TDA4VM: Failed to start mcu of main domain
Part Number: TDA4VM
Other Parts Discussed in Thread: INA226, PCM3168A
Hello, my SDK version is as follows:
ti-processor-sdk-linux-j7-evm-08_02_00_03-Linux-x86-Install.bin
ti-processor-sdk-rtos-j721e-evm-08_02_00_05.tar.gz
My hardware board is a TDA4EVM board.
My purpose is to compile and run the mcu firmware of the main domain by myself.
After installing the SDK for Linux and RTOS, my compilation operation is as follows:
cd linux_sdk
make -j4 linux
make -j4 u-boot
make -j4 sysfw-image
DESTDIR=${CUR_DIR}/rtos_sdk/targetfs make install
cp ./board-support/u-boot_build/a72/u-boot.img /media/lqd/boot
cp ./board-support/u-boot_build/a72/tispl.bin /media/lqd/boot
cp ./board-support/u-boot_build/r5/tiboot3.bin /media/lqd/boot
cp ./board-support/k3-image-gen-2022.01/sysfw.itb /media/lqd/boot
cd rtos_sdk/vision_apps/
make -j4 imaging
make -j4 vision_apps
make -j4 linux_fs_install
sudo cp -drf ./rtos/targetfs/* /media/lqd/rootfs/
sync
Then I inserted the SD card into the TDA4EVM board and powered on. Prompt the following information:
[ 9.117189] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[ 9.153924] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[ 9.201682] img_enc 4200000.video-encoder: encoder registered as /dev/video1
[ 9.263875] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[ 9.276399] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[ 9.284679] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
[ 9.298114] remoteproc remoteproc0: 4d80800000.dsp is available
[ 9.315134] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[ 9.325554] PVR_K: 205: Read BVNC 22.104.208.318 from HW device registers
[ 9.333482] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[ 9.341555] PVR_K: 205: RGX Device registered with BVNC 22.104.208.318
[ 9.348670] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
[ 9.367118] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
[ 9.372837] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
[ 9.375358] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[ 9.381637] remoteproc remoteproc0: powering up 4d80800000.dsp
[ 9.395692] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 1452820
[ 9.409334] remoteproc remoteproc0: bad phdr da 0xa8100000 mem 0x8c
[ 9.410517] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[ 9.415729] remoteproc remoteproc0: Failed to load program segments: -22
[ 9.428629] remoteproc remoteproc1: 4d81800000.dsp is available
[ 9.438323] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[ 9.523053] remoteproc remoteproc1: powering up 4d81800000.dsp
[ 9.531588] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 9.532092] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 1452820
[ 9.551066] remoteproc remoteproc1: bad phdr da 0xa9100000 mem 0x8c
[ 9.557474] remoteproc remoteproc1: Failed to load program segments: -22
[ 9.580981] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[ 9.588289] remoteproc remoteproc2: 64800000.dsp is available
[ 9.689346] platform 41000000.r5f: configured R5F for IPC-only mode
[ 9.706583] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[ 9.810558] remoteproc remoteproc3: 41000000.r5f is available
[ 9.822676] remoteproc remoteproc2: powering up 64800000.dsp
[ 9.828396] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 13242432
[ 9.842418] remoteproc remoteproc2: unsupported resource 65538
[ 9.848485] remoteproc remoteproc2: bad phdr da 0xaa100000 mem 0x98
[ 9.857790] remoteproc remoteproc2: Failed to load program segments: -22
[ 9.891033] remoteproc remoteproc3: attaching to 41000000.r5f
[ 10.010927] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 10.105309] remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[ 10.209511] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 10.223495] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 10.231963] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 10.261682] remoteproc3#vdev0buffer: registered virtio0 (type 7)
[ 10.289833] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
[ 10.306240] platform 5c00000.r5f: configured R5F for remoteproc mode
[ 10.316149] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[ 10.328244] remoteproc remoteproc4: 5c00000.r5f is available
[ 10.337537] platform 5d00000.r5f: configured R5F for remoteproc mode
[ 10.347846] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[ 10.356096] remoteproc remoteproc5: 5d00000.r5f is available
[ 10.366219] platform 5e00000.r5f: configured R5F for remoteproc mode
[ 10.378407] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[ 10.386799] remoteproc remoteproc6: 5e00000.r5f is available
[ 10.392982] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[ 10.402157] remoteproc remoteproc6: powering up 5e00000.r5f
[ 10.407767] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[ 10.417103] remoteproc remoteproc5: powering up 5d00000.r5f
[ 10.423979] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 301996
[ 10.433118] remoteproc remoteproc6: request_firmware failed: -2
[ 10.440900] platform 5f00000.r5f: configured R5F for remoteproc mode
Later, I checked other blogs in the forum and found that it needs to be set in the uboot stage: setenv dorprocboot 1
I have setenv dorprocboot 1 set. Then execute run bootcmd, the program starts normally, but when it starts to the kernel stage, other problems occur. The relevant logs are as follows:
U-Boot SPL 2021.01 (May 24 2022 - 13:40:09 +0800)
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev E7
SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.5(release):08.01.00.006-dirty
NOTICE: BL31: Built : 21:03:57, Mar 23 2022
Detected: J7X-BASE-CPB rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2021.01 (May 24 2022 - 13:40:09 +0800)
SoC: J721E SR1.0
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net: eth0: ethernet@46000000port@1
Hit any key to stop autoboot: 0
=> setenv dorprocboot 1
=> run bootcmd
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
gpio: pin gpio@22_17 (gpio 281) value is 1
gpio: pin gpio@22_16 (gpio 280) value is 0
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
1367476 bytes read in 70 ms (18.6 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 1367476 bytes: Success!
301996 bytes read in 26 ms (11.1 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 301996 bytes: Success!
Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
1452820 bytes read in 74 ms (18.7 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 1452820 bytes: Success!
1452820 bytes read in 73 ms (19 MiB/s)
Load Remote Processor 7 with data@addr=0x82000000 1452820 bytes: Success!
13242432 bytes read in 216 ms (58.5 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 13242432 bytes: Success!
19407360 bytes read in 789 ms (23.5 MiB/s)
102246 bytes read in 14 ms (7 MiB/s)
Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.100-g7a7a3af903 (lqd@ubuntu) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue May 24 10:34:44 CST 2022
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff]
[ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff]
[ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000abffffff]
[ 0.000000] node 0: [mem 0x00000000ac000000-0x00000000adffffff]
[ 0.000000] node 0: [mem 0x00000000ae000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=22ecc83b-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[ 0.000000] Memory: 3339008K/4194304K available (10944K kernel code, 1352K rwdata, 4352K rodata, 1856K init, 751K bss, 331008K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008800b0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[ 0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008358] Console: colour dummy device 80x25
[ 0.012919] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023588] pid_max: default: 32768 minimum: 301
[ 0.028334] LSM: Security Framework initializing
[ 0.033083] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.040652] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.049646] rcu: Hierarchical SRCU implementation.
[ 0.054714] Platform MSI: msi-controller@1820000 domain created
[ 0.060970] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070268] EFI services will not be available.
[ 0.075036] smp: Bringing up secondary CPUs ...
[ 0.080302] Detected PIPT I-cache on CPU1
[ 0.080326] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.080337] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[ 0.080376] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.080430] smp: Brought up 1 node, 2 CPUs
[ 0.109777] SMP: Total of 2 processors activated.
[ 0.114581] CPU features: detected: 32-bit EL0 Support
[ 0.119835] CPU features: detected: CRC32 instructions
[ 0.133676] CPU: All CPU(s) started at EL2
[ 0.137874] alternatives: patching kernel code
[ 0.142914] devtmpfs: initialized
[ 0.151361] KASLR disabled due to lack of seed
[ 0.156025] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.165989] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[ 0.173689] pinctrl core: initialized pinctrl subsystem
[ 0.179270] DMI not present or invalid.
