TDA4VM: fail to boot vision_apps through SBL
Part Number: TDA4VM
Hi, Experts,
I can boot vision_apps through SPL normally, but fail while use SBL, below are the steps, please help to check and help to find the root cause. Thanks.
SW: 8.0 SDK
HW: TDA4VM EVM
1. make vision_apps SD card
2. make sbl_mmcsd_image
3. make can_boot_app_mcu_rtos
4. modify k3-j721e-common-proc-board on bootargs and reserved_memory
5. generate atf_optee.appimagetikernelimage_linux.appimagetidtb_linux.appimage
6. make vision_apps
7. use vx_app_rtos_linux_mcu2_0.out, vx_app_rtos_linux_mcu2_1.out, vx_app_rtos_linux_c6x_1.out, vx_app_rtos_linux_c6x_2.out, vx_app_rtos_linux_c7x_1.out to generate lateapp1 and lateapp2
8. copy tiboot3.bintifs.binapplateapp1lateapp2atf_optee.appimagetikernelimage_linux.appimagetidtb_linux.appimage to BOOT
9. copy vx_app_rtos_linux_mcu2_0.out, vx_app_rtos_linux_mcu2_1.out, vx_app_rtos_linux_c6x_1.out, vx_app_rtos_linux_c6x_2.out, vx_app_rtos_linux_c7x_1 to lib/firmware/vision_apps_evm
10. boot from SD card
Then, log output from MCU_UART and MAIN_UART. on MAIN_UART, login and run vision_apps_init.sh, it shows mcu2_0 and mcu2_1 get stuck on "IPC: Waiting for HLOS to be ready... !!!", connect to mcu2_0 with CCS and find it get stuck on "while(!Ipc_isRemoteReady(ipc_proc_list[cpu_id]))".
  • Hi Fan,
    Can you confirm if you are using rootfs, sbl and appimage from the same SDK version?
    Parth
  • Hi, Patrh,
    Yes, all image were built in 8.0 SDK.RTOS SDK 08_00_00_12, Linux SDK 08_00_00_08.
    Thanks.
  • Hi, Parth,
    I did the same steps with SDK 7.3, it works well.
    Why same operation does not work with SDK 8.0?
    Thanks.
  • Hi Fan.
    There might be some changes with respect to memory allocation from 7.3 to 8.0.
    Can you please mention what modifications are done for bootargs and reserved memory?
    Parth
  • Hi, Parth,
    I have send the modified k3-j721e-common-proc-board.dts file to you through email. Please help to check.
    Thanks.
  • Hi Fan,
    I checked the dts you shared that looks fine.
    Can you please more details on how you are generating these images?
    Parth
  • Hi, Parth,
    use the modified dts to generate dtb, copy k3-j721e-common-proc-board.dtb to prebuilt-images folder and rename to base-board.dts
    modify constructappimagehlos.sh for linux build directory
    run constructappimagehlos.sh to get above three appimages
  • Hi, Parth,
    Can you give a try on SBL booting vision_app on your side and share the detailed steps to make it work.
    Thanks.
  • Hi Fan,
    Sure, I'll try that and get back to you.
    Parth
  • Hi, Parth,
    Any update from your side?
    Thanks.
  • Hi Fan_Zhang,
    Can you please to below e2e ticket? I have explained how to boot Linux using SBL an BootApp in OSPI mode
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1029452/tda4vm-how-to-boot-mcu-1-0-autosar-from-tiboot3/
    Brijesh
  • Hi, Brijesh,
    uboot is not needed in customer's boot flow. The target boot flow is RBL -> SBL -> can_boot_app -> vision_app image on R5F/DSP and Linux kernal/filesystem.
    We can boot successfully with SDK 7.3 using steps descripted above, but failed with SDK 8.0 using same steps.
    Please help to point the corresponding changes in operation. Thanks.
  • Hi Fan Zhang,
    Could you please let us understand what fails in the SDK8.0? Is it booting or building? Can you share build/boot log?
    Brijesh
  • Hi, Brijesh,
    It can boot, but main r5f is blocking at IPC hand shaking.
    Please see the log below. Thanks.
    root@j7-evm:~# cd /opt/vision_apps/
    root@j7-evm:/opt/vision_apps# ./vision_apps_init.sh
    root@j7-evm:/opt/vision_apps# [MCU2_0]      8.383210 s: CIO: Init ... Done !!!
    [MCU2_0]      8.383259 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_0]      8.383288 s: APP: Init ... !!!
    [MCU2_0]      8.383305 s: SCICLIENT: Init ... !!!
    [MCU2_0]      8.383483 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
    [MCU2_0]      8.383519 s: SCICLIENT: DMSC FW revision 0x15
    [MCU2_0]      8.383541 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_0]      8.383565 s: SCICLIENT: Init ... Done !!!
