Part Number: SK-TDA4VM
I have flashed the SD card for TDA4VM-SK and I am able to login to it. When I try to run the setup_script.sh command under edge_ai_apps, it shows an error that it is not able to access the github repo. The Getting Started guide mentioned that we need to add our proxy settings to the /usr/bin/setup_proxy.sh file to go through proxies. I did add the required proxy settings to that script file but the board is still not able to access internet. Could you provide an example of how to modify that "setup_proxy.sh" file? Also, where can we find the IP configuration file for the board if we need to modify it?
Thanks.
