Part Number: TDA4VM
Accroiing to this documentation, the only image formats RGB, BGR and RGBmax.
our camerea and images are gerscale.
which format should i use?
You can convert your input data to raw binary data and use inFileFormat = 1 to feed raw binary data to TIDL. Please refer inFileFormat and inData variables in following documentation :
Anshu
HI,
and i should still use inDataForma=1t?
i an asking nows about the TIDL inporter.
inDataFormat becomes irrelevant when user uses inFileFormat =1 as in this case no pre-processing is done on the input and the input is directly fed as it is to the TIDL network.
Anshu
HI,
According to this the tidl library suppport the following versions:
Is it correct? do you have a more updated version that supports TensorFlow 1.14?
how do i know whici versions are suppported by the library?
Oren
Hi Oren,
As mentioned in the documentation, In most cases new version models also shall work since the basic operations like convolution, pooling etc don't change. Incase something has changed then import tool parser needs to be updated for the same. Design for the same is available here :
software-dl.ti.com/.../md_tidl_fsg_import_tool_design.html
Anshu
HI Anshu
Thanks for the reply
the model_import.out always return DIM error for all converted models.
Here are example for configuration file we use:
for pb
modelType = 1
inputNetFile = /dms_app/models/seatbelt/seatbelt_ambarella.ckpt.pb
outputNetFile = /dms_app/models/seatbelt/tidl/seatbelt_ambarella.ckpt.pb.tidl
outputParamsFile = /dms_app/models/seatbelt/tidl/seatbelt_ambarella.ckpt.pb.tidl.params
inDataNorm = 0
inFileFormat = 1
inData = seatbelt_images_list.txt
tidl_model_import.out models/seatbelt/seatbelt_config_tf.txt
TF Model (Proto) File : /dms_app/models/seatbelt/seatbelt_ambarella.ckpt.pb
TIDL Network File : /dms_app/models/seatbelt/tidl/seatbelt_ambarella.ckpt.pb.tidl
TIDL IO Info File : /dms_app/models/seatbelt/tidl/seatbelt_ambarella.ckpt.pb.tidl.params
** All the Input Tensor Dimensions has to be greater then Zero
** DIM Error - For Tensor 0, Dim 0 is 0
for onnyx
modelType = 2
inputNetFile = /dms_app/models/seatbelt/onnyx/SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314-onnx
outputNetFile = /dms_app/models/seatbelt/tidl/seatbelt_onnyx.tidl
outputParamsFile = /dms_app/models/seatbelt/tidl/seatbelt_onnyx.tidl.params
inDataNorm = 0
inFileFormat = 1ONNX Model (Proto) File : /dms_app/models/seatbelt/onnyx/SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314-onnx
TIDL Network File : /dms_app/models/seatbelt/tidl/seatbelt_onnyx.tidl
TIDL IO Info File : /dms_app/models/seatbelt/tidl/seatbelt_onnyx.tidl.params
Current ONNX OpSet Version : 15
we are converting form keras to pb and onnyx,
Do you know of proven convertor that works with your tidl_model_import.out ?
BTW, the link you had sent is for running tests, we need to import the modes first.
Oren
Hi Oren,
Can you share the import configuration file? it look like you are not setting the input tensor dimensions correctly.
Anshu
Oren,
I just noticed that you probably shared the import configuration in your previous reply. Can you set following parameter to inform the input resolution to the import tool :
inWidth = ?
inHeight = ?
inNumChannels = ?
Anshu
sure, attaching two files, one for onnx and one for tensor flow.
i willl and set the values. but according to the document, they are not mandatory
modelType = 1 inputNetFile = /dms_app/models/seatbelt/seatbelt_ambarella.ckpt.pb outputNetFile = /dms_app/models/seatbelt/tidl/seatbelt_ambarella.ckpt.pb.tidl outputParamsFile = /dms_app/models/seatbelt/tidl/seatbelt_ambarella.ckpt.pb.tidl.params inDataNorm = 0 inFileFormat = 1 inData = seatbelt_images_list.txt
modelType = 2 inputNetFile = /dms_app/models/seatbelt/onnyx/SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314-onnx outputNetFile = /dms_app/models/seatbelt/tidl/seatbelt_onnyx.tidl outputParamsFile = /dms_app/models/seatbelt/tidl/seatbelt_onnyx.tidl.params inDataNorm = 0 inFileFormat = 1 inData = seatbelt_images_list.txt
HI,
I have used the below confguration:
modelType = 1
inWidth = 80
inHeight = 128
inNumChannels = 1
inDataNorm = 0
inFileFormat = 1
inData = /dms_app/models/seatbelt/seatbelt_images_list.txt
Now i get the below error:
TIDL ALLOWLISTING LAYER CHECK: [TIDL_InnerProductLayer] y/MatMul input shape of inner product must be 1x1x1xN.
TIDL ALLOWLISTING LAYER CHECK: [TIDL_InnerProductLayer] width/MatMul input shape of inner product must be 1x1x1xN.
TIDL ALLOWLISTING LAYER CHECK: [TIDL_InnerProductLayer] height/MatMul input shape of inner product must be 1x1x1xN.
