DM6467_h264fhdvenc_Encode: Remote node creation FAILED (0x80008008)
Dvsdk  is 2_00_00_22
h264fhdvenc is  dm6467_h264fhdvenc_01_10_02_05
hdvicp is dm6467_hdvicp_1_01_020
my .cfg for DSPServer as following:
var Server = xdc.useModule('ti.sdo.ce.Server');
Server.threadAttrs.stackSize = 16384 ;
Server.threadAttrs.priority = Server.MINPRI ;
/* get various codec modules; i.e., implementation of codecs */
var H264ENC = xdc.useModule('unic.sdo.codecs.h264enc.ce.H264ENC') ;
var H264FHDVENC = xdc.useModule('unic.sdo.codecs.h264fhdvenc.ce.H264FHDVENC') ;
var JPEGENC = xdc.useModule('unic.sdo.codecs.jpegenc.ce.JPEGENC') ;
var YUVCONVERT = xdc.useModule('unic.sdo.codecs.yuvconvert.ce.YUVCONVERT');
var HDVICP = xdc.useModule('unic.sdo.codecs.hdvicp.HDVICP');
if (prog.build.cfgArgs.profile == "eval") {
    /* This server is for evaluation, so use the watermarked versions */
    print("Configuring server to use watermarked codecs...");
    H264ENC.alg.watermark = true;
    H264FHDVENC.alg.watermark = true;
    JPEGENC.alg.watermark = true;
    HDVICP.watermark = true;
else
  /* This server is for production, so use the actual versions */
    print("Configuring server to use original codecs...");
    H264ENC.alg.watermark = false ;
    H264FHDVENC.alg.watermark = false ;
    JPEGENC.alg.watermark = false ;
    HDVICP.watermark = false ;
H264ENC.alg.codeSection  = "DDR2" ;
H264FHDVENC.alg.codeSection  = "DDR2" ;
H264FHDVENC.alg.intMemSection = "IRAM" ;
JPEGENC.alg.codeSection  = "DDR2" ;
/* Switching off Outs Bufs Cache */
H264ENC.manageOutBufsCache = [ false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false ];
H264FHDVENC.manageOutBufsCache = [ false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false ];
JPEGENC.manageOutBufsCache = [ false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false ];
Server.algs = [
    {name: "h264enc", mod: H264ENC,groupId:0,threadAttrs: {
            stackMemId: 0, priority: Server.MINPRI + 1}
    {name: "h264fhdenc", mod: H264FHDVENC,groupId:0,threadAttrs: {
    {name: "jpegenc", mod: JPEGENC,groupId:0,threadAttrs: {
    {name: "yuvconvert", mod: YUVCONVERT,groupId:0,threadAttrs: {
 *  ======== DSKT2 and RMAN Configuration ========
 *  XDAIS Algorithm Memory and DMA allocation
    var DSKT2 = xdc.useModule('ti.sdo.fc.dskt2.DSKT2');
    DSKT2.DARAM0     = "IRAM";
    DSKT2.DARAM1     = "IRAM";
    DSKT2.DARAM2     = "IRAM";
    DSKT2.SARAM0     = "IRAM";
    DSKT2.SARAM1     = "IRAM";
    DSKT2.SARAM2     = "IRAM";
    DSKT2.ESDATA     = "DDRALGHEAP";
    DSKT2.IPROG      = "IRAM";
    DSKT2.EPROG      = "DDR2";
    DSKT2.DSKT2_HEAP = "DDR2";
    DSKT2.trace = false;
    DSKT2.debug = false;
    DSKT2.ALLOW_EXTERNAL_SCRATCH = false ;
    DSKT2.DARAM_SCRATCH_SIZES = [ 64 * 1024, 0, 0,0,0,0,0, /* ... */ 0 ] ;
    DSKT2.SARAM_SCRATCH_SIZES = [ 64 * 1024, 0, 0,0,0,0,0, /* ... */ 0 ] ;
    var RMAN = xdc.useModule('ti.sdo.fc.rman.RMAN');
    RMAN.useDSKT2 = true;
    RMAN.tableSize = 10;
    RMAN.semCreateFxn = "Sem_create";
    RMAN.semDeleteFxn = "Sem_delete";
    RMAN.semPendFxn = "Sem_pend";
    RMAN.semPostFxn = "Sem_post";
    RMAN.debug = false;
    RMAN.trace = false;
 *  ======== DMAN3 (DMA manager) configuration ========
var DMAN3 = xdc.useModule('ti.sdo.fc.dman3.DMAN3');
 DMAN3.heapInternal    = "L1DHEAP";       /* L1DHEAP is an internal segment */
 // DMAN3.heapInternal = "DDRALGHEAP";    /* DDRALGHEAP is an external segment */
 DMAN3.heapExternal    = "DDRALGHEAP";
 DMAN3.idma3Internal   = true ;
 //DMAN3.scratchAllocFxn = "DSKT2_allocScratch";
 //DMAN3.scratchFreeFxn  = "DSKT2_freeScratch";
 DMAN3.paRamBaseIndex     = 80;  // 1st EDMA3 PaRAM set available for DMAN3
 DMAN3.numQdmaChannels    = 8;   // number of device's QDMA channels to use
 DMAN3.qdmaChannels       = [0,1,2,3,4,5,6,7]; // choice of QDMA channels to use
 DMAN3.numPaRamEntries    = 48;  // number of PaRAM sets exclusively used by DMAN
 DMAN3.numPaRamGroup[0]   = 48;  // number of PaRAM sets for scratch group 0
 DMAN3.numTccGroup[0]     = 32;  // number of TCCs assigned to scratch group 0
 DMAN3.tccAllocationMaskL = 0;   // bit mask indicating which TCCs 0..31 to use
 DMAN3.tccAllocationMaskH = 0xffffffff; // assign all TCCs 32..63 for DMAN
    var EDMA3 = xdc.useModule('ti.sdo.fc.edma3.Settings');
    EDMA3.maxPaRams[0] = 384;
    EDMA3.maxTccs[0] = 24;
    EDMA3.maxEdmaChannels[0] = 24;
    EDMA3.maxQdmaChannels[0] = 0;
    EDMA3.trace = false;
    EDMA3.debug = false;
    var EDMA3CHAN = xdc.useModule('ti.sdo.fc.ires.edma3chan.EDMA3CHAN');
    EDMA3CHAN.debug = false;
    EDMA3CHAN.trace = false;
    var HDVICP =  xdc.useModule('ti.sdo.fc.ires.hdvicp.HDVICP');
    HDVICP.debug = false;
    HDVICP.trace = false;
    var HDINTC = xdc.useModule('ti.sdo.fc.hdintc.HDINTC');
    HDINTC.interruptVectorId_0 = 10;
    HDINTC.interruptVectorId_1 = 11;
    HDINTC.hdvicpInterruptEventNo_0 = 29;
    HDINTC.hdvicpInterruptEventNo_1 = 39;
    HDINTC.biosInterruptVectorId_0 = 7;
    HDINTC.biosInterruptVectorId_1 = 8;
    HDINTC.biosInterruptEventNo_0 = 30;
    HDINTC.biosInterruptEventNo_1 = 31;
When I create "h264fhdvenc" in Montavista(Linux), it always faled.
After CE_DEBUG=0, it always say "Remote node creation FAILED (0x80008008)" and "Algorithm_create> Assignment of alg resources through RMAN FAILED (0x7)". details as following:
@0,678,292us: [+4 T:0x4001fb20 S:0xbefaebac] OG - Global_init> This program was built with the following packages:
@0,678,848us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package gnu.targets.rts470MV (/usr/local/xdctools_3_10_03/packages/gnu/targets/rts470MV/) [1,0,0,0,1225517438755]
@0,679,314us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package unic.sdo.codecs.h264fhdvenc (/home/Phocus1855/ALG/packages/unic/sdo/codecs/h264fhdvenc/) [1,0,0,1305227643000]
@0,679,889us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package unic.sdo.codecs.jpegenc (/home/Phocus1855/ALG/packages/unic/sdo/codecs/jpegenc/) [1,0,0,1304714973000]
@0,680,357us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package unic.sdo.codecs.yuvconvert (/home/Phocus1855/ALG/packages/unic/sdo/codecs/yuvconvert/) [1,0,0,1304714978000]
@0,680,829us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.global (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
@0,681,297us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package dsplink.gpp (/home/unic/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/gpp/) [5,0,0,1239931267000]
@0,682,008us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.linuxutils.cmem (/home/unic/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/) [2,2,0,1240253001679]
@0,682,497us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.xdais.dm (/home/unic/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
@0,682,964us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.utils.trace (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
@0,683,438us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.utils.xdm (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
@0,683,911us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.xdais (/home/unic/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
@0,684,380us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.node (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
@0,684,850us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.fc.global (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
@0,685,323us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.fc.dman3 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
@0,685,794us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.fc.memutils (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
@0,686,462us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.fc.acpy3 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
@0,686,947us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package gnu.targets (/usr/local/xdctools_3_10_03/packages/gnu/targets/) [1,0,1,1225517427930]
@0,687,415us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.catalog.c470 (/usr/local/xdctools_3_10_03/packages/ti/catalog/c470/) [1,0,1,0,0]
@0,687,883us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.catalog.c6000 (/usr/local/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
@0,688,350us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.platforms.evmDM6467 (/usr/local/bios_5_33_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
@0,688,817us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.osal (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
@0,689,290us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.osal.linux (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/linux/) [2,0,1,1240276736840]
@0,689,852us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.ipc (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
@0,690,324us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.ipc.dsplink (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/) [2,0,1,1240276714152]
@0,690,991us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.alg (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
@0,691,472us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
@0,691,939us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.speech (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech/) [1,0,2,1240276762193]
@0,692,412us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.speech1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech1/) [1,0,1,1240276763928]
@0,692,885us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.audio (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio/) [1,0,2,1240276296374]
@0,693,352us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.audio1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
@0,693,822us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.video (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video/) [1,0,3,1240276930771]
@0,694,294us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.video1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
@0,694,811us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.video2 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
@0,695,343us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.image (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image/) [1,0,3,1240276700525]
@0,695,969us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.ce.image1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
@0,696,442us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package ti.sdo.dmai (/home/unic/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/) [1,0,0,1292320625000]
@0,696,911us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package unic.sdo.codecs.h264fhdvenc.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1305227644000]
@0,697,383us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package unic.sdo.codecs.jpegenc.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/jpegenc/ce/) [1,0,0,1304714976000]
@0,697,853us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package unic.sdo.codecs.yuvconvert.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/yuvconvert/ce/) [1,0,0,1304714981000]
@0,698,326us: [+4 T:0x4001fb20 S:0xbefaebac] OG -     package PhocusCamera_dm6467_config (/home/Phocus1855/PhocusCamera/linux/PhocusCamera_dm6467_config/) []
@0,698,815us: [+0 T:0x4001fb20 S:0xbefaebb4] OG - Global_atexit> enter (fxn=0x2a288)
@0,699,297us: [+0 T:0x4001fb20 S:0xbefaebb4] OG - Global_atexit> enter (fxn=0x296d4)
@0,699,972us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_alloc> Enter(0x18)
@0,700,671us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_alloc> return (0x5a110)
@0,701,396us: [+0 T:0x4001fb20 S:0xbefaeba4] OG - Global_atexit> enter (fxn=0x27604)
@0,701,920us: [+0 T:0x4001fb20 S:0xbefaeb7c] OM - Memory_alloc> Enter(0x18)
@0,702,393us: [+0 T:0x4001fb20 S:0xbefaeb7c] OM - Memory_alloc> return (0x5a160)
@0,702,858us: [+0 T:0x4001fb20 S:0xbefaeb9c] OG - Global_atexit> enter (fxn=0x264b0)
@0,703,372us: [+0 T:0x4001fb20 S:0xbefaeba4] OG - Global_atexit> enter (fxn=0x28d38)
@0,703,899us: [+0 T:0x4001fb20 S:0xbefaeb9c] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,704,358us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_alloc> Enter(0x14)
@0,704,828us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_alloc> return (0x5a1e0)
@0,705,284us: [+0 T:0x4001fb20 S:0xbefaeb9c] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x5a1e0]
@0,705,745us: [+0 T:0x4001fb20 S:0xbefaeb9c] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,706,201us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_alloc> Enter(0x14)
@0,706,668us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_alloc> return (0x5a1f8)
@0,707,128us: [+0 T:0x4001fb20 S:0xbefaeb9c] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x5a1f8]
@0,707,591us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_alloc> Enter(0x18)
@0,708,062us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_alloc> return (0x5a210)
@0,708,525us: [+0 T:0x4001fb20 S:0xbefaeb7c] OT - Thread_create> Enter (fxn=0x24c88, attrs=0x0)
@0,708,987us: [+0 T:0x4001fb20 S:0xbefaeb64] OM - Memory_alloc> Enter(0x64)
@0,709,726us: [+0 T:0x4001fb20 S:0xbefaeb64] OM - Memory_alloc> return (0x5a230)
@0,710,732us: [+0 T:0x4001fb20 S:0xbefaeb7c] OT - Thread_create> Exit (task=0x5a230)
@0,711,200us: [+0 T:0x4001fb20 S:0xbefaebb4] OG - Global_atexit> enter (fxn=0x24678)
@0,711,684us: [+0 T:0x4001fb20 S:0xbefaebb4] OG - Global_atexit> enter (fxn=0x269fc)
@0,712,247us: [+0 T:0x4001fb20 S:0xbefaeb9c] ti.sdo.ce.alg - ALG_init> Enter
@0,712,707us: [+0 T:0x4001fb20 S:0xbefaeb8c] OG - Global_atexit> enter (fxn=0x242c4)
@0,713,176us: [+0 T:0x4001fb20 S:0xbefaebbc] ti.sdo.ce.alg - ALG_init> Exit
@0,713,632us: [+0 T:0x4001fb20 S:0xbefaebb4] OG - Global_atexit> enter (fxn=0x236f0)
@0,714,122us: [+0 T:0x4001fb20 S:0xbefaeb8c] OM - Memory_alloc> Enter(0x18)
@0,714,595us: [+0 T:0x4001fb20 S:0xbefaeb8c] OM - Memory_alloc> return (0x5a410)
@0,715,055us: [+0 T:0x4001fb20 S:0xbefaebb4] OG - Global_atexit> enter (fxn=0x29228)
@0,715,579us: [+6 T:0x4001fb20 S:0xbefaebac] CE - Engine_init> CE debugging on (CE_DEBUG=0; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@0,716,051us: [+0 T:0x4001fb20 S:0xbefaeb9c] OG - Global_atexit> enter (fxn=0x20b84)
@0,716,521us: [+0 T:0x4001fb20 S:0xbefaeb7c] OM - Memory_alloc> Enter(0x18)
@0,716,994us: [+0 T:0x4001fb20 S:0xbefaeb7c] OM - Memory_alloc> return (0x5a450)
@0,717,458us: [+0 T:0x4001fb20 S:0xbefaeb7c] OM - Memory_alloc> Enter(0x18)
@0,717,929us: [+0 T:0x4001fb20 S:0xbefaeb7c] OM - Memory_alloc> return (0x5a470)
@0,718,392us: [+0 T:0x4001fb20 S:0xbefaeb7c] OM - Memory_alloc> Enter(0x18)
@0,719,055us: [+0 T:0x4001fb20 S:0xbefaeb7c] OM - Memory_alloc> return (0x5a490)
@0,719,669us: [+0 T:0x4001fb20 S:0xbefaebbc] CS - Server_init()
@0,720,127us: [+0 T:0x4001fb20 S:0xbefaebbc] CS - Server_init> Global_useLinkArbiter = 0
@0,720,591us: [+0 T:0x4001fb20 S:0xbefaebbc] OG - Global_atexit> enter (fxn=0x1ee64)
@0,721,128us: [+0 T:0x4001fb20 S:0xbefaeb6c] CE - Engine_open> Enter('encode', 0x0, 0xbefaebdc)
@0,721,597us: [+0 T:0x4001fb20 S:0xbefaeb54] OM - Memory_alloc> Enter(0x2c)
@0,722,069us: [+0 T:0x4001fb20 S:0xbefaeb54] OM - Memory_alloc> return (0x5a4e0)
@0,722,535us: [+0 T:0x4001fb20 S:0xbefaeb6c] CE - rserverOpen('PhocusALG.x64P'), count = 0
@0,723,037us: [+0 T:0x4001fb20 S:0xbefaeb34] OP - Processor_create> Enter(imageName='PhocusALG.x64P', linkCfg='(null)', attrs=0xbefaebc0)
@0,723,717us: [+0 T:0x4001fb20 S:0xbefaeb1c] OM - Memory_alloc> Enter(0x24)
@0,724,188us: [+0 T:0x4001fb20 S:0xbefaeb1c] OM - Memory_alloc> return (0x5a510)
@0,724,649us: [+0 T:0x4001fb20 S:0xbefaeb14] OP - doCmd> Enter (cmdId=1, proc=0x5a510)
@0,725,115us: [+0 T:0x4001fb20 S:0xbefaeb04] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5a1e0]
@0,725,656us: [+0 T:0x4001fb20 S:0xbefaeb14] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5a1e0]
@0,726,124us: [+0 T:0x4001fb20 S:0xbefaeaf4] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5a1f8] timeout[0xffffffff]
@0,726,740us: [+1 T:0x416ed490 S:0x416ecd74] OP - daemon> thread created.
@0,727,210us: [+0 T:0x416ed490 S:0x416ecd74] OP - getCmd_d> Enter (proc=0x416ecde8)
@0,727,877us: [+0 T:0x416ed490 S:0x416ecd54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5a1e0] timeout[0xffffffff]
@0,728,364us: [+0 T:0x416ed490 S:0x416ecd54] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5a1e0] status[0]
@0,728,841us: [+0 T:0x416ed490 S:0x416ecd74] OP - getCmd_d> Exit (result=1)
@0,729,310us: [+0 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Enter(proc=0x5a510)
@0,729,854us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Initializing DSP PROC...
@0,730,332us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'PhocusALG.x64P']
@0,730,820us: [+0 T:0x416ed490 S:0x416ecd5c] OM - Memory_alloc> Enter(0xe0)
@0,731,302us: [+0 T:0x416ed490 S:0x416ecd5c] OM - Memory_alloc> return (0x5a538)
@0,731,831us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1, syncd=0
@0,732,342us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1, syncd=0
@0,732,852us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x8ff00000, sizeInBytes=0x80, shared=1, syncd=0
@0,733,359us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x8ba00000, sizeInBytes=0x4000000, shared=0, syncd=0
@0,733,923us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> DODSPCTRL was=1; now=0
@0,737,221us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Attaching to DSP PROC...
@0,742,709us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Opening MSGQ pool...
@0,743,561us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Loading PhocusALG.x64P on DSP (1 args)...
@0,816,716us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Starting DSP PROC...
@0,863,531us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Opening remote transport...
@0,864,655us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> return (1)
@0,865,130us: [+0 T:0x416ed490 S:0x416ecd64] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5a1f8]
@0,865,644us: [+0 T:0x4001fb20 S:0xbefaeaf4] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5a1f8] status[0]
@0,866,112us: [+0 T:0x4001fb20 S:0xbefaeb14] OP - doCmd> Exit (result=1)
@0,866,571us: [+0 T:0x4001fb20 S:0xbefaeb34] OP - Processor_create> return (0x5a510)
@0,867,031us: [+0 T:0x4001fb20 S:0xbefaeb6c] CE - rserverOpen('PhocusALG.x64P'): 0x58cb0 done.
@0,867,504us: [+0 T:0x4001fb20 S:0xbefaeb54] OM - Memory_alloc> Enter(0x24)
@0,867,976us: [+0 T:0x4001fb20 S:0xbefaeb54] OM - Memory_alloc> return (0x5a770)
@0,868,523us: [+0 T:0x4001fb20 S:0xbefaeb44] OC - Comm_create> Enter(queueName='encode_288_0', queue=0x5a4f0, attrs=0x0)
@0,868,990us: [+0 T:0x4001fb20 S:0xbefaeb2c] OM - Memory_alloc> Enter(0x4)
@0,869,547us: [+0 T:0x4001fb20 S:0xbefaeb2c] OM - Memory_alloc> return (0x5a798)
@0,870,454us: [+0 T:0x4001fb20 S:0xbefaeb44] OC - Comm_create> return (0x5a798)
@0,870,930us: [+0 T:0x4001fb20 S:0xbefaeb4c] OM - Memory_free> Enter(0x5a770, 0x24)
@0,871,453us: [+0 T:0x4001fb20 S:0xbefaeb4c] OM - Memory_free> return (0x1)
@0,871,918us: [+0 T:0x4001fb20 S:0xbefaeb4c] OC - Comm_alloc> Enter(poolId=0x0, msg=0x5a4fc, size=576)
@0,872,422us: [+0 T:0x4001fb20 S:0xbefaeb4c] OC - Comm_alloc> msg=0x41efd880, returning (0)
@0,872,884us: [+0 T:0x4001fb20 S:0xbefaeb34] OC - Comm_locate> Enter(queueName='rmsq', queue=0x5a4ec)
@0,873,666us: [+0 T:0x4001fb20 S:0xbefaeb34] OC - Comm_locate> return (0)
@0,874,131us: [+0 T:0x4001fb20 S:0xbefaeb6c] CE - checkServer(0x5a4e0)
@0,874,611us: [+0 T:0x4001fb20 S:0xbefaeb3c] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@0,875,131us: [+0 T:0x4001fb20 S:0xbefaeb3c] OC - Comm_put> return (0)
@0,875,695us: [+0 T:0x4001fb20 S:0xbefaeb34] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaebd8, timeout=-1)
@0,876,200us: [+0 T:0x4001fb20 S:0xbefaeb34] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@0,876,670us: [+0 T:0x4001fb20 S:0xbefaeb6c] CE - rmsInit> RMS initialized(0x5a4e0); CE_DEBUG on, setting DSP trace mask to *+01234567,GT_prefix=12345,GT_time=3
@0,877,151us: [+0 T:0x4001fb20 S:0xbefaeb44] CE - Engine_setTrace> Enter(engine=0x5a4e0, mask='*+01234567,GT_prefix=12345,GT_time=3')
@0,877,645us: [+1 T:0x4001fb20 S:0xbefaeb44] CE - Engine_setTrace> Requesting DSP set trace ...
@0,878,105us: [+0 T:0x4001fb20 S:0xbefaeb14] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@0,878,820us: [+0 T:0x4001fb20 S:0xbefaeb14] OC - Comm_put> return (0)
@0,879,292us: [+0 T:0x4001fb20 S:0xbefaeb0c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaeb8c, timeout=-1)
@0,879,884us: [+0 T:0x416ed490 S:0x416ecd74] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5a1f8]
@0,880,553us: [+0 T:0x4001fb20 S:0xbefaeb0c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@0,881,030us: [+0 T:0x4001fb20 S:0xbefaeb44] CE - Engine_setTrace> return(0)
@0,881,512us: [+0 T:0x4001fb20 S:0xbefaead4] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@0,882,028us: [+0 T:0x4001fb20 S:0xbefaead4] OC - Comm_put> return (0)
@0,882,606us: [+0 T:0x4001fb20 S:0xbefaeacc] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaeb6c, timeout=-1)
@0,883,109us: [+0 T:0x4001fb20 S:0xbefaeacc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @0,043,729tk: [+0 T:0x8ba00784 S:0x8ba046fc] OG - Global_setSpecialTrace> enter(mask='*+01234567,GT_prefix=12345,GT_time=3')
[DSP] @0,043,824tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG - Global_setSpecialTrace> This program was built with the following packages:
[DSP] @0,043,886tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.targets.rts6000 (/usr/local/xdctools_3_10_03/packages/ti/targets/rts6000/) [1,0,0,0,1225517497925]
[DSP] @0,043,962tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.h264fhdvenc (/home/Phocus1855/ALG/packages/unic/sdo/codecs/h264fhdvenc/) [1,0,0,1305227643000]
[DSP] @0,044,042tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.jpegenc (/home/Phocus1855/ALG/packages/unic/sdo/codecs/jpegenc/) [1,0,0,1304714973000]
[DSP] @0,044,119tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.yuvconvert (/home/Phocus1855/ALG/packages/unic/sdo/codecs/yuvconvert/) [1,0,0,1304714978000]
[DSP] @0,044,197tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.hdvicp (/home/Phocus1855/ALG/packages/unic/sdo/codecs/hdvicp/) [1,0,0,1305227644000]
[DSP] @0,044,273tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.global (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
[DSP] @0,044,358tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.dman3 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
[DSP] @0,044,442tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.ires.hdvicp (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/hdvicp/) [1,0,1,1240266763264]
[DSP] @0,044,531tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.rtdx (/usr/local/bios_5_33_03/packages/ti/rtdx/) [2,0,0,4,1219531643983]
[DSP] @0,044,597tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.psl (/usr/local/bios_5_33_03/packages/ti/psl/) [5,0,0,0,0]
[DSP] @0,044,665tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.bios (/usr/local/bios_5_33_03/packages/ti/bios/) [5,2,5,6,1227035764854]
[DSP] @0,044,732tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.dskt2 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dskt2/) [1,0,4,1240266678055]
[DSP] @0,044,816tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.hdintc (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/hdintc/) [1,0,4,1240266707594]
[DSP] @0,044,901tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.memutils (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
[DSP] @0,044,987tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.edma3.rm (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/fctools/packages/ti/sdo/edma3/rm/) [1,3,4,1225865844769]
[DSP] @0,045,074tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.ires.nullresource (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/nullresource/) [1,0,0,1240266782634]
[DSP] @0,045,166tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.rman (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/rman/) [2,0,0,1240266813533]
[DSP] @0,045,250tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.edma3 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/edma3/) [2,0,0,1240266681138]
[DSP] @0,045,334tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.ires.edma3chan (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/edma3chan/) [1,0,0,1240266737833]
[DSP] @0,045,424tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.global (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
[DSP] @0,045,506tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.xdais.dm (/home/unic/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
[DSP] @0,045,581tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.xdais (/home/unic/dvsdk_2_00_00_22/xd@0,896,929us: [+0 T:0x4001fb20 S:0xbefaead4] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@0,897,460us: [+0 T:0x4001fb20 S:0xbefaead4] OC - Comm_put> return (0)
@0,898,032us: [+0 T:0x4001fb20 S:0xbefaeacc] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaeb6c, timeout=-1)
@0,898,537us: [+0 T:0x4001fb20 S:0xbefaeacc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @0,045,653tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.node (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
[DSP] @0,045,733tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.ipc.dsplink.dsp (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2,0,1,1240276720026]
[DSP] @0,045,821tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.utils.trace (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
[DSP] @0,045,907tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.utils.xdm (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
[DSP] @0,045,991tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.acpy3 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
[DSP] @0,046,075tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package dsplink.dsp (/home/unic/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/dsp/) [1,4,0,1239931280000]
[DSP] @0,046,155tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.bios.utils (/home/unic/dvsdk_2_00_00_22/biosutils_1_01_00/packages/ti/bios/utils/) [2,0,1,0,0]
[DSP] @0,046,229tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.catalog.c6000 (/usr/local/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
[DSP] @0,046,300tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.platforms.evmDM6467 (/usr/local/bios_5_33_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
[DSP] @0,046,373tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.osal (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
[DSP] @0,046,454tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.osal.bios (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/bios/) [2,0,1,1240276734107]
[DSP] @0,046,537tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.ipc (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
[DSP] @0,046,617tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.ipc.bios (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/bios/) [2,0,1,1240276705217]
[DSP] @0,046,700tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.alg (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
[DSP] @0,046,780tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
[DSP] @0,046,856tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.bioslog (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
[DSP] @0,046,939tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.video1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
[DSP] @0,047,023tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.h264fhdvenc.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1305227644000]
[DSP] @0,047,105tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.image1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
[DSP] @0,047,186tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.jpegenc.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/jpegenc/ce/) [1,0,0,1304714976000]
[DSP] @0,047,265tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.image (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image/) [1,0,3,1240276700525]
[DSP] @0,047,346tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.yuvconvert.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/yuvconvert/ce/) [1,0,0,1304714981000]
[DSP] @0,047,427tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.servers.encode (/home/Phocus1855/ALG/packag@0,912,288us: [+0 T:0x4001fb20 S:0xbefaead4] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@0,912,833us: [+0 T:0x4001fb20 S:0xbefaead4] OC - Comm_put> return (0)
@0,913,406us: [+0 T:0x4001fb20 S:0xbefaeacc] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaeb6c, timeout=-1)
@0,913,909us: [+0 T:0x4001fb20 S:0xbefaeacc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
es/unic/sdo/servers/encode/) []
[DSP] @0,047,497tk: [+0 T:0x8ba00784 S:0x8ba046fc] OG - Global_setSpecialTrace> return
[DSP] @0,052,838tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @0,052,896tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
[DSP] @0,096,776tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @0,096,833tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
[DSP] @0,140,555tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @0,140,617tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
@0,917,918us: [+0 T:0x4001fb20 S:0xbefaeb04] CE - Engine_fwriteTrace> returning count [9056]
@0,918,387us: [+0 T:0x4001fb20 S:0xbefaeb6c] CE - Engine_open> return(369888)
@0,918,849us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> Enter(size=10027008, align=-1, cached=FALSE, heap=FALSE)
@0,919,971us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_alloc(10027008) = 0x41f6e000.
@0,920,618us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_getPhys(0x41f6e000) = 0x8b070000.
@0,921,082us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> Enter(virtAddr=0x41f6e000, size=10027008, physAddr=0x8b070000)
@0,921,557us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> creating new contigBuf object
@0,922,019us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> Enter(0x10)
@0,922,491us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> return (0x5a7a8)
@0,922,951us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> returning: cb->phys=0x8b070000, cb->size=10027008, cb->virt=0x41f6e000
@0,923,431us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> return (0x41f6e000)
@0,987,321us: [+0 T:0x4001fb20 S:0xbefaeb94] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x41f6e000, size=10027008)
@0,987,801us: [+1 T:0x4001fb20 S:0xbefaeb94] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x41f6e000, size=10027008)
@0,988,272us: [+1 T:0x4001fb20 S:0xbefaeb94] OM - Memory__getPhysicalAddress> found in cb(Sc=0x41f6e000, Ec=0x428fe000, Ss=0x41f6e000, Es=0x428fe000, PSc=0x8b070000)
@0,988,754us: [+1 T:0x4001fb20 S:0xbefaeb94] OM - Memory__getPhysicalAddress> returning physAddr=0x8b070000
@0,989,219us: [+0 T:0x4001fb20 S:0xbefaeb94] OM - Memory_getBufferPhysicalAddress> return (0x8b070000)
@0,989,810us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> Enter(size=10027008, align=-1, cached=FALSE, heap=FALSE)
@0,990,969us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_alloc(10027008) = 0x428fe000.
@0,991,465us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_getPhys(0x428fe000) = 0x8a6e0000.
@0,991,932us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> Enter(virtAddr=0x428fe000, size=10027008, physAddr=0x8a6e0000)
@0,992,410us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> creating new contigBuf object
@0,992,870us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> Enter(0x10)
@0,993,341us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> return (0x5a7c0)
@0,993,802us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> returning: cb->phys=0x8a6e0000, cb->size=10027008, cb->virt=0x428fe000
@0,994,279us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> return (0x428fe000)
@1,058,623us: [+0 T:0x4001fb20 S:0xbefaeb94] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x428fe000, size=10027008)
@1,059,117us: [+1 T:0x4001fb20 S:0xbefaeb94] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x428fe000, size=10027008)
@1,059,659us: [+1 T:0x4001fb20 S:0xbefaeb94] OM - Memory__getPhysicalAddress> found in cb(Sc=0x428fe000, Ec=0x4328e000, Ss=0x428fe000, Es=0x4328e000, PSc=0x8a6e0000)
@1,060,142us: [+1 T:0x4001fb20 S:0xbefaeb94] OM - Memory__getPhysicalAddress> returning physAddr=0x8a6e0000
@1,060,610us: [+0 T:0x4001fb20 S:0xbefaeb94] OM - Memory_getBufferPhysicalAddress> return (0x8a6e0000)
@1,061,082us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> Enter(size=10027008, align=-1, cached=FALSE, heap=FALSE)
@1,062,078us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_alloc(10027008) = 0x4328e000.
@1,062,575us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_getPhys(0x4328e000) = 0x89d50000.
@1,063,046us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> Enter(virtAddr=0x4328e000, size=10027008, physAddr=0x89d50000)
@1,063,526us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> creating new contigBuf object
@1,063,988us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> Enter(0x10)
@1,064,461us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> return (0x5a7d8)
@1,064,922us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> returning: cb->phys=0x89d50000, cb->size=10027008, cb->virt=0x4328e000
@1,065,653us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> return (0x4328e000)
@1,129,579us: [+0 T:0x4001fb20 S:0xbefaeb94] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x4328e000, size=10027008)
@1,130,062us: [+1 T:0x4001fb20 S:0xbefaeb94] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x4328e000, size=10027008)
@1,130,538us: [+1 T:0x4001fb20 S:0xbefaeb94] OM - Memory__getPhysicalAddress> found in cb(Sc=0x4328e000, Ec=0x43c1e000, Ss=0x4328e000, Es=0x43c1e000, PSc=0x89d50000)
@1,131,020us: [+1 T:0x4001fb20 S:0xbefaeb94] OM - Memory__getPhysicalAddress> returning physAddr=0x89d50000
@1,131,489us: [+0 T:0x4001fb20 S:0xbefaeb94] OM - Memory_getBufferPhysicalAddress> return (0x89d50000)
@1,131,959us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> Enter(size=10027008, align=-1, cached=FALSE, heap=FALSE)
@1,132,944us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_alloc(10027008) = 0x43c1e000.
@1,133,439us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_getPhys(0x43c1e000) = 0x893c0000.
@1,133,905us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> Enter(virtAddr=0x43c1e000, size=10027008, physAddr=0x893c0000)
@1,134,379us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> creating new contigBuf object
@1,134,839us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> Enter(0x10)
@1,135,312us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> return (0x5a7f0)
@1,135,817us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> returning: cb->phys=0x893c0000, cb->size=10027008, cb->virt=0x43c1e000
@1,136,457us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> return (0x43c1e000)
@1,200,405us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> Enter(size=2048, align=-1, cached=FALSE, heap=FALSE)
@1,200,972us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_alloc(2048) = 0x445ae000.
@1,201,461us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_getPhys(0x445ae000) = 0x88db6000.
@1,201,931us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> Enter(virtAddr=0x445ae000, size=2048, physAddr=0x88db6000)
@1,202,406us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> creating new contigBuf object
@1,202,866us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> Enter(0x10)
@1,203,338us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> return (0x5a808)
@1,203,796us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> returning: cb->phys=0x88db6000, cb->size=2048, cb->virt=0x445ae000
@1,204,272us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> return (0x445ae000)
@1,204,823us: [+0 T:0x4001fb20 S:0xbefaeba4] ti.sdo.ce.image1.IMGENC1 - IMGENC1_create> Enter (engine=0x5a4e0, name='jpegenc', params=0x58078)
@1,205,323us: [+0 T:0x4001fb20 S:0xbefaeb74] CV - VISA_create(0x5a4e0, 'jpegenc', 0x58078, 0x700, 'ti.sdo.ce.image1.IIMGENC1')
@1,205,800us: [+0 T:0x4001fb20 S:0xbefaea74] CV - VISA_create2(0x5a4e0, 'jpegenc', 0x58078, 0x24, 0x700, 'ti.sdo.ce.image1.IIMGENC1')
@1,206,295us: [+0 T:0x4001fb20 S:0xbefaea5c] OM - Memory_alloc> Enter(0x30)
@1,207,004us: [+0 T:0x4001fb20 S:0xbefaea5c] OM - Memory_alloc> return (0x5a870)
@1,207,480us: [+0 T:0x4001fb20 S:0xbefae9fc] CE - Engine_createNode(0x5a4e0, 'jpegenc', 700, 0x58078, 0x24, 0xbefaeb6c)
@1,207,957us: [+0 T:0x4001fb20 S:0xbefae9fc] CE - Engine> allocNode Enter(engine=0x5a4e0, impId='jpegenc')
@1,208,422us: [+0 T:0x4001fb20 S:0xbefae9e4] OM - Memory_alloc> Enter(0x20)
@1,208,893us: [+0 T:0x4001fb20 S:0xbefae9e4] OM - Memory_alloc> return (0x5a770)
@1,209,447us: [+0 T:0x4001fb20 S:0xbefae9fc] CE - Engine> allocNode(). Calling Comm_create(gppfromnode_288_1, 0x5a778, NULL)
@1,209,911us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_create> Enter(queueName='gppfromnode_288_1', queue=0x5a778, attrs=0x0)
@1,210,387us: [+0 T:0x4001fb20 S:0xbefae9bc] OM - Memory_alloc> Enter(0x4)
@1,210,861us: [+0 T:0x4001fb20 S:0xbefae9bc] OM - Memory_alloc> return (0x5a8a8)
@1,211,579us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_create> return (0x5a8a8)
@1,212,053us: [+0 T:0x4001fb20 S:0xbefae9dc] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,212,573us: [+0 T:0x4001fb20 S:0xbefae9dc] OC - Comm_put> return (0)
@1,213,041us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaea84, timeout=-1)
@1,213,658us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@1,214,128us: [+0 T:0x4001fb20 S:0xbefae9dc] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,214,648us: [+0 T:0x4001fb20 S:0xbefae9dc] OC - Comm_put> return (0)
@1,215,417us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaea84, timeout=-1)
@1,215,936us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@1,216,400us: [+4 T:0x4001fb20 S:0xbefae9fc] CE - Engine_createNode> created node(stdIn=0x2, stdOut=0x10001, msgq=0x5a8a8, algName='jpegenc', rmsNode=0x8fa8ec80, algHandle=0x8fa8ed68)
@1,216,907us: [+0 T:0x4001fb20 S:0xbefae964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,217,424us: [+0 T:0x4001fb20 S:0xbefae964] OC - Comm_put> return (0)
@1,217,995us: [+0 T:0x4001fb20 S:0xbefae95c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefae9fc, timeout=-1)
@1,218,501us: [+0 T:0x4001fb20 S:0xbefae95c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @0,994,111tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 0
[DSP] @0,994,176tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> Enter(size=0x18)
[DSP] @0,994,229tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> return (0x8fa8ec80)
[DSP] @0,994,281tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> Enter(size=0xa)
[DSP] @0,994,328tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> return (0x8fa8ec98)
[DSP] @0,994,387tk: [+0 T:0x8ba00784 S:0x8ba045fc] OM - Memory_alloc> Enter(size=0x20)
[DSP] @0,994,438tk: [+0 T:0x8ba00784 S:0x8ba045fc] OM - Memory_alloc> return (0x8fa8eca8)
[DSP] @0,994,489tk: [+0 T:0x8ba00784 S:0x8ba045cc] OM - Memory_alloc> Enter(size=0x24)
[DSP] @0,994,537tk: [+0 T:0x8ba00784 S:0x8ba045cc] OM - Memory_alloc> return (0x8fa8ecc8)
[DSP] @0,994,615tk: [+0 T:0x8ba00784 S:0x8ba045e4] ti.sdo.ce.image1.IMGENC1 - IMGENC1_create> Enter (engine=0x0, name='jpegenc', params=0x8fe038c0)
[DSP] @0,994,695tk: [+0 T:0x8ba00784 S:0x8ba045ac] CV - VISA_create(0x0, 'jpegenc', 0x8fe038c0, 0x700, 'ti.sdo.ce.image1.IIMGENC1')
[DSP] @0,994,767tk: [+0 T:0x8ba00784 S:0x8ba0449c] CV - VISA_create2(0x0, 'jpegenc', 0x8fe038c0, 0x24, 0x700, 'ti.sdo.ce.image1.IIMGENC1')
[DSP] @0,994,850tk: [+0 T:0x8ba00784 S:0x8ba04434] CE - Engine_open> Enter('local', 0x8ba04484, 0x8fe038c0)
[DSP] @0,994,915tk: [+0 T:0x8ba00784 S:0x8ba04414] OM - Memory_alloc> Enter(size=0x2c)
[DSP] @0,994,964tk: [+0 T:0x8ba00784 S:0x8ba04414] OM - Memory_alloc> return (0x8fa8ed38)
[DSP] @0,995,021tk: [+0 T:0x8ba00784 S:0x8ba04434] CE - Engine_open> return(-1884754632)
[DSP] @0,995,084tk: [+0 T:0x8ba00784 S:0x8ba0447c] OM - Memory_alloc> Enter(size=0x30)
[DSP] @0,995,133tk: [+0 T:0x8ba00784 S:0x8ba0447c] OM - Memory_alloc> return (0x8fa8ed68)
[DSP] @0,995,187tk: [+0 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fa48dc4, idma3Fxns=0x0, iresFxns=0x0, params=0x8fe038c0, attrs=0x8ba04598)
[DSP] @0,995,281tk: [+0 T:0x8ba00784 S:0x8ba04434] OM - Memory_alloc> Enter(size=0x10)
[DSP] @0,995,329tk: [+0 T:0x8ba00784 S:0x8ba04434] OM - Memory_alloc> return (0x8fa8ed98)
[DSP] @0,995,657tk: [+0 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x8fa8ed98)
[DSP] @0,995,722tk: [+5 T:0x8ba00784 S:0x8ba0449c] CV - VISA_create> local codec created (name='jpegenc', handle=0x8fa8ed98)
[DSP] @0,995,787tk: [+0 T:0x8ba00784 S:0x8ba045e4] ti.sdo.ce.image1.IMGENC1 - IMGENC_create> return (0x8fa8ed68)
[DSP] @0,995,847tk: [+4 T:0x8ba00784 S:0x8ba045a4] OT - Thread_create > name: "jpegenc#0", pri:  -1, stack size:  17192, stack seg: 0
[DSP] @1,000,029tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 1
[DSP] @1,007,930tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @1,007,992tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
@1,232,452us: [+0 T:0x4001fb20 S:0xbefae994] CE - Engine_fwriteTrace> returning count [2916]
@1,232,922us: [+2 T:0x4001fb20 S:0xbefae9fc] CE - Engine_createNode> Returning 0x5a770
@1,233,390us: [+0 T:0x4001fb20 S:0xbefaea5c] OM - Memory_alloc> Enter(0x4)
@1,233,861us: [+0 T:0x4001fb20 S:0xbefaea5c] OM - Memory_alloc> return (0x5a8b8)
@1,234,324us: [+0 T:0x4001fb20 S:0xbefaea54] OC - Comm_alloc> Enter(poolId=0x0, msg=0x5a8b8, size=700)
@1,234,829us: [+0 T:0x4001fb20 S:0xbefaea54] OC - Comm_alloc> msg=0x41efe880, returning (0)
@1,235,311us: [+5 T:0x4001fb20 S:0xbefaea74] CV - VISA_create> remote codec created (name='jpegenc', localQueueID=0x10001, remoteQueueID=0x0002)
@1,235,792us: [+0 T:0x4001fb20 S:0xbefaeba4] ti.sdo.ce.image1.IMGENC1 - IMGENC_create> return (0x5a870)
500W
@1,236,809us: [+0 T:0x4001fb20 S:0xbefaeb4c] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Enter (handle=0x5a870, id=1, dynParams=0x57d04 (size=0x44), status=0x57d48 (size=0xa0)
@1,237,315us: [+5 T:0x4001fb20 S:0xbefaeb1c] CV - VISA_allocMsg> Allocating message for messageId=0x00025598
@1,237,786us: [+0 T:0x4001fb20 S:0xbefaeaec] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x445ae000, size=128)
@1,238,255us: [+1 T:0x4001fb20 S:0xbefaeaec] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x445ae000, size=128)
@1,238,725us: [+1 T:0x4001fb20 S:0xbefaeaec] OM - Memory__getPhysicalAddress> found in cb(Sc=0x445ae000, Ec=0x445ae800, Ss=0x445ae000, Es=0x445ae080, PSc=0x88db6000)
@1,239,208us: [+1 T:0x4001fb20 S:0xbefaeaec] OM - Memory__getPhysicalAddress> returning physAddr=0x88db6000
@1,239,739us: [+0 T:0x4001fb20 S:0xbefaeaec] OM - Memory_getBufferPhysicalAddress> return (0x88db6000)
@1,240,205us: [+0 T:0x4001fb20 S:0xbefaeafc] CV - VISA_call(visa=0x5a870, msg=0x41efe880): messageId=0x00025598, command=0x1
@1,240,679us: [+0 T:0x4001fb20 S:0xbefaeac4] OC - Comm_put> Enter(queue=0x2, msg=0x41efe880)
@1,241,198us: [+0 T:0x4001fb20 S:0xbefaeac4] OC - Comm_put> return (0)
@1,241,777us: [+0 T:0x4001fb20 S:0xbefaeabc] OC - Comm_get> Enter(queue=0x10001, msg=0xbefaeb64, timeout=-1)
@1,242,282us: [+0 T:0x4001fb20 S:0xbefaeabc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@1,242,761us: [+0 T:0x4001fb20 S:0xbefaea4c] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,243,477us: [+0 T:0x4001fb20 S:0xbefaea4c] OC - Comm_put> return (0)
@1,244,061us: [+0 T:0x4001fb20 S:0xbefaea44] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaeae4, timeout=-1)
@1,244,570us: [+0 T:0x4001fb20 S:0xbefaea44] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @1,075,626tk: [+5 T:0x8ba08a64 S:0x8ba0cd54] CN - NODE> 0x8fa8eca8(jpegenc#0) call(algHandle=0x8fa8ed68, msg=0x8fe04880); messageId=0x00025598
[DSP] @1,075,720tk: [+0 T:0x8ba08a64 S:0x8ba0cb7c] OM - Memory_cacheInv> Enter(addr=0x88db6000, sizeInBytes=128)
[DSP] @1,075,781tk: [+0 T:0x8ba08a64 S:0x8ba0cb7c] OM - Memory_cacheInv> return
[DSP] @1,075,827tk: [+0 T:0x8ba08a64 S:0x8ba0cb24] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Enter (handle=0x8fa8ed68, id=1, dynParams=0x8fe048b4 (size=0x44), status=0x8fe048f8 (size=0xa0)
[DSP] @1,075,939tk: [+5 T:0x8ba08a64 S:0x8ba0cb04] CV - VISA_enter(visa=0x8fa8ed68): algHandle = 0x8fa8ed98
[DSP] @1,076,001tk: [+0 T:0x8ba08a64 S:0x8ba0cae4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x8fa8ed98)
[DSP] @1,076,071tk: [+0 T:0x8ba08a64 S:0x8ba0cae4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
[DSP] @1,076,246tk: [+5 T:0x8ba08a64 S:0x8ba0cb04] CV - VISA_exit(visa=0x8fa8ed68): algHandle = 0x8fa8ed98
[DSP] @1,076,312tk: [+0 T:0x8ba08a64 S:0x8ba0cae4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x8fa8ed98)
[DSP] @1,076,377tk: [+0 T:0x8ba08a64 S:0x8ba0cae4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
[DSP] @1,076,433tk: [+0 T:0x8ba08a64 S:0x8ba0cb24] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Exit (handle=0x8fa8ed68, retVal=0x0)
[DSP] @1,076,501tk: [+5 T:0x8ba08a64 S:0x8ba0cd54] CN - NODE> returned from call(algHandle=0x8fa8ed68, msg=0x8fe04880); messageId=0x00025598
[DSP] @1,082,120tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @1,082,178tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
@1,251,992us: [+0 T:0x4001fb20 S:0xbefaea7c] CE - Engine_fwriteTrace> returning count [1664]
@1,252,464us: [+0 T:0x4001fb20 S:0xbefaeafc] CV - VISA_call Completed: messageId=0x00025598, command=0x1, return(status=0)
@1,252,944us: [+5 T:0x4001fb20 S:0xbefaeb04] CV - VISA_freeMsg(0x5a870, 0x41efe880): Freeing message with messageId=0x00025598
@1,253,418us: [+0 T:0x4001fb20 S:0xbefaeb4c] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Exit (handle=0x5a870, retVal=0x0)
@1,253,894us: [+0 T:0x4001fb20 S:0xbefaeb4c] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Enter (handle=0x5a870, id=5, dynParams=0x57d04 (size=0x44), status=0x57d48 (size=0xa0)
@1,254,387us: [+5 T:0x4001fb20 S:0xbefaeb1c] CV - VISA_allocMsg> Allocating message for messageId=0x00025599
@1,254,861us: [+0 T:0x4001fb20 S:0xbefaeaec] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x445ae000, size=128)
@1,255,332us: [+1 T:0x4001fb20 S:0xbefaeaec] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x445ae000, size=128)
@1,255,862us: [+1 T:0x4001fb20 S:0xbefaeaec] OM - Memory__getPhysicalAddress> found in cb(Sc=0x445ae000, Ec=0x445ae800, Ss=0x445ae000, Es=0x445ae080, PSc=0x88db6000)
@1,256,479us: [+1 T:0x4001fb20 S:0xbefaeaec] OM - Memory__getPhysicalAddress> returning physAddr=0x88db6000
@1,256,953us: [+0 T:0x4001fb20 S:0xbefaeaec] OM - Memory_getBufferPhysicalAddress> return (0x88db6000)
@1,257,422us: [+0 T:0x4001fb20 S:0xbefaeafc] CV - VISA_call(visa=0x5a870, msg=0x41efe880): messageId=0x00025599, command=0x1
@1,257,899us: [+0 T:0x4001fb20 S:0xbefaeac4] OC - Comm_put> Enter(queue=0x2, msg=0x41efe880)
@1,258,417us: [+0 T:0x4001fb20 S:0xbefaeac4] OC - Comm_put> return (0)
@1,258,984us: [+0 T:0x4001fb20 S:0xbefaeabc] OC - Comm_get> Enter(queue=0x10001, msg=0xbefaeb64, timeout=-1)
@1,259,569us: [+0 T:0x4001fb20 S:0xbefaeabc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@1,260,048us: [+0 T:0x4001fb20 S:0xbefaea4c] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,260,567us: [+0 T:0x4001fb20 S:0xbefaea4c] OC - Comm_put> return (0)
@1,261,143us: [+0 T:0x4001fb20 S:0xbefaea44] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaeae4, timeout=-1)
@1,261,645us: [+0 T:0x4001fb20 S:0xbefaea44] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @1,124,664tk: [+5 T:0x8ba08a64 S:0x8ba0cd54] CN - NODE> 0x8fa8eca8(jpegenc#0) call(algHandle=0x8fa8ed68, msg=0x8fe04880); messageId=0x00025599
[DSP] @1,124,752tk: [+0 T:0x8ba08a64 S:0x8ba0cb7c] OM - Memory_cacheInv> Enter(addr=0x88db6000, sizeInBytes=128)
[DSP] @1,124,813tk: [+0 T:0x8ba08a64 S:0x8ba0cb7c] OM - Memory_cacheInv> return
[DSP] @1,124,857tk: [+0 T:0x8ba08a64 S:0x8ba0cb24] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Enter (handle=0x8fa8ed68, id=5, dynParams=0x8fe048b4 (size=0x44), status=0x8fe048f8 (size=0xa0)
[DSP] @1,124,959tk: [+5 T:0x8ba08a64 S:0x8ba0cb04] CV - VISA_enter(visa=0x8fa8ed68): algHandle = 0x8fa8ed98
[DSP] @1,125,021tk: [+0 T:0x8ba08a64 S:0x8ba0cae4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x8fa8ed98)
[DSP] @1,125,088tk: [+0 T:0x8ba08a64 S:0x8ba0cae4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
[DSP] @1,125,154tk: [+5 T:0x8ba08a64 S:0x8ba0cb04] CV - VISA_exit(visa=0x8fa8ed68): algHandle = 0x8fa8ed98
[DSP] @1,125,215tk: [+0 T:0x8ba08a64 S:0x8ba0cae4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x8fa8ed98)
[DSP] @1,125,278tk: [+0 T:0x8ba08a64 S:0x8ba0cae4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
[DSP] @1,125,331tk: [+0 T:0x8ba08a64 S:0x8ba0cb24] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Exit (handle=0x8fa8ed68, retVal=0x0)
[DSP] @1,125,399tk: [+5 T:0x8ba08a64 S:0x8ba0cd54] CN - NODE> returned from call(algHandle=0x8fa8ed68, msg=0x8fe04880); messageId=0x00025599
[DSP] @1,130,783tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @1,130,840tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
@1,268,982us: [+0 T:0x4001fb20 S:0xbefaea7c] CE - Engine_fwriteTrace> returning count [1664]
@1,269,534us: [+0 T:0x4001fb20 S:0xbefaeafc] CV - VISA_call Completed: messageId=0x00025599, command=0x1, return(status=0)
@1,270,014us: [+5 T:0x4001fb20 S:0xbefaeb04] CV - VISA_freeMsg(0x5a870, 0x41efe880): Freeing message with messageId=0x00025599
@1,270,553us: [+0 T:0x4001fb20 S:0xbefaeb4c] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Exit (handle=0x5a870, retVal=0x0)
@1,271,093us: [+0 T:0x4001fb20 S:0xbefaeba4] ti.sdo.ce.image.IMGENC - IMGENC_create> Enter (engine=0x5a4e0, name='yuvconvert', params=0x580b0)
@1,271,574us: [+0 T:0x4001fb20 S:0xbefaeb74] CV - VISA_create(0x5a4e0, 'yuvconvert', 0x580b0, 0x828, 'ti.sdo.ce.image.IIMGENC')
@1,272,199us: [+0 T:0x4001fb20 S:0xbefaea74] CV - VISA_create2(0x5a4e0, 'yuvconvert', 0x580b0, 0x0, 0x828, 'ti.sdo.ce.image.IIMGENC')
@1,272,704us: [+0 T:0x4001fb20 S:0xbefaea5c] OM - Memory_alloc> Enter(0x30)
@1,273,176us: [+0 T:0x4001fb20 S:0xbefaea5c] OM - Memory_alloc> return (0x5a8f8)
@1,273,636us: [+0 T:0x4001fb20 S:0xbefae9fc] CE - Engine_createNode(0x5a4e0, 'yuvconvert', 828, 0x580b0, 0x0, 0xbefaeb6c)
@1,274,113us: [+0 T:0x4001fb20 S:0xbefae9fc] CE - Engine> allocNode Enter(engine=0x5a4e0, impId='yuvconvert')
@1,274,580us: [+0 T:0x4001fb20 S:0xbefae9e4] OM - Memory_alloc> Enter(0x20)
@1,275,052us: [+0 T:0x4001fb20 S:0xbefae9e4] OM - Memory_alloc> return (0x5a930)
@1,275,541us: [+0 T:0x4001fb20 S:0xbefae9fc] CE - Engine> allocNode(). Calling Comm_create(gppfromnode_288_2, 0x5a938, NULL)
@1,276,007us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_create> Enter(queueName='gppfromnode_288_2', queue=0x5a938, attrs=0x0)
@1,276,484us: [+0 T:0x4001fb20 S:0xbefae9bc] OM - Memory_alloc> Enter(0x4)
@1,276,952us: [+0 T:0x4001fb20 S:0xbefae9bc] OM - Memory_alloc> return (0x5a958)
@1,277,683us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_create> return (0x5a958)
@1,278,157us: [+0 T:0x4001fb20 S:0xbefae9dc] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,278,677us: [+0 T:0x4001fb20 S:0xbefae9dc] OC - Comm_put> return (0)
@1,279,143us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaea84, timeout=-1)
@1,279,828us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@1,280,358us: [+0 T:0x4001fb20 S:0xbefae9dc] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,281,080us: [+0 T:0x4001fb20 S:0xbefae9dc] OC - Comm_put> return (0)
@1,281,656us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaea84, timeout=-1)
@1,282,159us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@1,282,628us: [+4 T:0x4001fb20 S:0xbefae9fc] CE - Engine_createNode> created node(stdIn=0x3, stdOut=0x10002, msgq=0x5a958, algName='yuvconvert', rmsNode=0x8fa8eda8, algHandle=0x8fa8ee40)
@1,283,139us: [+0 T:0x4001fb20 S:0xbefae964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,283,655us: [+0 T:0x4001fb20 S:0xbefae964] OC - Comm_put> return (0)
@1,284,228us: [+0 T:0x4001fb20 S:0xbefae95c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefae9fc, timeout=-1)
@1,284,734us: [+0 T:0x4001fb20 S:0xbefae95c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @1,182,354tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 0
[DSP] @1,182,423tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> Enter(size=0x18)
[DSP] @1,182,480tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> return (0x8fa8eda8)
[DSP] @1,182,531tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> Enter(size=0xd)
[DSP] @1,182,579tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> return (0x8fa8edc0)
[DSP] @1,182,636tk: [+0 T:0x8ba00784 S:0x8ba045fc] OM - Memory_alloc> Enter(size=0x20)
[DSP] @1,182,685tk: [+0 T:0x8ba00784 S:0x8ba045fc] OM - Memory_alloc> return (0x8fa8edd0)
[DSP] @1,182,737tk: [+0 T:0x8ba00784 S:0x8ba045cc] OM - Memory_alloc> Enter(size=0x24)
[DSP] @1,182,785tk: [+0 T:0x8ba00784 S:0x8ba045cc] OM - Memory_alloc> return (0x8fa8edf0)
[DSP] @1,182,862tk: [+0 T:0x8ba00784 S:0x8ba045e4] ti.sdo.ce.image.IMGENC - IMGENC_create> Enter (engine=0x0, name='yuvconvert', params=0x0)
[DSP] @1,182,934tk: [+0 T:0x8ba00784 S:0x8ba045ac] CV - VISA_create(0x0, 'yuvconvert', 0x0, 0x828, 'ti.sdo.ce.image.IIMGENC')
[DSP] @1,182,999tk: [+0 T:0x8ba00784 S:0x8ba0449c] CV - VISA_create2(0x0, 'yuvconvert', 0x0, 0x0, 0x828, 'ti.sdo.ce.image.IIMGENC')
[DSP] @1,183,084tk: [+0 T:0x8ba00784 S:0x8ba0447c] OM - Memory_alloc> Enter(size=0x30)
[DSP] @1,183,132tk: [+0 T:0x8ba00784 S:0x8ba0447c] OM - Memory_alloc> return (0x8fa8ee40)
[DSP] @1,183,185tk: [+0 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fa497f8, idma3Fxns=0x8fa4982c, iresFxns=0x0, params=0x0, attrs=0x8ba04598)
[DSP] @1,183,279tk: [+0 T:0x8ba00784 S:0x8ba04434] OM - Memory_alloc> Enter(size=0x10)
[DSP] @1,183,327tk: [+0 T:0x8ba00784 S:0x8ba04434] OM - Memory_alloc> return (0x8fa8ee70)
[DSP] @1,183,400tk: [+0 T:0x8ba00784 S:0x8ba043d4] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_alloc(0x0, 0x8ba0cde0, 0x8ba0cde0)
[DSP] @1,183,494tk: [+0 T:0x8ba00784 S:0x8ba043dc] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_initObj(0x8ba07be0, 0x0, 0x8ba0cde0, 0x1)
[DSP] @1,183,579tk: [+0 T:0x8ba00784 S:0x8ba043f4] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_dmaGetChannels(0x8ba07be0, 0x8ba0ce48)
[DSP] @1,183,664tk: [+0 T:0x8ba00784 S:0x8ba043f4] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_dmaGetChannels(0x8ba07be0, 0x8ba0ce48)
[DSP] @1,183,852tk: [+0 T:0x8ba00784 S:0x8ba043e4] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_dmaInit(0x8ba07be0, 0x8ba0ce48)
[DSP] @1,183,937tk: [+0 T:0x8ba00784 S:0x8ba043e4] unic.sdo.codecs.yuvconvert - dmaHandle[0] = 8ba0d198
[DSP] @1,183,992tk: [+0 T:0x8ba00784 S:0x8ba043e4] unic.sdo.codecs.yuvconvert - dmaHandle[1] = 8ba0d200
[DSP] @1,184,047tk: [+0 T:0x8ba00784 S:0x8ba043e4] unic.sdo.codecs.yuvconvert - dmaHandle[2] = 8ba0d280
[DSP] @1,184,102tk: [+0 T:0x8ba00784 S:0x8ba043e4] unic.sdo.codecs.yuvconvert - dmaHandle[3] = 8ba0d300
[DSP] @1,184,163tk: [+0 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x8fa8ee70)
[DSP] @1,184,223tk: [+5 T:0x8ba00784 S:0x8ba0449c] CV - VISA_create> local codec created (name='yuvconvert', handle=0x8fa8ee70)
[DSP] @1,184,289tk: [+0 T:0x8ba00784 S:0x8ba045e4] ti.sdo.ce.image.IMGENC - IMGENC_create> return (0x8fa8ee40)
[DSP] @1,184,353tk: [+4 T:0x8ba00784 S:0x8ba045a4] OT - Thread_create > name: "yuvconvert#1", pri:  -1, stack size:  10024, stack seg: 0
[DSP] @1,189,205tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 1
[DSP] @1,196,531tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @1,196,593tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
@1,299,436us: [+0 T:0x416ed490 S:0x416ecd74] OP - getCmd_d> Enter (proc=0x416ecde8)
@1,301,965us: [+0 T:0x4001fb20 S:0xbefae994] CE - Engine_fwriteTrace> returning count [3599]
@1,302,439us: [+2 T:0x4001fb20 S:0xbefae9fc] CE - Engine_createNode> Returning 0x5a930
@1,302,901us: [+0 T:0x4001fb20 S:0xbefaea5c] OM - Memory_alloc> Enter(0x4)
@1,303,372us: [+0 T:0x4001fb20 S:0xbefaea5c] OM - Memory_alloc> return (0x5a968)
@1,303,833us: [+0 T:0x4001fb20 S:0xbefaea54] OC - Comm_alloc> Enter(poolId=0x0, msg=0x5a968, size=828)
@1,304,338us: [+0 T:0x4001fb20 S:0xbefaea54] OC - Comm_alloc> msg=0x41eff880, returning (0)
@1,304,817us: [+5 T:0x4001fb20 S:0xbefaea74] CV - VISA_create> remote codec created (name='yuvconvert', localQueueID=0x10002, remoteQueueID=0x0003)
@1,305,300us: [+0 T:0x4001fb20 S:0xbefaeba4] ti.sdo.ce.image.IMGENC - IMGENC_create> return (0x5a8f8)
@1,305,771us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> Enter(size=3133440, align=-1, cached=FALSE, heap=FALSE)
@1,306,480us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_alloc(3133440) = 0x445be000.
