TDA4VM: Issue with first install of TDA4VM-EVM
Part Number: TDA4VM
I am using a TDA4VM-EVM for Edge AI and I was following the guide "getting started"  (Getting Started — Processor SDK Linux for Edge AI Documentation).
I have installed the following sdk : PROCESSOR-SDK-LINUX-SK-TDA4VM_08.01.00.02 | TI.com
An error occurs if I run the command to install dependencies (./setup_script.sh).
I have already try to fix this issue thanks to the forum discussion : (+) SK-TDA4VM: Problem with first install of SK-TDA4VM - Processors forum - Processors - TI E2E support forums
How can I solve this issue ?
Thank you,
Xavier
  • Hello Xavier,
    Could you post the entire log from the setup_script.sh so that I can understand the issue more for debugging on my side?
    In parallel, on your side, could you make sure there is internet connection, power cycle the board, and do a clean build?
    Takuma
  • Hi Takuma,
    The entire log from the setup_script.sh:
    U-Boot SPL 2021.01-g15769936a5 (Dec 20 2021 - 17:09:03 +0000)
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev E8
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 16:34:52, Dec 20 2021
    U-Boot SPL 2021.01-g15769936a5 (Dec 20 2021 - 16:36:05 +0000)
    Detected: J7X-BASE-CPB rev E3
    Detected: J7X-VSC8514-ETH rev E2
    U-Boot 2021.01-g15769936a5 (Dec 20 2021 - 16:36:05 +0000)
    SoC:   J721E SR2.0
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cp0
    eth0: ethernet@46000000
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    483 bytes read in 10 ms (46.9 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    Running uenvcmd ...
    1 bytes read in 15 ms (0 Bytes/s)
    Already setup.
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    572788 bytes read in 35 ms (15.6 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 572788 bytes: Success!
    301996 bytes read in 24 ms (12 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 301996 bytes: Success!
    Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
    Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
    1436436 bytes read in 71 ms (19.3 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 1436436 bytes: Success!
    Load Remote Processor 7 with data@addr=0x82000000 1436436 bytes: Success!
    12980288 bytes read in 547 ms (22.6 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 12980288 bytes: Success!
    19270144 bytes read in 805 ms (22.8 MiB/s)
    100196 bytes read in 16 ms (6 MiB/s)
    10336 bytes read in 11 ms (917 KiB/s)
    ERROR: reserving fdt memory region failed (addr=fe000000 size=1000000)
    ERROR: reserving fdt memory region failed (addr=fc000000 size=2000000)
    ERROR: reserving fdt memory region failed (addr=ac000000 size=200000)
    ERROR: reserving fdt memory region failed (addr=ac200000 size=1e00000)
       Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.65-gdcc6bedb2c (oe-user@oe-host) (aarch64-non1
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] OF: reserved mem: OVERLAP DETECTED!
    [    0.000000] vision-apps-c71-memory@aa100000 (0x00000000aa100000--0x00000000a)
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, B
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a01000l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a11000l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a21000l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a41000l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a61000l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a71000l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a81000l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a91000l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aal
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa1000l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, B
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac0000l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, B
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b20000l
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, t
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, B
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000fc000000, B
    [    0.000000] OF: reserved mem: initialized node intercore-eth-r5f-memory@fc00l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000fe000000, B
    [    0.000000] OF: reserved mem: initialized node eeprom-shadow-r5f-memory@fe00l
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, B
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
    [    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
    [    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000feffffff]
    [    0.000000]   node   0: [mem 0x00000000ff000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x000000088fffffff]
    [    0.000000]   node   0: [mem 0x0000000890000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Failed to reserve 512 MiB
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmt
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes,)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e8000)
    [    0.000000] Memory: 2270080K/4194304K available (10880K kernel code, 1346K r)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 ji.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0800000 (fl)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008a00b0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a00c000
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 wi0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398s
    [    0.008370] Console: colour dummy device 80x25
    [    0.012933] Calibrating delay loop (skipped), value calculated using timer f)
    [    0.023604] pid_max: default: 32768 minimum: 301
    [    0.028352] LSM: Security Framework initializing
    [    0.033102] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, lin)
    [    0.040672] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes)
    [    0.049708] rcu: Hierarchical SRCU implementation.
    [    0.054773] Platform MSI: msi-controller@1820000 domain created
    [    0.061031] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controllerd
    [    0.070330] EFI services will not be available.
    [    0.075093] smp: Bringing up secondary CPUs ...
    [    0.080347] Detected PIPT I-cache on CPU1
    [    0.080371] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.080382] GICv3: CPU1: using allocated LPI pending table @0x00000008a00d000
    [    0.080414] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.080475] smp: Brought up 1 node, 2 CPUs
    [    0.109822] SMP: Total of 2 processors activated.
    [    0.114627] CPU features: detected: 32-bit EL0 Support
    [    0.119881] CPU features: detected: CRC32 instructions
    [    0.133732] CPU: All CPU(s) started at EL2
    [    0.137928] alternatives: patching kernel code
    [    0.142969] devtmpfs: initialized
    [    0.151524] KASLR disabled due to lack of seed
    [    0.156206] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
    [    0.166168] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.173330] pinctrl core: initialized pinctrl subsystem
    [    0.178898] DMI not present or invalid.
    [    0.183110] NET: Registered protocol family 16
    [    0.187882] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.195217] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic alls
    [    0.203185] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic as
    [    0.211466] thermal_sys: Registered thermal governor 'step_wise'
    [    0.211468] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.217887] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.231519] ASID allocator initialised with 65536 entries
    [    0.254621] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.261478] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.268237] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.275955] cryptd: max_cpu_qlen set to 1000
    [    0.282042] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bbd
    [    0.290845] vsys_3v3: supplied by evm_12v0
    [    0.295228] vsys_5v0: supplied by evm_12v0
    [    0.299949] iommu: Default domain type: Translated
    [    0.305121] SCSI subsystem initialized
    [    0.309248] mc: Linux media interface: v0.10
    [    0.313625] videodev: Linux video capture interface: v2.00
    [    0.319254] pps_core: LinuxPPS API ver. 1 registered
    [    0.324324] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
    [    0.333661] PTP clock support registered
    [    0.337682] EDAC MC: Ver: 3.0.0
    [    0.341454] FPGA manager framework
    [    0.344986] Advanced Linux Sound Architecture Driver Initialized.