[ 0.183512] NET: Registered protocol family 16
[ 0.190864] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.198175] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.206188] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.214497] thermal_sys: Registered thermal governor 'step_wise'
[ 0.214500] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.220941] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.234584] ASID allocator initialised with 65536 entries
[ 0.258124] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[ 0.264985] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[ 0.271743] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.279644] cryptd: max_cpu_qlen set to 1000
[ 0.285842] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
[ 0.294650] vsys_3v3: supplied by evm_12v0
[ 0.299020] vsys_5v0: supplied by evm_12v0
[ 0.303765] iommu: Default domain type: Translated
[ 0.308898] SCSI subsystem initialized
[ 0.313011] mc: Linux media interface: v0.10
[ 0.317429] videodev: Linux video capture interface: v2.00
[ 0.323057] pps_core: LinuxPPS API ver. 1 registered
[ 0.328127] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.337464] PTP clock support registered
[ 0.341485] EDAC MC: Ver: 3.0.0
[ 0.345249] FPGA manager framework
[ 0.348763] Advanced Linux Sound Architecture Driver Initialized.
[ 0.355376] clocksource: Switched to clocksource arch_sys_counter
[ 0.361802] VFS: Disk quotas dquot_6.6.0
[ 0.365852] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[ 0.375561] NET: Registered protocol family 2
[ 0.380169] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[ 0.388819] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[ 0.397590] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[ 0.405787] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[ 0.413607] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.420368] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.427261] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.434652] NET: Registered protocol family 1
[ 0.439368] RPC: Registered named UNIX socket transport module.
[ 0.445440] RPC: Registered udp transport module.
[ 0.450244] RPC: Registered tcp transport module.
[ 0.455047] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.461632] PCI: CLS 0 bytes, default 64
[ 0.465987] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.476460] Initialise system trusted keyrings
[ 0.481082] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[ 0.489345] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.495648] NFS: Registering the id_resolver key type
[ 0.500839] Key type id_resolver registered
[ 0.505114] Key type id_legacy registered
[ 0.509239] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.516088] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.523734] 9p: Installing v9fs 9p2000 file system support
[ 0.548860] Key type asymmetric registered
[ 0.553047] Asymmetric key parser 'x509' registered
[ 0.558044] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.565603] io scheduler mq-deadline registered
[ 0.570229] io scheduler kyber registered
[ 0.575514] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.581690] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.590354] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.596631] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.604519] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.612645] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.621999] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[ 0.631727] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[ 0.639679] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.652705] brd: module loaded
[ 0.658689] loop: module loaded
[ 0.662553] megasas: 07.714.04.00-rc1
[ 0.668106] tun: Universal TUN/TAP device driver, 1.6
[ 0.673549] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.679957] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.686029] sky2: driver version 1.30
[ 0.690304] VFIO - User Level meta-driver version: 0.3
[ 0.696001] i2c /dev entries driver
[ 0.700202] sdhci: Secure Digital Host Controller Interface driver
[ 0.706523] sdhci: Copyright(c) Pierre Ossman
[ 0.711158] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.717503] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.723846] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.731008] optee: probing for conduit method.
[ 0.735564] optee: revision 3.12 (3d47a131)
[ 0.735826] optee: initialized driver
[ 0.745199] NET: Registered protocol family 17
[ 0.749812] 9pnet: Installing 9P2000 support
[ 0.754198] Key type dns_resolver registered
[ 0.758659] Loading compiled-in X.509 certificates
[ 0.768243] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.774576] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.782689] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
[ 0.812860] random: fast init done
[ 0.845787] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.853533] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.859635] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.865685] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.872135] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.878971] pca953x 3-0020: using no AI
[ 0.904195] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 0.911000] pca953x 3-0022: using AI
[ 0.915267] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
[ 0.921240] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
[ 0.927482] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
[ 0.933977] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.940452] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.950484] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
[ 0.956801] pca953x 6-0020: supply vcc not found, using dummy regulator
[ 0.963624] pca953x 6-0020: using no AI
[ 0.992070] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.998178] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[ 1.004168] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[ 1.010469] pca953x 9-0020: supply vcc not found, using dummy regulator
[ 1.017293] pca953x 9-0020: using no AI
[ 1.043706] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[ 1.050126] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.060114] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.068924] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.078777] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.102023] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 1.109699] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 1.117976] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 1.126256] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.136915] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[ 2.143343] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.148955] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 2.158647] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 2.165695] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 2.171836] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.181705] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.191594] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
[ 2.201556] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.211523] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[ 2.221483] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[ 2.231467] pci 0000:00:00.0: supports D1
[ 2.235561] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.241432] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[ 2.253091] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.261283] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.271242] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.281200] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.292658] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.299427] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.304708] pcieport 0000:00:00.0: PME: Signaling with IRQ 61
[ 2.311074] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.318744] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.327023] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.335300] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.346623] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[ 3.353045] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 3.358651] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[ 3.368518] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 3.375565] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[ 3.381765] pci 0001:00:00.0: supports D1
[ 3.385859] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 3.393369] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.403047] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.409815] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 3.415118] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[ 3.421488] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 3.429157] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 3.437433] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 3.445710] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.457157] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
[ 4.463580] pci_bus 0002:00: root bus resource [bus 00-ff]
[ 4.469186] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[ 4.478433] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[ 4.489210] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
[ 4.495413] pci 0002:00:00.0: supports D1
[ 4.499507] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
[ 4.507020] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.516706] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.523480] pci 0002:00:00.0: PCI bridge to [bus 01]
[ 4.528759] pcieport 0002:00:00.0: PME: Signaling with IRQ 67
[ 4.535532] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 4.545406] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 4.552164] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 4.561090] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 4.571247] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 4.578006] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 4.585982] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 4.595367] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[ 4.604116] printk: console [ttyS2] enabled
[ 4.612552] printk: bootconsole [ns16550a0] disabled
[ 4.623007] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[ 4.631955] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[ 4.642535] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.653047] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 4.663198] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 4.673436] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 4.684354] scsi host0: ufshcd
[ 4.706361] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[ 4.727382] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 4.736380] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 4.742384] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[ 4.744679] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 4.756297] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[ 4.780316] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 4.789192] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 4.789199] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 4.803502] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[ 4.813041] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 4.813467] mmc0: CQHCI version 5.10
[ 4.818947] mmc1: CQHCI version 5.10
[ 4.832341] vdd_mmc1: supplied by vsys_3v3
[ 4.837358] pca953x 4-0020: supply vcc not found, using dummy regulator
[ 4.844019] pca953x 4-0020: using no AI
[ 4.859960] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 4.872362] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 4.879218] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 4.886060] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 4.892892] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 4.899697] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 4.910156] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 4.920577] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 4.935100] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[ 4.940343] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[ 4.946942] Creating 8 MTD partitions on "47040000.spi.0":
[ 4.948083] mmc0: Command Queue Engine enabled
[ 4.952416] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 4.952922] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 4.956869] mmc0: new HS200 MMC card at address 0001
[ 4.962759] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 4.967913] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 4.972972] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 4.978106] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 4.982903] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[ 4.987748] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 4.993933] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[ 5.004773] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[ 5.010878] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 5.020822] mmcblk0: p1 p2
[ 5.023578] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 5.034877] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[ 5.079384] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 5.088312] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 5.096611] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 5.110274] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 5.117287] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 5.124499] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 5.130859] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 5.141054] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 5.155018] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 5.162272] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 5.170470] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 5.177791] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 5.185095] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 5.192402] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 5.200601] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.221562] ALSA device list:
[ 5.224541] No soundcards found.
[ 5.886162] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 5.894555] Waiting for root device PARTUUID=22ecc83b-02...
[ 5.930880] mmc1: new high speed SDHC card at address aaaa
[ 5.936708] mmcblk1: mmc1:aaaa SA08G 7.40 GiB
[ 5.945652] mmcblk1: p1 p2
[ 6.111149] EXT4-fs (mmcblk1p2): recovery complete
[ 6.116850] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.124960] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 6.134786] devtmpfs: mounted
[ 6.138169] Freeing unused kernel memory: 1856K
[ 6.142727] Run /sbin/init as init process
[ 6.412557] systemd[1]: System time before build time, advancing clock.
[ 6.499197] NET: Registered protocol family 10
[ 6.504118] Segment Routing with IPv6
[ 6.527419] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 6.549163] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[ 6.588655] systemd[1]: Set hostname to <j7-evm>.
[ 6.854136] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ 6.933363] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.940096] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 6.952424] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 6.962356] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 6.983462] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.990754] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 7.011452] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.018672] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 7.039573] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 7.063514] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 7.087489] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 7.103438] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 7.123426] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 7.139432] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 7.163794] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 7.187465] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 7.210702] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 7.231570] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 7.270044] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 7.278410] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 7.299672] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 7.315716] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 7.339624] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 7.359550] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 7.382653] systemd[1]: Mounting Huge Pages File System...