    [MCU2_0]      8.383584 s: UDMA: Init ... !!!
    [MCU2_0]      8.384418 s: UDMA: Init ... Done !!!
    [MCU2_0]      8.384465 s: MEM: Init ... !!!
    [MCU2_0]      8.384496 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e1000000 of size 16777216 bytes !!!
    [MCU2_0]      8.384543 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
    [MCU2_0]      8.384585 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ d8000000 of size 16777216 bytes !!!
    [MCU2_0]      8.384626 s: MEM: Init ... Done !!!
    [MCU2_0]      8.384644 s: IPC: Init ... !!!
    [MCU2_0]      8.384687 s: IPC: 6 CPUs participating in IPC !!!
    [MCU2_0]      8.384723 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_1]      8.662825 s: CIO: Init ... Done !!!
    [MCU2_1]      8.662875 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_1]      8.662906 s: APP: Init ... !!!
    [MCU2_1]      8.662923 s: SCICLIENT: Init ... !!!
    [MCU2_1]      8.663102 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
    [MCU2_1]      8.663140 s: SCICLIENT: DMSC FW revision 0x15
    [MCU2_1]      8.663164 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_1]      8.663188 s: SCICLIENT: Init ... Done !!!
    [MCU2_1]      8.663209 s: UDMA: Init ... !!!
    [MCU2_1]      8.664101 s: UDMA: Init ... Done !!!
    [MCU2_1]      8.664143 s: MEM: Init ... !!!
    [MCU2_1]      8.664175 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e2000000 of size 16777216 bytes !!!
    [MCU2_1]      8.664225 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!!
    [MCU2_1]      8.664268 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ d9000000 of size 117440512 bytes !!!
    [MCU2_1]      8.664311 s: MEM: Init ... Done !!!
    [MCU2_1]      8.664331 s: IPC: Init ... !!!
    [MCU2_1]      8.664377 s: IPC: 6 CPUs participating in IPC !!!
    [MCU2_1]      8.664413 s: IPC: Waiting for HLOS to be ready ... !!!
  • Hi Fan Zhang,
    I think vision apps dtb file is not included. Could you please check? You might require to merge this dtb file with common-proc-board dtb file.
    Brijesh
  • Hi, Brijesh,
    I have done the mergence. Similar merge operations were done when I test with 7.3 and 8.0 SDK. But 7.3 works, but 8.0 is blocked.
    Thanks.
  • Hi Fan Zhang
    Can you please share you updated DTB which you use to create the tidtb_linux.appimage and also send the Linux kernel logs?
    Also, one of the main changes from 7.3 SDK to 8.0 SDK w.r.t remoteprocs is the adoption of a design-by-contract (DBC) approach for resource table. The kernel drivers were loading the firmware again to look up the .resource_table section in 7.x SDKs, and this was optimized out in 8.x SDKs with the expectation that the .resource_table section be present at a specific location in the memory map. So if you are using old vision apps firmwares with 8.x Linux image then things would not work. I assume your baseline is SDK8.0 for everything based on your older response.
    Karan
  • Hi, Karan,
    I have sent the dts file to you by mail.
    Below is the Linux Kernel logs.
    Thanks.
    Welcome to minicom 2.7.1
    OPTIONS: I18n
    Compiled on Aug 13 2017, 15:25:34.
    Port /dev/ttyUSB0, 15:41:21
    Press CTRL-A Z for help on special keys
    NOTICE:  BL31: v2.5(release):08.00.00.004-dirty
    NOTICE:  BL31: Built : 22:30:09, Aug  4 2021
    ERROR:   GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.41-g4c2eade9f7 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain fo1
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
    [    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
    [    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000fbffffff]
    [    0.000000]   node   0: [mem 0x00000000fc000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x000000088fffffff]
    [    0.000000]   node   0: [mem 0x0000000890000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Failed to reserve 512 MiB
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: kernel page table isolation forced ON by KASLR
    [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
    [    0.000000] Memory: 2319360K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 1874944K reserved, 0K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008a00b0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a00c0000
    [    0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008363] Console: colour dummy device 80x25
    [    0.012926] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023596] pid_max: default: 32768 minimum: 301
    [    0.028342] LSM: Security Framework initializing
    [    0.033089] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040658] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.049649] rcu: Hierarchical SRCU implementation.
    [    0.054713] Platform MSI: msi-controller@1820000 domain created
    [    0.060966] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070265] EFI services will not be available.
    [    0.075026] smp: Bringing up secondary CPUs ...
    [    0.085958] Detected PIPT I-cache on CPU1
    [    0.085983] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.085993] GICv3: CPU1: using allocated LPI pending table @0x00000008a00d0000
    [    0.086026] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.086079] smp: Brought up 1 node, 2 CPUs
    [    0.115424] SMP: Total of 2 processors activated.
