I am develop the
Other Parts Discussed in Thread: DM3725
I am develop the video play function on DM3725 chip, the sequence is as following:
 Init():
                Open Device (“/dev/video2”)
                Query Capability
                Rotate
                Set Pixel Format
                Set Color Key
                Enable Alpha Blending
                Request Buffer
                Query Buffer
                Memory Map
                Queue Buffer
                Set Crop Size
                Set Display Size
                Stream On
Play():   loop
                                Dequeue Buffer
                                Fill Data
                                Queue Buffer
Exit():
                Stream Off
                Memory Unmap
                Close Device
It works well.
But I have a question: when I want to scale the video during playing, I need change the “crop size” and/or “display size” (red steps), which steps above should I do?
Now my solution is run exit() and then init() again, it works but not good, the performance is bad and apparent screen blink is observable, so I want to know which steps could be skipped.
Thank you very much.
  • Gang Wu,
    Have you found success with this? If so, please post your method.
    If not, my recommendation is
    1. Cleanly exit the loop
    2. Stream Off
    3. Set Crop Size
    4. Set Display Size
    5. Stream On
    6. Re-enter the loop
    Please let me know if this helps. I have not tested it and I am not an expert on this, but it has been a while since your post and I wanted to at least offer a suggestion.
    RandyP
    If you need more help, please reply back. If this answers the question, please click  Verify Answer  , below.
