SK-TDA4VM: setup_script.sh compilation error, missing h. file
Part Number: SK-TDA4VM
Other Parts Discussed in Thread: TDA4VM
Hi team,
Here's an issue from the customer may need your help:
SDK: Linux SDK for edge AI applications on TDA4VM JacintoTm processors, Version: 08.01.00.02.
[ 7%] Building CXX object dl_inferer/CMakeFiles/ti_dl_inferer.dir/src/ti_dl_inferer.cpp.o
In file included from /opt/tensorflow/tensorflow/lite/core/api/op_resolver.h:22,
from /opt/tensorflow/tensorflow/lite/interpreter_builder.h:25,
from /opt/tensorflow/tensorflow/lite/model.h:21,
from /opt/edge_ai_apps/apps_cpp/dl_inferer/../dl_inferer/include/ti_tflite_inferer.h:36,
from /opt/edge_ai_apps/apps_cpp/dl_inferer/src/ti_dl_inferer.cpp:37:
/opt/tensorflow/tensorflow/lite/schema/schema_generated.h:21:10: fatal error: flatbuffers/flatbuffers.h: No such file or directory
21 | #include "flatbuffers/flatbuffers.h"
compilation terminated.
make[2]: *** [dl_inferer/CMakeFiles/ti_dl_inferer.dir/build.make:63: dl_inferer/CMakeFiles/ti_dl_inferer.dir/src/ti_dl_inferer.cpp.o] Error 1
make[2]: Leaving directory '/opt/edge_ai_apps/apps_cpp/build'
make[1]: *** [CMakeFiles/Makefile2:199: dl_inferer/CMakeFiles/ti_dl_inferer.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 10%] Building CXX object utils/CMakeFiles/edgeai_utils.dir/src/ti_logger.cpp.o
[ 14%] Linking CXX static library ../../lib/Release/libedgeai_utils.a
[ 14%] Built target edgeai_utils
make[1]: Leaving directory '/opt/edge_ai_apps/apps_cpp/build'
make: *** [Makefile:130: all] Error 2
Setup FAILED! : Make sure you have active network connection
Could you help check this case? Thanks.
Cherry
  • Hi Cherry,
    I did a clean installation of Linux SDK for Edge AI and ran the setup script, but I have not been able to replicate the error on my side.
    • Could you make sure the customer has ethernet connected before booting up the board?
    • Could the customer check whether /opt/tensorflow/tensorflow/lite/tools/make/downloads/flatbuffers/include/flatbuffers has flatbuffers.h?
    Takuma
