Part Number: TDA4VM
Hi e2e-team,
I am getting following error when I do the 'shutdown now' command. Please let me now the solution??
ERROR: System Off: operation not handled.
Setup: psdk8.1
Log,
root@j7-evm:/opt/vision_apps# shutdown now
Stopping Session c2 of user root.
[ OK ] Removed slice system-weston.slice.
[ OK ] Stopped target Multi-User System.
[ OK ] Stopped target Login Prompts.
[ OK ] Stopped target RPC Port Mapper.
[ OK ] Stopped target Timers.
[ OK ] Stopped Daily rotation of log files.
[ OK ] Stopped Daily Cleanup of Temporary Directories.
[ OK ] Stopped target Hardware activated USB gadget.
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping The Apache HTTP Server...
Stopping Job spooling tools...
Stopping Avahi mDNS/DNS-SD Stack...
Stopping Periodic Command Scheduler...
[ OK ] Stopped DEMO.
Stopping Docker Application Container Engine...
Stopping Getty on tty1...
Stopping irqbalance daemon...
Stopping Reboot and dump vmcore via kexec...
Stopping NFS status monitor for NFSv2/3 locking....
Stopping Telephony service...
Stopping Serial Getty on ttyS2...
Stopping Serial Getty on ttyS3...
Stopping Simple Network Ma…ent Protocol (SNMP) Daemon....
[ OK ] Stopped startwlan.
Stopping strongSwan IPsec …Ev2 daemon using ipsec.conf...
Stopping Load/Save Random Seed...
Stopping thermal-zone-init.service...
[ OK ] Stopped Job spooling tools.
[ OK ] Stopped Periodic Command Scheduler.
[ OK ] Stopped irqbalance daemon.
[ OK ] Stopped Telephony service.
[ OK ] Stopped Avahi mDNS/DNS-SD Stack.
[ OK ] Stopped NFS status monitor for NFSv2/3 locking..
[ OK ] Stopped Simple Network Man…ement Protocol (SNMP) Daemon..
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped Serial Getty on ttyS2.
[ OK ] Stopped Serial Getty on ttyS3.
[ OK ] Stopped strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
[ OK ] Stopped Reboot and dump vmcore via kexec.
[ OK ] Stopped Load/Save Random Seed.
[ OK ] Stopped thermal-zone-init.service.
[ OK ] Stopped Session c2 of user root.
[ OK ] Removed slice system-getty.slice.
[ OK ] Removed slice system-serial\x2dgetty.slice.
Stopping LSB: start and stop docker...
Stopping LSB: network benchmark...
Stopping Login Service...
Stopping User Manager for UID 0...
[ OK ] Stopped User Manager for UID 0.
[ OK ] Stopped LSB: start and stop docker.
[ OK ] Stopped LSB: network benchmark.
[ OK ] Stopped target System Time Synchronized.
[ OK ] Stopped target System Time Set.
Stopping telnetd.service...
Stopping User Runtime Directory /run/user/0...
[ OK ] Unmounted /run/user/0.
[ OK ] Stopped telnetd.service.
[ OK ] Stopped User Runtime Directory /run/user/0.
[ OK ] Removed slice User Slice of UID 0.
Stopping D-Bus System Message Bus...
Stopping Permit User Sessions...
Stopping weston.service...
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped Login Service.
[ OK ] Stopped Permit User Sessions.
[ OK ] Stopped weston.service.
Stopping rc.pvr.service...
[ OK ] Stopped Update weston ini …ge based on the platform name.
[ OK ] Stopped rc.pvr.service.
[ OK ] Stopped Docker Application Container Engine.
[ OK ] Stopped target Network is Online.
[ OK ] Stopped Wait for Network to be Configured.
[ OK ] Stopped The Apache HTTP Server.
[ OK ] Stopped target Network.
[ OK ] Stopped target Host and Network Name Lookups.
[ OK ] Stopped target Remote File Systems.
Stopping Network Name Resolution...
[ OK ] Stopped Network Name Resolution.
Stopping Network Service...
[ OK ] Stopped Network Service.
[ OK ] Stopped target Network (Pre).
[ OK ] Stopped IPv6 Packet Filtering Framework.
[ OK ] Stopped IPv4 Packet Filtering Framework.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Paths.
[ OK ] Stopped Dispatch Password …ts to Console Directory Watch.
[ OK ] Stopped Forward Password R…uests to Wall Directory Watch.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
[ OK ] Stopped target Sockets.
[ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Closed Docker Socket for the API.
[ OK ] Closed dropbear.socket.
[ OK ] Stopped target System Initialization.
Stopping Hardware RNG Entropy Gatherer Daemon...
[ OK ] Stopped Apply Kernel Variables.
[ OK ] Stopped Load Kernel Modules.
Stopping Network Time Synchronization...
[ OK ] Stopped Hardware RNG Entropy Gatherer Daemon.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Stopped Create Volatile Files and Directories.
[ OK ] Stopped target Local File Systems.
Unmounting /media/ram...
Unmounting /run/media/mmcblk0...
Unmounting /run/media/mmcblk1p1...
Unmounting Temporary Directory (/tmp)...
Unmounting /var/volatile...
[ OK ] Unmounted /media/ram.
[ OK ] Unmounted /run/media/mmcblk0.
[ OK ] Unmounted /run/media/mmcblk1p1.
[ OK ] Unmounted Temporary Directory (/tmp).
[ OK ] Unmounted /var/volatile.
[ OK ] Stopped target Swap.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped File System Check on /dev/mmcblk0.
[ OK ] Stopped File System Check on /dev/mmcblk1p1.
[ OK ] Removed slice system-systemd\x2dfsck.slice.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Reached target Shutdown.
[ OK ] Reached target Final Step.
[ OK ] Started Power-Off.
[ OK ] Reached target Power-Off.
[ 94.209408] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 94.240322] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 94.251184] systemd-journald[175]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 94.261057] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 94.271942] systemd-shutdown[1]: Unmounting file systems.
[ 94.278813] [1522]: Remounting '/' read-only in with options '(null)'.
[ 94.299638] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 94.306738] systemd-shutdown[1]: All filesystems unmounted.
[ 94.312319] systemd-shutdown[1]: Deactivating swaps.
[ 94.317405] systemd-shutdown[1]: All swaps deactivated.
[ 94.322629] systemd-shutdown[1]: Detaching loop devices.
[ 94.329556] systemd-shutdown[1]: All loop devices detached.
[ 94.335131] systemd-shutdown[1]: Detaching DM devices.
[ 94.340378] systemd-shutdown[1]: All DM devices detached.
[ 94.345769] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
[ 94.365823] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 94.372502] systemd-shutdown[1]: Powering off.
[ 94.410097] reboot: Power down
Thanks & Regards,
Vadivel
