_line(0xd6)
.dwattr $C$DW$1702, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$452
.dwattr $C$DW$T$452, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$452, DW_AT_decl_line(0xd2)
.dwattr $C$DW$T$452, DW_AT_decl_column(0x01)
$C$DW$T$453 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ParamUpdateCmd")
.dwattr $C$DW$T$453, DW_AT_type(*$C$DW$T$452)
.dwattr $C$DW$T$453, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$453, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$453, DW_AT_decl_line(0xd7)
.dwattr $C$DW$T$453, DW_AT_decl_column(0x03)
$C$DW$T$561 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$561, DW_AT_name("McMgr_ProcessCmd")
.dwattr $C$DW$T$561, DW_AT_byte_size(0x04)
$C$DW$1703 .dwtag DW_TAG_member
.dwattr $C$DW$1703, DW_AT_type(*$C$DW$T$555)
.dwattr $C$DW$1703, DW_AT_name("cmndEnum")
.dwattr $C$DW$1703, DW_AT_TI_symbol_name("cmndEnum")
.dwattr $C$DW$1703, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1703, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1703, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1703, DW_AT_decl_line(0xcb)
.dwattr $C$DW$1703, DW_AT_decl_column(0x1a)
$C$DW$1704 .dwtag DW_TAG_member
.dwattr $C$DW$1704, DW_AT_type(*$C$DW$T$556)
.dwattr $C$DW$1704, DW_AT_name("bits")
.dwattr $C$DW$1704, DW_AT_TI_symbol_name("bits")
.dwattr $C$DW$1704, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1704, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1704, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1704, DW_AT_decl_line(0xcc)
.dwattr $C$DW$1704, DW_AT_decl_column(0x1a)
$C$DW$79 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$79, DW_AT_declaration
.dwattr $C$DW$79, DW_AT_TI_symbol_name("_ZN16McMgr_ProcessCmdaSERKS_")
.dwattr $C$DW$79, DW_AT_type(*$C$DW$T$557)
.dwattr $C$DW$79, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1705 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1705, DW_AT_type(*$C$DW$T$559)
.dwendtag $C$DW$79
.dwendtag $C$DW$T$561
.dwattr $C$DW$T$561, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$561, DW_AT_decl_line(0xca)
.dwattr $C$DW$T$561, DW_AT_decl_column(0x0f)
$C$DW$T$454 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ProcessCmd")
.dwattr $C$DW$T$454, DW_AT_type(*$C$DW$T$561)
.dwattr $C$DW$T$454, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$454, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$454, DW_AT_decl_line(0xcd)
.dwattr $C$DW$T$454, DW_AT_decl_column(0x03)
$C$DW$T$518 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$518, DW_AT_type(*$C$DW$T$454)
.dwattr $C$DW$T$518, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$518, DW_AT_byte_size(0x08)
$C$DW$1706 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$1706, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$518
$C$DW$T$558 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$558, DW_AT_type(*$C$DW$T$561)
$C$DW$T$559 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$559, DW_AT_type(*$C$DW$T$558)
.dwattr $C$DW$T$559, DW_AT_address_class(0x20)
$C$DW$T$557 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$557, DW_AT_type(*$C$DW$T$561)
.dwattr $C$DW$T$557, DW_AT_address_class(0x20)
$C$DW$T$560 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$560, DW_AT_type(*$C$DW$T$557)
.dwattr $C$DW$T$560, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1707 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1707, DW_AT_type(*$C$DW$T$559)
.dwendtag $C$DW$T$560
$C$DW$T$566 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$566, DW_AT_name("McMgr_ProcessCmdBits")
.dwattr $C$DW$T$566, DW_AT_byte_size(0x04)
$C$DW$1708 .dwtag DW_TAG_member
.dwattr $C$DW$1708, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1708, DW_AT_name("modeCmdEnum")
.dwattr $C$DW$1708, DW_AT_TI_symbol_name("modeCmdEnum")
.dwattr $C$DW$1708, DW_AT_bit_offset(0x08), DW_AT_bit_size(0x18)
.dwattr $C$DW$1708, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1708, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1708, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1708, DW_AT_decl_line(0xc6)
.dwattr $C$DW$1708, DW_AT_decl_column(0x0c)
$C$DW$1709 .dwtag DW_TAG_member
.dwattr $C$DW$1709, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1709, DW_AT_name("mode")
.dwattr $C$DW$1709, DW_AT_TI_symbol_name("mode")
.dwattr $C$DW$1709, DW_AT_bit_offset(0x00), DW_AT_bit_size(0x08)
.dwattr $C$DW$1709, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1709, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1709, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1709, DW_AT_decl_line(0xc7)
.dwattr $C$DW$1709, DW_AT_decl_column(0x0c)
$C$DW$80 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$80, DW_AT_declaration
.dwattr $C$DW$80, DW_AT_TI_symbol_name("_ZN20McMgr_ProcessCmdBitsaSERKS_")
.dwattr $C$DW$80, DW_AT_type(*$C$DW$T$562)
.dwattr $C$DW$80, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1710 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1710, DW_AT_type(*$C$DW$T$564)
.dwendtag $C$DW$80
.dwendtag $C$DW$T$566
.dwattr $C$DW$T$566, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$566, DW_AT_decl_line(0xc5)
.dwattr $C$DW$T$566, DW_AT_decl_column(0x01)
$C$DW$T$556 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ProcessCmdBits")
.dwattr $C$DW$T$556, DW_AT_type(*$C$DW$T$566)
.dwattr $C$DW$T$556, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$556, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$556, DW_AT_decl_line(0xc8)
.dwattr $C$DW$T$556, DW_AT_decl_column(0x03)
$C$DW$T$563 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$563, DW_AT_type(*$C$DW$T$566)
$C$DW$T$564 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$564, DW_AT_type(*$C$DW$T$563)
.dwattr $C$DW$T$564, DW_AT_address_class(0x20)
$C$DW$T$562 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$562, DW_AT_type(*$C$DW$T$566)
.dwattr $C$DW$T$562, DW_AT_address_class(0x20)
$C$DW$T$565 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$565, DW_AT_type(*$C$DW$T$562)
.dwattr $C$DW$T$565, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1711 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1711, DW_AT_type(*$C$DW$T$564)
.dwendtag $C$DW$T$565
$C$DW$T$554 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$554, DW_AT_name("McMgr_ProcessCmdEnum")
.dwattr $C$DW$T$554, DW_AT_byte_size(0x04)
$C$DW$1712 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_NONE"), DW_AT_const_value(0x00)
.dwattr $C$DW$1712, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1712, DW_AT_decl_line(0xbc)
.dwattr $C$DW$1712, DW_AT_decl_column(0x05)
$C$DW$1713 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_EOL"), DW_AT_const_value(0x20)
.dwattr $C$DW$1713, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1713, DW_AT_decl_line(0xbd)
.dwattr $C$DW$1713, DW_AT_decl_column(0x05)
$C$DW$1714 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_START"), DW_AT_const_value(0x01)
.dwattr $C$DW$1714, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1714, DW_AT_decl_line(0xbe)
.dwattr $C$DW$1714, DW_AT_decl_column(0x05)
$C$DW$1715 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_END"), DW_AT_const_value(0x1f)
.dwattr $C$DW$1715, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1715, DW_AT_decl_line(0xbf)
.dwattr $C$DW$1715, DW_AT_decl_column(0x05)
$C$DW$1716 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_START"), DW_AT_const_value(0x01)
.dwattr $C$DW$1716, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1716, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1716, DW_AT_decl_column(0x05)
$C$DW$1717 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_NON_MB_INP_SHIFT"), DW_AT_const_value(0x02)
.dwattr $C$DW$1717, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1717, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1717, DW_AT_decl_column(0x05)
$C$DW$1718 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_NON_MB_PERST_CMPR"), DW_AT_const_value(0x03)
.dwattr $C$DW$1718, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1718, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1718, DW_AT_decl_column(0x05)
$C$DW$1719 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_MB_REG"), DW_AT_const_value(0x04)
.dwattr $C$DW$1719, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1719, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1719, DW_AT_decl_column(0x05)
$C$DW$1720 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_MB_CMPD"), DW_AT_const_value(0x05)
.dwattr $C$DW$1720, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1720, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1720, DW_AT_decl_column(0x05)
$C$DW$1721 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_POST_PROCESS"), DW_AT_const_value(0x06)
.dwattr $C$DW$1721, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1721, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1721, DW_AT_decl_column(0x05)
$C$DW$1722 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_CVIZ_FULL_FRAME"), DW_AT_const_value(0x07)
.dwattr $C$DW$1722, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1722, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1722, DW_AT_decl_column(0x05)
$C$DW$1723 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_CVIZ1"), DW_AT_const_value(0x08)
.dwattr $C$DW$1723, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1723, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1723, DW_AT_decl_column(0x05)
$C$DW$1724 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_CVIZ2"), DW_AT_const_value(0x09)
.dwattr $C$DW$1724, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1724, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1724, DW_AT_decl_column(0x05)
$C$DW$1725 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_CVIZ_STITCH"), DW_AT_const_value(0x0a)
.dwattr $C$DW$1725, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1725, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1725, DW_AT_decl_column(0x05)
$C$DW$1726 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_REMAP"), DW_AT_const_value(0x0b)
.dwattr $C$DW$1726, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1726, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1726, DW_AT_decl_column(0x05)
$C$DW$1727 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_SCAN_CONV"), DW_AT_const_value(0x0c)
.dwattr $C$DW$1727, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1727, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1727, DW_AT_decl_column(0x05)
$C$DW$1728 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_SCALE_ZOOM"), DW_AT_const_value(0x0d)
.dwattr $C$DW$1728, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1728, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1728, DW_AT_decl_column(0x05)
$C$DW$1729 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_END"), DW_AT_const_value(0x1f)
.dwattr $C$DW$1729, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1729, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1729, DW_AT_decl_column(0x05)
$C$DW$1730 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_COLOR_START"), DW_AT_const_value(0x1000001)
.dwattr $C$DW$1730, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1730, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1730, DW_AT_decl_column(0x05)
$C$DW$1731 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_COLOR_MPFIR_VELVAR"), DW_AT_const_value(0x1000002)
.dwattr $C$DW$1731, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1731, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1731, DW_AT_decl_column(0x05)
$C$DW$1732 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_COLOR_END"), DW_AT_const_value(0x100001f)
.dwattr $C$DW$1732, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1732, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1732, DW_AT_decl_column(0x05)
$C$DW$1733 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_START"), DW_AT_const_value(0x2000001)
.dwattr $C$DW$1733, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1733, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1733, DW_AT_decl_column(0x05)
$C$DW$1734 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_PREPROCESS"), DW_AT_const_value(0x2000002)
.dwattr $C$DW$1734, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1734, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1734, DW_AT_decl_column(0x05)
$C$DW$1735 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_FFT_RATE"), DW_AT_const_value(0x2000003)
.dwattr $C$DW$1735, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1735, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1735, DW_AT_decl_column(0x05)
$C$DW$1736 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_FFT_RATE_BY_N"), DW_AT_const_value(0x2000004)
.dwattr $C$DW$1736, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1736, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1736, DW_AT_decl_column(0x05)
$C$DW$1737 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_FFT_POSTPROCESS"), DW_AT_const_value(0x2000005)
.dwattr $C$DW$1737, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1737, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1737, DW_AT_decl_column(0x05)
$C$DW$1738 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_END"), DW_AT_const_value(0x200001f)
.dwattr $C$DW$1738, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1738, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1738, DW_AT_decl_column(0x05)
$C$DW$1739 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_MMODE_START"), DW_AT_const_value(0x3000001)
.dwattr $C$DW$1739, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1739, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1739, DW_AT_decl_column(0x05)
$C$DW$1740 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_MMODE_AMM_INTERP"), DW_AT_const_value(0x3000002)
.dwattr $C$DW$1740, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1740, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1740, DW_AT_decl_column(0x05)
$C$DW$1741 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_MMODE_PROCESS"), DW_AT_const_value(0x3000003)
.dwattr $C$DW$1741, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1741, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1741, DW_AT_decl_column(0x05)
$C$DW$1742 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_MMODE_END"), DW_AT_const_value(0x300001f)
.dwattr $C$DW$1742, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1742, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1742, DW_AT_decl_column(0x05)
$C$DW$1743 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_PAI_START"), DW_AT_const_value(0x4000001)
.dwattr $C$DW$1743, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1743, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1743, DW_AT_decl_column(0x05)
$C$DW$1744 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_PAI_PROCESS"), DW_AT_const_value(0x4000002)
.dwattr $C$DW$1744, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1744, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1744, DW_AT_decl_column(0x05)
$C$DW$1745 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_PAI_SCAN_CONV"), DW_AT_const_value(0x4000003)
.dwattr $C$DW$1745, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1745, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1745, DW_AT_decl_column(0x05)
$C$DW$1746 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_PAI_SCALE_ZOOM"), DW_AT_const_value(0x4000004)
.dwattr $C$DW$1746, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1746, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1746, DW_AT_decl_column(0x05)
$C$DW$1747 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_PAI_END"), DW_AT_const_value(0x400001f)
.dwattr $C$DW$1747, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1747, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1747, DW_AT_decl_column(0x05)
$C$DW$1748 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_ECG_START"), DW_AT_const_value(0x5000001)
.dwattr $C$DW$1748, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1748, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1748, DW_AT_decl_column(0x05)
$C$DW$1749 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_ECG_PROCESS"), DW_AT_const_value(0x5000002)
.dwattr $C$DW$1749, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1749, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1749, DW_AT_decl_column(0x05)
$C$DW$1750 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_ECG_END"), DW_AT_const_value(0x500001f)
.dwattr $C$DW$1750, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1750, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1750, DW_AT_decl_column(0x05)
$C$DW$1751 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BOL"), DW_AT_const_value(0x00)
.dwattr $C$DW$1751, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1751, DW_AT_decl_line(0xc1)
.dwattr $C$DW$1751, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$554
.dwattr $C$DW$T$554, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$554, DW_AT_decl_line(0xbb)
.dwattr $C$DW$T$554, DW_AT_decl_column(0x01)
$C$DW$T$555 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ProcessCmdEnum")
.dwattr $C$DW$T$555, DW_AT_type(*$C$DW$T$554)
.dwattr $C$DW$T$555, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$555, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$555, DW_AT_decl_line(0xc2)
.dwattr $C$DW$T$555, DW_AT_decl_column(0x03)
$C$DW$T$573 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$573, DW_AT_name("McMgr_ProcessState")
.dwattr $C$DW$T$573, DW_AT_byte_size(0x10)
$C$DW$1752 .dwtag DW_TAG_member
.dwattr $C$DW$1752, DW_AT_type(*$C$DW$T$567)
.dwattr $C$DW$1752, DW_AT_name("module")
.dwattr $C$DW$1752, DW_AT_TI_symbol_name("module")
.dwattr $C$DW$1752, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1752, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1752, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1752, DW_AT_decl_line(0x1a0)
.dwattr $C$DW$1752, DW_AT_decl_column(0x1e)
$C$DW$1753 .dwtag DW_TAG_member
.dwattr $C$DW$1753, DW_AT_type(*$C$DW$T$568)
.dwattr $C$DW$1753, DW_AT_name("sharedResource")
.dwattr $C$DW$1753, DW_AT_TI_symbol_name("sharedResource")
.dwattr $C$DW$1753, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1753, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1753, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1753, DW_AT_decl_line(0x1a2)
.dwattr $C$DW$1753, DW_AT_decl_column(0x1f)
$C$DW$81 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$81, DW_AT_declaration
.dwattr $C$DW$81, DW_AT_TI_symbol_name("_ZN18McMgr_ProcessStateaSERKS_")
.dwattr $C$DW$81, DW_AT_type(*$C$DW$T$569)
.dwattr $C$DW$81, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1754 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1754, DW_AT_type(*$C$DW$T$571)
.dwendtag $C$DW$81
.dwendtag $C$DW$T$573
.dwattr $C$DW$T$573, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$573, DW_AT_decl_line(0x19f)
.dwattr $C$DW$T$573, DW_AT_decl_column(0x01)
$C$DW$T$570 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$570, DW_AT_type(*$C$DW$T$573)
$C$DW$T$571 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$571, DW_AT_type(*$C$DW$T$570)
.dwattr $C$DW$T$571, DW_AT_address_class(0x20)
$C$DW$T$1450 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ProcessState")
.dwattr $C$DW$T$1450, DW_AT_type(*$C$DW$T$573)
.dwattr $C$DW$T$1450, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1450, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1450, DW_AT_decl_line(0x1a3)
.dwattr $C$DW$T$1450, DW_AT_decl_column(0x03)
$C$DW$T$569 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$569, DW_AT_type(*$C$DW$T$573)
.dwattr $C$DW$T$569, DW_AT_address_class(0x20)
$C$DW$T$572 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$572, DW_AT_type(*$C$DW$T$569)
.dwattr $C$DW$T$572, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1755 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1755, DW_AT_type(*$C$DW$T$571)
.dwendtag $C$DW$T$572
$C$DW$T$578 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$578, DW_AT_name("McMgr_SharedResourceState")
.dwattr $C$DW$T$578, DW_AT_byte_size(0x02)
$C$DW$1756 .dwtag DW_TAG_member
.dwattr $C$DW$1756, DW_AT_type(*$C$DW$T$456)
.dwattr $C$DW$1756, DW_AT_name("remapTableUpdate")
.dwattr $C$DW$1756, DW_AT_TI_symbol_name("remapTableUpdate")
.dwattr $C$DW$1756, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1756, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1756, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1756, DW_AT_decl_line(0x12e)
.dwattr $C$DW$1756, DW_AT_decl_column(0x0a)
$C$DW$82 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$82, DW_AT_declaration
.dwattr $C$DW$82, DW_AT_TI_symbol_name("_ZN25McMgr_SharedResourceStateaSERKS_")
.dwattr $C$DW$82, DW_AT_type(*$C$DW$T$574)
.dwattr $C$DW$82, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1757 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1757, DW_AT_type(*$C$DW$T$576)
.dwendtag $C$DW$82
.dwendtag $C$DW$T$578
.dwattr $C$DW$T$578, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$578, DW_AT_decl_line(0x12d)
.dwattr $C$DW$T$578, DW_AT_decl_column(0x01)
$C$DW$T$568 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_SharedResourceState")
.dwattr $C$DW$T$568, DW_AT_type(*$C$DW$T$578)
.dwattr $C$DW$T$568, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$568, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$568, DW_AT_decl_line(0x12f)
.dwattr $C$DW$T$568, DW_AT_decl_column(0x03)
$C$DW$T$575 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$575, DW_AT_type(*$C$DW$T$578)
$C$DW$T$576 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$576, DW_AT_type(*$C$DW$T$575)
.dwattr $C$DW$T$576, DW_AT_address_class(0x20)
$C$DW$T$574 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$574, DW_AT_type(*$C$DW$T$578)
.dwattr $C$DW$T$574, DW_AT_address_class(0x20)
$C$DW$T$577 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$577, DW_AT_type(*$C$DW$T$574)
.dwattr $C$DW$T$577, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1758 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1758, DW_AT_type(*$C$DW$T$576)
.dwendtag $C$DW$T$577
$C$DW$T$1928 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1928, DW_AT_name("McMgr_SharedResourceType")
.dwattr $C$DW$T$1928, DW_AT_byte_size(0x04)
$C$DW$1759 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_SHARED_RESOURCE_BMODE_REMAP_TABLE"), DW_AT_const_value(0x00)
.dwattr $C$DW$1759, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1759, DW_AT_decl_line(0x127)
.dwattr $C$DW$1759, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1928
.dwattr $C$DW$T$1928, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1928, DW_AT_decl_line(0x126)
.dwattr $C$DW$T$1928, DW_AT_decl_column(0x01)
$C$DW$T$1929 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_SharedResourceType")
.dwattr $C$DW$T$1929, DW_AT_type(*$C$DW$T$1928)
.dwattr $C$DW$T$1929, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1929, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1929, DW_AT_decl_line(0x128)
.dwattr $C$DW$T$1929, DW_AT_decl_column(0x03)
$C$DW$T$1930 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1930, DW_AT_name("McMgr_Triggered_Command_Ordinal")
.dwattr $C$DW$T$1930, DW_AT_byte_size(0x04)
$C$DW$1760 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_TRIG_CMD_BOL"), DW_AT_const_value(0x00)
.dwattr $C$DW$1760, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1760, DW_AT_decl_line(0xaa)
.dwattr $C$DW$1760, DW_AT_decl_column(0x05)
$C$DW$1761 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_FIRST_TRIG_CMD"), DW_AT_const_value(0x00)
.dwattr $C$DW$1761, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1761, DW_AT_decl_line(0xab)
.dwattr $C$DW$1761, DW_AT_decl_column(0x05)
$C$DW$1762 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_SECOND_TRIG_CMD"), DW_AT_const_value(0x01)
.dwattr $C$DW$1762, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1762, DW_AT_decl_line(0xac)
.dwattr $C$DW$1762, DW_AT_decl_column(0x05)
$C$DW$1763 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_TRIG_CMD_EOL"), DW_AT_const_value(0x02)
.dwattr $C$DW$1763, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1763, DW_AT_decl_line(0xad)
.dwattr $C$DW$1763, DW_AT_decl_column(0x05)
$C$DW$1764 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_MCMGR_TRIG_CMD_CNT"), DW_AT_const_value(0x02)
.dwattr $C$DW$1764, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$1764, DW_AT_decl_line(0xae)
.dwattr $C$DW$1764, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1930
.dwattr $C$DW$T$1930, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1930, DW_AT_decl_line(0xa9)
.dwattr $C$DW$T$1930, DW_AT_decl_column(0x01)
$C$DW$T$1931 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_Triggered_Command_Ordinal")
.dwattr $C$DW$T$1931, DW_AT_type(*$C$DW$T$1930)
.dwattr $C$DW$T$1931, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1931, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h")
.dwattr $C$DW$T$1931, DW_AT_decl_line(0xaf)
.dwattr $C$DW$T$1931, DW_AT_decl_column(0x03)
$C$DW$T$889 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$889, DW_AT_name("MessageQ_MsgHeader")
.dwattr $C$DW$T$889, DW_AT_byte_size(0x20)
$C$DW$1765 .dwtag DW_TAG_member
.dwattr $C$DW$1765, DW_AT_type(*$C$DW$T$883)
.dwattr $C$DW$1765, DW_AT_name("reserved0")
.dwattr $C$DW$1765, DW_AT_TI_symbol_name("reserved0")
.dwattr $C$DW$1765, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1765, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1765, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1765, DW_AT_decl_line(0x25a)
.dwattr $C$DW$1765, DW_AT_decl_column(0x12)
$C$DW$1766 .dwtag DW_TAG_member
.dwattr $C$DW$1766, DW_AT_type(*$C$DW$T$883)
.dwattr $C$DW$1766, DW_AT_name("reserved1")
.dwattr $C$DW$1766, DW_AT_TI_symbol_name("reserved1")
.dwattr $C$DW$1766, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1766, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1766, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1766, DW_AT_decl_line(0x25b)
.dwattr $C$DW$1766, DW_AT_decl_column(0x12)
$C$DW$1767 .dwtag DW_TAG_member
.dwattr $C$DW$1767, DW_AT_type(*$C$DW$T$883)
.dwattr $C$DW$1767, DW_AT_name("msgSize")
.dwattr $C$DW$1767, DW_AT_TI_symbol_name("msgSize")
.dwattr $C$DW$1767, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1767, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1767, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1767, DW_AT_decl_line(0x25c)
.dwattr $C$DW$1767, DW_AT_decl_column(0x12)
$C$DW$1768 .dwtag DW_TAG_member
.dwattr $C$DW$1768, DW_AT_type(*$C$DW$T$884)
.dwattr $C$DW$1768, DW_AT_name("flags")
.dwattr $C$DW$1768, DW_AT_TI_symbol_name("flags")
.dwattr $C$DW$1768, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1768, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1768, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1768, DW_AT_decl_line(0x25d)
.dwattr $C$DW$1768, DW_AT_decl_column(0x12)
$C$DW$1769 .dwtag DW_TAG_member
.dwattr $C$DW$1769, DW_AT_type(*$C$DW$T$884)
.dwattr $C$DW$1769, DW_AT_name("msgId")
.dwattr $C$DW$1769, DW_AT_TI_symbol_name("msgId")
.dwattr $C$DW$1769, DW_AT_data_member_location[DW_OP_plus_uconst 0xe]
.dwattr $C$DW$1769, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1769, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1769, DW_AT_decl_line(0x25e)
.dwattr $C$DW$1769, DW_AT_decl_column(0x12)
$C$DW$1770 .dwtag DW_TAG_member
.dwattr $C$DW$1770, DW_AT_type(*$C$DW$T$884)
.dwattr $C$DW$1770, DW_AT_name("dstId")
.dwattr $C$DW$1770, DW_AT_TI_symbol_name("dstId")
.dwattr $C$DW$1770, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1770, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1770, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1770, DW_AT_decl_line(0x25f)
.dwattr $C$DW$1770, DW_AT_decl_column(0x12)
$C$DW$1771 .dwtag DW_TAG_member
.dwattr $C$DW$1771, DW_AT_type(*$C$DW$T$884)
.dwattr $C$DW$1771, DW_AT_name("dstProc")
.dwattr $C$DW$1771, DW_AT_TI_symbol_name("dstProc")
.dwattr $C$DW$1771, DW_AT_data_member_location[DW_OP_plus_uconst 0x12]
.dwattr $C$DW$1771, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1771, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1771, DW_AT_decl_line(0x260)
.dwattr $C$DW$1771, DW_AT_decl_column(0x12)
$C$DW$1772 .dwtag DW_TAG_member
.dwattr $C$DW$1772, DW_AT_type(*$C$DW$T$884)
.dwattr $C$DW$1772, DW_AT_name("replyId")
.dwattr $C$DW$1772, DW_AT_TI_symbol_name("replyId")
.dwattr $C$DW$1772, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1772, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1772, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1772, DW_AT_decl_line(0x261)
.dwattr $C$DW$1772, DW_AT_decl_column(0x12)
$C$DW$1773 .dwtag DW_TAG_member
.dwattr $C$DW$1773, DW_AT_type(*$C$DW$T$884)
.dwattr $C$DW$1773, DW_AT_name("replyProc")
.dwattr $C$DW$1773, DW_AT_TI_symbol_name("replyProc")
.dwattr $C$DW$1773, DW_AT_data_member_location[DW_OP_plus_uconst 0x16]
.dwattr $C$DW$1773, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1773, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1773, DW_AT_decl_line(0x262)
.dwattr $C$DW$1773, DW_AT_decl_column(0x12)
$C$DW$1774 .dwtag DW_TAG_member
.dwattr $C$DW$1774, DW_AT_type(*$C$DW$T$884)
.dwattr $C$DW$1774, DW_AT_name("srcProc")
.dwattr $C$DW$1774, DW_AT_TI_symbol_name("srcProc")
.dwattr $C$DW$1774, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1774, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1774, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1774, DW_AT_decl_line(0x263)
.dwattr $C$DW$1774, DW_AT_decl_column(0x12)
$C$DW$1775 .dwtag DW_TAG_member
.dwattr $C$DW$1775, DW_AT_type(*$C$DW$T$884)
.dwattr $C$DW$1775, DW_AT_name("heapId")
.dwattr $C$DW$1775, DW_AT_TI_symbol_name("heapId")
.dwattr $C$DW$1775, DW_AT_data_member_location[DW_OP_plus_uconst 0x1a]
.dwattr $C$DW$1775, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1775, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1775, DW_AT_decl_line(0x264)
.dwattr $C$DW$1775, DW_AT_decl_column(0x12)
$C$DW$1776 .dwtag DW_TAG_member
.dwattr $C$DW$1776, DW_AT_type(*$C$DW$T$884)
.dwattr $C$DW$1776, DW_AT_name("seqNum")
.dwattr $C$DW$1776, DW_AT_TI_symbol_name("seqNum")
.dwattr $C$DW$1776, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c]
.dwattr $C$DW$1776, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1776, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1776, DW_AT_decl_line(0x265)
.dwattr $C$DW$1776, DW_AT_decl_column(0x12)
$C$DW$1777 .dwtag DW_TAG_member
.dwattr $C$DW$1777, DW_AT_type(*$C$DW$T$884)
.dwattr $C$DW$1777, DW_AT_name("reserved")
.dwattr $C$DW$1777, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1777, DW_AT_data_member_location[DW_OP_plus_uconst 0x1e]
.dwattr $C$DW$1777, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1777, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1777, DW_AT_decl_line(0x266)
.dwattr $C$DW$1777, DW_AT_decl_column(0x12)
$C$DW$83 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$83, DW_AT_declaration
.dwattr $C$DW$83, DW_AT_TI_symbol_name("_ZN18MessageQ_MsgHeaderaSERKS_")
.dwattr $C$DW$83, DW_AT_type(*$C$DW$T$885)
.dwattr $C$DW$83, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1778 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1778, DW_AT_type(*$C$DW$T$887)
.dwendtag $C$DW$83
.dwendtag $C$DW$T$889
.dwattr $C$DW$T$889, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$889, DW_AT_decl_line(0x259)
.dwattr $C$DW$T$889, DW_AT_decl_column(0x10)
$C$DW$T$886 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$886, DW_AT_type(*$C$DW$T$889)
$C$DW$T$887 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$887, DW_AT_type(*$C$DW$T$886)
.dwattr $C$DW$T$887, DW_AT_address_class(0x20)
$C$DW$T$1529 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_MsgHeader")
.dwattr $C$DW$T$1529, DW_AT_type(*$C$DW$T$889)
.dwattr $C$DW$T$1529, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1529, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$1529, DW_AT_decl_line(0x267)
.dwattr $C$DW$T$1529, DW_AT_decl_column(0x03)
$C$DW$T$1647 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1647, DW_AT_type(*$C$DW$T$1529)
.dwattr $C$DW$T$1647, DW_AT_address_class(0x20)
$C$DW$T$1648 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_Msg")
.dwattr $C$DW$T$1648, DW_AT_type(*$C$DW$T$1647)
.dwattr $C$DW$T$1648, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1648, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$1648, DW_AT_decl_line(0x26c)
.dwattr $C$DW$T$1648, DW_AT_decl_column(0x1d)
$C$DW$T$885 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$885, DW_AT_type(*$C$DW$T$889)
.dwattr $C$DW$T$885, DW_AT_address_class(0x20)
$C$DW$T$888 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$888, DW_AT_type(*$C$DW$T$885)
.dwattr $C$DW$T$888, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1779 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1779, DW_AT_type(*$C$DW$T$887)
.dwendtag $C$DW$T$888
$C$DW$T$92 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$92, DW_AT_name("MessageQ_Object")
.dwattr $C$DW$T$92, DW_AT_declaration
.dwendtag $C$DW$T$92
.dwattr $C$DW$T$92, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$92, DW_AT_decl_line(0x1fa)
.dwattr $C$DW$T$92, DW_AT_decl_column(0x10)
$C$DW$T$2147 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2147, DW_AT_type(*$C$DW$T$92)
.dwattr $C$DW$T$2147, DW_AT_address_class(0x20)
$C$DW$T$2148 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_Handle")
.dwattr $C$DW$T$2148, DW_AT_type(*$C$DW$T$2147)
.dwattr $C$DW$T$2148, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2148, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$2148, DW_AT_decl_line(0x1fa)
.dwattr $C$DW$T$2148, DW_AT_decl_column(0x21)
$C$DW$T$897 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$897, DW_AT_name("MessageQ_Params")
.dwattr $C$DW$T$897, DW_AT_byte_size(0x0c)
$C$DW$1780 .dwtag DW_TAG_member
.dwattr $C$DW$1780, DW_AT_type(*$C$DW$T$890)
.dwattr $C$DW$1780, DW_AT_name("__version")
.dwattr $C$DW$1780, DW_AT_TI_symbol_name("__version")
.dwattr $C$DW$1780, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1780, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1780, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1780, DW_AT_decl_line(0x201)
.dwattr $C$DW$1780, DW_AT_decl_column(0x09)
$C$DW$1781 .dwtag DW_TAG_member
.dwattr $C$DW$1781, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$1781, DW_AT_name("synchronizer")
.dwattr $C$DW$1781, DW_AT_TI_symbol_name("synchronizer")
.dwattr $C$DW$1781, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1781, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1781, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1781, DW_AT_decl_line(0x207)
.dwattr $C$DW$1781, DW_AT_decl_column(0x0b)
$C$DW$1782 .dwtag DW_TAG_member
.dwattr $C$DW$1782, DW_AT_type(*$C$DW$T$892)
.dwattr $C$DW$1782, DW_AT_name("queueIndex")
.dwattr $C$DW$1782, DW_AT_TI_symbol_name("queueIndex")
.dwattr $C$DW$1782, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1782, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1782, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1782, DW_AT_decl_line(0x210)
.dwattr $C$DW$1782, DW_AT_decl_column(0x1a)
$C$DW$84 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$84, DW_AT_declaration
.dwattr $C$DW$84, DW_AT_TI_symbol_name("_ZN15MessageQ_ParamsaSERKS_")
.dwattr $C$DW$84, DW_AT_type(*$C$DW$T$893)
.dwattr $C$DW$84, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1783 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1783, DW_AT_type(*$C$DW$T$895)
.dwendtag $C$DW$84
.dwendtag $C$DW$T$897
.dwattr $C$DW$T$897, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$897, DW_AT_decl_line(0x1ff)
.dwattr $C$DW$T$897, DW_AT_decl_column(0x10)
$C$DW$T$894 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$894, DW_AT_type(*$C$DW$T$897)
$C$DW$T$895 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$895, DW_AT_type(*$C$DW$T$894)
.dwattr $C$DW$T$895, DW_AT_address_class(0x20)
$C$DW$T$2149 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_Params")
.dwattr $C$DW$T$2149, DW_AT_type(*$C$DW$T$897)
.dwattr $C$DW$T$2149, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2149, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$2149, DW_AT_decl_line(0x21f)
.dwattr $C$DW$T$2149, DW_AT_decl_column(0x03)
$C$DW$T$893 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$893, DW_AT_type(*$C$DW$T$897)
.dwattr $C$DW$T$893, DW_AT_address_class(0x20)
$C$DW$T$896 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$896, DW_AT_type(*$C$DW$T$893)
.dwattr $C$DW$T$896, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1784 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1784, DW_AT_type(*$C$DW$T$895)
.dwendtag $C$DW$T$896
$C$DW$T$902 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$902, DW_AT_name("MessageQ_Params2")
.dwattr $C$DW$T$902, DW_AT_byte_size(0x08)
$C$DW$1785 .dwtag DW_TAG_member
.dwattr $C$DW$1785, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$1785, DW_AT_name("synchronizer")
.dwattr $C$DW$1785, DW_AT_TI_symbol_name("synchronizer")
.dwattr $C$DW$1785, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1785, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1785, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1785, DW_AT_decl_line(0x23c)
.dwattr $C$DW$1785, DW_AT_decl_column(0x0b)
$C$DW$1786 .dwtag DW_TAG_member
.dwattr $C$DW$1786, DW_AT_type(*$C$DW$T$892)
.dwattr $C$DW$1786, DW_AT_name("queueIndex")
.dwattr $C$DW$1786, DW_AT_TI_symbol_name("queueIndex")
.dwattr $C$DW$1786, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1786, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1786, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1786, DW_AT_decl_line(0x245)
.dwattr $C$DW$1786, DW_AT_decl_column(0x1a)
$C$DW$85 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$85, DW_AT_declaration
.dwattr $C$DW$85, DW_AT_TI_symbol_name("_ZN16MessageQ_Params2aSERKS_")
.dwattr $C$DW$85, DW_AT_type(*$C$DW$T$898)
.dwattr $C$DW$85, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1787 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1787, DW_AT_type(*$C$DW$T$900)
.dwendtag $C$DW$85
.dwendtag $C$DW$T$902
.dwattr $C$DW$T$902, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$902, DW_AT_decl_line(0x23b)
.dwattr $C$DW$T$902, DW_AT_decl_column(0x10)
$C$DW$T$899 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$899, DW_AT_type(*$C$DW$T$902)
$C$DW$T$900 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$900, DW_AT_type(*$C$DW$T$899)
.dwattr $C$DW$T$900, DW_AT_address_class(0x20)
$C$DW$T$2150 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_Params2")
.dwattr $C$DW$T$2150, DW_AT_type(*$C$DW$T$902)
.dwattr $C$DW$T$2150, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2150, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$2150, DW_AT_decl_line(0x254)
.dwattr $C$DW$T$2150, DW_AT_decl_column(0x03)
$C$DW$T$898 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$898, DW_AT_type(*$C$DW$T$902)
.dwattr $C$DW$T$898, DW_AT_address_class(0x20)
$C$DW$T$901 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$901, DW_AT_type(*$C$DW$T$898)
.dwattr $C$DW$T$901, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1788 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1788, DW_AT_type(*$C$DW$T$900)
.dwendtag $C$DW$T$901
$C$DW$T$2151 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$2151, DW_AT_name("MessageQ_Priority")
.dwattr $C$DW$T$2151, DW_AT_byte_size(0x04)
$C$DW$1789 .dwtag DW_TAG_enumerator, DW_AT_name("MessageQ_NORMALPRI"), DW_AT_const_value(0x00)
.dwattr $C$DW$1789, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1789, DW_AT_decl_line(0x272)
.dwattr $C$DW$1789, DW_AT_decl_column(0x05)
$C$DW$1790 .dwtag DW_TAG_enumerator, DW_AT_name("MessageQ_HIGHPRI"), DW_AT_const_value(0x01)
.dwattr $C$DW$1790, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1790, DW_AT_decl_line(0x273)
.dwattr $C$DW$1790, DW_AT_decl_column(0x05)
$C$DW$1791 .dwtag DW_TAG_enumerator, DW_AT_name("MessageQ_RESERVEDPRI"), DW_AT_const_value(0x02)
.dwattr $C$DW$1791, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1791, DW_AT_decl_line(0x274)
.dwattr $C$DW$1791, DW_AT_decl_column(0x05)
$C$DW$1792 .dwtag DW_TAG_enumerator, DW_AT_name("MessageQ_URGENTPRI"), DW_AT_const_value(0x03)
.dwattr $C$DW$1792, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$1792, DW_AT_decl_line(0x275)
.dwattr $C$DW$1792, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$2151
.dwattr $C$DW$T$2151, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$2151, DW_AT_decl_line(0x271)
.dwattr $C$DW$T$2151, DW_AT_decl_column(0x0e)
$C$DW$T$2152 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_Priority")
.dwattr $C$DW$T$2152, DW_AT_type(*$C$DW$T$2151)
.dwattr $C$DW$T$2152, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2152, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$2152, DW_AT_decl_line(0x276)
.dwattr $C$DW$T$2152, DW_AT_decl_column(0x03)
$C$DW$T$1484 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$1484, DW_AT_name("MsgData")
.dwattr $C$DW$T$1484, DW_AT_byte_size(0xd8)
$C$DW$1793 .dwtag DW_TAG_member
.dwattr $C$DW$1793, DW_AT_type(*$C$DW$T$1469)
.dwattr $C$DW$1793, DW_AT_name("inputMgrData")
.dwattr $C$DW$1793, DW_AT_TI_symbol_name("inputMgrData")
.dwattr $C$DW$1793, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1793, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1793, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1793, DW_AT_decl_line(0xb8)
.dwattr $C$DW$1793, DW_AT_decl_column(0x1d)
$C$DW$1794 .dwtag DW_TAG_member
.dwattr $C$DW$1794, DW_AT_type(*$C$DW$T$1470)
.dwattr $C$DW$1794, DW_AT_name("outputMgrData")
.dwattr $C$DW$1794, DW_AT_TI_symbol_name("outputMgrData")
.dwattr $C$DW$1794, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1794, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1794, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1794, DW_AT_decl_line(0xb9)
.dwattr $C$DW$1794, DW_AT_decl_column(0x1d)
$C$DW$1795 .dwtag DW_TAG_member
.dwattr $C$DW$1795, DW_AT_type(*$C$DW$T$1471)
.dwattr $C$DW$1795, DW_AT_name("mainCtlrData")
.dwattr $C$DW$1795, DW_AT_TI_symbol_name("mainCtlrData")
.dwattr $C$DW$1795, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1795, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1795, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1795, DW_AT_decl_line(0xba)
.dwattr $C$DW$1795, DW_AT_decl_column(0x1d)
$C$DW$1796 .dwtag DW_TAG_member
.dwattr $C$DW$1796, DW_AT_type(*$C$DW$T$1472)
.dwattr $C$DW$1796, DW_AT_name("processMsg")
.dwattr $C$DW$1796, DW_AT_TI_symbol_name("processMsg")
.dwattr $C$DW$1796, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1796, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1796, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1796, DW_AT_decl_line(0xbb)
.dwattr $C$DW$1796, DW_AT_decl_column(0x1d)
$C$DW$1797 .dwtag DW_TAG_member
.dwattr $C$DW$1797, DW_AT_type(*$C$DW$T$1473)
.dwattr $C$DW$1797, DW_AT_name("initMsg")
.dwattr $C$DW$1797, DW_AT_TI_symbol_name("initMsg")
.dwattr $C$DW$1797, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1797, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1797, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1797, DW_AT_decl_line(0xbc)
.dwattr $C$DW$1797, DW_AT_decl_column(0x1d)
$C$DW$1798 .dwtag DW_TAG_member
.dwattr $C$DW$1798, DW_AT_type(*$C$DW$T$1474)
.dwattr $C$DW$1798, DW_AT_name("startMsg")
.dwattr $C$DW$1798, DW_AT_TI_symbol_name("startMsg")
.dwattr $C$DW$1798, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1798, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1798, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1798, DW_AT_decl_line(0xbd)
.dwattr $C$DW$1798, DW_AT_decl_column(0x1d)
$C$DW$1799 .dwtag DW_TAG_member
.dwattr $C$DW$1799, DW_AT_type(*$C$DW$T$1475)
.dwattr $C$DW$1799, DW_AT_name("stopMsg")
.dwattr $C$DW$1799, DW_AT_TI_symbol_name("stopMsg")
.dwattr $C$DW$1799, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1799, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1799, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1799, DW_AT_decl_line(0xbe)
.dwattr $C$DW$1799, DW_AT_decl_column(0x1d)
$C$DW$1800 .dwtag DW_TAG_member
.dwattr $C$DW$1800, DW_AT_type(*$C$DW$T$1476)
.dwattr $C$DW$1800, DW_AT_name("paramUpdateMsg")
.dwattr $C$DW$1800, DW_AT_TI_symbol_name("paramUpdateMsg")
.dwattr $C$DW$1800, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1800, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1800, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1800, DW_AT_decl_line(0xbf)
.dwattr $C$DW$1800, DW_AT_decl_column(0x1d)
$C$DW$1801 .dwtag DW_TAG_member
.dwattr $C$DW$1801, DW_AT_type(*$C$DW$T$1477)
.dwattr $C$DW$1801, DW_AT_name("errorMsg")
.dwattr $C$DW$1801, DW_AT_TI_symbol_name("errorMsg")
.dwattr $C$DW$1801, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1801, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1801, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1801, DW_AT_decl_line(0xc0)
.dwattr $C$DW$1801, DW_AT_decl_column(0x1d)
$C$DW$1802 .dwtag DW_TAG_member
.dwattr $C$DW$1802, DW_AT_type(*$C$DW$T$1478)
.dwattr $C$DW$1802, DW_AT_name("dbellMsg")
.dwattr $C$DW$1802, DW_AT_TI_symbol_name("dbellMsg")
.dwattr $C$DW$1802, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1802, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1802, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1802, DW_AT_decl_line(0xc1)
.dwattr $C$DW$1802, DW_AT_decl_column(0x1d)
$C$DW$1803 .dwtag DW_TAG_member
.dwattr $C$DW$1803, DW_AT_type(*$C$DW$T$1479)
.dwattr $C$DW$1803, DW_AT_name("testInterfaceMsg")
.dwattr $C$DW$1803, DW_AT_TI_symbol_name("testInterfaceMsg")
.dwattr $C$DW$1803, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1803, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1803, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1803, DW_AT_decl_line(0xc2)
.dwattr $C$DW$1803, DW_AT_decl_column(0x1d)
$C$DW$1804 .dwtag DW_TAG_member
.dwattr $C$DW$1804, DW_AT_type(*$C$DW$T$152)
.dwattr $C$DW$1804, DW_AT_name("data")
.dwattr $C$DW$1804, DW_AT_TI_symbol_name("data")
.dwattr $C$DW$1804, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1804, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1804, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1804, DW_AT_decl_line(0xc3)
.dwattr $C$DW$1804, DW_AT_decl_column(0x1d)
$C$DW$86 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$86, DW_AT_declaration
.dwattr $C$DW$86, DW_AT_TI_symbol_name("_ZN7MsgDataaSERKS_")
.dwattr $C$DW$86, DW_AT_type(*$C$DW$T$1480)
.dwattr $C$DW$86, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1805 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1805, DW_AT_type(*$C$DW$T$1482)
.dwendtag $C$DW$86
.dwendtag $C$DW$T$1484
.dwattr $C$DW$T$1484, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1484, DW_AT_decl_line(0xb7)
.dwattr $C$DW$T$1484, DW_AT_decl_column(0x01)
$C$DW$T$1481 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1481, DW_AT_type(*$C$DW$T$1484)
$C$DW$T$1482 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1482, DW_AT_type(*$C$DW$T$1481)
.dwattr $C$DW$T$1482, DW_AT_address_class(0x20)
$C$DW$T$1532 .dwtag DW_TAG_typedef, DW_AT_name("MsgData")
.dwattr $C$DW$T$1532, DW_AT_type(*$C$DW$T$1484)
.dwattr $C$DW$T$1532, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1532, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1532, DW_AT_decl_line(0xc4)
.dwattr $C$DW$T$1532, DW_AT_decl_column(0x03)
$C$DW$T$1480 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1480, DW_AT_type(*$C$DW$T$1484)
.dwattr $C$DW$T$1480, DW_AT_address_class(0x20)
$C$DW$T$1483 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1483, DW_AT_type(*$C$DW$T$1480)
.dwattr $C$DW$T$1483, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1806 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1806, DW_AT_type(*$C$DW$T$1482)
.dwendtag $C$DW$T$1483
$C$DW$T$1518 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1518, DW_AT_name("MultiBeamInputData")
.dwattr $C$DW$T$1518, DW_AT_byte_size(0x10)
$C$DW$1807 .dwtag DW_TAG_member
.dwattr $C$DW$1807, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$1807, DW_AT_name("timeStamp")
.dwattr $C$DW$1807, DW_AT_TI_symbol_name("timeStamp")
.dwattr $C$DW$1807, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1807, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1807, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1807, DW_AT_decl_line(0x22)
.dwattr $C$DW$1807, DW_AT_decl_column(0x19)
$C$DW$1808 .dwtag DW_TAG_member
.dwattr $C$DW$1808, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1808, DW_AT_name("rfBufIdx")
.dwattr $C$DW$1808, DW_AT_TI_symbol_name("rfBufIdx")
.dwattr $C$DW$1808, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1808, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1808, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1808, DW_AT_decl_line(0x23)
.dwattr $C$DW$1808, DW_AT_decl_column(0x19)
$C$DW$87 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$87, DW_AT_declaration
.dwattr $C$DW$87, DW_AT_TI_symbol_name("_ZN18MultiBeamInputDataaSERKS_")
.dwattr $C$DW$87, DW_AT_type(*$C$DW$T$1514)
.dwattr $C$DW$87, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1809 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1809, DW_AT_type(*$C$DW$T$1516)
.dwendtag $C$DW$87
.dwendtag $C$DW$T$1518
.dwattr $C$DW$T$1518, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1518, DW_AT_decl_line(0x20)
.dwattr $C$DW$T$1518, DW_AT_decl_column(0x01)
$C$DW$T$1165 .dwtag DW_TAG_typedef, DW_AT_name("ColorInputData")
.dwattr $C$DW$T$1165, DW_AT_type(*$C$DW$T$1518)
.dwattr $C$DW$T$1165, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1165, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1165, DW_AT_decl_line(0x24)
.dwattr $C$DW$T$1165, DW_AT_decl_column(0x2e)
$C$DW$T$1167 .dwtag DW_TAG_typedef, DW_AT_name("EcgInputData")
.dwattr $C$DW$T$1167, DW_AT_type(*$C$DW$T$1518)
.dwattr $C$DW$T$1167, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1167, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1167, DW_AT_decl_line(0x24)
.dwattr $C$DW$T$1167, DW_AT_decl_column(0x4e)
$C$DW$T$1166 .dwtag DW_TAG_typedef, DW_AT_name("MModeInputData")
.dwattr $C$DW$T$1166, DW_AT_type(*$C$DW$T$1518)
.dwattr $C$DW$T$1166, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1166, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1166, DW_AT_decl_line(0x24)
.dwattr $C$DW$T$1166, DW_AT_decl_column(0x3e)
$C$DW$T$1162 .dwtag DW_TAG_typedef, DW_AT_name("MultiBeamInputData")
.dwattr $C$DW$T$1162, DW_AT_type(*$C$DW$T$1518)
.dwattr $C$DW$T$1162, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1162, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1162, DW_AT_decl_line(0x24)
.dwattr $C$DW$T$1162, DW_AT_decl_column(0x03)
$C$DW$T$1515 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1515, DW_AT_type(*$C$DW$T$1518)
$C$DW$T$1516 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1516, DW_AT_type(*$C$DW$T$1515)
.dwattr $C$DW$T$1516, DW_AT_address_class(0x20)
$C$DW$T$1163 .dwtag DW_TAG_typedef, DW_AT_name("NonMultiBeamInputData")
.dwattr $C$DW$T$1163, DW_AT_type(*$C$DW$T$1518)
.dwattr $C$DW$T$1163, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1163, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1163, DW_AT_decl_line(0x24)
.dwattr $C$DW$T$1163, DW_AT_decl_column(0x17)
$C$DW$T$1514 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1514, DW_AT_type(*$C$DW$T$1518)
.dwattr $C$DW$T$1514, DW_AT_address_class(0x20)
$C$DW$T$1517 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1517, DW_AT_type(*$C$DW$T$1514)
.dwattr $C$DW$T$1517, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1810 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1810, DW_AT_type(*$C$DW$T$1516)
.dwendtag $C$DW$T$1517
$C$DW$T$1528 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1528, DW_AT_name("MultiBeam_Param")
.dwattr $C$DW$T$1528, DW_AT_byte_size(0x1d0)
$C$DW$1811 .dwtag DW_TAG_member
.dwattr $C$DW$1811, DW_AT_type(*$C$DW$T$1519)
.dwattr $C$DW$1811, DW_AT_name("steerAngleParam")
.dwattr $C$DW$1811, DW_AT_TI_symbol_name("steerAngleParam")
.dwattr $C$DW$1811, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1811, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1811, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1811, DW_AT_decl_line(0x2bf)
.dwattr $C$DW$1811, DW_AT_decl_column(0x05)
$C$DW$1812 .dwtag DW_TAG_member
.dwattr $C$DW$1812, DW_AT_type(*$C$DW$T$1521)
.dwattr $C$DW$1812, DW_AT_name("mbeamType")
.dwattr $C$DW$1812, DW_AT_TI_symbol_name("mbeamType")
.dwattr $C$DW$1812, DW_AT_data_member_location[DW_OP_plus_uconst 0x108]
.dwattr $C$DW$1812, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1812, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1812, DW_AT_decl_line(0x2c0)
.dwattr $C$DW$1812, DW_AT_decl_column(0x05)
$C$DW$1813 .dwtag DW_TAG_member
.dwattr $C$DW$1813, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1813, DW_AT_name("taperEnable")
.dwattr $C$DW$1813, DW_AT_TI_symbol_name("taperEnable")
.dwattr $C$DW$1813, DW_AT_data_member_location[DW_OP_plus_uconst 0x110]
.dwattr $C$DW$1813, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1813, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1813, DW_AT_decl_line(0x2c1)
.dwattr $C$DW$1813, DW_AT_decl_column(0x05)
$C$DW$1814 .dwtag DW_TAG_member
.dwattr $C$DW$1814, DW_AT_type(*$C$DW$T$1522)
.dwattr $C$DW$1814, DW_AT_name("taperCoeffs")
.dwattr $C$DW$1814, DW_AT_TI_symbol_name("taperCoeffs")
.dwattr $C$DW$1814, DW_AT_data_member_location[DW_OP_plus_uconst 0x118]
.dwattr $C$DW$1814, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1814, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1814, DW_AT_decl_line(0x2c2)
.dwattr $C$DW$1814, DW_AT_decl_column(0x05)
$C$DW$1815 .dwtag DW_TAG_member
.dwattr $C$DW$1815, DW_AT_type(*$C$DW$T$1523)
.dwattr $C$DW$1815, DW_AT_name("cmpdFactor")
.dwattr $C$DW$1815, DW_AT_TI_symbol_name("cmpdFactor")
.dwattr $C$DW$1815, DW_AT_data_member_location[DW_OP_plus_uconst 0x138]
.dwattr $C$DW$1815, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1815, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1815, DW_AT_decl_line(0x2c3)
.dwattr $C$DW$1815, DW_AT_decl_column(0x05)
$C$DW$1816 .dwtag DW_TAG_member
.dwattr $C$DW$1816, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$1816, DW_AT_name("num_look_directions")
.dwattr $C$DW$1816, DW_AT_TI_symbol_name("num_look_directions")
.dwattr $C$DW$1816, DW_AT_data_member_location[DW_OP_plus_uconst 0x148]
.dwattr $C$DW$1816, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1816, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1816, DW_AT_decl_line(0x2c4)
.dwattr $C$DW$1816, DW_AT_decl_column(0x05)
$C$DW$1817 .dwtag DW_TAG_member
.dwattr $C$DW$1817, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1817, DW_AT_name("trapezoidEnable")
.dwattr $C$DW$1817, DW_AT_TI_symbol_name("trapezoidEnable")
.dwattr $C$DW$1817, DW_AT_data_member_location[DW_OP_plus_uconst 0x150]
.dwattr $C$DW$1817, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1817, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1817, DW_AT_decl_line(0x2c5)
.dwattr $C$DW$1817, DW_AT_decl_column(0x05)
$C$DW$1818 .dwtag DW_TAG_member
.dwattr $C$DW$1818, DW_AT_type(*$C$DW$T$1291)
.dwattr $C$DW$1818, DW_AT_name("reserved")
.dwattr $C$DW$1818, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1818, DW_AT_data_member_location[DW_OP_plus_uconst 0x158]
.dwattr $C$DW$1818, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1818, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1818, DW_AT_decl_line(0x2c6)
.dwattr $C$DW$1818, DW_AT_decl_column(0x05)
$C$DW$88 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$88, DW_AT_declaration
.dwattr $C$DW$88, DW_AT_TI_symbol_name("_ZN15MultiBeam_ParamaSERKS_")
.dwattr $C$DW$88, DW_AT_type(*$C$DW$T$1524)
.dwattr $C$DW$88, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1819 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1819, DW_AT_type(*$C$DW$T$1526)
.dwendtag $C$DW$88
.dwendtag $C$DW$T$1528
.dwattr $C$DW$T$1528, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1528, DW_AT_decl_line(0x2be)
.dwattr $C$DW$T$1528, DW_AT_decl_column(0x01)
$C$DW$T$1525 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1525, DW_AT_type(*$C$DW$T$1528)
$C$DW$T$1526 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1526, DW_AT_type(*$C$DW$T$1525)
.dwattr $C$DW$T$1526, DW_AT_address_class(0x20)
$C$DW$T$1581 .dwtag DW_TAG_typedef, DW_AT_name("MultiBeam_Param")
.dwattr $C$DW$T$1581, DW_AT_type(*$C$DW$T$1528)
.dwattr $C$DW$T$1581, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1581, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1581, DW_AT_decl_line(0x2c7)
.dwattr $C$DW$T$1581, DW_AT_decl_column(0x03)
$C$DW$T$1524 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1524, DW_AT_type(*$C$DW$T$1528)
.dwattr $C$DW$T$1524, DW_AT_address_class(0x20)
$C$DW$T$1527 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1527, DW_AT_type(*$C$DW$T$1524)
.dwattr $C$DW$T$1527, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1820 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1820, DW_AT_type(*$C$DW$T$1526)
.dwendtag $C$DW$T$1527
$C$DW$T$1520 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1520, DW_AT_name("MultiBeam_Type")
.dwattr $C$DW$T$1520, DW_AT_byte_size(0x04)
$C$DW$1821 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_0_NoSC"), DW_AT_const_value(0x00)
.dwattr $C$DW$1821, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1821, DW_AT_decl_line(0xf0)
.dwattr $C$DW$1821, DW_AT_decl_column(0x05)
$C$DW$1822 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_1_NoSC"), DW_AT_const_value(0x01)
.dwattr $C$DW$1822, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1822, DW_AT_decl_line(0xf1)
.dwattr $C$DW$1822, DW_AT_decl_column(0x05)
$C$DW$1823 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_2_NoSC"), DW_AT_const_value(0x02)
.dwattr $C$DW$1823, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1823, DW_AT_decl_line(0xf2)
.dwattr $C$DW$1823, DW_AT_decl_column(0x05)
$C$DW$1824 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_3_NoSC"), DW_AT_const_value(0x03)
.dwattr $C$DW$1824, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1824, DW_AT_decl_line(0xf3)
.dwattr $C$DW$1824, DW_AT_decl_column(0x05)
$C$DW$1825 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_4_NoSC"), DW_AT_const_value(0x04)
.dwattr $C$DW$1825, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1825, DW_AT_decl_line(0xf4)
.dwattr $C$DW$1825, DW_AT_decl_column(0x05)
$C$DW$1826 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_5_NoSC"), DW_AT_const_value(0x05)
.dwattr $C$DW$1826, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1826, DW_AT_decl_line(0xf5)
.dwattr $C$DW$1826, DW_AT_decl_column(0x05)
$C$DW$1827 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_6_NoSC"), DW_AT_const_value(0x06)
.dwattr $C$DW$1827, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1827, DW_AT_decl_line(0xf6)
.dwattr $C$DW$1827, DW_AT_decl_column(0x05)
$C$DW$1828 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_7_NoSC"), DW_AT_const_value(0x07)
.dwattr $C$DW$1828, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1828, DW_AT_decl_line(0xf7)
.dwattr $C$DW$1828, DW_AT_decl_column(0x05)
$C$DW$1829 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_8_NoSC"), DW_AT_const_value(0x08)
.dwattr $C$DW$1829, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1829, DW_AT_decl_line(0xf8)
.dwattr $C$DW$1829, DW_AT_decl_column(0x05)
$C$DW$1830 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_NV_NoSC"), DW_AT_const_value(0x09)
.dwattr $C$DW$1830, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1830, DW_AT_decl_line(0xf9)
.dwattr $C$DW$1830, DW_AT_decl_column(0x05)
$C$DW$1831 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_ANGLE_SEL_MASK"), DW_AT_const_value(0xfff)
.dwattr $C$DW$1831, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1831, DW_AT_decl_line(0xfa)
.dwattr $C$DW$1831, DW_AT_decl_column(0x05)
$C$DW$1832 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_0_wSC"), DW_AT_const_value(0x1000)
.dwattr $C$DW$1832, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1832, DW_AT_decl_line(0xfb)
.dwattr $C$DW$1832, DW_AT_decl_column(0x05)
$C$DW$1833 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_1_wSC"), DW_AT_const_value(0x1001)
.dwattr $C$DW$1833, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1833, DW_AT_decl_line(0xfc)
.dwattr $C$DW$1833, DW_AT_decl_column(0x05)
$C$DW$1834 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_2_wSC"), DW_AT_const_value(0x1002)
.dwattr $C$DW$1834, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1834, DW_AT_decl_line(0xfd)
.dwattr $C$DW$1834, DW_AT_decl_column(0x05)
$C$DW$1835 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_3_wSC"), DW_AT_const_value(0x1003)
.dwattr $C$DW$1835, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1835, DW_AT_decl_line(0xfe)
.dwattr $C$DW$1835, DW_AT_decl_column(0x05)
$C$DW$1836 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_4_wSC"), DW_AT_const_value(0x1004)
.dwattr $C$DW$1836, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1836, DW_AT_decl_line(0xff)
.dwattr $C$DW$1836, DW_AT_decl_column(0x05)
$C$DW$1837 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_5_wSC"), DW_AT_const_value(0x1005)
.dwattr $C$DW$1837, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1837, DW_AT_decl_line(0x100)
.dwattr $C$DW$1837, DW_AT_decl_column(0x05)
$C$DW$1838 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_6_wSC"), DW_AT_const_value(0x1006)
.dwattr $C$DW$1838, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1838, DW_AT_decl_line(0x101)
.dwattr $C$DW$1838, DW_AT_decl_column(0x05)
$C$DW$1839 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_7_wSC"), DW_AT_const_value(0x1007)
.dwattr $C$DW$1839, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1839, DW_AT_decl_line(0x102)
.dwattr $C$DW$1839, DW_AT_decl_column(0x05)
$C$DW$1840 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_8_wSC"), DW_AT_const_value(0x1008)
.dwattr $C$DW$1840, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1840, DW_AT_decl_line(0x103)
.dwattr $C$DW$1840, DW_AT_decl_column(0x05)
$C$DW$1841 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_NV_wSC"), DW_AT_const_value(0x1009)
.dwattr $C$DW$1841, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1841, DW_AT_decl_line(0x104)
.dwattr $C$DW$1841, DW_AT_decl_column(0x05)
$C$DW$1842 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_NORMAL"), DW_AT_const_value(0x3000)
.dwattr $C$DW$1842, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1842, DW_AT_decl_line(0x105)
.dwattr $C$DW$1842, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1520
.dwattr $C$DW$T$1520, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1520, DW_AT_decl_line(0xef)
.dwattr $C$DW$T$1520, DW_AT_decl_column(0x01)
$C$DW$T$1521 .dwtag DW_TAG_typedef, DW_AT_name("MultiBeam_Type")
.dwattr $C$DW$T$1521, DW_AT_type(*$C$DW$T$1520)
.dwattr $C$DW$T$1521, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1521, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1521, DW_AT_decl_line(0x106)
.dwattr $C$DW$T$1521, DW_AT_decl_column(0x03)
$C$DW$T$1538 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1538, DW_AT_name("MulticoreMsg_tag")
.dwattr $C$DW$T$1538, DW_AT_byte_size(0x200)
$C$DW$1843 .dwtag DW_TAG_member
.dwattr $C$DW$1843, DW_AT_type(*$C$DW$T$1529)
.dwattr $C$DW$1843, DW_AT_name("header")
.dwattr $C$DW$1843, DW_AT_TI_symbol_name("header")
.dwattr $C$DW$1843, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1843, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1843, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1843, DW_AT_decl_line(0xcd)
.dwattr $C$DW$1843, DW_AT_decl_column(0x19)
$C$DW$1844 .dwtag DW_TAG_member
.dwattr $C$DW$1844, DW_AT_type(*$C$DW$T$1531)
.dwattr $C$DW$1844, DW_AT_name("msgType")
.dwattr $C$DW$1844, DW_AT_TI_symbol_name("msgType")
.dwattr $C$DW$1844, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1844, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1844, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1844, DW_AT_decl_line(0xce)
.dwattr $C$DW$1844, DW_AT_decl_column(0x19)
$C$DW$1845 .dwtag DW_TAG_member
.dwattr $C$DW$1845, DW_AT_type(*$C$DW$T$1532)
.dwattr $C$DW$1845, DW_AT_name("content")
.dwattr $C$DW$1845, DW_AT_TI_symbol_name("content")
.dwattr $C$DW$1845, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1845, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1845, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1845, DW_AT_decl_line(0xcf)
.dwattr $C$DW$1845, DW_AT_decl_column(0x19)
$C$DW$1846 .dwtag DW_TAG_member
.dwattr $C$DW$1846, DW_AT_type(*$C$DW$T$1533)
.dwattr $C$DW$1846, DW_AT_name("filler")
.dwattr $C$DW$1846, DW_AT_TI_symbol_name("filler")
.dwattr $C$DW$1846, DW_AT_data_member_location[DW_OP_plus_uconst 0x100]
.dwattr $C$DW$1846, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1846, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1846, DW_AT_decl_line(0xd1)
.dwattr $C$DW$1846, DW_AT_decl_column(0x19)
$C$DW$89 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$89, DW_AT_declaration
.dwattr $C$DW$89, DW_AT_TI_symbol_name("_ZN16MulticoreMsg_tagaSERKS_")
.dwattr $C$DW$89, DW_AT_type(*$C$DW$T$1534)
.dwattr $C$DW$89, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1847 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1847, DW_AT_type(*$C$DW$T$1536)
.dwendtag $C$DW$89
.dwendtag $C$DW$T$1538
.dwattr $C$DW$T$1538, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1538, DW_AT_decl_line(0xcb)
.dwattr $C$DW$T$1538, DW_AT_decl_column(0x10)
$C$DW$T$2208 .dwtag DW_TAG_typedef, DW_AT_name("MulticoreMsg")
.dwattr $C$DW$T$2208, DW_AT_type(*$C$DW$T$1538)
.dwattr $C$DW$T$2208, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2208, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$2208, DW_AT_decl_line(0xd2)
.dwattr $C$DW$T$2208, DW_AT_decl_column(0x03)
$C$DW$T$1535 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1535, DW_AT_type(*$C$DW$T$1538)
$C$DW$T$1536 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1536, DW_AT_type(*$C$DW$T$1535)
.dwattr $C$DW$T$1536, DW_AT_address_class(0x20)
$C$DW$T$1534 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1534, DW_AT_type(*$C$DW$T$1538)
.dwattr $C$DW$T$1534, DW_AT_address_class(0x20)
$C$DW$T$1537 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1537, DW_AT_type(*$C$DW$T$1534)
.dwattr $C$DW$T$1537, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1848 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1848, DW_AT_type(*$C$DW$T$1536)
.dwendtag $C$DW$T$1537
$C$DW$T$1543 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1543, DW_AT_name("Multiline_Param")
.dwattr $C$DW$T$1543, DW_AT_byte_size(0xa0)
$C$DW$1849 .dwtag DW_TAG_member
.dwattr $C$DW$1849, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1849, DW_AT_name("rfBuffNumMl")
.dwattr $C$DW$1849, DW_AT_TI_symbol_name("rfBuffNumMl")
.dwattr $C$DW$1849, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1849, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1849, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1849, DW_AT_decl_line(0x416)
.dwattr $C$DW$1849, DW_AT_decl_column(0x05)
$C$DW$1850 .dwtag DW_TAG_member
.dwattr $C$DW$1850, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1850, DW_AT_name("mpfOutMl")
.dwattr $C$DW$1850, DW_AT_TI_symbol_name("mpfOutMl")
.dwattr $C$DW$1850, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1850, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1850, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1850, DW_AT_decl_line(0x417)
.dwattr $C$DW$1850, DW_AT_decl_column(0x05)
$C$DW$1851 .dwtag DW_TAG_member
.dwattr $C$DW$1851, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1851, DW_AT_name("rdBufNumPings")
.dwattr $C$DW$1851, DW_AT_TI_symbol_name("rdBufNumPings")
.dwattr $C$DW$1851, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1851, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1851, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1851, DW_AT_decl_line(0x418)
.dwattr $C$DW$1851, DW_AT_decl_column(0x05)
$C$DW$1852 .dwtag DW_TAG_member
.dwattr $C$DW$1852, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1852, DW_AT_name("direction")
.dwattr $C$DW$1852, DW_AT_TI_symbol_name("direction")
.dwattr $C$DW$1852, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1852, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1852, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1852, DW_AT_decl_line(0x419)
.dwattr $C$DW$1852, DW_AT_decl_column(0x05)
$C$DW$1853 .dwtag DW_TAG_member
.dwattr $C$DW$1853, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1853, DW_AT_name("reserved")
.dwattr $C$DW$1853, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1853, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1853, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1853, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1853, DW_AT_decl_line(0x41a)
.dwattr $C$DW$1853, DW_AT_decl_column(0x05)
$C$DW$90 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$90, DW_AT_declaration
.dwattr $C$DW$90, DW_AT_TI_symbol_name("_ZN15Multiline_ParamaSERKS_")
.dwattr $C$DW$90, DW_AT_type(*$C$DW$T$1539)
.dwattr $C$DW$90, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1854 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1854, DW_AT_type(*$C$DW$T$1541)
.dwendtag $C$DW$90
.dwendtag $C$DW$T$1543
.dwattr $C$DW$T$1543, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1543, DW_AT_decl_line(0x415)
.dwattr $C$DW$T$1543, DW_AT_decl_column(0x01)
$C$DW$T$1182 .dwtag DW_TAG_typedef, DW_AT_name("Multiline_Param")
.dwattr $C$DW$T$1182, DW_AT_type(*$C$DW$T$1543)
.dwattr $C$DW$T$1182, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1182, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1182, DW_AT_decl_line(0x41b)
.dwattr $C$DW$T$1182, DW_AT_decl_column(0x03)
$C$DW$T$1540 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1540, DW_AT_type(*$C$DW$T$1543)
$C$DW$T$1541 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1541, DW_AT_type(*$C$DW$T$1540)
.dwattr $C$DW$T$1541, DW_AT_address_class(0x20)
$C$DW$T$1539 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1539, DW_AT_type(*$C$DW$T$1543)
.dwattr $C$DW$T$1539, DW_AT_address_class(0x20)
$C$DW$T$1542 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1542, DW_AT_type(*$C$DW$T$1539)
.dwattr $C$DW$T$1542, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1855 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1855, DW_AT_type(*$C$DW$T$1541)
.dwendtag $C$DW$T$1542
$C$DW$T$173 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$173, DW_AT_name("NTV_Param")
.dwattr $C$DW$T$173, DW_AT_byte_size(0x4c0)
$C$DW$1856 .dwtag DW_TAG_member
.dwattr $C$DW$1856, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1856, DW_AT_name("startRayInFeRd")
.dwattr $C$DW$1856, DW_AT_TI_symbol_name("startRayInFeRd")
.dwattr $C$DW$1856, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1856, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1856, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1856, DW_AT_decl_line(0x3e9)
.dwattr $C$DW$1856, DW_AT_decl_column(0x05)
$C$DW$1857 .dwtag DW_TAG_member
.dwattr $C$DW$1857, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1857, DW_AT_name("rayIncrement")
.dwattr $C$DW$1857, DW_AT_TI_symbol_name("rayIncrement")
.dwattr $C$DW$1857, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1857, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1857, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1857, DW_AT_decl_line(0x3ea)
.dwattr $C$DW$1857, DW_AT_decl_column(0x05)
$C$DW$1858 .dwtag DW_TAG_member
.dwattr $C$DW$1858, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1858, DW_AT_name("numMLs")
.dwattr $C$DW$1858, DW_AT_TI_symbol_name("numMLs")
.dwattr $C$DW$1858, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1858, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1858, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1858, DW_AT_decl_line(0x3eb)
.dwattr $C$DW$1858, DW_AT_decl_column(0x05)
$C$DW$1859 .dwtag DW_TAG_member
.dwattr $C$DW$1859, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1859, DW_AT_name("inpLinesPerFrame")
.dwattr $C$DW$1859, DW_AT_TI_symbol_name("inpLinesPerFrame")
.dwattr $C$DW$1859, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1859, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1859, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1859, DW_AT_decl_line(0x3ec)
.dwattr $C$DW$1859, DW_AT_decl_column(0x05)
$C$DW$1860 .dwtag DW_TAG_member
.dwattr $C$DW$1860, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1860, DW_AT_name("inpEstimatesPerLine")
.dwattr $C$DW$1860, DW_AT_TI_symbol_name("inpEstimatesPerLine")
.dwattr $C$DW$1860, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1860, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1860, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1860, DW_AT_decl_line(0x3ed)
.dwattr $C$DW$1860, DW_AT_decl_column(0x05)
$C$DW$1861 .dwtag DW_TAG_member
.dwattr $C$DW$1861, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1861, DW_AT_name("halfDecRateEnable")
.dwattr $C$DW$1861, DW_AT_TI_symbol_name("halfDecRateEnable")
.dwattr $C$DW$1861, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1861, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1861, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1861, DW_AT_decl_line(0x3ee)
.dwattr $C$DW$1861, DW_AT_decl_column(0x05)
$C$DW$1862 .dwtag DW_TAG_member
.dwattr $C$DW$1862, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$1862, DW_AT_name("persistenceFactor")
.dwattr $C$DW$1862, DW_AT_TI_symbol_name("persistenceFactor")
.dwattr $C$DW$1862, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1862, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1862, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1862, DW_AT_decl_line(0x3ef)
.dwattr $C$DW$1862, DW_AT_decl_column(0x05)
$C$DW$1863 .dwtag DW_TAG_member
.dwattr $C$DW$1863, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$1863, DW_AT_name("lateralThreshold")
.dwattr $C$DW$1863, DW_AT_TI_symbol_name("lateralThreshold")
.dwattr $C$DW$1863, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$1863, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1863, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1863, DW_AT_decl_line(0x3f0)
.dwattr $C$DW$1863, DW_AT_decl_column(0x05)
$C$DW$1864 .dwtag DW_TAG_member
.dwattr $C$DW$1864, DW_AT_type(*$C$DW$T$168)
.dwattr $C$DW$1864, DW_AT_name("remapTable")
.dwattr $C$DW$1864, DW_AT_TI_symbol_name("remapTable")
.dwattr $C$DW$1864, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$1864, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1864, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1864, DW_AT_decl_line(0x3f1)
.dwattr $C$DW$1864, DW_AT_decl_column(0x05)
$C$DW$1865 .dwtag DW_TAG_member
.dwattr $C$DW$1865, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1865, DW_AT_name("reserved")
.dwattr $C$DW$1865, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1865, DW_AT_data_member_location[DW_OP_plus_uconst 0x440]
.dwattr $C$DW$1865, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1865, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1865, DW_AT_decl_line(0x3f3)
.dwattr $C$DW$1865, DW_AT_decl_column(0x05)
$C$DW$91 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$91, DW_AT_declaration
.dwattr $C$DW$91, DW_AT_TI_symbol_name("_ZN9NTV_ParamaSERKS_")
.dwattr $C$DW$91, DW_AT_type(*$C$DW$T$169)
.dwattr $C$DW$91, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1866 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1866, DW_AT_type(*$C$DW$T$171)
.dwendtag $C$DW$91
.dwendtag $C$DW$T$173
.dwattr $C$DW$T$173, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$173, DW_AT_decl_line(0x3e8)
.dwattr $C$DW$T$173, DW_AT_decl_column(0x01)
$C$DW$T$170 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$170, DW_AT_type(*$C$DW$T$173)
$C$DW$T$171 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$171, DW_AT_type(*$C$DW$T$170)
.dwattr $C$DW$T$171, DW_AT_address_class(0x20)
$C$DW$T$356 .dwtag DW_TAG_typedef, DW_AT_name("NTV_Param")
.dwattr $C$DW$T$356, DW_AT_type(*$C$DW$T$173)
.dwattr $C$DW$T$356, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$356, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$356, DW_AT_decl_line(0x3f4)
.dwattr $C$DW$T$356, DW_AT_decl_column(0x03)
$C$DW$T$169 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$169, DW_AT_type(*$C$DW$T$173)
.dwattr $C$DW$T$169, DW_AT_address_class(0x20)
$C$DW$T$172 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$172, DW_AT_type(*$C$DW$T$169)
.dwattr $C$DW$T$172, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1867 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1867, DW_AT_type(*$C$DW$T$171)
.dwendtag $C$DW$T$172
$C$DW$T$194 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$194, DW_AT_name("NV_Param")
.dwattr $C$DW$T$194, DW_AT_byte_size(0x138)
$C$DW$1868 .dwtag DW_TAG_member
.dwattr $C$DW$1868, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1868, DW_AT_name("startRayInFeRd")
.dwattr $C$DW$1868, DW_AT_TI_symbol_name("startRayInFeRd")
.dwattr $C$DW$1868, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1868, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1868, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1868, DW_AT_decl_line(0x2cb)
.dwattr $C$DW$1868, DW_AT_decl_column(0x05)
$C$DW$1869 .dwtag DW_TAG_member
.dwattr $C$DW$1869, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1869, DW_AT_name("rayIncrement")
.dwattr $C$DW$1869, DW_AT_TI_symbol_name("rayIncrement")
.dwattr $C$DW$1869, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1869, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1869, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1869, DW_AT_decl_line(0x2cc)
.dwattr $C$DW$1869, DW_AT_decl_column(0x05)
$C$DW$1870 .dwtag DW_TAG_member
.dwattr $C$DW$1870, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1870, DW_AT_name("numMLs")
.dwattr $C$DW$1870, DW_AT_TI_symbol_name("numMLs")
.dwattr $C$DW$1870, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1870, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1870, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1870, DW_AT_decl_line(0x2cd)
.dwattr $C$DW$1870, DW_AT_decl_column(0x05)
$C$DW$1871 .dwtag DW_TAG_member
.dwattr $C$DW$1871, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1871, DW_AT_name("inpLinesPerFrame")
.dwattr $C$DW$1871, DW_AT_TI_symbol_name("inpLinesPerFrame")
.dwattr $C$DW$1871, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1871, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1871, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1871, DW_AT_decl_line(0x2ce)
.dwattr $C$DW$1871, DW_AT_decl_column(0x05)
$C$DW$1872 .dwtag DW_TAG_member
.dwattr $C$DW$1872, DW_AT_type(*$C$DW$T$186)
.dwattr $C$DW$1872, DW_AT_name("inpEstimatesPerLine")
.dwattr $C$DW$1872, DW_AT_TI_symbol_name("inpEstimatesPerLine")
.dwattr $C$DW$1872, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1872, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1872, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1872, DW_AT_decl_line(0x2cf)
.dwattr $C$DW$1872, DW_AT_decl_column(0x05)
$C$DW$1873 .dwtag DW_TAG_member
.dwattr $C$DW$1873, DW_AT_type(*$C$DW$T$187)
.dwattr $C$DW$1873, DW_AT_name("steerAngle")
.dwattr $C$DW$1873, DW_AT_TI_symbol_name("steerAngle")
.dwattr $C$DW$1873, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1873, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1873, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1873, DW_AT_decl_line(0x2d0)
.dwattr $C$DW$1873, DW_AT_decl_column(0x05)
$C$DW$1874 .dwtag DW_TAG_member
.dwattr $C$DW$1874, DW_AT_type(*$C$DW$T$188)
.dwattr $C$DW$1874, DW_AT_name("decimation")
.dwattr $C$DW$1874, DW_AT_TI_symbol_name("decimation")
.dwattr $C$DW$1874, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$1874, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1874, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1874, DW_AT_decl_line(0x2d1)
.dwattr $C$DW$1874, DW_AT_decl_column(0x05)
$C$DW$1875 .dwtag DW_TAG_member
.dwattr $C$DW$1875, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1875, DW_AT_name("score_window")
.dwattr $C$DW$1875, DW_AT_TI_symbol_name("score_window")
.dwattr $C$DW$1875, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$1875, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1875, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1875, DW_AT_decl_line(0x2d2)
.dwattr $C$DW$1875, DW_AT_decl_column(0x05)
$C$DW$1876 .dwtag DW_TAG_member
.dwattr $C$DW$1876, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1876, DW_AT_name("score_threshold")
.dwattr $C$DW$1876, DW_AT_TI_symbol_name("score_threshold")
.dwattr $C$DW$1876, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$1876, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1876, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1876, DW_AT_decl_line(0x2d3)
.dwattr $C$DW$1876, DW_AT_decl_column(0x05)
$C$DW$1877 .dwtag DW_TAG_member
.dwattr $C$DW$1877, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1877, DW_AT_name("blend_type")
.dwattr $C$DW$1877, DW_AT_TI_symbol_name("blend_type")
.dwattr $C$DW$1877, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$1877, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1877, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1877, DW_AT_decl_line(0x2d4)
.dwattr $C$DW$1877, DW_AT_decl_column(0x05)
$C$DW$1878 .dwtag DW_TAG_member
.dwattr $C$DW$1878, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1878, DW_AT_name("mask_half_width")
.dwattr $C$DW$1878, DW_AT_TI_symbol_name("mask_half_width")
.dwattr $C$DW$1878, DW_AT_data_member_location[DW_OP_plus_uconst 0x68]
.dwattr $C$DW$1878, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1878, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1878, DW_AT_decl_line(0x2d5)
.dwattr $C$DW$1878, DW_AT_decl_column(0x05)
$C$DW$1879 .dwtag DW_TAG_member
.dwattr $C$DW$1879, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1879, DW_AT_name("trk_lo_thresh")
.dwattr $C$DW$1879, DW_AT_TI_symbol_name("trk_lo_thresh")
.dwattr $C$DW$1879, DW_AT_data_member_location[DW_OP_plus_uconst 0x70]
.dwattr $C$DW$1879, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1879, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1879, DW_AT_decl_line(0x2d6)
.dwattr $C$DW$1879, DW_AT_decl_column(0x05)
$C$DW$1880 .dwtag DW_TAG_member
.dwattr $C$DW$1880, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1880, DW_AT_name("trk_hi_thresh")
.dwattr $C$DW$1880, DW_AT_TI_symbol_name("trk_hi_thresh")
.dwattr $C$DW$1880, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$1880, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1880, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1880, DW_AT_decl_line(0x2d7)
.dwattr $C$DW$1880, DW_AT_decl_column(0x05)
$C$DW$1881 .dwtag DW_TAG_member
.dwattr $C$DW$1881, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1881, DW_AT_name("det_dec_facX")
.dwattr $C$DW$1881, DW_AT_TI_symbol_name("det_dec_facX")
.dwattr $C$DW$1881, DW_AT_data_member_location[DW_OP_plus_uconst 0x80]
.dwattr $C$DW$1881, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1881, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1881, DW_AT_decl_line(0x2d8)
.dwattr $C$DW$1881, DW_AT_decl_column(0x05)
$C$DW$1882 .dwtag DW_TAG_member
.dwattr $C$DW$1882, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1882, DW_AT_name("det_dec_facY")
.dwattr $C$DW$1882, DW_AT_TI_symbol_name("det_dec_facY")
.dwattr $C$DW$1882, DW_AT_data_member_location[DW_OP_plus_uconst 0x88]
.dwattr $C$DW$1882, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1882, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1882, DW_AT_decl_line(0x2d9)
.dwattr $C$DW$1882, DW_AT_decl_column(0x05)
$C$DW$1883 .dwtag DW_TAG_member
.dwattr $C$DW$1883, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$1883, DW_AT_name("num_NVlooks")
.dwattr $C$DW$1883, DW_AT_TI_symbol_name("num_NVlooks")
.dwattr $C$DW$1883, DW_AT_data_member_location[DW_OP_plus_uconst 0x90]
.dwattr $C$DW$1883, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1883, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1883, DW_AT_decl_line(0x2da)
.dwattr $C$DW$1883, DW_AT_decl_column(0x05)
$C$DW$1884 .dwtag DW_TAG_member
.dwattr $C$DW$1884, DW_AT_type(*$C$DW$T$189)
.dwattr $C$DW$1884, DW_AT_name("nvContextAddrForDebug")
.dwattr $C$DW$1884, DW_AT_TI_symbol_name("nvContextAddrForDebug")
.dwattr $C$DW$1884, DW_AT_data_member_location[DW_OP_plus_uconst 0x98]
.dwattr $C$DW$1884, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1884, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1884, DW_AT_decl_line(0x2db)
.dwattr $C$DW$1884, DW_AT_decl_column(0x05)
$C$DW$1885 .dwtag DW_TAG_member
.dwattr $C$DW$1885, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1885, DW_AT_name("reserved")
.dwattr $C$DW$1885, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1885, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8]
.dwattr $C$DW$1885, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1885, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1885, DW_AT_decl_line(0x2dc)
.dwattr $C$DW$1885, DW_AT_decl_column(0x05)
$C$DW$92 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$92, DW_AT_declaration
.dwattr $C$DW$92, DW_AT_TI_symbol_name("_ZN8NV_ParamaSERKS_")
.dwattr $C$DW$92, DW_AT_type(*$C$DW$T$190)
.dwattr $C$DW$92, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1886 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1886, DW_AT_type(*$C$DW$T$192)
.dwendtag $C$DW$92
.dwendtag $C$DW$T$194
.dwattr $C$DW$T$194, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$194, DW_AT_decl_line(0x2ca)
.dwattr $C$DW$T$194, DW_AT_decl_column(0x01)
$C$DW$T$191 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$191, DW_AT_type(*$C$DW$T$194)
$C$DW$T$192 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$192, DW_AT_type(*$C$DW$T$191)
.dwattr $C$DW$T$192, DW_AT_address_class(0x20)
$C$DW$T$1601 .dwtag DW_TAG_typedef, DW_AT_name("NV_Param")
.dwattr $C$DW$T$1601, DW_AT_type(*$C$DW$T$194)
.dwattr $C$DW$T$1601, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1601, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1601, DW_AT_decl_line(0x2dd)
.dwattr $C$DW$T$1601, DW_AT_decl_column(0x03)
$C$DW$T$190 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$190, DW_AT_type(*$C$DW$T$194)
.dwattr $C$DW$T$190, DW_AT_address_class(0x20)
$C$DW$T$193 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$193, DW_AT_type(*$C$DW$T$190)
.dwattr $C$DW$T$193, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1887 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1887, DW_AT_type(*$C$DW$T$192)
.dwendtag $C$DW$T$193
$C$DW$T$1571 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1571, DW_AT_name("OutputMgrData")
.dwattr $C$DW$T$1571, DW_AT_byte_size(0x04)
$C$DW$1888 .dwtag DW_TAG_member
.dwattr $C$DW$1888, DW_AT_type(*$C$DW$T$510)
.dwattr $C$DW$1888, DW_AT_name("spDataType")
.dwattr $C$DW$1888, DW_AT_TI_symbol_name("spDataType")
.dwattr $C$DW$1888, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1888, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1888, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1888, DW_AT_decl_line(0x45)
.dwattr $C$DW$1888, DW_AT_decl_column(0x16)
$C$DW$93 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$93, DW_AT_declaration
.dwattr $C$DW$93, DW_AT_TI_symbol_name("_ZN13OutputMgrDataaSERKS_")
.dwattr $C$DW$93, DW_AT_type(*$C$DW$T$1567)
.dwattr $C$DW$93, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1889 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1889, DW_AT_type(*$C$DW$T$1569)
.dwendtag $C$DW$93
.dwendtag $C$DW$T$1571
.dwattr $C$DW$T$1571, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1571, DW_AT_decl_line(0x44)
.dwattr $C$DW$T$1571, DW_AT_decl_column(0x01)
$C$DW$T$1470 .dwtag DW_TAG_typedef, DW_AT_name("OutputMgrData")
.dwattr $C$DW$T$1470, DW_AT_type(*$C$DW$T$1571)
.dwattr $C$DW$T$1470, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1470, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1470, DW_AT_decl_line(0x46)
.dwattr $C$DW$T$1470, DW_AT_decl_column(0x03)
$C$DW$T$1568 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1568, DW_AT_type(*$C$DW$T$1571)
$C$DW$T$1569 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1569, DW_AT_type(*$C$DW$T$1568)
.dwattr $C$DW$T$1569, DW_AT_address_class(0x20)
$C$DW$T$1567 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1567, DW_AT_type(*$C$DW$T$1571)
.dwattr $C$DW$T$1567, DW_AT_address_class(0x20)
$C$DW$T$1570 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1570, DW_AT_type(*$C$DW$T$1567)
.dwattr $C$DW$T$1570, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1890 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1890, DW_AT_type(*$C$DW$T$1569)
.dwendtag $C$DW$T$1570
$C$DW$T$348 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$348, DW_AT_name("Pack64")
.dwattr $C$DW$T$348, DW_AT_byte_size(0x08)
$C$DW$1891 .dwtag DW_TAG_member
.dwattr $C$DW$1891, DW_AT_type(*$C$DW$T$342)
.dwattr $C$DW$1891, DW_AT_name("ll")
.dwattr $C$DW$1891, DW_AT_TI_symbol_name("ll")
.dwattr $C$DW$1891, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1891, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1891, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h")
.dwattr $C$DW$1891, DW_AT_decl_line(0x21)
.dwattr $C$DW$1891, DW_AT_decl_column(0x0f)
$C$DW$1892 .dwtag DW_TAG_member
.dwattr $C$DW$1892, DW_AT_type(*$C$DW$T$343)
.dwattr $C$DW$1892, DW_AT_name("p16")
.dwattr $C$DW$1892, DW_AT_TI_symbol_name("p16")
.dwattr $C$DW$1892, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1892, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1892, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h")
.dwattr $C$DW$1892, DW_AT_decl_line(0x22)
.dwattr $C$DW$1892, DW_AT_decl_column(0x0f)
$C$DW$94 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$94, DW_AT_declaration
.dwattr $C$DW$94, DW_AT_TI_symbol_name("_ZN6Pack64aSERKS_")
.dwattr $C$DW$94, DW_AT_type(*$C$DW$T$344)
.dwattr $C$DW$94, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1893 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1893, DW_AT_type(*$C$DW$T$346)
.dwendtag $C$DW$94
.dwendtag $C$DW$T$348
.dwattr $C$DW$T$348, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h")
.dwattr $C$DW$T$348, DW_AT_decl_line(0x20)
.dwattr $C$DW$T$348, DW_AT_decl_column(0x0f)
$C$DW$T$345 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$345, DW_AT_type(*$C$DW$T$348)
$C$DW$T$346 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$346, DW_AT_type(*$C$DW$T$345)
.dwattr $C$DW$T$346, DW_AT_address_class(0x20)
$C$DW$T$1919 .dwtag DW_TAG_typedef, DW_AT_name("Pack64")
.dwattr $C$DW$T$1919, DW_AT_type(*$C$DW$T$348)
.dwattr $C$DW$T$1919, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1919, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h")
.dwattr $C$DW$T$1919, DW_AT_decl_line(0x23)
.dwattr $C$DW$T$1919, DW_AT_decl_column(0x03)
$C$DW$T$344 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$344, DW_AT_type(*$C$DW$T$348)
.dwattr $C$DW$T$344, DW_AT_address_class(0x20)
$C$DW$T$347 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$347, DW_AT_type(*$C$DW$T$344)
.dwattr $C$DW$T$347, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1894 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1894, DW_AT_type(*$C$DW$T$346)
.dwendtag $C$DW$T$347
$C$DW$T$353 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$353, DW_AT_name("Pack64_16")
.dwattr $C$DW$T$353, DW_AT_byte_size(0x08)
$C$DW$1895 .dwtag DW_TAG_member
.dwattr $C$DW$1895, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$1895, DW_AT_name("loLsb")
.dwattr $C$DW$1895, DW_AT_TI_symbol_name("loLsb")
.dwattr $C$DW$1895, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1895, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1895, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h")
.dwattr $C$DW$1895, DW_AT_decl_line(0x1a)
.dwattr $C$DW$1895, DW_AT_decl_column(0x0b)
$C$DW$1896 .dwtag DW_TAG_member
.dwattr $C$DW$1896, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$1896, DW_AT_name("loMsb")
.dwattr $C$DW$1896, DW_AT_TI_symbol_name("loMsb")
.dwattr $C$DW$1896, DW_AT_data_member_location[DW_OP_plus_uconst 0x2]
.dwattr $C$DW$1896, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1896, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h")
.dwattr $C$DW$1896, DW_AT_decl_line(0x1b)
.dwattr $C$DW$1896, DW_AT_decl_column(0x0b)
$C$DW$1897 .dwtag DW_TAG_member
.dwattr $C$DW$1897, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$1897, DW_AT_name("hiLsb")
.dwattr $C$DW$1897, DW_AT_TI_symbol_name("hiLsb")
.dwattr $C$DW$1897, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1897, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1897, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h")
.dwattr $C$DW$1897, DW_AT_decl_line(0x1c)
.dwattr $C$DW$1897, DW_AT_decl_column(0x0b)
$C$DW$1898 .dwtag DW_TAG_member
.dwattr $C$DW$1898, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$1898, DW_AT_name("hiMsb")
.dwattr $C$DW$1898, DW_AT_TI_symbol_name("hiMsb")
.dwattr $C$DW$1898, DW_AT_data_member_location[DW_OP_plus_uconst 0x6]
.dwattr $C$DW$1898, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1898, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h")
.dwattr $C$DW$1898, DW_AT_decl_line(0x1d)
.dwattr $C$DW$1898, DW_AT_decl_column(0x0b)
$C$DW$95 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$95, DW_AT_declaration
.dwattr $C$DW$95, DW_AT_TI_symbol_name("_ZN9Pack64_16aSERKS_")
.dwattr $C$DW$95, DW_AT_type(*$C$DW$T$349)
.dwattr $C$DW$95, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1899 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1899, DW_AT_type(*$C$DW$T$351)
.dwendtag $C$DW$95
.dwendtag $C$DW$T$353
.dwattr $C$DW$T$353, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h")
.dwattr $C$DW$T$353, DW_AT_decl_line(0x19)
.dwattr $C$DW$T$353, DW_AT_decl_column(0x10)
$C$DW$T$343 .dwtag DW_TAG_typedef, DW_AT_name("Pack64_16")
.dwattr $C$DW$T$343, DW_AT_type(*$C$DW$T$353)
.dwattr $C$DW$T$343, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$343, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h")
.dwattr $C$DW$T$343, DW_AT_decl_line(0x1e)
.dwattr $C$DW$T$343, DW_AT_decl_column(0x03)
$C$DW$T$350 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$350, DW_AT_type(*$C$DW$T$353)
$C$DW$T$351 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$351, DW_AT_type(*$C$DW$T$350)
.dwattr $C$DW$T$351, DW_AT_address_class(0x20)
$C$DW$T$349 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$349, DW_AT_type(*$C$DW$T$353)
.dwattr $C$DW$T$349, DW_AT_address_class(0x20)
$C$DW$T$352 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$352, DW_AT_type(*$C$DW$T$349)
.dwattr $C$DW$T$352, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1900 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1900, DW_AT_type(*$C$DW$T$351)
.dwendtag $C$DW$T$352
$C$DW$T$361 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$361, DW_AT_name("Pai_Param")
.dwattr $C$DW$T$361, DW_AT_byte_size(0x548)
$C$DW$1901 .dwtag DW_TAG_member
.dwattr $C$DW$1901, DW_AT_type(*$C$DW$T$355)
.dwattr $C$DW$1901, DW_AT_name("subMode")
.dwattr $C$DW$1901, DW_AT_TI_symbol_name("subMode")
.dwattr $C$DW$1901, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1901, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1901, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1901, DW_AT_decl_line(0x3f8)
.dwattr $C$DW$1901, DW_AT_decl_column(0x05)
$C$DW$1902 .dwtag DW_TAG_member
.dwattr $C$DW$1902, DW_AT_type(*$C$DW$T$356)
.dwattr $C$DW$1902, DW_AT_name("NTVParam")
.dwattr $C$DW$1902, DW_AT_TI_symbol_name("NTVParam")
.dwattr $C$DW$1902, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1902, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1902, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1902, DW_AT_decl_line(0x3f9)
.dwattr $C$DW$1902, DW_AT_decl_column(0x05)
$C$DW$1903 .dwtag DW_TAG_member
.dwattr $C$DW$1903, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1903, DW_AT_name("reserved")
.dwattr $C$DW$1903, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1903, DW_AT_data_member_location[DW_OP_plus_uconst 0x4c8]
.dwattr $C$DW$1903, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1903, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1903, DW_AT_decl_line(0x3fb)
.dwattr $C$DW$1903, DW_AT_decl_column(0x05)
$C$DW$96 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$96, DW_AT_declaration
.dwattr $C$DW$96, DW_AT_TI_symbol_name("_ZN9Pai_ParamaSERKS_")
.dwattr $C$DW$96, DW_AT_type(*$C$DW$T$357)
.dwattr $C$DW$96, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1904 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1904, DW_AT_type(*$C$DW$T$359)
.dwendtag $C$DW$96
.dwendtag $C$DW$T$361
.dwattr $C$DW$T$361, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$361, DW_AT_decl_line(0x3f7)
.dwattr $C$DW$T$361, DW_AT_decl_column(0x01)
$C$DW$T$358 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$358, DW_AT_type(*$C$DW$T$361)
$C$DW$T$359 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$359, DW_AT_type(*$C$DW$T$358)
.dwattr $C$DW$T$359, DW_AT_address_class(0x20)
$C$DW$T$1920 .dwtag DW_TAG_typedef, DW_AT_name("Pai_Param")
.dwattr $C$DW$T$1920, DW_AT_type(*$C$DW$T$361)
.dwattr $C$DW$T$1920, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1920, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1920, DW_AT_decl_line(0x3fc)
.dwattr $C$DW$T$1920, DW_AT_decl_column(0x03)
$C$DW$T$357 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$357, DW_AT_type(*$C$DW$T$361)
.dwattr $C$DW$T$357, DW_AT_address_class(0x20)
$C$DW$T$360 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$360, DW_AT_type(*$C$DW$T$357)
.dwattr $C$DW$T$360, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1905 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1905, DW_AT_type(*$C$DW$T$359)
.dwendtag $C$DW$T$360
$C$DW$T$378 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$378, DW_AT_name("ParamAniso2DAdpFilEmph")
.dwattr $C$DW$T$378, DW_AT_byte_size(0x14)
$C$DW$1906 .dwtag DW_TAG_member
.dwattr $C$DW$1906, DW_AT_type(*$C$DW$T$373)
.dwattr $C$DW$1906, DW_AT_name("wghtTblS")
.dwattr $C$DW$1906, DW_AT_TI_symbol_name("wghtTblS")
.dwattr $C$DW$1906, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1906, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1906, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1906, DW_AT_decl_line(0x421)
.dwattr $C$DW$1906, DW_AT_decl_column(0x14)
$C$DW$1907 .dwtag DW_TAG_member
.dwattr $C$DW$1907, DW_AT_type(*$C$DW$T$373)
.dwattr $C$DW$1907, DW_AT_name("emphTbl")
.dwattr $C$DW$1907, DW_AT_TI_symbol_name("emphTbl")
.dwattr $C$DW$1907, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1907, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1907, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1907, DW_AT_decl_line(0x422)
.dwattr $C$DW$1907, DW_AT_decl_column(0x14)
$C$DW$1908 .dwtag DW_TAG_member
.dwattr $C$DW$1908, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1908, DW_AT_name("alpha")
.dwattr $C$DW$1908, DW_AT_TI_symbol_name("alpha")
.dwattr $C$DW$1908, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1908, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1908, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1908, DW_AT_decl_line(0x423)
.dwattr $C$DW$1908, DW_AT_decl_column(0x14)
$C$DW$1909 .dwtag DW_TAG_member
.dwattr $C$DW$1909, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1909, DW_AT_name("beta")
.dwattr $C$DW$1909, DW_AT_TI_symbol_name("beta")
.dwattr $C$DW$1909, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1909, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1909, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1909, DW_AT_decl_line(0x424)
.dwattr $C$DW$1909, DW_AT_decl_column(0x14)
$C$DW$1910 .dwtag DW_TAG_member
.dwattr $C$DW$1910, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1910, DW_AT_name("gamma")
.dwattr $C$DW$1910, DW_AT_TI_symbol_name("gamma")
.dwattr $C$DW$1910, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1910, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1910, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1910, DW_AT_decl_line(0x425)
.dwattr $C$DW$1910, DW_AT_decl_column(0x14)
$C$DW$97 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$97, DW_AT_declaration
.dwattr $C$DW$97, DW_AT_TI_symbol_name("_ZN22ParamAniso2DAdpFilEmphaSERKS_")
.dwattr $C$DW$97, DW_AT_type(*$C$DW$T$374)
.dwattr $C$DW$97, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1911 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1911, DW_AT_type(*$C$DW$T$376)
.dwendtag $C$DW$97
.dwendtag $C$DW$T$378
.dwattr $C$DW$T$378, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$T$378, DW_AT_decl_line(0x41f)
.dwattr $C$DW$T$378, DW_AT_decl_column(0x08)
$C$DW$T$375 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$375, DW_AT_type(*$C$DW$T$378)
$C$DW$T$376 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$376, DW_AT_type(*$C$DW$T$375)
.dwattr $C$DW$T$376, DW_AT_address_class(0x20)
$C$DW$T$374 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$374, DW_AT_type(*$C$DW$T$378)
.dwattr $C$DW$T$374, DW_AT_address_class(0x20)
$C$DW$T$377 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$377, DW_AT_type(*$C$DW$T$374)
.dwattr $C$DW$T$377, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1912 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1912, DW_AT_type(*$C$DW$T$376)
.dwendtag $C$DW$T$377
$C$DW$T$383 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$383, DW_AT_name("ParamBlackSpotFill")
.dwattr $C$DW$T$383, DW_AT_byte_size(0x90)
$C$DW$1913 .dwtag DW_TAG_member
.dwattr $C$DW$1913, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1913, DW_AT_name("gapThres")
.dwattr $C$DW$1913, DW_AT_TI_symbol_name("gapThres")
.dwattr $C$DW$1913, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1913, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1913, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1913, DW_AT_decl_line(0x3a8)
.dwattr $C$DW$1913, DW_AT_decl_column(0x05)
$C$DW$1914 .dwtag DW_TAG_member
.dwattr $C$DW$1914, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1914, DW_AT_name("fillingLevel")
.dwattr $C$DW$1914, DW_AT_TI_symbol_name("fillingLevel")
.dwattr $C$DW$1914, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1914, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1914, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1914, DW_AT_decl_line(0x3a9)
.dwattr $C$DW$1914, DW_AT_decl_column(0x05)
$C$DW$1915 .dwtag DW_TAG_member
.dwattr $C$DW$1915, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1915, DW_AT_name("reserved")
.dwattr $C$DW$1915, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1915, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1915, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1915, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1915, DW_AT_decl_line(0x3aa)
.dwattr $C$DW$1915, DW_AT_decl_column(0x05)
$C$DW$98 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$98, DW_AT_declaration
.dwattr $C$DW$98, DW_AT_TI_symbol_name("_ZN18ParamBlackSpotFillaSERKS_")
.dwattr $C$DW$98, DW_AT_type(*$C$DW$T$379)
.dwattr $C$DW$98, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1916 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1916, DW_AT_type(*$C$DW$T$381)
.dwendtag $C$DW$98
.dwendtag $C$DW$T$383
.dwattr $C$DW$T$383, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$383, DW_AT_decl_line(0x3a7)
.dwattr $C$DW$T$383, DW_AT_decl_column(0x01)
$C$DW$T$216 .dwtag DW_TAG_typedef, DW_AT_name("ParamBlackSpotFill")
.dwattr $C$DW$T$216, DW_AT_type(*$C$DW$T$383)
.dwattr $C$DW$T$216, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$216, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$216, DW_AT_decl_line(0x3ab)
.dwattr $C$DW$T$216, DW_AT_decl_column(0x03)
$C$DW$T$380 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$380, DW_AT_type(*$C$DW$T$383)
$C$DW$T$381 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$381, DW_AT_type(*$C$DW$T$380)
.dwattr $C$DW$T$381, DW_AT_address_class(0x20)
$C$DW$T$379 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$379, DW_AT_type(*$C$DW$T$383)
.dwattr $C$DW$T$379, DW_AT_address_class(0x20)
$C$DW$T$382 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$382, DW_AT_type(*$C$DW$T$379)
.dwattr $C$DW$T$382, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1917 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1917, DW_AT_type(*$C$DW$T$381)
.dwendtag $C$DW$T$382
$C$DW$T$392 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$392, DW_AT_name("ParamEdgeDirProc")
.dwattr $C$DW$T$392, DW_AT_byte_size(0x14)
$C$DW$1918 .dwtag DW_TAG_member
.dwattr $C$DW$1918, DW_AT_type(*$C$DW$T$384)
.dwattr $C$DW$1918, DW_AT_name("param")
.dwattr $C$DW$1918, DW_AT_TI_symbol_name("param")
.dwattr $C$DW$1918, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1918, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1918, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1918, DW_AT_decl_line(0x3f)
.dwattr $C$DW$1918, DW_AT_decl_column(0x2e)
$C$DW$1919 .dwtag DW_TAG_member
.dwattr $C$DW$1919, DW_AT_type(*$C$DW$T$385)
.dwattr $C$DW$1919, DW_AT_name("paramDetect")
.dwattr $C$DW$1919, DW_AT_TI_symbol_name("paramDetect")
.dwattr $C$DW$1919, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1919, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1919, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1919, DW_AT_decl_line(0x40)
.dwattr $C$DW$1919, DW_AT_decl_column(0x2e)
$C$DW$1920 .dwtag DW_TAG_member
.dwattr $C$DW$1920, DW_AT_type(*$C$DW$T$386)
.dwattr $C$DW$1920, DW_AT_name("context")
.dwattr $C$DW$1920, DW_AT_TI_symbol_name("context")
.dwattr $C$DW$1920, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1920, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1920, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1920, DW_AT_decl_line(0x41)
.dwattr $C$DW$1920, DW_AT_decl_column(0x15)
$C$DW$1921 .dwtag DW_TAG_member
.dwattr $C$DW$1921, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1921, DW_AT_name("lev")
.dwattr $C$DW$1921, DW_AT_TI_symbol_name("lev")
.dwattr $C$DW$1921, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1921, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1921, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1921, DW_AT_decl_line(0x42)
.dwattr $C$DW$1921, DW_AT_decl_column(0x09)
$C$DW$1922 .dwtag DW_TAG_member
.dwattr $C$DW$1922, DW_AT_type(*$C$DW$T$387)
.dwattr $C$DW$1922, DW_AT_name("be")
.dwattr $C$DW$1922, DW_AT_TI_symbol_name("be")
.dwattr $C$DW$1922, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1922, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1922, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1922, DW_AT_decl_line(0x43)
.dwattr $C$DW$1922, DW_AT_decl_column(0x10)
$C$DW$99 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$99, DW_AT_declaration
.dwattr $C$DW$99, DW_AT_TI_symbol_name("_ZN16ParamEdgeDirProcaSERKS_")
.dwattr $C$DW$99, DW_AT_type(*$C$DW$T$388)
.dwattr $C$DW$99, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1923 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1923, DW_AT_type(*$C$DW$T$390)
.dwendtag $C$DW$99
.dwendtag $C$DW$T$392
.dwattr $C$DW$T$392, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$T$392, DW_AT_decl_line(0x3d)
.dwattr $C$DW$T$392, DW_AT_decl_column(0x09)
$C$DW$T$389 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$389, DW_AT_type(*$C$DW$T$392)
$C$DW$T$390 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$390, DW_AT_type(*$C$DW$T$389)
.dwattr $C$DW$T$390, DW_AT_address_class(0x20)
$C$DW$T$388 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$388, DW_AT_type(*$C$DW$T$392)
.dwattr $C$DW$T$388, DW_AT_address_class(0x20)
$C$DW$T$391 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$391, DW_AT_type(*$C$DW$T$388)
.dwattr $C$DW$T$391, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1924 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1924, DW_AT_type(*$C$DW$T$390)
.dwendtag $C$DW$T$391
$C$DW$T$398 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$398, DW_AT_name("ParamEdgeEnhance")
.dwattr $C$DW$T$398, DW_AT_byte_size(0x90)
$C$DW$1925 .dwtag DW_TAG_member
.dwattr $C$DW$1925, DW_AT_type(*$C$DW$T$393)
.dwattr $C$DW$1925, DW_AT_name("level")
.dwattr $C$DW$1925, DW_AT_TI_symbol_name("level")
.dwattr $C$DW$1925, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1925, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1925, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1925, DW_AT_decl_line(0x39a)
.dwattr $C$DW$1925, DW_AT_decl_column(0x05)
$C$DW$1926 .dwtag DW_TAG_member
.dwattr $C$DW$1926, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1926, DW_AT_name("reserved")
.dwattr $C$DW$1926, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1926, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1926, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1926, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1926, DW_AT_decl_line(0x39b)
.dwattr $C$DW$1926, DW_AT_decl_column(0x05)
$C$DW$100 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$100, DW_AT_declaration
.dwattr $C$DW$100, DW_AT_TI_symbol_name("_ZN16ParamEdgeEnhanceaSERKS_")
.dwattr $C$DW$100, DW_AT_type(*$C$DW$T$394)
.dwattr $C$DW$100, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1927 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1927, DW_AT_type(*$C$DW$T$396)
.dwendtag $C$DW$100
.dwendtag $C$DW$T$398
.dwattr $C$DW$T$398, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$398, DW_AT_decl_line(0x399)
.dwattr $C$DW$T$398, DW_AT_decl_column(0x01)
$C$DW$T$214 .dwtag DW_TAG_typedef, DW_AT_name("ParamEdgeEnhance")
.dwattr $C$DW$T$214, DW_AT_type(*$C$DW$T$398)
.dwattr $C$DW$T$214, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$214, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$214, DW_AT_decl_line(0x39c)
.dwattr $C$DW$T$214, DW_AT_decl_column(0x03)
$C$DW$T$395 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$395, DW_AT_type(*$C$DW$T$398)
$C$DW$T$396 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$396, DW_AT_type(*$C$DW$T$395)
.dwattr $C$DW$T$396, DW_AT_address_class(0x20)
$C$DW$T$394 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$394, DW_AT_type(*$C$DW$T$398)
.dwattr $C$DW$T$394, DW_AT_address_class(0x20)
$C$DW$T$397 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$397, DW_AT_type(*$C$DW$T$394)
.dwattr $C$DW$T$397, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1928 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1928, DW_AT_type(*$C$DW$T$396)
.dwendtag $C$DW$T$397
$C$DW$T$404 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$404, DW_AT_name("ParamEdgeReliabilityNorm")
.dwattr $C$DW$T$404, DW_AT_byte_size(0x10)
$C$DW$1929 .dwtag DW_TAG_member
.dwattr $C$DW$1929, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1929, DW_AT_name("inRange")
.dwattr $C$DW$1929, DW_AT_TI_symbol_name("inRange")
.dwattr $C$DW$1929, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1929, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1929, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1929, DW_AT_decl_line(0x15f)