    [    0.120229] CPU features: detected: 32-bit EL0 Support
    [    0.125484] CPU features: detected: CRC32 instructions
    [    0.139223] CPU: All CPU(s) started at EL2
    [    0.143418] alternatives: patching kernel code
    [    0.148443] devtmpfs: initialized
    [    0.156828] KASLR disabled due to lack of seed
    [    0.161499] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.171463] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.178609] pinctrl core: initialized pinctrl subsystem
    [    0.184166] DMI not present or invalid.
    [    0.188379] NET: Registered protocol family 16
    [    0.193143] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.200486] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.208452] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.216732] thermal_sys: Registered thermal governor 'step_wise'
    [    0.216734] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.223126] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.236757] ASID allocator initialised with 32768 entries
    [    0.257447] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.264304] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.271061] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.278808] cryptd: max_cpu_qlen set to 1000
    [    0.284753] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.293634] vsys_3v3: supplied by evm_12v0
    [    0.297952] vsys_5v0: supplied by evm_12v0
    [    0.302580] iommu: Default domain type: Translated
    [    0.307739] SCSI subsystem initialized
    [    0.311883] mc: Linux media interface: v0.10
    [    0.316261] videodev: Linux video capture interface: v2.00
    [    0.321893] pps_core: LinuxPPS API ver. 1 registered
    [    0.326963] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.336300] PTP clock support registered
    [    0.340318] EDAC MC: Ver: 3.0.0
    [    0.344072] FPGA manager framework
    [    0.347579] Advanced Linux Sound Architecture Driver Initialized.
    [    0.354193] clocksource: Switched to clocksource arch_sys_counter
    [    0.360603] VFS: Disk quotas dquot_6.6.0
    [    0.364650] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.374385] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.380680] NET: Registered protocol family 2
    [    0.385278] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.393847] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.402614] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.410812] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.418618] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.425366] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.432257] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.439650] NET: Registered protocol family 1
    [    0.444353] RPC: Registered named UNIX socket transport module.
    [    0.450408] RPC: Registered udp transport module.
    [    0.455222] RPC: Registered tcp transport module.
    [    0.460027] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.466611] PCI: CLS 0 bytes, default 64
    [    0.470938] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.481229] Initialise system trusted keyrings
    [    0.485847] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.494091] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.500303] NFS: Registering the id_resolver key type
    [    0.505490] Key type id_resolver registered
    [    0.509764] Key type id_legacy registered
    [    0.513882] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.520730] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.528369] 9p: Installing v9fs 9p2000 file system support
    [    0.553577] Key type asymmetric registered
    [    0.557764] Asymmetric key parser 'x509' registered
    [    0.562762] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.570321] io scheduler mq-deadline registered
    [    0.574946] io scheduler kyber registered
    [    0.580133] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.586318] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.594727] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.600989] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.608796] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.616852] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.626145] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [    0.635672] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [    0.643526] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.656321] brd: module loaded
    [    0.662313] loop: module loaded
    [    0.666050] megasas: 07.714.04.00-rc1
    [    0.670952] libphy: Fixed MDIO Bus: probed
    [    0.675592] tun: Universal TUN/TAP device driver, 1.6
    [    0.680991] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.687404] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.693485] sky2: driver version 1.30
    [    0.697727] VFIO - User Level meta-driver version: 0.3
    [    0.703406] i2c /dev entries driver
    [    0.707546] sdhci: Secure Digital Host Controller Interface driver
    [    0.713866] sdhci: Copyright(c) Pierre Ossman
    [    0.718477] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.724762] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.731068] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.738164] optee: probing for conduit method.