@1,306,970us: [+4 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> CMEM_getPhys(0x445be000) = 0x890c3000.
@1,307,438us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> Enter(virtAddr=0x445be000, size=3133440, physAddr=0x890c3000)
@1,307,914us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> creating new contigBuf object
@1,308,610us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> Enter(0x10)
@1,309,099us: [+0 T:0x4001fb20 S:0xbefaeb24] OM - Memory_alloc> return (0x5a978)
@1,309,622us: [+1 T:0x4001fb20 S:0xbefaeb3c] OM - Memory__addContigBuf> returning: cb->phys=0x890c3000, cb->size=3133440, cb->virt=0x445be000
@1,310,100us: [+0 T:0x4001fb20 S:0xbefaeb84] OM - Memory_contigAlloc> return (0x445be000)
@1,330,423us: [+0 T:0x4001fb20 S:0xbefaeb5c] ti.sdo.ce.image.IMGENC - IMGENC_control> Enter (handle=0x5a8f8, id=0, dynParams=0x580c8 (size=0x24), status=0x580ec (size=0x94)
@1,330,923us: [+5 T:0x4001fb20 S:0xbefaeb34] CV - VISA_allocMsg> Allocating message for messageId=0x00035578
@1,331,396us: [+0 T:0x4001fb20 S:0xbefaeb14] CV - VISA_call(visa=0x5a8f8, msg=0x41eff880): messageId=0x00035578, command=0x1
@1,331,872us: [+0 T:0x4001fb20 S:0xbefaeadc] OC - Comm_put> Enter(queue=0x3, msg=0x41eff880)
@1,332,391us: [+0 T:0x4001fb20 S:0xbefaeadc] OC - Comm_put> return (0)
@1,332,962us: [+0 T:0x4001fb20 S:0xbefaead4] OC - Comm_get> Enter(queue=0x10002, msg=0xbefaeb7c, timeout=-1)
@1,333,463us: [+0 T:0x4001fb20 S:0xbefaead4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@1,333,942us: [+0 T:0x4001fb20 S:0xbefaea64] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,334,458us: [+0 T:0x4001fb20 S:0xbefaea64] OC - Comm_put> return (0)
@1,335,029us: [+0 T:0x4001fb20 S:0xbefaea5c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaeafc, timeout=-1)
@1,335,536us: [+0 T:0x4001fb20 S:0xbefaea5c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @1,335,310tk: [+5 T:0x8ba0ce54 S:0x8ba0fa1c] CN - NODE> 0x8fa8edd0(yuvconvert#1) call(algHandle=0x8fa8ee40, msg=0x8fe05880); messageId=0x00035578
[DSP] @1,335,406tk: [+0 T:0x8ba0ce54 S:0x8ba0f964] ti.sdo.ce.image.IMGENC - IMGENC_control> Enter (handle=0x8fa8ee40, id=0, dynParams=0x8fe058b4 (size=0x24), status=0x8fe058d8 (size=0x94)
[DSP] @1,335,511tk: [+5 T:0x8ba0ce54 S:0x8ba0f944] CV - VISA_enter(visa=0x8fa8ee40): algHandle = 0x8fa8ee70
[DSP] @1,335,572tk: [+0 T:0x8ba0ce54 S:0x8ba0f924] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x8fa8ee70)
[DSP] @1,335,641tk: [+0 T:0x8ba0ce54 S:0x8ba0f924] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
[DSP] @1,335,698tk: [+0 T:0x8ba0ce54 S:0x8ba0f924] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_control(0x8ba07be0, 0x8fe058b4, 0x8fe058d8, 0x8fa70738)
[DSP] @1,335,783tk: [+5 T:0x8ba0ce54 S:0x8ba0f944] CV - VISA_exit(visa=0x8fa8ee40): algHandle = 0x8fa8ee70
[DSP] @1,335,845tk: [+0 T:0x8ba0ce54 S:0x8ba0f924] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x8fa8ee70)
[DSP] @1,335,908tk: [+0 T:0x8ba0ce54 S:0x8ba0f924] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
[DSP] @1,335,962tk: [+0 T:0x8ba0ce54 S:0x8ba0f964] ti.sdo.ce.image.IMGENC - IMGENC_control> Exit (handle=0x8fa8ee40, retVal=0x0)
[DSP] @1,336,028tk: [+5 T:0x8ba0ce54 S:0x8ba0fa1c] CN - NODE> returned from call(algHandle=0x8fa8ee40, msg=0x8fe05880); messageId=0x00035578
[DSP] @1,341,203tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @1,341,259tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
@1,342,754us: [+0 T:0x4001fb20 S:0xbefaea94] CE - Engine_fwriteTrace> returning count [1618]
@1,343,223us: [+0 T:0x4001fb20 S:0xbefaeb14] CV - VISA_call Completed: messageId=0x00035578, command=0x1, return(status=0)
@1,343,704us: [+5 T:0x4001fb20 S:0xbefaeb1c] CV - VISA_freeMsg(0x5a8f8, 0x41eff880): Freeing message with messageId=0x00035578
@1,344,181us: [+0 T:0x4001fb20 S:0xbefaeb5c] ti.sdo.ce.image.IMGENC - IMGENC_control> Exit (handle=0x5a8f8, retVal=0x0)
@1,344,664us: [+0 T:0x4001fb20 S:0xbefaeb5c] ti.sdo.ce.image.IMGENC - IMGENC_control> Enter (handle=0x5a8f8, id=1, dynParams=0x580c8 (size=0x24), status=0x580ec (size=0x94)
@1,345,154us: [+5 T:0x4001fb20 S:0xbefaeb34] CV - VISA_allocMsg> Allocating message for messageId=0x00035579
@1,345,625us: [+0 T:0x4001fb20 S:0xbefaeb14] CV - VISA_call(visa=0x5a8f8, msg=0x41eff880): messageId=0x00035579, command=0x1
@1,346,101us: [+0 T:0x4001fb20 S:0xbefaeadc] OC - Comm_put> Enter(queue=0x3, msg=0x41eff880)
@1,346,619us: [+0 T:0x4001fb20 S:0xbefaeadc] OC - Comm_put> return (0)
@1,347,196us: [+0 T:0x4001fb20 S:0xbefaead4] OC - Comm_get> Enter(queue=0x10002, msg=0xbefaeb7c, timeout=-1)
@1,347,698us: [+0 T:0x4001fb20 S:0xbefaead4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@1,348,179us: [+0 T:0x4001fb20 S:0xbefaea64] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,348,697us: [+0 T:0x4001fb20 S:0xbefaea64] OC - Comm_put> return (0)
@1,349,523us: [+0 T:0x4001fb20 S:0xbefaea5c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaeafc, timeout=-1)
@1,350,047us: [+0 T:0x4001fb20 S:0xbefaea5c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @1,375,825tk: [+5 T:0x8ba0ce54 S:0x8ba0fa1c] CN - NODE> 0x8fa8edd0(yuvconvert#1) call(algHandle=0x8fa8ee40, msg=0x8fe05880); messageId=0x00035579
[DSP] @1,375,913tk: [+0 T:0x8ba0ce54 S:0x8ba0f964] ti.sdo.ce.image.IMGENC - IMGENC_control> Enter (handle=0x8fa8ee40, id=1, dynParams=0x8fe058b4 (size=0x24), status=0x8fe058d8 (size=0x94)
[DSP] @1,376,010tk: [+5 T:0x8ba0ce54 S:0x8ba0f944] CV - VISA_enter(visa=0x8fa8ee40): algHandle = 0x8fa8ee70
[DSP] @1,376,071tk: [+0 T:0x8ba0ce54 S:0x8ba0f924] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x8fa8ee70)
[DSP] @1,376,138tk: [+0 T:0x8ba0ce54 S:0x8ba0f924] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
[DSP] @1,376,190tk: [+0 T:0x8ba0ce54 S:0x8ba0f924] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_control(0x8ba07be0, 0x8fe058b4, 0x8fe058d8, 0x8fa70738)
[DSP] @1,376,285tk: [+0 T:0x8ba0ce54 S:0x8ba0f8f4] unic.sdo.codecs.yuvconvert - g_pInternalBuf = 11828000
[DSP] @1,376,370tk: [+5 T:0x8ba0ce54 S:0x8ba0f944] CV - VISA_exit(visa=0x8fa8ee40): algHandle = 0x8fa8ee70
[DSP] @1,376,430tk: [+0 T:0x8ba0ce54 S:0x8ba0f924] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x8fa8ee70)
[DSP] @1,376,493tk: [+0 T:0x8ba0ce54 S:0x8ba0f924] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
[DSP] @1,376,556tk: [+0 T:0x8ba0ce54 S:0x8ba0f964] ti.sdo.ce.image.IMGENC - IMGENC_control> Exit (handle=0x8fa8ee40, retVal=0x0)
[DSP] @1,376,621tk: [+5 T:0x8ba0ce54 S:0x8ba0fa1c] CN - NODE> returned from call(algHandle=0x8fa8ee40, msg=0x8fe05880); messageId=0x00035579
[DSP] @1,381,750tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @1,381,807tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
@1,357,484us: [+0 T:0x4001fb20 S:0xbefaea94] CE - Engine_fwriteTrace> returning count [1724]
@1,357,956us: [+0 T:0x4001fb20 S:0xbefaeb14] CV - VISA_call Completed: messageId=0x00035579, command=0x1, return(status=0)
@1,358,434us: [+5 T:0x4001fb20 S:0xbefaeb1c] CV - VISA_freeMsg(0x5a8f8, 0x41eff880): Freeing message with messageId=0x00035579
@1,358,911us: [+0 T:0x4001fb20 S:0xbefaeb5c] ti.sdo.ce.image.IMGENC - IMGENC_control> Exit (handle=0x5a8f8, retVal=0x0)
Ctrl Time = 14785
@1,359,899us: [+0 T:0x4001fb20 S:0xbefaeba4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x5a4e0, name='h264fhdvenc', params=0x58180)
@1,360,376us: [+0 T:0x4001fb20 S:0xbefaeb74] CV - VISA_create(0x5a4e0, 'h264fhdvenc', 0x58180, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
@1,360,857us: [+0 T:0x4001fb20 S:0xbefaea74] CV - VISA_create2(0x5a4e0, 'h264fhdvenc', 0x58180, 0x3c, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
@1,361,356us: [+0 T:0x4001fb20 S:0xbefaea5c] OM - Memory_alloc> Enter(0x30)
@1,361,826us: [+0 T:0x4001fb20 S:0xbefaea5c] OM - Memory_alloc> return (0x5a9c0)
@1,362,487us: [+0 T:0x4001fb20 S:0xbefae9fc] CE - Engine_createNode(0x5a4e0, 'h264fhdvenc', 2496, 0x58180, 0x3c, 0xbefaeb6c)
@1,362,980us: [+0 T:0x4001fb20 S:0xbefae9fc] CE - Engine> allocNode Enter(engine=0x5a4e0, impId='h264fhdvenc')
@1,363,451us: [+0 T:0x4001fb20 S:0xbefae9e4] OM - Memory_alloc> Enter(0x20)
@1,363,925us: [+0 T:0x4001fb20 S:0xbefae9e4] OM - Memory_alloc> return (0x5a9f8)
@1,364,414us: [+0 T:0x4001fb20 S:0xbefae9fc] CE - Engine> allocNode(). Calling Comm_create(gppfromnode_288_3, 0x5aa00, NULL)
@1,364,880us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_create> Enter(queueName='gppfromnode_288_3', queue=0x5aa00, attrs=0x0)
@1,365,355us: [+0 T:0x4001fb20 S:0xbefae9bc] OM - Memory_alloc> Enter(0x4)
@1,365,827us: [+0 T:0x4001fb20 S:0xbefae9bc] OM - Memory_alloc> return (0x5aa20)
@1,366,562us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_create> return (0x5aa20)
@1,367,039us: [+0 T:0x4001fb20 S:0xbefae9dc] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,367,562us: [+0 T:0x4001fb20 S:0xbefae9dc] OC - Comm_put> return (0)
@1,368,033us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_get> Enter(queue=0x10000, msg=0xbefaea84, timeout=-1)
@1,368,654us: [+0 T:0x416ed490 S:0x416ecd54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5a1e0] timeout[0xffffffff]
@1,406,448us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@1,406,928us: [+0 T:0x4001fb20 S:0xbefae9d4] OC - Comm_delete> Enter (comm=0x5aa20)
@1,407,632us: [+0 T:0x4001fb20 S:0xbefae9b4] OM - Memory_free> Enter(0x5aa20, 0x4)
@1,408,109us: [+0 T:0x4001fb20 S:0xbefae9b4] OM - Memory_free> return (0x1)
@1,408,570us: [+0 T:0x4001fb20 S:0xbefae9f4] OC - Comm_delete> return
@1,409,029us: [+0 T:0x4001fb20 S:0xbefae9dc] OM - Memory_free> Enter(0x5a9f8, 0x20)
@1,409,579us: [+0 T:0x4001fb20 S:0xbefae9dc] OM - Memory_free> return (0x1)
@1,410,040us: [+6 T:0x4001fb20 S:0xbefae9fc] CE - Engine_createNode> Remote node creation FAILED (0x80008008).
@1,410,525us: [+0 T:0x4001fb20 S:0xbefae964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,411,041us: [+0 T:0x4001fb20 S:0xbefae964] OC - Comm_put> return (0)
@1,411,620us: [+0 T:0x4001fb20 S:0xbefae95c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefae9fc, timeout=-1)
@1,412,125us: [+0 T:0x4001fb20 S:0xbefae95c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @1,435,467tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 0
[DSP] @1,435,530tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> Enter(size=0x18)
[DSP] @1,435,583tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> return (0x8fa8eeb0)
[DSP] @1,435,634tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> Enter(size=0xe)
[DSP] @1,435,682tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> return (0x8fa8eec8)
[DSP] @1,435,738tk: [+0 T:0x8ba00784 S:0x8ba045fc] OM - Memory_alloc> Enter(size=0x20)
[DSP] @1,435,788tk: [+0 T:0x8ba00784 S:0x8ba045fc] OM - Memory_alloc> return (0x8fa8eed8)
[DSP] @1,435,839tk: [+0 T:0x8ba00784 S:0x8ba045cc] OM - Memory_alloc> Enter(size=0x24)
[DSP] @1,435,888tk: [+0 T:0x8ba00784 S:0x8ba045cc] OM - Memory_alloc> return (0x8fa8eef8)
[DSP] @1,435,964tk: [+0 T:0x8ba00784 S:0x8ba045e4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x0, name='h264fhdvenc', params=0x8fe038c0)
[DSP] @1,436,040tk: [+0 T:0x8ba00784 S:0x8ba045ac] CV - VISA_create(0x0, 'h264fhdvenc', 0x8fe038c0, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
[DSP] @1,436,112tk: [+0 T:0x8ba00784 S:0x8ba0449c] CV - VISA_create2(0x0, 'h264fhdvenc', 0x8fe038c0, 0x3c, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
[DSP] @1,436,205tk: [+0 T:0x8ba00784 S:0x8ba0447c] OM - Memory_alloc> Enter(size=0x30)
[DSP] @1,436,254tk: [+0 T:0x8ba00784 S:0x8ba0447c] OM - Memory_alloc> return (0x8fa8ef50)
[DSP] @1,436,307tk: [+0 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fa483dc, idma3Fxns=0x0, iresFxns=0x8fa48334, params=0x8fe038c0, attrs=0x8ba04598)
[DSP] @1,436,404tk: [+0 T:0x8ba00784 S:0x8ba04434] OM - Memory_alloc> Enter(size=0x10)
[DSP] @1,436,452tk: [+0 T:0x8ba00784 S:0x8ba04434] OM - Memory_alloc> return (0x8fa8ef80)
[DSP] @1,542,437tk: [+0 T:0x8ba00784 S:0x8ba03e6c] ti.sdo.ce.osal.Sem - Sem_create> count 1
[DSP] @1,542,517tk: [+0 T:0x8ba00784 S:0x8ba03e6c] ti.sdo.ce.osal.Sem - Sem_create> sem: 0x8ba0d034
[DSP] @1,542,648tk: [+0 T:0x8ba00784 S:0x8ba03e6c] ti.sdo.ce.osal.Sem - Sem_create> count 1
[DSP] @1,542,702tk: [+0 T:0x8ba00784 S:0x8ba03e6c] ti.sdo.ce.osal.Sem - Sem_create> sem: 0x8ba0d064
[DSP] @1,544,088tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.ce.osal.Sem - Sem_delete> sem: 0x8ba0d064
[DSP] @1,544,476tk: [+7 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> Assignment of alg resources through RMAN FAILED (0x7)
[DSP] @1,544,551tk: [+0 T:0x8ba00784 S:0x8ba04434] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(alg=0x8fa8ef80)
[DSP] @1,544,651tk: [+0 T:0x8ba00784 S:0x8ba04404] OM - Memory_free> Enter(addr=0x8fa8ef80, size=16)
[DSP] @1,544,708tk: [+0 T:0x8ba00784 S:0x8ba04404] OM - Memory_free> return (0x1)
[DSP] @1,544,752tk: [+0 T:0x8ba00784 S:0x8ba04434] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Exit
[DSP] @1,544,803tk: [+0 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x0)
[DSP] @1,544,858tk: [+2 T:0x8ba00784 S:0x8ba0449c] CV - VISA_create2> FAILED to create local codec.
[DSP] @1,544,912tk: [+0 T:0x8ba00784 S:0x8ba0446c] CV - VISA_delete(0x8fa8ef50)
[DSP] @1,544,960tk: [+5 T:0x8ba00784 S:0x8ba0446c] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
[DSP] @1,545,025tk: [+0 T:0x8ba00784 S:0x8ba0443c] OM - Memory_free> Enter(addr=0x8fa8ef50, size=48)
[DSP] @1,545,080tk: [+0 T:0x8ba00784 S:0x8ba0443c] OM - Memory_free> return (0x1)
[DSP] @1,545,128tk: [+0 T:0x8ba00784 S:0x8ba045e4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
[DSP] @1,545,189tk: [+0 T:0x8ba00784 S:0x8ba045d4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> Enter (handle=0x0)
[DSP] @1,545,246tk: [+0 T:0x8ba00784 S:0x8ba045a4] CV - VISA_delete(0x0)
[DSP] @1,545,287tk: [+0 T:0x8ba00784 S:0x8ba045d4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> return
[DSP] @1,545,344tk: [+0 T:0x8ba00784 S:0x8ba045bc] OM - Memory_free> Enter(addr=0x8fa8eef8, size=36)
[DSP] @1,545,400tk: [+0 T:0x8ba00784 S:0x8ba045bc] OM - Memory_free> return (0x1)
[DSP] @1,545,444tk: [+0 T:0x8ba00784 S:0x8ba045c4] OM - Memory_free> Enter(addr=0x8fa8eed8, size=32)
[DSP] @1,545,500tk: [+0 T:0x8ba00784 S:0x8ba045c4] OM - Memory_free> return (0x1)
[DSP] @1,545,548tk: [+0 T:0x8ba00784 S:0x8ba04644] OM - Memory_free> Enter(addr=0x8fa8eec8, size=14)
[DSP] @1,545,604tk:@1,432,645us: [+0 T:0x4001fb20 S:0xbefae964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
@1,433,165us: [+0 T:0x4001fb20 S:0xbefae964] OC - Comm_put> return (0)
@1,433,734us: [+0 T:0x4001fb20 S:0xbefae95c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefae9fc, timeout=-1)
@1,434,237us: [+0 T:0x4001fb20 S:0xbefae95c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
 [+0 T:0x8ba00784 S:0x8ba04644] OM - Memory_free> return (0x1)
[DSP] @1,545,648tk: [+0 T:0x8ba00784 S:0x8ba04644] OM - Memory_free> Enter(addr=0x8fa8eeb0, size=24)
[DSP] @1,545,704tk: [+0 T:0x8ba00784 S:0x8ba04644] OM - Memory_free> return (0x1)
[DSP] @1,559,290tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @1,559,355tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
[DSP] @1,622,282tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @1,622,344tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
@1,438,051us: [+0 T:0x4001fb20 S:0xbefae994] CE - Engine_fwriteTrace> returning count [4930]
@1,438,520us: [+2 T:0x4001fb20 S:0xbefae9fc] CE - Engine_createNode> Returning 0x0
@1,438,984us: [+2 T:0x4001fb20 S:0xbefaea74] CV - VISA_create2> FAILED to create remote codec (0x8).
@1,439,529us: [+0 T:0x4001fb20 S:0xbefaea4c] CV - VISA_delete(0x5a9c0)
@1,439,989us: [+5 T:0x4001fb20 S:0xbefaea4c] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
@1,440,462us: [+0 T:0x4001fb20 S:0xbefaea2c] OM - Memory_free> Enter(0x5a9c0, 0x30)
@1,440,931us: [+0 T:0x4001fb20 S:0xbefaea2c] OM - Memory_free> return (0x1)
@1,441,397us: [+0 T:0x4001fb20 S:0xbefaeba4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
Failed to create video encoder: h264fhdvenc
  • i want to know how to fixed this problem, who can help me?
    thanks very much
  • i counter the same problem, who can help me?
  • Shaquille,
    The resource allocation for your algorithm failed for some reason, although it's not clear why from the trace messages. You could rebuild your server with framework components trace enabled by adding the following line to your server .cfg file:
    xdc.useModule('ti.sdo.fc.global.Settings').profile = "debug_trace";
    Then rebuild the server and re-run your app. You should get a lot more trace from the DSP, and hopefully that will indicate the cause of the failure.
    Janet
  • Thanks for your answer, Janet
    I will try your method for further tracing information.
  • Hello Janet, I have tried your method,  It prompt 3 error message:
    1.Engine_createNode> Remote node creation FAILED (0x80008008).
    2.ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Could not allocate Tcc 1010
    3.Algorithm_create> Assignment of alg resources through RMAN FAILED (0x7)
    1st&3rd has been metioned in past Post, 2nd is the new message after trying your method.
    It seems that my configuration for EDMA3 or DMAN3 is incorrect in my *.cfg file, the *.cfg file has been mentioned in past Post, Could you tell me how to config these settings in *.cfg ? Thanks very much
    the details after CE_DEBUG=3 as following:
    @0,391,992us: [+4 T:0x4001fb20 S:0xbefb1bac] OG - Global_init> This program was built with the following packages:
    @0,392,555us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package gnu.targets.rts470MV (/usr/local/xdctools_3_10_03/packages/gnu/targets/rts470MV/) [1,0,0,0,1225517438755]
    @0,393,031us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package unic.sdo.codecs.h264fhdvenc (/home/Phocus1855/ALG/packages/unic/sdo/codecs/h264fhdvenc/) [1,0,0,1305227643000]
    @0,393,507us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package unic.sdo.codecs.jpegenc (/home/Phocus1855/ALG/packages/unic/sdo/codecs/jpegenc/) [1,0,0,1304714973000]
    @0,393,980us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package unic.sdo.codecs.yuvconvert (/home/Phocus1855/ALG/packages/unic/sdo/codecs/yuvconvert/) [1,0,0,1304714978000]
    @0,394,456us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.global (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    @0,394,931us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package dsplink.gpp (/home/unic/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/gpp/) [5,0,0,1239931267000]
    @0,395,615us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.linuxutils.cmem (/home/unic/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/) [2,2,0,1240253001679]
    @0,396,089us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.xdais.dm (/home/unic/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
    @0,396,861us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.utils.trace (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    @0,397,335us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.utils.xdm (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    @0,397,808us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.xdais (/home/unic/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    @0,398,274us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.node (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    @0,398,750us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.fc.global (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    @0,399,225us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.fc.dman3 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    @0,399,767us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.fc.memutils (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    @0,400,238us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.fc.acpy3 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    @0,400,920us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package gnu.targets (/usr/local/xdctools_3_10_03/packages/gnu/targets/) [1,0,1,1225517427930]
    @0,401,389us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.catalog.c470 (/usr/local/xdctools_3_10_03/packages/ti/catalog/c470/) [1,0,1,0,0]
    @0,402,153us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.catalog.c6000 (/usr/local/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    @0,402,621us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.platforms.evmDM6467 (/usr/local/bios_5_33_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    @0,403,092us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.osal (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    @0,403,566us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.osal.linux (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/linux/) [2,0,1,1240276736840]
    @0,404,039us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.ipc (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    @0,404,513us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.ipc.dsplink (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/) [2,0,1,1240276714152]
    @0,404,989us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.alg (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    @0,405,461us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    @0,406,190us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.speech (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech/) [1,0,2,1240276762193]
    @0,406,662us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.speech1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech1/) [1,0,1,1240276763928]
    @0,407,431us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.audio (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio/) [1,0,2,1240276296374]
    @0,407,904us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.audio1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
    @0,408,378us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.video (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video/) [1,0,3,1240276930771]
    @0,408,852us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.video1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
    @0,409,486us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.video2 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
    @0,409,960us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.image (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image/) [1,0,3,1240276700525]
    @0,410,433us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.ce.image1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
    @0,410,905us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package ti.sdo.dmai (/home/unic/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/) [1,0,0,1292320625000]
    @0,411,587us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package unic.sdo.codecs.h264fhdvenc.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1305227644000]
    @0,412,060us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package unic.sdo.codecs.jpegenc.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/jpegenc/ce/) [1,0,0,1304714976000]
    @0,412,824us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package unic.sdo.codecs.yuvconvert.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/yuvconvert/ce/) [1,0,0,1304714981000]
    @0,413,299us: [+4 T:0x4001fb20 S:0xbefb1bac] OG -     package PhocusCamera_dm6467_config (/home/Phocus1855/PhocusCamera/linux/PhocusCamera_dm6467_config/) []
    @0,413,790us: [+0 T:0x4001fb20 S:0xbefb1bb4] OG - Global_atexit> enter (fxn=0x2a288)
    @0,414,274us: [+0 T:0x4001fb20 S:0xbefb1bb4] OG - Global_atexit> enter (fxn=0x296d4)
    @0,414,801us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_alloc> Enter(0x18)
    @0,415,272us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_alloc> return (0x5a110)
    @0,415,980us: [+0 T:0x4001fb20 S:0xbefb1ba4] OG - Global_atexit> enter (fxn=0x27604)
    @0,416,507us: [+0 T:0x4001fb20 S:0xbefb1b7c] OM - Memory_alloc> Enter(0x18)
    @0,416,980us: [+0 T:0x4001fb20 S:0xbefb1b7c] OM - Memory_alloc> return (0x5a160)
    @0,417,443us: [+0 T:0x4001fb20 S:0xbefb1b9c] OG - Global_atexit> enter (fxn=0x264b0)
    @0,417,957us: [+0 T:0x4001fb20 S:0xbefb1ba4] OG - Global_atexit> enter (fxn=0x28d38)
    @0,418,485us: [+0 T:0x4001fb20 S:0xbefb1b9c] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,418,944us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_alloc> Enter(0x14)
    @0,419,492us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_alloc> return (0x5a1e0)
    @0,420,163us: [+0 T:0x4001fb20 S:0xbefb1b9c] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x5a1e0]
    @0,420,626us: [+0 T:0x4001fb20 S:0xbefb1b9c] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,421,371us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_alloc> Enter(0x14)
    @0,421,839us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_alloc> return (0x5a1f8)
    @0,422,299us: [+0 T:0x4001fb20 S:0xbefb1b9c] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x5a1f8]
    @0,422,764us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_alloc> Enter(0x18)
    @0,423,232us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_alloc> return (0x5a210)
    @0,423,695us: [+0 T:0x4001fb20 S:0xbefb1b7c] OT - Thread_create> Enter (fxn=0x24c88, attrs=0x0)
    @0,424,159us: [+0 T:0x4001fb20 S:0xbefb1b64] OM - Memory_alloc> Enter(0x64)
    @0,424,627us: [+0 T:0x4001fb20 S:0xbefb1b64] OM - Memory_alloc> return (0x5a230)
    @0,425,644us: [+0 T:0x4001fb20 S:0xbefb1b7c] OT - Thread_create> Exit (task=0x5a230)
    @0,426,116us: [+0 T:0x4001fb20 S:0xbefb1bb4] OG - Global_atexit> enter (fxn=0x24678)
    @0,426,607us: [+0 T:0x4001fb20 S:0xbefb1bb4] OG - Global_atexit> enter (fxn=0x269fc)
    @0,427,172us: [+0 T:0x4001fb20 S:0xbefb1b9c] ti.sdo.ce.alg - ALG_init> Enter
    @0,427,637us: [+0 T:0x4001fb20 S:0xbefb1b8c] OG - Global_atexit> enter (fxn=0x242c4)
    @0,428,111us: [+0 T:0x4001fb20 S:0xbefb1bbc] ti.sdo.ce.alg - ALG_init> Exit
    @0,428,569us: [+0 T:0x4001fb20 S:0xbefb1bb4] OG - Global_atexit> enter (fxn=0x236f0)
    @0,429,062us: [+0 T:0x4001fb20 S:0xbefb1b8c] OM - Memory_alloc> Enter(0x18)
    @0,429,659us: [+0 T:0x4001fb20 S:0xbefb1b8c] OM - Memory_alloc> return (0x5a410)
    @0,430,338us: [+0 T:0x4001fb20 S:0xbefb1bb4] OG - Global_atexit> enter (fxn=0x29228)
    @0,430,861us: [+6 T:0x4001fb20 S:0xbefb1bac] CE - Engine_init> CE debugging on (CE_DEBUG=3; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
    @0,431,620us: [+0 T:0x4001fb20 S:0xbefb1b9c] OG - Global_atexit> enter (fxn=0x20b84)
    @0,432,094us: [+0 T:0x4001fb20 S:0xbefb1b7c] OM - Memory_alloc> Enter(0x18)
    @0,432,572us: [+0 T:0x4001fb20 S:0xbefb1b7c] OM - Memory_alloc> return (0x5a450)
    @0,433,039us: [+0 T:0x4001fb20 S:0xbefb1b7c] OM - Memory_alloc> Enter(0x18)
    @0,433,515us: [+0 T:0x4001fb20 S:0xbefb1b7c] OM - Memory_alloc> return (0x5a470)
    @0,433,981us: [+0 T:0x4001fb20 S:0xbefb1b7c] OM - Memory_alloc> Enter(0x18)
    @0,434,457us: [+0 T:0x4001fb20 S:0xbefb1b7c] OM - Memory_alloc> return (0x5a490)
    @0,434,982us: [+0 T:0x4001fb20 S:0xbefb1bbc] CS - Server_init()
    @0,435,438us: [+0 T:0x4001fb20 S:0xbefb1bbc] CS - Server_init> Global_useLinkArbiter = 0
    @0,435,904us: [+0 T:0x4001fb20 S:0xbefb1bbc] OG - Global_atexit> enter (fxn=0x1ee64)
    @0,436,511us: [+0 T:0x4001fb20 S:0xbefb1b6c] CE - Engine_open> Enter('encode', 0x0, 0xbefb1bdc)
    @0,436,987us: [+0 T:0x4001fb20 S:0xbefb1b54] OM - Memory_alloc> Enter(0x2c)
    @0,437,459us: [+0 T:0x4001fb20 S:0xbefb1b54] OM - Memory_alloc> return (0x5a4e0)
    @0,437,924us: [+0 T:0x4001fb20 S:0xbefb1b6c] CE - rserverOpen('PhocusALG.x64P'), count = 0
    @0,438,429us: [+0 T:0x4001fb20 S:0xbefb1b34] OP - Processor_create> Enter(imageName='PhocusALG.x64P', linkCfg='(null)', attrs=0xbefb1bc0)
    @0,439,112us: [+0 T:0x4001fb20 S:0xbefb1b1c] OM - Memory_alloc> Enter(0x24)
    @0,439,906us: [+0 T:0x4001fb20 S:0xbefb1b1c] OM - Memory_alloc> return (0x5a510)
    @0,440,369us: [+0 T:0x4001fb20 S:0xbefb1b14] OP - doCmd> Enter (cmdId=1, proc=0x5a510)
    @0,440,835us: [+0 T:0x4001fb20 S:0xbefb1b04] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5a1e0]
    @0,441,671us: [+0 T:0x4001fb20 S:0xbefb1b14] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5a1e0]
    @0,442,139us: [+0 T:0x4001fb20 S:0xbefb1af4] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5a1f8] timeout[0xffffffff]
    @0,442,757us: [+1 T:0x416ed490 S:0x416ecd74] OP - daemon> thread created.
    @0,443,229us: [+0 T:0x416ed490 S:0x416ecd74] OP - getCmd_d> Enter (proc=0x416ecde8)
    @0,443,699us: [+0 T:0x416ed490 S:0x416ecd54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5a1e0] timeout[0xffffffff]
    @0,444,178us: [+0 T:0x416ed490 S:0x416ecd54] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5a1e0] status[0]
    @0,444,659us: [+0 T:0x416ed490 S:0x416ecd74] OP - getCmd_d> Exit (result=1)
    @0,445,130us: [+0 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Enter(proc=0x5a510)
    @0,445,601us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Initializing DSP PROC...
    @0,446,082us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'PhocusALG.x64P']
    @0,446,571us: [+0 T:0x416ed490 S:0x416ecd5c] OM - Memory_alloc> Enter(0xe0)
    @0,447,056us: [+0 T:0x416ed490 S:0x416ecd5c] OM - Memory_alloc> return (0x5a538)
    @0,447,588us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1, syncd=0
    @0,448,100us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1, syncd=0
    @0,448,818us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x8ff00000, sizeInBytes=0x80, shared=1, syncd=0
    @0,449,328us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x8ba00000, sizeInBytes=0x4000000, shared=0, syncd=0
    @0,450,219us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> DODSPCTRL was=1; now=0
    @0,453,156us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Attaching to DSP PROC...
    @0,458,654us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Opening MSGQ pool...
    @0,459,567us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Loading PhocusALG.x64P on DSP (1 args)...
    @0,536,850us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Starting DSP PROC...
    @0,600,452us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> Opening remote transport...
    @0,601,575us: [+2 T:0x416ed490 S:0x416ecd74] OP - Processor_create_d> return (1)
    @0,602,051us: [+0 T:0x416ed490 S:0x416ecd64] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5a1f8]
    @0,602,569us: [+0 T:0x4001fb20 S:0xbefb1af4] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5a1f8] status[0]
    @0,603,037us: [+0 T:0x4001fb20 S:0xbefb1b14] OP - doCmd> Exit (result=1)
    @0,603,496us: [+0 T:0x4001fb20 S:0xbefb1b34] OP - Processor_create> return (0x5a510)
    @0,603,961us: [+0 T:0x4001fb20 S:0xbefb1b6c] CE - rserverOpen('PhocusALG.x64P'): 0x58cb0 done.
    @0,604,432us: [+0 T:0x4001fb20 S:0xbefb1b54] OM - Memory_alloc> Enter(0x24)
    @0,604,907us: [+0 T:0x4001fb20 S:0xbefb1b54] OM - Memory_alloc> return (0x5a770)
    @0,605,768us: [+0 T:0x4001fb20 S:0xbefb1b44] OC - Comm_create> Enter(queueName='encode_441_0', queue=0x5a4f0, attrs=0x0)
    @0,606,237us: [+0 T:0x4001fb20 S:0xbefb1b2c] OM - Memory_alloc> Enter(0x4)
    @0,606,708us: [+0 T:0x4001fb20 S:0xbefb1b2c] OM - Memory_alloc> return (0x5a798)
    @0,607,421us: [+0 T:0x4001fb20 S:0xbefb1b44] OC - Comm_create> return (0x5a798)
    @0,607,887us: [+0 T:0x4001fb20 S:0xbefb1b4c] OM - Memory_free> Enter(0x5a770, 0x24)
    @0,608,410us: [+0 T:0x4001fb20 S:0xbefb1b4c] OM - Memory_free> return (0x1)
    @0,608,874us: [+0 T:0x4001fb20 S:0xbefb1b4c] OC - Comm_alloc> Enter(poolId=0x0, msg=0x5a4fc, size=576)
    @0,609,446us: [+0 T:0x4001fb20 S:0xbefb1b4c] OC - Comm_alloc> msg=0x41efd880, returning (0)
    @0,609,913us: [+0 T:0x4001fb20 S:0xbefb1b34] OC - Comm_locate> Enter(queueName='rmsq', queue=0x5a4ec)
    @0,610,693us: [+0 T:0x4001fb20 S:0xbefb1b34] OC - Comm_locate> return (0)
    @0,611,160us: [+0 T:0x4001fb20 S:0xbefb1b6c] CE - checkServer(0x5a4e0)
    @0,611,639us: [+0 T:0x4001fb20 S:0xbefb1b3c] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @0,612,162us: [+0 T:0x4001fb20 S:0xbefb1b3c] OC - Comm_put> return (0)
    @0,612,726us: [+0 T:0x4001fb20 S:0xbefb1b34] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1bd8, timeout=-1)
    @0,613,232us: [+0 T:0x4001fb20 S:0xbefb1b34] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @0,613,703us: [+0 T:0x4001fb20 S:0xbefb1b6c] CE - rmsInit> RMS initialized(0x5a4e0); CE_DEBUG on, setting DSP trace mask to *+01234567,GT_prefix=12345,GT_time=3
    @0,614,400us: [+0 T:0x4001fb20 S:0xbefb1b44] CE - Engine_setTrace> Enter(engine=0x5a4e0, mask='*+01234567,GT_prefix=12345,GT_time=3')
    @0,614,895us: [+1 T:0x4001fb20 S:0xbefb1b44] CE - Engine_setTrace> Requesting DSP set trace ...
