I am having trouble compiling dsplink on a windows host. Please note that I am only interested in building the DSP side of dsplink on windows (eventually I want to use CCSv4 to build the dsp side of dsplink applications, and I figure I'll need to point to it.) I am following the instructions in the DSPLink Userguide. Here are the steps I'm taking:
1) I downloaded and installed ActivePerl (64 bit version). NOTE: I had to change the install directory from c:\perl64\bin to c:\perl\bin because apparently the path to perl is hard coded in the dsplink build scripts.
2) I downloaded and installed dsplink 1.65.00.03 porting kit for windows CE and PrOS. Note that our arm will be running linux, but it seems from other posts that I need the wince version to build correctly in windows.
3) I ran the dsplinkenv.bat script.
c:\TiBuild\dsplink_1_65_00_03\dsplink>etc\host\scripts\msdos\dsplinkenv.bat
The environment for DSP/BIOS LINK development has been set:
DSPLINK = c:\TiBuild\dsplink_1_65_00_03\dsplink
PATH += c:\TiBuild\dsplink_1_65_00_03\dsplink\etc\host\scripts\msdos;C:\Perl\bin
4) I configured dsplink:
c:\TiBuild\dsplink_1_65_00_03\dsplink>perl config\bin\dsplinkcfg.pl --platform=O
MAPL1XX --nodsp=1 --dspcfg_0=OMAPL1XXGEMSHMEM --dspos_0=DSPBIOS5XX --comps=ponsl
rmc --gppos=WINCE
Welcome to DSP/BIOS(TM) Link Configuration Utility
!!DSPLINK will be configured for Build OS: WINDOWS!!
!!DSPLINK Directory : c:\TiBuild\dsplink_1_65_00_03\dsplink!!
Chosen configuration is as follows:
Chosen platform:
Identifier: OMAPL1XX
Description: OMAP-L1XX SoC - C674x DSP interfaced directly to ARM9
This platform does not support multi DSP scenario
No of DSPs: 1
Chosen combination for DSP0:
Identifier : DA8XXGEM
DSP Description : On-Chip DSP of Primus SoC
Physical Interface (PHY): OMAPL1XXGEMSHMEM
PHY Description : Shared Memory Physical Interface
Chosen DSP OS for DSP0:
Identifier: DSPBIOS5XX
Description: DSP/BIOS (TM) Version 5.XX
****************** ADVICE !!! ***************************
Binaries for DSP can be generated at preferred location
For example: --dsp0_temp=/home/dsplink/dsp<#>/bin
Chosen GPP OS for selected DSP(s):
Identifier: WINCE
Description: WinCE OS 6.0
Binaries for GPP can be generated at preferred location
For example: --gpp_temp=/home/dsplink/gpp/bin
Chosen Components for DSPLink:
USE_PROC = 1
USE_NOTIFY = 1
USE_POOL = 1
USE_MPCS = 1
USE_MPLIST = 1
USE_RINGIO = 1
USE_MSGQ = 1
USE_CHNL = 1
To enable trace use option: --trace=1
Provided:
Assuming trace disable and continuing...
To enable legacy support use option: --legacy=1
Provided:
Assuming legacy support disable and continuing...
To enable DSP TSK mode select: --DspTskMode=1
Provided:
Assuming SWI mode enabled and continuing...
To enter the priority to which the task priority should be
temporarily raised in MPCS-enter add '--swipriority=..'(Enter priority)
To disable usage of MQT DPC to handle MSGQ messages use option: --skipDPC=1
NOTE: You can use this only for WinCE GPPOS and when RINGIO, CHNL, NOTIFY compon
ents are not selected
Provided:
Assuming default usage of DPC to handle messages from DSP and continuing...
Configuration done successfully!!
Generating CURRENTCFG.MK file...
Generating multimake script...
Generating CFG_system.c File...
Generating GPP RTSC xdc file...
Generating DSP RTSC xdc file...
Please edit the following files for toolchains, kernel sources, etc changes.