    [    0.742718] optee: revision 3.12 (3d47a131)
    [    0.742962] optee: initialized driver
    [    0.752218] NET: Registered protocol family 17
    [    0.756830] 9pnet: Installing 9P2000 support
    [    0.761214] Key type dns_resolver registered
    [    0.765688] Loading compiled-in X.509 certificates
    [    0.774701] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.781032] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.789023] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
    [    0.813656] random: fast init done
    [    0.834235] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.841705] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.847762] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.853779] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.860142] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.866975] pca953x 3-0020: using no AI
    [    0.894937] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.901734] pca953x 3-0022: using AI
    [    0.906001] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    0.911976] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    0.918219] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    0.924709] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.934279] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.940512] pca953x 5-0020: supply vcc not found, using dummy regulator
    [    0.947327] pca953x 5-0020: using no AI
    [    0.974848] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
    [    0.980862] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
    [    0.986779] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
    [    0.993138] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.003088] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.011873] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.021676] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.038750] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.046435] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.054712] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.062988] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.073340] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.079759] pci_bus 0000:00: root bus resource [bus 00-0f]
    [    2.085365] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    2.095056] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.102106] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.108245] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.118114] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.128004] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    2.137962] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.147932] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [    2.157893] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [    2.167876] pci 0000:00:00.0: supports D1
    [    2.171970] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.177842] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [    2.189567] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.197757] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.207721] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.217680] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.229187] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
    [    2.235957] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.241232] pcieport 0000:00:00.0: PME: Signaling with IRQ 49
    [    2.247572] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.255243] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.263518] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.271799] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.281948] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    3.288358] pci_bus 0001:00: root bus resource [bus 00-0f]
    [    3.293963] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    3.303831] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    3.310877] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    3.317079] pci 0001:00:00.0: supports D1
    [    3.321173] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    3.328737] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.338478] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
    [    3.345245] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    3.350526] pcieport 0001:00:00.0: PME: Signaling with IRQ 52
    [    3.356783] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.364452] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.372729] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.381005] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.389542] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    4.395950] pci_bus 0002:00: root bus resource [bus 00-0f]
    [    4.401556] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [    4.410802] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
    [    4.421578] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    4.427779] pci 0002:00:00.0: supports D1
    [    4.431873] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    4.439427] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    4.449156] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
    [    4.455924] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    4.461184] pcieport 0002:00:00.0: PME: Signaling with IRQ 55
    [    4.467859] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    4.477748] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    4.484509] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.493430] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    4.503583] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    4.510342] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.518245] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    4.527577] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    4.536323] printk: console [ttyS2] enabled
    [    4.544760] printk: bootconsole [ns16550a0] disabled
    [    4.555155] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    4.564045] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    4.573541] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    4.584051] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    4.594203] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    4.604440] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    4.615044] scsi host0: ufshcd
    [    4.636925] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
    [    4.658198] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    4.665844] libphy: 46000f00.mdio: probed
    [    4.671223] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    4.679534] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    4.693341] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    4.702052] mmc0: CQHCI version 5.10
    [    4.706233] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    4.713965] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [    4.725674] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
    [    4.729165] vdd_mmc1: supplied by vsys_3v3
    [    4.741068] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.741670] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    4.756374] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    4.762086] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    4.763204] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    4.770385] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.777233] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    4.792227] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    4.792235] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    4.801656] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    4.816022] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
    [    4.828819] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
    [    4.836523] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [    4.882200] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    4.889860] libphy: 46000f00.mdio: probed
    [    4.895161] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    4.903463] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    4.916923] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    4.923826] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    4.931045] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    4.937293] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    4.947385] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    4.947669] mmc1: CQHCI version 5.10
    [    4.963105] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    4.970510] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    4.977854] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    4.985187] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    4.985201] mmc0: Command Queue Engine enabled
    [    4.993246] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    4.996930] mmc0: new HS400 MMC card at address 0001
    [    5.008936] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    5.010485] ALSA device list:
    [    5.013578] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    5.016456]   No soundcards found.
    [    5.022435] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    5.031710] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    6.020832] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    6.028835] Waiting for root device /dev/mmcblk1p2...
    [    6.085659] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    6.092518] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    6.102422]  mmcblk1: p1 p2
    [    6.640413] EXT4-fs (mmcblk1p2): recovery complete
    [    6.646245] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.654355] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    6.665832] devtmpfs: mounted
    [    6.669196] Freeing unused kernel memory: 1856K
    [    6.673797] Run /sbin/init as init process
    [    6.833323] systemd[1]: System time before build time, advancing clock.
    [    6.886595] NET: Registered protocol family 10
    [    6.891523] Segment Routing with IPv6
    [    6.910710] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -I)
    [    6.932477] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2020.09!
    [    6.972936] systemd[1]: Set hostname to <j7-evm>.
    [    7.173796] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock ��→ /run/docker.sock; please update the unit .
    [    7.242645] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.249375] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    7.261699] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    7.271631] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    7.294269] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.301523] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    7.322259] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.329414] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    7.350382] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password ��…ts to Console Directory Watch.
    [    7.374305] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R��…uests to Wall Directory Watch.
    [    7.398296] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    7.414251] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    7.434243] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    7.450247] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    7.474061] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    7.498274] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    7.522519] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    7.542378] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    7.577062] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    7.585399] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    7.606471] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    7.622531] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    7.646433] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    7.666364] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    7.689394] systemd[1]: Mounting Huge Pages File System...
    [    7.709873] systemd[1]: Mounting POSIX Message Queue File System...
    [    7.733275] systemd[1]: Mounting Kernel Debug File System...
    [    7.755054] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    7.774406] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st��…odes for the current kernel...
    [    7.801767] systemd[1]: Starting Start psplash boot splash screen...
    [    7.832334] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [    7.856772] systemd[1]: Starting RPC Bind...