    @0,615,653us: [+0 T:0x4001fb20 S:0xbefb1b14] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @0,616,177us: [+0 T:0x4001fb20 S:0xbefb1b14] OC - Comm_put> return (0)
    @0,616,643us: [+0 T:0x4001fb20 S:0xbefb1b0c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1b8c, timeout=-1)
    @0,617,161us: [+0 T:0x416ed490 S:0x416ecd74] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5a1f8]
    @0,617,848us: [+0 T:0x4001fb20 S:0xbefb1b0c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @0,618,327us: [+0 T:0x4001fb20 S:0xbefb1b44] CE - Engine_setTrace> return(0)
    @0,618,811us: [+0 T:0x4001fb20 S:0xbefb1ad4] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @0,619,332us: [+0 T:0x4001fb20 S:0xbefb1ad4] OC - Comm_put> return (0)
    @0,619,963us: [+0 T:0x4001fb20 S:0xbefb1acc] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1b6c, timeout=-1)
    @0,620,470us: [+0 T:0x4001fb20 S:0xbefb1acc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @0,044,964tk: [+0 T:0x8ba00784 S:0x8ba046fc] OG - Global_setSpecialTrace> enter(mask='*+01234567,GT_prefix=12345,GT_time=3')
    [DSP] @0,045,059tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG - Global_setSpecialTrace> This program was built with the following packages:
    [DSP] @0,045,119tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.targets.rts6000 (/usr/local/xdctools_3_10_03/packages/ti/targets/rts6000/) [1,0,0,0,1225517497925]
    [DSP] @0,045,195tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.global (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    [DSP] @0,045,279tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.h264fhdvenc (/home/Phocus1855/ALG/packages/unic/sdo/codecs/h264fhdvenc/) [1,0,0,1305227643000]
    [DSP] @0,045,357tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.jpegenc (/home/Phocus1855/ALG/packages/unic/sdo/codecs/jpegenc/) [1,0,0,1304714973000]
    [DSP] @0,045,433tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.yuvconvert (/home/Phocus1855/ALG/packages/unic/sdo/codecs/yuvconvert/) [1,0,0,1304714978000]
    [DSP] @0,045,510tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.hdvicp (/home/Phocus1855/ALG/packages/unic/sdo/codecs/hdvicp/) [1,0,0,1305227644000]
    [DSP] @0,045,585tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.dman3 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    [DSP] @0,045,668tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.ires.hdvicp (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/hdvicp/) [1,0,1,1240266763264]
    [DSP] @0,045,755tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.utils.trace (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    [DSP] @0,045,841tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.rtdx (/usr/local/bios_5_33_03/packages/ti/rtdx/) [2,0,0,4,1219531643983]
    [DSP] @0,045,907tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.psl (/usr/local/bios_5_33_03/packages/ti/psl/) [5,0,0,0,0]
    [DSP] @0,045,968tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.bios (/usr/local/bios_5_33_03/packages/ti/bios/) [5,2,5,6,1227035764854]
    [DSP] @0,046,033tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.dskt2 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dskt2/) [1,0,4,1240266678055]
    [DSP] @0,046,116tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.hdintc (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/hdintc/) [1,0,4,1240266707594]
    [DSP] @0,046,199tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.memutils (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    [DSP] @0,046,285tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.edma3.rm (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/fctools/packages/ti/sdo/edma3/rm/) [1,3,4,1225865844769]
    [DSP] @0,046,370tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.ires.nullresource (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/nullresource/) [1,0,0,1240266782634]
    [DSP] @0,046,462tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.rman (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/rman/) [2,0,0,1240266813533]
    [DSP] @0,046,544tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.edma3 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/edma3/) [2,0,0,1240266681138]
    [DSP] @0,046,627tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.ires.edma3chan (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/edma3chan/) [1,0,0,1240266737833]
    [DSP] @0,046,717tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.global (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    [DSP] @0,046,797tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.xdais@0,634,931us: [+0 T:0x4001fb20 S:0xbefb1ad4] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @0,635,749us: [+0 T:0x4001fb20 S:0xbefb1ad4] OC - Comm_put> return (0)
    @0,636,339us: [+0 T:0x4001fb20 S:0xbefb1acc] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1b6c, timeout=-1)
    @0,636,849us: [+0 T:0x4001fb20 S:0xbefb1acc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @0,046,871tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.xdais (/home/unic/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    [DSP] @0,046,942tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.node (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    [DSP] @0,047,021tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.ipc.dsplink.dsp (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2,0,1,1240276720026]
    [DSP] @0,047,120tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.utils.xdm (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    [DSP] @0,047,203tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.fc.acpy3 (/home/unic/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    [DSP] @0,047,286tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package dsplink.dsp (/home/unic/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/dsp/) [1,4,0,1239931280000]
    [DSP] @0,047,364tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.bios.utils (/home/unic/dvsdk_2_00_00_22/biosutils_1_01_00/packages/ti/bios/utils/) [2,0,1,0,0]
    [DSP] @0,047,438tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.catalog.c6000 (/usr/local/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    [DSP] @0,047,507tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.platforms.evmDM6467 (/usr/local/bios_5_33_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    [DSP] @0,047,580tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.osal (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    [DSP] @0,047,659tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.osal.bios (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/bios/) [2,0,1,1240276734107]
    [DSP] @0,047,742tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.ipc (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    [DSP] @0,047,820tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.ipc.bios (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/bios/) [2,0,1,1240276705217]
    [DSP] @0,047,902tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.alg (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    [DSP] @0,047,981tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    [DSP] @0,048,057tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.bioslog (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
    [DSP] @0,048,138tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.video1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
    [DSP] @0,048,218tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.h264fhdvenc.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1305227644000]
    [DSP] @0,048,299tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.image1 (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
    [DSP] @0,048,380tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.jpegenc.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/jpegenc/ce/) [1,0,0,1304714976000]
    [DSP] @0,048,458tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package ti.sdo.ce.image (/home/unic/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image/) [1,0,3,1240276700525]
    [DSP] @0,048,538tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.codecs.yuvconvert.ce (/home/Phocus1855/ALG/packages/unic/sdo/codecs/yuvconvert/ce/) [1,0,0,1304714981000]
    [DSP] @0,048,618tk: [+4 T:0x8ba00784 S:0x8ba046fc] OG -     package unic.sdo.servers.encode (/home/Phocus1855/ALG/packag@0,651,048us: [+0 T:0x4001fb20 S:0xbefb1ad4] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @0,651,586us: [+0 T:0x4001fb20 S:0xbefb1ad4] OC - Comm_put> return (0)
    @0,652,159us: [+0 T:0x4001fb20 S:0xbefb1acc] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1b6c, timeout=-1)
    @0,652,665us: [+0 T:0x4001fb20 S:0xbefb1acc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    es/unic/sdo/servers/encode/) []
    [DSP] @0,048,687tk: [+0 T:0x8ba00784 S:0x8ba046fc] OG - Global_setSpecialTrace> return
    [DSP] @0,053,924tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @0,053,981tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @0,100,652tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @0,100,707tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @0,145,769tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @0,145,822tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    @0,657,278us: [+0 T:0x4001fb20 S:0xbefb1b04] CE - Engine_fwriteTrace> returning count [9056]
    @0,657,748us: [+0 T:0x4001fb20 S:0xbefb1b6c] CE - Engine_open> return(369888)
    @0,658,212us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> Enter(size=10027008, align=-1, cached=FALSE, heap=FALSE)
    @0,659,211us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_alloc(10027008) = 0x41f6e000.
    @0,659,770us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_getPhys(0x41f6e000) = 0x8b070000.
    @0,660,239us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> Enter(virtAddr=0x41f6e000, size=10027008, physAddr=0x8b070000)
    @0,660,716us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> creating new contigBuf object
    @0,661,180us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> Enter(0x10)
    @0,661,651us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> return (0x5a7a8)
    @0,662,112us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> returning: cb->phys=0x8b070000, cb->size=10027008, cb->virt=0x41f6e000
    @0,662,802us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> return (0x41f6e000)
    @0,727,101us: [+0 T:0x4001fb20 S:0xbefb1b94] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x41f6e000, size=10027008)
    @0,727,791us: [+1 T:0x4001fb20 S:0xbefb1b94] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x41f6e000, size=10027008)
    @0,728,274us: [+1 T:0x4001fb20 S:0xbefb1b94] OM - Memory__getPhysicalAddress> found in cb(Sc=0x41f6e000, Ec=0x428fe000, Ss=0x41f6e000, Es=0x428fe000, PSc=0x8b070000)
    @0,728,760us: [+1 T:0x4001fb20 S:0xbefb1b94] OM - Memory__getPhysicalAddress> returning physAddr=0x8b070000
    @0,729,227us: [+0 T:0x4001fb20 S:0xbefb1b94] OM - Memory_getBufferPhysicalAddress> return (0x8b070000)
    @0,729,762us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> Enter(size=10027008, align=-1, cached=FALSE, heap=FALSE)
    @0,730,762us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_alloc(10027008) = 0x428fe000.
    @0,731,258us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_getPhys(0x428fe000) = 0x8a6e0000.
    @0,731,730us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> Enter(virtAddr=0x428fe000, size=10027008, physAddr=0x8a6e0000)
    @0,732,208us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> creating new contigBuf object
    @0,732,671us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> Enter(0x10)
    @0,733,146us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> return (0x5a7c0)
    @0,733,608us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> returning: cb->phys=0x8a6e0000, cb->size=10027008, cb->virt=0x428fe000
    @0,734,087us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> return (0x428fe000)
    @0,798,577us: [+0 T:0x4001fb20 S:0xbefb1b94] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x428fe000, size=10027008)
    @0,799,068us: [+1 T:0x4001fb20 S:0xbefb1b94] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x428fe000, size=10027008)
    @0,799,622us: [+1 T:0x4001fb20 S:0xbefb1b94] OM - Memory__getPhysicalAddress> found in cb(Sc=0x428fe000, Ec=0x4328e000, Ss=0x428fe000, Es=0x4328e000, PSc=0x8a6e0000)
    @0,800,109us: [+1 T:0x4001fb20 S:0xbefb1b94] OM - Memory__getPhysicalAddress> returning physAddr=0x8a6e0000
    @0,800,578us: [+0 T:0x4001fb20 S:0xbefb1b94] OM - Memory_getBufferPhysicalAddress> return (0x8a6e0000)
    @0,801,051us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> Enter(size=10027008, align=-1, cached=FALSE, heap=FALSE)
    @0,802,054us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_alloc(10027008) = 0x4328e000.
    @0,802,554us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_getPhys(0x4328e000) = 0x89d50000.
    @0,803,026us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> Enter(virtAddr=0x4328e000, size=10027008, physAddr=0x89d50000)
    @0,803,509us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> creating new contigBuf object
    @0,803,971us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> Enter(0x10)
    @0,804,440us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> return (0x5a7d8)
    @0,804,901us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> returning: cb->phys=0x89d50000, cb->size=10027008, cb->virt=0x4328e000
    @0,805,638us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> return (0x4328e000)
    @0,869,863us: [+0 T:0x4001fb20 S:0xbefb1b94] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x4328e000, size=10027008)
    @0,870,554us: [+1 T:0x4001fb20 S:0xbefb1b94] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x4328e000, size=10027008)
    @0,871,035us: [+1 T:0x4001fb20 S:0xbefb1b94] OM - Memory__getPhysicalAddress> found in cb(Sc=0x4328e000, Ec=0x43c1e000, Ss=0x4328e000, Es=0x43c1e000, PSc=0x89d50000)
    @0,871,526us: [+1 T:0x4001fb20 S:0xbefb1b94] OM - Memory__getPhysicalAddress> returning physAddr=0x89d50000
    @0,871,994us: [+0 T:0x4001fb20 S:0xbefb1b94] OM - Memory_getBufferPhysicalAddress> return (0x89d50000)
    @0,872,465us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> Enter(size=10027008, align=-1, cached=FALSE, heap=FALSE)
    @0,873,455us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_alloc(10027008) = 0x43c1e000.
    @0,873,950us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_getPhys(0x43c1e000) = 0x893c0000.
    @0,874,421us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> Enter(virtAddr=0x43c1e000, size=10027008, physAddr=0x893c0000)
    @0,874,898us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> creating new contigBuf object
    @0,875,360us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> Enter(0x10)
    @0,875,832us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> return (0x5a7f0)
    @0,876,362us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> returning: cb->phys=0x893c0000, cb->size=10027008, cb->virt=0x43c1e000
    @0,876,845us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> return (0x43c1e000)
    @0,941,416us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> Enter(size=2048, align=-1, cached=FALSE, heap=FALSE)
    @0,942,191us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_alloc(2048) = 0x445ae000.
    @0,942,690us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_getPhys(0x445ae000) = 0x88db6000.
    @0,943,158us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> Enter(virtAddr=0x445ae000, size=2048, physAddr=0x88db6000)
    @0,943,634us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> creating new contigBuf object
    @0,944,096us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> Enter(0x10)
    @0,944,568us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> return (0x5a808)
    @0,945,029us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> returning: cb->phys=0x88db6000, cb->size=2048, cb->virt=0x445ae000
    @0,945,506us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> return (0x445ae000)
    @0,946,060us: [+0 T:0x4001fb20 S:0xbefb1ba4] ti.sdo.ce.image1.IMGENC1 - IMGENC1_create> Enter (engine=0x5a4e0, name='jpegenc', params=0x58078)
    @0,946,564us: [+0 T:0x4001fb20 S:0xbefb1b74] CV - VISA_create(0x5a4e0, 'jpegenc', 0x58078, 0x700, 'ti.sdo.ce.image1.IIMGENC1')
    @0,947,042us: [+0 T:0x4001fb20 S:0xbefb1a74] CV - VISA_create2(0x5a4e0, 'jpegenc', 0x58078, 0x24, 0x700, 'ti.sdo.ce.image1.IIMGENC1')
    @0,947,544us: [+0 T:0x4001fb20 S:0xbefb1a5c] OM - Memory_alloc> Enter(0x30)
    @0,948,014us: [+0 T:0x4001fb20 S:0xbefb1a5c] OM - Memory_alloc> return (0x5a870)
    @0,948,479us: [+0 T:0x4001fb20 S:0xbefb19fc] CE - Engine_createNode(0x5a4e0, 'jpegenc', 700, 0x58078, 0x24, 0xbefb1b6c)
    @0,949,171us: [+0 T:0x4001fb20 S:0xbefb19fc] CE - Engine> allocNode Enter(engine=0x5a4e0, impId='jpegenc')
    @0,949,715us: [+0 T:0x4001fb20 S:0xbefb19e4] OM - Memory_alloc> Enter(0x20)
    @0,950,493us: [+0 T:0x4001fb20 S:0xbefb19e4] OM - Memory_alloc> return (0x5a770)
    @0,950,985us: [+0 T:0x4001fb20 S:0xbefb19fc] CE - Engine> allocNode(). Calling Comm_create(gppfromnode_441_1, 0x5a778, NULL)
    @0,951,453us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_create> Enter(queueName='gppfromnode_441_1', queue=0x5a778, attrs=0x0)
    @0,951,930us: [+0 T:0x4001fb20 S:0xbefb19bc] OM - Memory_alloc> Enter(0x4)
    @0,952,399us: [+0 T:0x4001fb20 S:0xbefb19bc] OM - Memory_alloc> return (0x5a8a8)
    @0,953,124us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_create> return (0x5a8a8)
    @0,953,596us: [+0 T:0x4001fb20 S:0xbefb19dc] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @0,954,122us: [+0 T:0x4001fb20 S:0xbefb19dc] OC - Comm_put> return (0)
    @0,954,588us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1a84, timeout=-1)
    @0,955,115us: [+0 T:0x416ed490 S:0x416ecd74] OP - getCmd_d> Enter (proc=0x416ecde8)
    @0,955,593us: [+0 T:0x416ed490 S:0x416ecd54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5a1e0] timeout[0xffffffff]
    @0,956,293us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @0,956,772us: [+0 T:0x4001fb20 S:0xbefb19dc] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @0,957,296us: [+0 T:0x4001fb20 S:0xbefb19dc] OC - Comm_put> return (0)
    @0,957,868us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1a84, timeout=-1)
    @0,958,628us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @0,959,096us: [+4 T:0x4001fb20 S:0xbefb19fc] CE - Engine_createNode> created node(stdIn=0x2, stdOut=0x10001, msgq=0x5a8a8, algName='jpegenc', rmsNode=0x8fa9edb8, algHandle=0x8fa9eea0)
    @0,959,984us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @0,960,504us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @0,961,078us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @0,961,590us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @1,007,288tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 0
    [DSP] @1,007,347tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> Enter(size=0x18)
    [DSP] @1,007,397tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> return (0x8fa9edb8)
    [DSP] @1,007,447tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> Enter(size=0xa)
    [DSP] @1,007,493tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> return (0x8fa9edd0)
    [DSP] @1,007,547tk: [+0 T:0x8ba00784 S:0x8ba045fc] OM - Memory_alloc> Enter(size=0x20)
    [DSP] @1,007,594tk: [+0 T:0x8ba00784 S:0x8ba045fc] OM - Memory_alloc> return (0x8fa9ede0)
    [DSP] @1,007,643tk: [+0 T:0x8ba00784 S:0x8ba045cc] OM - Memory_alloc> Enter(size=0x24)
    [DSP] @1,007,689tk: [+0 T:0x8ba00784 S:0x8ba045cc] OM - Memory_alloc> return (0x8fa9ee00)
    [DSP] @1,007,779tk: [+0 T:0x8ba00784 S:0x8ba045e4] ti.sdo.ce.image1.IMGENC1 - IMGENC1_create> Enter (engine=0x0, name='jpegenc', params=0x8fe038c0)
    [DSP] @1,007,861tk: [+0 T:0x8ba00784 S:0x8ba045ac] CV - VISA_create(0x0, 'jpegenc', 0x8fe038c0, 0x700, 'ti.sdo.ce.image1.IIMGENC1')
    [DSP] @1,007,932tk: [+0 T:0x8ba00784 S:0x8ba0449c] CV - VISA_create2(0x0, 'jpegenc', 0x8fe038c0, 0x24, 0x700, 'ti.sdo.ce.image1.IIMGENC1')
    [DSP] @1,008,010tk: [+0 T:0x8ba00784 S:0x8ba04434] CE - Engine_open> Enter('local', 0x8ba04484, 0x8fe038c0)
    [DSP] @1,008,072tk: [+0 T:0x8ba00784 S:0x8ba04414] OM - Memory_alloc> Enter(size=0x2c)
    [DSP] @1,008,117tk: [+0 T:0x8ba00784 S:0x8ba04414] OM - Memory_alloc> return (0x8fa9ee70)
    [DSP] @1,008,173tk: [+0 T:0x8ba00784 S:0x8ba04434] CE - Engine_open> return(-1884688784)
    [DSP] @1,008,233tk: [+0 T:0x8ba00784 S:0x8ba0447c] OM - Memory_alloc> Enter(size=0x30)
    [DSP] @1,008,279tk: [+0 T:0x8ba00784 S:0x8ba0447c] OM - Memory_alloc> return (0x8fa9eea0)
    [DSP] @1,008,331tk: [+0 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fa9d4e4, idma3Fxns=0x0, iresFxns=0x0, params=0x8fe038c0, attrs=0x8ba04598)
    [DSP] @1,008,421tk: [+0 T:0x8ba00784 S:0x8ba04434] OM - Memory_alloc> Enter(size=0x10)
    [DSP] @1,008,467tk: [+0 T:0x8ba00784 S:0x8ba04434] OM - Memory_alloc> return (0x8fa9eed0)
    [DSP] @1,008,534tk: [+0 T:0x8ba00784 S:0x8ba04414] ti.sdo.fc.dskt2 - _DSKT2_init> Enter
    [DSP] @1,008,605tk: [+0 T:0x8ba00784 S:0x8ba04414] ti.sdo.fc.dskt2 - _DSKT2_init> Exit
    [DSP] @1,008,649tk: [+0 T:0x8ba00784 S:0x8ba04424] ti.sdo.fc.dskt2 - DSKT2_createAlg> Enter (scratchId=0, fxns=0x8fa9d4e4, parentAlg=0x0, params=0x8fe038c0)
    [DSP] @1,008,726tk: [+0 T:0x8ba00784 S:0x8ba043ac] ti.sdo.fc.dskt2 - _DSKT2_init> Enter
    [DSP] @1,008,771tk: [+0 T:0x8ba00784 S:0x8ba043ac] ti.sdo.fc.dskt2 - _DSKT2_init> Exit
    [DSP] @1,008,815tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Enter (scratchId=0, fxns=0x8fa9d4e4, parentAlg=0x0, params=0x8fe038c0, extHeapId=-1881130816, singleHeap=0)
    [DSP] @1,008,911tk: [+2 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> DSKT2_AlgAttrs extHeapId -1 and singleHeap 0
    [DSP] @1,008,980tk: [+2 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Num memory recs requested 8
    [DSP] @1,009,040tk: [+2 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> memTab allocated at 0x8ba05470 size=0xa0
    [DSP] @1,009,108tk: [+2 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Num memory recs requested 5
    [DSP] @1,009,169tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Requested memTab[0]: size=0x260, align=0x8, space=IALG_EXTERNAL, attrs=IALG_PERSIST
    [DSP] @1,009,249tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Requested memTab[1]: size=0xe00, align=0x8, space=IALG_EXTERNAL, attrs=IALG_SCRATCH
    [DSP] @1,009,328tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Requested memTab[2]: size=0x253, align=0x8, space=IALG_EXTERNAL, attrs=IALG_PERSIST
    [DSP] @1,009,406tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Requested memTab[3]: size=0x1400, align=0x8, space=IALG_EXTERNAL, attrs=IALG_SCRATCH
    [DSP] @1,009,485tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Requested memTab[4]: size=0xe54, align=0x80, space=IALG_EXTERNAL, attrs=IALG_PERSIST
    [DSP] @1,009,568tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - _@0,980,604us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @0,981,135us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @0,982,007us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @0,982,516us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    DSKT2_assignInstanceMemory> Enter (scratchId=0, numRecs=5, extHeapId=0)
    [DSP] @1,009,634tk: [+0 T:0x8ba00784 S:0x8ba0435c] ti.sdo.fc.dskt2 - _DSKT2_usesInternalScratch> Enter (numRecs=5)
    [DSP] @1,009,692tk: [+0 T:0x8ba00784 S:0x8ba0435c] ti.sdo.fc.dskt2 - _DSKT2_usesInternalScratch> Exit (returnVal=0)
    [DSP] @1,009,752tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @1,009,831tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @1,009,889tk: [+2 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba05510
    [DSP] @1,009,974tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=1, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @1,010,102tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @1,010,159tk: [+2 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[1] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba05770
    [DSP] @1,010,246tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=2, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @1,010,322tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @1,010,380tk: [+2 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[2] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba06570
    [DSP] @1,010,465tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=3, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @1,010,580tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @1,010,637tk: [+2 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[3] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba067c8
    [DSP] @1,010,722tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=4, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @1,010,822tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @1,010,880tk: [+2 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[4] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba07c00
    [DSP] @1,010,965tk: [+0 T:0x8ba00784 S:0x8ba0435c] ti.sdo.fc.dskt2 - _DSKT2_usesInternalScratch> Enter (numRecs=5)
    [DSP] @1,011,020tk: [+0 T:0x8ba00784 S:0x8ba0435c] ti.sdo.fc.dskt2 - _DSKT2_usesInternalScratch> Exit (returnVal=0)
    [DSP] @1,011,076tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @1,011,133tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Allocated memTab[0]: base=0x8ba05510, size=0x260, align=0x8, space=IALG_EXTERNAL, attrs=IALG_PERSIST
    [DSP] @1,011,221tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Allocated memTab[1]: base=0x8ba05770, size=0xe00, align=0x8, space=IALG_EXTERNAL, attrs=IALG_PERSIST
    [DSP] @1,011,309tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Allocated memTab[2]: base=0x8ba06570, size=0x253, align=0x8, space=IALG_EXTERNAL, attrs=IALG_PERSIST
    [DSP] @1,011,397tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Allocated memTab[3]: base=0x8ba067c8, size=0x1400, align=0x8, space=IALG_EXTERNAL, attrs=IALG_PERSIST
    [DSP] @1,011,486tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Allocated memTab[4]: base=0x8ba07c00, size=0xe54, align=0x80, space=IALG_EXTERNAL, attrs=IALG_PERSIST
    [DSP] @1,011,576tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_enqueueMemTab> Enter (segId=0, memTabSize=160, numRecs=5, extHeapId=0)
    [DSP] @1,011,663tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_enqueueMemTab> Exit (status=TRUE)
    [DSP] @1,011,811tk: [+4 T@0,998,491us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @0,999,016us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @0,999,668us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,000,174us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    :0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Algorithm init successful.
    [DSP] @1,011,866tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Exit (algHandle=0x8ba05510)
    [DSP] @1,011,924tk: [+0 T:0x8ba00784 S:0x8ba04424] ti.sdo.fc.dskt2 - DSKT2_createAlg> Exit (algHandle=0x8ba05510)
    [DSP] @1,011,986tk: [+0 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x8fa9eed0)
    [DSP] @1,012,047tk: [+5 T:0x8ba00784 S:0x8ba0449c] CV - VISA_create> local codec created (name='jpegenc', handle=0x8fa9eed0)
    [DSP] @1,012,111tk: [+0 T:0x8ba00784 S:0x8ba045e4] ti.sdo.ce.image1.IMGENC1 - IMGENC_create> return (0x8fa9eea0)
    [DSP] @1,012,178tk: [+4 T:0x8ba00784 S:0x8ba045a4] OT - Thread_create > name: "jpegenc#0", pri:  -1, stack size:  16384, stack seg: 0
    [DSP] @1,016,335tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 1
    [DSP] @1,025,460tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,025,517tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @1,084,211tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,084,266tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @1,135,127tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,135,181tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    @1,007,733us: [+0 T:0x4001fb20 S:0xbefb1994] CE - Engine_fwriteTrace> returning count [9947]
    @1,008,202us: [+2 T:0x4001fb20 S:0xbefb19fc] CE - Engine_createNode> Returning 0x5a770
    @1,008,879us: [+0 T:0x4001fb20 S:0xbefb1a5c] OM - Memory_alloc> Enter(0x4)
    @1,009,420us: [+0 T:0x4001fb20 S:0xbefb1a5c] OM - Memory_alloc> return (0x5a8b8)
    @1,010,184us: [+0 T:0x4001fb20 S:0xbefb1a54] OC - Comm_alloc> Enter(poolId=0x0, msg=0x5a8b8, size=700)
    @1,010,688us: [+0 T:0x4001fb20 S:0xbefb1a54] OC - Comm_alloc> msg=0x41efe880, returning (0)
    @1,011,170us: [+5 T:0x4001fb20 S:0xbefb1a74] CV - VISA_create> remote codec created (name='jpegenc', localQueueID=0x10001, remoteQueueID=0x0002)
    @1,011,656us: [+0 T:0x4001fb20 S:0xbefb1ba4] ti.sdo.ce.image1.IMGENC1 - IMGENC_create> return (0x5a870)
    500W
    @1,012,483us: [+0 T:0x4001fb20 S:0xbefb1b4c] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Enter (handle=0x5a870, id=1, dynParams=0x57d04 (size=0x44), status=0x57d48 (size=0xa0)
    @1,012,982us: [+5 T:0x4001fb20 S:0xbefb1b1c] CV - VISA_allocMsg> Allocating message for messageId=0x00025562
    @1,013,458us: [+0 T:0x4001fb20 S:0xbefb1aec] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x445ae000, size=128)
    @1,013,932us: [+1 T:0x4001fb20 S:0xbefb1aec] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x445ae000, size=128)
    @1,014,406us: [+1 T:0x4001fb20 S:0xbefb1aec] OM - Memory__getPhysicalAddress> found in cb(Sc=0x445ae000, Ec=0x445ae800, Ss=0x445ae000, Es=0x445ae080, PSc=0x88db6000)
    @1,015,234us: [+1 T:0x4001fb20 S:0xbefb1aec] OM - Memory__getPhysicalAddress> returning physAddr=0x88db6000
    @1,015,703us: [+0 T:0x4001fb20 S:0xbefb1aec] OM - Memory_getBufferPhysicalAddress> return (0x88db6000)
    @1,016,175us: [+0 T:0x4001fb20 S:0xbefb1afc] CV - VISA_call(visa=0x5a870, msg=0x41efe880): messageId=0x00025562, command=0x1
    @1,016,651us: [+0 T:0x4001fb20 S:0xbefb1ac4] OC - Comm_put> Enter(queue=0x2, msg=0x41efe880)
    @1,017,175us: [+0 T:0x4001fb20 S:0xbefb1ac4] OC - Comm_put> return (0)
    @1,017,644us: [+0 T:0x4001fb20 S:0xbefb1abc] OC - Comm_get> Enter(queue=0x10001, msg=0xbefb1b64, timeout=-1)
    @1,018,269us: [+0 T:0x4001fb20 S:0xbefb1abc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @1,018,751us: [+0 T:0x4001fb20 S:0xbefb1a4c] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,019,274us: [+0 T:0x4001fb20 S:0xbefb1a4c] OC - Comm_put> return (0)
    @1,019,921us: [+0 T:0x4001fb20 S:0xbefb1a44] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1ae4, timeout=-1)
    @1,020,426us: [+0 T:0x4001fb20 S:0xbefb1a44] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @1,186,840tk: [+5 T:0x8ba08a64 S:0x8ba0ca2c] CN - NODE> 0x8fa9ede0(jpegenc#0) call(algHandle=0x8fa9eea0, msg=0x8fe04880); messageId=0x00025562
    [DSP] @1,186,929tk: [+0 T:0x8ba08a64 S:0x8ba0c854] OM - Memory_cacheInv> Enter(addr=0x88db6000, sizeInBytes=128)
    [DSP] @1,186,990tk: [+0 T:0x8ba08a64 S:0x8ba0c854] OM - Memory_cacheInv> return
    [DSP] @1,187,036tk: [+0 T:0x8ba08a64 S:0x8ba0c7fc] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Enter (handle=0x8fa9eea0, id=1, dynParams=0x8fe048b4 (size=0x44), status=0x8fe048f8 (size=0xa0)
    [DSP] @1,187,141tk: [+5 T:0x8ba08a64 S:0x8ba0c7dc] CV - VISA_enter(visa=0x8fa9eea0): algHandle = 0x8fa9eed0
    [DSP] @1,187,203tk: [+0 T:0x8ba08a64 S:0x8ba0c7bc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x8fa9eed0)
    [DSP] @1,187,266tk: [+0 T:0x8ba08a64 S:0x8ba0c794] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Enter (scratchId=0, alg=0x8ba05510)
    [DSP] @1,187,332tk: [+2 T:0x8ba08a64 S:0x8ba0c794] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Last active algorithm 0x0, current algorithm to be activated 0x8ba05510
    [DSP] @1,187,409tk: [+4 T:0x8ba08a64 S:0x8ba0c794] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Real activation of algorithm 0x8ba05510
    [DSP] @1,187,473tk: [+0 T:0x8ba08a64 S:0x8ba0c794] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Exit
    [DSP] @1,187,520tk: [+0 T:0x8ba08a64 S:0x8ba0c7bc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
    [DSP] @1,187,684tk: [+5 T:0x8ba08a64 S:0x8ba0c7dc] CV - VISA_exit(visa=0x8fa9eea0): algHandle = 0x8fa9eed0
    [DSP] @1,187,746tk: [+0 T:0x8ba08a64 S:0x8ba0c7bc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x8fa9eed0)
    [DSP] @1,187,808tk: [+0 T:0x8ba08a64 S:0x8ba0c79c] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Enter (scratchId=0, algHandle=0x8ba05510)
    [DSP] @1,187,874tk: [+4 T:0x8ba08a64 S:0x8ba0c79c] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Lazy deactivate of algorithm 0x8ba05510
    [DSP] @1,187,938tk: [+0 T:0x8ba08a64 S:0x8ba0c79c] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Exit
    [DSP] @1,187,986tk: [+0 T:0x8ba08a64 S:0x8ba0c7bc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
    [DSP] @1,188,041tk: [+0 T:0x8ba08a64 S:0x8ba0c7fc] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Exit (handle=0x8fa9eea0, retVal=0x0)
    [DSP] @1,188,108tk: [+5 T:0x8ba08a64 S:0x8ba0ca2c] CN - NODE> returned from call(algHandle=0x8fa9eea0, msg=0x8fe04880); messageId=0x00025562
    [DSP] @1,192,823tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,192,878tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    @1,032,323us: [+0 T:0x4001fb20 S:0xbefb1a7c] CE - Engine_fwriteTrace> returning count [2526]
    @1,032,793us: [+0 T:0x4001fb20 S:0xbefb1afc] CV - VISA_call Completed: messageId=0x00025562, command=0x1, return(status=0)
    @1,033,275us: [+5 T:0x4001fb20 S:0xbefb1b04] CV - VISA_freeMsg(0x5a870, 0x41efe880): Freeing message with messageId=0x00025562
    @1,033,755us: [+0 T:0x4001fb20 S:0xbefb1b4c] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Exit (handle=0x5a870, retVal=0x0)
    @1,034,234us: [+0 T:0x4001fb20 S:0xbefb1b4c] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Enter (handle=0x5a870, id=5, dynParams=0x57d04 (size=0x44), status=0x57d48 (size=0xa0)
    @1,034,729us: [+5 T:0x4001fb20 S:0xbefb1b1c] CV - VISA_allocMsg> Allocating message for messageId=0x00025563
    @1,035,203us: [+0 T:0x4001fb20 S:0xbefb1aec] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x445ae000, size=128)
    @1,035,679us: [+1 T:0x4001fb20 S:0xbefb1aec] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x445ae000, size=128)
    @1,036,362us: [+1 T:0x4001fb20 S:0xbefb1aec] OM - Memory__getPhysicalAddress> found in cb(Sc=0x445ae000, Ec=0x445ae800, Ss=0x445ae000, Es=0x445ae080, PSc=0x88db6000)
    @1,036,850us: [+1 T:0x4001fb20 S:0xbefb1aec] OM - Memory__getPhysicalAddress> returning physAddr=0x88db6000
    @1,037,613us: [+0 T:0x4001fb20 S:0xbefb1aec] OM - Memory_getBufferPhysicalAddress> return (0x88db6000)
    @1,038,083us: [+0 T:0x4001fb20 S:0xbefb1afc] CV - VISA_call(visa=0x5a870, msg=0x41efe880): messageId=0x00025563, command=0x1
    @1,038,564us: [+0 T:0x4001fb20 S:0xbefb1ac4] OC - Comm_put> Enter(queue=0x2, msg=0x41efe880)
    @1,039,091us: [+0 T:0x4001fb20 S:0xbefb1ac4] OC - Comm_put> return (0)
    @1,039,749us: [+0 T:0x4001fb20 S:0xbefb1abc] OC - Comm_get> Enter(queue=0x10001, msg=0xbefb1b64, timeout=-1)
    @1,040,256us: [+0 T:0x4001fb20 S:0xbefb1abc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @1,040,740us: [+0 T:0x4001fb20 S:0xbefb1a4c] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,041,262us: [+0 T:0x4001fb20 S:0xbefb1a4c] OC - Comm_put> return (0)
    @1,041,841us: [+0 T:0x4001fb20 S:0xbefb1a44] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1ae4, timeout=-1)
    @1,042,351us: [+0 T:0x4001fb20 S:0xbefb1a44] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @1,249,250tk: [+5 T:0x8ba08a64 S:0x8ba0ca2c] CN - NODE> 0x8fa9ede0(jpegenc#0) call(algHandle=0x8fa9eea0, msg=0x8fe04880); messageId=0x00025563
    [DSP] @1,249,331tk: [+0 T:0x8ba08a64 S:0x8ba0c854] OM - Memory_cacheInv> Enter(addr=0x88db6000, sizeInBytes=128)
    [DSP] @1,249,391tk: [+0 T:0x8ba08a64 S:0x8ba0c854] OM - Memory_cacheInv> return
    [DSP] @1,249,435tk: [+0 T:0x8ba08a64 S:0x8ba0c7fc] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Enter (handle=0x8fa9eea0, id=5, dynParams=0x8fe048b4 (size=0x44), status=0x8fe048f8 (size=0xa0)
    [DSP] @1,249,533tk: [+5 T:0x8ba08a64 S:0x8ba0c7dc] CV - VISA_enter(visa=0x8fa9eea0): algHandle = 0x8fa9eed0
    [DSP] @1,249,594tk: [+0 T:0x8ba08a64 S:0x8ba0c7bc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x8fa9eed0)
    [DSP] @1,249,653tk: [+0 T:0x8ba08a64 S:0x8ba0c794] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Enter (scratchId=0, alg=0x8ba05510)
    [DSP] @1,249,716tk: [+2 T:0x8ba08a64 S:0x8ba0c794] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Last active algorithm 0x8ba05510, current algorithm to be activated 0x8ba05510
    [DSP] @1,249,796tk: [+2 T:0x8ba08a64 S:0x8ba0c794] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Activation of algorithm 0x8ba05510 not required, already active
    [DSP] @1,249,867tk: [+0 T:0x8ba08a64 S:0x8ba0c794] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Exit
    [DSP] @1,249,913tk: [+0 T:0x8ba08a64 S:0x8ba0c7bc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
    [DSP] @1,249,977tk: [+5 T:0x8ba08a64 S:0x8ba0c7dc] CV - VISA_exit(visa=0x8fa9eea0): algHandle = 0x8fa9eed0
    [DSP] @1,250,035tk: [+0 T:0x8ba08a64 S:0x8ba0c7bc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x8fa9eed0)
    [DSP] @1,250,095tk: [+0 T:0x8ba08a64 S:0x8ba0c79c] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Enter (scratchId=0, algHandle=0x8ba05510)
    [DSP] @1,250,159tk: [+4 T:0x8ba08a64 S:0x8ba0c79c] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Lazy deactivate of algorithm 0x8ba05510
    [DSP] @1,250,223tk: [+0 T:0x8ba08a64 S:0x8ba0c79c] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Exit
    [DSP] @1,250,270tk: [+0 T:0x8ba08a64 S:0x8ba0c7bc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
    [DSP] @1,250,322tk: [+0 T:0x8ba08a64 S:0x8ba0c7fc] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Exit (handle=0x8fa9eea0, retVal=0x0)
    [DSP] @1,250,387tk: [+5 T:0x8ba08a64 S:0x8ba0ca2c] CN - NODE> returned from call(algHandle=0x8fa9eea0, msg=0x8fe04880); messageId=0x00025563
    [DSP] @1,255,431tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,255,485tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    @1,054,036us: [+0 T:0x4001fb20 S:0xbefb1a7c] CE - Engine_fwriteTrace> returning count [2557]
    @1,054,509us: [+0 T:0x4001fb20 S:0xbefb1afc] CV - VISA_call Completed: messageId=0x00025563, command=0x1, return(status=0)
    @1,054,993us: [+5 T:0x4001fb20 S:0xbefb1b04] CV - VISA_freeMsg(0x5a870, 0x41efe880): Freeing message with messageId=0x00025563
    @1,055,473us: [+0 T:0x4001fb20 S:0xbefb1b4c] ti.sdo.ce.image1.IMGENC1 - IMGENC1_control> Exit (handle=0x5a870, retVal=0x0)
    @1,056,016us: [+0 T:0x4001fb20 S:0xbefb1ba4] ti.sdo.ce.image.IMGENC - IMGENC_create> Enter (engine=0x5a4e0, name='yuvconvert', params=0x580b0)
    @1,056,501us: [+0 T:0x4001fb20 S:0xbefb1b74] CV - VISA_create(0x5a4e0, 'yuvconvert', 0x580b0, 0x828, 'ti.sdo.ce.image.IIMGENC')
    @1,056,985us: [+0 T:0x4001fb20 S:0xbefb1a74] CV - VISA_create2(0x5a4e0, 'yuvconvert', 0x580b0, 0x0, 0x828, 'ti.sdo.ce.image.IIMGENC')
    @1,057,486us: [+0 T:0x4001fb20 S:0xbefb1a5c] OM - Memory_alloc> Enter(0x30)
    @1,057,963us: [+0 T:0x4001fb20 S:0xbefb1a5c] OM - Memory_alloc> return (0x5a8f8)
    @1,058,429us: [+0 T:0x4001fb20 S:0xbefb19fc] CE - Engine_createNode(0x5a4e0, 'yuvconvert', 828, 0x580b0, 0x0, 0xbefb1b6c)
    @1,058,914us: [+0 T:0x4001fb20 S:0xbefb19fc] CE - Engine> allocNode Enter(engine=0x5a4e0, impId='yuvconvert')
    @1,059,683us: [+0 T:0x4001fb20 S:0xbefb19e4] OM - Memory_alloc> Enter(0x20)
    @1,060,155us: [+0 T:0x4001fb20 S:0xbefb19e4] OM - Memory_alloc> return (0x5a930)
    @1,060,647us: [+0 T:0x4001fb20 S:0xbefb19fc] CE - Engine> allocNode(). Calling Comm_create(gppfromnode_441_2, 0x5a938, NULL)
    @1,061,115us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_create> Enter(queueName='gppfromnode_441_2', queue=0x5a938, attrs=0x0)
    @1,061,593us: [+0 T:0x4001fb20 S:0xbefb19bc] OM - Memory_alloc> Enter(0x4)
    @1,062,063us: [+0 T:0x4001fb20 S:0xbefb19bc] OM - Memory_alloc> return (0x5a958)
    @1,063,080us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_create> return (0x5a958)
    @1,063,565us: [+0 T:0x4001fb20 S:0xbefb19dc] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,064,090us: [+0 T:0x4001fb20 S:0xbefb19dc] OC - Comm_put> return (0)
    @1,064,554us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1a84, timeout=-1)
    @1,070,025us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @1,070,500us: [+0 T:0x4001fb20 S:0xbefb19dc] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,071,024us: [+0 T:0x4001fb20 S:0xbefb19dc] OC - Comm_put> return (0)
    @1,071,600us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1a84, timeout=-1)
    @1,072,110us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @1,072,578us: [+4 T:0x4001fb20 S:0xbefb19fc] CE - Engine_createNode> created node(stdIn=0x3, stdOut=0x10002, msgq=0x5a958, algName='yuvconvert', rmsNode=0x8fa9ef00, algHandle=0x8fa9ef98)
    @1,073,092us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,073,618us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,074,194us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,074,703us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @1,320,440tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 0
    [DSP] @1,320,499tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> Enter(size=0x18)
    [DSP] @1,320,552tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> return (0x8fa9ef00)
    [DSP] @1,320,603tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> Enter(size=0xd)
    [DSP] @1,320,651tk: [+0 T:0x8ba00784 S:0x8ba04634] OM - Memory_alloc> return (0x8fa9ef18)
    [DSP] @1,320,703tk: [+0 T:0x8ba00784 S:0x8ba045fc] OM - Memory_alloc> Enter(size=0x20)
    [DSP] @1,320,750tk: [+0 T:0x8ba00784 S:0x8ba045fc] OM - Memory_alloc> return (0x8fa9ef28)
    [DSP] @1,320,799tk: [+0 T:0x8ba00784 S:0x8ba045cc] OM - Memory_alloc> Enter(size=0x24)
    [DSP] @1,320,845tk: [+0 T:0x8ba00784 S:0x8ba045cc] OM - Memory_alloc> return (0x8fa9ef48)
    [DSP] @1,320,927tk: [+0 T:0x8ba00784 S:0x8ba045e4] ti.sdo.ce.image.IMGENC - IMGENC_create> Enter (engine=0x0, name='yuvconvert', params=0x0)
    [DSP] @1,321,007tk: [+0 T:0x8ba00784 S:0x8ba045ac] CV - VISA_create(0x0, 'yuvconvert', 0x0, 0x828, 'ti.sdo.ce.image.IIMGENC')
    [DSP] @1,321,072tk: [+0 T:0x8ba00784 S:0x8ba0449c] CV - VISA_create2(0x0, 'yuvconvert', 0x0, 0x0, 0x828, 'ti.sdo.ce.image.IIMGENC')
    [DSP] @1,321,153tk: [+0 T:0x8ba00784 S:0x8ba0447c] OM - Memory_alloc> Enter(size=0x30)
    [DSP] @1,321,200tk: [+0 T:0x8ba00784 S:0x8ba0447c] OM - Memory_alloc> return (0x8fa9ef98)
    [DSP] @1,321,252tk: [+0 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fa9df18, idma3Fxns=0x8fa9df4c, iresFxns=0x0, params=0x0, attrs=0x8ba04598)
    [DSP] @1,321,342tk: [+0 T:0x8ba00784 S:0x8ba04434] OM - Memory_alloc> Enter(size=0x10)
    [DSP] @1,321,388tk: [+0 T:0x8ba00784 S:0x8ba04434] OM - Memory_alloc> return (0x8fa9efc8)
    [DSP] @1,321,441tk: [+0 T:0x8ba00784 S:0x8ba04414] ti.sdo.fc.dskt2 - _DSKT2_init> Enter
    [DSP] @1,321,486tk: [+0 T:0x8ba00784 S:0x8ba04414] ti.sdo.fc.dskt2 - _DSKT2_init> Exit
    [DSP] @1,321,530tk: [+0 T:0x8ba00784 S:0x8ba04424] ti.sdo.fc.dskt2 - DSKT2_createAlg> Enter (scratchId=0, fxns=0x8fa9df18, parentAlg=0x0, params=0x0)
    [DSP] @1,321,603tk: [+0 T:0x8ba00784 S:0x8ba043ac] ti.sdo.fc.dskt2 - _DSKT2_init> Enter
    [DSP] @1,321,648tk: [+0 T:0x8ba00784 S:0x8ba043ac] ti.sdo.fc.dskt2 - _DSKT2_init> Exit
    [DSP] @1,321,693tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Enter (scratchId=0, fxns=0x8fa9df18, parentAlg=0x0, params=0x0, extHeapId=0, singleHeap=0)
    [DSP] @1,321,777tk: [+2 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> DSKT2_AlgAttrs extHeapId -1 and singleHeap 0
    [DSP] @1,321,845tk: [+2 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> AlgNumAlloc not implemented
    [DSP] @1,321,904tk: [+2 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> memTab allocated at 0x8ba0cab8 size=0x50
    [DSP] @1,321,981tk: [+0 T:0x8ba00784 S:0x8ba04394] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_alloc(0x0, 0x8ba0cab8, 0x8fa9efc8)
    [DSP] @1,322,049tk: [+2 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Num memory recs requested 1
    [DSP] @1,322,108tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Requested memTab[0]: size=0x14, align=0x0, space=IALG_EXTERNAL, attrs=IALG_PERSIST
    [DSP] @1,322,189tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=0, numRecs=1, extHeapId=0)
    [DSP] @1,322,255tk: [+0 T:0x8ba00784 S:0x8ba0435c] ti.sdo.fc.dskt2 - _DSKT2_usesInternalScratch> Enter (numRecs=1)
    [DSP] @1,322,311tk: [+0 T:0x8ba00784 S:0x8ba0435c] ti.sdo.fc.dskt2 - _DSKT2_usesInternalScratch> Exit (returnVal=0)
    [DSP] @1,322,372tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @1,322,447tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @1,322,505tk: [+2 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba07be0
    [DSP] @1,322,591tk: [+0 T:0x8ba00784 S:0x8ba0435c] ti.sdo.fc.dskt2 - _DSKT2_usesInternalScratch> Enter (numRecs=1)
    [DSP] @1,322,646tk: [+0 T:0x8ba00784 S:0x8ba0435c] ti.sdo.fc.dskt2 - _DSKT2_usesInternalScrat@1,094,042us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,094,575us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,095,152us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,095,660us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @1,322,702tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @1,322,759tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Allocated memTab[0]: base=0x8ba07be0, size=0x14, align=0x0, space=IALG_EXTERNAL, attrs=IALG_PERSIST
    [DSP] @1,322,849tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_enqueueMemTab> Enter (segId=0, memTabSize=80, numRecs=1, extHeapId=0)
    [DSP] @1,322,928tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_enqueueMemTab> Exit (status=TRUE)
    [DSP] @1,322,984tk: [+0 T:0x8ba00784 S:0x8ba0439c] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_initObj(0x8ba07be0, 0x0, 0x8fb364a1, 0x8fb364a1)
    [DSP] @1,323,059tk: [+4 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Algorithm init successful.
