how to show peripheral registers in CCS
I am new to CCS, and am using ezDSP5505. I was able to successfully build and run the LED program, but when I open the register window (View|Registers), I only see IODIR, IODATA, Rev, and Die registers; none others exist. The contents of these 4 peripheral registers are all 0s. What's wrong?
Ben
  • Ben,
    Do you not see the CPU registers?  Is it only Peripheral registers that you are commenting on?
    There needs to be a definition file developed that defines the peripheral registers.  TI ususally develops these files, but apparently this hasn't been done yet for the C5505.  I need to check with the team and find out what the plans are.
    For right now the easiest way to see the register contents is to use a memory window.  The addresses of all the registers are shown in the C5505 DSP System User's Guide located here: http://www-s.ti.com/sc/techlit/sprufp0.  Look in section 2.2 for the overview list.  Note that the registers are located in I/O space, so you need to select that in the Memory window before putting in the address.  The choices here are PROGRAM, DATA, I/O.  If you need details on the individual bit fields of the registers you need to look in the Peripheral User's Guide for the peripheral you are interested in.
    Regards.
  • Ben,
    I have an update on the Register View issue you raised.  The C5505 team is working on the XML files for displaying peripheral registers, but I don't have a delivery date yet.
    In the mean time, a colleague has developed a GEL script that will display registers in a watch window.  I am attaching for you to try out.
    Regards.
  • Thanks for your quick reply.
    Sorry I didn't make it very clear. I see all the CPU registers correctly, but there are only 4 peripheral registers shown; the contents of these 4 peripheral registers are always 0. So I think there's something wrong. I am using evaluation version of CSS Version: 4.0.0.16001.
    Ben