    [    0.351602] clocksource: Switched to clocksource arch_sys_counter
    [    0.358024] VFS: Disk quotas dquot_6.6.0
    [    0.362074] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.371771] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.378071] NET: Registered protocol family 2
    [    0.382669] IP idents hash table entries: 65536 (order: 3, 524288 bytes, lin)
    [    0.391290] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 655)
    [    0.400060] TCP established hash table entries: 32768 (order: 2, 262144 byte)
    [    0.408255] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, line)
    [    0.416214] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.422979] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.429869] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.437277] NET: Registered protocol family 1
    [    0.441988] RPC: Registered named UNIX socket transport module.
    [    0.448047] RPC: Registered udp transport module.
    [    0.452860] RPC: Registered tcp transport module.
    [    0.457663] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.464248] PCI: CLS 0 bytes, default 64
    [    0.468624] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counte
    [    0.479037] Initialise system trusted keyrings
    [    0.483681] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.491994] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.498190] NFS: Registering the id_resolver key type
    [    0.503421] Key type id_resolver registered
    [    0.507693] Key type id_legacy registered
    [    0.511812] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.518660] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registerin.
    [    0.526307] 9p: Installing v9fs 9p2000 file system support
    [    0.551811] Key type asymmetric registered
    [    0.555997] Asymmetric key parser 'x509' registered
    [    0.560996] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
    [    0.568554] io scheduler mq-deadline registered
    [    0.573179] io scheduler kyber registered
    [    0.578472] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.584650] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.593191] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.599456] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.607305] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.615436] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x0)
    [    0.624786] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [    0.634430] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [    0.642311] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to s
    [    0.655385] brd: module loaded
    [    0.661432] loop: module loaded
    [    0.665011] sysfs: cannot create duplicate filename '/devices/platform/dma_b'
    [    0.672941] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.65-gdcc6bedb2c #1
    [    0.680140] Hardware name: Texas Instruments K3 J721E SoC (DT)
    [    0.686095] Call trace:
    [    0.688601]  dump_backtrace+0x0/0x1a0
    [    0.692337]  show_stack+0x18/0x68
    [    0.695720]  dump_stack+0xd0/0x12c
    [    0.699191]  sysfs_warn_dup+0x60/0x80
    [    0.702925]  sysfs_create_dir_ns+0xe0/0xf8
    [    0.707106]  kobject_add_internal+0x98/0x288
    [    0.711462]  kobject_add+0x94/0x100
    [    0.715024]  device_add+0xe0/0x740
    [    0.718494]  platform_device_add+0x100/0x238
    [    0.722851]  platform_device_register_full+0xcc/0x150
    [    0.728010]  dma_buf_phys_init+0x6c/0x9c
    [    0.732010]  do_one_initcall+0x54/0x1b8
    [    0.735924]  kernel_init_freeable+0x220/0x2a0
    [    0.740370]  kernel_init+0x14/0x114
    [    0.743927]  ret_from_fork+0x10/0x34
    [    0.747583] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't.
    [    0.760748] megasas: 07.714.04.00-rc1
    [    0.765813] libphy: Fixed MDIO Bus: probed
    [    0.770455] tun: Universal TUN/TAP device driver, 1.6
    [    0.775880] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.782287] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.788358] sky2: driver version 1.30
    [    0.792633] VFIO - User Level meta-driver version: 0.3
    [    0.798306] i2c /dev entries driver
    [    0.802489] sdhci: Secure Digital Host Controller Interface driver
    [    0.808830] sdhci: Copyright(c) Pierre Ossman
    [    0.813531] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.819877] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.826187] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.833320] optee: probing for conduit method.
