TDA4VM: EMMC HS400 MODE
Part Number: TDA4VM
HI TI,
I found the emmc don't support the hs400 mode, but the code in uboot dts is hs400 mode, why? the uboot dts is used by mcu r5f and a72, so the mcu r5f and a72 emmc is hs400 mode, right?
~/ti-processor-sdk-linux-j7-evm-08_01_00_07/board-support/u-boot-2021.01+gitAUTOINC+15769936a5-g15769936a5/arch/arm/dts/k3-j721e-main.dtsi
main_sdhci0: sdhci@4f80000 {
compatible = "ti,j721e-sdhci-8bit";
reg = <0x0 0x4f80000 0x0 0x1000>, <0x0 0x4f88000 0x0 0x400>;
interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 91 TI_SCI_PD_EXCLUSIVE>;
clock-names = "clk_xin", "clk_ahb";
clocks = <&k3_clks 91 1>, <&k3_clks 91 0>;
assigned-clocks = <&k3_clks 91 1>;
assigned-clock-parents = <&k3_clks 91 2>;
bus-width = <8>;
mmc-hs400-1_8v;
mmc-ddr-1_8v;
ti,otap-del-sel-legacy = <0xf>;
ti,otap-del-sel-mmc-hs = <0xf>;
ti,otap-del-sel-ddr52 = <0x5>;
ti,otap-del-sel-hs200 = <0x6>;
ti,otap-del-sel-hs400 = <0x0>;
ti,itap-del-sel-legacy = <0x10>;
ti,itap-del-sel-mmc-hs = <0xa>;
ti,itap-del-sel-ddr52 = <0x3>;
ti,trm-icp = <0x8>;
dma-coherent;
but in kernel is hs200 mode?
~/ti-processor-sdk-linux-j7-evm-08_01_00_07/board-support/linux-5.10.65+gitAUTOINC+dcc6bedb2c-gdcc6bedb2c/arch/arm64/boot/dts/ti/k3-j721e-main.dtsi
main_sdhci0: mmc@4f80000 {
clock-names = "clk_ahb", "clk_xin";
clocks = <&k3_clks 91 0>, <&k3_clks 91 1>;
bus-width = <8>;
mmc-hs200-1_8v;
mmc-ddr-1_8v;
ti,trm-icp = <0x8>;
ti,strobe-sel = <0x77>;
dma-coherent;