.dwattr $C$DW$1929, DW_AT_decl_column(0x0c)
$C$DW$1930 .dwtag DW_TAG_member
.dwattr $C$DW$1930, DW_AT_type(*$C$DW$T$399)
.dwattr $C$DW$1930, DW_AT_name("top")
.dwattr $C$DW$1930, DW_AT_TI_symbol_name("top")
.dwattr $C$DW$1930, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1930, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1930, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1930, DW_AT_decl_line(0x160)
.dwattr $C$DW$1930, DW_AT_decl_column(0x0c)
$C$DW$1931 .dwtag DW_TAG_member
.dwattr $C$DW$1931, DW_AT_type(*$C$DW$T$399)
.dwattr $C$DW$1931, DW_AT_name("botom")
.dwattr $C$DW$1931, DW_AT_TI_symbol_name("botom")
.dwattr $C$DW$1931, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1931, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1931, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1931, DW_AT_decl_line(0x161)
.dwattr $C$DW$1931, DW_AT_decl_column(0x0c)
$C$DW$1932 .dwtag DW_TAG_member
.dwattr $C$DW$1932, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1932, DW_AT_name("levelNum")
.dwattr $C$DW$1932, DW_AT_TI_symbol_name("levelNum")
.dwattr $C$DW$1932, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1932, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1932, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1932, DW_AT_decl_line(0x162)
.dwattr $C$DW$1932, DW_AT_decl_column(0x0c)
$C$DW$101 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$101, DW_AT_declaration
.dwattr $C$DW$101, DW_AT_TI_symbol_name("_ZN24ParamEdgeReliabilityNormaSERKS_")
.dwattr $C$DW$101, DW_AT_type(*$C$DW$T$400)
.dwattr $C$DW$101, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1933 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1933, DW_AT_type(*$C$DW$T$402)
.dwendtag $C$DW$101
.dwendtag $C$DW$T$404
.dwattr $C$DW$T$404, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$T$404, DW_AT_decl_line(0x15d)
.dwattr $C$DW$T$404, DW_AT_decl_column(0x09)
$C$DW$T$401 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$401, DW_AT_type(*$C$DW$T$404)
$C$DW$T$402 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$402, DW_AT_type(*$C$DW$T$401)
.dwattr $C$DW$T$402, DW_AT_address_class(0x20)
$C$DW$T$400 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$400, DW_AT_type(*$C$DW$T$404)
.dwattr $C$DW$T$400, DW_AT_address_class(0x20)
$C$DW$T$403 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$403, DW_AT_type(*$C$DW$T$400)
.dwattr $C$DW$T$403, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1934 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1934, DW_AT_type(*$C$DW$T$402)
.dwendtag $C$DW$T$403
$C$DW$T$409 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$409, DW_AT_name("ParamEdgeThreshold")
.dwattr $C$DW$T$409, DW_AT_byte_size(0xa0)
$C$DW$1935 .dwtag DW_TAG_member
.dwattr $C$DW$1935, DW_AT_type(*$C$DW$T$393)
.dwattr $C$DW$1935, DW_AT_name("level")
.dwattr $C$DW$1935, DW_AT_TI_symbol_name("level")
.dwattr $C$DW$1935, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1935, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1935, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1935, DW_AT_decl_line(0x3b6)
.dwattr $C$DW$1935, DW_AT_decl_column(0x05)
$C$DW$1936 .dwtag DW_TAG_member
.dwattr $C$DW$1936, DW_AT_type(*$C$DW$T$393)
.dwattr $C$DW$1936, DW_AT_name("width")
.dwattr $C$DW$1936, DW_AT_TI_symbol_name("width")
.dwattr $C$DW$1936, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1936, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1936, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1936, DW_AT_decl_line(0x3b7)
.dwattr $C$DW$1936, DW_AT_decl_column(0x05)
$C$DW$1937 .dwtag DW_TAG_member
.dwattr $C$DW$1937, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1937, DW_AT_name("reserved")
.dwattr $C$DW$1937, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1937, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1937, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1937, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1937, DW_AT_decl_line(0x3b8)
.dwattr $C$DW$1937, DW_AT_decl_column(0x05)
$C$DW$102 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$102, DW_AT_declaration
.dwattr $C$DW$102, DW_AT_TI_symbol_name("_ZN18ParamEdgeThresholdaSERKS_")
.dwattr $C$DW$102, DW_AT_type(*$C$DW$T$405)
.dwattr $C$DW$102, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1938 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1938, DW_AT_type(*$C$DW$T$407)
.dwendtag $C$DW$102
.dwendtag $C$DW$T$409
.dwattr $C$DW$T$409, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$409, DW_AT_decl_line(0x3b5)
.dwattr $C$DW$T$409, DW_AT_decl_column(0x01)
$C$DW$T$218 .dwtag DW_TAG_typedef, DW_AT_name("ParamEdgeThreshold")
.dwattr $C$DW$T$218, DW_AT_type(*$C$DW$T$409)
.dwattr $C$DW$T$218, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$218, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$218, DW_AT_decl_line(0x3b9)
.dwattr $C$DW$T$218, DW_AT_decl_column(0x03)
$C$DW$T$406 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$406, DW_AT_type(*$C$DW$T$409)
$C$DW$T$407 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$407, DW_AT_type(*$C$DW$T$406)
.dwattr $C$DW$T$407, DW_AT_address_class(0x20)
$C$DW$T$405 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$405, DW_AT_type(*$C$DW$T$409)
.dwattr $C$DW$T$405, DW_AT_address_class(0x20)
$C$DW$T$408 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$408, DW_AT_type(*$C$DW$T$405)
.dwattr $C$DW$T$408, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1939 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1939, DW_AT_type(*$C$DW$T$407)
.dwendtag $C$DW$T$408
$C$DW$T$414 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$414, DW_AT_name("ParamFTCProc")
.dwattr $C$DW$T$414, DW_AT_byte_size(0x20)
$C$DW$1940 .dwtag DW_TAG_member
.dwattr $C$DW$1940, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1940, DW_AT_name("delay")
.dwattr $C$DW$1940, DW_AT_TI_symbol_name("delay")
.dwattr $C$DW$1940, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1940, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1940, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1940, DW_AT_decl_line(0xde)
.dwattr $C$DW$1940, DW_AT_decl_column(0x15)
$C$DW$1941 .dwtag DW_TAG_member
.dwattr $C$DW$1941, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1941, DW_AT_name("offset")
.dwattr $C$DW$1941, DW_AT_TI_symbol_name("offset")
.dwattr $C$DW$1941, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1941, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1941, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1941, DW_AT_decl_line(0xdf)
.dwattr $C$DW$1941, DW_AT_decl_column(0x15)
$C$DW$1942 .dwtag DW_TAG_member
.dwattr $C$DW$1942, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1942, DW_AT_name("alphaS")
.dwattr $C$DW$1942, DW_AT_TI_symbol_name("alphaS")
.dwattr $C$DW$1942, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1942, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1942, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1942, DW_AT_decl_line(0xe0)
.dwattr $C$DW$1942, DW_AT_decl_column(0x15)
$C$DW$1943 .dwtag DW_TAG_member
.dwattr $C$DW$1943, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$1943, DW_AT_name("alphaE")
.dwattr $C$DW$1943, DW_AT_TI_symbol_name("alphaE")
.dwattr $C$DW$1943, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1943, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1943, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1943, DW_AT_decl_line(0xe1)
.dwattr $C$DW$1943, DW_AT_decl_column(0x15)
$C$DW$1944 .dwtag DW_TAG_member
.dwattr $C$DW$1944, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1944, DW_AT_name("thS")
.dwattr $C$DW$1944, DW_AT_TI_symbol_name("thS")
.dwattr $C$DW$1944, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1944, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1944, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1944, DW_AT_decl_line(0xe2)
.dwattr $C$DW$1944, DW_AT_decl_column(0x15)
$C$DW$1945 .dwtag DW_TAG_member
.dwattr $C$DW$1945, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1945, DW_AT_name("thE")
.dwattr $C$DW$1945, DW_AT_TI_symbol_name("thE")
.dwattr $C$DW$1945, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1945, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1945, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1945, DW_AT_decl_line(0xe3)
.dwattr $C$DW$1945, DW_AT_decl_column(0x15)
$C$DW$1946 .dwtag DW_TAG_member
.dwattr $C$DW$1946, DW_AT_type(*$C$DW$T$373)
.dwattr $C$DW$1946, DW_AT_name("Tbl2")
.dwattr $C$DW$1946, DW_AT_TI_symbol_name("Tbl2")
.dwattr $C$DW$1946, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1946, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1946, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1946, DW_AT_decl_line(0xe4)
.dwattr $C$DW$1946, DW_AT_decl_column(0x15)
$C$DW$1947 .dwtag DW_TAG_member
.dwattr $C$DW$1947, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1947, DW_AT_name("accuracyBits")
.dwattr $C$DW$1947, DW_AT_TI_symbol_name("accuracyBits")
.dwattr $C$DW$1947, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c]
.dwattr $C$DW$1947, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1947, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$1947, DW_AT_decl_line(0xe5)
.dwattr $C$DW$1947, DW_AT_decl_column(0x15)
$C$DW$103 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$103, DW_AT_declaration
.dwattr $C$DW$103, DW_AT_TI_symbol_name("_ZN12ParamFTCProcaSERKS_")
.dwattr $C$DW$103, DW_AT_type(*$C$DW$T$410)
.dwattr $C$DW$103, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1948 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1948, DW_AT_type(*$C$DW$T$412)
.dwendtag $C$DW$103
.dwendtag $C$DW$T$414
.dwattr $C$DW$T$414, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$T$414, DW_AT_decl_line(0xdc)
.dwattr $C$DW$T$414, DW_AT_decl_column(0x08)
$C$DW$T$411 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$411, DW_AT_type(*$C$DW$T$414)
$C$DW$T$412 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$412, DW_AT_type(*$C$DW$T$411)
.dwattr $C$DW$T$412, DW_AT_address_class(0x20)
$C$DW$T$410 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$410, DW_AT_type(*$C$DW$T$414)
.dwattr $C$DW$T$410, DW_AT_address_class(0x20)
$C$DW$T$413 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$413, DW_AT_type(*$C$DW$T$410)
.dwattr $C$DW$T$413, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1949 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1949, DW_AT_type(*$C$DW$T$412)
.dwendtag $C$DW$T$413
$C$DW$T$423 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$423, DW_AT_name("ParamGaussianProc")
.dwattr $C$DW$T$423, DW_AT_byte_size(0x14)
$C$DW$1950 .dwtag DW_TAG_member
.dwattr $C$DW$1950, DW_AT_type(*$C$DW$T$416)
.dwattr $C$DW$1950, DW_AT_name("in")
.dwattr $C$DW$1950, DW_AT_TI_symbol_name("in")
.dwattr $C$DW$1950, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1950, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1950, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1950, DW_AT_decl_line(0x153)
.dwattr $C$DW$1950, DW_AT_decl_column(0x0d)
$C$DW$1951 .dwtag DW_TAG_member
.dwattr $C$DW$1951, DW_AT_type(*$C$DW$T$417)
.dwattr $C$DW$1951, DW_AT_name("info")
.dwattr $C$DW$1951, DW_AT_TI_symbol_name("info")
.dwattr $C$DW$1951, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1951, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1951, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1951, DW_AT_decl_line(0x154)
.dwattr $C$DW$1951, DW_AT_decl_column(0x10)
$C$DW$1952 .dwtag DW_TAG_member
.dwattr $C$DW$1952, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1952, DW_AT_name("level")
.dwattr $C$DW$1952, DW_AT_TI_symbol_name("level")
.dwattr $C$DW$1952, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1952, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1952, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1952, DW_AT_decl_line(0x155)
.dwattr $C$DW$1952, DW_AT_decl_column(0x09)
$C$DW$1953 .dwtag DW_TAG_member
.dwattr $C$DW$1953, DW_AT_type(*$C$DW$T$418)
.dwattr $C$DW$1953, DW_AT_name("filterGauss")
.dwattr $C$DW$1953, DW_AT_TI_symbol_name("filterGauss")
.dwattr $C$DW$1953, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1953, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1953, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1953, DW_AT_decl_line(0x156)
.dwattr $C$DW$1953, DW_AT_decl_column(0x13)
$C$DW$1954 .dwtag DW_TAG_member
.dwattr $C$DW$1954, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$1954, DW_AT_name("workA")
.dwattr $C$DW$1954, DW_AT_TI_symbol_name("workA")
.dwattr $C$DW$1954, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1954, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1954, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1954, DW_AT_decl_line(0x157)
.dwattr $C$DW$1954, DW_AT_decl_column(0x0b)
$C$DW$104 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$104, DW_AT_declaration
.dwattr $C$DW$104, DW_AT_TI_symbol_name("_ZN17ParamGaussianProcaSERKS_")
.dwattr $C$DW$104, DW_AT_type(*$C$DW$T$419)
.dwattr $C$DW$104, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1955 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1955, DW_AT_type(*$C$DW$T$421)
.dwendtag $C$DW$104
.dwendtag $C$DW$T$423
.dwattr $C$DW$T$423, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$T$423, DW_AT_decl_line(0x151)
.dwattr $C$DW$T$423, DW_AT_decl_column(0x08)
$C$DW$T$420 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$420, DW_AT_type(*$C$DW$T$423)
$C$DW$T$421 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$421, DW_AT_type(*$C$DW$T$420)
.dwattr $C$DW$T$421, DW_AT_address_class(0x20)
$C$DW$T$419 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$419, DW_AT_type(*$C$DW$T$423)
.dwattr $C$DW$T$419, DW_AT_address_class(0x20)
$C$DW$T$422 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$422, DW_AT_type(*$C$DW$T$419)
.dwattr $C$DW$T$422, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1956 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1956, DW_AT_type(*$C$DW$T$421)
.dwendtag $C$DW$T$422
$C$DW$T$428 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$428, DW_AT_name("ParamHContrast")
.dwattr $C$DW$T$428, DW_AT_byte_size(0xa0)
$C$DW$1957 .dwtag DW_TAG_member
.dwattr $C$DW$1957, DW_AT_type(*$C$DW$T$393)
.dwattr $C$DW$1957, DW_AT_name("thLevel")
.dwattr $C$DW$1957, DW_AT_TI_symbol_name("thLevel")
.dwattr $C$DW$1957, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1957, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1957, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1957, DW_AT_decl_line(0x3bd)
.dwattr $C$DW$1957, DW_AT_decl_column(0x05)
$C$DW$1958 .dwtag DW_TAG_member
.dwattr $C$DW$1958, DW_AT_type(*$C$DW$T$393)
.dwattr $C$DW$1958, DW_AT_name("suppressionLevel")
.dwattr $C$DW$1958, DW_AT_TI_symbol_name("suppressionLevel")
.dwattr $C$DW$1958, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1958, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1958, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1958, DW_AT_decl_line(0x3be)
.dwattr $C$DW$1958, DW_AT_decl_column(0x05)
$C$DW$1959 .dwtag DW_TAG_member
.dwattr $C$DW$1959, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1959, DW_AT_name("reserved")
.dwattr $C$DW$1959, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1959, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1959, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1959, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1959, DW_AT_decl_line(0x3bf)
.dwattr $C$DW$1959, DW_AT_decl_column(0x05)
$C$DW$105 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$105, DW_AT_declaration
.dwattr $C$DW$105, DW_AT_TI_symbol_name("_ZN14ParamHContrastaSERKS_")
.dwattr $C$DW$105, DW_AT_type(*$C$DW$T$424)
.dwattr $C$DW$105, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1960 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1960, DW_AT_type(*$C$DW$T$426)
.dwendtag $C$DW$105
.dwendtag $C$DW$T$428
.dwattr $C$DW$T$428, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$428, DW_AT_decl_line(0x3bc)
.dwattr $C$DW$T$428, DW_AT_decl_column(0x01)
$C$DW$T$219 .dwtag DW_TAG_typedef, DW_AT_name("ParamHContrast")
.dwattr $C$DW$T$219, DW_AT_type(*$C$DW$T$428)
.dwattr $C$DW$T$219, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$219, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$219, DW_AT_decl_line(0x3c0)
.dwattr $C$DW$T$219, DW_AT_decl_column(0x03)
$C$DW$T$425 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$425, DW_AT_type(*$C$DW$T$428)
$C$DW$T$426 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$426, DW_AT_type(*$C$DW$T$425)
.dwattr $C$DW$T$426, DW_AT_address_class(0x20)
$C$DW$T$424 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$424, DW_AT_type(*$C$DW$T$428)
.dwattr $C$DW$T$424, DW_AT_address_class(0x20)
$C$DW$T$427 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$427, DW_AT_type(*$C$DW$T$424)
.dwattr $C$DW$T$427, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1961 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1961, DW_AT_type(*$C$DW$T$426)
.dwendtag $C$DW$T$427
$C$DW$T$433 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$433, DW_AT_name("ParamLineThinning")
.dwattr $C$DW$T$433, DW_AT_byte_size(0x90)
$C$DW$1962 .dwtag DW_TAG_member
.dwattr $C$DW$1962, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1962, DW_AT_name("tissueVariationThres")
.dwattr $C$DW$1962, DW_AT_TI_symbol_name("tissueVariationThres")
.dwattr $C$DW$1962, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1962, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1962, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1962, DW_AT_decl_line(0x3af)
.dwattr $C$DW$1962, DW_AT_decl_column(0x05)
$C$DW$1963 .dwtag DW_TAG_member
.dwattr $C$DW$1963, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1963, DW_AT_name("thinningLevel")
.dwattr $C$DW$1963, DW_AT_TI_symbol_name("thinningLevel")
.dwattr $C$DW$1963, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1963, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1963, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1963, DW_AT_decl_line(0x3b0)
.dwattr $C$DW$1963, DW_AT_decl_column(0x05)
$C$DW$1964 .dwtag DW_TAG_member
.dwattr $C$DW$1964, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1964, DW_AT_name("reserved")
.dwattr $C$DW$1964, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1964, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1964, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1964, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1964, DW_AT_decl_line(0x3b1)
.dwattr $C$DW$1964, DW_AT_decl_column(0x05)
$C$DW$106 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$106, DW_AT_declaration
.dwattr $C$DW$106, DW_AT_TI_symbol_name("_ZN17ParamLineThinningaSERKS_")
.dwattr $C$DW$106, DW_AT_type(*$C$DW$T$429)
.dwattr $C$DW$106, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1965 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1965, DW_AT_type(*$C$DW$T$431)
.dwendtag $C$DW$106
.dwendtag $C$DW$T$433
.dwattr $C$DW$T$433, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$433, DW_AT_decl_line(0x3ae)
.dwattr $C$DW$T$433, DW_AT_decl_column(0x01)
$C$DW$T$217 .dwtag DW_TAG_typedef, DW_AT_name("ParamLineThinning")
.dwattr $C$DW$T$217, DW_AT_type(*$C$DW$T$433)
.dwattr $C$DW$T$217, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$217, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$217, DW_AT_decl_line(0x3b2)
.dwattr $C$DW$T$217, DW_AT_decl_column(0x03)
$C$DW$T$430 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$430, DW_AT_type(*$C$DW$T$433)
$C$DW$T$431 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$431, DW_AT_type(*$C$DW$T$430)
.dwattr $C$DW$T$431, DW_AT_address_class(0x20)
$C$DW$T$429 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$429, DW_AT_type(*$C$DW$T$433)
.dwattr $C$DW$T$429, DW_AT_address_class(0x20)
$C$DW$T$432 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$432, DW_AT_type(*$C$DW$T$429)
.dwattr $C$DW$T$432, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1966 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1966, DW_AT_type(*$C$DW$T$431)
.dwendtag $C$DW$T$432
$C$DW$T$438 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$438, DW_AT_name("ParamSharpness")
.dwattr $C$DW$T$438, DW_AT_byte_size(0x98)
$C$DW$1967 .dwtag DW_TAG_member
.dwattr $C$DW$1967, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1967, DW_AT_name("levelLow")
.dwattr $C$DW$1967, DW_AT_TI_symbol_name("levelLow")
.dwattr $C$DW$1967, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1967, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1967, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1967, DW_AT_decl_line(0x3a0)
.dwattr $C$DW$1967, DW_AT_decl_column(0x05)
$C$DW$1968 .dwtag DW_TAG_member
.dwattr $C$DW$1968, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1968, DW_AT_name("levelHigh")
.dwattr $C$DW$1968, DW_AT_TI_symbol_name("levelHigh")
.dwattr $C$DW$1968, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1968, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1968, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1968, DW_AT_decl_line(0x3a1)
.dwattr $C$DW$1968, DW_AT_decl_column(0x05)
$C$DW$1969 .dwtag DW_TAG_member
.dwattr $C$DW$1969, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1969, DW_AT_name("type")
.dwattr $C$DW$1969, DW_AT_TI_symbol_name("type")
.dwattr $C$DW$1969, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1969, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1969, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1969, DW_AT_decl_line(0x3a2)
.dwattr $C$DW$1969, DW_AT_decl_column(0x05)
$C$DW$1970 .dwtag DW_TAG_member
.dwattr $C$DW$1970, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1970, DW_AT_name("reserved")
.dwattr $C$DW$1970, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1970, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1970, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1970, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1970, DW_AT_decl_line(0x3a3)
.dwattr $C$DW$1970, DW_AT_decl_column(0x05)
$C$DW$107 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$107, DW_AT_declaration
.dwattr $C$DW$107, DW_AT_TI_symbol_name("_ZN14ParamSharpnessaSERKS_")
.dwattr $C$DW$107, DW_AT_type(*$C$DW$T$434)
.dwattr $C$DW$107, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1971 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1971, DW_AT_type(*$C$DW$T$436)
.dwendtag $C$DW$107
.dwendtag $C$DW$T$438
.dwattr $C$DW$T$438, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$438, DW_AT_decl_line(0x39f)
.dwattr $C$DW$T$438, DW_AT_decl_column(0x01)
$C$DW$T$215 .dwtag DW_TAG_typedef, DW_AT_name("ParamSharpness")
.dwattr $C$DW$T$215, DW_AT_type(*$C$DW$T$438)
.dwattr $C$DW$T$215, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$215, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$215, DW_AT_decl_line(0x3a4)
.dwattr $C$DW$T$215, DW_AT_decl_column(0x03)
$C$DW$T$435 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$435, DW_AT_type(*$C$DW$T$438)
$C$DW$T$436 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$436, DW_AT_type(*$C$DW$T$435)
.dwattr $C$DW$T$436, DW_AT_address_class(0x20)
$C$DW$T$434 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$434, DW_AT_type(*$C$DW$T$438)
.dwattr $C$DW$T$434, DW_AT_address_class(0x20)
$C$DW$T$437 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$437, DW_AT_type(*$C$DW$T$434)
.dwattr $C$DW$T$437, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1972 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1972, DW_AT_type(*$C$DW$T$436)
.dwendtag $C$DW$T$437
$C$DW$T$443 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$443, DW_AT_name("ParamSpeckleReduction")
.dwattr $C$DW$T$443, DW_AT_byte_size(0x88)
$C$DW$1973 .dwtag DW_TAG_member
.dwattr $C$DW$1973, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1973, DW_AT_name("level")
.dwattr $C$DW$1973, DW_AT_TI_symbol_name("level")
.dwattr $C$DW$1973, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1973, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1973, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1973, DW_AT_decl_line(0x394)
.dwattr $C$DW$1973, DW_AT_decl_column(0x05)
$C$DW$1974 .dwtag DW_TAG_member
.dwattr $C$DW$1974, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1974, DW_AT_name("reserved")
.dwattr $C$DW$1974, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1974, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1974, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1974, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1974, DW_AT_decl_line(0x395)
.dwattr $C$DW$1974, DW_AT_decl_column(0x05)
$C$DW$108 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$108, DW_AT_declaration
.dwattr $C$DW$108, DW_AT_TI_symbol_name("_ZN21ParamSpeckleReductionaSERKS_")
.dwattr $C$DW$108, DW_AT_type(*$C$DW$T$439)
.dwattr $C$DW$108, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1975 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1975, DW_AT_type(*$C$DW$T$441)
.dwendtag $C$DW$108
.dwendtag $C$DW$T$443
.dwattr $C$DW$T$443, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$443, DW_AT_decl_line(0x393)
.dwattr $C$DW$T$443, DW_AT_decl_column(0x01)
$C$DW$T$213 .dwtag DW_TAG_typedef, DW_AT_name("ParamSpeckleReduction")
.dwattr $C$DW$T$213, DW_AT_type(*$C$DW$T$443)
.dwattr $C$DW$T$213, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$213, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$213, DW_AT_decl_line(0x396)
.dwattr $C$DW$T$213, DW_AT_decl_column(0x03)
$C$DW$T$440 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$440, DW_AT_type(*$C$DW$T$443)
$C$DW$T$441 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$441, DW_AT_type(*$C$DW$T$440)
.dwattr $C$DW$T$441, DW_AT_address_class(0x20)
$C$DW$T$439 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$439, DW_AT_type(*$C$DW$T$443)
.dwattr $C$DW$T$439, DW_AT_address_class(0x20)
$C$DW$T$442 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$442, DW_AT_type(*$C$DW$T$439)
.dwattr $C$DW$T$442, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1976 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1976, DW_AT_type(*$C$DW$T$441)
.dwendtag $C$DW$T$442
$C$DW$T$449 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$449, DW_AT_name("ParamUnSharpProc")
.dwattr $C$DW$T$449, DW_AT_byte_size(0x1c)
$C$DW$1977 .dwtag DW_TAG_member
.dwattr $C$DW$1977, DW_AT_type(*$C$DW$T$416)
.dwattr $C$DW$1977, DW_AT_name("outHif")
.dwattr $C$DW$1977, DW_AT_TI_symbol_name("outHif")
.dwattr $C$DW$1977, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1977, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1977, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1977, DW_AT_decl_line(0x167)
.dwattr $C$DW$1977, DW_AT_decl_column(0x0e)
$C$DW$1978 .dwtag DW_TAG_member
.dwattr $C$DW$1978, DW_AT_type(*$C$DW$T$417)
.dwattr $C$DW$1978, DW_AT_name("info")
.dwattr $C$DW$1978, DW_AT_TI_symbol_name("info")
.dwattr $C$DW$1978, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1978, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1978, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1978, DW_AT_decl_line(0x168)
.dwattr $C$DW$1978, DW_AT_decl_column(0x10)
$C$DW$1979 .dwtag DW_TAG_member
.dwattr $C$DW$1979, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$1979, DW_AT_name("level")
.dwattr $C$DW$1979, DW_AT_TI_symbol_name("level")
.dwattr $C$DW$1979, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1979, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1979, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1979, DW_AT_decl_line(0x169)
.dwattr $C$DW$1979, DW_AT_decl_column(0x09)
$C$DW$1980 .dwtag DW_TAG_member
.dwattr $C$DW$1980, DW_AT_type(*$C$DW$T$418)
.dwattr $C$DW$1980, DW_AT_name("filter")
.dwattr $C$DW$1980, DW_AT_TI_symbol_name("filter")
.dwattr $C$DW$1980, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1980, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1980, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1980, DW_AT_decl_line(0x16a)
.dwattr $C$DW$1980, DW_AT_decl_column(0x13)
$C$DW$1981 .dwtag DW_TAG_member
.dwattr $C$DW$1981, DW_AT_type(*$C$DW$T$444)
.dwattr $C$DW$1981, DW_AT_name("emphasis1")
.dwattr $C$DW$1981, DW_AT_TI_symbol_name("emphasis1")
.dwattr $C$DW$1981, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1981, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1981, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1981, DW_AT_decl_line(0x16b)
.dwattr $C$DW$1981, DW_AT_decl_column(0x13)
$C$DW$1982 .dwtag DW_TAG_member
.dwattr $C$DW$1982, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$1982, DW_AT_name("workA")
.dwattr $C$DW$1982, DW_AT_TI_symbol_name("workA")
.dwattr $C$DW$1982, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$1982, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1982, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1982, DW_AT_decl_line(0x16c)
.dwattr $C$DW$1982, DW_AT_decl_column(0x0b)
$C$DW$1983 .dwtag DW_TAG_member
.dwattr $C$DW$1983, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$1983, DW_AT_name("workB")
.dwattr $C$DW$1983, DW_AT_TI_symbol_name("workB")
.dwattr $C$DW$1983, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1983, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1983, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$1983, DW_AT_decl_line(0x16d)
.dwattr $C$DW$1983, DW_AT_decl_column(0x0b)
$C$DW$109 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$109, DW_AT_declaration
.dwattr $C$DW$109, DW_AT_TI_symbol_name("_ZN16ParamUnSharpProcaSERKS_")
.dwattr $C$DW$109, DW_AT_type(*$C$DW$T$445)
.dwattr $C$DW$109, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1984 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1984, DW_AT_type(*$C$DW$T$447)
.dwendtag $C$DW$109
.dwendtag $C$DW$T$449
.dwattr $C$DW$T$449, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h")
.dwattr $C$DW$T$449, DW_AT_decl_line(0x165)
.dwattr $C$DW$T$449, DW_AT_decl_column(0x08)
$C$DW$T$446 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$446, DW_AT_type(*$C$DW$T$449)
$C$DW$T$447 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$447, DW_AT_type(*$C$DW$T$446)
.dwattr $C$DW$T$447, DW_AT_address_class(0x20)
$C$DW$T$445 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$445, DW_AT_type(*$C$DW$T$449)
.dwattr $C$DW$T$445, DW_AT_address_class(0x20)
$C$DW$T$448 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$448, DW_AT_type(*$C$DW$T$445)
.dwattr $C$DW$T$448, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1985 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1985, DW_AT_type(*$C$DW$T$447)
.dwendtag $C$DW$T$448
$C$DW$T$461 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$461, DW_AT_name("ParamUpdateMsg")
.dwattr $C$DW$T$461, DW_AT_byte_size(0x14)
$C$DW$1986 .dwtag DW_TAG_member
.dwattr $C$DW$1986, DW_AT_type(*$C$DW$T$451)
.dwattr $C$DW$1986, DW_AT_name("subCmd")
.dwattr $C$DW$1986, DW_AT_TI_symbol_name("subCmd")
.dwattr $C$DW$1986, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1986, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1986, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1986, DW_AT_decl_line(0x96)
.dwattr $C$DW$1986, DW_AT_decl_column(0x18)
$C$DW$1987 .dwtag DW_TAG_member
.dwattr $C$DW$1987, DW_AT_type(*$C$DW$T$453)
.dwattr $C$DW$1987, DW_AT_name("paramUpdateCmd")
.dwattr $C$DW$1987, DW_AT_TI_symbol_name("paramUpdateCmd")
.dwattr $C$DW$1987, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$1987, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1987, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1987, DW_AT_decl_line(0x97)
.dwattr $C$DW$1987, DW_AT_decl_column(0x18)
$C$DW$1988 .dwtag DW_TAG_member
.dwattr $C$DW$1988, DW_AT_type(*$C$DW$T$454)
.dwattr $C$DW$1988, DW_AT_name("processModule")
.dwattr $C$DW$1988, DW_AT_TI_symbol_name("processModule")
.dwattr $C$DW$1988, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1988, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1988, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1988, DW_AT_decl_line(0x98)
.dwattr $C$DW$1988, DW_AT_decl_column(0x1b)
$C$DW$1989 .dwtag DW_TAG_member
.dwattr $C$DW$1989, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$1989, DW_AT_name("coreId")
.dwattr $C$DW$1989, DW_AT_TI_symbol_name("coreId")
.dwattr $C$DW$1989, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$1989, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1989, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1989, DW_AT_decl_line(0x99)
.dwattr $C$DW$1989, DW_AT_decl_column(0x1b)
$C$DW$1990 .dwtag DW_TAG_member
.dwattr $C$DW$1990, DW_AT_type(*$C$DW$T$456)
.dwattr $C$DW$1990, DW_AT_name("isRealTime")
.dwattr $C$DW$1990, DW_AT_TI_symbol_name("isRealTime")
.dwattr $C$DW$1990, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1990, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1990, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$1990, DW_AT_decl_line(0x9a)
.dwattr $C$DW$1990, DW_AT_decl_column(0x1b)
$C$DW$110 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$110, DW_AT_declaration
.dwattr $C$DW$110, DW_AT_TI_symbol_name("_ZN14ParamUpdateMsgaSERKS_")
.dwattr $C$DW$110, DW_AT_type(*$C$DW$T$457)
.dwattr $C$DW$110, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$1991 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1991, DW_AT_type(*$C$DW$T$459)
.dwendtag $C$DW$110
.dwendtag $C$DW$T$461
.dwattr $C$DW$T$461, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$461, DW_AT_decl_line(0x95)
.dwattr $C$DW$T$461, DW_AT_decl_column(0x01)
$C$DW$T$458 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$458, DW_AT_type(*$C$DW$T$461)
$C$DW$T$459 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$459, DW_AT_type(*$C$DW$T$458)
.dwattr $C$DW$T$459, DW_AT_address_class(0x20)
$C$DW$T$1476 .dwtag DW_TAG_typedef, DW_AT_name("ParamUpdateMsg")
.dwattr $C$DW$T$1476, DW_AT_type(*$C$DW$T$461)
.dwattr $C$DW$T$1476, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1476, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1476, DW_AT_decl_line(0x9b)
.dwattr $C$DW$T$1476, DW_AT_decl_column(0x03)
$C$DW$T$457 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$457, DW_AT_type(*$C$DW$T$461)
.dwattr $C$DW$T$457, DW_AT_address_class(0x20)
$C$DW$T$460 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$460, DW_AT_type(*$C$DW$T$457)
.dwattr $C$DW$T$460, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$1992 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$1992, DW_AT_type(*$C$DW$T$459)
.dwendtag $C$DW$T$460
$C$DW$T$1448 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1448, DW_AT_name("Probe_Info")
.dwattr $C$DW$T$1448, DW_AT_byte_size(0xb0)
$C$DW$1993 .dwtag DW_TAG_member
.dwattr $C$DW$1993, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1993, DW_AT_name("numElements")
.dwattr $C$DW$1993, DW_AT_TI_symbol_name("numElements")
.dwattr $C$DW$1993, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$1993, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1993, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1993, DW_AT_decl_line(0x213)
.dwattr $C$DW$1993, DW_AT_decl_column(0x05)
$C$DW$1994 .dwtag DW_TAG_member
.dwattr $C$DW$1994, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1994, DW_AT_name("pitchMm")
.dwattr $C$DW$1994, DW_AT_TI_symbol_name("pitchMm")
.dwattr $C$DW$1994, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$1994, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1994, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1994, DW_AT_decl_line(0x214)
.dwattr $C$DW$1994, DW_AT_decl_column(0x05)
$C$DW$1995 .dwtag DW_TAG_member
.dwattr $C$DW$1995, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1995, DW_AT_name("rocMm")
.dwattr $C$DW$1995, DW_AT_TI_symbol_name("rocMm")
.dwattr $C$DW$1995, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$1995, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1995, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1995, DW_AT_decl_line(0x215)
.dwattr $C$DW$1995, DW_AT_decl_column(0x05)
$C$DW$1996 .dwtag DW_TAG_member
.dwattr $C$DW$1996, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$1996, DW_AT_name("lensThicknessMm")
.dwattr $C$DW$1996, DW_AT_TI_symbol_name("lensThicknessMm")
.dwattr $C$DW$1996, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$1996, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1996, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1996, DW_AT_decl_line(0x216)
.dwattr $C$DW$1996, DW_AT_decl_column(0x05)
$C$DW$1997 .dwtag DW_TAG_member
.dwattr $C$DW$1997, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$1997, DW_AT_name("frontEndRayDensity")
.dwattr $C$DW$1997, DW_AT_TI_symbol_name("frontEndRayDensity")
.dwattr $C$DW$1997, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$1997, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1997, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1997, DW_AT_decl_line(0x217)
.dwattr $C$DW$1997, DW_AT_decl_column(0x05)
$C$DW$1998 .dwtag DW_TAG_member
.dwattr $C$DW$1998, DW_AT_type(*$C$DW$T$1443)
.dwattr $C$DW$1998, DW_AT_name("probeType")
.dwattr $C$DW$1998, DW_AT_TI_symbol_name("probeType")
.dwattr $C$DW$1998, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$1998, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1998, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1998, DW_AT_decl_line(0x218)
.dwattr $C$DW$1998, DW_AT_decl_column(0x05)
$C$DW$1999 .dwtag DW_TAG_member
.dwattr $C$DW$1999, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$1999, DW_AT_name("reserved")
.dwattr $C$DW$1999, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$1999, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$1999, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$1999, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$1999, DW_AT_decl_line(0x21a)
.dwattr $C$DW$1999, DW_AT_decl_column(0x05)
$C$DW$111 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$111, DW_AT_declaration
.dwattr $C$DW$111, DW_AT_TI_symbol_name("_ZN10Probe_InfoaSERKS_")
.dwattr $C$DW$111, DW_AT_type(*$C$DW$T$1444)
.dwattr $C$DW$111, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2000 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2000, DW_AT_type(*$C$DW$T$1446)
.dwendtag $C$DW$111
.dwendtag $C$DW$T$1448
.dwattr $C$DW$T$1448, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1448, DW_AT_decl_line(0x212)
.dwattr $C$DW$T$1448, DW_AT_decl_column(0x01)
$C$DW$T$475 .dwtag DW_TAG_typedef, DW_AT_name("Probe_Info")
.dwattr $C$DW$T$475, DW_AT_type(*$C$DW$T$1448)
.dwattr $C$DW$T$475, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$475, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$475, DW_AT_decl_line(0x21b)
.dwattr $C$DW$T$475, DW_AT_decl_column(0x03)
$C$DW$T$1445 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1445, DW_AT_type(*$C$DW$T$1448)
$C$DW$T$1446 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1446, DW_AT_type(*$C$DW$T$1445)
.dwattr $C$DW$T$1446, DW_AT_address_class(0x20)
$C$DW$T$1444 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1444, DW_AT_type(*$C$DW$T$1448)
.dwattr $C$DW$T$1444, DW_AT_address_class(0x20)
$C$DW$T$1447 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1447, DW_AT_type(*$C$DW$T$1444)
.dwattr $C$DW$T$1447, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2001 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2001, DW_AT_type(*$C$DW$T$1446)
.dwendtag $C$DW$T$1447
$C$DW$T$1457 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1457, DW_AT_name("ProcessMsg")
.dwattr $C$DW$T$1457, DW_AT_byte_size(0xd8)
$C$DW$2002 .dwtag DW_TAG_member
.dwattr $C$DW$2002, DW_AT_type(*$C$DW$T$506)
.dwattr $C$DW$2002, DW_AT_name("cbufBundle")
.dwattr $C$DW$2002, DW_AT_TI_symbol_name("cbufBundle")
.dwattr $C$DW$2002, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2002, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2002, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2002, DW_AT_decl_line(0x63)
.dwattr $C$DW$2002, DW_AT_decl_column(0x21)
$C$DW$2003 .dwtag DW_TAG_member
.dwattr $C$DW$2003, DW_AT_type(*$C$DW$T$510)
.dwattr $C$DW$2003, DW_AT_name("spDataType")
.dwattr $C$DW$2003, DW_AT_TI_symbol_name("spDataType")
.dwattr $C$DW$2003, DW_AT_data_member_location[DW_OP_plus_uconst 0x88]
.dwattr $C$DW$2003, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2003, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2003, DW_AT_decl_line(0x64)
.dwattr $C$DW$2003, DW_AT_decl_column(0x21)
$C$DW$2004 .dwtag DW_TAG_member
.dwattr $C$DW$2004, DW_AT_type(*$C$DW$T$454)
.dwattr $C$DW$2004, DW_AT_name("command")
.dwattr $C$DW$2004, DW_AT_TI_symbol_name("command")
.dwattr $C$DW$2004, DW_AT_data_member_location[DW_OP_plus_uconst 0x8c]
.dwattr $C$DW$2004, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2004, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2004, DW_AT_decl_line(0x65)
.dwattr $C$DW$2004, DW_AT_decl_column(0x21)
$C$DW$2005 .dwtag DW_TAG_member
.dwattr $C$DW$2005, DW_AT_type(*$C$DW$T$456)
.dwattr $C$DW$2005, DW_AT_name("isCineData")
.dwattr $C$DW$2005, DW_AT_TI_symbol_name("isCineData")
.dwattr $C$DW$2005, DW_AT_data_member_location[DW_OP_plus_uconst 0x90]
.dwattr $C$DW$2005, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2005, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2005, DW_AT_decl_line(0x66)
.dwattr $C$DW$2005, DW_AT_decl_column(0x21)
$C$DW$2006 .dwtag DW_TAG_member
.dwattr $C$DW$2006, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$2006, DW_AT_name("timeStarted")
.dwattr $C$DW$2006, DW_AT_TI_symbol_name("timeStarted")
.dwattr $C$DW$2006, DW_AT_data_member_location[DW_OP_plus_uconst 0x98]
.dwattr $C$DW$2006, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2006, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2006, DW_AT_decl_line(0x67)
.dwattr $C$DW$2006, DW_AT_decl_column(0x21)
$C$DW$2007 .dwtag DW_TAG_member
.dwattr $C$DW$2007, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$2007, DW_AT_name("timeEnded")
.dwattr $C$DW$2007, DW_AT_TI_symbol_name("timeEnded")
.dwattr $C$DW$2007, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0]
.dwattr $C$DW$2007, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2007, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2007, DW_AT_decl_line(0x68)
.dwattr $C$DW$2007, DW_AT_decl_column(0x21)
$C$DW$2008 .dwtag DW_TAG_member
.dwattr $C$DW$2008, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$2008, DW_AT_name("jobId")
.dwattr $C$DW$2008, DW_AT_TI_symbol_name("jobId")
.dwattr $C$DW$2008, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8]
.dwattr $C$DW$2008, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2008, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2008, DW_AT_decl_line(0x69)
.dwattr $C$DW$2008, DW_AT_decl_column(0x21)
$C$DW$2009 .dwtag DW_TAG_member
.dwattr $C$DW$2009, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$2009, DW_AT_name("inputSeqId")
.dwattr $C$DW$2009, DW_AT_TI_symbol_name("inputSeqId")
.dwattr $C$DW$2009, DW_AT_data_member_location[DW_OP_plus_uconst 0xac]
.dwattr $C$DW$2009, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2009, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2009, DW_AT_decl_line(0x6a)
.dwattr $C$DW$2009, DW_AT_decl_column(0x21)
$C$DW$2010 .dwtag DW_TAG_member
.dwattr $C$DW$2010, DW_AT_type(*$C$DW$T$1449)
.dwattr $C$DW$2010, DW_AT_name("coreLoad")
.dwattr $C$DW$2010, DW_AT_TI_symbol_name("coreLoad")
.dwattr $C$DW$2010, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0]
.dwattr $C$DW$2010, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2010, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2010, DW_AT_decl_line(0x6b)
.dwattr $C$DW$2010, DW_AT_decl_column(0x21)
$C$DW$2011 .dwtag DW_TAG_member
.dwattr $C$DW$2011, DW_AT_type(*$C$DW$T$1449)
.dwattr $C$DW$2011, DW_AT_name("wrIdxIncrement")
.dwattr $C$DW$2011, DW_AT_TI_symbol_name("wrIdxIncrement")
.dwattr $C$DW$2011, DW_AT_data_member_location[DW_OP_plus_uconst 0xb4]
.dwattr $C$DW$2011, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2011, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2011, DW_AT_decl_line(0x6c)
.dwattr $C$DW$2011, DW_AT_decl_column(0x1e)
$C$DW$2012 .dwtag DW_TAG_member
.dwattr $C$DW$2012, DW_AT_type(*$C$DW$T$456)
.dwattr $C$DW$2012, DW_AT_name("updateParam")
.dwattr $C$DW$2012, DW_AT_TI_symbol_name("updateParam")
.dwattr $C$DW$2012, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8]
.dwattr $C$DW$2012, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2012, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2012, DW_AT_decl_line(0x6d)
.dwattr $C$DW$2012, DW_AT_decl_column(0x21)
$C$DW$2013 .dwtag DW_TAG_member
.dwattr $C$DW$2013, DW_AT_type(*$C$DW$T$1450)
.dwattr $C$DW$2013, DW_AT_name("imagingState")
.dwattr $C$DW$2013, DW_AT_TI_symbol_name("imagingState")
.dwattr $C$DW$2013, DW_AT_data_member_location[DW_OP_plus_uconst 0xbc]
.dwattr $C$DW$2013, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2013, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2013, DW_AT_decl_line(0x6e)
.dwattr $C$DW$2013, DW_AT_decl_column(0x21)
$C$DW$2014 .dwtag DW_TAG_member
.dwattr $C$DW$2014, DW_AT_type(*$C$DW$T$1452)
.dwattr $C$DW$2014, DW_AT_name("coreId")
.dwattr $C$DW$2014, DW_AT_TI_symbol_name("coreId")
.dwattr $C$DW$2014, DW_AT_data_member_location[DW_OP_plus_uconst 0xcc]
.dwattr $C$DW$2014, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2014, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2014, DW_AT_decl_line(0x70)
.dwattr $C$DW$2014, DW_AT_decl_column(0x21)
$C$DW$2015 .dwtag DW_TAG_member
.dwattr $C$DW$2015, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2015, DW_AT_name("cineOutDelay")
.dwattr $C$DW$2015, DW_AT_TI_symbol_name("cineOutDelay")
.dwattr $C$DW$2015, DW_AT_data_member_location[DW_OP_plus_uconst 0xd0]
.dwattr $C$DW$2015, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2015, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2015, DW_AT_decl_line(0x71)
.dwattr $C$DW$2015, DW_AT_decl_column(0x21)
$C$DW$112 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$112, DW_AT_declaration
.dwattr $C$DW$112, DW_AT_TI_symbol_name("_ZN10ProcessMsgaSERKS_")
.dwattr $C$DW$112, DW_AT_type(*$C$DW$T$1453)
.dwattr $C$DW$112, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2016 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2016, DW_AT_type(*$C$DW$T$1455)
.dwendtag $C$DW$112
.dwendtag $C$DW$T$1457
.dwattr $C$DW$T$1457, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1457, DW_AT_decl_line(0x62)
.dwattr $C$DW$T$1457, DW_AT_decl_column(0x01)
$C$DW$T$1454 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1454, DW_AT_type(*$C$DW$T$1457)
$C$DW$T$1455 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1455, DW_AT_type(*$C$DW$T$1454)
.dwattr $C$DW$T$1455, DW_AT_address_class(0x20)
$C$DW$T$1472 .dwtag DW_TAG_typedef, DW_AT_name("ProcessMsg")
.dwattr $C$DW$T$1472, DW_AT_type(*$C$DW$T$1457)
.dwattr $C$DW$T$1472, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1472, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1472, DW_AT_decl_line(0x72)
.dwattr $C$DW$T$1472, DW_AT_decl_column(0x03)
$C$DW$T$1453 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1453, DW_AT_type(*$C$DW$T$1457)
.dwattr $C$DW$T$1453, DW_AT_address_class(0x20)
$C$DW$T$1456 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1456, DW_AT_type(*$C$DW$T$1453)
.dwattr $C$DW$T$1456, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2017 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2017, DW_AT_type(*$C$DW$T$1455)
.dwendtag $C$DW$T$1456
$C$DW$T$179 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$179, DW_AT_name("RThetaInp_Param")
.dwattr $C$DW$T$179, DW_AT_byte_size(0xc8)
$C$DW$2018 .dwtag DW_TAG_member
.dwattr $C$DW$2018, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2018, DW_AT_name("numEstimates")
.dwattr $C$DW$2018, DW_AT_TI_symbol_name("numEstimates")
.dwattr $C$DW$2018, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2018, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2018, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2018, DW_AT_decl_line(0x23e)
.dwattr $C$DW$2018, DW_AT_decl_column(0x05)
$C$DW$2019 .dwtag DW_TAG_member
.dwattr $C$DW$2019, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2019, DW_AT_name("startDepthEstMm")
.dwattr $C$DW$2019, DW_AT_TI_symbol_name("startDepthEstMm")
.dwattr $C$DW$2019, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2019, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2019, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2019, DW_AT_decl_line(0x23f)
.dwattr $C$DW$2019, DW_AT_decl_column(0x05)
$C$DW$2020 .dwtag DW_TAG_member
.dwattr $C$DW$2020, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2020, DW_AT_name("stopDepthEstMm")
.dwattr $C$DW$2020, DW_AT_TI_symbol_name("stopDepthEstMm")
.dwattr $C$DW$2020, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2020, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2020, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2020, DW_AT_decl_line(0x240)
.dwattr $C$DW$2020, DW_AT_decl_column(0x05)
$C$DW$2021 .dwtag DW_TAG_member
.dwattr $C$DW$2021, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2021, DW_AT_name("initRayOffset")
.dwattr $C$DW$2021, DW_AT_TI_symbol_name("initRayOffset")
.dwattr $C$DW$2021, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2021, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2021, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2021, DW_AT_decl_line(0x241)
.dwattr $C$DW$2021, DW_AT_decl_column(0x05)
$C$DW$2022 .dwtag DW_TAG_member
.dwattr $C$DW$2022, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2022, DW_AT_name("steerAngleRads")
.dwattr $C$DW$2022, DW_AT_TI_symbol_name("steerAngleRads")
.dwattr $C$DW$2022, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2022, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2022, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2022, DW_AT_decl_line(0x242)
.dwattr $C$DW$2022, DW_AT_decl_column(0x05)
$C$DW$2023 .dwtag DW_TAG_member
.dwattr $C$DW$2023, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$2023, DW_AT_name("lineDensity")
.dwattr $C$DW$2023, DW_AT_TI_symbol_name("lineDensity")
.dwattr $C$DW$2023, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2023, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2023, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2023, DW_AT_decl_line(0x243)
.dwattr $C$DW$2023, DW_AT_decl_column(0x05)
$C$DW$2024 .dwtag DW_TAG_member
.dwattr $C$DW$2024, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$2024, DW_AT_name("startRayInFeRd")
.dwattr $C$DW$2024, DW_AT_TI_symbol_name("startRayInFeRd")
.dwattr $C$DW$2024, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2024, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2024, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2024, DW_AT_decl_line(0x244)
.dwattr $C$DW$2024, DW_AT_decl_column(0x05)
$C$DW$2025 .dwtag DW_TAG_member
.dwattr $C$DW$2025, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$2025, DW_AT_name("stopRayInFeRd")
.dwattr $C$DW$2025, DW_AT_TI_symbol_name("stopRayInFeRd")
.dwattr $C$DW$2025, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$2025, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2025, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2025, DW_AT_decl_line(0x245)
.dwattr $C$DW$2025, DW_AT_decl_column(0x05)
$C$DW$2026 .dwtag DW_TAG_member
.dwattr $C$DW$2026, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$2026, DW_AT_name("rayIncrement")
.dwattr $C$DW$2026, DW_AT_TI_symbol_name("rayIncrement")
.dwattr $C$DW$2026, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$2026, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2026, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2026, DW_AT_decl_line(0x246)
.dwattr $C$DW$2026, DW_AT_decl_column(0x05)
$C$DW$2027 .dwtag DW_TAG_member
.dwattr $C$DW$2027, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2027, DW_AT_name("reserved")
.dwattr $C$DW$2027, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2027, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$2027, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2027, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2027, DW_AT_decl_line(0x247)
.dwattr $C$DW$2027, DW_AT_decl_column(0x05)
$C$DW$113 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$113, DW_AT_declaration
.dwattr $C$DW$113, DW_AT_TI_symbol_name("_ZN15RThetaInp_ParamaSERKS_")
.dwattr $C$DW$113, DW_AT_type(*$C$DW$T$175)
.dwattr $C$DW$113, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2028 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2028, DW_AT_type(*$C$DW$T$177)
.dwendtag $C$DW$113
.dwendtag $C$DW$T$179
.dwattr $C$DW$T$179, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$179, DW_AT_decl_line(0x23d)
.dwattr $C$DW$T$179, DW_AT_decl_column(0x01)
$C$DW$T$176 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$176, DW_AT_type(*$C$DW$T$179)
$C$DW$T$177 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$177, DW_AT_type(*$C$DW$T$176)
.dwattr $C$DW$T$177, DW_AT_address_class(0x20)
$C$DW$T$476 .dwtag DW_TAG_typedef, DW_AT_name("RThetaInp_Param")
.dwattr $C$DW$T$476, DW_AT_type(*$C$DW$T$179)
.dwattr $C$DW$T$476, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$476, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$476, DW_AT_decl_line(0x248)
.dwattr $C$DW$T$476, DW_AT_decl_column(0x03)
$C$DW$T$175 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$175, DW_AT_type(*$C$DW$T$179)
.dwattr $C$DW$T$175, DW_AT_address_class(0x20)
$C$DW$T$178 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$178, DW_AT_type(*$C$DW$T$175)
.dwattr $C$DW$T$178, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2029 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2029, DW_AT_type(*$C$DW$T$177)
.dwendtag $C$DW$T$178
$C$DW$T$185 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$185, DW_AT_name("RThetaOut_Param")
.dwattr $C$DW$T$185, DW_AT_byte_size(0x1100)
$C$DW$2030 .dwtag DW_TAG_member
.dwattr $C$DW$2030, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2030, DW_AT_name("numRays")
.dwattr $C$DW$2030, DW_AT_TI_symbol_name("numRays")
.dwattr $C$DW$2030, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2030, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2030, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2030, DW_AT_decl_line(0x260)
.dwattr $C$DW$2030, DW_AT_decl_column(0x05)
$C$DW$2031 .dwtag DW_TAG_member
.dwattr $C$DW$2031, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2031, DW_AT_name("pitchRads")
.dwattr $C$DW$2031, DW_AT_TI_symbol_name("pitchRads")
.dwattr $C$DW$2031, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2031, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2031, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2031, DW_AT_decl_line(0x261)
.dwattr $C$DW$2031, DW_AT_decl_column(0x05)
$C$DW$2032 .dwtag DW_TAG_member
.dwattr $C$DW$2032, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2032, DW_AT_name("radsPerRay")
.dwattr $C$DW$2032, DW_AT_TI_symbol_name("radsPerRay")
.dwattr $C$DW$2032, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2032, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2032, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2032, DW_AT_decl_line(0x262)
.dwattr $C$DW$2032, DW_AT_decl_column(0x05)
$C$DW$2033 .dwtag DW_TAG_member
.dwattr $C$DW$2033, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2033, DW_AT_name("mmPerEst")
.dwattr $C$DW$2033, DW_AT_TI_symbol_name("mmPerEst")
.dwattr $C$DW$2033, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2033, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2033, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2033, DW_AT_decl_line(0x263)
.dwattr $C$DW$2033, DW_AT_decl_column(0x05)
$C$DW$2034 .dwtag DW_TAG_member
.dwattr $C$DW$2034, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2034, DW_AT_name("mmPerRay")
.dwattr $C$DW$2034, DW_AT_TI_symbol_name("mmPerRay")
.dwattr $C$DW$2034, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2034, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2034, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2034, DW_AT_decl_line(0x264)
.dwattr $C$DW$2034, DW_AT_decl_column(0x05)
$C$DW$2035 .dwtag DW_TAG_member
.dwattr $C$DW$2035, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2035, DW_AT_name("startRayThetaRads")
.dwattr $C$DW$2035, DW_AT_TI_symbol_name("startRayThetaRads")
.dwattr $C$DW$2035, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2035, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2035, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2035, DW_AT_decl_line(0x265)
.dwattr $C$DW$2035, DW_AT_decl_column(0x05)
$C$DW$2036 .dwtag DW_TAG_member
.dwattr $C$DW$2036, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2036, DW_AT_name("startRayLensXmm")
.dwattr $C$DW$2036, DW_AT_TI_symbol_name("startRayLensXmm")
.dwattr $C$DW$2036, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2036, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2036, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2036, DW_AT_decl_line(0x266)
.dwattr $C$DW$2036, DW_AT_decl_column(0x05)
$C$DW$2037 .dwtag DW_TAG_member
.dwattr $C$DW$2037, DW_AT_type(*$C$DW$T$180)
.dwattr $C$DW$2037, DW_AT_name("rayThetasRads")
.dwattr $C$DW$2037, DW_AT_TI_symbol_name("rayThetasRads")
.dwattr $C$DW$2037, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$2037, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2037, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2037, DW_AT_decl_line(0x267)
.dwattr $C$DW$2037, DW_AT_decl_column(0x05)
$C$DW$2038 .dwtag DW_TAG_member
.dwattr $C$DW$2038, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2038, DW_AT_name("startEstRmm")
.dwattr $C$DW$2038, DW_AT_TI_symbol_name("startEstRmm")
.dwattr $C$DW$2038, DW_AT_data_member_location[DW_OP_plus_uconst 0x1038]
.dwattr $C$DW$2038, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2038, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2038, DW_AT_decl_line(0x268)
.dwattr $C$DW$2038, DW_AT_decl_column(0x05)
$C$DW$2039 .dwtag DW_TAG_member
.dwattr $C$DW$2039, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2039, DW_AT_name("stopEstRmm")
.dwattr $C$DW$2039, DW_AT_TI_symbol_name("stopEstRmm")
.dwattr $C$DW$2039, DW_AT_data_member_location[DW_OP_plus_uconst 0x1040]
.dwattr $C$DW$2039, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2039, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2039, DW_AT_decl_line(0x269)
.dwattr $C$DW$2039, DW_AT_decl_column(0x05)
$C$DW$2040 .dwtag DW_TAG_member
.dwattr $C$DW$2040, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2040, DW_AT_name("lensFaceMm")
.dwattr $C$DW$2040, DW_AT_TI_symbol_name("lensFaceMm")
.dwattr $C$DW$2040, DW_AT_data_member_location[DW_OP_plus_uconst 0x1048]
.dwattr $C$DW$2040, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2040, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2040, DW_AT_decl_line(0x26a)
.dwattr $C$DW$2040, DW_AT_decl_column(0x05)
$C$DW$2041 .dwtag DW_TAG_member
.dwattr $C$DW$2041, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2041, DW_AT_name("rThetaOriginXmm")
.dwattr $C$DW$2041, DW_AT_TI_symbol_name("rThetaOriginXmm")
.dwattr $C$DW$2041, DW_AT_data_member_location[DW_OP_plus_uconst 0x1050]
.dwattr $C$DW$2041, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2041, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2041, DW_AT_decl_line(0x26b)
.dwattr $C$DW$2041, DW_AT_decl_column(0x05)
$C$DW$2042 .dwtag DW_TAG_member
.dwattr $C$DW$2042, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2042, DW_AT_name("rThetaOriginYmm")
.dwattr $C$DW$2042, DW_AT_TI_symbol_name("rThetaOriginYmm")
.dwattr $C$DW$2042, DW_AT_data_member_location[DW_OP_plus_uconst 0x1058]
.dwattr $C$DW$2042, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2042, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2042, DW_AT_decl_line(0x26c)
.dwattr $C$DW$2042, DW_AT_decl_column(0x05)
$C$DW$2043 .dwtag DW_TAG_member
.dwattr $C$DW$2043, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2043, DW_AT_name("depthExtentMm")
.dwattr $C$DW$2043, DW_AT_TI_symbol_name("depthExtentMm")
.dwattr $C$DW$2043, DW_AT_data_member_location[DW_OP_plus_uconst 0x1060]
.dwattr $C$DW$2043, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2043, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2043, DW_AT_decl_line(0x26d)
.dwattr $C$DW$2043, DW_AT_decl_column(0x05)
$C$DW$2044 .dwtag DW_TAG_member
.dwattr $C$DW$2044, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2044, DW_AT_name("azimuthExtentMm")
.dwattr $C$DW$2044, DW_AT_TI_symbol_name("azimuthExtentMm")
.dwattr $C$DW$2044, DW_AT_data_member_location[DW_OP_plus_uconst 0x1068]
.dwattr $C$DW$2044, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2044, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2044, DW_AT_decl_line(0x26e)
.dwattr $C$DW$2044, DW_AT_decl_column(0x05)
$C$DW$2045 .dwtag DW_TAG_member
.dwattr $C$DW$2045, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2045, DW_AT_name("startEst")
.dwattr $C$DW$2045, DW_AT_TI_symbol_name("startEst")
.dwattr $C$DW$2045, DW_AT_data_member_location[DW_OP_plus_uconst 0x1070]
.dwattr $C$DW$2045, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2045, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2045, DW_AT_decl_line(0x26f)
.dwattr $C$DW$2045, DW_AT_decl_column(0x05)
$C$DW$2046 .dwtag DW_TAG_member
.dwattr $C$DW$2046, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2046, DW_AT_name("stopEst")
.dwattr $C$DW$2046, DW_AT_TI_symbol_name("stopEst")
.dwattr $C$DW$2046, DW_AT_data_member_location[DW_OP_plus_uconst 0x1078]
.dwattr $C$DW$2046, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2046, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2046, DW_AT_decl_line(0x270)
.dwattr $C$DW$2046, DW_AT_decl_column(0x05)
$C$DW$2047 .dwtag DW_TAG_member
.dwattr $C$DW$2047, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2047, DW_AT_name("reserved")
.dwattr $C$DW$2047, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2047, DW_AT_data_member_location[DW_OP_plus_uconst 0x1080]
.dwattr $C$DW$2047, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2047, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2047, DW_AT_decl_line(0x271)
.dwattr $C$DW$2047, DW_AT_decl_column(0x05)
$C$DW$114 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$114, DW_AT_declaration
.dwattr $C$DW$114, DW_AT_TI_symbol_name("_ZN15RThetaOut_ParamaSERKS_")
.dwattr $C$DW$114, DW_AT_type(*$C$DW$T$181)
.dwattr $C$DW$114, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2048 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2048, DW_AT_type(*$C$DW$T$183)
.dwendtag $C$DW$114
.dwendtag $C$DW$T$185
.dwattr $C$DW$T$185, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$185, DW_AT_decl_line(0x25f)
.dwattr $C$DW$T$185, DW_AT_decl_column(0x01)
$C$DW$T$182 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$182, DW_AT_type(*$C$DW$T$185)
$C$DW$T$183 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$183, DW_AT_type(*$C$DW$T$182)
.dwattr $C$DW$T$183, DW_AT_address_class(0x20)
$C$DW$T$477 .dwtag DW_TAG_typedef, DW_AT_name("RThetaOut_Param")
.dwattr $C$DW$T$477, DW_AT_type(*$C$DW$T$185)
.dwattr $C$DW$T$477, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$477, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$477, DW_AT_decl_line(0x272)
.dwattr $C$DW$T$477, DW_AT_decl_column(0x03)
$C$DW$T$181 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$181, DW_AT_type(*$C$DW$T$185)
.dwattr $C$DW$T$181, DW_AT_address_class(0x20)
$C$DW$T$184 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$184, DW_AT_type(*$C$DW$T$181)
.dwattr $C$DW$T$184, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2049 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2049, DW_AT_type(*$C$DW$T$183)
.dwendtag $C$DW$T$184
$C$DW$T$469 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$469, DW_AT_name("RasterInp_Param")
.dwattr $C$DW$T$469, DW_AT_byte_size(0xb0)
$C$DW$2050 .dwtag DW_TAG_member
.dwattr $C$DW$2050, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2050, DW_AT_name("sizeX")
.dwattr $C$DW$2050, DW_AT_TI_symbol_name("sizeX")
.dwattr $C$DW$2050, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2050, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2050, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2050, DW_AT_decl_line(0x255)
.dwattr $C$DW$2050, DW_AT_decl_column(0x05)
$C$DW$2051 .dwtag DW_TAG_member
.dwattr $C$DW$2051, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2051, DW_AT_name("sizeY")
.dwattr $C$DW$2051, DW_AT_TI_symbol_name("sizeY")
.dwattr $C$DW$2051, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2051, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2051, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2051, DW_AT_decl_line(0x256)
.dwattr $C$DW$2051, DW_AT_decl_column(0x05)
$C$DW$2052 .dwtag DW_TAG_member
.dwattr $C$DW$2052, DW_AT_type(*$C$DW$T$463)
.dwattr $C$DW$2052, DW_AT_name("zoomType")
.dwattr $C$DW$2052, DW_AT_TI_symbol_name("zoomType")
.dwattr $C$DW$2052, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2052, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2052, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2052, DW_AT_decl_line(0x257)
.dwattr $C$DW$2052, DW_AT_decl_column(0x05)
$C$DW$2053 .dwtag DW_TAG_member
.dwattr $C$DW$2053, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2053, DW_AT_name("rotate")
.dwattr $C$DW$2053, DW_AT_TI_symbol_name("rotate")
.dwattr $C$DW$2053, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2053, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2053, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2053, DW_AT_decl_line(0x258)
.dwattr $C$DW$2053, DW_AT_decl_column(0x05)
$C$DW$2054 .dwtag DW_TAG_member
.dwattr $C$DW$2054, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2054, DW_AT_name("curvedPhasedFitVertical")
.dwattr $C$DW$2054, DW_AT_TI_symbol_name("curvedPhasedFitVertical")
.dwattr $C$DW$2054, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2054, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2054, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2054, DW_AT_decl_line(0x259)
.dwattr $C$DW$2054, DW_AT_decl_column(0x05)
$C$DW$2055 .dwtag DW_TAG_member
.dwattr $C$DW$2055, DW_AT_type(*$C$DW$T$464)
.dwattr $C$DW$2055, DW_AT_name("zoomBitsAlloc")
.dwattr $C$DW$2055, DW_AT_TI_symbol_name("zoomBitsAlloc")
.dwattr $C$DW$2055, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2055, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2055, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2055, DW_AT_decl_line(0x25a)
.dwattr $C$DW$2055, DW_AT_decl_column(0x05)
$C$DW$2056 .dwtag DW_TAG_member
.dwattr $C$DW$2056, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2056, DW_AT_name("reserved")
.dwattr $C$DW$2056, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2056, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2056, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2056, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2056, DW_AT_decl_line(0x25b)
.dwattr $C$DW$2056, DW_AT_decl_column(0x05)
$C$DW$115 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$115, DW_AT_declaration
.dwattr $C$DW$115, DW_AT_TI_symbol_name("_ZN15RasterInp_ParamaSERKS_")
.dwattr $C$DW$115, DW_AT_type(*$C$DW$T$465)
.dwattr $C$DW$115, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2057 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2057, DW_AT_type(*$C$DW$T$467)
.dwendtag $C$DW$115
.dwendtag $C$DW$T$469
.dwattr $C$DW$T$469, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$469, DW_AT_decl_line(0x254)
.dwattr $C$DW$T$469, DW_AT_decl_column(0x01)
$C$DW$T$466 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$466, DW_AT_type(*$C$DW$T$469)
$C$DW$T$467 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$467, DW_AT_type(*$C$DW$T$466)
.dwattr $C$DW$T$467, DW_AT_address_class(0x20)
$C$DW$T$478 .dwtag DW_TAG_typedef, DW_AT_name("RasterInp_Param")
.dwattr $C$DW$T$478, DW_AT_type(*$C$DW$T$469)
.dwattr $C$DW$T$478, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$478, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$478, DW_AT_decl_line(0x25c)
.dwattr $C$DW$T$478, DW_AT_decl_column(0x03)
$C$DW$T$465 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$465, DW_AT_type(*$C$DW$T$469)
.dwattr $C$DW$T$465, DW_AT_address_class(0x20)
$C$DW$T$468 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$468, DW_AT_type(*$C$DW$T$465)
.dwattr $C$DW$T$468, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2058 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2058, DW_AT_type(*$C$DW$T$467)
.dwendtag $C$DW$T$468
$C$DW$T$474 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$474, DW_AT_name("RasterOut_Param")
.dwattr $C$DW$T$474, DW_AT_byte_size(0xe0)
$C$DW$2059 .dwtag DW_TAG_member
.dwattr $C$DW$2059, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2059, DW_AT_name("mmPerPixelBase")
.dwattr $C$DW$2059, DW_AT_TI_symbol_name("mmPerPixelBase")
.dwattr $C$DW$2059, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2059, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2059, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2059, DW_AT_decl_line(0x276)
.dwattr $C$DW$2059, DW_AT_decl_column(0x05)
$C$DW$2060 .dwtag DW_TAG_member
.dwattr $C$DW$2060, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2060, DW_AT_name("mmPerPixel")
.dwattr $C$DW$2060, DW_AT_TI_symbol_name("mmPerPixel")
.dwattr $C$DW$2060, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2060, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2060, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2060, DW_AT_decl_line(0x277)
.dwattr $C$DW$2060, DW_AT_decl_column(0x05)
$C$DW$2061 .dwtag DW_TAG_member
.dwattr $C$DW$2061, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2061, DW_AT_name("rasterOriginXmm")
.dwattr $C$DW$2061, DW_AT_TI_symbol_name("rasterOriginXmm")
.dwattr $C$DW$2061, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2061, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2061, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2061, DW_AT_decl_line(0x278)
.dwattr $C$DW$2061, DW_AT_decl_column(0x05)
$C$DW$2062 .dwtag DW_TAG_member
.dwattr $C$DW$2062, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2062, DW_AT_name("rasterOriginYmm")
.dwattr $C$DW$2062, DW_AT_TI_symbol_name("rasterOriginYmm")
.dwattr $C$DW$2062, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2062, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2062, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2062, DW_AT_decl_line(0x279)
.dwattr $C$DW$2062, DW_AT_decl_column(0x05)
$C$DW$2063 .dwtag DW_TAG_member
.dwattr $C$DW$2063, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2063, DW_AT_name("centerAngleRad")
.dwattr $C$DW$2063, DW_AT_TI_symbol_name("centerAngleRad")
.dwattr $C$DW$2063, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2063, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2063, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2063, DW_AT_decl_line(0x27a)
.dwattr $C$DW$2063, DW_AT_decl_column(0x05)
$C$DW$2064 .dwtag DW_TAG_member
.dwattr $C$DW$2064, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2064, DW_AT_name("rotMmPerPixelBase")
.dwattr $C$DW$2064, DW_AT_TI_symbol_name("rotMmPerPixelBase")
.dwattr $C$DW$2064, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2064, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2064, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2064, DW_AT_decl_line(0x27b)
.dwattr $C$DW$2064, DW_AT_decl_column(0x05)
$C$DW$2065 .dwtag DW_TAG_member
.dwattr $C$DW$2065, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2065, DW_AT_name("rotMmPerPixel")
.dwattr $C$DW$2065, DW_AT_TI_symbol_name("rotMmPerPixel")
.dwattr $C$DW$2065, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2065, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2065, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2065, DW_AT_decl_line(0x27c)
.dwattr $C$DW$2065, DW_AT_decl_column(0x05)
$C$DW$2066 .dwtag DW_TAG_member
.dwattr $C$DW$2066, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2066, DW_AT_name("rotOriginXmm")
.dwattr $C$DW$2066, DW_AT_TI_symbol_name("rotOriginXmm")
.dwattr $C$DW$2066, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$2066, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2066, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2066, DW_AT_decl_line(0x27d)
.dwattr $C$DW$2066, DW_AT_decl_column(0x05)
$C$DW$2067 .dwtag DW_TAG_member
.dwattr $C$DW$2067, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2067, DW_AT_name("rotOriginYmm")
.dwattr $C$DW$2067, DW_AT_TI_symbol_name("rotOriginYmm")
.dwattr $C$DW$2067, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$2067, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2067, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2067, DW_AT_decl_line(0x27e)
.dwattr $C$DW$2067, DW_AT_decl_column(0x05)
$C$DW$2068 .dwtag DW_TAG_member
.dwattr $C$DW$2068, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2068, DW_AT_name("minXMm")
.dwattr $C$DW$2068, DW_AT_TI_symbol_name("minXMm")
.dwattr $C$DW$2068, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$2068, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2068, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2068, DW_AT_decl_line(0x27f)
.dwattr $C$DW$2068, DW_AT_decl_column(0x05)
$C$DW$2069 .dwtag DW_TAG_member
.dwattr $C$DW$2069, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2069, DW_AT_name("minYMm")
.dwattr $C$DW$2069, DW_AT_TI_symbol_name("minYMm")
.dwattr $C$DW$2069, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$2069, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2069, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2069, DW_AT_decl_line(0x280)
.dwattr $C$DW$2069, DW_AT_decl_column(0x05)
$C$DW$2070 .dwtag DW_TAG_member
.dwattr $C$DW$2070, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$2070, DW_AT_name("startRow")
.dwattr $C$DW$2070, DW_AT_TI_symbol_name("startRow")
.dwattr $C$DW$2070, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$2070, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2070, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2070, DW_AT_decl_line(0x281)
.dwattr $C$DW$2070, DW_AT_decl_column(0x05)
$C$DW$2071 .dwtag DW_TAG_member
.dwattr $C$DW$2071, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2071, DW_AT_name("reserved")
.dwattr $C$DW$2071, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2071, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$2071, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2071, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2071, DW_AT_decl_line(0x282)
.dwattr $C$DW$2071, DW_AT_decl_column(0x05)
$C$DW$116 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$116, DW_AT_declaration
.dwattr $C$DW$116, DW_AT_TI_symbol_name("_ZN15RasterOut_ParamaSERKS_")
.dwattr $C$DW$116, DW_AT_type(*$C$DW$T$470)
.dwattr $C$DW$116, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2072 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2072, DW_AT_type(*$C$DW$T$472)
.dwendtag $C$DW$116
.dwendtag $C$DW$T$474
.dwattr $C$DW$T$474, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$474, DW_AT_decl_line(0x275)
.dwattr $C$DW$T$474, DW_AT_decl_column(0x01)
$C$DW$T$471 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$471, DW_AT_type(*$C$DW$T$474)
$C$DW$T$472 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$472, DW_AT_type(*$C$DW$T$471)
.dwattr $C$DW$T$472, DW_AT_address_class(0x20)
$C$DW$T$479 .dwtag DW_TAG_typedef, DW_AT_name("RasterOut_Param")
.dwattr $C$DW$T$479, DW_AT_type(*$C$DW$T$474)
.dwattr $C$DW$T$479, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$479, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$479, DW_AT_decl_line(0x283)
.dwattr $C$DW$T$479, DW_AT_decl_column(0x03)
$C$DW$T$470 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$470, DW_AT_type(*$C$DW$T$474)
.dwattr $C$DW$T$470, DW_AT_address_class(0x20)
$C$DW$T$473 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$473, DW_AT_type(*$C$DW$T$470)
.dwattr $C$DW$T$473, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2073 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2073, DW_AT_type(*$C$DW$T$472)
.dwendtag $C$DW$T$473
$C$DW$T$485 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$485, DW_AT_name("RasterScanConv_Param")
.dwattr $C$DW$T$485, DW_AT_byte_size(0x3a70)
$C$DW$2074 .dwtag DW_TAG_member
.dwattr $C$DW$2074, DW_AT_type(*$C$DW$T$475)
.dwattr $C$DW$2074, DW_AT_name("probeInfo")
.dwattr $C$DW$2074, DW_AT_TI_symbol_name("probeInfo")
.dwattr $C$DW$2074, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2074, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2074, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2074, DW_AT_decl_line(0x287)
.dwattr $C$DW$2074, DW_AT_decl_column(0x05)
$C$DW$2075 .dwtag DW_TAG_member
.dwattr $C$DW$2075, DW_AT_type(*$C$DW$T$476)
.dwattr $C$DW$2075, DW_AT_name("rTInpParamB")
.dwattr $C$DW$2075, DW_AT_TI_symbol_name("rTInpParamB")
.dwattr $C$DW$2075, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0]
.dwattr $C$DW$2075, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2075, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2075, DW_AT_decl_line(0x288)
.dwattr $C$DW$2075, DW_AT_decl_column(0x05)
$C$DW$2076 .dwtag DW_TAG_member
.dwattr $C$DW$2076, DW_AT_type(*$C$DW$T$476)
.dwattr $C$DW$2076, DW_AT_name("rTInpParamC")
.dwattr $C$DW$2076, DW_AT_TI_symbol_name("rTInpParamC")
.dwattr $C$DW$2076, DW_AT_data_member_location[DW_OP_plus_uconst 0x178]
.dwattr $C$DW$2076, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2076, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2076, DW_AT_decl_line(0x289)
.dwattr $C$DW$2076, DW_AT_decl_column(0x05)
$C$DW$2077 .dwtag DW_TAG_member
.dwattr $C$DW$2077, DW_AT_type(*$C$DW$T$476)
.dwattr $C$DW$2077, DW_AT_name("rTInpScZoom")
.dwattr $C$DW$2077, DW_AT_TI_symbol_name("rTInpScZoom")
.dwattr $C$DW$2077, DW_AT_data_member_location[DW_OP_plus_uconst 0x240]
.dwattr $C$DW$2077, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2077, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2077, DW_AT_decl_line(0x28a)
.dwattr $C$DW$2077, DW_AT_decl_column(0x05)
$C$DW$2078 .dwtag DW_TAG_member
.dwattr $C$DW$2078, DW_AT_type(*$C$DW$T$477)
.dwattr $C$DW$2078, DW_AT_name("rThetaOutParamB")
.dwattr $C$DW$2078, DW_AT_TI_symbol_name("rThetaOutParamB")
.dwattr $C$DW$2078, DW_AT_data_member_location[DW_OP_plus_uconst 0x308]
.dwattr $C$DW$2078, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2078, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2078, DW_AT_decl_line(0x28b)
.dwattr $C$DW$2078, DW_AT_decl_column(0x05)
$C$DW$2079 .dwtag DW_TAG_member
.dwattr $C$DW$2079, DW_AT_type(*$C$DW$T$477)
.dwattr $C$DW$2079, DW_AT_name("rThetaOutParamC")
.dwattr $C$DW$2079, DW_AT_TI_symbol_name("rThetaOutParamC")
.dwattr $C$DW$2079, DW_AT_data_member_location[DW_OP_plus_uconst 0x1408]
.dwattr $C$DW$2079, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2079, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2079, DW_AT_decl_line(0x28c)
.dwattr $C$DW$2079, DW_AT_decl_column(0x05)
$C$DW$2080 .dwtag DW_TAG_member
.dwattr $C$DW$2080, DW_AT_type(*$C$DW$T$477)
.dwattr $C$DW$2080, DW_AT_name("rThetaOutParamRef")
.dwattr $C$DW$2080, DW_AT_TI_symbol_name("rThetaOutParamRef")
.dwattr $C$DW$2080, DW_AT_data_member_location[DW_OP_plus_uconst 0x2508]
.dwattr $C$DW$2080, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2080, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2080, DW_AT_decl_line(0x28d)
.dwattr $C$DW$2080, DW_AT_decl_column(0x05)
$C$DW$2081 .dwtag DW_TAG_member
.dwattr $C$DW$2081, DW_AT_type(*$C$DW$T$478)
.dwattr $C$DW$2081, DW_AT_name("rasterInpParam")
.dwattr $C$DW$2081, DW_AT_TI_symbol_name("rasterInpParam")
.dwattr $C$DW$2081, DW_AT_data_member_location[DW_OP_plus_uconst 0x3608]
.dwattr $C$DW$2081, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2081, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2081, DW_AT_decl_line(0x28e)
.dwattr $C$DW$2081, DW_AT_decl_column(0x05)
$C$DW$2082 .dwtag DW_TAG_member
.dwattr $C$DW$2082, DW_AT_type(*$C$DW$T$479)
.dwattr $C$DW$2082, DW_AT_name("rasterOutParamB")
.dwattr $C$DW$2082, DW_AT_TI_symbol_name("rasterOutParamB")
.dwattr $C$DW$2082, DW_AT_data_member_location[DW_OP_plus_uconst 0x36b8]
.dwattr $C$DW$2082, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2082, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2082, DW_AT_decl_line(0x28f)
.dwattr $C$DW$2082, DW_AT_decl_column(0x05)
$C$DW$2083 .dwtag DW_TAG_member
.dwattr $C$DW$2083, DW_AT_type(*$C$DW$T$479)
.dwattr $C$DW$2083, DW_AT_name("rasterOutParamC")
.dwattr $C$DW$2083, DW_AT_TI_symbol_name("rasterOutParamC")
.dwattr $C$DW$2083, DW_AT_data_member_location[DW_OP_plus_uconst 0x3798]
.dwattr $C$DW$2083, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2083, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2083, DW_AT_decl_line(0x290)
.dwattr $C$DW$2083, DW_AT_decl_column(0x05)
$C$DW$2084 .dwtag DW_TAG_member
.dwattr $C$DW$2084, DW_AT_type(*$C$DW$T$480)
.dwattr $C$DW$2084, DW_AT_name("rasterZoomParamB")
.dwattr $C$DW$2084, DW_AT_TI_symbol_name("rasterZoomParamB")
.dwattr $C$DW$2084, DW_AT_data_member_location[DW_OP_plus_uconst 0x3878]
.dwattr $C$DW$2084, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2084, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2084, DW_AT_decl_line(0x291)
.dwattr $C$DW$2084, DW_AT_decl_column(0x05)
$C$DW$2085 .dwtag DW_TAG_member
.dwattr $C$DW$2085, DW_AT_type(*$C$DW$T$480)
.dwattr $C$DW$2085, DW_AT_name("rasterZoomParamC")
.dwattr $C$DW$2085, DW_AT_TI_symbol_name("rasterZoomParamC")
.dwattr $C$DW$2085, DW_AT_data_member_location[DW_OP_plus_uconst 0x3930]
.dwattr $C$DW$2085, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2085, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2085, DW_AT_decl_line(0x292)
.dwattr $C$DW$2085, DW_AT_decl_column(0x05)
$C$DW$2086 .dwtag DW_TAG_member
.dwattr $C$DW$2086, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2086, DW_AT_name("useArrayref")
.dwattr $C$DW$2086, DW_AT_TI_symbol_name("useArrayref")
.dwattr $C$DW$2086, DW_AT_data_member_location[DW_OP_plus_uconst 0x39e8]
.dwattr $C$DW$2086, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2086, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2086, DW_AT_decl_line(0x293)
.dwattr $C$DW$2086, DW_AT_decl_column(0x05)
$C$DW$2087 .dwtag DW_TAG_member
.dwattr $C$DW$2087, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2087, DW_AT_name("reserved")
.dwattr $C$DW$2087, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2087, DW_AT_data_member_location[DW_OP_plus_uconst 0x39f0]
.dwattr $C$DW$2087, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2087, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2087, DW_AT_decl_line(0x294)
.dwattr $C$DW$2087, DW_AT_decl_column(0x05)
$C$DW$117 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$117, DW_AT_declaration
.dwattr $C$DW$117, DW_AT_TI_symbol_name("_ZN20RasterScanConv_ParamaSERKS_")
.dwattr $C$DW$117, DW_AT_type(*$C$DW$T$481)
.dwattr $C$DW$117, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2088 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2088, DW_AT_type(*$C$DW$T$483)
.dwendtag $C$DW$117
.dwendtag $C$DW$T$485
.dwattr $C$DW$T$485, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$485, DW_AT_decl_line(0x286)
.dwattr $C$DW$T$485, DW_AT_decl_column(0x01)
$C$DW$T$482 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$482, DW_AT_type(*$C$DW$T$485)
$C$DW$T$483 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$483, DW_AT_type(*$C$DW$T$482)
.dwattr $C$DW$T$483, DW_AT_address_class(0x20)
$C$DW$T$1921 .dwtag DW_TAG_typedef, DW_AT_name("RasterScanConv_Param")
.dwattr $C$DW$T$1921, DW_AT_type(*$C$DW$T$485)
.dwattr $C$DW$T$1921, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1921, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1921, DW_AT_decl_line(0x295)
.dwattr $C$DW$T$1921, DW_AT_decl_column(0x03)
$C$DW$T$481 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$481, DW_AT_type(*$C$DW$T$485)
.dwattr $C$DW$T$481, DW_AT_address_class(0x20)
$C$DW$T$484 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$484, DW_AT_type(*$C$DW$T$481)
.dwattr $C$DW$T$484, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2089 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2089, DW_AT_type(*$C$DW$T$483)
.dwendtag $C$DW$T$484
$C$DW$T$490 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$490, DW_AT_name("RasterZoomParam")
.dwattr $C$DW$T$490, DW_AT_byte_size(0xb8)
$C$DW$2090 .dwtag DW_TAG_member
.dwattr $C$DW$2090, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2090, DW_AT_name("zoomRegionStartX")
.dwattr $C$DW$2090, DW_AT_TI_symbol_name("zoomRegionStartX")
.dwattr $C$DW$2090, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2090, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2090, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2090, DW_AT_decl_line(0x232)
.dwattr $C$DW$2090, DW_AT_decl_column(0x05)
$C$DW$2091 .dwtag DW_TAG_member
.dwattr $C$DW$2091, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2091, DW_AT_name("zoomRegionStartY")
.dwattr $C$DW$2091, DW_AT_TI_symbol_name("zoomRegionStartY")
.dwattr $C$DW$2091, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2091, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2091, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2091, DW_AT_decl_line(0x233)
.dwattr $C$DW$2091, DW_AT_decl_column(0x05)
$C$DW$2092 .dwtag DW_TAG_member
.dwattr $C$DW$2092, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2092, DW_AT_name("zoomRegionSizeX")
.dwattr $C$DW$2092, DW_AT_TI_symbol_name("zoomRegionSizeX")
.dwattr $C$DW$2092, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2092, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2092, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2092, DW_AT_decl_line(0x234)
.dwattr $C$DW$2092, DW_AT_decl_column(0x05)
$C$DW$2093 .dwtag DW_TAG_member
.dwattr $C$DW$2093, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2093, DW_AT_name("zoomRegionSizeY")
.dwattr $C$DW$2093, DW_AT_TI_symbol_name("zoomRegionSizeY")
.dwattr $C$DW$2093, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2093, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2093, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2093, DW_AT_decl_line(0x235)
.dwattr $C$DW$2093, DW_AT_decl_column(0x05)
$C$DW$2094 .dwtag DW_TAG_member
.dwattr $C$DW$2094, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2094, DW_AT_name("zoomOutSizeX")
.dwattr $C$DW$2094, DW_AT_TI_symbol_name("zoomOutSizeX")
.dwattr $C$DW$2094, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2094, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2094, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2094, DW_AT_decl_line(0x236)
.dwattr $C$DW$2094, DW_AT_decl_column(0x05)
$C$DW$2095 .dwtag DW_TAG_member
.dwattr $C$DW$2095, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2095, DW_AT_name("zoomOutSizeY")
.dwattr $C$DW$2095, DW_AT_TI_symbol_name("zoomOutSizeY")
.dwattr $C$DW$2095, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2095, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2095, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2095, DW_AT_decl_line(0x237)
.dwattr $C$DW$2095, DW_AT_decl_column(0x05)
$C$DW$2096 .dwtag DW_TAG_member
.dwattr $C$DW$2096, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2096, DW_AT_name("zoomFactor")
.dwattr $C$DW$2096, DW_AT_TI_symbol_name("zoomFactor")
.dwattr $C$DW$2096, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2096, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2096, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2096, DW_AT_decl_line(0x238)
.dwattr $C$DW$2096, DW_AT_decl_column(0x05)
$C$DW$2097 .dwtag DW_TAG_member
.dwattr $C$DW$2097, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2097, DW_AT_name("reserved")
.dwattr $C$DW$2097, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2097, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$2097, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2097, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2097, DW_AT_decl_line(0x239)
.dwattr $C$DW$2097, DW_AT_decl_column(0x05)
$C$DW$118 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$118, DW_AT_declaration
.dwattr $C$DW$118, DW_AT_TI_symbol_name("_ZN15RasterZoomParamaSERKS_")
.dwattr $C$DW$118, DW_AT_type(*$C$DW$T$486)
.dwattr $C$DW$118, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2098 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2098, DW_AT_type(*$C$DW$T$488)
.dwendtag $C$DW$118
.dwendtag $C$DW$T$490
.dwattr $C$DW$T$490, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$490, DW_AT_decl_line(0x231)
.dwattr $C$DW$T$490, DW_AT_decl_column(0x01)
$C$DW$T$480 .dwtag DW_TAG_typedef, DW_AT_name("RasterZoomParam")
.dwattr $C$DW$T$480, DW_AT_type(*$C$DW$T$490)
.dwattr $C$DW$T$480, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$480, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$480, DW_AT_decl_line(0x23a)
.dwattr $C$DW$T$480, DW_AT_decl_column(0x03)
$C$DW$T$487 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$487, DW_AT_type(*$C$DW$T$490)
$C$DW$T$488 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$488, DW_AT_type(*$C$DW$T$487)
.dwattr $C$DW$T$488, DW_AT_address_class(0x20)
$C$DW$T$486 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$486, DW_AT_type(*$C$DW$T$490)
.dwattr $C$DW$T$486, DW_AT_address_class(0x20)
$C$DW$T$489 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$489, DW_AT_type(*$C$DW$T$486)
.dwattr $C$DW$T$489, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2099 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2099, DW_AT_type(*$C$DW$T$488)
.dwendtag $C$DW$T$489
$C$DW$T$364 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$364, DW_AT_name("SemaphoreCheckinIDType")
.dwattr $C$DW$T$364, DW_AT_byte_size(0x04)
$C$DW$2100 .dwtag DW_TAG_enumerator, DW_AT_name("SEMAPHORE_CHECKIN_ID_CINE_MANAGER"), DW_AT_const_value(0x00)
.dwattr $C$DW$2100, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2100, DW_AT_decl_line(0x4b)
.dwattr $C$DW$2100, DW_AT_decl_column(0x05)
$C$DW$2101 .dwtag DW_TAG_enumerator, DW_AT_name("SEMAPHORE_CHECKIN_ID_OUTPUT_MANAGER"), DW_AT_const_value(0x01)
.dwattr $C$DW$2101, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2101, DW_AT_decl_line(0x4c)
.dwattr $C$DW$2101, DW_AT_decl_column(0x05)
$C$DW$2102 .dwtag DW_TAG_enumerator, DW_AT_name("SEMAPHORE_CHECKIN_ID_STOP_COMPLETE"), DW_AT_const_value(0x02)
.dwattr $C$DW$2102, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2102, DW_AT_decl_line(0x4d)
.dwattr $C$DW$2102, DW_AT_decl_column(0x05)
$C$DW$2103 .dwtag DW_TAG_enumerator, DW_AT_name("SEMAPHORE_CHECKIN_ID_DISPLAY_LAYOUT_CHANGE"), DW_AT_const_value(0x03)
.dwattr $C$DW$2103, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2103, DW_AT_decl_line(0x4e)
.dwattr $C$DW$2103, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$364
.dwattr $C$DW$T$364, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$364, DW_AT_decl_line(0x4a)
.dwattr $C$DW$T$364, DW_AT_decl_column(0x01)
$C$DW$T$365 .dwtag DW_TAG_typedef, DW_AT_name("SemaphoreCheckinIDType")
.dwattr $C$DW$T$365, DW_AT_type(*$C$DW$T$364)
.dwattr $C$DW$T$365, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$365, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$365, DW_AT_decl_line(0x4f)
.dwattr $C$DW$T$365, DW_AT_decl_column(0x03)
$C$DW$T$1368 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1368, DW_AT_name("SpDspRfBuf_Type")
.dwattr $C$DW$T$1368, DW_AT_byte_size(0x04)
$C$DW$2104 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_INVALID"), DW_AT_const_value(-1)
.dwattr $C$DW$2104, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2104, DW_AT_decl_line(0x12c)
.dwattr $C$DW$2104, DW_AT_decl_column(0x05)
$C$DW$2105 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_ECHO_PI0"), DW_AT_const_value(0x00)
.dwattr $C$DW$2105, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2105, DW_AT_decl_line(0x12d)
.dwattr $C$DW$2105, DW_AT_decl_column(0x05)
$C$DW$2106 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_ECHO_PI1"), DW_AT_const_value(0x01)
.dwattr $C$DW$2106, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2106, DW_AT_decl_line(0x12e)
.dwattr $C$DW$2106, DW_AT_decl_column(0x05)
$C$DW$2107 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG0_PI0"), DW_AT_const_value(0x02)
.dwattr $C$DW$2107, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2107, DW_AT_decl_line(0x12f)
.dwattr $C$DW$2107, DW_AT_decl_column(0x05)
$C$DW$2108 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG0_PI1"), DW_AT_const_value(0x03)
.dwattr $C$DW$2108, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2108, DW_AT_decl_line(0x130)
.dwattr $C$DW$2108, DW_AT_decl_column(0x05)
$C$DW$2109 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG1_PI0"), DW_AT_const_value(0x04)
.dwattr $C$DW$2109, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2109, DW_AT_decl_line(0x131)
.dwattr $C$DW$2109, DW_AT_decl_column(0x05)
$C$DW$2110 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG1_PI1"), DW_AT_const_value(0x05)
.dwattr $C$DW$2110, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2110, DW_AT_decl_line(0x132)
.dwattr $C$DW$2110, DW_AT_decl_column(0x05)
$C$DW$2111 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG2_PI0"), DW_AT_const_value(0x06)
.dwattr $C$DW$2111, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2111, DW_AT_decl_line(0x133)
.dwattr $C$DW$2111, DW_AT_decl_column(0x05)
$C$DW$2112 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG2_PI1"), DW_AT_const_value(0x07)
.dwattr $C$DW$2112, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2112, DW_AT_decl_line(0x134)
.dwattr $C$DW$2112, DW_AT_decl_column(0x05)
$C$DW$2113 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG3_PI0"), DW_AT_const_value(0x08)
.dwattr $C$DW$2113, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2113, DW_AT_decl_line(0x135)
.dwattr $C$DW$2113, DW_AT_decl_column(0x05)
$C$DW$2114 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG3_PI1"), DW_AT_const_value(0x09)
.dwattr $C$DW$2114, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2114, DW_AT_decl_line(0x136)
.dwattr $C$DW$2114, DW_AT_decl_column(0x05)
$C$DW$2115 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG4_PI0"), DW_AT_const_value(0x0a)
.dwattr $C$DW$2115, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2115, DW_AT_decl_line(0x137)
.dwattr $C$DW$2115, DW_AT_decl_column(0x05)
$C$DW$2116 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG4_PI1"), DW_AT_const_value(0x0b)
.dwattr $C$DW$2116, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2116, DW_AT_decl_line(0x138)
.dwattr $C$DW$2116, DW_AT_decl_column(0x05)
$C$DW$2117 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG5_PI0"), DW_AT_const_value(0x0c)
.dwattr $C$DW$2117, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2117, DW_AT_decl_line(0x139)
.dwattr $C$DW$2117, DW_AT_decl_column(0x05)
$C$DW$2118 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG5_PI1"), DW_AT_const_value(0x0d)
.dwattr $C$DW$2118, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2118, DW_AT_decl_line(0x13a)
.dwattr $C$DW$2118, DW_AT_decl_column(0x05)
$C$DW$2119 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG6_PI0"), DW_AT_const_value(0x0e)
.dwattr $C$DW$2119, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2119, DW_AT_decl_line(0x13b)
.dwattr $C$DW$2119, DW_AT_decl_column(0x05)
$C$DW$2120 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG6_PI1"), DW_AT_const_value(0x0f)
.dwattr $C$DW$2120, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2120, DW_AT_decl_line(0x13c)
.dwattr $C$DW$2120, DW_AT_decl_column(0x05)
$C$DW$2121 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG7_PI0"), DW_AT_const_value(0x10)
.dwattr $C$DW$2121, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2121, DW_AT_decl_line(0x13d)
.dwattr $C$DW$2121, DW_AT_decl_column(0x05)
$C$DW$2122 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG7_PI1"), DW_AT_const_value(0x11)
.dwattr $C$DW$2122, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2122, DW_AT_decl_line(0x13e)
.dwattr $C$DW$2122, DW_AT_decl_column(0x05)
$C$DW$2123 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG8_PI0"), DW_AT_const_value(0x12)
.dwattr $C$DW$2123, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2123, DW_AT_decl_line(0x13f)
.dwattr $C$DW$2123, DW_AT_decl_column(0x05)
$C$DW$2124 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG8_PI1"), DW_AT_const_value(0x13)
.dwattr $C$DW$2124, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2124, DW_AT_decl_line(0x140)
.dwattr $C$DW$2124, DW_AT_decl_column(0x05)
$C$DW$2125 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_NV_ANG0"), DW_AT_const_value(0x14)
.dwattr $C$DW$2125, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2125, DW_AT_decl_line(0x141)
.dwattr $C$DW$2125, DW_AT_decl_column(0x05)
$C$DW$2126 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_NV_ANG1"), DW_AT_const_value(0x15)
.dwattr $C$DW$2126, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2126, DW_AT_decl_line(0x142)
.dwattr $C$DW$2126, DW_AT_decl_column(0x05)
$C$DW$2127 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_NV_ANG2"), DW_AT_const_value(0x16)
.dwattr $C$DW$2127, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2127, DW_AT_decl_line(0x143)
.dwattr $C$DW$2127, DW_AT_decl_column(0x05)
$C$DW$2128 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_COLOR"), DW_AT_const_value(0x17)
.dwattr $C$DW$2128, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2128, DW_AT_decl_line(0x144)
.dwattr $C$DW$2128, DW_AT_decl_column(0x05)
$C$DW$2129 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MMODE_PI0"), DW_AT_const_value(0x18)
.dwattr $C$DW$2129, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2129, DW_AT_decl_line(0x145)
.dwattr $C$DW$2129, DW_AT_decl_column(0x05)
$C$DW$2130 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MMODE_PI1"), DW_AT_const_value(0x19)
.dwattr $C$DW$2130, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2130, DW_AT_decl_line(0x146)
.dwattr $C$DW$2130, DW_AT_decl_column(0x05)
$C$DW$2131 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_PW"), DW_AT_const_value(0x1a)
.dwattr $C$DW$2131, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2131, DW_AT_decl_line(0x147)
.dwattr $C$DW$2131, DW_AT_decl_column(0x05)
$C$DW$2132 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_PAI"), DW_AT_const_value(0x1b)
.dwattr $C$DW$2132, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2132, DW_AT_decl_line(0x148)
.dwattr $C$DW$2132, DW_AT_decl_column(0x05)
$C$DW$2133 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_EOL"), DW_AT_const_value(0x1c)
.dwattr $C$DW$2133, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2133, DW_AT_decl_line(0x149)
.dwattr $C$DW$2133, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1368
.dwattr $C$DW$T$1368, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1368, DW_AT_decl_line(0x12b)
.dwattr $C$DW$T$1368, DW_AT_decl_column(0x01)
$C$DW$T$1369 .dwtag DW_TAG_typedef, DW_AT_name("SpDspRfBuf_Type")
.dwattr $C$DW$T$1369, DW_AT_type(*$C$DW$T$1368)
.dwattr $C$DW$T$1369, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1369, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1369, DW_AT_decl_line(0x14a)
.dwattr $C$DW$T$1369, DW_AT_decl_column(0x03)
$C$DW$T$1370 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1370, DW_AT_type(*$C$DW$T$1369)
.dwattr $C$DW$T$1370, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1370, DW_AT_byte_size(0x80)
$C$DW$2134 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2134, DW_AT_upper_bound(0x1f)
.dwendtag $C$DW$T$1370
$C$DW$T$1364 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1364, DW_AT_name("SpDspSem_Type")
.dwattr $C$DW$T$1364, DW_AT_byte_size(0x04)
$C$DW$2135 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SEM_POST"), DW_AT_const_value(0x00)
.dwattr $C$DW$2135, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2135, DW_AT_decl_line(0x110)
.dwattr $C$DW$2135, DW_AT_decl_column(0x05)
$C$DW$2136 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SEM_PEND"), DW_AT_const_value(0x01)
.dwattr $C$DW$2136, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2136, DW_AT_decl_line(0x111)
.dwattr $C$DW$2136, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1364
.dwattr $C$DW$T$1364, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1364, DW_AT_decl_line(0x10f)
.dwattr $C$DW$T$1364, DW_AT_decl_column(0x01)
$C$DW$T$1365 .dwtag DW_TAG_typedef, DW_AT_name("SpDspSem_Type")
.dwattr $C$DW$T$1365, DW_AT_type(*$C$DW$T$1364)
.dwattr $C$DW$T$1365, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1365, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1365, DW_AT_decl_line(0x112)
.dwattr $C$DW$T$1365, DW_AT_decl_column(0x03)
$C$DW$T$1442 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1442, DW_AT_name("SpDspShdb_Type")
.dwattr $C$DW$T$1442, DW_AT_byte_size(0x04)
$C$DW$2137 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SHDB_INVALID"), DW_AT_const_value(0x00)
.dwattr $C$DW$2137, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2137, DW_AT_decl_line(0x14e)
.dwattr $C$DW$2137, DW_AT_decl_column(0x05)
$C$DW$2138 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SHDB_LINEAR_ARRAY"), DW_AT_const_value(0x01)
.dwattr $C$DW$2138, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2138, DW_AT_decl_line(0x14f)
.dwattr $C$DW$2138, DW_AT_decl_column(0x05)
$C$DW$2139 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SHDB_CURVED_ARRAY"), DW_AT_const_value(0x02)
.dwattr $C$DW$2139, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2139, DW_AT_decl_line(0x150)
.dwattr $C$DW$2139, DW_AT_decl_column(0x05)
$C$DW$2140 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SHDB_PHASED_ARRAY"), DW_AT_const_value(0x03)
.dwattr $C$DW$2140, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2140, DW_AT_decl_line(0x151)
.dwattr $C$DW$2140, DW_AT_decl_column(0x05)
$C$DW$2141 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SHDB_EOL"), DW_AT_const_value(0x04)
.dwattr $C$DW$2141, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2141, DW_AT_decl_line(0x152)
.dwattr $C$DW$2141, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1442
.dwattr $C$DW$T$1442, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1442, DW_AT_decl_line(0x14d)
.dwattr $C$DW$T$1442, DW_AT_decl_column(0x01)
$C$DW$T$1443 .dwtag DW_TAG_typedef, DW_AT_name("SpDspShdb_Type")
.dwattr $C$DW$T$1443, DW_AT_type(*$C$DW$T$1442)
.dwattr $C$DW$T$1443, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1443, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1443, DW_AT_decl_line(0x153)
.dwattr $C$DW$T$1443, DW_AT_decl_column(0x03)
$C$DW$T$1282 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1282, DW_AT_name("SpDsp_AudioParams")
.dwattr $C$DW$T$1282, DW_AT_byte_size(0x18)
$C$DW$2142 .dwtag DW_TAG_member
.dwattr $C$DW$2142, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2142, DW_AT_name("audioTestLength")
.dwattr $C$DW$2142, DW_AT_TI_symbol_name("audioTestLength")
.dwattr $C$DW$2142, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2142, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2142, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2142, DW_AT_decl_line(0x65b)
.dwattr $C$DW$2142, DW_AT_decl_column(0x02)
$C$DW$2143 .dwtag DW_TAG_member
.dwattr $C$DW$2143, DW_AT_type(*$C$DW$T$1275)
.dwattr $C$DW$2143, DW_AT_name("audioTestSignal")
.dwattr $C$DW$2143, DW_AT_TI_symbol_name("audioTestSignal")
.dwattr $C$DW$2143, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2143, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2143, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2143, DW_AT_decl_line(0x65c)
.dwattr $C$DW$2143, DW_AT_decl_column(0x02)
$C$DW$2144 .dwtag DW_TAG_member
.dwattr $C$DW$2144, DW_AT_type(*$C$DW$T$1277)
.dwattr $C$DW$2144, DW_AT_name("audioTestChannel")
.dwattr $C$DW$2144, DW_AT_TI_symbol_name("audioTestChannel")
.dwattr $C$DW$2144, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2144, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2144, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2144, DW_AT_decl_line(0x65d)
.dwattr $C$DW$2144, DW_AT_decl_column(0x02)
$C$DW$119 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$119, DW_AT_declaration
.dwattr $C$DW$119, DW_AT_TI_symbol_name("_ZN17SpDsp_AudioParamsaSERKS_")
.dwattr $C$DW$119, DW_AT_type(*$C$DW$T$1278)
.dwattr $C$DW$119, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2145 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2145, DW_AT_type(*$C$DW$T$1280)
.dwendtag $C$DW$119
.dwendtag $C$DW$T$1282
.dwattr $C$DW$T$1282, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1282, DW_AT_decl_line(0x65a)
.dwattr $C$DW$T$1282, DW_AT_decl_column(0x01)
$C$DW$T$292 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_AudioParams")
.dwattr $C$DW$T$292, DW_AT_type(*$C$DW$T$1282)
.dwattr $C$DW$T$292, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$292, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$292, DW_AT_decl_line(0x65e)
.dwattr $C$DW$T$292, DW_AT_decl_column(0x03)
$C$DW$T$1279 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1279, DW_AT_type(*$C$DW$T$1282)
$C$DW$T$1280 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1280, DW_AT_type(*$C$DW$T$1279)
.dwattr $C$DW$T$1280, DW_AT_address_class(0x20)
$C$DW$T$1278 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1278, DW_AT_type(*$C$DW$T$1282)
.dwattr $C$DW$T$1278, DW_AT_address_class(0x20)
$C$DW$T$1281 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1281, DW_AT_type(*$C$DW$T$1278)
.dwattr $C$DW$T$1281, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2146 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2146, DW_AT_type(*$C$DW$T$1280)
.dwendtag $C$DW$T$1281
$C$DW$T$1287 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1287, DW_AT_name("SpDsp_CodeVers")
.dwattr $C$DW$T$1287, DW_AT_byte_size(0x20)
$C$DW$2147 .dwtag DW_TAG_member
.dwattr $C$DW$2147, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$2147, DW_AT_name("platform")
.dwattr $C$DW$2147, DW_AT_TI_symbol_name("platform")
.dwattr $C$DW$2147, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2147, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2147, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2147, DW_AT_decl_line(0x54b)
.dwattr $C$DW$2147, DW_AT_decl_column(0x05)
$C$DW$2148 .dwtag DW_TAG_member
.dwattr $C$DW$2148, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$2148, DW_AT_name("release")
.dwattr $C$DW$2148, DW_AT_TI_symbol_name("release")
.dwattr $C$DW$2148, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2148, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2148, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2148, DW_AT_decl_line(0x54c)
.dwattr $C$DW$2148, DW_AT_decl_column(0x05)
$C$DW$2149 .dwtag DW_TAG_member
.dwattr $C$DW$2149, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$2149, DW_AT_name("major")
.dwattr $C$DW$2149, DW_AT_TI_symbol_name("major")
.dwattr $C$DW$2149, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2149, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2149, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2149, DW_AT_decl_line(0x54d)
.dwattr $C$DW$2149, DW_AT_decl_column(0x05)
$C$DW$2150 .dwtag DW_TAG_member
.dwattr $C$DW$2150, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$2150, DW_AT_name("minor")
.dwattr $C$DW$2150, DW_AT_TI_symbol_name("minor")
.dwattr $C$DW$2150, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2150, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2150, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2150, DW_AT_decl_line(0x54e)
.dwattr $C$DW$2150, DW_AT_decl_column(0x05)
$C$DW$120 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$120, DW_AT_declaration
.dwattr $C$DW$120, DW_AT_TI_symbol_name("_ZN14SpDsp_CodeVersaSERKS_")
.dwattr $C$DW$120, DW_AT_type(*$C$DW$T$1283)
.dwattr $C$DW$120, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2151 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2151, DW_AT_type(*$C$DW$T$1285)
.dwendtag $C$DW$120
.dwendtag $C$DW$T$1287
.dwattr $C$DW$T$1287, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1287, DW_AT_decl_line(0x54a)
.dwattr $C$DW$T$1287, DW_AT_decl_column(0x01)
$C$DW$T$158 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_CodeVers")
.dwattr $C$DW$T$158, DW_AT_type(*$C$DW$T$1287)
.dwattr $C$DW$T$158, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$158, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$158, DW_AT_decl_line(0x54f)
.dwattr $C$DW$T$158, DW_AT_decl_column(0x03)
$C$DW$T$1284 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1284, DW_AT_type(*$C$DW$T$1287)
$C$DW$T$1285 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1285, DW_AT_type(*$C$DW$T$1284)
.dwattr $C$DW$T$1285, DW_AT_address_class(0x20)
$C$DW$T$1283 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1283, DW_AT_type(*$C$DW$T$1287)
.dwattr $C$DW$T$1283, DW_AT_address_class(0x20)
$C$DW$T$1286 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1286, DW_AT_type(*$C$DW$T$1283)
.dwattr $C$DW$T$1286, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2152 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2152, DW_AT_type(*$C$DW$T$1285)
.dwendtag $C$DW$T$1286
$C$DW$T$1362 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1362, DW_AT_name("SpDsp_Command")
.dwattr $C$DW$T$1362, DW_AT_byte_size(0x04)
$C$DW$2153 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_COMMAND_NONE"), DW_AT_const_value(0x00)
.dwattr $C$DW$2153, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2153, DW_AT_decl_line(0x37)
.dwattr $C$DW$2153, DW_AT_decl_column(0x05)
$C$DW$2154 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_COMMAND_STOP"), DW_AT_const_value(0x01)
.dwattr $C$DW$2154, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2154, DW_AT_decl_line(0x38)
.dwattr $C$DW$2154, DW_AT_decl_column(0x05)
$C$DW$2155 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_COMMAND_START"), DW_AT_const_value(0x02)
.dwattr $C$DW$2155, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2155, DW_AT_decl_line(0x39)
.dwattr $C$DW$2155, DW_AT_decl_column(0x05)
$C$DW$2156 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_COMMAND_RT_PROCESS"), DW_AT_const_value(0x03)
.dwattr $C$DW$2156, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2156, DW_AT_decl_line(0x3a)
.dwattr $C$DW$2156, DW_AT_decl_column(0x05)
$C$DW$2157 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_COMMAND_NRT_PROCESS"), DW_AT_const_value(0x04)
.dwattr $C$DW$2157, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2157, DW_AT_decl_line(0x3b)
.dwattr $C$DW$2157, DW_AT_decl_column(0x05)
$C$DW$2158 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_COMMAND_EOL"), DW_AT_const_value(0x05)
.dwattr $C$DW$2158, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2158, DW_AT_decl_line(0x3c)
.dwattr $C$DW$2158, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1362
.dwattr $C$DW$T$1362, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1362, DW_AT_decl_line(0x36)
.dwattr $C$DW$T$1362, DW_AT_decl_column(0x01)
$C$DW$T$1363 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_Command")