    [    0.837879] optee: revision 3.12 (3d47a131)
    [    0.838131] optee: initialized driver
    [    0.847461] NET: Registered protocol family 17
    [    0.852076] 9pnet: Installing 9P2000 support
    [    0.856463] Key type dns_resolver registered
    [    0.860908] Loading compiled-in X.509 certificates
    [    0.870279] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.876615] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.884712] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v20)
    [    0.915529] random: fast init done
    [    0.950192] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.957871] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.963965] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.970038] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.976486] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.983311] pca953x 3-0020: using no AI
    [    1.008453] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    1.015255] pca953x 3-0022: using AI
    [    1.019522] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    1.025498] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    1.031741] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    1.038232] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.044717] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    1.054800] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    1.061109] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    1.067923] pca953x 6-0020: using no AI
    [    1.096294] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    1.102360] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.108331] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.114587] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.121405] pca953x 9-0020: using no AI
    [    1.147929] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.154351] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interd
    [    1.164329] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 1d
    [    1.173136] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrud
    [    1.182983] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator d
    [    1.203731] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
    [    1.211431] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ra:
    [    1.219099] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0
    [    1.227382] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0
    [    1.235661] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -0
    [    2.245996] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.252409] pci_bus 0000:00: root bus resource [bus 00-0f]
    [    2.258014] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus addr)
    [    2.267704] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.274753] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.280892] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 s
    [    2.290761] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 s
    [    2.300651] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8s
    [    2.310610] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3es
    [    2.320578] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92s
    [    2.330538] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2s
    [    2.340523] pci 0000:00:00.0: supports D1
    [    2.344624] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.350496] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84s
    [    2.362267] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reg
    [    2.370459] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3es
    [    2.380423] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3es
    [    2.390383] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3es
    [    2.401946] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
    [    2.408715] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.413987] pcieport 0000:00:00.0: PME: Signaling with IRQ 61
    [    2.420376] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ra:
    [    2.428074] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0
    [    2.436364] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0
    [    2.444643] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -0
    [    3.453183] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    3.459592] pci_bus 0001:00: root bus resource [bus 00-0f]
    [    3.465198] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus ad)
    [    3.475066] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    3.482110] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    3.488310] pci 0001:00:00.0: supports D1
    [    3.492403] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    3.500042] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reg
    [    3.509832] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
    [    3.516606] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    3.521871] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
    [    3.528214] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ra:
    [    3.535884] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0
    [    3.544159] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0
    [    3.552435] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -0
    [    4.553185] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    4.559594] pci_bus 0002:00: root bus resource [bus 00-0f]
    [    4.565201] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus ad)
    [    4.574449] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407fffff)
    [    4.585223] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    4.591420] pci 0002:00:00.0: supports D1
    [    4.595514] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    4.603121] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reg
    [    4.612921] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
    [    4.619692] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    4.624976] pcieport 0002:00:00.0: PME: Signaling with IRQ 67
    [    4.631740] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, 5
    [    4.641612] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    4.648371] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies4
    [    4.657426] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024,1
    [    4.667585] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    4.674344] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies4
    [    4.682328] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud =0
    [    4.691717] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 30
    [    4.700458] printk: console [ttyS2] enabled
    [    4.708894] printk: bootconsole [ns16550a0] disabled
    [    4.719340] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 30
    [    4.728276] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 30
    [    4.738926] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd
    [    4.749437] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcd
    [    4.759588] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcd
    [    4.769825] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcd
    [    4.780669] scsi host0: ufshcd
    [    4.802424] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[10
    [    4.823606] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 0
    [    4.831257] libphy: 46000f00.mdio: probed
    [    4.836662] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, dri7
    [    4.844980] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss ve0
    [    4.859036] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, ad0
    [    4.867922] mmc0: CQHCI version 5.10
    [    4.871731] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    4.881176] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[32
    [    4.884633] vdd_mmc1: supplied by vsys_3v3
    [    4.897694] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    4.904377] pca953x 4-0020: using no AI
    [    4.917905] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 6t
    [    4.932625] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    4.939609] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    4.946455] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    4.953288] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    4.960103] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    4.970115] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan:)
    [    4.980691] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan)
    [    4.995263] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
    [    5.000508] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    5.007116] Creating 8 MTD partitions on "47040000.spi.0":
    [    5.012589] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    5.018544] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    5.024304] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    5.030126] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    5.035277] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: R0
    [    5.035639] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    5.052125] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    5.058252] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    5.064053] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    5.072796] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [    5.081122] mmc0: Command Queue Engine enabled
    [    5.085568] mmc0: new HS200 MMC card at address 0001
    [    5.090825] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    5.095470] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    5.101502] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    5.107496] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237)
    [    5.115618] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 0
    [    5.123289] libphy: 46000f00.mdio: probed
    [    5.127627] cdns-ufshcd 4e84000.ufs: __ufshcd_issue_tm_cmd: task management t
    [    5.136257] cdns-ufshcd 4e84000.ufs: ufshcd_try_to_abort_task: no response f0
    [    5.146459] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, dri7
    [    5.154780] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss ve0
    [    5.168417] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    5.175445] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 14
    [    5.182655] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    5.188569] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[10
    [    5.201331] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:50000
    [    5.211715] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    5.217761] mmc1: CQHCI version 5.10
    [    5.229779] debugfs: Directory 'pd:27' with parent 'pm_genpd' already presen!
    [    5.234109] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[32
    [    5.237088] debugfs: Directory 'pd:26' with parent 'pm_genpd' already presen!
    [    5.248653] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: R0
    [    5.256785] debugfs: Directory 'pd:242' with parent 'pm_genpd' already prese!
    [    5.267070] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 036
    [    5.274281] debugfs: Directory 'pd:241' with parent 'pm_genpd' already prese!
    [    5.283155] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 036
    [    5.289976] debugfs: Directory 'pd:240' with parent 'pm_genpd' already prese!
    [    5.298687] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not foud
    [    5.305685] debugfs: Directory 'pd:239' with parent 'pm_genpd' already prese!
    [    5.320987] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    5.341674] ALSA device list:
    [    5.344651]   No soundcards found.
    [    6.278362] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 6t
    [    6.286661] Waiting for root device PARTUUID=4b0ab967-02...
    [    6.342143] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    6.348992] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    6.358754]  mmcblk1: p1 p2
    [    6.923402] EXT4-fs (mmcblk1p2): recovery complete
    [    6.929164] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. )
    [    6.937274] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    6.950567] devtmpfs: mounted
    [    6.953965] Freeing unused kernel memory: 1856K
    [    6.958519] Run /sbin/init as init process
    [    7.139016] systemd[1]: System time before build time, advancing clock.
    [    7.190377] NET: Registered protocol family 10
    [    7.195302] Segment Routing with IPv6
    [    7.217979] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT )
    [    7.239749] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    7.282304] systemd[1]: Set hostname to <j7-evm>.
    [    7.489196] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= r.
    [    7.557040] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.563751] systemd[1]: system-getty.slice: unit configures an IP firewall, .
    [    7.576075] systemd[1]: (This warning is only shown for the first unit using)
    [    7.585993] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    7.607684] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.614963] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    7.635673] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.642849] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    7.663789] systemd[1]: Started Dispatch Password Requests to Console Direct.
    [  OK  ] Started Dispatch Password ��…ts to Console Directory Watch.
    [    7.687714] systemd[1]: Started Forward Password Requests to Wall Directory .