[ 7.402021] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.426069] systemd[1]: Mounting Kernel Debug File System...
[ 7.447634] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 7.467601] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st…odes for the current kernel...
[ 7.493882] systemd[1]: Starting Start psplash boot splash screen...
[ 7.525332] systemd[1]: Starting RPC Bind...
[ 7.539603] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.552253] systemd[1]: Starting Journal Service...
[ 7.572257] systemd[1]: Starting Load Kernel Modules...
[ 7.590117] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.607035] cryptodev: loading out-of-tree module taints kernel.
[ 7.608441] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 7.622542] systemd[1]: Starting udev Coldplug all Devices...
[ 7.632902] cryptodev: driver 1.10 loaded.
[ 7.644361] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 7.663809] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ 7.885760] systemd-journald[171]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting udev Wait for Complete Device Initialization...
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ 8.400368] CAN device driver interface
[ 8.567941] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.580831] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.602279] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.643840] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.660105] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.684354] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 8.709939] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.720972] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.739152] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[ 8.753652] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.761699] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[ 8.768865] img_enc 4200000.video-encoder: encoder registered as /dev/video1
[ 8.769894] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.803138] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.812404] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.820042] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.828102] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.842287] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.858453] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
[ 8.883592] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[ 9.017973] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[ 9.064599] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[ 9.076914] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[ 9.077979] remoteproc remoteproc0: 4d80800000.dsp is available
[ 9.089327] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 9.090687] remoteproc remoteproc0: attaching to 4d80800000.dsp
[ 9.107063] Unable to handle kernel paging request at virtual address ffff800019ffffff
[ 9.115533] Mem abort info:
[ 9.118345] ESR = 0x96000007
[ 9.122785] PVR_K: 208: Read BVNC 22.104.208.318 from HW device registers
[ 9.143819] PVR_K: 208: RGX Device registered with BVNC 22.104.208.318
[ 9.151262] EC = 0x25: DABT (current EL), IL = 32 bits
[ 9.156644] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 1
[ 9.183957] platform 41000000.r5f: configured R5F for IPC-only mode
[ 9.190629] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[ 9.198892] remoteproc remoteproc1: 41000000.r5f is available
[ 9.204669] remoteproc remoteproc1: attaching to 41000000.r5f
[ 9.210602] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 9.220620] SET = 0, FnV = 0
[ 9.224052] EA = 0, S1PTW = 0
[ 9.227183] Data abort info:
[ 9.230173] ISV = 0, ISS = 0x00000007
[ 9.235193] CM = 0, WnR = 0
[ 9.238177] swapper pgtable: 64k pages, 48-bit VAs, pgdp=0000000082f50000
[ 9.247141] [ffff800019ffffff] pgd=00000008ffff0003, p4d=00000008ffff0003, pud=00000008ffff0003, pmd=00000008fffe0003, pte=0000000000000000
[ 9.259692] Internal error: Oops: 96000007 [#1] PREEMPT SMP
[ 9.265247] Modules linked in: ti_k3_r5_remoteproc(+) pruss cdns_mhdp8546 sa2ul pvrsrvkm(O) sha512_generic authenc ti_k3_dsp_remoteproc(+) virtio_rpmsg_bus cdns_dphy j721e_csi2rx vxe_enc vxd_dec videobuf2_dma_sg videobuf2_dma_contig v4l2_mem2mem videobuf2_memops videobuf2_v4l2 videobuf2_common cdns3_ti snd_soc_pcm3168a_i2c pci_endpoint_test snd_soc_pcm3168a ina2xx m_can_platform m_can can_dev rti_wdt sch_fq_codel rpmsg_kdrv_switch cryptodev(O) ipv6
[ 9.303893] remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[ 9.304925] CPU: 0 PID: 194 Comm: systemd-udevd Tainted: G O 5.10.100-g7a7a3af903 #1
[ 9.322270] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 9.328087] pstate: 00000005 (nzcv daif -PAN -UAO -TCO BTYPE=--)
[ 9.334088] pc : rproc_handle_resources.constprop.0+0x94/0x168
[ 9.339906] lr : rproc_boot+0x334/0x670
[ 9.343726] sp : ffff8000137af7d0
[ 9.347026] x29: ffff8000137af7d0 x28: ffff800011326788
[ 9.352324] x27: ffff00087ff2e868 x26: ffffffffffffffff
[ 9.357621] x25: ffff80001a000000 x24: ffff800010e39278
[ 9.362918] x23: ffff000804fbb838 x22: 0000000000000000
[ 9.368215] x21: ffff80001125e290 x20: ffff000804fbb800
[ 9.373511] x19: 0000000000000000 x18: 0000000000000010
[ 9.378807] x17: 0000000000000000 x16: 0000000000000000
[ 9.384103] x15: 0000006a40d55d13 x14: ffffffffffffffff
[ 9.389400] x13: ffffffffffffffff x12: ffffffffffffffff
[ 9.394699] x11: ffffffffffffffff x10: ffffffffffffffff
[ 9.399997] x9 : ffffffffffffffff x8 : ffffffffffffffff
[ 9.405293] x7 : ffffffffffffffff x6 : ffff0008059f0300
[ 9.410589] x5 : 0000000000000000 x4 : 0000000000000000
[ 9.415885] x3 : 00000000000000fd x2 : 00000000ffffffff
[ 9.421181] x1 : ffff80001a000003 x0 : ffff80001a000000
[ 9.426478] Call trace:
[ 9.428920] rproc_handle_resources.constprop.0+0x94/0x168
[ 9.434389] rproc_boot+0x334/0x670
[ 9.437863] rproc_add+0x88/0x158
[ 9.441176] k3_dsp_rproc_probe+0x710/0x850 [ti_k3_dsp_remoteproc]
[ 9.447339] platform_drv_probe+0x54/0xa8
[ 9.451334] really_probe+0xec/0x3e0
[ 9.454895] driver_probe_device+0x58/0xb8
[ 9.458977] device_driver_attach+0x74/0x80
[ 9.463145] __driver_attach+0x58/0xe0
[ 9.466880] bus_for_each_dev+0x70/0xc0
[ 9.470707] driver_attach+0x24/0x30
[ 9.474273] bus_add_driver+0x14c/0x1f0
[ 9.478099] driver_register+0x64/0x120
[ 9.481923] __platform_driver_register+0x48/0x58
[ 9.486622] k3_dsp_rproc_driver_init+0x20/0x10000 [ti_k3_dsp_remoteproc]
[ 9.493395] do_one_initcall+0x54/0x1b8
[ 9.497222] do_init_module+0x54/0x208
[ 9.500960] load_module+0x1f28/0x24c8
[ 9.504701] __do_sys_finit_module+0xb8/0xf8
[ 9.508961] __arm64_sys_finit_module+0x20/0x30
[ 9.513483] el0_svc_common.constprop.0+0x78/0x1c8
[ 9.518263] do_el0_svc+0x24/0x90
[ 9.521568] el0_svc+0x14/0x20
[ 9.524609] el0_sync_handler+0xb0/0xb8
[ 9.528431] el0_sync+0x180/0x1c0
[ 9.531736] Code: 128002b3 91090021 97ffeb8a 1400002e (b87a6b20)
[ 9.537813] ---[ end trace f29cd81f5d27b589 ]---
[ 9.586233] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 9.596940] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 9.607782] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 9.608431] remoteproc1#vdev0buffer: registered virtio0 (type 7)
[ 9.756063] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
[ 9.844879] platform 5c00000.r5f: configured R5F for IPC-only mode
[ 9.963093] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[ 10.001301] remoteproc remoteproc2: 5c00000.r5f is available
[ 10.071935] remoteproc remoteproc2: attaching to 5c00000.r5f
[ 10.123580] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[ 10.184912] remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[ 10.198050] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 10.213011] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[ 10.249324] remoteproc2#vdev0buffer: registered virtio1 (type 7)
[ 10.295797] remoteproc remoteproc2: remote processor 5c00000.r5f is now attached
[ 10.310224] platform 5d00000.r5f: configured R5F for IPC-only mode
[ 10.316686] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[ 10.326189] remoteproc remoteproc3: 5d00000.r5f is available
[ 10.333364] remoteproc remoteproc3: attaching to 5d00000.r5f
[ 10.339140] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[ 10.346976] remoteproc remoteproc3: remote processor 5d00000.r5f is now attached
[ 10.577317] platform 5e00000.r5f: configured R5F for remoteproc mode
[ 10.646427] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[ 10.708325] remoteproc remoteproc4: 5e00000.r5f is available
[ 10.749328] remoteproc remoteproc4: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[ 10.760189] remoteproc remoteproc4: powering up 5e00000.r5f
[ 10.769312] remoteproc remoteproc4: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[ 10.779742] platform 5f00000.r5f: configured R5F for remoteproc mode
[ 10.786163] remoteproc remoteproc4: request_firmware failed: -2
[ 10.843173] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[ 10.851395] random: crng init done
[ 10.854790] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.866091] remoteproc remoteproc5: 5f00000.r5f is available
[ 10.872624] remoteproc remoteproc5: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[ 10.885248] remoteproc remoteproc5: powering up 5f00000.r5f
[ 10.890882] remoteproc remoteproc5: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[ 10.904029] remoteproc remoteproc5: request_firmware failed: -2
[ OK ] Started Load/Save Random Seed.
