Part Number: SK-AM62
I'm using SK-AM62 board. I have build using Yocto and I'm trying to load the bootloader using DFU following the instructions at https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/08_03_00_19/exports/docs/linux/Foundational_Components/U-Boot/UG-DFU.html
This is currently not working, at the first step, when loading the bootloader, this fails at the end saying it's impossible to detach. See following log.
sudo dfu-util -R -a bootloader -D tiboot3.bin dfu-util 0.9 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2016 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to http://sourceforge.net/p/dfu-util/tickets/ dfu-util: Invalid DFU suffix signature dfu-util: A valid DFU suffix will be required in a future dfu-util release!!! Opening DFU capable USB device... ID 0451:6165 Run-time device DFU version 0110 Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing DFU mode device DFU version 0110 Device returned transfer size 512 Copying data from PC to DFU device Download [=========================] 100% 335442 bytes Download done. state(6) = dfuMANIFEST-SYNC, status(0) = No error condition is present dfu-util: unable to read DFU status after completion dfu-util: can't detach Resetting USB to switch back to runtime mode
I notice at the same time there is an USB error in kernel logs using dmesg:
[ 3480.911198] usb 1-1: new high-speed USB device number 18 using xhci_hcd [ 3481.060021] usb 1-1: New USB device found, idVendor=0451, idProduct=6165, bcdDevice= 2.00 [ 3481.060026] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 3481.060030] usb 1-1: Product: AM62x DFU [ 3481.060033] usb 1-1: Manufacturer: Texas Instruments, Inc. [ 3481.060035] usb 1-1: SerialNumber: 01.00.00.00 [ 3502.999506] usb 1-1: reset high-speed USB device number 18 using xhci_hcd [ 3508.131230] usb 1-1: device descriptor read/64, error -110 [ 3513.507240] usb 1-1: device descriptor read/64, error -71 [ 3513.743257] usb 1-1: reset high-speed USB device number 18 using xhci_hcd [ 3513.871233] usb 1-1: device descriptor read/64, error -71 [ 3514.107321] usb 1-1: device descriptor read/64, error -71 [ 3514.343319] usb 1-1: reset high-speed USB device number 18 using xhci_hcd [ 3514.343492] usb 1-1: Device not responding to setup address. [ 3514.551368] usb 1-1: Device not responding to setup address. [ 3514.759198] usb 1-1: device not accepting address 18, error -71 [ 3514.887229] usb 1-1: reset high-speed USB device number 18 using xhci_hcd [ 3514.887390] usb 1-1: Device not responding to setup address. [ 3515.095296] usb 1-1: Device not responding to setup address. [ 3515.303202] usb 1-1: device not accepting address 18, error -71 [ 3515.303554] usb 1-1: USB disconnect, device number 18 [ 3515.431017] usb 1-1: new high-speed USB device number 19 using xhci_hcd [ 3515.559276] usb 1-1: device descriptor read/64, error -71 [ 3515.795230] usb 1-1: device descriptor read/64, error -71 [ 3516.031201] usb 1-1: new high-speed USB device number 20 using xhci_hcd [ 3516.159232] usb 1-1: device descriptor read/64, error -71 [ 3516.395248] usb 1-1: device descriptor read/64, error -71 [ 3516.503304] usb usb1-port1: attempt power cycle [ 3516.915200] usb 1-1: new high-speed USB device number 21 using xhci_hcd [ 3516.915334] usb 1-1: Device not responding to setup address. [ 3517.123322] usb 1-1: Device not responding to setup address. [ 3517.331195] usb 1-1: device not accepting address 21, error -71 [ 3517.459201] usb 1-1: new high-speed USB device number 22 using xhci_hcd [ 3517.459333] usb 1-1: Device not responding to setup address. [ 3517.667344] usb 1-1: Device not responding to setup address. [ 3517.875203] usb 1-1: device not accepting address 22, error -71 [ 3517.875339] usb usb1-port1: unable to enumerate USB device
Any ideas ?!
Joel
