Hi TI Team,
I am integrating opencv libs from ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/<libopencv_*> into my app folder and getting below errors below.
1. can i continue using opencv prebuilt libs from TI SDK/targetfs/usr/lib?? are these libs tested with any demo example within TI SDK. if yes this could ready ref for us. I've seen some OPENCV usecase in TIDL lib but not sure on this.
2. what header file inclusions(CLAGS/LDFLAGS/LDIRS/IDIRS etc) we need in concerto.mak to make proper linking and compiling to success??
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/gen3_sw/build/J7/A72/QNX/debug/libnext_gen_me_shared.so: warning: `sys_nerr' is deprecated; use `strerror' or `strerror_r' instead
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libc.so.5, needed by /home/gako/gen3_sw/qnx_build/qnx/sharedmemallocator/usr/aarch64/so.le.g/libsharedmemallocator_g.so, may conflict with libc.so.6
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/qnx710/target/qnx7/aarch64le/lib/libc.so.5: warning: the `getwd' function is dangerous and should not be used.
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/qnx710/target/qnx7/aarch64le/lib/libc.so.5: warning: the `gets' function is dangerous and should not be used.
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/qnx710/target/qnx7/aarch64le/lib/libc.so.5: warning: the use of `tmpnam' is dangerous, better use `mkstemp'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/qnx710/target/qnx7/aarch64le/lib/libc.so.5: warning: the use of `mktemp' is dangerous, better use `mkstemp' or `mkdtemp'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/qnx710/target/qnx7/aarch64le/lib/libc.so.5: warning: `sys_errlist' is deprecated; use `strerror' or `strerror_r' instead
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/qnx710/target/qnx7/aarch64le/lib/libc.so.5: warning: the use of `tempnam' is dangerous, better use `mkstemp'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libm.so.3, needed by /home/gako/gen3_sw/build/J7/A72/QNX/debug/libnext_gen_me_shared.so, may conflict with libm.so.6
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libdl.so.2, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libpthread.so.0, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libtbb.so.2, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libz.so.1, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libjpeg.so.62, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libwebp.so.7, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libglog.so.0, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_sfm.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libgstreamer-1.0.so.0, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libgobject-2.0.so.0, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libglib-2.0.so.0, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libgstapp-1.0.so.0, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libgstriff-1.0.so.0, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libgstpbutils-1.0.so.0, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libgphoto2.so.6, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: warning: libgphoto2_port.so.12, needed by /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so, not found (try using -rpath or -rpath-link)
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_object_ref'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_flann.so: undefined reference to `std::__cxx11::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_src_push_buffer'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_unref'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `pthread_join@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_caps_set_simple'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_uri_get_protocol'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::interface5::internal::task_base::destroy(tbb::task&)'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_abilities_list_get_abilities'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_set_abilities'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `pthread_create@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_message_parse_stream_status'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_type_check_instance_cast'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_context_unref'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_get_readonly'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_sample_get_caps'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_query_position'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_src_get_type'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::task::note_affinity(unsigned short)'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_structure_remove_field'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `pthread_getspecific@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_finish_decompress@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `dladdr@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_iterator_resync'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::interface7::internal::task_arena_base::internal_current_slot()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `WebPFree'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_make_from_uri'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_list_count'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_link'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_bus_have_pending'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `std::istream::seekg(std::fpos<__mbstate_t>)'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_sink_set_emit_signals'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_caps_from_string'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_count_children'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_result_as_string'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_sfm.so: undefined reference to `fLI::FLAGS_v'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_signal_connect_data'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_port_info_list_free@LIBGPHOTO2_5_0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_mini_object_unref'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::task_group_context::is_group_execution_cancelled() const'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_free'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_structure_get_int'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_sink_get_max_buffers'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_sink_set_max_buffers'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_parse_launch'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_sfm.so: undefined reference to `google::InitVLOG3__(int**, int*, char const*, int)'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `_gst_caps_type'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_abilities_list_free'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_set_defaults@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_sink_is_eos'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_destroy_compress@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_caps_fixate'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_factory_find'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::internal::allocate_continuation_proxy::allocate(unsigned long) const'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_pad_link'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_sink_set_caps'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_sample_get_buffer'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_bin_get_type'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_count_choices'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_mini_object_make_writable'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_structure_get_string'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_CreateDecompress@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `pthread_key_create@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_context_new'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_message_parse_state_changed'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_sink_get_type'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_gapi.so: undefined reference to `std::logic_error::logic_error(std::logic_error&&)'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_flann.so: undefined reference to `__floatunditf@GCC_4.2.0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_list_get_name'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_CreateCompress@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_version'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_port_info_list_get_info@LIBGPHOTO2_5_0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_resync_to_restart@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_bin_add_many'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_error_free'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_src_set_stream_type'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_context_set_status_func'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `typeinfo for tbb::task'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_structure_get_fraction'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_alloc_huff_table@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `sem_getvalue@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_port_info_list_new@LIBGPHOTO2_5_0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_bin_iterate_sources'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_iterator_next'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_iterator_free'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::task_group_context::reset()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_capture'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_object_get_type'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_pad_get_current_caps'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_get_state'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::interface7::internal::task_arena_base::internal_terminate()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `_gst_message_type'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_caps_can_intersect'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_structure_get_name'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_file_new'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_link_many'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_list_get_value'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_aruco.so: undefined reference to `_Unwind_Resume@GCC_3.0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_set_changed'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_stdio_src@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_ximgproc.so: undefined reference to `__mulsc3@GCC_4.0.0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_object_get'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_file_get_data_and_size'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_sfm.so: undefined reference to `google::LogMessage::LogMessage(char const*, int)'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_buffer_new_allocate'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_file_delete'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_std_error@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `pthread_key_delete@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_flann.so: undefined reference to `__extendsftf2@GCC_3.0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_get_choice'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `sem_init@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_get_type'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_buffer_unmap'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::internal::allocate_root_with_context_proxy::free(tbb::task&) const'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_riff_create_video_caps'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_uri_is_valid'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `sem_destroy@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `_gst_fraction_type'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_factory_make'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `sem_trywait@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::task_group_context::init()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_mini_object_is_writable'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_read_scanlines@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_query_duration'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