.dwattr $C$DW$T$1363, DW_AT_type(*$C$DW$T$1362)
.dwattr $C$DW$T$1363, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1363, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1363, DW_AT_decl_line(0x3d)
.dwattr $C$DW$T$1363, DW_AT_decl_column(0x03)
$C$DW$T$1451 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1451, DW_AT_name("SpDsp_Core")
.dwattr $C$DW$T$1451, DW_AT_byte_size(0x04)
$C$DW$2159 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_CORE_BOL"), DW_AT_const_value(0x00)
.dwattr $C$DW$2159, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2159, DW_AT_decl_line(0x91)
.dwattr $C$DW$2159, DW_AT_decl_column(0x05)
$C$DW$2160 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_CORE_ZERO"), DW_AT_const_value(0x00)
.dwattr $C$DW$2160, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2160, DW_AT_decl_line(0x92)
.dwattr $C$DW$2160, DW_AT_decl_column(0x05)
$C$DW$2161 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_CORE_ONE"), DW_AT_const_value(0x01)
.dwattr $C$DW$2161, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2161, DW_AT_decl_line(0x93)
.dwattr $C$DW$2161, DW_AT_decl_column(0x05)
$C$DW$2162 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_CORE_TWO"), DW_AT_const_value(0x02)
.dwattr $C$DW$2162, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2162, DW_AT_decl_line(0x94)
.dwattr $C$DW$2162, DW_AT_decl_column(0x05)
$C$DW$2163 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_CORE_THREE"), DW_AT_const_value(0x03)
.dwattr $C$DW$2163, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2163, DW_AT_decl_line(0x95)
.dwattr $C$DW$2163, DW_AT_decl_column(0x05)
$C$DW$2164 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_CORE_FOUR"), DW_AT_const_value(0x04)
.dwattr $C$DW$2164, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2164, DW_AT_decl_line(0x96)
.dwattr $C$DW$2164, DW_AT_decl_column(0x05)
$C$DW$2165 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_CORE_FIVE"), DW_AT_const_value(0x05)
.dwattr $C$DW$2165, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2165, DW_AT_decl_line(0x97)
.dwattr $C$DW$2165, DW_AT_decl_column(0x05)
$C$DW$2166 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_CORE_SIX"), DW_AT_const_value(0x06)
.dwattr $C$DW$2166, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2166, DW_AT_decl_line(0x98)
.dwattr $C$DW$2166, DW_AT_decl_column(0x05)
$C$DW$2167 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_CORE_SEVEN"), DW_AT_const_value(0x07)
.dwattr $C$DW$2167, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2167, DW_AT_decl_line(0x99)
.dwattr $C$DW$2167, DW_AT_decl_column(0x05)
$C$DW$2168 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_CORE_EOL"), DW_AT_const_value(0x08)
.dwattr $C$DW$2168, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2168, DW_AT_decl_line(0x9a)
.dwattr $C$DW$2168, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1451
.dwattr $C$DW$T$1451, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1451, DW_AT_decl_line(0x90)
.dwattr $C$DW$T$1451, DW_AT_decl_column(0x01)
$C$DW$T$1452 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_Core")
.dwattr $C$DW$T$1452, DW_AT_type(*$C$DW$T$1451)
.dwattr $C$DW$T$1452, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1452, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1452, DW_AT_decl_line(0x9b)
.dwattr $C$DW$T$1452, DW_AT_decl_column(0x03)
$C$DW$T$1296 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1296, DW_AT_name("SpDsp_DebugInfo")
.dwattr $C$DW$T$1296, DW_AT_byte_size(0x1a90)
$C$DW$2169 .dwtag DW_TAG_member
.dwattr $C$DW$2169, DW_AT_type(*$C$DW$T$1288)
.dwattr $C$DW$2169, DW_AT_name("maxCalcInFrameRate")
.dwattr $C$DW$2169, DW_AT_TI_symbol_name("maxCalcInFrameRate")
.dwattr $C$DW$2169, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2169, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2169, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2169, DW_AT_decl_line(0x5fc)
.dwattr $C$DW$2169, DW_AT_decl_column(0x05)
$C$DW$2170 .dwtag DW_TAG_member
.dwattr $C$DW$2170, DW_AT_type(*$C$DW$T$1288)
.dwattr $C$DW$2170, DW_AT_name("avgCalcInFrameRate")
.dwattr $C$DW$2170, DW_AT_TI_symbol_name("avgCalcInFrameRate")
.dwattr $C$DW$2170, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2170, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2170, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2170, DW_AT_decl_line(0x5ff)
.dwattr $C$DW$2170, DW_AT_decl_column(0x05)
$C$DW$2171 .dwtag DW_TAG_member
.dwattr $C$DW$2171, DW_AT_type(*$C$DW$T$1288)
.dwattr $C$DW$2171, DW_AT_name("targetOutputFrameRate")
.dwattr $C$DW$2171, DW_AT_TI_symbol_name("targetOutputFrameRate")
.dwattr $C$DW$2171, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2171, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2171, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2171, DW_AT_decl_line(0x602)
.dwattr $C$DW$2171, DW_AT_decl_column(0x05)
$C$DW$2172 .dwtag DW_TAG_member
.dwattr $C$DW$2172, DW_AT_type(*$C$DW$T$1288)
.dwattr $C$DW$2172, DW_AT_name("maxCalcOutFrameRate")
.dwattr $C$DW$2172, DW_AT_TI_symbol_name("maxCalcOutFrameRate")
.dwattr $C$DW$2172, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$2172, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2172, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2172, DW_AT_decl_line(0x605)
.dwattr $C$DW$2172, DW_AT_decl_column(0x05)
$C$DW$2173 .dwtag DW_TAG_member
.dwattr $C$DW$2173, DW_AT_type(*$C$DW$T$1288)
.dwattr $C$DW$2173, DW_AT_name("avgCalcOutFrameRate")
.dwattr $C$DW$2173, DW_AT_TI_symbol_name("avgCalcOutFrameRate")
.dwattr $C$DW$2173, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$2173, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2173, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2173, DW_AT_decl_line(0x608)
.dwattr $C$DW$2173, DW_AT_decl_column(0x05)
$C$DW$2174 .dwtag DW_TAG_member
.dwattr $C$DW$2174, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2174, DW_AT_name("logBufferHandle")
.dwattr $C$DW$2174, DW_AT_TI_symbol_name("logBufferHandle")
.dwattr $C$DW$2174, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$2174, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2174, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2174, DW_AT_decl_line(0x60c)
.dwattr $C$DW$2174, DW_AT_decl_column(0x05)
$C$DW$2175 .dwtag DW_TAG_member
.dwattr $C$DW$2175, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2175, DW_AT_name("logBuffer0Ptr")
.dwattr $C$DW$2175, DW_AT_TI_symbol_name("logBuffer0Ptr")
.dwattr $C$DW$2175, DW_AT_data_member_location[DW_OP_plus_uconst 0x80]
.dwattr $C$DW$2175, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2175, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2175, DW_AT_decl_line(0x60d)
.dwattr $C$DW$2175, DW_AT_decl_column(0x05)
$C$DW$2176 .dwtag DW_TAG_member
.dwattr $C$DW$2176, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2176, DW_AT_name("logBuffer1Ptr")
.dwattr $C$DW$2176, DW_AT_TI_symbol_name("logBuffer1Ptr")
.dwattr $C$DW$2176, DW_AT_data_member_location[DW_OP_plus_uconst 0x88]
.dwattr $C$DW$2176, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2176, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2176, DW_AT_decl_line(0x60e)
.dwattr $C$DW$2176, DW_AT_decl_column(0x05)
$C$DW$2177 .dwtag DW_TAG_member
.dwattr $C$DW$2177, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2177, DW_AT_name("logBuffer2Ptr")
.dwattr $C$DW$2177, DW_AT_TI_symbol_name("logBuffer2Ptr")
.dwattr $C$DW$2177, DW_AT_data_member_location[DW_OP_plus_uconst 0x90]
.dwattr $C$DW$2177, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2177, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2177, DW_AT_decl_line(0x60f)
.dwattr $C$DW$2177, DW_AT_decl_column(0x05)
$C$DW$2178 .dwtag DW_TAG_member
.dwattr $C$DW$2178, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2178, DW_AT_name("logBuffer3Ptr")
.dwattr $C$DW$2178, DW_AT_TI_symbol_name("logBuffer3Ptr")
.dwattr $C$DW$2178, DW_AT_data_member_location[DW_OP_plus_uconst 0x98]
.dwattr $C$DW$2178, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2178, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2178, DW_AT_decl_line(0x610)
.dwattr $C$DW$2178, DW_AT_decl_column(0x05)
$C$DW$2179 .dwtag DW_TAG_member
.dwattr $C$DW$2179, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2179, DW_AT_name("logBuffer4Ptr")
.dwattr $C$DW$2179, DW_AT_TI_symbol_name("logBuffer4Ptr")
.dwattr $C$DW$2179, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0]
.dwattr $C$DW$2179, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2179, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2179, DW_AT_decl_line(0x611)
.dwattr $C$DW$2179, DW_AT_decl_column(0x05)
$C$DW$2180 .dwtag DW_TAG_member
.dwattr $C$DW$2180, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2180, DW_AT_name("abortPtr")
.dwattr $C$DW$2180, DW_AT_TI_symbol_name("abortPtr")
.dwattr $C$DW$2180, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8]
.dwattr $C$DW$2180, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2180, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2180, DW_AT_decl_line(0x613)
.dwattr $C$DW$2180, DW_AT_decl_column(0x05)
$C$DW$2181 .dwtag DW_TAG_member
.dwattr $C$DW$2181, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2181, DW_AT_name("pDspLoadInfo")
.dwattr $C$DW$2181, DW_AT_TI_symbol_name("pDspLoadInfo")
.dwattr $C$DW$2181, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0]
.dwattr $C$DW$2181, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2181, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2181, DW_AT_decl_line(0x615)
.dwattr $C$DW$2181, DW_AT_decl_column(0x05)
$C$DW$2182 .dwtag DW_TAG_member
.dwattr $C$DW$2182, DW_AT_type(*$C$DW$T$1289)
.dwattr $C$DW$2182, DW_AT_name("traceBuf")
.dwattr $C$DW$2182, DW_AT_TI_symbol_name("traceBuf")
.dwattr $C$DW$2182, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8]
.dwattr $C$DW$2182, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2182, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2182, DW_AT_decl_line(0x618)
.dwattr $C$DW$2182, DW_AT_decl_column(0x05)
$C$DW$2183 .dwtag DW_TAG_member
.dwattr $C$DW$2183, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2183, DW_AT_name("universalTestInterfaceAddr")
.dwattr $C$DW$2183, DW_AT_TI_symbol_name("universalTestInterfaceAddr")
.dwattr $C$DW$2183, DW_AT_data_member_location[DW_OP_plus_uconst 0x1940]
.dwattr $C$DW$2183, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2183, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2183, DW_AT_decl_line(0x61b)
.dwattr $C$DW$2183, DW_AT_decl_column(0x05)
$C$DW$2184 .dwtag DW_TAG_member
.dwattr $C$DW$2184, DW_AT_type(*$C$DW$T$1290)
.dwattr $C$DW$2184, DW_AT_name("debugInfoOptions")
.dwattr $C$DW$2184, DW_AT_TI_symbol_name("debugInfoOptions")
.dwattr $C$DW$2184, DW_AT_data_member_location[DW_OP_plus_uconst 0x1948]
.dwattr $C$DW$2184, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2184, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2184, DW_AT_decl_line(0x61d)
.dwattr $C$DW$2184, DW_AT_decl_column(0x05)
$C$DW$2185 .dwtag DW_TAG_member
.dwattr $C$DW$2185, DW_AT_type(*$C$DW$T$136)
.dwattr $C$DW$2185, DW_AT_name("playListNotSynced")
.dwattr $C$DW$2185, DW_AT_TI_symbol_name("playListNotSynced")
.dwattr $C$DW$2185, DW_AT_data_member_location[DW_OP_plus_uconst 0x1a10]
.dwattr $C$DW$2185, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2185, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2185, DW_AT_decl_line(0x61e)
.dwattr $C$DW$2185, DW_AT_decl_column(0x05)
$C$DW$2186 .dwtag DW_TAG_member
.dwattr $C$DW$2186, DW_AT_type(*$C$DW$T$1291)
.dwattr $C$DW$2186, DW_AT_name("reserved")
.dwattr $C$DW$2186, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2186, DW_AT_data_member_location[DW_OP_plus_uconst 0x1a18]
.dwattr $C$DW$2186, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2186, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2186, DW_AT_decl_line(0x61f)
.dwattr $C$DW$2186, DW_AT_decl_column(0x05)
$C$DW$121 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$121, DW_AT_declaration
.dwattr $C$DW$121, DW_AT_TI_symbol_name("_ZN15SpDsp_DebugInfoaSERKS_")
.dwattr $C$DW$121, DW_AT_type(*$C$DW$T$1292)
.dwattr $C$DW$121, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2187 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2187, DW_AT_type(*$C$DW$T$1294)
.dwendtag $C$DW$121
.dwendtag $C$DW$T$1296
.dwattr $C$DW$T$1296, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1296, DW_AT_decl_line(0x5fa)
.dwattr $C$DW$T$1296, DW_AT_decl_column(0x01)
$C$DW$T$1293 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1293, DW_AT_type(*$C$DW$T$1296)
$C$DW$T$1294 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1294, DW_AT_type(*$C$DW$T$1293)
.dwattr $C$DW$T$1294, DW_AT_address_class(0x20)
$C$DW$T$1373 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_DebugInfo")
.dwattr $C$DW$T$1373, DW_AT_type(*$C$DW$T$1296)
.dwattr $C$DW$T$1373, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1373, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1373, DW_AT_decl_line(0x621)
.dwattr $C$DW$T$1373, DW_AT_decl_column(0x03)
$C$DW$T$1292 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1292, DW_AT_type(*$C$DW$T$1296)
.dwattr $C$DW$T$1292, DW_AT_address_class(0x20)
$C$DW$T$1295 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1295, DW_AT_type(*$C$DW$T$1292)
.dwattr $C$DW$T$1295, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2188 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2188, DW_AT_type(*$C$DW$T$1294)
.dwendtag $C$DW$T$1295
$C$DW$T$1301 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1301, DW_AT_name("SpDsp_DebugInfoOptions")
.dwattr $C$DW$T$1301, DW_AT_byte_size(0xc8)
$C$DW$2189 .dwtag DW_TAG_member
.dwattr $C$DW$2189, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2189, DW_AT_name("frameNumberRenderOn")
.dwattr $C$DW$2189, DW_AT_TI_symbol_name("frameNumberRenderOn")
.dwattr $C$DW$2189, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2189, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2189, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2189, DW_AT_decl_line(0x5e5)
.dwattr $C$DW$2189, DW_AT_decl_column(0x02)
$C$DW$2190 .dwtag DW_TAG_member
.dwattr $C$DW$2190, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2190, DW_AT_name("dopplerSequenceMarkersOn")
.dwattr $C$DW$2190, DW_AT_TI_symbol_name("dopplerSequenceMarkersOn")
.dwattr $C$DW$2190, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2190, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2190, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2190, DW_AT_decl_line(0x5e6)
.dwattr $C$DW$2190, DW_AT_decl_column(0x02)
$C$DW$2191 .dwtag DW_TAG_member
.dwattr $C$DW$2191, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2191, DW_AT_name("dopplerInsertSawtoothForPeakMean")
.dwattr $C$DW$2191, DW_AT_TI_symbol_name("dopplerInsertSawtoothForPeakMean")
.dwattr $C$DW$2191, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2191, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2191, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2191, DW_AT_decl_line(0x5e7)
.dwattr $C$DW$2191, DW_AT_decl_column(0x02)
$C$DW$2192 .dwtag DW_TAG_member
.dwattr $C$DW$2192, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2192, DW_AT_name("insertFrameRateIn2dFrame")
.dwattr $C$DW$2192, DW_AT_TI_symbol_name("insertFrameRateIn2dFrame")
.dwattr $C$DW$2192, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2192, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2192, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2192, DW_AT_decl_line(0x5e8)
.dwattr $C$DW$2192, DW_AT_decl_column(0x02)
$C$DW$2193 .dwtag DW_TAG_member
.dwattr $C$DW$2193, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2193, DW_AT_name("drawZeroHzDopplerLine")
.dwattr $C$DW$2193, DW_AT_TI_symbol_name("drawZeroHzDopplerLine")
.dwattr $C$DW$2193, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2193, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2193, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2193, DW_AT_decl_line(0x5e9)
.dwattr $C$DW$2193, DW_AT_decl_column(0x02)
$C$DW$2194 .dwtag DW_TAG_member
.dwattr $C$DW$2194, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2194, DW_AT_name("drawEcgRmarkerSymbol")
.dwattr $C$DW$2194, DW_AT_TI_symbol_name("drawEcgRmarkerSymbol")
.dwattr $C$DW$2194, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2194, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2194, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2194, DW_AT_decl_line(0x5ea)
.dwattr $C$DW$2194, DW_AT_decl_column(0x02)
$C$DW$2195 .dwtag DW_TAG_member
.dwattr $C$DW$2195, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2195, DW_AT_name("useExternalLineDrawForEcg")
.dwattr $C$DW$2195, DW_AT_TI_symbol_name("useExternalLineDrawForEcg")
.dwattr $C$DW$2195, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2195, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2195, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2195, DW_AT_decl_line(0x5eb)
.dwattr $C$DW$2195, DW_AT_decl_column(0x02)
$C$DW$2196 .dwtag DW_TAG_member
.dwattr $C$DW$2196, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2196, DW_AT_name("maxOutputFrameRate")
.dwattr $C$DW$2196, DW_AT_TI_symbol_name("maxOutputFrameRate")
.dwattr $C$DW$2196, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$2196, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2196, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2196, DW_AT_decl_line(0x5ec)
.dwattr $C$DW$2196, DW_AT_decl_column(0x05)
$C$DW$2197 .dwtag DW_TAG_member
.dwattr $C$DW$2197, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2197, DW_AT_name("dspColsPerUpdate")
.dwattr $C$DW$2197, DW_AT_TI_symbol_name("dspColsPerUpdate")
.dwattr $C$DW$2197, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$2197, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2197, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2197, DW_AT_decl_line(0x5ed)
.dwattr $C$DW$2197, DW_AT_decl_column(0x05)
$C$DW$2198 .dwtag DW_TAG_member
.dwattr $C$DW$2198, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2198, DW_AT_name("reserved")
.dwattr $C$DW$2198, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2198, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$2198, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2198, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2198, DW_AT_decl_line(0x5ee)
.dwattr $C$DW$2198, DW_AT_decl_column(0x05)
$C$DW$122 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$122, DW_AT_declaration
.dwattr $C$DW$122, DW_AT_TI_symbol_name("_ZN22SpDsp_DebugInfoOptionsaSERKS_")
.dwattr $C$DW$122, DW_AT_type(*$C$DW$T$1297)
.dwattr $C$DW$122, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2199 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2199, DW_AT_type(*$C$DW$T$1299)
.dwendtag $C$DW$122
.dwendtag $C$DW$T$1301
.dwattr $C$DW$T$1301, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1301, DW_AT_decl_line(0x5e3)
.dwattr $C$DW$T$1301, DW_AT_decl_column(0x01)
$C$DW$T$1290 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_DebugInfoOptions")
.dwattr $C$DW$T$1290, DW_AT_type(*$C$DW$T$1301)
.dwattr $C$DW$T$1290, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1290, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1290, DW_AT_decl_line(0x5ef)
.dwattr $C$DW$T$1290, DW_AT_decl_column(0x03)
$C$DW$T$1298 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1298, DW_AT_type(*$C$DW$T$1301)
$C$DW$T$1299 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1299, DW_AT_type(*$C$DW$T$1298)
.dwattr $C$DW$T$1299, DW_AT_address_class(0x20)
$C$DW$T$1297 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1297, DW_AT_type(*$C$DW$T$1301)
.dwattr $C$DW$T$1297, DW_AT_address_class(0x20)
$C$DW$T$1300 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1300, DW_AT_type(*$C$DW$T$1297)
.dwattr $C$DW$T$1300, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2200 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2200, DW_AT_type(*$C$DW$T$1299)
.dwendtag $C$DW$T$1300
$C$DW$T$1307 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1307, DW_AT_name("SpDsp_DiagMemParams")
.dwattr $C$DW$T$1307, DW_AT_byte_size(0x18)
$C$DW$2201 .dwtag DW_TAG_member
.dwattr $C$DW$2201, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2201, DW_AT_name("ddrMemFailAddress")
.dwattr $C$DW$2201, DW_AT_TI_symbol_name("ddrMemFailAddress")
.dwattr $C$DW$2201, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2201, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2201, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2201, DW_AT_decl_line(0x654)
.dwattr $C$DW$2201, DW_AT_decl_column(0x02)
$C$DW$2202 .dwtag DW_TAG_member
.dwattr $C$DW$2202, DW_AT_type(*$C$DW$T$1302)
.dwattr $C$DW$2202, DW_AT_name("ddrMemExpectedVal")
.dwattr $C$DW$2202, DW_AT_TI_symbol_name("ddrMemExpectedVal")
.dwattr $C$DW$2202, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2202, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2202, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2202, DW_AT_decl_line(0x655)
.dwattr $C$DW$2202, DW_AT_decl_column(0x02)
$C$DW$2203 .dwtag DW_TAG_member
.dwattr $C$DW$2203, DW_AT_type(*$C$DW$T$1302)
.dwattr $C$DW$2203, DW_AT_name("ddrMemActualVal")
.dwattr $C$DW$2203, DW_AT_TI_symbol_name("ddrMemActualVal")
.dwattr $C$DW$2203, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2203, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2203, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2203, DW_AT_decl_line(0x656)
.dwattr $C$DW$2203, DW_AT_decl_column(0x02)
$C$DW$123 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$123, DW_AT_declaration
.dwattr $C$DW$123, DW_AT_TI_symbol_name("_ZN19SpDsp_DiagMemParamsaSERKS_")
.dwattr $C$DW$123, DW_AT_type(*$C$DW$T$1303)
.dwattr $C$DW$123, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2204 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2204, DW_AT_type(*$C$DW$T$1305)
.dwendtag $C$DW$123
.dwendtag $C$DW$T$1307
.dwattr $C$DW$T$1307, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1307, DW_AT_decl_line(0x653)
.dwattr $C$DW$T$1307, DW_AT_decl_column(0x01)
$C$DW$T$291 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_DiagMemParams")
.dwattr $C$DW$T$291, DW_AT_type(*$C$DW$T$1307)
.dwattr $C$DW$T$291, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$291, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$291, DW_AT_decl_line(0x657)
.dwattr $C$DW$T$291, DW_AT_decl_column(0x03)
$C$DW$T$1304 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1304, DW_AT_type(*$C$DW$T$1307)
$C$DW$T$1305 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1305, DW_AT_type(*$C$DW$T$1304)
.dwattr $C$DW$T$1305, DW_AT_address_class(0x20)
$C$DW$T$1303 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1303, DW_AT_type(*$C$DW$T$1307)
.dwattr $C$DW$T$1303, DW_AT_address_class(0x20)
$C$DW$T$1306 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1306, DW_AT_type(*$C$DW$T$1303)
.dwattr $C$DW$T$1306, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2205 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2205, DW_AT_type(*$C$DW$T$1305)
.dwendtag $C$DW$T$1306
$C$DW$T$1276 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1276, DW_AT_name("SpDsp_DiagsAudioChannel")
.dwattr $C$DW$T$1276, DW_AT_byte_size(0x04)
$C$DW$2206 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_AUDIO_STEREO"), DW_AT_const_value(0x00)
.dwattr $C$DW$2206, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2206, DW_AT_decl_line(0x19b)
.dwattr $C$DW$2206, DW_AT_decl_column(0x05)
$C$DW$2207 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_AUDIO_LEFT"), DW_AT_const_value(0x01)
.dwattr $C$DW$2207, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2207, DW_AT_decl_line(0x19c)
.dwattr $C$DW$2207, DW_AT_decl_column(0x05)
$C$DW$2208 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_AUDIO_RIGHT"), DW_AT_const_value(0x02)
.dwattr $C$DW$2208, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2208, DW_AT_decl_line(0x19d)
.dwattr $C$DW$2208, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1276
.dwattr $C$DW$T$1276, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1276, DW_AT_decl_line(0x19a)
.dwattr $C$DW$T$1276, DW_AT_decl_column(0x01)
$C$DW$T$1277 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_DiagsAudioChannel")
.dwattr $C$DW$T$1277, DW_AT_type(*$C$DW$T$1276)
.dwattr $C$DW$T$1277, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1277, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1277, DW_AT_decl_line(0x19e)
.dwattr $C$DW$T$1277, DW_AT_decl_column(0x03)
$C$DW$T$1274 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1274, DW_AT_name("SpDsp_DiagsAudioSignal")
.dwattr $C$DW$T$1274, DW_AT_byte_size(0x04)
$C$DW$2209 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_AUDIO_CHIRP"), DW_AT_const_value(0x00)
.dwattr $C$DW$2209, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2209, DW_AT_decl_line(0x194)
.dwattr $C$DW$2209, DW_AT_decl_column(0x05)
$C$DW$2210 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_AUDIO_NOISE"), DW_AT_const_value(0x01)
.dwattr $C$DW$2210, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2210, DW_AT_decl_line(0x195)
.dwattr $C$DW$2210, DW_AT_decl_column(0x05)
$C$DW$2211 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_AUDIO_SQUARE"), DW_AT_const_value(0x02)
.dwattr $C$DW$2211, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2211, DW_AT_decl_line(0x196)
.dwattr $C$DW$2211, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1274
.dwattr $C$DW$T$1274, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1274, DW_AT_decl_line(0x193)
.dwattr $C$DW$T$1274, DW_AT_decl_column(0x01)
$C$DW$T$1275 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_DiagsAudioSignal")
.dwattr $C$DW$T$1275, DW_AT_type(*$C$DW$T$1274)
.dwattr $C$DW$T$1275, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1275, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1275, DW_AT_decl_line(0x197)
.dwattr $C$DW$T$1275, DW_AT_decl_column(0x03)
$C$DW$T$1316 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1316, DW_AT_name("SpDsp_DiagsResult")
.dwattr $C$DW$T$1316, DW_AT_byte_size(0xa8)
$C$DW$2212 .dwtag DW_TAG_member
.dwattr $C$DW$2212, DW_AT_type(*$C$DW$T$1309)
.dwattr $C$DW$2212, DW_AT_name("testName")
.dwattr $C$DW$2212, DW_AT_TI_symbol_name("testName")
.dwattr $C$DW$2212, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2212, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2212, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2212, DW_AT_decl_line(0x662)
.dwattr $C$DW$2212, DW_AT_decl_column(0x05)
$C$DW$2213 .dwtag DW_TAG_member
.dwattr $C$DW$2213, DW_AT_type(*$C$DW$T$1311)
.dwattr $C$DW$2213, DW_AT_name("testStatus")
.dwattr $C$DW$2213, DW_AT_TI_symbol_name("testStatus")
.dwattr $C$DW$2213, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2213, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2213, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2213, DW_AT_decl_line(0x663)
.dwattr $C$DW$2213, DW_AT_decl_column(0x05)
$C$DW$2214 .dwtag DW_TAG_member
.dwattr $C$DW$2214, DW_AT_type(*$C$DW$T$297)
.dwattr $C$DW$2214, DW_AT_name("DiagsTestOptions")
.dwattr $C$DW$2214, DW_AT_TI_symbol_name("DiagsTestOptions")
.dwattr $C$DW$2214, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2214, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2214, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2214, DW_AT_decl_line(0x66a)
.dwattr $C$DW$2214, DW_AT_decl_column(0x04)
$C$DW$2215 .dwtag DW_TAG_member
.dwattr $C$DW$2215, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2215, DW_AT_name("reserved")
.dwattr $C$DW$2215, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2215, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2215, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2215, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2215, DW_AT_decl_line(0x66c)
.dwattr $C$DW$2215, DW_AT_decl_column(0x05)
$C$DW$124 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$124, DW_AT_declaration
.dwattr $C$DW$124, DW_AT_TI_symbol_name("_ZN17SpDsp_DiagsResultaSERKS_")
.dwattr $C$DW$124, DW_AT_type(*$C$DW$T$1312)
.dwattr $C$DW$124, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2216 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2216, DW_AT_type(*$C$DW$T$1314)
.dwendtag $C$DW$124
.dwendtag $C$DW$T$1316
.dwattr $C$DW$T$1316, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1316, DW_AT_decl_line(0x661)
.dwattr $C$DW$T$1316, DW_AT_decl_column(0x01)
$C$DW$T$1313 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1313, DW_AT_type(*$C$DW$T$1316)
$C$DW$T$1314 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1314, DW_AT_type(*$C$DW$T$1313)
.dwattr $C$DW$T$1314, DW_AT_address_class(0x20)
$C$DW$T$1375 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_DiagsResult")
.dwattr $C$DW$T$1375, DW_AT_type(*$C$DW$T$1316)
.dwattr $C$DW$T$1375, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1375, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1375, DW_AT_decl_line(0x66d)
.dwattr $C$DW$T$1375, DW_AT_decl_column(0x03)
$C$DW$T$1312 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1312, DW_AT_type(*$C$DW$T$1316)
.dwattr $C$DW$T$1312, DW_AT_address_class(0x20)
$C$DW$T$1315 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1315, DW_AT_type(*$C$DW$T$1312)
.dwattr $C$DW$T$1315, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2217 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2217, DW_AT_type(*$C$DW$T$1314)
.dwendtag $C$DW$T$1315
$C$DW$T$1310 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1310, DW_AT_name("SpDsp_DiagsStatus")
.dwattr $C$DW$T$1310, DW_AT_byte_size(0x04)
$C$DW$2218 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_DIAGS_NOT_STARTED"), DW_AT_const_value(0x00)
.dwattr $C$DW$2218, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2218, DW_AT_decl_line(0x184)
.dwattr $C$DW$2218, DW_AT_decl_column(0x02)
$C$DW$2219 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_DIAGS_IN_PROGRESS"), DW_AT_const_value(0x01)
.dwattr $C$DW$2219, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2219, DW_AT_decl_line(0x185)
.dwattr $C$DW$2219, DW_AT_decl_column(0x02)
$C$DW$2220 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_DIAGS_PASSED"), DW_AT_const_value(0x02)
.dwattr $C$DW$2220, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2220, DW_AT_decl_line(0x186)
.dwattr $C$DW$2220, DW_AT_decl_column(0x02)
$C$DW$2221 .dwtag DW_TAG_enumerator, DW_AT_name("SPDS_DIAGS_FAILED"), DW_AT_const_value(0x03)
.dwattr $C$DW$2221, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2221, DW_AT_decl_line(0x187)
.dwattr $C$DW$2221, DW_AT_decl_column(0x02)
.dwendtag $C$DW$T$1310
.dwattr $C$DW$T$1310, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1310, DW_AT_decl_line(0x183)
.dwattr $C$DW$T$1310, DW_AT_decl_column(0x01)
$C$DW$T$1311 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_DiagsStatus")
.dwattr $C$DW$T$1311, DW_AT_type(*$C$DW$T$1310)
.dwattr $C$DW$T$1311, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1311, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1311, DW_AT_decl_line(0x188)
.dwattr $C$DW$T$1311, DW_AT_decl_column(0x03)
$C$DW$T$1308 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1308, DW_AT_name("SpDsp_DiagsTestName")
.dwattr $C$DW$T$1308, DW_AT_byte_size(0x04)
$C$DW$2222 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_DIAGS_NONE"), DW_AT_const_value(0x00)
.dwattr $C$DW$2222, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2222, DW_AT_decl_line(0x18d)
.dwattr $C$DW$2222, DW_AT_decl_column(0x02)
$C$DW$2223 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_DIAGS_DDR"), DW_AT_const_value(0x01)
.dwattr $C$DW$2223, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2223, DW_AT_decl_line(0x18e)
.dwattr $C$DW$2223, DW_AT_decl_column(0x02)
$C$DW$2224 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_DIAGS_AUDIO"), DW_AT_const_value(0x02)
.dwattr $C$DW$2224, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2224, DW_AT_decl_line(0x18f)
.dwattr $C$DW$2224, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1308
.dwattr $C$DW$T$1308, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1308, DW_AT_decl_line(0x18c)
.dwattr $C$DW$T$1308, DW_AT_decl_column(0x01)
$C$DW$T$1309 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_DiagsTestName")
.dwattr $C$DW$T$1309, DW_AT_type(*$C$DW$T$1308)
.dwattr $C$DW$T$1309, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1309, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1309, DW_AT_decl_line(0x190)
.dwattr $C$DW$T$1309, DW_AT_decl_column(0x03)
$C$DW$T$579 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$579, DW_AT_name("SpDsp_Ecg_SubMode")
.dwattr $C$DW$T$579, DW_AT_byte_size(0x04)
$C$DW$2225 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_ECG_FREE_RUN"), DW_AT_const_value(0x00)
.dwattr $C$DW$2225, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2225, DW_AT_decl_line(0xe1)
.dwattr $C$DW$2225, DW_AT_decl_column(0x05)
$C$DW$2226 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_ECG_TRIGGER"), DW_AT_const_value(0x01)
.dwattr $C$DW$2226, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2226, DW_AT_decl_line(0xe2)
.dwattr $C$DW$2226, DW_AT_decl_column(0x05)
$C$DW$2227 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_ECG_EOL"), DW_AT_const_value(0x02)
.dwattr $C$DW$2227, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2227, DW_AT_decl_line(0xe3)
.dwattr $C$DW$2227, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$579
.dwattr $C$DW$T$579, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$579, DW_AT_decl_line(0xe0)
.dwattr $C$DW$T$579, DW_AT_decl_column(0x01)
$C$DW$T$580 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_Ecg_SubMode")
.dwattr $C$DW$T$580, DW_AT_type(*$C$DW$T$579)
.dwattr $C$DW$T$580, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$580, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$580, DW_AT_decl_line(0xe4)
.dwattr $C$DW$T$580, DW_AT_decl_column(0x03)
$C$DW$T$1322 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$1322, DW_AT_name("SpDsp_ErrHist")
.dwattr $C$DW$T$1322, DW_AT_byte_size(0x04)
$C$DW$2228 .dwtag DW_TAG_member
.dwattr $C$DW$2228, DW_AT_type(*$C$DW$T$1317)
.dwattr $C$DW$2228, DW_AT_name("mask")
.dwattr $C$DW$2228, DW_AT_TI_symbol_name("mask")
.dwattr $C$DW$2228, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2228, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2228, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2228, DW_AT_decl_line(0x59f)
.dwattr $C$DW$2228, DW_AT_decl_column(0x1d)
$C$DW$2229 .dwtag DW_TAG_member
.dwattr $C$DW$2229, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2229, DW_AT_name("word")
.dwattr $C$DW$2229, DW_AT_TI_symbol_name("word")
.dwattr $C$DW$2229, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2229, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2229, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2229, DW_AT_decl_line(0x5a0)
.dwattr $C$DW$2229, DW_AT_decl_column(0x1d)
$C$DW$125 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$125, DW_AT_declaration
.dwattr $C$DW$125, DW_AT_TI_symbol_name("_ZN13SpDsp_ErrHistaSERKS_")
.dwattr $C$DW$125, DW_AT_type(*$C$DW$T$1318)
.dwattr $C$DW$125, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2230 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2230, DW_AT_type(*$C$DW$T$1320)
.dwendtag $C$DW$125
.dwendtag $C$DW$T$1322
.dwattr $C$DW$T$1322, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1322, DW_AT_decl_line(0x59e)
.dwattr $C$DW$T$1322, DW_AT_decl_column(0x01)
$C$DW$T$1319 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1319, DW_AT_type(*$C$DW$T$1322)
$C$DW$T$1320 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1320, DW_AT_type(*$C$DW$T$1319)
.dwattr $C$DW$T$1320, DW_AT_address_class(0x20)
$C$DW$T$1331 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_ErrHist")
.dwattr $C$DW$T$1331, DW_AT_type(*$C$DW$T$1322)
.dwattr $C$DW$T$1331, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1331, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1331, DW_AT_decl_line(0x5a1)
.dwattr $C$DW$T$1331, DW_AT_decl_column(0x03)
$C$DW$T$1318 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1318, DW_AT_type(*$C$DW$T$1322)
.dwattr $C$DW$T$1318, DW_AT_address_class(0x20)
$C$DW$T$1321 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1321, DW_AT_type(*$C$DW$T$1318)
.dwattr $C$DW$T$1321, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2231 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2231, DW_AT_type(*$C$DW$T$1320)
.dwendtag $C$DW$T$1321
$C$DW$T$1327 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1327, DW_AT_name("SpDsp_ErrHistBitMask")
.dwattr $C$DW$T$1327, DW_AT_byte_size(0x04)
$C$DW$2232 .dwtag DW_TAG_member
.dwattr $C$DW$2232, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2232, DW_AT_name("dspState")
.dwattr $C$DW$2232, DW_AT_TI_symbol_name("dspState")
.dwattr $C$DW$2232, DW_AT_bit_offset(0x18), DW_AT_bit_size(0x08)
.dwattr $C$DW$2232, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2232, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2232, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2232, DW_AT_decl_line(0x597)
.dwattr $C$DW$2232, DW_AT_decl_column(0x09)
$C$DW$2233 .dwtag DW_TAG_member
.dwattr $C$DW$2233, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2233, DW_AT_name("frameworkState")
.dwattr $C$DW$2233, DW_AT_TI_symbol_name("frameworkState")
.dwattr $C$DW$2233, DW_AT_bit_offset(0x10), DW_AT_bit_size(0x08)
.dwattr $C$DW$2233, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2233, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2233, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2233, DW_AT_decl_line(0x598)
.dwattr $C$DW$2233, DW_AT_decl_column(0x09)
$C$DW$2234 .dwtag DW_TAG_member
.dwattr $C$DW$2234, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2234, DW_AT_name("mainCtlrState")
.dwattr $C$DW$2234, DW_AT_TI_symbol_name("mainCtlrState")
.dwattr $C$DW$2234, DW_AT_bit_offset(0x08), DW_AT_bit_size(0x08)
.dwattr $C$DW$2234, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2234, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2234, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2234, DW_AT_decl_line(0x599)
.dwattr $C$DW$2234, DW_AT_decl_column(0x09)
$C$DW$2235 .dwtag DW_TAG_member
.dwattr $C$DW$2235, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2235, DW_AT_name("mainCtlrEvt")
.dwattr $C$DW$2235, DW_AT_TI_symbol_name("mainCtlrEvt")
.dwattr $C$DW$2235, DW_AT_bit_offset(0x00), DW_AT_bit_size(0x08)
.dwattr $C$DW$2235, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2235, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2235, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2235, DW_AT_decl_line(0x59a)
.dwattr $C$DW$2235, DW_AT_decl_column(0x09)
$C$DW$126 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$126, DW_AT_declaration
.dwattr $C$DW$126, DW_AT_TI_symbol_name("_ZN20SpDsp_ErrHistBitMaskaSERKS_")
.dwattr $C$DW$126, DW_AT_type(*$C$DW$T$1323)
.dwattr $C$DW$126, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2236 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2236, DW_AT_type(*$C$DW$T$1325)
.dwendtag $C$DW$126
.dwendtag $C$DW$T$1327
.dwattr $C$DW$T$1327, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1327, DW_AT_decl_line(0x596)
.dwattr $C$DW$T$1327, DW_AT_decl_column(0x01)
$C$DW$T$1317 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_ErrHistBitMask")
.dwattr $C$DW$T$1317, DW_AT_type(*$C$DW$T$1327)
.dwattr $C$DW$T$1317, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1317, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1317, DW_AT_decl_line(0x59b)
.dwattr $C$DW$T$1317, DW_AT_decl_column(0x03)
$C$DW$T$1324 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1324, DW_AT_type(*$C$DW$T$1327)
$C$DW$T$1325 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1325, DW_AT_type(*$C$DW$T$1324)
.dwattr $C$DW$T$1325, DW_AT_address_class(0x20)
$C$DW$T$1323 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1323, DW_AT_type(*$C$DW$T$1327)
.dwattr $C$DW$T$1323, DW_AT_address_class(0x20)
$C$DW$T$1326 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1326, DW_AT_type(*$C$DW$T$1323)
.dwattr $C$DW$T$1326, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2237 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2237, DW_AT_type(*$C$DW$T$1325)
.dwendtag $C$DW$T$1326
$C$DW$T$1337 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1337, DW_AT_name("SpDsp_ErrorInfo")
.dwattr $C$DW$T$1337, DW_AT_byte_size(0x1a8)
$C$DW$2238 .dwtag DW_TAG_member
.dwattr $C$DW$2238, DW_AT_type(*$C$DW$T$1329)
.dwattr $C$DW$2238, DW_AT_name("fileName")
.dwattr $C$DW$2238, DW_AT_TI_symbol_name("fileName")
.dwattr $C$DW$2238, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2238, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2238, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2238, DW_AT_decl_line(0x5a7)
.dwattr $C$DW$2238, DW_AT_decl_column(0x05)
$C$DW$2239 .dwtag DW_TAG_member
.dwattr $C$DW$2239, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2239, DW_AT_name("lineNum")
.dwattr $C$DW$2239, DW_AT_TI_symbol_name("lineNum")
.dwattr $C$DW$2239, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$2239, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2239, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2239, DW_AT_decl_line(0x5a8)
.dwattr $C$DW$2239, DW_AT_decl_column(0x05)
$C$DW$2240 .dwtag DW_TAG_member
.dwattr $C$DW$2240, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2240, DW_AT_name("errorType")
.dwattr $C$DW$2240, DW_AT_TI_symbol_name("errorType")
.dwattr $C$DW$2240, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$2240, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2240, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2240, DW_AT_decl_line(0x5a9)
.dwattr $C$DW$2240, DW_AT_decl_column(0x05)
$C$DW$2241 .dwtag DW_TAG_member
.dwattr $C$DW$2241, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2241, DW_AT_name("arg")
.dwattr $C$DW$2241, DW_AT_TI_symbol_name("arg")
.dwattr $C$DW$2241, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$2241, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2241, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2241, DW_AT_decl_line(0x5aa)
.dwattr $C$DW$2241, DW_AT_decl_column(0x05)
$C$DW$2242 .dwtag DW_TAG_member
.dwattr $C$DW$2242, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2242, DW_AT_name("numSoftErrs")
.dwattr $C$DW$2242, DW_AT_TI_symbol_name("numSoftErrs")
.dwattr $C$DW$2242, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$2242, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2242, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2242, DW_AT_decl_line(0x5ad)
.dwattr $C$DW$2242, DW_AT_decl_column(0x05)
$C$DW$2243 .dwtag DW_TAG_member
.dwattr $C$DW$2243, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2243, DW_AT_name("lastSoftErrIndx")
.dwattr $C$DW$2243, DW_AT_TI_symbol_name("lastSoftErrIndx")
.dwattr $C$DW$2243, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$2243, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2243, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2243, DW_AT_decl_line(0x5ae)
.dwattr $C$DW$2243, DW_AT_decl_column(0x05)
$C$DW$2244 .dwtag DW_TAG_member
.dwattr $C$DW$2244, DW_AT_type(*$C$DW$T$1330)
.dwattr $C$DW$2244, DW_AT_name("softErrHistory")
.dwattr $C$DW$2244, DW_AT_TI_symbol_name("softErrHistory")
.dwattr $C$DW$2244, DW_AT_data_member_location[DW_OP_plus_uconst 0x68]
.dwattr $C$DW$2244, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2244, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2244, DW_AT_decl_line(0x5af)
.dwattr $C$DW$2244, DW_AT_decl_column(0x05)
$C$DW$2245 .dwtag DW_TAG_member
.dwattr $C$DW$2245, DW_AT_type(*$C$DW$T$1331)
.dwattr $C$DW$2245, DW_AT_name("hist")
.dwattr $C$DW$2245, DW_AT_TI_symbol_name("hist")
.dwattr $C$DW$2245, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8]
.dwattr $C$DW$2245, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2245, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2245, DW_AT_decl_line(0x5b2)
.dwattr $C$DW$2245, DW_AT_decl_column(0x05)
$C$DW$2246 .dwtag DW_TAG_member
.dwattr $C$DW$2246, DW_AT_type(*$C$DW$T$1332)
.dwattr $C$DW$2246, DW_AT_name("mainCtrlMsg")
.dwattr $C$DW$2246, DW_AT_TI_symbol_name("mainCtrlMsg")
.dwattr $C$DW$2246, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0]
.dwattr $C$DW$2246, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2246, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2246, DW_AT_decl_line(0x5b5)
.dwattr $C$DW$2246, DW_AT_decl_column(0x05)
$C$DW$2247 .dwtag DW_TAG_member
.dwattr $C$DW$2247, DW_AT_type(*$C$DW$T$1332)
.dwattr $C$DW$2247, DW_AT_name("mainCtrlState")
.dwattr $C$DW$2247, DW_AT_TI_symbol_name("mainCtrlState")
.dwattr $C$DW$2247, DW_AT_data_member_location[DW_OP_plus_uconst 0xd8]
.dwattr $C$DW$2247, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2247, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2247, DW_AT_decl_line(0x5b6)
.dwattr $C$DW$2247, DW_AT_decl_column(0x05)
$C$DW$2248 .dwtag DW_TAG_member
.dwattr $C$DW$2248, DW_AT_type(*$C$DW$T$1332)
.dwattr $C$DW$2248, DW_AT_name("mainCtrlEvent")
.dwattr $C$DW$2248, DW_AT_TI_symbol_name("mainCtrlEvent")
.dwattr $C$DW$2248, DW_AT_data_member_location[DW_OP_plus_uconst 0x100]
.dwattr $C$DW$2248, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2248, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2248, DW_AT_decl_line(0x5b7)
.dwattr $C$DW$2248, DW_AT_decl_column(0x05)
$C$DW$2249 .dwtag DW_TAG_member
.dwattr $C$DW$2249, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2249, DW_AT_name("reserved")
.dwattr $C$DW$2249, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2249, DW_AT_data_member_location[DW_OP_plus_uconst 0x128]
.dwattr $C$DW$2249, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2249, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2249, DW_AT_decl_line(0x5b9)
.dwattr $C$DW$2249, DW_AT_decl_column(0x05)
$C$DW$127 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$127, DW_AT_declaration
.dwattr $C$DW$127, DW_AT_TI_symbol_name("_ZN15SpDsp_ErrorInfoaSERKS_")
.dwattr $C$DW$127, DW_AT_type(*$C$DW$T$1333)
.dwattr $C$DW$127, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2250 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2250, DW_AT_type(*$C$DW$T$1335)
.dwendtag $C$DW$127
.dwendtag $C$DW$T$1337
.dwattr $C$DW$T$1337, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1337, DW_AT_decl_line(0x5a5)
.dwattr $C$DW$T$1337, DW_AT_decl_column(0x01)
$C$DW$T$1334 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1334, DW_AT_type(*$C$DW$T$1337)
$C$DW$T$1335 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1335, DW_AT_type(*$C$DW$T$1334)
.dwattr $C$DW$T$1335, DW_AT_address_class(0x20)
$C$DW$T$2200 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_ErrorInfo")
.dwattr $C$DW$T$2200, DW_AT_type(*$C$DW$T$1337)
.dwattr $C$DW$T$2200, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2200, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$2200, DW_AT_decl_line(0x5ba)
.dwattr $C$DW$T$2200, DW_AT_decl_column(0x03)
$C$DW$T$1333 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1333, DW_AT_type(*$C$DW$T$1337)
.dwattr $C$DW$T$1333, DW_AT_address_class(0x20)
$C$DW$T$1336 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1336, DW_AT_type(*$C$DW$T$1333)
.dwattr $C$DW$T$1336, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2251 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2251, DW_AT_type(*$C$DW$T$1335)
.dwendtag $C$DW$T$1336
$C$DW$T$1343 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1343, DW_AT_name("SpDsp_ExtInterface")
.dwattr $C$DW$T$1343, DW_AT_byte_size(0x118)
$C$DW$2252 .dwtag DW_TAG_member
.dwattr $C$DW$2252, DW_AT_type(*$C$DW$T$1338)
.dwattr $C$DW$2252, DW_AT_name("edmaPeek")
.dwattr $C$DW$2252, DW_AT_TI_symbol_name("edmaPeek")
.dwattr $C$DW$2252, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2252, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2252, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2252, DW_AT_decl_line(0x568)
.dwattr $C$DW$2252, DW_AT_decl_column(0x05)
$C$DW$2253 .dwtag DW_TAG_member
.dwattr $C$DW$2253, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2253, DW_AT_name("reserved")
.dwattr $C$DW$2253, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2253, DW_AT_data_member_location[DW_OP_plus_uconst 0x98]
.dwattr $C$DW$2253, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2253, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2253, DW_AT_decl_line(0x569)
.dwattr $C$DW$2253, DW_AT_decl_column(0x05)
$C$DW$128 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$128, DW_AT_declaration
.dwattr $C$DW$128, DW_AT_TI_symbol_name("_ZN18SpDsp_ExtInterfaceaSERKS_")
.dwattr $C$DW$128, DW_AT_type(*$C$DW$T$1339)
.dwattr $C$DW$128, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2254 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2254, DW_AT_type(*$C$DW$T$1341)
.dwendtag $C$DW$128
.dwendtag $C$DW$T$1343
.dwattr $C$DW$T$1343, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1343, DW_AT_decl_line(0x567)
.dwattr $C$DW$T$1343, DW_AT_decl_column(0x01)
$C$DW$T$1340 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1340, DW_AT_type(*$C$DW$T$1343)
$C$DW$T$1341 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1341, DW_AT_type(*$C$DW$T$1340)
.dwattr $C$DW$T$1341, DW_AT_address_class(0x20)
$C$DW$T$1366 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_ExtInterface")
.dwattr $C$DW$T$1366, DW_AT_type(*$C$DW$T$1343)
.dwattr $C$DW$T$1366, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1366, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1366, DW_AT_decl_line(0x56a)
.dwattr $C$DW$T$1366, DW_AT_decl_column(0x03)
$C$DW$T$1339 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1339, DW_AT_type(*$C$DW$T$1343)
.dwattr $C$DW$T$1339, DW_AT_address_class(0x20)
$C$DW$T$1342 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1342, DW_AT_type(*$C$DW$T$1339)
.dwattr $C$DW$T$1342, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2255 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2255, DW_AT_type(*$C$DW$T$1341)
.dwendtag $C$DW$T$1342
$C$DW$T$1349 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1349, DW_AT_name("SpDsp_FeedbackInfo")
.dwattr $C$DW$T$1349, DW_AT_byte_size(0x348)
$C$DW$2256 .dwtag DW_TAG_member
.dwattr $C$DW$2256, DW_AT_type(*$C$DW$T$1344)
.dwattr $C$DW$2256, DW_AT_name("msRequiredPerFrameNormal")
.dwattr $C$DW$2256, DW_AT_TI_symbol_name("msRequiredPerFrameNormal")
.dwattr $C$DW$2256, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2256, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2256, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2256, DW_AT_decl_line(0x633)
.dwattr $C$DW$2256, DW_AT_decl_column(0x05)
$C$DW$2257 .dwtag DW_TAG_member
.dwattr $C$DW$2257, DW_AT_type(*$C$DW$T$1344)
.dwattr $C$DW$2257, DW_AT_name("msRequiredPerFramePreCine")
.dwattr $C$DW$2257, DW_AT_TI_symbol_name("msRequiredPerFramePreCine")
.dwattr $C$DW$2257, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2257, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2257, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2257, DW_AT_decl_line(0x63a)
.dwattr $C$DW$2257, DW_AT_decl_column(0x05)
$C$DW$2258 .dwtag DW_TAG_member
.dwattr $C$DW$2258, DW_AT_type(*$C$DW$T$1344)
.dwattr $C$DW$2258, DW_AT_name("msRequiredPerFramePostCine")
.dwattr $C$DW$2258, DW_AT_TI_symbol_name("msRequiredPerFramePostCine")
.dwattr $C$DW$2258, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2258, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2258, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2258, DW_AT_decl_line(0x63b)
.dwattr $C$DW$2258, DW_AT_decl_column(0x05)
$C$DW$2259 .dwtag DW_TAG_member
.dwattr $C$DW$2259, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2259, DW_AT_name("reservedCommonForFutureFeedback")
.dwattr $C$DW$2259, DW_AT_TI_symbol_name("reservedCommonForFutureFeedback")
.dwattr $C$DW$2259, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$2259, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2259, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2259, DW_AT_decl_line(0x63d)
.dwattr $C$DW$2259, DW_AT_decl_column(0x05)
$C$DW$2260 .dwtag DW_TAG_member
.dwattr $C$DW$2260, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2260, DW_AT_name("reservedBModeForFutureFeedback")
.dwattr $C$DW$2260, DW_AT_TI_symbol_name("reservedBModeForFutureFeedback")
.dwattr $C$DW$2260, DW_AT_data_member_location[DW_OP_plus_uconst 0xc8]
.dwattr $C$DW$2260, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2260, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2260, DW_AT_decl_line(0x640)
.dwattr $C$DW$2260, DW_AT_decl_column(0x05)
$C$DW$2261 .dwtag DW_TAG_member
.dwattr $C$DW$2261, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2261, DW_AT_name("reservedColorForFutureFeedback")
.dwattr $C$DW$2261, DW_AT_TI_symbol_name("reservedColorForFutureFeedback")
.dwattr $C$DW$2261, DW_AT_data_member_location[DW_OP_plus_uconst 0x148]
.dwattr $C$DW$2261, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2261, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2261, DW_AT_decl_line(0x643)
.dwattr $C$DW$2261, DW_AT_decl_column(0x05)
$C$DW$2262 .dwtag DW_TAG_member
.dwattr $C$DW$2262, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2262, DW_AT_name("reservedDopForFutureFeedback")
.dwattr $C$DW$2262, DW_AT_TI_symbol_name("reservedDopForFutureFeedback")
.dwattr $C$DW$2262, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c8]
.dwattr $C$DW$2262, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2262, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2262, DW_AT_decl_line(0x646)
.dwattr $C$DW$2262, DW_AT_decl_column(0x05)
$C$DW$2263 .dwtag DW_TAG_member
.dwattr $C$DW$2263, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2263, DW_AT_name("reservedMModeForFutureFeedback")
.dwattr $C$DW$2263, DW_AT_TI_symbol_name("reservedMModeForFutureFeedback")
.dwattr $C$DW$2263, DW_AT_data_member_location[DW_OP_plus_uconst 0x248]
.dwattr $C$DW$2263, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2263, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2263, DW_AT_decl_line(0x649)
.dwattr $C$DW$2263, DW_AT_decl_column(0x05)
$C$DW$2264 .dwtag DW_TAG_member
.dwattr $C$DW$2264, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2264, DW_AT_name("reservedEcgForFutureFeedback")
.dwattr $C$DW$2264, DW_AT_TI_symbol_name("reservedEcgForFutureFeedback")
.dwattr $C$DW$2264, DW_AT_data_member_location[DW_OP_plus_uconst 0x2c8]
.dwattr $C$DW$2264, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2264, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2264, DW_AT_decl_line(0x64c)
.dwattr $C$DW$2264, DW_AT_decl_column(0x05)
$C$DW$129 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$129, DW_AT_declaration
.dwattr $C$DW$129, DW_AT_TI_symbol_name("_ZN18SpDsp_FeedbackInfoaSERKS_")
.dwattr $C$DW$129, DW_AT_type(*$C$DW$T$1345)
.dwattr $C$DW$129, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2265 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2265, DW_AT_type(*$C$DW$T$1347)
.dwendtag $C$DW$129
.dwendtag $C$DW$T$1349
.dwattr $C$DW$T$1349, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1349, DW_AT_decl_line(0x625)
.dwattr $C$DW$T$1349, DW_AT_decl_column(0x01)
$C$DW$T$1346 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1346, DW_AT_type(*$C$DW$T$1349)
$C$DW$T$1347 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1347, DW_AT_type(*$C$DW$T$1346)
.dwattr $C$DW$T$1347, DW_AT_address_class(0x20)
$C$DW$T$1374 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_FeedbackInfo")
.dwattr $C$DW$T$1374, DW_AT_type(*$C$DW$T$1349)
.dwattr $C$DW$T$1374, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1374, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1374, DW_AT_decl_line(0x64e)
.dwattr $C$DW$T$1374, DW_AT_decl_column(0x03)
$C$DW$T$1345 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1345, DW_AT_type(*$C$DW$T$1349)
.dwattr $C$DW$T$1345, DW_AT_address_class(0x20)
$C$DW$T$1348 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1348, DW_AT_type(*$C$DW$T$1345)
.dwattr $C$DW$T$1348, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2266 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2266, DW_AT_type(*$C$DW$T$1347)
.dwendtag $C$DW$T$1348
$C$DW$T$1355 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1355, DW_AT_name("SpDsp_Fov")
.dwattr $C$DW$T$1355, DW_AT_byte_size(0x04)
$C$DW$2267 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_FOV_ONE"), DW_AT_const_value(0x00)
.dwattr $C$DW$2267, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2267, DW_AT_decl_line(0x88)
.dwattr $C$DW$2267, DW_AT_decl_column(0x05)
$C$DW$2268 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_FOV_TWO"), DW_AT_const_value(0x01)
.dwattr $C$DW$2268, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2268, DW_AT_decl_line(0x89)
.dwattr $C$DW$2268, DW_AT_decl_column(0x05)
$C$DW$2269 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_FOV_THREE"), DW_AT_const_value(0x02)
.dwattr $C$DW$2269, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2269, DW_AT_decl_line(0x8a)
.dwattr $C$DW$2269, DW_AT_decl_column(0x05)
$C$DW$2270 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_FOV_FOUR"), DW_AT_const_value(0x03)
.dwattr $C$DW$2270, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2270, DW_AT_decl_line(0x8b)
.dwattr $C$DW$2270, DW_AT_decl_column(0x05)
$C$DW$2271 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_FOV_EOL"), DW_AT_const_value(0x04)
.dwattr $C$DW$2271, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2271, DW_AT_decl_line(0x8c)
.dwattr $C$DW$2271, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1355
.dwattr $C$DW$T$1355, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1355, DW_AT_decl_line(0x87)
.dwattr $C$DW$T$1355, DW_AT_decl_column(0x01)
$C$DW$T$1356 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_Fov")
.dwattr $C$DW$T$1356, DW_AT_type(*$C$DW$T$1355)
.dwattr $C$DW$T$1356, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1356, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1356, DW_AT_decl_line(0x8d)
.dwattr $C$DW$T$1356, DW_AT_decl_column(0x03)
$C$DW$T$1361 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1361, DW_AT_name("SpDsp_Fov_Param")
.dwattr $C$DW$T$1361, DW_AT_byte_size(0x198)
$C$DW$2272 .dwtag DW_TAG_member
.dwattr $C$DW$2272, DW_AT_type(*$C$DW$T$1351)
.dwattr $C$DW$2272, DW_AT_name("state")
.dwattr $C$DW$2272, DW_AT_TI_symbol_name("state")
.dwattr $C$DW$2272, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2272, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2272, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2272, DW_AT_decl_line(0x58a)
.dwattr $C$DW$2272, DW_AT_decl_column(0x05)
$C$DW$2273 .dwtag DW_TAG_member
.dwattr $C$DW$2273, DW_AT_type(*$C$DW$T$1353)
.dwattr $C$DW$2273, DW_AT_name("spDataParams")
.dwattr $C$DW$2273, DW_AT_TI_symbol_name("spDataParams")
.dwattr $C$DW$2273, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2273, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2273, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2273, DW_AT_decl_line(0x58b)
.dwattr $C$DW$2273, DW_AT_decl_column(0x05)
$C$DW$2274 .dwtag DW_TAG_member
.dwattr $C$DW$2274, DW_AT_type(*$C$DW$T$1354)
.dwattr $C$DW$2274, DW_AT_name("modeParams")
.dwattr $C$DW$2274, DW_AT_TI_symbol_name("modeParams")
.dwattr $C$DW$2274, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2274, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2274, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2274, DW_AT_decl_line(0x58c)
.dwattr $C$DW$2274, DW_AT_decl_column(0x05)
$C$DW$2275 .dwtag DW_TAG_member
.dwattr $C$DW$2275, DW_AT_type(*$C$DW$T$167)
.dwattr $C$DW$2275, DW_AT_name("fovHandle")
.dwattr $C$DW$2275, DW_AT_TI_symbol_name("fovHandle")
.dwattr $C$DW$2275, DW_AT_data_member_location[DW_OP_plus_uconst 0x100]
.dwattr $C$DW$2275, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2275, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2275, DW_AT_decl_line(0x58d)
.dwattr $C$DW$2275, DW_AT_decl_column(0x05)
$C$DW$2276 .dwtag DW_TAG_member
.dwattr $C$DW$2276, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2276, DW_AT_name("pErrorInfo")
.dwattr $C$DW$2276, DW_AT_TI_symbol_name("pErrorInfo")
.dwattr $C$DW$2276, DW_AT_data_member_location[DW_OP_plus_uconst 0x108]
.dwattr $C$DW$2276, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2276, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2276, DW_AT_decl_line(0x58e)
.dwattr $C$DW$2276, DW_AT_decl_column(0x05)
$C$DW$2277 .dwtag DW_TAG_member
.dwattr $C$DW$2277, DW_AT_type(*$C$DW$T$1356)
.dwattr $C$DW$2277, DW_AT_name("playlistIdx")
.dwattr $C$DW$2277, DW_AT_TI_symbol_name("playlistIdx")
.dwattr $C$DW$2277, DW_AT_data_member_location[DW_OP_plus_uconst 0x110]
.dwattr $C$DW$2277, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2277, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2277, DW_AT_decl_line(0x58f)
.dwattr $C$DW$2277, DW_AT_decl_column(0x05)
$C$DW$2278 .dwtag DW_TAG_member
.dwattr $C$DW$2278, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2278, DW_AT_name("reserved")
.dwattr $C$DW$2278, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2278, DW_AT_data_member_location[DW_OP_plus_uconst 0x118]
.dwattr $C$DW$2278, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2278, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2278, DW_AT_decl_line(0x590)
.dwattr $C$DW$2278, DW_AT_decl_column(0x05)
$C$DW$130 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$130, DW_AT_declaration
.dwattr $C$DW$130, DW_AT_TI_symbol_name("_ZN15SpDsp_Fov_ParamaSERKS_")
.dwattr $C$DW$130, DW_AT_type(*$C$DW$T$1357)
.dwattr $C$DW$130, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2279 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2279, DW_AT_type(*$C$DW$T$1359)
.dwendtag $C$DW$130
.dwendtag $C$DW$T$1361
.dwattr $C$DW$T$1361, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1361, DW_AT_decl_line(0x589)
.dwattr $C$DW$T$1361, DW_AT_decl_column(0x01)
$C$DW$T$1358 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1358, DW_AT_type(*$C$DW$T$1361)
$C$DW$T$1359 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1359, DW_AT_type(*$C$DW$T$1358)
.dwattr $C$DW$T$1359, DW_AT_address_class(0x20)
$C$DW$T$1371 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_Fov_Param")
.dwattr $C$DW$T$1371, DW_AT_type(*$C$DW$T$1361)
.dwattr $C$DW$T$1371, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1371, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1371, DW_AT_decl_line(0x591)
.dwattr $C$DW$T$1371, DW_AT_decl_column(0x03)
$C$DW$T$1372 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1372, DW_AT_type(*$C$DW$T$1371)
.dwattr $C$DW$T$1372, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1372, DW_AT_byte_size(0x660)
$C$DW$2280 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2280, DW_AT_upper_bound(0x03)
.dwendtag $C$DW$T$1372
$C$DW$T$1357 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1357, DW_AT_type(*$C$DW$T$1361)
.dwattr $C$DW$T$1357, DW_AT_address_class(0x20)
$C$DW$T$1360 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1360, DW_AT_type(*$C$DW$T$1357)
.dwattr $C$DW$T$1360, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2281 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2281, DW_AT_type(*$C$DW$T$1359)
.dwendtag $C$DW$T$1360
$C$DW$T$1380 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1380, DW_AT_name("SpDsp_Interface")
.dwattr $C$DW$T$1380, DW_AT_byte_size(0x2d60)
$C$DW$2282 .dwtag DW_TAG_member
.dwattr $C$DW$2282, DW_AT_type(*$C$DW$T$158)
.dwattr $C$DW$2282, DW_AT_name("appVersion")
.dwattr $C$DW$2282, DW_AT_TI_symbol_name("appVersion")
.dwattr $C$DW$2282, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2282, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2282, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2282, DW_AT_decl_line(0x673)
.dwattr $C$DW$2282, DW_AT_decl_column(0x05)
$C$DW$2283 .dwtag DW_TAG_member
.dwattr $C$DW$2283, DW_AT_type(*$C$DW$T$158)
.dwattr $C$DW$2283, DW_AT_name("iblVersion")
.dwattr $C$DW$2283, DW_AT_TI_symbol_name("iblVersion")
.dwattr $C$DW$2283, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2283, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2283, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2283, DW_AT_decl_line(0x674)
.dwattr $C$DW$2283, DW_AT_decl_column(0x05)
$C$DW$2284 .dwtag DW_TAG_member
.dwattr $C$DW$2284, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2284, DW_AT_name("formatVersion")
.dwattr $C$DW$2284, DW_AT_TI_symbol_name("formatVersion")
.dwattr $C$DW$2284, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$2284, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2284, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2284, DW_AT_decl_line(0x675)
.dwattr $C$DW$2284, DW_AT_decl_column(0x05)
$C$DW$2285 .dwtag DW_TAG_member
.dwattr $C$DW$2285, DW_AT_type(*$C$DW$T$1356)
.dwattr $C$DW$2285, DW_AT_name("activeFov")
.dwattr $C$DW$2285, DW_AT_TI_symbol_name("activeFov")
.dwattr $C$DW$2285, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$2285, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2285, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2285, DW_AT_decl_line(0x676)
.dwattr $C$DW$2285, DW_AT_decl_column(0x05)
$C$DW$2286 .dwtag DW_TAG_member
.dwattr $C$DW$2286, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2286, DW_AT_name("numFov")
.dwattr $C$DW$2286, DW_AT_TI_symbol_name("numFov")
.dwattr $C$DW$2286, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$2286, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2286, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2286, DW_AT_decl_line(0x677)
.dwattr $C$DW$2286, DW_AT_decl_column(0x05)
$C$DW$2287 .dwtag DW_TAG_member
.dwattr $C$DW$2287, DW_AT_type(*$C$DW$T$1363)
.dwattr $C$DW$2287, DW_AT_name("command")
.dwattr $C$DW$2287, DW_AT_TI_symbol_name("command")
.dwattr $C$DW$2287, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$2287, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2287, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2287, DW_AT_decl_line(0x678)
.dwattr $C$DW$2287, DW_AT_decl_column(0x05)
$C$DW$2288 .dwtag DW_TAG_member
.dwattr $C$DW$2288, DW_AT_type(*$C$DW$T$451)
.dwattr $C$DW$2288, DW_AT_name("subCommand")
.dwattr $C$DW$2288, DW_AT_TI_symbol_name("subCommand")
.dwattr $C$DW$2288, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$2288, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2288, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2288, DW_AT_decl_line(0x679)
.dwattr $C$DW$2288, DW_AT_decl_column(0x05)
$C$DW$2289 .dwtag DW_TAG_member
.dwattr $C$DW$2289, DW_AT_type(*$C$DW$T$1365)
.dwattr $C$DW$2289, DW_AT_name("spDspSemaphore")
.dwattr $C$DW$2289, DW_AT_TI_symbol_name("spDspSemaphore")
.dwattr $C$DW$2289, DW_AT_data_member_location[DW_OP_plus_uconst 0x68]
.dwattr $C$DW$2289, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2289, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2289, DW_AT_decl_line(0x67a)
.dwattr $C$DW$2289, DW_AT_decl_column(0x05)
$C$DW$2290 .dwtag DW_TAG_member
.dwattr $C$DW$2290, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2290, DW_AT_name("errMask")
.dwattr $C$DW$2290, DW_AT_TI_symbol_name("errMask")
.dwattr $C$DW$2290, DW_AT_data_member_location[DW_OP_plus_uconst 0x70]
.dwattr $C$DW$2290, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2290, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2290, DW_AT_decl_line(0x67b)
.dwattr $C$DW$2290, DW_AT_decl_column(0x05)
$C$DW$2291 .dwtag DW_TAG_member
.dwattr $C$DW$2291, DW_AT_type(*$C$DW$T$1366)
.dwattr $C$DW$2291, DW_AT_name("extInterface")
.dwattr $C$DW$2291, DW_AT_TI_symbol_name("extInterface")
.dwattr $C$DW$2291, DW_AT_data_member_location[DW_OP_plus_uconst 0x78]
.dwattr $C$DW$2291, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2291, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2291, DW_AT_decl_line(0x67c)
.dwattr $C$DW$2291, DW_AT_decl_column(0x05)
$C$DW$2292 .dwtag DW_TAG_member
.dwattr $C$DW$2292, DW_AT_type(*$C$DW$T$1367)
.dwattr $C$DW$2292, DW_AT_name("cineProcessCommands")
.dwattr $C$DW$2292, DW_AT_TI_symbol_name("cineProcessCommands")
.dwattr $C$DW$2292, DW_AT_data_member_location[DW_OP_plus_uconst 0x190]
.dwattr $C$DW$2292, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2292, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2292, DW_AT_decl_line(0x67e)
.dwattr $C$DW$2292, DW_AT_decl_column(0x05)
$C$DW$2293 .dwtag DW_TAG_member
.dwattr $C$DW$2293, DW_AT_type(*$C$DW$T$1370)
.dwattr $C$DW$2293, DW_AT_name("dspRfBufLUT")
.dwattr $C$DW$2293, DW_AT_TI_symbol_name("dspRfBufLUT")
.dwattr $C$DW$2293, DW_AT_data_member_location[DW_OP_plus_uconst 0x7f0]
.dwattr $C$DW$2293, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2293, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2293, DW_AT_decl_line(0x686)
.dwattr $C$DW$2293, DW_AT_decl_column(0x05)
$C$DW$2294 .dwtag DW_TAG_member
.dwattr $C$DW$2294, DW_AT_type(*$C$DW$T$1372)
.dwattr $C$DW$2294, DW_AT_name("fovParam")
.dwattr $C$DW$2294, DW_AT_TI_symbol_name("fovParam")
.dwattr $C$DW$2294, DW_AT_data_member_location[DW_OP_plus_uconst 0x870]
.dwattr $C$DW$2294, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2294, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2294, DW_AT_decl_line(0x687)
.dwattr $C$DW$2294, DW_AT_decl_column(0x05)
$C$DW$2295 .dwtag DW_TAG_member
.dwattr $C$DW$2295, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2295, DW_AT_name("residualVsync")
.dwattr $C$DW$2295, DW_AT_TI_symbol_name("residualVsync")
.dwattr $C$DW$2295, DW_AT_data_member_location[DW_OP_plus_uconst 0xed0]
.dwattr $C$DW$2295, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2295, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2295, DW_AT_decl_line(0x688)
.dwattr $C$DW$2295, DW_AT_decl_column(0x05)
$C$DW$2296 .dwtag DW_TAG_member
.dwattr $C$DW$2296, DW_AT_type(*$C$DW$T$1373)
.dwattr $C$DW$2296, DW_AT_name("debugInfo")
.dwattr $C$DW$2296, DW_AT_TI_symbol_name("debugInfo")
.dwattr $C$DW$2296, DW_AT_data_member_location[DW_OP_plus_uconst 0xed8]
.dwattr $C$DW$2296, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2296, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2296, DW_AT_decl_line(0x68a)
.dwattr $C$DW$2296, DW_AT_decl_column(0x05)
$C$DW$2297 .dwtag DW_TAG_member
.dwattr $C$DW$2297, DW_AT_type(*$C$DW$T$1374)
.dwattr $C$DW$2297, DW_AT_name("feedbackInfo")
.dwattr $C$DW$2297, DW_AT_TI_symbol_name("feedbackInfo")
.dwattr $C$DW$2297, DW_AT_data_member_location[DW_OP_plus_uconst 0x2968]
.dwattr $C$DW$2297, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2297, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2297, DW_AT_decl_line(0x68b)
.dwattr $C$DW$2297, DW_AT_decl_column(0x05)
$C$DW$2298 .dwtag DW_TAG_member
.dwattr $C$DW$2298, DW_AT_type(*$C$DW$T$1375)
.dwattr $C$DW$2298, DW_AT_name("diagsResult")
.dwattr $C$DW$2298, DW_AT_TI_symbol_name("diagsResult")
.dwattr $C$DW$2298, DW_AT_data_member_location[DW_OP_plus_uconst 0x2cb0]
.dwattr $C$DW$2298, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2298, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2298, DW_AT_decl_line(0x68c)
.dwattr $C$DW$2298, DW_AT_decl_column(0x05)
$C$DW$2299 .dwtag DW_TAG_member
.dwattr $C$DW$2299, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2299, DW_AT_name("frameSeqClkHz")
.dwattr $C$DW$2299, DW_AT_TI_symbol_name("frameSeqClkHz")
.dwattr $C$DW$2299, DW_AT_data_member_location[DW_OP_plus_uconst 0x2d58]
.dwattr $C$DW$2299, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2299, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2299, DW_AT_decl_line(0x68d)
.dwattr $C$DW$2299, DW_AT_decl_column(0x05)
$C$DW$131 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$131, DW_AT_declaration
.dwattr $C$DW$131, DW_AT_TI_symbol_name("_ZN15SpDsp_InterfaceaSERKS_")
.dwattr $C$DW$131, DW_AT_type(*$C$DW$T$1376)
.dwattr $C$DW$131, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2300 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2300, DW_AT_type(*$C$DW$T$1378)
.dwendtag $C$DW$131
.dwendtag $C$DW$T$1380
.dwattr $C$DW$T$1380, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1380, DW_AT_decl_line(0x672)
.dwattr $C$DW$T$1380, DW_AT_decl_column(0x01)
$C$DW$T$1377 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1377, DW_AT_type(*$C$DW$T$1380)
$C$DW$T$1378 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1378, DW_AT_type(*$C$DW$T$1377)
.dwattr $C$DW$T$1378, DW_AT_address_class(0x20)
$C$DW$T$2201 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_Interface")
.dwattr $C$DW$T$2201, DW_AT_type(*$C$DW$T$1380)
.dwattr $C$DW$T$2201, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2201, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$2201, DW_AT_decl_line(0x68e)
.dwattr $C$DW$T$2201, DW_AT_decl_column(0x03)
$C$DW$T$1376 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1376, DW_AT_type(*$C$DW$T$1380)
.dwattr $C$DW$T$1376, DW_AT_address_class(0x20)
$C$DW$T$1379 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1379, DW_AT_type(*$C$DW$T$1376)
.dwattr $C$DW$T$1379, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2301 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2301, DW_AT_type(*$C$DW$T$1378)
.dwendtag $C$DW$T$1379
$C$DW$T$131 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$131, DW_AT_name("SpDsp_MMode_SubMode")
.dwattr $C$DW$T$131, DW_AT_byte_size(0x04)
$C$DW$2302 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_MMODE_ECHO_ONLY"), DW_AT_const_value(0x00)
.dwattr $C$DW$2302, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2302, DW_AT_decl_line(0xc8)
.dwattr $C$DW$2302, DW_AT_decl_column(0x05)
$C$DW$2303 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_MMODE_COLOR_ECHO"), DW_AT_const_value(0x01)
.dwattr $C$DW$2303, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2303, DW_AT_decl_line(0xc9)
.dwattr $C$DW$2303, DW_AT_decl_column(0x05)
$C$DW$2304 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_MMODE_ANATOMICAL"), DW_AT_const_value(0x02)
.dwattr $C$DW$2304, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2304, DW_AT_decl_line(0xca)
.dwattr $C$DW$2304, DW_AT_decl_column(0x05)
$C$DW$2305 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_MMODE_EOL"), DW_AT_const_value(0x03)
.dwattr $C$DW$2305, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2305, DW_AT_decl_line(0xcb)
.dwattr $C$DW$2305, DW_AT_decl_column(0x05)
.dwattr $C$DW$T$131, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$131, DW_AT_decl_line(0xc7)
.dwattr $C$DW$T$131, DW_AT_decl_column(0x01)
$C$DW$T$132 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_MMode_SubMode")
.dwattr $C$DW$T$132, DW_AT_type(*$C$DW$T$131)
.dwattr $C$DW$T$132, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$132, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$132, DW_AT_decl_line(0xcc)
.dwattr $C$DW$T$132, DW_AT_decl_column(0x03)
$C$DW$T$1385 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1385, DW_AT_name("SpDsp_MemAccess")
.dwattr $C$DW$T$1385, DW_AT_byte_size(0x98)
$C$DW$2306 .dwtag DW_TAG_member
.dwattr $C$DW$2306, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2306, DW_AT_name("sourceAddr")
.dwattr $C$DW$2306, DW_AT_TI_symbol_name("sourceAddr")
.dwattr $C$DW$2306, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2306, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2306, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2306, DW_AT_decl_line(0x55f)
.dwattr $C$DW$2306, DW_AT_decl_column(0x05)
$C$DW$2307 .dwtag DW_TAG_member
.dwattr $C$DW$2307, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2307, DW_AT_name("destAddr")
.dwattr $C$DW$2307, DW_AT_TI_symbol_name("destAddr")
.dwattr $C$DW$2307, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2307, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2307, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2307, DW_AT_decl_line(0x560)
.dwattr $C$DW$2307, DW_AT_decl_column(0x05)
$C$DW$2308 .dwtag DW_TAG_member
.dwattr $C$DW$2308, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2308, DW_AT_name("sizeInBytes")
.dwattr $C$DW$2308, DW_AT_TI_symbol_name("sizeInBytes")
.dwattr $C$DW$2308, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2308, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2308, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2308, DW_AT_decl_line(0x561)
.dwattr $C$DW$2308, DW_AT_decl_column(0x05)
$C$DW$2309 .dwtag DW_TAG_member
.dwattr $C$DW$2309, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2309, DW_AT_name("reserved")
.dwattr $C$DW$2309, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2309, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2309, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2309, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2309, DW_AT_decl_line(0x562)
.dwattr $C$DW$2309, DW_AT_decl_column(0x05)
$C$DW$132 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$132, DW_AT_declaration
.dwattr $C$DW$132, DW_AT_TI_symbol_name("_ZN15SpDsp_MemAccessaSERKS_")
.dwattr $C$DW$132, DW_AT_type(*$C$DW$T$1381)
.dwattr $C$DW$132, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2310 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2310, DW_AT_type(*$C$DW$T$1383)
.dwendtag $C$DW$132
.dwendtag $C$DW$T$1385
.dwattr $C$DW$T$1385, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1385, DW_AT_decl_line(0x55e)
.dwattr $C$DW$T$1385, DW_AT_decl_column(0x01)
$C$DW$T$1338 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_MemAccess")
.dwattr $C$DW$T$1338, DW_AT_type(*$C$DW$T$1385)
.dwattr $C$DW$T$1338, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1338, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1338, DW_AT_decl_line(0x563)
.dwattr $C$DW$T$1338, DW_AT_decl_column(0x03)
$C$DW$T$1382 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1382, DW_AT_type(*$C$DW$T$1385)
$C$DW$T$1383 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1383, DW_AT_type(*$C$DW$T$1382)
.dwattr $C$DW$T$1383, DW_AT_address_class(0x20)
$C$DW$T$1381 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1381, DW_AT_type(*$C$DW$T$1385)
.dwattr $C$DW$T$1381, DW_AT_address_class(0x20)
$C$DW$T$1384 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1384, DW_AT_type(*$C$DW$T$1381)
.dwattr $C$DW$T$1384, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2311 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2311, DW_AT_type(*$C$DW$T$1383)
.dwendtag $C$DW$T$1384
$C$DW$T$1391 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$1391, DW_AT_name("SpDsp_Mode")
.dwattr $C$DW$T$1391, DW_AT_byte_size(0x04)
$C$DW$2312 .dwtag DW_TAG_member
.dwattr $C$DW$2312, DW_AT_type(*$C$DW$T$1386)
.dwattr $C$DW$2312, DW_AT_name("mode")
.dwattr $C$DW$2312, DW_AT_TI_symbol_name("mode")
.dwattr $C$DW$2312, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2312, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2312, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2312, DW_AT_decl_line(0x22a)
.dwattr $C$DW$2312, DW_AT_decl_column(0x19)
$C$DW$2313 .dwtag DW_TAG_member
.dwattr $C$DW$2313, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2313, DW_AT_name("modeWord")
.dwattr $C$DW$2313, DW_AT_TI_symbol_name("modeWord")
.dwattr $C$DW$2313, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2313, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2313, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2313, DW_AT_decl_line(0x22b)
.dwattr $C$DW$2313, DW_AT_decl_column(0x19)
$C$DW$133 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$133, DW_AT_declaration
.dwattr $C$DW$133, DW_AT_TI_symbol_name("_ZN10SpDsp_ModeaSERKS_")
.dwattr $C$DW$133, DW_AT_type(*$C$DW$T$1387)
.dwattr $C$DW$133, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2314 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2314, DW_AT_type(*$C$DW$T$1389)
.dwendtag $C$DW$133
.dwendtag $C$DW$T$1391
.dwattr $C$DW$T$1391, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1391, DW_AT_decl_line(0x229)
.dwattr $C$DW$T$1391, DW_AT_decl_column(0x01)
$C$DW$T$1003 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_Mode")
.dwattr $C$DW$T$1003, DW_AT_type(*$C$DW$T$1391)
.dwattr $C$DW$T$1003, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1003, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1003, DW_AT_decl_line(0x22c)
.dwattr $C$DW$T$1003, DW_AT_decl_column(0x03)
$C$DW$T$1388 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1388, DW_AT_type(*$C$DW$T$1391)
$C$DW$T$1389 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1389, DW_AT_type(*$C$DW$T$1388)
.dwattr $C$DW$T$1389, DW_AT_address_class(0x20)
$C$DW$T$1387 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1387, DW_AT_type(*$C$DW$T$1391)
.dwattr $C$DW$T$1387, DW_AT_address_class(0x20)
$C$DW$T$1390 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1390, DW_AT_type(*$C$DW$T$1387)
.dwattr $C$DW$T$1390, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2315 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2315, DW_AT_type(*$C$DW$T$1389)
.dwendtag $C$DW$T$1390
$C$DW$T$1396 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1396, DW_AT_name("SpDsp_ModeBitMask")
.dwattr $C$DW$T$1396, DW_AT_byte_size(0x04)
$C$DW$2316 .dwtag DW_TAG_member
.dwattr $C$DW$2316, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2316, DW_AT_name("twodEnable")
.dwattr $C$DW$2316, DW_AT_TI_symbol_name("twodEnable")
.dwattr $C$DW$2316, DW_AT_bit_offset(0x1f), DW_AT_bit_size(0x01)
.dwattr $C$DW$2316, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2316, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2316, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2316, DW_AT_decl_line(0x21f)
.dwattr $C$DW$2316, DW_AT_decl_column(0x09)
$C$DW$2317 .dwtag DW_TAG_member
.dwattr $C$DW$2317, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2317, DW_AT_name("colorEnable")
.dwattr $C$DW$2317, DW_AT_TI_symbol_name("colorEnable")
.dwattr $C$DW$2317, DW_AT_bit_offset(0x1e), DW_AT_bit_size(0x01)
.dwattr $C$DW$2317, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2317, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2317, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2317, DW_AT_decl_line(0x220)
.dwattr $C$DW$2317, DW_AT_decl_column(0x09)
$C$DW$2318 .dwtag DW_TAG_member
.dwattr $C$DW$2318, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2318, DW_AT_name("dopplerEnable")
.dwattr $C$DW$2318, DW_AT_TI_symbol_name("dopplerEnable")
.dwattr $C$DW$2318, DW_AT_bit_offset(0x1d), DW_AT_bit_size(0x01)
.dwattr $C$DW$2318, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2318, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2318, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2318, DW_AT_decl_line(0x221)
.dwattr $C$DW$2318, DW_AT_decl_column(0x09)
$C$DW$2319 .dwtag DW_TAG_member
.dwattr $C$DW$2319, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2319, DW_AT_name("mModeEnable")
.dwattr $C$DW$2319, DW_AT_TI_symbol_name("mModeEnable")
.dwattr $C$DW$2319, DW_AT_bit_offset(0x1c), DW_AT_bit_size(0x01)
.dwattr $C$DW$2319, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2319, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2319, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2319, DW_AT_decl_line(0x222)
.dwattr $C$DW$2319, DW_AT_decl_column(0x09)
$C$DW$2320 .dwtag DW_TAG_member
.dwattr $C$DW$2320, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2320, DW_AT_name("paiEnable")
.dwattr $C$DW$2320, DW_AT_TI_symbol_name("paiEnable")
.dwattr $C$DW$2320, DW_AT_bit_offset(0x1b), DW_AT_bit_size(0x01)
.dwattr $C$DW$2320, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2320, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2320, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2320, DW_AT_decl_line(0x223)
.dwattr $C$DW$2320, DW_AT_decl_column(0x09)
$C$DW$2321 .dwtag DW_TAG_member
.dwattr $C$DW$2321, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2321, DW_AT_name("ecgEnable")
.dwattr $C$DW$2321, DW_AT_TI_symbol_name("ecgEnable")
.dwattr $C$DW$2321, DW_AT_bit_offset(0x1a), DW_AT_bit_size(0x01)
.dwattr $C$DW$2321, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2321, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2321, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2321, DW_AT_decl_line(0x224)
.dwattr $C$DW$2321, DW_AT_decl_column(0x09)
$C$DW$134 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$134, DW_AT_declaration
.dwattr $C$DW$134, DW_AT_TI_symbol_name("_ZN17SpDsp_ModeBitMaskaSERKS_")
.dwattr $C$DW$134, DW_AT_type(*$C$DW$T$1392)
.dwattr $C$DW$134, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2322 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2322, DW_AT_type(*$C$DW$T$1394)
.dwendtag $C$DW$134
.dwendtag $C$DW$T$1396
.dwattr $C$DW$T$1396, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1396, DW_AT_decl_line(0x21e)
.dwattr $C$DW$T$1396, DW_AT_decl_column(0x01)
$C$DW$T$1386 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_ModeBitMask")
.dwattr $C$DW$T$1386, DW_AT_type(*$C$DW$T$1396)
.dwattr $C$DW$T$1386, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1386, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1386, DW_AT_decl_line(0x226)
.dwattr $C$DW$T$1386, DW_AT_decl_column(0x03)
$C$DW$T$1393 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1393, DW_AT_type(*$C$DW$T$1396)
$C$DW$T$1394 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1394, DW_AT_type(*$C$DW$T$1393)
.dwattr $C$DW$T$1394, DW_AT_address_class(0x20)
$C$DW$T$1392 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1392, DW_AT_type(*$C$DW$T$1396)
.dwattr $C$DW$T$1392, DW_AT_address_class(0x20)
$C$DW$T$1395 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1395, DW_AT_type(*$C$DW$T$1392)
.dwattr $C$DW$T$1395, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2323 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2323, DW_AT_type(*$C$DW$T$1394)
.dwendtag $C$DW$T$1395
$C$DW$T$1401 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1401, DW_AT_name("SpDsp_ModeParams")
.dwattr $C$DW$T$1401, DW_AT_byte_size(0xe0)
$C$DW$2324 .dwtag DW_TAG_member
.dwattr $C$DW$2324, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2324, DW_AT_name("pTwoDParam")
.dwattr $C$DW$2324, DW_AT_TI_symbol_name("pTwoDParam")
.dwattr $C$DW$2324, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2324, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2324, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2324, DW_AT_decl_line(0x578)
.dwattr $C$DW$2324, DW_AT_decl_column(0x05)
$C$DW$2325 .dwtag DW_TAG_member
.dwattr $C$DW$2325, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2325, DW_AT_name("pColorParam")
.dwattr $C$DW$2325, DW_AT_TI_symbol_name("pColorParam")
.dwattr $C$DW$2325, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2325, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2325, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2325, DW_AT_decl_line(0x579)
.dwattr $C$DW$2325, DW_AT_decl_column(0x05)
$C$DW$2326 .dwtag DW_TAG_member
.dwattr $C$DW$2326, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2326, DW_AT_name("pDopplerParam")
.dwattr $C$DW$2326, DW_AT_TI_symbol_name("pDopplerParam")
.dwattr $C$DW$2326, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2326, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2326, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2326, DW_AT_decl_line(0x57a)
.dwattr $C$DW$2326, DW_AT_decl_column(0x05)
$C$DW$2327 .dwtag DW_TAG_member
.dwattr $C$DW$2327, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2327, DW_AT_name("pMModeParam")
.dwattr $C$DW$2327, DW_AT_TI_symbol_name("pMModeParam")
.dwattr $C$DW$2327, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2327, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2327, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2327, DW_AT_decl_line(0x57b)
.dwattr $C$DW$2327, DW_AT_decl_column(0x05)
$C$DW$2328 .dwtag DW_TAG_member
.dwattr $C$DW$2328, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2328, DW_AT_name("pRSCParam")
.dwattr $C$DW$2328, DW_AT_TI_symbol_name("pRSCParam")
.dwattr $C$DW$2328, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2328, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2328, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2328, DW_AT_decl_line(0x57c)
.dwattr $C$DW$2328, DW_AT_decl_column(0x05)
$C$DW$2329 .dwtag DW_TAG_member
.dwattr $C$DW$2329, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2329, DW_AT_name("pEcgParam")
.dwattr $C$DW$2329, DW_AT_TI_symbol_name("pEcgParam")
.dwattr $C$DW$2329, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2329, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2329, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2329, DW_AT_decl_line(0x57d)
.dwattr $C$DW$2329, DW_AT_decl_column(0x05)
$C$DW$2330 .dwtag DW_TAG_member
.dwattr $C$DW$2330, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2330, DW_AT_name("pCineParam")
.dwattr $C$DW$2330, DW_AT_TI_symbol_name("pCineParam")
.dwattr $C$DW$2330, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2330, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2330, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2330, DW_AT_decl_line(0x57e)
.dwattr $C$DW$2330, DW_AT_decl_column(0x05)
$C$DW$2331 .dwtag DW_TAG_member
.dwattr $C$DW$2331, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2331, DW_AT_name("pNvParam")
.dwattr $C$DW$2331, DW_AT_TI_symbol_name("pNvParam")
.dwattr $C$DW$2331, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$2331, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2331, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2331, DW_AT_decl_line(0x57f)
.dwattr $C$DW$2331, DW_AT_decl_column(0x05)
$C$DW$2332 .dwtag DW_TAG_member
.dwattr $C$DW$2332, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2332, DW_AT_name("pPaParam")
.dwattr $C$DW$2332, DW_AT_TI_symbol_name("pPaParam")
.dwattr $C$DW$2332, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$2332, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2332, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2332, DW_AT_decl_line(0x580)
.dwattr $C$DW$2332, DW_AT_decl_column(0x05)
$C$DW$2333 .dwtag DW_TAG_member
.dwattr $C$DW$2333, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2333, DW_AT_name("pNewFeatParam2")
.dwattr $C$DW$2333, DW_AT_TI_symbol_name("pNewFeatParam2")
.dwattr $C$DW$2333, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$2333, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2333, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2333, DW_AT_decl_line(0x581)
.dwattr $C$DW$2333, DW_AT_decl_column(0x05)
$C$DW$2334 .dwtag DW_TAG_member
.dwattr $C$DW$2334, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2334, DW_AT_name("pNewFeatParam1")
.dwattr $C$DW$2334, DW_AT_TI_symbol_name("pNewFeatParam1")
.dwattr $C$DW$2334, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$2334, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2334, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2334, DW_AT_decl_line(0x582)
.dwattr $C$DW$2334, DW_AT_decl_column(0x05)
$C$DW$2335 .dwtag DW_TAG_member
.dwattr $C$DW$2335, DW_AT_type(*$C$DW$T$134)
.dwattr $C$DW$2335, DW_AT_name("pFovBase_Param")
.dwattr $C$DW$2335, DW_AT_TI_symbol_name("pFovBase_Param")
.dwattr $C$DW$2335, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$2335, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2335, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2335, DW_AT_decl_line(0x583)
.dwattr $C$DW$2335, DW_AT_decl_column(0x05)
$C$DW$2336 .dwtag DW_TAG_member
.dwattr $C$DW$2336, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2336, DW_AT_name("reserved")
.dwattr $C$DW$2336, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2336, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$2336, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2336, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2336, DW_AT_decl_line(0x584)
.dwattr $C$DW$2336, DW_AT_decl_column(0x05)
$C$DW$135 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$135, DW_AT_declaration
.dwattr $C$DW$135, DW_AT_TI_symbol_name("_ZN16SpDsp_ModeParamsaSERKS_")
.dwattr $C$DW$135, DW_AT_type(*$C$DW$T$1397)
.dwattr $C$DW$135, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2337 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2337, DW_AT_type(*$C$DW$T$1399)
.dwendtag $C$DW$135
.dwendtag $C$DW$T$1401
.dwattr $C$DW$T$1401, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1401, DW_AT_decl_line(0x577)
.dwattr $C$DW$T$1401, DW_AT_decl_column(0x01)
$C$DW$T$1354 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_ModeParams")
.dwattr $C$DW$T$1354, DW_AT_type(*$C$DW$T$1401)
.dwattr $C$DW$T$1354, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1354, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1354, DW_AT_decl_line(0x585)
.dwattr $C$DW$T$1354, DW_AT_decl_column(0x03)
$C$DW$T$1398 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1398, DW_AT_type(*$C$DW$T$1401)
$C$DW$T$1399 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1399, DW_AT_type(*$C$DW$T$1398)
.dwattr $C$DW$T$1399, DW_AT_address_class(0x20)
$C$DW$T$1397 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1397, DW_AT_type(*$C$DW$T$1401)
.dwattr $C$DW$T$1397, DW_AT_address_class(0x20)
$C$DW$T$1400 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1400, DW_AT_type(*$C$DW$T$1397)
.dwattr $C$DW$T$1400, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2338 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2338, DW_AT_type(*$C$DW$T$1399)
.dwendtag $C$DW$T$1400
$C$DW$T$354 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$354, DW_AT_name("SpDsp_Pai_SubMode")
.dwattr $C$DW$T$354, DW_AT_byte_size(0x04)
$C$DW$2339 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_PAI_PASSTHROUGH"), DW_AT_const_value(0x00)
.dwattr $C$DW$2339, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2339, DW_AT_decl_line(0xe9)
.dwattr $C$DW$2339, DW_AT_decl_column(0x05)
$C$DW$2340 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_PAI_NTV"), DW_AT_const_value(0x01)
.dwattr $C$DW$2340, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2340, DW_AT_decl_line(0xea)
.dwattr $C$DW$2340, DW_AT_decl_column(0x05)
$C$DW$2341 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_PAI_EOL"), DW_AT_const_value(0x02)
.dwattr $C$DW$2341, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2341, DW_AT_decl_line(0xeb)
.dwattr $C$DW$2341, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$354
.dwattr $C$DW$T$354, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$354, DW_AT_decl_line(0xe8)
.dwattr $C$DW$T$354, DW_AT_decl_column(0x01)
$C$DW$T$355 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_Pai_SubMode")
.dwattr $C$DW$T$355, DW_AT_type(*$C$DW$T$354)
.dwattr $C$DW$T$355, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$355, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$355, DW_AT_decl_line(0xec)
.dwattr $C$DW$T$355, DW_AT_decl_column(0x03)
$C$DW$T$1412 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$1412, DW_AT_name("SpDsp_Ptr")
.dwattr $C$DW$T$1412, DW_AT_byte_size(0x08)
$C$DW$2342 .dwtag DW_TAG_member
.dwattr $C$DW$2342, DW_AT_type(*$C$DW$T$1302)
.dwattr $C$DW$2342, DW_AT_name("addr")
.dwattr $C$DW$2342, DW_AT_TI_symbol_name("addr")
.dwattr $C$DW$2342, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2342, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2342, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2342, DW_AT_decl_line(0x23)
.dwattr $C$DW$2342, DW_AT_decl_column(0x19)
$C$DW$2343 .dwtag DW_TAG_member
.dwattr $C$DW$2343, DW_AT_type(*$C$DW$T$1402)
.dwattr $C$DW$2343, DW_AT_name("u8Ptr")
.dwattr $C$DW$2343, DW_AT_TI_symbol_name("u8Ptr")
.dwattr $C$DW$2343, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2343, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2343, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2343, DW_AT_decl_line(0x24)
.dwattr $C$DW$2343, DW_AT_decl_column(0x19)
$C$DW$2344 .dwtag DW_TAG_member
.dwattr $C$DW$2344, DW_AT_type(*$C$DW$T$1403)
.dwattr $C$DW$2344, DW_AT_name("s8Ptr")
.dwattr $C$DW$2344, DW_AT_TI_symbol_name("s8Ptr")
.dwattr $C$DW$2344, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2344, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2344, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2344, DW_AT_decl_line(0x25)
.dwattr $C$DW$2344, DW_AT_decl_column(0x19)
$C$DW$2345 .dwtag DW_TAG_member
.dwattr $C$DW$2345, DW_AT_type(*$C$DW$T$1404)
.dwattr $C$DW$2345, DW_AT_name("u16Ptr")
.dwattr $C$DW$2345, DW_AT_TI_symbol_name("u16Ptr")
.dwattr $C$DW$2345, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2345, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2345, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2345, DW_AT_decl_line(0x26)
.dwattr $C$DW$2345, DW_AT_decl_column(0x19)
$C$DW$2346 .dwtag DW_TAG_member
.dwattr $C$DW$2346, DW_AT_type(*$C$DW$T$1405)
.dwattr $C$DW$2346, DW_AT_name("s16Ptr")
.dwattr $C$DW$2346, DW_AT_TI_symbol_name("s16Ptr")
.dwattr $C$DW$2346, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2346, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2346, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2346, DW_AT_decl_line(0x27)
.dwattr $C$DW$2346, DW_AT_decl_column(0x19)
$C$DW$2347 .dwtag DW_TAG_member
.dwattr $C$DW$2347, DW_AT_type(*$C$DW$T$1406)
.dwattr $C$DW$2347, DW_AT_name("u32Ptr")
.dwattr $C$DW$2347, DW_AT_TI_symbol_name("u32Ptr")
.dwattr $C$DW$2347, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2347, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2347, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2347, DW_AT_decl_line(0x28)
.dwattr $C$DW$2347, DW_AT_decl_column(0x19)
$C$DW$2348 .dwtag DW_TAG_member
.dwattr $C$DW$2348, DW_AT_type(*$C$DW$T$1407)
.dwattr $C$DW$2348, DW_AT_name("s32Ptr")
.dwattr $C$DW$2348, DW_AT_TI_symbol_name("s32Ptr")
.dwattr $C$DW$2348, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2348, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2348, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2348, DW_AT_decl_line(0x29)
.dwattr $C$DW$2348, DW_AT_decl_column(0x19)
$C$DW$2349 .dwtag DW_TAG_member
.dwattr $C$DW$2349, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$2349, DW_AT_name("voidPtr")
.dwattr $C$DW$2349, DW_AT_TI_symbol_name("voidPtr")
.dwattr $C$DW$2349, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2349, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2349, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2349, DW_AT_decl_line(0x2a)
.dwattr $C$DW$2349, DW_AT_decl_column(0x19)
$C$DW$136 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$136, DW_AT_declaration
.dwattr $C$DW$136, DW_AT_TI_symbol_name("_ZN9SpDsp_PtraSERKS_")
.dwattr $C$DW$136, DW_AT_type(*$C$DW$T$1408)
.dwattr $C$DW$136, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2350 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2350, DW_AT_type(*$C$DW$T$1410)
.dwendtag $C$DW$136
.dwendtag $C$DW$T$1412
.dwattr $C$DW$T$1412, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1412, DW_AT_decl_line(0x21)
.dwattr $C$DW$T$1412, DW_AT_decl_column(0x01)
$C$DW$T$134 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_Ptr")
.dwattr $C$DW$T$134, DW_AT_type(*$C$DW$T$1412)
.dwattr $C$DW$T$134, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$134, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$134, DW_AT_decl_line(0x2b)
.dwattr $C$DW$T$134, DW_AT_decl_column(0x03)
$C$DW$T$1409 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1409, DW_AT_type(*$C$DW$T$1412)
$C$DW$T$1410 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1410, DW_AT_type(*$C$DW$T$1409)
.dwattr $C$DW$T$1410, DW_AT_address_class(0x20)
$C$DW$T$1408 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1408, DW_AT_type(*$C$DW$T$1412)
.dwattr $C$DW$T$1408, DW_AT_address_class(0x20)
$C$DW$T$1411 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1411, DW_AT_type(*$C$DW$T$1408)
.dwattr $C$DW$T$1411, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2351 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2351, DW_AT_type(*$C$DW$T$1410)
.dwendtag $C$DW$T$1411
$C$DW$T$509 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$509, DW_AT_name("SpDsp_SPDataType")
.dwattr $C$DW$T$509, DW_AT_byte_size(0x04)
$C$DW$2352 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SPDATATYPE_BOL"), DW_AT_const_value(0x00)
.dwattr $C$DW$2352, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2352, DW_AT_decl_line(0xae)
.dwattr $C$DW$2352, DW_AT_decl_column(0x05)
$C$DW$2353 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SPDATATYPE_TWOD"), DW_AT_const_value(0x00)
.dwattr $C$DW$2353, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2353, DW_AT_decl_line(0xaf)
.dwattr $C$DW$2353, DW_AT_decl_column(0x05)
$C$DW$2354 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SPDATATYPE_COLOR"), DW_AT_const_value(0x01)
.dwattr $C$DW$2354, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2354, DW_AT_decl_line(0xb0)
.dwattr $C$DW$2354, DW_AT_decl_column(0x05)
$C$DW$2355 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SPDATATYPE_DOPPLER"), DW_AT_const_value(0x02)
.dwattr $C$DW$2355, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2355, DW_AT_decl_line(0xb1)
.dwattr $C$DW$2355, DW_AT_decl_column(0x05)
$C$DW$2356 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SPDATATYPE_MMODE"), DW_AT_const_value(0x03)
.dwattr $C$DW$2356, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2356, DW_AT_decl_line(0xb2)
.dwattr $C$DW$2356, DW_AT_decl_column(0x05)
$C$DW$2357 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SPDATATYPE_PAI"), DW_AT_const_value(0x04)
.dwattr $C$DW$2357, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2357, DW_AT_decl_line(0xb3)
.dwattr $C$DW$2357, DW_AT_decl_column(0x05)
$C$DW$2358 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SPDATATYPE_ECG"), DW_AT_const_value(0x05)
.dwattr $C$DW$2358, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2358, DW_AT_decl_line(0xb4)
.dwattr $C$DW$2358, DW_AT_decl_column(0x05)
$C$DW$2359 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SPDATATYPE_EOL"), DW_AT_const_value(0x06)
.dwattr $C$DW$2359, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2359, DW_AT_decl_line(0xb5)
.dwattr $C$DW$2359, DW_AT_decl_column(0x05)
$C$DW$2360 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SPDATATYPE_NULL"), DW_AT_const_value(0x07)
.dwattr $C$DW$2360, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2360, DW_AT_decl_line(0xb7)
.dwattr $C$DW$2360, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$509
.dwattr $C$DW$T$509, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$509, DW_AT_decl_line(0xad)
.dwattr $C$DW$T$509, DW_AT_decl_column(0x01)
$C$DW$T$510 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_SPDataType")
.dwattr $C$DW$T$510, DW_AT_type(*$C$DW$T$509)
.dwattr $C$DW$T$510, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$510, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$510, DW_AT_decl_line(0xb9)
.dwattr $C$DW$T$510, DW_AT_decl_column(0x03)
$C$DW$T$1417 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1417, DW_AT_name("SpDsp_SpDataBehaviorParams")
.dwattr $C$DW$T$1417, DW_AT_byte_size(0x04)
$C$DW$2361 .dwtag DW_TAG_member
.dwattr $C$DW$2361, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2361, DW_AT_name("enable")
.dwattr $C$DW$2361, DW_AT_TI_symbol_name("enable")
.dwattr $C$DW$2361, DW_AT_bit_offset(0x1f), DW_AT_bit_size(0x01)
.dwattr $C$DW$2361, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2361, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2361, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2361, DW_AT_decl_line(0x553)
.dwattr $C$DW$2361, DW_AT_decl_column(0x09)
$C$DW$2362 .dwtag DW_TAG_member
.dwattr $C$DW$2362, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2362, DW_AT_name("freeze")
.dwattr $C$DW$2362, DW_AT_TI_symbol_name("freeze")
.dwattr $C$DW$2362, DW_AT_bit_offset(0x1e), DW_AT_bit_size(0x01)
.dwattr $C$DW$2362, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2362, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2362, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2362, DW_AT_decl_line(0x554)
.dwattr $C$DW$2362, DW_AT_decl_column(0x09)
$C$DW$2363 .dwtag DW_TAG_member
.dwattr $C$DW$2363, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2363, DW_AT_name("sizeChange")
.dwattr $C$DW$2363, DW_AT_TI_symbol_name("sizeChange")
.dwattr $C$DW$2363, DW_AT_bit_offset(0x1d), DW_AT_bit_size(0x01)
.dwattr $C$DW$2363, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2363, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2363, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2363, DW_AT_decl_line(0x555)
.dwattr $C$DW$2363, DW_AT_decl_column(0x09)
$C$DW$2364 .dwtag DW_TAG_member
.dwattr $C$DW$2364, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2364, DW_AT_name("flushCine")
.dwattr $C$DW$2364, DW_AT_TI_symbol_name("flushCine")
.dwattr $C$DW$2364, DW_AT_bit_offset(0x1c), DW_AT_bit_size(0x01)
.dwattr $C$DW$2364, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2364, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2364, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2364, DW_AT_decl_line(0x556)
.dwattr $C$DW$2364, DW_AT_decl_column(0x09)
$C$DW$2365 .dwtag DW_TAG_member
.dwattr $C$DW$2365, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2365, DW_AT_name("showData")
.dwattr $C$DW$2365, DW_AT_TI_symbol_name("showData")
.dwattr $C$DW$2365, DW_AT_bit_offset(0x1b), DW_AT_bit_size(0x01)
.dwattr $C$DW$2365, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2365, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2365, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2365, DW_AT_decl_line(0x557)
.dwattr $C$DW$2365, DW_AT_decl_column(0x09)
$C$DW$2366 .dwtag DW_TAG_member
.dwattr $C$DW$2366, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2366, DW_AT_name("reserved")
.dwattr $C$DW$2366, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2366, DW_AT_bit_offset(0x00), DW_AT_bit_size(0x1b)
.dwattr $C$DW$2366, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2366, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2366, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2366, DW_AT_decl_line(0x558)
.dwattr $C$DW$2366, DW_AT_decl_column(0x09)
$C$DW$137 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$137, DW_AT_declaration
.dwattr $C$DW$137, DW_AT_TI_symbol_name("_ZN26SpDsp_SpDataBehaviorParamsaSERKS_")
.dwattr $C$DW$137, DW_AT_type(*$C$DW$T$1413)
.dwattr $C$DW$137, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2367 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2367, DW_AT_type(*$C$DW$T$1415)
.dwendtag $C$DW$137
.dwendtag $C$DW$T$1417
.dwattr $C$DW$T$1417, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1417, DW_AT_decl_line(0x552)
.dwattr $C$DW$T$1417, DW_AT_decl_column(0x01)
$C$DW$T$1352 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_SpDataBehaviorParams")
.dwattr $C$DW$T$1352, DW_AT_type(*$C$DW$T$1417)
.dwattr $C$DW$T$1352, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1352, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1352, DW_AT_decl_line(0x559)
.dwattr $C$DW$T$1352, DW_AT_decl_column(0x03)
$C$DW$T$1353 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1353, DW_AT_type(*$C$DW$T$1352)
.dwattr $C$DW$T$1353, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1353, DW_AT_byte_size(0x18)
$C$DW$2368 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2368, DW_AT_upper_bound(0x05)
.dwendtag $C$DW$T$1353
$C$DW$T$1414 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1414, DW_AT_type(*$C$DW$T$1417)
$C$DW$T$1415 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1415, DW_AT_type(*$C$DW$T$1414)
.dwattr $C$DW$T$1415, DW_AT_address_class(0x20)
$C$DW$T$1413 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1413, DW_AT_type(*$C$DW$T$1417)
.dwattr $C$DW$T$1413, DW_AT_address_class(0x20)
$C$DW$T$1416 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1416, DW_AT_type(*$C$DW$T$1413)
.dwattr $C$DW$T$1416, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2369 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2369, DW_AT_type(*$C$DW$T$1415)
.dwendtag $C$DW$T$1416
$C$DW$T$1350 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1350, DW_AT_name("SpDsp_State")
.dwattr $C$DW$T$1350, DW_AT_byte_size(0x04)
$C$DW$2370 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_STATE_RESET"), DW_AT_const_value(0x00)
.dwattr $C$DW$2370, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2370, DW_AT_decl_line(0xa0)
.dwattr $C$DW$2370, DW_AT_decl_column(0x05)
$C$DW$2371 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_STATE_IDLE"), DW_AT_const_value(0x01)
.dwattr $C$DW$2371, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2371, DW_AT_decl_line(0xa1)
.dwattr $C$DW$2371, DW_AT_decl_column(0x05)
$C$DW$2372 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_STATE_SP_RUN"), DW_AT_const_value(0x02)
.dwattr $C$DW$2372, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2372, DW_AT_decl_line(0xa2)
.dwattr $C$DW$2372, DW_AT_decl_column(0x05)
$C$DW$2373 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_STATE_NRT_RUN"), DW_AT_const_value(0x03)
.dwattr $C$DW$2373, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2373, DW_AT_decl_line(0xa3)
.dwattr $C$DW$2373, DW_AT_decl_column(0x05)
$C$DW$2374 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_STATE_TERMINATED"), DW_AT_const_value(0x04)
.dwattr $C$DW$2374, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2374, DW_AT_decl_line(0xa4)
.dwattr $C$DW$2374, DW_AT_decl_column(0x05)
$C$DW$2375 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_STATE_DIAGS"), DW_AT_const_value(0x05)
.dwattr $C$DW$2375, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2375, DW_AT_decl_line(0xa5)
.dwattr $C$DW$2375, DW_AT_decl_column(0x05)
$C$DW$2376 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_STATE_EOL"), DW_AT_const_value(0x06)
.dwattr $C$DW$2376, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2376, DW_AT_decl_line(0xa6)
.dwattr $C$DW$2376, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1350
.dwattr $C$DW$T$1350, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1350, DW_AT_decl_line(0x9f)
.dwattr $C$DW$T$1350, DW_AT_decl_column(0x01)
$C$DW$T$1351 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_State")
.dwattr $C$DW$T$1351, DW_AT_type(*$C$DW$T$1350)
.dwattr $C$DW$T$1351, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1351, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1351, DW_AT_decl_line(0xa7)
.dwattr $C$DW$T$1351, DW_AT_decl_column(0x03)
$C$DW$T$450 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$450, DW_AT_name("SpDsp_SubCommand")
.dwattr $C$DW$T$450, DW_AT_byte_size(0x04)
$C$DW$2377 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NONE"), DW_AT_const_value(0x00)
.dwattr $C$DW$2377, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2377, DW_AT_decl_line(0x41)
.dwattr $C$DW$2377, DW_AT_decl_column(0x05)
$C$DW$2378 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_1ST"), DW_AT_const_value(0x100)
.dwattr $C$DW$2378, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2378, DW_AT_decl_line(0x43)
.dwattr $C$DW$2378, DW_AT_decl_column(0x05)
$C$DW$2379 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_ECG_SHOW"), DW_AT_const_value(0x100)
.dwattr $C$DW$2379, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2379, DW_AT_decl_line(0x44)