[ 11.052530] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
[ 11.067364] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
[ 11.085900] m_can_platform 2701000.can: m_can device registered (irq=55, version=32)
[ 11.098333] m_can_platform 2721000.can: m_can device registered (irq=57, version=32)
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Found device /dev/mmcblk0p2.
Starting File System Check on /dev/mmcblk0p2...
[ OK ] Started File System Check on /dev/mmcblk0p2.
Mounting /run/media/mmcblk0p2...
[ 12.159281] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
[ 12.172461] remoteproc remoteproc6: b034000.pru is available
[ 12.181144] usbcore: registered new interface driver usbfs
[ 12.182085] remoteproc remoteproc7: b004000.rtu is available
[ 12.193538] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ OK ] Mounted /run/media/mmcblk0p2.
[ 12.206370] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
[ 12.215952] usbcore: registered new interface driver hub
[ 12.222779] usbcore: registered new device driver usb
[ 12.229301] remoteproc remoteproc8: b00a000.txpru is available
[ OK ] Found device /dev/mmcblk1p1.
[ 12.237353] remoteproc remoteproc9: b038000.pru is available
[ 12.251327] remoteproc remoteproc10: b006000.rtu is available
[ 12.259330] remoteproc remoteproc11: b00c000.txpru is available
[ 12.266135] remoteproc remoteproc12: b134000.pru is available
Starting File System Check on /dev/mmcblk1p1...
[ 12.280644] remoteproc remoteproc13: b104000.rtu is available
[ 12.287236] remoteproc remoteproc14: b10a000.txpru is available
[ 12.297002] remoteproc remoteproc15: b138000.pru is available
[ 12.305907] remoteproc remoteproc16: b106000.rtu is available
[ 12.312691] remoteproc remoteproc17: b10c000.txpru is available
[ OK ] Found device /dev/mmcblk0p1.
Starting File System Check on /dev/mmcblk0p1...
[ OK ] Started File System Check on /dev/mmcblk0p1.
Mounting /run/media/mmcblk0p1...
[ OK ] Mounted /run/media/mmcblk0p1.
[ OK ] Started File System Check on /dev/mmcblk1p1.
Mounting /run/media/mmcblk1p1...
[ 12.469107] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[ OK ] Mounted /run/media/mmcblk1p1.
[ 13.067259] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 13.072789] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[ 13.081034] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[ 13.090462] xhci-hcd xhci-hcd.2.auto: irq 663, io mem 0x06410000
[ 13.096643] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 13.104905] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 13.112163] usb usb1: Product: xHCI Host Controller
[ 13.117039] usb usb1: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd
[ 13.123648] usb usb1: SerialNumber: xhci-hcd.2.auto
[ 13.128794] hub 1-0:1.0: USB hub found
[ 13.132576] hub 1-0:1.0: 1 port detected
[ 13.137450] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 13.142951] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[ 13.150610] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[ 13.157171] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 13.165316] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 13.173568] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 13.180780] usb usb2: Product: xHCI Host Controller
[ 13.185654] usb usb2: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd
[ 13.192262] usb usb2: SerialNumber: xhci-hcd.2.auto
[ 13.197404] hub 2-0:1.0: USB hub found
[ 13.201176] hub 2-0:1.0: 1 port detected
[ 13.395390] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 13.547656] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 13.555821] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 13.562945] usb 1-1: SerialNumber: 05000089DE36
[ 13.568241] hub 1-1:1.0: USB hub found
[ 13.572024] hub 1-1:1.0: 4 ports detected
[** ] A start job is running for udev Wai…ce Initialization (22s / 2min 55s)
[ 35.911392] vdd_mmc1: disabling
[FAILED] Failed to start udev Wait …omplete Device Initialization.
See 'systemctl status systemd-udev-settle.service' for details.
[ 128.905718] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 128.956939] mmc1: tried to HW reset card, got error -84
[ 128.962161] mmcblk1: recovery failed!
[ 128.965845] blk_update_request: I/O error, dev mmcblk1, sector 202248 op 0x0:(READ) flags 0x3000 phys_seg 1 prio class 0
[ 128.976714] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #49: comm systemd: reading directory lblock 0
[ 128.993410] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.047504] mmc1: tried to HW reset card, got error -84
[ 129.052721] mmcblk1: recovery failed!
[ 129.056393] blk_update_request: I/O error, dev mmcblk1, sector 129024 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 129.067247] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 129.075000] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ 129.089989] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.096230] mmcblk1: recovery failed!
[ 129.099914] blk_update_request: I/O error, dev mmcblk1, sector 9327760 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ OK ] Reached target System Initializatio[ 129.116766] sdhci-am654 4fb0000.mmc: error -84 requesting status
n.
[ 129.123232] mmcblk1: recovery failed!
[ 129.127589] blk_update_request: I/O error, dev mmcblk1, sector 9327760 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 129.138300] EXT4-fs error (device mmcblk1p2): ext4_check_bdev_write_error:217: comm (rngd): Error while async write back metadata
[ 129.155723] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.161722] mmcblk1: recovery failed!
[ 129.165397] blk_update_request: I/O error, dev mmcblk1, sector 129024 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 129.176260] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 129.184027] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ 129.189430] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.196285] mmcblk1: recovery failed!
[ 129.199964] blk_update_request: I/O error, dev mmcblk1, sector 4409408 op 0x0:(READ) flags 0x3000 phys_seg 1 prio class 0
[ 129.210921] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #169443: comm systemd: reading directory lblock 0
[ 129.227973] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.233970] mmcblk1: recovery failed!
[ 129.237637] blk_update_request: I/O error, dev mmcblk1, sector 129024 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 129.248493] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 129.256260] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API.[ 129.350728] EXT4-fs error (device mmcblk1p2): ext4_check_bdev_write_error:217: comm (sd-chown): Error while async write back metadata
[ 129.372669] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.378674] mmcblk1: recovery failed!
[ 129.382357] blk_update_request: I/O error, dev mmcblk1, sector 129024 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 129.393228] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 129.401024] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ 129.406402] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.407416] EXT4-fs error (device mmcblk1p2): ext4_check_bdev_write_error:217: comm (sd-chown): Error while async write back metadata
[ 129.413270] mmcblk1: recovery failed!
[ 129.429333] blk_update_request: I/O error, dev mmcblk1, sector 8979368 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 129.445813] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.451811] mmcblk1: recovery failed!
[ 129.455484] blk_update_request: I/O error, dev mmcblk1, sector 129024 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 129.461180] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.466340] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 129.472325] mmcblk1: recovery failed!
[ 129.480400] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ 129.487405] EXT4-fs error (device mmcblk1p2): ext4_check_bdev_write_error:217: comm systemd: Error while async write back metadata
[ 129.507455] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.513454] mmcblk1: recovery failed!
[ 129.517125] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 129.524873] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ OK ] Listening on dropbear.socket.
Starting Reboot and dump vmcore via kexec...
[ 129.557570] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.563574] mmcblk1: recovery failed!
