66AK2E05: KEYSTONE II <-> DSP <-> TSIP TIMESLOTS RAM ALLOCATION
Part Number: 66AK2E05
I try to use TSIP in order to send 512 timeslots via one lane, but i run out of L2SRAM.
When i try to use MSMCSRAM or DDR3 Sections, i get "corrupted" data in TSIP output.
Is it possible to use MSMCSRAM or DDR3 for TSIP ??
The project i use is: TSIP_K2E_C66TestProject.
.tsipData 188K
.appData 46124
My configuration:
file: test.cmd
SECTIONS
.tsipData > L2SRAM
.appData > L2SRAM
file: test.c
/* Buffer size is based only on the size of the instance*/
#define BUFSIZE_TSIP_INST_SHARED 40
/* Buffer size is function of TSIP_N_PORTS */
#define BUFSIZE_TSIP_HEAP_SHARED 200
/* Buffer size is a function of the number of time slots */
#define BUFSIZE_TSIP_HEAP_TIMESLOT 28672
/* Buffer size is a function of the number of time slots and TSIP_N_PORTS*/
#define BUFSIZE_TSIP_TX_DMA_BUFFER 8512
#define BUFSIZE_TSIP_RX_DMA_BUFFER 8512
#define BUFSIZE_TSIP_INST_SIZE_PORT 17
file: test.h
/* Size of application buffers */
#define BUFSIZE_APP 40*1 /*must be a multiple of the tx.frameSize (40).
Due to L2 memory size, max value for this define is 880*/
/* Number of TSIP ports used in the test */
#define NUM_USED_TSIP_PORTS 1
/* This test uses the same number of time slots per TSIP port being tested*/
/* Number of used time slots per TSIP port (same for all ports)*/
#define NUM_USED_TIME_SLOTS 512
file: tsip_cfg.h
* @def TSIP_MAX_TIMESLOTS
* The maximal number of TSIP timeslots to be used
#define TSIP_MAX_TIMESLOTS 512
