FLASHTOOL: Uniflash Tool V7.1 on ubuntu18.04
Part Number: FLASHTOOL
Other Parts Discussed in Thread: UNIFLASH, MSP-FET
Hi Champs:
While installed the uniflash tool 7.1, and launching it,
Ubuntu will give me these errors.
How to solve it?
BR Rio
(Setup:9915): IBUS-WARNING **: 23:00:04.576: The owner of /home/rio/.config/ibus/bus is not root!
root@ubuntu:/opt# [10146:10169:0228/230254.338721:ERROR:bus.cc(397)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[10146:10169:0228/230254.338845:ERROR:bus.cc(397)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[10146:10169:0228/230254.471959:ERROR:bus.cc(397)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[10146:10169:0228/230254.474622:ERROR:bus.cc(397)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[10194:10194:0228/230254.777881:FATAL:nw_content_renderer_hooks.cc(53)] Failed to load node library (error: libatomic.so.1: cannot open shared object file: No such file or directory)
#0 0x7fa1803ce463 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x57b5462)
#1 0x7fa1803e1a8e (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x57c8a8d)
#2 0x7fa185317ec5 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0xa6feec4)
#3 0x7fa18537e1c2 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0xa7651c1)
#4 0x7fa17ff397f6 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x53207f5)
#5 0x7fa17ff36f26 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x531df25)
#6 0x7fa17ff37a9b (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x531ea9a)
#7 0x7fa17cc6f866 ChromeMain
#8 0x7fa17a80109b __libc_start_main
Crash keys:
"switch-19" = "--user-data-dir=/home/rio/.config/Uniflash"
"switch-18" = "--enable-crashpad"
"switch-17" = "--shared-files=v8_context_snapshot_data:100"
"switch-16" = "--launch-time-ticks=1124384130"
"switch-15" = "--renderer-client-id=5"
"switch-14" = "--num-raster-threads=1"
"switch-13" = "--lang=en-US"
"switch-12" = "--field-trial-handle=11734278632836316258,15781706659671034314,1"
"switch-11" = "--no-zygote"
"switch-10" = "--no-sandbox"
"switch-9" = "--change-stack-guard-on-fork=enable"
"switch-8" = "--display-capture-permissions-policy-allowed"
"switch-7" = "--extension-process"
"switch-6" = "--nwjs"
"switch-5" = "--nwapp-path=/opt/ti/uniflash_7.1.0"
"switch-4" = "--user-data-dir=/home/rio/.config/Uniflash"
"switch-3" = "--enable-crash-reporter=,"
"switch-2" = "--crashpad-handler-pid=10152"
"switch-1" = "--enable-crashpad"
"num-switches" = "20"
"osarch" = "x86_64"
"pid" = "10194"
"ptype" = "renderer"
[0228/230254.789769:ERROR:file_io_posix.cc(144)] open /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq: No such file or directory (2)
[0228/230254.789858:ERROR:file_io_posix.cc(144)] open /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq: No such file or directory (2)
Received signal 6
#1 0x7fa180464321 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x584b320)
#2 0x7fa17abf1dd0 (/lib/x86_64-linux-gnu/libpthread-2.28.so+0x12dcf)
#3 0x7fa1803e1f17 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x57c8f16)
#4 0x7fa185317ec5 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0xa6feec4)
#5 0x7fa18537e1c2 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0xa7651c1)
#6 0x7fa17ff397f6 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x53207f5)
#7 0x7fa17ff36f26 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x531df25)
#8 0x7fa17ff37a9b (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x531ea9a)
#9 0x7fa17cc6f866 ChromeMain
#10 0x7fa17a80109b __libc_start_main
r8: 0000000000000000 r9: 00007ffc17a35ae0 r10: 0000000000000008 r11: 0000000000000246
r12: 00000000000000b6 r13: 00007ffc17a36e00 r14: 00007ffc17a36e10 r15: 00007ffc17a36e18
di: 0000000000000002 si: 00007ffc17a35ae0 bp: 00007ffc17a35d30 bx: 00007ffc17a35d41
dx: 0000000000000000 ax: 0000000000000000 cx: 00007fa17a81e077 sp: 00007ffc17a35ae0
ip: 00007fa17a81e077 efl: 0000000000000246 cgf: 002b000000000033 erf: 0000000000000000
trp: 0000000000000000 msk: 0000000000000000 cr2: 0000000000000000
[end of stack trace]
[10195:10195:0228/230254.832103:FATAL:nw_content_renderer_hooks.cc(53)] Failed to load node library (error: libatomic.so.1: cannot open shared object file: No such file or directory)
#0 0x7f42fa1d7463 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x57b5462)
#1 0x7f42fa1eaa8e (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x57c8a8d)
#2 0x7f42ff120ec5 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0xa6feec4)
#3 0x7f42ff1871c2 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0xa7651c1)
#4 0x7f42f9d427f6 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x53207f5)
#5 0x7f42f9d3ff26 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x531df25)
#6 0x7f42f9d40a9b (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x531ea9a)
#7 0x7f42f6a78866 ChromeMain
#8 0x7f42f460a09b __libc_start_main
Crash keys:
"switch-16" = "--launch-time-ticks=1124417890"
"switch-15" = "--renderer-client-id=6"
"osarch" = "x86_64"
"pid" = "10195"
[0228/230254.917153:ERROR:file_io_posix.cc(144)] open /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq: No such file or directory (2)
[0228/230254.919601:ERROR:file_io_posix.cc(144)] open /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq: No such file or directory (2)
Received signal 6
#1 0x7f42fa26d321 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x584b320)
#2 0x7f42f49fadd0 (/lib/x86_64-linux-gnu/libpthread-2.28.so+0x12dcf)
#3 0x7f42fa1eaf17 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x57c8f16)
#4 0x7f42ff120ec5 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0xa6feec4)
#5 0x7f42ff1871c2 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0xa7651c1)
#6 0x7f42f9d427f6 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x53207f5)
#7 0x7f42f9d3ff26 (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x531df25)
#8 0x7f42f9d40a9b (/opt/ti/uniflash_7.1.0/node-webkit/lib/libnw.so+0x531ea9a)
#9 0x7f42f6a78866 ChromeMain
#10 0x7f42f460a09b __libc_start_main
r8: 0000000000000000 r9: 00007ffe99941b20 r10: 0000000000000008 r11: 0000000000000246
r12: 00000000000000b6 r13: 00007ffe99942e40 r14: 00007ffe99942e50 r15: 00007ffe99942e58
di: 0000000000000002 si: 00007ffe99941b20 bp: 00007ffe99941d70 bx: 00007ffe99941d81
dx: 0000000000000000 ax: 0000000000000000 cx: 00007f42f4627077 sp: 00007ffe99941b20
ip: 00007f42f4627077 efl: 0000000000000246 cgf: 002b000000000033 erf: 0000000000000000
[10146:10172:0228/230259.013383:ERROR:chrome_browser_main_extra_parts_metrics.cc(227)] START: ReportBluetoothAvailability(). If you don't see the END: message, this is crbug.com/1216328.
[10146:10172:0228/230259.013577:ERROR:chrome_browser_main_extra_parts_metrics.cc(230)] END: ReportBluetoothAvailability()
[10183:10189:0228/230356.547030:ERROR:cert_verify_proc_builtin.cc(600)] No net_fetcher for performing AIA chasing.
^C
root@ubuntu:/o
