Part Number: AM3358
HI:
Recently, I was testing WiFi, but found that 5G AP could not be generated,while 2.4G AP work normal.
and then check the frequency by "iw reg get",It is found that 5g AP cannot be used:
global
country 00: DFS-UNSET
(2402 - 2472 @ 40), (6, 20), (N/A)
(2457 - 2482 @ 20), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (6, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (6, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
So I tried to set up CRDA by "iw reg set US",Unfortunately, this did not work.
Then I checked the corresponding firmware and found that they all exist
ls /lib/firmware/regulatory.db*
/lib/firmware/regulatory.db /lib/firmware/regulatory.db.p7s
But there are errors in the startup log:
dmesg | grep regulatory
[ 2.230878] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.249693] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.258518] cfg80211: failed to load regulatory.db
Could you give me some suggestions?
