Hello Champs,
Can DM6437 do a D1@30fps Encode and a D1@30fps Decode simulataenously?
As per codec data sheets, it should be possible, but it is not very clear from the stream names alone.
Thanks & Regards
Feroz
Hello Champs,
Thanks & Regards
Feroz
Hi Feroz,
Can you please specify the codec used along with the release version number?
Thanks and Regards,
Roopesh RN
Hello Roopesh,
It will be for H264.
In general, for all codecs would be a better answer to get.
Best REgards
Feroz
Hi Feroz,
We would be in a better position to give info if you can specify the release version numbers used for decoder and encoder.
Thanks and Regards,
Roopesh RN