    [    7.870381] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    7.893288] systemd[1]: Starting Journal Service...
    [    7.924551] systemd[1]: Starting Load Kernel Modules...
    [    7.949257] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems   7.956388] cryptodev: loading out-of-tree module taints kernel.
    [0m...
    [    7.968990] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    7.980604] systemd[1]: Starting udev Coldplug all Devices...
    [    7.991234] cryptodev: driver 1.10 loaded.
    [    8.001710] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    8.019454] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta��… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star��…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    8.232627] systemd-journald[167]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting rc.pvr.service...
             Starting Login Service...
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Network (Pre).
             Starting Network Service...
    [  OK  ] Started Telephony service.
    [    9.243493] PVR_K:  242: Read BVNC 22.104.208.318 from HW device registers
    [    9.255925] PVR_K:  242: RGX Device registered with BVNC 22.104.208.318
    [    9.267105] Bluetooth: Core ver 2.22
    [    9.271817] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
    [    9.279758] NET: Registered protocol family 31
    [    9.284236] Bluetooth: HCI device and connection manager initialized
    [    9.290634] Bluetooth: HCI socket layer initialized
    [    9.299854] Bluetooth: L2CAP socket layer initialized
    [    9.309957] Bluetooth: SCO socket layer initialized
    [  OK  ] Started Login Service.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [    9.543357] ina2xx 4-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma��…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [    9.770855] ina2xx 4-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.864921] ina2xx 4-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.936953] ina2xx 4-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.981441] ina2xx 4-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.044774] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [   10.096817] ina2xx 4-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.150478] ina2xx 4-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.202128] ina2xx 4-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.254424] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [   10.265039] ina2xx 4-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.313006] ina2xx 4-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.342235] random: crng init done
    [   10.345631] random: 7 urandom warning(s) missed due to ratelimiting
    [   10.354414] ina2xx 4-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.381529] ina2xx 4-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.418315] ina2xx 4-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.435001] ina2xx 4-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.459013] ina2xx 4-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.515780] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [   10.798225] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [   10.837985] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [  OK  ] Started Simple Network Man��…ement Protocol (SNMP) Daemon..
    [   10.908262] remoteproc remoteproc0: 4d80800000.dsp is available
    [   11.008219] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [   11.023578] CAN device driver interface
    [   11.106273] platform 41000000.r5f: configured R5F for IPC-only mode
    [   11.238808] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [   11.318390] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [   11.406264]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [   11.498543] remoteproc remoteproc1: 41000000.r5f is available
    [   11.579066] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   11.584668] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [   11.634285] remoteproc remoteproc1: attaching to 41000000.r5f
    [   11.689111] Unable to handle kernel paging request at virtual address ffff800018c0f983
    [   11.691153]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    **************************************************************[   11.750973] Mem abort info:
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages[   11.860922]   ESR = 0x96000021
     as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [   11.902975] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [   11.950466]   EC = 0x25: DABT (current EL), IL = 32 bits
    [   11.991679] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [   12.011228] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [   12.027951]   SET = 0, FnV = 0
    [   12.039642]   EA = 0, S1PTW = 0
    [   12.068580] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    [   12.078293] remoteproc remoteproc2: 4d81800000.dsp is available
    [   12.088017] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [   12.096000] Data abort info:
    [   12.153371]   ISV = 0, ISS = 0x00000021
    [   12.184758]   CM = 0, WnR = 0
    [   12.214047] remoteproc remoteproc2: attaching to 4d81800000.dsp
    [   12.247830] swapper pgtable: 64k pages, 48-bit VAs, pgdp=0000000080f90000
    [   12.314391] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [   12.347823] [ffff800018c0f983] pgd=00000008ffff0003, p4d=00000008ffff0003, pud=00000008ffff0003, pmd=00000008fffe0003, pte=0068000038000f17
    [   12.396491]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [   12.449302] Internal error: Oops: 96000021 [#1] PREEMPT SMP
    [   12.454868] Modules linked in: m_can_platform m_can can_dev ti_am335x_tscadc pruss ti_k3_r5_remoteproc(+) sa2ul sha512_generic authenc ti_k3_dsp_remoteproc(+) virtio_rpmsg_bus cdns_dphy vxd_dec videobuf6
    [   12.495950] CPU: 0 PID: 200 Comm: systemd-udevd Tainted: G           O      5.10.41-g4c2eade9f7 #1
    [   12.504639] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   12.504888] Hardware name: Texas Instruments K3 J721E SoC (DT)
    [   12.516171] pstate: 00000005 (nzcv daif -PAN -UAO -TCO BTYPE=--)
    [   12.522170] pc : rproc_handle_resources.constprop.0+0x94/0x168
    [   12.527989] lr : rproc_boot+0x334/0x670
    [   12.531810] sp : ffff80001328f7a0
    [   12.535111] x29: ffff80001328f7a0 x28: ffff8000113666a0
    [   12.540408] x27: ffff000826c59800 x26: fffffffffbc0f983
    [   12.545705] x25: ffff80001d000000 x24: ffff800010e89a08
    [   12.551001] x23: ffff000826c59838 x22: 0000000000000000
    [   12.556298] x21: ffff80001129c458 x20: ffff000826c59800
    [   12.561595] x19: 0000000000000000 x18: 0000000000000000
    [   12.566891] x17: 0000000000000000 x16: 0000000000000000
    [   12.572188] x15: 000043b933561ff2 x14: f973ec89dbeb57f3
    [   12.577488] x13: a0ff07bb35bb3edb x12: a5edf946fcdd63be
    [   12.582786] x11: 1eee5fb9510bfec1 x10: fd89eca808fe29d9
    [   12.588083] x9 : efdc1dbebb2ff09f x8 : 8d0599d4bb6cc19b
    [   12.593383] x7 : 579fcf3c9bf784c0 x6 : ffff000827258000
    [   12.598680] x5 : 0000000000000000 x4 : 0000000000000000
    [   12.603978] x3 : 00000000043f0779 x2 : 00000000fbc0f983
    [   12.609273] x1 : ffff800018c0f987 x0 : ffff80001d000000
    [   12.610847]  remoteproc2#vdev0buffer: registered virtio1 (type 7)
    [   12.614569] Call trace:
    [   12.614578]  rproc_handle_resources.constprop.0+0x94/0x168
    [   12.614582]  rproc_boot+0x334/0x670
    [   12.614584]  rproc_add+0x88/0x158
    [   12.614598]  k3_r5_probe+0x698/0xcf0 [ti_k3_r5_remoteproc]
    [   12.614605]  platform_drv_probe+0x54/0xa8
    [   12.644809]  really_probe+0xe4/0x3b0
    [   12.648373]  driver_probe_device+0x58/0xb8
    [   12.652456]  device_driver_attach+0x74/0x80
    [   12.656624]  __driver_attach+0x58/0xe0
    [   12.660360]  bus_for_each_dev+0x70/0xc0
    [   12.664180]  driver_attach+0x24/0x30
    [   12.667744]  bus_add_driver+0x14c/0x1f0
    [   12.671570]  driver_register+0x64/0x120
    [   12.675393]  __platform_driver_register+0x48/0x58
    [   12.680090]  k3_r5_rproc_driver_init+0x20/0x10000 [ti_k3_r5_remoteproc]
    [   12.686686]  do_one_initcall+0x54/0x1b8
    [   12.690511]  do_init_module+0x54/0x208
    [   12.694247]  load_module+0x1f28/0x24c8
    [   12.697981]  __do_sys_finit_module+0xb8/0xf8
    [   12.702236]  __arm64_sys_finit_module+0x20/0x30
    [   12.706755]  el0_svc_common.constprop.0+0x78/0x1a0
    [   12.711529]  do_el0_svc+0x24/0x90
    [   12.714832]  el0_svc+0x14/0x20
    [   12.717873]  el0_sync_handler+0xb0/0xb8
    [   12.721694]  el0_sync+0x180/0x1c0
    [   12.725000] Code: 128002b3 91274021 97ffebcc 1400002e (b87a6b20)
    [   12.731077] ---[ end trace 6589b7a440b7bdec ]---
    [   12.735822] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [   13.080290] remoteproc remoteproc2: remote processor 4d81800000.dsp is now attached
    [   13.090921] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [   13.110244] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [   13.248558] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [   13.366912] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [   13.466259] remoteproc remoteproc3: 64800000.dsp is available
    [   13.491082] remoteproc remoteproc3: attaching to 64800000.dsp
    [   13.514817] remoteproc remoteproc3: unsupported resource 65538
    [   13.526954] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [   13.542414]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [   13.568544] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   13.570438] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [   13.581889]  remoteproc3#vdev0buffer: registered virtio2 (type 7)
    [   13.617353] remoteproc remoteproc3: remote processor 64800000.dsp is now attached
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Listening on Load/Save RF ��…itch Status /dev/rfkill Watch.
    [  OK  ] Created slice system-weston.slice.
    [  OK  ] Started Weston Wayland Compositor.
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
             Mounting /run/media/mmcblk1p1...