_read_header@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_bin_iterate_elements'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_value_get_object'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_abilities_list_load'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_caps_new_simple'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_autodetect'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_pad_peer_query_caps'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_stdio_dest@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_encoding_video_profile_new'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_new'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_init'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_bus_pop'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_finish_compress@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_sink_pull_sample'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_value_unset'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_context_set_error_func'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_filename_to_uri'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_write_scanlines@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_start_compress@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_get_bus'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_set_value'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_abilities_list_new'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_caps_get_size'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::interface7::internal::task_arena_base::internal_initialize()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::internal::get_initial_auto_partitioner_divisor()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_sfm.so: undefined reference to `google::LogMessageFatal::~LogMessageFatal()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_init'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_start_decompress@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_encoding_container_profile_new'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `std::ostream::seekp(std::fpos<__mbstate_t>)'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_bus_timed_pop_filtered'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_unref'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_seek_simple'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_encoding_container_profile_add_profile'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `WebPEncodeBGRA'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_sfm.so: undefined reference to `google::LogMessage::~LogMessage()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_sfm.so: undefined reference to `google::kLogSiteUninitialized'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_calib3d.so: undefined reference to `__divdc3@GCC_4.0.0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_calib3d.so: undefined reference to `__muldc3@GCC_4.0.0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_port_info_list_lookup_path@LIBGPHOTO2_5_0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_set_quality@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_object_unref'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_sfm.so: undefined reference to `google::LogMessage::stream()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_type_check_instance_is_a'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_src_end_of_stream'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_port_info_list_load@LIBGPHOTO2_5_0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::task_group_context::~task_group_context()'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_get_config'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_set_port_info'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::internal::allocate_child_proxy::allocate(unsigned long) const'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `sem_wait@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `WebPDecodeBGRAInto'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_src_set_caps'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::interface7::internal::task_arena_base::internal_execute(tbb::interface7::internal::delegate_base&) const'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `WebPEncodeLosslessBGR'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_list_unref'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_get_child'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_exit'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_context_set_message_func'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `sem_post@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_get_id'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_file_get'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_debug_bin_to_dot_file'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_flann.so: undefined reference to `__divtf3@GCC_3.0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_file_unref'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_get_name'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_get_type'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `dlclose@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `WebPDecodeBGRInto'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_set_state'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `WebPEncodeLosslessBGRA'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_element_get_static_pad'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_strdup'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `WebPGetFeaturesInternal'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::internal::allocate_root_with_context_proxy::allocate(unsigned