.dwattr $C$DW$2379, DW_AT_decl_column(0x05)
$C$DW$2380 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_ECG_HIDE"), DW_AT_const_value(0x101)
.dwattr $C$DW$2380, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2380, DW_AT_decl_line(0x45)
.dwattr $C$DW$2380, DW_AT_decl_column(0x05)
$C$DW$2381 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_ECG_SHOW_TRIG"), DW_AT_const_value(0x102)
.dwattr $C$DW$2381, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2381, DW_AT_decl_line(0x46)
.dwattr $C$DW$2381, DW_AT_decl_column(0x05)
$C$DW$2382 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_ECG_HIDE_TRIG"), DW_AT_const_value(0x103)
.dwattr $C$DW$2382, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2382, DW_AT_decl_line(0x47)
.dwattr $C$DW$2382, DW_AT_decl_column(0x05)
$C$DW$2383 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_ECG_SHOW_R"), DW_AT_const_value(0x104)
.dwattr $C$DW$2383, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2383, DW_AT_decl_line(0x48)
.dwattr $C$DW$2383, DW_AT_decl_column(0x05)
$C$DW$2384 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_ECG_HIDE_R"), DW_AT_const_value(0x105)
.dwattr $C$DW$2384, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2384, DW_AT_decl_line(0x49)
.dwattr $C$DW$2384, DW_AT_decl_column(0x05)
$C$DW$2385 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_DOP_AUDIO_VOLUME_CHANGE"), DW_AT_const_value(0x200)
.dwattr $C$DW$2385, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2385, DW_AT_decl_line(0x4b)
.dwattr $C$DW$2385, DW_AT_decl_column(0x05)
$C$DW$2386 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_DOP_RSRVD0"), DW_AT_const_value(0x201)
.dwattr $C$DW$2386, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2386, DW_AT_decl_line(0x4c)
.dwattr $C$DW$2386, DW_AT_decl_column(0x05)
$C$DW$2387 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_DOP_RSRVD1"), DW_AT_const_value(0x202)
.dwattr $C$DW$2387, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2387, DW_AT_decl_line(0x4d)
.dwattr $C$DW$2387, DW_AT_decl_column(0x05)
$C$DW$2388 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_DOP_WF_COEFF_CHANGE"), DW_AT_const_value(0x203)
.dwattr $C$DW$2388, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2388, DW_AT_decl_line(0x4e)
.dwattr $C$DW$2388, DW_AT_decl_column(0x05)
$C$DW$2389 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_DOP_WF_GAIN_CHANGE"), DW_AT_const_value(0x204)
.dwattr $C$DW$2389, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2389, DW_AT_decl_line(0x4f)
.dwattr $C$DW$2389, DW_AT_decl_column(0x05)
$C$DW$2390 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_UPDATE_FRAMERATE"), DW_AT_const_value(0x205)
.dwattr $C$DW$2390, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2390, DW_AT_decl_line(0x50)
.dwattr $C$DW$2390, DW_AT_decl_column(0x05)
$C$DW$2391 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_DOP_PK_MN_CHANGE"), DW_AT_const_value(0x206)
.dwattr $C$DW$2391, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2391, DW_AT_decl_line(0x51)
.dwattr $C$DW$2391, DW_AT_decl_column(0x05)
$C$DW$2392 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_DOP_BLANKING_ON"), DW_AT_const_value(0x207)
.dwattr $C$DW$2392, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2392, DW_AT_decl_line(0x52)
.dwattr $C$DW$2392, DW_AT_decl_column(0x05)
$C$DW$2393 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_DOP_BLANKING_OFF"), DW_AT_const_value(0x208)
.dwattr $C$DW$2393, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2393, DW_AT_decl_line(0x53)
.dwattr $C$DW$2393, DW_AT_decl_column(0x05)
$C$DW$2394 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_FLUSH_CINE"), DW_AT_const_value(0x209)
.dwattr $C$DW$2394, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2394, DW_AT_decl_line(0x54)
.dwattr $C$DW$2394, DW_AT_decl_column(0x05)
$C$DW$2395 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_DUAL_UPDATE"), DW_AT_const_value(0x20a)
.dwattr $C$DW$2395, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2395, DW_AT_decl_line(0x55)
.dwattr $C$DW$2395, DW_AT_decl_column(0x05)
$C$DW$2396 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_DYN_RANGE"), DW_AT_const_value(0x20b)
.dwattr $C$DW$2396, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2396, DW_AT_decl_line(0x56)
.dwattr $C$DW$2396, DW_AT_decl_column(0x02)
$C$DW$2397 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_EDMA_PEEK"), DW_AT_const_value(0x20c)
.dwattr $C$DW$2397, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2397, DW_AT_decl_line(0x57)
.dwattr $C$DW$2397, DW_AT_decl_column(0x05)
$C$DW$2398 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_EDMA_POKE"), DW_AT_const_value(0x20d)
.dwattr $C$DW$2398, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2398, DW_AT_decl_line(0x58)
.dwattr $C$DW$2398, DW_AT_decl_column(0x02)
$C$DW$2399 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_AMMLINE_UPDATE"), DW_AT_const_value(0x20e)
.dwattr $C$DW$2399, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2399, DW_AT_decl_line(0x5a)
.dwattr $C$DW$2399, DW_AT_decl_column(0x05)
$C$DW$2400 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_DIAG_AUDIO"), DW_AT_const_value(0x300)
.dwattr $C$DW$2400, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2400, DW_AT_decl_line(0x5e)
.dwattr $C$DW$2400, DW_AT_decl_column(0x05)
$C$DW$2401 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_RT_EOL"), DW_AT_const_value(0xfff)
.dwattr $C$DW$2401, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2401, DW_AT_decl_line(0x60)
.dwattr $C$DW$2401, DW_AT_decl_column(0x05)
$C$DW$2402 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_1ST"), DW_AT_const_value(0x1000)
.dwattr $C$DW$2402, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2402, DW_AT_decl_line(0x63)
.dwattr $C$DW$2402, DW_AT_decl_column(0x05)
$C$DW$2403 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_RD_ZOOM"), DW_AT_const_value(0x1000)
.dwattr $C$DW$2403, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2403, DW_AT_decl_line(0x64)
.dwattr $C$DW$2403, DW_AT_decl_column(0x05)
$C$DW$2404 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_RD_POSITION"), DW_AT_const_value(0x1001)
.dwattr $C$DW$2404, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2404, DW_AT_decl_line(0x65)
.dwattr $C$DW$2404, DW_AT_decl_column(0x05)
$C$DW$2405 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_QUERY_FRAMERATE"), DW_AT_const_value(0x1002)
.dwattr $C$DW$2405, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2405, DW_AT_decl_line(0x66)
.dwattr $C$DW$2405, DW_AT_decl_column(0x05)
$C$DW$2406 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_CINE_SCROLL"), DW_AT_const_value(0x1100)
.dwattr $C$DW$2406, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2406, DW_AT_decl_line(0x68)
.dwattr $C$DW$2406, DW_AT_decl_column(0x05)
$C$DW$2407 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_CINE_PLAYBACK_ENABLE"), DW_AT_const_value(0x1101)
.dwattr $C$DW$2407, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2407, DW_AT_decl_line(0x69)
.dwattr $C$DW$2407, DW_AT_decl_column(0x05)
$C$DW$2408 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_CINE_PLAYBACK_DISABLE"), DW_AT_const_value(0x1102)
.dwattr $C$DW$2408, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2408, DW_AT_decl_line(0x6a)
.dwattr $C$DW$2408, DW_AT_decl_column(0x05)
$C$DW$2409 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_TWOD_AUTOGAIN"), DW_AT_const_value(0x1200)
.dwattr $C$DW$2409, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2409, DW_AT_decl_line(0x6c)
.dwattr $C$DW$2409, DW_AT_decl_column(0x05)
$C$DW$2410 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_SCALE_DISPLAY"), DW_AT_const_value(0x1300)
.dwattr $C$DW$2410, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2410, DW_AT_decl_line(0x6e)
.dwattr $C$DW$2410, DW_AT_decl_column(0x05)
$C$DW$2411 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_DOPPLER_PARAM_UPDATE"), DW_AT_const_value(0x1400)
.dwattr $C$DW$2411, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2411, DW_AT_decl_line(0x70)
.dwattr $C$DW$2411, DW_AT_decl_column(0x05)
$C$DW$2412 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_DOPPLER_INVERT"), DW_AT_const_value(0x1401)
.dwattr $C$DW$2412, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2412, DW_AT_decl_line(0x71)
.dwattr $C$DW$2412, DW_AT_decl_column(0x05)
$C$DW$2413 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_DOPPLER_BASELINE_SHIFT"), DW_AT_const_value(0x1402)
.dwattr $C$DW$2413, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2413, DW_AT_decl_line(0x72)
.dwattr $C$DW$2413, DW_AT_decl_column(0x05)
$C$DW$2414 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_DOPPLER_PK_MN_UPDATE"), DW_AT_const_value(0x1403)
.dwattr $C$DW$2414, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2414, DW_AT_decl_line(0x73)
.dwattr $C$DW$2414, DW_AT_decl_column(0x05)
$C$DW$2415 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_PARAM_UPDATE"), DW_AT_const_value(0x1500)
.dwattr $C$DW$2415, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2415, DW_AT_decl_line(0x75)
.dwattr $C$DW$2415, DW_AT_decl_column(0x05)
$C$DW$2416 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_DYN_RANGE"), DW_AT_const_value(0x1501)
.dwattr $C$DW$2416, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2416, DW_AT_decl_line(0x76)
.dwattr $C$DW$2416, DW_AT_decl_column(0x05)
$C$DW$2417 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_DUAL_UPDATE"), DW_AT_const_value(0x1502)
.dwattr $C$DW$2417, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2417, DW_AT_decl_line(0x77)
.dwattr $C$DW$2417, DW_AT_decl_column(0x05)
$C$DW$2418 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_DUPLEX_UPDATE"), DW_AT_const_value(0x1503)
.dwattr $C$DW$2418, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2418, DW_AT_decl_line(0x78)
.dwattr $C$DW$2418, DW_AT_decl_column(0x05)
$C$DW$2419 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_DIAG_MEMORY"), DW_AT_const_value(0x1600)
.dwattr $C$DW$2419, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2419, DW_AT_decl_line(0x7a)
.dwattr $C$DW$2419, DW_AT_decl_column(0x02)
$C$DW$2420 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_LOOPBACK"), DW_AT_const_value(0x1601)
.dwattr $C$DW$2420, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2420, DW_AT_decl_line(0x7b)
.dwattr $C$DW$2420, DW_AT_decl_column(0x02)
$C$DW$2421 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_EDMA_PEEK"), DW_AT_const_value(0x1602)
.dwattr $C$DW$2421, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2421, DW_AT_decl_line(0x7c)
.dwattr $C$DW$2421, DW_AT_decl_column(0x05)
$C$DW$2422 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_EDMA_POKE"), DW_AT_const_value(0x1603)
.dwattr $C$DW$2422, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2422, DW_AT_decl_line(0x7d)
.dwattr $C$DW$2422, DW_AT_decl_column(0x02)
$C$DW$2423 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_AMMLINE_UPDATE"), DW_AT_const_value(0x1604)
.dwattr $C$DW$2423, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2423, DW_AT_decl_line(0x7f)
.dwattr $C$DW$2423, DW_AT_decl_column(0x05)
$C$DW$2424 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_NRT_EOL"), DW_AT_const_value(0x2000)
.dwattr $C$DW$2424, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2424, DW_AT_decl_line(0x81)
.dwattr $C$DW$2424, DW_AT_decl_column(0x05)
$C$DW$2425 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBCMD_EOL"), DW_AT_const_value(0xffff)
.dwattr $C$DW$2425, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2425, DW_AT_decl_line(0x83)
.dwattr $C$DW$2425, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$450
.dwattr $C$DW$T$450, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$450, DW_AT_decl_line(0x40)
.dwattr $C$DW$T$450, DW_AT_decl_column(0x01)
$C$DW$T$451 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_SubCommand")
.dwattr $C$DW$T$451, DW_AT_type(*$C$DW$T$450)
.dwattr $C$DW$T$451, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$451, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$451, DW_AT_decl_line(0x84)
.dwattr $C$DW$T$451, DW_AT_decl_column(0x03)
$C$DW$T$1424 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1424, DW_AT_name("SpDsp_TraceBuf")
.dwattr $C$DW$T$1424, DW_AT_byte_size(0x1888)
$C$DW$2426 .dwtag DW_TAG_member
.dwattr $C$DW$2426, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2426, DW_AT_name("curIdx")
.dwattr $C$DW$2426, DW_AT_TI_symbol_name("curIdx")
.dwattr $C$DW$2426, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2426, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2426, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2426, DW_AT_decl_line(0x5db)
.dwattr $C$DW$2426, DW_AT_decl_column(0x05)
$C$DW$2427 .dwtag DW_TAG_member
.dwattr $C$DW$2427, DW_AT_type(*$C$DW$T$1419)
.dwattr $C$DW$2427, DW_AT_name("entries")
.dwattr $C$DW$2427, DW_AT_TI_symbol_name("entries")
.dwattr $C$DW$2427, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2427, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2427, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2427, DW_AT_decl_line(0x5dc)
.dwattr $C$DW$2427, DW_AT_decl_column(0x05)
$C$DW$2428 .dwtag DW_TAG_member
.dwattr $C$DW$2428, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2428, DW_AT_name("reserved")
.dwattr $C$DW$2428, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2428, DW_AT_data_member_location[DW_OP_plus_uconst 0x1808]
.dwattr $C$DW$2428, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2428, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2428, DW_AT_decl_line(0x5dd)
.dwattr $C$DW$2428, DW_AT_decl_column(0x05)
$C$DW$138 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$138, DW_AT_declaration
.dwattr $C$DW$138, DW_AT_TI_symbol_name("_ZN14SpDsp_TraceBufaSERKS_")
.dwattr $C$DW$138, DW_AT_type(*$C$DW$T$1420)
.dwattr $C$DW$138, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2429 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2429, DW_AT_type(*$C$DW$T$1422)
.dwendtag $C$DW$138
.dwendtag $C$DW$T$1424
.dwattr $C$DW$T$1424, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1424, DW_AT_decl_line(0x5da)
.dwattr $C$DW$T$1424, DW_AT_decl_column(0x01)
$C$DW$T$1289 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_TraceBuf")
.dwattr $C$DW$T$1289, DW_AT_type(*$C$DW$T$1424)
.dwattr $C$DW$T$1289, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1289, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1289, DW_AT_decl_line(0x5de)
.dwattr $C$DW$T$1289, DW_AT_decl_column(0x03)
$C$DW$T$1421 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1421, DW_AT_type(*$C$DW$T$1424)
$C$DW$T$1422 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1422, DW_AT_type(*$C$DW$T$1421)
.dwattr $C$DW$T$1422, DW_AT_address_class(0x20)
$C$DW$T$1420 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1420, DW_AT_type(*$C$DW$T$1424)
.dwattr $C$DW$T$1420, DW_AT_address_class(0x20)
$C$DW$T$1423 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1423, DW_AT_type(*$C$DW$T$1420)
.dwattr $C$DW$T$1423, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2430 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2430, DW_AT_type(*$C$DW$T$1422)
.dwendtag $C$DW$T$1423
$C$DW$T$1430 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1430, DW_AT_name("SpDsp_TraceEntry")
.dwattr $C$DW$T$1430, DW_AT_byte_size(0xc0)
$C$DW$2431 .dwtag DW_TAG_member
.dwattr $C$DW$2431, DW_AT_type(*$C$DW$T$1425)
.dwattr $C$DW$2431, DW_AT_name("states")
.dwattr $C$DW$2431, DW_AT_TI_symbol_name("states")
.dwattr $C$DW$2431, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2431, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2431, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2431, DW_AT_decl_line(0x5cd)
.dwattr $C$DW$2431, DW_AT_decl_column(0x05)
$C$DW$2432 .dwtag DW_TAG_member
.dwattr $C$DW$2432, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2432, DW_AT_name("pendingCineCount")
.dwattr $C$DW$2432, DW_AT_TI_symbol_name("pendingCineCount")
.dwattr $C$DW$2432, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2432, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2432, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2432, DW_AT_decl_line(0x5ce)
.dwattr $C$DW$2432, DW_AT_decl_column(0x05)
$C$DW$2433 .dwtag DW_TAG_member
.dwattr $C$DW$2433, DW_AT_type(*$C$DW$T$1356)
.dwattr $C$DW$2433, DW_AT_name("activeFov")
.dwattr $C$DW$2433, DW_AT_TI_symbol_name("activeFov")
.dwattr $C$DW$2433, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2433, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2433, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2433, DW_AT_decl_line(0x5d1)
.dwattr $C$DW$2433, DW_AT_decl_column(0x05)
$C$DW$2434 .dwtag DW_TAG_member
.dwattr $C$DW$2434, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2434, DW_AT_name("cmd_subCmd")
.dwattr $C$DW$2434, DW_AT_TI_symbol_name("cmd_subCmd")
.dwattr $C$DW$2434, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2434, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2434, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2434, DW_AT_decl_line(0x5d2)
.dwattr $C$DW$2434, DW_AT_decl_column(0x05)
$C$DW$2435 .dwtag DW_TAG_member
.dwattr $C$DW$2435, DW_AT_type(*$C$DW$T$1365)
.dwattr $C$DW$2435, DW_AT_name("semaphore")
.dwattr $C$DW$2435, DW_AT_TI_symbol_name("semaphore")
.dwattr $C$DW$2435, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2435, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2435, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2435, DW_AT_decl_line(0x5d3)
.dwattr $C$DW$2435, DW_AT_decl_column(0x05)
$C$DW$2436 .dwtag DW_TAG_member
.dwattr $C$DW$2436, DW_AT_type(*$C$DW$T$1353)
.dwattr $C$DW$2436, DW_AT_name("spDataParams")
.dwattr $C$DW$2436, DW_AT_TI_symbol_name("spDataParams")
.dwattr $C$DW$2436, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2436, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2436, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2436, DW_AT_decl_line(0x5d4)
.dwattr $C$DW$2436, DW_AT_decl_column(0x05)
$C$DW$2437 .dwtag DW_TAG_member
.dwattr $C$DW$2437, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2437, DW_AT_name("reserved")
.dwattr $C$DW$2437, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2437, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$2437, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2437, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2437, DW_AT_decl_line(0x5d6)
.dwattr $C$DW$2437, DW_AT_decl_column(0x05)
$C$DW$139 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$139, DW_AT_declaration
.dwattr $C$DW$139, DW_AT_TI_symbol_name("_ZN16SpDsp_TraceEntryaSERKS_")
.dwattr $C$DW$139, DW_AT_type(*$C$DW$T$1426)
.dwattr $C$DW$139, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2438 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2438, DW_AT_type(*$C$DW$T$1428)
.dwendtag $C$DW$139
.dwendtag $C$DW$T$1430
.dwattr $C$DW$T$1430, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1430, DW_AT_decl_line(0x5cb)
.dwattr $C$DW$T$1430, DW_AT_decl_column(0x01)
$C$DW$T$1418 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_TraceEntry")
.dwattr $C$DW$T$1418, DW_AT_type(*$C$DW$T$1430)
.dwattr $C$DW$T$1418, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1418, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1418, DW_AT_decl_line(0x5d7)
.dwattr $C$DW$T$1418, DW_AT_decl_column(0x03)
$C$DW$T$1419 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1419, DW_AT_type(*$C$DW$T$1418)
.dwattr $C$DW$T$1419, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1419, DW_AT_byte_size(0x1800)
$C$DW$2439 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2439, DW_AT_upper_bound(0x1f)
.dwendtag $C$DW$T$1419
$C$DW$T$1427 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1427, DW_AT_type(*$C$DW$T$1430)
$C$DW$T$1428 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1428, DW_AT_type(*$C$DW$T$1427)
.dwattr $C$DW$T$1428, DW_AT_address_class(0x20)
$C$DW$T$1426 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1426, DW_AT_type(*$C$DW$T$1430)
.dwattr $C$DW$T$1426, DW_AT_address_class(0x20)
$C$DW$T$1429 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1429, DW_AT_type(*$C$DW$T$1426)
.dwattr $C$DW$T$1429, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2440 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2440, DW_AT_type(*$C$DW$T$1428)
.dwendtag $C$DW$T$1429
$C$DW$T$1436 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$1436, DW_AT_name("SpDsp_TraceState")
.dwattr $C$DW$T$1436, DW_AT_byte_size(0x04)
$C$DW$2441 .dwtag DW_TAG_member
.dwattr $C$DW$2441, DW_AT_type(*$C$DW$T$1431)
.dwattr $C$DW$2441, DW_AT_name("mask")
.dwattr $C$DW$2441, DW_AT_TI_symbol_name("mask")
.dwattr $C$DW$2441, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2441, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2441, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2441, DW_AT_decl_line(0x5c6)
.dwattr $C$DW$2441, DW_AT_decl_column(0x1d)
$C$DW$2442 .dwtag DW_TAG_member
.dwattr $C$DW$2442, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2442, DW_AT_name("word")
.dwattr $C$DW$2442, DW_AT_TI_symbol_name("word")
.dwattr $C$DW$2442, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2442, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2442, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2442, DW_AT_decl_line(0x5c7)
.dwattr $C$DW$2442, DW_AT_decl_column(0x1d)
$C$DW$140 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$140, DW_AT_declaration
.dwattr $C$DW$140, DW_AT_TI_symbol_name("_ZN16SpDsp_TraceStateaSERKS_")
.dwattr $C$DW$140, DW_AT_type(*$C$DW$T$1432)
.dwattr $C$DW$140, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2443 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2443, DW_AT_type(*$C$DW$T$1434)
.dwendtag $C$DW$140
.dwendtag $C$DW$T$1436
.dwattr $C$DW$T$1436, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1436, DW_AT_decl_line(0x5c5)
.dwattr $C$DW$T$1436, DW_AT_decl_column(0x01)
$C$DW$T$1425 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_TraceState")
.dwattr $C$DW$T$1425, DW_AT_type(*$C$DW$T$1436)
.dwattr $C$DW$T$1425, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1425, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1425, DW_AT_decl_line(0x5c8)
.dwattr $C$DW$T$1425, DW_AT_decl_column(0x03)
$C$DW$T$1433 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1433, DW_AT_type(*$C$DW$T$1436)
$C$DW$T$1434 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1434, DW_AT_type(*$C$DW$T$1433)
.dwattr $C$DW$T$1434, DW_AT_address_class(0x20)
$C$DW$T$1432 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1432, DW_AT_type(*$C$DW$T$1436)
.dwattr $C$DW$T$1432, DW_AT_address_class(0x20)
$C$DW$T$1435 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1435, DW_AT_type(*$C$DW$T$1432)
.dwattr $C$DW$T$1435, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2444 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2444, DW_AT_type(*$C$DW$T$1434)
.dwendtag $C$DW$T$1435
$C$DW$T$1441 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1441, DW_AT_name("SpDsp_TraceStateBitMask")
.dwattr $C$DW$T$1441, DW_AT_byte_size(0x04)
$C$DW$2445 .dwtag DW_TAG_member
.dwattr $C$DW$2445, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2445, DW_AT_name("dsp")
.dwattr $C$DW$2445, DW_AT_TI_symbol_name("dsp")
.dwattr $C$DW$2445, DW_AT_bit_offset(0x18), DW_AT_bit_size(0x08)
.dwattr $C$DW$2445, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2445, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2445, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2445, DW_AT_decl_line(0x5be)
.dwattr $C$DW$2445, DW_AT_decl_column(0x09)
$C$DW$2446 .dwtag DW_TAG_member
.dwattr $C$DW$2446, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2446, DW_AT_name("framework")
.dwattr $C$DW$2446, DW_AT_TI_symbol_name("framework")
.dwattr $C$DW$2446, DW_AT_bit_offset(0x10), DW_AT_bit_size(0x08)
.dwattr $C$DW$2446, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2446, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2446, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2446, DW_AT_decl_line(0x5bf)
.dwattr $C$DW$2446, DW_AT_decl_column(0x09)
$C$DW$2447 .dwtag DW_TAG_member
.dwattr $C$DW$2447, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2447, DW_AT_name("mainCtlr")
.dwattr $C$DW$2447, DW_AT_TI_symbol_name("mainCtlr")
.dwattr $C$DW$2447, DW_AT_bit_offset(0x08), DW_AT_bit_size(0x08)
.dwattr $C$DW$2447, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2447, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2447, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2447, DW_AT_decl_line(0x5c0)
.dwattr $C$DW$2447, DW_AT_decl_column(0x09)
$C$DW$2448 .dwtag DW_TAG_member
.dwattr $C$DW$2448, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2448, DW_AT_name("mainCtlSem")
.dwattr $C$DW$2448, DW_AT_TI_symbol_name("mainCtlSem")
.dwattr $C$DW$2448, DW_AT_bit_offset(0x00), DW_AT_bit_size(0x08)
.dwattr $C$DW$2448, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2448, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2448, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2448, DW_AT_decl_line(0x5c1)
.dwattr $C$DW$2448, DW_AT_decl_column(0x09)
$C$DW$141 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$141, DW_AT_declaration
.dwattr $C$DW$141, DW_AT_TI_symbol_name("_ZN23SpDsp_TraceStateBitMaskaSERKS_")
.dwattr $C$DW$141, DW_AT_type(*$C$DW$T$1437)
.dwattr $C$DW$141, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2449 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2449, DW_AT_type(*$C$DW$T$1439)
.dwendtag $C$DW$141
.dwendtag $C$DW$T$1441
.dwattr $C$DW$T$1441, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1441, DW_AT_decl_line(0x5bd)
.dwattr $C$DW$T$1441, DW_AT_decl_column(0x01)
$C$DW$T$1431 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_TraceStateBitMask")
.dwattr $C$DW$T$1431, DW_AT_type(*$C$DW$T$1441)
.dwattr $C$DW$T$1431, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1431, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1431, DW_AT_decl_line(0x5c2)
.dwattr $C$DW$T$1431, DW_AT_decl_column(0x03)
$C$DW$T$1438 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1438, DW_AT_type(*$C$DW$T$1441)
$C$DW$T$1439 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1439, DW_AT_type(*$C$DW$T$1438)
.dwattr $C$DW$T$1439, DW_AT_address_class(0x20)
$C$DW$T$1437 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1437, DW_AT_type(*$C$DW$T$1441)
.dwattr $C$DW$T$1437, DW_AT_address_class(0x20)
$C$DW$T$1440 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1440, DW_AT_type(*$C$DW$T$1437)
.dwattr $C$DW$T$1440, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2450 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2450, DW_AT_type(*$C$DW$T$1439)
.dwendtag $C$DW$T$1440
$C$DW$T$462 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$462, DW_AT_name("SpDsp_Zoom")
.dwattr $C$DW$T$462, DW_AT_byte_size(0x04)
$C$DW$2451 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_ZOOM_DISABLED"), DW_AT_const_value(0x00)
.dwattr $C$DW$2451, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2451, DW_AT_decl_line(0x170)
.dwattr $C$DW$2451, DW_AT_decl_column(0x05)
$C$DW$2452 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_ZOOM_ENABLED"), DW_AT_const_value(0x01)
.dwattr $C$DW$2452, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2452, DW_AT_decl_line(0x171)
.dwattr $C$DW$2452, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$462
.dwattr $C$DW$T$462, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$462, DW_AT_decl_line(0x16f)
.dwattr $C$DW$T$462, DW_AT_decl_column(0x01)
$C$DW$T$463 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_Zoom")
.dwattr $C$DW$T$463, DW_AT_type(*$C$DW$T$462)
.dwattr $C$DW$T$463, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$463, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$463, DW_AT_decl_line(0x172)
.dwattr $C$DW$T$463, DW_AT_decl_column(0x02)
$C$DW$T$1180 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1180, DW_AT_name("SpDsp_color_SubMode")
.dwattr $C$DW$T$1180, DW_AT_byte_size(0x04)
$C$DW$2453 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_COLOR_CVD"), DW_AT_const_value(0x00)
.dwattr $C$DW$2453, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2453, DW_AT_decl_line(0xd1)
.dwattr $C$DW$2453, DW_AT_decl_column(0x07)
$C$DW$2454 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_COLOR_CPD"), DW_AT_const_value(0x01)
.dwattr $C$DW$2454, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2454, DW_AT_decl_line(0xd2)
.dwattr $C$DW$2454, DW_AT_decl_column(0x07)
$C$DW$2455 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_COLOR_EOL"), DW_AT_const_value(0x02)
.dwattr $C$DW$2455, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2455, DW_AT_decl_line(0xd3)
.dwattr $C$DW$2455, DW_AT_decl_column(0x07)
.dwendtag $C$DW$T$1180
.dwattr $C$DW$T$1180, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1180, DW_AT_decl_line(0xd0)
.dwattr $C$DW$T$1180, DW_AT_decl_column(0x01)
$C$DW$T$1181 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_color_SubMode")
.dwattr $C$DW$T$1181, DW_AT_type(*$C$DW$T$1180)
.dwattr $C$DW$T$1181, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1181, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1181, DW_AT_decl_line(0xd4)
.dwattr $C$DW$T$1181, DW_AT_decl_column(0x03)
$C$DW$T$1260 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1260, DW_AT_name("SpDsp_doppler_SubMode")
.dwattr $C$DW$T$1260, DW_AT_byte_size(0x04)
$C$DW$2456 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_DOPPLER_PW"), DW_AT_const_value(0x00)
.dwattr $C$DW$2456, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2456, DW_AT_decl_line(0xd9)
.dwattr $C$DW$2456, DW_AT_decl_column(0x07)
$C$DW$2457 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_DOPPLER_CW"), DW_AT_const_value(0x01)
.dwattr $C$DW$2457, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2457, DW_AT_decl_line(0xda)
.dwattr $C$DW$2457, DW_AT_decl_column(0x07)
$C$DW$2458 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_DOPPLER_EOL"), DW_AT_const_value(0x02)
.dwattr $C$DW$2458, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2458, DW_AT_decl_line(0xdb)
.dwattr $C$DW$2458, DW_AT_decl_column(0x07)
.dwendtag $C$DW$T$1260
.dwattr $C$DW$T$1260, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1260, DW_AT_decl_line(0xd8)
.dwattr $C$DW$T$1260, DW_AT_decl_column(0x01)
$C$DW$T$1261 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_doppler_SubMode")
.dwattr $C$DW$T$1261, DW_AT_type(*$C$DW$T$1260)
.dwattr $C$DW$T$1261, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1261, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1261, DW_AT_decl_line(0xdc)
.dwattr $C$DW$T$1261, DW_AT_decl_column(0x03)
$C$DW$T$1577 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1577, DW_AT_name("SpDsp_twod_SubMode")
.dwattr $C$DW$T$1577, DW_AT_byte_size(0x04)
$C$DW$2459 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_TWOD_PASSTHROUGH"), DW_AT_const_value(0x00)
.dwattr $C$DW$2459, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2459, DW_AT_decl_line(0xbe)
.dwattr $C$DW$2459, DW_AT_decl_column(0x05)
$C$DW$2460 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_TWOD_NEEDLEVIS"), DW_AT_const_value(0x01)
.dwattr $C$DW$2460, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2460, DW_AT_decl_line(0xbf)
.dwattr $C$DW$2460, DW_AT_decl_column(0x05)
$C$DW$2461 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_TWOD_SONORES"), DW_AT_const_value(0x02)
.dwattr $C$DW$2461, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2461, DW_AT_decl_line(0xc0)
.dwattr $C$DW$2461, DW_AT_decl_column(0x05)
$C$DW$2462 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_TWOD_MULTIBEAMwSONORES"), DW_AT_const_value(0x03)
.dwattr $C$DW$2462, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2462, DW_AT_decl_line(0xc1)
.dwattr $C$DW$2462, DW_AT_decl_column(0x05)
$C$DW$2463 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SUBMODE_TWOD_EOL"), DW_AT_const_value(0x04)
.dwattr $C$DW$2463, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2463, DW_AT_decl_line(0xc2)
.dwattr $C$DW$2463, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1577
.dwattr $C$DW$T$1577, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1577, DW_AT_decl_line(0xbd)
.dwattr $C$DW$T$1577, DW_AT_decl_column(0x01)
$C$DW$T$1578 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_twod_SubMode")
.dwattr $C$DW$T$1578, DW_AT_type(*$C$DW$T$1577)
.dwattr $C$DW$T$1578, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1578, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1578, DW_AT_decl_line(0xc3)
.dwattr $C$DW$T$1578, DW_AT_decl_column(0x03)
$C$DW$T$1500 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1500, DW_AT_name("StartMsg")
.dwattr $C$DW$T$1500, DW_AT_byte_size(0x18)
$C$DW$2464 .dwtag DW_TAG_member
.dwattr $C$DW$2464, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$2464, DW_AT_name("timeStarted")
.dwattr $C$DW$2464, DW_AT_TI_symbol_name("timeStarted")
.dwattr $C$DW$2464, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2464, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2464, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2464, DW_AT_decl_line(0x86)
.dwattr $C$DW$2464, DW_AT_decl_column(0x19)
$C$DW$2465 .dwtag DW_TAG_member
.dwattr $C$DW$2465, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$2465, DW_AT_name("timeEnded")
.dwattr $C$DW$2465, DW_AT_TI_symbol_name("timeEnded")
.dwattr $C$DW$2465, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2465, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2465, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2465, DW_AT_decl_line(0x87)
.dwattr $C$DW$2465, DW_AT_decl_column(0x19)
$C$DW$2466 .dwtag DW_TAG_member
.dwattr $C$DW$2466, DW_AT_type(*$C$DW$T$508)
.dwattr $C$DW$2466, DW_AT_name("coreId")
.dwattr $C$DW$2466, DW_AT_TI_symbol_name("coreId")
.dwattr $C$DW$2466, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2466, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2466, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2466, DW_AT_decl_line(0x88)
.dwattr $C$DW$2466, DW_AT_decl_column(0x19)
$C$DW$142 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$142, DW_AT_declaration
.dwattr $C$DW$142, DW_AT_TI_symbol_name("_ZN8StartMsgaSERKS_")
.dwattr $C$DW$142, DW_AT_type(*$C$DW$T$1496)
.dwattr $C$DW$142, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2467 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2467, DW_AT_type(*$C$DW$T$1498)
.dwendtag $C$DW$142
.dwendtag $C$DW$T$1500
.dwattr $C$DW$T$1500, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1500, DW_AT_decl_line(0x85)
.dwattr $C$DW$T$1500, DW_AT_decl_column(0x01)
$C$DW$T$1474 .dwtag DW_TAG_typedef, DW_AT_name("StartMsg")
.dwattr $C$DW$T$1474, DW_AT_type(*$C$DW$T$1500)
.dwattr $C$DW$T$1474, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1474, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1474, DW_AT_decl_line(0x89)
.dwattr $C$DW$T$1474, DW_AT_decl_column(0x03)
$C$DW$T$1497 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1497, DW_AT_type(*$C$DW$T$1500)
$C$DW$T$1498 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1498, DW_AT_type(*$C$DW$T$1497)
.dwattr $C$DW$T$1498, DW_AT_address_class(0x20)
$C$DW$T$1496 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1496, DW_AT_type(*$C$DW$T$1500)
.dwattr $C$DW$T$1496, DW_AT_address_class(0x20)
$C$DW$T$1499 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1499, DW_AT_type(*$C$DW$T$1496)
.dwattr $C$DW$T$1499, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2468 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2468, DW_AT_type(*$C$DW$T$1498)
.dwendtag $C$DW$T$1499
$C$DW$T$1508 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1508, DW_AT_name("SteerAngle_Param")
.dwattr $C$DW$T$1508, DW_AT_byte_size(0x108)
$C$DW$2469 .dwtag DW_TAG_member
.dwattr $C$DW$2469, DW_AT_type(*$C$DW$T$1501)
.dwattr $C$DW$2469, DW_AT_name("decimation")
.dwattr $C$DW$2469, DW_AT_TI_symbol_name("decimation")
.dwattr $C$DW$2469, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2469, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2469, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2469, DW_AT_decl_line(0x2b5)
.dwattr $C$DW$2469, DW_AT_decl_column(0x05)
$C$DW$2470 .dwtag DW_TAG_member
.dwattr $C$DW$2470, DW_AT_type(*$C$DW$T$1502)
.dwattr $C$DW$2470, DW_AT_name("steerAngle")
.dwattr $C$DW$2470, DW_AT_TI_symbol_name("steerAngle")
.dwattr $C$DW$2470, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2470, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2470, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2470, DW_AT_decl_line(0x2b6)
.dwattr $C$DW$2470, DW_AT_decl_column(0x05)
$C$DW$2471 .dwtag DW_TAG_member
.dwattr $C$DW$2471, DW_AT_type(*$C$DW$T$1503)
.dwattr $C$DW$2471, DW_AT_name("inpEstimatesPerLine")
.dwattr $C$DW$2471, DW_AT_TI_symbol_name("inpEstimatesPerLine")
.dwattr $C$DW$2471, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$2471, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2471, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2471, DW_AT_decl_line(0x2b7)
.dwattr $C$DW$2471, DW_AT_decl_column(0x05)
$C$DW$2472 .dwtag DW_TAG_member
.dwattr $C$DW$2472, DW_AT_type(*$C$DW$T$1503)
.dwattr $C$DW$2472, DW_AT_name("inStartRayIdx")
.dwattr $C$DW$2472, DW_AT_TI_symbol_name("inStartRayIdx")
.dwattr $C$DW$2472, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$2472, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2472, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2472, DW_AT_decl_line(0x2b8)
.dwattr $C$DW$2472, DW_AT_decl_column(0x02)
$C$DW$2473 .dwtag DW_TAG_member
.dwattr $C$DW$2473, DW_AT_type(*$C$DW$T$1503)
.dwattr $C$DW$2473, DW_AT_name("numLinesPerFrame")
.dwattr $C$DW$2473, DW_AT_TI_symbol_name("numLinesPerFrame")
.dwattr $C$DW$2473, DW_AT_data_member_location[DW_OP_plus_uconst 0x70]
.dwattr $C$DW$2473, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2473, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2473, DW_AT_decl_line(0x2b9)
.dwattr $C$DW$2473, DW_AT_decl_column(0x02)
$C$DW$2474 .dwtag DW_TAG_member
.dwattr $C$DW$2474, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2474, DW_AT_name("reserved")
.dwattr $C$DW$2474, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2474, DW_AT_data_member_location[DW_OP_plus_uconst 0x88]
.dwattr $C$DW$2474, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2474, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2474, DW_AT_decl_line(0x2ba)
.dwattr $C$DW$2474, DW_AT_decl_column(0x05)
$C$DW$143 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$143, DW_AT_declaration
.dwattr $C$DW$143, DW_AT_TI_symbol_name("_ZN16SteerAngle_ParamaSERKS_")
.dwattr $C$DW$143, DW_AT_type(*$C$DW$T$1504)
.dwattr $C$DW$143, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2475 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2475, DW_AT_type(*$C$DW$T$1506)
.dwendtag $C$DW$143
.dwendtag $C$DW$T$1508
.dwattr $C$DW$T$1508, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1508, DW_AT_decl_line(0x2b4)
.dwattr $C$DW$T$1508, DW_AT_decl_column(0x01)
$C$DW$T$1505 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1505, DW_AT_type(*$C$DW$T$1508)
$C$DW$T$1506 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1506, DW_AT_type(*$C$DW$T$1505)
.dwattr $C$DW$T$1506, DW_AT_address_class(0x20)
$C$DW$T$1519 .dwtag DW_TAG_typedef, DW_AT_name("SteerAngle_Param")
.dwattr $C$DW$T$1519, DW_AT_type(*$C$DW$T$1508)
.dwattr $C$DW$T$1519, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1519, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1519, DW_AT_decl_line(0x2bb)
.dwattr $C$DW$T$1519, DW_AT_decl_column(0x03)
$C$DW$T$1504 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1504, DW_AT_type(*$C$DW$T$1508)
.dwattr $C$DW$T$1504, DW_AT_address_class(0x20)
$C$DW$T$1507 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1507, DW_AT_type(*$C$DW$T$1504)
.dwattr $C$DW$T$1507, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2476 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2476, DW_AT_type(*$C$DW$T$1506)
.dwendtag $C$DW$T$1507
$C$DW$T$1513 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1513, DW_AT_name("StopMsg")
.dwattr $C$DW$T$1513, DW_AT_byte_size(0x18)
$C$DW$2477 .dwtag DW_TAG_member
.dwattr $C$DW$2477, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$2477, DW_AT_name("timeStarted")
.dwattr $C$DW$2477, DW_AT_TI_symbol_name("timeStarted")
.dwattr $C$DW$2477, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2477, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2477, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2477, DW_AT_decl_line(0x8e)
.dwattr $C$DW$2477, DW_AT_decl_column(0x19)
$C$DW$2478 .dwtag DW_TAG_member
.dwattr $C$DW$2478, DW_AT_type(*$C$DW$T$492)
.dwattr $C$DW$2478, DW_AT_name("timeEnded")
.dwattr $C$DW$2478, DW_AT_TI_symbol_name("timeEnded")
.dwattr $C$DW$2478, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2478, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2478, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2478, DW_AT_decl_line(0x8f)
.dwattr $C$DW$2478, DW_AT_decl_column(0x19)
$C$DW$2479 .dwtag DW_TAG_member
.dwattr $C$DW$2479, DW_AT_type(*$C$DW$T$508)
.dwattr $C$DW$2479, DW_AT_name("coreId")
.dwattr $C$DW$2479, DW_AT_TI_symbol_name("coreId")
.dwattr $C$DW$2479, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2479, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2479, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2479, DW_AT_decl_line(0x90)
.dwattr $C$DW$2479, DW_AT_decl_column(0x19)
$C$DW$144 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$144, DW_AT_declaration
.dwattr $C$DW$144, DW_AT_TI_symbol_name("_ZN7StopMsgaSERKS_")
.dwattr $C$DW$144, DW_AT_type(*$C$DW$T$1509)
.dwattr $C$DW$144, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2480 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2480, DW_AT_type(*$C$DW$T$1511)
.dwendtag $C$DW$144
.dwendtag $C$DW$T$1513
.dwattr $C$DW$T$1513, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1513, DW_AT_decl_line(0x8d)
.dwattr $C$DW$T$1513, DW_AT_decl_column(0x01)
$C$DW$T$1475 .dwtag DW_TAG_typedef, DW_AT_name("StopMsg")
.dwattr $C$DW$T$1475, DW_AT_type(*$C$DW$T$1513)
.dwattr $C$DW$T$1475, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1475, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1475, DW_AT_decl_line(0x91)
.dwattr $C$DW$T$1475, DW_AT_decl_column(0x03)
$C$DW$T$1510 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1510, DW_AT_type(*$C$DW$T$1513)
$C$DW$T$1511 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1511, DW_AT_type(*$C$DW$T$1510)
.dwattr $C$DW$T$1511, DW_AT_address_class(0x20)
$C$DW$T$1509 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1509, DW_AT_type(*$C$DW$T$1513)
.dwattr $C$DW$T$1509, DW_AT_address_class(0x20)
$C$DW$T$1512 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1512, DW_AT_type(*$C$DW$T$1509)
.dwattr $C$DW$T$1512, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2481 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2481, DW_AT_type(*$C$DW$T$1511)
.dwendtag $C$DW$T$1512
$C$DW$T$362 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$362, DW_AT_name("TaskIDType")
.dwattr $C$DW$T$362, DW_AT_byte_size(0x04)
$C$DW$2482 .dwtag DW_TAG_enumerator, DW_AT_name("TASKID_INPUTMGR"), DW_AT_const_value(0x00)
.dwattr $C$DW$2482, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2482, DW_AT_decl_line(0x53)
.dwattr $C$DW$2482, DW_AT_decl_column(0x05)
$C$DW$2483 .dwtag DW_TAG_enumerator, DW_AT_name("TASKID_OUTPUTMGR"), DW_AT_const_value(0x01)
.dwattr $C$DW$2483, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2483, DW_AT_decl_line(0x54)
.dwattr $C$DW$2483, DW_AT_decl_column(0x05)
$C$DW$2484 .dwtag DW_TAG_enumerator, DW_AT_name("TASKID_BOSS"), DW_AT_const_value(0x02)
.dwattr $C$DW$2484, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2484, DW_AT_decl_line(0x55)
.dwattr $C$DW$2484, DW_AT_decl_column(0x05)
$C$DW$2485 .dwtag DW_TAG_enumerator, DW_AT_name("TASKID_MAINCTLR"), DW_AT_const_value(0x03)
.dwattr $C$DW$2485, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2485, DW_AT_decl_line(0x56)
.dwattr $C$DW$2485, DW_AT_decl_column(0x05)
$C$DW$2486 .dwtag DW_TAG_enumerator, DW_AT_name("TASKID_EOL"), DW_AT_const_value(0x04)
.dwattr $C$DW$2486, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$2486, DW_AT_decl_line(0x57)
.dwattr $C$DW$2486, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$362
.dwattr $C$DW$T$362, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$362, DW_AT_decl_line(0x52)
.dwattr $C$DW$T$362, DW_AT_decl_column(0x01)
$C$DW$T$363 .dwtag DW_TAG_typedef, DW_AT_name("TaskIDType")
.dwattr $C$DW$T$363, DW_AT_type(*$C$DW$T$362)
.dwattr $C$DW$T$363, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$363, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$363, DW_AT_decl_line(0x58)
.dwattr $C$DW$T$363, DW_AT_decl_column(0x03)
$C$DW$T$1576 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1576, DW_AT_name("TwodBase_Param")
.dwattr $C$DW$T$1576, DW_AT_byte_size(0xe0)
$C$DW$2487 .dwtag DW_TAG_member
.dwattr $C$DW$2487, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2487, DW_AT_name("decimation0")
.dwattr $C$DW$2487, DW_AT_TI_symbol_name("decimation0")
.dwattr $C$DW$2487, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2487, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2487, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2487, DW_AT_decl_line(0x29c)
.dwattr $C$DW$2487, DW_AT_decl_column(0x05)
$C$DW$2488 .dwtag DW_TAG_member
.dwattr $C$DW$2488, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$2488, DW_AT_name("startRay0")
.dwattr $C$DW$2488, DW_AT_TI_symbol_name("startRay0")
.dwattr $C$DW$2488, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2488, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2488, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2488, DW_AT_decl_line(0x29d)
.dwattr $C$DW$2488, DW_AT_decl_column(0x02)
$C$DW$2489 .dwtag DW_TAG_member
.dwattr $C$DW$2489, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$2489, DW_AT_name("straightBeam_inpEstPerLine")
.dwattr $C$DW$2489, DW_AT_TI_symbol_name("straightBeam_inpEstPerLine")
.dwattr $C$DW$2489, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2489, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2489, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2489, DW_AT_decl_line(0x29e)
.dwattr $C$DW$2489, DW_AT_decl_column(0x05)
$C$DW$2490 .dwtag DW_TAG_member
.dwattr $C$DW$2490, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$2490, DW_AT_name("out_estimates_per_line")
.dwattr $C$DW$2490, DW_AT_TI_symbol_name("out_estimates_per_line")
.dwattr $C$DW$2490, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2490, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2490, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2490, DW_AT_decl_line(0x29f)
.dwattr $C$DW$2490, DW_AT_decl_column(0x05)
$C$DW$2491 .dwtag DW_TAG_member
.dwattr $C$DW$2491, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$2491, DW_AT_name("dspInputValidEsts")
.dwattr $C$DW$2491, DW_AT_TI_symbol_name("dspInputValidEsts")
.dwattr $C$DW$2491, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2491, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2491, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2491, DW_AT_decl_line(0x2a0)
.dwattr $C$DW$2491, DW_AT_decl_column(0x05)
$C$DW$2492 .dwtag DW_TAG_member
.dwattr $C$DW$2492, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$2492, DW_AT_name("inp_lines_per_frame")
.dwattr $C$DW$2492, DW_AT_TI_symbol_name("inp_lines_per_frame")
.dwattr $C$DW$2492, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2492, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2492, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2492, DW_AT_decl_line(0x2a1)
.dwattr $C$DW$2492, DW_AT_decl_column(0x05)
$C$DW$2493 .dwtag DW_TAG_member
.dwattr $C$DW$2493, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$2493, DW_AT_name("numMLs")
.dwattr $C$DW$2493, DW_AT_TI_symbol_name("numMLs")
.dwattr $C$DW$2493, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2493, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2493, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2493, DW_AT_decl_line(0x2a2)
.dwattr $C$DW$2493, DW_AT_decl_column(0x05)
$C$DW$2494 .dwtag DW_TAG_member
.dwattr $C$DW$2494, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$2494, DW_AT_name("persistenceFactor")
.dwattr $C$DW$2494, DW_AT_TI_symbol_name("persistenceFactor")
.dwattr $C$DW$2494, DW_AT_data_member_location[DW_OP_plus_uconst 0x38]
.dwattr $C$DW$2494, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2494, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2494, DW_AT_decl_line(0x2a3)
.dwattr $C$DW$2494, DW_AT_decl_column(0x05)
$C$DW$2495 .dwtag DW_TAG_member
.dwattr $C$DW$2495, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2495, DW_AT_name("firstAcquiredEstDepthMm")
.dwattr $C$DW$2495, DW_AT_TI_symbol_name("firstAcquiredEstDepthMm")
.dwattr $C$DW$2495, DW_AT_data_member_location[DW_OP_plus_uconst 0x40]
.dwattr $C$DW$2495, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2495, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2495, DW_AT_decl_line(0x2a4)
.dwattr $C$DW$2495, DW_AT_decl_column(0x05)
$C$DW$2496 .dwtag DW_TAG_member
.dwattr $C$DW$2496, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2496, DW_AT_name("displayRegionTopMm")
.dwattr $C$DW$2496, DW_AT_TI_symbol_name("displayRegionTopMm")
.dwattr $C$DW$2496, DW_AT_data_member_location[DW_OP_plus_uconst 0x48]
.dwattr $C$DW$2496, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2496, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2496, DW_AT_decl_line(0x2a5)
.dwattr $C$DW$2496, DW_AT_decl_column(0x05)
$C$DW$2497 .dwtag DW_TAG_member
.dwattr $C$DW$2497, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2497, DW_AT_name("displayRegionBottomMm")
.dwattr $C$DW$2497, DW_AT_TI_symbol_name("displayRegionBottomMm")
.dwattr $C$DW$2497, DW_AT_data_member_location[DW_OP_plus_uconst 0x50]
.dwattr $C$DW$2497, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2497, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2497, DW_AT_decl_line(0x2a6)
.dwattr $C$DW$2497, DW_AT_decl_column(0x05)
$C$DW$2498 .dwtag DW_TAG_member
.dwattr $C$DW$2498, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2498, DW_AT_name("mmPerEstActive")
.dwattr $C$DW$2498, DW_AT_TI_symbol_name("mmPerEstActive")
.dwattr $C$DW$2498, DW_AT_data_member_location[DW_OP_plus_uconst 0x58]
.dwattr $C$DW$2498, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2498, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2498, DW_AT_decl_line(0x2a7)
.dwattr $C$DW$2498, DW_AT_decl_column(0x05)
$C$DW$2499 .dwtag DW_TAG_member
.dwattr $C$DW$2499, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2499, DW_AT_name("reserved")
.dwattr $C$DW$2499, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2499, DW_AT_data_member_location[DW_OP_plus_uconst 0x60]
.dwattr $C$DW$2499, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2499, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2499, DW_AT_decl_line(0x2a8)
.dwattr $C$DW$2499, DW_AT_decl_column(0x05)
$C$DW$145 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$145, DW_AT_declaration
.dwattr $C$DW$145, DW_AT_TI_symbol_name("_ZN14TwodBase_ParamaSERKS_")
.dwattr $C$DW$145, DW_AT_type(*$C$DW$T$1572)
.dwattr $C$DW$145, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2500 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2500, DW_AT_type(*$C$DW$T$1574)
.dwendtag $C$DW$145
.dwendtag $C$DW$T$1576
.dwattr $C$DW$T$1576, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1576, DW_AT_decl_line(0x29b)
.dwattr $C$DW$T$1576, DW_AT_decl_column(0x01)
$C$DW$T$1573 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1573, DW_AT_type(*$C$DW$T$1576)
$C$DW$T$1574 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1574, DW_AT_type(*$C$DW$T$1573)
.dwattr $C$DW$T$1574, DW_AT_address_class(0x20)
$C$DW$T$1579 .dwtag DW_TAG_typedef, DW_AT_name("TwodBase_Param")
.dwattr $C$DW$T$1579, DW_AT_type(*$C$DW$T$1576)
.dwattr $C$DW$T$1579, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1579, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1579, DW_AT_decl_line(0x2a9)
.dwattr $C$DW$T$1579, DW_AT_decl_column(0x03)
$C$DW$T$1572 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1572, DW_AT_type(*$C$DW$T$1576)
.dwattr $C$DW$T$1572, DW_AT_address_class(0x20)
$C$DW$T$1575 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1575, DW_AT_type(*$C$DW$T$1572)
.dwattr $C$DW$T$1575, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2501 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2501, DW_AT_type(*$C$DW$T$1574)
.dwendtag $C$DW$T$1575
$C$DW$T$1589 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1589, DW_AT_name("Twod_Param")
.dwattr $C$DW$T$1589, DW_AT_byte_size(0x1ac0)
$C$DW$2502 .dwtag DW_TAG_member
.dwattr $C$DW$2502, DW_AT_type(*$C$DW$T$1578)
.dwattr $C$DW$2502, DW_AT_name("subMode")
.dwattr $C$DW$2502, DW_AT_TI_symbol_name("subMode")
.dwattr $C$DW$2502, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2502, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2502, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2502, DW_AT_decl_line(0x3d2)
.dwattr $C$DW$2502, DW_AT_decl_column(0x05)
$C$DW$2503 .dwtag DW_TAG_member
.dwattr $C$DW$2503, DW_AT_type(*$C$DW$T$1579)
.dwattr $C$DW$2503, DW_AT_name("baseParam")
.dwattr $C$DW$2503, DW_AT_TI_symbol_name("baseParam")
.dwattr $C$DW$2503, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2503, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2503, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2503, DW_AT_decl_line(0x3d3)
.dwattr $C$DW$2503, DW_AT_decl_column(0x05)
$C$DW$2504 .dwtag DW_TAG_member
.dwattr $C$DW$2504, DW_AT_type(*$C$DW$T$1580)
.dwattr $C$DW$2504, DW_AT_name("usConstants")
.dwattr $C$DW$2504, DW_AT_TI_symbol_name("usConstants")
.dwattr $C$DW$2504, DW_AT_data_member_location[DW_OP_plus_uconst 0xe8]
.dwattr $C$DW$2504, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2504, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2504, DW_AT_decl_line(0x3d4)
.dwattr $C$DW$2504, DW_AT_decl_column(0x05)
$C$DW$2505 .dwtag DW_TAG_member
.dwattr $C$DW$2505, DW_AT_type(*$C$DW$T$1581)
.dwattr $C$DW$2505, DW_AT_name("mbeam")
.dwattr $C$DW$2505, DW_AT_TI_symbol_name("mbeam")
.dwattr $C$DW$2505, DW_AT_data_member_location[DW_OP_plus_uconst 0x178]
.dwattr $C$DW$2505, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2505, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2505, DW_AT_decl_line(0x3d5)
.dwattr $C$DW$2505, DW_AT_decl_column(0x05)
$C$DW$2506 .dwtag DW_TAG_member
.dwattr $C$DW$2506, DW_AT_type(*$C$DW$T$1582)
.dwattr $C$DW$2506, DW_AT_name("bhf")
.dwattr $C$DW$2506, DW_AT_TI_symbol_name("bhf")
.dwattr $C$DW$2506, DW_AT_data_member_location[DW_OP_plus_uconst 0x348]
.dwattr $C$DW$2506, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2506, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2506, DW_AT_decl_line(0x3d6)
.dwattr $C$DW$2506, DW_AT_decl_column(0x05)
$C$DW$2507 .dwtag DW_TAG_member
.dwattr $C$DW$2507, DW_AT_type(*$C$DW$T$1202)
.dwattr $C$DW$2507, DW_AT_name("cvizbase")
.dwattr $C$DW$2507, DW_AT_TI_symbol_name("cvizbase")
.dwattr $C$DW$2507, DW_AT_data_member_location[DW_OP_plus_uconst 0x3d8]
.dwattr $C$DW$2507, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2507, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2507, DW_AT_decl_line(0x3d7)
.dwattr $C$DW$2507, DW_AT_decl_column(0x05)
$C$DW$2508 .dwtag DW_TAG_member
.dwattr $C$DW$2508, DW_AT_type(*$C$DW$T$1583)
.dwattr $C$DW$2508, DW_AT_name("cvizuser")
.dwattr $C$DW$2508, DW_AT_TI_symbol_name("cvizuser")
.dwattr $C$DW$2508, DW_AT_data_member_location[DW_OP_plus_uconst 0xff0]
.dwattr $C$DW$2508, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2508, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2508, DW_AT_decl_line(0x3d8)
.dwattr $C$DW$2508, DW_AT_decl_column(0x05)
$C$DW$2509 .dwtag DW_TAG_member
.dwattr $C$DW$2509, DW_AT_type(*$C$DW$T$1584)
.dwattr $C$DW$2509, DW_AT_name("autoGain")
.dwattr $C$DW$2509, DW_AT_TI_symbol_name("autoGain")
.dwattr $C$DW$2509, DW_AT_data_member_location[DW_OP_plus_uconst 0x1430]
.dwattr $C$DW$2509, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2509, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2509, DW_AT_decl_line(0x3d9)
.dwattr $C$DW$2509, DW_AT_decl_column(0x05)
$C$DW$2510 .dwtag DW_TAG_member
.dwattr $C$DW$2510, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2510, DW_AT_name("acqFrameRate")
.dwattr $C$DW$2510, DW_AT_TI_symbol_name("acqFrameRate")
.dwattr $C$DW$2510, DW_AT_data_member_location[DW_OP_plus_uconst 0x1630]
.dwattr $C$DW$2510, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2510, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2510, DW_AT_decl_line(0x3da)
.dwattr $C$DW$2510, DW_AT_decl_column(0x05)
$C$DW$2511 .dwtag DW_TAG_member
.dwattr $C$DW$2511, DW_AT_type(*$C$DW$T$168)
.dwattr $C$DW$2511, DW_AT_name("remapTable")
.dwattr $C$DW$2511, DW_AT_TI_symbol_name("remapTable")
.dwattr $C$DW$2511, DW_AT_data_member_location[DW_OP_plus_uconst 0x1638]
.dwattr $C$DW$2511, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2511, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2511, DW_AT_decl_line(0x3db)
.dwattr $C$DW$2511, DW_AT_decl_column(0x05)
$C$DW$2512 .dwtag DW_TAG_member
.dwattr $C$DW$2512, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2512, DW_AT_name("clksPerFrame")
.dwattr $C$DW$2512, DW_AT_TI_symbol_name("clksPerFrame")
.dwattr $C$DW$2512, DW_AT_data_member_location[DW_OP_plus_uconst 0x1a38]
.dwattr $C$DW$2512, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2512, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2512, DW_AT_decl_line(0x3dc)
.dwattr $C$DW$2512, DW_AT_decl_column(0x05)
$C$DW$2513 .dwtag DW_TAG_member
.dwattr $C$DW$2513, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2513, DW_AT_name("reserved")
.dwattr $C$DW$2513, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2513, DW_AT_data_member_location[DW_OP_plus_uconst 0x1a40]
.dwattr $C$DW$2513, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2513, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2513, DW_AT_decl_line(0x3e2)
.dwattr $C$DW$2513, DW_AT_decl_column(0x05)
$C$DW$146 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$146, DW_AT_declaration
.dwattr $C$DW$146, DW_AT_TI_symbol_name("_ZN10Twod_ParamaSERKS_")
.dwattr $C$DW$146, DW_AT_type(*$C$DW$T$1585)
.dwattr $C$DW$146, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2514 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2514, DW_AT_type(*$C$DW$T$1587)
.dwendtag $C$DW$146
.dwendtag $C$DW$T$1589
.dwattr $C$DW$T$1589, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1589, DW_AT_decl_line(0x3d1)
.dwattr $C$DW$T$1589, DW_AT_decl_column(0x01)
$C$DW$T$1586 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1586, DW_AT_type(*$C$DW$T$1589)
$C$DW$T$1587 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1587, DW_AT_type(*$C$DW$T$1586)
.dwattr $C$DW$T$1587, DW_AT_address_class(0x20)
$C$DW$T$2209 .dwtag DW_TAG_typedef, DW_AT_name("Twod_Param")
.dwattr $C$DW$T$2209, DW_AT_type(*$C$DW$T$1589)
.dwattr $C$DW$T$2209, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2209, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$2209, DW_AT_decl_line(0x3e3)
.dwattr $C$DW$T$2209, DW_AT_decl_column(0x03)
$C$DW$T$1585 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1585, DW_AT_type(*$C$DW$T$1589)
.dwattr $C$DW$T$1585, DW_AT_address_class(0x20)
$C$DW$T$1588 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1588, DW_AT_type(*$C$DW$T$1585)
.dwattr $C$DW$T$1588, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2515 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2515, DW_AT_type(*$C$DW$T$1587)
.dwendtag $C$DW$T$1588
$C$DW$T$157 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$157, DW_AT_name("UTI_Chapter")
.dwattr $C$DW$T$157, DW_AT_byte_size(0x50)
$C$DW$2516 .dwtag DW_TAG_member
.dwattr $C$DW$2516, DW_AT_type(*$C$DW$T$151)
.dwattr $C$DW$2516, DW_AT_name("chapterName")
.dwattr $C$DW$2516, DW_AT_TI_symbol_name("chapterName")
.dwattr $C$DW$2516, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2516, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2516, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$2516, DW_AT_decl_line(0x34)
.dwattr $C$DW$2516, DW_AT_decl_column(0x0a)
$C$DW$2517 .dwtag DW_TAG_member
.dwattr $C$DW$2517, DW_AT_type(*$C$DW$T$152)
.dwattr $C$DW$2517, DW_AT_name("additionalFields")
.dwattr $C$DW$2517, DW_AT_TI_symbol_name("additionalFields")
.dwattr $C$DW$2517, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2517, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2517, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$2517, DW_AT_decl_line(0x35)
.dwattr $C$DW$2517, DW_AT_decl_column(0x0c)
$C$DW$147 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$147, DW_AT_declaration
.dwattr $C$DW$147, DW_AT_TI_symbol_name("_ZN11UTI_ChapteraSERKS_")
.dwattr $C$DW$147, DW_AT_type(*$C$DW$T$153)
.dwattr $C$DW$147, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2518 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2518, DW_AT_type(*$C$DW$T$155)
.dwendtag $C$DW$147
.dwattr $C$DW$T$157, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$T$157, DW_AT_decl_line(0x33)
.dwattr $C$DW$T$157, DW_AT_decl_column(0x01)
$C$DW$T$154 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$154, DW_AT_type(*$C$DW$T$157)
$C$DW$T$155 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$155, DW_AT_type(*$C$DW$T$154)
.dwattr $C$DW$T$155, DW_AT_address_class(0x20)
$C$DW$T$159 .dwtag DW_TAG_typedef, DW_AT_name("UTI_Chapter")
.dwattr $C$DW$T$159, DW_AT_type(*$C$DW$T$157)
.dwattr $C$DW$T$159, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$159, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$T$159, DW_AT_decl_line(0x36)
.dwattr $C$DW$T$159, DW_AT_decl_column(0x03)
$C$DW$T$1479 .dwtag DW_TAG_typedef, DW_AT_name("UTIMsg")
.dwattr $C$DW$T$1479, DW_AT_type(*$C$DW$T$159)
.dwattr $C$DW$T$1479, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1479, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h")
.dwattr $C$DW$T$1479, DW_AT_decl_line(0xb0)
.dwattr $C$DW$T$1479, DW_AT_decl_column(0x15)
$C$DW$T$160 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$160, DW_AT_type(*$C$DW$T$159)
.dwattr $C$DW$T$160, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$160, DW_AT_byte_size(0xf00)
$C$DW$2519 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2519, DW_AT_upper_bound(0x2f)
.dwendtag $C$DW$T$160
$C$DW$T$153 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$153, DW_AT_type(*$C$DW$T$157)
.dwattr $C$DW$T$153, DW_AT_address_class(0x20)
$C$DW$T$156 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$156, DW_AT_type(*$C$DW$T$153)
.dwattr $C$DW$T$156, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2520 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2520, DW_AT_type(*$C$DW$T$155)
.dwendtag $C$DW$T$156
$C$DW$T$165 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$165, DW_AT_name("UTI_TableOfContents")
.dwattr $C$DW$T$165, DW_AT_byte_size(0xf38)
$C$DW$2521 .dwtag DW_TAG_member
.dwattr $C$DW$2521, DW_AT_type(*$C$DW$T$158)
.dwattr $C$DW$2521, DW_AT_name("dspVersionNumber")
.dwattr $C$DW$2521, DW_AT_TI_symbol_name("dspVersionNumber")
.dwattr $C$DW$2521, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2521, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2521, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$2521, DW_AT_decl_line(0x4a)
.dwattr $C$DW$2521, DW_AT_decl_column(0x1d)
$C$DW$2522 .dwtag DW_TAG_member
.dwattr $C$DW$2522, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2522, DW_AT_name("utiVersionNumber")
.dwattr $C$DW$2522, DW_AT_TI_symbol_name("utiVersionNumber")
.dwattr $C$DW$2522, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2522, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2522, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$2522, DW_AT_decl_line(0x4b)
.dwattr $C$DW$2522, DW_AT_decl_column(0x1d)
$C$DW$2523 .dwtag DW_TAG_member
.dwattr $C$DW$2523, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2523, DW_AT_name("numValidEntries")
.dwattr $C$DW$2523, DW_AT_TI_symbol_name("numValidEntries")
.dwattr $C$DW$2523, DW_AT_data_member_location[DW_OP_plus_uconst 0x24]
.dwattr $C$DW$2523, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2523, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$2523, DW_AT_decl_line(0x4c)
.dwattr $C$DW$2523, DW_AT_decl_column(0x1d)
$C$DW$2524 .dwtag DW_TAG_member
.dwattr $C$DW$2524, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2524, DW_AT_name("chapterLength")
.dwattr $C$DW$2524, DW_AT_TI_symbol_name("chapterLength")
.dwattr $C$DW$2524, DW_AT_data_member_location[DW_OP_plus_uconst 0x28]
.dwattr $C$DW$2524, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2524, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$2524, DW_AT_decl_line(0x4d)
.dwattr $C$DW$2524, DW_AT_decl_column(0x1d)
$C$DW$2525 .dwtag DW_TAG_member
.dwattr $C$DW$2525, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2525, DW_AT_name("chapterTitleCharLimit")
.dwattr $C$DW$2525, DW_AT_TI_symbol_name("chapterTitleCharLimit")
.dwattr $C$DW$2525, DW_AT_data_member_location[DW_OP_plus_uconst 0x2c]
.dwattr $C$DW$2525, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2525, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$2525, DW_AT_decl_line(0x4e)
.dwattr $C$DW$2525, DW_AT_decl_column(0x1d)
$C$DW$2526 .dwtag DW_TAG_member
.dwattr $C$DW$2526, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2526, DW_AT_name("endOfUTIParams")
.dwattr $C$DW$2526, DW_AT_TI_symbol_name("endOfUTIParams")
.dwattr $C$DW$2526, DW_AT_data_member_location[DW_OP_plus_uconst 0x30]
.dwattr $C$DW$2526, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2526, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$2526, DW_AT_decl_line(0x4f)
.dwattr $C$DW$2526, DW_AT_decl_column(0x1d)
$C$DW$2527 .dwtag DW_TAG_member
.dwattr $C$DW$2527, DW_AT_type(*$C$DW$T$160)
.dwattr $C$DW$2527, DW_AT_name("chapters")
.dwattr $C$DW$2527, DW_AT_TI_symbol_name("chapters")
.dwattr $C$DW$2527, DW_AT_data_member_location[DW_OP_plus_uconst 0x34]
.dwattr $C$DW$2527, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2527, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$2527, DW_AT_decl_line(0x50)
.dwattr $C$DW$2527, DW_AT_decl_column(0x1d)
$C$DW$2528 .dwtag DW_TAG_member
.dwattr $C$DW$2528, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2528, DW_AT_name("endOfUTI")
.dwattr $C$DW$2528, DW_AT_TI_symbol_name("endOfUTI")
.dwattr $C$DW$2528, DW_AT_data_member_location[DW_OP_plus_uconst 0xf34]
.dwattr $C$DW$2528, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2528, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$2528, DW_AT_decl_line(0x51)
.dwattr $C$DW$2528, DW_AT_decl_column(0x1d)
$C$DW$148 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$148, DW_AT_declaration
.dwattr $C$DW$148, DW_AT_TI_symbol_name("_ZN19UTI_TableOfContentsaSERKS_")
.dwattr $C$DW$148, DW_AT_type(*$C$DW$T$161)
.dwattr $C$DW$148, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2529 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2529, DW_AT_type(*$C$DW$T$163)
.dwendtag $C$DW$148
.dwendtag $C$DW$T$165
.dwattr $C$DW$T$165, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$T$165, DW_AT_decl_line(0x49)
.dwattr $C$DW$T$165, DW_AT_decl_column(0x01)
$C$DW$T$162 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$162, DW_AT_type(*$C$DW$T$165)
$C$DW$T$163 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$163, DW_AT_type(*$C$DW$T$162)
.dwattr $C$DW$T$163, DW_AT_address_class(0x20)
$C$DW$T$1600 .dwtag DW_TAG_typedef, DW_AT_name("UTI_TableOfContents")
.dwattr $C$DW$T$1600, DW_AT_type(*$C$DW$T$165)
.dwattr $C$DW$T$1600, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1600, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/UniversalTestInterface.h")
.dwattr $C$DW$T$1600, DW_AT_decl_line(0x52)
.dwattr $C$DW$T$1600, DW_AT_decl_column(0x03)
$C$DW$T$161 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$161, DW_AT_type(*$C$DW$T$165)
.dwattr $C$DW$T$161, DW_AT_address_class(0x20)
$C$DW$T$164 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$164, DW_AT_type(*$C$DW$T$161)
.dwattr $C$DW$T$164, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2530 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2530, DW_AT_type(*$C$DW$T$163)
.dwendtag $C$DW$T$164
$C$DW$T$1046 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1046, DW_AT_name("Ultrasound_Constants")
.dwattr $C$DW$T$1046, DW_AT_byte_size(0x90)
$C$DW$2531 .dwtag DW_TAG_member
.dwattr $C$DW$2531, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2531, DW_AT_name("sample_freq")
.dwattr $C$DW$2531, DW_AT_TI_symbol_name("sample_freq")
.dwattr $C$DW$2531, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2531, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2531, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2531, DW_AT_decl_line(0x2ae)
.dwattr $C$DW$2531, DW_AT_decl_column(0x05)
$C$DW$2532 .dwtag DW_TAG_member
.dwattr $C$DW$2532, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$2532, DW_AT_name("rt_sos")
.dwattr $C$DW$2532, DW_AT_TI_symbol_name("rt_sos")
.dwattr $C$DW$2532, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2532, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2532, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2532, DW_AT_decl_line(0x2af)
.dwattr $C$DW$2532, DW_AT_decl_column(0x05)
$C$DW$2533 .dwtag DW_TAG_member
.dwattr $C$DW$2533, DW_AT_type(*$C$DW$T$144)
.dwattr $C$DW$2533, DW_AT_name("reserved")
.dwattr $C$DW$2533, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2533, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2533, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2533, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2533, DW_AT_decl_line(0x2b0)
.dwattr $C$DW$2533, DW_AT_decl_column(0x05)
$C$DW$149 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$149, DW_AT_declaration
.dwattr $C$DW$149, DW_AT_TI_symbol_name("_ZN20Ultrasound_ConstantsaSERKS_")
.dwattr $C$DW$149, DW_AT_type(*$C$DW$T$1042)
.dwattr $C$DW$149, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2534 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2534, DW_AT_type(*$C$DW$T$1044)
.dwendtag $C$DW$149
.dwendtag $C$DW$T$1046
.dwattr $C$DW$T$1046, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1046, DW_AT_decl_line(0x2ad)
.dwattr $C$DW$T$1046, DW_AT_decl_column(0x01)
$C$DW$T$1043 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1043, DW_AT_type(*$C$DW$T$1046)
$C$DW$T$1044 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1044, DW_AT_type(*$C$DW$T$1043)
.dwattr $C$DW$T$1044, DW_AT_address_class(0x20)
$C$DW$T$1580 .dwtag DW_TAG_typedef, DW_AT_name("Ultrasound_Constants")
.dwattr $C$DW$T$1580, DW_AT_type(*$C$DW$T$1046)
.dwattr $C$DW$T$1580, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1580, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1580, DW_AT_decl_line(0x2b1)
.dwattr $C$DW$T$1580, DW_AT_decl_column(0x03)
$C$DW$T$1042 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1042, DW_AT_type(*$C$DW$T$1046)
.dwattr $C$DW$T$1042, DW_AT_address_class(0x20)
$C$DW$T$1045 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1045, DW_AT_type(*$C$DW$T$1042)
.dwattr $C$DW$T$1045, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2535 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2535, DW_AT_type(*$C$DW$T$1044)
.dwendtag $C$DW$T$1045
$C$DW$T$1156 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$1156, DW_AT_name("UnionChar2")
.dwattr $C$DW$T$1156, DW_AT_byte_size(0x02)
$C$DW$2536 .dwtag DW_TAG_member
.dwattr $C$DW$2536, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$2536, DW_AT_name("i16")
.dwattr $C$DW$2536, DW_AT_TI_symbol_name("i16")
.dwattr $C$DW$2536, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2536, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2536, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$2536, DW_AT_decl_line(0x658)
.dwattr $C$DW$2536, DW_AT_decl_column(0x08)
$C$DW$2537 .dwtag DW_TAG_member
.dwattr $C$DW$2537, DW_AT_type(*$C$DW$T$230)
.dwattr $C$DW$2537, DW_AT_name("i8")
.dwattr $C$DW$2537, DW_AT_TI_symbol_name("i8")
.dwattr $C$DW$2537, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2537, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2537, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$2537, DW_AT_decl_line(0x65d)
.dwattr $C$DW$2537, DW_AT_decl_column(0x04)
$C$DW$150 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$150, DW_AT_declaration
.dwattr $C$DW$150, DW_AT_TI_symbol_name("_ZN10UnionChar2aSERKS_")
.dwattr $C$DW$150, DW_AT_type(*$C$DW$T$1152)
.dwattr $C$DW$150, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2538 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2538, DW_AT_type(*$C$DW$T$1154)
.dwendtag $C$DW$150
.dwendtag $C$DW$T$1156
.dwattr $C$DW$T$1156, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$T$1156, DW_AT_decl_line(0x656)
.dwattr $C$DW$T$1156, DW_AT_decl_column(0x07)
$C$DW$T$1153 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1153, DW_AT_type(*$C$DW$T$1156)
$C$DW$T$1154 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1154, DW_AT_type(*$C$DW$T$1153)
.dwattr $C$DW$T$1154, DW_AT_address_class(0x20)
$C$DW$T$1152 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1152, DW_AT_type(*$C$DW$T$1156)
.dwattr $C$DW$T$1152, DW_AT_address_class(0x20)
$C$DW$T$1155 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1155, DW_AT_type(*$C$DW$T$1152)
.dwattr $C$DW$T$1155, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2539 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2539, DW_AT_type(*$C$DW$T$1154)
.dwendtag $C$DW$T$1155
$C$DW$T$2206 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$2206, DW_AT_name("VsyncDisableMargin")
.dwattr $C$DW$T$2206, DW_AT_byte_size(0x04)
$C$DW$2540 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_VSYNC_BEFORE_DISABLE"), DW_AT_const_value(0x01)
.dwattr $C$DW$2540, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/HwMgr.h")
.dwattr $C$DW$2540, DW_AT_decl_line(0x56)
.dwattr $C$DW$2540, DW_AT_decl_column(0x05)
$C$DW$2541 .dwtag DW_TAG_enumerator, DW_AT_name("LIVE_VSYNC_BEFORE_DISABLE"), DW_AT_const_value(0x01)
.dwattr $C$DW$2541, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/HwMgr.h")
.dwattr $C$DW$2541, DW_AT_decl_line(0x57)
.dwattr $C$DW$2541, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$2206
.dwattr $C$DW$T$2206, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/HwMgr.h")
.dwattr $C$DW$T$2206, DW_AT_decl_line(0x55)
.dwattr $C$DW$T$2206, DW_AT_decl_column(0x0e)
$C$DW$T$2207 .dwtag DW_TAG_typedef, DW_AT_name("VsyncDisableMargin")
.dwattr $C$DW$T$2207, DW_AT_type(*$C$DW$T$2206)
.dwattr $C$DW$T$2207, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2207, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/HwMgr.h")
.dwattr $C$DW$T$2207, DW_AT_decl_line(0x58)
.dwattr $C$DW$T$2207, DW_AT_decl_column(0x03)
$C$DW$T$1238 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$1238, DW_AT_name("Zoom_BitAllocation")
.dwattr $C$DW$T$1238, DW_AT_byte_size(0x04)
$C$DW$2542 .dwtag DW_TAG_member
.dwattr $C$DW$2542, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2542, DW_AT_name("ScZoom")
.dwattr $C$DW$2542, DW_AT_TI_symbol_name("ScZoom")
.dwattr $C$DW$2542, DW_AT_bit_offset(0x1f), DW_AT_bit_size(0x01)
.dwattr $C$DW$2542, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2542, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2542, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2542, DW_AT_decl_line(0x24c)
.dwattr $C$DW$2542, DW_AT_decl_column(0x09)
$C$DW$2543 .dwtag DW_TAG_member
.dwattr $C$DW$2543, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2543, DW_AT_name("RasterScale")
.dwattr $C$DW$2543, DW_AT_TI_symbol_name("RasterScale")
.dwattr $C$DW$2543, DW_AT_bit_offset(0x1e), DW_AT_bit_size(0x01)
.dwattr $C$DW$2543, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2543, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2543, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2543, DW_AT_decl_line(0x24d)
.dwattr $C$DW$2543, DW_AT_decl_column(0x09)
$C$DW$2544 .dwtag DW_TAG_member
.dwattr $C$DW$2544, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2544, DW_AT_name("RasterZoom")
.dwattr $C$DW$2544, DW_AT_TI_symbol_name("RasterZoom")
.dwattr $C$DW$2544, DW_AT_bit_offset(0x1d), DW_AT_bit_size(0x01)
.dwattr $C$DW$2544, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2544, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2544, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2544, DW_AT_decl_line(0x24e)
.dwattr $C$DW$2544, DW_AT_decl_column(0x09)
$C$DW$2545 .dwtag DW_TAG_member
.dwattr $C$DW$2545, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2545, DW_AT_name("AcqZoom")
.dwattr $C$DW$2545, DW_AT_TI_symbol_name("AcqZoom")
.dwattr $C$DW$2545, DW_AT_bit_offset(0x1c), DW_AT_bit_size(0x01)
.dwattr $C$DW$2545, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2545, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2545, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2545, DW_AT_decl_line(0x24f)
.dwattr $C$DW$2545, DW_AT_decl_column(0x09)
$C$DW$2546 .dwtag DW_TAG_member
.dwattr $C$DW$2546, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$2546, DW_AT_name("reserved")
.dwattr $C$DW$2546, DW_AT_TI_symbol_name("reserved")
.dwattr $C$DW$2546, DW_AT_bit_offset(0x00), DW_AT_bit_size(0x1c)
.dwattr $C$DW$2546, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2546, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2546, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2546, DW_AT_decl_line(0x250)
.dwattr $C$DW$2546, DW_AT_decl_column(0x09)
$C$DW$151 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$151, DW_AT_declaration
.dwattr $C$DW$151, DW_AT_TI_symbol_name("_ZN18Zoom_BitAllocationaSERKS_")
.dwattr $C$DW$151, DW_AT_type(*$C$DW$T$1234)
.dwattr $C$DW$151, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2547 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2547, DW_AT_type(*$C$DW$T$1236)
.dwendtag $C$DW$151
.dwendtag $C$DW$T$1238
.dwattr $C$DW$T$1238, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$1238, DW_AT_decl_line(0x24b)
.dwattr $C$DW$T$1238, DW_AT_decl_column(0x01)
$C$DW$T$464 .dwtag DW_TAG_typedef, DW_AT_name("Zoom_BitAllocation")
.dwattr $C$DW$T$464, DW_AT_type(*$C$DW$T$1238)
.dwattr $C$DW$T$464, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$464, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$464, DW_AT_decl_line(0x251)
.dwattr $C$DW$T$464, DW_AT_decl_column(0x03)
$C$DW$T$1235 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1235, DW_AT_type(*$C$DW$T$1238)
$C$DW$T$1236 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1236, DW_AT_type(*$C$DW$T$1235)
.dwattr $C$DW$T$1236, DW_AT_address_class(0x20)
$C$DW$T$1234 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1234, DW_AT_type(*$C$DW$T$1238)
.dwattr $C$DW$T$1234, DW_AT_address_class(0x20)
$C$DW$T$1237 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1237, DW_AT_type(*$C$DW$T$1234)
.dwattr $C$DW$T$1237, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2548 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2548, DW_AT_type(*$C$DW$T$1236)
.dwendtag $C$DW$T$1237
$C$DW$T$230 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$230, DW_AT_byte_size(0x02)
$C$DW$2549 .dwtag DW_TAG_member
.dwattr $C$DW$2549, DW_AT_type(*$C$DW$T$150)
.dwattr $C$DW$2549, DW_AT_name("x")
.dwattr $C$DW$2549, DW_AT_TI_symbol_name("x")
.dwattr $C$DW$2549, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2549, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2549, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$2549, DW_AT_decl_line(0x65b)
.dwattr $C$DW$2549, DW_AT_decl_column(0x08)
$C$DW$2550 .dwtag DW_TAG_member
.dwattr $C$DW$2550, DW_AT_type(*$C$DW$T$150)
.dwattr $C$DW$2550, DW_AT_name("y")
.dwattr $C$DW$2550, DW_AT_TI_symbol_name("y")
.dwattr $C$DW$2550, DW_AT_data_member_location[DW_OP_plus_uconst 0x1]
.dwattr $C$DW$2550, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2550, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$2550, DW_AT_decl_line(0x65c)
.dwattr $C$DW$2550, DW_AT_decl_column(0x08)
$C$DW$152 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$152, DW_AT_declaration
.dwattr $C$DW$152, DW_AT_TI_symbol_name("_ZN10UnionChar24__C1aSERKS0_")
.dwattr $C$DW$152, DW_AT_type(*$C$DW$T$226)
.dwattr $C$DW$152, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2551 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2551, DW_AT_type(*$C$DW$T$228)
.dwendtag $C$DW$152
.dwendtag $C$DW$T$230
.dwattr $C$DW$T$230, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$T$230, DW_AT_decl_line(0x65a)
.dwattr $C$DW$T$230, DW_AT_decl_column(0x02)
$C$DW$T$227 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$227, DW_AT_type(*$C$DW$T$230)
$C$DW$T$228 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$228, DW_AT_type(*$C$DW$T$227)
.dwattr $C$DW$T$228, DW_AT_address_class(0x20)
$C$DW$T$226 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$226, DW_AT_type(*$C$DW$T$230)
.dwattr $C$DW$T$226, DW_AT_address_class(0x20)
$C$DW$T$229 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$229, DW_AT_type(*$C$DW$T$226)
.dwattr $C$DW$T$229, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2552 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2552, DW_AT_type(*$C$DW$T$228)
.dwendtag $C$DW$T$229
$C$DW$T$306 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$306, DW_AT_byte_size(0x04)
$C$DW$2553 .dwtag DW_TAG_member
.dwattr $C$DW$2553, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$2553, DW_AT_name("i")
.dwattr $C$DW$2553, DW_AT_TI_symbol_name("i")
.dwattr $C$DW$2553, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2553, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2553, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$2553, DW_AT_decl_line(0x2f)
.dwattr $C$DW$2553, DW_AT_decl_column(0x0f)
$C$DW$2554 .dwtag DW_TAG_member
.dwattr $C$DW$2554, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$2554, DW_AT_name("q")
.dwattr $C$DW$2554, DW_AT_TI_symbol_name("q")
.dwattr $C$DW$2554, DW_AT_data_member_location[DW_OP_plus_uconst 0x2]
.dwattr $C$DW$2554, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2554, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$2554, DW_AT_decl_line(0x30)
.dwattr $C$DW$2554, DW_AT_decl_column(0x0f)
$C$DW$153 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$153, DW_AT_declaration
.dwattr $C$DW$153, DW_AT_TI_symbol_name("_ZN7cmplx324__C1aSERKS0_")
.dwattr $C$DW$153, DW_AT_type(*$C$DW$T$302)
.dwattr $C$DW$153, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2555 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2555, DW_AT_type(*$C$DW$T$304)
.dwendtag $C$DW$153
.dwendtag $C$DW$T$306
.dwattr $C$DW$T$306, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$306, DW_AT_decl_line(0x2e)
.dwattr $C$DW$T$306, DW_AT_decl_column(0x05)
$C$DW$T$303 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$303, DW_AT_type(*$C$DW$T$306)
$C$DW$T$304 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$304, DW_AT_type(*$C$DW$T$303)
.dwattr $C$DW$T$304, DW_AT_address_class(0x20)
$C$DW$T$302 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$302, DW_AT_type(*$C$DW$T$306)
.dwattr $C$DW$T$302, DW_AT_address_class(0x20)
$C$DW$T$305 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$305, DW_AT_type(*$C$DW$T$302)
.dwattr $C$DW$T$305, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2556 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2556, DW_AT_type(*$C$DW$T$304)
.dwendtag $C$DW$T$305
$C$DW$T$311 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$311, DW_AT_byte_size(0x08)
$C$DW$2557 .dwtag DW_TAG_member
.dwattr $C$DW$2557, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$2557, DW_AT_name("i")
.dwattr $C$DW$2557, DW_AT_TI_symbol_name("i")
.dwattr $C$DW$2557, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2557, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2557, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$2557, DW_AT_decl_line(0x3b)
.dwattr $C$DW$2557, DW_AT_decl_column(0x0f)
$C$DW$2558 .dwtag DW_TAG_member
.dwattr $C$DW$2558, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$2558, DW_AT_name("q")
.dwattr $C$DW$2558, DW_AT_TI_symbol_name("q")
.dwattr $C$DW$2558, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2558, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2558, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$2558, DW_AT_decl_line(0x3c)
.dwattr $C$DW$2558, DW_AT_decl_column(0x0f)
$C$DW$154 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$154, DW_AT_declaration
.dwattr $C$DW$154, DW_AT_TI_symbol_name("_ZN7cmplx644__C1aSERKS0_")
.dwattr $C$DW$154, DW_AT_type(*$C$DW$T$307)
.dwattr $C$DW$154, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2559 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2559, DW_AT_type(*$C$DW$T$309)
.dwendtag $C$DW$154
.dwendtag $C$DW$T$311
.dwattr $C$DW$T$311, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$311, DW_AT_decl_line(0x3a)
.dwattr $C$DW$T$311, DW_AT_decl_column(0x05)
$C$DW$T$308 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$308, DW_AT_type(*$C$DW$T$311)
$C$DW$T$309 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$309, DW_AT_type(*$C$DW$T$308)
.dwattr $C$DW$T$309, DW_AT_address_class(0x20)
$C$DW$T$307 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$307, DW_AT_type(*$C$DW$T$311)
.dwattr $C$DW$T$307, DW_AT_address_class(0x20)
$C$DW$T$310 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$310, DW_AT_type(*$C$DW$T$307)
.dwattr $C$DW$T$310, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2560 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2560, DW_AT_type(*$C$DW$T$309)
.dwendtag $C$DW$T$310
$C$DW$T$327 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$327, DW_AT_byte_size(0x04)
$C$DW$2561 .dwtag DW_TAG_member
.dwattr $C$DW$2561, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$2561, DW_AT_name("f32")
.dwattr $C$DW$2561, DW_AT_TI_symbol_name("f32")
.dwattr $C$DW$2561, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2561, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2561, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/common/include/nam_tool.h")
.dwattr $C$DW$2561, DW_AT_decl_line(0x2d)
.dwattr $C$DW$2561, DW_AT_decl_column(0x09)
$C$DW$2562 .dwtag DW_TAG_member
.dwattr $C$DW$2562, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$2562, DW_AT_name("i32")
.dwattr $C$DW$2562, DW_AT_TI_symbol_name("i32")
.dwattr $C$DW$2562, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2562, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2562, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/common/include/nam_tool.h")
.dwattr $C$DW$2562, DW_AT_decl_line(0x2e)
.dwattr $C$DW$2562, DW_AT_decl_column(0x09)
.dwendtag $C$DW$T$327
.dwattr $C$DW$T$327, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/common/include/nam_tool.h")
.dwattr $C$DW$T$327, DW_AT_decl_line(0x2c)
.dwattr $C$DW$T$327, DW_AT_decl_column(0x08)
$C$DW$T$297 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$297, DW_AT_byte_size(0x18)
$C$DW$2563 .dwtag DW_TAG_member
.dwattr $C$DW$2563, DW_AT_type(*$C$DW$T$291)
.dwattr $C$DW$2563, DW_AT_name("ddrMemory")
.dwattr $C$DW$2563, DW_AT_TI_symbol_name("ddrMemory")
.dwattr $C$DW$2563, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2563, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2563, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2563, DW_AT_decl_line(0x667)
.dwattr $C$DW$2563, DW_AT_decl_column(0x1e)
$C$DW$2564 .dwtag DW_TAG_member
.dwattr $C$DW$2564, DW_AT_type(*$C$DW$T$292)
.dwattr $C$DW$2564, DW_AT_name("audio")
.dwattr $C$DW$2564, DW_AT_TI_symbol_name("audio")
.dwattr $C$DW$2564, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2564, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2564, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$2564, DW_AT_decl_line(0x668)
.dwattr $C$DW$2564, DW_AT_decl_column(0x1e)
$C$DW$155 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$155, DW_AT_declaration
.dwattr $C$DW$155, DW_AT_TI_symbol_name("_ZN17SpDsp_DiagsResult4__C3aSERKS0_")
.dwattr $C$DW$155, DW_AT_type(*$C$DW$T$293)
.dwattr $C$DW$155, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2565 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2565, DW_AT_type(*$C$DW$T$295)
.dwendtag $C$DW$155
.dwendtag $C$DW$T$297
.dwattr $C$DW$T$297, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h")
.dwattr $C$DW$T$297, DW_AT_decl_line(0x666)
.dwattr $C$DW$T$297, DW_AT_decl_column(0x02)
$C$DW$T$294 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$294, DW_AT_type(*$C$DW$T$297)
$C$DW$T$295 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$295, DW_AT_type(*$C$DW$T$294)
.dwattr $C$DW$T$295, DW_AT_address_class(0x20)
$C$DW$T$293 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$293, DW_AT_type(*$C$DW$T$297)
.dwattr $C$DW$T$293, DW_AT_address_class(0x20)
$C$DW$T$296 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$296, DW_AT_type(*$C$DW$T$293)
.dwattr $C$DW$T$296, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2566 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2566, DW_AT_type(*$C$DW$T$295)
.dwendtag $C$DW$T$296
$C$DW$T$2 .dwtag DW_TAG_unspecified_type
.dwattr $C$DW$T$2, DW_AT_name("void")
$C$DW$T$3 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$3, DW_AT_type(*$C$DW$T$2)
.dwattr $C$DW$T$3, DW_AT_address_class(0x20)
$C$DW$T$1606 .dwtag DW_TAG_typedef, DW_AT_name("__builtin_va_list")
.dwattr $C$DW$T$1606, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$T$1606, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$T$668 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Ptr")
.dwattr $C$DW$T$668, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$T$668, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$668, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$668, DW_AT_decl_line(0x2e)
.dwattr $C$DW$T$668, DW_AT_decl_column(0x1a)
$C$DW$T$1607 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__gateObj")
.dwattr $C$DW$T$1607, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1607, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1607, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1607, DW_AT_decl_line(0xb0)
.dwattr $C$DW$T$1607, DW_AT_decl_column(0x11)
$C$DW$T$1608 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__gatePrms")
.dwattr $C$DW$T$1608, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1608, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1608, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1608, DW_AT_decl_line(0xb4)
.dwattr $C$DW$T$1608, DW_AT_decl_column(0x11)
$C$DW$T$1609 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__loggerObj")
.dwattr $C$DW$T$1609, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1609, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1609, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1609, DW_AT_decl_line(0xc0)
.dwattr $C$DW$T$1609, DW_AT_decl_column(0x11)
$C$DW$T$1610 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Object__table")
.dwattr $C$DW$T$1610, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1610, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1610, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1610, DW_AT_decl_line(0xe8)
.dwattr $C$DW$T$1610, DW_AT_decl_column(0x11)
$C$DW$T$1611 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__gateObj")
.dwattr $C$DW$T$1611, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1611, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1611, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1611, DW_AT_decl_line(0x80)
.dwattr $C$DW$T$1611, DW_AT_decl_column(0x11)
$C$DW$T$1612 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__gatePrms")
.dwattr $C$DW$T$1612, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1612, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1612, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1612, DW_AT_decl_line(0x84)
.dwattr $C$DW$T$1612, DW_AT_decl_column(0x11)
$C$DW$T$1613 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__loggerObj")
.dwattr $C$DW$T$1613, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1613, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1613, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1613, DW_AT_decl_line(0x90)
.dwattr $C$DW$T$1613, DW_AT_decl_column(0x11)
$C$DW$T$1614 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Object__table")
.dwattr $C$DW$T$1614, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1614, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1614, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1614, DW_AT_decl_line(0xb8)
.dwattr $C$DW$T$1614, DW_AT_decl_column(0x11)
$C$DW$T$1615 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__gateObj")
.dwattr $C$DW$T$1615, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1615, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1615, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1615, DW_AT_decl_line(0x59)
.dwattr $C$DW$T$1615, DW_AT_decl_column(0x11)
$C$DW$T$1616 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__gatePrms")
.dwattr $C$DW$T$1616, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1616, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1616, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1616, DW_AT_decl_line(0x5d)
.dwattr $C$DW$T$1616, DW_AT_decl_column(0x11)
$C$DW$T$1617 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__loggerObj")
.dwattr $C$DW$T$1617, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1617, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1617, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1617, DW_AT_decl_line(0x69)
.dwattr $C$DW$T$1617, DW_AT_decl_column(0x11)
$C$DW$T$1618 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Object__table")
.dwattr $C$DW$T$1618, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1618, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1618, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1618, DW_AT_decl_line(0x91)
.dwattr $C$DW$T$1618, DW_AT_decl_column(0x11)
$C$DW$T$1619 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__gateObj")
.dwattr $C$DW$T$1619, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1619, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1619, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1619, DW_AT_decl_line(0x59)
.dwattr $C$DW$T$1619, DW_AT_decl_column(0x11)
$C$DW$T$1620 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__gatePrms")
.dwattr $C$DW$T$1620, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1620, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1620, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1620, DW_AT_decl_line(0x5d)
.dwattr $C$DW$T$1620, DW_AT_decl_column(0x11)
$C$DW$T$1621 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__loggerObj")
.dwattr $C$DW$T$1621, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1621, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1621, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1621, DW_AT_decl_line(0x69)
.dwattr $C$DW$T$1621, DW_AT_decl_column(0x11)
$C$DW$T$1622 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Object__table")
.dwattr $C$DW$T$1622, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1622, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1622, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1622, DW_AT_decl_line(0x91)
.dwattr $C$DW$T$1622, DW_AT_decl_column(0x11)
$C$DW$T$1623 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__gateObj")
.dwattr $C$DW$T$1623, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1623, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1623, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1623, DW_AT_decl_line(0x53)
.dwattr $C$DW$T$1623, DW_AT_decl_column(0x11)
$C$DW$T$1624 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__gatePrms")
.dwattr $C$DW$T$1624, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1624, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1624, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1624, DW_AT_decl_line(0x57)
.dwattr $C$DW$T$1624, DW_AT_decl_column(0x11)
$C$DW$T$1625 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__loggerObj")
.dwattr $C$DW$T$1625, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1625, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1625, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1625, DW_AT_decl_line(0x63)
.dwattr $C$DW$T$1625, DW_AT_decl_column(0x11)
$C$DW$T$1626 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Object__table")
.dwattr $C$DW$T$1626, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1626, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1626, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1626, DW_AT_decl_line(0x8b)
.dwattr $C$DW$T$1626, DW_AT_decl_column(0x11)
$C$DW$T$1627 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__gateObj")
.dwattr $C$DW$T$1627, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1627, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1627, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1627, DW_AT_decl_line(0x67)
.dwattr $C$DW$T$1627, DW_AT_decl_column(0x11)
$C$DW$T$1628 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__gatePrms")
.dwattr $C$DW$T$1628, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1628, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1628, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1628, DW_AT_decl_line(0x6b)
.dwattr $C$DW$T$1628, DW_AT_decl_column(0x11)
$C$DW$T$1629 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__loggerObj")
.dwattr $C$DW$T$1629, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1629, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1629, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1629, DW_AT_decl_line(0x77)
.dwattr $C$DW$T$1629, DW_AT_decl_column(0x11)
$C$DW$T$1630 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Object__table")
.dwattr $C$DW$T$1630, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1630, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1630, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1630, DW_AT_decl_line(0x9f)
.dwattr $C$DW$T$1630, DW_AT_decl_column(0x11)
$C$DW$T$1631 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__gateObj")
.dwattr $C$DW$T$1631, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1631, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1631, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1631, DW_AT_decl_line(0xe3)
.dwattr $C$DW$T$1631, DW_AT_decl_column(0x11)
$C$DW$T$1632 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__gatePrms")
.dwattr $C$DW$T$1632, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1632, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1632, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1632, DW_AT_decl_line(0xe7)
.dwattr $C$DW$T$1632, DW_AT_decl_column(0x11)
$C$DW$T$1633 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__loggerObj")
.dwattr $C$DW$T$1633, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1633, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1633, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1633, DW_AT_decl_line(0xf3)
.dwattr $C$DW$T$1633, DW_AT_decl_column(0x11)
$C$DW$T$1634 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Object__table")
.dwattr $C$DW$T$1634, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1634, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1634, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1634, DW_AT_decl_line(0x11b)
.dwattr $C$DW$T$1634, DW_AT_decl_column(0x11)
$C$DW$T$1636 .dwtag DW_TAG_typedef, DW_AT_name("Ptr")
.dwattr $C$DW$T$1636, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$1636, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1636, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1636, DW_AT_decl_line(0xf2)
.dwattr $C$DW$T$1636, DW_AT_decl_column(0x19)
$C$DW$T$672 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$672, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$672, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2567 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2567, DW_AT_type(*$C$DW$T$3)
$C$DW$2568 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2568, DW_AT_type(*$C$DW$T$669)
$C$DW$2569 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2569, DW_AT_type(*$C$DW$T$669)
$C$DW$2570 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2570, DW_AT_type(*$C$DW$T$671)
.dwendtag $C$DW$T$672
$C$DW$T$673 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$673, DW_AT_type(*$C$DW$T$672)
.dwattr $C$DW$T$673, DW_AT_address_class(0x20)
$C$DW$T$1635 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IHeap_alloc_FxnT")
.dwattr $C$DW$T$1635, DW_AT_type(*$C$DW$T$673)
.dwattr $C$DW$T$1635, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1635, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$T$1635, DW_AT_decl_line(0xa5)
.dwattr $C$DW$T$1635, DW_AT_decl_column(0x13)
$C$DW$T$757 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$757, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$757, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2571 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2571, DW_AT_type(*$C$DW$T$756)
$C$DW$2572 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2572, DW_AT_type(*$C$DW$T$669)
$C$DW$2573 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2573, DW_AT_type(*$C$DW$T$669)
$C$DW$2574 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2574, DW_AT_type(*$C$DW$T$671)
.dwendtag $C$DW$T$757
$C$DW$T$758 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$758, DW_AT_type(*$C$DW$T$757)
.dwattr $C$DW$T$758, DW_AT_address_class(0x20)
$C$DW$T$839 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$839, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$839, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2575 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2575, DW_AT_type(*$C$DW$T$668)
$C$DW$2576 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2576, DW_AT_type(*$C$DW$T$669)
$C$DW$2577 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2577, DW_AT_type(*$C$DW$T$668)
$C$DW$2578 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2578, DW_AT_type(*$C$DW$T$838)
$C$DW$2579 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2579, DW_AT_type(*$C$DW$T$669)
$C$DW$2580 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2580, DW_AT_type(*$C$DW$T$671)
.dwendtag $C$DW$T$839
$C$DW$T$840 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$840, DW_AT_type(*$C$DW$T$839)
.dwattr $C$DW$T$840, DW_AT_address_class(0x20)
$C$DW$T$855 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$855, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$T$855, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2581 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2581, DW_AT_type(*$C$DW$T$668)
$C$DW$2582 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2582, DW_AT_type(*$C$DW$T$669)
$C$DW$2583 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2583, DW_AT_type(*$C$DW$T$668)
$C$DW$2584 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2584, DW_AT_type(*$C$DW$T$854)
$C$DW$2585 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2585, DW_AT_type(*$C$DW$T$669)
$C$DW$2586 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2586, DW_AT_type(*$C$DW$T$671)
.dwendtag $C$DW$T$855
$C$DW$T$856 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$856, DW_AT_type(*$C$DW$T$855)
.dwattr $C$DW$T$856, DW_AT_address_class(0x20)
$C$DW$T$838 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$838, DW_AT_type(*$C$DW$T$668)
$C$DW$T$644 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$644, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2587 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2587, DW_AT_type(*$C$DW$T$3)
$C$DW$2588 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2588, DW_AT_type(*$C$DW$T$589)
.dwendtag $C$DW$T$644
$C$DW$T$645 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$645, DW_AT_type(*$C$DW$T$644)
.dwattr $C$DW$T$645, DW_AT_address_class(0x20)
$C$DW$T$1640 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IGateProvider_leave_FxnT")
.dwattr $C$DW$T$1640, DW_AT_type(*$C$DW$T$645)
.dwattr $C$DW$T$1640, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1640, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$T$1640, DW_AT_decl_line(0xb0)
.dwattr $C$DW$T$1640, DW_AT_decl_column(0x14)
$C$DW$T$652 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$652, DW_AT_type(*$C$DW$T$2)
$C$DW$T$653 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$653, DW_AT_type(*$C$DW$T$652)
.dwattr $C$DW$T$653, DW_AT_address_class(0x20)
$C$DW$T$1638 .dwtag DW_TAG_typedef, DW_AT_name("xdc_CPtr")
.dwattr $C$DW$T$1638, DW_AT_type(*$C$DW$T$653)
.dwattr $C$DW$T$1638, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1638, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1638, DW_AT_decl_line(0x2f)
.dwattr $C$DW$T$1638, DW_AT_decl_column(0x1a)
$C$DW$T$1639 .dwtag DW_TAG_typedef, DW_AT_name("CPtr")
.dwattr $C$DW$T$1639, DW_AT_type(*$C$DW$T$1638)
.dwattr $C$DW$T$1639, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1639, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1639, DW_AT_decl_line(0xf3)
.dwattr $C$DW$T$1639, DW_AT_decl_column(0x19)
$C$DW$T$674 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$674, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2589 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2589, DW_AT_type(*$C$DW$T$3)
$C$DW$2590 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2590, DW_AT_type(*$C$DW$T$668)
$C$DW$2591 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2591, DW_AT_type(*$C$DW$T$669)
.dwendtag $C$DW$T$674
$C$DW$T$675 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$675, DW_AT_type(*$C$DW$T$674)
.dwattr $C$DW$T$675, DW_AT_address_class(0x20)
$C$DW$T$1641 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IHeap_free_FxnT")
.dwattr $C$DW$T$1641, DW_AT_type(*$C$DW$T$675)
.dwattr $C$DW$T$1641, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1641, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$T$1641, DW_AT_decl_line(0xac)
.dwattr $C$DW$T$1641, DW_AT_decl_column(0x14)
$C$DW$T$680 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$680, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2592 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2592, DW_AT_type(*$C$DW$T$3)
$C$DW$2593 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2593, DW_AT_type(*$C$DW$T$679)
.dwendtag $C$DW$T$680
$C$DW$T$681 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$681, DW_AT_type(*$C$DW$T$680)
.dwattr $C$DW$T$681, DW_AT_address_class(0x20)
$C$DW$T$1642 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IHeap_getStats_FxnT")
.dwattr $C$DW$T$1642, DW_AT_type(*$C$DW$T$681)
.dwattr $C$DW$T$1642, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1642, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$T$1642, DW_AT_decl_line(0xba)
.dwattr $C$DW$T$1642, DW_AT_decl_column(0x14)
$C$DW$T$732 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$732, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2594 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2594, DW_AT_type(*$C$DW$T$729)
$C$DW$2595 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2595, DW_AT_type(*$C$DW$T$589)
.dwendtag $C$DW$T$732
$C$DW$T$733 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$733, DW_AT_type(*$C$DW$T$732)
.dwattr $C$DW$T$733, DW_AT_address_class(0x20)
$C$DW$T$759 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$759, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2596 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2596, DW_AT_type(*$C$DW$T$756)
$C$DW$2597 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2597, DW_AT_type(*$C$DW$T$668)
$C$DW$2598 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2598, DW_AT_type(*$C$DW$T$669)
.dwendtag $C$DW$T$759
$C$DW$T$760 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$760, DW_AT_type(*$C$DW$T$759)
.dwattr $C$DW$T$760, DW_AT_address_class(0x20)
$C$DW$T$763 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$763, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2599 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2599, DW_AT_type(*$C$DW$T$756)
$C$DW$2600 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2600, DW_AT_type(*$C$DW$T$679)
.dwendtag $C$DW$T$763
$C$DW$T$764 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$764, DW_AT_type(*$C$DW$T$763)
.dwattr $C$DW$T$764, DW_AT_address_class(0x20)
$C$DW$T$841 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$841, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2601 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2601, DW_AT_type(*$C$DW$T$668)
.dwendtag $C$DW$T$841
$C$DW$T$842 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$842, DW_AT_type(*$C$DW$T$841)
.dwattr $C$DW$T$842, DW_AT_address_class(0x20)
$C$DW$T$924 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$924, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2602 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2602, DW_AT_type(*$C$DW$T$921)
$C$DW$2603 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2603, DW_AT_type(*$C$DW$T$923)
$C$DW$2604 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2604, DW_AT_type(*$C$DW$T$668)
$C$DW$2605 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2605, DW_AT_type(*$C$DW$T$784)
.dwendtag $C$DW$T$924
$C$DW$T$925 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$925, DW_AT_type(*$C$DW$T$924)
.dwattr $C$DW$T$925, DW_AT_address_class(0x20)
$C$DW$T$926 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_ErrFxn")
.dwattr $C$DW$T$926, DW_AT_type(*$C$DW$T$925)
.dwattr $C$DW$T$926, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$926, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$926, DW_AT_decl_line(0x53)
.dwattr $C$DW$T$926, DW_AT_decl_column(0x14)
$C$DW$T$927 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$927, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2606 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2606, DW_AT_type(*$C$DW$T$926)
.dwendtag $C$DW$T$927
$C$DW$T$928 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$928, DW_AT_type(*$C$DW$T$927)
.dwattr $C$DW$T$928, DW_AT_address_class(0x20)
$C$DW$T$1637 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_setErrFxn_FxnT")
.dwattr $C$DW$T$1637, DW_AT_type(*$C$DW$T$928)
.dwattr $C$DW$T$1637, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1637, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$1637, DW_AT_decl_line(0xc4)
.dwattr $C$DW$T$1637, DW_AT_decl_column(0x14)
$C$DW$T$1643 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1643, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2607 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2607, DW_AT_type(*$C$DW$T$884)
$C$DW$2608 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2608, DW_AT_type(*$C$DW$T$884)
.dwendtag $C$DW$T$1643
$C$DW$T$1644 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1644, DW_AT_type(*$C$DW$T$1643)
.dwattr $C$DW$T$1644, DW_AT_address_class(0x20)