[ 129.567252] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #162551: comm (p-helper): reading directory lblock 0
[ OK ] Listening on Docker Socket for the [ 129.584725] sdhci-am654 4fb0000.mmc: error -84 requesting status
API.
[ 129.594846] mmcblk1: recovery failed!
[ 129.599351] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 129.607101] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ 129.643536] EXT4-fs error (device mmcblk1p2): ext4_check_bdev_write_error:217: comm systemd: Error while async write back metadata
[ 129.661041] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.667041] mmcblk1: recovery failed!
[ 129.670731] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 129.678479] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ 129.688896] EXT4-fs error (device mmcblk1p2): ext4_check_bdev_write_error:217: comm (alsactl): Error while async write back metadata
[ 129.711038] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.717044] mmcblk1: recovery failed!
[ 129.720735] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 129.728600] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ 129.734976] EXT4-fs error (device mmcblk1p2): ext4_check_bdev_write_error:217: comm (alsactl): Error while async write back metadata
[ OK ] Started Job spooling tools.[ 129.751719] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.758080] mmcblk1: recovery failed!
[ 129.767629] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.773646] mmcblk1: recovery failed!
[ 129.777328] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 129.785146] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ 129.796509] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.802509] mmcblk1: recovery failed!
[ 129.811918] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.817939] mmcblk1: recovery failed!
[ 129.827315] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.833311] mmcblk1: recovery failed!
[ 129.842788] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.848797] mmcblk1: recovery failed!
[ 129.858255] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.864255] mmcblk1: recovery failed!
[ 129.873680] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.879676] mmcblk1: recovery failed!
[ 129.889336] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.895333] mmcblk1: recovery failed!
[ 129.904774] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.910772] mmcblk1: recovery failed!
[ 129.920309] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.926305] mmcblk1: recovery failed!
[ 129.935776] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.941775] mmcblk1: recovery failed!
[ 129.951473] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.957471] mmcblk1: recovery failed!
[ 129.966923] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.972920] mmcblk1: recovery failed!
[ 129.982351] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 129.988347] mmcblk1: recovery failed!
[ 129.997801] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.003794] mmcblk1: recovery failed!
[ 130.013331] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.019327] mmcblk1: recovery failed!
[ 130.028776] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.034769] mmcblk1: recovery failed!
[ 130.044203] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.050200] mmcblk1: recovery failed!
[ 130.059654] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.065646] mmcblk1: recovery failed!
[ 130.075174] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.081168] mmcblk1: recovery failed!
[ 130.090576] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.096570] mmcblk1: recovery failed!
[FAILED] Failed to start Periodic Command Scheduler.
[ 130.107454] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.114562] mmcblk1: recovery failed!
See 'systemctl status crond.service' for details.
[ 130.124056] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.130054] mmcblk1: recovery failed!
[ OK ] Started D-Bus System Message Bus 130.140214] sdhci-am654 4fb0000.mmc: error -84 requesting status
m.
[ 130.146843] mmcblk1: recovery failed!
[ 130.156570] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.162608] mmcblk1: recovery failed!
Starting Print notice about GPLv3 packages[ 130.168443] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.178238] mmcblk1: recovery failed!
Starting set host name as per compatible name...
Starting IPv6 Packet Filtering Framewo[ 130.188500] sdhci-am654 4fb0000.mmc: error -84 requesting status
rk...
[ 130.199609] mmcblk1: recovery failed!
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
[ 130.210839] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.221340] mmcblk1: recovery failed!
Starting Telephony service...
Starting rc.pvr.service...
[ 130.230846] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.240207] mmcblk1: recovery failed!
Starting startwlanap...
[ 130.250600] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.256718] mmcblk1: recovery failed!
Starting startwlansta...
[ 130.266444] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.272537] mmcblk1: recovery failed!
[ 130.282601] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.288791] mmcblk1: recovery failed!
Starting Login Service...
[ 130.298409] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.304555] mmcblk1: recovery failed!
[ 130.314169] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.320221] mmcblk1: recovery failed!
[ 130.329826] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.335857] mmcblk1: recovery failed!
[ 130.345263] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.351270] mmcblk1: recovery failed!
[ 130.360711] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.366716] mmcblk1: recovery failed!
[ 130.376190] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.382210] mmcblk1: recovery failed!
[ 130.391620] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.397643] mmcblk1: recovery failed!
[ 130.407011] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.413008] mmcblk1: recovery failed!
[ 130.422464] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.428465] mmcblk1: recovery failed!
[ 130.437859] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.443904] mmcblk1: recovery failed!
[ 130.453283] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.459326] mmcblk1: recovery failed!
[ 130.468732] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.474745] mmcblk1: recovery failed!
[ OK ] Started TEE Supplicant.[ 130.485036] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.491461] mmcblk1: recovery failed!
[ 130.501009] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.507036] mmcblk1: recovery failed!
Starting Update weston ini… based on the pla[ 130.516544] sdhci-am654 4fb0000.mmc: error -84 requesting status
tform name...
[ 130.522802] mmcblk1: recovery failed!
[ 130.533865] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.539895] mmcblk1: recovery failed!
[FAILED] Failed to start Reboot and dump v[ 130.545695] sdhci-am654 4fb0000.mmc: error -84 requesting status
mcore via kexec.
[ 130.555317] mmcblk1: recovery failed!
See 'systemctl status kdump.service' for details.
[ 130.566568] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.573999] mmcblk1: recovery failed!
[ 130.583500] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.589522] mmcblk1: recovery failed!
[FAILED] Failed to start Print notice abou[ 130.598665] sdhci-am654 4fb0000.mmc: error -84 requesting status
t GPLv3 packages.
[ 130.605020] mmcblk1: recovery failed!
See 'systemctl status gplv3-notice.service' for details.
[ 130.617153] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.626614] mmcblk1: recovery failed!
[FAILED] Failed to start set host name as [ 130.636239] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.644698] mmcblk1: recovery failed!
See 'systemctl status hostname-update.service' for details.
[ 130.656485] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.666826] mmcblk1: recovery failed!
[FAILED] Failed to start IPv6 Packet Filte[ 130.676431] sdhci-am654 4fb0000.mmc: error -84 requesting status
ring Framework.
[ 130.685010] mmcblk1: recovery failed!
[ 130.696588] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.702593] mmcblk1: recovery failed!
See 'systemctl status ip6tables.service' for details.
[ 130.712652] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.718654] mmcblk1: recovery failed!
[FAILED] Failed to start IPv4 Packet Filte[ 130.728896] sdhci-am654 4fb0000.mmc: error -84 requesting status
ring Framework.
[ 130.736009] mmcblk1: recovery failed!
[ 130.747360] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.753381] mmcblk1: recovery failed!
See 'systemctl status iptables.service' for details.
[ 130.763090] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.769088] mmcblk1: recovery failed!
[FAILED] Failed to start Telephony service[ 130.778978] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.785441] mmcblk1: recovery failed!
[ 130.795786] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.801793] mmcblk1: recovery failed!
See 'systemctl status ofono.service' for details.
[ 130.811425] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.817426] mmcblk1: recovery failed!
[ OK ] Started rc.pvr.service.
[ 130.827148] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.833148] mmcblk1: recovery failed!
[ 130.842732] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.849110] mmcblk1: recovery failed!
[ 130.858757] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.864753] mmcblk1: recovery failed!
See 'systemctl status startwlanap.service' for details.
[ 130.874234] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.880231] mmcblk1: recovery failed!
[FAILED] Failed to start startwlansta.[ 130.889828] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.896181] mmcblk1: recovery failed!
[ 130.905812] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.911813] mmcblk1: recovery failed!
See 'systemctl status startwlansta.service' for details.
[ 130.921323] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.927318] mmcblk1: recovery failed!
[FAILED] Failed to start Update wes…ge b[ 130.942803] sdhci-am654 4fb0000.mmc: error -84 requesting status
ased on the platform name.
[ 130.951261] mmcblk1: recovery failed!
See 'systemctl status weston-bg-update.service' for details.
[ 130.964000] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.970011] mmcblk1: recovery failed!
[ OK ] Reached target Network (Pre).
[ 130.979521] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 130.987201] mmcblk1: recovery failed!
[ OK ] Stopped Periodic Command Scheduler 130.996621] sdhci-am654 4fb0000.mmc: error -84 requesting status
[0m.