long) const'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_get_info'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_get_value'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_destroy_decompress@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `std::basic_streambuf<char, std::char_traits<char> >::seekpos(std::fpos<__mbstate_t>, std::_Ios_Openmode)'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `g_object_set'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_abilities_list_lookup_model'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_object_get_name'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_list_new'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_get_range'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_capture_preview'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_message_parse_error'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `dlopen@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `dlsym@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_is_missing_plugin_message'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_simple_progression@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_app_src_set_size'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_pipeline_new'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_camera_set_config'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_object_unref'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `tbb::interface7::internal::task_arena_base::internal_max_concurrency(tbb::interface7::task_arena const*)'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gp_widget_get_label'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_caps_get_structure'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_sfm.so: undefined reference to `google::LogMessageFatal::LogMessageFatal(char const*, int)'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_videoio.so: undefined reference to `gst_buffer_map'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_core.so: undefined reference to `pthread_setspecific@GLIBC_2.17'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `jpeg_calc_output_dimensions@LIBJPEG_6.2'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_flann.so: undefined reference to `__trunctfdf2@GCC_3.0'
/home/gako/qnx710/host/linux/x86_64/usr/bin/aarch64-unknown-nto-qnx7.1.0-ld: /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib/libopencv_imgcodecs.so: undefined reference to `WebPEncodeBGR'
collect2: error: ld returned 1 exit status
concerto/finale.mak:212: recipe for target '/home/gako/gen3_sw/build/J7/A72/QNX/debug/vx_ted_output.out' failed
make[1]: [/home/gako/gen3_sw/build/J7/A72/QNX/debug/vx_ted_output.out] Error 1 (ignored)
content of concerto.mak
ifeq ($(TARGET_CPU), $(filter $(TARGET_CPU), x86_64 A72))
#ifeq ($(TARGET_CPU), $(filter $(TARGET_CPU), A73))
include $(PRELUDE)
TARGET := vx_ted_output
TARGETTYPE := exe
CSOURCES := $(call all-c-files)
CPPSOURCES := $(call all-cpp-files)
# CPPFLAGS = $(shell pkg-config --cflags opencv)
# LDLIBS = $(shell pkg-config --libs opencv)
# INCLUDE_DIRS = -I/usr/include/opencv
ifeq ($(HOST_COMPILER),$(filter $(HOST_COMPILER),GCC GCC_LINARO GCC_WINDOWS GCC_LINUX GCC_SYSBIOS_ARM GCC_LINUX_ARM GCC_QNX_ARM))
# CFLAGS += -Wno-unused-function
# CFLAGS += -Wno-unused-variable
CFLAGS += -Wno-format-security
#CFLAGS += $(pkg-config opencv --cflags --libs)
CFLAGS += -I/usr/include/opencv
$(info $$CFLAGS is [${CFLAGS}])
CPPFLAGS += -I/usr/include/opencv
$(info $$CPPFLAGS is [${CPPFLAGS}])
endif
LDIRS += /usr/lib
LDFLAGS += -ldl -lm -pthread -lrt
$(info $$LDFLAGS is [${LDFLAGS}])
IDIRS := $(IMAGING_IDIRS)
IDIRS += $(NEXT_GEN_ME_KERNELS_IDIRS)
IDIRS += $(NEXT_GEN_ME_MODULES_IDIRS)
IDIRS += $(NEXT_GEN_ME_PATH)/src/apps/common
IDIRS += $(TIOVX_PATH)/conformance_tests
IDIRS+=$(NEXT_GEN_ME_PATH)/src/apps/mpu1_0/TED/_sharedutils
IDIRS+=$(NEXT_GEN_ME_PATH)/src/apps/mpu1_0/TED/kinematic_model
IDIRS+=$(NEXT_GEN_ME_PATH)/src/apps/mpu1_0/TED/TrailerEndLineCalc
IDIRS+=$(NEXT_GEN_ME_PATH)/src/apps/mpu1_0/TED/wheel_detector_g2
IDIRS+=$(NEXT_GEN_ME_PATH)/src/apps/mpu1_0/TED/FilterWDwithKMAngle
IDIRS+=$(NEXT_GEN_ME_PATH)/src/apps/mpu1_0/TED/WDTrajectory_Qua_Regression
IDIRS+=$(NEXT_GEN_ME_PATH)/src/apps/mpu1_0/TED/toolbox/vision/builtins/src/ocv/include
IDIRS+=$(NEXT_GEN_ME_PATH)/src/apps/mpu1_0/TED/toolbox/vision/builtins/src/ocvcg/opencv/include
IDIRS+=$(NEXT_GEN_ME_PATH)/src/apps/mpu1_0/TED/toolbox/vision/builtins/src/ocvcg/opencv/include/opencv2
include $(NEXT_GEN_ME_PATH)/src/apps/common/app_libs/libnext_gen_me_shared/concerto_a72_inc.mak
STATIC_LIBS := $(IMAGING_LIBS)
STATIC_LIBS += $(NEXT_GEN_ME_KERNELS_LIBS)
STATIC_LIBS += $(NEXT_GEN_ME_MODULES_LIBS)
# LDIRS += /usr/lib/x86_64-linux-gnu
LDIRS += /home/gako/ti-processor-sdk-rtos-j721e-evm-08_01_00_11/targetfs/usr/lib
$(info $$LDIRS is [${LDIRS}])
SYS_SHARED_LIBS += opencv_aruco \
opencv_bgsegm \
opencv_bioinspired \
opencv_calib3d \
opencv_ccalib \
opencv_core \
opencv_datasets \
opencv_dpm \
opencv_face \
opencv_features2d \
opencv_flann \
opencv_fuzzy \
opencv_gapi \
opencv_hfs \
opencv_highgui \
opencv_imgcodecs \
opencv_img_hash \
opencv_imgproc \
opencv_line_descriptor \
opencv_ml \
opencv_objdetect \
opencv_optflow \
opencv_phase_unwrapping \
opencv_photo \
opencv_plot \
opencv_quality \
opencv_reg \
opencv_rgbd \
opencv_saliency \
opencv_sfm \
opencv_shape \
opencv_stereo \
opencv_stitching \
opencv_structured_light \
opencv_superres \
opencv_surface_matching \
opencv_tracking \
opencv_videoio \
opencv_video \
opencv_videostab \
opencv_xfeatures2d \
opencv_ximgproc \
opencv_xobjdetect \
opencv_xphoto
#opencv_ts
# SYS_SHARED_LIBS += opencv_shape opencv_stitching opencv_superres \
# opencv_videostab opencv_aruco opencv_bgsegm opencv_bioinspired opencv_ccalib \
# opencv_datasets opencv_dpm opencv_face opencv_fuzzy opencv_line_descriptor \
# opencv_optflow opencv_video opencv_plot \
# opencv_reg opencv_saliency opencv_stereo opencv_structured_light \
# opencv_phase_unwrapping opencv_rgbd opencv_surface_matching \
# opencv_ximgproc opencv_calib3d opencv_features2d opencv_flann \
# opencv_xobjdetect opencv_objdetect opencv_ml opencv_xphoto opencv_highgui \
# opencv_videoio opencv_imgcodecs opencv_photo opencv_imgproc opencv_core
$(info $$SYS_SHARED_LIBS is [${SYS_SHARED_LIBS}])
# SYS_STATIC_LIBS += opencv_shape opencv_stitching opencv_superres \
# opencv_datasets opencv_dpm opencv_face opencv_freetype opencv_fuzzy \
# opencv_hdf opencv_line_descriptor opencv_optflow opencv_video opencv_plot \
# opencv_phase_unwrapping opencv_rgbd opencv_viz opencv_surface_matching \
# opencv_text opencv_ximgproc opencv_calib3d opencv_features2d opencv_flann \
# $(info $$SYS_STATIC_LIBS is [${SYS_STATIC_LIBS}])
#STATIC_LIBS += opencv_features2d
#STATIC_LIBS += kinematic_model
#STATIC_LIBS += _sharedutils
#STATIC_LIBS += TrailerEndLineCalc
#STATIC_LIBS += wheel_detector_g2
#STATIC_LIBS += WDTrajectory_Qua_Regression
#STATIC_LIBS += toolbox_ocv
include $(FINALE)
endif