$C$DW$T$1645 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_FreeHookFxn")
.dwattr $C$DW$T$1645, DW_AT_type(*$C$DW$T$1644)
.dwattr $C$DW$T$1645, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1645, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$1645, DW_AT_decl_line(0x286)
.dwattr $C$DW$T$1645, DW_AT_decl_column(0x10)
$C$DW$T$1649 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1649, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2609 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2609, DW_AT_type(*$C$DW$T$1646)
$C$DW$2610 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2610, DW_AT_type(*$C$DW$T$1648)
.dwendtag $C$DW$T$1649
$C$DW$T$1650 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1650, DW_AT_type(*$C$DW$T$1649)
.dwattr $C$DW$T$1650, DW_AT_address_class(0x20)
$C$DW$T$1651 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_PutHookFxn")
.dwattr $C$DW$T$1651, DW_AT_type(*$C$DW$T$1650)
.dwattr $C$DW$T$1651, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1651, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$1651, DW_AT_decl_line(0x292)
.dwattr $C$DW$T$1651, DW_AT_decl_column(0x10)
$C$DW$T$1653 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1653, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2611 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2611, DW_AT_type(*$C$DW$T$668)
$C$DW$2612 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2612, DW_AT_type(*$C$DW$T$1652)
$C$DW$2613 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2613, DW_AT_type(*$C$DW$T$596)
.dwendtag $C$DW$T$1653
$C$DW$T$1654 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1654, DW_AT_type(*$C$DW$T$1653)
.dwattr $C$DW$T$1654, DW_AT_address_class(0x20)
$C$DW$T$1655 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_LoggerFxn0")
.dwattr $C$DW$T$1655, DW_AT_type(*$C$DW$T$1654)
.dwattr $C$DW$T$1655, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1655, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1655, DW_AT_decl_line(0x95)
.dwattr $C$DW$T$1655, DW_AT_decl_column(0x14)
$C$DW$T$1656 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__loggerFxn0")
.dwattr $C$DW$T$1656, DW_AT_type(*$C$DW$T$1655)
.dwattr $C$DW$T$1656, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1656, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1656, DW_AT_decl_line(0xc4)
.dwattr $C$DW$T$1656, DW_AT_decl_column(0x26)
$C$DW$T$1657 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__loggerFxn0")
.dwattr $C$DW$T$1657, DW_AT_type(*$C$DW$T$1655)
.dwattr $C$DW$T$1657, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1657, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1657, DW_AT_decl_line(0x94)
.dwattr $C$DW$T$1657, DW_AT_decl_column(0x26)
$C$DW$T$1658 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__loggerFxn0")
.dwattr $C$DW$T$1658, DW_AT_type(*$C$DW$T$1655)
.dwattr $C$DW$T$1658, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1658, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1658, DW_AT_decl_line(0x6d)
.dwattr $C$DW$T$1658, DW_AT_decl_column(0x26)
$C$DW$T$1659 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__loggerFxn0")
.dwattr $C$DW$T$1659, DW_AT_type(*$C$DW$T$1655)
.dwattr $C$DW$T$1659, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1659, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1659, DW_AT_decl_line(0x6d)
.dwattr $C$DW$T$1659, DW_AT_decl_column(0x26)
$C$DW$T$1660 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__loggerFxn0")
.dwattr $C$DW$T$1660, DW_AT_type(*$C$DW$T$1655)
.dwattr $C$DW$T$1660, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1660, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1660, DW_AT_decl_line(0x67)
.dwattr $C$DW$T$1660, DW_AT_decl_column(0x26)
$C$DW$T$1661 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__loggerFxn0")
.dwattr $C$DW$T$1661, DW_AT_type(*$C$DW$T$1655)
.dwattr $C$DW$T$1661, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1661, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1661, DW_AT_decl_line(0x7b)
.dwattr $C$DW$T$1661, DW_AT_decl_column(0x26)
$C$DW$T$1662 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__loggerFxn0")
.dwattr $C$DW$T$1662, DW_AT_type(*$C$DW$T$1655)
.dwattr $C$DW$T$1662, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1662, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1662, DW_AT_decl_line(0xf7)
.dwattr $C$DW$T$1662, DW_AT_decl_column(0x26)
$C$DW$T$1663 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1663, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2614 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2614, DW_AT_type(*$C$DW$T$668)
$C$DW$2615 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2615, DW_AT_type(*$C$DW$T$1652)
$C$DW$2616 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2616, DW_AT_type(*$C$DW$T$596)
$C$DW$2617 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2617, DW_AT_type(*$C$DW$T$589)
.dwendtag $C$DW$T$1663
$C$DW$T$1664 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1664, DW_AT_type(*$C$DW$T$1663)
.dwattr $C$DW$T$1664, DW_AT_address_class(0x20)
$C$DW$T$1665 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_LoggerFxn1")
.dwattr $C$DW$T$1665, DW_AT_type(*$C$DW$T$1664)
.dwattr $C$DW$T$1665, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1665, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1665, DW_AT_decl_line(0x98)
.dwattr $C$DW$T$1665, DW_AT_decl_column(0x14)
$C$DW$T$1666 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__loggerFxn1")
.dwattr $C$DW$T$1666, DW_AT_type(*$C$DW$T$1665)
.dwattr $C$DW$T$1666, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1666, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1666, DW_AT_decl_line(0xc8)
.dwattr $C$DW$T$1666, DW_AT_decl_column(0x26)
$C$DW$T$1667 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__loggerFxn1")
.dwattr $C$DW$T$1667, DW_AT_type(*$C$DW$T$1665)
.dwattr $C$DW$T$1667, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1667, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1667, DW_AT_decl_line(0x98)
.dwattr $C$DW$T$1667, DW_AT_decl_column(0x26)
$C$DW$T$1668 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__loggerFxn1")
.dwattr $C$DW$T$1668, DW_AT_type(*$C$DW$T$1665)
.dwattr $C$DW$T$1668, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1668, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1668, DW_AT_decl_line(0x71)
.dwattr $C$DW$T$1668, DW_AT_decl_column(0x26)
$C$DW$T$1669 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__loggerFxn1")
.dwattr $C$DW$T$1669, DW_AT_type(*$C$DW$T$1665)
.dwattr $C$DW$T$1669, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1669, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1669, DW_AT_decl_line(0x71)
.dwattr $C$DW$T$1669, DW_AT_decl_column(0x26)
$C$DW$T$1670 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__loggerFxn1")
.dwattr $C$DW$T$1670, DW_AT_type(*$C$DW$T$1665)
.dwattr $C$DW$T$1670, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1670, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1670, DW_AT_decl_line(0x6b)
.dwattr $C$DW$T$1670, DW_AT_decl_column(0x26)
$C$DW$T$1671 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__loggerFxn1")
.dwattr $C$DW$T$1671, DW_AT_type(*$C$DW$T$1665)
.dwattr $C$DW$T$1671, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1671, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1671, DW_AT_decl_line(0x7f)
.dwattr $C$DW$T$1671, DW_AT_decl_column(0x26)
$C$DW$T$1672 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__loggerFxn1")
.dwattr $C$DW$T$1672, DW_AT_type(*$C$DW$T$1665)
.dwattr $C$DW$T$1672, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1672, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1672, DW_AT_decl_line(0xfb)
.dwattr $C$DW$T$1672, DW_AT_decl_column(0x26)
$C$DW$T$1673 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1673, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2618 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2618, DW_AT_type(*$C$DW$T$668)
$C$DW$2619 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2619, DW_AT_type(*$C$DW$T$1652)
$C$DW$2620 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2620, DW_AT_type(*$C$DW$T$596)
$C$DW$2621 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2621, DW_AT_type(*$C$DW$T$589)
$C$DW$2622 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2622, DW_AT_type(*$C$DW$T$589)
.dwendtag $C$DW$T$1673
$C$DW$T$1674 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1674, DW_AT_type(*$C$DW$T$1673)
.dwattr $C$DW$T$1674, DW_AT_address_class(0x20)
$C$DW$T$1675 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_LoggerFxn2")
.dwattr $C$DW$T$1675, DW_AT_type(*$C$DW$T$1674)
.dwattr $C$DW$T$1675, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1675, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1675, DW_AT_decl_line(0x9b)
.dwattr $C$DW$T$1675, DW_AT_decl_column(0x14)
$C$DW$T$1676 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__loggerFxn2")
.dwattr $C$DW$T$1676, DW_AT_type(*$C$DW$T$1675)
.dwattr $C$DW$T$1676, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1676, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1676, DW_AT_decl_line(0xcc)
.dwattr $C$DW$T$1676, DW_AT_decl_column(0x26)
$C$DW$T$1677 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__loggerFxn2")
.dwattr $C$DW$T$1677, DW_AT_type(*$C$DW$T$1675)
.dwattr $C$DW$T$1677, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1677, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1677, DW_AT_decl_line(0x9c)
.dwattr $C$DW$T$1677, DW_AT_decl_column(0x26)
$C$DW$T$1678 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__loggerFxn2")
.dwattr $C$DW$T$1678, DW_AT_type(*$C$DW$T$1675)
.dwattr $C$DW$T$1678, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1678, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1678, DW_AT_decl_line(0x75)
.dwattr $C$DW$T$1678, DW_AT_decl_column(0x26)
$C$DW$T$1679 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__loggerFxn2")
.dwattr $C$DW$T$1679, DW_AT_type(*$C$DW$T$1675)
.dwattr $C$DW$T$1679, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1679, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1679, DW_AT_decl_line(0x75)
.dwattr $C$DW$T$1679, DW_AT_decl_column(0x26)
$C$DW$T$1680 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__loggerFxn2")
.dwattr $C$DW$T$1680, DW_AT_type(*$C$DW$T$1675)
.dwattr $C$DW$T$1680, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1680, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1680, DW_AT_decl_line(0x6f)
.dwattr $C$DW$T$1680, DW_AT_decl_column(0x26)
$C$DW$T$1681 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__loggerFxn2")
.dwattr $C$DW$T$1681, DW_AT_type(*$C$DW$T$1675)
.dwattr $C$DW$T$1681, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1681, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1681, DW_AT_decl_line(0x83)
.dwattr $C$DW$T$1681, DW_AT_decl_column(0x26)
$C$DW$T$1682 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__loggerFxn2")
.dwattr $C$DW$T$1682, DW_AT_type(*$C$DW$T$1675)
.dwattr $C$DW$T$1682, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1682, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1682, DW_AT_decl_line(0xff)
.dwattr $C$DW$T$1682, DW_AT_decl_column(0x26)
$C$DW$T$1683 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1683, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2623 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2623, DW_AT_type(*$C$DW$T$668)
$C$DW$2624 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2624, DW_AT_type(*$C$DW$T$1652)
$C$DW$2625 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2625, DW_AT_type(*$C$DW$T$596)
$C$DW$2626 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2626, DW_AT_type(*$C$DW$T$589)
$C$DW$2627 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2627, DW_AT_type(*$C$DW$T$589)
$C$DW$2628 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2628, DW_AT_type(*$C$DW$T$589)
$C$DW$2629 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2629, DW_AT_type(*$C$DW$T$589)
.dwendtag $C$DW$T$1683
$C$DW$T$1684 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1684, DW_AT_type(*$C$DW$T$1683)
.dwattr $C$DW$T$1684, DW_AT_address_class(0x20)
$C$DW$T$1685 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_LoggerFxn4")
.dwattr $C$DW$T$1685, DW_AT_type(*$C$DW$T$1684)
.dwattr $C$DW$T$1685, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1685, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1685, DW_AT_decl_line(0x9e)
.dwattr $C$DW$T$1685, DW_AT_decl_column(0x14)
$C$DW$T$1686 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__loggerFxn4")
.dwattr $C$DW$T$1686, DW_AT_type(*$C$DW$T$1685)
.dwattr $C$DW$T$1686, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1686, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1686, DW_AT_decl_line(0xd0)
.dwattr $C$DW$T$1686, DW_AT_decl_column(0x26)
$C$DW$T$1687 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__loggerFxn4")
.dwattr $C$DW$T$1687, DW_AT_type(*$C$DW$T$1685)
.dwattr $C$DW$T$1687, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1687, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1687, DW_AT_decl_line(0xa0)
.dwattr $C$DW$T$1687, DW_AT_decl_column(0x26)
$C$DW$T$1688 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__loggerFxn4")
.dwattr $C$DW$T$1688, DW_AT_type(*$C$DW$T$1685)
.dwattr $C$DW$T$1688, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1688, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1688, DW_AT_decl_line(0x79)
.dwattr $C$DW$T$1688, DW_AT_decl_column(0x26)
$C$DW$T$1689 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__loggerFxn4")
.dwattr $C$DW$T$1689, DW_AT_type(*$C$DW$T$1685)
.dwattr $C$DW$T$1689, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1689, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1689, DW_AT_decl_line(0x79)
.dwattr $C$DW$T$1689, DW_AT_decl_column(0x26)
$C$DW$T$1690 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__loggerFxn4")
.dwattr $C$DW$T$1690, DW_AT_type(*$C$DW$T$1685)
.dwattr $C$DW$T$1690, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1690, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1690, DW_AT_decl_line(0x73)
.dwattr $C$DW$T$1690, DW_AT_decl_column(0x26)
$C$DW$T$1691 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__loggerFxn4")
.dwattr $C$DW$T$1691, DW_AT_type(*$C$DW$T$1685)
.dwattr $C$DW$T$1691, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1691, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1691, DW_AT_decl_line(0x87)
.dwattr $C$DW$T$1691, DW_AT_decl_column(0x26)
$C$DW$T$1692 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__loggerFxn4")
.dwattr $C$DW$T$1692, DW_AT_type(*$C$DW$T$1685)
.dwattr $C$DW$T$1692, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1692, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1692, DW_AT_decl_line(0x103)
.dwattr $C$DW$T$1692, DW_AT_decl_column(0x26)
$C$DW$T$1693 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1693, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2630 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2630, DW_AT_type(*$C$DW$T$668)
$C$DW$2631 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2631, DW_AT_type(*$C$DW$T$1652)
$C$DW$2632 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2632, DW_AT_type(*$C$DW$T$596)
$C$DW$2633 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2633, DW_AT_type(*$C$DW$T$589)
$C$DW$2634 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2634, DW_AT_type(*$C$DW$T$589)
$C$DW$2635 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2635, DW_AT_type(*$C$DW$T$589)
$C$DW$2636 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2636, DW_AT_type(*$C$DW$T$589)
$C$DW$2637 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2637, DW_AT_type(*$C$DW$T$589)
$C$DW$2638 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2638, DW_AT_type(*$C$DW$T$589)
$C$DW$2639 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2639, DW_AT_type(*$C$DW$T$589)
$C$DW$2640 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2640, DW_AT_type(*$C$DW$T$589)
.dwendtag $C$DW$T$1693
$C$DW$T$1694 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1694, DW_AT_type(*$C$DW$T$1693)
.dwattr $C$DW$T$1694, DW_AT_address_class(0x20)
$C$DW$T$1695 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_LoggerFxn8")
.dwattr $C$DW$T$1695, DW_AT_type(*$C$DW$T$1694)
.dwattr $C$DW$T$1695, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1695, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1695, DW_AT_decl_line(0xa1)
.dwattr $C$DW$T$1695, DW_AT_decl_column(0x14)
$C$DW$T$1696 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__loggerFxn8")
.dwattr $C$DW$T$1696, DW_AT_type(*$C$DW$T$1695)
.dwattr $C$DW$T$1696, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1696, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1696, DW_AT_decl_line(0xd4)
.dwattr $C$DW$T$1696, DW_AT_decl_column(0x26)
$C$DW$T$1697 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__loggerFxn8")
.dwattr $C$DW$T$1697, DW_AT_type(*$C$DW$T$1695)
.dwattr $C$DW$T$1697, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1697, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1697, DW_AT_decl_line(0xa4)
.dwattr $C$DW$T$1697, DW_AT_decl_column(0x26)
$C$DW$T$1698 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__loggerFxn8")
.dwattr $C$DW$T$1698, DW_AT_type(*$C$DW$T$1695)
.dwattr $C$DW$T$1698, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1698, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1698, DW_AT_decl_line(0x7d)
.dwattr $C$DW$T$1698, DW_AT_decl_column(0x26)
$C$DW$T$1699 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__loggerFxn8")
.dwattr $C$DW$T$1699, DW_AT_type(*$C$DW$T$1695)
.dwattr $C$DW$T$1699, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1699, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1699, DW_AT_decl_line(0x7d)
.dwattr $C$DW$T$1699, DW_AT_decl_column(0x26)
$C$DW$T$1700 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__loggerFxn8")
.dwattr $C$DW$T$1700, DW_AT_type(*$C$DW$T$1695)
.dwattr $C$DW$T$1700, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1700, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1700, DW_AT_decl_line(0x77)
.dwattr $C$DW$T$1700, DW_AT_decl_column(0x26)
$C$DW$T$1701 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__loggerFxn8")
.dwattr $C$DW$T$1701, DW_AT_type(*$C$DW$T$1695)
.dwattr $C$DW$T$1701, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1701, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1701, DW_AT_decl_line(0x8b)
.dwattr $C$DW$T$1701, DW_AT_decl_column(0x26)
$C$DW$T$1702 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__loggerFxn8")
.dwattr $C$DW$T$1702, DW_AT_type(*$C$DW$T$1695)
.dwattr $C$DW$T$1702, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1702, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1702, DW_AT_decl_line(0x107)
.dwattr $C$DW$T$1702, DW_AT_decl_column(0x26)
$C$DW$T$1703 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1703, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2641 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2641, DW_AT_type(*$C$DW$T$671)
.dwendtag $C$DW$T$1703
$C$DW$T$1704 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1704, DW_AT_type(*$C$DW$T$1703)
.dwattr $C$DW$T$1704, DW_AT_address_class(0x20)
$C$DW$T$1705 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Error_HookFxn")
.dwattr $C$DW$T$1705, DW_AT_type(*$C$DW$T$1704)
.dwattr $C$DW$T$1705, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1705, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1705, DW_AT_decl_line(0x4c)
.dwattr $C$DW$T$1705, DW_AT_decl_column(0x14)
$C$DW$T$1706 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_raiseHook")
.dwattr $C$DW$T$1706, DW_AT_type(*$C$DW$T$1705)
.dwattr $C$DW$T$1706, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1706, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1706, DW_AT_decl_line(0xd6)
.dwattr $C$DW$T$1706, DW_AT_decl_column(0x23)
$C$DW$T$1707 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1707, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2642 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2642, DW_AT_type(*$C$DW$T$671)
$C$DW$2643 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2643, DW_AT_type(*$C$DW$T$596)
$C$DW$2644 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2644, DW_AT_type(*$C$DW$T$827)
$C$DW$2645 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2645, DW_AT_type(*$C$DW$T$639)
$C$DW$2646 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2646, DW_AT_type(*$C$DW$T$607)
$C$DW$2647 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2647, DW_AT_type(*$C$DW$T$589)
$C$DW$2648 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2648, DW_AT_type(*$C$DW$T$589)
.dwendtag $C$DW$T$1707
$C$DW$T$1708 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1708, DW_AT_type(*$C$DW$T$1707)
.dwattr $C$DW$T$1708, DW_AT_address_class(0x20)
$C$DW$T$1709 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Error_PolicyFxn")
.dwattr $C$DW$T$1709, DW_AT_type(*$C$DW$T$1708)
.dwattr $C$DW$T$1709, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1709, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1709, DW_AT_decl_line(0x67)
.dwattr $C$DW$T$1709, DW_AT_decl_column(0x14)
$C$DW$T$1710 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_policyFxn")
.dwattr $C$DW$T$1710, DW_AT_type(*$C$DW$T$1709)
.dwattr $C$DW$T$1710, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1710, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1710, DW_AT_decl_line(0xbd)
.dwattr $C$DW$T$1710, DW_AT_decl_column(0x25)
$C$DW$T$1711 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1711, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$T$1712 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1712, DW_AT_type(*$C$DW$T$1711)
.dwattr $C$DW$T$1712, DW_AT_address_class(0x20)
$C$DW$T$1713 .dwtag DW_TAG_typedef, DW_AT_name("__TI_atexit_fn")
.dwattr $C$DW$T$1713, DW_AT_type(*$C$DW$T$1712)
.dwattr $C$DW$T$1713, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1713, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$T$1713, DW_AT_decl_line(0x8d)
.dwattr $C$DW$T$1713, DW_AT_decl_column(0x14)
$C$DW$T$4 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$4, DW_AT_encoding(DW_ATE_boolean)
.dwattr $C$DW$T$4, DW_AT_name("bool")
.dwattr $C$DW$T$4, DW_AT_byte_size(0x01)
$C$DW$T$5 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$5, DW_AT_encoding(DW_ATE_signed_char)
.dwattr $C$DW$T$5, DW_AT_name("signed char")
.dwattr $C$DW$T$5, DW_AT_byte_size(0x01)
$C$DW$T$1725 .dwtag DW_TAG_typedef, DW_AT_name("int8_t")
.dwattr $C$DW$T$1725, DW_AT_type(*$C$DW$T$5)
.dwattr $C$DW$T$1725, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1725, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1725, DW_AT_decl_line(0x2a)
.dwattr $C$DW$T$1725, DW_AT_decl_column(0x1d)
$C$DW$T$1726 .dwtag DW_TAG_typedef, DW_AT_name("int_least8_t")
.dwattr $C$DW$T$1726, DW_AT_type(*$C$DW$T$1725)
.dwattr $C$DW$T$1726, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1726, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1726, DW_AT_decl_line(0x39)
.dwattr $C$DW$T$1726, DW_AT_decl_column(0x17)
$C$DW$T$1727 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Int8")
.dwattr $C$DW$T$1727, DW_AT_type(*$C$DW$T$1726)
.dwattr $C$DW$T$1727, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1727, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$1727, DW_AT_decl_line(0x6c)
.dwattr $C$DW$T$1727, DW_AT_decl_column(0x19)
$C$DW$T$1728 .dwtag DW_TAG_typedef, DW_AT_name("Int8")
.dwattr $C$DW$T$1728, DW_AT_type(*$C$DW$T$1727)
.dwattr $C$DW$T$1728, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1728, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1728, DW_AT_decl_line(0xee)
.dwattr $C$DW$T$1728, DW_AT_decl_column(0x19)
$C$DW$T$1328 .dwtag DW_TAG_typedef, DW_AT_name("s8")
.dwattr $C$DW$T$1328, DW_AT_type(*$C$DW$T$5)
.dwattr $C$DW$T$1328, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1328, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1328, DW_AT_decl_line(0x25)
.dwattr $C$DW$T$1328, DW_AT_decl_column(0x1c)
$C$DW$T$1329 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1329, DW_AT_type(*$C$DW$T$1328)
.dwattr $C$DW$T$1329, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1329, DW_AT_byte_size(0x40)
$C$DW$2649 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2649, DW_AT_upper_bound(0x3f)
.dwendtag $C$DW$T$1329
$C$DW$T$1403 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1403, DW_AT_type(*$C$DW$T$1328)
.dwattr $C$DW$T$1403, DW_AT_address_class(0x20)
$C$DW$T$1458 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1458, DW_AT_type(*$C$DW$T$1328)
.dwattr $C$DW$T$1458, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1458, DW_AT_byte_size(0xc8)
$C$DW$2650 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2650, DW_AT_upper_bound(0xc7)
.dwendtag $C$DW$T$1458
$C$DW$T$6 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$6, DW_AT_encoding(DW_ATE_unsigned_char)
.dwattr $C$DW$T$6, DW_AT_name("unsigned char")
.dwattr $C$DW$T$6, DW_AT_byte_size(0x01)
$C$DW$T$1198 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1198, DW_AT_type(*$C$DW$T$6)
.dwattr $C$DW$T$1198, DW_AT_address_class(0x20)
$C$DW$T$1199 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1199, DW_AT_type(*$C$DW$T$1198)
.dwattr $C$DW$T$1199, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1199, DW_AT_byte_size(0x08)
$C$DW$2651 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2651, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$1199
$C$DW$T$167 .dwtag DW_TAG_typedef, DW_AT_name("u8")
.dwattr $C$DW$T$167, DW_AT_type(*$C$DW$T$6)
.dwattr $C$DW$T$167, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$167, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$167, DW_AT_decl_line(0x21)
.dwattr $C$DW$T$167, DW_AT_decl_column(0x1c)
$C$DW$T$168 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$168, DW_AT_type(*$C$DW$T$167)
.dwattr $C$DW$T$168, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$168, DW_AT_byte_size(0x400)
$C$DW$2652 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2652, DW_AT_upper_bound(0x3ff)
$C$DW$T$1402 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1402, DW_AT_type(*$C$DW$T$167)
.dwattr $C$DW$T$1402, DW_AT_address_class(0x20)
$C$DW$T$101 .dwtag DW_TAG_typedef, DW_AT_name("uint8_t")
.dwattr $C$DW$T$101, DW_AT_type(*$C$DW$T$6)
.dwattr $C$DW$T$101, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$101, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$101, DW_AT_decl_line(0x2b)
.dwattr $C$DW$T$101, DW_AT_decl_column(0x1c)
$C$DW$T$102 .dwtag DW_TAG_typedef, DW_AT_name("uint_least8_t")
.dwattr $C$DW$T$102, DW_AT_type(*$C$DW$T$101)
.dwattr $C$DW$T$102, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$102, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$102, DW_AT_decl_line(0x3a)
.dwattr $C$DW$T$102, DW_AT_decl_column(0x16)
$C$DW$T$103 .dwtag DW_TAG_typedef, DW_AT_name("xdc_UInt8")
.dwattr $C$DW$T$103, DW_AT_type(*$C$DW$T$102)
.dwattr $C$DW$T$103, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$103, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$103, DW_AT_decl_line(0x6d)
.dwattr $C$DW$T$103, DW_AT_decl_column(0x19)
$C$DW$T$1732 .dwtag DW_TAG_typedef, DW_AT_name("UInt8")
.dwattr $C$DW$T$1732, DW_AT_type(*$C$DW$T$103)
.dwattr $C$DW$T$1732, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1732, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1732, DW_AT_decl_line(0xf9)
.dwattr $C$DW$T$1732, DW_AT_decl_column(0x19)
$C$DW$T$104 .dwtag DW_TAG_typedef, DW_AT_name("Uint8")
.dwattr $C$DW$T$104, DW_AT_type(*$C$DW$T$103)
.dwattr $C$DW$T$104, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$104, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$104, DW_AT_decl_line(0x106)
.dwattr $C$DW$T$104, DW_AT_decl_column(0x19)
$C$DW$T$1733 .dwtag DW_TAG_typedef, DW_AT_name("CSL_BitMask8")
.dwattr $C$DW$T$1733, DW_AT_type(*$C$DW$T$104)
.dwattr $C$DW$T$1733, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1733, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1733, DW_AT_decl_line(0x3b)
.dwattr $C$DW$T$1733, DW_AT_decl_column(0x19)
$C$DW$T$1734 .dwtag DW_TAG_volatile_type
.dwattr $C$DW$T$1734, DW_AT_type(*$C$DW$T$104)
$C$DW$T$1735 .dwtag DW_TAG_typedef, DW_AT_name("CSL_Reg8")
.dwattr $C$DW$T$1735, DW_AT_type(*$C$DW$T$1734)
.dwattr $C$DW$T$1735, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1735, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1735, DW_AT_decl_line(0x3f)
.dwattr $C$DW$T$1735, DW_AT_decl_column(0x19)
$C$DW$T$105 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$105, DW_AT_type(*$C$DW$T$104)
.dwattr $C$DW$T$105, DW_AT_address_class(0x20)
$C$DW$T$1730 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Bits8")
.dwattr $C$DW$T$1730, DW_AT_type(*$C$DW$T$101)
.dwattr $C$DW$T$1730, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1730, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$1730, DW_AT_decl_line(0x89)
.dwattr $C$DW$T$1730, DW_AT_decl_column(0x19)
$C$DW$T$1731 .dwtag DW_TAG_typedef, DW_AT_name("Bits8")
.dwattr $C$DW$T$1731, DW_AT_type(*$C$DW$T$1730)
.dwattr $C$DW$T$1731, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1731, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1731, DW_AT_decl_line(0x11a)
.dwattr $C$DW$T$1731, DW_AT_decl_column(0x19)
$C$DW$T$852 .dwtag DW_TAG_typedef, DW_AT_name("xdc_UChar")
.dwattr $C$DW$T$852, DW_AT_type(*$C$DW$T$6)
.dwattr $C$DW$T$852, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$852, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$852, DW_AT_decl_line(0x1e)
.dwattr $C$DW$T$852, DW_AT_decl_column(0x19)
$C$DW$T$1729 .dwtag DW_TAG_typedef, DW_AT_name("UChar")
.dwattr $C$DW$T$1729, DW_AT_type(*$C$DW$T$852)
.dwattr $C$DW$T$1729, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1729, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1729, DW_AT_decl_line(0xdc)
.dwattr $C$DW$T$1729, DW_AT_decl_column(0x19)
$C$DW$T$853 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$853, DW_AT_type(*$C$DW$T$852)
$C$DW$T$854 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$854, DW_AT_type(*$C$DW$T$853)
.dwattr $C$DW$T$854, DW_AT_address_class(0x20)
$C$DW$T$7 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$7, DW_AT_encoding(DW_ATE_signed_char)
.dwattr $C$DW$T$7, DW_AT_name("wchar_t")
.dwattr $C$DW$T$7, DW_AT_byte_size(0x02)
$C$DW$T$8 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$8, DW_AT_encoding(DW_ATE_signed)
.dwattr $C$DW$T$8, DW_AT_name("short")
.dwattr $C$DW$T$8, DW_AT_byte_size(0x02)
$C$DW$T$1739 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1739, DW_AT_type(*$C$DW$T$8)
$C$DW$T$1740 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1740, DW_AT_type(*$C$DW$T$1739)
.dwattr $C$DW$T$1740, DW_AT_address_class(0x20)
$C$DW$T$1746 .dwtag DW_TAG_typedef, DW_AT_name("int16")
.dwattr $C$DW$T$1746, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$T$1746, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1746, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1746, DW_AT_decl_line(0x15)
.dwattr $C$DW$T$1746, DW_AT_decl_column(0x19)
$C$DW$T$298 .dwtag DW_TAG_typedef, DW_AT_name("int16_t")
.dwattr $C$DW$T$298, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$T$298, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$298, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$298, DW_AT_decl_line(0x2c)
.dwattr $C$DW$T$298, DW_AT_decl_column(0x1d)
$C$DW$T$299 .dwtag DW_TAG_typedef, DW_AT_name("int_least16_t")
.dwattr $C$DW$T$299, DW_AT_type(*$C$DW$T$298)
.dwattr $C$DW$T$299, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$299, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$299, DW_AT_decl_line(0x3c)
.dwattr $C$DW$T$299, DW_AT_decl_column(0x17)
$C$DW$T$300 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Int16")
.dwattr $C$DW$T$300, DW_AT_type(*$C$DW$T$299)
.dwattr $C$DW$T$300, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$300, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$300, DW_AT_decl_line(0x6e)
.dwattr $C$DW$T$300, DW_AT_decl_column(0x19)
$C$DW$T$301 .dwtag DW_TAG_typedef, DW_AT_name("Int16")
.dwattr $C$DW$T$301, DW_AT_type(*$C$DW$T$300)
.dwattr $C$DW$T$301, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$301, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$301, DW_AT_decl_line(0xef)
.dwattr $C$DW$T$301, DW_AT_decl_column(0x19)
$C$DW$T$1747 .dwtag DW_TAG_typedef, DW_AT_name("CSL_ChaNum")
.dwattr $C$DW$T$1747, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$T$1747, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1747, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1747, DW_AT_decl_line(0x45)
.dwattr $C$DW$T$1747, DW_AT_decl_column(0x19)
$C$DW$T$1748 .dwtag DW_TAG_typedef, DW_AT_name("CSL_InstNum")
.dwattr $C$DW$T$1748, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$T$1748, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1748, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1748, DW_AT_decl_line(0x44)
.dwattr $C$DW$T$1748, DW_AT_decl_column(0x19)
$C$DW$T$1749 .dwtag DW_TAG_typedef, DW_AT_name("CSL_ModuleId")
.dwattr $C$DW$T$1749, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$T$1749, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1749, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1749, DW_AT_decl_line(0x38)
.dwattr $C$DW$T$1749, DW_AT_decl_column(0x19)
$C$DW$T$1750 .dwtag DW_TAG_typedef, DW_AT_name("CSL_Status")
.dwattr $C$DW$T$1750, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$T$1750, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1750, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1750, DW_AT_decl_line(0x43)
.dwattr $C$DW$T$1750, DW_AT_decl_column(0x19)
$C$DW$T$1751 .dwtag DW_TAG_typedef, DW_AT_name("CSL_Uid")
.dwattr $C$DW$T$1751, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$T$1751, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1751, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1751, DW_AT_decl_line(0x37)
.dwattr $C$DW$T$1751, DW_AT_decl_column(0x19)
$C$DW$T$1249 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1249, DW_AT_type(*$C$DW$T$301)
.dwattr $C$DW$T$1249, DW_AT_address_class(0x20)
$C$DW$T$415 .dwtag DW_TAG_typedef, DW_AT_name("ip_int")
.dwattr $C$DW$T$415, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$T$415, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$415, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_types.h")
.dwattr $C$DW$T$415, DW_AT_decl_line(0x0f)
.dwattr $C$DW$T$415, DW_AT_decl_column(0x0f)
$C$DW$T$416 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$416, DW_AT_type(*$C$DW$T$415)
.dwattr $C$DW$T$416, DW_AT_address_class(0x20)
$C$DW$T$1065 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1065, DW_AT_type(*$C$DW$T$416)
.dwattr $C$DW$T$1065, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1065, DW_AT_byte_size(0x14)
$C$DW$2653 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2653, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1065
$C$DW$T$1066 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1066, DW_AT_type(*$C$DW$T$416)
.dwattr $C$DW$T$1066, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1066, DW_AT_byte_size(0x64)
$C$DW$2654 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2654, DW_AT_upper_bound(0x04)
$C$DW$2655 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2655, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1066
$C$DW$T$1216 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1216, DW_AT_type(*$C$DW$T$416)
.dwattr $C$DW$T$1216, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1216, DW_AT_byte_size(0x28)
$C$DW$2656 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2656, DW_AT_upper_bound(0x01)
$C$DW$2657 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2657, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1216
$C$DW$T$1714 .dwtag DW_TAG_restrict_type
.dwattr $C$DW$T$1714, DW_AT_type(*$C$DW$T$416)
$C$DW$T$1204 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1204, DW_AT_type(*$C$DW$T$415)
.dwattr $C$DW$T$1204, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1204, DW_AT_byte_size(0x190)
$C$DW$2658 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2658, DW_AT_upper_bound(0xc7)
.dwendtag $C$DW$T$1204
$C$DW$T$1715 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1715, DW_AT_type(*$C$DW$T$415)
$C$DW$T$1716 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1716, DW_AT_type(*$C$DW$T$1715)
.dwattr $C$DW$T$1716, DW_AT_address_class(0x20)
$C$DW$T$1717 .dwtag DW_TAG_restrict_type
.dwattr $C$DW$T$1717, DW_AT_type(*$C$DW$T$1716)
$C$DW$T$174 .dwtag DW_TAG_typedef, DW_AT_name("s16")
.dwattr $C$DW$T$174, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$T$174, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$174, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$174, DW_AT_decl_line(0x24)
.dwattr $C$DW$T$174, DW_AT_decl_column(0x1c)
$C$DW$T$872 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$872, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$T$872, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$872, DW_AT_byte_size(0x32)
$C$DW$2659 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2659, DW_AT_upper_bound(0x18)
.dwendtag $C$DW$T$872
$C$DW$T$1173 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1173, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$T$1173, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1173, DW_AT_byte_size(0x10)
$C$DW$2660 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2660, DW_AT_upper_bound(0x07)
.dwendtag $C$DW$T$1173
$C$DW$T$1174 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1174, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$T$1174, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1174, DW_AT_byte_size(0x40)
$C$DW$2661 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2661, DW_AT_upper_bound(0x03)
$C$DW$2662 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2662, DW_AT_upper_bound(0x07)
.dwendtag $C$DW$T$1174
$C$DW$T$1405 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1405, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$T$1405, DW_AT_address_class(0x20)
$C$DW$T$1502 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1502, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$T$1502, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1502, DW_AT_byte_size(0x12)
$C$DW$2663 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2663, DW_AT_upper_bound(0x08)
.dwendtag $C$DW$T$1502
$C$DW$T$1523 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1523, DW_AT_type(*$C$DW$T$174)
.dwattr $C$DW$T$1523, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1523, DW_AT_byte_size(0x0a)
$C$DW$2664 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2664, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1523
$C$DW$T$371 .dwtag DW_TAG_typedef, DW_AT_name("tbl_int")
.dwattr $C$DW$T$371, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$T$371, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$371, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_types.h")
.dwattr $C$DW$T$371, DW_AT_decl_line(0x11)
.dwattr $C$DW$T$371, DW_AT_decl_column(0x0f)
$C$DW$T$1544 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1544, DW_AT_type(*$C$DW$T$371)
.dwattr $C$DW$T$1544, DW_AT_address_class(0x20)
$C$DW$T$372 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$372, DW_AT_type(*$C$DW$T$371)
$C$DW$T$373 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$373, DW_AT_type(*$C$DW$T$372)
.dwattr $C$DW$T$373, DW_AT_address_class(0x20)
$C$DW$T$1718 .dwtag DW_TAG_restrict_type
.dwattr $C$DW$T$1718, DW_AT_type(*$C$DW$T$373)
$C$DW$T$1744 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Short")
.dwattr $C$DW$T$1744, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$T$1744, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1744, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1744, DW_AT_decl_line(0x1f)
.dwattr $C$DW$T$1744, DW_AT_decl_column(0x19)
$C$DW$T$1745 .dwtag DW_TAG_typedef, DW_AT_name("Short")
.dwattr $C$DW$T$1745, DW_AT_type(*$C$DW$T$1744)
.dwattr $C$DW$T$1745, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1745, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1745, DW_AT_decl_line(0xdd)
.dwattr $C$DW$T$1745, DW_AT_decl_column(0x19)
$C$DW$T$9 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$9, DW_AT_encoding(DW_ATE_unsigned)
.dwattr $C$DW$T$9, DW_AT_name("unsigned short")
.dwattr $C$DW$T$9, DW_AT_byte_size(0x02)
$C$DW$T$166 .dwtag DW_TAG_typedef, DW_AT_name("u16")
.dwattr $C$DW$T$166, DW_AT_type(*$C$DW$T$9)
.dwattr $C$DW$T$166, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$166, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$166, DW_AT_decl_line(0x20)
.dwattr $C$DW$T$166, DW_AT_decl_column(0x1c)
$C$DW$T$1404 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1404, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$T$1404, DW_AT_address_class(0x20)
$C$DW$T$1503 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1503, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$T$1503, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1503, DW_AT_byte_size(0x12)
$C$DW$2665 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2665, DW_AT_upper_bound(0x08)
.dwendtag $C$DW$T$1503
$C$DW$T$1522 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1522, DW_AT_type(*$C$DW$T$166)
.dwattr $C$DW$T$1522, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1522, DW_AT_byte_size(0x20)
$C$DW$2666 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2666, DW_AT_upper_bound(0x0f)
.dwendtag $C$DW$T$1522
$C$DW$T$1777 .dwtag DW_TAG_typedef, DW_AT_name("uint16")
.dwattr $C$DW$T$1777, DW_AT_type(*$C$DW$T$9)
.dwattr $C$DW$T$1777, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1777, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1777, DW_AT_decl_line(0x16)
.dwattr $C$DW$T$1777, DW_AT_decl_column(0x19)
$C$DW$T$110 .dwtag DW_TAG_typedef, DW_AT_name("uint16_t")
.dwattr $C$DW$T$110, DW_AT_type(*$C$DW$T$9)
.dwattr $C$DW$T$110, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$110, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$110, DW_AT_decl_line(0x2d)
.dwattr $C$DW$T$110, DW_AT_decl_column(0x1c)
$C$DW$T$111 .dwtag DW_TAG_typedef, DW_AT_name("uint_least16_t")
.dwattr $C$DW$T$111, DW_AT_type(*$C$DW$T$110)
.dwattr $C$DW$T$111, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$111, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$111, DW_AT_decl_line(0x3d)
.dwattr $C$DW$T$111, DW_AT_decl_column(0x16)
$C$DW$T$112 .dwtag DW_TAG_typedef, DW_AT_name("xdc_UInt16")
.dwattr $C$DW$T$112, DW_AT_type(*$C$DW$T$111)
.dwattr $C$DW$T$112, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$112, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$112, DW_AT_decl_line(0x6f)
.dwattr $C$DW$T$112, DW_AT_decl_column(0x19)
$C$DW$T$1794 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_maxDepth")
.dwattr $C$DW$T$1794, DW_AT_type(*$C$DW$T$112)
.dwattr $C$DW$T$1794, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1794, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1794, DW_AT_decl_line(0xde)
.dwattr $C$DW$T$1794, DW_AT_decl_column(0x14)
$C$DW$T$891 .dwtag DW_TAG_typedef, DW_AT_name("UInt16")
.dwattr $C$DW$T$891, DW_AT_type(*$C$DW$T$112)
.dwattr $C$DW$T$891, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$891, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$891, DW_AT_decl_line(0xfa)
.dwattr $C$DW$T$891, DW_AT_decl_column(0x19)
$C$DW$T$892 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_QueueIndex")
.dwattr $C$DW$T$892, DW_AT_type(*$C$DW$T$891)
.dwattr $C$DW$T$892, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$892, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$892, DW_AT_decl_line(0x1f5)
.dwattr $C$DW$T$892, DW_AT_decl_column(0x10)
$C$DW$T$113 .dwtag DW_TAG_typedef, DW_AT_name("Uint16")
.dwattr $C$DW$T$113, DW_AT_type(*$C$DW$T$112)
.dwattr $C$DW$T$113, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$113, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$113, DW_AT_decl_line(0x107)
.dwattr $C$DW$T$113, DW_AT_decl_column(0x19)
$C$DW$T$1795 .dwtag DW_TAG_typedef, DW_AT_name("CSL_BitMask16")
.dwattr $C$DW$T$1795, DW_AT_type(*$C$DW$T$113)
.dwattr $C$DW$T$1795, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1795, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1795, DW_AT_decl_line(0x3c)
.dwattr $C$DW$T$1795, DW_AT_decl_column(0x19)
$C$DW$T$1796 .dwtag DW_TAG_volatile_type
.dwattr $C$DW$T$1796, DW_AT_type(*$C$DW$T$113)
$C$DW$T$1797 .dwtag DW_TAG_typedef, DW_AT_name("CSL_Reg16")
.dwattr $C$DW$T$1797, DW_AT_type(*$C$DW$T$1796)
.dwattr $C$DW$T$1797, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1797, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1797, DW_AT_decl_line(0x40)
.dwattr $C$DW$T$1797, DW_AT_decl_column(0x19)
$C$DW$T$595 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Bits16")
.dwattr $C$DW$T$595, DW_AT_type(*$C$DW$T$110)
.dwattr $C$DW$T$595, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$595, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$595, DW_AT_decl_line(0x8c)
.dwattr $C$DW$T$595, DW_AT_decl_column(0x19)
$C$DW$T$884 .dwtag DW_TAG_typedef, DW_AT_name("Bits16")
.dwattr $C$DW$T$884, DW_AT_type(*$C$DW$T$595)
.dwattr $C$DW$T$884, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$884, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$884, DW_AT_decl_line(0x11e)
.dwattr $C$DW$T$884, DW_AT_decl_column(0x19)
$C$DW$T$1778 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1778, DW_AT_type(*$C$DW$T$595)
.dwattr $C$DW$T$1778, DW_AT_address_class(0x20)
$C$DW$T$1779 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__diagsMask")
.dwattr $C$DW$T$1779, DW_AT_type(*$C$DW$T$1778)
.dwattr $C$DW$T$1779, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1779, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1779, DW_AT_decl_line(0xac)
.dwattr $C$DW$T$1779, DW_AT_decl_column(0x15)
$C$DW$T$1780 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__diagsMask")
.dwattr $C$DW$T$1780, DW_AT_type(*$C$DW$T$1778)
.dwattr $C$DW$T$1780, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1780, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1780, DW_AT_decl_line(0x7c)
.dwattr $C$DW$T$1780, DW_AT_decl_column(0x15)
$C$DW$T$1781 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__diagsMask")
.dwattr $C$DW$T$1781, DW_AT_type(*$C$DW$T$1778)
.dwattr $C$DW$T$1781, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1781, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1781, DW_AT_decl_line(0x55)
.dwattr $C$DW$T$1781, DW_AT_decl_column(0x15)
$C$DW$T$1782 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__diagsMask")
.dwattr $C$DW$T$1782, DW_AT_type(*$C$DW$T$1778)
.dwattr $C$DW$T$1782, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1782, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1782, DW_AT_decl_line(0x55)
.dwattr $C$DW$T$1782, DW_AT_decl_column(0x15)
$C$DW$T$1783 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__diagsMask")
.dwattr $C$DW$T$1783, DW_AT_type(*$C$DW$T$1778)
.dwattr $C$DW$T$1783, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1783, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1783, DW_AT_decl_line(0x4f)
.dwattr $C$DW$T$1783, DW_AT_decl_column(0x15)
$C$DW$T$1784 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__diagsMask")
.dwattr $C$DW$T$1784, DW_AT_type(*$C$DW$T$1778)
.dwattr $C$DW$T$1784, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1784, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1784, DW_AT_decl_line(0x63)
.dwattr $C$DW$T$1784, DW_AT_decl_column(0x15)
$C$DW$T$1785 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__diagsMask")
.dwattr $C$DW$T$1785, DW_AT_type(*$C$DW$T$1778)
.dwattr $C$DW$T$1785, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1785, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1785, DW_AT_decl_line(0xdf)
.dwattr $C$DW$T$1785, DW_AT_decl_column(0x15)
$C$DW$T$597 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_DiagsMask")
.dwattr $C$DW$T$597, DW_AT_type(*$C$DW$T$595)
.dwattr $C$DW$T$597, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$597, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$597, DW_AT_decl_line(0x42)
.dwattr $C$DW$T$597, DW_AT_decl_column(0x14)
$C$DW$T$598 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Diags_Mask")
.dwattr $C$DW$T$598, DW_AT_type(*$C$DW$T$597)
.dwattr $C$DW$T$598, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$598, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$598, DW_AT_decl_line(0x43)
.dwattr $C$DW$T$598, DW_AT_decl_column(0x25)
$C$DW$T$599 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$599, DW_AT_type(*$C$DW$T$598)
.dwattr $C$DW$T$599, DW_AT_address_class(0x20)
$C$DW$T$596 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_ModuleId")
.dwattr $C$DW$T$596, DW_AT_type(*$C$DW$T$595)
.dwattr $C$DW$T$596, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$596, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$596, DW_AT_decl_line(0x3f)
.dwattr $C$DW$T$596, DW_AT_decl_column(0x14)
$C$DW$T$1786 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__id")
.dwattr $C$DW$T$1786, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$T$1786, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1786, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1786, DW_AT_decl_line(0xb8)
.dwattr $C$DW$T$1786, DW_AT_decl_column(0x24)
$C$DW$T$1787 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__id")
.dwattr $C$DW$T$1787, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$T$1787, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1787, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1787, DW_AT_decl_line(0x88)
.dwattr $C$DW$T$1787, DW_AT_decl_column(0x24)
$C$DW$T$1788 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__id")
.dwattr $C$DW$T$1788, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$T$1788, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1788, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1788, DW_AT_decl_line(0x61)
.dwattr $C$DW$T$1788, DW_AT_decl_column(0x24)
$C$DW$T$1789 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__id")
.dwattr $C$DW$T$1789, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$T$1789, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1789, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1789, DW_AT_decl_line(0x61)
.dwattr $C$DW$T$1789, DW_AT_decl_column(0x24)
$C$DW$T$1790 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__id")
.dwattr $C$DW$T$1790, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$T$1790, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1790, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1790, DW_AT_decl_line(0x5b)
.dwattr $C$DW$T$1790, DW_AT_decl_column(0x24)
$C$DW$T$1791 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__id")
.dwattr $C$DW$T$1791, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$T$1791, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1791, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1791, DW_AT_decl_line(0x6f)
.dwattr $C$DW$T$1791, DW_AT_decl_column(0x24)
$C$DW$T$1792 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__id")
.dwattr $C$DW$T$1792, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$T$1792, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1792, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1792, DW_AT_decl_line(0xeb)
.dwattr $C$DW$T$1792, DW_AT_decl_column(0x24)
$C$DW$T$1793 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_RopeId")
.dwattr $C$DW$T$1793, DW_AT_type(*$C$DW$T$595)
.dwattr $C$DW$T$1793, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1793, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1793, DW_AT_decl_line(0x57)
.dwattr $C$DW$T$1793, DW_AT_decl_column(0x14)
$C$DW$T$455 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Bool")
.dwattr $C$DW$T$455, DW_AT_type(*$C$DW$T$9)
.dwattr $C$DW$T$455, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$455, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$455, DW_AT_decl_line(0x2d)
.dwattr $C$DW$T$455, DW_AT_decl_column(0x19)
$C$DW$T$456 .dwtag DW_TAG_typedef, DW_AT_name("Bool")
.dwattr $C$DW$T$456, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$456, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$456, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$456, DW_AT_decl_line(0xed)
.dwattr $C$DW$T$456, DW_AT_decl_column(0x19)
$C$DW$T$1754 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__loggerDefined")
.dwattr $C$DW$T$1754, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$1754, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1754, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1754, DW_AT_decl_line(0xbc)
.dwattr $C$DW$T$1754, DW_AT_decl_column(0x12)
$C$DW$T$1755 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_setMaskEnabled")
.dwattr $C$DW$T$1755, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$1755, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1755, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1755, DW_AT_decl_line(0xf0)
.dwattr $C$DW$T$1755, DW_AT_decl_column(0x12)
$C$DW$T$1756 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__loggerDefined")
.dwattr $C$DW$T$1756, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$1756, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1756, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1756, DW_AT_decl_line(0x8c)
.dwattr $C$DW$T$1756, DW_AT_decl_column(0x12)
$C$DW$T$1757 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__loggerDefined")
.dwattr $C$DW$T$1757, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$1757, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1757, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1757, DW_AT_decl_line(0x65)
.dwattr $C$DW$T$1757, DW_AT_decl_column(0x12)
$C$DW$T$1758 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__loggerDefined")
.dwattr $C$DW$T$1758, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$1758, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1758, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1758, DW_AT_decl_line(0x65)
.dwattr $C$DW$T$1758, DW_AT_decl_column(0x12)
$C$DW$T$1759 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__loggerDefined")
.dwattr $C$DW$T$1759, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$1759, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1759, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1759, DW_AT_decl_line(0x5f)
.dwattr $C$DW$T$1759, DW_AT_decl_column(0x12)
$C$DW$T$1760 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__loggerDefined")
.dwattr $C$DW$T$1760, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$1760, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1760, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1760, DW_AT_decl_line(0x73)
.dwattr $C$DW$T$1760, DW_AT_decl_column(0x12)
$C$DW$T$1761 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__loggerDefined")
.dwattr $C$DW$T$1761, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$1761, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1761, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1761, DW_AT_decl_line(0xef)
.dwattr $C$DW$T$1761, DW_AT_decl_column(0x12)
$C$DW$T$640 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$640, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$640, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2667 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2667, DW_AT_type(*$C$DW$T$639)
.dwendtag $C$DW$T$640
$C$DW$T$641 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$641, DW_AT_type(*$C$DW$T$640)
.dwattr $C$DW$T$641, DW_AT_address_class(0x20)
$C$DW$T$1764 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IGateProvider_query_FxnT")
.dwattr $C$DW$T$1764, DW_AT_type(*$C$DW$T$641)
.dwattr $C$DW$T$1764, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1764, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$T$1764, DW_AT_decl_line(0xa2)
.dwattr $C$DW$T$1764, DW_AT_decl_column(0x14)
$C$DW$T$676 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$676, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$676, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2668 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2668, DW_AT_type(*$C$DW$T$3)
.dwendtag $C$DW$T$676
$C$DW$T$677 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$677, DW_AT_type(*$C$DW$T$676)
.dwattr $C$DW$T$677, DW_AT_address_class(0x20)
$C$DW$T$1765 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IHeap_isBlocking_FxnT")
.dwattr $C$DW$T$1765, DW_AT_type(*$C$DW$T$677)
.dwattr $C$DW$T$1765, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1765, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$T$1765, DW_AT_decl_line(0xb3)
.dwattr $C$DW$T$1765, DW_AT_decl_column(0x14)
$C$DW$T$761 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$761, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$761, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2669 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2669, DW_AT_type(*$C$DW$T$756)
.dwendtag $C$DW$T$761
$C$DW$T$762 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$762, DW_AT_type(*$C$DW$T$761)
.dwattr $C$DW$T$762, DW_AT_address_class(0x20)
$C$DW$T$931 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$931, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$931, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2670 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2670, DW_AT_type(*$C$DW$T$3)
$C$DW$2671 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2671, DW_AT_type(*$C$DW$T$668)
.dwendtag $C$DW$T$931
$C$DW$T$932 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$932, DW_AT_type(*$C$DW$T$931)
.dwattr $C$DW$T$932, DW_AT_address_class(0x20)
$C$DW$T$1762 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_put_FxnT")
.dwattr $C$DW$T$1762, DW_AT_type(*$C$DW$T$932)
.dwattr $C$DW$T$1762, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1762, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$1762, DW_AT_decl_line(0xd2)
.dwattr $C$DW$T$1762, DW_AT_decl_column(0x14)
$C$DW$T$934 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$934, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$934, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2672 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2672, DW_AT_type(*$C$DW$T$3)
$C$DW$2673 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2673, DW_AT_type(*$C$DW$T$933)
$C$DW$2674 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2674, DW_AT_type(*$C$DW$T$784)
.dwendtag $C$DW$T$934
$C$DW$T$935 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$935, DW_AT_type(*$C$DW$T$934)
.dwattr $C$DW$T$935, DW_AT_address_class(0x20)
$C$DW$T$1763 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_control_FxnT")
.dwattr $C$DW$T$1763, DW_AT_type(*$C$DW$T$935)
.dwattr $C$DW$T$1763, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1763, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$1763, DW_AT_decl_line(0xd9)
.dwattr $C$DW$T$1763, DW_AT_decl_column(0x14)
$C$DW$T$1766 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1766, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$T$1766, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$T$1767 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1767, DW_AT_type(*$C$DW$T$1766)
.dwattr $C$DW$T$1767, DW_AT_address_class(0x20)
$C$DW$T$1768 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__startupDoneFxn")
.dwattr $C$DW$T$1768, DW_AT_type(*$C$DW$T$1767)
.dwattr $C$DW$T$1768, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1768, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1768, DW_AT_decl_line(0xd8)
.dwattr $C$DW$T$1768, DW_AT_decl_column(0x14)
$C$DW$T$1769 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__startupDoneFxn")
.dwattr $C$DW$T$1769, DW_AT_type(*$C$DW$T$1767)
.dwattr $C$DW$T$1769, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1769, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1769, DW_AT_decl_line(0xa8)
.dwattr $C$DW$T$1769, DW_AT_decl_column(0x14)
$C$DW$T$1770 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__startupDoneFxn")
.dwattr $C$DW$T$1770, DW_AT_type(*$C$DW$T$1767)
.dwattr $C$DW$T$1770, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1770, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1770, DW_AT_decl_line(0x81)
.dwattr $C$DW$T$1770, DW_AT_decl_column(0x14)
$C$DW$T$1771 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__startupDoneFxn")
.dwattr $C$DW$T$1771, DW_AT_type(*$C$DW$T$1767)
.dwattr $C$DW$T$1771, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1771, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1771, DW_AT_decl_line(0x81)
.dwattr $C$DW$T$1771, DW_AT_decl_column(0x14)
$C$DW$T$1772 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__startupDoneFxn")
.dwattr $C$DW$T$1772, DW_AT_type(*$C$DW$T$1767)
.dwattr $C$DW$T$1772, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1772, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1772, DW_AT_decl_line(0x7b)
.dwattr $C$DW$T$1772, DW_AT_decl_column(0x14)
$C$DW$T$1773 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__startupDoneFxn")
.dwattr $C$DW$T$1773, DW_AT_type(*$C$DW$T$1767)
.dwattr $C$DW$T$1773, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1773, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1773, DW_AT_decl_line(0x8f)
.dwattr $C$DW$T$1773, DW_AT_decl_column(0x14)
$C$DW$T$1774 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__startupDoneFxn")
.dwattr $C$DW$T$1774, DW_AT_type(*$C$DW$T$1767)
.dwattr $C$DW$T$1774, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1774, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1774, DW_AT_decl_line(0x10b)
.dwattr $C$DW$T$1774, DW_AT_decl_column(0x14)
$C$DW$T$1775 .dwtag DW_TAG_typedef, DW_AT_name("xdc_UShort")
.dwattr $C$DW$T$1775, DW_AT_type(*$C$DW$T$9)
.dwattr $C$DW$T$1775, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1775, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1775, DW_AT_decl_line(0x20)
.dwattr $C$DW$T$1775, DW_AT_decl_column(0x19)
$C$DW$T$1776 .dwtag DW_TAG_typedef, DW_AT_name("UShort")
.dwattr $C$DW$T$1776, DW_AT_type(*$C$DW$T$1775)
.dwattr $C$DW$T$1776, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1776, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1776, DW_AT_decl_line(0xde)
.dwattr $C$DW$T$1776, DW_AT_decl_column(0x19)
$C$DW$T$10 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$10, DW_AT_encoding(DW_ATE_signed)
.dwattr $C$DW$T$10, DW_AT_name("int")
.dwattr $C$DW$T$10, DW_AT_byte_size(0x04)
$C$DW$T$231 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$231, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$231, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$231, DW_AT_byte_size(0x14)
$C$DW$2675 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2675, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$231
$C$DW$T$984 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$984, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$984, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$984, DW_AT_byte_size(0x80)
$C$DW$2676 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2676, DW_AT_upper_bound(0x1f)
.dwendtag $C$DW$T$984
$C$DW$T$1025 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1025, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$1025, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1025, DW_AT_byte_size(0x24)
$C$DW$2677 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2677, DW_AT_upper_bound(0x08)
.dwendtag $C$DW$T$1025
$C$DW$T$1031 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1031, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$1031, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1031, DW_AT_byte_size(0x1f44)
$C$DW$2678 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2678, DW_AT_upper_bound(0x7d0)
.dwendtag $C$DW$T$1031
$C$DW$T$1195 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1195, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$1195, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1195, DW_AT_byte_size(0x08)
$C$DW$2679 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2679, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$1195
$C$DW$T$1485 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1485, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$1485, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1485, DW_AT_byte_size(0x10)
$C$DW$2680 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2680, DW_AT_upper_bound(0x03)
.dwendtag $C$DW$T$1485
$C$DW$T$1799 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1799, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$1799, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$T$1800 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1800, DW_AT_type(*$C$DW$T$1799)
.dwattr $C$DW$T$1800, DW_AT_address_class(0x20)
$C$DW$T$1801 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Fxn")
.dwattr $C$DW$T$1801, DW_AT_type(*$C$DW$T$1800)
.dwattr $C$DW$T$1801, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1801, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1801, DW_AT_decl_line(0x43)
.dwattr $C$DW$T$1801, DW_AT_decl_column(0x1f)
$C$DW$T$1802 .dwtag DW_TAG_typedef, DW_AT_name("Fxn")
.dwattr $C$DW$T$1802, DW_AT_type(*$C$DW$T$1801)
.dwattr $C$DW$T$1802, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1802, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1802, DW_AT_decl_line(0xf1)
.dwattr $C$DW$T$1802, DW_AT_decl_column(0x19)
$C$DW$T$1803 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1803, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$1803, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2681 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2681, DW_AT_type(*$C$DW$T$653)
$C$DW$2682 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2682, DW_AT_type(*$C$DW$T$653)
.dwendtag $C$DW$T$1803
$C$DW$T$1804 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1804, DW_AT_type(*$C$DW$T$1803)
.dwattr $C$DW$T$1804, DW_AT_address_class(0x20)
$C$DW$T$1805 .dwtag DW_TAG_typedef, DW_AT_name("__TI_compar_fn")
.dwattr $C$DW$T$1805, DW_AT_type(*$C$DW$T$1804)
.dwattr $C$DW$T$1805, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1805, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$T$1805, DW_AT_decl_line(0x90)
.dwattr $C$DW$T$1805, DW_AT_decl_column(0x13)
$C$DW$T$1830 .dwtag DW_TAG_typedef, DW_AT_name("cpx32")
.dwattr $C$DW$T$1830, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$1830, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1830, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1830, DW_AT_decl_line(0x10)
.dwattr $C$DW$T$1830, DW_AT_decl_column(0x13)
$C$DW$T$1822 .dwtag DW_TAG_typedef, DW_AT_name("int32")
.dwattr $C$DW$T$1822, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$1822, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1822, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1822, DW_AT_decl_line(0x14)
.dwattr $C$DW$T$1822, DW_AT_decl_column(0x19)
$C$DW$T$106 .dwtag DW_TAG_typedef, DW_AT_name("int32_t")
.dwattr $C$DW$T$106, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$106, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$106, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$106, DW_AT_decl_line(0x2e)
.dwattr $C$DW$T$106, DW_AT_decl_column(0x1d)
$C$DW$T$333 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$333, DW_AT_type(*$C$DW$T$106)
.dwattr $C$DW$T$333, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$333, DW_AT_byte_size(0x10)
$C$DW$2683 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2683, DW_AT_upper_bound(0x03)
.dwendtag $C$DW$T$333
$C$DW$T$1823 .dwtag DW_TAG_typedef, DW_AT_name("int_fast16_t")
.dwattr $C$DW$T$1823, DW_AT_type(*$C$DW$T$106)
.dwattr $C$DW$T$1823, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1823, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1823, DW_AT_decl_line(0x4b)
.dwattr $C$DW$T$1823, DW_AT_decl_column(0x17)
$C$DW$T$1824 .dwtag DW_TAG_typedef, DW_AT_name("int_fast32_t")
.dwattr $C$DW$T$1824, DW_AT_type(*$C$DW$T$106)
.dwattr $C$DW$T$1824, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1824, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1824, DW_AT_decl_line(0x4e)
.dwattr $C$DW$T$1824, DW_AT_decl_column(0x17)
$C$DW$T$1825 .dwtag DW_TAG_typedef, DW_AT_name("int_fast8_t")
.dwattr $C$DW$T$1825, DW_AT_type(*$C$DW$T$106)
.dwattr $C$DW$T$1825, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1825, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1825, DW_AT_decl_line(0x49)
.dwattr $C$DW$T$1825, DW_AT_decl_column(0x17)
$C$DW$T$107 .dwtag DW_TAG_typedef, DW_AT_name("int_least32_t")
.dwattr $C$DW$T$107, DW_AT_type(*$C$DW$T$106)
.dwattr $C$DW$T$107, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$107, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$107, DW_AT_decl_line(0x3e)
.dwattr $C$DW$T$107, DW_AT_decl_column(0x17)
$C$DW$T$108 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Int32")
.dwattr $C$DW$T$108, DW_AT_type(*$C$DW$T$107)
.dwattr $C$DW$T$108, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$108, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$108, DW_AT_decl_line(0x70)
.dwattr $C$DW$T$108, DW_AT_decl_column(0x19)
$C$DW$T$109 .dwtag DW_TAG_typedef, DW_AT_name("Int32")
.dwattr $C$DW$T$109, DW_AT_type(*$C$DW$T$108)
.dwattr $C$DW$T$109, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$109, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$109, DW_AT_decl_line(0xf0)
.dwattr $C$DW$T$109, DW_AT_decl_column(0x19)
$C$DW$T$1719 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1719, DW_AT_type(*$C$DW$T$109)
$C$DW$T$519 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$519, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$T$519, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$519, DW_AT_byte_size(0x08)
$C$DW$2684 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2684, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$519
$C$DW$T$1205 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1205, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$T$1205, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1205, DW_AT_byte_size(0xda0)
$C$DW$2685 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2685, DW_AT_upper_bound(0x367)
.dwendtag $C$DW$T$1205
$C$DW$T$1207 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1207, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$T$1207, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1207, DW_AT_byte_size(0x1b40)
$C$DW$2686 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2686, DW_AT_upper_bound(0x01)
$C$DW$2687 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2687, DW_AT_upper_bound(0x367)
.dwendtag $C$DW$T$1207
$C$DW$T$1206 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1206, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$T$1206, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1206, DW_AT_byte_size(0x1000)
$C$DW$2688 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2688, DW_AT_upper_bound(0x3ff)
.dwendtag $C$DW$T$1206
$C$DW$T$1208 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1208, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$T$1208, DW_AT_address_class(0x20)
$C$DW$T$1209 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1209, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$T$1209, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1209, DW_AT_byte_size(0x6d0)
$C$DW$2689 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2689, DW_AT_upper_bound(0x1b3)
.dwendtag $C$DW$T$1209
$C$DW$T$1210 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1210, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$T$1210, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1210, DW_AT_byte_size(0xda0)
$C$DW$2690 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2690, DW_AT_upper_bound(0x01)
$C$DW$2691 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2691, DW_AT_upper_bound(0x1b3)
.dwendtag $C$DW$T$1210
$C$DW$T$588 .dwtag DW_TAG_typedef, DW_AT_name("intptr_t")
.dwattr $C$DW$T$588, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$588, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$588, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$588, DW_AT_decl_line(0x58)
.dwattr $C$DW$T$588, DW_AT_decl_column(0x1a)
$C$DW$T$589 .dwtag DW_TAG_typedef, DW_AT_name("xdc_IArg")
.dwattr $C$DW$T$589, DW_AT_type(*$C$DW$T$588)
.dwattr $C$DW$T$589, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$589, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$589, DW_AT_decl_line(0x98)
.dwattr $C$DW$T$589, DW_AT_decl_column(0x19)
$C$DW$T$1826 .dwtag DW_TAG_typedef, DW_AT_name("IArg")
.dwattr $C$DW$T$1826, DW_AT_type(*$C$DW$T$589)
.dwattr $C$DW$T$1826, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1826, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1826, DW_AT_decl_line(0xeb)
.dwattr $C$DW$T$1826, DW_AT_decl_column(0x19)
$C$DW$T$1827 .dwtag DW_TAG_typedef, DW_AT_name("__T1_xdc_runtime_Error_Block__xtra")
.dwattr $C$DW$T$1827, DW_AT_type(*$C$DW$T$589)
.dwattr $C$DW$T$1827, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1827, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1827, DW_AT_decl_line(0x5a)
.dwattr $C$DW$T$1827, DW_AT_decl_column(0x12)
$C$DW$T$1828 .dwtag DW_TAG_typedef, DW_AT_name("__T1_xdc_runtime_Error_Data__arg")
.dwattr $C$DW$T$1828, DW_AT_type(*$C$DW$T$589)
.dwattr $C$DW$T$1828, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1828, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1828, DW_AT_decl_line(0x52)
.dwattr $C$DW$T$1828, DW_AT_decl_column(0x12)
$C$DW$T$611 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$611, DW_AT_type(*$C$DW$T$589)
.dwattr $C$DW$T$611, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$611, DW_AT_byte_size(0x10)
$C$DW$2692 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2692, DW_AT_upper_bound(0x03)
.dwendtag $C$DW$T$611
$C$DW$T$612 .dwtag DW_TAG_typedef, DW_AT_name("__ARRAY1_xdc_runtime_Error_Block__xtra")
.dwattr $C$DW$T$612, DW_AT_type(*$C$DW$T$611)
.dwattr $C$DW$T$612, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$612, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$612, DW_AT_decl_line(0x5b)
.dwattr $C$DW$T$612, DW_AT_decl_column(0x12)
$C$DW$T$613 .dwtag DW_TAG_typedef, DW_AT_name("__TA_xdc_runtime_Error_Block__xtra")
.dwattr $C$DW$T$613, DW_AT_type(*$C$DW$T$612)
.dwattr $C$DW$T$613, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$613, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$613, DW_AT_decl_line(0x5c)
.dwattr $C$DW$T$613, DW_AT_decl_column(0x30)
$C$DW$T$619 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$619, DW_AT_type(*$C$DW$T$589)
.dwattr $C$DW$T$619, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$619, DW_AT_byte_size(0x08)
$C$DW$2693 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2693, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$619
$C$DW$T$620 .dwtag DW_TAG_typedef, DW_AT_name("__ARRAY1_xdc_runtime_Error_Data__arg")
.dwattr $C$DW$T$620, DW_AT_type(*$C$DW$T$619)
.dwattr $C$DW$T$620, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$620, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$620, DW_AT_decl_line(0x53)
.dwattr $C$DW$T$620, DW_AT_decl_column(0x12)
$C$DW$T$621 .dwtag DW_TAG_typedef, DW_AT_name("__TA_xdc_runtime_Error_Data__arg")
.dwattr $C$DW$T$621, DW_AT_type(*$C$DW$T$620)
.dwattr $C$DW$T$621, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$621, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$621, DW_AT_decl_line(0x54)
.dwattr $C$DW$T$621, DW_AT_decl_column(0x2e)
$C$DW$T$642 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$642, DW_AT_type(*$C$DW$T$589)
.dwattr $C$DW$T$642, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2694 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2694, DW_AT_type(*$C$DW$T$3)
.dwendtag $C$DW$T$642
$C$DW$T$643 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$643, DW_AT_type(*$C$DW$T$642)
.dwattr $C$DW$T$643, DW_AT_address_class(0x20)
$C$DW$T$1829 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IGateProvider_enter_FxnT")
.dwattr $C$DW$T$1829, DW_AT_type(*$C$DW$T$643)
.dwattr $C$DW$T$1829, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1829, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$T$1829, DW_AT_decl_line(0xa9)
.dwattr $C$DW$T$1829, DW_AT_decl_column(0x14)
$C$DW$T$730 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$730, DW_AT_type(*$C$DW$T$589)
.dwattr $C$DW$T$730, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2695 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2695, DW_AT_type(*$C$DW$T$729)
.dwendtag $C$DW$T$730
$C$DW$T$731 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$731, DW_AT_type(*$C$DW$T$730)
.dwattr $C$DW$T$731, DW_AT_address_class(0x20)
$C$DW$T$1798 .dwtag DW_TAG_typedef, DW_AT_name("ptrdiff_t")
.dwattr $C$DW$T$1798, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$1798, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1798, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stddef.h")
.dwattr $C$DW$T$1798, DW_AT_decl_line(0x31)
.dwattr $C$DW$T$1798, DW_AT_decl_column(0x1c)
$C$DW$T$133 .dwtag DW_TAG_typedef, DW_AT_name("s32")
.dwattr $C$DW$T$133, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$133, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$133, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$133, DW_AT_decl_line(0x23)
.dwattr $C$DW$T$133, DW_AT_decl_column(0x1c)
$C$DW$T$187 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$187, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$T$187, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$187, DW_AT_byte_size(0x0c)
$C$DW$2696 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2696, DW_AT_upper_bound(0x02)
.dwendtag $C$DW$T$187
$C$DW$T$1047 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1047, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$T$1047, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1047, DW_AT_byte_size(0x14)
$C$DW$2697 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2697, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1047
$C$DW$T$1087 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1087, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$T$1087, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1087, DW_AT_byte_size(0x08)
$C$DW$2698 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2698, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$1087
$C$DW$T$1121 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1121, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$T$1121, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1121, DW_AT_byte_size(0x10)
$C$DW$2699 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2699, DW_AT_upper_bound(0x03)
.dwendtag $C$DW$T$1121
$C$DW$T$1330 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1330, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$T$1330, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1330, DW_AT_byte_size(0x40)
$C$DW$2700 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2700, DW_AT_upper_bound(0x0f)
.dwendtag $C$DW$T$1330
$C$DW$T$1332 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1332, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$T$1332, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1332, DW_AT_byte_size(0x28)
$C$DW$2701 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2701, DW_AT_upper_bound(0x09)
.dwendtag $C$DW$T$1332
$C$DW$T$1407 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1407, DW_AT_type(*$C$DW$T$133)
.dwattr $C$DW$T$1407, DW_AT_address_class(0x20)
$C$DW$T$1810 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Arg")
.dwattr $C$DW$T$1810, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$1810, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1810, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$1810, DW_AT_decl_line(0x27)
.dwattr $C$DW$T$1810, DW_AT_decl_column(0x15)
$C$DW$T$1811 .dwtag DW_TAG_typedef, DW_AT_name("Arg")
.dwattr $C$DW$T$1811, DW_AT_type(*$C$DW$T$1810)
.dwattr $C$DW$T$1811, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1811, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1811, DW_AT_decl_line(0x103)
.dwattr $C$DW$T$1811, DW_AT_decl_column(0x19)
$C$DW$T$639 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Int")
.dwattr $C$DW$T$639, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$639, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$639, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$639, DW_AT_decl_line(0x21)
.dwattr $C$DW$T$639, DW_AT_decl_column(0x19)
$C$DW$T$1812 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Object__count")
.dwattr $C$DW$T$1812, DW_AT_type(*$C$DW$T$639)
.dwattr $C$DW$T$1812, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1812, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1812, DW_AT_decl_line(0xdc)
.dwattr $C$DW$T$1812, DW_AT_decl_column(0x11)
$C$DW$T$1813 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Object__count")
.dwattr $C$DW$T$1813, DW_AT_type(*$C$DW$T$639)
.dwattr $C$DW$T$1813, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1813, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1813, DW_AT_decl_line(0xac)
.dwattr $C$DW$T$1813, DW_AT_decl_column(0x11)
$C$DW$T$1814 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Object__count")
.dwattr $C$DW$T$1814, DW_AT_type(*$C$DW$T$639)
.dwattr $C$DW$T$1814, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1814, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1814, DW_AT_decl_line(0x85)
.dwattr $C$DW$T$1814, DW_AT_decl_column(0x11)
$C$DW$T$1815 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Object__count")
.dwattr $C$DW$T$1815, DW_AT_type(*$C$DW$T$639)
.dwattr $C$DW$T$1815, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1815, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1815, DW_AT_decl_line(0x85)
.dwattr $C$DW$T$1815, DW_AT_decl_column(0x11)
$C$DW$T$1816 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Object__count")
.dwattr $C$DW$T$1816, DW_AT_type(*$C$DW$T$639)
.dwattr $C$DW$T$1816, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1816, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1816, DW_AT_decl_line(0x7f)
.dwattr $C$DW$T$1816, DW_AT_decl_column(0x11)
$C$DW$T$1817 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Object__count")
.dwattr $C$DW$T$1817, DW_AT_type(*$C$DW$T$639)
.dwattr $C$DW$T$1817, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1817, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1817, DW_AT_decl_line(0x93)
.dwattr $C$DW$T$1817, DW_AT_decl_column(0x11)
$C$DW$T$1818 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Object__count")
.dwattr $C$DW$T$1818, DW_AT_type(*$C$DW$T$639)
.dwattr $C$DW$T$1818, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1818, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1818, DW_AT_decl_line(0x10f)
.dwattr $C$DW$T$1818, DW_AT_decl_column(0x11)
$C$DW$T$890 .dwtag DW_TAG_typedef, DW_AT_name("Int")
.dwattr $C$DW$T$890, DW_AT_type(*$C$DW$T$639)
.dwattr $C$DW$T$890, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$890, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$890, DW_AT_decl_line(0xdf)
.dwattr $C$DW$T$890, DW_AT_decl_column(0x19)
$C$DW$T$929 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$929, DW_AT_type(*$C$DW$T$639)
.dwattr $C$DW$T$929, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2702 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2702, DW_AT_type(*$C$DW$T$3)
.dwendtag $C$DW$T$929
$C$DW$T$930 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$930, DW_AT_type(*$C$DW$T$929)
.dwattr $C$DW$T$930, DW_AT_address_class(0x20)
$C$DW$T$1819 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_getStatus_FxnT")
.dwattr $C$DW$T$1819, DW_AT_type(*$C$DW$T$930)
.dwattr $C$DW$T$1819, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1819, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$1819, DW_AT_decl_line(0xcb)
.dwattr $C$DW$T$1819, DW_AT_decl_column(0x13)
$C$DW$T$1820 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Long")
.dwattr $C$DW$T$1820, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$1820, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1820, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1820, DW_AT_decl_line(0x23)
.dwattr $C$DW$T$1820, DW_AT_decl_column(0x19)
$C$DW$T$1821 .dwtag DW_TAG_typedef, DW_AT_name("Long")
.dwattr $C$DW$T$1821, DW_AT_type(*$C$DW$T$1820)
.dwattr $C$DW$T$1821, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1821, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1821, DW_AT_decl_line(0xe1)
.dwattr $C$DW$T$1821, DW_AT_decl_column(0x19)
$C$DW$T$11 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$11, DW_AT_encoding(DW_ATE_unsigned)
.dwattr $C$DW$T$11, DW_AT_name("unsigned int")
.dwattr $C$DW$T$11, DW_AT_byte_size(0x04)
$C$DW$T$651 .dwtag DW_TAG_typedef, DW_AT_name("size_t")
.dwattr $C$DW$T$651, DW_AT_type(*$C$DW$T$11)
.dwattr $C$DW$T$651, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$651, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stddef.h")
.dwattr $C$DW$T$651, DW_AT_decl_line(0x35)
.dwattr $C$DW$T$651, DW_AT_decl_column(0x19)
$C$DW$T$669 .dwtag DW_TAG_typedef, DW_AT_name("xdc_SizeT")
.dwattr $C$DW$T$669, DW_AT_type(*$C$DW$T$651)
.dwattr $C$DW$T$669, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$669, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$669, DW_AT_decl_line(0x28)
.dwattr $C$DW$T$669, DW_AT_decl_column(0x19)
$C$DW$T$1831 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Object__sizeof")
.dwattr $C$DW$T$1831, DW_AT_type(*$C$DW$T$669)
.dwattr $C$DW$T$1831, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1831, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1831, DW_AT_decl_line(0xe4)
.dwattr $C$DW$T$1831, DW_AT_decl_column(0x13)
$C$DW$T$1832 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Object__sizeof")
.dwattr $C$DW$T$1832, DW_AT_type(*$C$DW$T$669)
.dwattr $C$DW$T$1832, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1832, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1832, DW_AT_decl_line(0xb4)
.dwattr $C$DW$T$1832, DW_AT_decl_column(0x13)
$C$DW$T$1833 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Object__sizeof")
.dwattr $C$DW$T$1833, DW_AT_type(*$C$DW$T$669)
.dwattr $C$DW$T$1833, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1833, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1833, DW_AT_decl_line(0x8d)
.dwattr $C$DW$T$1833, DW_AT_decl_column(0x13)
$C$DW$T$1834 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Object__sizeof")
.dwattr $C$DW$T$1834, DW_AT_type(*$C$DW$T$669)
.dwattr $C$DW$T$1834, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1834, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1834, DW_AT_decl_line(0x8d)
.dwattr $C$DW$T$1834, DW_AT_decl_column(0x13)
$C$DW$T$1835 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Object__sizeof")
.dwattr $C$DW$T$1835, DW_AT_type(*$C$DW$T$669)
.dwattr $C$DW$T$1835, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1835, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1835, DW_AT_decl_line(0x87)
.dwattr $C$DW$T$1835, DW_AT_decl_column(0x13)
$C$DW$T$1836 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Object__sizeof")
.dwattr $C$DW$T$1836, DW_AT_type(*$C$DW$T$669)
.dwattr $C$DW$T$1836, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1836, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1836, DW_AT_decl_line(0x9b)
.dwattr $C$DW$T$1836, DW_AT_decl_column(0x13)
$C$DW$T$1837 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Object__sizeof")
.dwattr $C$DW$T$1837, DW_AT_type(*$C$DW$T$669)
.dwattr $C$DW$T$1837, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1837, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1837, DW_AT_decl_line(0x117)
.dwattr $C$DW$T$1837, DW_AT_decl_column(0x13)
$C$DW$T$1838 .dwtag DW_TAG_typedef, DW_AT_name("SizeT")
.dwattr $C$DW$T$1838, DW_AT_type(*$C$DW$T$669)
.dwattr $C$DW$T$1838, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1838, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1838, DW_AT_decl_line(0xe8)
.dwattr $C$DW$T$1838, DW_AT_decl_column(0x19)
$C$DW$T$143 .dwtag DW_TAG_typedef, DW_AT_name("u32")
.dwattr $C$DW$T$143, DW_AT_type(*$C$DW$T$11)
.dwattr $C$DW$T$143, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$143, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$143, DW_AT_decl_line(0x1f)
.dwattr $C$DW$T$143, DW_AT_decl_column(0x1c)
$C$DW$T$186 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$186, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$T$186, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$186, DW_AT_byte_size(0x0c)
$C$DW$2703 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2703, DW_AT_upper_bound(0x02)
.dwendtag $C$DW$T$186
$C$DW$T$189 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$189, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$T$189, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$189, DW_AT_byte_size(0x20)
$C$DW$2704 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2704, DW_AT_upper_bound(0x07)
.dwendtag $C$DW$T$189
$C$DW$T$1288 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1288, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$T$1288, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1288, DW_AT_byte_size(0x18)
$C$DW$2705 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2705, DW_AT_upper_bound(0x05)
.dwendtag $C$DW$T$1288
$C$DW$T$1406 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1406, DW_AT_type(*$C$DW$T$143)
.dwattr $C$DW$T$1406, DW_AT_address_class(0x20)
$C$DW$T$1843 .dwtag DW_TAG_typedef, DW_AT_name("uint32")
.dwattr $C$DW$T$1843, DW_AT_type(*$C$DW$T$11)
.dwattr $C$DW$T$1843, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1843, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1843, DW_AT_decl_line(0x17)
.dwattr $C$DW$T$1843, DW_AT_decl_column(0x19)
$C$DW$T$114 .dwtag DW_TAG_typedef, DW_AT_name("uint32_t")
.dwattr $C$DW$T$114, DW_AT_type(*$C$DW$T$11)
.dwattr $C$DW$T$114, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$114, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$114, DW_AT_decl_line(0x2f)
.dwattr $C$DW$T$114, DW_AT_decl_column(0x1c)
$C$DW$T$1865 .dwtag DW_TAG_typedef, DW_AT_name("uint_fast16_t")
.dwattr $C$DW$T$1865, DW_AT_type(*$C$DW$T$114)
.dwattr $C$DW$T$1865, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1865, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1865, DW_AT_decl_line(0x4c)
.dwattr $C$DW$T$1865, DW_AT_decl_column(0x16)
$C$DW$T$1866 .dwtag DW_TAG_typedef, DW_AT_name("uint_fast32_t")
.dwattr $C$DW$T$1866, DW_AT_type(*$C$DW$T$114)
.dwattr $C$DW$T$1866, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1866, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1866, DW_AT_decl_line(0x4f)
.dwattr $C$DW$T$1866, DW_AT_decl_column(0x16)
$C$DW$T$1867 .dwtag DW_TAG_typedef, DW_AT_name("uint_fast8_t")
.dwattr $C$DW$T$1867, DW_AT_type(*$C$DW$T$114)
.dwattr $C$DW$T$1867, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1867, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1867, DW_AT_decl_line(0x4a)
.dwattr $C$DW$T$1867, DW_AT_decl_column(0x16)
$C$DW$T$115 .dwtag DW_TAG_typedef, DW_AT_name("uint_least32_t")
.dwattr $C$DW$T$115, DW_AT_type(*$C$DW$T$114)
.dwattr $C$DW$T$115, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$115, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$115, DW_AT_decl_line(0x3f)
.dwattr $C$DW$T$115, DW_AT_decl_column(0x16)
$C$DW$T$116 .dwtag DW_TAG_typedef, DW_AT_name("xdc_UInt32")
.dwattr $C$DW$T$116, DW_AT_type(*$C$DW$T$115)
.dwattr $C$DW$T$116, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$116, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$116, DW_AT_decl_line(0x71)
.dwattr $C$DW$T$116, DW_AT_decl_column(0x19)
$C$DW$T$1449 .dwtag DW_TAG_typedef, DW_AT_name("UInt32")
.dwattr $C$DW$T$1449, DW_AT_type(*$C$DW$T$116)
.dwattr $C$DW$T$1449, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1449, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1449, DW_AT_decl_line(0xfb)
.dwattr $C$DW$T$1449, DW_AT_decl_column(0x19)
$C$DW$T$1646 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_QueueId")
.dwattr $C$DW$T$1646, DW_AT_type(*$C$DW$T$1449)
.dwattr $C$DW$T$1646, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1646, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h")
.dwattr $C$DW$T$1646, DW_AT_decl_line(0x1f0)
.dwattr $C$DW$T$1646, DW_AT_decl_column(0x10)
$C$DW$T$117 .dwtag DW_TAG_typedef, DW_AT_name("Uint32")
.dwattr $C$DW$T$117, DW_AT_type(*$C$DW$T$116)
.dwattr $C$DW$T$117, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$117, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$117, DW_AT_decl_line(0x108)
.dwattr $C$DW$T$117, DW_AT_decl_column(0x19)
$C$DW$T$1868 .dwtag DW_TAG_typedef, DW_AT_name("CSL_BitMask32")
.dwattr $C$DW$T$1868, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$T$1868, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1868, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1868, DW_AT_decl_line(0x3d)
.dwattr $C$DW$T$1868, DW_AT_decl_column(0x19)
$C$DW$T$1869 .dwtag DW_TAG_typedef, DW_AT_name("CSL_Xio")
.dwattr $C$DW$T$1869, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$T$1869, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1869, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1869, DW_AT_decl_line(0x39)
.dwattr $C$DW$T$1869, DW_AT_decl_column(0x19)
$C$DW$T$1870 .dwtag DW_TAG_volatile_type
.dwattr $C$DW$T$1870, DW_AT_type(*$C$DW$T$117)
$C$DW$T$1871 .dwtag DW_TAG_typedef, DW_AT_name("CSL_Reg32")
.dwattr $C$DW$T$1871, DW_AT_type(*$C$DW$T$1870)
.dwattr $C$DW$T$1871, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1871, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1871, DW_AT_decl_line(0x41)
.dwattr $C$DW$T$1871, DW_AT_decl_column(0x19)
$C$DW$T$152 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$152, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$T$152, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$152, DW_AT_byte_size(0x20)
$C$DW$2706 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2706, DW_AT_upper_bound(0x07)
$C$DW$T$493 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$493, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$T$493, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$493, DW_AT_byte_size(0x1c)
$C$DW$2707 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2707, DW_AT_upper_bound(0x06)
.dwendtag $C$DW$T$493
$C$DW$T$520 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$520, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$T$520, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$520, DW_AT_byte_size(0x08)
$C$DW$2708 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2708, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$520
$C$DW$T$542 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$542, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$T$542, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$542, DW_AT_byte_size(0x18)
$C$DW$2709 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2709, DW_AT_upper_bound(0x05)
.dwendtag $C$DW$T$542
$C$DW$T$606 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Bits32")
.dwattr $C$DW$T$606, DW_AT_type(*$C$DW$T$114)
.dwattr $C$DW$T$606, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$606, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$606, DW_AT_decl_line(0x8f)
.dwattr $C$DW$T$606, DW_AT_decl_column(0x19)
$C$DW$T$883 .dwtag DW_TAG_typedef, DW_AT_name("Bits32")
.dwattr $C$DW$T$883, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$883, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$883, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$883, DW_AT_decl_line(0x122)
.dwattr $C$DW$T$883, DW_AT_decl_column(0x19)
$C$DW$T$1845 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__diagsEnabled")
.dwattr $C$DW$T$1845, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1845, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1845, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1845, DW_AT_decl_line(0xa4)
.dwattr $C$DW$T$1845, DW_AT_decl_column(0x14)
$C$DW$T$1846 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Module__diagsIncluded")
.dwattr $C$DW$T$1846, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1846, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1846, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1846, DW_AT_decl_line(0xa8)
.dwattr $C$DW$T$1846, DW_AT_decl_column(0x14)
$C$DW$T$1847 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__diagsEnabled")
.dwattr $C$DW$T$1847, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1847, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1847, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1847, DW_AT_decl_line(0x74)
.dwattr $C$DW$T$1847, DW_AT_decl_column(0x14)
$C$DW$T$1848 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Module__diagsIncluded")
.dwattr $C$DW$T$1848, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1848, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1848, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1848, DW_AT_decl_line(0x78)
.dwattr $C$DW$T$1848, DW_AT_decl_column(0x14)
$C$DW$T$1849 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__diagsEnabled")
.dwattr $C$DW$T$1849, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1849, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1849, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1849, DW_AT_decl_line(0x4d)
.dwattr $C$DW$T$1849, DW_AT_decl_column(0x14)
$C$DW$T$1850 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Module__diagsIncluded")
.dwattr $C$DW$T$1850, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1850, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1850, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1850, DW_AT_decl_line(0x51)
.dwattr $C$DW$T$1850, DW_AT_decl_column(0x14)
$C$DW$T$1851 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__diagsEnabled")
.dwattr $C$DW$T$1851, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1851, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1851, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1851, DW_AT_decl_line(0x4d)
.dwattr $C$DW$T$1851, DW_AT_decl_column(0x14)
$C$DW$T$1852 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module__diagsIncluded")
.dwattr $C$DW$T$1852, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1852, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1852, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1852, DW_AT_decl_line(0x51)
.dwattr $C$DW$T$1852, DW_AT_decl_column(0x14)
$C$DW$T$1853 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__diagsEnabled")
.dwattr $C$DW$T$1853, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1853, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1853, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1853, DW_AT_decl_line(0x47)
.dwattr $C$DW$T$1853, DW_AT_decl_column(0x14)
$C$DW$T$1854 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Module__diagsIncluded")
.dwattr $C$DW$T$1854, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1854, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1854, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1854, DW_AT_decl_line(0x4b)
.dwattr $C$DW$T$1854, DW_AT_decl_column(0x14)
$C$DW$T$1855 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__diagsEnabled")
.dwattr $C$DW$T$1855, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1855, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1855, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1855, DW_AT_decl_line(0x5b)
.dwattr $C$DW$T$1855, DW_AT_decl_column(0x14)
$C$DW$T$1856 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Module__diagsIncluded")
.dwattr $C$DW$T$1856, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1856, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1856, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1856, DW_AT_decl_line(0x5f)
.dwattr $C$DW$T$1856, DW_AT_decl_column(0x14)
$C$DW$T$1857 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__diagsEnabled")
.dwattr $C$DW$T$1857, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1857, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1857, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1857, DW_AT_decl_line(0xd7)
.dwattr $C$DW$T$1857, DW_AT_decl_column(0x14)
$C$DW$T$1858 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Module__diagsIncluded")
.dwattr $C$DW$T$1858, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1858, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1858, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1858, DW_AT_decl_line(0xdb)
.dwattr $C$DW$T$1858, DW_AT_decl_column(0x14)
$C$DW$T$607 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Error_Id")
.dwattr $C$DW$T$607, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$607, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$607, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error__prologue.h")
.dwattr $C$DW$T$607, DW_AT_decl_line(0x12)
.dwattr $C$DW$T$607, DW_AT_decl_column(0x14)
$C$DW$T$1859 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_E_generic")
.dwattr $C$DW$T$1859, DW_AT_type(*$C$DW$T$607)
.dwattr $C$DW$T$1859, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1859, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1859, DW_AT_decl_line(0xc2)
.dwattr $C$DW$T$1859, DW_AT_decl_column(0x1e)
$C$DW$T$1860 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_E_memory")
.dwattr $C$DW$T$1860, DW_AT_type(*$C$DW$T$607)
.dwattr $C$DW$T$1860, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1860, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1860, DW_AT_decl_line(0xc7)
.dwattr $C$DW$T$1860, DW_AT_decl_column(0x1e)
$C$DW$T$1861 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_E_msgCode")
.dwattr $C$DW$T$1861, DW_AT_type(*$C$DW$T$607)
.dwattr $C$DW$T$1861, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1861, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1861, DW_AT_decl_line(0xcc)
.dwattr $C$DW$T$1861, DW_AT_decl_column(0x1e)
$C$DW$T$1862 .dwtag DW_TAG_typedef, DW_AT_name("Id")
.dwattr $C$DW$T$1862, DW_AT_type(*$C$DW$T$607)
.dwattr $C$DW$T$1862, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1862, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error__prologue.h")
.dwattr $C$DW$T$1862, DW_AT_decl_line(0x16)
.dwattr $C$DW$T$1862, DW_AT_decl_column(0x22)
$C$DW$T$1863 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_Event")
.dwattr $C$DW$T$1863, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1863, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1863, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1863, DW_AT_decl_line(0x45)
.dwattr $C$DW$T$1863, DW_AT_decl_column(0x14)
$C$DW$T$1864 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_EventId")
.dwattr $C$DW$T$1864, DW_AT_type(*$C$DW$T$1863)
.dwattr $C$DW$T$1864, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1864, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1864, DW_AT_decl_line(0x48)
.dwattr $C$DW$T$1864, DW_AT_decl_column(0x21)
$C$DW$T$1652 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_LogEvent")
.dwattr $C$DW$T$1652, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$T$1652, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1652, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$1652, DW_AT_decl_line(0x92)
.dwattr $C$DW$T$1652, DW_AT_decl_column(0x14)
$C$DW$T$783 .dwtag DW_TAG_typedef, DW_AT_name("uintptr_t")
.dwattr $C$DW$T$783, DW_AT_type(*$C$DW$T$11)
.dwattr $C$DW$T$783, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$783, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$783, DW_AT_decl_line(0x59)
.dwattr $C$DW$T$783, DW_AT_decl_column(0x1a)
$C$DW$T$784 .dwtag DW_TAG_typedef, DW_AT_name("xdc_UArg")
.dwattr $C$DW$T$784, DW_AT_type(*$C$DW$T$783)
.dwattr $C$DW$T$784, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$784, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$784, DW_AT_decl_line(0x99)
.dwattr $C$DW$T$784, DW_AT_decl_column(0x19)
$C$DW$T$1872 .dwtag DW_TAG_typedef, DW_AT_name("UArg")
.dwattr $C$DW$T$1872, DW_AT_type(*$C$DW$T$784)
.dwattr $C$DW$T$1872, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1872, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1872, DW_AT_decl_line(0xec)
.dwattr $C$DW$T$1872, DW_AT_decl_column(0x19)
$C$DW$T$785 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Memory_Size")
.dwattr $C$DW$T$785, DW_AT_type(*$C$DW$T$784)
.dwattr $C$DW$T$785, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$785, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$785, DW_AT_decl_line(0x47)
.dwattr $C$DW$T$785, DW_AT_decl_column(0x12)
$C$DW$T$933 .dwtag DW_TAG_typedef, DW_AT_name("xdc_UInt")
.dwattr $C$DW$T$933, DW_AT_type(*$C$DW$T$11)
.dwattr $C$DW$T$933, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$933, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$933, DW_AT_decl_line(0x22)
.dwattr $C$DW$T$933, DW_AT_decl_column(0x19)
$C$DW$T$1839 .dwtag DW_TAG_typedef, DW_AT_name("UInt")
.dwattr $C$DW$T$1839, DW_AT_type(*$C$DW$T$933)
.dwattr $C$DW$T$1839, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1839, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1839, DW_AT_decl_line(0xe0)
.dwattr $C$DW$T$1839, DW_AT_decl_column(0x19)
$C$DW$T$1840 .dwtag DW_TAG_typedef, DW_AT_name("Uns")
.dwattr $C$DW$T$1840, DW_AT_type(*$C$DW$T$933)
.dwattr $C$DW$T$1840, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1840, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1840, DW_AT_decl_line(0x109)
.dwattr $C$DW$T$1840, DW_AT_decl_column(0x19)
$C$DW$T$1841 .dwtag DW_TAG_typedef, DW_AT_name("xdc_ULong")
.dwattr $C$DW$T$1841, DW_AT_type(*$C$DW$T$11)
.dwattr $C$DW$T$1841, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1841, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1841, DW_AT_decl_line(0x24)
.dwattr $C$DW$T$1841, DW_AT_decl_column(0x19)
$C$DW$T$1842 .dwtag DW_TAG_typedef, DW_AT_name("ULong")
.dwattr $C$DW$T$1842, DW_AT_type(*$C$DW$T$1841)
.dwattr $C$DW$T$1842, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1842, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1842, DW_AT_decl_line(0xe2)
.dwattr $C$DW$T$1842, DW_AT_decl_column(0x19)
$C$DW$T$12 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$12, DW_AT_encoding(DW_ATE_signed)
.dwattr $C$DW$T$12, DW_AT_name("__int40_t")
.dwattr $C$DW$T$12, DW_AT_byte_size(0x08)
.dwattr $C$DW$T$12, DW_AT_bit_size(0x28)
.dwattr $C$DW$T$12, DW_AT_bit_offset(0x18)
$C$DW$T$1873 .dwtag DW_TAG_typedef, DW_AT_name("int40_t")
.dwattr $C$DW$T$1873, DW_AT_type(*$C$DW$T$12)
.dwattr $C$DW$T$1873, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1873, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1873, DW_AT_decl_line(0x31)
.dwattr $C$DW$T$1873, DW_AT_decl_column(0x21)
$C$DW$T$1874 .dwtag DW_TAG_typedef, DW_AT_name("int40")
.dwattr $C$DW$T$1874, DW_AT_type(*$C$DW$T$1873)
.dwattr $C$DW$T$1874, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1874, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1874, DW_AT_decl_line(0x1a)
.dwattr $C$DW$T$1874, DW_AT_decl_column(0x11)
$C$DW$T$1875 .dwtag DW_TAG_typedef, DW_AT_name("int_fast40_t")
.dwattr $C$DW$T$1875, DW_AT_type(*$C$DW$T$1873)
.dwattr $C$DW$T$1875, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1875, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1875, DW_AT_decl_line(0x51)
.dwattr $C$DW$T$1875, DW_AT_decl_column(0x17)
$C$DW$T$1876 .dwtag DW_TAG_typedef, DW_AT_name("int_least40_t")
.dwattr $C$DW$T$1876, DW_AT_type(*$C$DW$T$1873)
.dwattr $C$DW$T$1876, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1876, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1876, DW_AT_decl_line(0x41)
.dwattr $C$DW$T$1876, DW_AT_decl_column(0x17)
$C$DW$T$1877 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Int40")
.dwattr $C$DW$T$1877, DW_AT_type(*$C$DW$T$1876)
.dwattr $C$DW$T$1877, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1877, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$1877, DW_AT_decl_line(0x79)
.dwattr $C$DW$T$1877, DW_AT_decl_column(0x1d)
$C$DW$T$1878 .dwtag DW_TAG_typedef, DW_AT_name("Int40")
.dwattr $C$DW$T$1878, DW_AT_type(*$C$DW$T$1877)
.dwattr $C$DW$T$1878, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1878, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$1878, DW_AT_decl_line(0x80)
.dwattr $C$DW$T$1878, DW_AT_decl_column(0x1d)
$C$DW$T$13 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$13, DW_AT_encoding(DW_ATE_unsigned)
.dwattr $C$DW$T$13, DW_AT_name("unsigned __int40_t")
.dwattr $C$DW$T$13, DW_AT_byte_size(0x08)
.dwattr $C$DW$T$13, DW_AT_bit_size(0x28)
.dwattr $C$DW$T$13, DW_AT_bit_offset(0x18)
$C$DW$T$1879 .dwtag DW_TAG_typedef, DW_AT_name("uint40_t")
.dwattr $C$DW$T$1879, DW_AT_type(*$C$DW$T$13)
.dwattr $C$DW$T$1879, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1879, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1879, DW_AT_decl_line(0x32)
.dwattr $C$DW$T$1879, DW_AT_decl_column(0x20)
$C$DW$T$1880 .dwtag DW_TAG_typedef, DW_AT_name("uint_fast40_t")
.dwattr $C$DW$T$1880, DW_AT_type(*$C$DW$T$1879)
.dwattr $C$DW$T$1880, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1880, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1880, DW_AT_decl_line(0x52)
.dwattr $C$DW$T$1880, DW_AT_decl_column(0x16)
$C$DW$T$1881 .dwtag DW_TAG_typedef, DW_AT_name("uint_least40_t")
.dwattr $C$DW$T$1881, DW_AT_type(*$C$DW$T$1879)
.dwattr $C$DW$T$1881, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1881, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1881, DW_AT_decl_line(0x42)
.dwattr $C$DW$T$1881, DW_AT_decl_column(0x16)
$C$DW$T$1882 .dwtag DW_TAG_typedef, DW_AT_name("xdc_UInt40")
.dwattr $C$DW$T$1882, DW_AT_type(*$C$DW$T$1881)
.dwattr $C$DW$T$1882, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1882, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$1882, DW_AT_decl_line(0x7a)
.dwattr $C$DW$T$1882, DW_AT_decl_column(0x1d)
$C$DW$T$1883 .dwtag DW_TAG_typedef, DW_AT_name("UInt40")
.dwattr $C$DW$T$1883, DW_AT_type(*$C$DW$T$1882)
.dwattr $C$DW$T$1883, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1883, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$1883, DW_AT_decl_line(0x81)
.dwattr $C$DW$T$1883, DW_AT_decl_column(0x1d)
$C$DW$T$14 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$14, DW_AT_encoding(DW_ATE_signed)
.dwattr $C$DW$T$14, DW_AT_name("long long")
.dwattr $C$DW$T$14, DW_AT_byte_size(0x08)
$C$DW$T$1886 .dwtag DW_TAG_typedef, DW_AT_name("int64_ll")
.dwattr $C$DW$T$1886, DW_AT_type(*$C$DW$T$14)
.dwattr $C$DW$T$1886, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1886, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1886, DW_AT_decl_line(0x1b)
.dwattr $C$DW$T$1886, DW_AT_decl_column(0x13)
$C$DW$T$339 .dwtag DW_TAG_typedef, DW_AT_name("int64_t")
.dwattr $C$DW$T$339, DW_AT_type(*$C$DW$T$14)
.dwattr $C$DW$T$339, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$339, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$339, DW_AT_decl_line(0x34)
.dwattr $C$DW$T$339, DW_AT_decl_column(0x21)
$C$DW$T$1887 .dwtag DW_TAG_typedef, DW_AT_name("int_fast64_t")
.dwattr $C$DW$T$1887, DW_AT_type(*$C$DW$T$339)