    [DSP] @1,323,113tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_createAlg3> Exit (algHandle=0x8ba07be0)
    [DSP] @1,323,172tk: [+0 T:0x8ba00784 S:0x8ba04424] ti.sdo.fc.dskt2 - DSKT2_createAlg> Exit (algHandle=0x8ba07be0)
    [DSP] @1,323,236tk: [+0 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Enter (groupId=0, algHandle=0x8fa9efc8, dmaFxns=0x8ba044ac, numAlgs=1)
    [DSP] @1,323,350tk: [+0 T:0x8ba00784 S:0x8ba043d4] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_dmaGetChannels(0x8ba07be0, 0x8ba0cb20)
    [DSP] @1,323,422tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Alg 0x8ba07be0:
    [DSP] @1,323,478tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Total Channels requested 4, PaRams requested 4, Tccs requested 4
    [DSP] @1,323,554tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dman3 - getContext> Enter (pContext=0x8ba04480, groupId=0, nTccs=4, nPaRams=4)
    [DSP] @1,323,625tk: [+2 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dman3 - getContext> Context exists for groupId 0, context 0x8ba00120
    [DSP] @1,323,690tk: [+2 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dman3 - getContext> Creating context for group 0 Tccs 4 PaRams 4
    [DSP] @1,323,752tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dman3 - createContext> Enter (pContext=0x8ba04428, groupId=0, nTccs=4, nPaRams=4)
    [DSP] @1,323,823tk: [+2 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dman3 - createContext> Allocate memory for the context
    [DSP] @1,323,880tk: [+2 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dman3 - createContext> Allocate 32 tccs
    [DSP] @1,323,941tk: [+2 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dman3 - createContext> Next free tcc index 0
    [DSP] @1,323,996tk: [+2 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dman3 - createContext> Allocate 48 paRams
    [DSP] @1,324,051tk: [+2 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dman3 - createContext> NextpaRam index 80
    [DSP] @1,324,103tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dman3 - createContext> Exit (status=0)
    [DSP] @1,324,153tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dman3 - getContext> Exit (status=DMAN3_SOK)
    [DSP] @1,324,204tk: [+2 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Context 0x8ba00120
    [DSP] @1,324,263tk: [+0 T:0x8ba00784 S:0x8ba043d4] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_dmaGetChannels(0x8ba07be0, 0x8ba0cb20)
    [DSP] @1,324,331tk: [+0 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Enter (context=0x8ba00120, alg=0x8ba07be0, groupId=0, dmaTab=0x8ba0cb20, numChans=4)
    [DSP] @1,324,418tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Channel 0
    [DSP] @1,324,470tk: [+0 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x8ba0cb20, memRec=0x8ba043dc)
    [DSP] @1,324,537tk: [+2 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> memRec size0x40, alignment 0x20 memType IDMA3_INTERNAL
    [DSP] @1,324,603tk: [+0 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
    [DSP] @1,324,653tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[0]: size=0x40, align=0x20, space=IALG_SCRATCH, attrs=IALG_DARAM0
    [DSP] @1,324,734tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Channel 1
    [DSP] @1,324,782tk: [+0 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x8ba0cb38, memRec=0x8ba043dc)
    [DSP] @1,324,848tk: [+2 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc@1,114,364us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,114,892us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,115,468us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,115,973us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @1,324,914tk: [+0 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
    [DSP] @1,324,961tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[1]: size=0x40, align=0x20, space=IALG_SCRATCH, attrs=IALG_DARAM0
    [DSP] @1,325,039tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Channel 2
    [DSP] @1,325,087tk: [+0 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x8ba0cb50, memRec=0x8ba043dc)
    [DSP] @1,325,153tk: [+2 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> memRec size0x40, alignment 0x20 memType IDMA3_INTERNAL
    [DSP] @1,325,219tk: [+0 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
    [DSP] @1,325,265tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[2]: size=0x40, align=0x20, space=IALG_SCRATCH, attrs=IALG_DARAM0
    [DSP] @1,325,344tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Channel 3
    [DSP] @1,325,392tk: [+0 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x8ba0cb68, memRec=0x8ba043dc)
    [DSP] @1,325,458tk: [+2 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> memRec size0x40, alignment 0x20 memType IDMA3_INTERNAL
    [DSP] @1,325,524tk: [+0 T:0x8ba00784 S:0x8ba04324] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
    [DSP] @1,325,571tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[3]: size=0x40, align=0x20, space=IALG_SCRATCH, attrs=IALG_DARAM0
    [DSP] @1,325,662tk: [+0 T:0x8ba00784 S:0x8ba042f4] ti.sdo.fc.dskt2 - DSKT2_allocScratch> Enter (alg=0x8ba07be0, mutexId=0, numRecs=4)
    [DSP] @1,325,738tk: [+0 T:0x8ba00784 S:0x8ba042ac] ti.sdo.fc.dskt2 - _DSKT2_getReqScratchSize> Enter (ialgSpace=IALG_DARAM0, numRecs=4)
    [DSP] @1,325,807tk: [+0 T:0x8ba00784 S:0x8ba042ac] ti.sdo.fc.dskt2 - _DSKT2_getReqScratchSize> Exit (size=0x180)
    [DSP] @1,325,866tk: [+0 T:0x8ba00784 S:0x8ba04264] ti.sdo.fc.dskt2 - _DSKT2_initializeAndUseSharedScratch> Enter (scratchGroupId=0, numRecs=1)
    [DSP] @1,325,943tk: [+0 T:0x8ba00784 S:0x8ba04214] ti.sdo.fc.dskt2 - _DSKT2_getScratchRequestInfo> Enter (ialgSpace=IALG_DARAM0, numRecs=1)
    [DSP] @1,326,010tk: [+0 T:0x8ba00784 S:0x8ba04214] ti.sdo.fc.dskt2 - _DSKT2_getScratchRequestInfo> Exit (sizeBestCase=384, sizeWorstCase=384, numScratchRecs=1)
    [DSP] @1,326,132tk: [+0 T:0x8ba00784 S:0x8ba04244] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> Enter (scrBuffDesc->base=0x11818000)
    [DSP] @1,326,197tk: [+0 T:0x8ba00784 S:0x8ba04244] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> Exit (status=TRUE)
    [DSP] @1,326,254tk: [+0 T:0x8ba00784 S:0x8ba04244] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> Enter (scrBuffDesc->base=0x11818000)
    [DSP] @1,326,318tk: [+0 T:0x8ba00784 S:0x8ba04244] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> Exit (status=TRUE)
    [DSP] @1,326,378tk: [+0 T:0x8ba00784 S:0x8ba04264] ti.sdo.fc.dskt2 - _DSKT2_initializeAndUseSharedScratch> Exit
    [DSP] @1,326,435tk: [+0 T:0x8ba00784 S:0x8ba042a4] ti.sdo.fc.dskt2 - _DSKT2_getScratchUsed> Enter (alg=0x8ba07be0, mutexId=0, heapId=0)
    [DSP] @1,326,509tk: [+0 T:0x8ba00784 S:0x8ba042a4] ti.sdo.fc.dskt2 - _DSKT2_getScratchUsed> Exit (size=0x0)
    [DSP] @1,326,562tk: [+0 T:0x8ba00784 S:0x8ba042d4] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> Enter (scrBuffDesc->base=0x11818000)
    [DSP] @1,326,625tk: [+0 T:0x8ba00784 S:0x8ba042d4] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> Exit (status=TRUE)
    [DSP] @1,326,680tk: [+0 T:0x8ba00784 S:0x8ba042d4] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> Enter (scrBuffDesc->base=0x11818000)
    [DSP] @1,326,744tk: [+0 T:0x8ba00784 S:0x8ba042d4] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> Exit (status=TRUE)
    [DSP] @1,326,798tk: [+0 T:0x8ba00784 S:0x8ba042d4] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> Enter (scrBuffDesc->base=0x11818000)
    [DSP] @1,326,861tk: [+0 T:0x8ba00784 S:0x8ba042d4] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> Exit (status=TRUE)
    [DSP] @1,326,916tk: [+0 T:0x8ba00784 S:0x8ba042d4] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> Enter (scrBuffDesc->base=0x11818000)
    [DSP] @1,326,979tk: [+0 T:0x8ba00784 S:0x8ba042d4] ti.sdo.fc.dskt2 - _DSKT2_useSharedScratch> E@1,134,354us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,135,094us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,135,679us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,136,185us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    xit (status=TRUE)
    [DSP] @1,327,036tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - _DSKT2_incrScratchReferenceCount> Enter (scratchMutexId=0)
    [DSP] @1,327,098tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - _DSKT2_incrScratchReferenceCount> Exit
    [DSP] @1,327,151tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - _DSKT2_incrScratchReferenceCount> Enter (scratchMutexId=0)
    [DSP] @1,327,211tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - _DSKT2_incrScratchReferenceCount> Exit
    [DSP] @1,327,264tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - _DSKT2_incrScratchReferenceCount> Enter (scratchMutexId=0)
    [DSP] @1,327,324tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - _DSKT2_incrScratchReferenceCount> Exit
    [DSP] @1,327,377tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - _DSKT2_incrScratchReferenceCount> Enter (scratchMutexId=0)
    [DSP] @1,327,438tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - _DSKT2_incrScratchReferenceCount> Exit
    [DSP] @1,327,490tk: [+0 T:0x8ba00784 S:0x8ba042f4] ti.sdo.fc.dskt2 - DSKT2_allocScratch Exit (status=1)
    [DSP] @1,327,548tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Creating channel 0, size 0x40, align 0x20, scratchEnv 0x11818000
    [DSP] @1,327,622tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[0]: size=0x28, align=0x4 heapId=0
    [DSP] @1,327,696tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[0]: size=0x28, align=0x4, heapId=0, base=0x8ba0ce70
    [DSP] @1,327,776tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 0
    [DSP] @1,327,830tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
    [DSP] @1,327,888tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[0]: size=0x40, align=0x20, heapId=0, base=0x8ba0cea0
    [DSP] @1,327,975tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
    [DSP] @1,328,029tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x8ba0ce70, dmaTab=0x8ba0cb20, qdmaChannel=0, env=0x8ba0cea0, scratchEnv=0x11818000, context=0x8ba00120)
    [DSP] @1,328,131tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 0, env 0x8ba0cea0
    [DSP] @1,328,207tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
    [DSP] @1,328,257tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> paRam block 0x1c04a00, tcc Table 0x8ba00030
    [DSP] @1,328,322tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
    [DSP] @1,328,375tk: [+0 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x8ba0ce70)
    [DSP] @1,328,431tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initialize ACPY3
    [DSP] @1,328,482tk: [+0 T:0x8ba00784 S:0x8ba042a4] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
    [DSP] @1,328,529tk: [+0 T:0x8ba00784 S:0x8ba0428c] ti.sdo.fc.acpy3 - initQdmaSettings> Enter
    [DSP] @1,328,576tk: [+2 T:0x8ba00784 S:0x8ba0428c] ti.sdo.fc.acpy3 - initQdmaSettings> Unlock all Qdma channels
    [DSP] @1,328,629tk: [+0 T:0x8ba00784 S:0x8ba0428c] ti.sdo.fc.acpy3 - initQdmaSettings > Exit
    [DSP] @1,328,675tk: [+0 T:0x8ba00784 S:0x8ba042a4] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
    [DSP] @1,328,720tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Scratch env 0x11818020
    [DSP] @1,328,775tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Address of env in persistent memory 0x8ba0cec0
    [DSP] @1,328,840tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initializing IPRH register to 0x0
    [DSP] @1,328,897tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initializing IPR mask to 0x1
    [DSP] @1,328,953tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> IPR clear masks 0x0 and 0x1
    [DSP] @1,329,008tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Saving original values of Tccs (1) PaRams (1) and waitIdofFinal (-1)
    [DSP] @1,329,077tk: [+0 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
    @1,155,046us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,155,569us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,156,145us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,156,652us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @1,329,127tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
    [DSP] @1,329,178tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):0
    [DSP] @1,329,233tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
    [DSP] @1,329,284tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> dmaTab[0].handle's paRamAddr 0x1c04a00
    [DSP] @1,329,346tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> 80 (Addr 0x1c04a00)
    [DSP] @1,329,400tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
    [DSP] @1,329,451tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> 32
    [DSP] @1,329,498tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Creating channel 1, size 0x40, align 0x20, scratchEnv 0x11818040
    [DSP] @1,329,571tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[1]: size=0x28, align=0x4 heapId=0
    [DSP] @1,329,641tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[1]: size=0x28, align=0x4, heapId=0, base=0x8ba0cee0
    [DSP] @1,329,720tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 1
    [DSP] @1,329,773tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
    [DSP] @1,329,831tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[1]: size=0x40, align=0x20, heapId=0, base=0x8ba0cf20
    [DSP] @1,329,908tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
    [DSP] @1,329,961tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x8ba0cee0, dmaTab=0x8ba0cb38, qdmaChannel=1, env=0x8ba0cf20, scratchEnv=0x11818040, context=0x8ba00120)
    [DSP] @1,330,062tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 1, env 0x8ba0cf20
    [DSP] @1,330,138tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
    [DSP] @1,330,188tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> paRam block 0x1c04a20, tcc Table 0x8ba00031
    [DSP] @1,330,257tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
    [DSP] @1,330,310tk: [+0 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x8ba0cee0)
    [DSP] @1,330,365tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initialize ACPY3
    [DSP] @1,330,415tk: [+0 T:0x8ba00784 S:0x8ba042a4] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
    [DSP] @1,330,460tk: [+0 T:0x8ba00784 S:0x8ba042a4] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
    [DSP] @1,330,505tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Scratch env 0x11818060
    [DSP] @1,330,559tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Address of env in persistent memory 0x8ba0cf40
    [DSP] @1,330,622tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initializing IPRH register to 0x0
    [DSP] @1,330,678tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initializing IPR mask to 0x2
    [DSP] @1,330,733tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> IPR clear masks 0x0 and 0x2
    [DSP] @1,330,788tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Saving original values of Tccs (1) PaRams (1) and waitIdofFinal (-1)
    [DSP] @1,330,858tk: [+0 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
    [DSP] @1,330,908tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
    [DSP] @1,330,956tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):1
    [DSP] @1,331,010tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
    [DSP] @1,331,060tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> dmaTab[1].handle's paRamAddr 0x1c04a20
    [DSP] @1,331,121tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> 81 (Addr 0x1c04a20)
    [DSP] @1,331,176tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned Tc@1,175,642us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,176,173us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,176,750us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,177,256us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    c(s):
    [DSP] @1,331,225tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> 33
    [DSP] @1,331,272tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Creating channel 2, size 0x40, align 0x20, scratchEnv 0x11818080
    [DSP] @1,331,344tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[2]: size=0x28, align=0x4 heapId=0
    [DSP] @1,331,415tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[2]: size=0x28, align=0x4, heapId=0, base=0x8ba0cf60
    [DSP] @1,331,493tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 2
    [DSP] @1,331,546tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
    [DSP] @1,331,605tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[2]: size=0x40, align=0x20, heapId=0, base=0x8ba0cfa0
    [DSP] @1,331,681tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
    [DSP] @1,331,734tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x8ba0cf60, dmaTab=0x8ba0cb50, qdmaChannel=2, env=0x8ba0cfa0, scratchEnv=0x11818080, context=0x8ba00120)
    [DSP] @1,331,836tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 2, env 0x8ba0cfa0
    [DSP] @1,331,911tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
    [DSP] @1,331,961tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> paRam block 0x1c04a40, tcc Table 0x8ba00032
    [DSP] @1,332,025tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
    [DSP] @1,332,077tk: [+0 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x8ba0cf60)
    [DSP] @1,332,132tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initialize ACPY3
    [DSP] @1,332,182tk: [+0 T:0x8ba00784 S:0x8ba042a4] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
    [DSP] @1,332,226tk: [+0 T:0x8ba00784 S:0x8ba042a4] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
    [DSP] @1,332,271tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Scratch env 0x118180a0
    [DSP] @1,332,326tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Address of env in persistent memory 0x8ba0cfc0
    [DSP] @1,332,389tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initializing IPRH register to 0x0
    [DSP] @1,332,445tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initializing IPR mask to 0x4
    [DSP] @1,332,499tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> IPR clear masks 0x0 and 0x4
    [DSP] @1,332,554tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Saving original values of Tccs (1) PaRams (1) and waitIdofFinal (-1)
    [DSP] @1,332,627tk: [+0 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
    [DSP] @1,332,677tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
    [DSP] @1,332,726tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):2
    [DSP] @1,332,780tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
    [DSP] @1,332,830tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> dmaTab[2].handle's paRamAddr 0x1c04a40
    [DSP] @1,332,891tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> 82 (Addr 0x1c04a40)
    [DSP] @1,332,945tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
    [DSP] @1,332,995tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> 34
    [DSP] @1,333,042tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Creating channel 3, size 0x40, align 0x20, scratchEnv 0x118180c0
    [DSP] @1,333,114tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[3]: size=0x28, align=0x4 heapId=0
    [DSP] @1,333,184tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[3]: size=0x28, align=0x4, heapId=0, base=0x8ba0cfe0
    [DSP] @1,333,263tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createCha@1,195,899us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,196,429us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,197,297us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,197,800us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    nnels> Assigning qdmaChannel 3
    [DSP] @1,333,316tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
    [DSP] @1,333,374tk: [+4 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[3]: size=0x40, align=0x20, heapId=0, base=0x8ba0d020
    [DSP] @1,333,451tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
    [DSP] @1,333,504tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x8ba0cfe0, dmaTab=0x8ba0cb68, qdmaChannel=3, env=0x8ba0d020, scratchEnv=0x118180c0, context=0x8ba00120)
    [DSP] @1,333,605tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 3, env 0x8ba0d020
    [DSP] @1,333,681tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
    [DSP] @1,333,731tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> paRam block 0x1c04a60, tcc Table 0x8ba00033
    [DSP] @1,333,795tk: [+2 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
    [DSP] @1,333,847tk: [+0 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x8ba0cfe0)
    [DSP] @1,333,903tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initialize ACPY3
    [DSP] @1,333,953tk: [+0 T:0x8ba00784 S:0x8ba042a4] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
    [DSP] @1,333,998tk: [+0 T:0x8ba00784 S:0x8ba042a4] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
    [DSP] @1,334,042tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Scratch env 0x118180e0
    [DSP] @1,334,096tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Address of env in persistent memory 0x8ba0d040
    [DSP] @1,334,160tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initializing IPRH register to 0x0
    [DSP] @1,334,216tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Initializing IPR mask to 0x8
    [DSP] @1,334,270tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> IPR clear masks 0x0 and 0x8
    [DSP] @1,334,325tk: [+2 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Saving original values of Tccs (1) PaRams (1) and waitIdofFinal (-1)
    [DSP] @1,334,395tk: [+0 T:0x8ba00784 S:0x8ba042c4] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
    [DSP] @1,334,445tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
    [DSP] @1,334,494tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):3
    [DSP] @1,334,548tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
    [DSP] @1,334,598tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> dmaTab[3].handle's paRamAddr 0x1c04a60
    [DSP] @1,334,659tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> 83 (Addr 0x1c04a60)
    [DSP] @1,334,713tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
    [DSP] @1,334,763tk: [+2 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> 35
    [DSP] @1,334,815tk: [+0 T:0x8ba00784 S:0x8ba04354] ti.sdo.fc.dman3 - createChannels> Exit (status=0)
    [DSP] @1,334,869tk: [+0 T:0x8ba00784 S:0x8ba043c4] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_dmaInit(0x8ba07be0, 0x8ba0cb20)
    [DSP] @1,334,939tk: [+0 T:0x8ba00784 S:0x8ba043c4] unic.sdo.codecs.yuvconvert - dmaHandle[0] = 8ba0ce70
    [DSP] @1,334,993tk: [+0 T:0x8ba00784 S:0x8ba043c4] unic.sdo.codecs.yuvconvert - dmaHandle[1] = 8ba0cee0
    [DSP] @1,335,047tk: [+0 T:0x8ba00784 S:0x8ba043c4] unic.sdo.codecs.yuvconvert - dmaHandle[2] = 8ba0cf60
    [DSP] @1,335,101tk: [+0 T:0x8ba00784 S:0x8ba043c4] unic.sdo.codecs.yuvconvert - dmaHandle[3] = 8ba0cfe0
    [DSP] @1,335,156tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 0
    [DSP] @1,335,209tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
    [DSP] @1,335,261tk: [+2 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[0].handle's paRamAddr 0x1c04a00
    [DSP] @1,335,325tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> 80 (Addr 0x1c04a00)
    [DSP] @1,335,382tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_creat@1,217,065us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,217,812us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,218,672us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,219,196us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @1,335,434tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> 32
    [DSP] @1,335,482tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 1
    [DSP] @1,335,535tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
    [DSP] @1,335,588tk: [+2 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[1].handle's paRamAddr 0x1c04a20
    [DSP] @1,335,651tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> 81 (Addr 0x1c04a20)
    [DSP] @1,335,707tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
    [DSP] @1,335,759tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> 33
    [DSP] @1,335,807tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 2
    [DSP] @1,335,860tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
    [DSP] @1,335,912tk: [+2 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[2].handle's paRamAddr 0x1c04a40
    [DSP] @1,335,976tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> 82 (Addr 0x1c04a40)
    [DSP] @1,336,032tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
    [DSP] @1,336,084tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> 34
    [DSP] @1,336,132tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 3
    [DSP] @1,336,184tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
    [DSP] @1,336,237tk: [+2 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[3].handle's paRamAddr 0x1c04a60
    [DSP] @1,336,300tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> 83 (Addr 0x1c04a60)
    [DSP] @1,336,357tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
    [DSP] @1,336,409tk: [+4 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_createChannels> 35
    [DSP] @1,336,459tk: [+0 T:0x8ba00784 S:0x8ba043f4] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Exit (status=0)
    [DSP] @1,336,517tk: [+0 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x8fa9efc8)
    [DSP] @1,336,582tk: [+5 T:0x8ba00784 S:0x8ba0449c] CV - VISA_create> local codec created (name='yuvconvert', handle=0x8fa9efc8)
    [DSP] @1,336,648tk: [+0 T:0x8ba00784 S:0x8ba045e4] ti.sdo.ce.image.IMGENC - IMGENC_create> return (0x8fa9ef98)
    [DSP] @1,336,714tk: [+4 T:0x8ba00784 S:0x8ba045a4] OT - Thread_create > name: "yuvconvert#1", pri:  -1, stack size:  9216, stack seg: 0
    [DSP] @1,340,201tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 1
    [DSP] @1,347,570tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,347,627tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @1,407,247tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,407,302tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @1,465,107tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,465,161tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @1,522,632tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,522,687tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @1,580,941tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,580,995tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @1,639,614tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,639,668tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @1,697,294tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,697,348tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @1,758,182tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd@1,239,595us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,240,126us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,240,699us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,241,418us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
     = 5
    [DSP] @1,758,237tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @1,821,728tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,821,782tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    @1,243,911us: [+0 T:0x4001fb20 S:0xbefb1994] CE - Engine_fwriteTrace> returning count [34280]
    @1,244,382us: [+2 T:0x4001fb20 S:0xbefb19fc] CE - Engine_createNode> Returning 0x5a930
    @1,244,848us: [+0 T:0x4001fb20 S:0xbefb1a5c] OM - Memory_alloc> Enter(0x4)
    @1,245,318us: [+0 T:0x4001fb20 S:0xbefb1a5c] OM - Memory_alloc> return (0x5a968)
    @1,245,780us: [+0 T:0x4001fb20 S:0xbefb1a54] OC - Comm_alloc> Enter(poolId=0x0, msg=0x5a968, size=828)
    @1,246,287us: [+0 T:0x4001fb20 S:0xbefb1a54] OC - Comm_alloc> msg=0x41eff880, returning (0)
    @1,246,765us: [+5 T:0x4001fb20 S:0xbefb1a74] CV - VISA_create> remote codec created (name='yuvconvert', localQueueID=0x10002, remoteQueueID=0x0003)
    @1,247,249us: [+0 T:0x4001fb20 S:0xbefb1ba4] ti.sdo.ce.image.IMGENC - IMGENC_create> return (0x5a8f8)
    @1,247,719us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> Enter(size=3133440, align=-1, cached=FALSE, heap=FALSE)
    @1,248,430us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_alloc(3133440) = 0x445be000.
    @1,248,920us: [+4 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> CMEM_getPhys(0x445be000) = 0x890c3000.
    @1,249,454us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> Enter(virtAddr=0x445be000, size=3133440, physAddr=0x890c3000)
    @1,250,148us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> creating new contigBuf object
    @1,250,611us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> Enter(0x10)
    @1,251,383us: [+0 T:0x4001fb20 S:0xbefb1b24] OM - Memory_alloc> return (0x5a978)
    @1,251,843us: [+1 T:0x4001fb20 S:0xbefb1b3c] OM - Memory__addContigBuf> returning: cb->phys=0x890c3000, cb->size=3133440, cb->virt=0x445be000
    @1,252,321us: [+0 T:0x4001fb20 S:0xbefb1b84] OM - Memory_contigAlloc> return (0x445be000)
    @1,272,658us: [+0 T:0x4001fb20 S:0xbefb1b5c] ti.sdo.ce.image.IMGENC - IMGENC_control> Enter (handle=0x5a8f8, id=0, dynParams=0x580c8 (size=0x24), status=0x580ec (size=0x94)
    @1,273,162us: [+5 T:0x4001fb20 S:0xbefb1b34] CV - VISA_allocMsg> Allocating message for messageId=0x00035522
    @1,273,633us: [+0 T:0x4001fb20 S:0xbefb1b14] CV - VISA_call(visa=0x5a8f8, msg=0x41eff880): messageId=0x00035522, command=0x1
    @1,274,112us: [+0 T:0x4001fb20 S:0xbefb1adc] OC - Comm_put> Enter(queue=0x3, msg=0x41eff880)
    @1,274,636us: [+0 T:0x4001fb20 S:0xbefb1adc] OC - Comm_put> return (0)
    @1,275,211us: [+0 T:0x4001fb20 S:0xbefb1ad4] OC - Comm_get> Enter(queue=0x10002, msg=0xbefb1b7c, timeout=-1)
    @1,275,717us: [+0 T:0x4001fb20 S:0xbefb1ad4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @1,276,198us: [+0 T:0x4001fb20 S:0xbefb1a64] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,276,720us: [+0 T:0x4001fb20 S:0xbefb1a64] OC - Comm_put> return (0)
    @1,277,296us: [+0 T:0x4001fb20 S:0xbefb1a5c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1afc, timeout=-1)
    @1,277,802us: [+0 T:0x4001fb20 S:0xbefb1a5c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @1,920,002tk: [+5 T:0x8ba0cb2c S:0x8ba0f3d4] CN - NODE> 0x8fa9ef28(yuvconvert#1) call(algHandle=0x8fa9ef98, msg=0x8fe05880); messageId=0x00035522
    [DSP] @1,920,090tk: [+0 T:0x8ba0cb2c S:0x8ba0f31c] ti.sdo.ce.image.IMGENC - IMGENC_control> Enter (handle=0x8fa9ef98, id=0, dynParams=0x8fe058b4 (size=0x24), status=0x8fe058d8 (size=0x94)
    [DSP] @1,920,195tk: [+5 T:0x8ba0cb2c S:0x8ba0f2fc] CV - VISA_enter(visa=0x8fa9ef98): algHandle = 0x8fa9efc8
    [DSP] @1,920,257tk: [+0 T:0x8ba0cb2c S:0x8ba0f2dc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x8fa9efc8)
    [DSP] @1,920,319tk: [+0 T:0x8ba0cb2c S:0x8ba0f2b4] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Enter (scratchId=0, alg=0x8ba07be0)
    [DSP] @1,920,388tk: [+2 T:0x8ba0cb2c S:0x8ba0f2b4] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Last active algorithm 0x8ba05510, current algorithm to be activated 0x8ba07be0
    [DSP] @1,920,468tk: [+4 T:0x8ba0cb2c S:0x8ba0f2b4] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Real deactivation of algorithm 0x8ba05510
    [DSP] @1,920,536tk: [+0 T:0x8ba0cb2c S:0x8ba0f2b4] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Exit
    [DSP] @1,920,582tk: [+0 T:0x8ba0cb2c S:0x8ba0f2dc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
    [DSP] @1,920,635tk: [+0 T:0x8ba0cb2c S:0x8ba0f2dc] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_control(0x8ba07be0, 0x8fe058b4, 0x8fe058d8, 0x8fa9efc8)
    [DSP] @1,920,719tk: [+5 T:0x8ba0cb2c S:0x8ba0f2fc] CV - VISA_exit(visa=0x8fa9ef98): algHandle = 0x8fa9efc8
    [DSP] @1,920,779tk: [+0 T:0x8ba0cb2c S:0x8ba0f2dc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x8fa9efc8)
    [DSP] @1,920,840tk: [+0 T:0x8ba0cb2c S:0x8ba0f2bc] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Enter (scratchId=0, algHandle=0x8ba07be0)
    [DSP] @1,920,905tk: [+4 T:0x8ba0cb2c S:0x8ba0f2bc] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Lazy deactivate of algorithm 0x8ba07be0
    [DSP] @1,920,969tk: [+0 T:0x8ba0cb2c S:0x8ba0f2bc] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Exit
    [DSP] @1,921,017tk: [+0 T:0x8ba0cb2c S:0x8ba0f2dc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
    [DSP] @1,921,070tk: [+0 T:0x8ba0cb2c S:0x8ba0f31c] ti.sdo.ce.image.IMGENC - IMGENC_control> Exit (handle=0x8fa9ef98, retVal=0x0)
    [DSP] @1,921,134tk: [+5 T:0x8ba0cb2c S:0x8ba0f3d4] CN - NODE> returned from call(algHandle=0x8fa9ef98, msg=0x8fe05880); messageId=0x00035522
    [DSP] @1,925,937tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,925,992tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    @1,289,073us: [+0 T:0x4001fb20 S:0xbefb1a94] CE - Engine_fwriteTrace> returning count [2489]
    @1,289,611us: [+0 T:0x4001fb20 S:0xbefb1b14] CV - VISA_call Completed: messageId=0x00035522, command=0x1, return(status=0)
    @1,290,092us: [+5 T:0x4001fb20 S:0xbefb1b1c] CV - VISA_freeMsg(0x5a8f8, 0x41eff880): Freeing message with messageId=0x00035522
    @1,290,573us: [+0 T:0x4001fb20 S:0xbefb1b5c] ti.sdo.ce.image.IMGENC - IMGENC_control> Exit (handle=0x5a8f8, retVal=0x0)
    @1,291,055us: [+0 T:0x4001fb20 S:0xbefb1b5c] ti.sdo.ce.image.IMGENC - IMGENC_control> Enter (handle=0x5a8f8, id=1, dynParams=0x580c8 (size=0x24), status=0x580ec (size=0x94)
    @1,291,550us: [+5 T:0x4001fb20 S:0xbefb1b34] CV - VISA_allocMsg> Allocating message for messageId=0x00035523
    @1,292,024us: [+0 T:0x4001fb20 S:0xbefb1b14] CV - VISA_call(visa=0x5a8f8, msg=0x41eff880): messageId=0x00035523, command=0x1
    @1,292,712us: [+0 T:0x4001fb20 S:0xbefb1adc] OC - Comm_put> Enter(queue=0x3, msg=0x41eff880)
    @1,293,235us: [+0 T:0x4001fb20 S:0xbefb1adc] OC - Comm_put> return (0)
    @1,294,101us: [+0 T:0x4001fb20 S:0xbefb1ad4] OC - Comm_get> Enter(queue=0x10002, msg=0xbefb1b7c, timeout=-1)
    @1,294,606us: [+0 T:0x4001fb20 S:0xbefb1ad4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @1,295,085us: [+0 T:0x4001fb20 S:0xbefb1a64] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,295,607us: [+0 T:0x4001fb20 S:0xbefb1a64] OC - Comm_put> return (0)
    @1,296,177us: [+0 T:0x4001fb20 S:0xbefb1a5c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1afc, timeout=-1)
    @1,296,680us: [+0 T:0x4001fb20 S:0xbefb1a5c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @1,972,959tk: [+5 T:0x8ba0cb2c S:0x8ba0f3d4] CN - NODE> 0x8fa9ef28(yuvconvert#1) call(algHandle=0x8fa9ef98, msg=0x8fe05880); messageId=0x00035523
    [DSP] @1,973,044tk: [+0 T:0x8ba0cb2c S:0x8ba0f31c] ti.sdo.ce.image.IMGENC - IMGENC_control> Enter (handle=0x8fa9ef98, id=1, dynParams=0x8fe058b4 (size=0x24), status=0x8fe058d8 (size=0x94)
    [DSP] @1,973,140tk: [+5 T:0x8ba0cb2c S:0x8ba0f2fc] CV - VISA_enter(visa=0x8fa9ef98): algHandle = 0x8fa9efc8
    [DSP] @1,973,201tk: [+0 T:0x8ba0cb2c S:0x8ba0f2dc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x8fa9efc8)
    [DSP] @1,973,260tk: [+0 T:0x8ba0cb2c S:0x8ba0f2b4] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Enter (scratchId=0, alg=0x8ba07be0)
    [DSP] @1,973,322tk: [+2 T:0x8ba0cb2c S:0x8ba0f2b4] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Last active algorithm 0x8ba07be0, current algorithm to be activated 0x8ba07be0
    [DSP] @1,973,403tk: [+2 T:0x8ba0cb2c S:0x8ba0f2b4] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Activation of algorithm 0x8ba07be0 not required, already active
    [DSP] @1,973,474tk: [+0 T:0x8ba0cb2c S:0x8ba0f2b4] ti.sdo.fc.dskt2 - DSKT2_activateAlg> Exit
    [DSP] @1,973,521tk: [+0 T:0x8ba0cb2c S:0x8ba0f2dc] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
    [DSP] @1,973,571tk: [+0 T:0x8ba0cb2c S:0x8ba0f2dc] unic.sdo.codecs.yuvconvert - YUVCONVERT_UN_control(0x8ba07be0, 0x8fe058b4, 0x8fe058d8, 0x8fa9efc8)
    [DSP] @1,973,660tk: [+0 T:0x8ba0cb2c S:0x8ba0f2ac] unic.sdo.codecs.yuvconvert - g_pInternalBuf = 11828000
    [DSP] @1,973,747tk: [+5 T:0x8ba0cb2c S:0x8ba0f2fc] CV - VISA_exit(visa=0x8fa9ef98): algHandle = 0x8fa9efc8
    [DSP] @1,973,806tk: [+0 T:0x8ba0cb2c S:0x8ba0f2dc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x8fa9efc8)
    [DSP] @1,973,866tk: [+0 T:0x8ba0cb2c S:0x8ba0f2bc] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Enter (scratchId=0, algHandle=0x8ba07be0)
    [DSP] @1,973,930tk: [+4 T:0x8ba0cb2c S:0x8ba0f2bc] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Lazy deactivate of algorithm 0x8ba07be0
    [DSP] @1,973,994tk: [+0 T:0x8ba0cb2c S:0x8ba0f2bc] ti.sdo.fc.dskt2 - DSKT2_deactivateAlg> Exit
    [DSP] @1,974,041tk: [+0 T:0x8ba0cb2c S:0x8ba0f2dc] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
    [DSP] @1,974,094tk: [+0 T:0x8ba0cb2c S:0x8ba0f31c] ti.sdo.ce.image.IMGENC - IMGENC_control> Exit (handle=0x8fa9ef98, retVal=0x0)
    [DSP] @1,974,157tk: [+5 T:0x8ba0cb2c S:0x8ba0f3d4] CN - NODE> returned from call(algHandle=0x8fa9ef98, msg=0x8fe05880); messageId=0x00035523
    [DSP] @1,979,721tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @1,979,777tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    @1,308,292us: [+0 T:0x4001fb20 S:0xbefb1a94] CE - Engine_fwriteTrace> returning count [2617]
    @1,309,054us: [+0 T:0x4001fb20 S:0xbefb1b14] CV - VISA_call Completed: messageId=0x00035523, command=0x1, return(status=0)
    @1,309,610us: [+5 T:0x4001fb20 S:0xbefb1b1c] CV - VISA_freeMsg(0x5a8f8, 0x41eff880): Freeing message with messageId=0x00035523
    @1,310,090us: [+0 T:0x4001fb20 S:0xbefb1b5c] ti.sdo.ce.image.IMGENC - IMGENC_control> Exit (handle=0x5a8f8, retVal=0x0)
    Ctrl Time = 19518
    @1,311,018us: [+0 T:0x4001fb20 S:0xbefb1ba4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x5a4e0, name='h264fhdvenc', params=0x58180)
    @1,311,502us: [+0 T:0x4001fb20 S:0xbefb1b74] CV - VISA_create(0x5a4e0, 'h264fhdvenc', 0x58180, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    @1,311,986us: [+0 T:0x4001fb20 S:0xbefb1a74] CV - VISA_create2(0x5a4e0, 'h264fhdvenc', 0x58180, 0x3c, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    @1,312,486us: [+0 T:0x4001fb20 S:0xbefb1a5c] OM - Memory_alloc> Enter(0x30)
    @1,312,959us: [+0 T:0x4001fb20 S:0xbefb1a5c] OM - Memory_alloc> return (0x5a9c0)
    @1,313,421us: [+0 T:0x4001fb20 S:0xbefb19fc] CE - Engine_createNode(0x5a4e0, 'h264fhdvenc', 2496, 0x58180, 0x3c, 0xbefb1b6c)
    @1,313,900us: [+0 T:0x4001fb20 S:0xbefb19fc] CE - Engine> allocNode Enter(engine=0x5a4e0, impId='h264fhdvenc')
    @1,314,371us: [+0 T:0x4001fb20 S:0xbefb19e4] OM - Memory_alloc> Enter(0x20)
    @1,314,841us: [+0 T:0x4001fb20 S:0xbefb19e4] OM - Memory_alloc> return (0x5a9f8)
    @1,315,586us: [+0 T:0x4001fb20 S:0xbefb19fc] CE - Engine> allocNode(). Calling Comm_create(gppfromnode_441_3, 0x5aa00, NULL)
    @1,316,052us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_create> Enter(queueName='gppfromnode_441_3', queue=0x5aa00, attrs=0x0)
    @1,316,903us: [+0 T:0x4001fb20 S:0xbefb19bc] OM - Memory_alloc> Enter(0x4)
    @1,317,374us: [+0 T:0x4001fb20 S:0xbefb19bc] OM - Memory_alloc> return (0x5aa20)
    @1,318,108us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_create> return (0x5aa20)
    @1,318,581us: [+0 T:0x4001fb20 S:0xbefb19dc] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,319,107us: [+0 T:0x4001fb20 S:0xbefb19dc] OC - Comm_put> return (0)
    @1,319,639us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb1a84, timeout=-1)
    @1,412,289us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @1,412,770us: [+0 T:0x4001fb20 S:0xbefb19d4] OC - Comm_delete> Enter (comm=0x5aa20)
    @1,413,472us: [+0 T:0x4001fb20 S:0xbefb19b4] OM - Memory_free> Enter(0x5aa20, 0x4)
    @1,413,948us: [+0 T:0x4001fb20 S:0xbefb19b4] OM - Memory_free> return (0x1)
    @1,414,410us: [+0 T:0x4001fb20 S:0xbefb19f4] OC - Comm_delete> return
    @1,414,869us: [+0 T:0x4001fb20 S:0xbefb19dc] OM - Memory_free> Enter(0x5a9f8, 0x20)
    @1,415,341us: [+0 T:0x4001fb20 S:0xbefb19dc] OM - Memory_free> return (0x1)
    @1,415,803us: [+6 T:0x4001fb20 S:0xbefb19fc] CE - Engine_createNode> Remote node creation FAILED (0x80008008).
    @1,416,360us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,416,880us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,417,449us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,417,956us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
     [ARM] WARNING: lost 50616 characters of DSP server trace due to buffer wrapping (got 4032 chars, 258088 left, max=262120; collect trace more often, or add Server.traceBufferSize = <largerSizeInBytes> to DSP server's .cfg file). [DSP] s IALG_PERSIST
    [DSP] @2,178,689tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,178,748tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,178,802tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,178,869tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,178,943tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,179,001tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cdd0
    [DSP] @2,179,085tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,179,140tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,179,194tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10b2c, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,179,287tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8ba0cdd0, paRamIndices 0x8ba0ce10, paRamAddresses 0x8ba0ce00, shadowParams 0x0, tccIndices 0x8ba0ce18, edmaChannel 1
    [DSP] @2,179,405tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 4, Num Tccs 1, Qdma channel 518 Edma channel 1
    [DSP] @2,179,504tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x2 IPR 0x0: 0x2
    [DSP] @2,179,569tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8ba0cdd0)
    [DSP] @2,179,639tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,179,696tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,179,765tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,179,832tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,179,890tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,179,945tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,179,993tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8ba0cdd0, status=IRES_OK)
    [DSP] @2,180,072tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,180,130tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,180,182tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,180,245tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,180,313tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,180,365tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,180,430tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,180,487tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,180,540tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,180,602tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,180,668tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle @1,435,725us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,436,259us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,436,831us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,437,340us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,180,741tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10b44, scratchGroupId=0)
    [DSP] @2,180,816tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,180,881tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,180,948tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,181,010tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,181,072tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams requested
    [DSP] @2,181,160tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained 12 PaRams starting at 136
    [DSP] @2,181,237tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 2
    [DSP] @2,181,296tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,181,357tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,181,430tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 2
    [DSP] @2,181,493tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,181,549tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,181,622tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,181,699tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,181,757tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,181,865tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,181,920tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,181,978tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10b44)
    [DSP] @2,182,043tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,182,102tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10b44, memRecs=0x8ba03f10)
    [DSP] @2,182,185tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x7a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,182,269tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,182,328tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,182,385tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,182,454tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,182,529tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,182,587tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24a7d0
    [DSP] @2,182,672tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,182,728tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,182,782tk: [+0 T:0x8ba00784 S:@1,454,959us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,455,485us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,456,062us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,456,571us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10b44, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,182,875tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24a7d0, paRamIndices 0x8c24a830, paRamAddresses 0x8c24a800, shadowParams 0x0, tccIndices 0x8c24a848, edmaChannel 2
    [DSP] @2,182,995tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 12, Num Tccs 1, Qdma channel 518 Edma channel 2
    [DSP] @2,183,076tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x4 IPR 0x0: 0x4
    [DSP] @2,183,141tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24a7d0)
    [DSP] @2,183,212tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,183,267tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,183,336tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,183,403tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,183,460tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,183,516tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,183,564tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24a7d0, status=IRES_OK)
    [DSP] @2,183,640tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,183,699tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,183,751tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,183,815tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,183,882tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,183,934tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,183,999tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,184,056tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,184,109tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,184,186tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,184,252tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,184,325tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10b5c, scratchGroupId=0)
    [DSP] @2,184,400tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,184,466tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,184,532tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,184,594tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,184,657tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams requested
    [DSP] @2,184,741tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained 4 PaRams starting at 148
    [DSP] @2,184,819tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtai@1,473,260us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,474,004us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,474,579us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,475,387us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    ned TCC 3
    [DSP] @2,184,878tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,184,939tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,185,011tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 3
    [DSP] @2,185,075tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,185,132tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,185,205tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,185,283tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,185,342tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,185,426tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,185,482tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,185,538tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10b5c)
    [DSP] @2,185,603tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,185,662tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10b5c, memRecs=0x8ba03f10)
    [DSP] @2,185,744tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x4a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,185,828tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,185,888tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,185,941tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,186,009tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,186,082tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,186,140tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0ce20
    [DSP] @2,186,224tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,186,280tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,186,334tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10b5c, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,186,427tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8ba0ce20, paRamIndices 0x8ba0ce60, paRamAddresses 0x8ba0ce50, shadowParams 0x0, tccIndices 0x8ba0ce68, edmaChannel 3
    [DSP] @2,186,564tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 4, Num Tccs 1, Qdma channel 518 Edma channel 3
    [DSP] @2,186,644tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x8 IPR 0x0: 0x8
    [DSP] @2,186,710tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8ba0ce20)
    [DSP] @2,186,780tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,186,837tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,1@1,492,092us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,492,617us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,493,193us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,493,699us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    86,906tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,186,974tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,187,031tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,187,086tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,187,134tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8ba0ce20, status=IRES_OK)
    [DSP] @2,187,211tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,187,269tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,187,321tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,187,384tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,187,452tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,187,504tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,187,569tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,187,626tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,187,680tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,187,741tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,187,807tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,187,880tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10b74, scratchGroupId=0)
    [DSP] @2,187,955tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,188,021tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,188,087tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,188,151tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,188,214tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams NOT required
    [DSP] @2,188,293tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Param 152
    [DSP] @2,188,361tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 13
    [DSP] @2,188,420tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,188,481tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,188,554tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 13
    [DSP] @2,188,616tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,188,672tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,188,745tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,188,841tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,188,899tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr@1,511,231us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,511,776us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,512,351us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,512,856us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    =0x8ba0cd68
    [DSP] @2,188,984tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,189,039tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,189,095tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10b74)
    [DSP] @2,189,160tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,189,219tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10b74, memRecs=0x8ba03f10)
    [DSP] @2,189,301tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,189,385tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,189,444tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,189,499tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,189,567tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,189,641tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,189,699tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24a850
    [DSP] @2,189,783tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,189,839tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,189,893tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10b74, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,189,985tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24a850, paRamIndices 0x8c24a884, paRamAddresses 0x8c24a880, shadowParams 0x0, tccIndices 0x8c24a886, edmaChannel 13
    [DSP] @2,190,103tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Num Tccs 1, Qdma channel 518 Edma channel 13
    [DSP] @2,190,183tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x2000 IPR 0x0: 0x2000
    [DSP] @2,190,252tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24a850)
    [DSP] @2,190,322tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,190,378tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,190,447tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,190,514tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,190,573tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,190,628tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,190,676tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24a850, status=IRES_OK)
    [DSP] @2,190,751tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,190,809tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,190,861tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,190,924tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)@1,529,536us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,530,077us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,530,649us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,531,155us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,190,992tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,191,044tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,191,126tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,191,183tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,191,236tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,191,298tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,191,364tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,191,437tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10b8c, scratchGroupId=0)
    [DSP] @2,191,512tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,191,578tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,191,645tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,191,708tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,191,772tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams requested
    [DSP] @2,191,863tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained 10 PaRams starting at 153
    [DSP] @2,191,940tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 14
    [DSP] @2,191,999tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,192,060tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,192,131tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 14
    [DSP] @2,192,195tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,192,253tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,192,325tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,192,403tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,192,461tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,192,547tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,192,603tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,192,658tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10b8c)
    [DSP] @2,192,724tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,192,782tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10b8c, memRecs=0x8ba03f10)
    [DSP] @2,192,865tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x6e, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,192,949tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,193,008tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,193,061tk:@1,547,243us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,547,700us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,548,210us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,548,652us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,193,128tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,193,202tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,193,260tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24a888
    [DSP] @2,193,345tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,193,418tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,193,472tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10b8c, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,193,563tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24a888, paRamIndices 0x8c24a8e0, paRamAddresses 0x8c24a8b8, shadowParams 0x0, tccIndices 0x8c24a8f4, edmaChannel 14
    [DSP] @2,193,684tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 10, Num Tccs 1, Qdma channel 518 Edma channel 14
    [DSP] @2,193,764tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x4000 IPR 0x0: 0x4000
    [DSP] @2,193,833tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24a888)
    [DSP] @2,193,903tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,193,961tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,194,030tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,194,097tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,194,154tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,194,209tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,194,257tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24a888, status=IRES_OK)
    [DSP] @2,194,335tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,194,394tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,194,446tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,194,510tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,194,577tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,194,629tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,194,694tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,194,751tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,194,804tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,194,866tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,194,932tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,195,006tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10ba4, scratchGroupId=0)
    [DSP] @2,195,080tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.@1,556,140us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @1,556,339us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @1,556,583us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @1,556,837us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,195,146tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,195,212tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,195,275tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,195,338tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams NOT required
    [DSP] @2,195,414tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Param 163
    [DSP] @2,195,481tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 15
    [DSP] @2,195,540tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,195,600tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,195,672tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 15
    [DSP] @2,195,752tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,195,808tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,195,882tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,195,958tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,196,016tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,196,100tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,196,156tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,196,212tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10ba4)
    [DSP] @2,196,277tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,196,336tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10ba4, memRecs=0x8ba03f10)
    [DSP] @2,196,418tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,196,502tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,196,561tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,196,615tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,196,682tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,196,756tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,196,814tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24a8f8
    [DSP] @2,196,898tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,196,954tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,197,008tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10ba4, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,197,100tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Ad@2,118,341us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @2,118,545us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @2,118,791us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @2,118,958us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    dress of handle 0x8c24a8f8, paRamIndices 0x8c24a92c, paRamAddresses 0x8c24a928, shadowParams 0x0, tccIndices 0x8c24a92e, edmaChannel 15
    [DSP] @2,197,219tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Num Tccs 1, Qdma channel 518 Edma channel 15
    [DSP] @2,197,300tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x8000 IPR 0x0: 0x8000
    [DSP] @2,197,369tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24a8f8)
    [DSP] @2,197,439tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,197,494tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,197,563tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,197,630tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,197,688tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,197,744tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,197,791tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24a8f8, status=IRES_OK)
    [DSP] @2,197,868tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,197,925tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,197,977tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,198,055tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,198,123tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,198,175tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,198,239tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,198,297tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,198,350tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,198,412tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,198,478tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,198,552tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10bbc, scratchGroupId=0)
    [DSP] @2,198,628tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,198,694tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,198,760tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,198,823tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,198,886tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams NOT required
    [DSP] @2,198,962tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Param 164
    [DSP] @2,199,028tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 20
    [DSP] @2,199,087tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,199,147tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY request@2,163,429us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @2,163,640us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @2,163,894us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @2,164,063us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    ed with 1 TCC ANY.
