TDA4VM: TIDL Demo Running error
Part Number: TDA4VM
Hi, TI experts,
SDK version:ti-processor-sdk-rtos-j721e-evm-08_00_00_12
We are trying to run tidl Demo:/ti-processor-sdk-rtos-j721e-evm-08_00_00_12/vision_apps/apps/dl_demos/app_tidl
But the following error is reported. What is the reason?
Error log:
root@j7-evm:/opt/vision_apps# ./run_app_tidl.sh
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
linux.c IPC: Init ... !!!
IPC: mcu1_0 : rpmsg local endpt is 1024
IPC: mcu2_0 : rpmsg local endpt is 1025
IPC: mcu2_1 : rpmsg local endpt is 1024
IPC: mcu3_0 : rpmsg local endpt is 1024
IPC: mcu3_1 : rpmsg local endpt is 1024
IPC: c6x_1 : rpmsg local endpt is 1024
IPC: c6x_2 : rpmsg local endpt is 1024
IPC: c7x_1 : rpmsg local endpt is 1024
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
86.548226 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
86.550258 s: VX_ZONE_INIT:Enabled
86.550269 s: VX_ZONE_ERROR:Enabled
86.550274 s: VX_ZONE_WARNING:Enabled
86.554292 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
86.554476 s: VX_ZONE_INIT:[tivxHostInit:48] Initialization Done for HOST !!!
main_linux_arm.c,next app_tidl_main
app_tidl_main before status:0
app_tidl_main first status:0
app_tidl_main first_2 status:0
app_tidl_main start
open_up_thread success!
running app_init
main .c app_tidl: Init ...
obj_2 227
obj_2 229
obj_2 running app_init
86.689339 s: VX_ZONE_ERROR:[vxLoadKernels:206] Publish function for module hwa failed
86.689391 s: VX_ZONE_ERROR:[vxLoadKernels:206] Publish function for module hwa failed
obj_2 app_create_graph(obj)
obj_2 app_verify_graph(obj)
86.701171 s: IPC: TX: mpu1_0 -> c7x_1 (port 13) msg = 0x00000080
[C7x_1 ] 86.701232 s: RPMessage_recv done... status:0
[C7x_1 ] 86.701248 s: RTOS.c recv len == 4)
[C7x_1 ] 86.701256 s: IPC: RX: mpu1_0 (port 1024) -> C7X_1 (port 13) msg = 0x00000080
[C7x_1 ] 86.701272 s: obj->ipc_notify_handler :��
[C7x_1 ] 86.701286 s: waiting...
86.709949 s: read payload :@ status:4
86.709971 s: line:121,payload : 2
86.709976 s: IPC: RX: c7x_1 -> mpu1_0 (port 1024) msg = 0x00000240
86.709982 s: obj->ipc_notify_handler :�
86.710030 s: VX_ZONE_ERROR:[ownContextSendCmd:783] Command ack message returned failure cmd_status: -1
86.710038 s: VX_ZONE_ERROR:[ownContextSendCmd:819] tivxEventWait() failed.
86.710049 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
86.710056 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
86.710064 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
86.710074 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
86.710084 s: IPC: TX: mpu1_0 -> c7x_1 (port 13) msg = 0x00001080
86.710100 s: VX_ZONE_ERROR:[vxVerifyGraph:2044] Node kernel init failed
86.710108 s: VX_ZONE_ERROR:[vxVerifyGraph:2098] Graph verify failed
[C7x_1 ] 86.709730 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:551] Network version - 0x20211201, Expected version - 0x20210723
[C7x_1 ] 86.709815 s: VX_ZONE_WARNING:[tivxKernelTIDLCreate:615] All Interrupts DISABLED during TIDL process
[C7x_1 ] 86.709846 s: IPC: TX: C7X_1 (port 13) -> mpu1_0 (port 1024) msg = 0x00000240
[C7x_1 ] 86.710122 s: RPMessage_recv done... status:0
[C7x_1 ] 86.710136 s: RTOS.c recv len == 4)
[C7x_1 ] 86.710144 s: IPC: RX: mpu1_0 (port 1024) -> C7X_1 (port 13) msg = 0x00001080
[C7x_1 ] 86.710159 s: obj->ipc_notify_handler :��
[C7x_1 ] 86.710171 s: waiting...
86.718641 s: read payload :@ status:4
86.718657 s: line:121,payload : 2
86.718662 s: IPC: RX: c7x_1 -> mpu1_0 (port 1024) msg = 0x00001240
86.718668 s: obj->ipc_notify_handler :�
86.718707 s: VX_ZONE_ERROR:[ownContextSendCmd:783] Command ack message returned failure cmd_status: -1
86.718714 s: VX_ZONE_ERROR:[ownContextSendCmd:819] tivxEventWait() failed.
86.718725 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
86.718731 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
86.718737 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
86.718744 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
86.718752 s: VX_ZONE_ERROR:[vxVerifyGraph:2044] Node kernel init failed
86.718758 s: VX_ZONE_ERROR:[vxVerifyGraph:2098] Graph verify failed
app_tidl: ERROR: Verifying graph ... Failed !!!