    [  OK  ] Started Forward Password R��…uests to Wall Directory Watch.
    [    7.711708] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    7.727660] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    7.747649] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    7.763657] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    7.790518] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    7.811681] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    7.835672] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    7.855793] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    7.890037] systemd[1]: Condition check resulted in Journal Audit Socket bei.
    [    7.898376] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    7.919875] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    7.935930] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    7.959840] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    7.979775] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    8.002691] systemd[1]: Mounting Huge Pages File System...
    [    8.021959] systemd[1]: Mounting POSIX Message Queue File System...
    [    8.046124] systemd[1]: Mounting Kernel Debug File System...
    [    8.069120] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    8.086732] systemd[1]: Starting Create list of static device nodes for the .
             Starting Create list of st��…odes for the current kernel...
    [    8.114653] systemd[1]: Starting Start psplash boot splash screen...
    [    8.139185] systemd[1]: Starting RPC Bind...
    [    8.155777] systemd[1]: Condition check resulted in File System Check on Roo.
    [    8.168182] systemd[1]: Starting Journal Service...
    [    8.202043] systemd[1]: Starting Load Kernel Modules...
    [    8.219376] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems   8.232244] cryptodev: l.
    [0m...
    [    8.242016] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    8.248542] cryptodev: driver 1.10 loaded.
    [    8.258771] systemd[1]: Starting udev Coldplug all Devices...
    [    8.286412] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    8.308029] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta��… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star��…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    8.542343] systemd-journald[172]: Received client request to flush runtime .
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
    [  OK  ] Started udev Kernel Device Manager.
             Starting udev Wait for Complete Device Initialization...
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    9.018622] CAN device driver interface
    [    9.176119] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.193494] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.207824] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.217516] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.227049] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.236359] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    9.244297] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.253583] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.262031] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.273411] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.281970] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.291255] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.300905] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.312202] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.324861] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.334172] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.489643] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node visio0
    [    9.564135] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for ic
    [    9.599526] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [    9.608023] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    9.615290] PVR_K:  200: Read BVNC 22.104.208.318 from HW device registers
    [    9.628362] PVR_K:  200: RGX Device registered with BVNC 22.104.208.318
    [    9.632172] remoteproc remoteproc0: 4d80800000.dsp is available
    [    9.644757] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [    9.650957] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [    9.664330]  remoteproc0#vdev0buffer: assigned reserved memory node vision-a0
    [    9.677127] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [    9.688033] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu o0
    [    9.688383] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    9.695945] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    9.701807]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    9.715587] remoteproc remoteproc0: remote processor 4d80800000.dsp is now ad
    [    9.725156] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node visio0
    [    9.736032] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [    9.743105] remoteproc remoteproc1: 4d81800000.dsp is available
    [    9.749961] remoteproc remoteproc1: attaching to 4d81800000.dsp
    [    9.756485] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [    9.763815]  remoteproc1#vdev0buffer: assigned reserved memory node vision-a0
    [    9.773795] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    9.779341] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    9.791585]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    9.824794] remoteproc remoteproc1: remote processor 4d81800000.dsp is now ad
    [    9.835902] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-0
    [    9.864553] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    9.873315] platform 41000000.r5f: R5F core may have been powered on by a di)
    [    9.885696] remoteproc remoteproc2: 64800000.dsp is available
    [    9.891701] remoteproc remoteproc2: attaching to 64800000.dsp
    [    9.897717] platform 41000000.r5f: configured R5F for IPC-only mode
    [    9.905280] remoteproc remoteproc2: unsupported resource 65538
    [    9.913809] platform 41000000.r5f: assigned reserved memory node vision-apps0
    [    9.924175] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    9.938916] remoteproc remoteproc3: 41000000.r5f is available
    [    9.945459]  remoteproc2#vdev0buffer: assigned reserved memory node vision-a0
    [    9.971731] remoteproc remoteproc3: attaching to 41000000.r5f
    [    9.981828] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    9.990378] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    9.995932] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [   10.003780]  remoteproc3#vdev0buffer: assigned reserved memory node vision-a0
    [   10.011287]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [   10.024304] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   10.030188]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [   10.036306] remoteproc remoteproc3: remote processor 41000000.r5f is now attd
    [   10.044361] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
    [   10.052696] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [   10.057656] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addd
    [   10.071702] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [   10.108443] remoteproc remoteproc2: remote processor 64800000.dsp is now attd
    [   10.171643] platform 5c00000.r5f: configured R5F for IPC-only mode
    [   10.247778] platform 5c00000.r5f: assigned reserved memory node vision-apps-0
    [   10.366645] remoteproc remoteproc4: 5c00000.r5f is available
    [   10.456399] remoteproc remoteproc4: attaching to 5c00000.r5f
    [   10.512968] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [   10.589889]  remoteproc4#vdev0buffer: assigned reserved memory node vision-a0
    [   10.681457] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   10.696608] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [   10.735681]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [   10.803937] remoteproc remoteproc4: remote processor 5c00000.r5f is now attad
    [   10.835458] platform 5d00000.r5f: configured R5F for IPC-only mode
    [   10.912488] platform 5d00000.r5f: assigned reserved memory node vision-apps-0
    [   10.919643] random: crng init done
    [   10.924920] random: 7 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [   11.010038] remoteproc remoteproc5: 5d00000.r5f is available
    [   11.055871] remoteproc remoteproc5: attaching to 5d00000.r5f
    [   11.078489] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [   11.101646]  remoteproc5#vdev0buffer: assigned reserved memory node vision-a0
    [   11.141859] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   11.157016] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [   11.164235] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [   11.176453]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [   11.177444] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [   11.193556] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong adde
    [   11.201319] remoteproc remoteproc5: remote processor 5d00000.r5f is now attad
    [   11.204807] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [   11.219770] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong adde
    [   11.231678] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [   11.240967] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong adde
    [   11.251266] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [   11.260277] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong adde
    [   11.267889] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong adde
    [   11.340017] m_can_platform 40528000.can: m_can device registered (irq=23, ve)
    [   11.351175] platform 5e00000.r5f: configured R5F for remoteproc mode
    [   11.360193] m_can_platform 40568000.can: m_can device registered (irq=25, ve)
    [   11.378426] m_can_platform 2701000.can: m_can device registered (irq=55, ver)
    [   11.394544] m_can_platform 2721000.can: m_can device registered (irq=57, ver)
    [   11.446599] platform 5e00000.r5f: assigned reserved memory node vision-apps-0
    [   11.469589] remoteproc remoteproc6: 5e00000.r5f is available
    [   11.477756] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-2
    [   11.486860] remoteproc remoteproc6: powering up 5e00000.r5f
    [   11.492493] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-2
    [   11.503645] remoteproc remoteproc6: request_firmware failed: -2
    [   11.510433] platform 5f00000.r5f: configured R5F for remoteproc mode
    [   11.578455] platform 5f00000.r5f: assigned reserved memory node vision-apps-0
    [   11.634929] remoteproc remoteproc7: 5f00000.r5f is available
    [   11.644101] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-2
    [   11.656923] remoteproc remoteproc7: powering up 5f00000.r5f
    [   11.662529] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-2
    [   11.677749] remoteproc remoteproc7: request_firmware failed: -2
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Created slice system-weston.slice.