.dwattr $C$DW$T$1887, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1887, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1887, DW_AT_decl_line(0x54)
.dwattr $C$DW$T$1887, DW_AT_decl_column(0x17)
$C$DW$T$340 .dwtag DW_TAG_typedef, DW_AT_name("int_least64_t")
.dwattr $C$DW$T$340, DW_AT_type(*$C$DW$T$339)
.dwattr $C$DW$T$340, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$340, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$340, DW_AT_decl_line(0x44)
.dwattr $C$DW$T$340, DW_AT_decl_column(0x17)
$C$DW$T$341 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Int64")
.dwattr $C$DW$T$341, DW_AT_type(*$C$DW$T$340)
.dwattr $C$DW$T$341, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$341, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$341, DW_AT_decl_line(0x74)
.dwattr $C$DW$T$341, DW_AT_decl_column(0x1d)
$C$DW$T$342 .dwtag DW_TAG_typedef, DW_AT_name("Int64")
.dwattr $C$DW$T$342, DW_AT_type(*$C$DW$T$341)
.dwattr $C$DW$T$342, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$342, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$342, DW_AT_decl_line(0x111)
.dwattr $C$DW$T$342, DW_AT_decl_column(0x19)
$C$DW$T$1888 .dwtag DW_TAG_typedef, DW_AT_name("intmax_t")
.dwattr $C$DW$T$1888, DW_AT_type(*$C$DW$T$14)
.dwattr $C$DW$T$1888, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1888, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1888, DW_AT_decl_line(0x5c)
.dwattr $C$DW$T$1888, DW_AT_decl_column(0x20)
$C$DW$T$136 .dwtag DW_TAG_typedef, DW_AT_name("s64")
.dwattr $C$DW$T$136, DW_AT_type(*$C$DW$T$14)
.dwattr $C$DW$T$136, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$136, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$136, DW_AT_decl_line(0x22)
.dwattr $C$DW$T$136, DW_AT_decl_column(0x1c)
$C$DW$T$137 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$137, DW_AT_type(*$C$DW$T$136)
.dwattr $C$DW$T$137, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$137, DW_AT_byte_size(0x60)
$C$DW$2710 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2710, DW_AT_upper_bound(0x0b)
.dwendtag $C$DW$T$137
$C$DW$T$144 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$144, DW_AT_type(*$C$DW$T$136)
.dwattr $C$DW$T$144, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$144, DW_AT_byte_size(0x80)
$C$DW$2711 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2711, DW_AT_upper_bound(0x0f)
.dwendtag $C$DW$T$144
$C$DW$T$1291 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1291, DW_AT_type(*$C$DW$T$136)
.dwattr $C$DW$T$1291, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1291, DW_AT_byte_size(0x78)
$C$DW$2712 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2712, DW_AT_upper_bound(0x0e)
.dwendtag $C$DW$T$1291
$C$DW$T$1884 .dwtag DW_TAG_typedef, DW_AT_name("xdc_LLong")
.dwattr $C$DW$T$1884, DW_AT_type(*$C$DW$T$14)
.dwattr $C$DW$T$1884, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1884, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1884, DW_AT_decl_line(0x83)
.dwattr $C$DW$T$1884, DW_AT_decl_column(0x21)
$C$DW$T$1885 .dwtag DW_TAG_typedef, DW_AT_name("LLong")
.dwattr $C$DW$T$1885, DW_AT_type(*$C$DW$T$1884)
.dwattr $C$DW$T$1885, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1885, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1885, DW_AT_decl_line(0xe3)
.dwattr $C$DW$T$1885, DW_AT_decl_column(0x19)
$C$DW$T$15 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$15, DW_AT_encoding(DW_ATE_unsigned)
.dwattr $C$DW$T$15, DW_AT_name("unsigned long long")
.dwattr $C$DW$T$15, DW_AT_byte_size(0x08)
$C$DW$T$1889 .dwtag DW_TAG_typedef, DW_AT_name("CSL_Uint64")
.dwattr $C$DW$T$1889, DW_AT_type(*$C$DW$T$15)
.dwattr $C$DW$T$1889, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1889, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h")
.dwattr $C$DW$T$1889, DW_AT_decl_line(0x47)
.dwattr $C$DW$T$1889, DW_AT_decl_column(0x21)
$C$DW$T$491 .dwtag DW_TAG_typedef, DW_AT_name("Uint64")
.dwattr $C$DW$T$491, DW_AT_type(*$C$DW$T$15)
.dwattr $C$DW$T$491, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$491, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$491, DW_AT_decl_line(0x11)
.dwattr $C$DW$T$491, DW_AT_decl_column(0x1f)
$C$DW$T$492 .dwtag DW_TAG_typedef, DW_AT_name("DspTimeStamp")
.dwattr $C$DW$T$492, DW_AT_type(*$C$DW$T$491)
.dwattr $C$DW$T$492, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$492, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/HwMgr/Misc/include/HwMgr_timer.h")
.dwattr $C$DW$T$492, DW_AT_decl_line(0x10)
.dwattr $C$DW$T$492, DW_AT_decl_column(0x10)
$C$DW$T$1302 .dwtag DW_TAG_typedef, DW_AT_name("u64")
.dwattr $C$DW$T$1302, DW_AT_type(*$C$DW$T$15)
.dwattr $C$DW$T$1302, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1302, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1302, DW_AT_decl_line(0x1e)
.dwattr $C$DW$T$1302, DW_AT_decl_column(0x1c)
$C$DW$T$1892 .dwtag DW_TAG_typedef, DW_AT_name("uint64_t")
.dwattr $C$DW$T$1892, DW_AT_type(*$C$DW$T$15)
.dwattr $C$DW$T$1892, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1892, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1892, DW_AT_decl_line(0x35)
.dwattr $C$DW$T$1892, DW_AT_decl_column(0x20)
$C$DW$T$1895 .dwtag DW_TAG_typedef, DW_AT_name("uint_fast64_t")
.dwattr $C$DW$T$1895, DW_AT_type(*$C$DW$T$1892)
.dwattr $C$DW$T$1895, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1895, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1895, DW_AT_decl_line(0x55)
.dwattr $C$DW$T$1895, DW_AT_decl_column(0x16)
$C$DW$T$1896 .dwtag DW_TAG_typedef, DW_AT_name("uint_least64_t")
.dwattr $C$DW$T$1896, DW_AT_type(*$C$DW$T$1892)
.dwattr $C$DW$T$1896, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1896, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1896, DW_AT_decl_line(0x45)
.dwattr $C$DW$T$1896, DW_AT_decl_column(0x16)
$C$DW$T$1897 .dwtag DW_TAG_typedef, DW_AT_name("xdc_UInt64")
.dwattr $C$DW$T$1897, DW_AT_type(*$C$DW$T$1896)
.dwattr $C$DW$T$1897, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1897, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$1897, DW_AT_decl_line(0x75)
.dwattr $C$DW$T$1897, DW_AT_decl_column(0x1e)
$C$DW$T$1898 .dwtag DW_TAG_typedef, DW_AT_name("UInt64")
.dwattr $C$DW$T$1898, DW_AT_type(*$C$DW$T$1897)
.dwattr $C$DW$T$1898, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1898, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1898, DW_AT_decl_line(0x112)
.dwattr $C$DW$T$1898, DW_AT_decl_column(0x19)
$C$DW$T$1893 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Bits64")
.dwattr $C$DW$T$1893, DW_AT_type(*$C$DW$T$1892)
.dwattr $C$DW$T$1893, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1893, DW_AT_decl_file("C:/ti/bios_6_46_04_53/packages/ti/targets/std.h")
.dwattr $C$DW$T$1893, DW_AT_decl_line(0x92)
.dwattr $C$DW$T$1893, DW_AT_decl_column(0x19)
$C$DW$T$1894 .dwtag DW_TAG_typedef, DW_AT_name("Bits64")
.dwattr $C$DW$T$1894, DW_AT_type(*$C$DW$T$1893)
.dwattr $C$DW$T$1894, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1894, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1894, DW_AT_decl_line(0x126)
.dwattr $C$DW$T$1894, DW_AT_decl_column(0x19)
$C$DW$T$1899 .dwtag DW_TAG_typedef, DW_AT_name("uintmax_t")
.dwattr $C$DW$T$1899, DW_AT_type(*$C$DW$T$15)
.dwattr $C$DW$T$1899, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1899, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdint.h")
.dwattr $C$DW$T$1899, DW_AT_decl_line(0x5d)
.dwattr $C$DW$T$1899, DW_AT_decl_column(0x20)
$C$DW$T$1890 .dwtag DW_TAG_typedef, DW_AT_name("xdc_ULLong")
.dwattr $C$DW$T$1890, DW_AT_type(*$C$DW$T$15)
.dwattr $C$DW$T$1890, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1890, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1890, DW_AT_decl_line(0x84)
.dwattr $C$DW$T$1890, DW_AT_decl_column(0x21)
$C$DW$T$1891 .dwtag DW_TAG_typedef, DW_AT_name("ULLong")
.dwattr $C$DW$T$1891, DW_AT_type(*$C$DW$T$1890)
.dwattr $C$DW$T$1891, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1891, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1891, DW_AT_decl_line(0xe4)
.dwattr $C$DW$T$1891, DW_AT_decl_column(0x19)
$C$DW$T$16 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$16, DW_AT_encoding(DW_ATE_float)
.dwattr $C$DW$T$16, DW_AT_name("float")
.dwattr $C$DW$T$16, DW_AT_byte_size(0x04)
$C$DW$T$232 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$232, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$T$232, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$232, DW_AT_byte_size(0x14)
$C$DW$2713 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2713, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$232
$C$DW$T$259 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$259, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$T$259, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$259, DW_AT_byte_size(0x64)
$C$DW$2714 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2714, DW_AT_upper_bound(0x04)
$C$DW$2715 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2715, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$259
$C$DW$T$285 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$285, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$T$285, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$285, DW_AT_byte_size(0x64)
$C$DW$2716 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2716, DW_AT_upper_bound(0x18)
.dwendtag $C$DW$T$285
$C$DW$T$399 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$399, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$T$399, DW_AT_address_class(0x20)
$C$DW$T$1201 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1201, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$T$1201, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1201, DW_AT_byte_size(0x20000)
$C$DW$2717 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2717, DW_AT_upper_bound(0x7fff)
.dwendtag $C$DW$T$1201
$C$DW$T$1203 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1203, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$T$1203, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1203, DW_AT_byte_size(0x320)
$C$DW$2718 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2718, DW_AT_upper_bound(0xc7)
.dwendtag $C$DW$T$1203
$C$DW$T$1550 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1550, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$T$1550, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1550, DW_AT_byte_size(0x40000)
$C$DW$2719 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2719, DW_AT_upper_bound(0xffff)
.dwendtag $C$DW$T$1550
$C$DW$T$125 .dwtag DW_TAG_typedef, DW_AT_name("f32")
.dwattr $C$DW$T$125, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$T$125, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$125, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$125, DW_AT_decl_line(0x26)
.dwattr $C$DW$T$125, DW_AT_decl_column(0x1c)
$C$DW$T$180 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$180, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$T$180, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$180, DW_AT_byte_size(0x1000)
$C$DW$2720 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2720, DW_AT_upper_bound(0x3ff)
$C$DW$T$188 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$188, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$T$188, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$188, DW_AT_byte_size(0x0c)
$C$DW$2721 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2721, DW_AT_upper_bound(0x02)
.dwendtag $C$DW$T$188
$C$DW$T$220 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$220, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$T$220, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$220, DW_AT_byte_size(0x28)
$C$DW$2722 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2722, DW_AT_upper_bound(0x09)
.dwendtag $C$DW$T$220
$C$DW$T$393 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$393, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$T$393, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$393, DW_AT_byte_size(0x10)
$C$DW$2723 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2723, DW_AT_upper_bound(0x03)
.dwendtag $C$DW$T$393
$C$DW$T$1048 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1048, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$T$1048, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1048, DW_AT_byte_size(0x14)
$C$DW$2724 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2724, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1048
$C$DW$T$1059 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1059, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$T$1059, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1059, DW_AT_byte_size(0x64)
$C$DW$2725 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2725, DW_AT_upper_bound(0x04)
$C$DW$2726 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2726, DW_AT_upper_bound(0x04)
.dwendtag $C$DW$T$1059
$C$DW$T$1088 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1088, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$T$1088, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1088, DW_AT_byte_size(0x08)
$C$DW$2727 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2727, DW_AT_upper_bound(0x01)
.dwendtag $C$DW$T$1088
$C$DW$T$1094 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1094, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$T$1094, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1094, DW_AT_byte_size(0x64)
$C$DW$2728 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2728, DW_AT_upper_bound(0x18)
.dwendtag $C$DW$T$1094
$C$DW$T$1344 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1344, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$T$1344, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1344, DW_AT_byte_size(0x18)
$C$DW$2729 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2729, DW_AT_upper_bound(0x05)
.dwendtag $C$DW$T$1344
$C$DW$T$1501 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1501, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$T$1501, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1501, DW_AT_byte_size(0x24)
$C$DW$2730 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2730, DW_AT_upper_bound(0x08)
.dwendtag $C$DW$T$1501
$C$DW$T$1561 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1561, DW_AT_type(*$C$DW$T$125)
.dwattr $C$DW$T$1561, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1561, DW_AT_byte_size(0x80)
$C$DW$2731 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2731, DW_AT_upper_bound(0x1f)
.dwendtag $C$DW$T$1561
$C$DW$T$1901 .dwtag DW_TAG_typedef, DW_AT_name("float32_t")
.dwattr $C$DW$T$1901, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$T$1901, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1901, DW_AT_decl_file("C:\ti\c6000_7.4.21\include\vect.h")
.dwattr $C$DW$T$1901, DW_AT_decl_line(0x30)
.dwattr $C$DW$T$1901, DW_AT_decl_column(0x0f)
$C$DW$T$587 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Float")
.dwattr $C$DW$T$587, DW_AT_type(*$C$DW$T$16)
.dwattr $C$DW$T$587, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$587, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$587, DW_AT_decl_line(0x25)
.dwattr $C$DW$T$587, DW_AT_decl_column(0x19)
$C$DW$T$1900 .dwtag DW_TAG_typedef, DW_AT_name("Float")
.dwattr $C$DW$T$1900, DW_AT_type(*$C$DW$T$587)
.dwattr $C$DW$T$1900, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1900, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1900, DW_AT_decl_line(0xe5)
.dwattr $C$DW$T$1900, DW_AT_decl_column(0x19)
$C$DW$T$17 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$17, DW_AT_encoding(DW_ATE_float)
.dwattr $C$DW$T$17, DW_AT_name("double")
.dwattr $C$DW$T$17, DW_AT_byte_size(0x08)
$C$DW$T$1903 .dwtag DW_TAG_typedef, DW_AT_name("__float2_t")
.dwattr $C$DW$T$1903, DW_AT_type(*$C$DW$T$17)
.dwattr $C$DW$T$1903, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1903, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/c6x.h")
.dwattr $C$DW$T$1903, DW_AT_decl_line(0x5f)
.dwattr $C$DW$T$1903, DW_AT_decl_column(0x14)
$C$DW$T$1902 .dwtag DW_TAG_typedef, DW_AT_name("f64")
.dwattr $C$DW$T$1902, DW_AT_type(*$C$DW$T$17)
.dwattr $C$DW$T$1902, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1902, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1902, DW_AT_decl_line(0x27)
.dwattr $C$DW$T$1902, DW_AT_decl_column(0x1c)
$C$DW$T$1906 .dwtag DW_TAG_typedef, DW_AT_name("int64_d")
.dwattr $C$DW$T$1906, DW_AT_type(*$C$DW$T$17)
.dwattr $C$DW$T$1906, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1906, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h")
.dwattr $C$DW$T$1906, DW_AT_decl_line(0x14)
.dwattr $C$DW$T$1906, DW_AT_decl_column(0x14)
$C$DW$T$1904 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Double")
.dwattr $C$DW$T$1904, DW_AT_type(*$C$DW$T$17)
.dwattr $C$DW$T$1904, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1904, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1904, DW_AT_decl_line(0x26)
.dwattr $C$DW$T$1904, DW_AT_decl_column(0x19)
$C$DW$T$1905 .dwtag DW_TAG_typedef, DW_AT_name("Double")
.dwattr $C$DW$T$1905, DW_AT_type(*$C$DW$T$1904)
.dwattr $C$DW$T$1905, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1905, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1905, DW_AT_decl_line(0xe6)
.dwattr $C$DW$T$1905, DW_AT_decl_column(0x19)
$C$DW$T$18 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$18, DW_AT_encoding(DW_ATE_float)
.dwattr $C$DW$T$18, DW_AT_name("long double")
.dwattr $C$DW$T$18, DW_AT_byte_size(0x08)
$C$DW$T$1907 .dwtag DW_TAG_typedef, DW_AT_name("xdc_LDouble")
.dwattr $C$DW$T$1907, DW_AT_type(*$C$DW$T$18)
.dwattr $C$DW$T$1907, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1907, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1907, DW_AT_decl_line(0x27)
.dwattr $C$DW$T$1907, DW_AT_decl_column(0x19)
$C$DW$T$1908 .dwtag DW_TAG_typedef, DW_AT_name("LDouble")
.dwattr $C$DW$T$1908, DW_AT_type(*$C$DW$T$1907)
.dwattr $C$DW$T$1908, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1908, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1908, DW_AT_decl_line(0xe7)
.dwattr $C$DW$T$1908, DW_AT_decl_column(0x19)
$C$DW$T$150 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$150, DW_AT_encoding(DW_ATE_signed_char)
.dwattr $C$DW$T$150, DW_AT_name("signed char")
.dwattr $C$DW$T$150, DW_AT_byte_size(0x01)
$C$DW$T$151 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$151, DW_AT_type(*$C$DW$T$150)
.dwattr $C$DW$T$151, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$151, DW_AT_byte_size(0x30)
$C$DW$2732 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2732, DW_AT_upper_bound(0x2f)
.dwendtag $C$DW$T$151
$C$DW$T$608 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$608, DW_AT_type(*$C$DW$T$150)
.dwattr $C$DW$T$608, DW_AT_address_class(0x20)
$C$DW$T$1909 .dwtag DW_TAG_typedef, DW_AT_name("va_list")
.dwattr $C$DW$T$1909, DW_AT_type(*$C$DW$T$608)
.dwattr $C$DW$T$1909, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1909, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdarg.h")
.dwattr $C$DW$T$1909, DW_AT_decl_line(0x2f)
.dwattr $C$DW$T$1909, DW_AT_decl_column(0x12)
$C$DW$T$1910 .dwtag DW_TAG_typedef, DW_AT_name("xdc_VaList")
.dwattr $C$DW$T$1910, DW_AT_type(*$C$DW$T$1909)
.dwattr $C$DW$T$1910, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1910, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1910, DW_AT_decl_line(0x29)
.dwattr $C$DW$T$1910, DW_AT_decl_column(0x19)
$C$DW$T$1911 .dwtag DW_TAG_typedef, DW_AT_name("VaList")
.dwattr $C$DW$T$1911, DW_AT_type(*$C$DW$T$1910)
.dwattr $C$DW$T$1911, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1911, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1911, DW_AT_decl_line(0xe9)
.dwattr $C$DW$T$1911, DW_AT_decl_column(0x19)
$C$DW$T$609 .dwtag DW_TAG_typedef, DW_AT_name("xdc_String")
.dwattr $C$DW$T$609, DW_AT_type(*$C$DW$T$608)
.dwattr $C$DW$T$609, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$609, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$609, DW_AT_decl_line(0x30)
.dwattr $C$DW$T$609, DW_AT_decl_column(0x1a)
$C$DW$T$1912 .dwtag DW_TAG_typedef, DW_AT_name("String")
.dwattr $C$DW$T$1912, DW_AT_type(*$C$DW$T$609)
.dwattr $C$DW$T$1912, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1912, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1912, DW_AT_decl_line(0xf5)
.dwattr $C$DW$T$1912, DW_AT_decl_column(0x19)
$C$DW$T$825 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$825, DW_AT_type(*$C$DW$T$150)
$C$DW$T$826 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$826, DW_AT_type(*$C$DW$T$825)
.dwattr $C$DW$T$826, DW_AT_address_class(0x20)
$C$DW$T$827 .dwtag DW_TAG_typedef, DW_AT_name("xdc_CString")
.dwattr $C$DW$T$827, DW_AT_type(*$C$DW$T$826)
.dwattr $C$DW$T$827, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$827, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$827, DW_AT_decl_line(0x31)
.dwattr $C$DW$T$827, DW_AT_decl_column(0x1a)
$C$DW$T$1913 .dwtag DW_TAG_typedef, DW_AT_name("CString")
.dwattr $C$DW$T$1913, DW_AT_type(*$C$DW$T$827)
.dwattr $C$DW$T$1913, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1913, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1913, DW_AT_decl_line(0xf7)
.dwattr $C$DW$T$1913, DW_AT_decl_column(0x19)
$C$DW$T$1533 .dwtag DW_TAG_array_type
.dwattr $C$DW$T$1533, DW_AT_type(*$C$DW$T$150)
.dwattr $C$DW$T$1533, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1533, DW_AT_byte_size(0xfc)
$C$DW$2733 .dwtag DW_TAG_subrange_type
.dwattr $C$DW$2733, DW_AT_upper_bound(0xfb)
.dwendtag $C$DW$T$1533
$C$DW$T$1914 .dwtag DW_TAG_typedef, DW_AT_name("xdc_Char")
.dwattr $C$DW$T$1914, DW_AT_type(*$C$DW$T$150)
.dwattr $C$DW$T$1914, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1914, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1914, DW_AT_decl_line(0x1d)
.dwattr $C$DW$T$1914, DW_AT_decl_column(0x19)
$C$DW$T$1915 .dwtag DW_TAG_typedef, DW_AT_name("Char")
.dwattr $C$DW$T$1915, DW_AT_type(*$C$DW$T$1914)
.dwattr $C$DW$T$1915, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1915, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1915, DW_AT_decl_line(0xdb)
.dwattr $C$DW$T$1915, DW_AT_decl_column(0x19)
$C$DW$T$248 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$248, DW_AT_encoding(DW_ATE_boolean)
.dwattr $C$DW$T$248, DW_AT_name("bool")
.dwattr $C$DW$T$248, DW_AT_byte_size(0x01)
$C$DW$T$338 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$338, DW_AT_name("__simd128_int32_t")
.dwattr $C$DW$T$338, DW_AT_byte_size(0x10)
$C$DW$2734 .dwtag DW_TAG_member
.dwattr $C$DW$2734, DW_AT_type(*$C$DW$T$333)
.dwattr $C$DW$2734, DW_AT_name("_v")
.dwattr $C$DW$2734, DW_AT_TI_symbol_name("_v")
.dwattr $C$DW$2734, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2734, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2734, DW_AT_decl_file("C:\ti\c6000_7.4.21\include\vect.h")
.dwattr $C$DW$2734, DW_AT_decl_line(0x44)
.dwattr $C$DW$2734, DW_AT_decl_column(0x01)
$C$DW$156 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$156, DW_AT_declaration
.dwattr $C$DW$156, DW_AT_TI_symbol_name("_ZN17__simd128_int32_taSERKS_")
.dwattr $C$DW$156, DW_AT_type(*$C$DW$T$334)
.dwattr $C$DW$156, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2735 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2735, DW_AT_type(*$C$DW$T$336)
.dwendtag $C$DW$156
.dwendtag $C$DW$T$338
.dwattr $C$DW$T$338, DW_AT_decl_file("C:\ti\c6000_7.4.21\include\vect.h")
.dwattr $C$DW$T$338, DW_AT_decl_line(0x44)
.dwattr $C$DW$T$338, DW_AT_decl_column(0x01)
$C$DW$T$334 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$334, DW_AT_type(*$C$DW$T$338)
.dwattr $C$DW$T$334, DW_AT_address_class(0x20)
$C$DW$T$337 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$337, DW_AT_type(*$C$DW$T$334)
.dwattr $C$DW$T$337, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2736 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2736, DW_AT_type(*$C$DW$T$336)
.dwendtag $C$DW$T$337
$C$DW$T$335 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$335, DW_AT_type(*$C$DW$T$338)
$C$DW$T$336 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$336, DW_AT_type(*$C$DW$T$335)
.dwattr $C$DW$T$336, DW_AT_address_class(0x20)
$C$DW$T$1916 .dwtag DW_TAG_typedef, DW_AT_name("int32x4_t")
.dwattr $C$DW$T$1916, DW_AT_type(*$C$DW$T$338)
.dwattr $C$DW$T$1916, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1916, DW_AT_decl_file("C:\ti\c6000_7.4.21\include\vect.h")
.dwattr $C$DW$T$1916, DW_AT_decl_line(0x44)
.dwattr $C$DW$T$1916, DW_AT_decl_column(0x01)
$C$DW$T$1917 .dwtag DW_TAG_typedef, DW_AT_name("__x128_t")
.dwattr $C$DW$T$1917, DW_AT_type(*$C$DW$T$1916)
.dwattr $C$DW$T$1917, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1917, DW_AT_decl_file("C:\ti\c6000_7.4.21\include\vect.h")
.dwattr $C$DW$T$1917, DW_AT_decl_line(0x46)
.dwattr $C$DW$T$1917, DW_AT_decl_column(0x13)
$C$DW$T$1918 .dwtag DW_TAG_typedef, DW_AT_name("Int128")
.dwattr $C$DW$T$1918, DW_AT_type(*$C$DW$T$1917)
.dwattr $C$DW$T$1918, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1918, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1918, DW_AT_decl_line(0x12)
.dwattr $C$DW$T$1918, DW_AT_decl_column(0x1f)
$C$DW$T$1146 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$1146, DW_AT_name("cmplx32")
.dwattr $C$DW$T$1146, DW_AT_byte_size(0x04)
$C$DW$2737 .dwtag DW_TAG_member
.dwattr $C$DW$2737, DW_AT_type(*$C$DW$T$109)
.dwattr $C$DW$2737, DW_AT_name("iq")
.dwattr $C$DW$2737, DW_AT_TI_symbol_name("iq")
.dwattr $C$DW$2737, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2737, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2737, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$2737, DW_AT_decl_line(0x2b)
.dwattr $C$DW$2737, DW_AT_decl_column(0x0b)
$C$DW$2738 .dwtag DW_TAG_member
.dwattr $C$DW$2738, DW_AT_type(*$C$DW$T$306)
.dwattr $C$DW$2738, DW_AT_name("component")
.dwattr $C$DW$2738, DW_AT_TI_symbol_name("component")
.dwattr $C$DW$2738, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2738, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2738, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$2738, DW_AT_decl_line(0x31)
.dwattr $C$DW$2738, DW_AT_decl_column(0x07)
$C$DW$157 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$157, DW_AT_declaration
.dwattr $C$DW$157, DW_AT_TI_symbol_name("_ZN7cmplx32aSERKS_")
.dwattr $C$DW$157, DW_AT_type(*$C$DW$T$1142)
.dwattr $C$DW$157, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2739 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2739, DW_AT_type(*$C$DW$T$1144)
.dwendtag $C$DW$157
.dwendtag $C$DW$T$1146
.dwattr $C$DW$T$1146, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1146, DW_AT_decl_line(0x2a)
.dwattr $C$DW$T$1146, DW_AT_decl_column(0x01)
$C$DW$T$1142 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1142, DW_AT_type(*$C$DW$T$1146)
.dwattr $C$DW$T$1142, DW_AT_address_class(0x20)
$C$DW$T$1145 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1145, DW_AT_type(*$C$DW$T$1142)
.dwattr $C$DW$T$1145, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2740 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2740, DW_AT_type(*$C$DW$T$1144)
.dwendtag $C$DW$T$1145
$C$DW$T$1143 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1143, DW_AT_type(*$C$DW$T$1146)
$C$DW$T$1144 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1144, DW_AT_type(*$C$DW$T$1143)
.dwattr $C$DW$T$1144, DW_AT_address_class(0x20)
$C$DW$T$2193 .dwtag DW_TAG_typedef, DW_AT_name("cmplx32")
.dwattr $C$DW$T$2193, DW_AT_type(*$C$DW$T$1146)
.dwattr $C$DW$T$2193, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2193, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$2193, DW_AT_decl_line(0x33)
.dwattr $C$DW$T$2193, DW_AT_decl_column(0x03)
$C$DW$T$1151 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$1151, DW_AT_name("cmplx64")
.dwattr $C$DW$T$1151, DW_AT_byte_size(0x08)
$C$DW$2741 .dwtag DW_TAG_member
.dwattr $C$DW$2741, DW_AT_type(*$C$DW$T$491)
.dwattr $C$DW$2741, DW_AT_name("iq")
.dwattr $C$DW$2741, DW_AT_TI_symbol_name("iq")
.dwattr $C$DW$2741, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2741, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2741, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$2741, DW_AT_decl_line(0x37)
.dwattr $C$DW$2741, DW_AT_decl_column(0x0c)
$C$DW$2742 .dwtag DW_TAG_member
.dwattr $C$DW$2742, DW_AT_type(*$C$DW$T$311)
.dwattr $C$DW$2742, DW_AT_name("component")
.dwattr $C$DW$2742, DW_AT_TI_symbol_name("component")
.dwattr $C$DW$2742, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2742, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2742, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$2742, DW_AT_decl_line(0x3d)
.dwattr $C$DW$2742, DW_AT_decl_column(0x07)
$C$DW$158 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$158, DW_AT_declaration
.dwattr $C$DW$158, DW_AT_TI_symbol_name("_ZN7cmplx64aSERKS_")
.dwattr $C$DW$158, DW_AT_type(*$C$DW$T$1147)
.dwattr $C$DW$158, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2743 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2743, DW_AT_type(*$C$DW$T$1149)
.dwendtag $C$DW$158
.dwendtag $C$DW$T$1151
.dwattr $C$DW$T$1151, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$1151, DW_AT_decl_line(0x36)
.dwattr $C$DW$T$1151, DW_AT_decl_column(0x01)
$C$DW$T$1147 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1147, DW_AT_type(*$C$DW$T$1151)
.dwattr $C$DW$T$1147, DW_AT_address_class(0x20)
$C$DW$T$1150 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$1150, DW_AT_type(*$C$DW$T$1147)
.dwattr $C$DW$T$1150, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2744 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2744, DW_AT_type(*$C$DW$T$1149)
.dwendtag $C$DW$T$1150
$C$DW$T$1148 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1148, DW_AT_type(*$C$DW$T$1151)
$C$DW$T$1149 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$1149, DW_AT_type(*$C$DW$T$1148)
.dwattr $C$DW$T$1149, DW_AT_address_class(0x20)
$C$DW$T$2194 .dwtag DW_TAG_typedef, DW_AT_name("cmplx64")
.dwattr $C$DW$T$2194, DW_AT_type(*$C$DW$T$1151)
.dwattr $C$DW$T$2194, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2194, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$2194, DW_AT_decl_line(0x3f)
.dwattr $C$DW$T$2194, DW_AT_decl_column(0x03)
$C$DW$T$316 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$316, DW_AT_name("div_t")
.dwattr $C$DW$T$316, DW_AT_byte_size(0x08)
$C$DW$2745 .dwtag DW_TAG_member
.dwattr $C$DW$2745, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$2745, DW_AT_name("quot")
.dwattr $C$DW$2745, DW_AT_TI_symbol_name("quot")
.dwattr $C$DW$2745, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2745, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2745, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$2745, DW_AT_decl_line(0x3e)
.dwattr $C$DW$2745, DW_AT_decl_column(0x16)
$C$DW$2746 .dwtag DW_TAG_member
.dwattr $C$DW$2746, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$2746, DW_AT_name("rem")
.dwattr $C$DW$2746, DW_AT_TI_symbol_name("rem")
.dwattr $C$DW$2746, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2746, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2746, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$2746, DW_AT_decl_line(0x3e)
.dwattr $C$DW$2746, DW_AT_decl_column(0x1c)
$C$DW$159 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$159, DW_AT_declaration
.dwattr $C$DW$159, DW_AT_TI_symbol_name("_ZNSt5div_taSERKS_")
.dwattr $C$DW$159, DW_AT_type(*$C$DW$T$312)
.dwattr $C$DW$159, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2747 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2747, DW_AT_type(*$C$DW$T$314)
.dwendtag $C$DW$159
.dwendtag $C$DW$T$316
.dwattr $C$DW$T$316, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$T$316, DW_AT_decl_line(0x3e)
.dwattr $C$DW$T$316, DW_AT_decl_column(0x10)
$C$DW$T$312 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$312, DW_AT_type(*$C$DW$T$316)
.dwattr $C$DW$T$312, DW_AT_address_class(0x20)
$C$DW$T$315 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$315, DW_AT_type(*$C$DW$T$312)
.dwattr $C$DW$T$315, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2748 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2748, DW_AT_type(*$C$DW$T$314)
.dwendtag $C$DW$T$315
$C$DW$T$313 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$313, DW_AT_type(*$C$DW$T$316)
$C$DW$T$314 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$314, DW_AT_type(*$C$DW$T$313)
.dwattr $C$DW$T$314, DW_AT_address_class(0x20)
$C$DW$T$1602 .dwtag DW_TAG_typedef, DW_AT_name("div_t")
.dwattr $C$DW$T$1602, DW_AT_type(*$C$DW$T$316)
.dwattr $C$DW$T$1602, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1602, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$T$1602, DW_AT_decl_line(0x3e)
.dwattr $C$DW$T$1602, DW_AT_decl_column(0x23)
$C$DW$T$321 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$321, DW_AT_name("ldiv_t")
.dwattr $C$DW$T$321, DW_AT_byte_size(0x08)
$C$DW$2749 .dwtag DW_TAG_member
.dwattr $C$DW$2749, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$2749, DW_AT_name("quot")
.dwattr $C$DW$2749, DW_AT_TI_symbol_name("quot")
.dwattr $C$DW$2749, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2749, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2749, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$2749, DW_AT_decl_line(0x40)
.dwattr $C$DW$2749, DW_AT_decl_column(0x17)
$C$DW$2750 .dwtag DW_TAG_member
.dwattr $C$DW$2750, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$2750, DW_AT_name("rem")
.dwattr $C$DW$2750, DW_AT_TI_symbol_name("rem")
.dwattr $C$DW$2750, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2750, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2750, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$2750, DW_AT_decl_line(0x40)
.dwattr $C$DW$2750, DW_AT_decl_column(0x1d)
$C$DW$160 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$160, DW_AT_declaration
.dwattr $C$DW$160, DW_AT_TI_symbol_name("_ZNSt6ldiv_taSERKS_")
.dwattr $C$DW$160, DW_AT_type(*$C$DW$T$317)
.dwattr $C$DW$160, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2751 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2751, DW_AT_type(*$C$DW$T$319)
.dwendtag $C$DW$160
.dwendtag $C$DW$T$321
.dwattr $C$DW$T$321, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$T$321, DW_AT_decl_line(0x40)
.dwattr $C$DW$T$321, DW_AT_decl_column(0x10)
$C$DW$T$317 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$317, DW_AT_type(*$C$DW$T$321)
.dwattr $C$DW$T$317, DW_AT_address_class(0x20)
$C$DW$T$320 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$320, DW_AT_type(*$C$DW$T$317)
.dwattr $C$DW$T$320, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2752 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2752, DW_AT_type(*$C$DW$T$319)
.dwendtag $C$DW$T$320
$C$DW$T$318 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$318, DW_AT_type(*$C$DW$T$321)
$C$DW$T$319 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$319, DW_AT_type(*$C$DW$T$318)
.dwattr $C$DW$T$319, DW_AT_address_class(0x20)
$C$DW$T$1603 .dwtag DW_TAG_typedef, DW_AT_name("ldiv_t")
.dwattr $C$DW$T$1603, DW_AT_type(*$C$DW$T$321)
.dwattr $C$DW$T$1603, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1603, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$T$1603, DW_AT_decl_line(0x40)
.dwattr $C$DW$T$1603, DW_AT_decl_column(0x24)
$C$DW$T$326 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$326, DW_AT_name("lldiv_t")
.dwattr $C$DW$T$326, DW_AT_byte_size(0x10)
$C$DW$2753 .dwtag DW_TAG_member
.dwattr $C$DW$2753, DW_AT_type(*$C$DW$T$14)
.dwattr $C$DW$2753, DW_AT_name("quot")
.dwattr $C$DW$2753, DW_AT_TI_symbol_name("quot")
.dwattr $C$DW$2753, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2753, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2753, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$2753, DW_AT_decl_line(0x43)
.dwattr $C$DW$2753, DW_AT_decl_column(0x1c)
$C$DW$2754 .dwtag DW_TAG_member
.dwattr $C$DW$2754, DW_AT_type(*$C$DW$T$14)
.dwattr $C$DW$2754, DW_AT_name("rem")
.dwattr $C$DW$2754, DW_AT_TI_symbol_name("rem")
.dwattr $C$DW$2754, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2754, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2754, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$2754, DW_AT_decl_line(0x43)
.dwattr $C$DW$2754, DW_AT_decl_column(0x22)
$C$DW$161 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$161, DW_AT_declaration
.dwattr $C$DW$161, DW_AT_TI_symbol_name("_ZNSt7lldiv_taSERKS_")
.dwattr $C$DW$161, DW_AT_type(*$C$DW$T$322)
.dwattr $C$DW$161, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2755 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2755, DW_AT_type(*$C$DW$T$324)
.dwendtag $C$DW$161
.dwendtag $C$DW$T$326
.dwattr $C$DW$T$326, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$T$326, DW_AT_decl_line(0x43)
.dwattr $C$DW$T$326, DW_AT_decl_column(0x10)
$C$DW$T$322 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$322, DW_AT_type(*$C$DW$T$326)
.dwattr $C$DW$T$322, DW_AT_address_class(0x20)
$C$DW$T$325 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$325, DW_AT_type(*$C$DW$T$322)
.dwattr $C$DW$T$325, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2756 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2756, DW_AT_type(*$C$DW$T$324)
.dwendtag $C$DW$T$325
$C$DW$T$323 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$323, DW_AT_type(*$C$DW$T$326)
$C$DW$T$324 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$324, DW_AT_type(*$C$DW$T$323)
.dwattr $C$DW$T$324, DW_AT_address_class(0x20)
$C$DW$T$1604 .dwtag DW_TAG_typedef, DW_AT_name("lldiv_t")
.dwattr $C$DW$T$1604, DW_AT_type(*$C$DW$T$326)
.dwattr $C$DW$T$1604, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1604, DW_AT_decl_file("C:/ti/c6000_7.4.21/include/stdlib.h")
.dwattr $C$DW$T$1604, DW_AT_decl_line(0x43)
.dwattr $C$DW$T$1604, DW_AT_decl_column(0x29)
$C$DW$T$907 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$907, DW_AT_name("test_counts_type")
.dwattr $C$DW$T$907, DW_AT_byte_size(0x20)
$C$DW$2757 .dwtag DW_TAG_member
.dwattr $C$DW$2757, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2757, DW_AT_name("inputMgrTimerCnt")
.dwattr $C$DW$2757, DW_AT_TI_symbol_name("inputMgrTimerCnt")
.dwattr $C$DW$2757, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2757, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2757, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$2757, DW_AT_decl_line(0x185)
.dwattr $C$DW$2757, DW_AT_decl_column(0x0c)
$C$DW$2758 .dwtag DW_TAG_member
.dwattr $C$DW$2758, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2758, DW_AT_name("inputMgrMsgSendCnt")
.dwattr $C$DW$2758, DW_AT_TI_symbol_name("inputMgrMsgSendCnt")
.dwattr $C$DW$2758, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2758, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2758, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$2758, DW_AT_decl_line(0x186)
.dwattr $C$DW$2758, DW_AT_decl_column(0x0c)
$C$DW$2759 .dwtag DW_TAG_member
.dwattr $C$DW$2759, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2759, DW_AT_name("hostMgrMsgRunSendCnt")
.dwattr $C$DW$2759, DW_AT_TI_symbol_name("hostMgrMsgRunSendCnt")
.dwattr $C$DW$2759, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2759, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2759, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$2759, DW_AT_decl_line(0x187)
.dwattr $C$DW$2759, DW_AT_decl_column(0x0c)
$C$DW$2760 .dwtag DW_TAG_member
.dwattr $C$DW$2760, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2760, DW_AT_name("hostMgrMsgStopSendCnt")
.dwattr $C$DW$2760, DW_AT_TI_symbol_name("hostMgrMsgStopSendCnt")
.dwattr $C$DW$2760, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2760, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2760, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$2760, DW_AT_decl_line(0x188)
.dwattr $C$DW$2760, DW_AT_decl_column(0x0c)
$C$DW$2761 .dwtag DW_TAG_member
.dwattr $C$DW$2761, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2761, DW_AT_name("hostMgrMsgRealTimeCmdSendCnt")
.dwattr $C$DW$2761, DW_AT_TI_symbol_name("hostMgrMsgRealTimeCmdSendCnt")
.dwattr $C$DW$2761, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2761, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2761, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$2761, DW_AT_decl_line(0x189)
.dwattr $C$DW$2761, DW_AT_decl_column(0x0c)
$C$DW$2762 .dwtag DW_TAG_member
.dwattr $C$DW$2762, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2762, DW_AT_name("hostMgrMsgNonRealTimeCmdSendCnt")
.dwattr $C$DW$2762, DW_AT_TI_symbol_name("hostMgrMsgNonRealTimeCmdSendCnt")
.dwattr $C$DW$2762, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$2762, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2762, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$2762, DW_AT_decl_line(0x18a)
.dwattr $C$DW$2762, DW_AT_decl_column(0x0c)
$C$DW$2763 .dwtag DW_TAG_member
.dwattr $C$DW$2763, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2763, DW_AT_name("outputMgrTimerCnt")
.dwattr $C$DW$2763, DW_AT_TI_symbol_name("outputMgrTimerCnt")
.dwattr $C$DW$2763, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2763, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2763, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$2763, DW_AT_decl_line(0x18b)
.dwattr $C$DW$2763, DW_AT_decl_column(0x0c)
$C$DW$2764 .dwtag DW_TAG_member
.dwattr $C$DW$2764, DW_AT_type(*$C$DW$T$117)
.dwattr $C$DW$2764, DW_AT_name("outputMgrMsgSendCnt")
.dwattr $C$DW$2764, DW_AT_TI_symbol_name("outputMgrMsgSendCnt")
.dwattr $C$DW$2764, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c]
.dwattr $C$DW$2764, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2764, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$2764, DW_AT_decl_line(0x18c)
.dwattr $C$DW$2764, DW_AT_decl_column(0x0c)
$C$DW$162 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$162, DW_AT_declaration
.dwattr $C$DW$162, DW_AT_TI_symbol_name("_ZN16test_counts_typeaSERKS_")
.dwattr $C$DW$162, DW_AT_type(*$C$DW$T$903)
.dwattr $C$DW$162, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2765 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2765, DW_AT_type(*$C$DW$T$905)
.dwendtag $C$DW$162
.dwendtag $C$DW$T$907
.dwattr $C$DW$T$907, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$T$907, DW_AT_decl_line(0x184)
.dwattr $C$DW$T$907, DW_AT_decl_column(0x10)
$C$DW$T$903 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$903, DW_AT_type(*$C$DW$T$907)
.dwattr $C$DW$T$903, DW_AT_address_class(0x20)
$C$DW$T$906 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$906, DW_AT_type(*$C$DW$T$903)
.dwattr $C$DW$T$906, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2766 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2766, DW_AT_type(*$C$DW$T$905)
.dwendtag $C$DW$T$906
$C$DW$T$904 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$904, DW_AT_type(*$C$DW$T$907)
$C$DW$T$905 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$905, DW_AT_type(*$C$DW$T$904)
.dwattr $C$DW$T$905, DW_AT_address_class(0x20)
$C$DW$T$2153 .dwtag DW_TAG_typedef, DW_AT_name("test_counts_type")
.dwattr $C$DW$T$2153, DW_AT_type(*$C$DW$T$907)
.dwattr $C$DW$T$2153, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2153, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h")
.dwattr $C$DW$T$2153, DW_AT_decl_line(0x18d)
.dwattr $C$DW$T$2153, DW_AT_decl_column(0x03)
$C$DW$T$93 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$93, DW_AT_name("ti_sdo_ipc_interfaces_IGateMPSupport_Fxns__")
.dwattr $C$DW$T$93, DW_AT_declaration
.dwendtag $C$DW$T$93
.dwattr $C$DW$T$93, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$93, DW_AT_decl_line(0x20)
.dwattr $C$DW$T$93, DW_AT_decl_column(0x10)
$C$DW$T$908 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IGateMPSupport_Fxns__")
.dwattr $C$DW$T$908, DW_AT_type(*$C$DW$T$93)
.dwattr $C$DW$T$908, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$908, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$908, DW_AT_decl_line(0x20)
.dwattr $C$DW$T$908, DW_AT_decl_column(0x3c)
$C$DW$T$909 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$909, DW_AT_type(*$C$DW$T$908)
.dwattr $C$DW$T$909, DW_AT_address_class(0x20)
$C$DW$T$2154 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2154, DW_AT_type(*$C$DW$T$93)
$C$DW$T$2155 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2155, DW_AT_type(*$C$DW$T$2154)
.dwattr $C$DW$T$2155, DW_AT_address_class(0x20)
$C$DW$T$2156 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IGateMPSupport_Module")
.dwattr $C$DW$T$2156, DW_AT_type(*$C$DW$T$2155)
.dwattr $C$DW$T$2156, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2156, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2156, DW_AT_decl_line(0x21)
.dwattr $C$DW$T$2156, DW_AT_decl_column(0x43)
$C$DW$T$94 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$94, DW_AT_name("ti_sdo_ipc_interfaces_IGateMPSupport_Params")
.dwattr $C$DW$T$94, DW_AT_declaration
.dwendtag $C$DW$T$94
.dwattr $C$DW$T$94, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$94, DW_AT_decl_line(0x22)
.dwattr $C$DW$T$94, DW_AT_decl_column(0x10)
$C$DW$T$2157 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IGateMPSupport_Params")
.dwattr $C$DW$T$2157, DW_AT_type(*$C$DW$T$94)
.dwattr $C$DW$T$2157, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2157, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2157, DW_AT_decl_line(0x22)
.dwattr $C$DW$T$2157, DW_AT_decl_column(0x3c)
$C$DW$T$914 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$914, DW_AT_name("ti_sdo_ipc_interfaces_IGateMPSupport___Object")
.dwattr $C$DW$T$914, DW_AT_byte_size(0x08)
$C$DW$2767 .dwtag DW_TAG_member
.dwattr $C$DW$2767, DW_AT_type(*$C$DW$T$909)
.dwattr $C$DW$2767, DW_AT_name("__fxns")
.dwattr $C$DW$2767, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2767, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2767, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2767, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$2767, DW_AT_decl_line(0x23)
.dwattr $C$DW$2767, DW_AT_decl_column(0x6d)
$C$DW$2768 .dwtag DW_TAG_member
.dwattr $C$DW$2768, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2768, DW_AT_name("__label")
.dwattr $C$DW$2768, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$2768, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2768, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2768, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$2768, DW_AT_decl_line(0x23)
.dwattr $C$DW$2768, DW_AT_decl_column(0x80)
$C$DW$163 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$163, DW_AT_declaration
.dwattr $C$DW$163, DW_AT_TI_symbol_name("_ZN45ti_sdo_ipc_interfaces_IGateMPSupport___ObjectaSERKS_")
.dwattr $C$DW$163, DW_AT_type(*$C$DW$T$910)
.dwattr $C$DW$163, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2769 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2769, DW_AT_type(*$C$DW$T$912)
.dwendtag $C$DW$163
.dwendtag $C$DW$T$914
.dwattr $C$DW$T$914, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$914, DW_AT_decl_line(0x23)
.dwattr $C$DW$T$914, DW_AT_decl_column(0x10)
$C$DW$T$910 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$910, DW_AT_type(*$C$DW$T$914)
.dwattr $C$DW$T$910, DW_AT_address_class(0x20)
$C$DW$T$913 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$913, DW_AT_type(*$C$DW$T$910)
.dwattr $C$DW$T$913, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2770 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2770, DW_AT_type(*$C$DW$T$912)
.dwendtag $C$DW$T$913
$C$DW$T$2158 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2158, DW_AT_type(*$C$DW$T$914)
.dwattr $C$DW$T$2158, DW_AT_address_class(0x20)
$C$DW$T$2159 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IGateMPSupport_Handle")
.dwattr $C$DW$T$2159, DW_AT_type(*$C$DW$T$2158)
.dwattr $C$DW$T$2159, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2159, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2159, DW_AT_decl_line(0x23)
.dwattr $C$DW$T$2159, DW_AT_decl_column(0x8c)
$C$DW$T$911 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$911, DW_AT_type(*$C$DW$T$914)
$C$DW$T$912 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$912, DW_AT_type(*$C$DW$T$911)
.dwattr $C$DW$T$912, DW_AT_address_class(0x20)
$C$DW$T$919 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$919, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Args__create")
.dwattr $C$DW$T$919, DW_AT_byte_size(0x02)
$C$DW$2771 .dwtag DW_TAG_member
.dwattr $C$DW$2771, DW_AT_type(*$C$DW$T$112)
.dwattr $C$DW$2771, DW_AT_name("procId")
.dwattr $C$DW$2771, DW_AT_TI_symbol_name("procId")
.dwattr $C$DW$2771, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2771, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2771, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2771, DW_AT_decl_line(0x5c)
.dwattr $C$DW$2771, DW_AT_decl_column(0x10)
$C$DW$164 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$164, DW_AT_declaration
.dwattr $C$DW$164, DW_AT_TI_symbol_name("_ZN53ti_sdo_ipc_interfaces_IMessageQTransport_Args__createaSERKS_")
.dwattr $C$DW$164, DW_AT_type(*$C$DW$T$915)
.dwattr $C$DW$164, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2772 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2772, DW_AT_type(*$C$DW$T$917)
.dwendtag $C$DW$164
.dwendtag $C$DW$T$919
.dwattr $C$DW$T$919, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$919, DW_AT_decl_line(0x5b)
.dwattr $C$DW$T$919, DW_AT_decl_column(0x10)
$C$DW$T$915 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$915, DW_AT_type(*$C$DW$T$919)
.dwattr $C$DW$T$915, DW_AT_address_class(0x20)
$C$DW$T$918 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$918, DW_AT_type(*$C$DW$T$915)
.dwattr $C$DW$T$918, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2773 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2773, DW_AT_type(*$C$DW$T$917)
.dwendtag $C$DW$T$918
$C$DW$T$916 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$916, DW_AT_type(*$C$DW$T$919)
$C$DW$T$917 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$917, DW_AT_type(*$C$DW$T$916)
.dwattr $C$DW$T$917, DW_AT_address_class(0x20)
$C$DW$T$2160 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Args__create")
.dwattr $C$DW$T$2160, DW_AT_type(*$C$DW$T$919)
.dwattr $C$DW$T$2160, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2160, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$2160, DW_AT_decl_line(0x5d)
.dwattr $C$DW$T$2160, DW_AT_decl_column(0x03)
$C$DW$T$940 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$940, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Fxns__")
.dwattr $C$DW$T$940, DW_AT_byte_size(0x28)
$C$DW$2774 .dwtag DW_TAG_member
.dwattr $C$DW$2774, DW_AT_type(*$C$DW$T$635)
.dwattr $C$DW$2774, DW_AT_name("__base")
.dwattr $C$DW$2774, DW_AT_TI_symbol_name("__base")
.dwattr $C$DW$2774, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2774, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2774, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2774, DW_AT_decl_line(0x74)
.dwattr $C$DW$2774, DW_AT_decl_column(0x1d)
$C$DW$2775 .dwtag DW_TAG_member
.dwattr $C$DW$2775, DW_AT_type(*$C$DW$T$638)
.dwattr $C$DW$2775, DW_AT_name("__sysp")
.dwattr $C$DW$2775, DW_AT_TI_symbol_name("__sysp")
.dwattr $C$DW$2775, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2775, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2775, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2775, DW_AT_decl_line(0x75)
.dwattr $C$DW$2775, DW_AT_decl_column(0x27)
$C$DW$2776 .dwtag DW_TAG_member
.dwattr $C$DW$2776, DW_AT_type(*$C$DW$T$928)
.dwattr $C$DW$2776, DW_AT_name("setErrFxn")
.dwattr $C$DW$2776, DW_AT_TI_symbol_name("setErrFxn")
.dwattr $C$DW$2776, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2776, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2776, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2776, DW_AT_decl_line(0x76)
.dwattr $C$DW$2776, DW_AT_decl_column(0x10)
$C$DW$2777 .dwtag DW_TAG_member
.dwattr $C$DW$2777, DW_AT_type(*$C$DW$T$930)
.dwattr $C$DW$2777, DW_AT_name("getStatus")
.dwattr $C$DW$2777, DW_AT_TI_symbol_name("getStatus")
.dwattr $C$DW$2777, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2777, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2777, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2777, DW_AT_decl_line(0x77)
.dwattr $C$DW$2777, DW_AT_decl_column(0x0f)
$C$DW$2778 .dwtag DW_TAG_member
.dwattr $C$DW$2778, DW_AT_type(*$C$DW$T$932)
.dwattr $C$DW$2778, DW_AT_name("put")
.dwattr $C$DW$2778, DW_AT_TI_symbol_name("put")
.dwattr $C$DW$2778, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2778, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2778, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2778, DW_AT_decl_line(0x78)
.dwattr $C$DW$2778, DW_AT_decl_column(0x10)
$C$DW$2779 .dwtag DW_TAG_member
.dwattr $C$DW$2779, DW_AT_type(*$C$DW$T$935)
.dwattr $C$DW$2779, DW_AT_name("control")
.dwattr $C$DW$2779, DW_AT_TI_symbol_name("control")
.dwattr $C$DW$2779, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$2779, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2779, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2779, DW_AT_decl_line(0x79)
.dwattr $C$DW$2779, DW_AT_decl_column(0x10)
$C$DW$2780 .dwtag DW_TAG_member
.dwattr $C$DW$2780, DW_AT_type(*$C$DW$T$636)
.dwattr $C$DW$2780, DW_AT_name("__sfxns")
.dwattr $C$DW$2780, DW_AT_TI_symbol_name("__sfxns")
.dwattr $C$DW$2780, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2780, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2780, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2780, DW_AT_decl_line(0x7a)
.dwattr $C$DW$2780, DW_AT_decl_column(0x20)
$C$DW$165 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$165, DW_AT_declaration
.dwattr $C$DW$165, DW_AT_TI_symbol_name("_ZN47ti_sdo_ipc_interfaces_IMessageQTransport_Fxns__aSERKS_")
.dwattr $C$DW$165, DW_AT_type(*$C$DW$T$936)
.dwattr $C$DW$165, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2781 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2781, DW_AT_type(*$C$DW$T$938)
.dwendtag $C$DW$165
.dwendtag $C$DW$T$940
.dwattr $C$DW$T$940, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$940, DW_AT_decl_line(0x73)
.dwattr $C$DW$T$940, DW_AT_decl_column(0x08)
$C$DW$T$936 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$936, DW_AT_type(*$C$DW$T$940)
.dwattr $C$DW$T$936, DW_AT_address_class(0x20)
$C$DW$T$939 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$939, DW_AT_type(*$C$DW$T$936)
.dwattr $C$DW$T$939, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2782 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2782, DW_AT_type(*$C$DW$T$938)
.dwendtag $C$DW$T$939
$C$DW$T$937 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$937, DW_AT_type(*$C$DW$T$940)
$C$DW$T$938 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$938, DW_AT_type(*$C$DW$T$937)
.dwattr $C$DW$T$938, DW_AT_address_class(0x20)
$C$DW$T$2161 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2161, DW_AT_type(*$C$DW$T$937)
.dwattr $C$DW$T$2161, DW_AT_address_class(0x20)
$C$DW$T$2162 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Module")
.dwattr $C$DW$T$2162, DW_AT_type(*$C$DW$T$2161)
.dwattr $C$DW$T$2162, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2162, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2162, DW_AT_decl_line(0x33)
.dwattr $C$DW$T$2162, DW_AT_decl_column(0x47)
$C$DW$T$946 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Fxns__")
.dwattr $C$DW$T$946, DW_AT_type(*$C$DW$T$940)
.dwattr $C$DW$T$946, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$946, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$946, DW_AT_decl_line(0x32)
.dwattr $C$DW$T$946, DW_AT_decl_column(0x40)
$C$DW$T$947 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$947, DW_AT_type(*$C$DW$T$946)
.dwattr $C$DW$T$947, DW_AT_address_class(0x20)
$C$DW$T$945 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$945, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Params")
.dwattr $C$DW$T$945, DW_AT_byte_size(0x14)
$C$DW$2783 .dwtag DW_TAG_member
.dwattr $C$DW$2783, DW_AT_type(*$C$DW$T$651)
.dwattr $C$DW$2783, DW_AT_name("__size")
.dwattr $C$DW$2783, DW_AT_TI_symbol_name("__size")
.dwattr $C$DW$2783, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2783, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2783, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2783, DW_AT_decl_line(0x66)
.dwattr $C$DW$2783, DW_AT_decl_column(0x0c)
$C$DW$2784 .dwtag DW_TAG_member
.dwattr $C$DW$2784, DW_AT_type(*$C$DW$T$653)
.dwattr $C$DW$2784, DW_AT_name("__self")
.dwattr $C$DW$2784, DW_AT_TI_symbol_name("__self")
.dwattr $C$DW$2784, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2784, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2784, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2784, DW_AT_decl_line(0x67)
.dwattr $C$DW$2784, DW_AT_decl_column(0x11)
$C$DW$2785 .dwtag DW_TAG_member
.dwattr $C$DW$2785, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$2785, DW_AT_name("__fxns")
.dwattr $C$DW$2785, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2785, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2785, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2785, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2785, DW_AT_decl_line(0x68)
.dwattr $C$DW$2785, DW_AT_decl_column(0x0b)
$C$DW$2786 .dwtag DW_TAG_member
.dwattr $C$DW$2786, DW_AT_type(*$C$DW$T$655)
.dwattr $C$DW$2786, DW_AT_name("instance")
.dwattr $C$DW$2786, DW_AT_TI_symbol_name("instance")
.dwattr $C$DW$2786, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2786, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2786, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2786, DW_AT_decl_line(0x69)
.dwattr $C$DW$2786, DW_AT_decl_column(0x23)
$C$DW$2787 .dwtag DW_TAG_member
.dwattr $C$DW$2787, DW_AT_type(*$C$DW$T$933)
.dwattr $C$DW$2787, DW_AT_name("priority")
.dwattr $C$DW$2787, DW_AT_TI_symbol_name("priority")
.dwattr $C$DW$2787, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2787, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2787, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2787, DW_AT_decl_line(0x6a)
.dwattr $C$DW$2787, DW_AT_decl_column(0x0e)
$C$DW$166 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$166, DW_AT_declaration
.dwattr $C$DW$166, DW_AT_TI_symbol_name("_ZN47ti_sdo_ipc_interfaces_IMessageQTransport_ParamsaSERKS_")
.dwattr $C$DW$166, DW_AT_type(*$C$DW$T$941)
.dwattr $C$DW$166, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2788 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2788, DW_AT_type(*$C$DW$T$943)
.dwendtag $C$DW$166
.dwendtag $C$DW$T$945
.dwattr $C$DW$T$945, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$945, DW_AT_decl_line(0x65)
.dwattr $C$DW$T$945, DW_AT_decl_column(0x08)
$C$DW$T$941 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$941, DW_AT_type(*$C$DW$T$945)
.dwattr $C$DW$T$941, DW_AT_address_class(0x20)
$C$DW$T$944 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$944, DW_AT_type(*$C$DW$T$941)
.dwattr $C$DW$T$944, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2789 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2789, DW_AT_type(*$C$DW$T$943)
.dwendtag $C$DW$T$944
$C$DW$T$942 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$942, DW_AT_type(*$C$DW$T$945)
$C$DW$T$943 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$943, DW_AT_type(*$C$DW$T$942)
.dwattr $C$DW$T$943, DW_AT_address_class(0x20)
$C$DW$T$2163 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Params")
.dwattr $C$DW$T$2163, DW_AT_type(*$C$DW$T$945)
.dwattr $C$DW$T$2163, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2163, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2163, DW_AT_decl_line(0x34)
.dwattr $C$DW$T$2163, DW_AT_decl_column(0x40)
$C$DW$T$920 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$920, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Reason")
.dwattr $C$DW$T$920, DW_AT_byte_size(0x04)
$C$DW$2790 .dwtag DW_TAG_enumerator, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Reason_FAILEDPUT"), DW_AT_const_value(0x00)
.dwattr $C$DW$2790, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2790, DW_AT_decl_line(0x4b)
.dwattr $C$DW$2790, DW_AT_decl_column(0x05)
$C$DW$2791 .dwtag DW_TAG_enumerator, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Reason_INTERNALERR"), DW_AT_const_value(0x01)
.dwattr $C$DW$2791, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2791, DW_AT_decl_line(0x4c)
.dwattr $C$DW$2791, DW_AT_decl_column(0x05)
$C$DW$2792 .dwtag DW_TAG_enumerator, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Reason_PHYSICALERR"), DW_AT_const_value(0x02)
.dwattr $C$DW$2792, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2792, DW_AT_decl_line(0x4d)
.dwattr $C$DW$2792, DW_AT_decl_column(0x05)
$C$DW$2793 .dwtag DW_TAG_enumerator, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Reason_FAILEDALLOC"), DW_AT_const_value(0x03)
.dwattr $C$DW$2793, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2793, DW_AT_decl_line(0x4e)
.dwattr $C$DW$2793, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$920
.dwattr $C$DW$T$920, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$920, DW_AT_decl_line(0x4a)
.dwattr $C$DW$T$920, DW_AT_decl_column(0x06)
$C$DW$T$921 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Reason")
.dwattr $C$DW$T$921, DW_AT_type(*$C$DW$T$920)
.dwattr $C$DW$T$921, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$921, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$921, DW_AT_decl_line(0x50)
.dwattr $C$DW$T$921, DW_AT_decl_column(0x3e)
$C$DW$T$2164 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$2164, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Status")
.dwattr $C$DW$T$2164, DW_AT_byte_size(0x04)
$C$DW$2794 .dwtag DW_TAG_enumerator, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_S_SUCCESS"), DW_AT_const_value(0x00)
.dwattr $C$DW$2794, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2794, DW_AT_decl_line(0x43)
.dwattr $C$DW$2794, DW_AT_decl_column(0x05)
$C$DW$2795 .dwtag DW_TAG_enumerator, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_E_FAIL"), DW_AT_const_value(-1)
.dwattr $C$DW$2795, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2795, DW_AT_decl_line(0x44)
.dwattr $C$DW$2795, DW_AT_decl_column(0x05)
$C$DW$2796 .dwtag DW_TAG_enumerator, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_E_ERROR"), DW_AT_const_value(-2)
.dwattr $C$DW$2796, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$2796, DW_AT_decl_line(0x45)
.dwattr $C$DW$2796, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$2164
.dwattr $C$DW$T$2164, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$2164, DW_AT_decl_line(0x42)
.dwattr $C$DW$T$2164, DW_AT_decl_column(0x06)
$C$DW$T$2165 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Status")
.dwattr $C$DW$T$2165, DW_AT_type(*$C$DW$T$2164)
.dwattr $C$DW$T$2165, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2165, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/IMessageQTransport.h")
.dwattr $C$DW$T$2165, DW_AT_decl_line(0x47)
.dwattr $C$DW$T$2165, DW_AT_decl_column(0x3e)
$C$DW$T$952 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$952, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport___Object")
.dwattr $C$DW$T$952, DW_AT_byte_size(0x08)
$C$DW$2797 .dwtag DW_TAG_member
.dwattr $C$DW$2797, DW_AT_type(*$C$DW$T$947)
.dwattr $C$DW$2797, DW_AT_name("__fxns")
.dwattr $C$DW$2797, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2797, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2797, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2797, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$2797, DW_AT_decl_line(0x35)
.dwattr $C$DW$2797, DW_AT_decl_column(0x75)
$C$DW$2798 .dwtag DW_TAG_member
.dwattr $C$DW$2798, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2798, DW_AT_name("__label")
.dwattr $C$DW$2798, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$2798, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2798, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2798, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$2798, DW_AT_decl_line(0x35)
.dwattr $C$DW$2798, DW_AT_decl_column(0x88)
$C$DW$167 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$167, DW_AT_declaration
.dwattr $C$DW$167, DW_AT_TI_symbol_name("_ZN49ti_sdo_ipc_interfaces_IMessageQTransport___ObjectaSERKS_")
.dwattr $C$DW$167, DW_AT_type(*$C$DW$T$948)
.dwattr $C$DW$167, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2799 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2799, DW_AT_type(*$C$DW$T$950)
.dwendtag $C$DW$167
.dwendtag $C$DW$T$952
.dwattr $C$DW$T$952, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$952, DW_AT_decl_line(0x35)
.dwattr $C$DW$T$952, DW_AT_decl_column(0x10)
$C$DW$T$922 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$922, DW_AT_type(*$C$DW$T$952)
.dwattr $C$DW$T$922, DW_AT_address_class(0x20)
$C$DW$T$923 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_IMessageQTransport_Handle")
.dwattr $C$DW$T$923, DW_AT_type(*$C$DW$T$922)
.dwattr $C$DW$T$923, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$923, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$923, DW_AT_decl_line(0x35)
.dwattr $C$DW$T$923, DW_AT_decl_column(0x94)
$C$DW$T$948 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$948, DW_AT_type(*$C$DW$T$952)
.dwattr $C$DW$T$948, DW_AT_address_class(0x20)
$C$DW$T$951 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$951, DW_AT_type(*$C$DW$T$948)
.dwattr $C$DW$T$951, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2800 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2800, DW_AT_type(*$C$DW$T$950)
.dwendtag $C$DW$T$951
$C$DW$T$949 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$949, DW_AT_type(*$C$DW$T$952)
$C$DW$T$950 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$950, DW_AT_type(*$C$DW$T$949)
.dwattr $C$DW$T$950, DW_AT_address_class(0x20)
$C$DW$T$95 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$95, DW_AT_name("ti_sdo_ipc_interfaces_INetworkTransport_Fxns__")
.dwattr $C$DW$T$95, DW_AT_declaration
.dwattr $C$DW$T$95, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$95, DW_AT_decl_line(0x3b)
.dwattr $C$DW$T$95, DW_AT_decl_column(0x10)
$C$DW$T$953 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_INetworkTransport_Fxns__")
.dwattr $C$DW$T$953, DW_AT_type(*$C$DW$T$95)
.dwattr $C$DW$T$953, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$953, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$953, DW_AT_decl_line(0x3b)
.dwattr $C$DW$T$953, DW_AT_decl_column(0x3f)
$C$DW$T$954 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$954, DW_AT_type(*$C$DW$T$953)
.dwattr $C$DW$T$954, DW_AT_address_class(0x20)
$C$DW$T$2166 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2166, DW_AT_type(*$C$DW$T$95)
$C$DW$T$2167 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2167, DW_AT_type(*$C$DW$T$2166)
.dwattr $C$DW$T$2167, DW_AT_address_class(0x20)
$C$DW$T$2168 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_INetworkTransport_Module")
.dwattr $C$DW$T$2168, DW_AT_type(*$C$DW$T$2167)
.dwattr $C$DW$T$2168, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2168, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2168, DW_AT_decl_line(0x3c)
.dwattr $C$DW$T$2168, DW_AT_decl_column(0x46)
$C$DW$T$96 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$96, DW_AT_name("ti_sdo_ipc_interfaces_INetworkTransport_Params")
.dwattr $C$DW$T$96, DW_AT_declaration
.dwendtag $C$DW$T$96
.dwattr $C$DW$T$96, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$96, DW_AT_decl_line(0x3d)
.dwattr $C$DW$T$96, DW_AT_decl_column(0x10)
$C$DW$T$2169 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_INetworkTransport_Params")
.dwattr $C$DW$T$2169, DW_AT_type(*$C$DW$T$96)
.dwattr $C$DW$T$2169, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2169, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2169, DW_AT_decl_line(0x3d)
.dwattr $C$DW$T$2169, DW_AT_decl_column(0x3f)
$C$DW$T$959 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$959, DW_AT_name("ti_sdo_ipc_interfaces_INetworkTransport___Object")
.dwattr $C$DW$T$959, DW_AT_byte_size(0x08)
$C$DW$2801 .dwtag DW_TAG_member
.dwattr $C$DW$2801, DW_AT_type(*$C$DW$T$954)
.dwattr $C$DW$2801, DW_AT_name("__fxns")
.dwattr $C$DW$2801, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2801, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2801, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2801, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$2801, DW_AT_decl_line(0x3e)
.dwattr $C$DW$2801, DW_AT_decl_column(0x73)
$C$DW$2802 .dwtag DW_TAG_member
.dwattr $C$DW$2802, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2802, DW_AT_name("__label")
.dwattr $C$DW$2802, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$2802, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2802, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2802, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$2802, DW_AT_decl_line(0x3e)
.dwattr $C$DW$2802, DW_AT_decl_column(0x86)
$C$DW$168 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$168, DW_AT_declaration
.dwattr $C$DW$168, DW_AT_TI_symbol_name("_ZN48ti_sdo_ipc_interfaces_INetworkTransport___ObjectaSERKS_")
.dwattr $C$DW$168, DW_AT_type(*$C$DW$T$955)
.dwattr $C$DW$168, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2803 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2803, DW_AT_type(*$C$DW$T$957)
.dwendtag $C$DW$168
.dwendtag $C$DW$T$959
.dwattr $C$DW$T$959, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$959, DW_AT_decl_line(0x3e)
.dwattr $C$DW$T$959, DW_AT_decl_column(0x10)
$C$DW$T$955 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$955, DW_AT_type(*$C$DW$T$959)
.dwattr $C$DW$T$955, DW_AT_address_class(0x20)
$C$DW$T$958 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$958, DW_AT_type(*$C$DW$T$955)
.dwattr $C$DW$T$958, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2804 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2804, DW_AT_type(*$C$DW$T$957)
.dwendtag $C$DW$T$958
$C$DW$T$2170 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2170, DW_AT_type(*$C$DW$T$959)
.dwattr $C$DW$T$2170, DW_AT_address_class(0x20)
$C$DW$T$2171 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_INetworkTransport_Handle")
.dwattr $C$DW$T$2171, DW_AT_type(*$C$DW$T$2170)
.dwattr $C$DW$T$2171, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2171, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2171, DW_AT_decl_line(0x3e)
.dwattr $C$DW$T$2171, DW_AT_decl_column(0x92)
$C$DW$T$956 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$956, DW_AT_type(*$C$DW$T$959)
$C$DW$T$957 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$957, DW_AT_type(*$C$DW$T$956)
.dwattr $C$DW$T$957, DW_AT_address_class(0x20)
$C$DW$T$97 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$97, DW_AT_name("ti_sdo_ipc_interfaces_INotifyDriver_Fxns__")
.dwattr $C$DW$T$97, DW_AT_declaration
.dwendtag $C$DW$T$97
.dwattr $C$DW$T$97, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$97, DW_AT_decl_line(0x10)
.dwattr $C$DW$T$97, DW_AT_decl_column(0x10)
$C$DW$T$960 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_INotifyDriver_Fxns__")
.dwattr $C$DW$T$960, DW_AT_type(*$C$DW$T$97)
.dwattr $C$DW$T$960, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$960, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$960, DW_AT_decl_line(0x10)
.dwattr $C$DW$T$960, DW_AT_decl_column(0x3b)
$C$DW$T$961 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$961, DW_AT_type(*$C$DW$T$960)
.dwattr $C$DW$T$961, DW_AT_address_class(0x20)
$C$DW$T$2172 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2172, DW_AT_type(*$C$DW$T$97)
$C$DW$T$2173 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2173, DW_AT_type(*$C$DW$T$2172)
.dwattr $C$DW$T$2173, DW_AT_address_class(0x20)
$C$DW$T$2174 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_INotifyDriver_Module")
.dwattr $C$DW$T$2174, DW_AT_type(*$C$DW$T$2173)
.dwattr $C$DW$T$2174, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2174, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2174, DW_AT_decl_line(0x11)
.dwattr $C$DW$T$2174, DW_AT_decl_column(0x42)
$C$DW$T$98 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$98, DW_AT_name("ti_sdo_ipc_interfaces_INotifyDriver_Params")
.dwattr $C$DW$T$98, DW_AT_declaration
.dwendtag $C$DW$T$98
.dwattr $C$DW$T$98, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$98, DW_AT_decl_line(0x12)
.dwattr $C$DW$T$98, DW_AT_decl_column(0x10)
$C$DW$T$2175 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_INotifyDriver_Params")
.dwattr $C$DW$T$2175, DW_AT_type(*$C$DW$T$98)
.dwattr $C$DW$T$2175, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2175, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2175, DW_AT_decl_line(0x12)
.dwattr $C$DW$T$2175, DW_AT_decl_column(0x3b)
$C$DW$T$966 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$966, DW_AT_name("ti_sdo_ipc_interfaces_INotifyDriver___Object")
.dwattr $C$DW$T$966, DW_AT_byte_size(0x08)
$C$DW$2805 .dwtag DW_TAG_member
.dwattr $C$DW$2805, DW_AT_type(*$C$DW$T$961)
.dwattr $C$DW$2805, DW_AT_name("__fxns")
.dwattr $C$DW$2805, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2805, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2805, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2805, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$2805, DW_AT_decl_line(0x13)
.dwattr $C$DW$2805, DW_AT_decl_column(0x6b)
$C$DW$2806 .dwtag DW_TAG_member
.dwattr $C$DW$2806, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2806, DW_AT_name("__label")
.dwattr $C$DW$2806, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$2806, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2806, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2806, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$2806, DW_AT_decl_line(0x13)
.dwattr $C$DW$2806, DW_AT_decl_column(0x7e)
$C$DW$169 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$169, DW_AT_declaration
.dwattr $C$DW$169, DW_AT_TI_symbol_name("_ZN44ti_sdo_ipc_interfaces_INotifyDriver___ObjectaSERKS_")
.dwattr $C$DW$169, DW_AT_type(*$C$DW$T$962)
.dwattr $C$DW$169, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2807 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2807, DW_AT_type(*$C$DW$T$964)
.dwendtag $C$DW$169
.dwendtag $C$DW$T$966
.dwattr $C$DW$T$966, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$966, DW_AT_decl_line(0x13)
.dwattr $C$DW$T$966, DW_AT_decl_column(0x10)
$C$DW$T$962 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$962, DW_AT_type(*$C$DW$T$966)
.dwattr $C$DW$T$962, DW_AT_address_class(0x20)
$C$DW$T$965 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$965, DW_AT_type(*$C$DW$T$962)
.dwattr $C$DW$T$965, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2808 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2808, DW_AT_type(*$C$DW$T$964)
.dwendtag $C$DW$T$965
$C$DW$T$2176 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2176, DW_AT_type(*$C$DW$T$966)
.dwattr $C$DW$T$2176, DW_AT_address_class(0x20)
$C$DW$T$2177 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_INotifyDriver_Handle")
.dwattr $C$DW$T$2177, DW_AT_type(*$C$DW$T$2176)
.dwattr $C$DW$T$2177, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2177, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2177, DW_AT_decl_line(0x13)
.dwattr $C$DW$T$2177, DW_AT_decl_column(0x8a)
$C$DW$T$963 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$963, DW_AT_type(*$C$DW$T$966)
$C$DW$T$964 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$964, DW_AT_type(*$C$DW$T$963)
.dwattr $C$DW$T$964, DW_AT_address_class(0x20)
$C$DW$T$99 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$99, DW_AT_name("ti_sdo_ipc_interfaces_INotifySetup_Fxns__")
.dwattr $C$DW$T$99, DW_AT_declaration
.dwendtag $C$DW$T$99
.dwattr $C$DW$T$99, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$99, DW_AT_decl_line(0x19)
.dwattr $C$DW$T$99, DW_AT_decl_column(0x10)
$C$DW$T$2178 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_INotifySetup_Fxns__")
.dwattr $C$DW$T$2178, DW_AT_type(*$C$DW$T$99)
.dwattr $C$DW$T$2178, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2178, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2178, DW_AT_decl_line(0x19)
.dwattr $C$DW$T$2178, DW_AT_decl_column(0x3a)
$C$DW$T$2179 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2179, DW_AT_type(*$C$DW$T$99)
$C$DW$T$2180 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2180, DW_AT_type(*$C$DW$T$2179)
.dwattr $C$DW$T$2180, DW_AT_address_class(0x20)
$C$DW$T$2181 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_INotifySetup_Module")
.dwattr $C$DW$T$2181, DW_AT_type(*$C$DW$T$2180)
.dwattr $C$DW$T$2181, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2181, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2181, DW_AT_decl_line(0x1a)
.dwattr $C$DW$T$2181, DW_AT_decl_column(0x41)
$C$DW$T$100 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$100, DW_AT_name("ti_sdo_ipc_interfaces_ITransportSetup_Fxns__")
.dwattr $C$DW$T$100, DW_AT_declaration
.dwendtag $C$DW$T$100
.dwattr $C$DW$T$100, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$100, DW_AT_decl_line(0x44)
.dwattr $C$DW$T$100, DW_AT_decl_column(0x10)
$C$DW$T$2182 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_ITransportSetup_Fxns__")
.dwattr $C$DW$T$2182, DW_AT_type(*$C$DW$T$100)
.dwattr $C$DW$T$2182, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2182, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2182, DW_AT_decl_line(0x44)
.dwattr $C$DW$T$2182, DW_AT_decl_column(0x3d)
$C$DW$T$2183 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2183, DW_AT_type(*$C$DW$T$100)
$C$DW$T$2184 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2184, DW_AT_type(*$C$DW$T$2183)
.dwattr $C$DW$T$2184, DW_AT_address_class(0x20)
$C$DW$T$2185 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_ITransportSetup_Module")
.dwattr $C$DW$T$2185, DW_AT_type(*$C$DW$T$2184)
.dwattr $C$DW$T$2185, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2185, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2185, DW_AT_decl_line(0x45)
.dwattr $C$DW$T$2185, DW_AT_decl_column(0x44)
$C$DW$T$971 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$971, DW_AT_name("ti_sdo_ipc_interfaces_ITransport_Fxns__")
.dwattr $C$DW$T$971, DW_AT_byte_size(0x18)
$C$DW$2809 .dwtag DW_TAG_member
.dwattr $C$DW$2809, DW_AT_type(*$C$DW$T$635)
.dwattr $C$DW$2809, DW_AT_name("__base")
.dwattr $C$DW$2809, DW_AT_TI_symbol_name("__base")
.dwattr $C$DW$2809, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2809, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2809, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/ITransport.h")
.dwattr $C$DW$2809, DW_AT_decl_line(0x53)
.dwattr $C$DW$2809, DW_AT_decl_column(0x1d)
$C$DW$2810 .dwtag DW_TAG_member
.dwattr $C$DW$2810, DW_AT_type(*$C$DW$T$638)
.dwattr $C$DW$2810, DW_AT_name("__sysp")
.dwattr $C$DW$2810, DW_AT_TI_symbol_name("__sysp")
.dwattr $C$DW$2810, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2810, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2810, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/ITransport.h")
.dwattr $C$DW$2810, DW_AT_decl_line(0x54)
.dwattr $C$DW$2810, DW_AT_decl_column(0x27)
$C$DW$2811 .dwtag DW_TAG_member
.dwattr $C$DW$2811, DW_AT_type(*$C$DW$T$636)
.dwattr $C$DW$2811, DW_AT_name("__sfxns")
.dwattr $C$DW$2811, DW_AT_TI_symbol_name("__sfxns")
.dwattr $C$DW$2811, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2811, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2811, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/ITransport.h")
.dwattr $C$DW$2811, DW_AT_decl_line(0x55)
.dwattr $C$DW$2811, DW_AT_decl_column(0x20)
$C$DW$170 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$170, DW_AT_declaration
.dwattr $C$DW$170, DW_AT_TI_symbol_name("_ZN39ti_sdo_ipc_interfaces_ITransport_Fxns__aSERKS_")
.dwattr $C$DW$170, DW_AT_type(*$C$DW$T$967)
.dwattr $C$DW$170, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2812 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2812, DW_AT_type(*$C$DW$T$969)
.dwendtag $C$DW$170
.dwendtag $C$DW$T$971
.dwattr $C$DW$T$971, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/ITransport.h")
.dwattr $C$DW$T$971, DW_AT_decl_line(0x52)
.dwattr $C$DW$T$971, DW_AT_decl_column(0x08)
$C$DW$T$967 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$967, DW_AT_type(*$C$DW$T$971)
.dwattr $C$DW$T$967, DW_AT_address_class(0x20)
$C$DW$T$970 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$970, DW_AT_type(*$C$DW$T$967)
.dwattr $C$DW$T$970, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2813 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2813, DW_AT_type(*$C$DW$T$969)
.dwendtag $C$DW$T$970
$C$DW$T$968 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$968, DW_AT_type(*$C$DW$T$971)
$C$DW$T$969 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$969, DW_AT_type(*$C$DW$T$968)
.dwattr $C$DW$T$969, DW_AT_address_class(0x20)
$C$DW$T$2186 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2186, DW_AT_type(*$C$DW$T$968)
.dwattr $C$DW$T$2186, DW_AT_address_class(0x20)
$C$DW$T$2187 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_ITransport_Module")
.dwattr $C$DW$T$2187, DW_AT_type(*$C$DW$T$2186)
.dwattr $C$DW$T$2187, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2187, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2187, DW_AT_decl_line(0x2a)
.dwattr $C$DW$T$2187, DW_AT_decl_column(0x3f)
$C$DW$T$977 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_ITransport_Fxns__")
.dwattr $C$DW$T$977, DW_AT_type(*$C$DW$T$971)
.dwattr $C$DW$T$977, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$977, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$977, DW_AT_decl_line(0x29)
.dwattr $C$DW$T$977, DW_AT_decl_column(0x38)
$C$DW$T$978 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$978, DW_AT_type(*$C$DW$T$977)
.dwattr $C$DW$T$978, DW_AT_address_class(0x20)
$C$DW$T$976 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$976, DW_AT_name("ti_sdo_ipc_interfaces_ITransport_Params")
.dwattr $C$DW$T$976, DW_AT_byte_size(0x10)
$C$DW$2814 .dwtag DW_TAG_member
.dwattr $C$DW$2814, DW_AT_type(*$C$DW$T$651)
.dwattr $C$DW$2814, DW_AT_name("__size")
.dwattr $C$DW$2814, DW_AT_TI_symbol_name("__size")
.dwattr $C$DW$2814, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2814, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2814, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/ITransport.h")
.dwattr $C$DW$2814, DW_AT_decl_line(0x46)
.dwattr $C$DW$2814, DW_AT_decl_column(0x0c)
$C$DW$2815 .dwtag DW_TAG_member
.dwattr $C$DW$2815, DW_AT_type(*$C$DW$T$653)
.dwattr $C$DW$2815, DW_AT_name("__self")
.dwattr $C$DW$2815, DW_AT_TI_symbol_name("__self")
.dwattr $C$DW$2815, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2815, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2815, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/ITransport.h")
.dwattr $C$DW$2815, DW_AT_decl_line(0x47)
.dwattr $C$DW$2815, DW_AT_decl_column(0x11)
$C$DW$2816 .dwtag DW_TAG_member
.dwattr $C$DW$2816, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$2816, DW_AT_name("__fxns")
.dwattr $C$DW$2816, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2816, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2816, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2816, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/ITransport.h")
.dwattr $C$DW$2816, DW_AT_decl_line(0x48)
.dwattr $C$DW$2816, DW_AT_decl_column(0x0b)
$C$DW$2817 .dwtag DW_TAG_member
.dwattr $C$DW$2817, DW_AT_type(*$C$DW$T$655)
.dwattr $C$DW$2817, DW_AT_name("instance")
.dwattr $C$DW$2817, DW_AT_TI_symbol_name("instance")
.dwattr $C$DW$2817, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2817, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2817, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/ITransport.h")
.dwattr $C$DW$2817, DW_AT_decl_line(0x49)
.dwattr $C$DW$2817, DW_AT_decl_column(0x23)
$C$DW$171 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$171, DW_AT_declaration
.dwattr $C$DW$171, DW_AT_TI_symbol_name("_ZN39ti_sdo_ipc_interfaces_ITransport_ParamsaSERKS_")
.dwattr $C$DW$171, DW_AT_type(*$C$DW$T$972)
.dwattr $C$DW$171, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2818 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2818, DW_AT_type(*$C$DW$T$974)
.dwendtag $C$DW$171
.dwendtag $C$DW$T$976
.dwattr $C$DW$T$976, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/ITransport.h")
.dwattr $C$DW$T$976, DW_AT_decl_line(0x45)
.dwattr $C$DW$T$976, DW_AT_decl_column(0x08)
$C$DW$T$972 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$972, DW_AT_type(*$C$DW$T$976)
.dwattr $C$DW$T$972, DW_AT_address_class(0x20)
$C$DW$T$975 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$975, DW_AT_type(*$C$DW$T$972)
.dwattr $C$DW$T$975, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2819 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2819, DW_AT_type(*$C$DW$T$974)
.dwendtag $C$DW$T$975
$C$DW$T$973 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$973, DW_AT_type(*$C$DW$T$976)
$C$DW$T$974 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$974, DW_AT_type(*$C$DW$T$973)
.dwattr $C$DW$T$974, DW_AT_address_class(0x20)
$C$DW$T$2188 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_ITransport_Params")
.dwattr $C$DW$T$2188, DW_AT_type(*$C$DW$T$976)
.dwattr $C$DW$T$2188, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2188, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2188, DW_AT_decl_line(0x2b)
.dwattr $C$DW$T$2188, DW_AT_decl_column(0x38)
$C$DW$T$983 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$983, DW_AT_name("ti_sdo_ipc_interfaces_ITransport___Object")
.dwattr $C$DW$T$983, DW_AT_byte_size(0x08)
$C$DW$2820 .dwtag DW_TAG_member
.dwattr $C$DW$2820, DW_AT_type(*$C$DW$T$978)
.dwattr $C$DW$2820, DW_AT_name("__fxns")
.dwattr $C$DW$2820, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2820, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2820, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2820, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$2820, DW_AT_decl_line(0x2c)
.dwattr $C$DW$2820, DW_AT_decl_column(0x65)
$C$DW$2821 .dwtag DW_TAG_member
.dwattr $C$DW$2821, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2821, DW_AT_name("__label")
.dwattr $C$DW$2821, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$2821, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2821, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2821, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$2821, DW_AT_decl_line(0x2c)
.dwattr $C$DW$2821, DW_AT_decl_column(0x78)
$C$DW$172 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$172, DW_AT_declaration
.dwattr $C$DW$172, DW_AT_TI_symbol_name("_ZN41ti_sdo_ipc_interfaces_ITransport___ObjectaSERKS_")
.dwattr $C$DW$172, DW_AT_type(*$C$DW$T$979)
.dwattr $C$DW$172, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2822 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2822, DW_AT_type(*$C$DW$T$981)
.dwendtag $C$DW$172
.dwendtag $C$DW$T$983
.dwattr $C$DW$T$983, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$983, DW_AT_decl_line(0x2c)
.dwattr $C$DW$T$983, DW_AT_decl_column(0x10)
$C$DW$T$979 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$979, DW_AT_type(*$C$DW$T$983)
.dwattr $C$DW$T$979, DW_AT_address_class(0x20)
$C$DW$T$982 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$982, DW_AT_type(*$C$DW$T$979)
.dwattr $C$DW$T$982, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2823 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2823, DW_AT_type(*$C$DW$T$981)
.dwendtag $C$DW$T$982
$C$DW$T$2189 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2189, DW_AT_type(*$C$DW$T$983)
.dwattr $C$DW$T$2189, DW_AT_address_class(0x20)
$C$DW$T$2190 .dwtag DW_TAG_typedef, DW_AT_name("ti_sdo_ipc_interfaces_ITransport_Handle")
.dwattr $C$DW$T$2190, DW_AT_type(*$C$DW$T$2189)
.dwattr $C$DW$T$2190, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2190, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/sdo/ipc/interfaces/package/package.defs.h")
.dwattr $C$DW$T$2190, DW_AT_decl_line(0x2c)
.dwattr $C$DW$T$2190, DW_AT_decl_column(0x84)
$C$DW$T$980 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$980, DW_AT_type(*$C$DW$T$983)
$C$DW$T$981 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$981, DW_AT_type(*$C$DW$T$980)
.dwattr $C$DW$T$981, DW_AT_address_class(0x20)
$C$DW$T$594 .dwtag DW_TAG_union_type
.dwattr $C$DW$T$594, DW_AT_name("xdc_FloatData")
.dwattr $C$DW$T$594, DW_AT_byte_size(0x04)
$C$DW$2824 .dwtag DW_TAG_member
.dwattr $C$DW$2824, DW_AT_type(*$C$DW$T$587)
.dwattr $C$DW$2824, DW_AT_name("f")
.dwattr $C$DW$2824, DW_AT_TI_symbol_name("f")
.dwattr $C$DW$2824, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2824, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2824, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$2824, DW_AT_decl_line(0xb2)
.dwattr $C$DW$2824, DW_AT_decl_column(0x0f)
$C$DW$2825 .dwtag DW_TAG_member
.dwattr $C$DW$2825, DW_AT_type(*$C$DW$T$589)
.dwattr $C$DW$2825, DW_AT_name("a")
.dwattr $C$DW$2825, DW_AT_TI_symbol_name("a")
.dwattr $C$DW$2825, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2825, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2825, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$2825, DW_AT_decl_line(0xb3)
.dwattr $C$DW$2825, DW_AT_decl_column(0x0f)
$C$DW$173 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$173, DW_AT_declaration
.dwattr $C$DW$173, DW_AT_TI_symbol_name("_ZN13xdc_FloatDataaSERKS_")
.dwattr $C$DW$173, DW_AT_type(*$C$DW$T$590)
.dwattr $C$DW$173, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2826 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2826, DW_AT_type(*$C$DW$T$592)
.dwendtag $C$DW$173
.dwendtag $C$DW$T$594
.dwattr $C$DW$T$594, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$594, DW_AT_decl_line(0xb1)
.dwattr $C$DW$T$594, DW_AT_decl_column(0x0f)
$C$DW$T$590 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$590, DW_AT_type(*$C$DW$T$594)
.dwattr $C$DW$T$590, DW_AT_address_class(0x20)
$C$DW$T$593 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$593, DW_AT_type(*$C$DW$T$590)
.dwattr $C$DW$T$593, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2827 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2827, DW_AT_type(*$C$DW$T$592)
.dwendtag $C$DW$T$593
$C$DW$T$591 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$591, DW_AT_type(*$C$DW$T$594)
$C$DW$T$592 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$592, DW_AT_type(*$C$DW$T$591)
.dwattr $C$DW$T$592, DW_AT_address_class(0x20)
$C$DW$T$1933 .dwtag DW_TAG_typedef, DW_AT_name("xdc_FloatData")
.dwattr $C$DW$T$1933, DW_AT_type(*$C$DW$T$594)
.dwattr $C$DW$T$1933, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1933, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$1933, DW_AT_decl_line(0xb4)
.dwattr $C$DW$T$1933, DW_AT_decl_column(0x03)
$C$DW$T$20 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$20, DW_AT_name("xdc_runtime_Core_ObjDesc")
.dwattr $C$DW$T$20, DW_AT_declaration
.dwendtag $C$DW$T$20
.dwattr $C$DW$T$20, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$20, DW_AT_decl_line(0x1c)
.dwattr $C$DW$T$20, DW_AT_decl_column(0x10)
$C$DW$T$1934 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Core_ObjDesc")
.dwattr $C$DW$T$1934, DW_AT_type(*$C$DW$T$20)
.dwattr $C$DW$T$1934, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1934, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1934, DW_AT_decl_line(0x1c)
.dwattr $C$DW$T$1934, DW_AT_decl_column(0x29)
$C$DW$T$604 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$604, DW_AT_name("xdc_runtime_Diags_DictElem")
.dwattr $C$DW$T$604, DW_AT_byte_size(0x08)
$C$DW$2828 .dwtag DW_TAG_member
.dwattr $C$DW$2828, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$2828, DW_AT_name("modId")
.dwattr $C$DW$2828, DW_AT_TI_symbol_name("modId")
.dwattr $C$DW$2828, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2828, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2828, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$2828, DW_AT_decl_line(0x9a)
.dwattr $C$DW$2828, DW_AT_decl_column(0x20)
$C$DW$2829 .dwtag DW_TAG_member
.dwattr $C$DW$2829, DW_AT_type(*$C$DW$T$599)
.dwattr $C$DW$2829, DW_AT_name("maskAddr")
.dwattr $C$DW$2829, DW_AT_TI_symbol_name("maskAddr")
.dwattr $C$DW$2829, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2829, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2829, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$2829, DW_AT_decl_line(0x9b)
.dwattr $C$DW$2829, DW_AT_decl_column(0x1d)
$C$DW$174 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$174, DW_AT_declaration
.dwattr $C$DW$174, DW_AT_TI_symbol_name("_ZN26xdc_runtime_Diags_DictElemaSERKS_")
.dwattr $C$DW$174, DW_AT_type(*$C$DW$T$600)
.dwattr $C$DW$174, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2830 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2830, DW_AT_type(*$C$DW$T$602)
.dwendtag $C$DW$174
.dwendtag $C$DW$T$604
.dwattr $C$DW$T$604, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$604, DW_AT_decl_line(0x99)
.dwattr $C$DW$T$604, DW_AT_decl_column(0x08)
$C$DW$T$600 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$600, DW_AT_type(*$C$DW$T$604)
.dwattr $C$DW$T$600, DW_AT_address_class(0x20)
$C$DW$T$603 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$603, DW_AT_type(*$C$DW$T$600)
.dwattr $C$DW$T$603, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2831 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2831, DW_AT_type(*$C$DW$T$602)
.dwendtag $C$DW$T$603
$C$DW$T$601 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$601, DW_AT_type(*$C$DW$T$604)
$C$DW$T$602 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$602, DW_AT_type(*$C$DW$T$601)
.dwattr $C$DW$T$602, DW_AT_address_class(0x20)
$C$DW$T$1935 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Diags_DictElem")
.dwattr $C$DW$T$1935, DW_AT_type(*$C$DW$T$604)
.dwattr $C$DW$T$1935, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1935, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1935, DW_AT_decl_line(0x27)
.dwattr $C$DW$T$1935, DW_AT_decl_column(0x2b)
$C$DW$T$1936 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1936, DW_AT_type(*$C$DW$T$1935)
.dwattr $C$DW$T$1936, DW_AT_address_class(0x20)
$C$DW$T$1937 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_dictBase")
.dwattr $C$DW$T$1937, DW_AT_type(*$C$DW$T$1936)
.dwattr $C$DW$T$1937, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1937, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1937, DW_AT_decl_line(0xf6)
.dwattr $C$DW$T$1937, DW_AT_decl_column(0x25)
$C$DW$T$1938 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1938, DW_AT_name("xdc_runtime_Diags_EventLevel")
.dwattr $C$DW$T$1938, DW_AT_byte_size(0x04)
$C$DW$2832 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Diags_LEVEL1"), DW_AT_const_value(0x00)
.dwattr $C$DW$2832, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$2832, DW_AT_decl_line(0x80)
.dwattr $C$DW$2832, DW_AT_decl_column(0x05)
$C$DW$2833 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Diags_LEVEL2"), DW_AT_const_value(0x20)
.dwattr $C$DW$2833, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$2833, DW_AT_decl_line(0x81)
.dwattr $C$DW$2833, DW_AT_decl_column(0x05)
$C$DW$2834 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Diags_LEVEL3"), DW_AT_const_value(0x40)
.dwattr $C$DW$2834, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$2834, DW_AT_decl_line(0x82)
.dwattr $C$DW$2834, DW_AT_decl_column(0x05)
$C$DW$2835 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Diags_LEVEL4"), DW_AT_const_value(0x60)
.dwattr $C$DW$2835, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$2835, DW_AT_decl_line(0x83)
.dwattr $C$DW$2835, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1938
.dwattr $C$DW$T$1938, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1938, DW_AT_decl_line(0x7f)
.dwattr $C$DW$T$1938, DW_AT_decl_column(0x06)
$C$DW$T$1939 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Diags_EventLevel")
.dwattr $C$DW$T$1939, DW_AT_type(*$C$DW$T$1938)
.dwattr $C$DW$T$1939, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1939, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1939, DW_AT_decl_line(0x85)
.dwattr $C$DW$T$1939, DW_AT_decl_column(0x2b)
$C$DW$T$618 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$618, DW_AT_name("xdc_runtime_Error_Block")
.dwattr $C$DW$T$618, DW_AT_byte_size(0x30)
$C$DW$2836 .dwtag DW_TAG_member
.dwattr $C$DW$2836, DW_AT_type(*$C$DW$T$112)
.dwattr $C$DW$2836, DW_AT_name("unused")
.dwattr $C$DW$2836, DW_AT_TI_symbol_name("unused")
.dwattr $C$DW$2836, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2836, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2836, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$2836, DW_AT_decl_line(0x5e)
.dwattr $C$DW$2836, DW_AT_decl_column(0x10)
$C$DW$2837 .dwtag DW_TAG_member
.dwattr $C$DW$2837, DW_AT_type(*$C$DW$T$605)
.dwattr $C$DW$2837, DW_AT_name("data")
.dwattr $C$DW$2837, DW_AT_TI_symbol_name("data")
.dwattr $C$DW$2837, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2837, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2837, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$2837, DW_AT_decl_line(0x5f)
.dwattr $C$DW$2837, DW_AT_decl_column(0x1c)
$C$DW$2838 .dwtag DW_TAG_member
.dwattr $C$DW$2838, DW_AT_type(*$C$DW$T$607)
.dwattr $C$DW$2838, DW_AT_name("id")
.dwattr $C$DW$2838, DW_AT_TI_symbol_name("id")
.dwattr $C$DW$2838, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2838, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2838, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$2838, DW_AT_decl_line(0x60)
.dwattr $C$DW$2838, DW_AT_decl_column(0x1a)
$C$DW$2839 .dwtag DW_TAG_member
.dwattr $C$DW$2839, DW_AT_type(*$C$DW$T$609)
.dwattr $C$DW$2839, DW_AT_name("msg")
.dwattr $C$DW$2839, DW_AT_TI_symbol_name("msg")
.dwattr $C$DW$2839, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2839, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2839, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$2839, DW_AT_decl_line(0x61)
.dwattr $C$DW$2839, DW_AT_decl_column(0x10)
$C$DW$2840 .dwtag DW_TAG_member
.dwattr $C$DW$2840, DW_AT_type(*$C$DW$T$610)
.dwattr $C$DW$2840, DW_AT_name("site")
.dwattr $C$DW$2840, DW_AT_TI_symbol_name("site")
.dwattr $C$DW$2840, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$2840, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2840, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$2840, DW_AT_decl_line(0x62)
.dwattr $C$DW$2840, DW_AT_decl_column(0x1c)
$C$DW$2841 .dwtag DW_TAG_member
.dwattr $C$DW$2841, DW_AT_type(*$C$DW$T$613)
.dwattr $C$DW$2841, DW_AT_name("xtra")
.dwattr $C$DW$2841, DW_AT_TI_symbol_name("xtra")
.dwattr $C$DW$2841, DW_AT_data_member_location[DW_OP_plus_uconst 0x20]
.dwattr $C$DW$2841, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2841, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$2841, DW_AT_decl_line(0x63)
.dwattr $C$DW$2841, DW_AT_decl_column(0x28)
$C$DW$175 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$175, DW_AT_declaration
.dwattr $C$DW$175, DW_AT_TI_symbol_name("_ZN23xdc_runtime_Error_BlockaSERKS_")
.dwattr $C$DW$175, DW_AT_type(*$C$DW$T$614)
.dwattr $C$DW$175, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2842 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2842, DW_AT_type(*$C$DW$T$616)
.dwendtag $C$DW$175
.dwendtag $C$DW$T$618
.dwattr $C$DW$T$618, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$618, DW_AT_decl_line(0x5d)
.dwattr $C$DW$T$618, DW_AT_decl_column(0x08)
$C$DW$T$614 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$614, DW_AT_type(*$C$DW$T$618)
.dwattr $C$DW$T$614, DW_AT_address_class(0x20)
$C$DW$T$617 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$617, DW_AT_type(*$C$DW$T$614)
.dwattr $C$DW$T$617, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2843 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2843, DW_AT_type(*$C$DW$T$616)
.dwendtag $C$DW$T$617
$C$DW$T$615 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$615, DW_AT_type(*$C$DW$T$618)
$C$DW$T$616 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$616, DW_AT_type(*$C$DW$T$615)
.dwattr $C$DW$T$616, DW_AT_address_class(0x20)
$C$DW$T$670 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Error_Block")
.dwattr $C$DW$T$670, DW_AT_type(*$C$DW$T$618)
.dwattr $C$DW$T$670, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$670, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$670, DW_AT_decl_line(0x2e)
.dwattr $C$DW$T$670, DW_AT_decl_column(0x28)
$C$DW$T$671 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$671, DW_AT_type(*$C$DW$T$670)
.dwattr $C$DW$T$671, DW_AT_address_class(0x20)
$C$DW$T$626 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$626, DW_AT_name("xdc_runtime_Error_Data")
.dwattr $C$DW$T$626, DW_AT_byte_size(0x08)
$C$DW$2844 .dwtag DW_TAG_member
.dwattr $C$DW$2844, DW_AT_type(*$C$DW$T$621)
.dwattr $C$DW$2844, DW_AT_name("arg")
.dwattr $C$DW$2844, DW_AT_TI_symbol_name("arg")
.dwattr $C$DW$2844, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2844, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2844, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$2844, DW_AT_decl_line(0x56)
.dwattr $C$DW$2844, DW_AT_decl_column(0x26)
$C$DW$176 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$176, DW_AT_declaration
.dwattr $C$DW$176, DW_AT_TI_symbol_name("_ZN22xdc_runtime_Error_DataaSERKS_")
.dwattr $C$DW$176, DW_AT_type(*$C$DW$T$622)
.dwattr $C$DW$176, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2845 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2845, DW_AT_type(*$C$DW$T$624)
.dwendtag $C$DW$176
.dwendtag $C$DW$T$626
.dwattr $C$DW$T$626, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$626, DW_AT_decl_line(0x55)
.dwattr $C$DW$T$626, DW_AT_decl_column(0x08)
$C$DW$T$622 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$622, DW_AT_type(*$C$DW$T$626)
.dwattr $C$DW$T$622, DW_AT_address_class(0x20)
$C$DW$T$625 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$625, DW_AT_type(*$C$DW$T$622)
.dwattr $C$DW$T$625, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2846 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2846, DW_AT_type(*$C$DW$T$624)
.dwendtag $C$DW$T$625
$C$DW$T$605 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Error_Data")
.dwattr $C$DW$T$605, DW_AT_type(*$C$DW$T$626)
.dwattr $C$DW$T$605, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$605, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$605, DW_AT_decl_line(0x2d)
.dwattr $C$DW$T$605, DW_AT_decl_column(0x27)
$C$DW$T$623 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$623, DW_AT_type(*$C$DW$T$626)
$C$DW$T$624 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$624, DW_AT_type(*$C$DW$T$623)
.dwattr $C$DW$T$624, DW_AT_address_class(0x20)
$C$DW$T$21 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$21, DW_AT_name("xdc_runtime_Error_Module_State")
.dwattr $C$DW$T$21, DW_AT_declaration
.dwattr $C$DW$T$21, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$21, DW_AT_decl_line(0x2f)
.dwattr $C$DW$T$21, DW_AT_decl_column(0x10)
$C$DW$T$1940 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Error_Module_State")
.dwattr $C$DW$T$1940, DW_AT_type(*$C$DW$T$21)
.dwattr $C$DW$T$1940, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1940, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1940, DW_AT_decl_line(0x2f)
.dwattr $C$DW$T$1940, DW_AT_decl_column(0x2f)
$C$DW$T$1941 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$1941, DW_AT_name("xdc_runtime_Error_Policy")
.dwattr $C$DW$T$1941, DW_AT_byte_size(0x04)
$C$DW$2847 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Error_TERMINATE"), DW_AT_const_value(0x00)
.dwattr $C$DW$2847, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$2847, DW_AT_decl_line(0x44)
.dwattr $C$DW$2847, DW_AT_decl_column(0x05)
$C$DW$2848 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Error_UNWIND"), DW_AT_const_value(0x01)
.dwattr $C$DW$2848, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$2848, DW_AT_decl_line(0x45)
.dwattr $C$DW$2848, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$1941
.dwattr $C$DW$T$1941, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1941, DW_AT_decl_line(0x43)
.dwattr $C$DW$T$1941, DW_AT_decl_column(0x06)
$C$DW$T$1942 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Error_Policy")
.dwattr $C$DW$T$1942, DW_AT_type(*$C$DW$T$1941)
.dwattr $C$DW$T$1942, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1942, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1942, DW_AT_decl_line(0x47)
.dwattr $C$DW$T$1942, DW_AT_decl_column(0x27)
$C$DW$T$1943 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_policy")
.dwattr $C$DW$T$1943, DW_AT_type(*$C$DW$T$1942)
.dwattr $C$DW$T$1943, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1943, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1943, DW_AT_decl_line(0xd1)
.dwattr $C$DW$T$1943, DW_AT_decl_column(0x22)
$C$DW$T$22 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$22, DW_AT_name("xdc_runtime_GateNull_Fxns__")
.dwattr $C$DW$T$22, DW_AT_declaration
.dwendtag $C$DW$T$22
.dwattr $C$DW$T$22, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$22, DW_AT_decl_line(0x43)
.dwattr $C$DW$T$22, DW_AT_decl_column(0x10)
$C$DW$T$1944 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_GateNull_Fxns__")
.dwattr $C$DW$T$1944, DW_AT_type(*$C$DW$T$22)
.dwattr $C$DW$T$1944, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1944, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1944, DW_AT_decl_line(0x43)
.dwattr $C$DW$T$1944, DW_AT_decl_column(0x2c)
$C$DW$T$1945 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1945, DW_AT_type(*$C$DW$T$22)
$C$DW$T$1946 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1946, DW_AT_type(*$C$DW$T$1945)
.dwattr $C$DW$T$1946, DW_AT_address_class(0x20)
$C$DW$T$1947 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_GateNull_Module")
.dwattr $C$DW$T$1947, DW_AT_type(*$C$DW$T$1946)
.dwattr $C$DW$T$1947, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1947, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1947, DW_AT_decl_line(0x44)
.dwattr $C$DW$T$1947, DW_AT_decl_column(0x33)
$C$DW$T$23 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$23, DW_AT_name("xdc_runtime_GateNull_Object")
.dwattr $C$DW$T$23, DW_AT_declaration
.dwendtag $C$DW$T$23
.dwattr $C$DW$T$23, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$23, DW_AT_decl_line(0x46)
.dwattr $C$DW$T$23, DW_AT_decl_column(0x10)
$C$DW$T$1948 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_GateNull_Object")
.dwattr $C$DW$T$1948, DW_AT_type(*$C$DW$T$23)
.dwattr $C$DW$T$1948, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1948, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1948, DW_AT_decl_line(0x46)
.dwattr $C$DW$T$1948, DW_AT_decl_column(0x2c)
$C$DW$T$1949 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1949, DW_AT_type(*$C$DW$T$1948)
.dwattr $C$DW$T$1949, DW_AT_address_class(0x20)
$C$DW$T$1950 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_GateNull_Handle")
.dwattr $C$DW$T$1950, DW_AT_type(*$C$DW$T$1949)
.dwattr $C$DW$T$1950, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1950, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1950, DW_AT_decl_line(0x48)
.dwattr $C$DW$T$1950, DW_AT_decl_column(0x26)
$C$DW$T$1951 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_GateNull_Instance")
.dwattr $C$DW$T$1951, DW_AT_type(*$C$DW$T$1949)
.dwattr $C$DW$T$1951, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1951, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1951, DW_AT_decl_line(0x4a)
.dwattr $C$DW$T$1951, DW_AT_decl_column(0x26)
$C$DW$T$24 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$24, DW_AT_name("xdc_runtime_GateNull_Object__")
.dwattr $C$DW$T$24, DW_AT_declaration
.dwendtag $C$DW$T$24
.dwattr $C$DW$T$24, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$24, DW_AT_decl_line(0x49)
.dwattr $C$DW$T$24, DW_AT_decl_column(0x10)
$C$DW$T$1952 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_GateNull_Instance_State")
.dwattr $C$DW$T$1952, DW_AT_type(*$C$DW$T$24)
.dwattr $C$DW$T$1952, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1952, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1952, DW_AT_decl_line(0x49)
.dwattr $C$DW$T$1952, DW_AT_decl_column(0x2e)
$C$DW$T$25 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$25, DW_AT_name("xdc_runtime_GateNull_Params")
.dwattr $C$DW$T$25, DW_AT_declaration
.dwendtag $C$DW$T$25
.dwattr $C$DW$T$25, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$25, DW_AT_decl_line(0x45)
.dwattr $C$DW$T$25, DW_AT_decl_column(0x10)
$C$DW$T$1953 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_GateNull_Params")
.dwattr $C$DW$T$1953, DW_AT_type(*$C$DW$T$25)
.dwattr $C$DW$T$1953, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1953, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1953, DW_AT_decl_line(0x45)
.dwattr $C$DW$T$1953, DW_AT_decl_column(0x2c)
$C$DW$T$26 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$26, DW_AT_name("xdc_runtime_GateNull_Struct")
.dwattr $C$DW$T$26, DW_AT_declaration
.dwendtag $C$DW$T$26
.dwattr $C$DW$T$26, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$26, DW_AT_decl_line(0x47)
.dwattr $C$DW$T$26, DW_AT_decl_column(0x10)
$C$DW$T$1954 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_GateNull_Struct")
.dwattr $C$DW$T$1954, DW_AT_type(*$C$DW$T$26)
.dwattr $C$DW$T$1954, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1954, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1954, DW_AT_decl_line(0x47)
.dwattr $C$DW$T$1954, DW_AT_decl_column(0x2c)
$C$DW$T$27 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$27, DW_AT_name("xdc_runtime_HeapMin_Fxns__")
.dwattr $C$DW$T$27, DW_AT_declaration
.dwendtag $C$DW$T$27
.dwattr $C$DW$T$27, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$27, DW_AT_decl_line(0xa6)
.dwattr $C$DW$T$27, DW_AT_decl_column(0x10)
$C$DW$T$1955 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapMin_Fxns__")
.dwattr $C$DW$T$1955, DW_AT_type(*$C$DW$T$27)
.dwattr $C$DW$T$1955, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1955, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1955, DW_AT_decl_line(0xa6)
.dwattr $C$DW$T$1955, DW_AT_decl_column(0x2b)
$C$DW$T$1956 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1956, DW_AT_type(*$C$DW$T$27)
$C$DW$T$1957 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1957, DW_AT_type(*$C$DW$T$1956)
.dwattr $C$DW$T$1957, DW_AT_address_class(0x20)
$C$DW$T$1958 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapMin_Module")
.dwattr $C$DW$T$1958, DW_AT_type(*$C$DW$T$1957)
.dwattr $C$DW$T$1958, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1958, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1958, DW_AT_decl_line(0xa7)
.dwattr $C$DW$T$1958, DW_AT_decl_column(0x32)
$C$DW$T$28 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$28, DW_AT_name("xdc_runtime_HeapMin_Object")
.dwattr $C$DW$T$28, DW_AT_declaration
.dwendtag $C$DW$T$28
.dwattr $C$DW$T$28, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$28, DW_AT_decl_line(0xa9)
.dwattr $C$DW$T$28, DW_AT_decl_column(0x10)