    [DSP] @2,199,219tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 20
    [DSP] @2,199,282tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,199,339tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,199,412tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,199,490tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,199,548tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,199,632tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,199,688tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,199,745tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10bbc)
    [DSP] @2,199,810tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,199,869tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10bbc, memRecs=0x8ba03f10)
    [DSP] @2,199,951tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,200,035tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,200,094tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,200,148tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,200,215tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,200,288tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,200,346tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24a930
    [DSP] @2,200,449tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,200,505tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,200,559tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10bbc, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,200,651tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24a930, paRamIndices 0x8c24a964, paRamAddresses 0x8c24a960, shadowParams 0x0, tccIndices 0x8c24a966, edmaChannel 20
    [DSP] @2,200,769tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Num Tccs 1, Qdma channel 518 Edma channel 20
    [DSP] @2,200,848tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x100000 IPR 0x0: 0x100000
    [DSP] @2,200,920tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24a930)
    [DSP] @2,200,990tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,201,046tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,201,115tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,201,182tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,201,2@2,172,779us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @2,172,971us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @2,173,215us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @2,173,381us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    39tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,201,295tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,201,342tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24a930, status=IRES_OK)
    [DSP] @2,201,418tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,201,477tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,201,529tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,201,592tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,201,660tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,201,711tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,201,776tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,201,834tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,201,887tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,201,948tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,202,014tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,202,088tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10bd4, scratchGroupId=0)
    [DSP] @2,202,162tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,202,228tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,202,294tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,202,357tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,202,420tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams NOT required
    [DSP] @2,202,496tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Param 165
    [DSP] @2,202,563tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 21
    [DSP] @2,202,622tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,202,698tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,202,770tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 21
    [DSP] @2,202,832tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,202,889tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,202,963tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,203,040tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,203,098tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,203,182tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,203,238tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,203,294tk: [+0 T:0x8b@2,182,814us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @2,183,337us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @2,183,912us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @2,184,417us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    a00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10bd4)
    [DSP] @2,203,359tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,203,419tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10bd4, memRecs=0x8ba03f10)
    [DSP] @2,203,501tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,203,585tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,203,644tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,203,698tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,203,765tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,203,839tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,203,897tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24a968
    [DSP] @2,203,982tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,204,037tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,204,091tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10bd4, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,204,183tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24a968, paRamIndices 0x8c24a99c, paRamAddresses 0x8c24a998, shadowParams 0x0, tccIndices 0x8c24a99e, edmaChannel 21
    [DSP] @2,204,303tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Num Tccs 1, Qdma channel 518 Edma channel 21
    [DSP] @2,204,383tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x200000 IPR 0x0: 0x200000
    [DSP] @2,204,455tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24a968)
    [DSP] @2,204,526tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,204,582tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,204,651tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,204,718tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,204,777tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,204,832tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,204,880tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24a968, status=IRES_OK)
    [DSP] @2,204,958tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,205,030tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,205,081tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,205,144tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,205,212tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,205,264tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,205,32@2,193,110us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @2,193,308us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @2,193,561us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @2,193,732us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,205,386tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,205,439tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,205,501tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,205,567tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,205,641tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10bec, scratchGroupId=0)
    [DSP] @2,205,716tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,205,782tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,205,848tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,205,911tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,205,973tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams NOT required
    [DSP] @2,206,052tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Param 166
    [DSP] @2,206,120tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 22
    [DSP] @2,206,178tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,206,239tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,206,312tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 22
    [DSP] @2,206,375tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,206,431tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,206,502tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,206,580tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,206,638tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,206,723tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,206,778tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,206,836tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10bec)
    [DSP] @2,206,901tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,206,959tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10bec, memRecs=0x8ba03f10)
    [DSP] @2,207,041tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,207,125tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,207,184tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,207,238tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,207,305tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNA@2,203,482us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @2,204,017us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @2,204,594us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @2,205,098us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    L, extHeapId=0)
    [DSP] @2,207,400tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,207,458tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24a9a0
    [DSP] @2,207,543tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,207,599tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,207,653tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10bec, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,207,745tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24a9a0, paRamIndices 0x8c24a9d4, paRamAddresses 0x8c24a9d0, shadowParams 0x0, tccIndices 0x8c24a9d6, edmaChannel 22
    [DSP] @2,207,863tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Num Tccs 1, Qdma channel 518 Edma channel 22
    [DSP] @2,207,943tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x400000 IPR 0x0: 0x400000
    [DSP] @2,208,015tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24a9a0)
    [DSP] @2,208,086tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,208,141tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,208,209tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,208,277tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,208,334tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,208,390tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,208,437tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24a9a0, status=IRES_OK)
    [DSP] @2,208,516tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,208,573tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,208,625tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,208,689tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,208,756tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,208,808tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,208,873tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,208,930tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,208,984tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,209,045tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,209,111tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,209,184tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10c04, scratchGroupId=0)
    [DSP] @2,209,258tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,209,324tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,209,390tk: [+0 T:0x8ba00784 S:0x8ba03e64] t@2,213,031us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @2,213,231us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @2,213,481us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @2,213,645us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,209,453tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,209,515tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams NOT required
    [DSP] @2,209,593tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Param 167
    [DSP] @2,209,673tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 23
    [DSP] @2,209,732tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,209,793tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,209,866tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 23
    [DSP] @2,209,929tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,209,985tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,210,058tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,210,136tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,210,194tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,210,278tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,210,334tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,210,391tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c04)
    [DSP] @2,210,456tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,210,515tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c04, memRecs=0x8ba03f10)
    [DSP] @2,210,597tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,210,681tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,210,740tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,210,794tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,210,861tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,210,935tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,210,993tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24a9d8
    [DSP] @2,211,077tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,211,133tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,211,187tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10c04, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,211,280tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24a9d8, paRamIndices 0x8c24aa0c, paRamAddresses 0x8c24aa08, shadowParams 0x0, tccIndices 0x8c24aa0e, edmaChannel 23
    [DSP] @2,211,398tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Nu@2,219,296us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @2,219,765us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @2,220,025us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @2,220,194us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    m Tccs 1, Qdma channel 518 Edma channel 23
    [DSP] @2,211,478tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x800000 IPR 0x0: 0x800000
    [DSP] @2,211,550tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24a9d8)
    [DSP] @2,211,621tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,211,677tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,211,747tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,211,814tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,211,872tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,211,927tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,211,991tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24a9d8, status=IRES_OK)
    [DSP] @2,212,069tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,212,127tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,212,178tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,212,242tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,212,310tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,212,361tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,212,426tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,212,483tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,212,537tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,212,598tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,212,664tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,212,737tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10c1c, scratchGroupId=0)
    [DSP] @2,212,812tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,212,877tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,212,944tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,213,007tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,213,069tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams requested
    [DSP] @2,213,160tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained 4 PaRams starting at 168
    [DSP] @2,213,239tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 24
    [DSP] @2,213,298tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,213,359tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,213,432tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 24
    [DSP] @2,213,496tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (@2,318,171us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @2,318,372us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @2,318,618us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @2,318,784us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    numRecs=1)
    [DSP] @2,213,554tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,213,627tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,213,704tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,213,762tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,213,851tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,213,906tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,213,962tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c1c)
    [DSP] @2,214,027tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,214,085tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c1c, memRecs=0x8ba03f10)
    [DSP] @2,214,168tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x4a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,214,251tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,214,329tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,214,385tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,214,454tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,214,528tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,214,586tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24aa10
    [DSP] @2,214,670tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,214,726tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,214,781tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10c1c, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,214,873tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24aa10, paRamIndices 0x8c24aa50, paRamAddresses 0x8c24aa40, shadowParams 0x0, tccIndices 0x8c24aa58, edmaChannel 24
    [DSP] @2,214,993tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 4, Num Tccs 1, Qdma channel 518 Edma channel 24
    [DSP] @2,215,073tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x1000000 IPR 0x0: 0x1000000
    [DSP] @2,215,146tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24aa10)
    [DSP] @2,215,216tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,215,270tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,215,339tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,215,407tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,215,464tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,215,520tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,215,568tk: [+0 T:0x8ba00784 S:0x8ba03ea4] @3,314,831us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @3,315,031us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @3,315,287us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @3,315,456us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24aa10, status=IRES_OK)
    [DSP] @2,215,647tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,215,705tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,215,757tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,215,821tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,215,888tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,215,940tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,216,005tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,216,062tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,216,115tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,216,176tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,216,242tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,216,315tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10c34, scratchGroupId=0)
    [DSP] @2,216,389tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,216,455tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,216,522tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,216,586tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,216,667tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams requested
    [DSP] @2,216,753tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained 4 PaRams starting at 172
    [DSP] @2,216,829tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 25
    [DSP] @2,216,888tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,216,949tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,217,021tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 25
    [DSP] @2,217,085tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,217,142tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,217,215tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,217,293tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,217,352tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,217,437tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,217,493tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,217,549tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c34)
    [DSP] @2,217,614tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,@3,322,674us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @3,322,870us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @3,323,119us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @3,323,289us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    217,673tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c34, memRecs=0x8ba03f10)
    [DSP] @2,217,755tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x4a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,217,839tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,217,899tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,217,952tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,218,020tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,218,094tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,218,151tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24aa60
    [DSP] @2,218,236tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,218,292tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,218,346tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10c34, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,218,439tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24aa60, paRamIndices 0x8c24aaa0, paRamAddresses 0x8c24aa90, shadowParams 0x0, tccIndices 0x8c24aaa8, edmaChannel 25
    [DSP] @2,218,557tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 4, Num Tccs 1, Qdma channel 518 Edma channel 25
    [DSP] @2,218,637tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x2000000 IPR 0x0: 0x2000000
    [DSP] @2,218,710tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24aa60)
    [DSP] @2,218,781tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,218,836tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,218,905tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,218,989tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,219,050tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,219,105tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,219,153tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24aa60, status=IRES_OK)
    [DSP] @2,219,231tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,219,288tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,219,340tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,219,404tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,219,471tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,219,523tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,219,588tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,219,646tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,219,6@3,337,588us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @3,338,111us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @3,338,686us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @3,339,192us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    99tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,219,760tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,219,826tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,219,901tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10c4c, scratchGroupId=0)
    [DSP] @2,219,977tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,220,042tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,220,108tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,220,171tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,220,233tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams NOT required
    [DSP] @2,220,310tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Param 176
    [DSP] @2,220,377tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 26
    [DSP] @2,220,436tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,220,497tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,220,569tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 26
    [DSP] @2,220,632tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,220,688tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,220,761tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,220,839tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,220,897tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,220,981tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,221,037tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,221,093tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c4c)
    [DSP] @2,221,158tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,221,216tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c4c, memRecs=0x8ba03f10)
    [DSP] @2,221,319tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,221,403tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,221,462tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,221,518tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,221,586tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,221,660tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,221,718tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory@3,344,952us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @3,345,159us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @3,345,412us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @3,345,584us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    > memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24aab0
    [DSP] @2,221,803tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,221,858tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,221,913tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10c4c, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,222,005tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24aab0, paRamIndices 0x8c24aae4, paRamAddresses 0x8c24aae0, shadowParams 0x0, tccIndices 0x8c24aae6, edmaChannel 26
    [DSP] @2,222,124tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Num Tccs 1, Qdma channel 518 Edma channel 26
    [DSP] @2,222,204tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x4000000 IPR 0x0: 0x4000000
    [DSP] @2,222,277tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24aab0)
    [DSP] @2,222,347tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,222,402tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,222,471tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,222,538tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,222,596tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,222,651tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,222,699tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24aab0, status=IRES_OK)
    [DSP] @2,222,775tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,222,833tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,222,885tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,222,949tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,223,016tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,223,068tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,223,132tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,223,190tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,223,243tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,223,305tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,223,371tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,223,444tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10c64, scratchGroupId=0)
    [DSP] @2,223,520tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,223,597tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,223,664tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,223,727tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,223,790tk: [+4 T:0x8ba@3,353,313us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @3,353,772us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @3,354,279us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @3,354,719us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,223,868tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Param 177
    [DSP] @2,223,933tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 27
    [DSP] @2,223,992tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,224,053tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,224,124tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 27
    [DSP] @2,224,187tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,224,244tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,224,319tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,224,398tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,224,456tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,224,541tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,224,596tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,224,653tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c64)
    [DSP] @2,224,718tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,224,776tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c64, memRecs=0x8ba03f10)
    [DSP] @2,224,858tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,224,942tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,225,001tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,225,055tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,225,122tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,225,195tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,225,253tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24aae8
    [DSP] @2,225,338tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,225,394tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,225,449tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10c64, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,225,541tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24aae8, paRamIndices 0x8c24ab1c, paRamAddresses 0x8c24ab18, shadowParams 0x0, tccIndices 0x8c24ab1e, edmaChannel 27
    [DSP] @2,225,661tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Num Tccs 1, Qdma channel 518 Edma channel 27
    [DSP] @2,225,742tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x8000000 IPR 0x0: 0x8000000
    [DSP] @2,225,816tk: [+0 T:0x8ba00784 S:0@3,361,404us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @3,361,600us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @3,361,846us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @3,362,015us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24aae8)
    [DSP] @2,225,898tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,225,955tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,226,024tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,226,090tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,226,148tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,226,203tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,226,251tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24aae8, status=IRES_OK)
    [DSP] @2,226,325tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,226,384tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,226,435tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,226,499tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,226,567tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,226,618tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,226,683tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,226,740tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,226,794tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,226,855tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,226,921tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,226,995tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10c7c, scratchGroupId=0)
    [DSP] @2,227,071tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,227,137tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,227,203tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,227,266tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,227,329tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams requested
    [DSP] @2,227,415tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained 2 PaRams starting at 178
    [DSP] @2,227,491tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 28
    [DSP] @2,227,551tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,227,612tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,227,684tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 28
    [DSP] @2,227,749tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,227,805tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,227,879tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_@4,240,651us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @4,241,160us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @4,241,432us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @4,241,603us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,227,955tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,228,013tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,228,098tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,228,153tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,228,233tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c7c)
    [DSP] @2,228,298tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,228,357tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c7c, memRecs=0x8ba03f10)
    [DSP] @2,228,440tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x3e, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,228,524tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,228,583tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,228,640tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,228,708tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,228,782tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,228,840tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24ab20
    [DSP] @2,228,925tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,228,980tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,229,035tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10c7c, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,229,129tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24ab20, paRamIndices 0x8c24ab58, paRamAddresses 0x8c24ab50, shadowParams 0x0, tccIndices 0x8c24ab5c, edmaChannel 28
    [DSP] @2,229,248tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 2, Num Tccs 1, Qdma channel 518 Edma channel 28
    [DSP] @2,229,328tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x10000000 IPR 0x0: 0x10000000
    [DSP] @2,229,403tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24ab20)
    [DSP] @2,229,474tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,229,529tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,229,598tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,229,665tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,229,723tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,229,778tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,229,826tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24ab20, status=IRES_OK)
    [DSP] @2,229,904tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,22@4,247,641us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @4,247,836us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @4,248,078us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @4,248,248us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    9,964tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,230,016tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,230,079tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,230,146tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,230,198tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,230,263tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,230,320tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,230,373tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,230,435tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,230,501tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,230,588tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10c94, scratchGroupId=0)
    [DSP] @2,230,662tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,230,728tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,230,795tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,230,857tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,230,920tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams requested
    [DSP] @2,231,004tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained 2 PaRams starting at 180
    [DSP] @2,231,084tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 29
    [DSP] @2,231,143tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,231,204tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,231,277tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 29
    [DSP] @2,231,340tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,231,397tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,231,469tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,231,548tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,231,606tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,231,691tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,231,747tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,231,804tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c94)
    [DSP] @2,231,869tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,231,928tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c94, memRecs=0x8ba03f10)
    [DSP] @2,232,010tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.f@4,255,493us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @4,255,696us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @4,255,948us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @4,256,119us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,232,094tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,232,153tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,232,206tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,232,274tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,232,348tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,232,406tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24ab60
    [DSP] @2,232,491tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,232,547tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,232,601tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10c94, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,232,694tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24ab60, paRamIndices 0x8c24ab98, paRamAddresses 0x8c24ab90, shadowParams 0x0, tccIndices 0x8c24ab9c, edmaChannel 29
    [DSP] @2,232,813tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 2, Num Tccs 1, Qdma channel 518 Edma channel 29
    [DSP] @2,232,914tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x20000000 IPR 0x0: 0x20000000
    [DSP] @2,232,989tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24ab60)
    [DSP] @2,233,060tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,233,116tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,233,185tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,233,252tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,233,311tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,233,366tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,233,414tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24ab60, status=IRES_OK)
    [DSP] @2,233,491tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,233,549tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,233,601tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,233,664tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,233,732tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,233,784tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,233,849tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,233,906tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,233,959tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,234,021tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtoc@4,262,218us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @4,262,420us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @4,262,667us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @4,262,837us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,234,087tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,234,159tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10cac, scratchGroupId=0)
    [DSP] @2,234,234tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,234,300tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,234,367tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,234,429tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,234,492tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams requested
    [DSP] @2,234,579tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained 4 PaRams starting at 182
    [DSP] @2,234,656tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 30
    [DSP] @2,234,715tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,234,776tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,234,849tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 30
    [DSP] @2,234,913tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,234,969tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,235,042tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,235,120tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,235,198tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,235,283tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,235,339tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,235,395tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10cac)
    [DSP] @2,235,461tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,235,520tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10cac, memRecs=0x8ba03f10)
    [DSP] @2,235,602tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x4a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,235,686tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,235,746tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,235,803tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,235,872tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,235,946tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,236,004tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24aba0
    [DSP] @2,236,088tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    @4,269,159us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @4,269,530us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @4,269,678us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @4,269,839us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,236,143tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,236,198tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10cac, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,236,291tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24aba0, paRamIndices 0x8c24abe0, paRamAddresses 0x8c24abd0, shadowParams 0x0, tccIndices 0x8c24abe8, edmaChannel 30
    [DSP] @2,236,411tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 4, Num Tccs 1, Qdma channel 518 Edma channel 30
    [DSP] @2,236,491tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x40000000 IPR 0x0: 0x40000000
    [DSP] @2,236,566tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24aba0)
    [DSP] @2,236,636tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,236,690tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,236,759tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,236,826tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,236,884tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,236,940tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,236,987tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24aba0, status=IRES_OK)
    [DSP] @2,237,064tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,237,121tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,237,173tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,237,237tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,237,304tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,237,356tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,237,421tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,237,478tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,237,547tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,237,609tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,237,675tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,237,749tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10cc4, scratchGroupId=0)
    [DSP] @2,237,825tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,237,891tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,237,958tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,238,020tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,238,082tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams NOT required
    [DSP] @2,238,161tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_g@4,276,245us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @4,276,448us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @4,276,696us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @4,276,868us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    etHandles> Obtained Param 186
    [DSP] @2,238,232tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 31
    [DSP] @2,238,291tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,238,351tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,238,424tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 31
    [DSP] @2,238,487tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,238,544tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,238,615tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,238,693tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,238,751tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,238,835tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,238,891tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,238,948tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10cc4)
    [DSP] @2,239,013tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,239,071tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10cc4, memRecs=0x8ba03f10)
    [DSP] @2,239,153tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,239,237tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,239,296tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,239,350tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,239,417tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,239,491tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,239,549tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24abf0
    [DSP] @2,239,633tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,239,689tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,239,744tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10cc4, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,239,851tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24abf0, paRamIndices 0x8c24ac24, paRamAddresses 0x8c24ac20, shadowParams 0x0, tccIndices 0x8c24ac26, edmaChannel 31
    [DSP] @2,239,971tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Num Tccs 1, Qdma channel 518 Edma channel 31
    [DSP] @2,240,050tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x0: 0x80000000 IPR 0x0: 0x80000000
    [DSP] @2,240,125tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24abf0)
    [DSP] @2,240,195tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (@4,288,418us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @4,288,881us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @4,289,457us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @4,289,901us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    numRecs=1)
    [DSP] @2,240,252tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,240,321tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,240,389tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,240,448tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,240,503tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,240,551tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24abf0, status=IRES_OK)
    [DSP] @2,240,629tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,240,687tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,240,739tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,240,802tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,240,870tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,240,921tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,240,986tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,241,044tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,241,097tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,241,158tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,241,224tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,241,296tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10cdc, scratchGroupId=0)
    [DSP] @2,241,371tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,241,437tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,241,503tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,241,567tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,241,630tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams requested
    [DSP] @2,241,715tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained 2 PaRams starting at 187
    [DSP] @2,241,791tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 32
    [DSP] @2,241,851tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,241,911tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,241,983tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 32
    [DSP] @2,242,047tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,242,103tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,242,201tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,242,280tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    @4,295,994us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @4,830,299us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @4,830,565us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @4,830,729us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,242,339tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,242,424tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,242,479tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,242,535tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10cdc)
    [DSP] @2,242,601tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,242,659tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10cdc, memRecs=0x8ba03f10)
    [DSP] @2,242,742tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x3e, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,242,826tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,242,885tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,242,939tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,243,006tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,243,079tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,243,137tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24ac28
    [DSP] @2,243,222tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,243,277tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,243,331tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10cdc, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,243,424tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24ac28, paRamIndices 0x8c24ac60, paRamAddresses 0x8c24ac58, shadowParams 0x0, tccIndices 0x8c24ac64, edmaChannel 32
    [DSP] @2,243,543tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 2, Num Tccs 1, Qdma channel 518 Edma channel 32
    [DSP] @2,243,622tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x1: 0x0 IPR 0x1: 0x0
    [DSP] @2,243,687tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24ac28)
    [DSP] @2,243,758tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,243,813tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,243,882tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,243,949tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,244,007tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,244,062tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,244,110tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24ac28, status=IRES_OK)
    [DSP] @2,244,190tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,244,248tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,244,300tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.@5,299,248us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @5,300,050us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @5,300,323us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @5,300,494us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    fc.ires.edma3chan)
    [DSP] @2,244,363tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,244,431tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,244,498tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,244,563tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,244,621tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,244,674tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,244,735tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,244,801tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,244,876tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10cf4, scratchGroupId=0)
    [DSP] @2,244,951tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,245,016tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,245,082tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,245,145tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,245,210tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams requested
    [DSP] @2,245,295tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained 2 PaRams starting at 189
    [DSP] @2,245,372tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 33
    [DSP] @2,245,432tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,245,493tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,245,565tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 33
    [DSP] @2,245,629tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,245,687tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,245,761tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,245,839tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,245,897tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,245,982tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,246,038tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,246,093tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10cf4)
    [DSP] @2,246,157tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,246,217tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10cf4, memRecs=0x8ba03f10)
    [DSP] @2,246,299tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x3e, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,246,383tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_E@5,308,354us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @5,308,883us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @5,309,543us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @5,309,747us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,246,442tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,246,496tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,246,563tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,246,637tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,246,695tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24ac68
    [DSP] @2,246,795tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,246,851tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,246,906tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10cf4, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,246,999tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24ac68, paRamIndices 0x8c24aca0, paRamAddresses 0x8c24ac98, shadowParams 0x0, tccIndices 0x8c24aca4, edmaChannel 33
    [DSP] @2,247,118tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 2, Num Tccs 1, Qdma channel 518 Edma channel 33
    [DSP] @2,247,197tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x2: 0x0 IPR 0x2: 0x0
    [DSP] @2,247,262tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24ac68)
    [DSP] @2,247,333tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,247,389tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,247,458tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,247,526tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,247,585tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,247,640tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,247,688tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24ac68, status=IRES_OK)
    [DSP] @2,247,765tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,247,823tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,247,875tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,247,938tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,248,006tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,248,057tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,248,122tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,248,179tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,248,232tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,248,294tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,248,360tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,248,433tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sd@5,316,362us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @5,316,563us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @5,316,813us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @5,316,985us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    o.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10d0c, scratchGroupId=0)
    [DSP] @2,248,509tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,248,574tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,248,641tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,248,703tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,248,766tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams NOT required
    [DSP] @2,248,844tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Param 191
    [DSP] @2,248,915tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 34
    [DSP] @2,248,974tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,249,035tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,249,122tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 34
    [DSP] @2,249,185tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,249,242tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,249,316tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,249,395tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,249,453tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,249,537tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,249,593tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,249,649tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10d0c)
    [DSP] @2,249,714tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,249,772tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10d0c, memRecs=0x8ba03f10)
    [DSP] @2,249,855tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,249,939tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,249,998tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,250,052tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,250,119tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,250,192tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,250,250tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24aca8
    [DSP] @2,250,335tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,250,390tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,250,445tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10d0c, memR@5,328,195us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @5,328,730us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @5,329,301us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @5,329,901us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,250,537tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24aca8, paRamIndices 0x8c24acdc, paRamAddresses 0x8c24acd8, shadowParams 0x0, tccIndices 0x8c24acde, edmaChannel 34
    [DSP] @2,250,656tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Num Tccs 1, Qdma channel 518 Edma channel 34
    [DSP] @2,250,737tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x4: 0x0 IPR 0x4: 0x0
    [DSP] @2,250,803tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24aca8)
    [DSP] @2,250,873tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,250,929tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,250,998tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,251,065tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,251,124tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,251,179tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,251,227tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24aca8, status=IRES_OK)
    [DSP] @2,251,302tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,251,360tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,251,425tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,251,489tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,251,557tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,251,608tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,251,673tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,251,731tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,251,784tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,251,845tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,251,911tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,251,987tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10d24, scratchGroupId=0)
    [DSP] @2,252,062tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,252,127tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,252,194tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,252,256tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,252,319tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams NOT required
    [DSP] @2,252,397tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Param 192
    [DSP] @2,252,463tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 35
    [DSP] @2,252,522tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DC@5,345,788us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @5,346,321us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @5,346,895us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @5,347,403us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,252,583tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,252,654tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 35
    [DSP] @2,252,717tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,252,773tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,252,846tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,252,923tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,252,981tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,253,065tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,253,121tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,253,179tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10d24)
    [DSP] @2,253,244tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,253,302tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10d24, memRecs=0x8ba03f10)
    [DSP] @2,253,385tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,253,469tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,253,528tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,253,582tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,253,649tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,253,723tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,253,799tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24ace0
    [DSP] @2,253,884tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,253,939tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,253,993tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10d24, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,254,086tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24ace0, paRamIndices 0x8c24ad14, paRamAddresses 0x8c24ad10, shadowParams 0x0, tccIndices 0x8c24ad16, edmaChannel 35
    [DSP] @2,254,204tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Num Tccs 1, Qdma channel 518 Edma channel 35
    [DSP] @2,254,284tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x8: 0x0 IPR 0x8: 0x0
    [DSP] @2,254,349tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24ace0)
    [DSP] @2,254,419tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,254,476tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,254,545tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1@5,361,419us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @5,361,624us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @5,361,870us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @5,362,042us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    , addr=0x8ba0cd68)
    [DSP] @2,254,612tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,254,670tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,254,725tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,254,773tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24ace0, status=IRES_OK)
    [DSP] @2,254,849tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,254,907tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,254,959tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,255,023tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,255,090tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,255,142tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,255,206tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,255,264tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,255,317tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,255,379tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,255,444tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,255,517tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10d3c, scratchGroupId=0)
    [DSP] @2,255,593tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,255,659tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,255,725tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,255,787tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,255,850tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams NOT required
    [DSP] @2,255,927tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Param 193
    [DSP] @2,255,995tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained TCC 36
    [DSP] @2,256,069tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,256,129tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> EDMA Channel ANY requested with 1 TCC ANY.
    [DSP] @2,256,201tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained Edma channel 36
    [DSP] @2,256,264tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,256,320tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,256,393tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,256,472tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,256,530tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8ba0cd68
    [DSP] @2,256,614tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (r@6,180,563us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @6,180,766us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @6,181,011us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @6,181,184us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    eturnVal=1)
    [DSP] @2,256,670tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,256,728tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10d3c)
    [DSP] @2,256,793tk: [+0 T:0x8ba00784 S:0x8ba03e94] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,256,851tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10d3c, memRecs=0x8ba03f10)
    [DSP] @2,256,933tk: [+4 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,257,017tk: [+0 T:0x8ba00784 S:0x8ba03e74] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,257,076tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Enter (numRecs=1)
    [DSP] @2,257,130tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Enter (scratchId=-1, numRecs=1, extHeapId=0)
    [DSP] @2,257,197tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
    [DSP] @2,257,271tk: [+0 T:0x8ba00784 S:0x8ba03dfc] ti.sdo.fc.dskt2 - _DSKT2_allocateInDesignatedSpace> Exit (returnVal=1)
    [DSP] @2,257,329tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_EXTERNAL. Addr=0x8c24ad18
    [DSP] @2,257,413tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.dskt2 - _DSKT2_assignInstanceMemory> Exit (returnVal=1)
    [DSP] @2,257,469tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_allocPersistent> Exit (status=1)
    [DSP] @2,257,523tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Enter (protArgs=0x8ba10d3c, memRecs=0x8ba03f10, constructHandleArgs=0x8ba0cd68)
    [DSP] @2,257,615tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Address of handle 0x8c24ad18, paRamIndices 0x8c24ad4c, paRamAddresses 0x8c24ad48, shadowParams 0x0, tccIndices 0x8c24ad4e, edmaChannel 36
    [DSP] @2,257,733tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Num params 1, Num Tccs 1, Qdma channel 518 Edma channel 36
    [DSP] @2,257,813tk: [+2 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> ESR 0x10: 0x0 IPR 0x10: 0x0
    [DSP] @2,257,880tk: [+0 T:0x8ba00784 S:0x8ba03e3c] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_constructHandle> Exit (status=0, handle=0x8c24ad18)
    [DSP] @2,257,951tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,258,006tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,258,075tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd68)
    [DSP] @2,258,142tk: [+0 T:0x8ba00784 S:0x8ba03e2c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,258,201tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,258,256tk: [+0 T:0x8ba00784 S:0x8ba03e7c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,258,304tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=0x8c24ad18, status=IRES_OK)
    [DSP] @2,258,397tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,258,454tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,258,506tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,258,570tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,258,637tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,258,689tk@6,187,807us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @6,188,004us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @6,188,256us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @6,188,426us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,258,754tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,258,811tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,258,864tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,258,926tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,258,992tk: [+2 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Call getHandle on the IRESMAN implementation 0x8fa9e548
    [DSP] @2,259,066tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Enter (protocolArgs=0x8ba10d54, scratchGroupId=0)
    [DSP] @2,259,140tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,259,206tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,259,273tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,259,334tk: [+2 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> DCHMAP exists on device
    [DSP] @2,259,397tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Contiguous PaRams requested
    [DSP] @2,259,488tk: [+4 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Obtained 4 PaRams starting at 194
    [DSP] @2,259,565tk: [+7 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Could not allocate Tcc 1010
    [DSP] @2,259,631tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.ires.edma3Chan - _freeResource> Enter (algHandle=0x8ba0f460, scratchGroupId=0, edma3Chan=518, qdmaChan=518, numPaRams=4, numTccs=0x0
    [DSP] )@2,259,722tk: [+0 T:0x8ba00784 S:0x8ba03e0c] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,259,788tk: [+2 T:0x8ba00784 S:0x8ba03e0c] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Look for matching entry for ALG 0x8ba0f460
    [DSP] @2,259,854tk: [+0 T:0x8ba00784 S:0x8ba03e0c] ti.sdo.fc.edma3 - EDMA3_getResourceManager> Exit (handle=0x8fa96788)
    [DSP] @2,259,933tk: [+0 T:0x8ba00784 S:0x8ba03e0c] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,260,006tk: [+2 T:0x8ba00784 S:0x8ba03e0c] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=25
    [DSP] @2,260,080tk: [+0 T:0x8ba00784 S:0x8ba03e0c] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,260,136tk: [+0 T:0x8ba00784 S:0x8ba03e4c] ti.sdo.fc.ires.edma3Chan - _freeResource> Exit (status=0)
    [DSP] @2,260,189tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,260,257tk: [+2 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=24
    [DSP] @2,260,330tk: [+0 T:0x8ba00784 S:0x8ba03e64] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,260,385tk: [+0 T:0x8ba00784 S:0x8ba03ea4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getHandles> Exit (handle=NULL, status=7)
    [DSP] @2,260,456tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,260,517tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,260,569tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,260,632tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,260,712tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,260,764tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3C@6,200,077us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @6,200,601us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @6,200,862us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @6,201,031us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,260,832tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_getProtocolName> Enter
    [DSP] @2,260,888tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getName> Enter
    [DSP] @2,260,937tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getName> Exit (Name=ti.sdo.fc.ires.hdvicp)
    [DSP] @2,260,998tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_getProtocolName> Exit (name=ti.sdo.fc.ires.hdvicp)
    [DSP] @2,261,062tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getName> Enter
    [DSP] @2,261,112tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getName> Exit (Name=ti.sdo.fc.ires.hdvicp)
    [DSP] @2,261,173tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_getProtocolRevision> Enter
    [DSP] @2,261,229tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getRevision> Enter
    [DSP] @2,261,280tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getRevision>Exit (Version=(1.0.1))
    [DSP] @2,261,339tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_getProtocolRevision> Exit (version=(1.0.1))
    [DSP] @2,261,407tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_freeHandle> Enter (handle=0x8ba0ccc8, protocolArgs=0x8ba10a38, scratchGroupId=0)
    [DSP] @2,261,495tk: [+0 T:0x8ba00784 S:0x8ba042f4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getNumMemRecs> Enter (protArgs=0x8ba10a38)
    [DSP] @2,261,558tk: [+0 T:0x8ba00784 S:0x8ba042f4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getNumMemRecs> Exit (Num=1)
    [DSP] @2,261,616tk: [+0 T:0x8ba00784 S:0x8ba042e4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10a38, memRecs=0x8ba04368)
    [DSP] @2,261,696tk: [+4 T:0x8ba00784 S:0x8ba042e4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getMemRecs> Amount of memory requested 0x1c, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,261,777tk: [+0 T:0x8ba00784 S:0x8ba042e4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,261,835tk: [+0 T:0x8ba00784 S:0x8ba042f4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_destructHandle> Enter
    [DSP] @2,261,888tk: [+0 T:0x8ba00784 S:0x8ba042f4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,261,949tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,262,006tk: [+0 T:0x8ba00784 S:0x8ba042ac] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,262,074tk: [+0 T:0x8ba00784 S:0x8ba0428c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0ccc8)
    [DSP] @2,262,141tk: [+0 T:0x8ba00784 S:0x8ba0428c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,262,202tk: [+0 T:0x8ba00784 S:0x8ba042ac] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,262,257tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,262,305tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_freeHandles> Exit (status=0)
    [DSP] @2,262,364tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,262,421tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,262,473tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,262,537tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,262,604tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,262,656tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,262,721tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_getProtocolName> Enter
    [DSP] @2,262,775tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getName> Enter
    [DSP] @2,262,824tk: [+0 @6,207,596us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @6,207,793us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @6,208,043us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @6,208,219us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,262,885tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_getProtocolName> Exit (name=ti.sdo.fc.ires.hdvicp)
    [DSP] @2,262,949tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getName> Enter
    [DSP] @2,262,999tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getName> Exit (Name=ti.sdo.fc.ires.hdvicp)
    [DSP] @2,263,073tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_getProtocolRevision> Enter
    [DSP] @2,263,129tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getRevision> Enter
    [DSP] @2,263,180tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getRevision>Exit (Version=(1.0.1))
    [DSP] @2,263,239tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_getProtocolRevision> Exit (version=(1.0.1))
    [DSP] @2,263,303tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_freeHandle> Enter (handle=0x8ba0cce8, protocolArgs=0x8ba10a44, scratchGroupId=0)
    [DSP] @2,263,385tk: [+0 T:0x8ba00784 S:0x8ba042f4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getNumMemRecs> Enter (protArgs=0x8ba10a44)
    [DSP] @2,263,448tk: [+0 T:0x8ba00784 S:0x8ba042f4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getNumMemRecs> Exit (Num=1)
    [DSP] @2,263,503tk: [+0 T:0x8ba00784 S:0x8ba042e4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10a44, memRecs=0x8ba04368)
    [DSP] @2,263,583tk: [+4 T:0x8ba00784 S:0x8ba042e4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getMemRecs> Amount of memory requested 0x1c, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,263,664tk: [+0 T:0x8ba00784 S:0x8ba042e4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,263,722tk: [+0 T:0x8ba00784 S:0x8ba042f4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_destructHandle> Enter
    [DSP] @2,263,774tk: [+0 T:0x8ba00784 S:0x8ba042f4] ti.sdo.fc.ires.hdvicp - IRES_HDVICP_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,263,833tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,263,887tk: [+0 T:0x8ba00784 S:0x8ba042ac] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,263,955tk: [+0 T:0x8ba00784 S:0x8ba0428c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cce8)
    [DSP] @2,264,022tk: [+0 T:0x8ba00784 S:0x8ba0428c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,264,080tk: [+0 T:0x8ba00784 S:0x8ba042ac] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,264,135tk: [+0 T:0x8ba00784 S:0x8ba042dc] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,264,182tk: [+0 T:0x8ba00784 S:0x8ba04304] ti.sdo.fc.ires.hdvicp - IRESMAN_HDVICP_freeHandles> Exit (status=0)
    [DSP] @2,264,241tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,264,297tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,264,349tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,264,413tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,264,480tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,264,532tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,264,597tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,264,654tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,264,707tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,264,769tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,264,837tk: [+0 T:0x8ba0078@6,220,989us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @6,221,190us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @6,221,441us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @6,221,613us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    4 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8ba0cd80, protocolArgs=0x8ba10b14, scratchGroupId=0)
    [DSP] @2,264,922tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,264,990tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=23
    [DSP] @2,265,062tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,265,117tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10b14)
    [DSP] @2,265,182tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,265,242tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10b14, memRecs=0x8ba04408)
    [DSP] @2,265,324tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x4a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,265,417tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,265,477tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,265,532tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,265,594tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,265,648tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,265,716tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cd80)
    [DSP] @2,265,783tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,265,840tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,265,895tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,265,943tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,266,004tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,266,059tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,266,111tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,266,174tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,266,242tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,266,293tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,266,358tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,266,416tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,266,469tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,266,530tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,266,597tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8ba0cdd0, protocolArgs=0x8ba10b2c, scratchGroupId=0)
    [DSP] @2,266,681tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,266,748tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=22
    [DSP] @2,266,821tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseRe@6,227,629us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @6,227,834us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @6,228,088us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @6,228,261us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,266,876tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10b2c)
    [DSP] @2,266,941tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,266,999tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10b2c, memRecs=0x8ba04408)
    [DSP] @2,267,081tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x4a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,267,165tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,267,224tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,267,278tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,267,340tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,267,393tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,267,461tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0cdd0)
    [DSP] @2,267,528tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,267,586tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,267,641tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,267,693tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,267,754tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,267,810tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,267,861tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,267,925tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,267,992tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,268,044tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,268,109tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,268,166tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,268,219tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,268,281tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,268,347tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24a7d0, protocolArgs=0x8ba10b44, scratchGroupId=0)
    [DSP] @2,268,431tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,268,499tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=21
    [DSP] @2,268,572tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,268,627tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10b44)
    [DSP] @2,268,692tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,268,749tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10b44, memRecs=0x8ba04408)
    [DSP] @2,268,831tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires@6,240,653us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @6,240,854us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @6,241,105us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @6,241,277us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    .edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x7a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,268,915tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,268,974tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,269,028tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,269,090tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,269,143tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,269,212tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24a7d0)
    [DSP] @2,269,279tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,269,337tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,269,393tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,269,440tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,269,500tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,269,556tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,269,608tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,269,672tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,269,739tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,269,791tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,269,856tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,269,913tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,269,967tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,270,033tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,270,099tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8ba0ce20, protocolArgs=0x8ba10b5c, scratchGroupId=0)
    [DSP] @2,270,182tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,270,250tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=20
    [DSP] @2,270,323tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,270,378tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10b5c)
    [DSP] @2,270,443tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,270,501tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10b5c, memRecs=0x8ba04408)
    [DSP] @2,270,583tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x4a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,270,667tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,270,727tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,270,781tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,270,843tk: [@6,246,726us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @6,246,920us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @6,247,165us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @6,247,332us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,270,897tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,270,964tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0ce20)
    [DSP] @2,271,032tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,271,089tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,271,144tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,271,191tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,271,252tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,271,308tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,271,359tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,271,423tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,271,491tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,271,542tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,271,607tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,271,664tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,271,718tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,271,779tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,271,846tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24a850, protocolArgs=0x8ba10b74, scratchGroupId=0)
    [DSP] @2,271,929tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,271,997tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=19
    [DSP] @2,272,070tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,272,125tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10b74)
    [DSP] @2,272,190tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,272,247tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10b74, memRecs=0x8ba04408)
    [DSP] @2,272,332tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,272,416tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,272,475tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,272,530tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,272,591tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,272,645tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,272,713tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24a850)
    [DSP] @2,272,780tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,272,837tk: [+0 T:0x8ba007@7,258,353us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @7,258,553us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @7,258,799us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @7,258,971us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,272,893tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,272,940tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,273,001tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,273,056tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,273,108tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,273,171tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,273,239tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,273,291tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,273,355tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,273,413tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,273,466tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,273,528tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,273,594tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24a888, protocolArgs=0x8ba10b8c, scratchGroupId=0)
    [DSP] @2,273,678tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,273,745tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=18
    [DSP] @2,273,818tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,273,873tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10b8c)
    [DSP] @2,273,938tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,273,996tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10b8c, memRecs=0x8ba04408)
    [DSP] @2,274,078tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x6e, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,274,162tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,274,221tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,274,275tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,274,337tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,274,391tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,274,458tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24a888)
    [DSP] @2,274,526tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,274,584tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,274,645tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,274,692tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,274,753tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,274,809tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> E@7,265,103us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @7,267,322us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @7,267,791us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @7,268,296us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    nter
    [DSP] @2,274,861tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,274,924tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,274,992tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,275,044tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,275,108tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,275,166tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,275,219tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,275,280tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,275,347tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24a8f8, protocolArgs=0x8ba10ba4, scratchGroupId=0)
    [DSP] @2,275,431tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,275,498tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=17
    [DSP] @2,275,571tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,275,626tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10ba4)
    [DSP] @2,275,691tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,275,748tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10ba4, memRecs=0x8ba04408)
    [DSP] @2,275,830tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,275,914tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,275,974tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,276,028tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,276,089tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,276,143tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,276,211tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24a8f8)
    [DSP] @2,276,278tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,276,335tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,276,391tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,276,438tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,276,498tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,276,554tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,276,606tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,276,670tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,276,737tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,276,789tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.@7,275,629us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @7,275,947us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @7,276,219us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @7,276,387us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    ires.edma3chan)
    [DSP] @2,276,854tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,276,911tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,276,968tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,277,029tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,277,095tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24a930, protocolArgs=0x8ba10bbc, scratchGroupId=0)
    [DSP] @2,277,179tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,277,247tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=16
    [DSP] @2,277,319tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,277,375tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10bbc)
    [DSP] @2,277,440tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,277,497tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10bbc, memRecs=0x8ba04408)
    [DSP] @2,277,579tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,277,663tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,277,723tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,277,777tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,277,838tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,277,892tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,277,960tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24a930)
    [DSP] @2,278,027tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,278,085tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,278,140tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,278,187tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,278,249tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,278,305tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,278,357tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,278,420tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,278,488tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,278,539tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,278,604tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,278,662tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,278,715tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,278,776tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,27@7,287,757us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @7,288,274us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @7,288,846us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @7,289,432us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    8,843tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24a968, protocolArgs=0x8ba10bd4, scratchGroupId=0)
    [DSP] @2,278,927tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,278,994tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=15
    [DSP] @2,279,067tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,279,122tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10bd4)
    [DSP] @2,279,187tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,279,244tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10bd4, memRecs=0x8ba04408)
    [DSP] @2,279,331tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,279,415tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,279,474tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,279,528tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,279,590tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,279,644tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,279,711tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24a968)
    [DSP] @2,279,779tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,279,836tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,279,891tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,279,939tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,279,999tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,280,055tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,280,107tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,280,170tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,280,238tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,280,290tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,280,355tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,280,412tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,280,465tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,280,527tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,280,593tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24a9a0, protocolArgs=0x8ba10bec, scratchGroupId=0)
    [DSP] @2,280,677tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,280,745tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=14
    [DSP] @2,280,817tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc@7,305,566us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @7,306,091us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @7,306,662us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @7,307,167us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,280,873tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10bec)
    [DSP] @2,280,938tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,280,996tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10bec, memRecs=0x8ba04408)
    [DSP] @2,281,078tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,281,162tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,281,221tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,281,275tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,281,337tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,281,390tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,281,458tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24a9a0)
    [DSP] @2,281,525tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,281,587tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,281,643tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,281,690tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,281,751tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,281,808tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,281,860tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,281,924tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,281,991tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,282,043tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,282,108tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,282,165tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,282,218tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,282,280tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,282,346tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24a9d8, protocolArgs=0x8ba10c04, scratchGroupId=0)
    [DSP] @2,282,430tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,282,498tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=13
    [DSP] @2,282,571tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,282,626tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c04)
    [DSP] @2,282,691tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,282,749tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c04, memRecs=0x8ba04408)
    [DSP] @2,282,831tk: [+4 T:0x8ba00784 S:0x@7,322,120us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @7,322,321us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @7,322,565us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @7,322,734us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,282,915tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,282,974tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,283,028tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,283,090tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,283,143tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,283,211tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24a9d8)
    [DSP] @2,283,278tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,283,335tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,283,391tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,283,438tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,283,499tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,283,555tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,283,606tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,283,670tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,283,738tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,283,789tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,283,854tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,283,915tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,283,968tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,284,030tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,284,096tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24aa10, protocolArgs=0x8ba10c1c, scratchGroupId=0)
    [DSP] @2,284,179tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,284,247tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=12
    [DSP] @2,284,320tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,284,375tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c1c)
    [DSP] @2,284,440tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,284,497tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c1c, memRecs=0x8ba04408)
    [DSP] @2,284,579tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x4a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,284,663tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,284,722tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,284,777tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=@8,066,939us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @8,067,152us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @8,067,403us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @8,067,578us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    IRES_OK)
    [DSP] @2,284,838tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,284,892tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,284,960tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24aa10)
    [DSP] @2,285,027tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,285,084tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,285,139tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,285,187tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,285,247tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,285,303tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,285,355tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,285,418tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,285,486tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,285,538tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,285,603tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,285,660tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,285,713tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,285,775tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,285,841tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24aa60, protocolArgs=0x8ba10c34, scratchGroupId=0)
    [DSP] @2,285,925tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,285,993tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=11
    [DSP] @2,286,065tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,286,120tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c34)
    [DSP] @2,286,185tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,286,249tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c34, memRecs=0x8ba04408)
    [DSP] @2,286,332tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x4a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,286,415tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,286,475tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,286,529tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,286,590tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,286,644tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,286,712tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24aa60)
    [DSP] @2,286,779tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,2@8,077,824us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @8,078,349us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @8,078,923us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @8,079,725us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    86,837tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,286,893tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,286,940tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,287,001tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,287,056tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,287,108tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,287,171tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,287,239tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,287,291tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,287,355tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,287,413tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,287,466tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,287,528tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,287,594tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24aab0, protocolArgs=0x8ba10c4c, scratchGroupId=0)
    [DSP] @2,287,678tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,287,745tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=10
    [DSP] @2,287,818tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,287,873tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c4c)
    [DSP] @2,287,938tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,287,995tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c4c, memRecs=0x8ba04408)
    [DSP] @2,288,078tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,288,161tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,288,220tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,288,275tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,288,336tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,288,390tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,288,458tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24aab0)
    [DSP] @2,288,525tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,288,587tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,288,642tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,288,690tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,288,750tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,288,806tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - I@8,086,485us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @8,086,792us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @8,087,063us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @8,087,236us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,288,858tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,288,921tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,288,989tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,289,041tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,289,105tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,289,163tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,289,216tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,289,277tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,289,344tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24aae8, protocolArgs=0x8ba10c64, scratchGroupId=0)
    [DSP] @2,289,428tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,289,495tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=9
    [DSP] @2,289,568tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,289,623tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c64)
    [DSP] @2,289,688tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,289,745tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c64, memRecs=0x8ba04408)
    [DSP] @2,289,827tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,289,911tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,289,971tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,290,025tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,290,086tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,290,139tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,290,207tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24aae8)
    [DSP] @2,290,274tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,290,332tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,290,387tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,290,435tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,290,495tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,290,551tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,290,603tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,290,666tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,290,734tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,290,786tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName@8,100,502us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @8,101,034us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @8,101,612us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @8,102,119us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,290,851tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,290,914tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,290,967tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,291,029tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,291,095tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24ab20, protocolArgs=0x8ba10c7c, scratchGroupId=0)
    [DSP] @2,291,179tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,291,247tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=8
    [DSP] @2,291,319tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,291,375tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c7c)
    [DSP] @2,291,440tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,291,496tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c7c, memRecs=0x8ba04408)
    [DSP] @2,291,579tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x3e, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,291,663tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,291,722tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,291,776tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,291,838tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,291,892tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,291,959tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24ab20)
    [DSP] @2,292,027tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,292,084tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,292,139tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,292,186tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,292,247tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,292,303tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,292,355tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,292,418tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,292,486tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,292,538tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,292,602tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,292,660tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,292,713tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,292,775tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (@8,113,123us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @8,113,330us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @8,113,580us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @8,113,755us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    version=(1.0.0))
    [DSP] @2,292,841tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24ab60, protocolArgs=0x8ba10c94, scratchGroupId=0)
    [DSP] @2,292,925tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,292,992tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=7
    [DSP] @2,293,065tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,293,119tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10c94)
    [DSP] @2,293,189tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,293,246tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10c94, memRecs=0x8ba04408)
    [DSP] @2,293,328tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x3e, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,293,412tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,293,471tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,293,525tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,293,587tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,293,641tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,293,709tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24ab60)
    [DSP] @2,293,776tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,293,835tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,293,890tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,293,937tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,293,998tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,294,054tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,294,106tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,294,169tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,294,237tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,294,289tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,294,353tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,294,411tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,294,464tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,294,526tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,294,592tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24aba0, protocolArgs=0x8ba10cac, scratchGroupId=0)
    [DSP] @2,294,676tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,294,743tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=6
    [DSP] @2,294,816tk: [+0 T:0x8ba00784 S:0@8,122,781us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @8,123,303us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @8,123,873us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @8,124,378us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,294,871tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10cac)
    [DSP] @2,294,936tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,294,993tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10cac, memRecs=0x8ba04408)
    [DSP] @2,295,075tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x4a, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,295,159tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,295,218tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,295,272tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,295,334tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,295,387tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,295,455tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24aba0)
    [DSP] @2,295,528tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,295,586tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,295,642tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,295,689tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,295,749tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,295,805tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,295,857tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,295,921tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,295,988tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,296,040tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,296,105tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,296,162tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,296,215tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,296,277tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,296,343tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24abf0, protocolArgs=0x8ba10cc4, scratchGroupId=0)
    [DSP] @2,296,427tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,296,495tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=5
    [DSP] @2,296,567tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,296,622tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10cc4)
    [DSP] @2,296,687tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,296,745tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10cc4, memRecs=0x8ba04408)
    [DSP] @2,296,827tk: [+@8,140,788us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @8,141,307us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @8,141,879us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @8,142,385us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,296,911tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,296,971tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,297,025tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,297,086tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,297,139tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,297,207tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24abf0)
    [DSP] @2,297,274tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,297,332tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,297,387tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,297,435tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,297,495tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,297,551tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,297,603tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,297,667tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,297,734tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,297,786tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,297,857tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,297,914tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,297,967tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,298,029tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,298,095tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24ac28, protocolArgs=0x8ba10cdc, scratchGroupId=0)
    [DSP] @2,298,178tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,298,246tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=4
    [DSP] @2,298,318tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,298,373tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10cdc)
    [DSP] @2,298,438tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,298,496tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10cdc, memRecs=0x8ba04408)
    [DSP] @2,298,578tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x3e, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,298,662tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,298,721tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,298,776tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle@8,152,350us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @8,152,551us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @8,152,798us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @8,152,966us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,298,837tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,298,891tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,298,959tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24ac28)
    [DSP] @2,299,026tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,299,084tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,299,139tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,299,186tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,299,247tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,299,303tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,299,355tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,299,418tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,299,486tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,299,538tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,299,602tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,299,660tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,299,713tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,299,775tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,299,841tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24ac68, protocolArgs=0x8ba10cf4, scratchGroupId=0)
    [DSP] @2,299,925tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,299,992tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=3
    [DSP] @2,300,065tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,300,120tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10cf4)
    [DSP] @2,300,189tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,300,246tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10cf4, memRecs=0x8ba04408)
    [DSP] @2,300,328tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x3e, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,300,412tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,300,471tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,300,526tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,300,587tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,300,641tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,300,709tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24ac68)
    [DSP] @2,300,776tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (s@8,158,404us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @8,158,607us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @8,158,848us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @8,159,015us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    tatus=FALSE)
    [DSP] @2,300,833tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,300,889tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,300,936tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,300,997tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,301,053tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,301,104tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,301,168tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,301,235tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,301,287tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,301,352tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,301,409tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,301,462tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,301,524tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,301,590tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24aca8, protocolArgs=0x8ba10d0c, scratchGroupId=0)
    [DSP] @2,301,674tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,301,742tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=2
    [DSP] @2,301,814tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,301,869tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10d0c)
    [DSP] @2,301,934tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,301,991tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10d0c, memRecs=0x8ba04408)
    [DSP] @2,302,073tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,302,157tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,302,216tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,302,271tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,302,332tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,302,386tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,302,461tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24aca8)
    [DSP] @2,302,528tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,302,587tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,302,642tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,302,689tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,302,750tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,302,807tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ir@9,143,285us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @9,143,487us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @9,143,739us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @9,143,909us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,302,859tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,302,923tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,302,990tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,303,042tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,303,107tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,303,164tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,303,217tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,303,279tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,303,345tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24ace0, protocolArgs=0x8ba10d24, scratchGroupId=0)
    [DSP] @2,303,429tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,303,496tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=1
    [DSP] @2,303,569tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,303,624tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10d24)
    [DSP] @2,303,689tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,303,747tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10d24, memRecs=0x8ba04408)
    [DSP] @2,303,829tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,303,913tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,303,972tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,304,027tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,304,088tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,304,141tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,304,209tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24ace0)
    [DSP] @2,304,276tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,304,334tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,304,389tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,304,437tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,304,497tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Enter
    [DSP] @2,304,553tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,304,605tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Exit (Name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,304,668tk: [+0 T:0x8ba00784 S:0x8ba043cc] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolName> Exit (name=ti.sdo.fc.ires.edma3chan)
    [DSP] @2,304,736tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getName> Enter
    [DSP] @2,304,791tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_E@9,159,993us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @9,160,503us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @9,160,771us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @9,160,938us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,304,856tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Enter
    [DSP] @2,304,913tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Enter
    [DSP] @2,304,966tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getRevision> Exit (Version=(1.0.0))
    [DSP] @2,305,028tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_getProtocolRevision> Exit (version=(1.0.0))
    [DSP] @2,305,094tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandle> Enter (handle=0x8c24ad18, protocolArgs=0x8ba10d3c, scratchGroupId=0)
    [DSP] @2,305,178tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Enter (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,305,245tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> (alg=0x8ba0f460, scratchGroupId=0) entry->refCount=0
    [DSP] @2,305,318tk: [+2 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Closing RM Handle (alg=0x8ba0f460, scratchGroupId=0)
    [DSP] @2,305,392tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.edma3 - closeRMHandle> Enter (handle=0x8fa96788)
    [DSP] @2,305,462tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.edma3 - closeRMHandle> Exit (status=0x0)
    [DSP] @2,305,518tk: [+0 T:0x8ba00784 S:0x8ba04354] ti.sdo.ce.osal.Sem - Sem_delete> sem: 0x8ba0cd44
    [DSP] @2,305,578tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,305,635tk: [+0 T:0x8ba00784 S:0x8ba0430c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,305,703tk: [+0 T:0x8ba00784 S:0x8ba042ec] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8ba0ccb0)
    [DSP] @2,305,770tk: [+0 T:0x8ba00784 S:0x8ba042ec] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,305,827tk: [+0 T:0x8ba00784 S:0x8ba0430c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,305,883tk: [+0 T:0x8ba00784 S:0x8ba0433c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,305,933tk: [+0 T:0x8ba00784 S:0x8ba0431c] ti.sdo.fc.edma3 - unpoulateScratchGroups> Enter (scratchGroupId=0)
    [DSP] @2,305,991tk: [+2 T:0x8ba00784 S:0x8ba0431c] ti.sdo.fc.edma3 - unpopulateScratchGroup> Freeing 24 tccs 24 edma 0 qdma channels and 384 params
    [DSP] @2,306,450tk: [+2 T:0x8ba00784 S:0x8ba0431c] ti.sdo.fc.edma3 - unpopulateScratchGroup> Exit (status=1)
    [DSP] @2,306,504tk: [+0 T:0x8ba00784 S:0x8ba04364] ti.sdo.fc.edma3 - EDMA3_releaseResourceManager> Exit (status=0)
    [DSP] @2,306,560tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Enter (protArgs=0x8ba10d3c)
    [DSP] @2,306,625tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getNumMemRecs> Exit (Num=1)
    [DSP] @2,306,682tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Enter (handle=0x0, resProtocolArgs=0x8ba10d3c, memRecs=0x8ba04408)
    [DSP] @2,306,764tk: [+4 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Amount of memory requested 0x38, alignment 0x4, space IALG_EXTERNAL attrs IALG_PERSIST
    [DSP] @2,306,848tk: [+0 T:0x8ba00784 S:0x8ba04374] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_getMemRecs> Exit (status=IRES_EOK)
    [DSP] @2,306,908tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Enter
    [DSP] @2,306,962tk: [+0 T:0x8ba00784 S:0x8ba04394] ti.sdo.fc.ires.edma3Chan - IRES_EDMA3CHAN_destructHandle> Exit (returnVal=IRES_OK)
    [DSP] @2,307,023tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,307,077tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,307,164tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24ad18)
    [DSP] @2,307,231tk: [+0 T:0x8ba00784 S:0x8ba0432c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,307,2@9,167,211us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @9,167,408us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @9,167,652us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @9,167,825us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    91tk: [+0 T:0x8ba00784 S:0x8ba0434c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,307,346tk: [+0 T:0x8ba00784 S:0x8ba0437c] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,307,394tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.ires.edma3Chan - IRESMAN_EDMA3CHAN_freeHandles> Exit (status=0)
    [DSP] @2,307,455tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Enter (numRecs=1)
    [DSP] @2,307,511tk: [+0 T:0x8ba00784 S:0x8ba0438c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=-1, number=1, extHeapId=0)
    [DSP] @2,307,579tk: [+0 T:0x8ba00784 S:0x8ba0436c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=-1, addr=0x8c24a4a0)
    [DSP] @2,307,646tk: [+0 T:0x8ba00784 S:0x8ba0436c] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Exit (status=FALSE)
    [DSP] @2,307,703tk: [+0 T:0x8ba00784 S:0x8ba0438c] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,307,759tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - DSKT2_freePersistent> Exit
    [DSP] @2,307,807tk: [+0 T:0x8ba00784 S:0x8ba04404] ti.sdo.fc.rman - RMAN_assignResources> Exit (status=7)
    [DSP] @2,307,865tk: [+7 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> Assignment of alg resources through RMAN FAILED (0x7)
    [DSP] @2,307,937tk: [+0 T:0x8ba00784 S:0x8ba04434] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(alg=0x8fa9f0d8)
    [DSP] @2,308,000tk: [+0 T:0x8ba00784 S:0x8ba043fc] ti.sdo.fc.dskt2 - DSKT2_freeAlg> Enter (scratchMutexId=0, alg=0x8ba0f460)
    [DSP] @2,308,073tk: [+2 T:0x8ba00784 S:0x8ba043fc] ti.sdo.fc.dskt2 - DSKT2_freeAlg> Dequeue alg  information
    [DSP] @2,308,126tk: [+0 T:0x8ba00784 S:0x8ba043c4] ti.sdo.fc.dskt2 - _DSKT2_dequeueMemTab> Enter (segId=0, alg=0x8ba0f460)
    [DSP] @2,308,196tk: [+0 T:0x8ba00784 S:0x8ba043c4] ti.sdo.fc.dskt2 - _DSKT2_dequeueMemTab> Exit (memTab=0x8ba0cb80)
    [DSP] @2,308,255tk: [+2 T:0x8ba00784 S:0x8ba043fc] ti.sdo.fc.dskt2 - DSKT2_freeAlg> Dequeued alg information, memTab 0x8ba0cb80 memTabSize 240, numRecs 12, extHeapId 0
    [DSP] @2,308,335tk: [+2 T:0x8ba00784 S:0x8ba043fc] ti.sdo.fc.dskt2 - DSKT2_freeAlg> Free instance memory
    [DSP] @2,308,389tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.dskt2 - _DSKT2_freeInstanceMemory> Enter (scratchMutexId=0, numRecs=12, extHeapId=0)
    [DSP] @2,308,457tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Enter (scratchMutexId=0, number=12, extHeapId=0)
    [DSP] @2,308,525tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x8ba0f460)
    [DSP] @2,308,593tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=0 )
    [DSP] @2,308,649tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x11818000)
    [DSP] @2,308,716tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=1 )
    [DSP] @2,308,769tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x8ba11360)
    [DSP] @2,308,836tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=0 )
    [DSP] @2,308,893tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x8ba11f60)
    [DSP] @2,308,960tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=0 )
    [DSP] @2,309,016tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x8ba17b60)
    [DSP] @2,309,083tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=0 )
    [DSP] @2,309,138tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x8ba18f60)
    [DSP] @2,309,206tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=0 )
    [DSP] @2,309,263tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x1181dc00)
    [DSP] @2,309,330tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=1 )
    [DSP] @2,309,383tk: [+0 T:0x8ba00784@9,180,265us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @9,180,464us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @9,180,712us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @9,180,883us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
     S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x1181e800)
    [DSP] @2,309,455tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=1 )
    [DSP] @2,309,509tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x8c249b00)
    [DSP] @2,309,576tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=0 )
    [DSP] @2,309,635tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x11827b80)
    [DSP] @2,309,702tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=1 )
    [DSP] @2,309,755tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x8ba0cc80)
    [DSP] @2,309,822tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=0 )
    [DSP] @2,309,878tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratchAddr> Enter (scratchMutexId=0, addr=0x11827c80)
    [DSP] @2,309,945tk: [+0 T:0x8ba00784 S:0x8ba04384] ti.sdo.fc.dskt2 - _DSKT2_isSharedScratch> Exit (status=1 )
    [DSP] @2,309,998tk: [+0 T:0x8ba00784 S:0x8ba043a4] ti.sdo.fc.dskt2 - _DSKT2_freeAllocatedMemory> Exit (returnVal=1)
    [DSP] @2,310,054tk: [+0 T:0x8ba00784 S:0x8ba043b4] ti.sdo.fc.dskt2 - _DSKT2_usesInternalScratch> Enter (numRecs=12)
    [DSP] @2,310,110tk: [+0 T:0x8ba00784 S:0x8ba043b4] ti.sdo.fc.dskt2 - _DSKT2_usesInternalScratch> Exit (returnVal=1)
    [DSP] @2,310,168tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - _DSKT2_decrScratchReferenceCount> Enter (scratchMutexId=0)
    [DSP] @2,310,232tk: [+0 T:0x8ba00784 S:0x8ba043bc] ti.sdo.fc.dskt2 - _DSKT2_decrScratchReferenceCount> Exit
    [DSP] @2,310,285tk: [+0 T:0x8ba00784 S:0x8ba043b4] ti.sdo.fc.dskt2 - _DSKT2_exitScratch> Enter (scratchMutexId=0)
    [DSP] @2,310,341tk: [+0 T:0x8ba00784 S:0x8ba043d4] ti.sdo.fc.dskt2 - _DSKT2_freeInstanceMemory> Exit (returnVal=1)
    [DSP] @2,310,397tk: [+0 T:0x8ba00784 S:0x8ba043fc] ti.sdo.fc.dskt2 - DSKT2_freeAlg> Exit
    [DSP] @2,310,444tk: [+0 T:0x8ba00784 S:0x8ba04404] OM - Memory_free> Enter(addr=0x8fa9f0d8, size=16)
    [DSP] @2,310,500tk: [+0 T:0x8ba00784 S:0x8ba04404] OM - Memory_free> return (0x1)
    [DSP] @2,310,545tk: [+0 T:0x8ba00784 S:0x8ba04434] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Exit
    [DSP] @2,310,595tk: [+0 T:0x8ba00784 S:0x8ba04454] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x0)
    [DSP] @2,310,651tk: [+2 T:0x8ba00784 S:0x8ba0449c] CV - VISA_create2> FAILED to create local codec.