TIDL ALLOWLISTING LAYER CHECK: TIDL_E_QUANT_STATS_NOT_AVAILABLE] tidl_quant_stats_tool.out fails to collect dynamic range. Please look into quant stats log. This model will get fault on ta
should i set outDataNamesList? how do i set the sizes? can it be done automaticvally?
another qustion,
The importer is in : /dms_app/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/tidl_j721e_08_02_00_11/ti_dl/utils/tidlModelImport/out and it is lookinf for
Couldn't open tidlStatsTool file: ../../test/PC_dsp_test_dl_algo.out
which exist someplace else. how can i set the path correctly?
Oren,
They are not mandatory if they are already present in the model but it looks like in this case model doesnt contain information about resolution.
Can you tell what kind of reshape operator is present before the inner product?
Couldn't open tidlStatsTool file: ../../test/PC_dsp_test_dl_algo.outwhich exist someplace else. how can i set the path correctly?
This file is present inside tidl_j721e_08_02_00_11/ti_dl/test/PC_dsp_test_dl_algo.out ( can you check if this file is present in your installation). By defaults paths are already relative to the import tool location
Anshu
yes. they exist in 3 locations:
/dms_app/models_builder/edgeai-tidl-tools/tidl_tools/PC_dsp_test_dl_algo.out
/dms_app/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/tidl_j721e_08_02_00_11/tidl_tools/PC_dsp_test_dl_algo.out
/dms_app/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/tidl_j721e_08_02_00_11/ti_dl/test/PC_dsp_test_dl_algo.out
but not in the relative path
Oren,
../../test/PC_dsp_test_dl_algo.out path looks right with relative to tidl_j721e_08_02_00_11/ti_dl/utils/tidlModelImport/. At this location you should have the PC_dsp_test_dl_algo.out. Can you confirm from which directory you are running the import tool? Expectation is to run from tidl_j721e_08_02_00_11/ti_dl/utils/tidlModelImport/ directory.
Anshu
HI,
this is the directory structure:
./ti-processor-sdk-rtos-j721e-evm-08_02_00_05/tidl_j721e_08_02_00_11/ti_dl/utils/tidlModelImport/out/tidl_model_import.out
./ti-processor-sdk-rtos-j721e-evm-08_02_00_05/tidl_j721e_08_02_00_11/ti_dl/test/PC_dsp_test_dl_algo.out
this will not work: ../../test/PC_dsp_test_dl_algo.out
this will work: ../../../test/PC_dsp_test_dl_algo.out
Can i change it myselft?
i am using: ti-processor-sdk-rtos-j721e-evm-08_02_00_05.tar.gz
Oren,
You need to run import tool from tidl_j721e_08_02_00_11/ti_dl/utils/tidlModelImport/ as below
./out/tidl_model_import.out <import config file>
Anshu
I have copuied the folder.
About
The also team had responded:
We don't have any reshape explicitlly defined in the model
Oren,
As per the snapshot of the model which you shared earlier it indicates that there is a reshape layer before inner product layer.
Anshu
Oren,
Can you share the generated model visualization output of this network. You can refer the following documentation incase you are not familiar with this ;
Anshu
aboive is the new model.
Now i get different errors:
TF operator Conv2DBackpropInput is not suported now.. By passing
TF operator Pack is not suported now.. By passing
TF operator StridedSlice is not suported now.. By passing
** DIM Error - For Tensor 26, Dim 1 is -1
this is the configuration:
modelType = 1
inWidth = 80
inHeight = 128
inNumChannels = 1
inDataNorm = 0
inFileFormat = 1
Do you a recommended tool for conversion between keras(h5) and onnyx or pb? i think that a better conversion tool will solve our problems
oren
Hi Oren,
Have you run optimize_for_inference script on the frozen model as mentioned in below documentation :
Anshu
HI Anshu,
I dont have the optimize_for_inference.py ifile is not a part of the ti-processor-sdk-rtos-j721e-evm-08_02_00_05.tar.gz.
Is this the right file? according to the doc you have sent it should be a part oif the delivery and should be at this location: ti_dl/test/testvecs/models/public/tensorflow/mobilenet_v2
Oren
Oren,
optimize_for_inference.py is not part of TIDL software. It comes as part of tensorflow the same is mentioned in the docs as can be seen from below snapshot of documentation:
Anshu
Hi Anshu,
I have taken the optimize_for_inference.py from the above location and ran the below command:
Oren,
Not sure why the error which you were getting earlier is different from what you are sharing now. Either ways can you try exporting the model to tflite and see if it helps? Also will it be possible for you to share a model/representative model where the issue is reproducible?
Have you considered using the below option for import, this will improve the ease of use for these scenarios.
https://github.com/TexasInstruments/edgeai-tidl-tools
Anshu
Incase you want to give a try with exporting to tflite model then you can refer the following link for the same :
https://www.tensorflow.org/api_docs/python/tf/compat/v1/lite/TFLiteConverter#from_frozen_graph
Anshu
Hi Jain,
I have alreadt tried it.
But all the examples refers to the model's zoo... they download it and the then run it.
Which does not help us.
