I am trying to get one of the demo programs for the ezDSP C5505 USB evaluation board running but I am having some trouble. The demo program that I'm trying to run is one that was distibuted at the Embedded Systems Conference last week. It is called USBKey_LED and was handed out by the folks from Texas Instruments. Anyways, I loaded Code Composer Studio V4 and built the program without too much difficulty, but when I try to debug it, it appears to load and launch, but never gets around to calling my main() entry point. I not sure exactly what it is doing before it calls main(), but I would guess that it is initializing registers and setting up the interrupt vectors. Does it run a bootloader before running my code?
Does anyone have any idea what program execution might be stuck on prior to calling main()?
Thank you for your time.
Here is what I see when I halt the program:
Here is a portion of the map file that is generated:
TMS320C55x Linker PC v4.3.2
>> Linked Mon Oct 05 17:31:32 2009
OUTPUT FILE NAME: <USBKey_LED.out>
ENTRY POINT SYMBOL: "reset_isr" address: 0000ca6e
MEMORY CONFIGURATION
name origin length used unused attr fill
(bytes) (bytes) (bytes) (bytes)
VEC 00000100 00000100 00000000 00000100 RW X
DATA 00000200 00007e00 00002440 000059c0 RW X
PROG 00008000 00010000 0000aabb 00005545 R X
SECTION ALLOCATION MAP
(Addresses surrounded by []'s are displayed for convenience only!)
output attributes/
section page orgn(bytes) orgn(words) len(bytes) len(words) input sections
.data 0 [ 00000200 ] 00000100 * 00000000 UNINITIALIZED
.sysmem 0 [ 00000200 ] 00000100 * 00001000 UNINITIALIZED
[ 00000200 ] 00000100 * 00001000 --HOLE--
.cio 0 [ 00002200 ] 00001100 * 00000120 UNINITIALIZED
[ 00002200 ] 00001100 * 00000120 rts55h.lib : trgmsg.obj (.cio)
vectors 0 00002500 [ 00001280 ] 00000200 * NOLOAD SECTION
00002500 [ 00001280 ] 00000100 * cslVC5505.lib : vectors.obj (vectors)
00002600 [ 00001300 ] 00000100 * rts55h.lib : vectors.obj (vectors)
.text 0 00008000 [ 00004000 ] 00004f9b *
00008000 [ 00004000 ] 00001526 * rts55h.lib : _printfi.obj (.text)
00009526 [ 00004a93 ] 00000554 * cslVC5505.lib : csl_intc.obj (.text)
00009a7a [ 00004d3d ] 00000538 * rts55h.lib : trgdrv.obj (.text)
00009fb2 [ 00004fd9 ] 0000052a * : memory.obj (.text)
0000a4dc [ 0000526e ] 00000518 * : lowlev.obj (.text)
0000a9f4 [ 000054fa ] 00000367 * : divd.obj (.text)
0000ad5b [ 000056ad+] 00000338 * csl_led_demo.obj (.text)
0000b093 [ 00005849+] 00000337 * cslVC5505.lib : csl_gpt.obj (.text)
0000b3ca [ 000059e5 ] 000002b7 * : csl_pll.obj (.text)
0000b681 [ 00005b40+] 0000026c * rts55h.lib : fopen.obj (.text)
0000b8ed [ 00005c76+] 0000025c * : llmpy.obj (.text)
0000bb49 [ 00005da4+] 00000257 * : addd.obj (.text)
0000bda0 [ 00005ed0 ] 000001ea * : cmpd.obj (.text)
0000bf8a [ 00005fc5 ] 0000017b * : fputs.obj (.text)
0000c105 [ 00006082+] 0000014b * : mpyd.obj (.text)
0000c250 [ 00006128 ] 000000f3 * : setvbuf.obj (.text)
0000c343 [ 000061a1+] 000000da * : _io_perm.obj (.text)
0000c41d [ 0000620e+] 000000c8 * : frcmpyd_div.obj (.text)
0000c4e5 [ 00006272+] 000000be * : trgmsg.obj (.text:CIO_breakpoint)
0000c5a3 [ 000062d1+] 000000ba * : fflush.obj (.text)
0000c65d [ 0000632e+] 000000a2 * : fputc.obj (.text)
0000c6ff [ 0000637f+] 000000a0 * : divul.obj (.text)
0000c79f [ 000063cf+] 0000008c * cslVC5505.lib : csl_irqplug.obj (.text)
0000c82b [ 00006415+] 00000079 * rts55h.lib : ltoa.obj (.text)
0000c8a4 [ 00006452 ] 00000076 * : fclose.obj (.text)
0000c91a [ 0000648d ] 00000076 * : frcmpyd.obj (.text)