    [   12.205027] usbcore: registered new interface driver usbfs
    [   12.206210] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [DEPEND] Dependency failed f[   12.229648] remoteproc remoteproc8: b034000.pru e
    [   12.243699] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
    [   12.275478] usbcore: registered new interface driver hub
             Mounting /run/media/mmcblk1p1...[   12.285206] usbcore: registered newb
    [   12.293663] remoteproc remoteproc9: b004000.rtu is available
    [   12.301826] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [   12.306605] remoteproc remoteproc10: b00a000.txpru is available
    [   12.350938] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data.
    [  OK  ] Mounted /run/media/mmcblk1p1.[   12.368747] remoteproc remoteproc11: be
    [   12.401087] remoteproc remoteproc12: b006000.rtu is available
    [   12.421704] remoteproc remoteproc13: b00c000.txpru is available
    [   12.433165] remoteproc remoteproc14: b134000.pru is available
    [   12.446268] remoteproc remoteproc15: b104000.rtu is available
    [   12.453529] remoteproc remoteproc16: b10a000.txpru is available
    [   12.464587] remoteproc remoteproc17: b138000.pru is available
    [   12.471900] remoteproc remoteproc18: b106000.rtu is available
    [   12.480843] remoteproc remoteproc19: b10c000.txpru is available
    [   13.254245] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   13.259834] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus n1
    [   13.267967] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100
    [   13.277382] xhci-hcd xhci-hcd.2.auto: irq 663, io mem 0x06410000
    [   13.283547] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, b0
    [   13.293395] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
    [   13.300613] usb usb1: Product: xHCI Host Controller
    [   13.305487] usb usb1: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd
    [   13.312002] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   13.317117] hub 1-0:1.0: USB hub found
    [   13.320890] hub 1-0:1.0: 1 port detected
    [   13.325685] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   13.331176] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus n2
    [   13.338829] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   13.345379] usb usb2: We don't know the algorithms for LPM for this host, di.
    [   13.353516] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, b0
    [   13.361766] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
    [   13.368976] usb usb2: Product: xHCI Host Controller
    [   13.373844] usb usb2: Manufacturer: Linux 5.10.65-gdcc6bedb2c xhci-hcd
    [   13.380357] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   13.385457] hub 2-0:1.0: USB hub found
    [   13.389222] hub 2-0:1.0: 1 port detected
    [   13.583617] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   13.735883] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bc0
    [   13.744046] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [   13.751187] usb 1-1: SerialNumber: FB0708790B90
    [   13.756177] hub 1-1:1.0: USB hub found
    [   13.759956] hub 1-1:1.0: 4 ports detected
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting rc.pvr.service...
             Starting startwlan...
             Starting Login Service...
             Starting Update weston ini��… based on the platform name...
    [  OK  ] Started Save/Restore Sound Card State.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Reached target Sound Card.
             Starting Network Service...
    [  OK  ] Started rc.pvr.service.
    [  OK  ] Started Telephony service.
    [  OK  ] Started Update weston ini ��…ge based on the platform name.
             Starting weston.service...
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [   14.363440] cfg80211: Loading compiled-in X.509 certificates for regulatory e
    [   14.405092] Bluetooth: Core ver 2.22
    [  OK  ] Started telnetd.service.
    [   14.413466] NET: Registered protocol family 31
    [   14.413697] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   14.427641] Bluetooth: HCI device and connection manager initialized
    [   14.441919] Bluetooth: HCI socket layer initialized
    [   14.451744] Bluetooth: L2CAP socket layer initialized
    [   14.461255] Bluetooth: SCO socket layer initialized
    [   14.517158] Intel(R) Wireless WiFi driver for Linux
    [  OK  ] Listening on Load/Save RF ��…itch Status /dev/rfkill Watch.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started Login Service.
    [   14.657270] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (m)
    [   14.686236] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma��…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting Weston Wayland Compositor...
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [   14.888693] PVR_K:  947: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [  OK  ] Created slice User Slice of UID 0.
             Starting User Runtime Directory /run/user/0...
    [  OK  ] Started User Runtime Directory /run/user/0.
             Starting User Manager for UID 0...
    [  OK  ] Started Simple Network Man��…ement Protocol (SNMP) Daemon..
    [  OK  ] Started User Manager for UID 0.
    [  OK  ] Started Session c1 of user root.