GPP side distribution file: $DSPLINK\make\WinCE\omapl1xx_wince6.0.mk
DSP side distribution file: $DSPLINK\make\DspBios\c674x_5.xx_windows.mk
Users consuming DSPLINK as XDC package, Need to do the following.
cd into the $(DSPLINK)\dsp directory and run:
$(XDC_INSTALL_DIR)\xdc clean
$(XDC_INSTALL_DIR)\xdc .interfaces
cd into the $(DSPLINK)\gpp directory and run:
5) tried to make:
cd $DSPLINK/dsp//src
gmake
c:\TiBuild\dsplink_1_65_00_03\dsplink\dsp\src>gmake
[SRC ] ======= DIRS ================== INCLUDE ============
gmake[1]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/base
[BASE ] ======= DIRS ================== INCLUDE ============
gmake[2]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/base
/gen'
[GEN ] ------- DIRS ------------------ INCLUDE ------------
gmake[2]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/base/
gen'
/ips'
[IPS ] ------- DIRS ------------------ INCLUDE ------------
ips'
/hal'
[HAL ] ------- DIRS ------------------ INCLUDE ------------
hal'
/drv'
[DRV ] ------- DIRS ------------------ INCLUDE ------------
drv'
gmake[1]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/base'
gmake[1]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/pool
s'
[POOLS ] ------- DIRS ------------------ INCLUDE ------------
gmake[1]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/pools
gmake[1]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/mpcs
[MPCS ] ------- DIRS ------------------ INCLUDE ------------
gmake[1]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/mpcs'
gmake[1]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/mpli
st'
[MPLIST ] ------- DIRS ------------------ INCLUDE ------------
gmake[1]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/mplis
t'
gmake[1]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/msg'
[MQT ] ------- DIRS ------------------ INCLUDE ------------
gmake[1]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/msg'
gmake[1]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/data
[DATA ] ------- DIRS ------------------ INCLUDE ------------
gmake[1]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/data'
gmake[1]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/noti
fy'
[NOTIFY ] ------- DIRS ------------------ INCLUDE ------------
gmake[1]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/notif
y'
gmake[1]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/ring
io'
[RINGIO ] ------- DIRS ------------------ INCLUDE ------------
gmake[1]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/ringi
o'
[SRC ] ======= DIRS ================== DEBUG ==============
[BASE ] ======= DIRS ================== DEBUG ==============
/gen'
[GEN ] ------- DIRS ------------------ DEBUG --------------
gen'
/ips'
[IPS ] ------- DIRS ------------------ DEBUG --------------
ips'
/hal'
[HAL ] ------- DIRS ------------------ DEBUG --------------
hal'
/drv'
[DRV ] ------- DIRS ------------------ DEBUG --------------
drv'
s'
[POOLS ] ------- DIRS ------------------ DEBUG --------------
[MPCS ] ------- DIRS ------------------ DEBUG --------------
st'
[MPLIST ] ------- DIRS ------------------ DEBUG --------------
t'
[MQT ] ------- DIRS ------------------ DEBUG --------------
[DATA ] ------- DIRS ------------------ DEBUG --------------
fy'
[NOTIFY ] ------- DIRS ------------------ DEBUG --------------
y'
io'
[RINGIO ] ------- DIRS ------------------ DEBUG --------------
o'
[SRC ] ======= DIRS ================== EXPORT =============
[BASE ] ======= DIRS ================== EXPORT =============
/gen'
[GEN ] ------- DIRS ------------------ EXPORT -------------
gen'
/ips'
[IPS ] ------- DIRS ------------------ EXPORT -------------
ips'
/hal'
[HAL ] ------- DIRS ------------------ EXPORT -------------
hal'
/drv'
[DRV ] ------- DIRS ------------------ EXPORT -------------
drv'
s'
[POOLS ] ------- DIRS ------------------ EXPORT -------------
[MPCS ] ------- DIRS ------------------ EXPORT -------------
st'
[MPLIST ] ------- DIRS ------------------ EXPORT -------------
t'
[MQT ] ------- DIRS ------------------ EXPORT -------------
[DATA ] ------- DIRS ------------------ EXPORT -------------
fy'
[NOTIFY ] ------- DIRS ------------------ EXPORT -------------
y'
io'
[RINGIO ] ------- DIRS ------------------ EXPORT -------------
