TMS320C5535: About register settings when supplying a external oscillator to USB(Again)
Part Number: TMS320C5535
Hi experts,
When supplying from a external oscillator instead of using the built-in USBOSC, are the following register settings correct?
USBOSCBIASDIS=1
USBOSCDIS=0
As background, my customer used to employ a 12MHz crystal and oscillate it using the built-in USBOSC, but the crystal they employ is now EOL. Many manufacturers do not handle 12MHz, and we are considering replacing it with a external oscillator. I have checked section 5.7.4.3.3.3 in the datasheet, but there is no explanation about the register setting values.
And Will you continue to support the C5535? (Same as C5517?).
I found the following thread.
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/818771/faq-support-guidance-for-c5000-digital-signal-processors
I was confused because the C5535 is not mentioned on the product page as shown below. The figure below is based on the C5515 page. It would be helpful to know the latest status regarding support guidance for the C553x.
O.H
