I am following this instruction to create SD card and boot the device from it:
1.1.1. Download and Install the SDK — Processor SDK Linux for J721e Documentation
I went till 1.1.3- formatiing SD card
ran the provided script,
sudo <SDK INSTALL DIR>/bin/mksdboot.sh --device /dev/sdX --sdk <SDK INSTALL DIR> #Replace the /dev/sdX with appropriate device name
It seemed to properly format the SD card, however when I inserted the card in the EVM connector board and powered on the board in bootup mode
It always get stuck in the bootup process. Following is the output logs I get from the board (through Uart connection)
U-Boot SPL 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:34:29 +0000)
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev E8
SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.5(release):08.01.00.006-dirty
NOTICE: BL31: Built : 21:03:57, Mar 23 2022
U-Boot SPL 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:04:54 +0000)
Detected: J7X-BASE-CPB rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:04:54 +0000)
SoC: J721E SR1.1
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
cdns,sierra serdes@5000000: sierra probed
Net: eth0: ethernet@46000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
0 bytes read in 1 ms (0 Bytes/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
19276288 bytes read in 811 ms (22.7 MiB/s)
102282 bytes read in 15 ms (6.5 MiB/s)
Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.100-g7a7a3af903 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Wed Mar 23 21:07:41 UTC 2022
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff]
[ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff]
[ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000abffffff]
[ 0.000000] node 0: [mem 0x00000000ac000000-0x00000000adffffff]
[ 0.000000] node 0: [mem 0x00000000ae000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=cad44646-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[ 0.000000] Memory: 3339136K/4194304K available (10880K kernel code, 1288K rwdata, 4352K rodata, 1856K init, 751K bss, 330880K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008800b0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[ 0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008387] Console: colour dummy device 80x25
[ 0.012947] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023618] pid_max: default: 32768 minimum: 301
[ 0.028365] LSM: Security Framework initializing
[ 0.033108] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.040675] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.049612] rcu: Hierarchical SRCU implementation.
[ 0.054667] Platform MSI: msi-controller@1820000 domain created
[ 0.060905] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070202] EFI services will not be available.
[ 0.074953] smp: Bringing up secondary CPUs ...
[ 0.080196] Detected PIPT I-cache on CPU1
[ 0.080220] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.080231] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[ 0.080265] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.080316] smp: Brought up 1 node, 2 CPUs
[ 0.109661] SMP: Total of 2 processors activated.
[ 0.114466] CPU features: detected: 32-bit EL0 Support
[ 0.119720] CPU features: detected: CRC32 instructions
[ 0.133679] CPU: All CPU(s) started at EL2
[ 0.137874] alternatives: patching kernel code
[ 0.142865] devtmpfs: initialized
[ 0.151242] KASLR disabled due to lack of seed
[ 0.155893] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.165856] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[ 0.173524] pinctrl core: initialized pinctrl subsystem
[ 0.179101] DMI not present or invalid.
[ 0.183330] NET: Registered protocol family 16
[ 0.190673] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.197972] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.205976] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.214275] thermal_sys: Registered thermal governor 'step_wise'
[ 0.214278] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.220704] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.234346] ASID allocator initialised with 65536 entries
[ 0.257969] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[ 0.264826] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[ 0.271583] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.279430] cryptd: max_cpu_qlen set to 1000
[ 0.285502] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.294299] vsys_3v3: supplied by evm_12v0
[ 0.298657] vsys_5v0: supplied by evm_12v0
[ 0.303355] iommu: Default domain type: Translated
[ 0.308469] SCSI subsystem initialized
[ 0.312586] mc: Linux media interface: v0.10
[ 0.317002] videodev: Linux video capture interface: v2.00
[ 0.322631] pps_core: LinuxPPS API ver. 1 registered
[ 0.327701] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.337038] PTP clock support registered
[ 0.341060] EDAC MC: Ver: 3.0.0
[ 0.344800] FPGA manager framework
[ 0.348310] Advanced Linux Sound Architecture Driver Initialized.
[ 0.354912] clocksource: Switched to clocksource arch_sys_counter
[ 0.361328] VFS: Disk quotas dquot_6.6.0
[ 0.365372] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[ 0.375067] NET: Registered protocol family 2
[ 0.379648] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[ 0.388260] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[ 0.397022] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[ 0.405217] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[ 0.413161] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.419911] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.426805] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.434190] NET: Registered protocol family 1
[ 0.438900] RPC: Registered named UNIX socket transport module.
[ 0.444962] RPC: Registered udp transport module.
[ 0.449767] RPC: Registered tcp transport module.
[ 0.454569] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.461153] PCI: CLS 0 bytes, default 64
[ 0.465516] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.475745] Initialise system trusted keyrings
[ 0.480357] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[ 0.488594] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.494811] NFS: Registering the id_resolver key type
[ 0.500022] Key type id_resolver registered
[ 0.504294] Key type id_legacy registered
[ 0.508413] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.515261] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.522896] 9p: Installing v9fs 9p2000 file system support
[ 0.548170] Key type asymmetric registered
[ 0.552357] Asymmetric key parser 'x509' registered
[ 0.557353] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.564911] io scheduler mq-deadline registered
[ 0.569537] io scheduler kyber registered
[ 0.574806] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.580985] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.589618] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.595886] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.603729] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.611834] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.620795] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[ 0.629615] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[ 0.637322] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.650194] brd: module loaded
[ 0.656134] loop: module loaded
[ 0.659976] megasas: 07.714.04.00-rc1
[ 0.665483] tun: Universal TUN/TAP device driver, 1.6
[ 0.670931] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.677335] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.683405] sky2: driver version 1.30
[ 0.687679] VFIO - User Level meta-driver version: 0.3
[ 0.693354] i2c /dev entries driver
[ 0.697547] sdhci: Secure Digital Host Controller Interface driver
[ 0.703865] sdhci: Copyright(c) Pierre Ossman
[ 0.708571] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.714934] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.721234] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.728361] optee: probing for conduit method.