    [   15.580856] startwlan.sh[903]: Starting WLAN AP setup
    [   15.592068] startwlan.sh[1011]: Starting WLAN AP se
    [   15.592517] startwlan.sh[1012]: Starting WLAN AP se
    [   15.599260] startwlan.sh[1012]: ddin
    [   15.599740] startwlan.sh[1014]: ddin
    [   15.635169] startwlan.sh[1014]: ommand failed: No such file or directory (
    [   15.635666] startwlan.sh[1015]: ommand failed: No such file or directory (
    [   15.680222] startwlan.sh[1015]: onfiguratioCould not read interface wlp1s0 fe
    [   15.680518] startwlan.sh[1015]: nl80211: Driver does not support authenticats
    [   15.680671] startwlan.sh[1015]: nl80211: deinit ifname=wlp1s0 disabled_11b_r0
    [   15.696248] startwlan.sh[1015]: Could not read interface wlp1s0 flags: No sue
    [   15.696445] startwlan.sh[1015]: nl80211 driver initialization failed.
    [   15.696527] startwlan.sh[1015]: wlp1s0: interface state UNINITIALIZED->DISABD
    [   15.696597] startwlan.sh[1015]: wlp1s0: AP-DISABLED
    [   15.696664] startwlan.sh[1015]: wlp1s0: CTRL-EVENT-TERMINATING
    [   15.696725] startwlan.sh[1015]: hostapd_free_hapd_data: Interface wlp1s0 wasd
    [   16.624581] startwlan.sh[1134]: SIOCSIFADDR: No such device
    [   16.640295] startwlan.sh[1134]: wlp1s0: ERROR while getting interface flags:e
    [   16.656249] startwlan.sh[1134]: SIOCSIFNETMASK: No such device
    [   16.672379] startwlan.sh[1134]: wlp1s0: ERROR while getting interface flags:e
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [  OK  ] Started startwlan.
    [   17.785085] startwlan.sh[1217]: iperf3: error - unable to start listener fors
    [   17.808166] startwlan.sh[1217]: iperf3: exiting
    [   18.793075] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full -f
    [   18.801602] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login: root
    Last login: Mon Dec 20 16:27:18 UTC 2021
    root@j7-evm:/opt/edge_ai_apps# ./setup_script.sh
    tensorflow
    dlpack
    onnxruntime
    edgeai-tidl-tools
    edgeai-tiovx-modules
    -- The C compiler identification is GNU 9.2.1
    -- The CXX compiler identification is GNU 9.2.1
    -- Check for working C compiler: /usr/bin/cc
    -- Check for working C compiler: /usr/bin/cc -- works
    -- Detecting C compiler ABI info
    -- Detecting C compiler ABI info - done
    -- Detecting C compile features
    -- Detecting C compile features - done
    -- Check for working CXX compiler: /usr/bin/c++
    -- Check for working CXX compiler: /usr/bin/c++ -- works
    -- Detecting CXX compiler ABI info
    -- Detecting CXX compiler ABI info - done
    -- Detecting CXX compile features
    -- Detecting CXX compile features - done
    -- CMAKE_BUILD_TYPE = Release PROJECT_NAME = edgeai-tiovx-modules
    -- CMAKE_BUILD_TYPE = Release PROJECT_NAME = edgeai-tiovx-modules-test
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /opt/edgeai-tiovx-modules/build
    -- Configuring done
    -- Generating done
    make[1]: Entering directory '/opt/edgeai-tiovx-modules/build'
    make[2]: Entering directory '/opt/edgeai-tiovx-modules/build'
    Scanning dependencies of target edgeai-tiovx-modules
    make[2]: Leaving directory '/opt/edgeai-tiovx-modules/build'
    make[2]: Warning: File '../bin/Release/libedgeai-tiovx-modules.so' has modificae
    [ 10%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_color_coo
    [ 10%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_multi_sco
    [ 15%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_img_mosao
    [ 21%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_dl_pre_po
    [ 26%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_dl_coloro
    [ 31%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_sensor_mo
    [ 42%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_viss_modo
    [ 42%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_ldc_moduo
    make[2]: warning:  Clock skew detected.  Your build may be incomplete.
    [ 47%] Built target edgeai-tiovx-modules
    Scanning dependencies of target edgeai-tiovx-modules-test
    make[2]: Warning: File '../bin/Release/edgeai-tiovx-modules-test' has modificate
    [ 57%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
    [ 63%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
    [ 68%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
    [ 73%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
    [ 78%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
    [ 84%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
    [ 89%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_commo
    [ 94%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/main.c.o
    [100%] Built target edgeai-tiovx-modules-test
    make[1]: Leaving directory '/opt/edgeai-tiovx-modules/build'
    -- Configuring done
    -- Generating done
    [  5%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_color_coo
    [ 36%] Building C object src/CMakeFiles/edgeai-tiovx-modules.dir/tiovx_viss_modo
    [ 52%] Building C object test/CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovo
    Install the project...
