I'm using framework downloaded from TI's gingerbread tree and I'm trying to rebuild the filesystem for emulator. Has anyone tried building it? Can you let me know what the procedure is?
Lavanya
Lavanya
Adding to my previous post, the error i get is
arget Java: framework (out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/classes)
frameworks/base/core/java/android/bluetooth/BluetoothHid.java:76: cannot find symbol
symbol : class IBluetoothHid
private final IBluetoothHid mService;
frameworks/base/core/java/android/server/BluetoothHidService.java:29: cannot find symbol
import android.bluetooth.IBluetoothHid;
frameworks/base/core/java/android/server/BluetoothHidService.java:46: package IBluetoothHid does not exist
public class BluetoothHidService extends IBluetoothHid.Stub {
frameworks/base/core/java/android/bluetooth/BluetoothHid.java:89: package IBluetoothHid does not exist
mService = IBluetoothHid.Stub.asInterface(b);
frameworks/base/core/java/android/server/BluetoothHidService.java:156: cannot find symbol
symbol : variable super
super.finalize();
frameworks/base/core/java/android/server/BluetoothHidService.java:151: method does not override or implement a method from a supertype
@Override
frameworks/base/core/java/android/server/BluetoothHidService.java:391: method does not override or implement a method from a supertype
@Override
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
Note: Some input files use unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
7 errors
make: *** [out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/classes-full-debug.jar] Error 41
I recommend to build with release repo manifest file. Do not build with latest release as some development on tree is still going on.
$ mkdir ~/rowboat-android
$ cd ~/rowboat-android
$ repo init -u git://gitorious.org/rowboat/manifest.git -m TI-Android-GingerBread-2.3-DevKit-1.0.xml
$ repo sync
I hope this code will work fine.
BR,
satish