    [DSP] @2,310,703tk: [+0 T:0x8ba00784 S:0x8ba0446c] CV - VISA_delete(0x8fa9f0a8)
    [DSP] @2,310,749tk: [+5 T:0x8ba00784 S:0x8ba0446c] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
    [DSP] @2,310,814tk: [+0 T:0x8ba00784 S:0x8ba0443c] OM - Memory_free> Enter(addr=0x8fa9f0a8, size=48)
    [DSP] @2,310,869tk: [+0 T:0x8ba00784 S:0x8ba0443c] OM - Memory_free> return (0x1)
    [DSP] @2,310,916tk: [+0 T:0x8ba00784 S:0x8ba045e4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
    [DSP] @2,310,978tk: [+0 T:0x8ba00784 S:0x8ba045d4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> Enter (handle=0x0)
    [DSP] @2,311,033tk: [+0 T:0x8ba00784 S:0x8ba045a4] CV - VISA_delete(0x0)
    [DSP] @2,311,073tk: [+0 T:0x8ba00784 S:0x8ba045d4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> return
    [DSP] @2,311,130tk: [+0 T:0x8ba00784 S:0x8ba045bc] OM - Memory_free> Enter(addr=0x8fa9f050, size=36)
    [DSP] @2,311,188tk: [+0 T:0x8ba00784 S:0x8ba045bc] OM - Memory_free> return (0x1)
    [DSP] @2,311,232tk: [+0 T:0x8ba00784 S:0x8ba045c4] OM - Memory_free> Enter(addr=0x8fa9f030, size=32)
    [DSP] @2,311,286tk: [+0 T:0x8ba00784 S:0x8ba045c4] OM - Memory_free> return (0x1)
    [DSP] @2,311,333tk: [+0 T:0x8ba00784 S:0x8ba04644] OM - Memory_free> Enter(addr=0x8fa9f020, size=14)
    [DSP] @2,311,387tk: [+0 T:0x8ba00784 S:0x8ba04644] OM - Memory_free> return (0x1)
    [DSP] @2,311,431tk: [+0 T:0x8ba00784 S:0x8ba04644] OM - Memory_free> Enter(addr=0x8fa9f008, size=24)
    [DSP] @2,311,485tk: [+0 T:0x8ba00784 S:0x8ba04644] OM - Memory_free> return (0x1)
    [DSP] @2,325,074tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @2,325,130tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remo@9,186,688us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> Enter(queue=0x0, msg=0x41efd880)
    @9,186,890us: [+0 T:0x4001fb20 S:0xbefb1964] OC - Comm_put> return (0)
    @9,187,137us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> Enter(queue=0x10000, msg=0xbefb19fc, timeout=-1)
    @9,187,310us: [+0 T:0x4001fb20 S:0xbefb195c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    te time = 0x0, trace buffer size = 4032
    [DSP] @2,380,250tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @2,380,305tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @2,434,994tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @2,435,049tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @2,487,734tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @2,487,788tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @2,540,737tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @2,540,792tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @2,595,295tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @2,595,349tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @2,647,407tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @2,647,462tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @2,697,595tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @2,697,649tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @2,722,202tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @2,722,256tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @4,323,169tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @4,323,223tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @4,451,585tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @4,451,639tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @4,478,160tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @4,478,214tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @4,507,670tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @4,507,724tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @4,536,069tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @4,536,123tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @4,566,559tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @4,566,614tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @4,592,803tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @4,592,856tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @4,611,404tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @4,611,458tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @4,892,211tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @4,892,264tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @7,730,351tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @7,730,406tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @7,752,674tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @7,752,728tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @7,796,070tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @7,796,125tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @7,816,148tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @7,816,201tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @7,840,665tk: [+0 T:0x8ba00784 S:0x8ba04744] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @7,840,719tk: [+@9,192,817us: [+0 T:0x4001fb20 S:0xbefb1994] CE - Engine_fwriteTrace> returning count [278592]
    @9,192,958us: [+2 T:0x4001fb20 S:0xbefb19fc] CE - Engine_createNode> Returning 0x0
    @9,193,074us: [+2 T:0x4001fb20 S:0xbefb1a74] CV - VISA_create2> FAILED to create remote codec (0x8).
    @9,886,178us: [+0 T:0x4001fb20 S:0xbefb1a4c] CV - VISA_delete(0x5a9c0)
    @9,886,322us: [+5 T:0x4001fb20 S:0xbefb1a4c] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
    @9,886,453us: [+0 T:0x4001fb20 S:0xbefb1a2c] OM - Memory_free> Enter(0x5a9c0, 0x30)
    @9,886,580us: [+0 T:0x4001fb20 S:0xbefb1a2c] OM - Memory_free> return (0x1)
    @9,886,700us: [+0 T:0x4001fb20 S:0xbefb1ba4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
    Failed to create video encoder: h264fhdvenc
  • From the trace it seems like the resource manager is actually running out of resources to grant. The trace is not complete, so I couldn't really count to account for the number of TCCs requested.
    But in the end, it seems to run out of TCCs.
    - Could you confirm the total number of TCCs that the codec actually requests ? This can be determined from the file that implements the IRES_Fxns interface in the codec or from codec data sheet.
    - Your configuration puts the total number of EDMA channels and TCCs at 24 for scratch group 0
    EDMA3.maxTccs[0] = 24;
        EDMA3.maxEdmaChannels[0] = 24;
    Maybe you could increase the above numbers to somethign greater, to see if codec creation proceeds further.
  • Thanks for your answer at first,
    I have changed my configuration about those parameters(maxTccs&maxEdmaChannels) that you mentioned. From the datasheet, I am acknowledged that this lib require 49 channels&Tcc.
    Now, It can be created successfully after following your suggestion, I changed them from 24 to 49.
    but there are 2 further problems about the configurations for Param&DynamicParam, could you give me some further suggestion?
    Note: My platform is DM6467, calling these interface through Codec_Engine in Linux, and the alg is in DSP
    1.when I call venc1_control( , GETBUFINFO,  &DynamicParam, &status), it gives the result of status as following:
    minNumInBufs of H264 is 2
    InBufSize[0] of H264 is 2088960
    InBufSize[1] of H264 is 1044480
    minNumOutBufs of H264 is 1
    OutBufSize[0] of H264 is 0
    it is obviously that the OutBufSize[0] is wrong, it should be (2088960 + 1044480), but the return value of venc1_control is 0(success). so i am very confused.
    2.when I call venc1_control( , SETPARAM,  &DynamicParam, &status), it failed, and it's return value is 57344
    I think the above two problem are reference to the configurations of Param&DynamicParam. Is there anyone teach me how to config these parameters?
    my configurations for Param&DynamicParam as followings:
     g_paraH264.videncParams.size   = sizeof(IH264FHDVENC_Params) ;
     g_paraH264.videncParams.encodingPreset  = XDM_DEFAULT ;
     g_paraH264.videncParams.rateControlPreset = IVIDEO_LOW_DELAY ;
     g_paraH264.videncParams.maxHeight  = 1920;
     g_paraH264.videncParams.maxWidth  = 1088;
     g_paraH264.videncParams.maxFrameRate  = 30000 ;
     g_paraH264.videncParams.maxBitRate  = 10000000 ;
     g_paraH264.videncParams.dataEndianness  = XDM_LE_32 ;
     g_paraH264.videncParams.maxInterFrameInterval = 0 ;
     g_paraH264.videncParams.inputChromaFormat = XDM_YUV_420SP ;
     g_paraH264.videncParams.inputContentType = IVIDEO_PROGRESSIVE ;
     g_paraH264.videncParams.reconChromaFormat = -1 ;
     g_paraH264.profileIdc    = 66 ; //BASELINE_PROFILE
     g_paraH264.levelIdc    = 40;
     g_paraH264.EntropyCodingMode   = 0 ; //CAVLC
     g_dpH264DynParams.videncDynamicParams.inputHeight = 1920;
     g_dpH264DynParams.videncDynamicParams.inputWidth = 1088;
     g_dpH264DynParams.videncDynamicParams.refFrameRate =30000;
     g_dpH264DynParams.videncDynamicParams.targetFrameRate = 30000 ;
     g_dpH264DynParams.videncDynamicParams.targetBitRate = 10000000 ;
     g_dpH264DynParams.videncDynamicParams.intraFrameInterval= 30;
     g_dpH264DynParams.videncDynamicParams.generateHeader = XDM_ENCODE_AU ;
     g_dpH264DynParams.videncDynamicParams.captureWidth = 0 ;
     g_dpH264DynParams.videncDynamicParams.forceFrame = -1 ;
     g_dpH264DynParams.videncDynamicParams.interFrameInterval= 0 ;
     g_dpH264DynParams.videncDynamicParams.mbDataFlag = 0 ;
     g_dpH264DynParams.QPISlice    = 28 ;
     g_dpH264DynParams.QPSlice    = 28 ;
     g_dpH264DynParams.RateCtrlQpMax    = 51 ;
     g_dpH264DynParams.RateCtrlQpMin    = 0 ;
     g_dpH264DynParams.NumRowsInSlice   = 0 ;
     g_dpH264DynParams.LfDisableIdc    = 0 ;
     g_dpH264DynParams.LFAlphaC0Offset   = 0 ;
     g_dpH264DynParams.LFBetaOffset    = 0 ;
     g_dpH264DynParams.ChromaQPOffset   = 0 ;
     g_dpH264DynParams.SecChromaQPOffset   = 0 ;
     g_dpH264DynParams.OutBufSize                 = -1;
  • Shaquille,
    Could you please enable the VISA checking in your configuration file for your ARM side app, by adding the following line to the .cfg file:
    /* set to true to enable checked libraries */
    xdc.useModule('ti.sdo.ce.Settings').checked = false;
    Then if you rebuild your app and re-run with CE_DEBUG=2, we should have more information where the failure is. Could you please attach the trace log?
        Janet
  • Thanks for your suggestion,
    I have set parameter in successfully through changing some parameters.but the "GET_BUFINFO" problem is still as past.
    now, i have a further question that is about MaxSlicesSupported_IFrame&MaxSlicesSupported_PFrame, they are require configurations as followings as the UserGuide prompting :
    Valid range is >0
    Default Values:
    90 for 30fps
    263 for 25fps
    306 for 24fps
    948 for 15fps
    but my device is just 10fps, so i want to know how to set these two parameters when my fps is 10?
    Another question is that I setting intraframeinterval = 10 in the dynamicparameter, but i just get i-frame as normal after calling "process", the other frame is abnormal.
    Because the other 9 frames' size(the generateBytes of outarg) are 12 or 11. so i think they are abnormal.
    my basice steps as following:
    dynamicparameter.intraframeinterval = 10;
    dynamicparameter.forceframe= -1;
    control(,SET_PARAM,)
    while(1)
        process(.....);
    who can help me?
  • janet,
           I encount the same problem with Shaquille's,and I do it according to  your method, adding the following line to my server .cfg file:
    xdc.useModule('ti.sdo.fc.global.Settings').profile = "debug_trace";
    and setting as follow in my server .cfg file:
    DSKT2.trace = true;//false;
    DSKT2.debug = true;//false;
    rebuild the server and re-run my app.
    But I cann't get more failure infomation than before.I am confusing now,and hopefully you can give me some  suggest. Thanks a lot.
    LiuLiang
  • LiuLiang,
    When you say you are encountering the same problem as Shaquille's, are you referring to the remote codec creation failure, the OutBufSize[0] being wrong, or one of the other problems mentioned in this thread?  Did you run your app with CE_DEBUG=2?
    As this thread is becoming difficult to navigate through, with the pages and pages of trace, could you please start a new thread, and give us the versions of Codec Engine (or DVSDK) you are using and a description of the problem you are having?  That would be very helpful for us.
        Janet
  • Janet,
            Thanks for your answers first!
             The DVEVM which I using is DM6467T,and the DVSDK  is dvsdk_2_00_00_22,and the code sever is cs2dm6467_1_00_00_10. Now,I want to test the encoder and decoder h264enc\h264dec\h264fhvdenc\h2641080p60vdec in the code server cs2dm6467_1_00_00_10. The other three are OK,but h264fhvdenc encounted the following problem.
    1.ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x61b00, name='h264fhdvenc', params=0x422ead84)
    CE - Engine_createNode> Remote node creation FAILED (0x80008008).
    2.ti.sdo.ce.alg.Algorithm - Algorithm_create> Algorithm creation FAILED; make sure that 1) alg params are correct/appropriate, 2) there is enough internal and external algorithm memory available -- check DSKT2 settings for heap assignments and scratch allocation
    3.CV - VISA_create2> FAILED to create local codec.
    4.CV - VISA_create2> FAILED to create remote codec (0x8).
    5.ti.sdo.dmai - [Venc1] Failed to open video encode algorithm: h264fhdvenc (0x8)
           So,I want to printf the error information of DSKT2 etc.I  try to set CE_DEBUG=3 and CE_DEBUG=2,the result has no differences that has ce_debug and dmai only.
           Now,I want to solve two problems, printfing debug_trace of DSKT2 and other modules debug_trace of framework_components is one,the other is solving the  problem that CE - Engine_createNode> Remote node creation FAILED (0x80008008).
           Hopefully you can give me some suggests.Thanks a lot.
    LiuLiang
  • Janet,
             The log details are following,please look up if  you need.
    root@iview:/mnt/nfs/liul/encoderdecoder_demo_TI# CE_DEBUG=2 DMAI_DEBUG=2 ./encodedecode -p -y3
    @0,139,882us: [+4 T:0x4001ee40] OG - Global_init> This program was built with the following packages:
    @0,140,656us: [+4 T:0x4001ee40] OG -     package gnu.targets.rts470MV (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/gnu/targets/rts470MV/) [1,0,0,0,1225517438755]
    @0,141,155us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h264fhdvenc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1,0,0,1322634196000]
    @0,141,625us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1,0,0,1322634196000]
    @0,142,102us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.global (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    @0,142,563us: [+4 T:0x4001ee40] OG -     package ti.xdais.dm (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
    @0,143,041us: [+4 T:0x4001ee40] OG -     package ti.sdo.utils.trace (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    @0,143,571us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.utils.xdm (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    @0,144,035us: [+4 T:0x4001ee40] OG -     package ti.xdais (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    @0,144,557us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.node (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    @0,145,011us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.global (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    @0,145,619us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.dman3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    @0,146,083us: [+4 T:0x4001ee40] OG -     package ti.sdo.linuxutils.cmem (/home/liul/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/) [2,2,0,1240253001679]
    @0,146,549us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.memutils (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    @0,147,015us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.acpy3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    @0,147,479us: [+4 T:0x4001ee40] OG -     package dsplink.gpp (/home/liul/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/gpp/) [5,0,0,1318065716000]
    @0,147,935us: [+4 T:0x4001ee40] OG -     package gnu.targets (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/gnu/targets/) [1,0,1,1225517427930]
    @0,148,385us: [+4 T:0x4001ee40] OG -     package ti.catalog.c470 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c470/) [1,0,1,0,0]
    @0,148,833us: [+4 T:0x4001ee40] OG -     package ti.catalog.c6000 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    @0,149,423us: [+4 T:0x4001ee40] OG -     package ti.platforms.evmDM6467 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    @0,149,883us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.osal (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    @0,150,490us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.osal.linux (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/linux/) [2,0,1,1240276736840]
    @0,150,955us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.ipc (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    @0,151,409us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.ipc.dsplink (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/) [2,0,1,1240276714152]
    @0,151,875us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.alg (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    @0,152,328us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    @0,152,776us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.video1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
    @0,153,234us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1322634196000]
    @0,153,708us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.video2 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
    @0,154,244us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1,0,0,1322634196000]
    @0,154,727us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.speech (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech/) [1,0,2,1240276762193]
    @0,155,328us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.speech1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech1/) [1,0,1,1240276763928]
    @0,155,789us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.audio (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio/) [1,0,2,1240276296374]
    @0,156,246us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.audio1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
    @0,156,705us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.video (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video/) [1,0,3,1240276930771]
    @0,157,162us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.image (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image/) [1,0,3,1240276700525]
    @0,157,619us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.image1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
    @0,158,077us: [+4 T:0x4001ee40] OG -     package ti.sdo.dmai (/home/liul/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/) [1,0,0,1322645673000]
    @0,158,527us: [+4 T:0x4001ee40] OG -     package ti.sdo.simplewidget (/home/liul/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/packages/ti/sdo/simplewidget/) []
    @0,159,058us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.bioslog (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
    @0,159,667us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.utils.trace (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/trace/) [1,0,1,1240276915917]
    @0,159,782us: [+4 T:0x4001ee40] OG -     package encodedecode_config (/home/liul/encoderdecoder_demo_TI/encodedecode/encodedecode_config/) []
    @0,160,451us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,160,583us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x611c0]
    @0,160,674us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,160,753us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x611d8]
    @0,160,835us: [+0 T:0x4001ee40] OT - Thread_create> Enter (fxn=0x2c464, attrs=0x0)
    @0,161,302us: [+0 T:0x4001ee40] OT - Thread_create> Exit (task=0x61210)
    @0,161,482us: [+0 T:0x4001ee40] ti.sdo.ce.alg - ALG_init> Enter
    @0,161,576us: [+0 T:0x4001ee40] ti.sdo.ce.alg - ALG_init> Exit
    @0,161,728us: [+6 T:0x4001ee40] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
    @0,161,894us: [+0 T:0x4001ee40] CS - Server_init()
    @0,161,977us: [+0 T:0x4001ee40] CS - Server_init> Global_useLinkArbiter = 0
    @0,162,214us: [+2 T:0x4001ee40] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note that calling CERuntime_init after this point may cause unexpected change to DMAI tracing behavior.
    Encodedecode demo started.
    create success name encodedecode!
    @0,176,308us: [+0 T:0x422eb490] CE - Engine_open> Enter('encodedecode', 0x0, 0x422eacb4)
    @0,176,421us: [+0 T:0x422eb490] CE - rserverOpen('./cs.x64P'), count = 0
    @0,176,502us: [+0 T:0x422eb490] OP - Processor_create> Enter(imageName='./cs.x64P', linkCfg='(null)', attrs=0x422eac98)
    @0,182,201us: [+0 T:0x422eb490] OP - doCmd> Enter (cmdId=1, proc=0x61b30)
    @0,182,328us: [+0 T:0x422eb490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611c0]
    @0,182,477us: [+0 T:0x422eb490] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x611c0]
    @0,182,570us: [+0 T:0x422eb490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611d8] timeout[0xffffffff]
    @0,183,728us: [+0 T:0x4001ee40] CE - Engine_open> Enter('encodedecode', 0x0, 0xbeb95ae4)
    @0,245,784us: [+1 T:0x40aeb490] OP - daemon> thread created.
    @0,246,181us: [+0 T:0x40aeb490] OP - getCmd_d> Enter (proc=0x40aeade8)
    @0,246,578us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611c0] timeout[0xffffffff]
    @0,247,002us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611c0] status[0]
    @0,247,417us: [+0 T:0x40aeb490] OP - getCmd_d> Exit (result=1)
    @0,247,804us: [+0 T:0x40aeb490] OP - Processor_create_d> Enter(proc=0x61b30)
    @0,248,207us: [+2 T:0x40aeb490] OP - Processor_create_d> Initializing DSP PROC...
    @0,248,614us: [+2 T:0x40aeb490] OP - Processor_create_d> Using DspLink config data for entry #0 [server './cs.x64P']
    @0,249,061us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1, syncd=0
    @0,249,655us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1, syncd=0
    @0,250,147us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESETCTRL', startAddress=0x8ff00000, sizeInBytes=0x80, shared=1, syncd=0
    @0,250,635us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x88000000, sizeInBytes=0x7a00000, shared=0, syncd=0
    @0,251,124us: [+2 T:0x40aeb490] OP - Processor_create_d> DODSPCTRL was=1; now=0
    @0,253,677us: [+2 T:0x40aeb490] OP - Processor_create_d> Attaching to DSP PROC...
    @0,257,896us: [+2 T:0x40aeb490] OP - Processor_create_d> Opening MSGQ pool...
    @0,258,601us: [+2 T:0x40aeb490] OP - Processor_create_d> Loading ./cs.x64P on DSP (1 args)...
    @0,471,246us: [+2 T:0x412eb490] ti.sdo.dmai - [Display] Video output set to size 1280x720 pitch 1280
    @0,471,902us: [+2 T:0x412eb490] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffers
    @0,472,295us: [+2 T:0x412eb490] ti.sdo.dmai - [Buffer] Set user pointer 0x42b69000 (physical 0x82800000)
    @0,669,426us: [+2 T:0x412eb490] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x42b69000 has physical address 0x82800000
    @0,669,811us: [+2 T:0x412eb490] ti.sdo.dmai - [Buffer] Set user pointer 0x42f5e000 (physical 0x82400000)
    @0,866,718us: [+2 T:0x412eb490] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x42f5e000 has physical address 0x82400000
    @0,867,103us: [+2 T:0x412eb490] ti.sdo.dmai - [Buffer] Set user pointer 0x43353000 (physical 0x82000000)
    @1,063,960us: [+2 T:0x412eb490] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x43353000 has physical address 0x82000000
    @1,070,911us: [+2 T:0x40aeb490] OP - Processor_create_d> Starting DSP PROC...
    @1,168,135us: [+2 T:0x40aeb490] OP - Processor_create_d> Opening remote transport...
    @1,200,919us: [+2 T:0x40aeb490] OP - Processor_create_d> return (1)
    @1,216,281us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611d8]
    @1,221,935us: [+0 T:0x422eb490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611d8] status[0]
    @1,222,051us: [+0 T:0x422eb490] OP - doCmd> Exit (result=1)
    @1,222,147us: [+0 T:0x422eb490] OP - Processor_create> return (0x61b30)
    @1,222,221us: [+0 T:0x422eb490] CE - rserverOpen('./cs.x64P'): 0x60194 done.
    @1,223,746us: [+0 T:0x4001ee40] CE - rserverOpen('./cs.x64P'), count = 1
    @1,223,870us: [+0 T:0x4001ee40] CE - rserverOpen('./cs.x64P'): 0x60194 done.
    @1,224,567us: [+0 T:0x422eb490] CE - checkServer(0x61b00)
    @1,225,070us: [+0 T:0x422eb490] CE - rmsInit> RMS initialized(0x61b00); CE_DEBUG on, setting DSP trace mask to *+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3
    @1,225,198us: [+0 T:0x422eb490] CE - Engine_setTrace> Enter(engine=0x61b00, mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
    @1,225,304us: [+1 T:0x422eb490] CE - Engine_setTrace> Requesting DSP set trace ...
    @1,225,561us: [+0 T:0x4001ee40] CE - checkServer(0x61b58)
    @1,226,906us: [+0 T:0x422eb490] CE - Engine_setTrace> return(0)
    [DSP] @0x000001bb:[T:0x00000000] codec_unitserver - main> Welcome to CS2DM6467 1.00.00.10 DSP server's main().
    [DSP] @0,221,949tk: [+0 T:0x8ba0006c] OG - Global_setSpecialTrace> enter(mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
    [DSP] @0,222,037tk: [+4 T:0x8ba0006c] OG - Global_setSpecialTrace> This program was built with the following packages:
    [DSP] @0,222,090tk: [+4 T:0x8ba0006c] OG -     package ti.targets.rts6000 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/targets/rts6000/) [1,0,0,0,1225517497925]
    [DSP] @0,222,164tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.aachedec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aachedec/) [1,0,0,1322634195000]
    [DSP] @0,222,241tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.g711dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711dec/) [1,0,0,1322634195000]
    [DSP] @0,222,318tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.g711enc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711enc/) [1,0,0,1322634196000]
    [DSP] @0,222,394tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1,0,0,1322634196000]
    [DSP] @0,222,476tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/) [1,0,0,1322634196000]
    [DSP] @0,222,552tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264enc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/) [1,0,0,1322634196000]
    [DSP] @0,222,629tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264fhdvenc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1,0,0,1322634196000]
    [DSP] @0,222,708tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg2dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/) [1,0,0,1322634197000]
    [DSP] @0,222,785tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.jpegdec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegdec/) [1,0,0,1322634196000]
    [DSP] @0,222,862tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.jpegenc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegenc/) [1,0,0,1322634197000]
    [DSP] @0,222,938tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg4dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/) [1,0,0,1322634197000]
    [DSP] @0,223,015tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg4enc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/) [1,0,0,1322634197000]
    [DSP] @0,223,092tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.hdvicp (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/hdvicp/) [1,0,0,1322634196000]
    [DSP] @0,223,167tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.global (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    [DSP] @0,223,287tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.ires.hdvicp (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/hdvicp/) [1,0,1,1240266763264]
    [DSP] @0,223,366tk: [+4 T:0x8ba0006c] OG -     package ti.rtdx (/home/liul/dvsdk_2_00_00_22/bios_5_33_03/packages/ti/rtdx/) [2,0,0,4,1219531643983]
    [DSP] @0,223,430tk: [+4 T:0x8ba0006c] OG -     package ti.psl (/home/liul/dvsdk_2_00_00_22/bios_5_33_03/packages/ti/psl/) [5,0,0,0,0]
    [DSP] @0,223,489tk: [+4 T:0x8ba0006c] OG -     package ti.bios (/home/liul/dvsdk_2_00_00_22/bios_5_33_03/packages/ti/bios/) [5,2,5,6,1227035764854]
    [DSP] @0,223,553tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.dskt2 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dskt2/) [1,0,4,1240266678055]
    [DSP] @0,223,627tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.hdintc (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/hdintc/) [1,0,4,1240266707594]
    [DSP] @0,223,703tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.memutils (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    [DSP] @0,223,780tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.edma3.rm (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/fctools/packages/ti/sdo/edma3/rm/) [1,3,4,1225865844769]
    [DSP] @0,223,858tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.ires.nullresource (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/nullresource/) [1,0,0,1240266782634]
    [DSP] @0,223,942tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.rman (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/rman/) [2,0,0,1240266813533]
    [DSP] @0,224,016tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.edma3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/edma3/) [2,0,0,1240266681138]
    [DSP] @0,224,091tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.ires.edma3chan (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/edma3chan/) [1,0,0,1240266737833]
    [DSP] @0,224,172tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.global (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    [DSP] @0,224,245tk: [+4 T:0x8ba0006c] OG -     package ti.xdais.dm (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
    [DSP] @0,224,310tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.utils.trace (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    [DSP] @0,224,387tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.utils.xdm (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    [DSP] @0,224,462tk: [+4 T:0x8ba0006c] OG -     package ti.xdais (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    [DSP] @0,224,526tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.node (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    [DSP] @0,224,597tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.ipc.dsplink.dsp (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2,0,1,1240276720026]
    [DSP] @0,224,676tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.dman3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    [DSP] @0,224,751tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.acpy3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    [DSP] @0,224,826tk: [+4 T:0x8ba0006c] OG -     package dsplink.dsp (/home/liul/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/dsp/) [1,4,0,1318065713000]
    [DSP] @0,224,896tk: [+4 T:0x8ba0006c] OG -     package ti.bios.utils (/home/liul/dvsdk_2_00_00_22/biosutils_1_01_00/packages/ti/bios/utils/) [2,0,1,0,0]
    [DSP] @0,224,963tk: [+4 T:0x8ba0006c] OG -     package ti.catalog.c6000 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    [DSP] @0,225,030tk: [+4 T:0x8ba0006c] OG -     package ti.platforms.evmDM6467 (/home/liul/dvsdk_2_00_00_22/bios_5_33_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    [DSP] @0,225,100tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.osal (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    [DSP] @0,225,172tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.osal.bios (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/bios/) [2,0,1,1240276734107]
    [DSP] @0,225,246tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.ipc (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    [DSP] @0,225,317tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.ipc.bios (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/bios/) [2,0,1,1240276705217]
    [DSP] @0,225,392tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.alg (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    [DSP] @0,225,462tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    [DSP] @0,225,530tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.bioslog (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
    [DSP] @0,225,606tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.audio1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
    [DSP] @0,225,678tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.aachedec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aachedec/ce/) [1,0,0,1322634195000]
    [DSP] @0,225,757tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.speech1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech1/) [1,0,1,1240276763928]
    [DSP] @0,225,831tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.g711dec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711dec/ce/) [1,0,0,1322634195000]
    [DSP] @0,225,909tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.g711enc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711enc/ce/) [1,0,0,1322634196000]
    [DSP] @0,225,988tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.video2 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
    [DSP] @0,226,060tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1,0,0,1322634196000]
    [DSP] @0,226,145tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264dec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/ce/) [1,0,0,1322634196000]
    [DSP] @0,226,223tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.video1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
    [DSP] @0,226,296tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264enc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/ce/) [1,0,0,1322634196000]
    [DSP] @0,226,374tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1322634196000]
    [DSP] @0,226,456tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg2dec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/ce/) [1,0,0,1322634197000]
    [DSP] @0,226,535tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.image1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
    [DSP] @0,226,608tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.jpegdec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegdec/ce/) [1,0,0,1322634197000]
    [DSP] @0,226,687tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.jpegenc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegenc/ce/) [1,0,0,1322634197000]
    [DSP] @0,226,766tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg4dec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/ce/) [1,0,0,1322634197000]
    [DSP] @0,226,845tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg4enc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/ce/) [1,0,0,1322634197000]
    [DSP] @0,226,925tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.server.cs (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/server/cs/) [1,0,0,1322634197000]
    [DSP] @0,226,998tk: [+0 T:0x8ba0006c] OG - Global_setSpecialTrace> return
    @1,246,096us: [+0 T:0x422eb490] CE - Engine_fwriteTrace> returning count [12010]
    @1,246,209us: [+0 T:0x422eb490] CE - Engine_open> return(400128)
    create Engine success!
    @1,251,088us: [+2 T:0x422eb490] ti.sdo.dmai - [Venc1] Creating encoder h264fhdvenc for max 1920x1088 bitrate 1000000 ratectrl 4
    @1,251,244us: [+0 T:0x422eb490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x61b00, name='h264fhdvenc', params=0x422ead84)
    @1,251,354us: [+0 T:0x422eb490] CV - VISA_create(0x61b00, 'h264fhdvenc', 0x422ead84, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    @1,251,540us: [+0 T:0x422eb490] CV - VISA_create2(0x61b00, 'h264fhdvenc', 0x422ead84, 0x30, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    @1,251,659us: [+0 T:0x422eb490] CE - Engine_createNode(0x61b00, 'h264fhdvenc', 2496, 0x422ead84, 0x30, 0x422eab6c)
    @1,251,753us: [+0 T:0x422eb490] CE - Engine> allocNode Enter(engine=0x61b00, impId='h264fhdvenc')
    @1,251,849us: [+0 T:0x422eb490] CE - Engine> allocNode(). Calling Comm_create(gppfromnode_894_2, 0x620e8, NULL)
    @1,252,236us: [+0 T:0x4001ee40] CE - Engine_fwriteTrace> returning count [0]
    @1,252,361us: [+0 T:0x4001ee40] CE - Engine_open> return(400216)
    @1,258,185us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x611d8]
    @1,258,854us: [+0 T:0x40aeb490] OP - getCmd_d> Enter (proc=0x40aeade8)
    @1,259,573us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611c0] timeout[0xffffffff]
    @1,281,108us: [+6 T:0x422eb490] CE - Engine_createNode> Remote node creation FAILED (0x80008008).
    [DSP] @0,325,480tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x18)
    [DSP] @0,325,526tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62980)
    [DSP] @0,325,569tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0xe)
    [DSP] @0,325,606tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62998)
    [DSP] @0,325,655tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x20)
    [DSP] @0,325,693tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc629a8)
    [DSP] @0,325,735tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x24)
    [DSP] @0,325,773tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc629c8)
    [DSP] @0,325,838tk: [+0 T:0x8ba0006c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x0, name='h264fhdvenc', params=0x8fe038c0)
    [DSP] @0,325,910tk: [+0 T:0x8ba0006c] CV - VISA_create(0x0, 'h264fhdvenc', 0x8fe038c0, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    [DSP] @0,325,975tk: [+0 T:0x8ba0006c] CV - VISA_create2(0x0, 'h264fhdvenc', 0x8fe038c0, 0x30, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    [DSP] @0,326,052tk: [+0 T:0x8ba0006c] CE - Engine_open> Enter('local', 0x8ba03d6c, 0x8fe038c0)
    [DSP] @0,326,105tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x2c)
    [DSP] @0,326,143tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62a38)
    [DSP] @0,326,194tk: [+0 T:0x8ba0006c] CE - Engine_open> return(-1882838472)
    [DSP] @0,326,252tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x30)
    [DSP] @0,326,291tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62a68)
    [DSP] @0,326,337tk: [+0 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fb8208c, idma3Fxns=0x0, iresFxns=0x8fb81fe4, params=0x8fe038c0, attrs=0x8ba03e80)
    [DSP] @0,326,424tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x10)
    [DSP] @0,326,462tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62a98)
    [DSP] @0,434,893tk: [+7 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Algorithm creation FAILED; make sure that 1) alg params are correct/appropriate, 2) there is enough internal and external algorithm memory available -- check DSKT2 settings for heap assignments and scratch allocation
    [DSP] @0,435,024tk: [+0 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(alg=0x8fc62a98)
    [DSP] @0,435,077tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc62a98, size=16)
    [DSP] @0,435,126tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    [DSP] @0,435,162tk: [+0 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Exit
    [DSP] @0,435,204tk: [+0 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x0)
    [DSP] @0,435,252tk: [+2 T:0x8ba0006c] CV - VISA_create2> FAILED to create local codec.
    [DSP] @0,435,294tk: [+0 T:0x8ba0006c] CV - VISA_delete(0x8fc62a68)
    [DSP] @0,435,333tk: [+5 T:0x8ba0006c] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
    [DSP] @0,435,387tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc62a68, size=48)
    [DSP] @0,435,434tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    [DSP] @0,435,471tk: [+0 T:0x8ba0006c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
    [DSP] @0,435,520tk: [+0 T:0x8ba0006c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> Enter (handle=0x0)
    [DSP] @0,435,567tk: [+0 T:0x8ba0006c] CV - VISA_delete(0x0)
    [DSP] @0,435,598tk: [+0 T:0x8ba0006c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> return
    [DSP] @0,435,643tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc629c8, size=36)
    [DSP] @0,435,689tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    [DSP] @0,435,724tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc629a8, size=32)
    [DSP] @0,435,770tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    [DSP] @0,435,807tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc62998, size=14)
    [DSP] @0,435,853tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    [DSP] @0,435,888tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc62980, size=24)
    [DSP] @0,435,934tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    @1,285,173us: [+0 T:0x422eb490] CE - Engine_fwriteTrace> returning count [3933]
    @1,285,449us: [+2 T:0x422eb490] CE - Engine_createNode> Returning 0x0
    @1,285,542us: [+2 T:0x422eb490] CV - VISA_create2> FAILED to create remote codec (0x8).
    @1,285,618us: [+0 T:0x422eb490] CV - VISA_delete(0x620a8)
    @1,285,683us: [+5 T:0x422eb490] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
    @1,285,760us: [+0 T:0x422eb490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
    @1,285,836us: [+7 T:0x422eb490] ti.sdo.dmai - [Venc1] Failed to open video encode algorithm: h264fhdvenc (0x8)
    Error: Failed to create video encoder: h264fhdvenc
    @1,703,916us: [+2 T:0x41aeb490] ti.sdo.dmai - [Capture] Video input connected size 1280x720 pitch 1280
    @1,818,738us: [+7 T:0x41aeb490] ti.sdo.dmai - [Dmai] Insufficient device driver buffer memory
    @1,818,847us: [+7 T:0x41aeb490] ti.sdo.dmai - [Capture] Failed to allocate capture driver buffers on /dev/video0
    Error: Failed to create capture device, 720P component input connected?
    @1,836,541us: [+0 T:0x41aeb490] OP - doCmd> Enter (cmdId=3, proc=0x0)
    @1,836,660us: [+0 T:0x41aeb490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611c0]
    @1,836,765us: [+0 T:0x41aeb490] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x611c0]
    @1,836,846us: [+0 T:0x41aeb490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611d8] timeout[0xffffffff]
    @1,837,411us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611c0] status[0]
    @1,837,535us: [+0 T:0x40aeb490] OP - getCmd_d> Exit (result=3)
    @1,837,619us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611d8]
    @1,837,726us: [+0 T:0x41aeb490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611d8] status[0]
    @1,837,816us: [+0 T:0x41aeb490] OP - doCmd> Exit (result=1)
    @1,837,890us: [+0 T:0x41aeb490] OT - Thread_delete> Enter (task=0x61210)
    @1,838,919us: [+4 T:0x41aeb490] OT - Thread_delete> pthread_cancel (0x0)
    @1,840,261us: [+4 T:0x41aeb490] OT - Thread_delete> pthread_join (0x0)
    @1,840,385us: [+0 T:0x41aeb490] OT - Thread_delete> Exit (task=0x61210)
    @1,840,469us: [+0 T:0x41aeb490] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x611c0]
    @1,840,572us: [+0 T:0x41aeb490] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
    @1,840,652us: [+0 T:0x41aeb490] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x611d8]
    @1,840,730us: [+0 T:0x41aeb490] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
  • Liang,
    Based on the version of your dvsdk, it looks like the Codec Engine and Framework Components are pretty old, so you will need to do some more work to enable trace in Framework Compents.  In your server's main function, which I will assume looks similar to the code below, could you please add the following lines that I've highlighted:
    Void main(Int argc, Char *argv[])
        /* init Codec Engine */
        CERuntime_init();
        /* init trace */
        GT_init();
        /* create a mask to allow a trace-print welcome message below */
        GT_create(&gtMask, "ti.sdo.ce.examples.servers.all_codecs");
        /* ...and initialize all masks in this module to "on" */
        GT_set("ti.sdo.ce.examples.servers.all_codecs=01234567");
        GT_set("ti.sdo.fc.dskt2=01234567");
        GT_0trace(gtMask, GT_4CLASS, "main> Welcome to DSP server's main().\n");
    Then re-run your app again with CE_DEBUG=2, using the re-built server.  This time you should get DSKT2 trace.
        Janet
  • Janet,
             Thanks for your suggests first!
             I has tried your method that adds follow line in my server's main function, re-run the app with CE_DEBUG=2 using the re-build server.
            I think this method is efficient also,but the result very dismayed and confused me. The softwre version are following:
            DVSDK                       = dvsdk_2_00_00_22
            FRAMEWORK           = framework_components_2_23_01
            CODE ENGINE         = codec_engine_2_23_01
            CODE GEN. TOOL   =cg6x_6_0_21
            CODE SERVER        = cs2dm6467_1_00_00_10
            Based on the problems-CE - Engine_createNode> Remote node creation FAILED (0x80008008) I encounted, I have a doubt that the software version is not compatible between DVSDK and CODE SERVER. Because I download the CODE SERVER-cs2dm6467_1_00_00_10 seperately from TI web and then integrate it into the DVSDK-dvsdk_2_00_00_22.
            But,the problem of DSKT2 trace should  not be  related with it. I need some time to solve it.
           Janet, hopefully you can notify me if you have some idea.Thanks your help for me. Welcome everybody to give me suggests.
           My Email: liuliang841210@163.com
    LiuLiang
  • LiuLiang,
    Thanks for the information on your codec engine and framework components version.  These versions are newer than I thought, so here is what you need to do to get trace from DSKT2 and other Framework Components, which you can also find here: http://processors.wiki.ti.com/index.php/Trace_in_Framework_Components
    In your server's .cfg file:
    • Set up GT
    var GT = xdc.useModule("ti.sdo.utils.trace.GT");
    var GTINFRA = xdc.useModule("ti.sdo.fc.utils.gtinfra.GTINFRA");
    GTINFRA.runtimeEnv = GTINFRA.NONE;
    GT.MALLOCFXN = "myMalloc";
    GT.PRINTFXN = "printfCaller";
    • Enable trace/debug for individual or all FC modules
    //Switch to debug + trace profile for all FC modules
    //Switch on trace for some modules specifically.
    xdc.loadPackage('ti.sdo.fc.rman').profile = "debug_trace";
    xdc.loadPackage('ti.sdo.fc.edma3').profile = "debug_trace";
    Then after rebuilding your server, and running your app with CE_DEBUG=2, you should see DSKT2 trace.  It is this line in the trace from your previous post that tells me we need to look at Framework Components trace:
    I'm hoping that will tell us whether it's a memory issue or your alg params are incorrect.  It will probably be quite a lot of trace, but if you could attach it as a file then we will gladly take a look at it.
        Janet
  • Janet,
             I'm so sorry to tell you the result,I really have no method.
             But the dskt2 trace and other FC trace are so important for me  that I must sovle this problem first.
             Farthermore,after adding the follow line in my server's cfg file,
             The APP run log is different .
             I will put the log details in another dialog.
  •  Janet,
       The setting following is the same.
               These are the APP logs before adding,
    @0,696,836us: [+4 T:0x4001ee40] OG - Global_init> This program was built with the following packages:
    @0,697,609us: [+4 T:0x4001ee40] OG -     package gnu.targets.rts470MV (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/gnu/targets/rts470MV/) [1,0,0,0,1225517438755]
    @0,698,108us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h264fhdvenc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1,0,0,1323674961000]
    @0,698,576us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1,0,0,1323674961000]
    @0,699,051us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.global (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    @0,699,642us: [+4 T:0x4001ee40] OG -     package ti.xdais.dm (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
    @0,699,757us: [+4 T:0x4001ee40] OG -     package ti.sdo.utils.trace (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    @0,699,847us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.utils.xdm (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    @0,699,929us: [+4 T:0x4001ee40] OG -     package ti.xdais (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    @0,700,002us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.node (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    @0,700,081us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.global (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    @0,700,160us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.dman3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    @0,700,237us: [+4 T:0x4001ee40] OG -     package ti.sdo.linuxutils.cmem (/home/liul/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/) [2,2,0,1240253001679]
    @0,700,313us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.memutils (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    @0,700,387us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.acpy3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    @0,700,461us: [+4 T:0x4001ee40] OG -     package dsplink.gpp (/home/liul/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/gpp/) [5,0,0,1318065716000]
    @0,700,535us: [+4 T:0x4001ee40] OG -     package gnu.targets (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/gnu/targets/) [1,0,1,1225517427930]
    @0,700,609us: [+4 T:0x4001ee40] OG -     package ti.catalog.c470 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c470/) [1,0,1,0,0]
    @0,700,683us: [+4 T:0x4001ee40] OG -     package ti.catalog.c6000 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    @0,700,756us: [+4 T:0x4001ee40] OG -     package ti.platforms.evmDM6467 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    @0,700,830us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.osal (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    @0,700,905us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.osal.linux (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/linux/) [2,0,1,1240276736840]
    @0,700,980us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.ipc (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    @0,701,054us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.ipc.dsplink (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/) [2,0,1,1240276714152]
    @0,701,131us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.alg (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    @0,701,205us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    @0,701,278us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.video1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
    @0,701,353us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1323674962000]
    @0,701,475us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.video2 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
    @0,701,558us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1,0,0,1323674961000]
    @0,704,716us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.speech (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech/) [1,0,2,1240276762193]
    @0,705,370us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.speech1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech1/) [1,0,1,1240276763928]
    @0,705,832us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.audio (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio/) [1,0,2,1240276296374]
    @0,706,430us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.audio1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
    @0,706,888us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.video (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video/) [1,0,3,1240276930771]
    @0,707,344us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.image (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image/) [1,0,3,1240276700525]
    @0,707,801us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.image1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
    @0,708,258us: [+4 T:0x4001ee40] OG -     package ti.sdo.dmai (/home/liul/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/) [1,0,0,1323673835000]
    @0,708,706us: [+4 T:0x4001ee40] OG -     package ti.sdo.simplewidget (/home/liul/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/packages/ti/sdo/simplewidget/) []
    @0,709,157us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.bioslog (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
    @0,709,703us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.utils.trace (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/trace/) [1,0,1,1240276915917]
    @0,710,248us: [+4 T:0x4001ee40] OG -     package encodedecode_config (/home/liul/encoderdecoder_demo_TI/encodedecode/encodedecode_config/) []
    @0,711,281us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,711,714us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x611c0]
    @0,712,120us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,712,524us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x611d8]
    @0,712,941us: [+0 T:0x4001ee40] OT - Thread_create> Enter (fxn=0x2c7cc, attrs=0x0)
    @0,713,755us: [+0 T:0x4001ee40] OT - Thread_create> Exit (task=0x61210)
    @0,714,226us: [+0 T:0x4001ee40] ti.sdo.ce.alg - ALG_init> Enter
    @0,714,620us: [+0 T:0x4001ee40] ti.sdo.ce.alg - ALG_init> Exit
    @0,715,082us: [+6 T:0x4001ee40] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
    @0,715,582us: [+0 T:0x4001ee40] CS - Server_init()
    @0,715,959us: [+0 T:0x4001ee40] CS - Server_init> Global_useLinkArbiter = 0
    @0,716,497us: [+2 T:0x4001ee40] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note that calling CERuntime_init after this point may cause unexpected change to DMAI tracing behavior.
    envp->engineName is encodedecode!
    @0,731,370us: [+0 T:0x422eb490] CE - Engine_open> Enter('encodedecode', 0x0, 0x422eabe4)
    @0,731,482us: [+0 T:0x422eb490] CE - rserverOpen('./cs.x64P'), count = 0
    @0,731,563us: [+0 T:0x422eb490] OP - Processor_create> Enter(imageName='./cs.x64P', linkCfg='(null)', attrs=0x422eabc8)
    @0,737,218us: [+0 T:0x422eb490] OP - doCmd> Enter (cmdId=1, proc=0x61b30)
    @0,737,342us: [+0 T:0x422eb490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611c0]
    @0,737,488us: [+0 T:0x422eb490] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x611c0]
    @0,737,579us: [+0 T:0x422eb490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611d8] timeout[0xffffffff]
    @0,738,736us: [+0 T:0x4001ee40] CE - Engine_open> Enter('encodedecode', 0x0, 0xbe93eae4)
    @0,757,426us: [+1 T:0x40aeb490] OP - daemon> thread created.
    @0,757,982us: [+0 T:0x40aeb490] OP - getCmd_d> Enter (proc=0x40aeade8)
    @0,758,551us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611c0] timeout[0xffffffff]
    @0,759,278us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611c0] status[0]
    @0,759,984us: [+0 T:0x40aeb490] OP - getCmd_d> Exit (result=1)
    @0,760,538us: [+0 T:0x40aeb490] OP - Processor_create_d> Enter(proc=0x61b30)
    @0,761,083us: [+2 T:0x40aeb490] OP - Processor_create_d> Initializing DSP PROC...
