Part Number: TDA4VM
Hi TI Experts,
I want to boot TDA4VM from eMMC UDA partition using SBL in SDK7.1. When I try to modify the code according to the FAQ of SDK8.1, it fails with no log.
Can someone share the process in SDK 7.1?
Thanks in advance.
Part Number: TDA4VM
Hi TI Experts,
Thanks in advance.
Are you able to partition eMMC and flash the binaries?
Also, can you please share the sbl_mmcsd.c you are using?
Parth
yes, I have partitioned eMMC and flashed the binaries.
The sbl_mmcsd.c I am using is as follows:
* \file sbl_mmcsd.c
* \brief This file contains functions for MMCSD File read operations for SBL
* Copyright (C) 2015 - 2018 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Include Files */
#include <stdint.h>
/* TI-RTOS Header files */
#include <ti/drv/uart/UART_stdio.h>
#include <ti/drv/mmcsd/MMCSD.h>
#include <ti/drv/mmcsd/soc/MMCSD_soc.h>
#include <ti/drv/mmcsd/src/MMCSD_osal.h>
/* SBL Header files. */
#include "sbl_rprc_parse.h"
#include "sbl_mmcsd.h"
/* K3 Header files */
#ifdef BUILD_MCU
#include <sbl_sci_client.h>
#endif
#ifdef SECURE_BOOT
#include "sbl_sec.h"
#endif
#define BOOT_EMMC
//zhangsc pdk_jacinto_07_01_00_45/packages/ti/build
//make BOARD=j721e_evm CORE=mcu1_0 sbl_lib_mmcsd_clean
//make BOARD=j721e_evm CORE=mcu1_0 sbl_mmcsd_img_clean
* \brief SBL_FileRead function reads N bytes from SD card and
* advances the cursor.
* \param buff - Pointer to data buffer
* \param fileptr - Read head pointer
* \param size - Number of bytes to read
* \return Error code on file error
int32_t SBL_FileRead(void *buff,
void *fileptr,
uint32_t size);
* \brief SBL_FileSeek function to move the read head by n bytes
* \param srcAddr - Read head pointer
* \param location - Move the read head pointer by n bytes
* \return none
void SBL_FileSeek(void *fileptr, uint32_t location);
int32_t SBL_loadMMCSDBootFile(FIL * fp);
/* Global Variables */
/* MMCSD function table for MMCSD implementation */
FATFS_DrvFxnTable FATFS_drvFxnTable = {
&MMCSD_close,
&MMCSD_control,
&MMCSD_init,
&MMCSD_open,
&MMCSD_write,
&MMCSD_read
/* FATFS configuration structure */
#if defined(BOOT_EMMC)
FATFS_HwAttrs FATFS_initCfg[_VOLUMES] =
#if defined(iceK2G) || defined(am65xx_evm) || defined(am65xx_idk) || defined(j721e_evm) || defined(j7200_evm) || defined(am64x_evm)
0U
#else
1U
#endif
0U
#else
1U
#endif
0U
#else
1U
#endif
0U
#else
1U
#endif
#else
1U
#else
0U
#endif
0U
#else
1U
#endif
0U
#else
1U
#endif
0U
#else
1U
#endif
#endif
/* FATFS objects */
FATFS_Object FATFS_objects[_VOLUMES];
/* FATFS Handle */
FATFS_Handle sbl_fatfsHandle = NULL;
const FATFS_Config FATFS_config[_VOLUMES + 1] = {
&FATFS_drvFxnTable,
&FATFS_objects[0],
&FATFS_initCfg[0]
&FATFS_drvFxnTable,
&FATFS_objects[1],
&FATFS_initCfg[1]
&FATFS_drvFxnTable,
&FATFS_objects[2],
&FATFS_initCfg[2]
{NULL, NULL, NULL},
{NULL, NULL, NULL}
#ifdef iceK2G
extern MMCSD_v1_HwAttrs MMCSDInitCfg[];
#endif
#if defined(SOC_J721E) || defined(SOC_J7200)
#define SBL_WKUP_DEVSTAT_PRIMARY_BOOT_MASK (0x78U)
#define SBL_WKUP_DEVSTAT_PRIMARY_BOOT_MMCSD (0x0U)
#define SBL_MAIN_DEVSTAT_PRIMARY_BUS_WIDTH_MASK (0x20U)
#define SBL_MAIN_DEVSTAT_BACKUP_BOOT_MASK (0xEU)
#define SBL_MAIN_DEVSTAT_BACKUP_BOOT_MMCSD (0xAU)
#define SBL_MAIN_DEVSTAT_PRIMARY_BOOT_B_MASK (0x1U)
#endif
#ifdef SECURE_BOOT