o'
[SRC ] ======= BLDINFO =============== DEBUG ==============
[BASE ] ======= BLDINFO =============== DEBUG ==============
/gen'
[GEN ] ------- BLDINFO --------------- DEBUG --------------
gmake[3]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/base
/gen'
gmake[3]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/base/
gen'
gen'
/ips'
[IPS ] ------- BLDINFO --------------- DEBUG --------------
/ips'
ips'
ips'
/hal'
[HAL ] ------- BLDINFO --------------- DEBUG --------------
/hal'
hal'
hal'
/drv'
[DRV ] ------- BLDINFO --------------- DEBUG --------------
/drv'
drv'
drv'
s'
[POOLS ] ------- BLDINFO --------------- DEBUG --------------
gmake[2]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/pool
s'
gmake[2]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/pools
[MPCS ] ------- BLDINFO --------------- DEBUG --------------
gmake[2]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/mpcs
gmake[2]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/mpcs'
st'
[MPLIST ] ------- BLDINFO --------------- DEBUG --------------
gmake[2]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/mpli
st'
gmake[2]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/mplis
t'
t'
[MQT ] ------- BLDINFO --------------- DEBUG --------------
gmake[2]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/msg'
gmake[2]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/msg'
[DATA ] ------- BLDINFO --------------- DEBUG --------------
gmake[2]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/data
gmake[2]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/data'
fy'
[NOTIFY ] ------- BLDINFO --------------- DEBUG --------------
gmake[2]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/noti
fy'
gmake[2]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/notif
y'
y'
io'
[RINGIO ] ------- BLDINFO --------------- DEBUG --------------
gmake[2]: Entering directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/ring
io'
gmake[2]: Leaving directory `c:/TiBuild/dsplink_1_65_00_03/dsplink/dsp/src/ringi
o'
o'
[SRC ] ======= CLEAN ================= DEBUG ==============
[BASE ] ======= CLEAN ================= DEBUG ==============
/gen'
[GEN ] ------- CLEAN ----------------- DEBUG --------------
gen'
/ips'
[IPS ] ------- CLEAN ----------------- DEBUG --------------
ips'
/hal'
[HAL ] ------- CLEAN ----------------- DEBUG --------------
hal'
/drv'
[DRV ] ------- CLEAN ----------------- DEBUG --------------
drv'
s'
[POOLS ] ------- CLEAN ----------------- DEBUG --------------
[MPCS ] ------- CLEAN ----------------- DEBUG --------------
st'
[MPLIST ] ------- CLEAN ----------------- DEBUG --------------
t'
[MQT ] ------- CLEAN ----------------- DEBUG --------------
[DATA ] ------- CLEAN ----------------- DEBUG --------------
fy'
[NOTIFY ] ------- CLEAN ----------------- DEBUG --------------
y'
io'
[RINGIO ] ------- CLEAN ----------------- DEBUG --------------
o'
[SRC ] ======= INCLUDES ===================================
[BASE ] ======= INCLUDES ===================================
/gen'
[GEN ] ------- INCLUDES -----------------------------------
gen'
/ips'
[IPS ] ------- INCLUDES -----------------------------------
ips'
/hal'
[HAL ] ------- INCLUDES -----------------------------------
hal'
/drv'
[DRV ] ------- INCLUDES -----------------------------------
drv'
s'
[POOLS ] ------- INCLUDES -----------------------------------
[MPCS ] ------- INCLUDES -----------------------------------
st'
[MPLIST ] ------- INCLUDES -----------------------------------
t'
[MQT ] ------- INCLUDES -----------------------------------
[DATA ] ------- INCLUDES -----------------------------------
fy'
[NOTIFY ] ------- INCLUDES -----------------------------------
y'
io'
[RINGIO ] ------- INCLUDES -----------------------------------
o'
[SRC ] ======= OBJECTS =============== DEBUG ==============
[BASE ] ======= OBJECTS =============== DEBUG ==============
/gen'
[GEN ] ------- OBJECT ---------------- DEBUG --------------
/gen'
Compiling failure.c...
The system cannot find the path specified.
gmake[3]: *** [failure.c.deb] Error 1
gen'
gmake[2]: *** [objdeb] Error 512
gen'
gmake[1]: *** [gen.objdeb] Error 2
gmake: *** [base.objdeb] Error 2
What am I missing?
Chris
