Other Parts Discussed in Thread: PCM5310, TLV320AIC3262
Hi Experts,
Good day. Seeking advise on this queryL
I have work to complete on dsp based audio mixer and the dsp based audio equalizer. So I am searching for the sample diagram to implement both of those devices from TI plus what development tools that goes with it.
What information you need extra on both of my requirement above? I hope you can assist in suggesting me the right dsp chip (if possible) that can handle both the audio mixer and the audio equalizer as well
2 products using the same dsp chip ... that is what I meant
To be detailed:
I am hoping to get the evalution circuit diagram from TI on implementing the dsp based audio mixer which takes about analog line signal (6 stereo input) by at least 1 stereo line level output. The audio equalizer takes at least 1 stereo analog audio in (line level) and give out 1 stereo analog audio before it goes into the D-class amplifier. I need the dsp chip as well as the dev tools like the IDE and the programming cable/ICE
Cool if the dsp can do both jobs so I can learn and hit both with single learning path. The products suppose to go into classrooms in universities
Pure Path Studio seems cool
Thank you.
Archie A.
