I have downloaded UPP_BIOS_Driver_Install_v10.zip from Wiki
I need to configure this driver for A transmit mode and B Recieve mode(Duplex1)
I have done the following changes in UPP_Config()
// start with default settings
*upp_setup = UPP_USERPARAMS;
// apply common settings
upp_setup->params.A.clock_div = upp_clock_div;
upp_setup->params.A.fxn_eow = (upp_CbFxn)Upp_Complete_CB;
upp_setup->params.A.fxn_dpe = (upp_CbFxn)Upp_Error_CB;
upp_setup->params.A.fxn_err = (upp_CbFxn)Upp_Error_CB;
upp_setup->params.A.fxn_uor = (upp_CbFxn)Upp_Error_CB;
upp_setup->params.A.idle_value = 0xAAAA;
upp_setup->params.B.clock_div = upp_clock_div;
upp_setup->params.B.fxn_eow = (upp_CbFxn)LOCAL_upp_complete_cb;
upp_setup->params.B.fxn_eol = (upp_CbFxn)LOCAL_upp_complete_EOL;
upp_setup->params.B.en_enable = TRUE;
upp_setup->params.B.en_wait = TRUE;
upp_setup->params.B.en_start = FALSE;
upp_setup->params.B.inv_clock =TRUE;
upp_setup->params.A.width = 16;
upp_setup->params.B.width = 16;
upp_setup->params.A.direction = upp_dir_xmit;
upp_setup->params.B.direction = upp_dir_rcv;
upp_setup->params.channels = 2;
I am able to recieve data bytes with this configuration. It would be of help if you could help me configure UPP driver in Transmit mode Thanks and regards Veena