extern SBL_incomingBootData_S sblInBootData;
#endif
#ifdef BUILD_MCU
int32_t SBL_ReadSysfwImage(void **pBuffer, uint32_t num_bytes)
int32_t retVal = CSL_PASS;
const TCHAR *fileName = "0:/tifs.bin";
#else
const TCHAR *fileName = "0:/sysfw.bin";
#endif
FIL fp = {0};
FRESULT fresult;
uint32_t bytes_read = 0;
void *sysfw_ptr = *pBuffer;
MMCSD_v2_HwAttrs hwAttrsConfig;
if(MMCSD_socGetInitCfg(FATFS_initCfg[0].drvInst,&hwAttrsConfig)!=0) {
UART_printf("\nUnable to get config.Exiting. TEST FAILED.\r\n");
retVal = E_FAIL;
uint32_t wkupCtrlDevstat = (*((volatile uint32_t *)(CSL_WKUP_CTRL_MMR0_CFG0_BASE + CSL_WKUP_CTRL_MMR_CFG0_WKUP_DEVSTAT)));
uint32_t mainCtrlDevstat = (*((volatile uint32_t *)(CSL_CTRL_MMR0_CFG0_BASE + CSL_MAIN_CTRL_MMR_CFG0_MAIN_DEVSTAT)));
if(((wkupCtrlDevstat & SBL_WKUP_DEVSTAT_PRIMARY_BOOT_MASK) == SBL_WKUP_DEVSTAT_PRIMARY_BOOT_MMCSD) &&
((mainCtrlDevstat & SBL_MAIN_DEVSTAT_PRIMARY_BOOT_B_MASK) == SBL_MAIN_DEVSTAT_PRIMARY_BOOT_B_MASK))
/* MMCSD as primary bootmode */
/* Check MAIN CTRL MMR DEVSTAT register for Primary boot mode Bus Width */
if((mainCtrlDevstat & SBL_MAIN_DEVSTAT_PRIMARY_BUS_WIDTH_MASK) == SBL_MAIN_DEVSTAT_PRIMARY_BUS_WIDTH_MASK)
hwAttrsConfig.supportedBusWidth = MMCSD_BUS_WIDTH_1BIT;
else
hwAttrsConfig.supportedBusWidth = MMCSD_BUS_WIDTH_4BIT;
#ifdef BOOT_EMMC
hwAttrsConfig.supportedBusWidth = MMCSD_BUS_WIDTH_8BIT;
#endif
else if((mainCtrlDevstat & SBL_MAIN_DEVSTAT_BACKUP_BOOT_MASK) == SBL_MAIN_DEVSTAT_BACKUP_BOOT_MMCSD)
/* MMCSD as backup bootmode only supports 1-bit bus width, as set by ROM code */
else
#ifdef BOOT_EMMC
#endif
#endif
hwAttrsConfig.enableInterrupt = ((uint32_t)(0U));
hwAttrsConfig.configSocIntrPath=NULL;
if(MMCSD_socSetInitCfg(FATFS_initCfg[0].drvInst,&hwAttrsConfig)!=0) {
UART_printf("\nUnable to set config.Exiting. TEST FAILED.\r\n");
retVal = E_FAIL;
/* Initialization of the driver. */
FATFS_init();
/* MMCSD FATFS initialization */
FATFS_open(0U, NULL, &sbl_fatfsHandle);
fresult = f_open(&fp, fileName, ((BYTE)FA_READ));
if (fresult != FR_OK)
UART_printf("\n SD Boot - tifs File open fails \n");
#else
UART_printf("\n SD Boot - sysfw File open fails \n");
#endif
retVal = E_FAIL;
else
fresult = f_read(&fp, sysfw_ptr, num_bytes, &bytes_read);
UART_printf("\n SD Boot - tifs read fails \n");
#else
UART_printf("\n SD Boot - sysfw read fails \n");
#endif
retVal = E_FAIL;
f_close(&fp);
FATFS_close(sbl_fatfsHandle);
return retVal;
#endif
int32_t SBL_MMCBootImage(sblEntryPoint_t *pEntry)
int32_t retVal = E_PASS;
const TCHAR *fileName = "0:/app";
FIL fp = {0};
FRESULT fresult;
#ifdef SECURE_BOOT
uint32_t authenticated = 0;
uint32_t srcAddr = 0;
uint32_t imgOffset = 0;
#endif
#ifdef iceK2G
MMCSDInitCfg[1].cardType = MMCSD_CARD_SD;
#endif
FATFS_init();
UART_printf("\n SD Boot - File open fails \n");
retVal = E_FAIL;
else
#ifndef SECURE_BOOT
fp_readData = &SBL_FileRead;
fp_seek = &SBL_FileSeek;
#if defined(SBL_ENABLE_HLOS_BOOT) && (defined(SOC_J721E) || defined(SOC_J7200))
retVal = SBL_MulticoreImageParse((void *) &fp, 0, pEntry, SBL_SKIP_BOOT_AFTER_COPY);
#else
retVal = SBL_MulticoreImageParse((void *) &fp, 0, pEntry, SBL_BOOT_AFTER_COPY);
#endif
#else
fp_readData = &SBL_MemRead;
fp_seek = &SBL_MemSeek;
/* handling secure boot image */
if (E_PASS == SBL_loadMMCSDBootFile(&fp))