[ 131.002678] mmcblk1: recovery failed!
[ 131.012593] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.018594] mmcblk1: recovery failed!
[ 131.028060] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.034132] mmcblk1: recovery failed!
[ 131.043543] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.049548] mmcblk1: recovery failed!
[ 131.058922] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.064917] mmcblk1: recovery failed!
[ 131.074304] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.080298] mmcblk1: recovery failed!
[ 131.091484] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.098268] mmcblk1: recovery failed!
[ OK ] Started D-Bus System Message Bus.
[ 131.125038] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.131056] mmcblk1: recovery failed!
[ OK ] Stopped set host name as per compat[ 131.140572] sdhci-am654 4fb0000.mmc: error -84 requesting status
ible name.
[ 131.149961] mmcblk1: recovery failed!
[ 131.169713] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.175719] mmcblk1: recovery failed!
Starting Network Service...
[ 131.185327] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.194400] mmcblk1: recovery failed!
Starting weston.service...
[ 131.209634] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.215696] mmcblk1: recovery failed!
[ OK ] Started Save/Restore Sound Card Sta[ 131.225158] sdhci-am654 4fb0000.mmc: error -84 requesting status
te.
[ 131.233283] mmcblk1: recovery failed!
[ 131.243454] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.249451] mmcblk1: recovery failed!
[FAILED] Failed to start Login Service.
[ 131.258873] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.265121] mmcblk1: recovery failed!
See 'systemctl status systemd-logind.service' for details.
[ 131.274543] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.280546] mmcblk1: recovery failed!
[FAILED] Failed to start set host name as per compatible name.
[ 131.290130] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.298326] mmcblk1: recovery failed!
[ 131.307835] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.313854] mmcblk1: recovery failed!
[FAILED] Failed to start Network Service 131.323407] sdhci-am654 4fb0000.mmc: error -84 requesting status
0m.
[ 131.329622] mmcblk1: recovery failed!
[ 131.339510] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.345515] mmcblk1: recovery failed!
See 'systemctl status systemd-networkd.service' for details.
[ 131.354987] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.361078] mmcblk1: recovery failed!
[DEPEND] Dependency failed for Wait [ 131.370796] sdhci-am654 4fb0000.mmc: error -84 requesting status
for Network to be Configured.
[ 131.376861] mmcblk1: recovery failed!
[ OK ] Reached target Sound Card.
[ 131.389402] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.400509] mmcblk1: recovery failed!
[ OK ] Stopped Periodic Command Scheduler 131.410182] sdhci-am654 4fb0000.mmc: error -84 requesting status
[0m.
[ 131.416327] mmcblk1: recovery failed!
[ 131.426336] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.432332] mmcblk1: recovery failed!
[ 131.441773] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.447770] mmcblk1: recovery failed!
[ 131.457133] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.463130] mmcblk1: recovery failed!
[ 131.472603] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.478602] mmcblk1: recovery failed!
[ 131.488053] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.494050] mmcblk1: recovery failed!
[ 131.503505] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.509502] mmcblk1: recovery failed!
[ 131.519054] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.525054] mmcblk1: recovery failed!
[ 131.534488] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.540485] mmcblk1: recovery failed!
[ 131.549919] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.555917] mmcblk1: recovery failed!
[ 131.565361] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.571358] mmcblk1: recovery failed!
[ 131.580895] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.586894] mmcblk1: recovery failed!
[ 131.596302] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.602299] mmcblk1: recovery failed!
[FAILED] Failed to start Periodic Command [ 131.612427] sdhci-am654 4fb0000.mmc: error -84 requesting status
Scheduler.
[ 131.619118] mmcblk1: recovery failed!
[ 131.630114] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.636114] mmcblk1: recovery failed!
[ OK ] Started D-Bus System Message Bus 131.646451] sdhci-am654 4fb0000.mmc: error -84 requesting status
m.
[ 131.655829] mmcblk1: recovery failed!
[ 131.665587] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.671594] mmcblk1: recovery failed!
[ OK ] Stopped Login Service.
[ 131.681072] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.689651] mmcblk1: recovery failed!
[ 131.699513] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.708350] mmcblk1: recovery failed!
[ OK ] Stopped Network Service.
[ 131.718209] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.724224] mmcblk1: recovery failed!
[ 131.738290] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.744326] mmcblk1: recovery failed!
[ OK ] Stopped Periodic Command Scheduler.
[ 131.761420] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.767428] mmcblk1: recovery failed!
[ 131.777086] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.783184] mmcblk1: recovery failed!
[ 131.792717] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.798729] mmcblk1: recovery failed!
[ 131.808144] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.814146] mmcblk1: recovery failed!
[ 131.823517] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.829517] mmcblk1: recovery failed!
[ 131.838941] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.844944] mmcblk1: recovery failed!
[FAILED] Failed to start Periodic Command [ 131.854496] sdhci-am654 4fb0000.mmc: error -84 requesting status
Scheduler.
[ 131.861608] mmcblk1: recovery failed!
[ 131.872526] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.882142] mmcblk1: recovery failed!
[ OK ] Started D-Bus System Message Bus 131.892146] sdhci-am654 4fb0000.mmc: error -84 requesting status
m.
[ 131.901960] mmcblk1: recovery failed!
[ OK ] Stopped set host name as per compat[ 131.911792] sdhci-am654 4fb0000.mmc: error -84 requesting status
ible name.
[ 131.921424] mmcblk1: recovery failed!
[ 131.932227] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.938252] mmcblk1: recovery failed!
Starting set host name as per compatible name 131.944066] sdhci-am654 4fb0000.mmc: error -84 requesting status
[0m...
[ 131.953981] mmcblk1: recovery failed!
[ 131.964084] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.970103] mmcblk1: recovery failed!
[FAILED] Failed to start Network Service.
[ 131.980518] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 131.986520] mmcblk1: recovery failed!
[ 131.995961] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.002922] mmcblk1: recovery failed!
[FAILED] Failed to start Login Service[ 132.012424] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.020507] mmcblk1: recovery failed!
[FAILED] Failed to start weston.service 132.041600] sdhci-am654 4fb0000.mmc: error -84 requesting status
m.
[ 132.049057] mmcblk1: recovery failed!
[ 132.058923] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.064921] mmcblk1: recovery failed!
See 'systemctl status weston.service' for details.
[ 132.074469] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.080470] mmcblk1: recovery failed!
[DEPEND] Dependency failed for DEMO.
[ 132.154399] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.160406] mmcblk1: recovery failed!
[ 132.170294] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.176290] mmcblk1: recovery failed!
[ 132.217672] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.223673] mmcblk1: recovery failed!
[ OK ] Stopped Login Service.[ 132.233183] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.242136] mmcblk1: recovery failed!
[ 132.259796] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.265801] mmcblk1: recovery failed!
[ 132.275712] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.281709] mmcblk1: recovery failed!
[ 132.291486] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.297480] mmcblk1: recovery failed!
[ 132.316517] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.327028] mmcblk1: recovery failed!
[ 132.337619] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.345677] mmcblk1: recovery failed!
Starting telnetd.service...
[ 132.360181] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.366235] mmcblk1: recovery failed!
[ 132.377327] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.383387] mmcblk1: recovery failed!
[FAILED] Failed to start Periodic Command [ 132.392884] sdhci-am654 4fb0000.mmc: error -84 requesting status
Scheduler.
[ 132.399326] mmcblk1: recovery failed!
[ 132.410135] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.416198] mmcblk1: recovery failed!
[FAILED] Failed to start D-Bus System Message Bus.
[ 132.426441] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.432998] mmcblk1: recovery failed!
See 'systemctl status dbus.service' for details.
[ 132.442561] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.448562] mmcblk1: recovery failed!
[ OK ] Stopped set host name as per compatible name.
[ 132.458176] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.465277] mmcblk1: recovery failed!
Starting set host name as per compatible name 132.477649] sdhci-am654 4fb0000.mmc: error -84 requesting status
[0m...
[ 132.484147] mmcblk1: recovery failed!
[ 132.494583] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.500637] mmcblk1: recovery failed!
[FAILED] Failed to start Network Service 132.509872] sdhci-am654 4fb0000.mmc: error -84 requesting status
0m.