I ditsnt see any documenatation that eaxplains how to take out own model and convert it to tidl.
Ihave tried running: edgeai-tidl-tools/examples/osrt_python/ort/onnxrt_ep.py but as i said, it use models from zoo which are alread converted(as far as i understand).
The Readm.md does not give exampes to gthe bring your own model example.
Unless the t/onnxrt_ep.py does just that, but is didnt undertand it from the documentation
Hi Anshu,
I have converting using the example in the site:
model = tf.keras.models.load_model('keras/SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314.h5')
converter = tf.lite.TFLiteConverter.from_keras_model(model)
tflite_model = converter.convert()
open("SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314.h5.tflite", "wb").write(tflite_model)
This is the configuration file i use:
modelType = 3
inputNetFile = /dms_app/models/seatbelt/SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314.h5.tflite
outputNetFile = /dms_app/models/seatbelt/tidl/SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314.h5.tflite.tidl
outputParamsFile = /dms_app/models/seatbelt/tidl/SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314.h5.tflite.tidl.params
inWidth = 80
inHeight = 128
inNumChannels = 1
inDataNorm = 0
inFileFormat = 1
This is how i run the converter:
d /dms_app/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/tidl_j721e_08_02_00_11/ti_dl/utils/tidlModelImport/out ; ./tidl_model_import.out /dms_app/models/seatbelt/seatbelt_config_tf.txt ; cd
I get segmetation fault:
TFLite Model (Flatbuf) File : /dms_app/models/seatbelt/SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314.h5.tflite
TIDL Network File : /dms_app/models/seatbelt/tidl/SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314.h5.tflite.tidl
TIDL IO Info File : /dms_app/models/seatbelt/tidl/SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314.h5.tflite.tidl.params
41
Segmentation fault (core dumped)
Hi Oren,
I see there is "Shape- Strided Slice- Pack" combination of layers in the model. It is caused due to dynamic batch size in the tflite model. In case it is not intentional, can you refer to below link and see if you can remove this combination?
https://github.com/tensorflow/tensorflow/issues/43882#issuecomment-731636562
As for running your model in edgeai_tidl_tools (https://github.com/TexasInstruments/edgeai-tidl-tools), you can set the model you want to run here: https://github.com/TexasInstruments/edgeai-tidl-tools/blob/a72b0b1b28de663a2fcbe8d40cd09b4bf4e7e3d3/examples/osrt_python/ort/onnxrt_ep.py#L224
And specify the corresponding config here: https://github.com/TexasInstruments/edgeai-tidl-tools/blob/a72b0b1b28de663a2fcbe8d40cd09b4bf4e7e3d3/examples/osrt_python/common_utils.py#L347
Please refer to the available configs to add new one.
You can specify the "model_path" (path where your tflite model is placed) as part of this config, and then run the onnxrt_ep.py script to compile the model.
Anand
Btw, since model is converted to tflite now, use tflrt_delegate.py above and not onnxrt_ep.py.
HI Anand,
Does the onnxrt_ep.py. does the same as tidl_model_import.out? according to code it is downloading model from the zoo,
Oren
Hi Oren,
"python3 onnxrt_ep.py -c" is equivalent to running tidl_model_import.out, however using ONNX runtime interface. If you have the model available in specified 'model_path', as I have explained above, it will use the existing model.
Anand
I have ran LD_LIBRARY_PATH="/dms_app/tidl_tools/" python3 onnxrt_ep.py --compile with our onnyx models.
i got the below error:
Process Process-1:
Traceback (most recent call last):
File "/usr/lib/python3.6/multiprocessing/process.py", line 258, in _bootstrap
self.run()
File "/usr/lib/python3.6/multiprocessing/process.py", line 93, in run
self._target(*self._args, **self._kwargs)
File "onnxrt_ep.py", line 219, in run_model
sess = rt.InferenceSession(config['model_path'] ,providers=EP_list, provider_options=[delegate_options, {}], sess_options=so)
File "/usr/local/lib/python3.6/dist-packages/onnxruntime/capi/onnxruntime_inference_collection.py", line 283, in __init__
self._create_inference_session(providers, provider_options)
File "/usr/local/lib/python3.6/dist-packages/onnxruntime/capi/onnxruntime_inference_collection.py", line 310, in _create_inference_session
sess = C.InferenceSession(session_options, self._model_path, True, self._read_config_from_model)
onnxruntime.capi.onnxruntime_pybind11_state.Fail: [ONNXRuntimeError] : 1 : FAIL : Load model from /dms_app/cipia/seatbelt/SeatbeltSegmentationUNet_128x80_6ch_v9_20210609T195314-onnx failed:/home/a0230315/workarea/onnxrt/onnxruntime/onnxruntime/core/graph/model.cc:111 onnxruntime::Model::Model(onnx::ModelProto&&, const PathString&, const IOnnxRuntimeOpSchemaRegistryList*, const onnxruntime::logging::Logger&) Unknown model file format version.
My script is able to run with your models
Hi Oren,
Can you please share your model? I can give a try on my end and check for the issue.
Anand
Hi Oren,
Please try exporting your model with opset version 11 and then running compilation and inference.
Anand
