Part Number: TDA4VM
Hi I was able to run the app_single_cam --test that uses the image stored in /opt/vision_apps/test_data/psdkra/app_single_cam/IMX390_001/input2.raw.
I am trying to modify the code in order to read a raw image saved with another IMX sensor with resolution 1924x1024.
I have customized the sensorParams.sensorInfo.raw_params structure in order to make ti compliant with the new raw image format as follow:
However the code get stuck within the function "app_run_graph" when the following function is called:
