Part Number: AM5728
Hi support team,
I am using Ubuntu 20.04 with kernel version 4.14.108-ti-r136. I designed own custom board.
We need correct setting required in device tree for LAN9720A device with am5728. The device tree setting is attached with this thread.
We gets below error.
davinci_mdio: probe of 48485000.mdio failed with error -5
Please help me regarding this error.
Thanks and Regards
Ajay
* Device tree setting
My own am57xx_custom.dtsi added in am57xx-beagle-x15.dts file. below setting in am57xx_custom.dtsi
&dra7_pmx_core {
cpsw_pins_default: cpsw_pins_default {
pinctrl-single,pins = <
/* Slave at addr 0x0 */
DRA7XX_CORE_IOPAD(0x3658, PIN_INPUT | MUX_MODE1) /* rgmii0_td3.rmii0_crs(ball number ---> V7 */
DRA7XX_CORE_IOPAD(0x365c, PIN_OUTPUT | MUX_MODE1) /* rgmii0_td2.rmii0_txen ---> V3 */
DRA7XX_CORE_IOPAD(0x3660, PIN_OUTPUT | MUX_MODE1) /* rgmii0_td1.rmii0_txd1 ---> Y2 */
DRA7XX_CORE_IOPAD(0x3664, PIN_OUTPUT | MUX_MODE1) /* rgmii0_td0.rmii0_txd0 ---> W2 */
DRA7XX_CORE_IOPAD(0x3674, PIN_INPUT_PULLDOWN | MUX_MODE1) /* rgmii0_rd2.rmii0_rxer ---> U7 */
DRA7XX_CORE_IOPAD(0x3678, PIN_INPUT_PULLDOWN | MUX_MODE1) /* rgmii0_rd1.rmii0_rxd1 ---> V6 */
DRA7XX_CORE_IOPAD(0x367c, PIN_INPUT_PULLDOWN | MUX_MODE1) /* rgmii0_rd0.rmii0_rxd0 ---> U6 */
DRA7XX_CORE_IOPAD(0x3644, PIN_INPUT_PULLUP | MUX_MODE0) /* RMII_MHZ_50_CLK --> U3*/
/* Slave at addr 0x1 */
DRA7XX_CORE_IOPAD(0x3648, PIN_INPUT | MUX_MODE2) /* UART3_RXD.rmii1_crs ---> V2 */
DRA7XX_CORE_IOPAD(0x3668, PIN_OUTPUT | MUX_MODE2) /* RGMII0_RXC.rmii1_txen ---> U5 */
DRA7XX_CORE_IOPAD(0x366C, PIN_OUTPUT | MUX_MODE2) /* RGMII0_RXCTL.rmii1_txd1 ---> V5 */
DRA7XX_CORE_IOPAD(0x3670, PIN_OUTPUT | MUX_MODE2) /* RGMII0_RXD3.rmii1_txd0 ---> V4 */
DRA7XX_CORE_IOPAD(0x364C, PIN_INPUT_PULLDOWN | MUX_MODE2) /* UART3_TXD.rmii1_rxer ---> Y1 */
DRA7XX_CORE_IOPAD(0x3650, PIN_INPUT_PULLDOWN | MUX_MODE2) /* RGMII0_TXC.rmii1_rxd1 ---> W9*/
DRA7XX_CORE_IOPAD(0x3654, PIN_INPUT_PULLDOWN | MUX_MODE2) /* RGMII0_TXCTL.rmii1_rxd0 ---> V9 */
cpsw_pins_sleep: cpsw_pins_sleep {
/* Slave 1 */
DRA7XX_CORE_IOPAD(0x3658, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x365C, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x3660, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x3664, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x3674, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x3678, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x367C, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x3644, PIN_INPUT_PULLDOWN | MUX_MODE15)
/* Slave 2 */
DRA7XX_CORE_IOPAD(0x3648, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x3668, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x366C, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x3670, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x364C, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x3650, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x3654, PIN_INPUT_PULLDOWN | MUX_MODE15)
davinci_mdio_pins_default: davinci_mdio_pins_default {
/* MDIO */
DRA7XX_CORE_IOPAD(0x3590, PIN_OUTPUT_PULLUP | MUX_MODE0) /* vin2a_d10.mdio_mclk */
DRA7XX_CORE_IOPAD(0x3594, PIN_INPUT_PULLUP | MUX_MODE0) /* vin2a_d11.mdio_d */
davinci_mdio_pins_sleep: davinci_mdio_pins_sleep {
DRA7XX_CORE_IOPAD(0x3590, PIN_INPUT_PULLDOWN | MUX_MODE15)
DRA7XX_CORE_IOPAD(0x3594, PIN_INPUT_PULLDOWN | MUX_MODE15)
&mac {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&cpsw_pins_default>;
pinctrl-1 = <&cpsw_pins_sleep>;
status = "okay";
active_slave = <1>;
dual_emac;
&cpsw_emac0 {
phy-handle = <&phy0>;
phy-mode = "rmii";
dual_emac_res_vlan = <0>;
&cpsw_emac1 {
phy-handle = <&phy1>;
phy-mode = "rmii";
dual_emac_res_vlan = <1>;
&davinci_mdio {
status = "okay";
pinctrl-0 = <&davinci_mdio_pins_default>;
pinctrl-1 = <&davinci_mdio_pins_sleep>;
phy0: ethernet-phy@0 {
reg = <0>;
phy1: ethernet-phy@1 {
reg = <1>;
In dra7.dtsi file for configure the address
mac: ethernet@48484000 {
compatible = "ti,dra7-cpsw","ti,cpsw";
ti,hwmods = "gmac";
clocks = <&gmac_main_clk>, <&l3init_clkctrl DRA7_GMAC_CLKCTRL 25>;
clock-names = "fck", "cpts";
cpdma_channels = <8>;
ale_entries = <1024>;
bd_ram_size = <0x2000>;
mac_control = <0x20>;
slaves = <2>;
active_slave = <0>;
cpts_clock_mult = <0x784CFE14>;
cpts_clock_shift = <29>;
reg = <0x48484000 0x1000
0x48485200 0x2E00>;
#address-cells = <1>;
#size-cells = <1>;
* Do not allow gating of cpsw clock as workaround
* for errata i877. Keeping internal clock disabled
* causes the device switching characteristics
* to degrade over time and eventually fail to meet
* the data manual delay time/skew specs.
ti,no-idle;
* rx_thresh_pend
* rx_pend
* tx_pend
* misc_pend
interrupts = <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>;
ranges;
syscon = <&scm_conf>;
status = "disabled";
davinci_mdio: mdio@48485000 {
compatible = "ti,cpsw-mdio","ti,davinci_mdio";
#size-cells = <0>;
ti,hwmods = "davinci_mdio";
bus_freq = <1000000>;
reg = <0x48485000 0x100>;
cpsw_emac0: slave@48480200 {
/* Filled in by U-Boot */
mac-address = [ 00 00 00 00 00 00 ];
cpsw_emac1: slave@48480300 {
phy_sel: cpsw-phy-sel@4a002554 {
compatible = "ti,dra7xx-cpsw-phy-sel";
reg= <0x4a002554 0x4>;
reg-names = "gmii-sel";
