TDA4VM: Yocto/Arago How to generate SDK/linux-devkit with yocto?
Part Number: TDA4VM
I would like to know, how to (re)generate the linux-devkit (or SDK in yocto terms) after the linux image has been changed.
I need to do this, for example after adding boost library, qt-framework, changing compiler version, etc... for developing efficiently linux userspace application.
Normally, you do this by bitbake <image-name> -c do_populate_sdk or -c do_populate_sdk_ext.
However I run into a lot of trouble by trying doing this.
So I am hoping for any help or suggestions, since the linux-devkit within the PSDKL had to be generated in some way.
I'm currently using the PDSKL 08_02 release configuration.
Thanks and best regards,
Thomas
//EDIT: I use PROCESSOR-SDK-LINUX-J721E 08.02