$C$DW$T$1959 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapMin_Object")
.dwattr $C$DW$T$1959, DW_AT_type(*$C$DW$T$28)
.dwattr $C$DW$T$1959, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1959, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1959, DW_AT_decl_line(0xa9)
.dwattr $C$DW$T$1959, DW_AT_decl_column(0x2b)
$C$DW$T$1960 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1960, DW_AT_type(*$C$DW$T$1959)
.dwattr $C$DW$T$1960, DW_AT_address_class(0x20)
$C$DW$T$1961 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapMin_Handle")
.dwattr $C$DW$T$1961, DW_AT_type(*$C$DW$T$1960)
.dwattr $C$DW$T$1961, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1961, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1961, DW_AT_decl_line(0xab)
.dwattr $C$DW$T$1961, DW_AT_decl_column(0x25)
$C$DW$T$1962 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapMin_Instance")
.dwattr $C$DW$T$1962, DW_AT_type(*$C$DW$T$1960)
.dwattr $C$DW$T$1962, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1962, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1962, DW_AT_decl_line(0xad)
.dwattr $C$DW$T$1962, DW_AT_decl_column(0x25)
$C$DW$T$29 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$29, DW_AT_name("xdc_runtime_HeapMin_Object__")
.dwattr $C$DW$T$29, DW_AT_declaration
.dwendtag $C$DW$T$29
.dwattr $C$DW$T$29, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$29, DW_AT_decl_line(0xac)
.dwattr $C$DW$T$29, DW_AT_decl_column(0x10)
$C$DW$T$1963 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapMin_Instance_State")
.dwattr $C$DW$T$1963, DW_AT_type(*$C$DW$T$29)
.dwattr $C$DW$T$1963, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1963, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1963, DW_AT_decl_line(0xac)
.dwattr $C$DW$T$1963, DW_AT_decl_column(0x2d)
$C$DW$T$30 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$30, DW_AT_name("xdc_runtime_HeapMin_Params")
.dwattr $C$DW$T$30, DW_AT_declaration
.dwendtag $C$DW$T$30
.dwattr $C$DW$T$30, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$30, DW_AT_decl_line(0xa8)
.dwattr $C$DW$T$30, DW_AT_decl_column(0x10)
$C$DW$T$1964 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapMin_Params")
.dwattr $C$DW$T$1964, DW_AT_type(*$C$DW$T$30)
.dwattr $C$DW$T$1964, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1964, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1964, DW_AT_decl_line(0xa8)
.dwattr $C$DW$T$1964, DW_AT_decl_column(0x2b)
$C$DW$T$31 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$31, DW_AT_name("xdc_runtime_HeapMin_Struct")
.dwattr $C$DW$T$31, DW_AT_declaration
.dwendtag $C$DW$T$31
.dwattr $C$DW$T$31, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$31, DW_AT_decl_line(0xaa)
.dwattr $C$DW$T$31, DW_AT_decl_column(0x10)
$C$DW$T$1965 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapMin_Struct")
.dwattr $C$DW$T$1965, DW_AT_type(*$C$DW$T$31)
.dwattr $C$DW$T$1965, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1965, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1965, DW_AT_decl_line(0xaa)
.dwattr $C$DW$T$1965, DW_AT_decl_column(0x2b)
$C$DW$T$32 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$32, DW_AT_name("xdc_runtime_HeapStd_Fxns__")
.dwattr $C$DW$T$32, DW_AT_declaration
.dwendtag $C$DW$T$32
.dwattr $C$DW$T$32, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$32, DW_AT_decl_line(0xb4)
.dwattr $C$DW$T$32, DW_AT_decl_column(0x10)
$C$DW$T$1966 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapStd_Fxns__")
.dwattr $C$DW$T$1966, DW_AT_type(*$C$DW$T$32)
.dwattr $C$DW$T$1966, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1966, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1966, DW_AT_decl_line(0xb4)
.dwattr $C$DW$T$1966, DW_AT_decl_column(0x2b)
$C$DW$T$1967 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1967, DW_AT_type(*$C$DW$T$32)
$C$DW$T$1968 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1968, DW_AT_type(*$C$DW$T$1967)
.dwattr $C$DW$T$1968, DW_AT_address_class(0x20)
$C$DW$T$1969 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapStd_Module")
.dwattr $C$DW$T$1969, DW_AT_type(*$C$DW$T$1968)
.dwattr $C$DW$T$1969, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1969, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1969, DW_AT_decl_line(0xb5)
.dwattr $C$DW$T$1969, DW_AT_decl_column(0x32)
$C$DW$T$33 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$33, DW_AT_name("xdc_runtime_HeapStd_Module_State")
.dwattr $C$DW$T$33, DW_AT_declaration
.dwendtag $C$DW$T$33
.dwattr $C$DW$T$33, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$33, DW_AT_decl_line(0xb3)
.dwattr $C$DW$T$33, DW_AT_decl_column(0x10)
$C$DW$T$1970 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapStd_Module_State")
.dwattr $C$DW$T$1970, DW_AT_type(*$C$DW$T$33)
.dwattr $C$DW$T$1970, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1970, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1970, DW_AT_decl_line(0xb3)
.dwattr $C$DW$T$1970, DW_AT_decl_column(0x31)
$C$DW$T$34 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$34, DW_AT_name("xdc_runtime_HeapStd_Object")
.dwattr $C$DW$T$34, DW_AT_declaration
.dwendtag $C$DW$T$34
.dwattr $C$DW$T$34, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$34, DW_AT_decl_line(0xb7)
.dwattr $C$DW$T$34, DW_AT_decl_column(0x10)
$C$DW$T$1971 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapStd_Object")
.dwattr $C$DW$T$1971, DW_AT_type(*$C$DW$T$34)
.dwattr $C$DW$T$1971, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1971, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1971, DW_AT_decl_line(0xb7)
.dwattr $C$DW$T$1971, DW_AT_decl_column(0x2b)
$C$DW$T$1972 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1972, DW_AT_type(*$C$DW$T$1971)
.dwattr $C$DW$T$1972, DW_AT_address_class(0x20)
$C$DW$T$1973 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapStd_Handle")
.dwattr $C$DW$T$1973, DW_AT_type(*$C$DW$T$1972)
.dwattr $C$DW$T$1973, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1973, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1973, DW_AT_decl_line(0xb9)
.dwattr $C$DW$T$1973, DW_AT_decl_column(0x25)
$C$DW$T$1974 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapStd_Instance")
.dwattr $C$DW$T$1974, DW_AT_type(*$C$DW$T$1972)
.dwattr $C$DW$T$1974, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1974, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1974, DW_AT_decl_line(0xbb)
.dwattr $C$DW$T$1974, DW_AT_decl_column(0x25)
$C$DW$T$35 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$35, DW_AT_name("xdc_runtime_HeapStd_Object__")
.dwattr $C$DW$T$35, DW_AT_declaration
.dwendtag $C$DW$T$35
.dwattr $C$DW$T$35, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$35, DW_AT_decl_line(0xba)
.dwattr $C$DW$T$35, DW_AT_decl_column(0x10)
$C$DW$T$1975 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapStd_Instance_State")
.dwattr $C$DW$T$1975, DW_AT_type(*$C$DW$T$35)
.dwattr $C$DW$T$1975, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1975, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1975, DW_AT_decl_line(0xba)
.dwattr $C$DW$T$1975, DW_AT_decl_column(0x2d)
$C$DW$T$36 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$36, DW_AT_name("xdc_runtime_HeapStd_Params")
.dwattr $C$DW$T$36, DW_AT_declaration
.dwendtag $C$DW$T$36
.dwattr $C$DW$T$36, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$36, DW_AT_decl_line(0xb6)
.dwattr $C$DW$T$36, DW_AT_decl_column(0x10)
$C$DW$T$1976 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapStd_Params")
.dwattr $C$DW$T$1976, DW_AT_type(*$C$DW$T$36)
.dwattr $C$DW$T$1976, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1976, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1976, DW_AT_decl_line(0xb6)
.dwattr $C$DW$T$1976, DW_AT_decl_column(0x2b)
$C$DW$T$37 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$37, DW_AT_name("xdc_runtime_HeapStd_Struct")
.dwattr $C$DW$T$37, DW_AT_declaration
.dwendtag $C$DW$T$37
.dwattr $C$DW$T$37, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$37, DW_AT_decl_line(0xb8)
.dwattr $C$DW$T$37, DW_AT_decl_column(0x10)
$C$DW$T$1977 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_HeapStd_Struct")
.dwattr $C$DW$T$1977, DW_AT_type(*$C$DW$T$37)
.dwattr $C$DW$T$1977, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1977, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1977, DW_AT_decl_line(0xb8)
.dwattr $C$DW$T$1977, DW_AT_decl_column(0x2b)
$C$DW$T$38 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$38, DW_AT_name("xdc_runtime_IFilterLogger_Fxns__")
.dwattr $C$DW$T$38, DW_AT_declaration
.dwendtag $C$DW$T$38
.dwattr $C$DW$T$38, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$38, DW_AT_decl_line(0x5f)
.dwattr $C$DW$T$38, DW_AT_decl_column(0x10)
$C$DW$T$627 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IFilterLogger_Fxns__")
.dwattr $C$DW$T$627, DW_AT_type(*$C$DW$T$38)
.dwattr $C$DW$T$627, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$627, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$627, DW_AT_decl_line(0x5f)
.dwattr $C$DW$T$627, DW_AT_decl_column(0x31)
$C$DW$T$628 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$628, DW_AT_type(*$C$DW$T$627)
.dwattr $C$DW$T$628, DW_AT_address_class(0x20)
$C$DW$T$1978 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$1978, DW_AT_type(*$C$DW$T$38)
$C$DW$T$1979 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1979, DW_AT_type(*$C$DW$T$1978)
.dwattr $C$DW$T$1979, DW_AT_address_class(0x20)
$C$DW$T$1980 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IFilterLogger_Module")
.dwattr $C$DW$T$1980, DW_AT_type(*$C$DW$T$1979)
.dwattr $C$DW$T$1980, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1980, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1980, DW_AT_decl_line(0x60)
.dwattr $C$DW$T$1980, DW_AT_decl_column(0x38)
$C$DW$T$39 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$39, DW_AT_name("xdc_runtime_IFilterLogger_Params")
.dwattr $C$DW$T$39, DW_AT_declaration
.dwendtag $C$DW$T$39
.dwattr $C$DW$T$39, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$39, DW_AT_decl_line(0x61)
.dwattr $C$DW$T$39, DW_AT_decl_column(0x10)
$C$DW$T$1981 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IFilterLogger_Params")
.dwattr $C$DW$T$1981, DW_AT_type(*$C$DW$T$39)
.dwattr $C$DW$T$1981, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1981, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1981, DW_AT_decl_line(0x61)
.dwattr $C$DW$T$1981, DW_AT_decl_column(0x31)
$C$DW$T$633 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$633, DW_AT_name("xdc_runtime_IFilterLogger___Object")
.dwattr $C$DW$T$633, DW_AT_byte_size(0x08)
$C$DW$2849 .dwtag DW_TAG_member
.dwattr $C$DW$2849, DW_AT_type(*$C$DW$T$628)
.dwattr $C$DW$2849, DW_AT_name("__fxns")
.dwattr $C$DW$2849, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2849, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2849, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2849, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$2849, DW_AT_decl_line(0x62)
.dwattr $C$DW$2849, DW_AT_decl_column(0x57)
$C$DW$2850 .dwtag DW_TAG_member
.dwattr $C$DW$2850, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2850, DW_AT_name("__label")
.dwattr $C$DW$2850, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$2850, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2850, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2850, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$2850, DW_AT_decl_line(0x62)
.dwattr $C$DW$2850, DW_AT_decl_column(0x6a)
$C$DW$177 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$177, DW_AT_declaration
.dwattr $C$DW$177, DW_AT_TI_symbol_name("_ZN34xdc_runtime_IFilterLogger___ObjectaSERKS_")
.dwattr $C$DW$177, DW_AT_type(*$C$DW$T$629)
.dwattr $C$DW$177, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2851 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2851, DW_AT_type(*$C$DW$T$631)
.dwendtag $C$DW$177
.dwendtag $C$DW$T$633
.dwattr $C$DW$T$633, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$633, DW_AT_decl_line(0x62)
.dwattr $C$DW$T$633, DW_AT_decl_column(0x10)
$C$DW$T$629 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$629, DW_AT_type(*$C$DW$T$633)
.dwattr $C$DW$T$629, DW_AT_address_class(0x20)
$C$DW$T$632 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$632, DW_AT_type(*$C$DW$T$629)
.dwattr $C$DW$T$632, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2852 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2852, DW_AT_type(*$C$DW$T$631)
.dwendtag $C$DW$T$632
$C$DW$T$1982 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1982, DW_AT_type(*$C$DW$T$633)
.dwattr $C$DW$T$1982, DW_AT_address_class(0x20)
$C$DW$T$1983 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IFilterLogger_Handle")
.dwattr $C$DW$T$1983, DW_AT_type(*$C$DW$T$1982)
.dwattr $C$DW$T$1983, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1983, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1983, DW_AT_decl_line(0x62)
.dwattr $C$DW$T$1983, DW_AT_decl_column(0x76)
$C$DW$T$630 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$630, DW_AT_type(*$C$DW$T$633)
$C$DW$T$631 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$631, DW_AT_type(*$C$DW$T$630)
.dwattr $C$DW$T$631, DW_AT_address_class(0x20)
$C$DW$T$650 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$650, DW_AT_name("xdc_runtime_IGateProvider_Fxns__")
.dwattr $C$DW$T$650, DW_AT_byte_size(0x24)
$C$DW$2853 .dwtag DW_TAG_member
.dwattr $C$DW$2853, DW_AT_type(*$C$DW$T$635)
.dwattr $C$DW$2853, DW_AT_name("__base")
.dwattr $C$DW$2853, DW_AT_TI_symbol_name("__base")
.dwattr $C$DW$2853, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2853, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2853, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$2853, DW_AT_decl_line(0x59)
.dwattr $C$DW$2853, DW_AT_decl_column(0x1d)
$C$DW$2854 .dwtag DW_TAG_member
.dwattr $C$DW$2854, DW_AT_type(*$C$DW$T$638)
.dwattr $C$DW$2854, DW_AT_name("__sysp")
.dwattr $C$DW$2854, DW_AT_TI_symbol_name("__sysp")
.dwattr $C$DW$2854, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2854, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2854, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$2854, DW_AT_decl_line(0x5a)
.dwattr $C$DW$2854, DW_AT_decl_column(0x27)
$C$DW$2855 .dwtag DW_TAG_member
.dwattr $C$DW$2855, DW_AT_type(*$C$DW$T$641)
.dwattr $C$DW$2855, DW_AT_name("query")
.dwattr $C$DW$2855, DW_AT_TI_symbol_name("query")
.dwattr $C$DW$2855, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2855, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2855, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$2855, DW_AT_decl_line(0x5b)
.dwattr $C$DW$2855, DW_AT_decl_column(0x10)
$C$DW$2856 .dwtag DW_TAG_member
.dwattr $C$DW$2856, DW_AT_type(*$C$DW$T$643)
.dwattr $C$DW$2856, DW_AT_name("enter")
.dwattr $C$DW$2856, DW_AT_TI_symbol_name("enter")
.dwattr $C$DW$2856, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2856, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2856, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$2856, DW_AT_decl_line(0x5c)
.dwattr $C$DW$2856, DW_AT_decl_column(0x10)
$C$DW$2857 .dwtag DW_TAG_member
.dwattr $C$DW$2857, DW_AT_type(*$C$DW$T$645)
.dwattr $C$DW$2857, DW_AT_name("leave")
.dwattr $C$DW$2857, DW_AT_TI_symbol_name("leave")
.dwattr $C$DW$2857, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2857, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2857, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$2857, DW_AT_decl_line(0x5d)
.dwattr $C$DW$2857, DW_AT_decl_column(0x10)
$C$DW$2858 .dwtag DW_TAG_member
.dwattr $C$DW$2858, DW_AT_type(*$C$DW$T$636)
.dwattr $C$DW$2858, DW_AT_name("__sfxns")
.dwattr $C$DW$2858, DW_AT_TI_symbol_name("__sfxns")
.dwattr $C$DW$2858, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$2858, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2858, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$2858, DW_AT_decl_line(0x5e)
.dwattr $C$DW$2858, DW_AT_decl_column(0x20)
$C$DW$178 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$178, DW_AT_declaration
.dwattr $C$DW$178, DW_AT_TI_symbol_name("_ZN32xdc_runtime_IGateProvider_Fxns__aSERKS_")
.dwattr $C$DW$178, DW_AT_type(*$C$DW$T$646)
.dwattr $C$DW$178, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2859 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2859, DW_AT_type(*$C$DW$T$648)
.dwendtag $C$DW$178
.dwendtag $C$DW$T$650
.dwattr $C$DW$T$650, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$T$650, DW_AT_decl_line(0x58)
.dwattr $C$DW$T$650, DW_AT_decl_column(0x08)
$C$DW$T$646 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$646, DW_AT_type(*$C$DW$T$650)
.dwattr $C$DW$T$646, DW_AT_address_class(0x20)
$C$DW$T$649 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$649, DW_AT_type(*$C$DW$T$646)
.dwattr $C$DW$T$649, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2860 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2860, DW_AT_type(*$C$DW$T$648)
.dwendtag $C$DW$T$649
$C$DW$T$647 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$647, DW_AT_type(*$C$DW$T$650)
$C$DW$T$648 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$648, DW_AT_type(*$C$DW$T$647)
.dwattr $C$DW$T$648, DW_AT_address_class(0x20)
$C$DW$T$1984 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1984, DW_AT_type(*$C$DW$T$647)
.dwattr $C$DW$T$1984, DW_AT_address_class(0x20)
$C$DW$T$1985 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IGateProvider_Module")
.dwattr $C$DW$T$1985, DW_AT_type(*$C$DW$T$1984)
.dwattr $C$DW$T$1985, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1985, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1985, DW_AT_decl_line(0x3b)
.dwattr $C$DW$T$1985, DW_AT_decl_column(0x38)
$C$DW$T$661 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IGateProvider_Fxns__")
.dwattr $C$DW$T$661, DW_AT_type(*$C$DW$T$650)
.dwattr $C$DW$T$661, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$661, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$661, DW_AT_decl_line(0x3a)
.dwattr $C$DW$T$661, DW_AT_decl_column(0x31)
$C$DW$T$662 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$662, DW_AT_type(*$C$DW$T$661)
.dwattr $C$DW$T$662, DW_AT_address_class(0x20)
$C$DW$T$660 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$660, DW_AT_name("xdc_runtime_IGateProvider_Params")
.dwattr $C$DW$T$660, DW_AT_byte_size(0x10)
$C$DW$2861 .dwtag DW_TAG_member
.dwattr $C$DW$2861, DW_AT_type(*$C$DW$T$651)
.dwattr $C$DW$2861, DW_AT_name("__size")
.dwattr $C$DW$2861, DW_AT_TI_symbol_name("__size")
.dwattr $C$DW$2861, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2861, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2861, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$2861, DW_AT_decl_line(0x4c)
.dwattr $C$DW$2861, DW_AT_decl_column(0x0c)
$C$DW$2862 .dwtag DW_TAG_member
.dwattr $C$DW$2862, DW_AT_type(*$C$DW$T$653)
.dwattr $C$DW$2862, DW_AT_name("__self")
.dwattr $C$DW$2862, DW_AT_TI_symbol_name("__self")
.dwattr $C$DW$2862, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2862, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2862, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$2862, DW_AT_decl_line(0x4d)
.dwattr $C$DW$2862, DW_AT_decl_column(0x11)
$C$DW$2863 .dwtag DW_TAG_member
.dwattr $C$DW$2863, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$2863, DW_AT_name("__fxns")
.dwattr $C$DW$2863, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2863, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2863, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2863, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$2863, DW_AT_decl_line(0x4e)
.dwattr $C$DW$2863, DW_AT_decl_column(0x0b)
$C$DW$2864 .dwtag DW_TAG_member
.dwattr $C$DW$2864, DW_AT_type(*$C$DW$T$655)
.dwattr $C$DW$2864, DW_AT_name("instance")
.dwattr $C$DW$2864, DW_AT_TI_symbol_name("instance")
.dwattr $C$DW$2864, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2864, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2864, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$2864, DW_AT_decl_line(0x4f)
.dwattr $C$DW$2864, DW_AT_decl_column(0x23)
$C$DW$179 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$179, DW_AT_declaration
.dwattr $C$DW$179, DW_AT_TI_symbol_name("_ZN32xdc_runtime_IGateProvider_ParamsaSERKS_")
.dwattr $C$DW$179, DW_AT_type(*$C$DW$T$656)
.dwattr $C$DW$179, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2865 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2865, DW_AT_type(*$C$DW$T$658)
.dwendtag $C$DW$179
.dwendtag $C$DW$T$660
.dwattr $C$DW$T$660, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IGateProvider.h")
.dwattr $C$DW$T$660, DW_AT_decl_line(0x4b)
.dwattr $C$DW$T$660, DW_AT_decl_column(0x08)
$C$DW$T$656 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$656, DW_AT_type(*$C$DW$T$660)
.dwattr $C$DW$T$656, DW_AT_address_class(0x20)
$C$DW$T$659 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$659, DW_AT_type(*$C$DW$T$656)
.dwattr $C$DW$T$659, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2866 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2866, DW_AT_type(*$C$DW$T$658)
.dwendtag $C$DW$T$659
$C$DW$T$657 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$657, DW_AT_type(*$C$DW$T$660)
$C$DW$T$658 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$658, DW_AT_type(*$C$DW$T$657)
.dwattr $C$DW$T$658, DW_AT_address_class(0x20)
$C$DW$T$1986 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IGateProvider_Params")
.dwattr $C$DW$T$1986, DW_AT_type(*$C$DW$T$660)
.dwattr $C$DW$T$1986, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1986, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1986, DW_AT_decl_line(0x3c)
.dwattr $C$DW$T$1986, DW_AT_decl_column(0x31)
$C$DW$T$667 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$667, DW_AT_name("xdc_runtime_IGateProvider___Object")
.dwattr $C$DW$T$667, DW_AT_byte_size(0x08)
$C$DW$2867 .dwtag DW_TAG_member
.dwattr $C$DW$2867, DW_AT_type(*$C$DW$T$662)
.dwattr $C$DW$2867, DW_AT_name("__fxns")
.dwattr $C$DW$2867, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2867, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2867, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2867, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$2867, DW_AT_decl_line(0x3d)
.dwattr $C$DW$2867, DW_AT_decl_column(0x57)
$C$DW$2868 .dwtag DW_TAG_member
.dwattr $C$DW$2868, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2868, DW_AT_name("__label")
.dwattr $C$DW$2868, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$2868, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2868, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2868, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$2868, DW_AT_decl_line(0x3d)
.dwattr $C$DW$2868, DW_AT_decl_column(0x6a)
$C$DW$180 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$180, DW_AT_declaration
.dwattr $C$DW$180, DW_AT_TI_symbol_name("_ZN34xdc_runtime_IGateProvider___ObjectaSERKS_")
.dwattr $C$DW$180, DW_AT_type(*$C$DW$T$663)
.dwattr $C$DW$180, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2869 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2869, DW_AT_type(*$C$DW$T$665)
.dwendtag $C$DW$180
.dwendtag $C$DW$T$667
.dwattr $C$DW$T$667, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$667, DW_AT_decl_line(0x3d)
.dwattr $C$DW$T$667, DW_AT_decl_column(0x10)
$C$DW$T$663 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$663, DW_AT_type(*$C$DW$T$667)
.dwattr $C$DW$T$663, DW_AT_address_class(0x20)
$C$DW$T$666 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$666, DW_AT_type(*$C$DW$T$663)
.dwattr $C$DW$T$666, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2870 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2870, DW_AT_type(*$C$DW$T$665)
.dwendtag $C$DW$T$666
$C$DW$T$728 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$728, DW_AT_type(*$C$DW$T$667)
.dwattr $C$DW$T$728, DW_AT_address_class(0x20)
$C$DW$T$1987 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IGateProvider_Handle")
.dwattr $C$DW$T$1987, DW_AT_type(*$C$DW$T$728)
.dwattr $C$DW$T$1987, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1987, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1987, DW_AT_decl_line(0x3d)
.dwattr $C$DW$T$1987, DW_AT_decl_column(0x76)
$C$DW$T$1988 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Module_GateProxy_Handle")
.dwattr $C$DW$T$1988, DW_AT_type(*$C$DW$T$728)
.dwattr $C$DW$T$1988, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1988, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1988, DW_AT_decl_line(0x14b)
.dwattr $C$DW$T$1988, DW_AT_decl_column(0x34)
$C$DW$T$729 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Main_Module_GateProxy_Handle")
.dwattr $C$DW$T$729, DW_AT_type(*$C$DW$T$728)
.dwattr $C$DW$T$729, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$729, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$729, DW_AT_decl_line(0x15b)
.dwattr $C$DW$T$729, DW_AT_decl_column(0x34)
$C$DW$T$1989 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_System_Module_GateProxy_Handle")
.dwattr $C$DW$T$1989, DW_AT_type(*$C$DW$T$728)
.dwattr $C$DW$T$1989, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1989, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1989, DW_AT_decl_line(0x174)
.dwattr $C$DW$T$1989, DW_AT_decl_column(0x34)
$C$DW$T$664 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$664, DW_AT_type(*$C$DW$T$667)
$C$DW$T$665 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$665, DW_AT_type(*$C$DW$T$664)
.dwattr $C$DW$T$665, DW_AT_address_class(0x20)
$C$DW$T$686 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$686, DW_AT_name("xdc_runtime_IHeap_Fxns__")
.dwattr $C$DW$T$686, DW_AT_byte_size(0x28)
$C$DW$2871 .dwtag DW_TAG_member
.dwattr $C$DW$2871, DW_AT_type(*$C$DW$T$635)
.dwattr $C$DW$2871, DW_AT_name("__base")
.dwattr $C$DW$2871, DW_AT_TI_symbol_name("__base")
.dwattr $C$DW$2871, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2871, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2871, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$2871, DW_AT_decl_line(0x55)
.dwattr $C$DW$2871, DW_AT_decl_column(0x1d)
$C$DW$2872 .dwtag DW_TAG_member
.dwattr $C$DW$2872, DW_AT_type(*$C$DW$T$638)
.dwattr $C$DW$2872, DW_AT_name("__sysp")
.dwattr $C$DW$2872, DW_AT_TI_symbol_name("__sysp")
.dwattr $C$DW$2872, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2872, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2872, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$2872, DW_AT_decl_line(0x56)
.dwattr $C$DW$2872, DW_AT_decl_column(0x27)
$C$DW$2873 .dwtag DW_TAG_member
.dwattr $C$DW$2873, DW_AT_type(*$C$DW$T$673)
.dwattr $C$DW$2873, DW_AT_name("alloc")
.dwattr $C$DW$2873, DW_AT_TI_symbol_name("alloc")
.dwattr $C$DW$2873, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2873, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2873, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$2873, DW_AT_decl_line(0x57)
.dwattr $C$DW$2873, DW_AT_decl_column(0x0f)
$C$DW$2874 .dwtag DW_TAG_member
.dwattr $C$DW$2874, DW_AT_type(*$C$DW$T$675)
.dwattr $C$DW$2874, DW_AT_name("free")
.dwattr $C$DW$2874, DW_AT_TI_symbol_name("free")
.dwattr $C$DW$2874, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2874, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2874, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$2874, DW_AT_decl_line(0x58)
.dwattr $C$DW$2874, DW_AT_decl_column(0x10)
$C$DW$2875 .dwtag DW_TAG_member
.dwattr $C$DW$2875, DW_AT_type(*$C$DW$T$677)
.dwattr $C$DW$2875, DW_AT_name("isBlocking")
.dwattr $C$DW$2875, DW_AT_TI_symbol_name("isBlocking")
.dwattr $C$DW$2875, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2875, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2875, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$2875, DW_AT_decl_line(0x59)
.dwattr $C$DW$2875, DW_AT_decl_column(0x10)
$C$DW$2876 .dwtag DW_TAG_member
.dwattr $C$DW$2876, DW_AT_type(*$C$DW$T$681)
.dwattr $C$DW$2876, DW_AT_name("getStats")
.dwattr $C$DW$2876, DW_AT_TI_symbol_name("getStats")
.dwattr $C$DW$2876, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$2876, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2876, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$2876, DW_AT_decl_line(0x5a)
.dwattr $C$DW$2876, DW_AT_decl_column(0x10)
$C$DW$2877 .dwtag DW_TAG_member
.dwattr $C$DW$2877, DW_AT_type(*$C$DW$T$636)
.dwattr $C$DW$2877, DW_AT_name("__sfxns")
.dwattr $C$DW$2877, DW_AT_TI_symbol_name("__sfxns")
.dwattr $C$DW$2877, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2877, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2877, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$2877, DW_AT_decl_line(0x5b)
.dwattr $C$DW$2877, DW_AT_decl_column(0x20)
$C$DW$181 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$181, DW_AT_declaration
.dwattr $C$DW$181, DW_AT_TI_symbol_name("_ZN24xdc_runtime_IHeap_Fxns__aSERKS_")
.dwattr $C$DW$181, DW_AT_type(*$C$DW$T$682)
.dwattr $C$DW$181, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2878 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2878, DW_AT_type(*$C$DW$T$684)
.dwendtag $C$DW$181
.dwendtag $C$DW$T$686
.dwattr $C$DW$T$686, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$T$686, DW_AT_decl_line(0x54)
.dwattr $C$DW$T$686, DW_AT_decl_column(0x08)
$C$DW$T$682 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$682, DW_AT_type(*$C$DW$T$686)
.dwattr $C$DW$T$682, DW_AT_address_class(0x20)
$C$DW$T$685 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$685, DW_AT_type(*$C$DW$T$682)
.dwattr $C$DW$T$685, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2879 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2879, DW_AT_type(*$C$DW$T$684)
.dwendtag $C$DW$T$685
$C$DW$T$683 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$683, DW_AT_type(*$C$DW$T$686)
$C$DW$T$684 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$684, DW_AT_type(*$C$DW$T$683)
.dwattr $C$DW$T$684, DW_AT_address_class(0x20)
$C$DW$T$1990 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$1990, DW_AT_type(*$C$DW$T$683)
.dwattr $C$DW$T$1990, DW_AT_address_class(0x20)
$C$DW$T$1991 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IHeap_Module")
.dwattr $C$DW$T$1991, DW_AT_type(*$C$DW$T$1990)
.dwattr $C$DW$T$1991, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1991, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1991, DW_AT_decl_line(0x9e)
.dwattr $C$DW$T$1991, DW_AT_decl_column(0x30)
$C$DW$T$692 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IHeap_Fxns__")
.dwattr $C$DW$T$692, DW_AT_type(*$C$DW$T$686)
.dwattr $C$DW$T$692, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$692, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$692, DW_AT_decl_line(0x9d)
.dwattr $C$DW$T$692, DW_AT_decl_column(0x29)
$C$DW$T$693 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$693, DW_AT_type(*$C$DW$T$692)
.dwattr $C$DW$T$693, DW_AT_address_class(0x20)
$C$DW$T$691 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$691, DW_AT_name("xdc_runtime_IHeap_Params")
.dwattr $C$DW$T$691, DW_AT_byte_size(0x10)
$C$DW$2880 .dwtag DW_TAG_member
.dwattr $C$DW$2880, DW_AT_type(*$C$DW$T$651)
.dwattr $C$DW$2880, DW_AT_name("__size")
.dwattr $C$DW$2880, DW_AT_TI_symbol_name("__size")
.dwattr $C$DW$2880, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2880, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2880, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$2880, DW_AT_decl_line(0x48)
.dwattr $C$DW$2880, DW_AT_decl_column(0x0c)
$C$DW$2881 .dwtag DW_TAG_member
.dwattr $C$DW$2881, DW_AT_type(*$C$DW$T$653)
.dwattr $C$DW$2881, DW_AT_name("__self")
.dwattr $C$DW$2881, DW_AT_TI_symbol_name("__self")
.dwattr $C$DW$2881, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2881, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2881, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$2881, DW_AT_decl_line(0x49)
.dwattr $C$DW$2881, DW_AT_decl_column(0x11)
$C$DW$2882 .dwtag DW_TAG_member
.dwattr $C$DW$2882, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$2882, DW_AT_name("__fxns")
.dwattr $C$DW$2882, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2882, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2882, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2882, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$2882, DW_AT_decl_line(0x4a)
.dwattr $C$DW$2882, DW_AT_decl_column(0x0b)
$C$DW$2883 .dwtag DW_TAG_member
.dwattr $C$DW$2883, DW_AT_type(*$C$DW$T$655)
.dwattr $C$DW$2883, DW_AT_name("instance")
.dwattr $C$DW$2883, DW_AT_TI_symbol_name("instance")
.dwattr $C$DW$2883, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2883, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2883, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$2883, DW_AT_decl_line(0x4b)
.dwattr $C$DW$2883, DW_AT_decl_column(0x23)
$C$DW$182 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$182, DW_AT_declaration
.dwattr $C$DW$182, DW_AT_TI_symbol_name("_ZN24xdc_runtime_IHeap_ParamsaSERKS_")
.dwattr $C$DW$182, DW_AT_type(*$C$DW$T$687)
.dwattr $C$DW$182, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2884 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2884, DW_AT_type(*$C$DW$T$689)
.dwendtag $C$DW$182
.dwendtag $C$DW$T$691
.dwattr $C$DW$T$691, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IHeap.h")
.dwattr $C$DW$T$691, DW_AT_decl_line(0x47)
.dwattr $C$DW$T$691, DW_AT_decl_column(0x08)
$C$DW$T$687 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$687, DW_AT_type(*$C$DW$T$691)
.dwattr $C$DW$T$687, DW_AT_address_class(0x20)
$C$DW$T$690 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$690, DW_AT_type(*$C$DW$T$687)
.dwattr $C$DW$T$690, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2885 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2885, DW_AT_type(*$C$DW$T$689)
.dwendtag $C$DW$T$690
$C$DW$T$688 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$688, DW_AT_type(*$C$DW$T$691)
$C$DW$T$689 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$689, DW_AT_type(*$C$DW$T$688)
.dwattr $C$DW$T$689, DW_AT_address_class(0x20)
$C$DW$T$1992 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IHeap_Params")
.dwattr $C$DW$T$1992, DW_AT_type(*$C$DW$T$691)
.dwattr $C$DW$T$1992, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1992, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1992, DW_AT_decl_line(0x9f)
.dwattr $C$DW$T$1992, DW_AT_decl_column(0x29)
$C$DW$T$698 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$698, DW_AT_name("xdc_runtime_IHeap___Object")
.dwattr $C$DW$T$698, DW_AT_byte_size(0x08)
$C$DW$2886 .dwtag DW_TAG_member
.dwattr $C$DW$2886, DW_AT_type(*$C$DW$T$693)
.dwattr $C$DW$2886, DW_AT_name("__fxns")
.dwattr $C$DW$2886, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2886, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2886, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2886, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$2886, DW_AT_decl_line(0xa0)
.dwattr $C$DW$2886, DW_AT_decl_column(0x47)
$C$DW$2887 .dwtag DW_TAG_member
.dwattr $C$DW$2887, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2887, DW_AT_name("__label")
.dwattr $C$DW$2887, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$2887, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2887, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2887, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$2887, DW_AT_decl_line(0xa0)
.dwattr $C$DW$2887, DW_AT_decl_column(0x5a)
$C$DW$183 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$183, DW_AT_declaration
.dwattr $C$DW$183, DW_AT_TI_symbol_name("_ZN26xdc_runtime_IHeap___ObjectaSERKS_")
.dwattr $C$DW$183, DW_AT_type(*$C$DW$T$694)
.dwattr $C$DW$183, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2888 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2888, DW_AT_type(*$C$DW$T$696)
.dwendtag $C$DW$183
.dwendtag $C$DW$T$698
.dwattr $C$DW$T$698, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$698, DW_AT_decl_line(0xa0)
.dwattr $C$DW$T$698, DW_AT_decl_column(0x10)
$C$DW$T$694 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$694, DW_AT_type(*$C$DW$T$698)
.dwattr $C$DW$T$694, DW_AT_address_class(0x20)
$C$DW$T$697 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$697, DW_AT_type(*$C$DW$T$694)
.dwattr $C$DW$T$697, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2889 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2889, DW_AT_type(*$C$DW$T$696)
.dwendtag $C$DW$T$697
$C$DW$T$755 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$755, DW_AT_type(*$C$DW$T$698)
.dwattr $C$DW$T$755, DW_AT_address_class(0x20)
$C$DW$T$1993 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IHeap_Handle")
.dwattr $C$DW$T$1993, DW_AT_type(*$C$DW$T$755)
.dwattr $C$DW$T$1993, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1993, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$1993, DW_AT_decl_line(0xa0)
.dwattr $C$DW$T$1993, DW_AT_decl_column(0x66)
$C$DW$T$1994 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Diags_Object__heap")
.dwattr $C$DW$T$1994, DW_AT_type(*$C$DW$T$1993)
.dwattr $C$DW$T$1994, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1994, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Diags.h")
.dwattr $C$DW$T$1994, DW_AT_decl_line(0xe0)
.dwattr $C$DW$T$1994, DW_AT_decl_column(0x22)
$C$DW$T$1995 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Error_Object__heap")
.dwattr $C$DW$T$1995, DW_AT_type(*$C$DW$T$1993)
.dwattr $C$DW$T$1995, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1995, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Error.h")
.dwattr $C$DW$T$1995, DW_AT_decl_line(0xb0)
.dwattr $C$DW$T$1995, DW_AT_decl_column(0x22)
$C$DW$T$1996 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Module_GateProxy_Object__heap")
.dwattr $C$DW$T$1996, DW_AT_type(*$C$DW$T$1993)
.dwattr $C$DW$T$1996, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1996, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$1996, DW_AT_decl_line(0x89)
.dwattr $C$DW$T$1996, DW_AT_decl_column(0x22)
$C$DW$T$1997 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Main_Object__heap")
.dwattr $C$DW$T$1997, DW_AT_type(*$C$DW$T$1993)
.dwattr $C$DW$T$1997, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1997, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Main.h")
.dwattr $C$DW$T$1997, DW_AT_decl_line(0x89)
.dwattr $C$DW$T$1997, DW_AT_decl_column(0x22)
$C$DW$T$1998 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_HeapProxy_Object__heap")
.dwattr $C$DW$T$1998, DW_AT_type(*$C$DW$T$1993)
.dwattr $C$DW$T$1998, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1998, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$1998, DW_AT_decl_line(0x83)
.dwattr $C$DW$T$1998, DW_AT_decl_column(0x22)
$C$DW$T$1999 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_Object__heap")
.dwattr $C$DW$T$1999, DW_AT_type(*$C$DW$T$1993)
.dwattr $C$DW$T$1999, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$1999, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$1999, DW_AT_decl_line(0x97)
.dwattr $C$DW$T$1999, DW_AT_decl_column(0x22)
$C$DW$T$2000 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Memory_defaultHeapInstance")
.dwattr $C$DW$T$2000, DW_AT_type(*$C$DW$T$1993)
.dwattr $C$DW$T$2000, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2000, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$2000, DW_AT_decl_line(0xa4)
.dwattr $C$DW$T$2000, DW_AT_decl_column(0x22)
$C$DW$T$2001 .dwtag DW_TAG_typedef, DW_AT_name("CT__xdc_runtime_Types_Object__heap")
.dwattr $C$DW$T$2001, DW_AT_type(*$C$DW$T$1993)
.dwattr $C$DW$T$2001, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2001, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$2001, DW_AT_decl_line(0x113)
.dwattr $C$DW$T$2001, DW_AT_decl_column(0x22)
$C$DW$T$756 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Memory_HeapProxy_Handle")
.dwattr $C$DW$T$756, DW_AT_type(*$C$DW$T$755)
.dwattr $C$DW$T$756, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$756, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$756, DW_AT_decl_line(0x164)
.dwattr $C$DW$T$756, DW_AT_decl_column(0x2c)
$C$DW$T$695 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$695, DW_AT_type(*$C$DW$T$698)
$C$DW$T$696 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$696, DW_AT_type(*$C$DW$T$695)
.dwattr $C$DW$T$696, DW_AT_address_class(0x20)
$C$DW$T$703 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$703, DW_AT_name("xdc_runtime_IInstance_Fxns__")
.dwattr $C$DW$T$703, DW_AT_byte_size(0x18)
$C$DW$2890 .dwtag DW_TAG_member
.dwattr $C$DW$2890, DW_AT_type(*$C$DW$T$635)
.dwattr $C$DW$2890, DW_AT_name("__base")
.dwattr $C$DW$2890, DW_AT_TI_symbol_name("__base")
.dwattr $C$DW$2890, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2890, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2890, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IInstance.h")
.dwattr $C$DW$2890, DW_AT_decl_line(0x4e)
.dwattr $C$DW$2890, DW_AT_decl_column(0x1d)
$C$DW$2891 .dwtag DW_TAG_member
.dwattr $C$DW$2891, DW_AT_type(*$C$DW$T$638)
.dwattr $C$DW$2891, DW_AT_name("__sysp")
.dwattr $C$DW$2891, DW_AT_TI_symbol_name("__sysp")
.dwattr $C$DW$2891, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2891, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2891, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IInstance.h")
.dwattr $C$DW$2891, DW_AT_decl_line(0x4f)
.dwattr $C$DW$2891, DW_AT_decl_column(0x27)
$C$DW$2892 .dwtag DW_TAG_member
.dwattr $C$DW$2892, DW_AT_type(*$C$DW$T$636)
.dwattr $C$DW$2892, DW_AT_name("__sfxns")
.dwattr $C$DW$2892, DW_AT_TI_symbol_name("__sfxns")
.dwattr $C$DW$2892, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2892, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2892, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IInstance.h")
.dwattr $C$DW$2892, DW_AT_decl_line(0x50)
.dwattr $C$DW$2892, DW_AT_decl_column(0x20)
$C$DW$184 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$184, DW_AT_declaration
.dwattr $C$DW$184, DW_AT_TI_symbol_name("_ZN28xdc_runtime_IInstance_Fxns__aSERKS_")
.dwattr $C$DW$184, DW_AT_type(*$C$DW$T$699)
.dwattr $C$DW$184, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2893 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2893, DW_AT_type(*$C$DW$T$701)
.dwendtag $C$DW$184
.dwendtag $C$DW$T$703
.dwattr $C$DW$T$703, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IInstance.h")
.dwattr $C$DW$T$703, DW_AT_decl_line(0x4d)
.dwattr $C$DW$T$703, DW_AT_decl_column(0x08)
$C$DW$T$699 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$699, DW_AT_type(*$C$DW$T$703)
.dwattr $C$DW$T$699, DW_AT_address_class(0x20)
$C$DW$T$702 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$702, DW_AT_type(*$C$DW$T$699)
.dwattr $C$DW$T$702, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2894 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2894, DW_AT_type(*$C$DW$T$701)
.dwendtag $C$DW$T$702
$C$DW$T$700 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$700, DW_AT_type(*$C$DW$T$703)
$C$DW$T$701 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$701, DW_AT_type(*$C$DW$T$700)
.dwattr $C$DW$T$701, DW_AT_address_class(0x20)
$C$DW$T$2002 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2002, DW_AT_type(*$C$DW$T$700)
.dwattr $C$DW$T$2002, DW_AT_address_class(0x20)
$C$DW$T$2003 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IInstance_Module")
.dwattr $C$DW$T$2003, DW_AT_type(*$C$DW$T$2002)
.dwattr $C$DW$T$2003, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2003, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2003, DW_AT_decl_line(0x139)
.dwattr $C$DW$T$2003, DW_AT_decl_column(0x34)
$C$DW$T$709 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IInstance_Fxns__")
.dwattr $C$DW$T$709, DW_AT_type(*$C$DW$T$703)
.dwattr $C$DW$T$709, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$709, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$709, DW_AT_decl_line(0x138)
.dwattr $C$DW$T$709, DW_AT_decl_column(0x2d)
$C$DW$T$710 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$710, DW_AT_type(*$C$DW$T$709)
.dwattr $C$DW$T$710, DW_AT_address_class(0x20)
$C$DW$T$708 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$708, DW_AT_name("xdc_runtime_IInstance_Params")
.dwattr $C$DW$T$708, DW_AT_byte_size(0x08)
$C$DW$2895 .dwtag DW_TAG_member
.dwattr $C$DW$2895, DW_AT_type(*$C$DW$T$651)
.dwattr $C$DW$2895, DW_AT_name("__size")
.dwattr $C$DW$2895, DW_AT_TI_symbol_name("__size")
.dwattr $C$DW$2895, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2895, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2895, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IInstance.h")
.dwattr $C$DW$2895, DW_AT_decl_line(0x43)
.dwattr $C$DW$2895, DW_AT_decl_column(0x0c)
$C$DW$2896 .dwtag DW_TAG_member
.dwattr $C$DW$2896, DW_AT_type(*$C$DW$T$609)
.dwattr $C$DW$2896, DW_AT_name("name")
.dwattr $C$DW$2896, DW_AT_TI_symbol_name("name")
.dwattr $C$DW$2896, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2896, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2896, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IInstance.h")
.dwattr $C$DW$2896, DW_AT_decl_line(0x44)
.dwattr $C$DW$2896, DW_AT_decl_column(0x10)
$C$DW$185 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$185, DW_AT_declaration
.dwattr $C$DW$185, DW_AT_TI_symbol_name("_ZN28xdc_runtime_IInstance_ParamsaSERKS_")
.dwattr $C$DW$185, DW_AT_type(*$C$DW$T$704)
.dwattr $C$DW$185, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2897 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2897, DW_AT_type(*$C$DW$T$706)
.dwendtag $C$DW$185
.dwendtag $C$DW$T$708
.dwattr $C$DW$T$708, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IInstance.h")
.dwattr $C$DW$T$708, DW_AT_decl_line(0x42)
.dwattr $C$DW$T$708, DW_AT_decl_column(0x08)
$C$DW$T$704 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$704, DW_AT_type(*$C$DW$T$708)
.dwattr $C$DW$T$704, DW_AT_address_class(0x20)
$C$DW$T$707 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$707, DW_AT_type(*$C$DW$T$704)
.dwattr $C$DW$T$707, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2898 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2898, DW_AT_type(*$C$DW$T$706)
.dwendtag $C$DW$T$707
$C$DW$T$654 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IInstance_Params")
.dwattr $C$DW$T$654, DW_AT_type(*$C$DW$T$708)
.dwattr $C$DW$T$654, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$654, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$654, DW_AT_decl_line(0x13a)
.dwattr $C$DW$T$654, DW_AT_decl_column(0x2d)
$C$DW$T$655 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$655, DW_AT_type(*$C$DW$T$654)
.dwattr $C$DW$T$655, DW_AT_address_class(0x20)
$C$DW$T$705 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$705, DW_AT_type(*$C$DW$T$708)
$C$DW$T$706 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$706, DW_AT_type(*$C$DW$T$705)
.dwattr $C$DW$T$706, DW_AT_address_class(0x20)
$C$DW$T$715 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$715, DW_AT_name("xdc_runtime_IInstance___Object")
.dwattr $C$DW$T$715, DW_AT_byte_size(0x08)
$C$DW$2899 .dwtag DW_TAG_member
.dwattr $C$DW$2899, DW_AT_type(*$C$DW$T$710)
.dwattr $C$DW$2899, DW_AT_name("__fxns")
.dwattr $C$DW$2899, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2899, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2899, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2899, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$2899, DW_AT_decl_line(0x13b)
.dwattr $C$DW$2899, DW_AT_decl_column(0x4f)
$C$DW$2900 .dwtag DW_TAG_member
.dwattr $C$DW$2900, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2900, DW_AT_name("__label")
.dwattr $C$DW$2900, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$2900, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2900, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2900, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$2900, DW_AT_decl_line(0x13b)
.dwattr $C$DW$2900, DW_AT_decl_column(0x62)
$C$DW$186 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$186, DW_AT_declaration
.dwattr $C$DW$186, DW_AT_TI_symbol_name("_ZN30xdc_runtime_IInstance___ObjectaSERKS_")
.dwattr $C$DW$186, DW_AT_type(*$C$DW$T$711)
.dwattr $C$DW$186, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2901 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2901, DW_AT_type(*$C$DW$T$713)
.dwendtag $C$DW$186
.dwendtag $C$DW$T$715
.dwattr $C$DW$T$715, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$715, DW_AT_decl_line(0x13b)
.dwattr $C$DW$T$715, DW_AT_decl_column(0x10)
$C$DW$T$711 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$711, DW_AT_type(*$C$DW$T$715)
.dwattr $C$DW$T$711, DW_AT_address_class(0x20)
$C$DW$T$714 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$714, DW_AT_type(*$C$DW$T$711)
.dwattr $C$DW$T$714, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2902 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2902, DW_AT_type(*$C$DW$T$713)
.dwendtag $C$DW$T$714
$C$DW$T$2004 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2004, DW_AT_type(*$C$DW$T$715)
.dwattr $C$DW$T$2004, DW_AT_address_class(0x20)
$C$DW$T$2005 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IInstance_Handle")
.dwattr $C$DW$T$2005, DW_AT_type(*$C$DW$T$2004)
.dwattr $C$DW$T$2005, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2005, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2005, DW_AT_decl_line(0x13b)
.dwattr $C$DW$T$2005, DW_AT_decl_column(0x6e)
$C$DW$T$712 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$712, DW_AT_type(*$C$DW$T$715)
$C$DW$T$713 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$713, DW_AT_type(*$C$DW$T$712)
.dwattr $C$DW$T$713, DW_AT_address_class(0x20)
$C$DW$T$40 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$40, DW_AT_name("xdc_runtime_ILogger_Fxns__")
.dwattr $C$DW$T$40, DW_AT_declaration
.dwendtag $C$DW$T$40
.dwattr $C$DW$T$40, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$40, DW_AT_decl_line(0x56)
.dwattr $C$DW$T$40, DW_AT_decl_column(0x10)
$C$DW$T$716 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_ILogger_Fxns__")
.dwattr $C$DW$T$716, DW_AT_type(*$C$DW$T$40)
.dwattr $C$DW$T$716, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$716, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$716, DW_AT_decl_line(0x56)
.dwattr $C$DW$T$716, DW_AT_decl_column(0x2b)
$C$DW$T$717 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$717, DW_AT_type(*$C$DW$T$716)
.dwattr $C$DW$T$717, DW_AT_address_class(0x20)
$C$DW$T$2006 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2006, DW_AT_type(*$C$DW$T$40)
$C$DW$T$2007 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2007, DW_AT_type(*$C$DW$T$2006)
.dwattr $C$DW$T$2007, DW_AT_address_class(0x20)
$C$DW$T$2008 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_ILogger_Module")
.dwattr $C$DW$T$2008, DW_AT_type(*$C$DW$T$2007)
.dwattr $C$DW$T$2008, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2008, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2008, DW_AT_decl_line(0x57)
.dwattr $C$DW$T$2008, DW_AT_decl_column(0x32)
$C$DW$T$41 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$41, DW_AT_name("xdc_runtime_ILogger_Params")
.dwattr $C$DW$T$41, DW_AT_declaration
.dwendtag $C$DW$T$41
.dwattr $C$DW$T$41, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$41, DW_AT_decl_line(0x58)
.dwattr $C$DW$T$41, DW_AT_decl_column(0x10)
$C$DW$T$2009 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_ILogger_Params")
.dwattr $C$DW$T$2009, DW_AT_type(*$C$DW$T$41)
.dwattr $C$DW$T$2009, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2009, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2009, DW_AT_decl_line(0x58)
.dwattr $C$DW$T$2009, DW_AT_decl_column(0x2b)
$C$DW$T$722 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$722, DW_AT_name("xdc_runtime_ILogger___Object")
.dwattr $C$DW$T$722, DW_AT_byte_size(0x08)
$C$DW$2903 .dwtag DW_TAG_member
.dwattr $C$DW$2903, DW_AT_type(*$C$DW$T$717)
.dwattr $C$DW$2903, DW_AT_name("__fxns")
.dwattr $C$DW$2903, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2903, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2903, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2903, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$2903, DW_AT_decl_line(0x59)
.dwattr $C$DW$2903, DW_AT_decl_column(0x4b)
$C$DW$2904 .dwtag DW_TAG_member
.dwattr $C$DW$2904, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2904, DW_AT_name("__label")
.dwattr $C$DW$2904, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$2904, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2904, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2904, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$2904, DW_AT_decl_line(0x59)
.dwattr $C$DW$2904, DW_AT_decl_column(0x5e)
$C$DW$187 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$187, DW_AT_declaration
.dwattr $C$DW$187, DW_AT_TI_symbol_name("_ZN28xdc_runtime_ILogger___ObjectaSERKS_")
.dwattr $C$DW$187, DW_AT_type(*$C$DW$T$718)
.dwattr $C$DW$187, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2905 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2905, DW_AT_type(*$C$DW$T$720)
.dwendtag $C$DW$187
.dwendtag $C$DW$T$722
.dwattr $C$DW$T$722, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$722, DW_AT_decl_line(0x59)
.dwattr $C$DW$T$722, DW_AT_decl_column(0x10)
$C$DW$T$718 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$718, DW_AT_type(*$C$DW$T$722)
.dwattr $C$DW$T$718, DW_AT_address_class(0x20)
$C$DW$T$721 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$721, DW_AT_type(*$C$DW$T$718)
.dwattr $C$DW$T$721, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2906 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2906, DW_AT_type(*$C$DW$T$720)
.dwendtag $C$DW$T$721
$C$DW$T$2010 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2010, DW_AT_type(*$C$DW$T$722)
.dwattr $C$DW$T$2010, DW_AT_address_class(0x20)
$C$DW$T$2011 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_ILogger_Handle")
.dwattr $C$DW$T$2011, DW_AT_type(*$C$DW$T$2010)
.dwattr $C$DW$T$2011, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2011, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2011, DW_AT_decl_line(0x59)
.dwattr $C$DW$T$2011, DW_AT_decl_column(0x6a)
$C$DW$T$719 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$719, DW_AT_type(*$C$DW$T$722)
$C$DW$T$720 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$720, DW_AT_type(*$C$DW$T$719)
.dwattr $C$DW$T$720, DW_AT_address_class(0x20)
$C$DW$T$727 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$727, DW_AT_name("xdc_runtime_IModule_Fxns__")
.dwattr $C$DW$T$727, DW_AT_byte_size(0x18)
$C$DW$2907 .dwtag DW_TAG_member
.dwattr $C$DW$2907, DW_AT_type(*$C$DW$T$635)
.dwattr $C$DW$2907, DW_AT_name("__base")
.dwattr $C$DW$2907, DW_AT_TI_symbol_name("__base")
.dwattr $C$DW$2907, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2907, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2907, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IModule.h")
.dwattr $C$DW$2907, DW_AT_decl_line(0x46)
.dwattr $C$DW$2907, DW_AT_decl_column(0x1d)
$C$DW$2908 .dwtag DW_TAG_member
.dwattr $C$DW$2908, DW_AT_type(*$C$DW$T$638)
.dwattr $C$DW$2908, DW_AT_name("__sysp")
.dwattr $C$DW$2908, DW_AT_TI_symbol_name("__sysp")
.dwattr $C$DW$2908, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2908, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2908, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IModule.h")
.dwattr $C$DW$2908, DW_AT_decl_line(0x47)
.dwattr $C$DW$2908, DW_AT_decl_column(0x27)
$C$DW$2909 .dwtag DW_TAG_member
.dwattr $C$DW$2909, DW_AT_type(*$C$DW$T$636)
.dwattr $C$DW$2909, DW_AT_name("__sfxns")
.dwattr $C$DW$2909, DW_AT_TI_symbol_name("__sfxns")
.dwattr $C$DW$2909, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2909, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2909, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IModule.h")
.dwattr $C$DW$2909, DW_AT_decl_line(0x48)
.dwattr $C$DW$2909, DW_AT_decl_column(0x20)
$C$DW$188 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$188, DW_AT_declaration
.dwattr $C$DW$188, DW_AT_TI_symbol_name("_ZN26xdc_runtime_IModule_Fxns__aSERKS_")
.dwattr $C$DW$188, DW_AT_type(*$C$DW$T$723)
.dwattr $C$DW$188, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2910 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2910, DW_AT_type(*$C$DW$T$725)
.dwendtag $C$DW$188
.dwendtag $C$DW$T$727
.dwattr $C$DW$T$727, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/IModule.h")
.dwattr $C$DW$T$727, DW_AT_decl_line(0x45)
.dwattr $C$DW$T$727, DW_AT_decl_column(0x08)
$C$DW$T$723 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$723, DW_AT_type(*$C$DW$T$727)
.dwattr $C$DW$T$723, DW_AT_address_class(0x20)
$C$DW$T$726 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$726, DW_AT_type(*$C$DW$T$723)
.dwattr $C$DW$T$726, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2911 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2911, DW_AT_type(*$C$DW$T$725)
.dwendtag $C$DW$T$726
$C$DW$T$724 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$724, DW_AT_type(*$C$DW$T$727)
$C$DW$T$725 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$725, DW_AT_type(*$C$DW$T$724)
.dwattr $C$DW$T$725, DW_AT_address_class(0x20)
$C$DW$T$2012 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2012, DW_AT_type(*$C$DW$T$724)
.dwattr $C$DW$T$2012, DW_AT_address_class(0x20)
$C$DW$T$2013 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IModule_Module")
.dwattr $C$DW$T$2013, DW_AT_type(*$C$DW$T$2012)
.dwattr $C$DW$T$2013, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2013, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2013, DW_AT_decl_line(0x11)
.dwattr $C$DW$T$2013, DW_AT_decl_column(0x32)
$C$DW$T$2014 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_IModule_Fxns__")
.dwattr $C$DW$T$2014, DW_AT_type(*$C$DW$T$727)
.dwattr $C$DW$T$2014, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2014, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2014, DW_AT_decl_line(0x10)
.dwattr $C$DW$T$2014, DW_AT_decl_column(0x2b)
$C$DW$T$42 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$42, DW_AT_name("xdc_runtime_ISystemSupport_Fxns__")
.dwattr $C$DW$T$42, DW_AT_declaration
.dwendtag $C$DW$T$42
.dwattr $C$DW$T$42, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$42, DW_AT_decl_line(0xdc)
.dwattr $C$DW$T$42, DW_AT_decl_column(0x10)
$C$DW$T$2015 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_ISystemSupport_Fxns__")
.dwattr $C$DW$T$2015, DW_AT_type(*$C$DW$T$42)
.dwattr $C$DW$T$2015, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2015, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2015, DW_AT_decl_line(0xdc)
.dwattr $C$DW$T$2015, DW_AT_decl_column(0x32)
$C$DW$T$2016 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2016, DW_AT_type(*$C$DW$T$42)
$C$DW$T$2017 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2017, DW_AT_type(*$C$DW$T$2016)
.dwattr $C$DW$T$2017, DW_AT_address_class(0x20)
$C$DW$T$2018 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_ISystemSupport_Module")
.dwattr $C$DW$T$2018, DW_AT_type(*$C$DW$T$2017)
.dwattr $C$DW$T$2018, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2018, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2018, DW_AT_decl_line(0xdd)
.dwattr $C$DW$T$2018, DW_AT_decl_column(0x39)
$C$DW$T$43 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$43, DW_AT_name("xdc_runtime_ITimestampClient_Fxns__")
.dwattr $C$DW$T$43, DW_AT_declaration
.dwendtag $C$DW$T$43
.dwattr $C$DW$T$43, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$43, DW_AT_decl_line(0x102)
.dwattr $C$DW$T$43, DW_AT_decl_column(0x10)
$C$DW$T$2019 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_ITimestampClient_Fxns__")
.dwattr $C$DW$T$2019, DW_AT_type(*$C$DW$T$43)
.dwattr $C$DW$T$2019, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2019, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2019, DW_AT_decl_line(0x102)
.dwattr $C$DW$T$2019, DW_AT_decl_column(0x34)
$C$DW$T$2020 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2020, DW_AT_type(*$C$DW$T$43)
$C$DW$T$2021 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2021, DW_AT_type(*$C$DW$T$2020)
.dwattr $C$DW$T$2021, DW_AT_address_class(0x20)
$C$DW$T$2022 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_ITimestampClient_Module")
.dwattr $C$DW$T$2022, DW_AT_type(*$C$DW$T$2021)
.dwattr $C$DW$T$2022, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2022, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2022, DW_AT_decl_line(0x103)
.dwattr $C$DW$T$2022, DW_AT_decl_column(0x3b)
$C$DW$T$44 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$44, DW_AT_name("xdc_runtime_ITimestampProvider_Fxns__")
.dwattr $C$DW$T$44, DW_AT_declaration
.dwendtag $C$DW$T$44
.dwattr $C$DW$T$44, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$44, DW_AT_decl_line(0x110)
.dwattr $C$DW$T$44, DW_AT_decl_column(0x10)
$C$DW$T$2023 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_ITimestampProvider_Fxns__")
.dwattr $C$DW$T$2023, DW_AT_type(*$C$DW$T$44)
.dwattr $C$DW$T$2023, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2023, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2023, DW_AT_decl_line(0x110)
.dwattr $C$DW$T$2023, DW_AT_decl_column(0x36)
$C$DW$T$2024 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2024, DW_AT_type(*$C$DW$T$44)
$C$DW$T$2025 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2025, DW_AT_type(*$C$DW$T$2024)
.dwattr $C$DW$T$2025, DW_AT_address_class(0x20)
$C$DW$T$2026 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_ITimestampProvider_Module")
.dwattr $C$DW$T$2026, DW_AT_type(*$C$DW$T$2025)
.dwattr $C$DW$T$2026, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2026, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2026, DW_AT_decl_line(0x111)
.dwattr $C$DW$T$2026, DW_AT_decl_column(0x3d)
$C$DW$T$45 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$45, DW_AT_name("xdc_runtime_Log_EventRec")
.dwattr $C$DW$T$45, DW_AT_declaration
.dwendtag $C$DW$T$45
.dwattr $C$DW$T$45, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$45, DW_AT_decl_line(0x50)
.dwattr $C$DW$T$45, DW_AT_decl_column(0x10)
$C$DW$T$2027 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Log_EventRec")
.dwattr $C$DW$T$2027, DW_AT_type(*$C$DW$T$45)
.dwattr $C$DW$T$2027, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2027, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2027, DW_AT_decl_line(0x50)
.dwattr $C$DW$T$2027, DW_AT_decl_column(0x29)
$C$DW$T$46 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$46, DW_AT_name("xdc_runtime_LoggerBuf_Entry")
.dwattr $C$DW$T$46, DW_AT_declaration
.dwendtag $C$DW$T$46
.dwattr $C$DW$T$46, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$46, DW_AT_decl_line(0x68)
.dwattr $C$DW$T$46, DW_AT_decl_column(0x10)
$C$DW$T$2028 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Entry")
.dwattr $C$DW$T$2028, DW_AT_type(*$C$DW$T$46)
.dwattr $C$DW$T$2028, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2028, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2028, DW_AT_decl_line(0x68)
.dwattr $C$DW$T$2028, DW_AT_decl_column(0x2c)
$C$DW$T$47 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$47, DW_AT_name("xdc_runtime_LoggerBuf_Fxns__")
.dwattr $C$DW$T$47, DW_AT_declaration
.dwendtag $C$DW$T$47
.dwattr $C$DW$T$47, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$47, DW_AT_decl_line(0x6a)
.dwattr $C$DW$T$47, DW_AT_decl_column(0x10)
$C$DW$T$2029 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Fxns__")
.dwattr $C$DW$T$2029, DW_AT_type(*$C$DW$T$47)
.dwattr $C$DW$T$2029, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2029, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2029, DW_AT_decl_line(0x6a)
.dwattr $C$DW$T$2029, DW_AT_decl_column(0x2d)
$C$DW$T$2030 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2030, DW_AT_type(*$C$DW$T$47)
$C$DW$T$2031 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2031, DW_AT_type(*$C$DW$T$2030)
.dwattr $C$DW$T$2031, DW_AT_address_class(0x20)
$C$DW$T$2032 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Module")
.dwattr $C$DW$T$2032, DW_AT_type(*$C$DW$T$2031)
.dwattr $C$DW$T$2032, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2032, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2032, DW_AT_decl_line(0x6b)
.dwattr $C$DW$T$2032, DW_AT_decl_column(0x34)
$C$DW$T$48 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$48, DW_AT_name("xdc_runtime_LoggerBuf_Module_GateProxy_Fxns__")
.dwattr $C$DW$T$48, DW_AT_declaration
.dwendtag $C$DW$T$48
.dwattr $C$DW$T$48, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$48, DW_AT_decl_line(0x148)
.dwattr $C$DW$T$48, DW_AT_decl_column(0x10)
$C$DW$T$2033 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Module_GateProxy_Fxns__")
.dwattr $C$DW$T$2033, DW_AT_type(*$C$DW$T$48)
.dwattr $C$DW$T$2033, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2033, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2033, DW_AT_decl_line(0x148)
.dwattr $C$DW$T$2033, DW_AT_decl_column(0x3e)
$C$DW$T$2034 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2034, DW_AT_type(*$C$DW$T$48)
$C$DW$T$2035 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2035, DW_AT_type(*$C$DW$T$2034)
.dwattr $C$DW$T$2035, DW_AT_address_class(0x20)
$C$DW$T$2036 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Module_GateProxy_Module")
.dwattr $C$DW$T$2036, DW_AT_type(*$C$DW$T$2035)
.dwattr $C$DW$T$2036, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2036, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2036, DW_AT_decl_line(0x149)
.dwattr $C$DW$T$2036, DW_AT_decl_column(0x45)
$C$DW$T$49 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$49, DW_AT_name("xdc_runtime_LoggerBuf_Module_GateProxy_Params")
.dwattr $C$DW$T$49, DW_AT_declaration
.dwendtag $C$DW$T$49
.dwattr $C$DW$T$49, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$49, DW_AT_decl_line(0x14a)
.dwattr $C$DW$T$49, DW_AT_decl_column(0x10)
$C$DW$T$2037 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Module_GateProxy_Params")
.dwattr $C$DW$T$2037, DW_AT_type(*$C$DW$T$49)
.dwattr $C$DW$T$2037, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2037, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2037, DW_AT_decl_line(0x14a)
.dwattr $C$DW$T$2037, DW_AT_decl_column(0x3e)
$C$DW$T$50 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$50, DW_AT_name("xdc_runtime_LoggerBuf_Module_State")
.dwattr $C$DW$T$50, DW_AT_declaration
.dwendtag $C$DW$T$50
.dwattr $C$DW$T$50, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$50, DW_AT_decl_line(0x69)
.dwattr $C$DW$T$50, DW_AT_decl_column(0x10)
$C$DW$T$2038 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Module_State")
.dwattr $C$DW$T$2038, DW_AT_type(*$C$DW$T$50)
.dwattr $C$DW$T$2038, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2038, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2038, DW_AT_decl_line(0x69)
.dwattr $C$DW$T$2038, DW_AT_decl_column(0x33)
$C$DW$T$51 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$51, DW_AT_name("xdc_runtime_LoggerBuf_Object")
.dwattr $C$DW$T$51, DW_AT_declaration
.dwendtag $C$DW$T$51
.dwattr $C$DW$T$51, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$51, DW_AT_decl_line(0x6d)
.dwattr $C$DW$T$51, DW_AT_decl_column(0x10)
$C$DW$T$2039 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Object")
.dwattr $C$DW$T$2039, DW_AT_type(*$C$DW$T$51)
.dwattr $C$DW$T$2039, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2039, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2039, DW_AT_decl_line(0x6d)
.dwattr $C$DW$T$2039, DW_AT_decl_column(0x2d)
$C$DW$T$2040 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2040, DW_AT_type(*$C$DW$T$2039)
.dwattr $C$DW$T$2040, DW_AT_address_class(0x20)
$C$DW$T$2041 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Handle")
.dwattr $C$DW$T$2041, DW_AT_type(*$C$DW$T$2040)
.dwattr $C$DW$T$2041, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2041, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2041, DW_AT_decl_line(0x6f)
.dwattr $C$DW$T$2041, DW_AT_decl_column(0x27)
$C$DW$T$2042 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Instance")
.dwattr $C$DW$T$2042, DW_AT_type(*$C$DW$T$2040)
.dwattr $C$DW$T$2042, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2042, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2042, DW_AT_decl_line(0x71)
.dwattr $C$DW$T$2042, DW_AT_decl_column(0x27)
$C$DW$T$52 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$52, DW_AT_name("xdc_runtime_LoggerBuf_Object__")
.dwattr $C$DW$T$52, DW_AT_declaration
.dwendtag $C$DW$T$52
.dwattr $C$DW$T$52, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$52, DW_AT_decl_line(0x70)
.dwattr $C$DW$T$52, DW_AT_decl_column(0x10)
$C$DW$T$2043 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Instance_State")
.dwattr $C$DW$T$2043, DW_AT_type(*$C$DW$T$52)
.dwattr $C$DW$T$2043, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2043, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2043, DW_AT_decl_line(0x70)
.dwattr $C$DW$T$2043, DW_AT_decl_column(0x2f)
$C$DW$T$53 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$53, DW_AT_name("xdc_runtime_LoggerBuf_Params")
.dwattr $C$DW$T$53, DW_AT_declaration
.dwendtag $C$DW$T$53
.dwattr $C$DW$T$53, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$53, DW_AT_decl_line(0x6c)
.dwattr $C$DW$T$53, DW_AT_decl_column(0x10)
$C$DW$T$2044 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Params")
.dwattr $C$DW$T$2044, DW_AT_type(*$C$DW$T$53)
.dwattr $C$DW$T$2044, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2044, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2044, DW_AT_decl_line(0x6c)
.dwattr $C$DW$T$2044, DW_AT_decl_column(0x2d)
$C$DW$T$54 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$54, DW_AT_name("xdc_runtime_LoggerBuf_Struct")
.dwattr $C$DW$T$54, DW_AT_declaration
.dwendtag $C$DW$T$54
.dwattr $C$DW$T$54, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$54, DW_AT_decl_line(0x6e)
.dwattr $C$DW$T$54, DW_AT_decl_column(0x10)
$C$DW$T$2045 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_Struct")
.dwattr $C$DW$T$2045, DW_AT_type(*$C$DW$T$54)
.dwattr $C$DW$T$2045, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2045, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2045, DW_AT_decl_line(0x6e)
.dwattr $C$DW$T$2045, DW_AT_decl_column(0x2d)
$C$DW$T$55 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$55, DW_AT_name("xdc_runtime_LoggerBuf_TimestampProxy_Fxns__")
.dwattr $C$DW$T$55, DW_AT_declaration
.dwendtag $C$DW$T$55
.dwattr $C$DW$T$55, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$55, DW_AT_decl_line(0x141)
.dwattr $C$DW$T$55, DW_AT_decl_column(0x10)
$C$DW$T$2046 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_TimestampProxy_Fxns__")
.dwattr $C$DW$T$2046, DW_AT_type(*$C$DW$T$55)
.dwattr $C$DW$T$2046, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2046, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2046, DW_AT_decl_line(0x141)
.dwattr $C$DW$T$2046, DW_AT_decl_column(0x3c)
$C$DW$T$2047 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2047, DW_AT_type(*$C$DW$T$55)
$C$DW$T$2048 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2048, DW_AT_type(*$C$DW$T$2047)
.dwattr $C$DW$T$2048, DW_AT_address_class(0x20)
$C$DW$T$2049 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerBuf_TimestampProxy_Module")
.dwattr $C$DW$T$2049, DW_AT_type(*$C$DW$T$2048)
.dwattr $C$DW$T$2049, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2049, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2049, DW_AT_decl_line(0x142)
.dwattr $C$DW$T$2049, DW_AT_decl_column(0x43)
$C$DW$T$56 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$56, DW_AT_name("xdc_runtime_LoggerCallback_Fxns__")
.dwattr $C$DW$T$56, DW_AT_declaration
.dwendtag $C$DW$T$56
.dwattr $C$DW$T$56, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$56, DW_AT_decl_line(0x77)
.dwattr $C$DW$T$56, DW_AT_decl_column(0x10)
$C$DW$T$2050 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerCallback_Fxns__")
.dwattr $C$DW$T$2050, DW_AT_type(*$C$DW$T$56)
.dwattr $C$DW$T$2050, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2050, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2050, DW_AT_decl_line(0x77)
.dwattr $C$DW$T$2050, DW_AT_decl_column(0x32)
$C$DW$T$2051 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2051, DW_AT_type(*$C$DW$T$56)
$C$DW$T$2052 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2052, DW_AT_type(*$C$DW$T$2051)
.dwattr $C$DW$T$2052, DW_AT_address_class(0x20)
$C$DW$T$2053 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerCallback_Module")
.dwattr $C$DW$T$2053, DW_AT_type(*$C$DW$T$2052)
.dwattr $C$DW$T$2053, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2053, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2053, DW_AT_decl_line(0x78)
.dwattr $C$DW$T$2053, DW_AT_decl_column(0x39)
$C$DW$T$57 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$57, DW_AT_name("xdc_runtime_LoggerCallback_Object")
.dwattr $C$DW$T$57, DW_AT_declaration
.dwendtag $C$DW$T$57
.dwattr $C$DW$T$57, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$57, DW_AT_decl_line(0x7a)
.dwattr $C$DW$T$57, DW_AT_decl_column(0x10)
$C$DW$T$2054 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerCallback_Object")
.dwattr $C$DW$T$2054, DW_AT_type(*$C$DW$T$57)
.dwattr $C$DW$T$2054, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2054, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2054, DW_AT_decl_line(0x7a)
.dwattr $C$DW$T$2054, DW_AT_decl_column(0x32)
$C$DW$T$2055 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2055, DW_AT_type(*$C$DW$T$2054)
.dwattr $C$DW$T$2055, DW_AT_address_class(0x20)
$C$DW$T$2056 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerCallback_Handle")
.dwattr $C$DW$T$2056, DW_AT_type(*$C$DW$T$2055)
.dwattr $C$DW$T$2056, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2056, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2056, DW_AT_decl_line(0x7c)
.dwattr $C$DW$T$2056, DW_AT_decl_column(0x2c)
$C$DW$T$2057 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerCallback_Instance")
.dwattr $C$DW$T$2057, DW_AT_type(*$C$DW$T$2055)
.dwattr $C$DW$T$2057, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2057, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2057, DW_AT_decl_line(0x7e)
.dwattr $C$DW$T$2057, DW_AT_decl_column(0x2c)
$C$DW$T$58 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$58, DW_AT_name("xdc_runtime_LoggerCallback_Object__")
.dwattr $C$DW$T$58, DW_AT_declaration
.dwendtag $C$DW$T$58
.dwattr $C$DW$T$58, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$58, DW_AT_decl_line(0x7d)
.dwattr $C$DW$T$58, DW_AT_decl_column(0x10)
$C$DW$T$2058 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerCallback_Instance_State")
.dwattr $C$DW$T$2058, DW_AT_type(*$C$DW$T$58)
.dwattr $C$DW$T$2058, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2058, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2058, DW_AT_decl_line(0x7d)
.dwattr $C$DW$T$2058, DW_AT_decl_column(0x34)
$C$DW$T$59 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$59, DW_AT_name("xdc_runtime_LoggerCallback_Params")
.dwattr $C$DW$T$59, DW_AT_declaration
.dwendtag $C$DW$T$59
.dwattr $C$DW$T$59, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$59, DW_AT_decl_line(0x79)
.dwattr $C$DW$T$59, DW_AT_decl_column(0x10)
$C$DW$T$2059 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerCallback_Params")
.dwattr $C$DW$T$2059, DW_AT_type(*$C$DW$T$59)
.dwattr $C$DW$T$2059, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2059, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2059, DW_AT_decl_line(0x79)
.dwattr $C$DW$T$2059, DW_AT_decl_column(0x32)
$C$DW$T$60 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$60, DW_AT_name("xdc_runtime_LoggerCallback_Struct")
.dwattr $C$DW$T$60, DW_AT_declaration
.dwendtag $C$DW$T$60
.dwattr $C$DW$T$60, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$60, DW_AT_decl_line(0x7b)
.dwattr $C$DW$T$60, DW_AT_decl_column(0x10)
$C$DW$T$2060 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerCallback_Struct")
.dwattr $C$DW$T$2060, DW_AT_type(*$C$DW$T$60)
.dwattr $C$DW$T$2060, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2060, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2060, DW_AT_decl_line(0x7b)
.dwattr $C$DW$T$2060, DW_AT_decl_column(0x32)
$C$DW$T$61 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$61, DW_AT_name("xdc_runtime_LoggerSys_Fxns__")
.dwattr $C$DW$T$61, DW_AT_declaration
.dwendtag $C$DW$T$61
.dwattr $C$DW$T$61, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$61, DW_AT_decl_line(0x84)
.dwattr $C$DW$T$61, DW_AT_decl_column(0x10)
$C$DW$T$2061 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerSys_Fxns__")
.dwattr $C$DW$T$2061, DW_AT_type(*$C$DW$T$61)
.dwattr $C$DW$T$2061, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2061, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2061, DW_AT_decl_line(0x84)
.dwattr $C$DW$T$2061, DW_AT_decl_column(0x2d)
$C$DW$T$2062 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2062, DW_AT_type(*$C$DW$T$61)
$C$DW$T$2063 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2063, DW_AT_type(*$C$DW$T$2062)
.dwattr $C$DW$T$2063, DW_AT_address_class(0x20)
$C$DW$T$2064 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerSys_Module")
.dwattr $C$DW$T$2064, DW_AT_type(*$C$DW$T$2063)
.dwattr $C$DW$T$2064, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2064, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2064, DW_AT_decl_line(0x85)
.dwattr $C$DW$T$2064, DW_AT_decl_column(0x34)
$C$DW$T$62 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$62, DW_AT_name("xdc_runtime_LoggerSys_Object")
.dwattr $C$DW$T$62, DW_AT_declaration
.dwendtag $C$DW$T$62
.dwattr $C$DW$T$62, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$62, DW_AT_decl_line(0x87)
.dwattr $C$DW$T$62, DW_AT_decl_column(0x10)
$C$DW$T$2065 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerSys_Object")
.dwattr $C$DW$T$2065, DW_AT_type(*$C$DW$T$62)
.dwattr $C$DW$T$2065, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2065, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2065, DW_AT_decl_line(0x87)
.dwattr $C$DW$T$2065, DW_AT_decl_column(0x2d)
$C$DW$T$2066 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2066, DW_AT_type(*$C$DW$T$2065)
.dwattr $C$DW$T$2066, DW_AT_address_class(0x20)
$C$DW$T$2067 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerSys_Handle")
.dwattr $C$DW$T$2067, DW_AT_type(*$C$DW$T$2066)
.dwattr $C$DW$T$2067, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2067, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2067, DW_AT_decl_line(0x89)
.dwattr $C$DW$T$2067, DW_AT_decl_column(0x27)
$C$DW$T$2068 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerSys_Instance")
.dwattr $C$DW$T$2068, DW_AT_type(*$C$DW$T$2066)
.dwattr $C$DW$T$2068, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2068, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2068, DW_AT_decl_line(0x8b)
.dwattr $C$DW$T$2068, DW_AT_decl_column(0x27)
$C$DW$T$63 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$63, DW_AT_name("xdc_runtime_LoggerSys_Object__")
.dwattr $C$DW$T$63, DW_AT_declaration
.dwendtag $C$DW$T$63
.dwattr $C$DW$T$63, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$63, DW_AT_decl_line(0x8a)
.dwattr $C$DW$T$63, DW_AT_decl_column(0x10)
$C$DW$T$2069 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerSys_Instance_State")
.dwattr $C$DW$T$2069, DW_AT_type(*$C$DW$T$63)
.dwattr $C$DW$T$2069, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2069, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2069, DW_AT_decl_line(0x8a)
.dwattr $C$DW$T$2069, DW_AT_decl_column(0x2f)
$C$DW$T$64 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$64, DW_AT_name("xdc_runtime_LoggerSys_Params")
.dwattr $C$DW$T$64, DW_AT_declaration
.dwendtag $C$DW$T$64
.dwattr $C$DW$T$64, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$64, DW_AT_decl_line(0x86)
.dwattr $C$DW$T$64, DW_AT_decl_column(0x10)
$C$DW$T$2070 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerSys_Params")
.dwattr $C$DW$T$2070, DW_AT_type(*$C$DW$T$64)
.dwattr $C$DW$T$2070, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2070, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2070, DW_AT_decl_line(0x86)
.dwattr $C$DW$T$2070, DW_AT_decl_column(0x2d)
$C$DW$T$65 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$65, DW_AT_name("xdc_runtime_LoggerSys_Struct")
.dwattr $C$DW$T$65, DW_AT_declaration
.dwendtag $C$DW$T$65
.dwattr $C$DW$T$65, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$65, DW_AT_decl_line(0x88)
.dwattr $C$DW$T$65, DW_AT_decl_column(0x10)
$C$DW$T$2071 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerSys_Struct")
.dwattr $C$DW$T$2071, DW_AT_type(*$C$DW$T$65)
.dwattr $C$DW$T$2071, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2071, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2071, DW_AT_decl_line(0x88)
.dwattr $C$DW$T$2071, DW_AT_decl_column(0x2d)
$C$DW$T$66 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$66, DW_AT_name("xdc_runtime_LoggerSys_TimestampProxy_Fxns__")
.dwattr $C$DW$T$66, DW_AT_declaration
.dwendtag $C$DW$T$66
.dwattr $C$DW$T$66, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$66, DW_AT_decl_line(0x151)
.dwattr $C$DW$T$66, DW_AT_decl_column(0x10)
$C$DW$T$2072 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerSys_TimestampProxy_Fxns__")
.dwattr $C$DW$T$2072, DW_AT_type(*$C$DW$T$66)
.dwattr $C$DW$T$2072, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2072, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2072, DW_AT_decl_line(0x151)
.dwattr $C$DW$T$2072, DW_AT_decl_column(0x3c)
$C$DW$T$2073 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2073, DW_AT_type(*$C$DW$T$66)
$C$DW$T$2074 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2074, DW_AT_type(*$C$DW$T$2073)
.dwattr $C$DW$T$2074, DW_AT_address_class(0x20)
$C$DW$T$2075 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_LoggerSys_TimestampProxy_Module")
.dwattr $C$DW$T$2075, DW_AT_type(*$C$DW$T$2074)
.dwattr $C$DW$T$2075, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2075, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2075, DW_AT_decl_line(0x152)
.dwattr $C$DW$T$2075, DW_AT_decl_column(0x43)
$C$DW$T$738 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$738, DW_AT_name("xdc_runtime_Main_Module_GateProxy_Fxns__")
.dwattr $C$DW$T$738, DW_AT_byte_size(0x24)
$C$DW$2912 .dwtag DW_TAG_member
.dwattr $C$DW$2912, DW_AT_type(*$C$DW$T$635)
.dwattr $C$DW$2912, DW_AT_name("__base")
.dwattr $C$DW$2912, DW_AT_TI_symbol_name("__base")
.dwattr $C$DW$2912, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2912, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2912, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2912, DW_AT_decl_line(0xaf)
.dwattr $C$DW$2912, DW_AT_decl_column(0x1d)
$C$DW$2913 .dwtag DW_TAG_member
.dwattr $C$DW$2913, DW_AT_type(*$C$DW$T$638)
.dwattr $C$DW$2913, DW_AT_name("__sysp")
.dwattr $C$DW$2913, DW_AT_TI_symbol_name("__sysp")
.dwattr $C$DW$2913, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2913, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2913, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2913, DW_AT_decl_line(0xb0)
.dwattr $C$DW$2913, DW_AT_decl_column(0x27)
$C$DW$2914 .dwtag DW_TAG_member
.dwattr $C$DW$2914, DW_AT_type(*$C$DW$T$641)
.dwattr $C$DW$2914, DW_AT_name("query")
.dwattr $C$DW$2914, DW_AT_TI_symbol_name("query")
.dwattr $C$DW$2914, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2914, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2914, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2914, DW_AT_decl_line(0xb1)
.dwattr $C$DW$2914, DW_AT_decl_column(0x10)
$C$DW$2915 .dwtag DW_TAG_member
.dwattr $C$DW$2915, DW_AT_type(*$C$DW$T$731)
.dwattr $C$DW$2915, DW_AT_name("enter")
.dwattr $C$DW$2915, DW_AT_TI_symbol_name("enter")
.dwattr $C$DW$2915, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2915, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2915, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2915, DW_AT_decl_line(0xb2)
.dwattr $C$DW$2915, DW_AT_decl_column(0x10)
$C$DW$2916 .dwtag DW_TAG_member
.dwattr $C$DW$2916, DW_AT_type(*$C$DW$T$733)
.dwattr $C$DW$2916, DW_AT_name("leave")
.dwattr $C$DW$2916, DW_AT_TI_symbol_name("leave")
.dwattr $C$DW$2916, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2916, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2916, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2916, DW_AT_decl_line(0xb3)
.dwattr $C$DW$2916, DW_AT_decl_column(0x10)
$C$DW$2917 .dwtag DW_TAG_member
.dwattr $C$DW$2917, DW_AT_type(*$C$DW$T$636)
.dwattr $C$DW$2917, DW_AT_name("__sfxns")
.dwattr $C$DW$2917, DW_AT_TI_symbol_name("__sfxns")
.dwattr $C$DW$2917, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$2917, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2917, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2917, DW_AT_decl_line(0xb4)
.dwattr $C$DW$2917, DW_AT_decl_column(0x20)
$C$DW$189 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$189, DW_AT_declaration
.dwattr $C$DW$189, DW_AT_TI_symbol_name("_ZN40xdc_runtime_Main_Module_GateProxy_Fxns__aSERKS_")
.dwattr $C$DW$189, DW_AT_type(*$C$DW$T$734)
.dwattr $C$DW$189, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2918 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2918, DW_AT_type(*$C$DW$T$736)
.dwendtag $C$DW$189
.dwendtag $C$DW$T$738
.dwattr $C$DW$T$738, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$738, DW_AT_decl_line(0xae)
.dwattr $C$DW$T$738, DW_AT_decl_column(0x08)
$C$DW$T$734 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$734, DW_AT_type(*$C$DW$T$738)
.dwattr $C$DW$T$734, DW_AT_address_class(0x20)
$C$DW$T$737 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$737, DW_AT_type(*$C$DW$T$734)
.dwattr $C$DW$T$737, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2919 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2919, DW_AT_type(*$C$DW$T$736)
.dwendtag $C$DW$T$737
$C$DW$T$735 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$735, DW_AT_type(*$C$DW$T$738)
$C$DW$T$736 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$736, DW_AT_type(*$C$DW$T$735)
.dwattr $C$DW$T$736, DW_AT_address_class(0x20)
$C$DW$T$2076 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2076, DW_AT_type(*$C$DW$T$735)
.dwattr $C$DW$T$2076, DW_AT_address_class(0x20)
$C$DW$T$2077 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Main_Module_GateProxy_Module")
.dwattr $C$DW$T$2077, DW_AT_type(*$C$DW$T$2076)
.dwattr $C$DW$T$2077, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2077, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2077, DW_AT_decl_line(0x159)
.dwattr $C$DW$T$2077, DW_AT_decl_column(0x40)
$C$DW$T$744 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Main_Module_GateProxy_Fxns__")
.dwattr $C$DW$T$744, DW_AT_type(*$C$DW$T$738)
.dwattr $C$DW$T$744, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$744, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$744, DW_AT_decl_line(0x158)
.dwattr $C$DW$T$744, DW_AT_decl_column(0x39)
$C$DW$T$745 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$745, DW_AT_type(*$C$DW$T$744)
$C$DW$T$746 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$746, DW_AT_type(*$C$DW$T$745)
.dwattr $C$DW$T$746, DW_AT_address_class(0x20)
$C$DW$T$743 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$743, DW_AT_name("xdc_runtime_Main_Module_GateProxy_Params")
.dwattr $C$DW$T$743, DW_AT_byte_size(0x18)
$C$DW$2920 .dwtag DW_TAG_member
.dwattr $C$DW$2920, DW_AT_type(*$C$DW$T$651)
.dwattr $C$DW$2920, DW_AT_name("__size")
.dwattr $C$DW$2920, DW_AT_TI_symbol_name("__size")
.dwattr $C$DW$2920, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2920, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2920, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2920, DW_AT_decl_line(0x9b)
.dwattr $C$DW$2920, DW_AT_decl_column(0x0c)
$C$DW$2921 .dwtag DW_TAG_member
.dwattr $C$DW$2921, DW_AT_type(*$C$DW$T$653)
.dwattr $C$DW$2921, DW_AT_name("__self")
.dwattr $C$DW$2921, DW_AT_TI_symbol_name("__self")
.dwattr $C$DW$2921, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2921, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2921, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2921, DW_AT_decl_line(0x9c)
.dwattr $C$DW$2921, DW_AT_decl_column(0x11)
$C$DW$2922 .dwtag DW_TAG_member
.dwattr $C$DW$2922, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$2922, DW_AT_name("__fxns")
.dwattr $C$DW$2922, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2922, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2922, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2922, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2922, DW_AT_decl_line(0x9d)
.dwattr $C$DW$2922, DW_AT_decl_column(0x0b)
$C$DW$2923 .dwtag DW_TAG_member
.dwattr $C$DW$2923, DW_AT_type(*$C$DW$T$655)
.dwattr $C$DW$2923, DW_AT_name("instance")
.dwattr $C$DW$2923, DW_AT_TI_symbol_name("instance")
.dwattr $C$DW$2923, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2923, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2923, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2923, DW_AT_decl_line(0x9e)
.dwattr $C$DW$2923, DW_AT_decl_column(0x23)
$C$DW$2924 .dwtag DW_TAG_member
.dwattr $C$DW$2924, DW_AT_type(*$C$DW$T$654)
.dwattr $C$DW$2924, DW_AT_name("__iprms")
.dwattr $C$DW$2924, DW_AT_TI_symbol_name("__iprms")
.dwattr $C$DW$2924, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2924, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2924, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2924, DW_AT_decl_line(0x9f)
.dwattr $C$DW$2924, DW_AT_decl_column(0x22)
$C$DW$190 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$190, DW_AT_declaration
.dwattr $C$DW$190, DW_AT_TI_symbol_name("_ZN40xdc_runtime_Main_Module_GateProxy_ParamsaSERKS_")
.dwattr $C$DW$190, DW_AT_type(*$C$DW$T$739)
.dwattr $C$DW$190, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2925 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2925, DW_AT_type(*$C$DW$T$741)
.dwendtag $C$DW$190
.dwendtag $C$DW$T$743
.dwattr $C$DW$T$743, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$743, DW_AT_decl_line(0x9a)
.dwattr $C$DW$T$743, DW_AT_decl_column(0x08)
$C$DW$T$739 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$739, DW_AT_type(*$C$DW$T$743)
.dwattr $C$DW$T$739, DW_AT_address_class(0x20)
$C$DW$T$742 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$742, DW_AT_type(*$C$DW$T$739)
.dwattr $C$DW$T$742, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2926 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2926, DW_AT_type(*$C$DW$T$741)
.dwendtag $C$DW$T$742
$C$DW$T$740 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$740, DW_AT_type(*$C$DW$T$743)
$C$DW$T$741 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$741, DW_AT_type(*$C$DW$T$740)
.dwattr $C$DW$T$741, DW_AT_address_class(0x20)
$C$DW$T$2078 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Main_Module_GateProxy_Params")
.dwattr $C$DW$T$2078, DW_AT_type(*$C$DW$T$743)
.dwattr $C$DW$T$2078, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2078, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2078, DW_AT_decl_line(0x15a)
.dwattr $C$DW$T$2078, DW_AT_decl_column(0x39)
$C$DW$T$754 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$754, DW_AT_name("xdc_runtime_Main_Module_GateProxy_Struct")
.dwattr $C$DW$T$754, DW_AT_byte_size(0x08)
$C$DW$2927 .dwtag DW_TAG_member
.dwattr $C$DW$2927, DW_AT_type(*$C$DW$T$746)
.dwattr $C$DW$2927, DW_AT_name("__fxns")
.dwattr $C$DW$2927, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2927, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2927, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2927, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2927, DW_AT_decl_line(0xa4)
.dwattr $C$DW$2927, DW_AT_decl_column(0x35)
$C$DW$2928 .dwtag DW_TAG_member
.dwattr $C$DW$2928, DW_AT_type(*$C$DW$T$749)
.dwattr $C$DW$2928, DW_AT_name("__name")
.dwattr $C$DW$2928, DW_AT_TI_symbol_name("__name")
.dwattr $C$DW$2928, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2928, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2928, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$2928, DW_AT_decl_line(0xa5)
.dwattr $C$DW$2928, DW_AT_decl_column(0x20)
$C$DW$191 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$191, DW_AT_declaration
.dwattr $C$DW$191, DW_AT_TI_symbol_name("_ZN40xdc_runtime_Main_Module_GateProxy_StructaSERKS_")
.dwattr $C$DW$191, DW_AT_type(*$C$DW$T$750)
.dwattr $C$DW$191, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2929 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2929, DW_AT_type(*$C$DW$T$752)
.dwendtag $C$DW$191
.dwendtag $C$DW$T$754
.dwattr $C$DW$T$754, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Main_Module_GateProxy.h")
.dwattr $C$DW$T$754, DW_AT_decl_line(0xa3)
.dwattr $C$DW$T$754, DW_AT_decl_column(0x08)
$C$DW$T$750 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$750, DW_AT_type(*$C$DW$T$754)
.dwattr $C$DW$T$750, DW_AT_address_class(0x20)
$C$DW$T$753 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$753, DW_AT_type(*$C$DW$T$750)
.dwattr $C$DW$T$753, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2930 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2930, DW_AT_type(*$C$DW$T$752)
.dwendtag $C$DW$T$753
$C$DW$T$751 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$751, DW_AT_type(*$C$DW$T$754)
$C$DW$T$752 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$752, DW_AT_type(*$C$DW$T$751)
.dwattr $C$DW$T$752, DW_AT_address_class(0x20)
$C$DW$T$769 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$769, DW_AT_name("xdc_runtime_Memory_HeapProxy_Fxns__")
.dwattr $C$DW$T$769, DW_AT_byte_size(0x28)
$C$DW$2931 .dwtag DW_TAG_member
.dwattr $C$DW$2931, DW_AT_type(*$C$DW$T$635)
.dwattr $C$DW$2931, DW_AT_name("__base")
.dwattr $C$DW$2931, DW_AT_TI_symbol_name("__base")
.dwattr $C$DW$2931, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2931, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2931, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2931, DW_AT_decl_line(0xa9)
.dwattr $C$DW$2931, DW_AT_decl_column(0x1d)
$C$DW$2932 .dwtag DW_TAG_member
.dwattr $C$DW$2932, DW_AT_type(*$C$DW$T$638)
.dwattr $C$DW$2932, DW_AT_name("__sysp")
.dwattr $C$DW$2932, DW_AT_TI_symbol_name("__sysp")
.dwattr $C$DW$2932, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2932, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2932, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2932, DW_AT_decl_line(0xaa)
.dwattr $C$DW$2932, DW_AT_decl_column(0x27)
$C$DW$2933 .dwtag DW_TAG_member
.dwattr $C$DW$2933, DW_AT_type(*$C$DW$T$758)
.dwattr $C$DW$2933, DW_AT_name("alloc")
.dwattr $C$DW$2933, DW_AT_TI_symbol_name("alloc")
.dwattr $C$DW$2933, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2933, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2933, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2933, DW_AT_decl_line(0xab)
.dwattr $C$DW$2933, DW_AT_decl_column(0x0f)
$C$DW$2934 .dwtag DW_TAG_member
.dwattr $C$DW$2934, DW_AT_type(*$C$DW$T$760)
.dwattr $C$DW$2934, DW_AT_name("free")
.dwattr $C$DW$2934, DW_AT_TI_symbol_name("free")
.dwattr $C$DW$2934, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2934, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2934, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2934, DW_AT_decl_line(0xac)
.dwattr $C$DW$2934, DW_AT_decl_column(0x10)
$C$DW$2935 .dwtag DW_TAG_member
.dwattr $C$DW$2935, DW_AT_type(*$C$DW$T$762)
.dwattr $C$DW$2935, DW_AT_name("isBlocking")
.dwattr $C$DW$2935, DW_AT_TI_symbol_name("isBlocking")
.dwattr $C$DW$2935, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2935, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2935, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2935, DW_AT_decl_line(0xad)
.dwattr $C$DW$2935, DW_AT_decl_column(0x10)
$C$DW$2936 .dwtag DW_TAG_member
.dwattr $C$DW$2936, DW_AT_type(*$C$DW$T$764)
.dwattr $C$DW$2936, DW_AT_name("getStats")
.dwattr $C$DW$2936, DW_AT_TI_symbol_name("getStats")
.dwattr $C$DW$2936, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$2936, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2936, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2936, DW_AT_decl_line(0xae)
.dwattr $C$DW$2936, DW_AT_decl_column(0x10)
$C$DW$2937 .dwtag DW_TAG_member
.dwattr $C$DW$2937, DW_AT_type(*$C$DW$T$636)
.dwattr $C$DW$2937, DW_AT_name("__sfxns")
.dwattr $C$DW$2937, DW_AT_TI_symbol_name("__sfxns")
.dwattr $C$DW$2937, DW_AT_data_member_location[DW_OP_plus_uconst 0x18]
.dwattr $C$DW$2937, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2937, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2937, DW_AT_decl_line(0xaf)
.dwattr $C$DW$2937, DW_AT_decl_column(0x20)
$C$DW$192 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$192, DW_AT_declaration
.dwattr $C$DW$192, DW_AT_TI_symbol_name("_ZN35xdc_runtime_Memory_HeapProxy_Fxns__aSERKS_")
.dwattr $C$DW$192, DW_AT_type(*$C$DW$T$765)
.dwattr $C$DW$192, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2938 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2938, DW_AT_type(*$C$DW$T$767)
.dwendtag $C$DW$192
.dwendtag $C$DW$T$769
.dwattr $C$DW$T$769, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$769, DW_AT_decl_line(0xa8)
.dwattr $C$DW$T$769, DW_AT_decl_column(0x08)
$C$DW$T$765 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$765, DW_AT_type(*$C$DW$T$769)
.dwattr $C$DW$T$765, DW_AT_address_class(0x20)
$C$DW$T$768 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$768, DW_AT_type(*$C$DW$T$765)
.dwattr $C$DW$T$768, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2939 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2939, DW_AT_type(*$C$DW$T$767)
.dwendtag $C$DW$T$768
$C$DW$T$766 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$766, DW_AT_type(*$C$DW$T$769)
$C$DW$T$767 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$767, DW_AT_type(*$C$DW$T$766)
.dwattr $C$DW$T$767, DW_AT_address_class(0x20)
$C$DW$T$2079 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2079, DW_AT_type(*$C$DW$T$766)
.dwattr $C$DW$T$2079, DW_AT_address_class(0x20)
$C$DW$T$2080 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Memory_HeapProxy_Module")
.dwattr $C$DW$T$2080, DW_AT_type(*$C$DW$T$2079)
.dwattr $C$DW$T$2080, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2080, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2080, DW_AT_decl_line(0x162)
.dwattr $C$DW$T$2080, DW_AT_decl_column(0x3b)
$C$DW$T$775 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Memory_HeapProxy_Fxns__")
.dwattr $C$DW$T$775, DW_AT_type(*$C$DW$T$769)
.dwattr $C$DW$T$775, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$775, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$775, DW_AT_decl_line(0x161)
.dwattr $C$DW$T$775, DW_AT_decl_column(0x34)
$C$DW$T$776 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$776, DW_AT_type(*$C$DW$T$775)
$C$DW$T$777 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$777, DW_AT_type(*$C$DW$T$776)
.dwattr $C$DW$T$777, DW_AT_address_class(0x20)
$C$DW$T$774 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$774, DW_AT_name("xdc_runtime_Memory_HeapProxy_Params")
.dwattr $C$DW$T$774, DW_AT_byte_size(0x18)
$C$DW$2940 .dwtag DW_TAG_member
.dwattr $C$DW$2940, DW_AT_type(*$C$DW$T$651)
.dwattr $C$DW$2940, DW_AT_name("__size")
.dwattr $C$DW$2940, DW_AT_TI_symbol_name("__size")
.dwattr $C$DW$2940, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2940, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2940, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2940, DW_AT_decl_line(0x95)
.dwattr $C$DW$2940, DW_AT_decl_column(0x0c)
$C$DW$2941 .dwtag DW_TAG_member
.dwattr $C$DW$2941, DW_AT_type(*$C$DW$T$653)
.dwattr $C$DW$2941, DW_AT_name("__self")
.dwattr $C$DW$2941, DW_AT_TI_symbol_name("__self")
.dwattr $C$DW$2941, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2941, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2941, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2941, DW_AT_decl_line(0x96)
.dwattr $C$DW$2941, DW_AT_decl_column(0x11)
$C$DW$2942 .dwtag DW_TAG_member
.dwattr $C$DW$2942, DW_AT_type(*$C$DW$T$3)
.dwattr $C$DW$2942, DW_AT_name("__fxns")
.dwattr $C$DW$2942, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2942, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2942, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2942, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2942, DW_AT_decl_line(0x97)
.dwattr $C$DW$2942, DW_AT_decl_column(0x0b)
$C$DW$2943 .dwtag DW_TAG_member
.dwattr $C$DW$2943, DW_AT_type(*$C$DW$T$655)
.dwattr $C$DW$2943, DW_AT_name("instance")
.dwattr $C$DW$2943, DW_AT_TI_symbol_name("instance")
.dwattr $C$DW$2943, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2943, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2943, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2943, DW_AT_decl_line(0x98)
.dwattr $C$DW$2943, DW_AT_decl_column(0x23)
$C$DW$2944 .dwtag DW_TAG_member
.dwattr $C$DW$2944, DW_AT_type(*$C$DW$T$654)
.dwattr $C$DW$2944, DW_AT_name("__iprms")
.dwattr $C$DW$2944, DW_AT_TI_symbol_name("__iprms")
.dwattr $C$DW$2944, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$2944, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2944, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2944, DW_AT_decl_line(0x99)
.dwattr $C$DW$2944, DW_AT_decl_column(0x22)
$C$DW$193 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$193, DW_AT_declaration
.dwattr $C$DW$193, DW_AT_TI_symbol_name("_ZN35xdc_runtime_Memory_HeapProxy_ParamsaSERKS_")
.dwattr $C$DW$193, DW_AT_type(*$C$DW$T$770)
.dwattr $C$DW$193, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2945 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2945, DW_AT_type(*$C$DW$T$772)
.dwendtag $C$DW$193
.dwendtag $C$DW$T$774
.dwattr $C$DW$T$774, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$774, DW_AT_decl_line(0x94)
.dwattr $C$DW$T$774, DW_AT_decl_column(0x08)
$C$DW$T$770 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$770, DW_AT_type(*$C$DW$T$774)
.dwattr $C$DW$T$770, DW_AT_address_class(0x20)
$C$DW$T$773 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$773, DW_AT_type(*$C$DW$T$770)
.dwattr $C$DW$T$773, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2946 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2946, DW_AT_type(*$C$DW$T$772)
.dwendtag $C$DW$T$773
$C$DW$T$771 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$771, DW_AT_type(*$C$DW$T$774)
$C$DW$T$772 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$772, DW_AT_type(*$C$DW$T$771)
.dwattr $C$DW$T$772, DW_AT_address_class(0x20)
$C$DW$T$2081 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Memory_HeapProxy_Params")
.dwattr $C$DW$T$2081, DW_AT_type(*$C$DW$T$774)
.dwattr $C$DW$T$2081, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2081, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2081, DW_AT_decl_line(0x163)
.dwattr $C$DW$T$2081, DW_AT_decl_column(0x34)
$C$DW$T$782 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$782, DW_AT_name("xdc_runtime_Memory_HeapProxy_Struct")
.dwattr $C$DW$T$782, DW_AT_byte_size(0x08)
$C$DW$2947 .dwtag DW_TAG_member
.dwattr $C$DW$2947, DW_AT_type(*$C$DW$T$777)
.dwattr $C$DW$2947, DW_AT_name("__fxns")
.dwattr $C$DW$2947, DW_AT_TI_symbol_name("__fxns")
.dwattr $C$DW$2947, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2947, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2947, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2947, DW_AT_decl_line(0x9e)
.dwattr $C$DW$2947, DW_AT_decl_column(0x30)
$C$DW$2948 .dwtag DW_TAG_member
.dwattr $C$DW$2948, DW_AT_type(*$C$DW$T$749)
.dwattr $C$DW$2948, DW_AT_name("__name")
.dwattr $C$DW$2948, DW_AT_TI_symbol_name("__name")
.dwattr $C$DW$2948, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2948, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2948, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$2948, DW_AT_decl_line(0x9f)
.dwattr $C$DW$2948, DW_AT_decl_column(0x20)
$C$DW$194 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$194, DW_AT_declaration
.dwattr $C$DW$194, DW_AT_TI_symbol_name("_ZN35xdc_runtime_Memory_HeapProxy_StructaSERKS_")
.dwattr $C$DW$194, DW_AT_type(*$C$DW$T$778)
.dwattr $C$DW$194, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2949 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2949, DW_AT_type(*$C$DW$T$780)
.dwendtag $C$DW$194
.dwendtag $C$DW$T$782
.dwattr $C$DW$T$782, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/Memory_HeapProxy.h")
.dwattr $C$DW$T$782, DW_AT_decl_line(0x9d)
.dwattr $C$DW$T$782, DW_AT_decl_column(0x08)
$C$DW$T$778 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$778, DW_AT_type(*$C$DW$T$782)
.dwattr $C$DW$T$778, DW_AT_address_class(0x20)
$C$DW$T$781 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$781, DW_AT_type(*$C$DW$T$778)
.dwattr $C$DW$T$781, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2950 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2950, DW_AT_type(*$C$DW$T$780)
.dwendtag $C$DW$T$781
$C$DW$T$779 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$779, DW_AT_type(*$C$DW$T$782)
$C$DW$T$780 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$780, DW_AT_type(*$C$DW$T$779)
.dwattr $C$DW$T$780, DW_AT_address_class(0x20)
$C$DW$T$67 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$67, DW_AT_name("xdc_runtime_Memory_Module_State")
.dwattr $C$DW$T$67, DW_AT_declaration
.dwendtag $C$DW$T$67
.dwattr $C$DW$T$67, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$67, DW_AT_decl_line(0x97)
.dwattr $C$DW$T$67, DW_AT_decl_column(0x10)
$C$DW$T$2082 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Memory_Module_State")
.dwattr $C$DW$T$2082, DW_AT_type(*$C$DW$T$67)
.dwattr $C$DW$T$2082, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2082, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2082, DW_AT_decl_line(0x97)
.dwattr $C$DW$T$2082, DW_AT_decl_column(0x30)
$C$DW$T$790 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$790, DW_AT_name("xdc_runtime_Memory_Stats")
.dwattr $C$DW$T$790, DW_AT_byte_size(0x0c)
$C$DW$2951 .dwtag DW_TAG_member
.dwattr $C$DW$2951, DW_AT_type(*$C$DW$T$785)
.dwattr $C$DW$2951, DW_AT_name("totalSize")
.dwattr $C$DW$2951, DW_AT_TI_symbol_name("totalSize")
.dwattr $C$DW$2951, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2951, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2951, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$2951, DW_AT_decl_line(0x4b)
.dwattr $C$DW$2951, DW_AT_decl_column(0x1d)
$C$DW$2952 .dwtag DW_TAG_member
.dwattr $C$DW$2952, DW_AT_type(*$C$DW$T$785)
.dwattr $C$DW$2952, DW_AT_name("totalFreeSize")
.dwattr $C$DW$2952, DW_AT_TI_symbol_name("totalFreeSize")
.dwattr $C$DW$2952, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2952, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2952, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$2952, DW_AT_decl_line(0x4c)
.dwattr $C$DW$2952, DW_AT_decl_column(0x1d)
$C$DW$2953 .dwtag DW_TAG_member
.dwattr $C$DW$2953, DW_AT_type(*$C$DW$T$785)
.dwattr $C$DW$2953, DW_AT_name("largestFreeSize")
.dwattr $C$DW$2953, DW_AT_TI_symbol_name("largestFreeSize")
.dwattr $C$DW$2953, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2953, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2953, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$2953, DW_AT_decl_line(0x4d)
.dwattr $C$DW$2953, DW_AT_decl_column(0x1d)
$C$DW$195 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$195, DW_AT_declaration
.dwattr $C$DW$195, DW_AT_TI_symbol_name("_ZN24xdc_runtime_Memory_StatsaSERKS_")
.dwattr $C$DW$195, DW_AT_type(*$C$DW$T$786)
.dwattr $C$DW$195, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2954 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2954, DW_AT_type(*$C$DW$T$788)
.dwendtag $C$DW$195
.dwendtag $C$DW$T$790
.dwattr $C$DW$T$790, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Memory.h")
.dwattr $C$DW$T$790, DW_AT_decl_line(0x4a)
.dwattr $C$DW$T$790, DW_AT_decl_column(0x08)
$C$DW$T$786 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$786, DW_AT_type(*$C$DW$T$790)
.dwattr $C$DW$T$786, DW_AT_address_class(0x20)
$C$DW$T$789 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$789, DW_AT_type(*$C$DW$T$786)
.dwattr $C$DW$T$789, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2955 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2955, DW_AT_type(*$C$DW$T$788)
.dwendtag $C$DW$T$789
$C$DW$T$678 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Memory_Stats")
.dwattr $C$DW$T$678, DW_AT_type(*$C$DW$T$790)
.dwattr $C$DW$T$678, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$678, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$678, DW_AT_decl_line(0x96)
.dwattr $C$DW$T$678, DW_AT_decl_column(0x29)
$C$DW$T$679 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$679, DW_AT_type(*$C$DW$T$678)
.dwattr $C$DW$T$679, DW_AT_address_class(0x20)
$C$DW$T$787 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$787, DW_AT_type(*$C$DW$T$790)
$C$DW$T$788 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$788, DW_AT_type(*$C$DW$T$787)
.dwattr $C$DW$T$788, DW_AT_address_class(0x20)
$C$DW$T$68 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$68, DW_AT_name("xdc_runtime_Registry_Module_State")
.dwattr $C$DW$T$68, DW_AT_declaration
.dwendtag $C$DW$T$68
.dwattr $C$DW$T$68, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$68, DW_AT_decl_line(0xc1)
.dwattr $C$DW$T$68, DW_AT_decl_column(0x10)
$C$DW$T$2083 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Registry_Module_State")
.dwattr $C$DW$T$2083, DW_AT_type(*$C$DW$T$68)
.dwattr $C$DW$T$2083, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2083, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2083, DW_AT_decl_line(0xc1)
.dwattr $C$DW$T$2083, DW_AT_decl_column(0x32)
$C$DW$T$69 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$69, DW_AT_name("xdc_runtime_Rta_CommandPacket")
.dwattr $C$DW$T$69, DW_AT_declaration
.dwendtag $C$DW$T$69
.dwattr $C$DW$T$69, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$69, DW_AT_decl_line(0xc7)
.dwattr $C$DW$T$69, DW_AT_decl_column(0x10)
$C$DW$T$2084 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Rta_CommandPacket")
.dwattr $C$DW$T$2084, DW_AT_type(*$C$DW$T$69)
.dwattr $C$DW$T$2084, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2084, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2084, DW_AT_decl_line(0xc7)
.dwattr $C$DW$T$2084, DW_AT_decl_column(0x2e)
$C$DW$T$70 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$70, DW_AT_name("xdc_runtime_Rta_ResponsePacket")
.dwattr $C$DW$T$70, DW_AT_declaration
.dwendtag $C$DW$T$70
.dwattr $C$DW$T$70, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$70, DW_AT_decl_line(0xc8)
.dwattr $C$DW$T$70, DW_AT_decl_column(0x10)
$C$DW$T$2085 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Rta_ResponsePacket")
.dwattr $C$DW$T$2085, DW_AT_type(*$C$DW$T$70)
.dwattr $C$DW$T$2085, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2085, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2085, DW_AT_decl_line(0xc8)
.dwattr $C$DW$T$2085, DW_AT_decl_column(0x2f)
$C$DW$T$71 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$71, DW_AT_name("xdc_runtime_Startup_IdMap")