    -- Install configuration: ""
    -- Up-to-date: /usr/lib/edgeai-tiovx-modules/libedgeai-tiovx-modules.so.0.1.0
    -- Up-to-date: /usr/include/edgeai-tiovx-modules/include
    -- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_ldc_module_lut_1h
    -- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_multi_scaler_modh
    -- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_dl_pre_proc_moduh
    -- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_img_mosaic_modulh
    -- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_viss_module.h
    -- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_ldc_module.h
    -- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_color_convert_moh
    -- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_dl_color_blend_mh
    -- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_sensor_module.h
    -- Up-to-date: /usr/include/edgeai-tiovx-modules/include/tiovx_modules_common.h
    edgeai-gst-plugins
    The Meson build system
    Version: 0.53.2
    Source dir: /opt/edgeai-gst-plugins
    Build dir: /opt/edgeai-gst-plugins/build
    Build type: native build
    Project name: GstTIOVX
    Project version: 0.3.0
    C compiler for the host machine: cc (gcc 9.2.1 "cc (GCC) 9.2.1 20191025")
    C linker for the host machine: cc ld.bfd 2.34.0.20200220
    Host machine cpu family: aarch64
    Host machine cpu: aarch64
    Found pkg-config: /usr/bin/pkg-config (0.29.2)
    Run-time dependency gstreamer-1.0 found: YES 1.16.3
    Run-time dependency gstreamer-base-1.0 found: YES 1.16.3
    Run-time dependency gstreamer-video-1.0 found: YES 1.16.3
    Run-time dependency gstreamer-check-1.0 found: YES 1.16.3
    Run-time dependency gstreamer-allocators-1.0 found: YES 1.16.3
    Run-time dependency tiovx found: YES 0.1.0
    Run-time dependency ti_vision_apps found: YES 0.1.0
    Run-time dependency edgeai_tiovx_modules found: YES 0.1.0
    Compiler for C supports arguments -Wmissing-declarations: YES
    Compiler for C supports arguments -Wmissing-prototypes: YES
    Compiler for C supports arguments -Wredundant-decls: YES
    Compiler for C supports arguments -Wundef: YES
    Compiler for C supports arguments -Wwrite-strings: YES
    Compiler for C supports arguments -Wformat: YES
    Compiler for C supports arguments -Wformat-nonliteral: YES
    Compiler for C supports arguments -Wformat-security: YES
    Compiler for C supports arguments -Wold-style-definition: YES
    Compiler for C supports arguments -Winit-self: YES
    Compiler for C supports arguments -Wmissing-include-dirs: YES
    Compiler for C supports arguments -Waddress: YES
    Compiler for C supports arguments -Waggregate-return: YES
    Compiler for C supports arguments -Wno-multichar -Wmultichar: YES
    Compiler for C supports arguments -Wdeclaration-after-statement: YES
    Compiler for C supports arguments -Wvla: YES
    Compiler for C supports arguments -Wpointer-arith: YES
    Compiler for C supports arguments -Wuninitialized: YES
    Compiler for C supports arguments -Wunknown-pragmas: YES
    Compiler for C supports arguments -Wunused-function: YES
    Compiler for C supports arguments -Wunused-label: YES
    Compiler for C supports arguments -Wunused-value: YES
    Compiler for C supports arguments -Wunused-variable: YES
    Compiler for C supports arguments -Werror: YES
    Has header "dlfcn.h" : YES
    Has header "inttypes.h" : YES
    Has header "memory.h" : YES
    Has header "poll.h" : YES
    Has header "stdint.h" : YES
    Has header "stdlib.h" : YES
    Has header "stdio_ext.h" : YES
    Has header "strings.h" : YES
    Has header "string.h" : YES
    Has header "sys/param.h" : YES
    Has header "sys/poll.h" : YES
    Has header "sys/prctl.h" : YES
    Has header "sys/socket.h" : YES
    Has header "sys/stat.h" : YES
    Has header "sys/times.h" : YES
    Has header "sys/time.h" : YES
    Has header "sys/types.h" : YES
    Has header "sys/utsname.h" : YES
    Has header "sys/wait.h" : YES
    Has header "ucontext.h" : YES
    Has header "unistd.h" : YES
    Has header "sys/resource.h" : YES
    Program python3 found: YES (/usr/bin/python3)
    Configuring config.h using configuration
    Program hotdoc skipped: feature doc disabled
    Message: Hotdoc not found, not building the documentation
    Build targets in project: 17
    Found ninja-1.10.0 at /usr/bin/ninja
    ninja: Entering directory `build'
    [0/1] Regenerating build files.
    Version: 0.53.2
    Dependency gstreamer-1.0 found: YES 1.16.3 (cached)
    Dependency gstreamer-base-1.0 found: YES 1.16.3 (cached)
    Dependency gstreamer-video-1.0 found: YES 1.16.3 (cached)
    Dependency gstreamer-check-1.0 found: YES 1.16.3 (cached)
    Dependency gstreamer-allocators-1.0 found: YES 1.16.3 (cached)
    Dependency tiovx found: YES 0.1.0 (cached)
    Dependency ti_vision_apps found: YES 0.1.0 (cached)
    Dependency edgeai_tiovx_modules found: YES 0.1.0 (cached)
    Has header "dlfcn.h" : YES (cached)
    Has header "inttypes.h" : YES (cached)
    Has header "memory.h" : YES (cached)
    Has header "poll.h" : YES (cached)
    Has header "stdint.h" : YES (cached)
    Has header "stdlib.h" : YES (cached)
    Has header "stdio_ext.h" : YES (cached)
    Has header "strings.h" : YES (cached)
    Has header "string.h" : YES (cached)
    Has header "sys/param.h" : YES (cached)
    Has header "sys/poll.h" : YES (cached)
    Has header "sys/prctl.h" : YES (cached)
    Has header "sys/socket.h" : YES (cached)
    Has header "sys/stat.h" : YES (cached)
    Has header "sys/times.h" : YES (cached)
    Has header "sys/time.h" : YES (cached)
    Has header "sys/types.h" : YES (cached)
    Has header "sys/utsname.h" : YES (cached)
    Has header "sys/wait.h" : YES (cached)
    Has header "ucontext.h" : YES (cached)
    Has header "unistd.h" : YES (cached)
    Has header "sys/resource.h" : YES (cached)
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    [  135.319998] Initializing XFRM netlink socket
    Version: 0.53.2
    Version: 0.53.2
    [  138.895082] process 'docker/tmp/qemu-check886028213/check' started with execk
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    Version: 0.53.2
    ninja: error: manifest 'build.ninja' still dirty after 100 tries
    Setup FAILED! : Make sure you have active network connection
    I have already tried to power cycle the board and same issue happened.
