Customers need to configure QSPI (6-wire) to standard spi (4-wire) under linux, do we provide demo? or user guide?
Hi Nancy,
Can you elaborate and explain the use case above? QSPI boot supported on AM5716: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/949626/linux-am5749-dtb--how-to-write-u-boot-to-spi/3510386#3510386
Is the request here to boot in normal spi mode?
- Keerthy
Customer needs Device tree configuration demo to configure QSPI as standard SPI。I just found below description about this use case。
Hi Nancy,
&qspi {
status = "okay";
spi-tx-bus-width = <1>;
spi-rx-bus-width = <1>;
spi-max-frequency = <500000>;
Can you try with the above properties added? Basically tx/rx bus width is set to 1 & clock frequency is lowered.
- Keerthy