    [   14.804014] usbcore: registered new interface driver usbfs
    [   14.864376] remoteproc remoteproc4: b034000.pru is available
    [   14.915315] remoteproc remoteproc5: b004000.rtu is available
    [   14.943705] usbcore: registered new interface driver hub
    [   14.999557] usbcore: registered new device driver usb
    [   15.000623] remoteproc remoteproc6: b00a000.txpru is available
    [   15.036058] remoteproc remoteproc7: b038000.pru is available
    [   15.097298] PVR_K:  900: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [   15.120556] remoteproc remoteproc8: b006000.rtu is available
    [   15.162249] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [   15.187157] remoteproc remoteproc9: b00c000.txpru is available
    [   15.219261] remoteproc remoteproc10: b134000.pru is available
    [   15.234999] remoteproc remoteproc11: b104000.rtu is available
    [   15.265422] remoteproc remoteproc12: b10a000.txpru is available
    [   15.310994] remoteproc remoteproc13: b138000.pru is available
    [   15.332350] remoteproc remoteproc14: b106000.rtu is available
    [   15.354913] remoteproc remoteproc15: b10c000.txpru is available
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm ttyS2
    Arago 2020.09 j7-evm ttyS2
    j7-evm login: [   16.072321] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   16.082351] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   16.090487] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [   16.102265] xhci-hcd xhci-hcd.2.auto: irq 613, io mem 0x06410000
    [   16.118368] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   16.134198] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   16.150198] usb usb1: Product: xHCI Host Controller
    [   16.155158] usb usb1: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
    [   16.170198] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   16.175423] hub 1-0:1.0: USB hub found
    [   16.186224] hub 1-0:1.0: 1 port detected
    [   16.191717] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   16.197234] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   16.206235] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   16.218213] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   16.226337] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   16.242194] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   16.249407] usb usb2: Product: xHCI Host Controller
    [   16.258195] usb usb2: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
    [   16.264711] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   16.274678] hub 2-0:1.0: USB hub found
    [   16.282206] hub 2-0:1.0: 1 port detected
    [   16.526204] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   16.686469] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
    [   16.698193] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [   16.705317] usb 1-1: SerialNumber: 35070061A7A1
    [   16.714689] hub 1-1:1.0: USB hub found
    [   16.722211] hub 1-1:1.0: 4 ports detected
    j7-evm login: root
    Last login: Wed Aug  4 22:20:53 UTC 2021
    root@j7-evm:/opt/vision_apps# [MCU2_0]      8.590799 s: CIO: Init ... Done !!!
    [MCU2_0]      8.590856 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_0]      8.590885 s: APP: Init ... !!!
    [MCU2_0]      8.590906 s: SCICLIENT: Init ... !!!
    [MCU2_0]      8.591102 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
    [MCU2_0]      8.591140 s: SCICLIENT: DMSC FW revision 0x15
    [MCU2_0]      8.591163 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_0]      8.591187 s: SCICLIENT: Init ... Done !!!
    [MCU2_0]      8.591207 s: UDMA: Init ... !!!
    [MCU2_0]      8.592401 s: UDMA: Init ... Done !!!
    [MCU2_0]      8.592453 s: MEM: Init ... !!!
    [MCU2_0]      8.592490 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e1000000 of size 16777216 bytes !!!
    [MCU2_0]      8.592589 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
    [MCU2_0]      8.592649 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ d8000000 of size 16777216 bytes !!!
    [MCU2_0]      8.592697 s: MEM: Init ... Done !!!
    [MCU2_0]      8.592717 s: IPC: Init ... !!!
    [MCU2_0]      8.592772 s: IPC: 6 CPUs participating in IPC !!!
    [MCU2_0]      8.592812 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_1]      8.877915 s: CIO: Init ... Done !!!
    [MCU2_1]      8.877974 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_1]      8.878004 s: APP: Init ... !!!
    [MCU2_1]      8.878022 s: SCICLIENT: Init ... !!!
    [MCU2_1]      8.878212 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
    [MCU2_1]      8.878254 s: SCICLIENT: DMSC FW revision 0x15
    [MCU2_1]      8.878280 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_1]      8.878305 s: SCICLIENT: Init ... Done !!!
    [MCU2_1]      8.878327 s: UDMA: Init ... !!!
    [MCU2_1]      8.879541 s: UDMA: Init ... Done !!!
    [MCU2_1]      8.879596 s: MEM: Init ... !!!
    [MCU2_1]      8.879672 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e2000000 of size 16777216 bytes !!!
    [MCU2_1]      8.879731 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!!
    [MCU2_1]      8.879780 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ d9000000 of size 117440512 bytes !!!
    [MCU2_1]      8.879825 s: MEM: Init ... Done !!!
    [MCU2_1]      8.879845 s: IPC: Init ... !!!
    [MCU2_1]      8.879899 s: IPC: 6 CPUs participating in IPC !!!
    [MCU2_1]      8.879938 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_1 ]     15.040464 s: CIO: Init ... Done !!!
    [C6x_1 ]     15.040488 s: ### CPU Frequency = 1350000000 Hz
    [C6x_1 ]     15.040499 s: APP: Init ... !!!