.dwattr $C$DW$T$71, DW_AT_declaration
.dwendtag $C$DW$T$71
.dwattr $C$DW$T$71, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$71, DW_AT_decl_line(0xce)
.dwattr $C$DW$T$71, DW_AT_decl_column(0x10)
$C$DW$T$2086 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Startup_IdMap")
.dwattr $C$DW$T$2086, DW_AT_type(*$C$DW$T$71)
.dwattr $C$DW$T$2086, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2086, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2086, DW_AT_decl_line(0xce)
.dwattr $C$DW$T$2086, DW_AT_decl_column(0x2a)
$C$DW$T$72 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$72, DW_AT_name("xdc_runtime_Startup_Module_State")
.dwattr $C$DW$T$72, DW_AT_declaration
.dwendtag $C$DW$T$72
.dwattr $C$DW$T$72, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$72, DW_AT_decl_line(0xcf)
.dwattr $C$DW$T$72, DW_AT_decl_column(0x10)
$C$DW$T$2087 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Startup_Module_State")
.dwattr $C$DW$T$2087, DW_AT_type(*$C$DW$T$72)
.dwattr $C$DW$T$2087, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2087, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2087, DW_AT_decl_line(0xcf)
.dwattr $C$DW$T$2087, DW_AT_decl_column(0x31)
$C$DW$T$73 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$73, DW_AT_name("xdc_runtime_SysCallback_Fxns__")
.dwattr $C$DW$T$73, DW_AT_declaration
.dwattr $C$DW$T$73, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$73, DW_AT_decl_line(0xe3)
.dwattr $C$DW$T$73, DW_AT_decl_column(0x10)
$C$DW$T$2088 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_SysCallback_Fxns__")
.dwattr $C$DW$T$2088, DW_AT_type(*$C$DW$T$73)
.dwattr $C$DW$T$2088, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2088, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2088, DW_AT_decl_line(0xe3)
.dwattr $C$DW$T$2088, DW_AT_decl_column(0x2f)
$C$DW$T$2089 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2089, DW_AT_type(*$C$DW$T$73)
$C$DW$T$2090 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2090, DW_AT_type(*$C$DW$T$2089)
.dwattr $C$DW$T$2090, DW_AT_address_class(0x20)
$C$DW$T$2091 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_SysCallback_Module")
.dwattr $C$DW$T$2091, DW_AT_type(*$C$DW$T$2090)
.dwattr $C$DW$T$2091, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2091, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2091, DW_AT_decl_line(0xe4)
.dwattr $C$DW$T$2091, DW_AT_decl_column(0x36)
$C$DW$T$74 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$74, DW_AT_name("xdc_runtime_SysMin_Fxns__")
.dwattr $C$DW$T$74, DW_AT_declaration
.dwattr $C$DW$T$74, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$74, DW_AT_decl_line(0xeb)
.dwattr $C$DW$T$74, DW_AT_decl_column(0x10)
$C$DW$T$2092 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_SysMin_Fxns__")
.dwattr $C$DW$T$2092, DW_AT_type(*$C$DW$T$74)
.dwattr $C$DW$T$2092, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2092, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2092, DW_AT_decl_line(0xeb)
.dwattr $C$DW$T$2092, DW_AT_decl_column(0x2a)
$C$DW$T$2093 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2093, DW_AT_type(*$C$DW$T$74)
$C$DW$T$2094 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2094, DW_AT_type(*$C$DW$T$2093)
.dwattr $C$DW$T$2094, DW_AT_address_class(0x20)
$C$DW$T$2095 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_SysMin_Module")
.dwattr $C$DW$T$2095, DW_AT_type(*$C$DW$T$2094)
.dwattr $C$DW$T$2095, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2095, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2095, DW_AT_decl_line(0xec)
.dwattr $C$DW$T$2095, DW_AT_decl_column(0x31)
$C$DW$T$75 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$75, DW_AT_name("xdc_runtime_SysMin_Module_State")
.dwattr $C$DW$T$75, DW_AT_declaration
.dwattr $C$DW$T$75, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$75, DW_AT_decl_line(0xea)
.dwattr $C$DW$T$75, DW_AT_decl_column(0x10)
$C$DW$T$2096 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_SysMin_Module_State")
.dwattr $C$DW$T$2096, DW_AT_type(*$C$DW$T$75)
.dwattr $C$DW$T$2096, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2096, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2096, DW_AT_decl_line(0xea)
.dwattr $C$DW$T$2096, DW_AT_decl_column(0x30)
$C$DW$T$76 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$76, DW_AT_name("xdc_runtime_SysStd_Fxns__")
.dwattr $C$DW$T$76, DW_AT_declaration
.dwattr $C$DW$T$76, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$76, DW_AT_decl_line(0xf2)
.dwattr $C$DW$T$76, DW_AT_decl_column(0x10)
$C$DW$T$2097 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_SysStd_Fxns__")
.dwattr $C$DW$T$2097, DW_AT_type(*$C$DW$T$76)
.dwattr $C$DW$T$2097, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2097, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2097, DW_AT_decl_line(0xf2)
.dwattr $C$DW$T$2097, DW_AT_decl_column(0x2a)
$C$DW$T$2098 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2098, DW_AT_type(*$C$DW$T$76)
$C$DW$T$2099 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2099, DW_AT_type(*$C$DW$T$2098)
.dwattr $C$DW$T$2099, DW_AT_address_class(0x20)
$C$DW$T$2100 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_SysStd_Module")
.dwattr $C$DW$T$2100, DW_AT_type(*$C$DW$T$2099)
.dwattr $C$DW$T$2100, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2100, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2100, DW_AT_decl_line(0xf3)
.dwattr $C$DW$T$2100, DW_AT_decl_column(0x31)
$C$DW$T$77 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$77, DW_AT_name("xdc_runtime_System_Module_GateProxy_Fxns__")
.dwattr $C$DW$T$77, DW_AT_declaration
.dwattr $C$DW$T$77, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$77, DW_AT_decl_line(0x171)
.dwattr $C$DW$T$77, DW_AT_decl_column(0x10)
$C$DW$T$2101 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_System_Module_GateProxy_Fxns__")
.dwattr $C$DW$T$2101, DW_AT_type(*$C$DW$T$77)
.dwattr $C$DW$T$2101, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2101, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2101, DW_AT_decl_line(0x171)
.dwattr $C$DW$T$2101, DW_AT_decl_column(0x3b)
$C$DW$T$2102 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2102, DW_AT_type(*$C$DW$T$77)
$C$DW$T$2103 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2103, DW_AT_type(*$C$DW$T$2102)
.dwattr $C$DW$T$2103, DW_AT_address_class(0x20)
$C$DW$T$2104 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_System_Module_GateProxy_Module")
.dwattr $C$DW$T$2104, DW_AT_type(*$C$DW$T$2103)
.dwattr $C$DW$T$2104, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2104, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2104, DW_AT_decl_line(0x172)
.dwattr $C$DW$T$2104, DW_AT_decl_column(0x42)
$C$DW$T$78 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$78, DW_AT_name("xdc_runtime_System_Module_GateProxy_Params")
.dwattr $C$DW$T$78, DW_AT_declaration
.dwattr $C$DW$T$78, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$78, DW_AT_decl_line(0x173)
.dwattr $C$DW$T$78, DW_AT_decl_column(0x10)
$C$DW$T$2105 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_System_Module_GateProxy_Params")
.dwattr $C$DW$T$2105, DW_AT_type(*$C$DW$T$78)
.dwattr $C$DW$T$2105, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2105, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2105, DW_AT_decl_line(0x173)
.dwattr $C$DW$T$2105, DW_AT_decl_column(0x3b)
$C$DW$T$79 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$79, DW_AT_name("xdc_runtime_System_Module_State")
.dwattr $C$DW$T$79, DW_AT_declaration
.dwattr $C$DW$T$79, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$79, DW_AT_decl_line(0xd6)
.dwattr $C$DW$T$79, DW_AT_decl_column(0x10)
$C$DW$T$2106 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_System_Module_State")
.dwattr $C$DW$T$2106, DW_AT_type(*$C$DW$T$79)
.dwattr $C$DW$T$2106, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2106, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2106, DW_AT_decl_line(0xd6)
.dwattr $C$DW$T$2106, DW_AT_decl_column(0x30)
$C$DW$T$80 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$80, DW_AT_name("xdc_runtime_System_ParseData")
.dwattr $C$DW$T$80, DW_AT_declaration
.dwendtag $C$DW$T$80
.dwattr $C$DW$T$80, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$80, DW_AT_decl_line(0xd5)
.dwattr $C$DW$T$80, DW_AT_decl_column(0x10)
$C$DW$T$2107 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_System_ParseData")
.dwattr $C$DW$T$2107, DW_AT_type(*$C$DW$T$80)
.dwattr $C$DW$T$2107, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2107, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2107, DW_AT_decl_line(0xd5)
.dwattr $C$DW$T$2107, DW_AT_decl_column(0x2d)
$C$DW$T$81 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$81, DW_AT_name("xdc_runtime_System_SupportProxy_Fxns__")
.dwattr $C$DW$T$81, DW_AT_declaration
.dwendtag $C$DW$T$81
.dwattr $C$DW$T$81, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$81, DW_AT_decl_line(0x16a)
.dwattr $C$DW$T$81, DW_AT_decl_column(0x10)
$C$DW$T$2108 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_System_SupportProxy_Fxns__")
.dwattr $C$DW$T$2108, DW_AT_type(*$C$DW$T$81)
.dwattr $C$DW$T$2108, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2108, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2108, DW_AT_decl_line(0x16a)
.dwattr $C$DW$T$2108, DW_AT_decl_column(0x37)
$C$DW$T$2109 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2109, DW_AT_type(*$C$DW$T$81)
$C$DW$T$2110 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2110, DW_AT_type(*$C$DW$T$2109)
.dwattr $C$DW$T$2110, DW_AT_address_class(0x20)
$C$DW$T$2111 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_System_SupportProxy_Module")
.dwattr $C$DW$T$2111, DW_AT_type(*$C$DW$T$2110)
.dwattr $C$DW$T$2111, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2111, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2111, DW_AT_decl_line(0x16b)
.dwattr $C$DW$T$2111, DW_AT_decl_column(0x3e)
$C$DW$T$82 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$82, DW_AT_name("xdc_runtime_Text_MatchVisState")
.dwattr $C$DW$T$82, DW_AT_declaration
.dwendtag $C$DW$T$82
.dwattr $C$DW$T$82, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$82, DW_AT_decl_line(0xfa)
.dwattr $C$DW$T$82, DW_AT_decl_column(0x10)
$C$DW$T$2112 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Text_MatchVisState")
.dwattr $C$DW$T$2112, DW_AT_type(*$C$DW$T$82)
.dwattr $C$DW$T$2112, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2112, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2112, DW_AT_decl_line(0xfa)
.dwattr $C$DW$T$2112, DW_AT_decl_column(0x2f)
$C$DW$T$83 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$83, DW_AT_name("xdc_runtime_Text_Module_State")
.dwattr $C$DW$T$83, DW_AT_declaration
.dwendtag $C$DW$T$83
.dwattr $C$DW$T$83, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$83, DW_AT_decl_line(0xfc)
.dwattr $C$DW$T$83, DW_AT_decl_column(0x10)
$C$DW$T$2113 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Text_Module_State")
.dwattr $C$DW$T$2113, DW_AT_type(*$C$DW$T$83)
.dwattr $C$DW$T$2113, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2113, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2113, DW_AT_decl_line(0xfc)
.dwattr $C$DW$T$2113, DW_AT_decl_column(0x2e)
$C$DW$T$84 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$84, DW_AT_name("xdc_runtime_Text_Node")
.dwattr $C$DW$T$84, DW_AT_declaration
.dwendtag $C$DW$T$84
.dwattr $C$DW$T$84, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$84, DW_AT_decl_line(0xf9)
.dwattr $C$DW$T$84, DW_AT_decl_column(0x10)
$C$DW$T$2114 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Text_Node")
.dwattr $C$DW$T$2114, DW_AT_type(*$C$DW$T$84)
.dwattr $C$DW$T$2114, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2114, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2114, DW_AT_decl_line(0xf9)
.dwattr $C$DW$T$2114, DW_AT_decl_column(0x26)
$C$DW$T$85 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$85, DW_AT_name("xdc_runtime_Text_PrintVisState")
.dwattr $C$DW$T$85, DW_AT_declaration
.dwendtag $C$DW$T$85
.dwattr $C$DW$T$85, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$85, DW_AT_decl_line(0xfb)
.dwattr $C$DW$T$85, DW_AT_decl_column(0x10)
$C$DW$T$2115 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Text_PrintVisState")
.dwattr $C$DW$T$2115, DW_AT_type(*$C$DW$T$85)
.dwattr $C$DW$T$2115, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2115, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2115, DW_AT_decl_line(0xfb)
.dwattr $C$DW$T$2115, DW_AT_decl_column(0x2f)
$C$DW$T$86 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$86, DW_AT_name("xdc_runtime_TimestampNull_Fxns__")
.dwattr $C$DW$T$86, DW_AT_declaration
.dwendtag $C$DW$T$86
.dwattr $C$DW$T$86, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$86, DW_AT_decl_line(0x117)
.dwattr $C$DW$T$86, DW_AT_decl_column(0x10)
$C$DW$T$2116 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_TimestampNull_Fxns__")
.dwattr $C$DW$T$2116, DW_AT_type(*$C$DW$T$86)
.dwattr $C$DW$T$2116, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2116, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2116, DW_AT_decl_line(0x117)
.dwattr $C$DW$T$2116, DW_AT_decl_column(0x31)
$C$DW$T$2117 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2117, DW_AT_type(*$C$DW$T$86)
$C$DW$T$2118 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2118, DW_AT_type(*$C$DW$T$2117)
.dwattr $C$DW$T$2118, DW_AT_address_class(0x20)
$C$DW$T$2119 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_TimestampNull_Module")
.dwattr $C$DW$T$2119, DW_AT_type(*$C$DW$T$2118)
.dwattr $C$DW$T$2119, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2119, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2119, DW_AT_decl_line(0x118)
.dwattr $C$DW$T$2119, DW_AT_decl_column(0x38)
$C$DW$T$87 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$87, DW_AT_name("xdc_runtime_TimestampStd_Fxns__")
.dwattr $C$DW$T$87, DW_AT_declaration
.dwendtag $C$DW$T$87
.dwattr $C$DW$T$87, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$87, DW_AT_decl_line(0x11e)
.dwattr $C$DW$T$87, DW_AT_decl_column(0x10)
$C$DW$T$2120 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_TimestampStd_Fxns__")
.dwattr $C$DW$T$2120, DW_AT_type(*$C$DW$T$87)
.dwattr $C$DW$T$2120, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2120, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2120, DW_AT_decl_line(0x11e)
.dwattr $C$DW$T$2120, DW_AT_decl_column(0x30)
$C$DW$T$2121 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2121, DW_AT_type(*$C$DW$T$87)
$C$DW$T$2122 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2122, DW_AT_type(*$C$DW$T$2121)
.dwattr $C$DW$T$2122, DW_AT_address_class(0x20)
$C$DW$T$2123 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_TimestampStd_Module")
.dwattr $C$DW$T$2123, DW_AT_type(*$C$DW$T$2122)
.dwattr $C$DW$T$2123, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2123, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2123, DW_AT_decl_line(0x11f)
.dwattr $C$DW$T$2123, DW_AT_decl_column(0x37)
$C$DW$T$88 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$88, DW_AT_name("xdc_runtime_Timestamp_Fxns__")
.dwattr $C$DW$T$88, DW_AT_declaration
.dwendtag $C$DW$T$88
.dwattr $C$DW$T$88, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$88, DW_AT_decl_line(0x109)
.dwattr $C$DW$T$88, DW_AT_decl_column(0x10)
$C$DW$T$2124 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Timestamp_Fxns__")
.dwattr $C$DW$T$2124, DW_AT_type(*$C$DW$T$88)
.dwattr $C$DW$T$2124, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2124, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2124, DW_AT_decl_line(0x109)
.dwattr $C$DW$T$2124, DW_AT_decl_column(0x2d)
$C$DW$T$2125 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2125, DW_AT_type(*$C$DW$T$88)
$C$DW$T$2126 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2126, DW_AT_type(*$C$DW$T$2125)
.dwattr $C$DW$T$2126, DW_AT_address_class(0x20)
$C$DW$T$2127 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Timestamp_Module")
.dwattr $C$DW$T$2127, DW_AT_type(*$C$DW$T$2126)
.dwattr $C$DW$T$2127, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2127, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2127, DW_AT_decl_line(0x10a)
.dwattr $C$DW$T$2127, DW_AT_decl_column(0x34)
$C$DW$T$89 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$89, DW_AT_name("xdc_runtime_Timestamp_SupportProxy_Fxns__")
.dwattr $C$DW$T$89, DW_AT_declaration
.dwendtag $C$DW$T$89
.dwattr $C$DW$T$89, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$89, DW_AT_decl_line(0x17a)
.dwattr $C$DW$T$89, DW_AT_decl_column(0x10)
$C$DW$T$2128 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Timestamp_SupportProxy_Fxns__")
.dwattr $C$DW$T$2128, DW_AT_type(*$C$DW$T$89)
.dwattr $C$DW$T$2128, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2128, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2128, DW_AT_decl_line(0x17a)
.dwattr $C$DW$T$2128, DW_AT_decl_column(0x3a)
$C$DW$T$2129 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$2129, DW_AT_type(*$C$DW$T$89)
$C$DW$T$2130 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2130, DW_AT_type(*$C$DW$T$2129)
.dwattr $C$DW$T$2130, DW_AT_address_class(0x20)
$C$DW$T$2131 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Timestamp_SupportProxy_Module")
.dwattr $C$DW$T$2131, DW_AT_type(*$C$DW$T$2130)
.dwattr $C$DW$T$2131, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2131, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2131, DW_AT_decl_line(0x17b)
.dwattr $C$DW$T$2131, DW_AT_decl_column(0x41)
$C$DW$T$796 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$796, DW_AT_name("xdc_runtime_Types_Base")
.dwattr $C$DW$T$796, DW_AT_byte_size(0x04)
$C$DW$2956 .dwtag DW_TAG_member
.dwattr $C$DW$2956, DW_AT_type(*$C$DW$T$791)
.dwattr $C$DW$2956, DW_AT_name("base")
.dwattr $C$DW$2956, DW_AT_TI_symbol_name("base")
.dwattr $C$DW$2956, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2956, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2956, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2956, DW_AT_decl_line(0xbe)
.dwattr $C$DW$2956, DW_AT_decl_column(0x1d)
$C$DW$196 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$196, DW_AT_declaration
.dwattr $C$DW$196, DW_AT_TI_symbol_name("_ZN22xdc_runtime_Types_BaseaSERKS_")
.dwattr $C$DW$196, DW_AT_type(*$C$DW$T$792)
.dwattr $C$DW$196, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2957 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2957, DW_AT_type(*$C$DW$T$794)
.dwendtag $C$DW$196
.dwendtag $C$DW$T$796
.dwattr $C$DW$T$796, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$796, DW_AT_decl_line(0xbd)
.dwattr $C$DW$T$796, DW_AT_decl_column(0x08)
$C$DW$T$791 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$791, DW_AT_type(*$C$DW$T$796)
.dwattr $C$DW$T$791, DW_AT_address_class(0x20)
$C$DW$T$792 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$792, DW_AT_type(*$C$DW$T$796)
.dwattr $C$DW$T$792, DW_AT_address_class(0x20)
$C$DW$T$795 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$795, DW_AT_type(*$C$DW$T$792)
.dwattr $C$DW$T$795, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2958 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2958, DW_AT_type(*$C$DW$T$794)
.dwendtag $C$DW$T$795
$C$DW$T$634 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_Base")
.dwattr $C$DW$T$634, DW_AT_type(*$C$DW$T$796)
.dwattr $C$DW$T$634, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$634, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$634, DW_AT_decl_line(0x130)
.dwattr $C$DW$T$634, DW_AT_decl_column(0x27)
$C$DW$T$635 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$635, DW_AT_type(*$C$DW$T$634)
.dwattr $C$DW$T$635, DW_AT_address_class(0x20)
$C$DW$T$793 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$793, DW_AT_type(*$C$DW$T$796)
$C$DW$T$794 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$794, DW_AT_type(*$C$DW$T$793)
.dwattr $C$DW$T$794, DW_AT_address_class(0x20)
$C$DW$T$90 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$90, DW_AT_name("xdc_runtime_Types_CordAddr__")
.dwattr $C$DW$T$90, DW_AT_declaration
.dwendtag $C$DW$T$90
.dwattr $C$DW$T$90, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$90, DW_AT_decl_line(0x125)
.dwattr $C$DW$T$90, DW_AT_decl_column(0x10)
$C$DW$T$747 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_CordAddr__")
.dwattr $C$DW$T$747, DW_AT_type(*$C$DW$T$90)
.dwattr $C$DW$T$747, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$747, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$747, DW_AT_decl_line(0x125)
.dwattr $C$DW$T$747, DW_AT_decl_column(0x2d)
$C$DW$T$748 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$748, DW_AT_type(*$C$DW$T$747)
.dwattr $C$DW$T$748, DW_AT_address_class(0x20)
$C$DW$T$749 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_CordAddr")
.dwattr $C$DW$T$749, DW_AT_type(*$C$DW$T$748)
.dwattr $C$DW$T$749, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$749, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$749, DW_AT_decl_line(0x4e)
.dwattr $C$DW$T$749, DW_AT_decl_column(0x27)
$C$DW$T$2132 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$2132, DW_AT_name("xdc_runtime_Types_CreatePolicy")
.dwattr $C$DW$T$2132, DW_AT_byte_size(0x04)
$C$DW$2959 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Types_STATIC_POLICY"), DW_AT_const_value(0x00)
.dwattr $C$DW$2959, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2959, DW_AT_decl_line(0x5b)
.dwattr $C$DW$2959, DW_AT_decl_column(0x05)
$C$DW$2960 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Types_CREATE_POLICY"), DW_AT_const_value(0x01)
.dwattr $C$DW$2960, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2960, DW_AT_decl_line(0x5c)
.dwattr $C$DW$2960, DW_AT_decl_column(0x05)
$C$DW$2961 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Types_DELETE_POLICY"), DW_AT_const_value(0x02)
.dwattr $C$DW$2961, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2961, DW_AT_decl_line(0x5d)
.dwattr $C$DW$2961, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$2132
.dwattr $C$DW$T$2132, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$2132, DW_AT_decl_line(0x5a)
.dwattr $C$DW$T$2132, DW_AT_decl_column(0x06)
$C$DW$T$2133 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_CreatePolicy")
.dwattr $C$DW$T$2133, DW_AT_type(*$C$DW$T$2132)
.dwattr $C$DW$T$2133, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2133, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$2133, DW_AT_decl_line(0x5f)
.dwattr $C$DW$T$2133, DW_AT_decl_column(0x2d)
$C$DW$T$801 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$801, DW_AT_name("xdc_runtime_Types_FreqHz")
.dwattr $C$DW$T$801, DW_AT_byte_size(0x08)
$C$DW$2962 .dwtag DW_TAG_member
.dwattr $C$DW$2962, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2962, DW_AT_name("hi")
.dwattr $C$DW$2962, DW_AT_TI_symbol_name("hi")
.dwattr $C$DW$2962, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2962, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2962, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2962, DW_AT_decl_line(0x80)
.dwattr $C$DW$2962, DW_AT_decl_column(0x10)
$C$DW$2963 .dwtag DW_TAG_member
.dwattr $C$DW$2963, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$2963, DW_AT_name("lo")
.dwattr $C$DW$2963, DW_AT_TI_symbol_name("lo")
.dwattr $C$DW$2963, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2963, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2963, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2963, DW_AT_decl_line(0x81)
.dwattr $C$DW$2963, DW_AT_decl_column(0x10)
$C$DW$197 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$197, DW_AT_declaration
.dwattr $C$DW$197, DW_AT_TI_symbol_name("_ZN24xdc_runtime_Types_FreqHzaSERKS_")
.dwattr $C$DW$197, DW_AT_type(*$C$DW$T$797)
.dwattr $C$DW$197, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2964 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2964, DW_AT_type(*$C$DW$T$799)
.dwendtag $C$DW$197
.dwendtag $C$DW$T$801
.dwattr $C$DW$T$801, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$801, DW_AT_decl_line(0x7f)
.dwattr $C$DW$T$801, DW_AT_decl_column(0x08)
$C$DW$T$797 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$797, DW_AT_type(*$C$DW$T$801)
.dwattr $C$DW$T$797, DW_AT_address_class(0x20)
$C$DW$T$800 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$800, DW_AT_type(*$C$DW$T$797)
.dwattr $C$DW$T$800, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2965 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2965, DW_AT_type(*$C$DW$T$799)
.dwendtag $C$DW$T$800
$C$DW$T$798 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$798, DW_AT_type(*$C$DW$T$801)
$C$DW$T$799 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$799, DW_AT_type(*$C$DW$T$798)
.dwattr $C$DW$T$799, DW_AT_address_class(0x20)
$C$DW$T$2134 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_FreqHz")
.dwattr $C$DW$T$2134, DW_AT_type(*$C$DW$T$801)
.dwattr $C$DW$T$2134, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2134, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2134, DW_AT_decl_line(0x12a)
.dwattr $C$DW$T$2134, DW_AT_decl_column(0x29)
$C$DW$T$91 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$91, DW_AT_name("xdc_runtime_Types_GateRef__")
.dwattr $C$DW$T$91, DW_AT_declaration
.dwendtag $C$DW$T$91
.dwattr $C$DW$T$91, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$91, DW_AT_decl_line(0x126)
.dwattr $C$DW$T$91, DW_AT_decl_column(0x10)
$C$DW$T$2135 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_GateRef__")
.dwattr $C$DW$T$2135, DW_AT_type(*$C$DW$T$91)
.dwattr $C$DW$T$2135, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2135, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2135, DW_AT_decl_line(0x126)
.dwattr $C$DW$T$2135, DW_AT_decl_column(0x2c)
$C$DW$T$2136 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$2136, DW_AT_type(*$C$DW$T$2135)
.dwattr $C$DW$T$2136, DW_AT_address_class(0x20)
$C$DW$T$2137 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_GateRef")
.dwattr $C$DW$T$2137, DW_AT_type(*$C$DW$T$2136)
.dwattr $C$DW$T$2137, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2137, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$2137, DW_AT_decl_line(0x54)
.dwattr $C$DW$T$2137, DW_AT_decl_column(0x26)
$C$DW$T$807 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$807, DW_AT_name("xdc_runtime_Types_InstHdr")
.dwattr $C$DW$T$807, DW_AT_byte_size(0x08)
$C$DW$2966 .dwtag DW_TAG_member
.dwattr $C$DW$2966, DW_AT_type(*$C$DW$T$802)
.dwattr $C$DW$2966, DW_AT_name("link")
.dwattr $C$DW$2966, DW_AT_TI_symbol_name("link")
.dwattr $C$DW$2966, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2966, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2966, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2966, DW_AT_decl_line(0xb1)
.dwattr $C$DW$2966, DW_AT_decl_column(0x1c)
$C$DW$198 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$198, DW_AT_declaration
.dwattr $C$DW$198, DW_AT_TI_symbol_name("_ZN25xdc_runtime_Types_InstHdraSERKS_")
.dwattr $C$DW$198, DW_AT_type(*$C$DW$T$803)
.dwattr $C$DW$198, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2967 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2967, DW_AT_type(*$C$DW$T$805)
.dwendtag $C$DW$198
.dwendtag $C$DW$T$807
.dwattr $C$DW$T$807, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$807, DW_AT_decl_line(0xb0)
.dwattr $C$DW$T$807, DW_AT_decl_column(0x08)
$C$DW$T$803 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$803, DW_AT_type(*$C$DW$T$807)
.dwattr $C$DW$T$803, DW_AT_address_class(0x20)
$C$DW$T$806 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$806, DW_AT_type(*$C$DW$T$803)
.dwattr $C$DW$T$806, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2968 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2968, DW_AT_type(*$C$DW$T$805)
.dwendtag $C$DW$T$806
$C$DW$T$804 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$804, DW_AT_type(*$C$DW$T$807)
$C$DW$T$805 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$805, DW_AT_type(*$C$DW$T$804)
.dwattr $C$DW$T$805, DW_AT_address_class(0x20)
$C$DW$T$2138 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_InstHdr")
.dwattr $C$DW$T$2138, DW_AT_type(*$C$DW$T$807)
.dwattr $C$DW$T$2138, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2138, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2138, DW_AT_decl_line(0x12e)
.dwattr $C$DW$T$2138, DW_AT_decl_column(0x2a)
$C$DW$T$812 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$812, DW_AT_name("xdc_runtime_Types_Label")
.dwattr $C$DW$T$812, DW_AT_byte_size(0x10)
$C$DW$2969 .dwtag DW_TAG_member
.dwattr $C$DW$2969, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$2969, DW_AT_name("handle")
.dwattr $C$DW$2969, DW_AT_TI_symbol_name("handle")
.dwattr $C$DW$2969, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2969, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2969, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2969, DW_AT_decl_line(0x6b)
.dwattr $C$DW$2969, DW_AT_decl_column(0x0d)
$C$DW$2970 .dwtag DW_TAG_member
.dwattr $C$DW$2970, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$2970, DW_AT_name("modId")
.dwattr $C$DW$2970, DW_AT_TI_symbol_name("modId")
.dwattr $C$DW$2970, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2970, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2970, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2970, DW_AT_decl_line(0x6c)
.dwattr $C$DW$2970, DW_AT_decl_column(0x20)
$C$DW$2971 .dwtag DW_TAG_member
.dwattr $C$DW$2971, DW_AT_type(*$C$DW$T$609)
.dwattr $C$DW$2971, DW_AT_name("iname")
.dwattr $C$DW$2971, DW_AT_TI_symbol_name("iname")
.dwattr $C$DW$2971, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2971, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2971, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2971, DW_AT_decl_line(0x6d)
.dwattr $C$DW$2971, DW_AT_decl_column(0x10)
$C$DW$2972 .dwtag DW_TAG_member
.dwattr $C$DW$2972, DW_AT_type(*$C$DW$T$455)
.dwattr $C$DW$2972, DW_AT_name("named")
.dwattr $C$DW$2972, DW_AT_TI_symbol_name("named")
.dwattr $C$DW$2972, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2972, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2972, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2972, DW_AT_decl_line(0x6e)
.dwattr $C$DW$2972, DW_AT_decl_column(0x0e)
$C$DW$199 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$199, DW_AT_declaration
.dwattr $C$DW$199, DW_AT_TI_symbol_name("_ZN23xdc_runtime_Types_LabelaSERKS_")
.dwattr $C$DW$199, DW_AT_type(*$C$DW$T$808)
.dwattr $C$DW$199, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2973 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2973, DW_AT_type(*$C$DW$T$810)
.dwendtag $C$DW$199
.dwendtag $C$DW$T$812
.dwattr $C$DW$T$812, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$812, DW_AT_decl_line(0x6a)
.dwattr $C$DW$T$812, DW_AT_decl_column(0x08)
$C$DW$T$808 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$808, DW_AT_type(*$C$DW$T$812)
.dwattr $C$DW$T$808, DW_AT_address_class(0x20)
$C$DW$T$811 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$811, DW_AT_type(*$C$DW$T$808)
.dwattr $C$DW$T$811, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2974 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2974, DW_AT_type(*$C$DW$T$810)
.dwendtag $C$DW$T$811
$C$DW$T$809 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$809, DW_AT_type(*$C$DW$T$812)
$C$DW$T$810 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$810, DW_AT_type(*$C$DW$T$809)
.dwattr $C$DW$T$810, DW_AT_address_class(0x20)
$C$DW$T$843 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_Label")
.dwattr $C$DW$T$843, DW_AT_type(*$C$DW$T$812)
.dwattr $C$DW$T$843, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$843, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$843, DW_AT_decl_line(0x127)
.dwattr $C$DW$T$843, DW_AT_decl_column(0x28)
$C$DW$T$844 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$844, DW_AT_type(*$C$DW$T$843)
.dwattr $C$DW$T$844, DW_AT_address_class(0x20)
$C$DW$T$845 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$845, DW_AT_type(*$C$DW$T$844)
.dwattr $C$DW$T$845, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2975 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2975, DW_AT_type(*$C$DW$T$668)
$C$DW$2976 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2976, DW_AT_type(*$C$DW$T$844)
.dwendtag $C$DW$T$845
$C$DW$T$846 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$846, DW_AT_type(*$C$DW$T$845)
.dwattr $C$DW$T$846, DW_AT_address_class(0x20)
$C$DW$T$818 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$818, DW_AT_name("xdc_runtime_Types_Link")
.dwattr $C$DW$T$818, DW_AT_byte_size(0x08)
$C$DW$2977 .dwtag DW_TAG_member
.dwattr $C$DW$2977, DW_AT_type(*$C$DW$T$813)
.dwattr $C$DW$2977, DW_AT_name("next")
.dwattr $C$DW$2977, DW_AT_TI_symbol_name("next")
.dwattr $C$DW$2977, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2977, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2977, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2977, DW_AT_decl_line(0xab)
.dwattr $C$DW$2977, DW_AT_decl_column(0x1d)
$C$DW$2978 .dwtag DW_TAG_member
.dwattr $C$DW$2978, DW_AT_type(*$C$DW$T$813)
.dwattr $C$DW$2978, DW_AT_name("prev")
.dwattr $C$DW$2978, DW_AT_TI_symbol_name("prev")
.dwattr $C$DW$2978, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2978, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2978, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2978, DW_AT_decl_line(0xac)
.dwattr $C$DW$2978, DW_AT_decl_column(0x1d)
$C$DW$200 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$200, DW_AT_declaration
.dwattr $C$DW$200, DW_AT_TI_symbol_name("_ZN22xdc_runtime_Types_LinkaSERKS_")
.dwattr $C$DW$200, DW_AT_type(*$C$DW$T$814)
.dwattr $C$DW$200, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2979 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2979, DW_AT_type(*$C$DW$T$816)
.dwendtag $C$DW$200
.dwendtag $C$DW$T$818
.dwattr $C$DW$T$818, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$818, DW_AT_decl_line(0xaa)
.dwattr $C$DW$T$818, DW_AT_decl_column(0x08)
$C$DW$T$813 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$813, DW_AT_type(*$C$DW$T$818)
.dwattr $C$DW$T$813, DW_AT_address_class(0x20)
$C$DW$T$814 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$814, DW_AT_type(*$C$DW$T$818)
.dwattr $C$DW$T$814, DW_AT_address_class(0x20)
$C$DW$T$817 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$817, DW_AT_type(*$C$DW$T$814)
.dwattr $C$DW$T$817, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2980 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2980, DW_AT_type(*$C$DW$T$816)
.dwendtag $C$DW$T$817
$C$DW$T$802 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_Link")
.dwattr $C$DW$T$802, DW_AT_type(*$C$DW$T$818)
.dwattr $C$DW$T$802, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$802, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$802, DW_AT_decl_line(0x12d)
.dwattr $C$DW$T$802, DW_AT_decl_column(0x27)
$C$DW$T$815 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$815, DW_AT_type(*$C$DW$T$818)
$C$DW$T$816 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$816, DW_AT_type(*$C$DW$T$815)
.dwattr $C$DW$T$816, DW_AT_address_class(0x20)
$C$DW$T$2139 .dwtag DW_TAG_enumeration_type
.dwattr $C$DW$T$2139, DW_AT_name("xdc_runtime_Types_OutputPolicy")
.dwattr $C$DW$T$2139, DW_AT_byte_size(0x04)
$C$DW$2981 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Types_COMMON_FILE"), DW_AT_const_value(0x00)
.dwattr $C$DW$2981, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2981, DW_AT_decl_line(0x63)
.dwattr $C$DW$2981, DW_AT_decl_column(0x05)
$C$DW$2982 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Types_SEPARATE_FILE"), DW_AT_const_value(0x01)
.dwattr $C$DW$2982, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2982, DW_AT_decl_line(0x64)
.dwattr $C$DW$2982, DW_AT_decl_column(0x05)
$C$DW$2983 .dwtag DW_TAG_enumerator, DW_AT_name("xdc_runtime_Types_NO_FILE"), DW_AT_const_value(0x02)
.dwattr $C$DW$2983, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2983, DW_AT_decl_line(0x65)
.dwattr $C$DW$2983, DW_AT_decl_column(0x05)
.dwendtag $C$DW$T$2139
.dwattr $C$DW$T$2139, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$2139, DW_AT_decl_line(0x62)
.dwattr $C$DW$T$2139, DW_AT_decl_column(0x06)
$C$DW$T$2140 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_OutputPolicy")
.dwattr $C$DW$T$2140, DW_AT_type(*$C$DW$T$2139)
.dwattr $C$DW$T$2140, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2140, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$2140, DW_AT_decl_line(0x67)
.dwattr $C$DW$T$2140, DW_AT_decl_column(0x2d)
$C$DW$T$823 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$823, DW_AT_name("xdc_runtime_Types_PrmsHdr")
.dwattr $C$DW$T$823, DW_AT_byte_size(0x10)
$C$DW$2984 .dwtag DW_TAG_member
.dwattr $C$DW$2984, DW_AT_type(*$C$DW$T$669)
.dwattr $C$DW$2984, DW_AT_name("size")
.dwattr $C$DW$2984, DW_AT_TI_symbol_name("size")
.dwattr $C$DW$2984, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2984, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2984, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2984, DW_AT_decl_line(0xb6)
.dwattr $C$DW$2984, DW_AT_decl_column(0x0f)
$C$DW$2985 .dwtag DW_TAG_member
.dwattr $C$DW$2985, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$2985, DW_AT_name("self")
.dwattr $C$DW$2985, DW_AT_TI_symbol_name("self")
.dwattr $C$DW$2985, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2985, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2985, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2985, DW_AT_decl_line(0xb7)
.dwattr $C$DW$2985, DW_AT_decl_column(0x0d)
$C$DW$2986 .dwtag DW_TAG_member
.dwattr $C$DW$2986, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$2986, DW_AT_name("modFxns")
.dwattr $C$DW$2986, DW_AT_TI_symbol_name("modFxns")
.dwattr $C$DW$2986, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2986, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2986, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2986, DW_AT_decl_line(0xb8)
.dwattr $C$DW$2986, DW_AT_decl_column(0x0d)
$C$DW$2987 .dwtag DW_TAG_member
.dwattr $C$DW$2987, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$2987, DW_AT_name("instPrms")
.dwattr $C$DW$2987, DW_AT_TI_symbol_name("instPrms")
.dwattr $C$DW$2987, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$2987, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2987, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2987, DW_AT_decl_line(0xb9)
.dwattr $C$DW$2987, DW_AT_decl_column(0x0d)
$C$DW$201 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$201, DW_AT_declaration
.dwattr $C$DW$201, DW_AT_TI_symbol_name("_ZN25xdc_runtime_Types_PrmsHdraSERKS_")
.dwattr $C$DW$201, DW_AT_type(*$C$DW$T$819)
.dwattr $C$DW$201, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2988 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2988, DW_AT_type(*$C$DW$T$821)
.dwendtag $C$DW$201
.dwendtag $C$DW$T$823
.dwattr $C$DW$T$823, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$823, DW_AT_decl_line(0xb5)
.dwattr $C$DW$T$823, DW_AT_decl_column(0x08)
$C$DW$T$819 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$819, DW_AT_type(*$C$DW$T$823)
.dwattr $C$DW$T$819, DW_AT_address_class(0x20)
$C$DW$T$822 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$822, DW_AT_type(*$C$DW$T$819)
.dwattr $C$DW$T$822, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2989 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2989, DW_AT_type(*$C$DW$T$821)
.dwendtag $C$DW$T$822
$C$DW$T$820 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$820, DW_AT_type(*$C$DW$T$823)
$C$DW$T$821 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$821, DW_AT_type(*$C$DW$T$820)
.dwattr $C$DW$T$821, DW_AT_address_class(0x20)
$C$DW$T$2141 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_PrmsHdr")
.dwattr $C$DW$T$2141, DW_AT_type(*$C$DW$T$823)
.dwattr $C$DW$T$2141, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2141, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2141, DW_AT_decl_line(0x12f)
.dwattr $C$DW$T$2141, DW_AT_decl_column(0x2a)
$C$DW$T$832 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$832, DW_AT_name("xdc_runtime_Types_RegDesc")
.dwattr $C$DW$T$832, DW_AT_byte_size(0x0c)
$C$DW$2990 .dwtag DW_TAG_member
.dwattr $C$DW$2990, DW_AT_type(*$C$DW$T$824)
.dwattr $C$DW$2990, DW_AT_name("next")
.dwattr $C$DW$2990, DW_AT_TI_symbol_name("next")
.dwattr $C$DW$2990, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2990, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2990, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2990, DW_AT_decl_line(0x86)
.dwattr $C$DW$2990, DW_AT_decl_column(0x20)
$C$DW$2991 .dwtag DW_TAG_member
.dwattr $C$DW$2991, DW_AT_type(*$C$DW$T$827)
.dwattr $C$DW$2991, DW_AT_name("modName")
.dwattr $C$DW$2991, DW_AT_TI_symbol_name("modName")
.dwattr $C$DW$2991, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2991, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2991, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2991, DW_AT_decl_line(0x87)
.dwattr $C$DW$2991, DW_AT_decl_column(0x11)
$C$DW$2992 .dwtag DW_TAG_member
.dwattr $C$DW$2992, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$2992, DW_AT_name("id")
.dwattr $C$DW$2992, DW_AT_TI_symbol_name("id")
.dwattr $C$DW$2992, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2992, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2992, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2992, DW_AT_decl_line(0x88)
.dwattr $C$DW$2992, DW_AT_decl_column(0x20)
$C$DW$2993 .dwtag DW_TAG_member
.dwattr $C$DW$2993, DW_AT_type(*$C$DW$T$597)
.dwattr $C$DW$2993, DW_AT_name("mask")
.dwattr $C$DW$2993, DW_AT_TI_symbol_name("mask")
.dwattr $C$DW$2993, DW_AT_data_member_location[DW_OP_plus_uconst 0xa]
.dwattr $C$DW$2993, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2993, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2993, DW_AT_decl_line(0x89)
.dwattr $C$DW$2993, DW_AT_decl_column(0x21)
$C$DW$202 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$202, DW_AT_declaration
.dwattr $C$DW$202, DW_AT_TI_symbol_name("_ZN25xdc_runtime_Types_RegDescaSERKS_")
.dwattr $C$DW$202, DW_AT_type(*$C$DW$T$828)
.dwattr $C$DW$202, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2994 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2994, DW_AT_type(*$C$DW$T$830)
.dwendtag $C$DW$202
.dwendtag $C$DW$T$832
.dwattr $C$DW$T$832, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$832, DW_AT_decl_line(0x85)
.dwattr $C$DW$T$832, DW_AT_decl_column(0x08)
$C$DW$T$824 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$824, DW_AT_type(*$C$DW$T$832)
.dwattr $C$DW$T$824, DW_AT_address_class(0x20)
$C$DW$T$828 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$828, DW_AT_type(*$C$DW$T$832)
.dwattr $C$DW$T$828, DW_AT_address_class(0x20)
$C$DW$T$831 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$831, DW_AT_type(*$C$DW$T$828)
.dwattr $C$DW$T$831, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$2995 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2995, DW_AT_type(*$C$DW$T$830)
.dwendtag $C$DW$T$831
$C$DW$T$829 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$829, DW_AT_type(*$C$DW$T$832)
$C$DW$T$830 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$830, DW_AT_type(*$C$DW$T$829)
.dwattr $C$DW$T$830, DW_AT_address_class(0x20)
$C$DW$T$2142 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_RegDesc")
.dwattr $C$DW$T$2142, DW_AT_type(*$C$DW$T$832)
.dwattr $C$DW$T$2142, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2142, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2142, DW_AT_decl_line(0x12b)
.dwattr $C$DW$T$2142, DW_AT_decl_column(0x2a)
$C$DW$T$837 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$837, DW_AT_name("xdc_runtime_Types_Site")
.dwattr $C$DW$T$837, DW_AT_byte_size(0x0c)
$C$DW$2996 .dwtag DW_TAG_member
.dwattr $C$DW$2996, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$2996, DW_AT_name("mod")
.dwattr $C$DW$2996, DW_AT_TI_symbol_name("mod")
.dwattr $C$DW$2996, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$2996, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2996, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2996, DW_AT_decl_line(0x73)
.dwattr $C$DW$2996, DW_AT_decl_column(0x20)
$C$DW$2997 .dwtag DW_TAG_member
.dwattr $C$DW$2997, DW_AT_type(*$C$DW$T$827)
.dwattr $C$DW$2997, DW_AT_name("file")
.dwattr $C$DW$2997, DW_AT_TI_symbol_name("file")
.dwattr $C$DW$2997, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$2997, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2997, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2997, DW_AT_decl_line(0x74)
.dwattr $C$DW$2997, DW_AT_decl_column(0x11)
$C$DW$2998 .dwtag DW_TAG_member
.dwattr $C$DW$2998, DW_AT_type(*$C$DW$T$639)
.dwattr $C$DW$2998, DW_AT_name("line")
.dwattr $C$DW$2998, DW_AT_TI_symbol_name("line")
.dwattr $C$DW$2998, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$2998, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$2998, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$2998, DW_AT_decl_line(0x75)
.dwattr $C$DW$2998, DW_AT_decl_column(0x0d)
$C$DW$203 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$203, DW_AT_declaration
.dwattr $C$DW$203, DW_AT_TI_symbol_name("_ZN22xdc_runtime_Types_SiteaSERKS_")
.dwattr $C$DW$203, DW_AT_type(*$C$DW$T$833)
.dwattr $C$DW$203, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$2999 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$2999, DW_AT_type(*$C$DW$T$835)
.dwendtag $C$DW$203
.dwendtag $C$DW$T$837
.dwattr $C$DW$T$837, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$837, DW_AT_decl_line(0x72)
.dwattr $C$DW$T$837, DW_AT_decl_column(0x08)
$C$DW$T$833 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$833, DW_AT_type(*$C$DW$T$837)
.dwattr $C$DW$T$833, DW_AT_address_class(0x20)
$C$DW$T$836 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$836, DW_AT_type(*$C$DW$T$833)
.dwattr $C$DW$T$836, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$3000 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$3000, DW_AT_type(*$C$DW$T$835)
.dwendtag $C$DW$T$836
$C$DW$T$610 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_Site")
.dwattr $C$DW$T$610, DW_AT_type(*$C$DW$T$837)
.dwattr $C$DW$T$610, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$610, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$610, DW_AT_decl_line(0x128)
.dwattr $C$DW$T$610, DW_AT_decl_column(0x27)
$C$DW$T$834 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$834, DW_AT_type(*$C$DW$T$837)
$C$DW$T$835 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$835, DW_AT_type(*$C$DW$T$834)
.dwattr $C$DW$T$835, DW_AT_address_class(0x20)
$C$DW$T$851 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$851, DW_AT_name("xdc_runtime_Types_SysFxns")
.dwattr $C$DW$T$851, DW_AT_byte_size(0x10)
$C$DW$3001 .dwtag DW_TAG_member
.dwattr $C$DW$3001, DW_AT_type(*$C$DW$T$840)
.dwattr $C$DW$3001, DW_AT_name("__create")
.dwattr $C$DW$3001, DW_AT_TI_symbol_name("__create")
.dwattr $C$DW$3001, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$3001, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3001, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3001, DW_AT_decl_line(0xc3)
.dwattr $C$DW$3001, DW_AT_decl_column(0x0f)
$C$DW$3002 .dwtag DW_TAG_member
.dwattr $C$DW$3002, DW_AT_type(*$C$DW$T$842)
.dwattr $C$DW$3002, DW_AT_name("__delete")
.dwattr $C$DW$3002, DW_AT_TI_symbol_name("__delete")
.dwattr $C$DW$3002, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$3002, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3002, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3002, DW_AT_decl_line(0xc4)
.dwattr $C$DW$3002, DW_AT_decl_column(0x10)
$C$DW$3003 .dwtag DW_TAG_member
.dwattr $C$DW$3003, DW_AT_type(*$C$DW$T$846)
.dwattr $C$DW$3003, DW_AT_name("__label")
.dwattr $C$DW$3003, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$3003, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$3003, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3003, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3003, DW_AT_decl_line(0xc5)
.dwattr $C$DW$3003, DW_AT_decl_column(0x20)
$C$DW$3004 .dwtag DW_TAG_member
.dwattr $C$DW$3004, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$3004, DW_AT_name("__mid")
.dwattr $C$DW$3004, DW_AT_TI_symbol_name("__mid")
.dwattr $C$DW$3004, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$3004, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3004, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3004, DW_AT_decl_line(0xc6)
.dwattr $C$DW$3004, DW_AT_decl_column(0x20)
$C$DW$204 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$204, DW_AT_declaration
.dwattr $C$DW$204, DW_AT_TI_symbol_name("_ZN25xdc_runtime_Types_SysFxnsaSERKS_")
.dwattr $C$DW$204, DW_AT_type(*$C$DW$T$847)
.dwattr $C$DW$204, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$3005 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$3005, DW_AT_type(*$C$DW$T$849)
.dwendtag $C$DW$204
.dwendtag $C$DW$T$851
.dwattr $C$DW$T$851, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$851, DW_AT_decl_line(0xc2)
.dwattr $C$DW$T$851, DW_AT_decl_column(0x08)
$C$DW$T$847 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$847, DW_AT_type(*$C$DW$T$851)
.dwattr $C$DW$T$847, DW_AT_address_class(0x20)
$C$DW$T$850 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$850, DW_AT_type(*$C$DW$T$847)
.dwattr $C$DW$T$850, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$3006 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$3006, DW_AT_type(*$C$DW$T$849)
.dwendtag $C$DW$T$850
$C$DW$T$848 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$848, DW_AT_type(*$C$DW$T$851)
$C$DW$T$849 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$849, DW_AT_type(*$C$DW$T$848)
.dwattr $C$DW$T$849, DW_AT_address_class(0x20)
$C$DW$T$2143 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_SysFxns")
.dwattr $C$DW$T$2143, DW_AT_type(*$C$DW$T$851)
.dwattr $C$DW$T$2143, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2143, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2143, DW_AT_decl_line(0x131)
.dwattr $C$DW$T$2143, DW_AT_decl_column(0x2a)
$C$DW$T$861 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$861, DW_AT_name("xdc_runtime_Types_SysFxns2")
.dwattr $C$DW$T$861, DW_AT_byte_size(0x10)
$C$DW$3007 .dwtag DW_TAG_member
.dwattr $C$DW$3007, DW_AT_type(*$C$DW$T$856)
.dwattr $C$DW$3007, DW_AT_name("__create")
.dwattr $C$DW$3007, DW_AT_TI_symbol_name("__create")
.dwattr $C$DW$3007, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$3007, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3007, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3007, DW_AT_decl_line(0xcb)
.dwattr $C$DW$3007, DW_AT_decl_column(0x0f)
$C$DW$3008 .dwtag DW_TAG_member
.dwattr $C$DW$3008, DW_AT_type(*$C$DW$T$842)
.dwattr $C$DW$3008, DW_AT_name("__delete")
.dwattr $C$DW$3008, DW_AT_TI_symbol_name("__delete")
.dwattr $C$DW$3008, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$3008, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3008, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3008, DW_AT_decl_line(0xcc)
.dwattr $C$DW$3008, DW_AT_decl_column(0x10)
$C$DW$3009 .dwtag DW_TAG_member
.dwattr $C$DW$3009, DW_AT_type(*$C$DW$T$846)
.dwattr $C$DW$3009, DW_AT_name("__label")
.dwattr $C$DW$3009, DW_AT_TI_symbol_name("__label")
.dwattr $C$DW$3009, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$3009, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3009, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3009, DW_AT_decl_line(0xcd)
.dwattr $C$DW$3009, DW_AT_decl_column(0x20)
$C$DW$3010 .dwtag DW_TAG_member
.dwattr $C$DW$3010, DW_AT_type(*$C$DW$T$596)
.dwattr $C$DW$3010, DW_AT_name("__mid")
.dwattr $C$DW$3010, DW_AT_TI_symbol_name("__mid")
.dwattr $C$DW$3010, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$3010, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3010, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3010, DW_AT_decl_line(0xce)
.dwattr $C$DW$3010, DW_AT_decl_column(0x20)
$C$DW$205 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$205, DW_AT_declaration
.dwattr $C$DW$205, DW_AT_TI_symbol_name("_ZN26xdc_runtime_Types_SysFxns2aSERKS_")
.dwattr $C$DW$205, DW_AT_type(*$C$DW$T$857)
.dwattr $C$DW$205, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$3011 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$3011, DW_AT_type(*$C$DW$T$859)
.dwendtag $C$DW$205
.dwendtag $C$DW$T$861
.dwattr $C$DW$T$861, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$861, DW_AT_decl_line(0xca)
.dwattr $C$DW$T$861, DW_AT_decl_column(0x08)
$C$DW$T$857 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$857, DW_AT_type(*$C$DW$T$861)
.dwattr $C$DW$T$857, DW_AT_address_class(0x20)
$C$DW$T$860 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$860, DW_AT_type(*$C$DW$T$857)
.dwattr $C$DW$T$860, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$3012 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$3012, DW_AT_type(*$C$DW$T$859)
.dwendtag $C$DW$T$860
$C$DW$T$636 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_SysFxns2")
.dwattr $C$DW$T$636, DW_AT_type(*$C$DW$T$861)
.dwattr $C$DW$T$636, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$636, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$636, DW_AT_decl_line(0x132)
.dwattr $C$DW$T$636, DW_AT_decl_column(0x2b)
$C$DW$T$637 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$637, DW_AT_type(*$C$DW$T$636)
$C$DW$T$638 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$638, DW_AT_type(*$C$DW$T$637)
.dwattr $C$DW$T$638, DW_AT_address_class(0x20)
$C$DW$T$858 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$858, DW_AT_type(*$C$DW$T$861)
$C$DW$T$859 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$859, DW_AT_type(*$C$DW$T$858)
.dwattr $C$DW$T$859, DW_AT_address_class(0x20)
$C$DW$T$866 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$866, DW_AT_name("xdc_runtime_Types_Timestamp64")
.dwattr $C$DW$T$866, DW_AT_byte_size(0x08)
$C$DW$3013 .dwtag DW_TAG_member
.dwattr $C$DW$3013, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$3013, DW_AT_name("hi")
.dwattr $C$DW$3013, DW_AT_TI_symbol_name("hi")
.dwattr $C$DW$3013, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$3013, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3013, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3013, DW_AT_decl_line(0x7a)
.dwattr $C$DW$3013, DW_AT_decl_column(0x10)
$C$DW$3014 .dwtag DW_TAG_member
.dwattr $C$DW$3014, DW_AT_type(*$C$DW$T$606)
.dwattr $C$DW$3014, DW_AT_name("lo")
.dwattr $C$DW$3014, DW_AT_TI_symbol_name("lo")
.dwattr $C$DW$3014, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$3014, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3014, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3014, DW_AT_decl_line(0x7b)
.dwattr $C$DW$3014, DW_AT_decl_column(0x10)
$C$DW$206 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$206, DW_AT_declaration
.dwattr $C$DW$206, DW_AT_TI_symbol_name("_ZN29xdc_runtime_Types_Timestamp64aSERKS_")
.dwattr $C$DW$206, DW_AT_type(*$C$DW$T$862)
.dwattr $C$DW$206, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$3015 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$3015, DW_AT_type(*$C$DW$T$864)
.dwendtag $C$DW$206
.dwendtag $C$DW$T$866
.dwattr $C$DW$T$866, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$866, DW_AT_decl_line(0x79)
.dwattr $C$DW$T$866, DW_AT_decl_column(0x08)
$C$DW$T$862 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$862, DW_AT_type(*$C$DW$T$866)
.dwattr $C$DW$T$862, DW_AT_address_class(0x20)
$C$DW$T$865 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$865, DW_AT_type(*$C$DW$T$862)
.dwattr $C$DW$T$865, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$3016 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$3016, DW_AT_type(*$C$DW$T$864)
.dwendtag $C$DW$T$865
$C$DW$T$863 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$863, DW_AT_type(*$C$DW$T$866)
$C$DW$T$864 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$864, DW_AT_type(*$C$DW$T$863)
.dwattr $C$DW$T$864, DW_AT_address_class(0x20)
$C$DW$T$2144 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_Timestamp64")
.dwattr $C$DW$T$2144, DW_AT_type(*$C$DW$T$866)
.dwattr $C$DW$T$2144, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2144, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2144, DW_AT_decl_line(0x129)
.dwattr $C$DW$T$2144, DW_AT_decl_column(0x2e)
$C$DW$T$871 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$871, DW_AT_name("xdc_runtime_Types_Vec")
.dwattr $C$DW$T$871, DW_AT_byte_size(0x08)
$C$DW$3017 .dwtag DW_TAG_member
.dwattr $C$DW$3017, DW_AT_type(*$C$DW$T$639)
.dwattr $C$DW$3017, DW_AT_name("len")
.dwattr $C$DW$3017, DW_AT_TI_symbol_name("len")
.dwattr $C$DW$3017, DW_AT_data_member_location[DW_OP_plus_uconst 0x0]
.dwattr $C$DW$3017, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3017, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3017, DW_AT_decl_line(0xa5)
.dwattr $C$DW$3017, DW_AT_decl_column(0x0d)
$C$DW$3018 .dwtag DW_TAG_member
.dwattr $C$DW$3018, DW_AT_type(*$C$DW$T$668)
.dwattr $C$DW$3018, DW_AT_name("arr")
.dwattr $C$DW$3018, DW_AT_TI_symbol_name("arr")
.dwattr $C$DW$3018, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$3018, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$3018, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$3018, DW_AT_decl_line(0xa6)
.dwattr $C$DW$3018, DW_AT_decl_column(0x0d)
$C$DW$207 .dwtag DW_TAG_subprogram, DW_AT_name("operator =")
.dwattr $C$DW$207, DW_AT_declaration
.dwattr $C$DW$207, DW_AT_TI_symbol_name("_ZN21xdc_runtime_Types_VecaSERKS_")
.dwattr $C$DW$207, DW_AT_type(*$C$DW$T$867)
.dwattr $C$DW$207, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$3019 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$3019, DW_AT_type(*$C$DW$T$869)
.dwendtag $C$DW$207
.dwendtag $C$DW$T$871
.dwattr $C$DW$T$871, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/Types.h")
.dwattr $C$DW$T$871, DW_AT_decl_line(0xa4)
.dwattr $C$DW$T$871, DW_AT_decl_column(0x08)
$C$DW$T$867 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$867, DW_AT_type(*$C$DW$T$871)
.dwattr $C$DW$T$867, DW_AT_address_class(0x20)
$C$DW$T$870 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$870, DW_AT_type(*$C$DW$T$867)
.dwattr $C$DW$T$870, DW_AT_language(DW_LANG_C_plus_plus)
$C$DW$3020 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$3020, DW_AT_type(*$C$DW$T$869)
.dwendtag $C$DW$T$870
$C$DW$T$868 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$868, DW_AT_type(*$C$DW$T$871)
$C$DW$T$869 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$869, DW_AT_type(*$C$DW$T$868)
.dwattr $C$DW$T$869, DW_AT_address_class(0x20)
$C$DW$T$2145 .dwtag DW_TAG_typedef, DW_AT_name("xdc_runtime_Types_Vec")
.dwattr $C$DW$T$2145, DW_AT_type(*$C$DW$T$871)
.dwattr $C$DW$T$2145, DW_AT_language(DW_LANG_C_plus_plus)
.dwattr $C$DW$T$2145, DW_AT_decl_file("C:/ti/xdctools_3_32_01_22_core/packages/xdc/runtime/package/package.defs.h")
.dwattr $C$DW$T$2145, DW_AT_decl_line(0x12c)
.dwattr $C$DW$T$2145, DW_AT_decl_column(0x26)
.dwattr $C$DW$CU, DW_AT_language(DW_LANG_C_plus_plus)
;* DWARF CIE ENTRIES *
$C$DW$CIE .dwcie 19
.dwcfi cfa_register, 31
.dwcfi cfa_offset, 0
.dwcfi undefined, 0
.dwcfi undefined, 1
.dwcfi undefined, 2
.dwcfi undefined, 3
.dwcfi undefined, 4
.dwcfi undefined, 5
.dwcfi undefined, 6
.dwcfi undefined, 7
.dwcfi undefined, 8
.dwcfi undefined, 9
.dwcfi same_value, 10
.dwcfi same_value, 11
.dwcfi same_value, 12
.dwcfi same_value, 13
.dwcfi same_value, 14
.dwcfi same_value, 15
.dwcfi undefined, 16
.dwcfi undefined, 17
.dwcfi undefined, 18
.dwcfi undefined, 19
.dwcfi undefined, 20
.dwcfi undefined, 21
.dwcfi undefined, 22
.dwcfi undefined, 23
.dwcfi undefined, 24
.dwcfi undefined, 25
.dwcfi same_value, 26
.dwcfi same_value, 27
.dwcfi same_value, 28
.dwcfi same_value, 29
.dwcfi same_value, 30
.dwcfi same_value, 31
.dwcfi same_value, 32
.dwcfi undefined, 33
.dwcfi undefined, 34
.dwcfi undefined, 35
.dwcfi undefined, 36
.dwcfi undefined, 37
.dwcfi undefined, 38
.dwcfi undefined, 39
.dwcfi undefined, 40
.dwcfi undefined, 41
.dwcfi undefined, 42
.dwcfi undefined, 43
.dwcfi undefined, 44
.dwcfi undefined, 45
.dwcfi undefined, 46
.dwcfi undefined, 47
.dwcfi undefined, 48
.dwcfi undefined, 49
.dwcfi undefined, 50
.dwcfi undefined, 51
.dwcfi undefined, 52
.dwcfi undefined, 53
.dwcfi undefined, 54
.dwcfi undefined, 55
.dwcfi undefined, 56
.dwcfi undefined, 57
.dwcfi undefined, 58
.dwcfi undefined, 59
.dwcfi undefined, 60
.dwcfi undefined, 61
.dwcfi undefined, 62
.dwcfi undefined, 63
.dwcfi undefined, 64
.dwcfi undefined, 65
.dwcfi undefined, 66
.dwcfi undefined, 67
.dwcfi undefined, 68
.dwcfi undefined, 69
.dwcfi undefined, 70
.dwcfi undefined, 71
.dwcfi undefined, 72
.dwcfi undefined, 73
.dwcfi undefined, 74
.dwcfi undefined, 75
.dwcfi undefined, 76
.dwcfi undefined, 77
.dwcfi undefined, 78
.dwcfi undefined, 79
.dwcfi undefined, 80
.dwcfi undefined, 81
.dwcfi undefined, 82
.dwcfi undefined, 83
.dwcfi undefined, 84
.dwcfi undefined, 85
.dwcfi undefined, 86
.dwcfi undefined, 87
.dwcfi undefined, 88
.dwcfi undefined, 89
.dwcfi undefined, 90
.dwcfi undefined, 91
.dwcfi undefined, 92
.dwcfi undefined, 93
.dwcfi undefined, 94
.dwcfi undefined, 95
.dwcfi undefined, 96
.dwcfi undefined, 97
.dwcfi undefined, 98
.dwcfi undefined, 99
.dwcfi undefined, 100
.dwcfi undefined, 101
.dwcfi undefined, 102
.dwcfi undefined, 103
.dwcfi undefined, 104
.dwcfi undefined, 105
.dwcfi undefined, 106
.dwcfi undefined, 107
.dwcfi undefined, 108
.dwcfi undefined, 109
.dwcfi undefined, 110
.dwcfi undefined, 111
.dwcfi undefined, 112
.dwcfi undefined, 113
.dwcfi undefined, 114
.dwcfi undefined, 115
.dwcfi undefined, 116
.dwcfi undefined, 117
.dwcfi undefined, 118
.dwcfi undefined, 119
.dwcfi undefined, 120
.dwcfi undefined, 121
.dwcfi undefined, 122
.dwcfi undefined, 123
.dwcfi undefined, 124
.dwcfi undefined, 125
.dwcfi undefined, 126
.dwcfi undefined, 127
.dwendentry
.dwendtag $C$DW$CU
;* G3 TMS320C6x C/C++ Codegen PC v8.3.2 *
;* Date/Time created: Mon Feb 28 22:33:50 2022 *
.compiler_opts --abi=eabi --array_alignment=8 --c64p_l1d_workaround=off --endian=little --hll_source=on --long_precision_bits=32 --mem_model:code=near --mem_model:const=data --mem_model:data=far --object_format=elf --silicon_version=6600 --symdebug:dwarf --symdebug:dwarf_version=4
;* GLOBAL FILE PARAMETERS *
;* Architecture : TMS320C66xx *
;* Optimization : Enabled at level 3 *
;* Optimizing for : Speed *
;* Based on options: -o3, no -ms *
;* Endian : Little *
;* Interrupt Thrshld : Disabled *
;* Data Access Model : Far *
;* Pipelining : Enabled *
;* Speculate Loads : Enabled with threshold = 0 *
;* Memory Aliases : Presume are aliases (pessimistic) *
;* Debug Info : DWARF Debug *
.asg A15, FP
.asg B14, DP
.asg B15, SP
.global $bss
$C$DW$CU .dwtag DW_TAG_compile_unit
.dwattr $C$DW$CU, DW_AT_name("../App/BMode/Integ/src/test_adap_emph.cpp")
.dwattr $C$DW$CU, DW_AT_producer("TI G3 TMS320C6x C/C++ Codegen PC v8.3.2 Copyright (c) 1996-2018 Texas Instruments Incorporated")
.dwattr $C$DW$CU, DW_AT_TI_version(0x01)
.dwattr $C$DW$CU, DW_AT_comp_dir("C:\git\phx_main\DevProjects\Apollo_DEBUG")
; C:\ti\ti-cgt-c6000_8.3.2\bin\opt6x.exe C:\\Users\\wlaw\\AppData\\Local\\Temp\\{5468E8CF-F7B0-4E66-87B2-7D6A972DC781} C:\\Users\\wlaw\\AppData\\Local\\Temp\\{78471E77-2E79-4F58-9E04-78A46F5D1B89}
.sect ".sect_DDR2_code"
.clink
.global _Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii
$C$DW$1 .dwtag DW_TAG_subprogram
.dwattr $C$DW$1, DW_AT_name("adap_emph")
.dwattr $C$DW$1, DW_AT_low_pc(_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii)
.dwattr $C$DW$1, DW_AT_high_pc(0x00)
.dwattr $C$DW$1, DW_AT_linkage_name("_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii")
.dwattr $C$DW$1, DW_AT_external
.dwattr $C$DW$1, DW_AT_decl_file("../App/BMode/Integ/src/test_adap_emph.cpp")
.dwattr $C$DW$1, DW_AT_decl_line(0x11)
.dwattr $C$DW$1, DW_AT_decl_column(0x06)
.dwattr $C$DW$1, DW_AT_TI_max_frame_size(0x08)
.dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 30,column 1,is_stmt,address _Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii,isa 0
.dwfde $C$DW$CIE, _Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii
$C$DW$4 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$4, DW_AT_name("adap")
.dwattr $C$DW$4, DW_AT_location[DW_OP_reg4]
$C$DW$5 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$5, DW_AT_name("lineBufOrig")
.dwattr $C$DW$5, DW_AT_location[DW_OP_reg20]
$C$DW$6 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$6, DW_AT_name("lineBufFilter")
.dwattr $C$DW$6, DW_AT_location[DW_OP_reg6]
$C$DW$7 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$7, DW_AT_name("range")
.dwattr $C$DW$7, DW_AT_location[DW_OP_reg22]
$C$DW$8 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$8, DW_AT_name("wghtTblS")
.dwattr $C$DW$8, DW_AT_location[DW_OP_reg8]
$C$DW$9 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$9, DW_AT_name("emphTbl")
.dwattr $C$DW$9, DW_AT_location[DW_OP_reg24]
$C$DW$10 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$10, DW_AT_name("sx")
.dwattr $C$DW$10, DW_AT_location[DW_OP_reg10]
$C$DW$11 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$11, DW_AT_name("y")
.dwattr $C$DW$11, DW_AT_location[DW_OP_reg26]
$C$DW$12 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$12, DW_AT_name("info")
.dwattr $C$DW$12, DW_AT_location[DW_OP_reg12]
$C$DW$13 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$13, DW_AT_name("scale")
.dwattr $C$DW$13, DW_AT_location[DW_OP_reg28]
$C$DW$14 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$14, DW_AT_name("alphaI")
.dwattr $C$DW$14, DW_AT_location[DW_OP_breg31 12]
$C$DW$15 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$15, DW_AT_name("betaI")
.dwattr $C$DW$15, DW_AT_location[DW_OP_breg31 16]
$C$DW$16 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$16, DW_AT_name("gammaI")
.dwattr $C$DW$16, DW_AT_location[DW_OP_breg31 20]
; 17 | void adap_emph(ip_int* restrict adap,
; 18 | const ip_int* restrict lineBufOrig,
; 19 | const ip_int* restrict lineBufFilter,
; 20 | const ip_int* restrict range,
; 21 | const tbl_int* restrict wghtTblS,
; 22 | const tbl_int* restrict emphTbl,
; 23 | const Int32 sx,
; 24 | const Int32 y,
; 25 | const ImageInfo* info,
; 26 | const Int32 scale,
; 27 | const Int32 alphaI,
; 28 | const Int32 betaI,
; 29 | const Int32 gammaI)
; 31 | const Int32 scaleT = (1 << (IMAGECALC_ACCURACY)) - 1;
; 32 | const Int32 scale2 = (1 << (IMAGECALC_ACCURACY - 1)) - 1;
; 34 | #pragma MUST_ITERATE(16, MAX_IMAGE_PROCESS_BE_Y_SIZE, 2)
;* FUNCTION NAME: adap_emph(short *, const short *, const short *, const short *, const short *, const short *, int, int, const ImageInfo *, int, int, int, int)*
;* Regs Modified : A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,A10,FP,A16,A17,A18,A19,*
;* A20,A21,A22,A23,A24,A25,A26,A27,A28,A29,A30,A31, *
;* B0,B1,B4,B5,B6,B7,B8,B9,SP,B16,B17,B18,B19,B20, *
;* B21,B22,B23,B24,B25 *
;* Regs Used : A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,A10,A12,FP,A16,A17,A18,*
;* A19,A20,A21,A22,A23,A24,A25,A26,A27,A28,A29,A30, *
;* A31,B0,B1,B3,B4,B5,B6,B7,B8,B9,B10,SP,B16,B17, *
;* B18,B19,B20,B21,B22,B23,B24,B25 *
;* Local Frame Size : 0 Args + 0 Auto + 8 Save = 8 byte *
_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii:
$C$DW$17 .dwtag DW_TAG_variable
.dwattr $C$DW$17, DW_AT_name("info")
.dwattr $C$DW$17, DW_AT_type(*$C$DW$T$34)
.dwattr $C$DW$17, DW_AT_location[DW_OP_reg12]
$C$DW$18 .dwtag DW_TAG_variable
.dwattr $C$DW$18, DW_AT_name("adap")
.dwattr $C$DW$18, DW_AT_type(*$C$DW$T$41)
.dwattr $C$DW$18, DW_AT_location[DW_OP_reg4]
$C$DW$19 .dwtag DW_TAG_variable
.dwattr $C$DW$19, DW_AT_name("range")
.dwattr $C$DW$19, DW_AT_type(*$C$DW$T$44)
.dwattr $C$DW$19, DW_AT_location[DW_OP_regx 0x2e]
$C$DW$20 .dwtag DW_TAG_variable
.dwattr $C$DW$20, DW_AT_name("wghtTblS")
.dwattr $C$DW$20, DW_AT_type(*$C$DW$T$48)
.dwattr $C$DW$20, DW_AT_location[DW_OP_reg8]
$C$DW$21 .dwtag DW_TAG_variable
.dwattr $C$DW$21, DW_AT_name("emphTbl")
.dwattr $C$DW$21, DW_AT_type(*$C$DW$T$48)
.dwattr $C$DW$21, DW_AT_location[DW_OP_reg24]
$C$DW$22 .dwtag DW_TAG_variable
.dwattr $C$DW$22, DW_AT_name("sx")
.dwattr $C$DW$22, DW_AT_type(*$C$DW$T$54)
.dwattr $C$DW$22, DW_AT_location[DW_OP_reg10]
$C$DW$23 .dwtag DW_TAG_variable
.dwattr $C$DW$23, DW_AT_name("alphaI")
.dwattr $C$DW$23, DW_AT_type(*$C$DW$T$54)
.dwattr $C$DW$23, DW_AT_location[DW_OP_regx 0x3a]
$C$DW$24 .dwtag DW_TAG_variable
.dwattr $C$DW$24, DW_AT_name("betaI")
.dwattr $C$DW$24, DW_AT_type(*$C$DW$T$54)
.dwattr $C$DW$24, DW_AT_location[DW_OP_regx 0x39]
$C$DW$25 .dwtag DW_TAG_variable
.dwattr $C$DW$25, DW_AT_name("gammaI")
.dwattr $C$DW$25, DW_AT_type(*$C$DW$T$54)
.dwattr $C$DW$25, DW_AT_location[DW_OP_regx 0x2c]
$C$DW$26 .dwtag DW_TAG_variable
.dwattr $C$DW$26, DW_AT_name("x")
.dwattr $C$DW$26, DW_AT_type(*$C$DW$T$53)
.dwattr $C$DW$26, DW_AT_location[DW_OP_regx 0x2b]
; EXCLUSIVE CPU CYCLES: 11
LDW .D1T2 *A12(12),B18 ; [A_D64P]
LDW .D1T1 *A12(0),A21 ; [A_D64P]
NOP 3 ; [A_L66]
ADD .L2 B10,B18,B9 ; [B_L66]
NOP 1 ; [A_L66]
MPY32 .M1X A21,B9,A21 ; [A_M66]
SHR .S2X A10,1,B9 ; [B_Sb66]
SUB .L2 B9,1,B9 ; [B_L66]
MVC .S2 B9,ILC ; [B_Sb66]
;* SOFTWARE PIPELINE INFORMATION
;* Loop found in file : ../App/BMode/Integ/src/test_adap_emph.cpp
;* Loop source line : 35
;* Loop opening brace source line : 35
;* Loop closing brace source line : 54
;* Loop Unroll Multiple : 2x
;* Known Minimum Trip Count : 8
;* Known Maximum Trip Count : 436
;* Known Max Trip Count Factor : 1
;* Loop Carried Dependency Bound(^) : 9
;* Unpartitioned Resource Bound : 12
;* Partitioned Resource Bound(*) : 12
;* Resource Partition:
;* A-side B-side
;* .L units 4 4
;* .S units 2 4
;* .D units 7 5
;* .M units 8 4
;* .X cross paths 0 0
;* .T address paths 0 0
;* Logical ops (.LS) 0 0 (.L or .S unit)
;* Addition ops (.LSD) 21 12 (.L or .S or .D unit)
;* Bound(.L .S .LS) 3 4
;* Bound(.L .S .D .LS .LSD) 12* 9
;* Searching for software pipeline schedule at ...
;* ii = 12 no sploop: Dynlen of 56 > 48
;* ii = 12 Schedule found with 4 iterations in parallel
;* Register Usage Table:
;* |AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA|BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB|
;* |00000000001111111111222222222233|00000000001111111111222222222233|
;* |01234567890123456789012345678901|01234567890123456789012345678901|
;* 0: |** ** * ****************|* * ** * ******** |
;* 1: | * ** **** ****************|* * ** ********** |
;* 2: | * ** **** ***************|* *** ** ********** |
;* 3: | ********* * **************|** *** ** * ******** |
;* 4: | ****** ** ************** | * **** ******** |
;* 5: | *** ** *** ** *********** | * **** ******** |
;* 6: |***** * *** ************** *|* **** ******** |
;* 7: |******* *** ****************|* ** *** ******** |
;* 8: | * **** ** ****************| * **** ********** |
;* 9: |** ** * ** ****************| ****** ********** |
;* 10: |* ** * ** ****************|* ****** ******** |
;* 11: |* ** ** *************** | * ** * ******** |
;* Done
;* Loop will be splooped
;* Collapsed epilog stages : 0
;* Collapsed prolog stages : 0
;* Minimum required memory pad : 0 bytes
;* Minimum safe trip count : 1 (after unrolling)
;* Min. prof. trip count (est.) : 3 (after unrolling)
;* Mem bank conflicts/iter(est.) : { min 0.000, est 0.125, max 1.000 }
;* Mem bank perf. penalty (est.) : 1.0%
;* Effective ii : { min 12.00, est 12.13, max 13.00 }
;* Total cycles (est.) : 36 + trip_cnt * 12 = Between 132 and 5268
;* SETUP CODE
;* MV B25,A21 ; []
;* ADD 6,A21,A21 ; []
;* ADD 4,B25,B25 ; []
;* MV B24,B18 ; []
;* ADD 6,B18,B18 ; []
;* ADD 4,B24,B24 ; []
;* MV A28,B9 ; [] Define a LI twin register
;* MV A22,B8 ; [] Define a LI twin register
;* SINGLE SCHEDULED ITERATION
;* $C$C127:
;* 0 ADD .D1 A22,A29,A19 ; [A_D64P] |97|
;* 1 LDH .D1T1 *+A25[A19],A31 ; [A_D64P] |97|
;* 2 ADD .L1 A29,A22,A5 ; [A_L66] |97|
;* || LDH .D1T1 *A21++(4),A30 ; [A_D64P] |97|
;* 3 NOP 2 ; [A_L66]
;* 5 LDH .D2T2 *B25++(4),B7 ; [B_D64P] |97|
;* || ADD .S1 1,A5,A20 ; [A_S66] |97|
;* 6 CMPLT .L1 A31,0,A1 ; [A_L66] |97|
;* || LDH .D1T1 *+A25[A20],A16 ; [A_D64P] |97|
;* 7 LDH .D2T1 *B24++(4),A1 ; [B_D64P] |97|
;* 8 NOP 1 ; [A_L66]
;* 9 XOR .L1 1,A1,A3 ; [A_L66] |97|
;* || ADD .S1 2,A22,A22 ; [A_S66] |35| Define a twin register
;* 10 MPY .M1 A3,A31,A31 ; [A_M66] |97|
;* || MPYLI .M2X B7,A23,B7:B6 ; [B_M66] |97|
;* 11 CMPLT .L1 A16,0,A4 ; [A_L66] |97|
;* || LDH .D2T2 *B18++(4),B7 ; [B_D64P] |97|
;* 12 MV .S1 A19,A9 ; [A_S66] |97| Split a long life (split-join)
;* || MPYLI .M1X A1,B20,A7:A6 ; [A_M66] |97|
;* || XOR .L1 1,A4,A7 ; [A_L66] |97|
;* 13 MV .L2X A31,B5 ; [B_L66] |97| Define a twin register
;* || MPY .M1 A7,A16,A2 ; [A_M66] |97|
;* 14 CMPGT .L2 B5,B9,B1 ; [B_L66] |97|
;* 15 [ B1] MV .D1 A28,A4 ; [A_D64P] |97|
;* || [!B1] MV .S1 A31,A4 ; [A_S66] |97|
;* || MPYLI .M1 A30,A23,A7:A6 ; [A_M66] |97|
;* 16 LDH .D1T1 *+A24[A4],A6 ; [A_D64P] |97|
;* || MV .L2X A2,B4 ; [B_L66] |97| Define a twin register
;* || MPYLI .M2 B7,B20,B5:B4 ; [B_M66] |97|
;* 17 MV .D1 A20,A18 ; [A_D64P] |97| Split a long life (split-join)
;* || CMPGT .L2 B4,B9,B0 ; [B_L66] |97|
;* 18 MPYLI .M1X A1,B21,A5:A4 ; [A_M66] |97|
;* || ADD .L2X B6,A6,B5 ; [B_L66] |97|
;* || [ B0] MV .S1 A28,A5 ; [A_S66] |97|
;* 19 SHR .S2 B5,11,B17 ; [B_Sb66] |97|
;* || [!B0] MV .L1 A2,A5 ; [A_L66] |97|
;* 20 LDH .D1T1 *+A24[A5],A6 ; [A_D64P] |97|
;* || ADD .L2X A6,B4,B4 ; [B_L66] |97|
;* 21 MPYLI .M1X A6,B17,A5:A4 ; [A_M66] |97|
;* || MPYLI .M2 B7,B21,B5:B4 ; [B_M66] |97|
;* 22 SHR .S1 A4,11,A3 ; [A_S66] |97|
;* || SUB .L1 A27,A6,A4 ; [A_L66] |97|
;* 23 MV .D1 A9,A8 ; [A_D64P] |97| Split a long life (split-join)
;* || MPY32 .M1 A4,A3,A6 ; [A_M66] |97|
;* 24 SHR .S2 B4,11,B17 ; [B_Sb66] |97|
;* 25 SUB .L1 A27,A6,A7 ; [A_L66] |97|
;* 26 SHR .S2 B4,11,B5 ; [B_Sb66] |97|
;* || MPYLI .M1X A6,B17,A5:A4 ; [A_M66] |97|
;* 27 ADD .L1 A4,A6,A17 ; [A_L66] |97|
;* || MPY32 .M2X A7,B5,B4 ; [B_M66] |97|
;* 28 SHR .S1 A17,15,A10 ; [A_S66] |97|
;* || MV .L1 A18,A17 ; [A_L66] |97| Split a long life (split-join)
;* 29 CMPLT .L1X A10,B23,A0 ; [A_L66] |97|
;* 30 NOP 1 ; [A_L66]
;* 31 [ A0] MV .D1X B23,A4 ; [A_D64P] |97|
;* || [!A0] MV .S1 A10,A4 ; [A_S66] |97|
;* || ADD .L2X A4,B4,B6 ; [B_L66] |97|
;* 32 CMPGT .L1 A4,A28,A0 ; [A_L66] |97|
;* || SHR .S2 B6,15,B5 ; [B_Sb66] |97|
;* 33 [!A0] MV .S2X A4,B19 ; [B_Sb66] |97|
;* || CMPLT .L2 B5,B23,B0 ; [B_L66] |97|
;* 34 [ B0] MV .L2 B23,B16 ; [B_L66] |97|
;* || [!B0] MV .S2 B5,B16 ; [B_Sb66] |97|
;* 35 MV .S1 A8,A3 ; [A_S66] |97| Split a long life (split-join)
;* || CMPGT .L2X B16,A28,B0 ; [B_L66] |97|
;* 36 [ A0] MV .L2X A28,B19 ; [B_L66] |97|
;* 37 NOP 1 ; [A_L66]
;* 38 MV .S1 A17,A16 ; [A_S66] |97| Split a long life (split-join)
;* || [ B0] MV .D2X A28,B4 ; [B_D64P] |97|
;* 39 LDH .D2T2 *+B22[B19],B16 ; [B_D64P] |97|
;* || [!B0] MV .L2 B16,B4 ; [B_L66] |97|
;* 40 LDH .D2T2 *+B22[B4],B6 ; [B_D64P] |97|
;* 41 NOP 4 ; [A_L66]
;* 45 STH .D1T2 B16,*+A26[A3] ; [A_D64P] |97|
;* 46 STH .D1T2 B6,*+A26[A16] ; [A_D64P] |97|
;* || ADD .D2 2,B8,B8 ; [B_D64P] |35|
;* || SPBR $C$C127 ; []
;* 47 NOP 1 ; [A_L66]
;* 48 ; BRANCHCC OCCURS {$C$C127} ; [] |35|
$C$L1: ; PIPED LOOP PROLOG
; EXCLUSIVE CPU CYCLES: 37
.dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 35,column 18,is_stmt,isa 0
; 35 | for (Int32 x = 0; x < sx; ++x) {
; 36 | Int32 idx = GetViewIndex(x, y, info);
; 37 | Int32 value = lineBufOrig[x];
; 39 | Int32 edge = range[idx];
; 40 | edge = RangeClip(edge, 0, scale2);
; 42 | Int32 w = wghtTblS[edge];
; 44 | Int32 value2 = lineBufFilter[x];
; 46 | Int32 wb = (1 << IMAGECALC_ACCURACY) - w;
; 47 | Int32 tmp2 = (value * alphaI) >> 11;
; 48 | Int32 tmp3 = (value * betaI + value2 * gammaI) >> 11;
; 49 | Int32 tmp = (tmp2 * wb + tmp3 * w) >> IMAGECALC_ACCURACY;
; 50 | tmp = RangeClip(tmp, -scale2 - 1, scale2);//actually image range is
; | +2^15~-2^15, but original algorithm is clip under 2^14. It will help i
; | mage saturate.
; 52 | tmp = emphTbl[tmp + scaleT + 1];
; 53 | adap[idx] = tmp;
; 59 |
SPLOOPD 12 ;48 ; [A_L66] (P)
|| ZERO .D1 A22 ; [A_D64P] |35|
|| ADD .S1X B18,A21,A29 ; [A_S66]
$C$L2: ; PIPED LOOP KERNEL
; EXCLUSIVE CPU CYCLES: 12
.dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 30,column 1,is_stmt,isa 0
SPMASK ; []
||^ MV .L1X B6,A25 ; [A_L66] |30|
|| ADD .D1 A22,A29,A19 ; [A_D64P] |97| (P) <0,0>
.dwpsn file "C:/git/phx_main/DevProjects/App/BMode/ClearVisualization/common/include/nam_tool.h",line 97,column 1,is_stmt,isa 0
; 60 |
; 61 |
; 62 |
; 63 |
; 64 |
; 65 |
; 66 |
; 67 |
; 68 |
; 69 |
; 70 |
; 71 |
; 72 |
; 73 |
; 74 |
; 75 |
; 76 |
; 77 |
; 78 |
; 79 |
; 80 |
; 81 |
; 82 |
; 83 |
; 84 |
; 85 |
; 86 |
; 87 |
; 88 |
; 89 |
; 90 |
; 91 |
; 92 |
; 93 |
; 94 |
; 95 |
; 96 |
; 97 |
SPMASK ; []
||^ ADD .L1 2,A6,A21 ; [A_L66]
|| LDH .D1T1 *+A25[A19],A31 ; [A_D64P] |97| (P) <0,1>
LDH .D1T1 *A21++(4),A30 ; [A_D64P] |97| (P) <0,2>
|| ADD .L1 A29,A22,A5 ; [A_L66] |97| (P) <0,2>
NOP 1 ; [A_L66]
SPMASK ; []
||^ MV .L2X A6,B25 ; [B_L66]
||^ MV .L1X SP,FP ; [A_L66] |30|
||^ STW .D2T1 FP,*SP++(-8) ; [B_D64P] |30|
.dwcfi save_reg_to_mem, 32, 0
.dwcfi cfa_offset, 8
SPMASK ; []
||^ LDW .D1T1 *FP(12),A23 ; [A_D64P] |30|
|| LDH .D2T2 *B25++(4),B7 ; [B_D64P] |97| (P) <0,5>
|| ADD .S1 1,A5,A20 ; [A_S66] |97| (P) <0,5>
SPMASK ; []
||^ MV .L2 B4,B24 ; [B_L66]
|| LDH .D1T1 *+A25[A20],A16 ; [A_D64P] |97| (P) <0,6>
|| CMPLT .L1 A31,0,A1 ; [A_L66] |97| (P) <0,6>
SPMASK ; []
||^ LDW .D1T2 *FP(8),B20 ; [A_D64P] |30|
|| LDH .D2T1 *B24++(4),A1 ; [B_D64P] |97| (P) <0,7>
NOP 1 ; [A_L66]
.dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 35,column 31,is_stmt,isa 0
ADD .S1 2,A22,A22 ; [A_S66] |35| (P) <0,9> Define a twin register
|| XOR .L1 1,A1,A3 ; [A_L66] |97| (P) <0,9>
SPMASK ; []
||^ ADD .L2 2,B4,B18 ; [B_L66]
||^ MVK .S1 16383,A28 ; [A_S66]
||^ LDW .D1T2 *FP(4),B21 ; [A_D64P] |30|
|| MPYLI .M2X B7,A23,B7:B6 ; [B_M66] |97| (P) <0,10>
|| MPY .M1 A3,A31,A31 ; [A_M66] |97| (P) <0,10>
SPMASK ; []
||^ MV .S1 A4,A26 ; [A_S66]
|| LDH .D2T2 *B18++(4),B7 ; [B_D64P] |97| (P) <0,11>
|| CMPLT .L1 A16,0,A4 ; [A_L66] |97| (P) <0,11>
SPMASK ; []
||^ MV .L2X A28,B9 ; [B_L66] Define a LI twin register
|| XOR .L1 1,A4,A7 ; [A_L66] |97| (P) <0,12>
|| MV .S1 A19,A9 ; [A_S66] |97| (P) <0,12> Split a long life (split-join)
|| MPYLI .M1X A1,B20,A7:A6 ; [A_M66] |97| (P) <0,12>
MV .L2X A31,B5 ; [B_L66] |97| (P) <0,13> Define a twin register
|| MPY .M1 A7,A16,A2 ; [A_M66] |97| (P) <0,13>
CMPGT .L2 B5,B9,B1 ; [B_L66] |97| (P) <0,14>
SPMASK ; []
||^ MV .L1 A8,A24 ; [A_L66]
|| MPYLI .M1 A30,A23,A7:A6 ; [A_M66] |97| (P) <0,15>
|| [!B1] MV .S1 A31,A4 ; [A_S66] |97| (P) <0,15>
|| [ B1] MV .D1 A28,A4 ; [A_D64P] |97| (P) <0,15>
MPYLI .M2 B7,B20,B5:B4 ; [B_M66] |97| (P) <0,16>
|| LDH .D1T1 *+A24[A4],A6 ; [A_D64P] |97| (P) <0,16>
|| MV .L2X A2,B4 ; [B_L66] |97| (P) <0,16> Define a twin register
MV .D1 A20,A18 ; [A_D64P] |97| (P) <0,17> Split a long life (split-join)
|| CMPGT .L2 B4,B9,B0 ; [B_L66] |97| (P) <0,17>
MPYLI .M1X A1,B21,A5:A4 ; [A_M66] |97| (P) <0,18>
|| [ B0] MV .S1 A28,A5 ; [A_S66] |97| (P) <0,18>
|| ADD .L2X B6,A6,B5 ; [B_L66] |97| (P) <0,18>
SPMASK ; []
||^ ZERO .S1 A27 ; [A_S66]
|| SHR .S2 B5,11,B17 ; [B_Sb66] |97| (P) <0,19>
|| [!B0] MV .L1 A2,A5 ; [A_L66] |97| (P) <0,19>
SPMASK ; []
||^ SET .S1 A27,15,15,A27 ; [A_S66]
|| ADD .L2X A6,B4,B4 ; [B_L66] |97| (P) <0,20>
|| LDH .D1T1 *+A24[A5],A6 ; [A_D64P] |97| (P) <0,20>
MPYLI .M2 B7,B21,B5:B4 ; [B_M66] |97| (P) <0,21>
|| MPYLI .M1X A6,B17,A5:A4 ; [A_M66] |97| (P) <0,21>
SPMASK ; []
||^ STW .D1T1 A10,*FP(-4) ; [A_D64P]
|| SHR .S1 A4,11,A3 ; [A_S66] |97| (P) <0,22>
|| SUB .L1 A27,A6,A4 ; [A_L66] |97| (P) <0,22>
.dwcfi save_reg_to_mem, 10, -4
MV .D1 A9,A8 ; [A_D64P] |97| (P) <0,23> Split a long life (split-join)
|| MPY32 .M1 A4,A3,A6 ; [A_M66] |97| (P) <0,23>
SHR .S2 B4,11,B17 ; [B_Sb66] |97| (P) <0,24>
SUB .L1 A27,A6,A7 ; [A_L66] |97| (P) <0,25>
SHR .S2 B4,11,B5 ; [B_Sb66] |97| (P) <0,26>
|| MPYLI .M1X A6,B17,A5:A4 ; [A_M66] |97| (P) <0,26>
SPMASK ; []
||^ MVK .S2 -16384,B23 ; [B_Sb66]
|| ADD .L1 A4,A6,A17 ; [A_L66] |97| (P) <0,27>
|| MPY32 .M2X A7,B5,B4 ; [B_M66] |97| (P) <0,27>
MV .L1 A18,A17 ; [A_L66] |97| (P) <0,28> Split a long life (split-join)
|| SHR .S1 A17,15,A10 ; [A_S66] |97| (P) <0,28>
CMPLT .L1X A10,B23,A0 ; [A_L66] |97| (P) <0,29>
SPMASK ; []
||^ MVK .S2 8192,B22 ; [B_Sb66]
[!A0] MV .S1 A10,A4 ; [A_S66] |97| (P) <0,31>
|| [ A0] MV .D1X B23,A4 ; [A_D64P] |97| (P) <0,31>
|| ADD .L2X A4,B4,B6 ; [B_L66] |97| (P) <0,31>
CMPGT .L1 A4,A28,A0 ; [A_L66] |97| (P) <0,32>
|| SHR .S2 B6,15,B5 ; [B_Sb66] |97| (P) <0,32>
CMPLT .L2 B5,B23,B0 ; [B_L66] |97| (P) <0,33>
|| [!A0] MV .S2X A4,B19 ; [B_Sb66] |97| (P) <0,33>
SPMASK ; []
||^ ADDAD .D2 B8,B22,B22 ; [B_D64P]
|| [ B0] MV .L2 B23,B16 ; [B_L66] |97| (P) <0,34>
|| [!B0] MV .S2 B5,B16 ; [B_Sb66] |97| (P) <0,34>
SPMASK ; []
||^ ZERO .S2 B8 ; [B_Sb66] |35|
|| MV .S1 A8,A3 ; [A_S66] |97| (P) <0,35> Split a long life (split-join)
|| CMPGT .L2X B16,A28,B0 ; [B_L66] |97| (P) <0,35>
[ A0] MV .L2X A28,B19 ; [B_L66] |97| <0,36>
NOP 1 ; [A_L66]
MV .S1 A17,A16 ; [A_S66] |97| <0,38> Split a long life (split-join)
|| [ B0] MV .D2X A28,B4 ; [B_D64P] |97| <0,38>
[!B0] MV .L2 B16,B4 ; [B_L66] |97| <0,39>
|| LDH .D2T2 *+B22[B19],B16 ; [B_D64P] |97| <0,39>
LDH .D2T2 *+B22[B4],B6 ; [B_D64P] |97| <0,40>
NOP 4 ; [A_L66]
STH .D1T2 B16,*+A26[A3] ; [A_D64P] |97| <0,45>
SPKERNEL 1,0 ; []
|| ADD .D2 2,B8,B8 ; [B_D64P] |35| <0,46>
|| STH .D1T2 B6,*+A26[A16] ; [A_D64P] |97| <0,46>
$C$L3: ; PIPED LOOP EPILOG
; EXCLUSIVE CPU CYCLES: 35
NOP 8 ; [A_L66]
.dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 55,column 1,is_stmt,isa 0
LDW .D1T1 *FP(-4),A10 ; [A_D64P] |55|
.dwcfi restore_reg, 10
NOP 7 ; [A_L66]
MV .L2X FP,SP ; [B_L66] |55|
|| LDW .D1T1 *FP(0),FP ; [A_D64P] |55|
.dwcfi restore_reg, 32
$C$DW$27 .dwtag DW_TAG_TI_branch
.dwattr $C$DW$27, DW_AT_low_pc(0x00)
.dwattr $C$DW$27, DW_AT_TI_return
RETNOP B3,5 ; [] |55|
; BRANCH OCCURS {B3} ; [] |55|
.dwattr $C$DW$1, DW_AT_TI_end_file("../App/BMode/Integ/src/test_adap_emph.cpp")
.dwattr $C$DW$1, DW_AT_TI_end_line(0x37)
.dwattr $C$DW$1, DW_AT_TI_end_column(0x01)
.dwendentry
.dwendtag $C$DW$1
;* BUILD ATTRIBUTES *
.battr "TI", Tag_File, 1, Tag_Long_Precision_Bits(2)
.battr "TI", Tag_File, 1, Tag_Bitfield_layout(2)
.battr "TI", Tag_File, 1, Tag_ABI_enum_size(3)
.battr "c6xabi", Tag_File, 1, Tag_ABI_wchar_t(1)
.battr "c6xabi", Tag_File, 1, Tag_ABI_array_object_alignment(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_array_object_align_expected(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_PIC(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_PID(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_DSBT(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_stack_align_needed(0)
.battr "c6xabi", Tag_File, 1, Tag_ABI_stack_align_preserved(0)
.battr "TI", Tag_File, 1, Tag_Tramps_Use_SOC(1)
$C$DW$CIE .dwcie 19
.dwendentry
.dwendtag $C$DW$CU
;* TYPE INFORMATION *
$C$DW$TU$32 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$32
$C$DW$T$32 .dwtag DW_TAG_structure_type
.dwattr $C$DW$T$32, DW_AT_name("ImageInfo")
.dwattr $C$DW$T$32, DW_AT_byte_size(0x18)
$C$DW$28 .dwtag DW_TAG_member
.dwattr $C$DW$28, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$28, DW_AT_name("xSize")
.dwattr $C$DW$28, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$28, DW_AT_decl_file("C:\git\phx_main\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$28, DW_AT_decl_line(0x26)
.dwattr $C$DW$28, DW_AT_decl_column(0x07)
$C$DW$29 .dwtag DW_TAG_member
.dwattr $C$DW$29, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$29, DW_AT_name("ySize")
.dwattr $C$DW$29, DW_AT_data_member_location[DW_OP_plus_uconst 0x4]
.dwattr $C$DW$29, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$29, DW_AT_decl_file("C:\git\phx_main\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$29, DW_AT_decl_line(0x27)
.dwattr $C$DW$29, DW_AT_decl_column(0x07)
$C$DW$30 .dwtag DW_TAG_member
.dwattr $C$DW$30, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$30, DW_AT_name("scaleBits")
.dwattr $C$DW$30, DW_AT_data_member_location[DW_OP_plus_uconst 0x8]
.dwattr $C$DW$30, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$30, DW_AT_decl_file("C:\git\phx_main\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$30, DW_AT_decl_line(0x28)
.dwattr $C$DW$30, DW_AT_decl_column(0x07)
$C$DW$31 .dwtag DW_TAG_member
.dwattr $C$DW$31, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$31, DW_AT_name("margin")
.dwattr $C$DW$31, DW_AT_data_member_location[DW_OP_plus_uconst 0xc]
.dwattr $C$DW$31, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$31, DW_AT_decl_file("C:\git\phx_main\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$31, DW_AT_decl_line(0x29)
.dwattr $C$DW$31, DW_AT_decl_column(0x07)
$C$DW$32 .dwtag DW_TAG_member
.dwattr $C$DW$32, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$32, DW_AT_name("xRotation")
.dwattr $C$DW$32, DW_AT_data_member_location[DW_OP_plus_uconst 0x10]
.dwattr $C$DW$32, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$32, DW_AT_decl_file("C:\git\phx_main\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$32, DW_AT_decl_line(0x2a)
.dwattr $C$DW$32, DW_AT_decl_column(0x07)
$C$DW$33 .dwtag DW_TAG_member
.dwattr $C$DW$33, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$33, DW_AT_name("yRotation")
.dwattr $C$DW$33, DW_AT_data_member_location[DW_OP_plus_uconst 0x14]
.dwattr $C$DW$33, DW_AT_accessibility(DW_ACCESS_public)
.dwattr $C$DW$33, DW_AT_decl_file("C:\git\phx_main\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$33, DW_AT_decl_line(0x2b)
.dwattr $C$DW$33, DW_AT_decl_column(0x07)
$C$DW$34 .dwtag DW_TAG_subprogram
.dwattr $C$DW$34, DW_AT_name("operator =")
.dwattr $C$DW$34, DW_AT_declaration
.dwattr $C$DW$34, DW_AT_linkage_name("_ZN9ImageInfoaSERKS_")
.dwattr $C$DW$34, DW_AT_type(*$C$DW$T$27)
.dwattr $C$DW$34, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$35 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$35, DW_AT_type(*$C$DW$T$29)
.dwendtag $C$DW$34
$C$DW$36 .dwtag DW_TAG_subprogram
.dwattr $C$DW$36, DW_AT_name("operator =")
.dwattr $C$DW$36, DW_AT_declaration
.dwattr $C$DW$36, DW_AT_linkage_name("_ZN9ImageInfoaSEOS_")
.dwattr $C$DW$36, DW_AT_type(*$C$DW$T$27)
.dwattr $C$DW$36, DW_AT_accessibility(DW_ACCESS_public)
$C$DW$37 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$37, DW_AT_type(*$C$DW$T$27)
.dwendtag $C$DW$36
.dwattr $C$DW$T$32, DW_AT_decl_file("C:\git\phx_main\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h")
.dwattr $C$DW$T$32, DW_AT_decl_line(0x24)
.dwattr $C$DW$T$32, DW_AT_decl_column(0x08)
.dwendtag $C$DW$T$32
.dwendtag $C$DW$TU$32
$C$DW$TU$28 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$28
$C$DW$T$28 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$28, DW_AT_type(*$C$DW$T$32)
.dwendtag $C$DW$TU$28
$C$DW$TU$29 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$29
$C$DW$T$29 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$29, DW_AT_type(*$C$DW$T$28)
.dwattr $C$DW$T$29, DW_AT_address_class(0x20)
.dwendtag $C$DW$TU$29
$C$DW$TU$34 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$34
$C$DW$T$34 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$34, DW_AT_type(*$C$DW$T$28)
.dwattr $C$DW$T$34, DW_AT_address_class(0x20)
.dwendtag $C$DW$TU$34
$C$DW$TU$27 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$27
$C$DW$T$27 .dwtag DW_TAG_reference_type
.dwattr $C$DW$T$27, DW_AT_type(*$C$DW$T$32)
.dwattr $C$DW$T$27, DW_AT_address_class(0x20)
.dwendtag $C$DW$TU$27
$C$DW$TU$30 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$30
$C$DW$T$30 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$30, DW_AT_type(*$C$DW$T$27)
$C$DW$38 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$38, DW_AT_type(*$C$DW$T$29)
.dwendtag $C$DW$T$30
.dwendtag $C$DW$TU$30
$C$DW$TU$31 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$31
$C$DW$T$31 .dwtag DW_TAG_subroutine_type
.dwattr $C$DW$T$31, DW_AT_type(*$C$DW$T$27)
$C$DW$39 .dwtag DW_TAG_formal_parameter
.dwattr $C$DW$39, DW_AT_type(*$C$DW$T$27)
.dwendtag $C$DW$T$31
.dwendtag $C$DW$TU$31
$C$DW$TU$2 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$2
$C$DW$T$2 .dwtag DW_TAG_unspecified_type
.dwattr $C$DW$T$2, DW_AT_name("void")
$C$DW$TU$4 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$4
$C$DW$T$4 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$4, DW_AT_encoding(DW_ATE_boolean)
.dwattr $C$DW$T$4, DW_AT_name("bool")
.dwattr $C$DW$T$4, DW_AT_byte_size(0x01)
.dwendtag $C$DW$TU$4
$C$DW$TU$5 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$5
$C$DW$T$5 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$5, DW_AT_encoding(DW_ATE_signed_char)
.dwattr $C$DW$T$5, DW_AT_name("signed char")
.dwattr $C$DW$T$5, DW_AT_byte_size(0x01)
.dwendtag $C$DW$TU$5
$C$DW$TU$6 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$6
$C$DW$T$6 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$6, DW_AT_encoding(DW_ATE_unsigned_char)
.dwattr $C$DW$T$6, DW_AT_name("unsigned char")
.dwattr $C$DW$T$6, DW_AT_byte_size(0x01)
.dwendtag $C$DW$TU$6
$C$DW$TU$7 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$7
$C$DW$T$7 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$7, DW_AT_encoding(DW_ATE_signed_char)
.dwattr $C$DW$T$7, DW_AT_name("wchar_t")
.dwattr $C$DW$T$7, DW_AT_byte_size(0x02)
.dwendtag $C$DW$TU$7
$C$DW$TU$8 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$8
$C$DW$T$8 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$8, DW_AT_encoding(DW_ATE_signed)
.dwattr $C$DW$T$8, DW_AT_name("short")
.dwattr $C$DW$T$8, DW_AT_byte_size(0x02)
.dwendtag $C$DW$TU$8
$C$DW$TU$39 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$39
$C$DW$T$39 .dwtag DW_TAG_typedef
.dwattr $C$DW$T$39, DW_AT_name("ip_int")
.dwattr $C$DW$T$39, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$T$39, DW_AT_decl_file("C:\git\phx_main\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_types.h")
.dwattr $C$DW$T$39, DW_AT_decl_line(0x0f)
.dwattr $C$DW$T$39, DW_AT_decl_column(0x0f)
.dwendtag $C$DW$TU$39
$C$DW$TU$40 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$40
$C$DW$T$40 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$40, DW_AT_type(*$C$DW$T$39)
.dwattr $C$DW$T$40, DW_AT_address_class(0x20)
.dwendtag $C$DW$TU$40
$C$DW$TU$41 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$41
$C$DW$T$41 .dwtag DW_TAG_restrict_type
.dwattr $C$DW$T$41, DW_AT_type(*$C$DW$T$40)
.dwendtag $C$DW$TU$41
$C$DW$TU$42 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$42
$C$DW$T$42 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$42, DW_AT_type(*$C$DW$T$39)
.dwendtag $C$DW$TU$42
$C$DW$TU$43 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$43
$C$DW$T$43 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$43, DW_AT_type(*$C$DW$T$42)
.dwattr $C$DW$T$43, DW_AT_address_class(0x20)
.dwendtag $C$DW$TU$43
$C$DW$TU$44 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$44
$C$DW$T$44 .dwtag DW_TAG_restrict_type
.dwattr $C$DW$T$44, DW_AT_type(*$C$DW$T$43)
.dwendtag $C$DW$TU$44
$C$DW$TU$45 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$45
$C$DW$T$45 .dwtag DW_TAG_typedef
.dwattr $C$DW$T$45, DW_AT_name("tbl_int")
.dwattr $C$DW$T$45, DW_AT_type(*$C$DW$T$8)
.dwattr $C$DW$T$45, DW_AT_decl_file("C:\git\phx_main\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_types.h")
.dwattr $C$DW$T$45, DW_AT_decl_line(0x11)
.dwattr $C$DW$T$45, DW_AT_decl_column(0x0f)
.dwendtag $C$DW$TU$45
$C$DW$TU$46 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$46
$C$DW$T$46 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$46, DW_AT_type(*$C$DW$T$45)
.dwendtag $C$DW$TU$46
$C$DW$TU$47 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$47
$C$DW$T$47 .dwtag DW_TAG_pointer_type
.dwattr $C$DW$T$47, DW_AT_type(*$C$DW$T$46)
.dwattr $C$DW$T$47, DW_AT_address_class(0x20)
.dwendtag $C$DW$TU$47
$C$DW$TU$48 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$48
$C$DW$T$48 .dwtag DW_TAG_restrict_type
.dwattr $C$DW$T$48, DW_AT_type(*$C$DW$T$47)
.dwendtag $C$DW$TU$48
$C$DW$TU$9 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$9
$C$DW$T$9 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$9, DW_AT_encoding(DW_ATE_unsigned)
.dwattr $C$DW$T$9, DW_AT_name("unsigned short")
.dwattr $C$DW$T$9, DW_AT_byte_size(0x02)
.dwendtag $C$DW$TU$9
$C$DW$TU$10 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$10
$C$DW$T$10 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$10, DW_AT_encoding(DW_ATE_signed)
.dwattr $C$DW$T$10, DW_AT_name("int")
.dwattr $C$DW$T$10, DW_AT_byte_size(0x04)
.dwendtag $C$DW$TU$10
$C$DW$TU$49 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$49
$C$DW$T$49 .dwtag DW_TAG_typedef
.dwattr $C$DW$T$49, DW_AT_name("__int32_t")
.dwattr $C$DW$T$49, DW_AT_type(*$C$DW$T$10)
.dwattr $C$DW$T$49, DW_AT_decl_file("C:/ti/ti-cgt-c6000_8.3.2/include/machine/_types.h")
.dwattr $C$DW$T$49, DW_AT_decl_line(0x62)
.dwattr $C$DW$T$49, DW_AT_decl_column(0x0f)
.dwendtag $C$DW$TU$49
$C$DW$TU$50 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$50
$C$DW$T$50 .dwtag DW_TAG_typedef
.dwattr $C$DW$T$50, DW_AT_name("__int_least32_t")
.dwattr $C$DW$T$50, DW_AT_type(*$C$DW$T$49)
.dwattr $C$DW$T$50, DW_AT_decl_file("C:/ti/ti-cgt-c6000_8.3.2/include/machine/_types.h")
.dwattr $C$DW$T$50, DW_AT_decl_line(0x7f)
.dwattr $C$DW$T$50, DW_AT_decl_column(0x13)
.dwendtag $C$DW$TU$50
$C$DW$TU$51 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$51
$C$DW$T$51 .dwtag DW_TAG_typedef
.dwattr $C$DW$T$51, DW_AT_name("int_least32_t")
.dwattr $C$DW$T$51, DW_AT_type(*$C$DW$T$50)
.dwattr $C$DW$T$51, DW_AT_decl_file("C:/ti/ti-cgt-c6000_8.3.2/include/sys/stdint.h")
.dwattr $C$DW$T$51, DW_AT_decl_line(0x2a)
.dwattr $C$DW$T$51, DW_AT_decl_column(0x1a)
.dwendtag $C$DW$TU$51
$C$DW$TU$52 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$52
$C$DW$T$52 .dwtag DW_TAG_typedef
.dwattr $C$DW$T$52, DW_AT_name("xdc_Int32")
.dwattr $C$DW$T$52, DW_AT_type(*$C$DW$T$51)
.dwattr $C$DW$T$52, DW_AT_decl_file("C:/ti/bios_6_76_03_01/packages/ti/targets/std.h")
.dwattr $C$DW$T$52, DW_AT_decl_line(0x7a)
.dwattr $C$DW$T$52, DW_AT_decl_column(0x19)
.dwendtag $C$DW$TU$52
$C$DW$TU$53 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$53
$C$DW$T$53 .dwtag DW_TAG_typedef
.dwattr $C$DW$T$53, DW_AT_name("Int32")
.dwattr $C$DW$T$53, DW_AT_type(*$C$DW$T$52)
.dwattr $C$DW$T$53, DW_AT_decl_file("C:/ti/xdctools_3_55_02_22_core/packages/xdc/std.h")
.dwattr $C$DW$T$53, DW_AT_decl_line(0xf5)
.dwattr $C$DW$T$53, DW_AT_decl_column(0x19)
.dwendtag $C$DW$TU$53
$C$DW$TU$54 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$54
$C$DW$T$54 .dwtag DW_TAG_const_type
.dwattr $C$DW$T$54, DW_AT_type(*$C$DW$T$53)
.dwendtag $C$DW$TU$54
$C$DW$TU$11 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$11
$C$DW$T$11 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$11, DW_AT_encoding(DW_ATE_unsigned)
.dwattr $C$DW$T$11, DW_AT_name("unsigned int")
.dwattr $C$DW$T$11, DW_AT_byte_size(0x04)
.dwendtag $C$DW$TU$11
$C$DW$TU$88 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$88
$C$DW$T$88 .dwtag DW_TAG_typedef
.dwattr $C$DW$T$88, DW_AT_name("uint32")
.dwattr $C$DW$T$88, DW_AT_type(*$C$DW$T$11)
.dwattr $C$DW$T$88, DW_AT_decl_file("C:\git\phx_main\DevProjects\App\include\SonoSiteM2_types.h")
.dwattr $C$DW$T$88, DW_AT_decl_line(0x17)
.dwattr $C$DW$T$88, DW_AT_decl_column(0x19)
.dwendtag $C$DW$TU$88
$C$DW$TU$12 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$12
$C$DW$T$12 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$12, DW_AT_encoding(DW_ATE_signed)
.dwattr $C$DW$T$12, DW_AT_name("__int40_t")
.dwattr $C$DW$T$12, DW_AT_byte_size(0x08)
.dwattr $C$DW$T$12, DW_AT_bit_size(0x28)
.dwattr $C$DW$T$12, DW_AT_data_bit_offset(0x18)
.dwendtag $C$DW$TU$12
$C$DW$TU$13 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$13
$C$DW$T$13 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$13, DW_AT_encoding(DW_ATE_unsigned)
.dwattr $C$DW$T$13, DW_AT_name("unsigned __int40_t")
.dwattr $C$DW$T$13, DW_AT_byte_size(0x08)
.dwattr $C$DW$T$13, DW_AT_bit_size(0x28)
.dwattr $C$DW$T$13, DW_AT_data_bit_offset(0x18)
.dwendtag $C$DW$TU$13
$C$DW$TU$14 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$14
$C$DW$T$14 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$14, DW_AT_encoding(DW_ATE_signed)
.dwattr $C$DW$T$14, DW_AT_name("long")
.dwattr $C$DW$T$14, DW_AT_byte_size(0x04)
.dwendtag $C$DW$TU$14
$C$DW$TU$15 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$15
$C$DW$T$15 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$15, DW_AT_encoding(DW_ATE_unsigned)
.dwattr $C$DW$T$15, DW_AT_name("unsigned long")
.dwattr $C$DW$T$15, DW_AT_byte_size(0x04)
.dwendtag $C$DW$TU$15
$C$DW$TU$16 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$16
$C$DW$T$16 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$16, DW_AT_encoding(DW_ATE_signed)
.dwattr $C$DW$T$16, DW_AT_name("long long")
.dwattr $C$DW$T$16, DW_AT_byte_size(0x08)
.dwendtag $C$DW$TU$16
$C$DW$TU$17 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$17
$C$DW$T$17 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$17, DW_AT_encoding(DW_ATE_unsigned)
.dwattr $C$DW$T$17, DW_AT_name("unsigned long long")
.dwattr $C$DW$T$17, DW_AT_byte_size(0x08)
.dwendtag $C$DW$TU$17
$C$DW$TU$18 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$18
$C$DW$T$18 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$18, DW_AT_encoding(DW_ATE_float)
.dwattr $C$DW$T$18, DW_AT_name("float")
.dwattr $C$DW$T$18, DW_AT_byte_size(0x04)
.dwendtag $C$DW$TU$18
$C$DW$TU$19 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$19
$C$DW$T$19 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$19, DW_AT_encoding(DW_ATE_float)
.dwattr $C$DW$T$19, DW_AT_name("double")
.dwattr $C$DW$T$19, DW_AT_byte_size(0x08)
.dwendtag $C$DW$TU$19
$C$DW$TU$20 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$20
$C$DW$T$20 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$20, DW_AT_encoding(DW_ATE_float)
.dwattr $C$DW$T$20, DW_AT_name("long double")
.dwattr $C$DW$T$20, DW_AT_byte_size(0x08)
.dwendtag $C$DW$TU$20
$C$DW$TU$21 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$21
$C$DW$T$21 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$21, DW_AT_encoding(DW_ATE_TI_complex_signed)
.dwattr $C$DW$T$21, DW_AT_name("cchar")
.dwattr $C$DW$T$21, DW_AT_byte_size(0x02)
.dwendtag $C$DW$TU$21
$C$DW$TU$22 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$22
$C$DW$T$22 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$22, DW_AT_encoding(DW_ATE_TI_complex_signed)
.dwattr $C$DW$T$22, DW_AT_name("cshort")
.dwattr $C$DW$T$22, DW_AT_byte_size(0x04)
.dwendtag $C$DW$TU$22
$C$DW$TU$23 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$23
$C$DW$T$23 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$23, DW_AT_encoding(DW_ATE_TI_complex_signed)
.dwattr $C$DW$T$23, DW_AT_name("cint")
.dwattr $C$DW$T$23, DW_AT_byte_size(0x08)
.dwendtag $C$DW$TU$23
$C$DW$TU$24 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$24
$C$DW$T$24 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$24, DW_AT_encoding(DW_ATE_TI_complex_signed)
.dwattr $C$DW$T$24, DW_AT_name("clonglong")
.dwattr $C$DW$T$24, DW_AT_byte_size(0x10)
.dwendtag $C$DW$TU$24
$C$DW$TU$25 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$25
$C$DW$T$25 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$25, DW_AT_encoding(DW_ATE_TI_complex_float)
.dwattr $C$DW$T$25, DW_AT_name("cfloat")
.dwattr $C$DW$T$25, DW_AT_byte_size(0x08)
.dwendtag $C$DW$TU$25
$C$DW$TU$26 .dwtag DW_TAG_type_unit
.dwmtype $C$DW$T$26
$C$DW$T$26 .dwtag DW_TAG_base_type
.dwattr $C$DW$T$26, DW_AT_encoding(DW_ATE_TI_complex_float)
.dwattr $C$DW$T$26, DW_AT_name("cdouble")
.dwattr $C$DW$T$26, DW_AT_byte_size(0x10)
.dwendtag $C$DW$TU$26
The compiling commands are
"C:/ti/c6000_7.4.21/bin/cl6x" -mv6600 --abi=eabi -O3 -g --optimize_with_debug=on --include_path="C:/ti/c6000_7.4.21/include" --include_path="C:/ti/c6000_7.4.21/dsplib_c66x_3_4_0_0/packages" --include_path="C:/ti/c6000_7.4.21/dsplib_c66x_3_4_0_0/packages/ti/dsplib" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/MexImport/DSP_euclidNorm_mex" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/MexImport/DSP_IQMath_IQNcmpy1xN_mex" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/MexImport/DSP_IQMath_IQNmpy1xcNIQx_mex" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/MexImport/DSP_maxAbs16_mex" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/MexImport/DSP_norm64_mex" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/MexImport/DSP_shiftAndRndInt32_mex" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/MexImport/DSP_unpack16WithShift_mex" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/MexImport/IirFilterMex" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/MexImport/DSP_IQMath_IQNdiv_mex" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/MexImport/DSP_dotProd_mex" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/MexImport/DSP_IQMath_IQNtoIQx_mex" --include_path="C:/git/phx_main_1/DevProjects/App/include" --include_path="C:/git/phx_main_1/DevProjects/App/Test/include" --include_path="C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include" --include_path="C:/git/phx_main_1/DevProjects/App/Framework/Integ/test" --include_path="C:/git/phx_main_1/DevProjects/App/Framework/InputMgr/include" --include_path="C:/git/phx_main_1/DevProjects/App/Framework/OutputMgr/include" --include_path="C:/git/phx_main_1/DevProjects/App/BMode/Test" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/IQMath/include" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/ImgProcess/include" --include_path="C:/git/phx_main_1/DevProjects/App/UlsLib/RSC/include" --include_path="C:/git/phx_main_1/DevProjects/App/UlsLib/RSC/test" --include_path="C:/git/phx_main_1/DevProjects/App/HwMgr/EDMA/include" --include_path="C:/git/phx_main_1/DevProjects/App/HwMgr/Misc/include" --include_path="C:/git/phx_main_1/DevProjects/App/HwMgr/PCIe/include" --include_path="C:/git/phx_main_1/DevProjects/App/HwMgr/SPCTL/include" --include_path="C:/git/phx_main_1/DevProjects/App/HwMgr/SRIO/include" --include_path="C:/git/phx_main_1/DevProjects/App/BMode/Integ/include" --include_path="C:/git/phx_main_1/DevProjects/App/BMode/MultiBeam/include" --include_path="C:/git/phx_main_1/DevProjects/App/Color/include" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/Math/include" --include_path="C:/git/phx_main_1/DevProjects/App/Components/include" --include_path="C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include" --include_path="C:/git/phx_main_1/DevProjects/App/Components/CineDataPack/include" --include_path="C:/git/phx_main_1/DevProjects/App/Components/Diagnostics/include" --include_path="C:/git/phx_main_1/DevProjects/App/Components/EDMA_API/include" --include_path="C:/git/phx_main_1/DevProjects/App/Components/Fifo/include" --include_path="C:/git/phx_main_1/DevProjects/App/Components/CounterExtender/include" --include_path="C:/git/phx_main_1/DevProjects/App/Components/FrameHistory/include" --include_path="C:/git/phx_main_1/DevProjects/App/Framework/include" --include_path="C:/git/phx_main_1/DevProjects/App/Framework/Integ/include" --include_path="C:/git/phx_main_1/DevProjects/App/Framework/CineMgr/include" --include_path="C:/git/phx_main_1/DevProjects/App/BMode/include" --include_path="C:/git/phx_main_1/DevProjects/App/BMode/MultiBeam/test" --include_path="C:/git/phx_main_1/DevProjects/App/Color/Integ/include" --include_path="C:/git/phx_main_1/DevProjects/App/Color/Integ/test" --include_path="C:/git/phx_main_1/DevProjects/App/Color/CFMP_Fir/include" --include_path="C:/git/phx_main_1/DevProjects/App/Doppler/include" --include_path="C:/git/phx_main_1/DevProjects/App/Doppler/Hilbert/include" --include_path="C:/git/phx_main_1/DevProjects/App/Doppler/WinFFT/include" --include_path="C:/git/phx_main_1/DevProjects/App/Doppler/GapFill/include" --include_path="C:/git/phx_main_1/DevProjects/App/Doppler/Integ/Test" --include_path="C:/git/phx_main_1/DevProjects/App/MMode/Integ/include" --include_path="C:/git/phx_main_1/DevProjects/App/MMode/Integ/test" --include_path="C:/git/phx_main_1/DevProjects/App/ECG/Integ/include" --include_path="C:/git/phx_main_1/DevProjects/App/UlsLib/AutoGain/include" --include_path="C:/git/phx_main_1/DevProjects/App/UlsLib/NeedleVis/include" --include_path="C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/common/include" --include_path="C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include" --include_path="C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include" --include_path="C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImgProcessLib/include" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/UlsMath/include" --include_path="C:/git/phx_main_1/DevProjects/App/Lib/Utils/include" --relaxed_ansi --gcc --define=_DEBUG --define=DOPPLER_USE_STP_FUNCTIONS --define=SOC_C6678 --define=VERSION_FOR_DSP --define=_OS_SUPPORT --define=__TMS320C6X__ --define=_TMS320C6600 --define=_TMS320C6700 --display_error_number --diag_wrap=off --diag_warning=225 --debug_software_pipeline --mem_model:data=far --optimizer_interlist --strip_coff_underscore --advice:performance=all --preproc_with_compile --preproc_dependency="App/BMode/Integ/src/test_adap_emph.d" --obj_directory="App/BMode/Integ/src" --cmd_file="C:/git/phx_main_1/PhoenixPlatformCfg/Default/configPkg/compiler.opt" "../App/BMode/Integ/src/test_adap_emph.cpp"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 -O3 --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/git/phx_main/DevProjects/App/Lib/MexImport/DSP_euclidNorm_mex" --include_path="C:/git/phx_main/DevProjects/App/Lib/MexImport/DSP_IQMath_IQNcmpy1xN_mex" --include_path="C:/git/phx_main/DevProjects/App/Lib/MexImport/DSP_IQMath_IQNmpy1xcNIQx_mex" --include_path="C:/git/phx_main/DevProjects/App/Lib/MexImport/DSP_maxAbs16_mex" --include_path="C:/git/phx_main/DevProjects/App/Lib/MexImport/DSP_norm64_mex" --include_path="C:/git/phx_main/DevProjects/App/Lib/MexImport/DSP_shiftAndRndInt32_mex" --include_path="C:/git/phx_main/DevProjects/App/Lib/MexImport/DSP_unpack16WithShift_mex" --include_path="C:/git/phx_main/DevProjects/App/Lib/MexImport/IirFilterMex" --include_path="C:/git/phx_main/DevProjects/App/Lib/MexImport/DSP_IQMath_IQNdiv_mex" --include_path="C:/git/phx_main/DevProjects/App/Lib/MexImport/DSP_dotProd_mex" --include_path="C:/git/phx_main/DevProjects/App/Lib/MexImport/DSP_IQMath_IQNtoIQx_mex" --include_path="C:/git/phx_main/DevProjects/App/include" --include_path="C:/git/phx_main/DevProjects/App/Test/include" --include_path="C:/git/phx_main/DevProjects/App/Framework/CoreMgr/include" --include_path="C:/git/phx_main/DevProjects/App/Framework/Integ/test" --include_path="C:/git/phx_main/DevProjects/App/Framework/InputMgr/include" --include_path="C:/git/phx_main/DevProjects/App/Framework/OutputMgr/include" --include_path="C:/git/phx_main/DevProjects/App/BMode/Test" --include_path="C:/git/phx_main/DevProjects/App/Lib/IQMath/include" --include_path="C:/git/phx_main/DevProjects/App/Lib/ImgProcess/include" --include_path="C:/git/phx_main/DevProjects/App/UlsLib/RSC/include" --include_path="C:/git/phx_main/DevProjects/App/UlsLib/RSC/test" --include_path="C:/git/phx_main/DevProjects/App/HwMgr/EDMA/include" --include_path="C:/git/phx_main/DevProjects/App/HwMgr/Misc/include" --include_path="C:/git/phx_main/DevProjects/App/HwMgr/PCIe/include" --include_path="C:/git/phx_main/DevProjects/App/HwMgr/SPCTL/include" --include_path="C:/git/phx_main/DevProjects/App/HwMgr/SRIO/include" --include_path="C:/git/phx_main/DevProjects/App/BMode/Integ/include" --include_path="C:/git/phx_main/DevProjects/App/BMode/MultiBeam/include" --include_path="C:/git/phx_main/DevProjects/App/Color/include" --include_path="C:/git/phx_main/DevProjects/App/Lib/Math/include" --include_path="C:/git/phx_main/DevProjects/App/Components/include" --include_path="C:/git/phx_main/DevProjects/App/Components/CBufMgr/include" --include_path="C:/git/phx_main/DevProjects/App/Components/CineDataPack/include" --include_path="C:/git/phx_main/DevProjects/App/Components/Diagnostics/include" --include_path="C:/git/phx_main/DevProjects/App/Components/EDMA_API/include" --include_path="C:/git/phx_main/DevProjects/App/Components/Fifo/include" --include_path="C:/git/phx_main/DevProjects/App/Components/CounterExtender/include" --include_path="C:/git/phx_main/DevProjects/App/Components/FrameHistory/include" --include_path="C:/git/phx_main/DevProjects/App/Framework/include" --include_path="C:/git/phx_main/DevProjects/App/Framework/Integ/include" --include_path="C:/git/phx_main/DevProjects/App/Framework/CineMgr/include" --include_path="C:/git/phx_main/DevProjects/App/BMode/include" --include_path="C:/git/phx_main/DevProjects/App/BMode/MultiBeam/test" --include_path="C:/git/phx_main/DevProjects/App/Color/Integ/include" --include_path="C:/git/phx_main/DevProjects/App/Color/Integ/test" --include_path="C:/git/phx_main/DevProjects/App/Color/CFMP_Fir/include" --include_path="C:/git/phx_main/DevProjects/App/Doppler/include" --include_path="C:/git/phx_main/DevProjects/App/Doppler/Hilbert/include" --include_path="C:/git/phx_main/DevProjects/App/Doppler/WinFFT/include" --include_path="C:/git/phx_main/DevProjects/App/Doppler/GapFill/include" --include_path="C:/git/phx_main/DevProjects/App/Doppler/Integ/Test" --include_path="C:/git/phx_main/DevProjects/App/MMode/Integ/include" --include_path="C:/git/phx_main/DevProjects/App/MMode/Integ/test" --include_path="C:/git/phx_main/DevProjects/App/UlsLib/AutoGain/include" --include_path="C:/git/phx_main/DevProjects/App/UlsLib/NeedleVis/include" --include_path="C:/git/phx_main/DevProjects/App/BMode/ClearVisualization/common/include" --include_path="C:/git/phx_main/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include" --include_path="C:/git/phx_main/DevProjects/App/BMode/ClearVisualization/param/include" --include_path="C:/git/phx_main/DevProjects/App/BMode/ClearVisualization/ImgProcessLib/include" --include_path="C:/git/phx_main/DevProjects/App/Lib/UlsMath/include" --include_path="C:/git/phx_main/DevProjects/App/Lib/Utils/include" --advice:performance=all --define=_DEBUG --define=DOPPLER_USE_STP_FUNCTIONS --define=SOC_C6678 --define=VERSION_FOR_DSP --define=_OS_SUPPORT --define=__TMS320C6X__ --define=_TMS320C6600 --define=_TMS320C6700 -g --symdebug:dwarf_version=4 --relaxed_ansi --diag_warning=225 --debug_software_pipeline --mem_model:data=far --asm_listing --c_src_interlist --strip_coff_underscore --preproc_with_compile --preproc_dependency="App/BMode/Integ/src/test_adap_emph.d_raw" --obj_directory="App/BMode/Integ/src" --cmd_file="C:/git/phx_main/PhoenixPlatformCfg/Default/configPkg/compiler.opt" "../App/BMode/Integ/src/test_adap_emph.cpp"
The number of cycles estimated in the assembly code files are 4400 (v7.4.2) and 5268 (v8.3.21). They match very well with the cycles measured on a target processor, C6678. The newer compiler (v8.3.21) has around 800 cycles more than the older version compiler (v7.4.2). This is a kernel function which is called many times per second.
What can cause V8.3.21 generating less efficient code? Any kind of help is appreciated.
Thanks!
Wai Kwok Law
