Locate the source file error
Other Parts Discussed in Thread: OMAPL138, SYSBIOS
I am using BIOSPSP and OMAPL138 device and CCS.
My code run perfect but when i press halt , it give me error.
source not found. and locate the source file error. source file which is not found " 0 ti_sysbios_family_da830_Hwi_restore_E(unsigned int) at Hwi.c : 0xc3034284 "
I know this is a place in sysbios/knl . But why compiler give this error. What setting do i need in tools or change in conf ?
Thank you
  • This message is just telling you that CCS can't locate the source file for the instruction that you're currently halted at. It's not really a problem--you've halted the target in the middle of some SYS/BIOS code. Unless you're interested in stepping through the SYS/BIOS source, you can just ignore this message.
    Chris