86.719410 s: VX_ZONE_ERROR:[vxRemoveKernel:237] Invalid kernel reference
86.719420 s: VX_ZONE_ERROR:[vxUnloadKernels:243] Unublish function for module hwa failed
86.719430 s: VX_ZONE_ERROR:[vxRemoveKernel:237] Invalid kernel reference
86.719439 s: VX_ZONE_ERROR:[vxUnloadKernels:243] Unublish function for module hwa failed
86.719616 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x705858 of type 00000804 at external count 1, internal count 1, releasing it
86.719624 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.hwa.vpac_nf_generic
86.719630 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719635 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.hwa.vpac_nf_generic has not been removed, possibly due to a kernel module not being unloaded.
86.719641 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719651 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x705dd0 of type 00000804 at external count 1, internal count 1, releasing it
86.719657 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.hwa.vpac_nf_bilateral
86.719662 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719668 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.hwa.vpac_nf_bilateral has not been removed, possibly due to a kernel module not being unloaded.
86.719674 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719682 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x706348 of type 00000804 at external count 1, internal count 1, releasing it
86.719688 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.hwa.dmpac_sde
86.719693 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719698 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.hwa.dmpac_sde has not been removed, possibly due to a kernel module not being unloaded.
86.719704 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719712 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x7068c0 of type 00000804 at external count 1, internal count 1, releasing it
86.719718 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.hwa.vpac_ldc
86.719723 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719729 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.hwa.vpac_ldc has not been removed, possibly due to a kernel module not being unloaded.
86.719734 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719743 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x706e38 of type 00000804 at external count 1, internal count 1, releasing it
86.719748 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.hwa.vpac_msc_multi_scale
86.719754 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719759 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.hwa.vpac_msc_multi_scale has not been removed, possibly due to a kernel module not being unloaded.
86.719765 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719773 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x7073b0 of type 00000804 at external count 1, internal count 1, releasing it
86.719779 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.hwa.vpac_msc_pyramid
86.719784 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719789 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.hwa.vpac_msc_pyramid has not been removed, possibly due to a kernel module not being unloaded.
86.719795 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719803 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x707928 of type 00000804 at external count 1, internal count 1, releasing it
86.719809 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.hwa.dmpac_dof
86.719815 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719820 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.hwa.dmpac_dof has not been removed, possibly due to a kernel module not being unloaded.
86.719826 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719834 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x707ea0 of type 00000804 at external count 1, internal count 1, releasing it
86.719840 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.hwa.dof_visualize
86.719845 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719850 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.hwa.dof_visualize has not been removed, possibly due to a kernel module not being unloaded.
86.719856 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719864 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x708418 of type 00000804 at external count 1, internal count 1, releasing it
86.719870 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.hwa.vpac_viss
86.719875 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719881 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.hwa.vpac_viss has not been removed, possibly due to a kernel module not being unloaded.
86.719886 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719895 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x708990 of type 00000804 at external count 1, internal count 1, releasing it
86.719900 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.hwa.display
86.719905 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719911 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.hwa.display has not been removed, possibly due to a kernel module not being unloaded.
86.719916 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719925 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x708f08 of type 00000804 at external count 1, internal count 1, releasing it
86.719931 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.capture
86.719936 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719941 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.capture has not been removed, possibly due to a kernel module not being unloaded.
86.719947 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719955 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x709480 of type 00000804 at external count 1, internal count 1, releasing it
86.719961 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.csitx
86.719966 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.719972 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.csitx has not been removed, possibly due to a kernel module not being unloaded.
86.719977 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.719985 s: VX_ZONE_WARNING:[vxReleaseContext:1012] Found a reference 0x7099f8 of type 00000804 at external count 1, internal count 1, releasing it
86.719992 s: VX_ZONE_WARNING:[vxReleaseContext:1016] Unreleased reference name = com.ti.hwa.displaym2m
86.719997 s: VX_ZONE_WARNING:[vxReleaseContext:1018] Releasing reference now as a part of garbage collection
86.720002 s: VX_ZONE_WARNING:[vxReleaseContext:1027] A kernel with name com.ti.hwa.displaym2m has not been removed, possibly due to a kernel module not being unloaded.
86.720008 s: VX_ZONE_WARNING:[vxReleaseContext:1028] Removing as a part of garbage collection
86.720084 s: VX_ZONE_INIT:[tivxHostDeInit:56] De-Initialization Done for HOST !!!
86.724386 s: VX_ZONE_INIT:[tivxDeInit:111] De-Initialization Done !!!
APP: Deinit ... !!!
REMOTE_SERVICE: Deinit ... !!!
[C7x_1 ] 86.718440 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:551] Network version - 0x20211201, Expected version - 0x20210723
[C7x_1 ] 86.718525 s: VX_ZONE_WARNING:[tivxKernelTIDLCreate:615] All Interrupts DISABLED during TIDL process
[C7x_1 ] 86.718554 s: IPC: TX: C7X_1 (port 13) -> mpu1_0 (port 1024) msg = 0x00001240
REMOTE_SERVICE: Deinit ... Done !!!
IPC: Deinit ... !!!
IPC: DeInit ... Done !!!
MEM: Deinit ... !!!
MEM: Alloc's: 24 alloc's of 44907762 bytes
MEM: Free's : 24 free's of 44907762 bytes
MEM: Open's : 0 allocs of 0 bytes
MEM: Deinit ... Done !!!
APP: Deinit ... Done !!!