    Is there a way to do this part without any internet connection, in offline mode ? Would you please explain me or share me some documentation about "do a clean build" ?
    Thank you for your time and attention.
    Xavier
  • Hi Takuma,
    This is the entire log from the setup_script.sh with a internet connection :
    tensorflow
    dlpack
    onnxruntime
    edgeai-tidl-tools
    -- Configuring done
    -- Generating done
    [ 47%] Linking C shared library ../../bin/Release/libedgeai-tiovx-modules.so
    [100%] Linking C executable ../../bin/Release/edgeai-tiovx-modules-test
    -- Installing: /usr/lib/edgeai-tiovx-modules/libedgeai-tiovx-modules.so.0.1.0
    edgeai-gst-plugins
    Version: 0.53.2
    [1/59] Compiling C object 'gst-libs/gs...ttiovx-1.0@sha/gsttiovxallocator.c.o'.
    FAILED: gst-libs/gst/tiovx/b91e147@@gsttiovx-1.0@sha/gsttiovxallocator.c.o
    cc -Igst-libs/gst/tiovx/b91e147@@gsttiovx-1.0@sha -Igst-libs/gst/tiovx -I../gstc
    cc1: error: /usr/include/processor_sdk/vision_apps/apps/basic_demos/app_rtos/rt]
    cc1: all warnings being treated as errors
    [2/59] Compiling C object 'gst-libs/gs...-1.0@sha/gsttiovxbufferpoolutils.c.o'.
    FAILED: gst-libs/gst/tiovx/b91e147@@gsttiovx-1.0@sha/gsttiovxbufferpoolutils.c.
    In file included from ../gst-libs/gst/tiovx/gsttiovxbufferpoolutils.c:67:
    ../gst-libs/gst/tiovx/gsttiovx.h:71:10: fatal error: app_init.h: No such file oy
       71 | #include <app_init.h>
    compilation terminated.
    [3/59] Compiling C object 'gst-libs/gs...tiovx-1.0@sha/gsttiovxbufferpool.c.o'.
    FAILED: gst-libs/gst/tiovx/b91e147@@gsttiovx-1.0@sha/gsttiovxbufferpool.c.o
    In file included from /usr/include/processor_sdk/tiovx/include/TI/tivx.h:77,
                     from ../gst-libs/gst/tiovx/gsttiovxbufferpool.h:70,
                     from ../gst-libs/gst/tiovx/gsttiovxbufferpool.c:64:
    /usr/include/processor_sdk/tiovx/include/TI/tivx_soc.h:73:2: error: #error Must2
       73 | #error Must define SOC_<SOC_NAME>, options: SOC_J6, SOC_J721E, SOC_J7212
    ninja: build stopped: subcommand failed.
    Xavier
  • Hi Xavier,
    I was able to reproduce the first issue. To fix this, I had to have an ethernet connection to internet before booting up the board, and run the setup_script.sh with internet.
    The root cause for this was during the compilation process it is either pulling some dependencies from a repository and/or there is some dependency with the system time, because the system time gets set at boot time by syncing with the time it gets through internet.
    As for a "clean build", my wording was bad. The setup_script.sh removes the build directories every time it is ran, so clean build is the same as just running the setup_script.sh again.
    For the second error that you are getting, I am in the process of reproducing that. I will get back to you tomorrow after I do some testing.
    Takuma
  • Hi Xavier,
    For the initial issue where the ninja build fails, it is due to system time not being set.
    As a workaround for the first issue, if you set the system time manually by using "date -s <current date>" then this issue should be fixed. The <current date> can be obtained by running "date" on a separate Linux machine that has the correct date/time. Alternatively, if the board is connected to internet at boot time, this time will automatically be obtained from the internet and set.
    The second issue I have not been able to reproduce on my side. Could you go into the /opt/edgeai-gst-plugins folder and post the output from running "git log"? My suspicion is the repository is not using the correct release branch. Attached is the expected git log for SDK 8.1 version.
    root@j7-evm:/opt/edgeai-gst-plugins# git log
    commit f899b0918c6743b10d0ec328e6f9cceb35c3f152 (HEAD -> release-0.5.3, origin/release-0.5.3)
    Author: Marco Herrera <marco.herrera@ridgerun.com>
    Date:   Wed Jan 12 14:35:34 2022 -0600
        Bump project version
    commit 1c03404c001c605daba2dcd0618ff824194ff791
    Merge: 303aec7 306bd02
    Date:   Tue Jan 11 12:20:34 2022 -0600
        Merge branch 'fix/memory-size-mismatch' into develop
    commit 306bd02b80a04f73472187ea5e1494ffe4d04779
    Date:   Tue Jan 11 12:14:47 2022 -0600
        Fix typo in warning message
    commit 6a117df6b253d865d695d5b9bbc59a57ae2d6d80
    Date:   Mon Jan 10 17:16:28 2022 -0600
    root@j7-evm:/opt/edgeai-gst-plugins# ls
    CONTRIBUTING  build       ext       meson.build        tests
    LICENSE       crossbuild  gst-libs  meson_options.txt
    README.md     docs        hooks     pkgconfig
    Takuma
  • Hi Xavier,
    I reread our posts, and came to the realization that the second issue is caused by having an older version of edgeai-gst-plugins. It should be solved by pulling in the latest commits by checking out the release-0.5.3 branch.
    So in summary:
    1. Initial issue where ninja build fails was due to invalid system time. This can either be solved by setting the system time manually with "date -s <correct date>" or rebooting the board with internet connection.
    2. Second issue where some files were not being found during build was due to having an older version of edgeai-gst-plugins repository. This can be fixed by checking out the correct release branch, which in our case would be release-0.5.3 branch.
    Takuma
  • Hi Takuma,
    It works perfectly thanks to your instructions, thanks Slight smile
    Xavier
