DRA725: Repeated power-up/down tests caused register values to change
Part Number: DRA725
Hi team,
Here's an issue from the customer may need your help:
SDK version:tisdk-rootfs-image-dra7xx-evm_vsdk_3_5
1) Switch machine test repeatedly, boot (14 v 1A 30 seconds) shutdown (0 v 10 seconds)
2) Phenomenon of the problem: after the test, the screen does not display, read the relevant register values, found DISPC_GFX_ATTRIBUTES values change
Relating to register:
Register
Normal value
fault value
DISPC_CONFIG1
0x00000C04
NULL
DISPC_CONFIG2
0x00000000
NULL
DISPC_CONFIG3
0x00000000
NULL
DISPC_GLOBAL_ALPHA
0xFFFFFFFF
NULL
DISPC_TRANS_COLOR0
0x00000000
NULL
DISPC_TRANS_COLOR1
0x00000000
NULL
DISPC_TRANS_COLOR2
0x00000000
NULL
DISPC_TRANS_COLOR3
0x00000000
NULL
0x0E000891
0x0E0000A0
DISPC_VID1_ATTRIBUTES
0x02288873
NULL
DISPC_VID2_ATTRIBUTES
0x06008400
NULL
DISPC_VID3_ATTRIBUTES
0x0A288A60
NULL
Could you help check this case? Thanks.
Cherry