0000c990 [ 000064c8 ] 00000070 * : remul.obj (.text)
0000ca00 [ 00006500 ] 0000006e * : fixdli.obj (.text)
0000ca6e [ 00006537 ] 0000006d * cslVC5505.lib : vectors.obj (.text)
0000cadb [ 0000656d+] 0000006b * rts55h.lib : trgmsg.obj (.text)
0000cb46 [ 000065a3 ] 00000068 * : fseek.obj (.text)
0000cbae [ 000065d7 ] 00000067 * : fltlid.obj (.text)
0000cc15 [ 0000660a+] 00000059 * : atoi.obj (.text)
0000cc6e [ 00006637 ] 00000056 * : memcpy.obj (.text)
0000ccc4 [ 00006662 ] 0000004e * : printf.obj (.text)
0000cd12 [ 00006689 ] 0000004d * : autoinit.obj (.text)
0000cd5f [ 000066af+] 0000004b * : remli.obj (.text)
0000cdaa [ 000066d5 ] 00000049 * : args_main.obj (.text)
0000cdf3 [ 000066f9+] 00000048 * : divli.obj (.text)
0000ce3b [ 0000671d+] 0000003e * : exit.obj (.text)
0000ce79 [ 0000673c+] 00000034 * : boot.obj (.text)
0000cead [ 00006756+] 0000002a * : fixdi.obj (.text)
0000ced7 [ 0000676b+] 0000002a * : udiv.obj (.text)
0000cf01 [ 00006780+] 00000022 * : memccpy.obj (.text)
0000cf23 [ 00006791+] 0000001b * : isinf.obj (.text)
0000cf3e [ 0000679f ] 00000014 * : subd.obj (.text)
0000cf52 [ 000067a9 ] 00000013 * : lmpy.obj (.text)
0000cf65 [ 000067b2+] 00000012 * : _lock.obj (.text)
0000cf77 [ 000067bb+] 00000010 * : negd.obj (.text)
0000cf87 [ 000067c3+] 0000000a * : remove.obj (.text)
0000cf91 [ 000067c8+] 00000007 * : exit.obj (.text:CIO_breakpoint)
0000cf98 [ 000067cc ] 00000002 * : vectors.obj (.text)
0000cf9a [ 000067cd ] 00000001 * --HOLE-- [fill = 20]
.stack 0 [ 0000cf9c ] 000067ce * 00001800 UNINITIALIZED
[ 0000cf9c ] 000067ce * 00001800 --HOLE--
.sysstack
* 0 [ 0000ff9c ] 00007fce * 00001000 UNINITIALIZED
[ 0000ff9c ] 00007fce * 00001000 --HOLE--
.bss 0 [ 00011f9c ] 00008fce * 000002f8 UNINITIALIZED
[ 00011f9c ] 00008fce * 00000119 rts55h.lib : defs.obj (.bss)
[ 000121ce ] 000090e7 * 000000d0 : trgdrv.obj (.bss)
[ 0001236e ] 000091b7 * 00000001 : fopen.obj (.bss)
[ 00012370 ] 000091b8 * 00000084 cslVC5505.lib : csl_intc.obj (.bss)
[ 00012478 ] 0000923c * 00000071 rts55h.lib : lowlev.obj (.bss)
[ 0001255a ] 000092ad * 00000001 --HOLE--
[ 0001255c ] 000092ae * 00000007 csl_led_demo.obj (.bss)
[ 0001256a ] 000092b5 * 00000001 --HOLE--
[ 0001256c ] 000092b6 * 00000007 rts55h.lib : memory.obj (.bss)
[ 0001257a ] 000092bd * 00000001 --HOLE--
[ 0001257c ] 000092be * 00000004 : _lock.obj (.bss)
[ 00012584 ] 000092c2 * 00000004 : exit.obj (.bss)
.const 0 [ 0001258c ] 000092c6 * 00000216
[ 0001258c ] 000092c6 * 00000101 rts55h.lib : ctype.obj (.const:__ctypes_)
[ 0001278e ] 000093c7 * 00000001 --HOLE-- [fill = 0]
[ 00012790 ] 000093c8 * 000000d5 csl_led_demo.obj (.const:.string)
[ 0001293a ] 0000949d * 00000001 --HOLE-- [fill = 0]
[ 0001293c ] 0000949e * 00000024 rts55h.lib : _printfi.obj (.const:.string)
[ 00012984 ] 000094c2 * 0000000c : _printfi.obj (.const)
[ 0001299c ] 000094ce * 00000008 : divd.obj (.const:_initial_approx$1)
[ 000129ac ] 000094d6 * 00000002 : fputs.obj (.const:.string)
[ 000129b0 ] 000094d8 * 00000002 : divd.obj (.const)
[ 000129b4 ] 000094da * 00000002 : fltlid.obj (.const)
.cinit 0 [ 000129b8 ] 000094dc * 00000082
[ 000129b8 ] 000094dc * 0000002d rts55h.lib : lowlev.obj (.cinit)
[ 00012a12 ] 00009509 * 0000002a : defs.obj (.cinit)
[ 00012a66 ] 00009533 * 0000000e csl_led_demo.obj (.cinit)
[ 00012a82 ] 00009541 * 0000000a rts55h.lib : _lock.obj (.cinit)
[ 00012a96 ] 0000954b * 0000000a : exit.obj (.cinit)
[ 00012aaa ] 00009555 * 00000004 : fopen.obj (.cinit)
[ 00012ab2 ] 00009559 * 00000004 : memory.obj (.cinit)
[ 00012aba ] 0000955d * 00000001 --HOLE-- [fill = 0]