    @0,761,747us: [+2 T:0x40aeb490] OP - Processor_create_d> Using DspLink config data for entry #0 [server './cs.x64P']
    @0,762,444us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1, syncd=0
    @0,763,202us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1, syncd=0
    @0,764,017us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESETCTRL', startAddress=0x8ff00000, sizeInBytes=0x80, shared=1, syncd=0
    @0,764,835us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x88000000, sizeInBytes=0x7a00000, shared=0, syncd=0
    @0,770,114us: [+2 T:0x40aeb490] OP - Processor_create_d> DODSPCTRL was=1; now=0
    @0,777,956us: [+2 T:0x40aeb490] OP - Processor_create_d> Attaching to DSP PROC...
    @0,807,209us: [+2 T:0x40aeb490] OP - Processor_create_d> Opening MSGQ pool...
    @0,807,924us: [+2 T:0x40aeb490] OP - Processor_create_d> Loading ./cs.x64P on DSP (1 args)...
    @1,022,112us: [+2 T:0x412eb490] ti.sdo.dmai - [Display] Video output set to size 1280x720 pitch 1280
    @1,022,775us: [+2 T:0x412eb490] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffers
    @1,023,197us: [+2 T:0x412eb490] ti.sdo.dmai - [Buffer] Set user pointer 0x42b69000 (physical 0x82000000)
    @1,219,954us: [+2 T:0x412eb490] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x42b69000 has physical address 0x82000000
    @1,220,337us: [+2 T:0x412eb490] ti.sdo.dmai - [Buffer] Set user pointer 0x42f5e000 (physical 0x82400000)
    @1,416,941us: [+2 T:0x412eb490] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x42f5e000 has physical address 0x82400000
    @1,417,328us: [+2 T:0x412eb490] ti.sdo.dmai - [Buffer] Set user pointer 0x43353000 (physical 0x82800000)
    @1,613,931us: [+2 T:0x412eb490] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x43353000 has physical address 0x82800000
    @1,621,099us: [+2 T:0x40aeb490] OP - Processor_create_d> Starting DSP PROC...
    @1,718,124us: [+2 T:0x40aeb490] OP - Processor_create_d> Opening remote transport...
    @1,755,862us: [+2 T:0x40aeb490] OP - Processor_create_d> return (1)
    @1,766,231us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611d8]
    @1,772,904us: [+0 T:0x422eb490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611d8] status[0]
    @1,773,029us: [+0 T:0x422eb490] OP - doCmd> Exit (result=1)
    @1,773,130us: [+0 T:0x422eb490] OP - Processor_create> return (0x61b30)
    @1,773,206us: [+0 T:0x422eb490] CE - rserverOpen('./cs.x64P'): 0x60614 done.
    @1,773,741us: [+0 T:0x4001ee40] CE - rserverOpen('./cs.x64P'), count = 1
    @1,773,868us: [+0 T:0x4001ee40] CE - rserverOpen('./cs.x64P'): 0x60614 done.
    @1,774,562us: [+0 T:0x422eb490] CE - checkServer(0x61b00)
    @1,775,067us: [+0 T:0x422eb490] CE - rmsInit> RMS initialized(0x61b00); CE_DEBUG on, setting DSP trace mask to *+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3
    @1,775,195us: [+0 T:0x422eb490] CE - Engine_setTrace> Enter(engine=0x61b00, mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
    @1,775,302us: [+1 T:0x422eb490] CE - Engine_setTrace> Requesting DSP set trace ...
    @1,775,558us: [+0 T:0x4001ee40] CE - checkServer(0x61b58)
    @1,776,919us: [+0 T:0x422eb490] CE - Engine_setTrace> return(0)
    [DSP] @0x000001be:[T:0x00000000] codec_unitserver - main> Welcome to CS2DM6467 1.00.00.10 DSP server's main().
    [DSP] @0,221,967tk: [+0 T:0x8ba0006c] OG - Global_setSpecialTrace> enter(mask='*+01234567,CR=67,ti.sdo.fc.dman3-2,ti.sdo.fc.dskt2-2,GT_prefix=1235,GT_time=3')
    [DSP] @0,222,057tk: [+4 T:0x8ba0006c] OG - Global_setSpecialTrace> This program was built with the following packages:
    [DSP] @0,222,110tk: [+4 T:0x8ba0006c] OG -     package ti.targets.rts6000 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/targets/rts6000/) [1,0,0,0,1225517497925]
    [DSP] @0,222,184tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.utils.trace (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    [DSP] @0,222,261tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.aachedec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aachedec/) [1,0,0,1323674961000]
    [DSP] @0,222,338tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.g711dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711dec/) [1,0,0,1323674961000]
    [DSP] @0,222,414tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.g711enc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711enc/) [1,0,0,1323674961000]
    [DSP] @0,222,491tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1,0,0,1323674961000]
    [DSP] @0,222,573tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/) [1,0,0,1323674961000]
    [DSP] @0,222,650tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264enc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/) [1,0,0,1323674961000]
    [DSP] @0,222,726tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264fhdvenc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1,0,0,1323674961000]
    [DSP] @0,222,805tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg2dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/) [1,0,0,1323674962000]
    [DSP] @0,222,882tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.jpegdec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegdec/) [1,0,0,1323674962000]
    [DSP] @0,222,958tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.jpegenc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegenc/) [1,0,0,1323674962000]
    [DSP] @0,223,035tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg4dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/) [1,0,0,1323674962000]
    [DSP] @0,223,111tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg4enc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/) [1,0,0,1323674962000]
    [DSP] @0,223,188tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.hdvicp (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/hdvicp/) [1,0,0,1323674962000]
    [DSP] @0,223,312tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.global (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    [DSP] @0,223,387tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.utils.gtinfra (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/utils/gtinfra/) [1,0,0,1240266906169]
    [DSP] @0,223,468tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.ires.hdvicp (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/hdvicp/) [1,0,1,1240266763264]
    [DSP] @0,223,548tk: [+4 T:0x8ba0006c] OG -     package ti.rtdx (/home/liul/dvsdk_2_00_00_22/bios_5_33_03/packages/ti/rtdx/) [2,0,0,4,1219531643983]
    [DSP] @0,223,611tk: [+4 T:0x8ba0006c] OG -     package ti.psl (/home/liul/dvsdk_2_00_00_22/bios_5_33_03/packages/ti/psl/) [5,0,0,0,0]
    [DSP] @0,223,670tk: [+4 T:0x8ba0006c] OG -     package ti.bios (/home/liul/dvsdk_2_00_00_22/bios_5_33_03/packages/ti/bios/) [5,2,5,6,1227035764854]
    [DSP] @0,223,734tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.dskt2 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dskt2/) [1,0,4,1240266678055]
    [DSP] @0,223,809tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.hdintc (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/hdintc/) [1,0,4,1240266707594]
    [DSP] @0,223,884tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.memutils (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    [DSP] @0,223,961tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.edma3.rm (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/fctools/packages/ti/sdo/edma3/rm/) [1,3,4,1225865844769]
    [DSP] @0,224,039tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.ires.nullresource (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/nullresource/) [1,0,0,1240266782634]
    [DSP] @0,224,123tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.rman (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/rman/) [2,0,0,1240266813533]
    [DSP] @0,224,197tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.edma3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/edma3/) [2,0,0,1240266681138]
    [DSP] @0,224,272tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.ires.edma3chan (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/edma3chan/) [1,0,0,1240266737833]
    [DSP] @0,224,353tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.global (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    [DSP] @0,224,426tk: [+4 T:0x8ba0006c] OG -     package ti.xdais.dm (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
    [DSP] @0,224,491tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.utils.xdm (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    [DSP] @0,224,566tk: [+4 T:0x8ba0006c] OG -     package ti.xdais (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    [DSP] @0,224,629tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.node (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    [DSP] @0,224,701tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.ipc.dsplink.dsp (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2,0,1,1240276720026]
    [DSP] @0,224,780tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.dman3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    [DSP] @0,224,854tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.fc.acpy3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    [DSP] @0,224,929tk: [+4 T:0x8ba0006c] OG -     package dsplink.dsp (/home/liul/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/dsp/) [1,4,0,1318065713000]
    [DSP] @0,225,000tk: [+4 T:0x8ba0006c] OG -     package ti.bios.utils (/home/liul/dvsdk_2_00_00_22/biosutils_1_01_00/packages/ti/bios/utils/) [2,0,1,0,0]
    [DSP] @0,225,065tk: [+4 T:0x8ba0006c] OG -     package ti.catalog.c6000 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    [DSP] @0,225,132tk: [+4 T:0x8ba0006c] OG -     package ti.platforms.evmDM6467 (/home/liul/dvsdk_2_00_00_22/bios_5_33_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    [DSP] @0,225,203tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.osal (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    [DSP] @0,225,274tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.osal.bios (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/bios/) [2,0,1,1240276734107]
    [DSP] @0,225,349tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.ipc (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    [DSP] @0,225,419tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.ipc.bios (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/bios/) [2,0,1,1240276705217]
    [DSP] @0,225,494tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.alg (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    [DSP] @0,225,564tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    [DSP] @0,225,634tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.bioslog (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
    [DSP] @0,225,708tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.audio1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
    [DSP] @0,225,780tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.aachedec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aachedec/ce/) [1,0,0,1323674961000]
    [DSP] @0,225,859tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.speech1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech1/) [1,0,1,1240276763928]
    [DSP] @0,225,933tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.g711dec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711dec/ce/) [1,0,0,1323674961000]
    [DSP] @0,226,011tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.g711enc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711enc/ce/) [1,0,0,1323674961000]
    [DSP] @0,226,090tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.video2 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
    [DSP] @0,226,162tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1,0,0,1323674961000]
    [DSP] @0,226,247tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264dec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/ce/) [1,0,0,1323674961000]
    [DSP] @0,226,325tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.video1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
    [DSP] @0,226,398tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264enc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/ce/) [1,0,0,1323674961000]
    [DSP] @0,226,476tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1323674962000]
    [DSP] @0,226,557tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg2dec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/ce/) [1,0,0,1323674962000]
    [DSP] @0,226,637tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.ce.image1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
    [DSP] @0,226,710tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.jpegdec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegdec/ce/) [1,0,0,1323674962000]
    [DSP] @0,226,788tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.jpegenc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegenc/ce/) [1,0,0,1323674962000]
    [DSP] @0,226,866tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg4dec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/ce/) [1,0,0,1323674962000]
    [DSP] @0,226,946tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.codecs.mpeg4enc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/ce/) [1,0,0,1323674962000]
    [DSP] @0,227,025tk: [+4 T:0x8ba0006c] OG -     package ti.sdo.server.cs (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/server/cs/) [1,0,0,1323674962000]
    [DSP] @0,227,098tk: [+0 T:0x8ba0006c] OG - Global_setSpecialTrace> return
    @1,800,515us: [+0 T:0x422eb490] CE - Engine_fwriteTrace> returning count [12204]
    @1,800,636us: [+0 T:0x422eb490] CE - Engine_open> return(400128)
    encParams = 0x422eac2c
    encDynParams = 0x422eac80
    (VIDENC1_Params *)&h264Param = 0x422eac2c
    (VIDENC1_DynamicParams *)&dynParams = 0x422eac80
    @1,800,962us: [+2 T:0x422eb490] ti.sdo.dmai - [Venc1] Creating encoder h264fhdvenc for max 1280x720 bitrate 2000000 ratectrl 4
    @1,801,108us: [+0 T:0x422eb490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x61b00, name='h264fhdvenc', params=0x422eac2c)
    @1,801,215us: [+0 T:0x422eb490] CV - VISA_create(0x61b00, 'h264fhdvenc', 0x422eac2c, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    @1,801,436us: [+0 T:0x422eb490] CV - VISA_create2(0x61b00, 'h264fhdvenc', 0x422eac2c, 0x3c, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    @1,801,557us: [+0 T:0x422eb490] CE - Engine_createNode(0x61b00, 'h264fhdvenc', 2496, 0x422eac2c, 0x3c, 0x422eaa9c)
    @1,801,648us: [+0 T:0x422eb490] CE - Engine> allocNode Enter(engine=0x61b00, impId='h264fhdvenc')
    @1,801,747us: [+0 T:0x422eb490] CE - Engine> allocNode(). Calling Comm_create(gppfromnode_719_2, 0x620f0, NULL)
    @1,806,017us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x611d8]
    @1,806,511us: [+0 T:0x40aeb490] OP - getCmd_d> Enter (proc=0x40aeade8)
    @1,806,992us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611c0] timeout[0xffffffff]
    @1,817,911us: [+6 T:0x422eb490] CE - Engine_createNode> Remote node creation FAILED (0x80008008).
    [DSP] @0,325,105tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x18)
    [DSP] @0,325,151tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62a18)
    [DSP] @0,325,194tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0xe)
    [DSP] @0,325,232tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62a30)
    [DSP] @0,325,281tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x20)
    [DSP] @0,325,319tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62a40)
    [DSP] @0,325,361tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x24)
    [DSP] @0,325,443tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62a60)
    [DSP] @0,325,510tk: [+0 T:0x8ba0006c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x0, name='h264fhdvenc', params=0x8fe038c0)
    [DSP] @0,325,583tk: [+0 T:0x8ba0006c] CV - VISA_create(0x0, 'h264fhdvenc', 0x8fe038c0, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    [DSP] @0,325,647tk: [+0 T:0x8ba0006c] CV - VISA_create2(0x0, 'h264fhdvenc', 0x8fe038c0, 0x3c, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    [DSP] @0,325,722tk: [+0 T:0x8ba0006c] CE - Engine_open> Enter('local', 0x8ba03d6c, 0x8fe038c0)
    [DSP] @0,325,774tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x2c)
    [DSP] @0,325,813tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62ad0)
    [DSP] @0,325,865tk: [+0 T:0x8ba0006c] CE - Engine_open> return(-1882838320)
    [DSP] @0,325,923tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x30)
    [DSP] @0,325,961tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62b00)
    [DSP] @0,326,007tk: [+0 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fb8208c, idma3Fxns=0x0, iresFxns=0x8fb81fe4, params=0x8fe038c0, attrs=0x8ba03e80)
    [DSP] @0,326,094tk: [+0 T:0x8ba0006c] OM - Memory_alloc> Enter(size=0x10)
    [DSP] @0,326,131tk: [+0 T:0x8ba0006c] OM - Memory_alloc> return (0x8fc62b30)
    [DSP] @0,383,805tk: [+7 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Algorithm creation FAILED; make sure that 1) alg params are correct/appropriate, 2) there is enough internal and external algorithm memory available -- check DSKT2 settings for heap assignments and scratch allocation
    [DSP] @0,383,934tk: [+0 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(alg=0x8fc62b30)
    [DSP] @0,383,987tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc62b30, size=16)
    [DSP] @0,384,035tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    [DSP] @0,384,070tk: [+0 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Exit
    [DSP] @0,384,112tk: [+0 T:0x8ba0006c] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x0)
    [DSP] @0,384,159tk: [+2 T:0x8ba0006c] CV - VISA_create2> FAILED to create local codec.
    [DSP] @0,384,202tk: [+0 T:0x8ba0006c] CV - VISA_delete(0x8fc62b00)
    [DSP] @0,384,241tk: [+5 T:0x8ba0006c] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
    [DSP] @0,384,295tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc62b00, size=48)
    [DSP] @0,384,342tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    [DSP] @0,384,379tk: [+0 T:0x8ba0006c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
    [DSP] @0,384,430tk: [+0 T:0x8ba0006c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> Enter (handle=0x0)
    [DSP] @0,384,476tk: [+0 T:0x8ba0006c] CV - VISA_delete(0x0)
    [DSP] @0,384,507tk: [+0 T:0x8ba0006c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> return
    [DSP] @0,384,552tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc62a60, size=36)
    [DSP] @0,384,598tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    [DSP] @0,384,633tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc62a40, size=32)
    [DSP] @0,384,679tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    [DSP] @0,384,716tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc62a30, size=14)
    [DSP] @0,384,762tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    [DSP] @0,384,797tk: [+0 T:0x8ba0006c] OM - Memory_free> Enter(addr=0x8fc62a18, size=24)
    [DSP] @0,384,843tk: [+0 T:0x8ba0006c] OM - Memory_free> return (0x1)
    @1,821,850us: [+0 T:0x4001ee40] CE - Engine_fwriteTrace> returning count [3933]
    @1,822,266us: [+0 T:0x4001ee40] CE - Engine_open> return(400216)
    @1,824,395us: [+0 T:0x422eb490] CE - Engine_fwriteTrace> returning count [0]
    @1,824,509us: [+2 T:0x422eb490] CE - Engine_createNode> Returning 0x0
    @1,824,591us: [+2 T:0x422eb490] CV - VISA_create2> FAILED to create remote codec (0x8).
    @1,824,663us: [+0 T:0x422eb490] CV - VISA_delete(0x620b0)
    @1,824,727us: [+5 T:0x422eb490] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
    @1,824,805us: [+0 T:0x422eb490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
    @1,824,880us: [+7 T:0x422eb490] ti.sdo.dmai - [Venc1] Failed to open video encode algorithm: h264fhdvenc (0x8)
    @2,253,920us: [+2 T:0x41aeb490] ti.sdo.dmai - [Capture] Video input connected size 1280x720 pitch 1280
    @2,254,656us: [+2 T:0x41aeb490] ti.sdo.dmai - [BufTab] Allocating BufTab for 4 buffers
    @2,255,038us: [+2 T:0x41aeb490] ti.sdo.dmai - [Buffer] Set user pointer 0x43748000 (physical 0x82c00000)
    @2,451,703us: [+2 T:0x41aeb490] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x43748000 has physical address 0x82c00000
    @2,452,090us: [+2 T:0x41aeb490] ti.sdo.dmai - [Buffer] Set user pointer 0x43b3d000 (physical 0x83000000)
    @2,648,835us: [+2 T:0x41aeb490] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x43b3d000 has physical address 0x83000000
    @2,649,229us: [+2 T:0x41aeb490] ti.sdo.dmai - [Buffer] Set user pointer 0x43f32000 (physical 0x83400000)
    @2,845,922us: [+2 T:0x41aeb490] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x43f32000 has physical address 0x83400000
    @2,846,308us: [+2 T:0x41aeb490] ti.sdo.dmai - [Buffer] Set user pointer 0x44327000 (physical 0x83800000)
    @3,043,123us: [+2 T:0x41aeb490] ti.sdo.dmai - [Dmai] Driver buffer 3 mapped to 0x44327000 has physical address 0x83800000
    @11,802,228us: [+0 T:0x4001ee40] OP - doCmd> Enter (cmdId=3, proc=0x0)
    @11,802,355us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611c0]
    @11,802,464us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x611c0]
    @11,802,552us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611d8] timeout[0xffffffff]
    @11,804,561us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611c0] status[0]
    @11,805,008us: [+0 T:0x40aeb490] OP - getCmd_d> Exit (result=3)
    @11,805,425us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611d8]
    @11,805,886us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611d8] status[0]
    @11,806,008us: [+0 T:0x4001ee40] OP - doCmd> Exit (result=1)
    @11,806,095us: [+0 T:0x4001ee40] OT - Thread_delete> Enter (task=0x61210)
    @11,806,231us: [+4 T:0x4001ee40] OT - Thread_delete> pthread_cancel (0x0)
    @11,807,078us: [+4 T:0x4001ee40] OT - Thread_delete> pthread_join (0x0)
    @11,807,207us: [+0 T:0x4001ee40] OT - Thread_delete> Exit (task=0x61210)
    @11,807,298us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x611c0]
    @11,807,411us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
    @11,807,496us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x611d8]
    @11,807,581us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
    root@iview:/mnt/nfs/liul/encoderdecoder_demo_TI#
    root@iview:/mnt/nfs/liul/encoderdecoder_demo_TI# CE_DEBUG=3 DMAI_DEBUG=2 ./encodedecode -p -y3
    @0,876,646us: [+4 T:0x4001ee40 S:0xbef19af4] OG - Global_init> This program was built with the following packages:
    @0,877,485us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package gnu.targets.rts470MV (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/gnu/targets/rts470MV/) [1,0,0,0,1225517438755]
    @0,878,024us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.codecs.h264fhdvenc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1,0,0,1323674961000]
    @0,878,598us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1,0,0,1323674961000]
    @0,879,113us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.global (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    @0,879,673us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.xdais.dm (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
    @0,880,153us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.utils.trace (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    @0,880,659us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.utils.xdm (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    @0,881,160us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.xdais (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    @0,881,713us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.node (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    @0,882,206us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.fc.global (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    @0,882,861us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.fc.dman3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    @0,883,361us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.linuxutils.cmem (/home/liul/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/) [2,2,0,1240253001679]
    @0,883,868us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.fc.memutils (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    @0,884,374us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.fc.acpy3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    @0,884,874us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package dsplink.gpp (/home/liul/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/gpp/) [5,0,0,1318065716000]
    @0,885,367us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package gnu.targets (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/gnu/targets/) [1,0,1,1225517427930]
    @0,885,852us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.catalog.c470 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c470/) [1,0,1,0,0]
    @0,886,336us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.catalog.c6000 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    @0,886,898us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.platforms.evmDM6467 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    @0,887,393us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.osal (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    @0,888,022us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.osal.linux (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/linux/) [2,0,1,1240276736840]
    @0,888,520us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.ipc (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    @0,889,010us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.ipc.dsplink (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/) [2,0,1,1240276714152]
    @0,889,613us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.alg (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    @0,889,759us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    @0,889,873us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.video1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
    @0,889,982us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1323674962000]
    @0,890,093us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.video2 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
    @0,890,201us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1,0,0,1323674961000]
    @0,890,309us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.speech (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech/) [1,0,2,1240276762193]
    @0,890,415us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.speech1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech1/) [1,0,1,1240276763928]
    @0,890,519us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.audio (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio/) [1,0,2,1240276296374]
    @0,890,624us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.audio1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
    @0,890,728us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.video (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video/) [1,0,3,1240276930771]
    @0,890,833us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.image (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image/) [1,0,3,1240276700525]
    @0,890,937us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.image1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
    @0,891,042us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.dmai (/home/liul/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/) [1,0,0,1323673835000]
    @0,891,145us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.simplewidget (/home/liul/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/packages/ti/sdo/simplewidget/) []
    @0,891,249us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.bioslog (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
    @0,891,356us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package ti.sdo.ce.utils.trace (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/trace/) [1,0,1,1240276915917]
    @0,891,462us: [+4 T:0x4001ee40 S:0xbef19af4] OG -     package encodedecode_config (/home/liul/encoderdecoder_demo_TI/encodedecode/encodedecode_config/) []
    @0,891,615us: [+0 T:0x4001ee40 S:0xbef19afc] OG - Global_atexit> enter (fxn=0x31dcc)
    @0,891,740us: [+0 T:0x4001ee40 S:0xbef19afc] OG - Global_atexit> enter (fxn=0x31218)
    @0,891,920us: [+0 T:0x4001ee40 S:0xbef19acc] OM - Memory_alloc> Enter(0x18)
    @0,892,042us: [+0 T:0x4001ee40 S:0xbef19acc] OM - Memory_alloc> return (0x610f0)
    @0,892,342us: [+0 T:0x4001ee40 S:0xbef19aec] OG - Global_atexit> enter (fxn=0x2f148)
    @0,892,519us: [+0 T:0x4001ee40 S:0xbef19ac4] OM - Memory_alloc> Enter(0x18)
    @0,892,640us: [+0 T:0x4001ee40 S:0xbef19ac4] OM - Memory_alloc> return (0x61140)
    @0,892,749us: [+0 T:0x4001ee40 S:0xbef19ae4] OG - Global_atexit> enter (fxn=0x2dff4)
    @0,892,920us: [+0 T:0x4001ee40 S:0xbef19aec] OG - Global_atexit> enter (fxn=0x3087c)
    @0,893,114us: [+0 T:0x4001ee40 S:0xbef19ae4] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,893,228us: [+0 T:0x4001ee40 S:0xbef19acc] OM - Memory_alloc> Enter(0x14)
    @0,896,520us: [+0 T:0x4001ee40 S:0xbef19acc] OM - Memory_alloc> return (0x611c0)
    @0,896,970us: [+0 T:0x4001ee40 S:0xbef19ae4] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x611c0]
    @0,897,592us: [+0 T:0x4001ee40 S:0xbef19ae4] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,898,159us: [+0 T:0x4001ee40 S:0xbef19acc] OM - Memory_alloc> Enter(0x14)
    @0,898,594us: [+0 T:0x4001ee40 S:0xbef19acc] OM - Memory_alloc> return (0x611d8)
    @0,899,024us: [+0 T:0x4001ee40 S:0xbef19ae4] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x611d8]
    @0,899,598us: [+0 T:0x4001ee40 S:0xbef19acc] OM - Memory_alloc> Enter(0x18)
    @0,900,034us: [+0 T:0x4001ee40 S:0xbef19acc] OM - Memory_alloc> return (0x611f0)
    @0,900,466us: [+0 T:0x4001ee40 S:0xbef19ac4] OT - Thread_create> Enter (fxn=0x2c7cc, attrs=0x0)
    @0,900,907us: [+0 T:0x4001ee40 S:0xbef19aac] OM - Memory_alloc> Enter(0x64)
    @0,901,342us: [+0 T:0x4001ee40 S:0xbef19aac] OM - Memory_alloc> return (0x61210)
    @0,902,172us: [+0 T:0x4001ee40 S:0xbef19ac4] OT - Thread_create> Exit (task=0x61210)
    @0,902,611us: [+0 T:0x4001ee40 S:0xbef19afc] OG - Global_atexit> enter (fxn=0x2c1bc)
    @0,903,064us: [+0 T:0x4001ee40 S:0xbef19afc] OG - Global_atexit> enter (fxn=0x2e540)
    @0,903,561us: [+0 T:0x4001ee40 S:0xbef19ae4] ti.sdo.ce.alg - ALG_init> Enter
    @0,903,985us: [+0 T:0x4001ee40 S:0xbef19ad4] OG - Global_atexit> enter (fxn=0x2be08)
    @0,904,427us: [+0 T:0x4001ee40 S:0xbef19b04] ti.sdo.ce.alg - ALG_init> Exit
    @0,904,848us: [+0 T:0x4001ee40 S:0xbef19afc] OG - Global_atexit> enter (fxn=0x2b234)
    @0,905,303us: [+0 T:0x4001ee40 S:0xbef19ad4] OM - Memory_alloc> Enter(0x18)
    @0,905,739us: [+0 T:0x4001ee40 S:0xbef19ad4] OM - Memory_alloc> return (0x613f0)
    @0,906,246us: [+0 T:0x4001ee40 S:0xbef19afc] OG - Global_atexit> enter (fxn=0x30d6c)
    @0,906,748us: [+6 T:0x4001ee40 S:0xbef19af4] CE - Engine_init> CE debugging on (CE_DEBUG=3; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
    @0,907,357us: [+0 T:0x4001ee40 S:0xbef19ae4] OG - Global_atexit> enter (fxn=0x286c8)
    @0,907,798us: [+0 T:0x4001ee40 S:0xbef19ac4] OM - Memory_alloc> Enter(0x18)
    @0,908,235us: [+0 T:0x4001ee40 S:0xbef19ac4] OM - Memory_alloc> return (0x61430)
    @0,908,667us: [+0 T:0x4001ee40 S:0xbef19ac4] OM - Memory_alloc> Enter(0x18)
    @0,909,105us: [+0 T:0x4001ee40 S:0xbef19ac4] OM - Memory_alloc> return (0x61450)
    @0,909,605us: [+0 T:0x4001ee40 S:0xbef19ac4] OM - Memory_alloc> Enter(0x18)
    @0,910,040us: [+0 T:0x4001ee40 S:0xbef19ac4] OM - Memory_alloc> return (0x61470)
    @0,910,523us: [+0 T:0x4001ee40 S:0xbef19afc] CS - Server_init()
    @0,910,936us: [+0 T:0x4001ee40 S:0xbef19afc] CS - Server_init> Global_useLinkArbiter = 0
    @0,911,373us: [+0 T:0x4001ee40 S:0xbef19afc] OG - Global_atexit> enter (fxn=0x269a8)
    @0,911,881us: [+0 T:0x4001ee40 S:0xbef19b0c] OG - Global_atexit> enter (fxn=0x129f8)
    @0,912,386us: [+2 T:0x4001ee40 S:0xbef19b0c] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note that calling CERuntime_init after this point may cause unexpected change to DMAI tracing behavior.
    Encodedecode demo started.
    @0,927,163us: [+0 T:0x422eb490 S:0x422eab74] CE - Engine_open> Enter('encodedecode', 0x0, 0x422eabe4)
    @0,927,291us: [+0 T:0x422eb490 S:0x422eab5c] OM - Memory_alloc> Enter(0x2c)
    @0,927,403us: [+0 T:0x422eb490 S:0x422eab5c] OM - Memory_alloc> return (0x61b00)
    @0,927,509us: [+0 T:0x422eb490 S:0x422eab74] CE - rserverOpen('./cs.x64P'), count = 0
    @0,927,610us: [+0 T:0x422eb490 S:0x422eab3c] OP - Processor_create> Enter(imageName='./cs.x64P', linkCfg='(null)', attrs=0x422eabc8)
    @0,933,325us: [+0 T:0x422eb490 S:0x422eab24] OM - Memory_alloc> Enter(0x24)
    @0,933,483us: [+0 T:0x422eb490 S:0x422eab24] OM - Memory_alloc> return (0x61b30)
    @0,933,594us: [+0 T:0x422eb490 S:0x422eab1c] OP - doCmd> Enter (cmdId=1, proc=0x61b30)
    @0,933,697us: [+0 T:0x422eb490 S:0x422eab0c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611c0]
    @0,933,860us: [+0 T:0x422eb490 S:0x422eab1c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x611c0]
    @0,933,979us: [+0 T:0x422eb490 S:0x422eaafc] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611d8] timeout[0xffffffff]
    @0,935,164us: [+0 T:0x4001ee40 S:0xbef19a74] CE - Engine_open> Enter('encodedecode', 0x0, 0xbef19ae4)
    @0,935,313us: [+0 T:0x4001ee40 S:0xbef19a5c] OM - Memory_alloc> Enter(0x2c)
    @0,935,500us: [+0 T:0x4001ee40 S:0xbef19a5c] OM - Memory_alloc> return (0x61b58)
    @0,961,460us: [+1 T:0x40aeb490 S:0x40aead74] OP - daemon> thread created.
    @0,962,132us: [+0 T:0x40aeb490 S:0x40aead74] OP - getCmd_d> Enter (proc=0x40aeade8)
    @0,962,818us: [+0 T:0x40aeb490 S:0x40aead54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611c0] timeout[0xffffffff]
    @0,963,594us: [+0 T:0x40aeb490 S:0x40aead54] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611c0] status[0]
    @0,964,281us: [+0 T:0x40aeb490 S:0x40aead74] OP - getCmd_d> Exit (result=1)
    @0,964,843us: [+0 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Enter(proc=0x61b30)
    @0,970,170us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Initializing DSP PROC...
    @0,970,925us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Using DspLink config data for entry #0 [server './cs.x64P']
    @0,971,628us: [+0 T:0x40aeb490 S:0x40aead5c] OM - Memory_alloc> Enter(0xe0)
    @0,972,323us: [+0 T:0x40aeb490 S:0x40aead5c] OM - Memory_alloc> return (0x61b88)
    @0,978,230us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1, syncd=0
    @0,979,033us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1, syncd=0
    @0,979,980us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESETCTRL', startAddress=0x8ff00000, sizeInBytes=0x80, shared=1, syncd=0
    @0,981,288us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x88000000, sizeInBytes=0x7a00000, shared=0, syncd=0
    @0,982,247us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> DODSPCTRL was=1; now=0
    @0,985,171us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Attaching to DSP PROC...
    @1,005,661us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Opening MSGQ pool...
    @1,006,407us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Loading ./cs.x64P on DSP (1 args)...
    @1,219,949us: [+2 T:0x412eb490 S:0x412eabf4] ti.sdo.dmai - [Display] Video output set to size 1280x720 pitch 1280
    @1,220,637us: [+2 T:0x412eb490 S:0x412eaa7c] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffers
    @1,221,051us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x42b69000, size=4)
    @1,221,193us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x42b69000, size=4)
    @1,221,304us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @1,221,418us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x42b69000) = 0x83800000.
    @1,221,534us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> Enter(virtAddr=0x42b69000, size=4, physAddr=0x83800000)
    @1,221,644us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> creating new contigBuf object
    @1,221,741us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> Enter(0x10)
    @1,221,846us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> return (0x61ec0)
    @1,221,947us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> returning: cb->phys=0x83800000, cb->size=4, cb->virt=0x42b69000
    @1,222,050us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> return (0x83800000)
    @1,222,152us: [+2 T:0x412eb490 S:0x412eaa84] ti.sdo.dmai - [Buffer] Set user pointer 0x42b69000 (physical 0x83800000)
    @1,418,768us: [+2 T:0x412eb490 S:0x412eaaa4] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x42b69000 has physical address 0x83800000
    @1,419,142us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x42f5e000, size=4)
    @1,419,279us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x42f5e000, size=4)
    @1,419,464us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @1,419,587us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x42f5e000) = 0x83400000.
    @1,419,707us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> Enter(virtAddr=0x42f5e000, size=4, physAddr=0x83400000)
    @1,419,819us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> creating new contigBuf object
    @1,419,916us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> Enter(0x10)
    @1,420,021us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> return (0x61ed8)
    @1,420,123us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> returning: cb->phys=0x83400000, cb->size=4, cb->virt=0x42f5e000
    @1,420,230us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> return (0x83400000)
    @1,420,330us: [+2 T:0x412eb490 S:0x412eaa84] ti.sdo.dmai - [Buffer] Set user pointer 0x42f5e000 (physical 0x83400000)
    @1,617,103us: [+2 T:0x412eb490 S:0x412eaaa4] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x42f5e000 has physical address 0x83400000
    @1,617,477us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43353000, size=4)
    @1,617,614us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43353000, size=4)
    @1,617,723us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @1,617,840us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x43353000) = 0x83000000.
    @1,617,957us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> Enter(virtAddr=0x43353000, size=4, physAddr=0x83000000)
    @1,618,067us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> creating new contigBuf object
    @1,618,167us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> Enter(0x10)
    @1,618,272us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> return (0x61ef0)
    @1,618,373us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> returning: cb->phys=0x83000000, cb->size=4, cb->virt=0x43353000
    @1,618,479us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> return (0x83000000)
    @1,618,577us: [+2 T:0x412eb490 S:0x412eaa84] ti.sdo.dmai - [Buffer] Set user pointer 0x43353000 (physical 0x83000000)
    @1,820,661us: [+2 T:0x412eb490 S:0x412eaaa4] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x43353000 has physical address 0x83000000
    @1,846,661us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Starting DSP PROC...
    @1,944,045us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Opening remote transport...
    @1,945,354us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> return (1)
    @1,945,999us: [+0 T:0x40aeb490 S:0x40aead64] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611d8]
    @1,946,716us: [+0 T:0x422eb490 S:0x422eaafc] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611d8] status[0]
    @1,946,868us: [+0 T:0x422eb490 S:0x422eab1c] OP - doCmd> Exit (result=1)
    @1,946,970us: [+0 T:0x422eb490 S:0x422eab3c] OP - Processor_create> return (0x61b30)
    @1,947,069us: [+0 T:0x422eb490 S:0x422eab74] CE - rserverOpen('./cs.x64P'): 0x60614 done.
    @1,947,189us: [+0 T:0x422eb490 S:0x422eab5c] OM - Memory_alloc> Enter(0x2a)
    @1,947,298us: [+0 T:0x422eb490 S:0x422eab5c] OM - Memory_alloc> return (0x61f08)
    @1,947,415us: [+0 T:0x422eb490 S:0x422eab4c] OC - Comm_create> Enter(queueName='encodedecode_735_0', queue=0x61b10, attrs=0x0)
    @1,947,521us: [+0 T:0x422eb490 S:0x422eab34] OM - Memory_alloc> Enter(0x4)
    @1,947,625us: [+0 T:0x422eb490 S:0x422eab34] OM - Memory_alloc> return (0x61f38)
    @1,947,926us: [+0 T:0x422eb490 S:0x422eab4c] OC - Comm_create> return (0x61f38)
    @1,948,061us: [+0 T:0x422eb490 S:0x422eab54] OM - Memory_free> Enter(0x61f08, 0x2a)
    @1,948,178us: [+0 T:0x422eb490 S:0x422eab54] OM - Memory_free> return (0x1)
    @1,948,280us: [+0 T:0x422eb490 S:0x422eab54] OC - Comm_alloc> Enter(poolId=0x0, msg=0x61b1c, size=576)
    @1,948,411us: [+0 T:0x422eb490 S:0x422eab54] OC - Comm_alloc> msg=0x42af8880, returning (0)
    @1,948,518us: [+0 T:0x422eb490 S:0x422eab3c] OC - Comm_locate> Enter(queueName='rmsq', queue=0x61b0c)
    @1,948,807us: [+0 T:0x4001ee40 S:0xbef19a74] CE - rserverOpen('./cs.x64P'), count = 1
    @1,948,960us: [+0 T:0x4001ee40 S:0xbef19a74] CE - rserverOpen('./cs.x64P'): 0x60614 done.
    @1,949,175us: [+0 T:0x4001ee40 S:0xbef19a5c] OM - Memory_alloc> Enter(0x2a)
    @1,949,437us: [+0 T:0x4001ee40 S:0xbef19a5c] OM - Memory_alloc> return (0x61f08)
    @1,949,595us: [+0 T:0x4001ee40 S:0xbef19a4c] OC - Comm_create> Enter(queueName='encodedecode_735_1', queue=0x61b68, attrs=0x0)
    @1,949,806us: [+0 T:0x4001ee40 S:0xbef19a34] OM - Memory_alloc> Enter(0x4)
    @1,950,004us: [+0 T:0x4001ee40 S:0xbef19a34] OM - Memory_alloc> return (0x61f48)
    @1,952,830us: [+0 T:0x4001ee40 S:0xbef19a4c] OC - Comm_create> return (0x61f48)
    @1,952,979us: [+0 T:0x4001ee40 S:0xbef19a54] OM - Memory_free> Enter(0x61f08, 0x2a)
    @1,953,190us: [+0 T:0x4001ee40 S:0xbef19a54] OM - Memory_free> return (0x1)
    @1,953,386us: [+0 T:0x4001ee40 S:0xbef19a54] OC - Comm_alloc> Enter(poolId=0x0, msg=0x61b74, size=576)
    @1,953,545us: [+0 T:0x4001ee40 S:0xbef19a54] OC - Comm_alloc> msg=0x42af9880, returning (0)
    @1,953,748us: [+0 T:0x4001ee40 S:0xbef19a3c] OC - Comm_locate> Enter(queueName='rmsq', queue=0x61b64)
    @1,954,106us: [+0 T:0x422eb490 S:0x422eab3c] OC - Comm_locate> return (0)
    @1,954,255us: [+0 T:0x422eb490 S:0x422eab74] CE - checkServer(0x61b00)
    @1,954,400us: [+0 T:0x422eb490 S:0x422eab44] OC - Comm_put> Enter(queue=0x0, msg=0x42af8880)
    @1,954,557us: [+0 T:0x422eb490 S:0x422eab44] OC - Comm_put> return (0)
    @1,954,692us: [+0 T:0x422eb490 S:0x422eab3c] OC - Comm_get> Enter(queue=0x10000, msg=0x422eabe0, timeout=-1)
    @1,955,118us: [+0 T:0x422eb490 S:0x422eab3c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @1,955,263us: [+0 T:0x422eb490 S:0x422eab74] CE - rmsInit> RMS initialized(0x61b00); CE_DEBUG on, setting DSP trace mask to *+01234567,GT_prefix=12345,GT_time=3
    @1,955,384us: [+0 T:0x422eb490 S:0x422eab4c] CE - Engine_setTrace> Enter(engine=0x61b00, mask='*+01234567,GT_prefix=12345,GT_time=3')
    @1,955,507us: [+1 T:0x422eb490 S:0x422eab4c] CE - Engine_setTrace> Requesting DSP set trace ...
    @1,955,603us: [+0 T:0x422eb490 S:0x422eab1c] OC - Comm_put> Enter(queue=0x0, msg=0x42af8880)
    @1,955,742us: [+0 T:0x422eb490 S:0x422eab1c] OC - Comm_put> return (0)
    @1,955,849us: [+0 T:0x422eb490 S:0x422eab14] OC - Comm_get> Enter(queue=0x10000, msg=0x422eab94, timeout=-1)
    @1,956,119us: [+0 T:0x4001ee40 S:0xbef19a3c] OC - Comm_locate> return (0)
    @1,956,344us: [+0 T:0x4001ee40 S:0xbef19a74] CE - checkServer(0x61b58)
    @1,956,491us: [+0 T:0x4001ee40 S:0xbef19a44] OC - Comm_put> Enter(queue=0x0, msg=0x42af9880)
    @1,956,736us: [+0 T:0x4001ee40 S:0xbef19a44] OC - Comm_put> return (0)
    @1,956,943us: [+0 T:0x4001ee40 S:0xbef19a3c] OC - Comm_get> Enter(queue=0x10001, msg=0xbef19ae0, timeout=-1)
    @1,957,592us: [+0 T:0x422eb490 S:0x422eab14] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @1,957,741us: [+0 T:0x422eb490 S:0x422eab4c] CE - Engine_setTrace> return(0)
    @1,957,859us: [+0 T:0x422eb490 S:0x422eaadc] OC - Comm_put> Enter(queue=0x0, msg=0x42af8880)
    @1,957,998us: [+0 T:0x422eb490 S:0x422eaadc] OC - Comm_put> return (0)
    @1,958,125us: [+0 T:0x422eb490 S:0x422eaad4] OC - Comm_get> Enter(queue=0x10000, msg=0x422eab74, timeout=-1)
    @1,958,331us: [+0 T:0x4001ee40 S:0xbef19a3c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @1,958,640us: [+0 T:0x422eb490 S:0x422eaad4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @0x000001b9:[T:0x00000000] codec_unitserver - main> Welcome to CS2DM6467 1.00.00.10 DSP server's main().
    [DSP] @0,045,646tk: [+0 T:0x8ba0006c S:0x8ba03fe4] OG - Global_setSpecialTrace> enter(mask='*+01234567,GT_prefix=12345,GT_time=3')
    [DSP] @0,045,731tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - Global_setSpecialTrace> This program was built with the following packages:
    [DSP] @0,045,796tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.targets.rts6000 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/targets/rts6000/) [1,0,0,0,1225517497925]
    [DSP] @0,045,881tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.utils.trace (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    [DSP] @0,045,970tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.aachedec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aachedec/) [1,0,0,1323674961000]
    [DSP] @0,046,058tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.g711dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711dec/) [1,0,0,1323674961000]
    [DSP] @0,046,146tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.g711enc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711enc/) [1,0,0,1323674961000]
    [DSP] @0,046,234tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1,0,0,1323674961000]
    [DSP] @0,046,327tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.h264dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/) [1,0,0,1323674961000]
    [DSP] @0,046,415tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.h264enc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/) [1,0,0,1323674961000]
    [DSP] @0,046,503tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.h264fhdvenc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1,0,0,1323674961000]
    [DSP] @0,046,594tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.mpeg2dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/) [1,0,0,1323674962000]
    [DSP] @0,046,682tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.jpegdec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegdec/) [1,0,0,1323674962000]
    [DSP] @0,046,770tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.jpegenc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegenc/) [1,0,0,1323674962000]
    [DSP] @0,046,858tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.mpeg4dec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/) [1,0,0,1323674962000]
    [DSP] @0,046,952tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.mpeg4enc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/) [1,0,0,1323674962000]
    [DSP] @0,047,041tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.hdvicp (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/hdvicp/) [1,0,0,1323674962000]
    [DSP] @0,047,128tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.global (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    [DSP] @0,047,215tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.utils.gtinfra (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/utils/gtinfra/) [1,0,0,1240266906169]
    [DSP] @0,047,307tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.ires.hdvicp (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/hdvicp/) [1,0,1,1240266763264]
    [DSP] @0,047,398tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.rtdx (/home/liul/dvsdk_2_00_00_22/bios_5_33_03/packages/ti/rtdx/) [2,0,0,4,1219531643983]
    [DSP] @0,047,473tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.psl (/home/l@1,998,632us: [+0 T:0x422eb490 S:0x422eaadc] OC - Comm_put> Enter(queue=0x0, msg=0x42af8880)
    @1,998,798us: [+0 T:0x422eb490 S:0x422eaadc] OC - Comm_put> return (0)
    @1,998,936us: [+0 T:0x422eb490 S:0x422eaad4] OC - Comm_get> Enter(queue=0x10000, msg=0x422eab74, timeout=-1)
    @1,999,241us: [+0 T:0x422eb490 S:0x422eaad4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @0,047,543tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.bios (/home/liul/dvsdk_2_00_00_22/bios_5_33_03/packages/ti/bios/) [5,2,5,6,1227035764854]
    [DSP] @0,047,618tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.dskt2 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dskt2/) [1,0,4,1240266678055]
    [DSP] @0,047,705tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.hdintc (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/hdintc/) [1,0,4,1240266707594]
    [DSP] @0,047,792tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.memutils (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    [DSP] @0,047,881tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.edma3.rm (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/fctools/packages/ti/sdo/edma3/rm/) [1,3,4,1225865844769]
    [DSP] @0,047,970tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.ires.nullresource (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/nullresource/) [1,0,0,1240266782634]
    [DSP] @0,048,065tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.rman (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/rman/) [2,0,0,1240266813533]
    [DSP] @0,048,150tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.edma3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/edma3/) [2,0,0,1240266681138]
    [DSP] @0,048,237tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.ires.edma3chan (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/ires/edma3chan/) [1,0,0,1240266737833]
    [DSP] @0,048,329tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.global (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    [DSP] @0,048,414tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.xdais.dm (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
    [DSP] @0,048,491tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.utils.xdm (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    [DSP] @0,048,577tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.xdais (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    [DSP] @0,048,652tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.node (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    [DSP] @0,048,735tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.ipc.dsplink.dsp (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2,0,1,1240276720026]
    [DSP] @0,048,825tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.dman3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    [DSP] @0,048,911tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.fc.acpy3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    [DSP] @0,048,998tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package dsplink.dsp (/home/liul/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/dsp/) [1,4,0,1318065713000]
    [DSP] @0,049,080tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.bios.utils (/home/liul/dvsdk_2_00_00_22/biosutils_1_01_00/packages/ti/bios/utils/) [2,0,1,0,0]
    [DSP] @0,049,157tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.catalog.c6000 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    [DSP] @0,049,236tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.platforms.evmDM6467 (/home/liul/dvsdk_2_00_00_22/bios_5_33_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    [DSP] @0,049,321tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.osal (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    [DSP] @0,049,403tk:@2,006,146us: [+0 T:0x422eb490 S:0x422eaadc] OC - Comm_put> Enter(queue=0x0, msg=0x42af8880)
    @2,006,310us: [+0 T:0x422eb490 S:0x422eaadc] OC - Comm_put> return (0)
    @2,006,450us: [+0 T:0x422eb490 S:0x422eaad4] OC - Comm_get> Enter(queue=0x10000, msg=0x422eab74, timeout=-1)
    @2,006,666us: [+0 T:0x422eb490 S:0x422eaad4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
     [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.osal.bios (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/bios/) [2,0,1,1240276734107]
    [DSP] @0,049,528tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.ipc (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    [DSP] @0,049,610tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.ipc.bios (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/bios/) [2,0,1,1240276705217]
    [DSP] @0,049,695tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.alg (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    [DSP] @0,049,777tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    [DSP] @0,049,856tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.bioslog (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
    [DSP] @0,049,941tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.audio1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
    [DSP] @0,050,025tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.aachedec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aachedec/ce/) [1,0,0,1323674961000]
    [DSP] @0,050,116tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.speech1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech1/) [1,0,1,1240276763928]
    [DSP] @0,050,200tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.g711dec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711dec/ce/) [1,0,0,1323674961000]
    [DSP] @0,050,290tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.g711enc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711enc/ce/) [1,0,0,1323674961000]
    [DSP] @0,050,381tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.video2 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
    [DSP] @0,050,465tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1,0,0,1323674961000]
    [DSP] @0,050,561tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.h264dec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/ce/) [1,0,0,1323674961000]
    [DSP] @0,050,651tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.video1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
    [DSP] @0,050,735tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.h264enc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/ce/) [1,0,0,1323674961000]
    [DSP] @0,050,825tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1323674962000]
    [DSP] @0,050,918tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.mpeg2dec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/ce/) [1,0,0,1323674962000]
    [DSP] @0,051,009tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.ce.image1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
    [DSP] @0,051,093tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.jpegdec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegdec/ce/) [1,0,0,1323674962000]
    [DSP] @0,051,183tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.jpegenc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegenc/ce/) [1,0,0,1323674962000]
    [DSP] @0,051,273tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.mpeg4dec.ce (/home/liul/dvsdk_2_00@2,013,527us: [+0 T:0x422eb490 S:0x422eaadc] OC - Comm_put> Enter(queue=0x0, msg=0x42af8880)
    @2,013,698us: [+0 T:0x422eb490 S:0x422eaadc] OC - Comm_put> return (0)
    @2,013,855us: [+0 T:0x422eb490 S:0x422eaad4] OC - Comm_get> Enter(queue=0x10000, msg=0x422eab74, timeout=-1)
    @2,014,071us: [+0 T:0x422eb490 S:0x422eaad4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @0,051,364tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.codecs.mpeg4enc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/ce/) [1,0,0,1323674962000]
    [DSP] @0,051,455tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG -     package ti.sdo.server.cs (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/server/cs/) [1,0,0,1323674962000]
    [DSP] @0,051,540tk: [+0 T:0x8ba0006c S:0x8ba03fe4] OG - Global_setSpecialTrace> return
    [DSP] @0,051,628tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8fe048a8, 4056): cmd = 6
    [DSP] @0,054,350tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @0,054,410tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @0,212,127tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @0,212,189tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @0,241,176tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @0,241,233tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @0,269,743tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @0,269,801tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032
    @2,015,492us: [+0 T:0x422eb490 S:0x422eab0c] CE - Engine_fwriteTrace> returning count [13945]
    @2,015,616us: [+0 T:0x422eb490 S:0x422eab74] CE - Engine_open> return(400128)
    create Engine success!