/* successfully loading boot image */
/* authentiate it */
authenticated = SBL_authentication(sblInBootData.sbl_boot_buff);
if (authenticated == 0)
/* fails authentiation */
UART_printf("\n SD Boot - fail authentication\n");
retVal = E_FAIL;
else
/* need to skip the TOC headers */
imgOffset = ((uint32_t*)sblInBootData.sbl_boot_buff)[0];
srcAddr = (uint32_t)(sblInBootData.sbl_boot_buff) + imgOffset;
retVal = SBL_MulticoreImageParse((void *)srcAddr, 0, pEntry, SBL_SKIP_BOOT_AFTER_COPY);
#else
retVal = SBL_MulticoreImageParse((void *)srcAddr, 0, pEntry, SBL_BOOT_AFTER_COPY);
#endif
else
UART_printf("\n SD sec Boot - incorrect image\n");
retVal = E_FAIL;
#endif
f_close(&fp);
#ifdef SECURE_BOOT
/* install RAM Secure Kernel to overwrite DSP secure server*/
UART_printf("\n Starting Secure Kernel on DSP...\n");
SBL_startSK();
#endif
return retVal;
#ifndef SECURE_BOOT
void *fileptr,
uint32_t size)
FIL *fp = (FIL *) (fileptr);
uint8_t *tmp_buff_ptr = (uint8_t *)buff;
uint32_t i = 0;
uint32_t Max_read = 0x400U; /*setting a fatfs read size of 1k */
FRESULT fresult = FR_OK;
int32_t retVal = E_FAIL;
for (i = ((uint32_t)0U); i < (size / Max_read); ++i)
fresult = f_read(fp, (void *)tmp_buff_ptr, Max_read, &bytes_read);
tmp_buff_ptr = tmp_buff_ptr + bytes_read;
break;
if (fresult == FR_OK)
fresult = f_read(fp, (void *)tmp_buff_ptr, (UINT) (size % Max_read), &bytes_read);
retVal = E_PASS;
return retVal;
f_lseek(fp, location);
#else
/* load signed boot image from MMCSD */
uint32_t bytes_read;
uint32_t doneRead = 0;
uint32_t buff_idx = 0;
/* reading entire boot image into memory */
buff_idx = 0;
while ((doneRead == 0) &&
((buff_idx + READ_BUFF_SIZE) < SBL_MAX_BOOT_BUFF_SIZE))
fresult = f_read(fp, (sblInBootData.sbl_boot_buff + buff_idx),
READ_BUFF_SIZE, &bytes_read);
if (bytes_read < READ_BUFF_SIZE)
doneRead = 1;
buff_idx += bytes_read;
else
doneRead = 1;
/* fail read */
retVal = E_FAIL;
if ((doneRead == 0) &&
((buff_idx + READ_BUFF_SIZE)>=SBL_MAX_BOOT_BUFF_SIZE))
/* boot image is bigger than reserved buffer. Error */
doneRead = 1;
retVal = E_FAIL;
sblInBootData.sbl_boot_size = buff_idx;
sblInBootData.sbl_boot_buff_idx = 0; /* reset the read pointer */
return retVal;
#endif
By comparing SDK8.1 and SDK7.1, I found some differences.
When I make the following changes, the SBL has some logs but still fails.
Logs:
SBL Revision: 01.00.10.00 (May 11 2022 - 14:51:22)
Changes:
diff --git a/packages/ti/boot/sbl/soc/k3/sbl_soc.c b/packages/ti/boot/sbl/soc/k3/sbl_soc.c
index ed3c2396e..88601a704 100755
--- a/packages/ti/boot/sbl/soc/k3/sbl_soc.c
+++ b/packages/ti/boot/sbl/soc/k3/sbl_soc.c
@@ -786,6 +786,10 @@ void SBL_SocLateInit(void)
J721E_SetupLeoPmicAvs(SBL_OPP_NOM);
+ #if !defined(SBL_ENABLE_DEV_GRP_MCU) && !defined(SBL_USE_MCU_DOMAIN_ONLY)
+ SBL_SetQoS(FALSE);
+ #endif
SBL_ADD_PROFILE_POINT;
@@ -822,9 +826,6 @@ void SBL_SocEarlyInit(uint32_t isBuildHs)
J721E_SetupLvCmosDriveStrength();
J721E_UART_InitPwrClk();
- #if !defined(SBL_ENABLE_DEV_GRP_MCU) && !defined(SBL_USE_MCU_DOMAIN_ONLY)
- SBL_SetQoS(isBuildHs);
- #endif
Can you increase the log level in SBL and share the logs?
You can increase the log levels in <PDK_Install_Path>\packages\ti\boot\sbl\sbl_component.mk by changing DSBL_LOG_LEVEL to 3.
Parth