    [C6x_1 ]     15.040507 s: SCICLIENT: Init ... !!!
    [C6x_1 ]     15.040698 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
    [C6x_1 ]     15.040712 s: SCICLIENT: DMSC FW revision 0x15
    [C6x_1 ]     15.040721 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C6x_1 ]     15.040732 s: SCICLIENT: Init ... Done !!!
    [C6x_1 ]     15.040741 s: UDMA: Init ... !!!
    [C6x_1 ]     15.041980 s: UDMA: Init ... Done !!!
    [C6x_1 ]     15.042003 s: MEM: Init ... !!!
    [C6x_1 ]     15.042015 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e4000000 of size 16777216 bytes !!!
    [C6x_1 ]     15.042034 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
    [C6x_1 ]     15.042050 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e5000000 of size 50331648 bytes !!!
    [C6x_1 ]     15.042067 s: MEM: Init ... Done !!!
    [C6x_1 ]     15.042076 s: IPC: Init ... !!!
    [C6x_1 ]     15.042096 s: IPC: 6 CPUs participating in IPC !!!
    [C6x_1 ]     15.042110 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_1 ]     40.282062 s: IPC: HLOS is ready !!!
    [C6x_1 ]     40.286065 s: IPC: Init ... Done !!!
    [C6x_1 ]     40.286097 s: APP: Syncing with 5 CPUs ... !!!
    [C6x_2 ]     15.453642 s: CIO: Init ... Done !!!
    [C6x_2 ]     15.453666 s: ### CPU Frequency = 1350000000 Hz
    [C6x_2 ]     15.453677 s: APP: Init ... !!!
    [C6x_2 ]     15.453685 s: SCICLIENT: Init ... !!!
    [C6x_2 ]     15.453876 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
    [C6x_2 ]     15.453890 s: SCICLIENT: DMSC FW revision 0x15
    [C6x_2 ]     15.453900 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C6x_2 ]     15.453911 s: SCICLIENT: Init ... Done !!!
    [C6x_2 ]     15.453920 s: UDMA: Init ... !!!
    [C6x_2 ]     15.455167 s: UDMA: Init ... Done !!!
    [C6x_2 ]     15.455190 s: MEM: Init ... !!!
    [C6x_2 ]     15.455203 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e8000000 of size 16777216 bytes !!!
    [C6x_2 ]     15.455222 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
    [C6x_2 ]     15.455238 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e9000000 of size 50331648 bytes !!!
    [C6x_2 ]     15.455255 s: MEM: Init ... Done !!!
    [C6x_2 ]     15.455264 s: IPC: Init ... !!!
    [C6x_2 ]     15.455285 s: IPC: 6 CPUs participating in IPC !!!
    [C6x_2 ]     15.455299 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_2 ]     41.207642 s: IPC: HLOS is ready !!!
    [C6x_2 ]     41.211604 s: IPC: Init ... Done !!!
    [C6x_2 ]     41.211634 s: APP: Syncing with 5 CPUs ... !!!
    [C7x_1 ]     15.875795 s: CIO: Init ... Done !!!
    [C7x_1 ]     15.875809 s: ### CPU Frequency = 1000000000 Hz
    [C7x_1 ]     15.875820 s: APP: Init ... !!!
    [C7x_1 ]     15.875828 s: SCICLIENT: Init ... !!!
    [C7x_1 ]     15.875985 s: SCICLIENT: DMSC FW version [21.5.0--v2021.05 (Terrific Llam]
    [C7x_1 ]     15.875998 s: SCICLIENT: DMSC FW revision 0x15
    [C7x_1 ]     15.876009 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_1 ]     15.876020 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]     15.876029 s: UDMA: Init ... !!!
    [C7x_1 ]     15.876783 s: UDMA: Init ... Done !!!
    [C7x_1 ]     15.876795 s: MEM: Init ... !!!
    [C7x_1 ]     15.876806 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ 100000000 of size 268435456 bytes !!!
    [C7x_1 ]     15.876826 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!!
    [C7x_1 ]     15.876844 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 491520 bytes !!!
    [C7x_1 ]     15.876861 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
    [C7x_1 ]     15.876878 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ ec000000 of size 268435456 bytes !!!
    [C7x_1 ]     15.876897 s: MEM: Init ... Done !!!
    [C7x_1 ]     15.876905 s: IPC: Init ... !!!
    [C7x_1 ]     15.876919 s: IPC: 6 CPUs participating in IPC !!!
    [C7x_1 ]     15.876933 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]     42.271550 s: IPC: HLOS is ready !!!
    [C7x_1 ]     42.273518 s: IPC: Init ... Done !!!
    [C7x_1 ]     42.273532 s: APP: Syncing with 5 CPUs ... !!!
  • Hi , ,
    Any further update on this ticket?
    Brijesh