    @2,015,963us: [+2 T:0x422eb490 S:0x422eaafc] ti.sdo.dmai - [Venc1] Creating encoder h264fhdvenc for max 1280x720 bitrate 2000000 ratectrl 4
    @2,016,140us: [+0 T:0x422eb490 S:0x422eaad4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x61b00, name='h264fhdvenc', params=0x422eac2c)
    @2,019,305us: [+0 T:0x422eb490 S:0x422eaaa4] CV - VISA_create(0x61b00, 'h264fhdvenc', 0x422eac2c, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    @2,019,544us: [+0 T:0x422eb490 S:0x422ea9a4] CV - VISA_create2(0x61b00, 'h264fhdvenc', 0x422eac2c, 0x3c, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    @2,019,682us: [+0 T:0x422eb490 S:0x422ea98c] OM - Memory_alloc> Enter(0x30)
    @2,019,792us: [+0 T:0x422eb490 S:0x422ea98c] OM - Memory_alloc> return (0x620b0)
    @2,020,062us: [+0 T:0x422eb490 S:0x422ea92c] CE - Engine_createNode(0x61b00, 'h264fhdvenc', 2496, 0x422eac2c, 0x3c, 0x422eaa9c)
    @2,020,181us: [+0 T:0x422eb490 S:0x422ea92c] CE - Engine> allocNode Enter(engine=0x61b00, impId='h264fhdvenc')
    @2,020,282us: [+0 T:0x422eb490 S:0x422ea914] OM - Memory_alloc> Enter(0x20)
    @2,020,383us: [+0 T:0x422eb490 S:0x422ea914] OM - Memory_alloc> return (0x620e8)
    @2,020,494us: [+0 T:0x422eb490 S:0x422ea92c] CE - Engine> allocNode(). Calling Comm_create(gppfromnode_735_2, 0x620f0, NULL)
    @2,020,599us: [+0 T:0x422eb490 S:0x422ea904] OC - Comm_create> Enter(queueName='gppfromnode_735_2', queue=0x620f0, attrs=0x0)
    @2,020,705us: [+0 T:0x422eb490 S:0x422ea8ec] OM - Memory_alloc> Enter(0x4)
    @2,020,805us: [+0 T:0x422eb490 S:0x422ea8ec] OM - Memory_alloc> return (0x62110)
    @2,021,132us: [+0 T:0x422eb490 S:0x422ea904] OC - Comm_create> return (0x62110)
    @2,021,274us: [+0 T:0x422eb490 S:0x422ea90c] OC - Comm_put> Enter(queue=0x0, msg=0x42af8880)
    @2,021,431us: [+0 T:0x422eb490 S:0x422ea90c] OC - Comm_put> return (0)
    @2,021,538us: [+0 T:0x422eb490 S:0x422ea904] OC - Comm_get> Enter(queue=0x10000, msg=0x422ea9b4, timeout=-1)
    @2,024,267us: [+0 T:0x4001ee40 S:0xbef199dc] OC - Comm_put> Enter(queue=0x0, msg=0x42af9880)
    @2,024,480us: [+0 T:0x4001ee40 S:0xbef199dc] OC - Comm_put> return (0)
    @2,024,621us: [+0 T:0x4001ee40 S:0xbef199d4] OC - Comm_get> Enter(queue=0x10001, msg=0xbef19a74, timeout=-1)
    @2,029,238us: [+0 T:0x40aeb490 S:0x40aead74] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x611d8]
    @2,029,922us: [+0 T:0x40aeb490 S:0x40aead74] OP - getCmd_d> Enter (proc=0x40aeade8)
    @2,030,671us: [+0 T:0x40aeb490 S:0x40aead54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611c0] timeout[0xffffffff]
    @2,037,222us: [+0 T:0x422eb490 S:0x422ea904] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @2,037,368us: [+0 T:0x422eb490 S:0x422ea904] OC - Comm_delete> Enter (comm=0x62110)
    @2,037,681us: [+0 T:0x422eb490 S:0x422ea8e4] OM - Memory_free> Enter(0x62110, 0x4)
    @2,037,826us: [+0 T:0x422eb490 S:0x422ea8e4] OM - Memory_free> return (0x1)
    @2,037,935us: [+0 T:0x422eb490 S:0x422ea924] OC - Comm_delete> return
    @2,038,033us: [+0 T:0x422eb490 S:0x422ea90c] OM - Memory_free> Enter(0x620e8, 0x20)
    @2,038,138us: [+0 T:0x422eb490 S:0x422ea90c] OM - Memory_free> return (0x1)
    @2,038,237us: [+6 T:0x422eb490 S:0x422ea92c] CE - Engine_createNode> Remote node creation FAILED (0x80008008).
    @2,038,389us: [+0 T:0x4001ee40 S:0xbef199d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @0,299,654tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 0
    [DSP] @0,299,721tk: [+0 T:0x8ba0006c S:0x8ba03f1c] OM - Memory_alloc> Enter(size=0x18)
    [DSP] @0,299,772tk: [+0 T:0x8ba0006c S:0x8ba03f1c] OM - Memory_alloc> return (0x8fc629d8)
    [DSP] @0,299,827tk: [+0 T:0x8ba0006c S:0x8ba03f1c] OM - Memory_alloc> Enter(size=0xe)
    [DSP] @0,299,881tk: [+0 T:0x8ba0006c S:0x8ba03f1c] OM - Memory_alloc> return (0x8fc629f0)
    [DSP] @0,299,941tk: [+0 T:0x8ba0006c S:0x8ba03ee4] OM - Memory_alloc> Enter(size=0x20)
    [DSP] @0,299,991tk: [+0 T:0x8ba0006c S:0x8ba03ee4] OM - Memory_alloc> return (0x8fc62a00)
    [DSP] @0,300,046tk: [+0 T:0x8ba0006c S:0x8ba03eb4] OM - Memory_alloc> Enter(size=0x24)
    [DSP] @0,300,095tk: [+0 T:0x8ba0006c S:0x8ba03eb4] OM - Memory_alloc> return (0x8fc62a20)
    [DSP] @0,300,172tk: [+0 T:0x8ba0006c S:0x8ba03ecc] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x0, name='h264fhdvenc', params=0x8fe038c0)
    [DSP] @0,300,256tk: [+0 T:0x8ba0006c S:0x8ba03e94] CV - VISA_create(0x0, 'h264fhdvenc', 0x8fe038c0, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    [DSP] @0,300,332tk: [+0 T:0x8ba0006c S:0x8ba03d84] CV - VISA_create2(0x0, 'h264fhdvenc', 0x8fe038c0, 0x3c, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
    [DSP] @0,300,420tk: [+0 T:0x8ba0006c S:0x8ba03d1c] CE - Engine_open> Enter('local', 0x8ba03d6c, 0x8fe038c0)
    [DSP] @0,300,485tk: [+0 T:0x8ba0006c S:0x8ba03cfc] OM - Memory_alloc> Enter(size=0x2c)
    [DSP] @0,300,535tk: [+0 T:0x8ba0006c S:0x8ba03cfc] OM - Memory_alloc> return (0x8fc62a90)
    [DSP] @0,300,599tk: [+0 T:0x8ba0006c S:0x8ba03d1c] CE - Engine_open> return(-1882838384)
    [DSP] @0,300,669tk: [+0 T:0x8ba0006c S:0x8ba03d64] OM - Memory_alloc> Enter(size=0x30)
    [DSP] @0,300,720tk: [+0 T:0x8ba0006c S:0x8ba03d64] OM - Memory_alloc> return (0x8fc62ac0)
    [DSP] @0,300,777tk: [+0 T:0x8ba0006c S:0x8ba03d3c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fb8208c, idma3Fxns=0x0, iresFxns=0x8fb81fe4, params=0x8fe038c0, attrs=0x8ba03e80)
    [DSP] @0,300,876tk: [+0 T:0x8ba0006c S:0x8ba03d1c] OM - Memory_alloc> Enter(size=0x10)
    [DSP] @0,300,928tk: [+0 T:0x8ba0006c S:0x8ba03d1c] OM - Memory_alloc> return (0x8fc62af0)
    [DSP] @0,358,713tk: [+7 T:0x8ba0006c S:0x8ba03d3c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Algorithm creation FAILED; make sure that 1) alg params are correct/appropriate, 2) there is enough internal and external algorithm memory available -- check DSKT2 settings for heap assignments and scratch allocation
    [DSP] @0,358,857tk: [+0 T:0x8ba0006c S:0x8ba03d1c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(alg=0x8fc62af0)
    [DSP] @0,358,923tk: [+0 T:0x8ba0006c S:0x8ba03cec] OM - Memory_free> Enter(addr=0x8fc62af0, size=16)
    [DSP] @0,358,984tk: [+0 T:0x8ba0006c S:0x8ba03cec] OM - Memory_free> return (0x1)
    [DSP] @0,359,031tk: [+0 T:0x8ba0006c S:0x8ba03d1c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Exit
    [DSP] @0,359,085tk: [+0 T:0x8ba0006c S:0x8ba03d3c] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x0)
    [DSP] @0,359,144tk: [+2 T:0x8ba0006c S:0x8ba03d84] CV - VISA_create2> FAILED to create local codec.
    [DSP] @0,359,198tk: [+0 T:0x8ba0006c S:0x8ba03d54] CV - VISA_delete(0x8fc62ac0)
    [DSP] @0,359,249tk: [+5 T:0x8ba0006c S:0x8ba03d54] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
    [DSP] @0,359,315tk: [+0 T:0x8ba0006c S:0x8ba03d24] OM - Memory_free> Enter(addr=0x8fc62ac0, size=48)
    [DSP] @0,359,373tk: [+0 T:0x8ba0006c S:0x8ba03d24] OM - Memory_free> return (0x1)
    [DSP] @0,359,423tk: [+0 T:0x8ba0006c S:0x8ba03ecc] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
    [DSP] @0,359,485tk: [+0 T:0x8ba0006c S:0x8ba03ebc] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> Enter (handle=0x0)
    [DSP] @0,359,543tk: [+0 T:0x8ba0006c S:0x8ba03e8c] CV - VISA_delete(0x0)
    [DSP] @0,359,586tk: [+0 T:0x8ba0006c S:0x8ba03ebc] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> return
    [DSP] @0,359,642tk: [+0 T:0x8ba0006c S:0x8ba03ea4] OM - Memory_free> Enter(addr=0x8fc62a20, size=36)
    [DSP] @0,359,700tk: [+0 T:0x8ba0006c S:0x8ba03ea4] OM - Memory_free> return (0x1)
    [DSP] @0,359,747tk: [+0 T:0x8ba0006c S:0x8ba03eac] OM - Memory_free> Enter(addr=0x8fc62a00, size=32)
    [DSP] @0,359,805tk: [+0 T:0x8ba0006c S:0x8ba03eac] OM - Memory_free> return (0x1)
    [DSP] @0,359,855tk: [+0 T:0x8ba0006c S:0x8ba03f2c] OM -@2,042,693us: [+0 T:0x4001ee40 S:0xbef199dc] OC - Comm_put> Enter(queue=0x0, msg=0x42af9880)
    @2,042,863us: [+0 T:0x4001ee40 S:0xbef199dc] OC - Comm_put> return (0)
    @2,043,011us: [+0 T:0x4001ee40 S:0xbef199d4] OC - Comm_get> Enter(queue=0x10001, msg=0xbef19a74, timeout=-1)
    @2,043,233us: [+0 T:0x4001ee40 S:0xbef199d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
     Memory_free> Enter(addr=0x8fc629f0, size=14)
    [DSP] @0,359,912tk: [+0 T:0x8ba0006c S:0x8ba03f2c] OM - Memory_free> return (0x1)
    [DSP] @0,359,959tk: [+0 T:0x8ba0006c S:0x8ba03f2c] OM - Memory_free> Enter(addr=0x8fc629d8, size=24)
    [DSP] @0,360,017tk: [+0 T:0x8ba0006c S:0x8ba03f2c] OM - Memory_free> return (0x1)
    [DSP] @0,360,115tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8fe048a8, 4056): cmd = 5
    [DSP] @0,360,174tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @0,382,539tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8fe048a8, 4056): cmd = 5
    [DSP] @0,382,602tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032
    @2,044,029us: [+0 T:0x4001ee40 S:0xbef19a0c] CE - Engine_fwriteTrace> returning count [4983]
    @2,044,180us: [+0 T:0x422eb490 S:0x422ea894] OC - Comm_put> Enter(queue=0x0, msg=0x42af8880)
    @2,044,338us: [+0 T:0x422eb490 S:0x422ea894] OC - Comm_put> return (0)
    @2,044,475us: [+0 T:0x422eb490 S:0x422ea88c] OC - Comm_get> Enter(queue=0x10000, msg=0x422ea92c, timeout=-1)
    @2,044,618us: [+0 T:0x4001ee40 S:0xbef19a74] CE - Engine_open> return(400216)
    @2,046,727us: [+0 T:0x422eb490 S:0x422ea88c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @0,388,242tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
    [DSP] @0,388,301tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032
    @2,047,065us: [+0 T:0x422eb490 S:0x422ea8c4] CE - Engine_fwriteTrace> returning count [197]
    @2,047,201us: [+2 T:0x422eb490 S:0x422ea92c] CE - Engine_createNode> Returning 0x0
    @2,047,305us: [+2 T:0x422eb490 S:0x422ea9a4] CV - VISA_create2> FAILED to create remote codec (0x8).
    @2,047,408us: [+0 T:0x422eb490 S:0x422ea97c] CV - VISA_delete(0x620b0)
    @2,047,500us: [+5 T:0x422eb490 S:0x422ea97c] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
    @2,047,600us: [+0 T:0x422eb490 S:0x422ea95c] OM - Memory_free> Enter(0x620b0, 0x30)
    @2,047,698us: [+0 T:0x422eb490 S:0x422ea95c] OM - Memory_free> return (0x1)
    @2,047,798us: [+0 T:0x422eb490 S:0x422eaad4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
    @2,047,899us: [+7 T:0x422eb490 S:0x422eaafc] ti.sdo.dmai - [Venc1] Failed to open video encode algorithm: h264fhdvenc (0x8)
    Error: Failed to create video encoder: h264fhdvenc
    @2,413,934us: [+2 T:0x41aeb490 S:0x41aeab34] ti.sdo.dmai - [Capture] Video input connected size 1280x720 pitch 1280
    @2,414,695us: [+2 T:0x41aeb490 S:0x41aea9bc] ti.sdo.dmai - [BufTab] Allocating BufTab for 4 buffers
    @2,415,067us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43748000, size=4)
    @2,415,208us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43748000, size=4)
    @2,415,320us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @2,415,435us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x43748000) = 0x82c00000.
    @2,415,554us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> Enter(virtAddr=0x43748000, size=4, physAddr=0x82c00000)
    @2,415,666us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> creating new contigBuf object
    @2,415,764us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> Enter(0x10)
    @2,415,872us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> return (0x620e8)
    @2,415,974us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> returning: cb->phys=0x82c00000, cb->size=4, cb->virt=0x43748000
    @2,416,080us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> return (0x82c00000)
    @2,416,186us: [+2 T:0x41aeb490 S:0x41aea9c4] ti.sdo.dmai - [Buffer] Set user pointer 0x43748000 (physical 0x82c00000)
    @2,612,999us: [+2 T:0x41aeb490 S:0x41aea9e4] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x43748000 has physical address 0x82c00000
    @2,613,383us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43b3d000, size=4)
    @2,613,522us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43b3d000, size=4)
    @2,613,633us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @2,613,750us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x43b3d000) = 0x82800000.
    @2,613,895us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> Enter(virtAddr=0x43b3d000, size=4, physAddr=0x82800000)
    @2,614,009us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> creating new contigBuf object
    @2,614,108us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> Enter(0x10)
    @2,614,214us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> return (0x62100)
    @2,614,314us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> returning: cb->phys=0x82800000, cb->size=4, cb->virt=0x43b3d000
    @2,614,421us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> return (0x82800000)
    @2,614,523us: [+2 T:0x41aeb490 S:0x41aea9c4] ti.sdo.dmai - [Buffer] Set user pointer 0x43b3d000 (physical 0x82800000)
    @2,811,175us: [+2 T:0x41aeb490 S:0x41aea9e4] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x43b3d000 has physical address 0x82800000
    @2,811,554us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43f32000, size=4)
    @2,811,692us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43f32000, size=4)
    @2,811,804us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @2,811,919us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x43f32000) = 0x82400000.
    @2,812,040us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> Enter(virtAddr=0x43f32000, size=4, physAddr=0x82400000)
    @2,812,156us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> creating new contigBuf object
    @2,812,255us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> Enter(0x10)
    @2,812,363us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> return (0x61ff0)
    @2,812,464us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> returning: cb->phys=0x82400000, cb->size=4, cb->virt=0x43f32000
    @2,812,571us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> return (0x82400000)
    @2,812,673us: [+2 T:0x41aeb490 S:0x41aea9c4] ti.sdo.dmai - [Buffer] Set user pointer 0x43f32000 (physical 0x82400000)
    @3,009,758us: [+2 T:0x41aeb490 S:0x41aea9e4] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x43f32000 has physical address 0x82400000
    @3,010,135us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x44327000, size=4)
    @3,010,272us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x44327000, size=4)
    @3,010,384us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @3,010,499us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x44327000) = 0x82000000.
    @3,010,617us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> Enter(virtAddr=0x44327000, size=4, physAddr=0x82000000)
    @3,010,729us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> creating new contigBuf object
    @3,010,824us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> Enter(0x10)
    @3,010,925us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> return (0x62008)
    @3,011,024us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> returning: cb->phys=0x82000000, cb->size=4, cb->virt=0x44327000
    @3,011,130us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> return (0x82000000)
    @3,011,229us: [+2 T:0x41aeb490 S:0x41aea9c4] ti.sdo.dmai - [Buffer] Set user pointer 0x44327000 (physical 0x82000000)
    @3,208,127us: [+2 T:0x41aeb490 S:0x41aea9e4] ti.sdo.dmai - [Dmai] Driver buffer 3 mapped to 0x44327000 has physical address 0x82000000
  •  Janet,
              These are the APP logs after adding the following line,
              xdc.useModule('ti.sdo.fc.global.Settings').profile = "debug_trace";
              In fact, the codec engine cann't open in this case,but it can open before the "debug_trace" setting.This is a puzzle to me also.
    root@iview:/mnt/nfs/liul/encoderdecoder_demo_TI# CE_DEBUG=2 DMAI_DEBUG=2 ./encodedecode -p -y3
    @0,959,486us: [+4 T:0x4001ee40] OG - Global_init> This program was built with the following packages:
    @0,960,272us: [+4 T:0x4001ee40] OG -     package gnu.targets.rts470MV (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/gnu/targets/rts470MV/) [1,0,0,0,1225517438755]
    @0,960,774us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h264fhdvenc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1,0,0,1323674961000]
    @0,961,247us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1,0,0,1323674961000]
    @0,961,723us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.global (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    @0,962,185us: [+4 T:0x4001ee40] OG -     package ti.xdais.dm (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
    @0,962,631us: [+4 T:0x4001ee40] OG -     package ti.sdo.utils.trace (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    @0,963,101us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.utils.xdm (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    @0,963,567us: [+4 T:0x4001ee40] OG -     package ti.xdais (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    @0,964,084us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.node (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    @0,964,737us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.global (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    @0,965,210us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.dman3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    @0,965,675us: [+4 T:0x4001ee40] OG -     package ti.sdo.linuxutils.cmem (/home/liul/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/) [2,2,0,1240253001679]
    @0,966,143us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.memutils (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    @0,966,609us: [+4 T:0x4001ee40] OG -     package ti.sdo.fc.acpy3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    @0,967,072us: [+4 T:0x4001ee40] OG -     package dsplink.gpp (/home/liul/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/gpp/) [5,0,0,1318065716000]
    @0,967,531us: [+4 T:0x4001ee40] OG -     package gnu.targets (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/gnu/targets/) [1,0,1,1225517427930]
    @0,967,981us: [+4 T:0x4001ee40] OG -     package ti.catalog.c470 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c470/) [1,0,1,0,0]
    @0,968,430us: [+4 T:0x4001ee40] OG -     package ti.catalog.c6000 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    @0,968,954us: [+4 T:0x4001ee40] OG -     package ti.platforms.evmDM6467 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    @0,969,496us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.osal (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    @0,969,612us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.osal.linux (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/linux/) [2,0,1,1240276736840]
    @0,969,701us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.ipc (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    @0,969,908us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.ipc.dsplink (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/) [2,0,1,1240276714152]
    @0,970,023us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.alg (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    @0,970,110us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    @0,970,189us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.video1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
    @0,970,268us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1323674962000]
    @0,970,389us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.video2 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
    @0,970,471us: [+4 T:0x4001ee40] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1,0,0,1323674961000]
    @0,970,553us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.speech (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech/) [1,0,2,1240276762193]
    @0,970,628us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.speech1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech1/) [1,0,1,1240276763928]
    @0,970,704us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.audio (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio/) [1,0,2,1240276296374]
    @0,970,780us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.audio1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
    @0,970,855us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.video (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video/) [1,0,3,1240276930771]
    @0,970,930us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.image (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image/) [1,0,3,1240276700525]
    @0,971,004us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.image1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
    @0,971,081us: [+4 T:0x4001ee40] OG -     package ti.sdo.dmai (/home/liul/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/) [1,0,0,1323673835000]
    @0,971,155us: [+4 T:0x4001ee40] OG -     package ti.sdo.simplewidget (/home/liul/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/packages/ti/sdo/simplewidget/) []
    @0,971,229us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.bioslog (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
    @0,971,303us: [+4 T:0x4001ee40] OG -     package ti.sdo.ce.utils.trace (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/trace/) [1,0,1,1240276915917]
    @0,971,378us: [+4 T:0x4001ee40] OG -     package encodedecode_config (/home/liul/encoderdecoder_demo_TI/encodedecode/encodedecode_config/) []
    @0,971,895us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,972,025us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x611c0]
    @0,972,115us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,972,192us: [+0 T:0x4001ee40] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x611d8]
    @0,972,278us: [+0 T:0x4001ee40] OT - Thread_create> Enter (fxn=0x2c7cc, attrs=0x0)
    @0,972,764us: [+0 T:0x4001ee40] OT - Thread_create> Exit (task=0x61210)
    @0,976,022us: [+0 T:0x4001ee40] ti.sdo.ce.alg - ALG_init> Enter
    @0,976,552us: [+0 T:0x4001ee40] ti.sdo.ce.alg - ALG_init> Exit
    @0,977,019us: [+6 T:0x4001ee40] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
    @0,977,659us: [+0 T:0x4001ee40] CS - Server_init()
    @0,978,034us: [+0 T:0x4001ee40] CS - Server_init> Global_useLinkArbiter = 0
    @0,978,581us: [+2 T:0x4001ee40] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note that calling CERuntime_init after this point may cause unexpected change to DMAI tracing behavior.
    envp->engineName is encodedecode!
    @0,993,501us: [+0 T:0x422eb490] CE - Engine_open> Enter('encodedecode', 0x0, 0x422eabe4)
    @0,993,614us: [+0 T:0x422eb490] CE - rserverOpen('./cs.x64P'), count = 0
    @0,993,697us: [+0 T:0x422eb490] OP - Processor_create> Enter(imageName='./cs.x64P', linkCfg='(null)', attrs=0x422eabc8)
    @0,999,412us: [+0 T:0x422eb490] OP - doCmd> Enter (cmdId=1, proc=0x61b30)
    @0,999,540us: [+0 T:0x422eb490] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611c0]
    @0,999,687us: [+0 T:0x422eb490] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x611c0]
    @0,999,778us: [+0 T:0x422eb490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611d8] timeout[0xffffffff]
    @1,000,939us: [+0 T:0x4001ee40] CE - Engine_open> Enter('encodedecode', 0x0, 0xbeaefae4)
    @1,017,298us: [+1 T:0x40aeb490] OP - daemon> thread created.
    @1,017,839us: [+0 T:0x40aeb490] OP - getCmd_d> Enter (proc=0x40aeade8)
    @1,018,388us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611c0] timeout[0xffffffff]
    @1,019,139us: [+0 T:0x40aeb490] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611c0] status[0]
    @1,019,971us: [+0 T:0x40aeb490] OP - getCmd_d> Exit (result=1)
    @1,020,517us: [+0 T:0x40aeb490] OP - Processor_create_d> Enter(proc=0x61b30)
    @1,020,968us: [+2 T:0x40aeb490] OP - Processor_create_d> Initializing DSP PROC...
    @1,021,383us: [+2 T:0x40aeb490] OP - Processor_create_d> Using DspLink config data for entry #0 [server './cs.x64P']
    @1,021,833us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1, syncd=0
    @1,022,325us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1, syncd=0
    @1,022,820us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESETCTRL', startAddress=0x8ff00000, sizeInBytes=0x80, shared=1, syncd=0
    @1,023,312us: [+2 T:0x40aeb490] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x88000000, sizeInBytes=0x7a00000, shared=0, syncd=0
    @1,023,802us: [+2 T:0x40aeb490] OP - Processor_create_d> DODSPCTRL was=1; now=0
    @1,026,150us: [+2 T:0x40aeb490] OP - Processor_create_d> Attaching to DSP PROC...
    @1,039,934us: [+2 T:0x40aeb490] OP - Processor_create_d> Opening MSGQ pool...
    @1,040,648us: [+2 T:0x40aeb490] OP - Processor_create_d> Loading ./cs.x64P on DSP (1 args)...
    @1,115,076us: [+2 T:0x412eb490] ti.sdo.dmai - [Display] Video output set to size 1280x720 pitch 1280
    @1,118,005us: [+2 T:0x412eb490] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffers
    @1,119,973us: [+2 T:0x412eb490] ti.sdo.dmai - [Buffer] Set user pointer 0x42b6c000 (physical 0x82000000)
    @1,341,959us: [+2 T:0x412eb490] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x42b6c000 has physical address 0x82000000
    @1,342,345us: [+2 T:0x412eb490] ti.sdo.dmai - [Buffer] Set user pointer 0x42f61000 (physical 0x82400000)
    @1,538,934us: [+2 T:0x412eb490] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x42f61000 has physical address 0x82400000
    @1,539,372us: [+2 T:0x412eb490] ti.sdo.dmai - [Buffer] Set user pointer 0x43356000 (physical 0x82800000)
    @1,735,977us: [+2 T:0x412eb490] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x43356000 has physical address 0x82800000
    @2,633,279us: [+2 T:0x41aeb490] ti.sdo.dmai - [Capture] Video input connected size 1280x720 pitch 1280
    @2,634,043us: [+2 T:0x41aeb490] ti.sdo.dmai - [BufTab] Allocating BufTab for 4 buffers
    @2,634,420us: [+2 T:0x41aeb490] ti.sdo.dmai - [Buffer] Set user pointer 0x4374b000 (physical 0x82c00000)
    @2,831,158us: [+2 T:0x41aeb490] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x4374b000 has physical address 0x82c00000
    @2,831,549us: [+2 T:0x41aeb490] ti.sdo.dmai - [Buffer] Set user pointer 0x43b40000 (physical 0x83000000)
    @3,028,172us: [+2 T:0x41aeb490] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x43b40000 has physical address 0x83000000
    @3,028,564us: [+2 T:0x41aeb490] ti.sdo.dmai - [Buffer] Set user pointer 0x43f35000 (physical 0x83400000)
    @3,225,382us: [+2 T:0x41aeb490] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x43f35000 has physical address 0x83400000
    @3,225,772us: [+2 T:0x41aeb490] ti.sdo.dmai - [Buffer] Set user pointer 0x4432a000 (physical 0x83800000)
    @3,422,427us: [+2 T:0x41aeb490] ti.sdo.dmai - [Dmai] Driver buffer 3 mapped to 0x4432a000 has physical address 0x83800000
    @9,121,202us: [+0 T:0x4001ee40] OP - doCmd> Enter (cmdId=3, proc=0x0)
    root@iview:/mnt/nfs/liul/encoderdecoder_demo_TI# CE_DEBUG=3 DMAI_DEBUG=2 ./encodedecode -p -y3
    @0,188,871us: [+4 T:0x4001ee40 S:0xbebe4af4] OG - Global_init> This program was built with the following packages:
    @0,189,775us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package gnu.targets.rts470MV (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/gnu/targets/rts470MV/) [1,0,0,0,1225517438755]
    @0,190,310us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.codecs.h264fhdvenc (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1,0,0,1323674961000]
    @0,190,820us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.codecs.h2641080p60vdec (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1,0,0,1323674961000]
    @0,191,332us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.global (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    @0,191,828us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.xdais.dm (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
    @0,192,310us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.utils.trace (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    @0,192,814us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.utils.xdm (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    @0,193,312us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.xdais (/home/liul/dvsdk_2_00_00_22/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    @0,193,862us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.node (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    @0,194,355us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.fc.global (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    @0,195,004us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.fc.dman3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    @0,195,565us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.linuxutils.cmem (/home/liul/dvsdk_2_00_00_22/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/) [2,2,0,1240253001679]
    @0,196,067us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.fc.memutils (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    @0,196,570us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.fc.acpy3 (/home/liul/dvsdk_2_00_00_22/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    @0,197,070us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package dsplink.gpp (/home/liul/dvsdk_2_00_00_22/dsplink-1_61_03-prebuilt/packages/dsplink/gpp/) [5,0,0,1318065716000]
    @0,197,562us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package gnu.targets (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/gnu/targets/) [1,0,1,1225517427930]
    @0,198,046us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.catalog.c470 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c470/) [1,0,1,0,0]
    @0,198,531us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.catalog.c6000 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    @0,199,091us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.platforms.evmDM6467 (/home/liul/dvsdk_2_00_00_22/xdctools_3_10_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    @0,199,670us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.osal (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    @0,199,946us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.osal.linux (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/osal/linux/) [2,0,1,1240276736840]
    @0,200,064us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.ipc (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    @0,200,172us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.ipc.dsplink (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/) [2,0,1,1240276714152]
    @0,200,278us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.alg (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    @0,200,382us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    @0,200,483us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.video1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
    @0,200,586us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.codecs.h264fhdvenc.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1,0,0,1323674962000]
    @0,200,691us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.video2 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
    @0,200,793us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.codecs.h2641080p60vdec.ce (/home/liul/dvsdk_2_00_00_22/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1,0,0,1323674961000]
    @0,200,899us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.speech (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech/) [1,0,2,1240276762193]
    @0,201,000us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.speech1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/speech1/) [1,0,1,1240276763928]
    @0,201,104us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.audio (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio/) [1,0,2,1240276296374]
    @0,201,206us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.audio1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
    @0,201,308us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.video (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/video/) [1,0,3,1240276930771]
    @0,201,407us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.image (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image/) [1,0,3,1240276700525]
    @0,201,509us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.image1 (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
    @0,201,611us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.dmai (/home/liul/dvsdk_2_00_00_22/dmai_1_20_00_06/packages/ti/sdo/dmai/) [1,0,0,1323673835000]
    @0,201,710us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.simplewidget (/home/liul/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/packages/ti/sdo/simplewidget/) []
    @0,201,811us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.bioslog (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
    @0,201,915us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package ti.sdo.ce.utils.trace (/home/liul/dvsdk_2_00_00_22/codec_engine_2_23_01/packages/ti/sdo/ce/utils/trace/) [1,0,1,1240276915917]
    @0,202,017us: [+4 T:0x4001ee40 S:0xbebe4af4] OG -     package encodedecode_config (/home/liul/encoderdecoder_demo_TI/encodedecode/encodedecode_config/) []
    @0,202,170us: [+0 T:0x4001ee40 S:0xbebe4afc] OG - Global_atexit> enter (fxn=0x31dcc)
    @0,202,293us: [+0 T:0x4001ee40 S:0xbebe4afc] OG - Global_atexit> enter (fxn=0x31218)
    @0,205,660us: [+0 T:0x4001ee40 S:0xbebe4acc] OM - Memory_alloc> Enter(0x18)
    @0,206,093us: [+0 T:0x4001ee40 S:0xbebe4acc] OM - Memory_alloc> return (0x610f0)
    @0,206,869us: [+0 T:0x4001ee40 S:0xbebe4aec] OG - Global_atexit> enter (fxn=0x2f148)
    @0,207,498us: [+0 T:0x4001ee40 S:0xbebe4ac4] OM - Memory_alloc> Enter(0x18)
    @0,207,932us: [+0 T:0x4001ee40 S:0xbebe4ac4] OM - Memory_alloc> return (0x61140)
    @0,208,362us: [+0 T:0x4001ee40 S:0xbebe4ae4] OG - Global_atexit> enter (fxn=0x2dff4)
    @0,208,871us: [+0 T:0x4001ee40 S:0xbebe4aec] OG - Global_atexit> enter (fxn=0x3087c)
    @0,209,536us: [+0 T:0x4001ee40 S:0xbebe4ae4] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,209,969us: [+0 T:0x4001ee40 S:0xbebe4acc] OM - Memory_alloc> Enter(0x14)
    @0,210,403us: [+0 T:0x4001ee40 S:0xbebe4acc] OM - Memory_alloc> return (0x611c0)
    @0,210,854us: [+0 T:0x4001ee40 S:0xbebe4ae4] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x611c0]
    @0,211,295us: [+0 T:0x4001ee40 S:0xbebe4ae4] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @0,211,723us: [+0 T:0x4001ee40 S:0xbebe4acc] OM - Memory_alloc> Enter(0x14)
    @0,212,157us: [+0 T:0x4001ee40 S:0xbebe4acc] OM - Memory_alloc> return (0x611d8)
    @0,212,587us: [+0 T:0x4001ee40 S:0xbebe4ae4] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x611d8]
    @0,213,027us: [+0 T:0x4001ee40 S:0xbebe4acc] OM - Memory_alloc> Enter(0x18)
    @0,213,461us: [+0 T:0x4001ee40 S:0xbebe4acc] OM - Memory_alloc> return (0x611f0)
    @0,213,891us: [+0 T:0x4001ee40 S:0xbebe4ac4] OT - Thread_create> Enter (fxn=0x2c7cc, attrs=0x0)
    @0,214,331us: [+0 T:0x4001ee40 S:0xbebe4aac] OM - Memory_alloc> Enter(0x64)
    @0,214,764us: [+0 T:0x4001ee40 S:0xbebe4aac] OM - Memory_alloc> return (0x61210)
    @0,215,684us: [+0 T:0x4001ee40 S:0xbebe4ac4] OT - Thread_create> Exit (task=0x61210)
    @0,216,259us: [+0 T:0x4001ee40 S:0xbebe4afc] OG - Global_atexit> enter (fxn=0x2c1bc)
    @0,216,711us: [+0 T:0x4001ee40 S:0xbebe4afc] OG - Global_atexit> enter (fxn=0x2e540)
    @0,217,209us: [+0 T:0x4001ee40 S:0xbebe4ae4] ti.sdo.ce.alg - ALG_init> Enter
    @0,217,633us: [+0 T:0x4001ee40 S:0xbebe4ad4] OG - Global_atexit> enter (fxn=0x2be08)
    @0,218,073us: [+0 T:0x4001ee40 S:0xbebe4b04] ti.sdo.ce.alg - ALG_init> Exit
    @0,218,495us: [+0 T:0x4001ee40 S:0xbebe4afc] OG - Global_atexit> enter (fxn=0x2b234)
    @0,218,949us: [+0 T:0x4001ee40 S:0xbebe4ad4] OM - Memory_alloc> Enter(0x18)
    @0,219,455us: [+0 T:0x4001ee40 S:0xbebe4ad4] OM - Memory_alloc> return (0x613f0)
    @0,219,952us: [+0 T:0x4001ee40 S:0xbebe4afc] OG - Global_atexit> enter (fxn=0x30d6c)
    @0,220,452us: [+6 T:0x4001ee40 S:0xbebe4af4] CE - Engine_init> CE debugging on (CE_DEBUG=3; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
    @0,220,924us: [+0 T:0x4001ee40 S:0xbebe4ae4] OG - Global_atexit> enter (fxn=0x286c8)
    @0,221,363us: [+0 T:0x4001ee40 S:0xbebe4ac4] OM - Memory_alloc> Enter(0x18)
    @0,221,799us: [+0 T:0x4001ee40 S:0xbebe4ac4] OM - Memory_alloc> return (0x61430)
    @0,222,234us: [+0 T:0x4001ee40 S:0xbebe4ac4] OM - Memory_alloc> Enter(0x18)
    @0,222,670us: [+0 T:0x4001ee40 S:0xbebe4ac4] OM - Memory_alloc> return (0x61450)
    @0,223,102us: [+0 T:0x4001ee40 S:0xbebe4ac4] OM - Memory_alloc> Enter(0x18)
    @0,223,539us: [+0 T:0x4001ee40 S:0xbebe4ac4] OM - Memory_alloc> return (0x61470)
    @0,224,094us: [+0 T:0x4001ee40 S:0xbebe4afc] CS - Server_init()
    @0,224,506us: [+0 T:0x4001ee40 S:0xbebe4afc] CS - Server_init> Global_useLinkArbiter = 0
    @0,225,074us: [+0 T:0x4001ee40 S:0xbebe4afc] OG - Global_atexit> enter (fxn=0x269a8)
    @0,225,585us: [+0 T:0x4001ee40 S:0xbebe4b0c] OG - Global_atexit> enter (fxn=0x129f8)
    @0,226,090us: [+2 T:0x4001ee40 S:0xbebe4b0c] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note that calling CERuntime_init after this point may cause unexpected change to DMAI tracing behavior.
    Encodedecode demo started.
    @0,241,011us: [+0 T:0x422eb490 S:0x422eab74] CE - Engine_open> Enter('encodedecode', 0x0, 0x422eabe4)
    @0,241,140us: [+0 T:0x422eb490 S:0x422eab5c] OM - Memory_alloc> Enter(0x2c)
    @0,241,248us: [+0 T:0x422eb490 S:0x422eab5c] OM - Memory_alloc> return (0x61b00)
    @0,241,349us: [+0 T:0x422eb490 S:0x422eab74] CE - rserverOpen('./cs.x64P'), count = 0
    @0,241,447us: [+0 T:0x422eb490 S:0x422eab3c] OP - Processor_create> Enter(imageName='./cs.x64P', linkCfg='(null)', attrs=0x422eabc8)
    @0,247,114us: [+0 T:0x422eb490 S:0x422eab24] OM - Memory_alloc> Enter(0x24)
    @0,247,273us: [+0 T:0x422eb490 S:0x422eab24] OM - Memory_alloc> return (0x61b30)
    @0,247,385us: [+0 T:0x422eb490 S:0x422eab1c] OP - doCmd> Enter (cmdId=1, proc=0x61b30)
    @0,247,486us: [+0 T:0x422eb490 S:0x422eab0c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x611c0]
    @0,247,647us: [+0 T:0x422eb490 S:0x422eab1c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x611c0]
    @0,247,764us: [+0 T:0x422eb490 S:0x422eaafc] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611d8] timeout[0xffffffff]
    @0,248,948us: [+0 T:0x4001ee40 S:0xbebe4a74] CE - Engine_open> Enter('encodedecode', 0x0, 0xbebe4ae4)
    @0,249,093us: [+0 T:0x4001ee40 S:0xbebe4a5c] OM - Memory_alloc> Enter(0x2c)
    @0,249,281us: [+0 T:0x4001ee40 S:0xbebe4a5c] OM - Memory_alloc> return (0x61b58)
    @0,277,252us: [+1 T:0x40aeb490 S:0x40aead74] OP - daemon> thread created.
    @0,277,861us: [+0 T:0x40aeb490 S:0x40aead74] OP - getCmd_d> Enter (proc=0x40aeade8)
    @0,278,498us: [+0 T:0x40aeb490 S:0x40aead54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x611c0] timeout[0xffffffff]
    @0,279,068us: [+0 T:0x40aeb490 S:0x40aead54] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x611c0] status[0]
    @0,279,829us: [+0 T:0x40aeb490 S:0x40aead74] OP - getCmd_d> Exit (result=1)
    @0,280,372us: [+0 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Enter(proc=0x61b30)
    @0,280,962us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Initializing DSP PROC...
    @0,281,579us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Using DspLink config data for entry #0 [server './cs.x64P']
    @0,282,278us: [+0 T:0x40aeb490 S:0x40aead5c] OM - Memory_alloc> Enter(0xe0)
    @0,282,893us: [+0 T:0x40aeb490 S:0x40aead5c] OM - Memory_alloc> return (0x61b88)
    @0,283,534us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, shared=1, syncd=0
    @0,284,219us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x100000, shared=1, syncd=0
    @0,284,996us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESETCTRL', startAddress=0x8ff00000, sizeInBytes=0x80, shared=1, syncd=0
    @0,290,211us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x88000000, sizeInBytes=0x7a00000, shared=0, syncd=0
    @0,291,068us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> DODSPCTRL was=1; now=0
    @0,298,493us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Attaching to DSP PROC...
    @0,327,071us: [+2 T:0x412eb490 S:0x412eabf4] ti.sdo.dmai - [Display] Video output set to size 1280x720 pitch 1280
    @0,327,756us: [+2 T:0x412eb490 S:0x412eaa7c] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffers
    @0,328,214us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x422ec000, size=4)
    @0,328,353us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x422ec000, size=4)
    @0,328,463us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @0,328,578us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x422ec000) = 0x83800000.
    @0,328,695us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> Enter(virtAddr=0x422ec000, size=4, physAddr=0x83800000)
    @0,328,803us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> creating new contigBuf object
    @0,328,897us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> Enter(0x10)
    @0,329,000us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> return (0x618f0)
    @0,329,102us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> returning: cb->phys=0x83800000, cb->size=4, cb->virt=0x422ec000
    @0,329,205us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> return (0x83800000)
    @0,329,304us: [+2 T:0x412eb490 S:0x412eaa84] ti.sdo.dmai - [Buffer] Set user pointer 0x422ec000 (physical 0x83800000)
    @0,525,916us: [+2 T:0x412eb490 S:0x412eaaa4] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x422ec000 has physical address 0x83800000
    @0,526,290us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x426e1000, size=4)
    @0,526,424us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x426e1000, size=4)
    @0,526,532us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @0,526,647us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x426e1000) = 0x83400000.
    @0,526,764us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> Enter(virtAddr=0x426e1000, size=4, physAddr=0x83400000)
    @0,526,874us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> creating new contigBuf object
    @0,526,972us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> Enter(0x10)
    @0,527,075us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> return (0x61908)
    @0,527,173us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> returning: cb->phys=0x83400000, cb->size=4, cb->virt=0x426e1000
    @0,527,277us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> return (0x83400000)
    @0,527,377us: [+2 T:0x412eb490 S:0x412eaa84] ti.sdo.dmai - [Buffer] Set user pointer 0x426e1000 (physical 0x83400000)
    @0,723,979us: [+2 T:0x412eb490 S:0x412eaaa4] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x426e1000 has physical address 0x83400000
    @0,724,351us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x42ad6000, size=4)
    @0,724,486us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x42ad6000, size=4)
    @0,724,593us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @0,724,707us: [+1 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x42ad6000) = 0x83000000.
    @0,724,822us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> Enter(virtAddr=0x42ad6000, size=4, physAddr=0x83000000)
    @0,724,929us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> creating new contigBuf object
    @0,725,026us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> Enter(0x10)
    @0,725,132us: [+0 T:0x412eb490 S:0x412ea9ec] OM - Memory_alloc> return (0x61920)
    @0,725,230us: [+1 T:0x412eb490 S:0x412eaa04] OM - Memory__addContigBuf> returning: cb->phys=0x83000000, cb->size=4, cb->virt=0x42ad6000
    @0,725,333us: [+0 T:0x412eb490 S:0x412eaa4c] OM - Memory_getBufferPhysicalAddress> return (0x83000000)
    @0,725,429us: [+2 T:0x412eb490 S:0x412eaa84] ti.sdo.dmai - [Buffer] Set user pointer 0x42ad6000 (physical 0x83000000)
    @0,927,956us: [+2 T:0x412eb490 S:0x412eaaa4] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x42ad6000 has physical address 0x83000000
    @0,957,258us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Opening MSGQ pool...
    @0,958,329us: [+2 T:0x40aeb490 S:0x40aead74] OP - Processor_create_d> Loading ./cs.x64P on DSP (1 args)...
    @1,483,985us: [+2 T:0x41aeb490 S:0x41aeab34] ti.sdo.dmai - [Capture] Video input connected size 1280x720 pitch 1280
    @1,484,783us: [+2 T:0x41aeb490 S:0x41aea9bc] ti.sdo.dmai - [BufTab] Allocating BufTab for 4 buffers
    @1,485,147us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43748000, size=4)
    @1,485,283us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43748000, size=4)
    @1,485,393us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @1,485,507us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x43748000) = 0x82c00000.
    @1,485,624us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> Enter(virtAddr=0x43748000, size=4, physAddr=0x82c00000)
    @1,485,733us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> creating new contigBuf object
    @1,485,831us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> Enter(0x10)
    @1,485,934us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> return (0x62278)
    @1,486,032us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> returning: cb->phys=0x82c00000, cb->size=4, cb->virt=0x43748000
    @1,486,138us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> return (0x82c00000)
    @1,486,239us: [+2 T:0x41aeb490 S:0x41aea9c4] ti.sdo.dmai - [Buffer] Set user pointer 0x43748000 (physical 0x82c00000)
    @1,683,115us: [+2 T:0x41aeb490 S:0x41aea9e4] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x43748000 has physical address 0x82c00000
    @1,683,493us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43b3d000, size=4)
    @1,683,627us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43b3d000, size=4)
    @1,683,735us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @1,683,851us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x43b3d000) = 0x82800000.
    @1,683,967us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> Enter(virtAddr=0x43b3d000, size=4, physAddr=0x82800000)
    @1,684,079us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> creating new contigBuf object
    @1,684,180us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> Enter(0x10)
    @1,684,284us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> return (0x62290)
    @1,684,382us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> returning: cb->phys=0x82800000, cb->size=4, cb->virt=0x43b3d000
    @1,684,486us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> return (0x82800000)
    @1,684,585us: [+2 T:0x41aeb490 S:0x41aea9c4] ti.sdo.dmai - [Buffer] Set user pointer 0x43b3d000 (physical 0x82800000)
    @1,881,202us: [+2 T:0x41aeb490 S:0x41aea9e4] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x43b3d000 has physical address 0x82800000
    @1,881,578us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43f32000, size=4)
    @1,881,712us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43f32000, size=4)
    @1,881,822us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @1,881,938us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x43f32000) = 0x82400000.
    @1,882,057us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> Enter(virtAddr=0x43f32000, size=4, physAddr=0x82400000)
    @1,882,169us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> creating new contigBuf object
    @1,882,266us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> Enter(0x10)
    @1,882,371us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> return (0x622a8)
    @1,882,470us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> returning: cb->phys=0x82400000, cb->size=4, cb->virt=0x43f32000
    @1,882,576us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> return (0x82400000)
    @1,882,675us: [+2 T:0x41aeb490 S:0x41aea9c4] ti.sdo.dmai - [Buffer] Set user pointer 0x43f32000 (physical 0x82400000)
    @2,079,563us: [+2 T:0x41aeb490 S:0x41aea9e4] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x43f32000 has physical address 0x82400000
    @2,079,941us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x44327000, size=4)
    @2,080,076us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x44327000, size=4)
    @2,080,186us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @2,080,298us: [+1 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x44327000) = 0x82000000.
    @2,080,414us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> Enter(virtAddr=0x44327000, size=4, physAddr=0x82000000)
    @2,080,523us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> creating new contigBuf object
    @2,080,618us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> Enter(0x10)
    @2,080,721us: [+0 T:0x41aeb490 S:0x41aea92c] OM - Memory_alloc> return (0x622c0)
    @2,080,819us: [+1 T:0x41aeb490 S:0x41aea944] OM - Memory__addContigBuf> returning: cb->phys=0x82000000, cb->size=4, cb->virt=0x44327000
    @2,080,923us: [+0 T:0x41aeb490 S:0x41aea98c] OM - Memory_getBufferPhysicalAddress> return (0x82000000)
    @2,081,019us: [+2 T:0x41aeb490 S:0x41aea9c4] ti.sdo.dmai - [Buffer] Set user pointer 0x44327000 (physical 0x82000000)
    @2,277,597us: [+2 T:0x41aeb490 S:0x41aea9e4] ti.sdo.dmai - [Dmai] Driver buffer 3 mapped to 0x44327000 has physical address 0x82000000
    @9,167,019us: [+0 T:0x4001ee40 S:0xbebe472c] OG - Global_exit> enter
    @9,167,168us: [+2 T:0x4001ee40 S:0xbebe472c] OG - Global_exit> calling function *0x129f8()...
    @9,167,304us: [+2 T:0x4001ee40 S:0xbebe472c] OG - Global_exit> calling function *0x269a8()...
    @9,167,421us: [+2 T:0x4001ee40 S:0xbebe472c] OG - Global_exit> calling function *0x286c8()...
    @9,167,556us: [+0 T:0x4001ee40 S:0xbebe46fc] OM - Memory_free> Enter(0x61430, 0x18)
    @9,167,681us: [+0 T:0x4001ee40 S:0xbebe46fc] OM - Memory_free> return (0x1)
    @9,167,790us: [+0 T:0x4001ee40 S:0xbebe46fc] OM - Memory_free> Enter(0x61450, 0x18)
    @9,167,900us: [+0 T:0x4001ee40 S:0xbebe46fc] OM - Memory_free> return (0x1)
    @9,168,004us: [+0 T:0x4001ee40 S:0xbebe46fc] OM - Memory_free> Enter(0x61470, 0x18)
    @9,168,112us: [+0 T:0x4001ee40 S:0xbebe46fc] OM - Memory_free> return (0x1)
    @9,168,219us: [+2 T:0x4001ee40 S:0xbebe472c] OG - Global_exit> calling function *0x30d6c()...
    @9,168,328us: [+2 T:0x4001ee40 S:0xbebe472c] OG - Global_exit> calling function *0x2b234()...
    @9,168,440us: [+2 T:0x4001ee40 S:0xbebe472c] OG - Global_exit> calling function *0x2be08()...
    @9,168,546us: [+2 T:0x4001ee40 S:0xbebe472c] OG - Global_exit> calling function *0x2e540()...
    @9,168,654us: [+2 T:0x4001ee40 S:0xbebe472c] OG - Global_exit> calling function *0x2c1bc()...
    @9,168,761us: [+0 T:0x4001ee40 S:0xbebe46fc] OP - doCmd> Enter (cmdId=3, proc=0x0)
              Janet,hopefully you can give me some suggests just the same.Thank you for you answers.
    Best regards
    LiuLiang
  • Janet,
             Can you tell me your telephone and I want to consult you by calling, OK?
             Thanks a lot.
    Best regards
    LiuLiang
  • Janet,
           Thank you for your help. I want to tell you a good news. I get DSKT2 trace finally.
           According your method,my settings in my server's cfg file are here,
    • Set up GT
    var GT = xdc.useModule("ti.sdo.utils.trace.GT");
    var GTINFRA = xdc.useModule("ti.sdo.fc.utils.gtinfra.GTINFRA");
    GTINFRA.runtimeEnv = GTINFRA.NONE;
    GT.MALLOCFXN = "myMalloc";
    GT.PRINTFXN = "printfCaller";
    • Enable trace/debug for individual or all FC modules
    //Switch to debug + trace profile for all FC modules
    //xdc.useModule('ti.sdo.fc.global.Settings').profile = "debug_trace";
    //Switch on trace for some modules specifically.
    //xdc.loadPackage('ti.sdo.fc.rman').profile = "debug_trace";
    //xdc.loadPackage('ti.sdo.fc.edma3').profile = "debug_trace";
    xdc.loadPackage('ti.sdo.fc.dskt2').profile = "debug_trace";
    However,I don't known why the setting
    "xdc.useModule('ti.sdo.fc.global.Settings').profile = "debug_trace";"
    will result in codec engine openning failure.
    Whether or no,I can get more information for the error "Algorithm creation FAILED".
    Best regards
    LiuLiang
  • LiuLiang,
    I'm glad you were able to get DSKT2 trace.  Could you post your server's .cfg file?  Then maybe I could determine why you could not get trace with just the line:
    I was able to get DSKT2 trace for a Codec Engine remote example using the above line in the all.cfg file.
    Also, do you know what your server's stack size is set to?  In your .cfg file, you should have something like:
    var Server = xdc.useModule('ti.sdo.ce.Server');
    Server.threadAttrs.stackSize = 4096;
    Your stack size might be much larger than this.  When I decreased the stack size of my codec engine all_codecs server to a small value (1200), I was able to run the remote app, but when I tried to run the same app with CE_DEBUG=2, it hung.  The printf()'s use a lot of stack space.  I don't know if this is your problem, but it may be worth looking into.
    If you do get DSKT2 trace, you can post the log file.
        Janet
  • Janet,
             Thanks for your patience and answers. But I'm so sorry that replay you so late.
             My server's stack size is set as follow,
    Server.threadAttrs.stackSize = 16384;
            I think it is enough large for the trace. And I don't find the reason all the same.
            By the way,dm6467_h264fhdvenc_01_10_02_05 and dm6467_h264dec_01_10_05_05 is the latest version for TMS320DM6467T?
            Thanks a lot.
    LiuLiang
