Hi Nikolay,
You are running out of memory. Did you change the semaphore example? Take a look at ROV's MEM view when the app gets to main(). You can see how memory you have. It looks like SEG0 corresponds to the L47SARAM heap. You can try increasing the size of this heap from 0x01f0 to a bigger number in the .tcf file (via config tool or a text editor).
Todd
Hi Todd,
My development board is early revision and have the TMX-revision processor. As it is writen in the SPRZ272.pdf document this revision have not working XINTF module.
In project settings was applied segment for DSP/BIOS and segment for malloc/free in SRAM location.
I was change it on L47SARAM and everything was fine.
Of course, for the following applications need to change the processor on the TMS-revision...