[ 132.516219] mmcblk1: recovery failed!
[ 132.525998] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.532008] mmcblk1: recovery failed!
[ 132.541481] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.549642] mmcblk1: recovery failed!
[ 132.559313] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.565334] mmcblk1: recovery failed!
[ 132.575325] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.581575] mmcblk1: recovery failed!
[ 132.591032] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.597105] mmcblk1: recovery failed!
[ 132.607353] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.613356] mmcblk1: recovery failed!
[ 132.623251] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.630615] mmcblk1: recovery failed!
[ 132.641674] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.649861] mmcblk1: recovery failed!
[ 132.659831] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.665848] mmcblk1: recovery failed!
[ 132.677766] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.683792] mmcblk1: recovery failed!
[ 132.693493] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.700624] mmcblk1: recovery failed!
Starting set host name as per compatible name 132.710329] sdhci-am654 4fb0000.mmc: error -84 requesting status
[0m...
[ 132.719364] mmcblk1: recovery failed!
[ 132.729657] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.735778] mmcblk1: recovery failed!
[FAILED] Failed to start Network Service 132.745407] sdhci-am654 4fb0000.mmc: error -84 requesting status
0m.
[ 132.753403] mmcblk1: recovery failed!
[ 132.763272] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.769339] mmcblk1: recovery failed!
[ 132.778764] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.784764] mmcblk1: recovery failed!
[FAILED] Failed to start set host name as [ 132.794252] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.801177] mmcblk1: recovery failed!
[ 132.813241] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.823238] mmcblk1: recovery failed!
[FAILED] Failed to start Login Service[ 132.832790] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.840751] mmcblk1: recovery failed!
[ 132.850518] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.856525] mmcblk1: recovery failed!
[ 132.866796] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.872796] mmcblk1: recovery failed!
[ 132.882345] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.888351] mmcblk1: recovery failed!
[ 132.898126] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.904138] mmcblk1: recovery failed!
[ 132.913774] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.919793] mmcblk1: recovery failed!
[ 132.929623] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.935708] mmcblk1: recovery failed!
[ 132.945569] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.952498] mmcblk1: recovery failed!
[FAILED] Failed to start set host name as [ 132.961948] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.968252] mmcblk1: recovery failed!
[ 132.979847] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 132.990840] mmcblk1: recovery failed!
[FAILED] Failed to start Network Service 133.000753] sdhci-am654 4fb0000.mmc: error -84 requesting status
0m.
[ 133.010288] mmcblk1: recovery failed!
See 'systemctl status systemd-networkd.service' for details.[ 133.020606] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.030933] mmcblk1: recovery failed!
[ OK ] Stopped Network Service.[ 133.040572] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.047160] mmcblk1: recovery failed!
[FAILED] Failed to start Network Service 133.056861] sdhci-am654 4fb0000.mmc: error -84 requesting status
0m.
[ 133.067431] mmcblk1: recovery failed!
[ 133.077797] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.083839] mmcblk1: recovery failed!
[ 133.094095] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.100100] mmcblk1: recovery failed!
Starting Network Name Resolution...
[ 133.110283] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.116409] mmcblk1: recovery failed!
[FAILED] Failed to start Login Service[ 133.126120] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.133665] mmcblk1: recovery failed!
[ 133.143327] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.149839] mmcblk1: recovery failed!
[ 133.159260] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.165308] mmcblk1: recovery failed!
[FAILED] Failed to start Login Service[ 133.174722] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.183205] mmcblk1: recovery failed!
See 'systemctl status systemd-logind.service' for details.[ 133.192828] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.202726] mmcblk1: recovery failed!
[ 133.212265] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.218271] mmcblk1: recovery failed!
[ 133.227667] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.233664] mmcblk1: recovery failed!
[ 133.243033] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.249030] mmcblk1: recovery failed!
[ 133.258392] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.264387] mmcblk1: recovery failed!
[ 133.273757] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.279751] mmcblk1: recovery failed!
[ 133.283500] Core dump to |/lib/systemd/systemd-coredump pipe failed
[ 133.289122] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.295771] mmcblk1: recovery failed!
[ OK ] Started telnetd.service.
[ 133.305356] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.312028] mmcblk1: recovery failed!
[ 133.321935] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.327939] mmcblk1: recovery failed!
[ 133.337534] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.343535] mmcblk1: recovery failed!
[ 133.353007] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.359003] mmcblk1: recovery failed!
[ 133.380849] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.386855] mmcblk1: recovery failed!
[ 133.397005] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.403001] mmcblk1: recovery failed!
[ 133.444494] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.450498] mmcblk1: recovery failed!
[ 133.460440] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.466434] mmcblk1: recovery failed!
[FAILED] Failed to start Network Name Resolution.
See 'systemctl status systemd-resolved.service' for details.
[ OK ] Stopped Network Name Resolution[ 133.509569] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.515853] mmcblk1: recovery failed!
[ 133.525573] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.531618] mmcblk1: recovery failed!
[ 133.541437] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.547651] mmcblk1: recovery failed!
[ 133.557216] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.563218] mmcblk1: recovery failed!
[ 133.572831] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.578835] mmcblk1: recovery failed!
[ 133.588491] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.594494] mmcblk1: recovery failed!
[ 133.604092] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.610091] mmcblk1: recovery failed!
[ 133.619530] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.625528] mmcblk1: recovery failed!
[ 133.634973] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.640971] mmcblk1: recovery failed!
[ 133.650416] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.656413] mmcblk1: recovery failed!
[ 133.666147] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.672148] mmcblk1: recovery failed!
[ 133.681684] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.687682] mmcblk1: recovery failed!
[ 133.697175] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.703175] mmcblk1: recovery failed!
[ 133.713410] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.719422] mmcblk1: recovery failed!
[ 133.757046] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.763053] mmcblk1: recovery failed!
[ OK ] Stopped Network Name Resolution[ 133.805578] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.811857] mmcblk1: recovery failed!
[ 133.821572] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.827621] mmcblk1: recovery failed!
[ 133.838297] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.844312] mmcblk1: recovery failed!
[ 133.884891] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.890894] mmcblk1: recovery failed!
[ OK ] Stopped Network Name Resolution[ 133.937589] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.943841] mmcblk1: recovery failed!
[ 133.953571] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.959615] mmcblk1: recovery failed!
[ 133.970157] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 133.976173] mmcblk1: recovery failed!
[ 133.979864] print_req_error: 238 callbacks suppressed
[ 133.979868] blk_update_request: I/O error, dev mmcblk1, sector 129024 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 134.016851] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.022857] mmcblk1: recovery failed!
[ 134.026555] blk_update_request: I/O error, dev mmcblk1, sector 8999488 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 134.071769] EXT4-fs error: 174 callbacks suppressed
[ 134.071775] EXT4-fs error (device mmcblk1p2): ext4_check_bdev_write_error:217: comm systemd: Error while async write back metadata
[ OK ] Stopped Network Name Resolution.
[ 134.094183] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.100353] mmcblk1: recovery failed!
[ 134.104030] blk_update_request: I/O error, dev mmcblk1, sector 129024 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 134.114891] buffer_io_error: 174 callbacks suppressed
[ 134.114894] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 134.131428] EXT4-fs: 174 callbacks suppressed
[ 134.131433] EXT4-fs (mmcblk1p2): I/O error while writing superblock
Starting Network Name Resolution...[ 134.142563] EXT4-fs error (device mmcblk1p2): ext4_check_bdev_write_error:217: comm systemd: Error while async write back metadata
[ 134.148406] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.164921] mmcblk1: recovery failed!
[ 134.168621] blk_update_request: I/O error, dev mmcblk1, sector 4587168 op 0x1:(WRITE) flags 0x800 phys_seg 51 prio class 0
[ 134.179974] Aborting journal on device mmcblk1p2-8.
[ 134.190051] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.196072] mmcblk1: recovery failed!
[ 134.200353] blk_update_request: I/O error, dev mmcblk1, sector 129024 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 134.211247] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 134.218995] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ 134.224120] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.225727] EXT4-fs error (device mmcblk1p2) in ext4_reserve_inode_write:5761: Journal has aborted
[ 134.231245] mmcblk1: recovery failed!
