Part Number: TDA4VM
In regards to the TDA4V Mid Plu / High:
Is it possible to use the SoC to output clock signals for FPDLink III/IV Ser/Des REFCLK input pins?
Part Number: TDA4VM
The output clocks from TDA4 devices are typically used for serial communication (SPI, McASP), Audio reference (sampling), and similar. Typically their quality is not sufficient to source clocks for higher performance ICs - which require higher accuracy/jitter specs.