[ 0.732918] optee: revision 3.12 (3d47a131)
[ 0.733154] optee: initialized driver
[ 0.742502] NET: Registered protocol family 17
[ 0.747109] 9pnet: Installing 9P2000 support
[ 0.751497] Key type dns_resolver registered
[ 0.755940] Loading compiled-in X.509 certificates
[ 0.765393] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.771729] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.779823] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
[ 0.809838] random: fast init done
[ 0.842514] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.850152] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.856233] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.862291] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.868753] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.875578] pca953x 3-0020: using no AI
[ 0.903745] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 0.910545] pca953x 3-0022: using AI
[ 0.914829] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
[ 0.920810] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
[ 0.927057] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
[ 0.933557] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.939988] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.950122] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
[ 0.956417] pca953x 6-0020: supply vcc not found, using dummy regulator
[ 0.963233] pca953x 6-0020: using no AI
[ 0.991613] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.997671] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[ 1.003613] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[ 1.009848] pca953x 9-0020: supply vcc not found, using dummy regulator
[ 1.016667] pca953x 9-0020: using no AI
[ 1.043235] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[ 1.049641] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.059619] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.068425] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.078267] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.099822] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 1.107498] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 1.115775] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 1.124052] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.139430] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[ 2.145861] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.151478] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 2.161169] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 2.168223] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 2.174362] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.184231] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.194123] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
[ 2.204084] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.214053] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[ 2.224012] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[ 2.234011] pci 0000:00:00.0: supports D1
[ 2.238105] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.243976] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[ 2.253941] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x208 may corrupt adjacent RW1C bits
[ 2.263995] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[ 2.271021] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[ 2.280987] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
[ 2.291033] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
[ 2.302870] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.312833] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.319606] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
[ 2.327083] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.332355] pcieport 0000:00:00.0: PME: Signaling with IRQ 61
[ 2.338682] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.346345] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.354622] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.362898] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.371522] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[ 3.377932] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 3.383536] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[ 3.393404] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 3.400446] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[ 3.406648] pci 0001:00:00.0: supports D1
[ 3.410742] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 3.418326] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.428160] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.434931] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 3.440184] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[ 3.446511] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 3.454178] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 3.462454] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 3.470731] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.482081] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
[ 4.488508] pci_bus 0002:00: root bus resource [bus 00-ff]
[ 4.494114] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[ 4.503360] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[ 4.514134] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
[ 4.520333] pci 0002:00:00.0: supports D1
[ 4.524427] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
[ 4.532043] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.541859] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.548630] pci 0002:00:00.0: PCI bridge to [bus 01]
[ 4.553893] pcieport 0002:00:00.0: PME: Signaling with IRQ 67
[ 4.560610] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 4.570486] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 4.577244] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 4.586133] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 4.596286] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 4.603045] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 4.610999] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 4.620373] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[ 4.629117] printk: console [ttyS2] enabled
[ 4.637554] printk: bootconsole [ns16550a0] disabled
[ 4.647998] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[ 4.656932] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[ 4.667556] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.678066] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 4.688220] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 4.698459] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 4.709356] scsi host0: ufshcd
[ 4.731191] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[ 4.754917] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 4.763897] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 4.772215] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 4.786190] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 4.795101] mmc0: CQHCI version 5.10
[ 4.795361] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 4.809099] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[ 4.810607] vdd_mmc1: supplied by vsys_3v3
[ 4.824842] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[ 4.825687] pca953x 4-0020: supply vcc not found, using dummy regulator
[ 4.842631] pca953x 4-0020: using no AI
[ 4.846496] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 4.855348] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 4.864034] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[ 4.867884] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 4.871262] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 4.878090] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 4.892249] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 4.899090] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 4.905944] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 4.916685] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 4.927066] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 4.941488] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[ 4.946726] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[ 4.953333] Creating 8 MTD partitions on "47040000.spi.0":
[ 4.958810] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 4.964767] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 4.970476] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 4.976239] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 4.981780] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[ 4.987432] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[ 4.993574] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 4.999329] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 5.007972] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[ 5.024881] mmc0: Command Queue Engine enabled
[ 5.029331] mmc0: new HS200 MMC card at address 0001
[ 5.034561] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 5.039191] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 5.045191] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 5.050927] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 5.051170] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[ 5.059924] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 5.074366] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 5.088007] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 5.095004] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 5.102212] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 5.108539] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 5.118954] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 5.119114] mmc1: CQHCI version 5.10
[ 5.136322] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 5.143630] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 5.151796] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 5.159128] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 5.166436] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 5.173744] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 5.181922] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.202559] ALSA device list:
[ 5.205537] No soundcards found.
[ 6.182439] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 6.190871] Waiting for root device PARTUUID=cad44646-02...
[ 6.231621] mmc1: error -110 whilst initialising SD card
[ 6.349706] mmc1: error -110 whilst initialising SD card
[ 6.472463] mmc1: error -110 whilst initialising SD card
[ 6.595120] mmc1: error -110 whilst initialising SD card
[ 35.910922] vdd_mmc1: disabling
(It was stuck with this output and nothing more happens)