[ 134.243854] blk_update_request: I/O error, dev mmcblk1, sector 4585472 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 134.254800] Buffer I/O error on dev mmcblk1p2, logical block 557056, lost sync page write
[ 134.262975] JBD2: Error -5 detected when updating journal superblock for mmcblk1p2-8.
[ 134.276180] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.282180] mmcblk1: recovery failed!
[ 134.285857] blk_update_request: I/O error, dev mmcblk1, sector 8999488 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 134.291546] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.302554] mmcblk1: recovery failed!
[ 134.306253] blk_update_request: I/O error, dev mmcblk1, sector 129024 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 134.306260] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 134.306302] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ 134.306309] EXT4-fs error (device mmcblk1p2): ext4_dirty_inode:5963: inode #162649: comm systemd: mark_inode_dirty error
[FAILED] Failed to start Network Name Reso[ 134.312080] sdhci-am654 4fb0000.mmc: error -84 requesting status
lution.
[ 134.353590] mmcblk1: recovery failed!
[ 134.358384] blk_update_request: I/O error, dev mmcblk1, sector 129024 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 134.369238] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 134.376981] EXT4-fs (mmcblk1p2): I/O error while writing superblock
See 'systemctl status systemd-resolved.service' for details.[ 134.383328] EXT4-fs error (device mmcblk1p2) in ext4_dirty_inode:5965: Journal has aborted
[ 134.402498] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.408496] mmcblk1: recovery failed!
[ 134.412185] blk_update_request: I/O error, dev mmcblk1, sector 129024 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[ 134.412192] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 134.415406] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ 134.423496] EXT4-fs (mmcblk1p2): previous I/O error to superblock detected
[ 134.450097] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.456136] mmcblk1: recovery failed!
[ 134.459814] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[ 134.467564] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ 134.467574] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[ 134.473929] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:83: Detected aborted journal
[ 134.480148] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:83: Detected aborted journal
[ 134.489123] EXT4-fs (mmcblk1p2): Remounting filesystem read-only
[ 134.498204] EXT4-fs (mmcblk1p2): Remounting filesystem read-only
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
[ 134.594013] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.600020] mmcblk1: recovery failed!
Starting Enable and configure wl18xx bluetooth[ 134.609655] sdhci-am654 4fb0000.mmc: error -84 requesting status
stack...
[ 134.617157] mmcblk1: recovery failed!
[ 134.627861] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.633943] mmcblk1: recovery failed!
Starting LSB: start and stop docker...
[ 134.643277] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.649728] mmcblk1: recovery failed!
Starting Docker Application Container Engine 134.659280] sdhci-am654 4fb0000.mmc: error -84 requesting status
0m...
[ 134.666684] mmcblk1: recovery failed!
[ 134.676721] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.682725] mmcblk1: recovery failed!
Starting LSB: network benchmark...[ 134.692457] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.698652] mmcblk1: recovery failed!
[ 134.708245] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.714314] mmcblk1: recovery failed!
[ 134.723716] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.729715] mmcblk1: recovery failed!
[ 134.739080] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.745076] mmcblk1: recovery failed!
[ 134.754433] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.760428] mmcblk1: recovery failed!
[ 134.769839] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.775839] mmcblk1: recovery failed!
[ 134.785249] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.791275] mmcblk1: recovery failed!
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ 134.803887] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.810176] mmcblk1: recovery failed!
[ 134.820254] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.826259] mmcblk1: recovery failed!
[ 134.835681] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.841682] mmcblk1: recovery failed!
[ 134.845375] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #49: comm systemd: reading directory lblock 0
[ 134.862068] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.868064] mmcblk1: recovery failed!
[ 134.871733] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
[ 134.889054] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.895057] mmcblk1: recovery failed!
[ OK ] Started strongSwan IPsec I…IKEv2 [ 134.904775] sdhci-am654 4fb0000.mmc: error -84 requesting status
daemon using ipsec.conf.
[ 134.914201] mmcblk1: recovery failed!
[ 134.926327] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.932378] mmcblk1: recovery failed!
Starting Permit User Sessions...
[ 134.938140] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.947099] mmcblk1: recovery failed!
[FAILED] Failed to start Avahi mDNS/DNS-SD[ 134.956588] sdhci-am654 4fb0000.mmc: error -84 requesting status
Stack.
[ 134.965730] mmcblk1: recovery failed!
See 'systemctl status avahi-daemon.service' for details.
[ 134.976274] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 134.986669] mmcblk1: recovery failed!
[FAILED] Failed to start Enable and…figure wl18xx bluetooth stack.
See 'systemctl status bt-enable.service' for details.
[FAILED] Failed to start LSB: start and stop docker.
See 'systemctl status docker.init.service' for details.
[FAILED] Failed to start Docker Application Container Engine.
See 'systemctl status docker.service' for details.
[ OK ] Started LSB: network benchmark.
[FAILED] Failed to start Simple Net…ement Protocol (SNMP) Daemon..
See 'systemctl status snmpd.service' for details.
[FAILED] Failed to start Permit User Sessions.
See 'systemctl status systemd-user-sessions.service' for details.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Started Serial Getty on ttyS3.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ 135.253464] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.259472] mmcblk1: recovery failed!
Starting thermal-zone-init.service...
[ 135.269143] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.277803] mmcblk1: recovery failed!
[ OK ] Started thermal-zone-init.service.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Stopped Docker Application Container Engine.
[ OK ] Closed Docker Socket for the API.
Stopping Docker Socket for the API.
[ OK ] Listening on Docker Socket for the API.
Starting Docker Application Container Engine...
[ 135.409020] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.415507] mmcblk1: recovery failed!
[ OK ] Reached target Multi-User System.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
[ 135.523287] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.529295] mmcblk1: recovery failed!
[ 135.538756] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.544807] mmcblk1: recovery failed!
[ 135.554326] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.560325] mmcblk1: recovery failed!
[ 135.569933] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.575985] mmcblk1: recovery failed!
[ 135.586607] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.592695] mmcblk1: recovery failed!
[ 135.607075] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.613117] mmcblk1: recovery failed!
[ 135.630433] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.636499] mmcblk1: recovery failed!
[ 135.653577] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.659580] mmcblk1: recovery failed!
[ 135.680093] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.686102] mmcblk1: recovery failed!
[ 135.695902] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.701925] mmcblk1: recovery failed!
[ 135.713929] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 135.719955] mmcblk1: recovery failed!
[ 136.058579] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 136.064592] mmcblk1: recovery failed!
[ 136.074194] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 136.080201] mmcblk1: recovery failed!
[ 136.308817] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 136.314823] mmcblk1: recovery failed!
[ 136.324417] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 136.330444] mmcblk1: recovery failed!
[ 136.558737] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 136.564758] mmcblk1: recovery failed!
[ 136.575482] sdhci-am654 4fb0000.mmc: error -84 requesting status
[ 136.581545] mmcblk1: recovery failed!
May I ask where is the problem in my operation process, which caused me to use the MCU firmware I compiled myself to not start normally. What should I do to run the MCU firmware compiled by myself?
  • I checked the j7-main-r5f0_0-fw and j7-main-r5f0_1-fw files through the readelf -l command, which contain resource_table information.
    I have a few queries here:
    1) Are you able to boot Linux on your system normally? (I mean with the defaults configurations that comes with the Linux SDK)
    2) Which app are you trying to boot? Is it a custom app or any app from SDK?
    Parth
    Question 1: I can start Linux normally through the default image of the SDK. That is, after installing the Linux SDK, I use the command:
    sudo ./bin/mksdboot.sh --device /dev/sdb --sdk /home/lqd/ti/tda4/sdk_install_dir/linux_sdk
    After inserting the SD card into the TDA4EVM board, Linux can be started normally.
    Question 2: I want to start the RTOS SDK, execute the command make vision_apps in the vision_apps directory, and then generate the out/J7/R5F/FREERTOS/release/vx_app_rtos_linux_mcu2_0.out program.
    What should I do to make the vx_app_rtos_linux_mcu2_0.out program run.
    For building RTOS SDK, could you do the below? (I'm assuming you do not have any changes in RTOS SDK?)
    Insert the SD card into your PC. You would have already partitioned the SD card to BOOT and rootfs right?
    cd rtos_sdk/vision_apps/
    make sdk -j4
    make linux_fs_install_sd
    Please check if you are able to run in the EVM after doing the above steps.
    Nikhil
